09-射频资源管理命令参考
01-射频管理命令
本章节下载 01-射频管理命令  (538.89 KB)
01-射频管理命令
  录
1 射频管理
1.1 射频管理配置命令
1.1.1 a-mpdu
1.1.2 a-msdu
1.1.3 ani
1.1.4 antenna type
1.1.5 auto-channel european-gap enable
1.1.6 beacon-interval
1.1.7 bss-color
1.1.8 channel
1.1.9 channel auto-select
1.1.10 channel band-width
1.1.11 channel-usage measure
1.1.12 channel-usage threshold
1.1.13 client dot11ac-only
1.1.14 client dot11ax-only
1.1.15 client dot11b-forbidden
1.1.16 client dot11n-only
1.1.17 client max-count
1.1.18 continuous-mode
1.1.19 display wlan ap continuous-mode
1.1.20 display wlan ap radio
1.1.21 display wlan ap radio channel
1.1.22 display wlan ap radio type
1.1.23 display wlan statistics ap radio
1.1.24 distance
1.1.25 dl-ofdma
1.1.26 dot11ac mandatory maximum-nss
1.1.27 dot11ac multicast-nss
1.1.28 dot11ac support maximum-nss
1.1.29 dot11ax mandatory maximum-nss
1.1.30 dot11ax multicast-nss
1.1.31 dot11ax support maximum-nss
1.1.32 dot11g protection
1.1.33 dot11n mandatory maximum-mcs
1.1.34 dot11n multicast-mcs
1.1.35 dot11n protection
1.1.36 dot11n support maximum-mcs
1.1.37 dtim
1.1.38 fragment-threshold
1.1.39 green-energy-management
1.1.40 ldpc
1.1.41 long-retry threshold
1.1.42 max-power
1.1.43 mimo
1.1.44 mu-txbf
1.1.45 power-lock
1.1.46 preamble
1.1.47 protection-mode
1.1.48 protection-threshold
1.1.49 radar-detect disable
1.1.50 radio
1.1.51 radio enable
1.1.52 radio scheduled-shutdown time-range
1.1.53 rate
1.1.54 reset wlan channel all
1.1.55 reset wlan statistics ap radio
1.1.56 short-gi
1.1.57 short-retry threshold
1.1.58 stbc
1.1.59 su-txbf
1.1.60 twt negotiate
1.1.61 type
1.1.62 ul-mu-mimo
1.1.63 ul-ofdma
1.1.64 wlan error-frame optimization
1.1.65 wlan radio
1.1.66 wlan radio channel band-width default
1.1.67 wlan radio channel default
1.1.68 wlan raido max-power default
1.1.69 wlan retransmit-frame optimization
1 射频管理
1.1  射频管理配置命令
1.1.1  a-mpdu
a-mpdu enable命令用来开启A-MPDU功能。
a-mpdu disable命令用来关闭A-MPDU功能。
undo a-mpdu命令用来恢复缺省情况。
a-mpdu { disable | enable }
undo a-mpdu
Radio视图下,继承AP组配置。
AP组Radio视图下,A-MPDU功能处于开启状态。
Radio视图
AP组Radio视图
该命令仅对802.11n、802.11ac、802.11gac、802.11ax和802.11gax模式的Radio有效。当Radio模式切换为dot11adot11bdot11g时,将取消该配置。
Radio视图下配置的优先级高于AP组Radio视图下的配置。
# 关闭A-MPDU功能。(Radio视图)
[Sysname] wlan ap ap1 model WAP922
[Sysname-wlan-ap-ap1] radio 1
[Sysname-wlan-ap-ap1-radio-1] type dot11an
[Sysname-wlan-ap-ap1-radio-1] a-mpdu disable
# 关闭A-MPDU功能。(AP组Radio视图)
[Sysname] wlan ap-group apgroup1
[Sysname-wlan-ap-group-apgroup1] ap-model WAP922
[Sysname-wlan-ap-group-apgroup1-ap-model-WAP922] radio 1
[Sysname-wlan-ap-group-apgroup1-ap-model-WAP922-radio-1] type dot11an
[Sysname-wlan-ap-group-apgroup1-ap-model-WAP922-radio-1] a-mpdu disable
1.1.2  a-msdu
a-msdu enable命令用来开启A-MSDU功能。
a-msdu disable命令用来关闭A-MSDU功能。
undo a-msdu命令用来恢复缺省情况。
a-msdu { disable | enable }
undo a-msdu
Radio视图下,继承AP组配置。
AP组Radio视图下,A-MSDU功能处于开启状态。
Radio视图
AP组Radio视图
目前,设备只支持接收A-MSDU报文,不支持发送A-MSDU。
# 关闭A-MSDU功能。(Radio视图)
[Sysname-wlan-ap-ap1-radio-1] a-msdu disable
# 关闭A-MSDU功能。(AP组Radio视图)
[Sysname-wlan-ap-group-apgroup1-ap-model-WAP922-radio-1] a-msdu disable
1.1.3  ani
ani enable命令用来开启ANI(Adaptive Noise Immunity,自动抗干扰)功能。
ani disable命令用来关闭ANI功能。
undo ani命令用来恢复缺省配置。
ani { disable | enable }
undo ani
Radio视图下,继承AP组配置。
AP组Radio视图下,ANI功能处于开启状态。
Radio视图
AP组Radio视图
开启ANI功能后,设备会根据周边信号环境自动调整抗噪等级,来抵消周边射频的干扰。
# 开启ANI功能。(Radio视图)‌
[Sysname-wlan-ap-ap1-radio-1] ani enable
# 开启ANI功能。(AP组Radio视图)
[Sysname-wlan-ap-group-apgroup1-ap-model-WAP922-radio-1] ani enable
1.1.4  antenna type
antenna type命令用来配置射频天线类型。
undo antenna type命令用来恢复缺省情况。
antenna type { antenna-type | custom gain custom-gain }
undo antenna type
Radio视图下,继承AP组配置。
AP组Radio视图下,与AP型号有关,请以设备的实际情况为准。
Radio视图
AP组Radio视图
antenna-type:射频天线类型,为1~10个字符的字符串,具体支持的射频天线类型与AP型号有关,请以设备的实际情况为准。
custom gain custom-gain:第三方射频天线的增益。其中custom-gain为增益值,取值范围为0~20,单位为dBi。本参数的支持情况与AP型号有关,请以设备的实际情况为准。
更换AP的天线后,需要配置本命令进行天线增益适配。
本命令支持配置的射频天线类型为H3C天线和第三方天线。
·     当使用H3C天线时:
用户必须保证天线类型为所使用的射频天线的真实类型。
·     当使用第三方天线时:
用户必须保证指定的天线增益值为所使用的第三方天线的真实增益。
若在AP组Radio视图下配置第三方天线的增益值,请确保该AP组下同一型号的所有AP上安装的天线的增益值相同。
# 配置射频天线类型为internal。(Radio视图)
[Sysname-wlan-ap-ap1-radio-1] antenna type internal
# 配置射频天线类型为internal。(AP组Radio视图)
[Sysname-wlan-ap-group-apgroup1-ap-model-WAP922-radio-1] antenna type internal
auto-channel european-gap enable命令用来配置2.4GHz射频在进行自动信道选择时使用欧洲信道间隔。
undo auto-channel european-gap enable命令用来恢复缺省情况。
2.4GHz射频在进行自动信道选择时使用非欧洲信道间隔。
全局配置视图
在WLAN标准协议里,2.4GHz频段被划分为13个相互交叠的信道。AP在进行自动信道选择时,将按固定信道间隔选择信道。信道间隔分为以下两种:
·     欧洲信道间隔:信道间隔为6,AP按此信道间隔进行自动选择的信道为1、7、13信道。
·     非欧洲信道间隔:信道间隔为5,AP按此信道间隔进行自动选择的信道为1、6、11信道。
# 配置2.4GHz射频在进行自动信道选择时使用欧洲信道间隔。
[Sysname] wlan global-configuration
[Sysname-wlan-global-configuration] auto-channel european-gap enable
·     channel
beacon-interval命令用来配置发送Beacon帧的时间间隔。
undo beacon-interval命令用来恢复缺省情况。
beacon-interval interval
Radio视图下,继承AP组配置
AP组Radio视图下,发送Beacon帧的时间间隔为100TU。
Radio视图
AP组Radio视图
interval:发送Beacon帧的时间间隔,取值范围为32~8191,单位为TU(Time Unit,1TU=1024微秒)。
# 配置发送Beacon帧的时间间隔为1000TU。(Radio视图)
[Sysname-wlan-ap-ap1-radio-1] beacon-interval 1000
# 配置发送Beacon帧的时间间隔为1000TU。(AP组Radio视图)
[Sysname-wlan-ap-group-apgroup1-ap-model-WAP922-radio-1] beacon-interval 1000
1.1.7  bss-color
bss-color enable命令用来开启BSS Color功能。
bss-color disable命令用来关闭BSS Color功能。
undo bss-color命令用来恢复缺省情况。
bss-color { disable | enable }
undo bss-color
Radio视图下,继承AP组配置。
AP组Radio视图下,BSS Color功能处于关闭状态。
Radio视图
AP组Radio视图
该命令仅对802.11ax和802.11gax模式的Radio有效。当Radio模式切换为dot11adot11bdot11gdot11ndot11acdot11gac时,将取消该配置。
BSS Color(BSS color bit,BSS的颜色比特)功能是指在AP发送报文前,会通过接收到的数据帧中携带的BSS Color判断接收到的数据报文是否是自己发送的,如果是自身发送的,则直接进行退避。否则,不认为形成干扰,直接发送报文。
在AP密集部署的场景下开启本功能后,AP可以快速判断接收到的数据报文是否来自自己,并及时进行退避,提高系统级性能和信道的有效使用率。
# 开启BSS Color功能。(Radio视图)
[Sysname-wlan-ap-ap1-radio-1] type dot11ax
[Sysname-wlan-ap-ap1-radio-1] bss-color enable
# 开启BSS Color功能。(AP组Radio视图)
[Sysname-wlan-ap-group-apgroup1]ap-model WAP922
[Sysname-wlan-ap-group-apgroup1-ap-model-WAP922-radio-1] type dot11ax
[Sysname-wlan-ap-group-apgroup1-ap-model-WAP922-radio-1] bss-color enable
·     type dot11ax
1.1.8  channel
channel命令用来配置射频工作信道。
undo channel命令用来恢复缺省情况。
channel { channel-number | auto { lock | unlock } }
undo channel [ auto ]
Radio视图下,继承AP组配置。
AP组Radio视图下,工作信道为auto unlock模式。
Radio视图
AP组Radio视图
channel-number:手动配置的射频工作信道。取值范围由区域码和射频模式决定。
auto lock:自动选择信道并加锁模式,由设备根据实际环境自动选择最优信道,并将该信道锁定。
auto unlock:自动选择信道并解锁模式。由设备根据实际环境自动选择最优信道,并将该信道设置为无锁模式。
在手工指定工作信道模式时,如果在当前工作信道上发现雷达信号,则AP会立即将工作信道调整至其他信道。AP会在30分钟后将信道切换回手工指定的信道,并静默一段时间,如果在静默时间内没有发现雷达信号,则开始使用该信道;如果发现雷达信号,则再次切换信道。
在自动选择信道模式上,无论信道加锁与否,如果在当前工作信道上发现雷达信号,则AP会立即将工作信道调整至其他信道。
当手动指定工作信道为36~64信道时,5.1GHz频段仅限室内使用。如需室外使用,针对以下地区有使用条件:
·     5150~5250Hz频段室外设备:
¡     中国:不能使用
¡     欧盟:不能使用
¡     美国:可以使用,但条件苛刻。需要保证仰角30度以上的辐射功率小于125mW,且单次部署数量小于1000台。若单次部署数量大于1000台,需要联系FCC(Federal Communications Commission,美国联邦通信委员会),并采取降低总输出功率、减小数量等措施减少向上辐射。
¡     加拿大:不能使用
·     5250~5350Hz频段室外设备:
¡     中国:不能使用
¡     欧盟:不能使用
¡     美国:可以使用(with DFS(Depth First Search,深度优先算法))
¡     加拿大:可以使用(with DFS(Depth First Search,深度优先算法))
# 配置射频工作信道号为149。(Radio视图)
[Sysname-wlan-ap-ap1-radio-1] channel 149
# 配置射频工作信道号为149。(AP组Radio视图)
[Sysname-wlan-ap-group-apgroup1-ap-model-WAP922-radio-1] channel 149
channel auto-select命令用来添加信道选择黑名单或白名单表项。
undo channel auto-select命令用来删除黑名单或白名单表项。
channel auto-select { blacklist | whitelist } channel-number
undo channel auto-select { blacklist | whitelist } { all | channel-number }
Radio视图下,继承AP组配置。
AP组Radio视图下,不存在信道选择黑名单或白名单表项。
Radio视图
AP组Radio视图
blacklist:添加信道选择黑名单表项,AP进行自动信道选择时,不会选择存在于黑名单中的信道。
whitelist:添加信道选择白名单表项,AP进行自动信道选择时,仅选择存在于白名单中的信道。
channel-number:黑白名单中的信道。取值范围由区域码和射频模式决定。
all:黑白名单中的所有信道。
同一个AP射频上仅允许存在信道选择黑名单或信道选择白名单,二者不能同时存在。
仅在AP自动信道选择处于开启的情况下,才会使用配置的黑白名单。
手动配置信道带宽模式为40MHz及以上时,若白名单中不存在可以组成同等带宽的信道,当射频检测到雷达后选择使用白名单中的信道工作,AP会因配置的带宽与实际工作带宽不同而被强制下线。因此配置白名单时,必须保证白名单中所有信道可以提供匹配的带宽。
# 将信道149,153,157添加到信道选择白名单。(Radio视图)
[Sysname-wlan-ap-ap1-radio-1] channel auto-select whitelist 149 153 157
# 将信道149,153,157添加到信道选择白名单。(AP组Radio视图)
[Sysname-wlan-ap-group-apgroup1-ap-model-WAP922-radio-1] channel auto-select whitelist 149 153 157
·     channel
channel band-width命令用来配置带宽模式。
undo channel band-width命令用来恢复缺省情况。
channel band-width { 20 | 40 [ auto-switch ] | 80 | { 160 | dual-80 } [ secondary-channel channel-number ] }
Radio视图下,继承AP组配置。
AP组Radio视图下,802.11ax射频模式的带宽模式为80MHz,802.11gax射频模式的带宽模式为20MHz,802.11ac射频模式的带宽模式为80MHz,802.11gac射频模式的带宽模式为20MHz,802.11an射频模式的带宽模式为40MHz,802.11gn射频模式的带宽模式为20MHz。
Radio视图
AP组Radio视图
20:将带宽模式设置成20MHz。
40:将带宽模式设置成40MHz。
80:将带宽模式设置成80MHz。
auto-switch:允许在20MHz和40MHz之间自动切换。仅当Radio模式为dot11gn、dot11gac和dot11gax模式时,支持配置本参数。
160:将带宽模式设置成160MHz。本参数的支持情况与AP的型号有关,请以设备的实际情况为准。
dual-80:将带宽模式设置成(80+80)MHz。本参数的支持情况与AP的型号有关,请以设备的实际情况为准。
secondary-channel channel-number:手工配置160/(80+80)MHz带宽模式下的辅信道。本参数的支持情况与AP的型号有关,请以设备的实际情况为准。
该命令仅对802.11n、802.11ac、802.11gac、802.11ax和802.11gax类型的Radio有效。当Radio模式切换时,带宽恢复切换模式下的缺省值。
·     在指定带宽为40MHz情况下,如果找到两条可以绑定到一起的相邻信道,那么使用40MHz带宽;如果找不到可以绑定的相邻信道,那么实际只能使用20MHz带宽。
·     在指定带宽为80MHz情况下,如果找到一组可以绑定为80MHz的相邻信道,那么使用80MHz带宽;如果找不到可以绑定为80MHz的一组信道,但可以找到两条可以绑定为40MHz带宽的信道,那么使用40MHz带宽;如果找不到可以绑定的信道,那么实际只能使用20MHz带宽。
·     在指定带宽为160MHz情况下,如果找到一组可以绑定为160MHz的相邻信道,那么使用160MHz带宽;如果找不到可以绑定为160MHz的一组信道,但可以找到一组绑定为80MHz的相邻信道,那么使用80MHz带宽;如果找不到可以绑定为80MHz的一组信道,但可以找到一组绑定为40MHz带宽的信道,那么使用40MHz带宽;如果找不到可以绑定的信道,那么实际只能使用20MHz带宽。
·     在指定带宽为(80+80)MHz情况下,如果找到一组可以绑定为160MHz的相邻信道,那么使用160MHz带宽;如果找不到可以绑定为160MHz的一组信道,但可以找到两组虽不相邻,但每组都可以绑定为80MHz的相邻信道,那么使用(80+80)MHz带宽;如果找不到可以绑定为(80+80)MHz的一组信道,但可以找到一组绑定为80MHz的相邻信道,那么使用80MHz带宽;如果找不到可以绑定为80MHz的一组信道,但可以找到一组绑定为40MHz带宽的信道,那么使用40MHz带宽;如果找不到可以绑定的信道,那么实际只能使用20MHz带宽。
根据协议规定,射频实际工作频宽一分为二,其中第一个频宽所处位置由主信道决定,第二个频宽所处位置由辅信道决定。主信道发送数据帧和所有的控制、管理帧;辅信道与主信道捆绑,仅发送数据帧。当使用channel命令配置了主信道,且射频的实际工作频宽为160/(80+80)MHz时,可使用secondary-channel参数指定第二个80M频宽的位置。其他情况下辅信道均由系统自动选择。
如果带宽配置继承AP组,则辅信道也继承AP组,反之辅信道也不继承AP组。
# 配置Radio 1的带宽为40MHz。(Radio视图)
[Sysname-wlan-ap-ap1-radio-1] channel band-width 40
# 配置Radio 1的带宽为40MHz。(AP组Radio视图)
[Sysname-wlan-ap-group-apgroup1-ap-model-WAP922-radio-1] channel band-width 40
·     channel
channel-usage measure命令用来测量信道使用率。
Radio视图
测量信道使用率时,AP获取当前射频支持的信道列表,然后轮询信道列表中的信道进行测量,在每个信道停留1秒的测量时间。所有信道测量结束后,显示测量结果。
# 配置ap1的Radio 2对信道使用率进行测量。
[Sysname-wlan-ap-ap1] radio 2
[Sysname-wlan-ap-ap1-radio-2] channel-usage measure
Please wait......Done.
Channel  Usage
1        63%
2        61%
3        55%
4        45%
5        64%
6        74%
7        66%
8        48%
9        35%
10       38%
11       54%
12       30%
13       72%
channel-usage threshold命令用来配置信道使用率告警门限值。
undo channel-usage threshold命令用来恢复缺省情况。
channel-usage threshold threshold
Radio视图下,继承AP组配置。
AP组Radio视图下,信道使用率告警门限值为90%。
Radio视图
AP组Radio视图
threshold:信道使用率告警门限的百分比数值,取值范围为5~100。
当信道使用率超过配置的告警门限值后,设备会输出告警日志信息。
# 配置信道使用率告警门限值为20%。(Radio视图)
[Sysname-wlan-ap-ap1-radio-1] channel-usage threshold 20
# 配置信道使用率告警门限值为20%。(AP组Radio视图)
[Sysname] wlan ap-group 1
[Sysname-wlan-ap-group-1] ap-model
[Sysname-wlan-ap-group-1-ap-model-] radio 1
[Sysname-wlan-ap-group-1-ap-model--radio-1] channel-usage threshold 20
client dot11ac-only enable命令用来开启仅允许802.11ac和802.11ax客户端接入功能。
client dot11ac-only disable命令用来关闭仅允许802.11ac和802.11ax客户端接入功能。
undo client dot11ac-only命令用来恢复缺省情况。
client dot11ac-only { disable | enable }
Radio视图下,继承AP组配置。
AP组Radio视图下,仅允许802.11ac和802.11ax客户端接入功能处于关闭状态。
Radio视图
AP组Radio视图
本配置仅对802.11ac、802.11gac、802.11ax和802.11gax模式的Radio有效。当Radio模式切换时,将取消该配置。
开启仅允许802.11ac客户端接入功能后,只有802.11ac和802.11ax的客户端才能接入此Radio,已经关联到该射频但不支持802.11ac的客户端将下线。
# 开启仅允许802.11ac和802.11ax用户接入功能。(Radio视图)
<System> system-view
[System] wlan ap ap1 model WAP922
[System-wlan-ap-ap1] radio 1
[System-wlan-ap-ap1-radio-1] type dot11ac
[System-wlan-ap-ap1-radio-1] client dot11ac-only enable
# 在AP组中,开启仅允许802.11ac和802.11ax用户接入功能。(AP组Radio视图)
[Sysname-wlan-ap-group-1] ap-model WAP922
[Sysname-wlan-ap-group-1-ap-model-WAP922] radio 1
[Sysname-wlan-ap-group-1-ap-model-WAP922-radio-1] client dot11ac-only enable
·     dot11ac mandatory maximum-nss
client dot11ax-only enable命令用来开启仅允许802.11ax客户端接入功能。
client dot11ax-only disable命令用来关闭仅允许802.11ax客户端接入功能。
undo client dot11ax-only命令用来恢复缺省情况。
client dot11ax-only { disable | enable }
Radio视图下,继承AP组配置。
AP组Radio视图下,仅允许802.11ax客户端接入功能处于关闭状态。
Radio视图
AP组Radio视图
Radio接口视图
开启仅允许802.11ax客户端接入功能后,只有802.11ax的客户端才能接入此Radio,已经关联到该射频但不支持802.11ax的客户端将下线。
本配置仅对802.11ax和802.11gax模式的Radio有效。当Radio模式切换时,将取消该配置。
# 开启仅允许802.11ax用户接入功能。(Radio视图)
[System-wlan-ap-ap1-radio-1] type dot11ax
[System-wlan-ap-ap1-radio-1] client dot11ax-only enable
# 在AP组中,开启仅允许802.11ax用户接入功能。(AP组Radio视图)
[Sysname-wlan-ap-group-1-ap-model-WAP922-radio-1] client dot11ax-only enable
[Sysname] interface wlan-radio 1/0/1
[Sysname-wlan-radio-1/0/1] client dot11ax-only enable
·     dot11ax mandatory maximum-nss
client dot11b-forbidden enable命令用来禁止802.11b客户端接入。
client dot11b-forbidden disable命令用来允许802.11b客户端接入。
undo client dot11b-forbidden命令用来恢复缺省情况。
client dot11b-forbidden { disable | enable }
Radio视图下,继承AP组配置。
AP组Radio视图下,允许802.11b客户端接入。
Radio视图
AP组Radio视图
只有在射频模式为802.11b、802.11g、802.11gac、802.11gn时才能配置本命令。
为了提高网络传输速率并隔离低速率的802.11b客户端的影响,AP可以开启禁止802.11b客户端接入功能。
# 配置禁止802.11b客户端接入。(Radio视图)
[Sysname-wlan-ap-ap1-radio-2] client dot11b-forbidden enable
# 配置禁止802.11b客户端接入。(AP组Radio视图)
[Sysname-wlan-ap-group-apgroup1-model-WAP922] radio 2
[Sysname-wlan-ap-group-apgroup1-model-WAP922-radio-2] client dot11b-forbidden enable
client dot11n-only enable命令用来开启仅允许802.11n、802.11ac和802.11ax客户端接入功能。
client dot11n-only disable命令用来关闭仅允许802.11n、802.11ac和802.11ax客户端接入功能。
undo client dot11n-only命令用来恢复缺省情况。
client dot11n-only { disable | enable }
Radio视图下,继承AP组配置。
AP组Radio视图下,仅允许802.11n、802.11ac和802.11ax客户端接入功能处于关闭状态。
Radio视图
AP组Radio视图
开启仅允许802.11n、802.11ac和802.11ax客户端接入功能后,只有802.11n、和802.11ax802.11ac的客户端才能接入此Radio,已经关联到该射频但不支持802.11n的客户端将下线。
本配置仅对802.11n、802.11ac、802.11gac、802.11ax和802.11gax模式的Radio有效。当Radio模式切换为dot11adot11bdot11g时,将取消该配置。
# 开启仅允许802.11n、802.11ac和802.11ax客户端接入功能。(Radio视图)
[Sysname-wlan-ap-ap1-radio-1] client dot11n-only enable
# 开启仅允许802.11n、802.11ac和802.11ax客户端接入功能。(AP组Radio视图)
[Sysname-wlan-ap-group-apgroup1-ap-model-WAP922-radio-1] client dot11n-only enable
client max-count命令用来配置射频允许关联的最大客户端数目。
undo client max-count命令用来恢复缺省情况。
client max-count max-number
Radio视图下,继承AP组配置。
AP组Radio视图下,不限制射频允许关联的最大客户端数目。
Radio视图
AP组Radio视图
max-number:射频所允许关联的最大客户端数目,取值范围与AP设备的型号有关,请以设备的实际情况为准。
射频上关联的客户端数达到允许关联的最大客户端数目后,将不再接受新的客户端接入且SSID会自动隐藏。
射频上允许关联的最大客户端数目会在AC和AP上分别限制,因此当同一个射频同时绑定客户端关联位置在AC和AP的无线服务模板时,设备上允许关联的最大客户端数目是配置的允许关联最大客户端数目的2倍。该场景下,若对上线客户端数量有要求,请根据预计上线的客户端数量来配置最大客户端数目。
# 配置射频允许关联的最大客户端数目为38。(Radio视图)
[Sysname-wlan-ap-ap1-radio-1] client max-count 38
# 配置射频允许关联的最大客户端数目为38。(AP组Radio视图)
[Sysname-wlan-ap-group-apgroup1-ap-model-WAP922-radio-1] client max-count 38
continuous-mode命令用来开启射频的常发模式功能。
undo continuous-mode命令用来恢复缺省情况。
continuous-mode { mcs mcs-index | nss nss-index vht-mcs vhtmcs-index | rate rate-value }
常发模式功能处于关闭状态。
Radio视图
mcs mcs-index:指定常发模式使用的MCS索引值,取值范围为0~76。
nss nss-index:指定常发模式使用的NSS(Number of Spatial Streams,空间流数)索引值,取值范围为1~8。
vht-mcs vhtmcs-index:指定常发模式使用的VHT-MCS索引值,取值范围为0~9。
rate rate-value:指定常发模式使用的速率,单位为Mbps。
常发模式是指根据指定速率不断发数据包来测试网络环境,属于测试专用功能,一旦启用会对正常业务造成影响,所以不推荐用户自行配置。开启常发模式后,除调整发射功率外,建议不要进行其它操作。
当射频模式是802.11a、802.11b或802.11g时,使用continuous-mode rate rate-value设置发射速率。
当射频模式是802.11n时,可以使用continuous-mode rate rate-value直接设置发射速率,也可以使用continuous-mode mcs mcs-index,通过选择MCS索引值的方式指定射频速率。
当射频模式是802.11ac和802.11gac时,可以使用continuous-mode rate rate-value直接设置发射速率,也可以使用continuous-mode mcs mcs-index,通过选择MCS索引值的方式指定射频速率,还可以使用continuous-mode nss nss-index vht-mcs vhtmcs-index,通过选择NSS和MCS索引值的方式指定射频速率。
# 开启射频的常发模式功能,使用的速率为6Mbps。
[Sysname-wlan-ap-ap1-radio-1] continuous-mode rate 6
·     display wlan ap continonus-mode
display wlan ap continuous-mode命令用来显示AP射频的常发模式。
display wlan ap { all | name ap-name } continuous-mode
all:显示所有AP射频的常发模式。
name ap-name:显示指定AP射频的常发模式,ap-name表示AP的名称,为1~64个字符的字符串,可以包含字母、数字、下划线、“.”、“[”、“]”、“/”及“-”,区分大小写。
# 显示ap1上Radio的常发模式。
<Sysname> display wlan ap name ap1 continuous-mode
AP name    Radio ID    Radio type      Rate    Mcs-Index   Nss   Vht-mcs
ap1        1           802.11a         6       N/A         N/A   N/A
表1-1 display wlan ap continuous-mode命令显示信息描述表
AP name
AP名称
Radio ID
射频ID
Radio type
射频类型
Rate
常发模式使用的速率
Mcs-Index
常发模式使用的MCS索引值
Nss
常发模式使用的NSS索引值
Vht-mcs
常发模式使用的VHT-MCS索引值
·     continuous-mode
display wlan ap radio命令用来显示AP的射频信息。
display wlan ap { all | name ap-name } radio [ frequency-band { 5 | 2.4 } ]
all:显示所有AP的射频信息。
name ap-name:显示指定AP的射频信息。ap-name表示AP的名称,为1~64个字符的字符串,可以包含字母、数字、下划线、“.”、“[”、“]”、“/”及“-”,区分大小写。
radio:显示AP上射频的信息。
frequency-band:显示工作在指定频段的射频的信息。
5:显示工作在5GHz频段的射频的信息。
2.4:显示工作在2.4GHz频段的射频的信息。
# 显示所有AP上的射频信息。
<Sysname> display wlan ap all radio
Total number of APs: 1
Total number of connected APs: 1
Total number of connected manual APs: 1
Total number of connected auto APs: 0
Total number of connected common APs: 1
Total number of connected WTUs: 0
Total number of inside APs: 0
Maximum supported APs: 6144
Remaining APs: 6144
Total AP licenses: 128
local AP licenses: 0
Server AP licenses: 0
Remaining local AP licenses: 127
Sync AP licenses: 0
AP name                  RID State Channel          BW    Usage TxPower Clients
                                                    (MHz) (%)   (dBm)
ap1                      1   Up    149(auto)        40    20     5      0
ap1                      2   Up    11(auto)         20    20     10     0
# 显示ap1上工作在2.4GHz频段的射频信息。
<Sysname> display wlan ap name ap1 radio frequency-band 2.4
                                                    (MHz) (%)   (dBm)
ap1                      2   Up    11(auto)         20    20     15     0
表1-2 display wlan ap all radio命令显示信息描述表
Total number of APs
AP的数量
处于连接状态的AP的数量
处于连接状态的手工AP数量
处于连接状态的自动AP的数量
处于连接状态的普通AP的总数量
处于连接状态的WTU总数量
处于连接状态的内部AP数量,内部AP为Anchor AP作为AC设备时自动创建的名称为本机MAC地址,序列号为本机序列号的手工AP
AC上最大AP容量,包括Fit AP和WTU,WT不计入AP容量
Remaining APs
剩余AP容量,即最大AP容量减去处于连接状态的Fit AP和WTU数量
Total AP licenses
AP license总数量,包括普通AP License数量,以及WTU License按照比例转换成普通AP License的数量,每个WTU License转换成0.25个普通AP License
local AP licenses
AC本地License数量
Server AP licenses
AC从服务器申请的License数量
剩余AP license数量,不同的AP类型所占用的AP License数量不同,例如WAP922占用1个AP License,WT1020不占用AP License,WTU420H占用0.25个AP License
Sync AP licenses
共享的AP License数量
AP name
AP名称
RadioID
射频的ID号
射频状态:
·     Up:开启状态
·     Down:关闭状态
Channel
射频使用的工作信道
BW(MHz)
射频运行带宽所支持的最大带宽
Usage
信道利用率
TxPower (dBm)
射频的发送功率(缺省为最大功率)
Clients
在线客户端数量
display wlan ap radio channel命令用来显示AP的射频信道信息。
display wlan ap { all | name ap-name } radio channel
all:显示所有AP的射频信道信息。
name ap-name:显示指定AP的射频信道信息。ap-name表示AP的名称,为1~64个字符的字符串,可以包含字母、数字、下划线、“.”、“[”、“]”、“/”及“-”,区分大小写。
# 显示ap3上的射频信道信息。
<Sysname> display wlan ap name ap3 radio channel
AP name                  RID Channel          Band-width           CenterFreq
                                              (MHz)
ap3                       1  36(auto)         20/40/80/160/(80+80) 42/58
ap3                       2  149              20/40/80             155
ap3                       3  11(auto)         20                   0
表1-3 display wlan ap name radio channel命令显示信息描述表
AP name
AP名称
RID
射频的ID号
Channel
射频使用的工作信道
Band-width (MHz)
支持的信道带宽
CenterFreq
带宽中心频点,仅当支持的信道带宽达到/超过80MHz时才会显示中心频点。当支持的信道带宽达到160/(80+80)MHz带宽时,将显示主信道和辅信道的中心频点
display wlan ap radio type命令用来显示AP射频的类型。
display wlan ap { all | name ap-name } radio type
all:显示所有AP射频的类型。
name ap-name:显示指定AP射频的类型。ap-name表示AP的名称,为1~64个字符的字符串,可以包含字母、数字、下划线、“[”、“]”、“/”及“-”,区分大小写。
# 显示ap1上射频的类型。
<Sysname> display wlan ap name ap1 radio type
AP name                  RID  AP state Radio state  Radio type
ap1                      1    Up        Up           802.11n(5GHz)
ap1                      2    Up        Down         802.11n(2.4GHz)
表1-4 display wlan ap radio type命令显示信息描述表
AP name
AP名称
RID
射频的ID号
AP state
AP状态:
·     Up:AP与AC成功建立CAPWAP隧道
·     Down:AP未与AC建立CAPWAP隧道
Radio state
·     射频状态:
·     Up:射频处于开启状态
·     Down:射频处于关闭状态
Radio type
射频类型
display wlan statistics ap radio命令用来显示射频统计信息。
display wlan statistics ap { all | name ap-name } radio
all:显示所有AP的射频统计信息。
ap ap-name:显示指定AP的射频统计信息。ap-name表示AP的名称,为1~64个字符的字符串,区分大小写。
# 显示ap1的射频统计信息。
<Sysname> display wlan statistics ap name ap1 radio
                                 Radio statistics
 AP name:ap1                                   Radio ID:1
Transmitted frame statistics:
   Total frames                              :836532
   Total frame bytes                         :214040681
   Unicast frames                            :4
   Unicast frame bytes                       :900
   Broadcast/Multicast frames                :836528
   Broadcast/Multicast frame bytes           :214039781
   Other frames                              :0
   Other frame bytes                         :0
   Discarded frames                          :0
   Failed RTS frames                         :0
   Retransmissions                           :6
   Successful RTS frames                     :0
   Retransmitted frames                      :3
   No-ACK frames                             :1555
   Authentication frames                     :1
   Association frames                        :1
   Packet statistics by size:
     Smaller than or equal to 128            :747
     Between 128 and 512 (inclusive)         :85983
     Between 512 and 1024 (inclusive)        :0
     Larger than 1024                        :0
   Packet statistics by rate:
       1 Mbps  :0            2 Mbps  :0
     5.5 Mbps  :0            6 Mbps  :0
       9 Mbps  :0           11 Mbps  :0
      12 Mbps  :0           18 Mbps  :0
      24 Mbps  :880         36 Mbps  :0
      48 Mbps  :0           54 Mbps  :0
  Packet statistics based on data rate:
    6.5 Mbps  :0             7.2 Mbps  :0
     13 Mbps  :0            13.5 Mbps  :0
   14.4 Mbps  :0              15 Mbps  :0
   19.5 Mbps  :0            21.7 Mbps  :0
     26 Mbps  :0              27 Mbps  :0
   28.9 Mbps  :0            29.3 Mbps  :0
     30 Mbps  :0            32.5 Mbps  :0
     39 Mbps  :0            40.5 Mbps  :0
   43.3 Mbps  :0              45 Mbps  :0
     52 Mbps  :0              54 Mbps  :0
   57.8 Mbps  :0            58.5 Mbps  :0
     60 Mbps  :0              65 Mbps  :0
   72.2 Mbps  :0              78 Mbps  :1
     81 Mbps  :0            86.7 Mbps  :0
   87.8 Mbps  :0              90 Mbps  :0
   97.5 Mbps  :0             104 Mbps  :3
    108 Mbps  :0           115.6 Mbps  :0
    117 Mbps  :0             120 Mbps  :0
  121.5 Mbps  :0             130 Mbps  :0
    135 Mbps  :0           144.4 Mbps  :0
    150 Mbps  :0             156 Mbps  :0
    162 Mbps  :0           173.3 Mbps  :0
  175.5 Mbps  :0             180 Mbps  :0
    195 Mbps  :0             200 Mbps  :0
    216 Mbps  :0           216.7 Mbps  :0
    234 Mbps  :0             240 Mbps  :0
    243 Mbps  :0             260 Mbps  :0
  263.3 Mbps  :0             270 Mbps  :0
  288.9 Mbps  :0           292.5 Mbps  :0
    300 Mbps  :0             324 Mbps  :0
    325 Mbps  :0             351 Mbps  :0
    360 Mbps  :0           364.5 Mbps  :0
    390 Mbps  :0             400 Mbps  :0
    405 Mbps  :0           433.3 Mbps  :0
    450 Mbps  :0            468 Mbps  :0
    486 Mbps  :0            520 Mbps  :0
  526.5 Mbps  :0            540 Mbps  :0
    585 Mbps  :0            600 Mbps  :0
    650 Mbps  :0            702 Mbps  :0
    780 Mbps  :0          866.7 Mbps  :0
  877.5 Mbps  :0            975 Mbps  :0
   1053 Mbps  :0           1170 Mbps  :0
   1300 Mbps  :0
Received frame statistics:
   Total frames                         :420815
   Total frame bytes                    :24112652
   Unicast frames                       :585
   Unicast frame bytes                  :15357
   Broadcast/Multicast frames           :420230
   Broadcast/Multicast frame bytes      :24097295
   Fragmented frames                    :0
   Duplicate frames                     :0
   FCS failures                         :474471639
   Decryption errors                    :0
     Smaller than or equal to 128            :420759
     Between 128 and 512 (inclusive)         :54
     Larger than 1024                        :0
       6 Mbps  :420115       9 Mbps  :0
      24 Mbps  :0           36 Mbps  :1
      48 Mbps  :0           54 Mbps  :2
      52 Mbps  :1              54 Mbps  :2
    57.8 Mbps  :0            58.5 Mbps  :17
      60 Mbps  :0              65 Mbps  :10
    72.2 Mbps  :0              78 Mbps  :48
      81 Mbps  :0            86.7 Mbps  :70
    97.5 Mbps  :0             104 Mbps  :87
     108 Mbps  :0           115.6 Mbps  :170
     117 Mbps  :130           120 Mbps  :0
   121.5 Mbps  :0             130 Mbps  :140
     135 Mbps  :0           144.4 Mbps  :22
    1300 Mbps  :0
                                 Radio statistics
 AP name:ap1                                   Radio ID:2
   Total frames                              :13134
   Total frame bytes                         :3259997
   Unicast frames                            :11
   Unicast frame bytes                       :3518
   Broadcast/Multicast frames                :13123
   Broadcast/Multicast frame bytes           :3256479
   Other frames                              :0
   Discarded frames                          :0
   Retransmissions                           :58
   Retransmitted frames                      :11
   No-ACK frames                             :7541
   Authentication frames                     :14
   Association frames                        :8
     Smaller than or equal to 128            :1020
     Between 128 and 512 (inclusive)         :11386
     Larger than 1024                        :0
       1 Mbps  :0            2 Mbps  :0
       9 Mbps  :0           11 Mbps  :1121
      24 Mbps  :0           36 Mbps  :0
    6.5 Mbps  :3             7.2 Mbps  :0
     13 Mbps  :1            13.5 Mbps  :0
   19.5 Mbps  :4            21.7 Mbps  :0
     39 Mbps  :1            40.5 Mbps  :0
   72.2 Mbps  :0              78 Mbps  :0
   97.5 Mbps  :0             104 Mbps  :1
    117 Mbps  :1             120 Mbps  :0
   1300 Mbps  :0
   Total frames                         :32156
   Total frame bytes                    :3076192
   Unicast frames                       :1613
   Unicast frame bytes                  :102957
   Broadcast/Multicast frames           :30543
   Broadcast/Multicast frame bytes      :2973235
   Duplicate frames                     :2
   FCS failures                         :9978084
     Smaller than or equal to 128            :25327
     Between 128 and 512 (inclusive)         :6097
     Larger than 1024                        :0
      1 Mbps  :28718        2 Mbps  :1895
    5.5 Mbps  :284          6 Mbps  :29
      9 Mbps  :12          11 Mbps  :0
     12 Mbps  :10          18 Mbps  :24
     24 Mbps  :11          36 Mbps  :5
     48 Mbps  :4           54 Mbps  :0
    6.5 Mbps  :45                7.2 Mbps  :0
     13 Mbps  :53               13.5 Mbps  :0
   19.5 Mbps  :120              21.7 Mbps  :0
     26 Mbps  :136                27 Mbps  :0
     39 Mbps  :59               40.5 Mbps  :0
     52 Mbps  :17                 54 Mbps  :0
   57.8 Mbps  :0                58.5 Mbps  :20
     60 Mbps  :0                  65 Mbps  :4
   97.5 Mbps  :0                 104 Mbps  :0
   1300 Mbps  :0
表1-5 display wlan statistics ap radio命令各字段的含义描述表
AP name
接入点名称
Radio ID
射频ID
传输的帧的统计信息
Total frames
传输的帧的总数,包括Probe Response帧和Beacon帧
Total frame bytes
传输帧的总字节数,包括Probe Response帧和Beacon帧
Unicast frames
传输的单播帧的总数,不包括Probe Response
Unicast frame bytes
传输的单播帧的总字节数,不包括Probe Response
传输的广播/组播帧的总数,不包括Beacon帧
传输的广播/组播帧的总字节数,不包括Beacon帧
Others frames
传输的其它帧的总数
Other frame bytes
传输的其它帧的总字节数
Discarded frames
丢弃的帧的数目
Failed RTS frames
传输失败的RTS帧的数目
Retransmissions
发生重传的次数
传输成功的RTS帧的数目
重传帧的数目
No-ACK frames
未收到ACK消息的已传帧的数目
传输的认证帧的数目
Association frames
传输的关联帧的数目
按照报文尺寸统计报文数量
按照802.11a/b/g的速率统计报文数量
按照802.11n的速率统计报文数量,如设备不支持802.11n,则不会显示该统计项
接收的帧的统计信息
Total frames
接收的帧的总数
Total frame bytes
接收的帧的总字节数
Unicast frames
接收的单播帧的总数
Unicast frame bytes
接收的单播帧的总字节数
接收的广播/组播帧的总数
接收的广播/组播帧的总字节数
Fragmented frames
接收的分片帧的数目
Duplicate frames
接收的重复帧的数目
FCS failures
接收中发生FCS错误的帧的数目
Decryption errors
接收中发生解码错误的帧的数目
接收的认证帧的数目
Association frames
接收的关联帧的数目
1.1.24  distance
distance命令用来配置射频可覆盖的最远距离。
undo distance命令用来恢复缺省情况。
distance distance
undo distance
Radio视图下,继承AP组配置。
AP组Radio视图下,射频可覆盖的最远距离为1公里。
Radio视图
AP组Radio视图
distance:射频可覆盖的最远距离,取值范围为1~40,单位为公里。
# 配置射频可覆盖的最远距离为5公里。(Radio视图)
[Sysname-wlan-ap-ap1-radio-1] distance 5
# 配置射频可覆盖的最远距离为5公里。(AP组Radio视图)
[Sysname-wlan-ap-group-apgroup1-ap-model-WAP922-radio-1] distance 5
1.1.25  dl-ofdma
dl-ofdma enable命令用来开启下行OFDMA(Orthogonal Frequency Division Multiple Access,正交频分多址)功能。
dl-ofdma disable命令用来关闭下行OFDMA功能。
undo dl-ofdma命令用来恢复缺省情况。
dl-ofdma { disable | enable }
undo dl-ofdma
Radio视图下,继承AP组配置。
AP组Radio视图下,下行OFDMA功能处于关闭状态。
Radio视图
AP组Radio视图
802.11ax借鉴了OFDMA的技术,在相同的信道带宽中复用多个用户。
在接入终端密集且传输数据包较小的场景下开启本功能后,AP可以同时向多个无线客户端传输报文,大大减少了多用户竞争退避导致的空口延时,提升了空口效率。
# 开启下行OFDMA功能。(Radio视图)
[Sysname-wlan-ap-ap1-radio-1] dl-ofdma enable
# 开启下行OFDMA功能。(AP组Radio视图)
[Sysname-wlan-ap-group-apgroup1-ap-model-WAP922-radio-1] dl-ofdma enable
·     type dot11ax
dot11ac mandatory maximum-nss命令用来配置802.11ac的最大基本NSS。
undo dot11ac mandatory maximum-nss命令用来恢复缺省情况。
dot11ac mandatory maximum-nss nss-number
Radio视图下,若已配置了802.11ac的最大支持NSS,则缺省情况下,未配置802.11ac的最大基本NSS;若未配置802.11ac的最大支持NSS,则缺省情况下,继承AP组配置。
AP组Radio视图下,未配置802.11ac的最大基本NSS。
Radio视图
AP组Radio视图
nss-number:最大基本NSS,取值范围为1~8。
本命令指定的802.11ac的最大基本NSS不能大于dot11ac support maximum-nss命令配置的802.11ac的最大支持NSS。
修改此配置,会导致当前已经关联到该射频但是不支持修改后的最大基本NSS的客户端下线。
该命令仅对802.11ac和802.11gac模式的Radio有效。当Radio模式切换为非dot11ac时,将取消该配置。
# 配置802.11ac的最大基本NSS为7。(Radio视图)
[Sysname-wlan-ap-ap1-radio-1] type dot11ac
[Sysname-wlan-ap-ap1-radio-1] dot11ac mandatory maximum-nss 7
# 配置802.11ac的最大基本NSS。(AP组Radio视图)
[Sysname-wlan-ap-group-1-ap-model-WAP922-radio-1] type dot11ac
[Sysname-wlan-ap-group-1-ap-model-WAP922-radio-1] dot11ac mandatory maximum-nss 7
·     dot11ac support maximum-nss
dot11ac multicast-nss命令用来配置802.11ac组播NSS及VHT-MCS索引值。
undo dot11ac multicast-nss命令用来恢复缺省情况。
dot11ac multicast-nss nss-number vht-mcs index
Radio视图下,若已配置了802.11ac的最大基本NSS或最大支持NSS,则缺省情况下,未配置802.11ac的组播NSS和VHT-MCS索引,若未配置802.11ac的最大基本NSS和最大支持NSS,则缺省情况下,继承AP组配置。
AP组Radio视图下,未配置802.11ac组播NSS及VHT-MCS索引。
Radio视图
AP组Radio视图
nss-number:指定802.11ac组播NSS,取值范围为1~8。
index:NSS对应的VHT-MCS索引值,取值范围为0~9。
必须先配置dot11ac mandatory maximum-nss命令,才能配置本命令。
用本命令指定的802.11ac组播的NSS不能大于dot11ac mandatory maximum-nss命令配置的802.11ac的最大基本NSS。
# 配置最大基本NSS为2,配置组播NSS为2,组播VHT-MCS索引为2。(Radio视图)
[Sysname-wlan-ap-ap1-radio-1] dot11ac mandatory maximum-nss 2
[Sysname-wlan-ap-ap1-radio-1] dot11ac multicast-nss 2 vht-mcs 2
# 配置最大基本NSS为2,配置组播NSS为2,组播VHT-MCS索引为2。(AP组Radio视图)
[Sysname-wlan-ap-group-1-ap-model-WAP922-radio-1] dot11ac mandatory maximum-nss 2
[Sysname-wlan-ap-group-1-ap-model-WAP922-radio-1] dot11ac multicast-nss 2 vht-mcs 2
dot11ac support maximum-nss命令用来配置802.11ac的最大支持NSS。
undo dot11ac support maximum-nss命令用来恢复缺省情况。
dot11ac support maximum-nss nss-number
Radio视图下,若已配置了802.11ac的最大基本NSS,则缺省情况下,802.11ac的最大支持NSS为8,若未配置802.11ac的最大基本NSS,则缺省情况下,继承AP组配置。
AP组Radio视图下,802.11ac的最大支持NSS为8。
Radio视图
AP组Radio视图
nss-number:指定802.11ac支持的最大NSS,取值范围为1~8。
本命令指定的802.11ac的最大支持NSS不能小于dot11ac mandatory maximum-nss命令配置的802.11ac的最大基本NSS。
# 配置802.11ac的最大支持NSS为7。(Radio视图)
[Sysname-wlan-ap-ap1-radio-1] dot11ac support maximum-nss 7
# 配置802.11ac的最大支持NSS为7。(AP组Radio视图)
[Sysname-wlan-ap-group-1-ap-model-WAP922-radio-1] dot11ac support maximum-nss 7
dot11ax mandatory maximum-nss命令用来配置802.11ax的强制最大基本NSS。
undo dot11ax mandatory maximum-nss命令用来恢复缺省情况。
dot11ax mandatory maximum-nss nss-number
Radio视图下,若已配置了802.11ax的最大支持NSS,则缺省情况下,未配置802.11ax的最大基本NSS;若未配置802.11ax的最大支持NSS,则缺省情况下,继承AP组配置。
AP组Radio视图下,未配置802.11ax的最大基本NSS。
Radio视图
AP组Radio视图
Radio接口视图
在AC设备上,Radio视图下配置的优先级高于AP组Radio视图下的配置。
本命令指定的802.11ax的最大基本NSS不能大于dot11ax support maximum-nss命令配置的802.11ax的最大支持NSS。
该命令仅对802.11ax和802.11gax模式的Radio有效。当Radio模式切换为非dot11ax时,将取消该配置。
# 配置802.11ax的最大基本NSS为8。(Radio视图)
[System-wlan-ap-ap1-radio-1] dot11ax mandatory maximum-nss 8
# 配置802.11ax的最大基本NSS。(AP组Radio视图)
[Sysname-wlan-ap-group-1-ap-model-WAP922-radio-1] dot11ax mandatory maximum-nss 8
[Sysname-wlan-radio-1/0/1] dot11ax mandatory maximum-nss 8
·     type dot11ax
dot11ax multicast-nss命令用来配置802.11ax组播NSS及HE-MCS索引值。
undo dot11ax multicast-nss命令用来恢复缺省情况。
dot11ax multicast-nss nss-number he-mcs index
Radio视图下,若已配置了802.11ax的最大基本NSS或最大支持NSS,则缺省情况下,未配置802.11ax的组播NSS和HE-MCS索引,若未配置802.11ax的最大基本NSS和最大支持NSS,则缺省情况下,继承AP组配置。
AP组Radio视图下,未配置802.11ax组播NSS及HE-MCS索引。
Radio视图
AP组Radio视图
Radio接口视图
nss-number:指定802.11ax组播NSS,取值范围为1~8。
index:NSS对应的HE-MCS索引值,取值范围为0~11
必须先配置dot11ax mandatory maximum-nss命令,才能配置本命令。
用本命令指定的802.11ax组播的NSS不能大于dot11ax mandatory maximum-nss命令配置的802.11ax的最大基本NSS。
# 配置最大基本NSS为2,配置组播NSS为2,组播HE-MCS索引为2。(Radio视图)
[Sysname-wlan-ap-ap1-radio-1] dot11ax mandatory maximum-nss 2
[Sysname-wlan-ap-ap1-radio-1] dot11ax multicast-nss 2 he-mcs 2
# 配置最大基本NSS为2,配置组播NSS为2,组播HE-MCS索引为2。(AP组Radio视图)
[Sysname-wlan-ap-group-1-ap-model-WAP922-radio-1] dot11ax mandatory maximum-nss 2
[Sysname-wlan-ap-group-1-ap-model-WAP922-radio-1] dot11ax multicast-nss 2 he-mcs 2
[Sysname-wlan-radio-1/0/1] dot11ax mandatory maximum-nss 2
[Sysname-wlan-radio-1/0/1] dot11ax multicast-nss 2 he-mcs 2
dot11ax support maximum-nss命令用来配置802.11ax最大支持NSS。
undo dot11ax support maximum-nss命令用来恢复缺省情况。
dot11ax support maximum-nss nss-number
Radio视图下,若已配置了802.11ax的最大基本NSS,则缺省情况下,802.11ax的最大支持NSS为8,若未配置802.11ax的最大基本NSS,则缺省情况下,继承AP组配置。
AP组Radio视图下,802.11ax的最大支持NSS为8。
802.11ax的最大支持NSS为8。
Radio视图
AP组Radio视图
Radio接口视图
nss-number:802.11ax协议默认最大基本NSS,取值范围为1~8。
# 配置支持最大基本NSS为8。(Radio视图)
[System-wlan-ap-ap1-radio-1] dot11ax support maximum-nss 8
# 在AP组中,配置支持最大基本NSS为8。(AP组Radio视图)
[Sysname-wlan-ap-group-1-ap-model-WAP922-radio-1] dot11ax support maximum-nss 8
# 配置支持最大基本NSS为8。
[Sysname-wlan-radio-1/0/1] dot11ax support maximum-nss 8
·     type dot11ax
dot11g protection enable命令用来开启802.11g保护功能。
dot11g protection disable命令用来关闭802.11g保护功能。
undo dot11g protection命令用来恢复缺省情况。
dot11g protection { disable | enable }
Radio视图下,继承AP组配置。
AP组Radio视图下,802.11g保护功能处于关闭状态。
Radio视图
AP组Radio视图
仅当射频模式为802.11g、802.11n(2.4GHz)和802.11gac时才支持配置802.11g保护功能,切换射频模式为其它模式时,802.11g保护功能的配置将被删除。
开启802.11g保护功能后,如果AP在其工作信道上扫描到802.11b信号,才会在传输数据前通过发送RTS/CTS报文或CTS-to-self报文进行冲突避免,并通知客户端开始执行802.11g保护功能;如果未检测到802.11b信号,则不会采取上述动作。
当802.11b客户端在开启了802.11g、802.11n(2.4GHz)或802.11gac的AP射频上接入时,AP上的802.11g保护功能将自动开启并生效。
Radio视图下配置的优先级高于AP组Radio视图下Radio视图下的配置。
# 开启802.11g保护的功能。(Radio视图)
[Sysname-wlan-ap-ap1-radio-2] type dot11gn
[Sysname-wlan-ap-ap1-radio-2] dot11g protection enable
# 开启802.11g保护的功能。(AP组Radio视图)
[Sysname-wlan-ap-group-apgroup1-ap-model-WAP922] radio 2
[Sysname-wlan-ap-group-apgroup1-ap-model-WAP922-radio-2] type dot11gn
[Sysname-wlan-ap-group-apgroup1-ap-model-WAP922-radio-2] dot11g protection enable
·     protection-mode
dot11n mandatory maximum-mcs命令用来配置802.11n射频的最大基本MCS索引。
undo dot11n mandatory maximum-mcs命令用来恢复缺省情况。
dot11n mandatory maximum-mcs index
Radio视图下,若已配置了最大支持MCS索引,则缺省情况下,未配置任何802.11n的基本MCS索引,若未配置最大支持MCS索引,则缺省情况下,继承AP组配置。
AP组Radio视图下,未配置任何802.11n的基本MCS索引。
Radio视图
AP组Radio视图
index:指定802.11n射频最大基本MCS索引值,取值范围为0~76。
如果用户需要在指定Radio下配置dot11n multicast-mcs命令,则必须配置802.11n最大基本MCS索引。
修改此配置,会导致当前已经关联到该射频但是不支持修改后的最大基本MCS索引的客户端下线。
该命令仅对802.11n、802.11ac和802.11gac模式的Radio有效。当Radio模式切换为dot11adot11bdot11g时,将取消该配置。
# 配置射频802.11n最大基本MCS索引为14。(Radio视图)
[Sysname-wlan-ap-ap1-radio-1] dot11n mandatory maximum-mcs 14
# 配置射频802.11n最大基本MCS索引为14。(AP组Radio视图)
[Sysname-wlan-ap-group-apgroup1-ap-model-WAP922-radio-1] dot11n mandatory maximum-mcs 14
dot11n multicast-mcs命令用来配置射频802.11n的组播MCS索引。
undo dot11n multicast-mcs命令用来恢复缺省情况。
dot11n multicast-mcs index
Radio视图下,若已配置了最大基本MCS索引或最大支持MCS索引,则缺省情况下,未配置任何802.11n的组播MCS索引,若未配置最大基本MCS索引和最大支持MCS索引,则缺省情况下,继承AP组配置。
AP组Radio视图下,未配置任何802.11n组播MCS索引。
Radio视图
AP组Radio视图
index:指定射频802.11n组播MCS索引值,取值范围为0~76。
当接入的客户端都是802.11n和802.11ac客户端时,组播MCS索引才会生效。
当存在802.11a/b/g客户端时,只能选用基础模式的组播速率,即802.11a/b/g的组播速率。
组播MCS索引起作用时,无论带宽模式设置的是20MHz模式还是40MHz模式,统一采用20MHz模式对应的速率。
# 配置射频802.11n组播MCS索引为14。(Radio视图)
[Sysname-wlan-ap-ap1-radio-1] dot11n mandatory maximum-mcs 15
[Sysname-wlan-ap-ap1-radio-1] dot11n multicast-mcs 14
# 配置射频802.11n组播MCS索引为14。(AP组Radio视图)
[Sysname-wlan-ap-group-apgroup1-ap-model-WAP922-radio-1] dot11n multicast-mcs 14
dot11n protection enable命令用来开启802.11n保护功能。
dot11n protection disable命令用来关闭802.11n保护功能。
undo dot11n protection命令用来恢复缺省情况。
dot11n protection { disable | enable }
Radio视图下,继承AP组配置。
AP组Radio视图下,802.11n保护功能处于关闭状态。
Radio视图
AP组Radio视图
仅当射频模式为802.11n、802.11ac和802.11gac时才支持配置802.11n保护功能,切换射频模式为其它模式时, 802.11n保护功能的配置将被删除。
开启802.11n保护功能后,如果AP在其工作信道上扫描到802.11a/b/g信号,将通知客户端开始执行802.11n保护功能;如果未检测到802.11a/b/g信号,则不会采取上述动作。
当802.11a/b/g客户端在开启了802.11n、802.11ac或802.11gac的AP射频上接入时,AP上的802.11n保护功能将自动开启并生效。
# 开启802.11n保护的功能。(Radio视图)
[Sysname-wlan-ap-ap1-radio-1] dot11n protection enable
# 开启802.11n保护的功能。(AP组Radio视图)
[Sysname-wlan-ap-group-apgroup1-ap-model-WAP922-radio-1] dot11n protection enable
dot11n support maximum-mcs命令用来配置射频802.11n最大支持MCS索引。
undo dot11n support maximum-mcs命令用来恢复缺省情况。
dot11n support maximum-mcs index
Radio视图下,若已配置了最大基本MCS索引,则缺省情况下,802.11n最大支持MCS索引为76,若未配置最大基本MCS索引,则缺省情况下,继承AP组配置。
AP组Radio视图下,802.11n最大支持MCS索引值为76。
Radio视图
AP组Radio视图
index:指定射频802.11n最大支持MCS索引值,取值范围为0~76。
用该命令指定的802.11n最大支持MCS索引不能小于dot11n mandatory maximum-mcs命令配置的802.11n最大基本MCS索引。
# 配置射频802.11n最大支持MCS索引为14。(Radio视图)
[System-wlan-ap-ap1-radio-1] dot11n support maximum-mcs 14
# 配置射频802.11n最大支持MCS索引为14。(AP组Radio视图)
[Sysname-wlan-ap-group-apgroup1-ap-model-WAP922-radio-1] dot11n support maximum-mcs 14
1.1.37  dtim
dtim命令用来配置发送DTIM(Delivery Traffic Indication Map,延迟传输指示映射)帧前需要发送的Beacon帧数目。
undo dtim命令用来恢复缺省情况。
dtim counter
undo dtim
Radio视图下,继承AP组配置。
AP组Radio视图下,发送DTIM帧前需要发送的发送的Beacon数目为1。
Radio视图
AP组Radio视图
counter:发送DTIM帧前需要发送的Beacon数目,取值范围为1~31。
AP周期发送DTIM帧通知客户端AP上缓存的广播帧与组播帧即将被发送。
由于DTIM帧是携带TIM(Traffic Indication Map,传输指示映射)信息的Beacon帧,所以当counter取值为1时,也就是缺省情况下,每个Beacon帧都会携带DTIM信息。
# 配置发送DTIM帧前需要发送的Beacon帧数目为5。(Radio视图)
[Sysname-wlan-ap-ap1-radio-1] dtim 5
# 配置发送DTIM帧前需要发送的Beacon帧数目为5。(AP组Radio视图)
[Sysname-wlan-ap-group-apgroup1-ap-model-WAP922-radio-1] dtim 5
fragment-threshold命令用来配置帧的分片门限。
undo fragment-threshold命令用来恢复缺省情况。
fragment-threshold size
Radio视图下,继承AP组配置。
AP组Radio视图下,帧的分片门限值为2346字节。
Radio视图
AP组Radio视图
帧的分片是将一个较大的帧分成多个小的分片,每个分片独立进行传输和确认。当帧的实际大小超过本配置指定的分片门限值时,该帧将被分片传输。
在干扰较大的无线网络环境,建议适当降低帧的分片门限值,增加帧的分片数量,设备仅需要重传未成功发送的分片,同时使用ip mtu命令对IP报文进行分片,并且MTU的门限小于帧的分片门限,从而提高吞吐量。
# 配置帧的分片门限为2048字节。(Radio视图)
[Sysname-wlan-ap-ap1-radio-1] fragment-threshold 2048
# 配置帧的分片门限为2048字节。(AP组Radio视图)
[Sysname-wlan-ap-group-apgroup1-ap-model-WAP922-radio-1] fragment-threshold 2048
green-energy-management enable命令用来开启AP绿色节能功能。
green-energy-management disable命令用来关闭AP绿色节能功能。
undo green-energy-management命令用来恢复缺省情况。
green-energy-management { disable | enable }
Radio视图下,继承AP组配置。
AP组Radio视图下,AP绿色节能功能处于关闭状态。
Radio视图
AP组Radio视图
开启AP绿色节能功能后,在没有用户与Radio关联并且Radio上没有开启WIPS功能时,Radio将工作在1x1模式,以减少辐射,节省用电量。
# 开启AP绿色节能功能。(Radio视图)
[Sysname-wlan-ap-ap1-radio-1] green-energy-management enable
# 开启AP绿色节能功能。(AP组Radio视图)
[Sysname-wlan-ap-group-apgroup1-ap-model-WAP922-radio-1] green-energy-management enable
1.1.40  ldpc
ldpc enable命令用来开启LDPC功能。
ldpc disable命令用来关闭LDPC功能。
undo ldpc命令用来恢复缺省情况。
ldpc { disable | enable }
undo ldpc
Radio视图下,继承AP组配置。
AP组Radio视图下,LDPC功能处于开启状态。
Radio视图
AP组Radio视图
目前,设备只支持接收LDPC报文,不支持发送LDPC报文。
# 关闭LDPC功能。(Radio视图)
[Sysname-wlan-ap-ap1-radio-1] ldpc disable
# 关闭LDPC功能。(AP组Radio视图)
[Sysname-wlan-ap-group-1-ap-model-WAP922-radio-1] type dot11an
[Sysname-wlan-ap-group-1-ap-model-WAP922-radio-1] ldpc disable
long-retry threshold命令用来配置长帧的最大硬件重传次数。
undo long-retry threshold命令用来恢复缺省情况。
long-retry threshold count
Radio视图下,继承AP组配置。
AP组Radio视图下,长帧的最大硬件重传次数为4。
Radio视图
AP组Radio视图
count:长帧的最大硬件重传次数,取值范围为1~15。
本命令用于配置帧长超过RTS门限的帧的最大硬件重传次数。
# 配置长帧的最大硬件重传次数为5。(Radio视图)
[Sysname-wlan-ap-ap1-radio-1] long-retry threshold 5
# 配置长帧的最大硬件重传次数为5。(AP组Radio视图)
[Sysname-wlan-ap-group-apgroup1-ap-model-WAP922-radio-1] long-retry threshold 5
·     protection-threshold
·     short-retry threshold
1.1.42  max-power
max-power命令用来配置射频最大传输功率。
undo max-power命令用来恢复缺省情况。
max-power radio-power
undo max-power
Radio视图下,继承AP组配置。
AP组Radio视图下,射频使用支持的最大功率。
Radio视图
AP组Radio视图
radio-power:射频的最大传输功率,其取值范围由区域码、信道、AP型号、射频模式、天线类型、带宽等属性决定。
射频的最大传输功率只能在射频支持的功率范围内进行选取,即保证射频的最大传输功率在合法范围内。射频支持的功率范围由区域码、信道、AP型号、射频模式、天线类型、带宽等属性决定,修改上述属性,射频支持的功率范围和最大传输功率将自动调整为合法值。
如果开启了射频的功率锁定功能,则AC会将射频最大传输功率修改为射频当前传输功率。
配置本命令后,当前Radio的自动功率调整功能将失效。有关自动功率调整功能的详细介绍,请参见“射频资源管理命令参考”中的“WLAN RRM”。
# 配置射频最大传输功率为15dBm。(Radio视图)
[Sysname-wlan-ap-ap1-radio-1] max-power 15
# 配置射频最大传输功率为15dBm。(AP组Radio视图)
[Sysname-wlan-ap-group-apgroup1-ap-model-WAP922-radio-1] max-power 15
1.1.43  mimo
本命令参数的支持情况与AP的型号有关请以设备的实际情况为准。
mimo命令用来配置射频的MIMO模式。
undo mimo命令用来恢复缺省情况。
mimo { 1x1 | 2x2 | 3x3 | 4x4 }
undo mimo
Radio视图下,继承AP组配置。
AP组Radio视图下,与AP设备的型号有关,请以设备的实际情况为准。
Radio视图
AP组Radio视图
1x1:配置Radio采用一条流发送和接收无线信号。
2x2:配置Radio采用两条流发送和接收无线信号。
3x3:配置Radio采用三条流发送和接收无线信号。
4x4:配置Radio采用四条流发送和接收无线信号。
MIMO(多输入多输出)技术是指一个系统采用多个天线(多条流)进行无线信号的发送和接收,能够在不增加带宽的情况下成倍的提高通信系统的容量和频谱利用率。
开启Green AP功能后,在没有用户与Radio关联时,Radio将工作在1x1的一条流模式,以减少辐射,节省电量。
# 配置Radio 1的MIMO模式为2x2。(Radio视图)
[Sysname-wlan-ap-ap1-radio-1] mimo 2x2
# 配置Radio 1的MIMO模式为2x2。(AP组Radio视图)
[Sysname-wlan-ap-group-apgroup1-ap-model-WAP922-radio-1] mimo 2x2
1.1.44  mu-txbf
本命令的支持情况与AP设备的型号有关,请以设备的实际情况为准。
mu-txbf enable命令用来开启AP多用户TxBF(Tx Beamforming,固定发送波速成形)功能。
mu-txbf disable命令用来关闭AP多用户TxBF功能。
undo mu-txbf命令用来恢复缺省情况。
mu-txbf { disable | enable }
undo mu-txbf
Radio视图下,继承AP组配置。
AP组Radio视图下,多用户TxBF功能处于关闭状态。
Radio视图
AP组Radio视图
该命令仅对802.11ac和802.11gac、802.11ax和802.11gax模式的Radio有效,当Radio模式切换为dot11a、dot11b、dot11g、dot11n模式时,将取消该配置。
开启TxBF功能后,AP通过获取其与客户端之间的信道信息来调整信号发送的参数,使得射频能量向客户端所处位置集中,从而提高客户端接收到的信号质量。
多用户TxBF技术是指AP通过TxBF技术在同一时刻向多个客户端发送数据,提供并行数据传输。多用户TxBF是802.11ac wave2的一部分。开启多用户TxBF功能后,AP通过多根天线同时向多个客户端发送无线信号,根据信道状态信息调整信号发送的参数,使给特定客户端的信息到达其它客户端时信号最小甚至感知不到。减少了客户端之间竞争式传输的延迟,提高了信息吞吐量和AP带宽利用。此功能适用于客户端数量多、AP带宽利用和传输延迟要求高的环境。
请先使用su-txbf enable命令开启单用户TxBF功能,多用户TxBF功能才能生效。
建议不要修改AP射频的缺省MIMO配置,以免AP射频无法实现多用户TxBF功能。
# 开启AP多用户TxBF功能。(Radio视图)
[Sysname-wlan-ap-ap1-radio-1] su-txbf enable
[Sysname-wlan-ap-ap1-radio-1] mu-txbf enable
# 开启AP多用户TxBF功能。(AP组Radio视图)
[Sysname-wlan-ap-group-apgroup1-ap-model-WAP922-radio-1] su-txbf enable
[Sysname-wlan-ap-group-apgroup1-ap-model-WAP922-radio-1] mu-txbf enable
·     mimo
·     su-txbf
1.1.45  power-lock
power-lock enable命令用来开启功率锁定功能。
power-lock disable命令用来关闭功率锁定功能。
undo power-lock命令用来恢复缺省情况。
power-lock { disable | enable }
undo power-lock
Radio视图下,继承AP组配置。
AP组Radio视图下,功率锁定功能处于关闭状态。
Radio视图
AP组Radio视图
开启功率锁定功能后,AC会将AP的当前传输功率进行锁定,并将射频最大传输功率修改为当前传输功率。如果AC发生重启,则AP在和AC重新建立连接后,将继续使用锁定的传输功率。
锁定功率后,如果信道发生调整,并且锁定的功率值大于调整后信道支持的最大功率,则设备会将功率值调整为信道支持的最大功率。
# 配置锁定功率。(Radio视图)
[Sysname-wlan-ap-ap1-radio-1] power-lock enable
# 配置锁定功率。(AP组Radio视图)
[Sysname-wlan-ap-group-apgroup1-ap-model-WAP922-radio-1] power-lock enable
1.1.46  preamble
preamble命令用来配置前导码类型。
undo preamble命令用来恢复缺省情况。
preamble { long | short }
undo preamble
Radio视图下,继承AP组配置。
AP组Radio视图下,Radio使用短前导码。
Radio视图
AP组Radio视图
long:长前导码。在网络中如果有客户端使用早期的客户端网卡,可以选择长前导码兼容这些客户端。
short:短前导码。选择短前导码能使网络同步性能更好,一般选择短前导码。
前导码是位于数据包起始处的一组bit位,接收者可以据此同步并准备接收数据。
只有射频模式为802.11b、802.11g或802.11gn模式,才支持配置前导码类型。
# 配置前导码类型为长前导码。(Radio视图)
[Sysname-wlan-ap-ap1-radio-2] preamble long
# 配置前导码类型为长前导码。(AP组Radio视图)
[Sysname-wlan-ap-group-apgroup1-ap-model-WAP922-radio-1] type dot11g
[Sysname-wlan-ap-group-apgroup1-ap-model-WAP922-radio-1] preamble long
protection-mode命令用来配置冲突避免方式。
undo protection-mode命令用来恢复缺省情况。
protection-mode { cts-to-self | rts-cts }
Radio视图下,继承AP组配置。
AP组Radio视图下,冲突避免方式为CTS-to-self方式。
Radio视图
AP组Radio视图
cts-to-self:指定冲突避免方式为CTS-to-self方式。
rts-cts:指定冲突避免方式为RTS/CTS方式。
冲突避免可以通过以下两种方式实现:
·     RTS/CTS(Request to Send/Clear to Send,请求发送/允许发送)方式:当AP向某个客户端发送数据时,AP会向客户端发送一个RTS报文,客户端收到RTS后,会回复一个CTS报文,接收到RTS或CTS报文的无线设备会在指定的时间内停止数据发送。
·     CTS-to-self(反身CTS)方式:当AP向某个客户端发送数据时,会使用自己的MAC地址作为目的MAC地址发送一个CTS报文,接收到CTS-to-self报文的无线设备会在指定的时间内停止数据发送。
# 配置冲突避免方式为RTS/CTS方式。(Radio视图)
[Sysname-wlan-ap-ap1-radio-2] protection-mode rts-cts
# 配置冲突避免方式为RTS/CTS方式。(AP组Radio视图)
[Sysname-wlan-ap-group-apgroup1-ap-model-WAP922-radio-2] protection-mode rts-cts
·     dot11g protection
protection-threshold命令用来配置RTS门限。
undo protection-threshold命令用来恢复缺省情况。
protection-threshold size
Radio视图下,继承AP组配置。
AP组Radio视图下,RTS门限为2346字节。
Radio视图
AP组Radio视图
当AP要发送的帧的长度达到RTS门限时,需要先执行冲突避免,即使用RTS/CTS帧或CTS-to-self帧来清空传送区域,取得信道使用权;长度小于RTS门限,则可以直接发送。
# 配置RTS门限为2048字节。(Radio视图)
[Sysname-wlan-ap-ap1-radio-1] protection-threshold 2048
# 配置RTS门限为2048字节。(AP组Radio视图)
[Sysname-wlan-ap-group-apgroup1-ap-model-WAP922-radio-1] protection-threshold 2048
·     protection-mode
radar-detect disable命令用来关闭雷达检测功能。
undo radar-detect命令用来恢复缺省情况。
undo radar-detect
Radio视图下,继承AP组Radio配置。
AP组Radio视图下,雷达检测功能处于开启状态。
Radio视图
AP组Radio视图
雷达检测功能开启时,当AP在当前信道上检测到雷达信号时,会切换信道或保持静默,防止对雷达造成干扰。切换信道30分钟后,AP会切换回原来的信道,继续工作。如果此时原信道还能检测到雷达信号,则继续切换信道进行避让或保持静默。
当雷达探测功能关闭时,AP即使在当前信道上检测到了雷达信号,也会继续在当前信道上工作。关闭雷达探测功能仅用于设备调试,请谨慎使用。
# 关闭雷达检测功能。(Radio视图)
<Syname> system-view
[Sysname-wlan-ap-ap1-radio-1] radar-detect disable
# 关闭雷达检测功能。(AP组Radio视图)
[Syname] wlan ap-group default-group
[Sysname-wlan-ap-group-default-group] ap-model WAP922
[Sysname-wlan-ap-group-default-group-ap-model-WAP922] radio 1
[Sysname-wlan-ap-group-default-group-ap-model-WAP922-radio-1] radar-detect disable
1.1.50  radio
radio命令用来进入Radio视图。
radio radio-id
AP视图
AP组ap-model视图
radio-id:射频编号,本参数的取值范围与AP型号有关,请以设备的实际情况为准。
# 进入Radio视图。(AP视图)
# 进入AP组Radio视图。(AP组视图)
1.1.51  radio enable
radio enable命令用来开启射频功能。
radio disable命令用来关闭射频功能。
undo radio命令用来恢复缺省情况。
radio { disable | enable }
undo radio
Radio视图下,继承AP组配置。
AP组Radio视图下,射频处于关闭状态。
Radio视图
AP组Radio视图
# 开启射频功能。(Radio视图)
[Sysname-wlan-ap-ap1-radio-1] radio enable
# 开启射频功能。(AP组Radio视图)
[Sysname-wlan-ap-group-apgroup1-ap-model-WAP922-radio-1] radio enable
radio scheduled-shutdown time-range命令用来配置AP Radio按时间段关闭无线服务功能。
undo radio scheduled-shutdown time-range命令用来恢复缺省情况。
radio scheduled-shutdown time-range range-name
未配置AP Radio按时间段关闭无线服务功能。
Radio视图
time-range range-name:指定时间段的名称,为1~32个字符的字符串,使用英文字母时不区分大小写。为避免混淆,时间段的名称不允许使用英文单词all。
# 配置AP Radio按时间段t1关闭无线服务。
[Sysname-wlan-ap-ap1-radio-1] radio scheduled-shutdown time-range t1
·     time-range(ACL和QoS命令参考/时间段)
1.1.53  rate
rate命令用来配置射频速率。
undo rate命令用来恢复缺省情况。
rate { multicast { auto | rate-value } | { disabled | mandatory | supported } rate-value }
undo rate
Radio视图下,继承AP组配置。
AP组Radio视图下:
·     802.11a/802.11an/802.11ac:
¡     禁用速率:无。
¡     强制速率:6,12,24。
¡     组播速率:自动从强制速率中选择合适的速率。
¡     支持速率:9,18,36,48,54。
·     802.11b:
¡     禁用速率:无。
¡     强制速率:1,2。
¡     支持速率:5.5,11。
·     802.11g/802.11gn/802.11gac:
¡     禁用速率:无。
¡     强制速率:1,2,5.5,11。
¡     支持速率:6,9,12,18,24,36,48,54。
Radio视图
AP组Radio视图
disabled:禁用速率。AP禁用的速率。
mandatory:强制速率。客户端关联AP时,AP要求客户端必须支持的速率。
multicast:组播速率,即AP向客户端发送组播报文的速率。组播速率必须在强制速率中选取。
supported:支持速率。AP所支持的速率。客户端关联AP后,可以在AP支持的“支持速率集”中选用更高/更低的速率发送报文。
auto自动从强制速率中选择合适的速率作为组播速率。
rate-value:速率值,单位为Mbps。可配置多个速率,用空格分隔。
·     802.11a/802.11an/802.11ac:可以取值6、9、12、18、24、36、48、54。
·     802.11b:可以取值1、2、5.5、11。
·     802.11g/802.1gn/802.11gac:可以取值1、2、5.5、6、9、11、12、18、24、36、48、54。
组播速率必须在强制速率中选取,且只能配置一个速率值或由AP自动选择合适的速率。
强制速率和组播速率必须配置。当强制速率只有一个值时,用户不能将这个值配置成支持速率或者禁用速率。
# 配置强制速率为6Mbps、12Mbps、24Mbps。(Radio视图)
[Sysname-wlan-ap-ap1-radio-1] rate mandatory 6 12 24
# 配置强制速率为6Mbps、12Mbps、24Mbps。(AP组Radio视图)
[Sysname-wlan-ap-group-apgroup1-ap-model-WAP922-radio-1] rate mandatory 6 12 24
reset wlan channel all命令用来重新划分射频工作信道。
执行本命令后,系统将会遍历当前AC上所有接入AP的所有无固定工作信道的射频,并重新划分工作信道。本命令适用于批量重新划分射频工作信道的场景,信道调整时会对业务有短暂影响,请谨慎使用。
对于命名有序、部署有序的AP,划分结果会更接近预期。
# 重新划分射频工作信道。
<Sysname> reset wlan channel all
Resetting working channels for radios without a working channel specified will affect services temporarily. Continue? [Y/N]:
reset wlan statistics ap radio命令用来清除射频统计信息。
reset wlan statistics ap { all | name ap-name } radio
all:清除所有AP的射频统计信息。
name ap-name:清除指定AP的射频统计信息。ap-name表示AP的名称,为1~64个字符的字符串,可以包含字母、数字、下划线、“.”、“[”、“]”、“/”及“-”,区分大小写。
#  清除ap1上的射频统计信息。
<Sysname> reset wlan statistics ap name ap1 radio
1.1.56  short-gi
short-gi enable命令用来开启Short-GI功能。
short-gi disable命令用来关闭Short-GI功能。
undo short-gi命令用来恢复缺省情况。
short-gi { disable | enable }
undo short-gi
Radio视图下,继承AP组配置。
AP组Radio视图下,Short GI功能处于开启状态。
Radio视图
AP组Radio视图
该命令仅在支持802.11n、802.11ac和802.11gac的Radio上支持。当Radio模式切换为dot11adot11bdot11g时,将取消该配置。
# 关闭Short GI功能。(Radio视图)
[Sysname-wlan-ap-ap1-radio-1] short-gi disable
# 关闭Short GI功能。(AP组Radio视图)
[Sysname-wlan-ap-group-apgroup1-ap-model-WAP922-radio-1] short-gi disable
short-retry threshold命令用来配置短帧的最大硬件重传次数。
undo short-retry threshold命令用来恢复缺省情况。
short-retry threshold count
Radio视图下,继承AP组配置。
AP组Radio视图下,短帧的最大硬件重传次数为7。
Radio视图
AP组Radio视图
count:短帧的最大硬件重传次数,取值范围为1~15。
本命令用于配置帧长小于或等于RTS门限的帧的最大硬件重传次数。
# 配置短帧的最大硬件重传次数为10。(Radio视图)
[Sysname-wlan-ap-ap1-radio-1] short-retry threshold 10
# 配置短帧的最大硬件重传次数为10。(AP组Radio视图)
[Sysname-wlan-ap-group-apgroup1-ap-model-WAP922-radio-1] short-retry threshold 10
·     long-retry threshold
1.1.58  stbc
stbc enable命令用来开启STBC功能。
stbc disable命令用来关闭STBC功能。
undo stbc命令用来恢复缺省情况。
stbc { disable | enable }
undo stbc
Radio视图下,继承AP组配置。
AP组Radio视图下,STBC功能处于开启状态。
Radio视图
AP组Radio视图
# 开启STBC功能。(Radio视图)
[Sysname-wlan-ap-ap1-radio-1] stbc enable
# 开启STBC功能。(AP组Radio视图)
[Sysname-wlan-ap-group-1-ap-model-WAP922-radio-1] stbc enable
1.1.59  su-txbf
su-txbf enable命令用来开启AP单用户TxBF功能。
su-txbf disable命令用来关闭AP单用户TxBF功能。
undo su-txbf命令用来恢复缺省情况。
su-txbf { disable | enable }
undo su-txbf
Radio视图下,继承AP组配置。
AP组Radio视图下,单用户TxBF功能处于关闭状态。
Radio视图
AP组Radio视图
该命令仅对802.11ac、802.11gac、802.11ax和802.11gax模式的Radio有效,当Radio模式切换为dot11a、dot11b、dot11g、dot11n模式时,将取消该配置。
单用户TxBF技术是指AP与占用当前信道的单个客户端使用TxBF技术进行数据传输。当开启单用户TxBF功能后,AP与当前客户端交互协议报文,获得其与客户端之间信道的基础信息,来调整信号发送的参数,使得多根天线传输的同一信号在接收端处叠加出较好的效果。此功能适用于客户端分布范围广、网络环境质量差、信号衰减严重的环境。
# 开启AP单用户TxBF功能。(Radio视图)
# 开启AP单用户TxBF功能。(AP组Radio视图)
·     mimo
·     mu-txbf
本命令的支持情况与AP型号有关,请以设备的实际情况为准。
twt negotiate enable命令用来开启TWT(Target Wake Time,定时唤醒)协商功能。
twt negotiate disable命令用来关闭TWT协商功能。
undo twt negotiate命令用来恢复缺省情况。
twt negotiate { disable | enable }
undo twt negotiate
Radio视图下,继承AP组配置。
AP组Radio视图下,本命令的缺省情况与AP设备的型号有关,请以设备的实际情况为准。
Radio视图
AP组Radio视图
开启TWT协商功能后,如果AP收到无线终端的协商请求(请求中携带服务周期、TWT间隔以及首个唤醒时间,每次唤醒时间由终端自行计算),则会对协商请求进行响应。协商完成后,终端将在唤醒时间到达前醒来,并等待AP发送的触发帧。终端收到触发帧后进入服务周期并交互数据报文。服务周期结束后,无论数据报文是否发送完成,终端立刻进入睡眠状态并等待下一个唤醒时间。使用TWT协商功能,可以降低无线终端的功耗并减少无线资源竞争。
每个射频最多为8个终端提供TWT服务。AP对8个终端的TWT协商请求进行应答后,后续其它终端发送的协商请求将会被AP拒绝。
本配置仅对802.11ax和802.11gax模式的Radio有效。当Radio模式从802.11ax或802.11gax切换至其它模式时,将取消该配置。
# 开启TWT协商功能。(Radio视图)
[Sysname-wlan-ap-ap1-radio-1] twt negotiate enable
# 开启TWT协商功能。(AP组Radio视图)
[Sysname-wlan-ap-group-apgroup1-ap-model-WAP922-radio-1] twt negotiate enable
·     type
1.1.61  type
type命令用来配置射频模式。
undo type命令用来恢复缺省情况。
type { dot11a | dot11ac | dot11an | dot11b | dot11g | dot11gac | dot11gn }
undo type
Radio视图
AP组Radio视图
dot11a:指定射频模式为802.11a。
dot11ac:指定射频模式为802.11ac。
dot11an:指定射频模式为802.11n(5GHz)。
dot11b:指定射频模式为802.11b。
dot11g:指定射频模式为802.11g。
dot11gac:指定射频模式为802.11gac。
dot11gn:指定射频模式为802.11n(2.4GHz)。
修改射频模式时,如果射频处于开启状态,会导致客户端下线。在AP组Radio视图下修改射频模式后,该视图下与射频模式有关的命令,例如信道、最大功率、速率都会恢复为缺省值。
# 配置射频模式为802.11n(5GHz)。(Radio视图)
# 配置射频模式为802.11n(5GHz)。(AP组Radio视图)
1.1.62  ul-mu-mimo
ul-mu-mimo enable命令用来开启上行MU-MIMO功能。
ul-mu-mimo disable命令用来关闭上行MU-MIMO功能。
undo ul-mu-mimo命令用来恢复缺省情况。
ul-mu-mimo { disable | enable }
undo ul-mu-mimo
Radio视图下,继承AP组配置。
AP组Radio视图下,上行MU-MIMO功能处于关闭状态。
Radio视图
AP组Radio视图
上行MU-MIMO功能可以实现AP在同一时刻接收多个无线客户端并行发送的数据报文的目的。由AP先向所有无线客户端发送一个HE_Trig告知对无线客户端在传输时间、频率、采样时钟以及功率等要求,收到HE_Trig的无线客户端按照要求同时向AP开始传输数据报文,最终在AP端同时接收客户端数据报文。
在接入终端密集且传输数据包较大的场景下开启本功能后,AP通过多根天线可以同时接收多个无线客户端传输的报文,保证传输数据完整性的同时大大减少了多用户竞争退避导致的射频接口的延时,提升了射频接口效率。
# 开启上行MU-MIMO功能。(Radio视图)
[Sysname-wlan-ap-ap1-radio-1] ul-mu-mimo enable
# 开启上行MU-MIMO功能。(AP组Radio视图)
[Sysname-wlan-ap-group-apgroup1-ap-model-WAP922-radio-1] ul-mu-mimo enable
·     mu-txbf
1.1.63  ul-ofdma
ul-ofdma enable命令用来开启上行OFDMA功能。
ul-ofdma disable命令用来关闭上行OFDMA功能。
undo ul-ofdma命令用来恢复缺省情况。
ul-ofdma { disable | enable }
undo ul-ofdma
Radio视图下,继承AP组配置。
AP组Radio视图下,上行OFDMA功能处于关闭状态。
Radio视图
AP组Radio视图
由于无线客户端间性能差异较大,为了可以兼容高低端设备间的通信,需要开启上行OFDMA功能。由AP先向所有无线客户端发送一个HE_Trig(HE Trigger-Based PPDU,HE触发回应帧)告知对无线客户端在传输时间、频率、采样时钟以及功率等要求,符合要求的多个无线客户端同时向AP开始传输数据包。
在接入终端密集且传输数据包较小的场景下开启本功能后,AP可以同时接收多个无线客户端传输的报文,大大减少了多用户竞争退避导致的空口延时,提升了空口效率。
# 开启上行OFDMA功能。(Radio视图)
[Sysname-wlan-ap-ap1-radio-1] ul-ofdma enable
# 开启上行OFDMA功能。(AP组Radio视图)
[Sysname-wlan-ap-group-apgroup1-ap-model-WAP922-radio-1] ul-ofdma enable
·     type dot11ax
wlan error-frame optimization命令用来配置射频接收错包率的优化参数值。
undo wlan error-frame optimization命令用来恢复缺省情况。
wlan error-frame optimization value
未配置射频接收错包率的优化参数值。
value:射频接收错包率的优化参数值,取值范围为0~1000。该数值越小,射频接收的错包率越小。
射频接收错包率是指射频接收的错误包占射频接收的所有包的百分比。
配置本命令后,设备会重新对射频接收的错包率进行优化计算。
# 配置射频接收错包率的优化参数值为100。
[Sysname] wlan error-frame optimization 100
1.1.65  wlan radio
wlan radio命令用来开启/关闭所有AP射频。
undo wlan radio命令用来恢复缺省情况。
wlan radio { disable | enable }
undo wlan radio
如果已经在Radio视图下开启射频,则射频处于开启状态,否则射频处于关闭状态。
disable:关闭所有AP射频。
enable:开启所有AP射频。
本命令仅对AC上已创建的手工AP和已上线的自动AP生效。
本命令与radio { disable | enable }命令为相互覆盖关系。
# 开启AC上的所有AP射频。
[Sysname] wlan radio enable
·     radio { disable | enable }
wlan radio channel band-width default命令用来将设备上所有AP的全部射频恢复为缺省的带宽模式。
使用本命令可将设备上所有Radio视图、AP组Radio视图下的带宽模式配置(channel band-width)恢复为缺省情况,即所有AP射频将根据其配置的射频模式恢复为缺省的带宽模式。
配置本命令后,部分射频可能更换工作信道并且使处于已连接状态的终端掉线,请谨慎操作。
# 配置将设备上所有AP的全部射频恢复为缺省的带宽模式。
[Sysname] wlan radio channel band-width default
This operation might cause channel change and client offline. Continue? [Y/N]:
·     channel band-width
wlan radio channel default命令用来将设备上所有AP的全部射频恢复为缺省的工作信道模式。
使用本命令可将AC上所有AP的全部射频恢复为缺省的工作信道模式,即自动选择信道并解锁模式。本命令的生效范围为AC上的所有AP和AP组,无论AP当前是否处于在线状态。
# 将设备上所有AP的全部射频恢复为缺省的工作信道模式。
[Sysname] wlan radio channel default
Restoring the default working channels might log off some online clients. Continue anyway? [Y/N]:y
wlan radio max-power default命令用来将设备上所有AP的全部射频恢复为缺省的最大传输功率。
使用本命令可将AC上所有AP的全部射频恢复为缺省的最大传输功率,即射频支持的最大传输功率。本命令的生效范围为AC上的所有AP和AP组,无论AP当前是否处于在线状态。
# 将设备上所有AP的全部射频恢复为缺省的最大传输功率。
[Sysname] wlan radio max-power default
wlan retransmit-frame optimization命令用来配置射频发送数据包重传率的优化参数值。
undo wlan retransmit-frame optimization命令用来恢复缺省情况。
wlan retransmit-frame optimization value
未配置射频发送数据包重传率的优化参数值。
value:射频发送数据包重传率的优化参数值,取值范围为0~1000。该数值越小,射频发送数据包重传率越小。
射频发送数据包重传率是指射频重传的包占所有发送包的百分比。
配置本命令后,设备会重新对射频发送数据包的重传率进行优化计算。
# 配置射频发送数据包重传率的优化参数值为100。
[Sysname] wlan retransmit-frame optimization 100
本站点使用Cookies,继续浏览表示您同意我们使用Cookies。 Cookies和隐私政策>
