09-安全
09-攻击检测与防范命令
本章节下载 09-攻击检测与防范命令  (727.49 KB)
09-攻击检测与防范命令
  录
1 攻击检测与防范
1.1 攻击检测与防范配置命令
1.1.1 ack-flood action
1.1.2 ack-flood detect
1.1.3 ack-flood detect non-specific
1.1.4 ack-flood threshold
1.1.5 attack-defense apply policy(interface view)
1.1.6 attack-defense apply policy(security zone view)
1.1.7 attack-defense local apply policy
1.1.8 attack-defense login reauthentication-delay
1.1.9 attack-defense policy
1.1.10 attack-defense signature log non-aggregate
1.1.11 attack-defense tcp fragment enable
1.1.12 attack-defense top-attack-statistics enable
1.1.13 client-verify dns enable(interface view)
1.1.14 client-verify dns enable(security zone view)
1.1.15 client-verify http enable(interface view)
1.1.16 client-verify http enable(security zone view)
1.1.17 client-verify protected ip
1.1.18 client-verify protected ipv6
1.1.19 client-verify tcp enable(interface view)
1.1.20 client-verify tcp enable(security zone view)
1.1.21 display attack-defense flood statistics ip(for interface)
1.1.22 display attack-defense flood statistics ip(for security zone)
1.1.23 display attack-defense flood statistics ipv6(for interface)
1.1.24 display attack-defense flood statistics ipv6(for security zone)
1.1.25 display attack-defense policy
1.1.26 display attack-defense policy ip
1.1.27 display attack-defense policy ipv6
1.1.28 display attack-defense scan attacker ip(for interface)
1.1.29 display attack-defense scan attacker ip( for security zone)
1.1.30 display attack-defense scan attacker ipv6(for interface)
1.1.31 display attack-defense scan attacker ipv6(for security zone)
1.1.32 display attack-defense scan victim ip(for interface)
1.1.33 display attack-defense scan victim ip (for security zone)
1.1.34 display attack-defense scan victim ipv6(for interface)
1.1.35 display attack-defense scan victim ipv6(for security zone)
1.1.36 display attack-defense statistics interface
1.1.37 display attack-defense statistics local
1.1.38 display attack-defense statistics security-zone
1.1.39 display attack-defense top-attack-statistics
1.1.40 display client-verify protected ip
1.1.41 display client-verify protected ipv6
1.1.42 display client-verify trusted ip
1.1.43 display client-verify trusted ipv6
1.1.44 dns-flood action
1.1.45 dns-flood detect
1.1.46 dns-flood detect non-specific
1.1.47 dns-flood port
1.1.48 dns-flood threshold
1.1.49 exempt acl
1.1.50 fin-flood action
1.1.51 fin-flood detect
1.1.52 fin-flood detect non-specific
1.1.53 fin-flood threshold
1.1.54 http-flood action
1.1.55 http-flood detect
1.1.56 http-flood detect non-specific
1.1.57 http-flood port
1.1.58 http-flood threshold
1.1.59 icmp-flood action
1.1.60 icmp-flood detect ip
1.1.61 icmp-flood detect non-specific
1.1.62 icmp-flood threshold
1.1.63 icmpv6-flood action
1.1.64 icmpv6-flood detect ipv6
1.1.65 icmpv6-flood detect non-specific
1.1.66 icmpv6-flood threshold
1.1.67 reset attack-defense policy flood
1.1.68 reset attack-defense statistics interface
1.1.69 reset attack-defense top-attack-statistics
1.1.70 reset attack-defense statistics local
1.1.71 reset attack-defense statistics security-zone
1.1.72 reset client-verify protected statistics
1.1.73 reset client-verify trusted
1.1.74 rst-flood action
1.1.75 rst-flood detect
1.1.76 rst-flood detect non-specific
1.1.77 rst-flood threshold
1.1.78 scan detect
1.1.79 signature { large-icmp | large-icmpv6 } max-length
1.1.80 signature detect
1.1.81 signature level action
1.1.82 signature level detect
1.1.83 syn-ack-flood action
1.1.84 syn-ack-flood detect
1.1.85 syn-ack-flood detect non-specific
1.1.86 syn-ack-flood threshold
1.1.87 syn-flood action
1.1.88 syn-flood detect
1.1.89 syn-flood detect non-specific
1.1.90 syn-flood threshold
1.1.91 udp-flood action
1.1.92 udp-flood detect
1.1.93 udp-flood detect non-specific
1.1.94 udp-flood threshold
1.1.95 whitelist enable (interface view)
1.1.96 whitelist enable (security zone view)
1.1.97 whitelist global enable
1.1.98 whitelist object-group
1 攻击检测与防范
设备暂不支持安全域相关内容。
1.1  攻击检测与防范配置命令
ack-flood action命令用来配置ACK flood攻击防范的全局处理行为。
undo ack-flood action命令用来恢复缺省情况。
ack-flood action { client-verify | drop | logging } *
不对检测到的ACK flood攻击采取任何措施。
攻击防范策略视图
client-verify:表示自动将受到攻击的IP地址添加到TCP客户端验证的受保护IP列表中。若客户端验证功能已使能,则对客户端与受保护IP地址之间的连接进行代理。
drop:表示丢弃攻击报文,即设备检测到攻击发生后,向被攻击者发送的后续所有ACK报文都会被丢弃。
logging:表示输出告警日志,即设备检测到攻击发生时,生成告警信息,生成的告警信息将被发送到日志系统。
本命令中client-verify参数的使用需要和TCP客户端验证功能配合。使能了TCP客户端验证功能的接口或安全域检测到ACK flood攻击时,若本命令中指定了client-verify参数,则设备会将受攻击的IP地址动态添加到相应客户端验证的受保护IP列表中,并对与这些IP地址建立的连接进行代理。若接口或安全域上未使能相应的代理功能,则不会对任何连接进行代理。
# 在攻击防范策略atk-policy-1中配置ACK flood攻击防范的全局处理行为是丢弃后续报文。
[Sysname] attack-defense policy atk-policy-1
[Sysname-attack-defense-policy-atk-policy-1] ack-flood action drop
·     ack-flood threshold
·     ack-flood detect
·     ack-flood detect non-specific
·     client-verify tcp enable
ack-flood detect命令用来开启对指定IP地址的ACK flood攻击防范检测,并配置ACK flood攻击防范的触发阈值和对ACK flood攻击的处理行为。
undo ack-flood detect命令用来关闭对指定IP地址的ACK flood攻击防范检测。
ack-flood detect { ip ipv4-address | ipv6 ipv6-address } [ vpn-instance vpn-instance-name ] [ threshold threshold-value ] [ action { { client-verify | drop | logging } * | none } ]
undo ack-flood detect { ip ipv4-address | ipv6 ipv6-address } [ vpn-instance vpn-instance-name ]
未对任何指定IP地址开启ACK flood攻击防范检测。
攻击防范策略视图
ip ipv4-address:指定要保护的IPv4地址。该IPv4地址不能为255.255.255.255或0.0.0.0。
ipv6 ipv6-address:指定要保护的IPv6地址。
vpn-instance vpn-instance-name:受保护IP地址所属的VPN实例。其中,vpn-instance-name表示MPLS L3VPN的VPN实例名称,为1~31个字符的字符串,区分大小写。若未指定本参数,则表示该保护IP地址属于公网。
threshold threshold-value:指定ACK flood攻击防范的触发阈值。其中,threshold-value为向指定IP地址每秒发送的ACK报文数目,取值范围为1~1000000。
action:设置对ACK flood攻击的处理行为。若未指定本参数,则表示采用ACK flood攻击防范的全局处理行为。
client-verify:表示自动将被攻击的IP地址添加到TCP客户端验证的受保护IP列表中。若客户端验证功能已使能,则对客户端与受保护IP地址之间的连接进行代理。
none:表示不采取任何动作。
每个攻击防范策略下可以同时对多个IP地址配置ACK flood攻击防范检测。
使能ACK flood攻击防范后,设备处于攻击检测状态,当它监测到向指定IP地址发送ACK报文的速率持续达到或超过了触发阈值时,即认为该IP地址受到了ACK flood攻击,则进入攻击防范状态,并根据配置启动相应的防范措施。此后,当设备检测到向该服务器发送报文的速率低于恢复阈值(触发阈值的3/4)时,即认为攻击结束,则由攻击防范状态恢复为攻击检测状态,并停止执行防范措施。
# 在攻击防范策略atk-policy-1中开启对IP地址192.168.1.2的ACK flood攻击防范检测,并指定触发阈值为2000。当设备监测到向该IP地址每秒发送的ACK报文数持续达到或超过2000时,启动ACK flood攻击防范。
[Sysname-attack-defense-policy-atk-policy-1] ack-flood detect ip 192.168.1.2 threshold 2000
·     ack-flood action
ack-flood detect non-specific命令用来对所有非受保护IP地址开启ACK flood攻击防范检测。
undo ack-flood detect non-specific命令用来关闭对所有非受保护IP地址的ACK flood攻击防范检测。
未对任何非受保护IP地址开启ACK flood攻击防范检测。
攻击防范策略视图
对所有未配置具体攻击防范策略的IP地址开启ACK flood攻击防范检测后,设备将采用全局的阈值设置(由ack-flood threshold命令设置)和处理行为(由ack-flood action命令配置)对这些IP地址进行保护。
# 在攻击防范策略atk-policy-1中,对所有非受保护IP地址开启ACK flood攻击防范检测。
[Sysname-attack-defense-policy-atk-policy-1] ack-flood detect non-specific
·     ack-flood action
·     ack-flood detect
ack-flood threshold命令用来配置ACK flood攻击防范的全局触发阈值。
undo ack-flood threshold命令用来恢复缺省情况。
ack-flood threshold threshold-value
ACK flood攻击防范的全局触发阈值为1000。
攻击防范策略视图
threshold-value:指定向某IP地址每秒发送的ACK报文数目,取值范围为1~1000000。使能ACK flood攻击防范后,设备处于攻击检测状态,当它监测到向某IP地址发送ACK报文的速率持续达到或超过了该触发阈值时,即认为该IP地址受到了ACK flood攻击,则进入攻击防范状态,并根据配置启动相应的防范措施。
对于未专门配置ACK flood攻击防范检测的IP地址,设备采用全局的阈值设置来进行保护。阈值的取值需要根据实际网络应用场景进行调整,对于正常情况下到被保护对象(HTTP服务器或者FTP服务器)的ACK报文流量较大的应用场景,建议调大触发阈值,以免阈值太小对正常的业务流量造成影响;对于网络状况较差,且对攻击流量比较敏感的场景,可以适当调小触发阈值。
# 在攻击防范策略atk-policy-1中配置ACK flood攻击防范的全局触发阈值为100,即当设备监测到向某IP地址每秒发送的ACK报文数持续达到或超过100时,启动ACK flood攻击防范。
[Sysname-attack-defense-policy-atk-policy-1] ack-flood threshold 100
·     ack-flood action
·     ack-flood detect
attack-defense apply policy命令用来在接口上应用攻击防范策略。
undo attack-defense apply policy命令用来恢复缺省情况。
attack-defense apply policy policy-name
接口上未应用任何攻击防范策略。
policy-name:攻击防范策略名称,为1~31个字符的字符串,不区分大小写。合法取值包括大写字母、小写字母、数字、特殊字符“_”和“-”。
一个接口上只能应用一个攻击防范策略(可多次配置,最后一次配置的有效),但一个攻击防范策略可应用到多个接口上。
# 将攻击防范策略atk-policy-1应用到接口GigabitEthernet2/1/1上。
[Sysname] interface gigabitethernet 2/1/1
[Sysname-GigabitEthernet2/1/1] attack-defense apply policy atk-policy-1
·     attack-defense policy
·     display attack-defense policy
attack-defense apply policy命令用来在安全域上应用攻击防范策略。
安全域上未应用任何攻击防范策略。
安全域视图
一个安全域上只能应用一个攻击防范策略(多次执行本命令,最后一次执行的命令生效),但一个攻击防范策略可应用到多个安全域上。
# 将攻击防范策略atk-policy-1应用到安全域DMZ上。
[Sysname] security-zone name dmz
[Sysname-security-zone-DMZ] attack-defense apply policy atk-policy-1
attack-defense local apply policy命令用来在本机应用安全攻击防范策略。
undo attack-defense local apply policy命令用来恢复缺省情况。
attack-defense local apply policy policy-name
本机未应用任何攻击防范策略。
可以通过在本机上应用攻击防范策略提高对目的地址为本机的攻击报文的处理效率。
·     本机只能应用一个攻击防范策略(可多次配置,最后一次配置的有效),但一个攻击防范策略除了可以应用到本机外,还可应用到多个接口上。
·     当同时在接口和本机应用攻击防范策略时,目的地址是本机的报文到达设备后,将会被根据应用在接口上的策略和应用在本机的策略先后检测两次。
# 在本机应用攻击防范策略atk-policy-1。
[Sysname] attack-defense local apply policy atk-policy-1
attack-defense login reauthentication-delay命令用来配置Login用户登录失败后重新进行认证的等待时长。
undo attack-defense login reauthentication-delay命令用来恢复缺省情况。
attack-defense login reauthentication-delay seconds
Login用户登录失败后重新进行认证不需要等待。
seconds:设备管理用户登录失败后重新进行认证的等待时长,取值范围为4~60,单位为秒。
Login用户登录失败后,若设备上配置了重新进行认证的等待时长,则系统将会延迟一定的时长之后再允许用户进行认证,可以避免设备受到字典式攻击。
Login用户延迟认证功能,只要配置了延迟认证等待时间,即可生效。
# 配置Login用户登录失败后重新进行认证的等待时长为5秒钟。
[Sysname] attack-defense login reauthentication-delay 5
attack-defense policy命令用来创建一个攻击防范策略,并进入攻击防范策略视图。如果指定的攻击防范策略已经存在,则直接进入攻击防范策略视图。
undo attack-defense policy命令用来删除指定的攻击防范策略。
attack-defense policy policy-name
undo attack-defense policy policy-name
不存在任何攻击防范策略。
# 创建攻击防范策略atk-policy-1,并进入攻击防范策略视图。
·     attack-defense apply policy
attack-defense signature log non-aggregate命令用来指定对单包攻击防范日志非聚合输出。
undo attack-defense signature log non-aggregate命令用来恢复缺省情况。
单包攻击防范的日志信息经系统聚合后再输出。
对日志进行聚合输出是指,在一定时间内,对在同一个接口或安全域上检测到的相同攻击类型、相同攻击防范动作、相同的源/目的地址以及属于相同VPN的单包攻击的所有日志聚合成一条日志输出。通常不建议开启单包攻击防范的日志非聚合输出功能,因为在单包攻击较为频繁的情况下,它会导致大量日志信息输出,占用控制台的显示资源。
# 开启对单包攻击防范日志的非聚合输出功能。
[Sysname] attack-defense signature log non-aggregate
·     signature detect
attack-defense tcp fragment enable命令用来开启TCP分片攻击防范功能。
undo attack-defense tcp fragment enable命令用来关闭TCP分片攻击防范功能。
TCP分片攻击防范功能处于开启状态。
设备的包过滤功能一般是通过判断TCP首个分片中的五元组(源IP地址、源端口号、目的IP地址、目的端口号、传输层协议号)信息来决定后续TCP分片是否允许通过。RFC 1858对TCP分片报文进行了规定,认为TCP分片报文中,首片报文中TCP报文长度小于20字节,或后续分片报文中分片偏移量等于8字节的报文为TCP分片攻击报文。这类报文可以成功绕过上述包过滤功能,对设备造成攻击。为防止这类攻击,可以在设备上开启TCP分片攻击防范功能,对TCP分片攻击报文进行丢弃。
如果设备上开启了TCP分片攻击防范功能,并应用了单包攻击防范策略,则TCP分片攻击防范功能会先于单包攻击防范策略检测并处理入方向的TCP报文。
# 开启TCP分片攻击防范功能。
[Sysname] attack-defense tcp fragment enable
attack-defense top-attack-statistics enable命令用来开启攻击排名的Top统计功能。
undo attack-defense top-attack-statistics enable命令用来关闭攻击排名的Top统计功能。
攻击排名的Top统计功能处于关闭状态。
可以通过display attack-defense top-attack-statistics命令查看攻击数目的Top排名统计信息。
# 开启攻击排名的Top统计功能。
[Sysname] attack-defense top-attack-statistics enable
·     display attack-defense top-attack-statistics
client-verify dns enable命令用来在接口上开启DNS客户端验证功能。
undo client-verify dns enable命令用来关闭接口上的DNS客户端验证功能。
接口上的DNS客户端验证功能处于关闭状态。
该功能一般应用在设备连接外部网络的接口上,用来保护内部网络的DNS服务器免受外部网络中非法客户端发起的DNS flood攻击。当设备监测到某服务器受到了DNS flood攻击时,会根据配置的攻击防范处理行为启动相应的防范措施。若防范处理行为配置为对攻击报文进行客户端验证(指定参数为client-verify),则设备会将该服务器IP地址添加到受保护IP表项中(可通过display client-verify dns protected ip命令查看),对后续新建DNS query请求连接的协商报文进行合法性检查,过滤非法客户端发起的DNS query请求报文。
# 在接口GigabitEthernet2/1/1上开启DNS客户端验证功能。
[Sysname-GigabitEthernet2/1/1] client-verify dns enable
·     client-verify dns protected ip
·     display client-verify dns protected ip
client-verify dns enable命令用来在安全域上开启DNS客户端验证功能。
undo client-verify dns enable命令用来关闭安全域上的DNS客户端验证功能。
安全域上的DNS客户端验证功能处于关闭状态。
安全域视图
该功能一般应用在设备连接外部网络的安全域上,用来保护内部网络的DNS服务器免受外部网络中非法客户端发起的DNS flood攻击。当设备监测到某服务器受到了DNS flood攻击时,会根据配置的攻击防范处理行为启动相应的防范措施。若防范处理行为配置为对攻击报文进行客户端验证(指定参数为client-verify),则设备会将该服务器IP地址添加到受保护IP表项中(可通过display client-verify dns protected ip命令查看),对后续新建DNS query请求连接的协商报文进行合法性检查,过滤非法客户端发起的DNS query请求报文。
# 在安全域DMZ上开启DNS客户端验证功能。
[Sysname-security-zone-DMZ] client-verify dns enable
client-verify http enable命令用来在接口上开启HTTP客户端验证功能。
undo client-verify http enable命令用来关闭接口上的HTTP客户端验证功能。
接口上的HTTP客户端验证功能处于关闭状态。
该功能一般应用在设备连接外部网络的接口上,用来保护内部网络的服务器免受外部网络中非法客户端发起的HTTP flood攻击。当设备监测到某服务器受到了HTTP flood攻击时,会根据配置的攻击防范处理行为启动相应的防范措施。若防范处理行为配置为对攻击报文进行客户端验证(指定参数为client-verify),则设备会将该服务器IP地址添加到受保护IP表项中(可通过display client-verify http protected ip命令查看),对后续新建HTTP get请求连接的协商报文进行合法性检查,过滤非法客户端发起的HTTP get请求报文。
# 在接口GigabitEthernet2/1/1上开启HTTP客户端验证功能。
[Sysname-GigabitEthernet2/1/1] client-verify http enable
·     client-verify http protected ip
·     display client-verify http protected ip
client-verify http enable命令用来在安全域上开启HTTP客户端验证功能。
undo client-verify http enable命令用来关闭安全域上的HTTP客户端验证功能。
安全域上的HTTP客户端验证功能处于关闭状态。
安全域视图
该功能一般应用在设备连接外部网络的安全域上,用来保护内部网络的服务器免受外部网络中非法客户端发起的HTTP flood攻击。当设备监测到某服务器受到了HTTP flood攻击时,会根据配置的攻击防范处理行为启动相应的防范措施。若防范处理行为配置为对攻击报文进行客户端验证(指定参数为client-verify),则设备会将该服务器IP地址添加到受保护IP表项中(可通过display client-verify http protected ip命令查看),对后续新建HTTP get请求连接的协商报文进行合法性检查,过滤非法客户端发起的HTTP get请求报文。
# 在安全域DMZ上开启HTTP客户端验证功能。
[Sysname- security-zone-DMZ] client-verify http enable
client-verify protected ip命令用来配置IPv4类型客户端验证的受保护IP地址。
undo client-verify protected ip命令用来删除指定的受保护IP地址。
client-verify { dns | http | tcp } protected ip destination-ip-address [ vpn-instance vpn-instance-name ] [ port port-number ]
undo client-verify { dns | http | tcp } protected ip destination-ip-address [ vpn-instance vpn-instance-name ] [ port port-number ]
不存在任何IPv4类型客户端验证受保护IP地址,即客户端验证功能未保护任何IPv4地址。
dns:指定DNS客户端验证功能。
http:指定HTTP客户端验证功能。
tcp:指定TCP客户端验证功能。
destination-ip-address:指定受客户端验证保护的IPv4地址,即会对向该目的地址发送的连接请求进行代理。
vpn-instance vpn-instance-name:受客户端验证保护的IP地址所属的VPN实例。其中,vpn-instance-name表示MPLS L3VPN的VPN实例名称,为1~31个字符的字符串,区分大小写。若未指定本参数,则表示该受保护IP地址属于公网。
port port-number:指定受客户端验证保护的端口号,取值范围为1~65535。若未指定本参数,对于DNS客户端验证的受保护IP,则表示对端口53的DNS query连接请求做代理;对于HTTP客户端验证的受保护IP,则表示对端口80的HTTP GET连接请求做代理;对于TCP客户端验证的受保护IP,则表示对所有端口的TCP连接请求做代理。
可通过多次执行本命令添加多个IPv4类型客户端验证受保护IP地址。
# 配置一个TCP客户端验证受保护IPv4地址为2.2.2.5、受保护端口号为25。
[Sysname] client-verify tcp protected ip 2.2.2.5 port 25
# 配置一个DNS客户端验证受保护IPv4地址为2.2.2.5、受保护端口号为50。
[Sysname] client-verify dns protected ip 2.2.2.5 port 50
·     display client-verify protected ip
client-verify protected ipv6命令用来配置IPv6类型客户端验证的受保护IP地址。
undo client-verify protected ipv6命令用来删除指定的受保护IP地址。
client-verify { dns | http | tcp } protected ipv6 destination-ipv6-address [ vpn-instance vpn-instance-name ] [ port port-number ]
undo client-verify { dns | http | tcp } protected ipv6 destination-ipv6-address [ vpn-instance vpn-instance-name ] [ port port-number ]
不存在任何IPv6类型客户端验证受保护IP地址,即客户端验证功能未保护任何IPv6地址。
dns:指定DNS客户端验证功能。
http:指定HTTP客户端验证功能。
tcp:指定TCP客户端验证功能。
destination-ipv6-address:指定受客户端验证保护的IPv6地址,即会对向该目的地址发送的连接请求进行代理。对于受TCP客户端验证保护的IPv6地址,发送的是TCP连接请求;对于受DNS客户端验证保护的IPv6地址,发送的是DNS query请求;对于受HTTP客户端验证保护的IPv6地址,发送的是HTTP get连接请求。
vpn-instance vpn-instance-name:受客户端验证保护的IPv6地址所属的VPN实例。其中,vpn-instance-name表示MPLS L3VPN的VPN实例名称,为1~31个字符的字符串,区分大小写。若未指定本参数,则表示该受保护IP地址属于公网。
可通过多次执行本命令添加多个IPv6类型客户端验证受保护IP地址。
# 配置一个TCP客户端验证受保护IPv6地址为2013::12、受保护端口号为23。
[Sysname] client-verify tcp protected ipv6 2013::12 port 23
# 配置一个HTTP客户端验证受保护IPv6地址为2013::12。
[Sysname] client-verify http protected ipv6 2013::12
·     display client-verify protected ipv6
client-verify tcp enable命令用来在接口上开启TCP客户端验证功能。
undo client-verify tcp enable命令用来关闭接口上的TCP客户端验证功能。
client-verify tcp enable [ mode { syn-cookie | safe-reset } ]
接口上的TCP客户端验证功能处于关闭状态。
mode:指定TCP客户端验证的工作模式。不指定该参数时,则表示工作模式为syn-cookie
syn-cookie:指定TCP客户端验证的工作模式为syn-cookie,即开启TCP客户端验证双向代理。
safe-reset:指定TCP客户端验证的工作模式为safe-reset,即开启TCP客户端验证单向代理。
该功能一般应用在设备连接外部网络的接口上,用来保护内部网络的服务器免受外部网络中非法客户端发起的SYN flood、SYN-ACK flood、RST flood、FIN flood、ACK flood攻击。当设备监测到某服务器受到了SYN flood、SYN-ACK flood、RST flood、FIN flood、ACK flood攻击时,会根据配置的攻击防范处理行为启动相应的防范措施。若防范处理行为配置为对攻击报文进行客户端验证(指定参数为client-verify),则设备会将该服务器IP地址添加到受保护IP表项中(可通过display client-verify tcp protected ip命令查看),并按照指定的单向或双向工作模式,对后续新建TCP连接的协商报文进行合法性检查,过滤非法客户端发起的TCP连接报文。TCP客户端验证功能支持两种代理模式:
·     单向代理模式(safe-reset):是指仅对TCP连接的正向报文进行处理。
·     双向代理模式(syn-cookie):是指对TCP连接的正向和反向报文都进行处理。
用户可以根据实际的组网情况选择不同的代理模式。若从客户端发出的报文经过使能了TCP客户端验证功能的设备时,而从服务器端发出的报文不经过该设备,此时只能使用单向代理模式;从客户端发出的报文经和从服务器端发出的报文都经过使能了TCP客户端验证功能的设备时,此时可以使用单向代理模式,也可以使用双向代理模式;代理只适合在入接口使能,否则无法建立正常连接。
# 在接口GigabitEthernet2/1/1上开启TCP客户端验证功能,并指定工作模式为双向代理。
[Sysname-GigabitEthernet2/1/1] client-verify tcp enable mode syn-cookie
·     client-verify tcp protected ip
·     display client-verify tcp protected ip
client-verify tcp enable命令用来在安全域上开启TCP客户端验证功能。
undo client-verify tcp enable命令用来关闭安全域上的TCP客户端验证功能。
安全域上的TCP客户端验证功能处于关闭状态。
安全域视图
该功能一般应用在设备连接外部网络的安全域上,用来保护内部网络的服务器免受外部网络中非法客户端发起的SYN flood、SYN-ACK flood、RST flood、FIN flood、ACK flood攻击。当设备监测到某服务器受到了SYN flood、SYN-ACK flood、RST flood、FIN flood、ACK flood攻击时,会根据配置的攻击防范处理行为启动相应的防范措施。若防范处理行为配置为对攻击报文进行客户端验证(指定参数为client-verify),则设备会将该服务器IP地址添加到受保护IP表项中(可通过display client-verify tcp protected ip命令查看),并按照指定的单向或双向工作模式,对后续新建TCP连接的协商报文进行合法性检查,过滤非法客户端发起的TCP连接报文。TCP客户端验证功能支持两种代理模式:
用户可以根据实际的组网情况选择不同的代理模式。若从客户端发出的报文经过使能了TCP客户端验证功能的设备时,而从服务器端发出的报文不经过该设备,此时只能使用单向代理模式;从客户端发出的报文经和从服务器端发出的报文都经过使能了TCP客户端验证功能的设备时,此时可以使用单向代理模式,也可以使用双向代理模式;代理只适合在入安全域上使能,否则无法建立正常连接。
# 在安全域DMZ上开启TCP客户端验证功能,并指定工作模式为单向代理。
[Sysname-security-zone-DMZ] client-verify tcp enable mode safe-reset
display attack-defense flood statistics ip命令用来显示IPv4 flood攻击防范统计信息。
独立运行模式:
display attack-defense { ack-flood | dns-flood | fin-flood | flood | http-flood | icmp-flood | rst-flood | syn-ack-flood | syn-flood | udp-flood } statistics ip [ ip-address [ vpn vpn-instance-name ] ] [ [ interface interface-type interface-number | local ] [ slot slot-number ] ] [ count ]
IRF模式:
display attack-defense { ack-flood | dns-flood | fin-flood | flood | http-flood | icmp-flood | rst-flood | syn-ack-flood | syn-flood | udp-flood } statistics ip [ ip-address [ vpn vpn-instance-name ] ] [ [ interface interface-type interface-number | local ] [ chassis chassis-number slot slot-number ] ] [ count ]
ack-flood:显示ACK flood攻击防范统计信息。
dns-flood:显示DNS flood攻击防范统计信息。
fin-flood:显示FIN flood攻击防范统计信息。
flood:显示所有类型的IPv4 flood攻击防范统计信息。
http-flood:显示HTTP flood攻击防范统计信息。
icmp-flood:显示ICMP flood攻击防范统计信息。
rst-flood:显示RST flood攻击防范统计信息。
syn-ack-flood:显示SYN-ACK flood攻击防范统计信息。
syn-flood:显示SYN flood攻击防范统计信息。
udp-flood:显示UDP flood攻击防范统计信息。
ip-address:显示指定目的IPv4地址的flood攻击防范统计信息。若未指定本参数,则显示指定接口或本机上的所有flood攻击防范统计信息。
vpn-instance vpn-instance-name:指定IPv4地址所属的VPN实例。其中,vpn-instance-name表示MPLS L3VPN的VPN实例名称,为1~31个字符的字符串,区分大小写。若未指定本参数,则表示该IPv4地址属于公网。
interface interface-type interface-number:显示指定接口的flood攻击防范统计信息,interface-type interface-number表示接口类型和接口编号。
local:显示本机上进行检测的flood攻击防范统计信息。
slot slot-number:显示指定slot上的flood攻击防范统计信息,slot-number表示槽位号(固定取值为0)。该参数仅在指定本机或指定全局接口(例如Tunnel接口)时可见。若未指定本参数,则表示显示所有slot或指定全局接口在所有slot上的flood攻击防范统计信息命令执行结果相同。(独立运行模式)
chassis chassis-number slot slot-number:显示指定成员设备的指定slot上的flood攻击防范统计信息,chassis-number表示设备在IRF中的成员编号,slot-number表示槽位号(固定取值为0)。该参数仅在指定本机或指定全局接口(例如Tunnel接口)时可见。若未指定本参数,则表示显示所有slot成员设备或指定全局接口在所有slot成员设备上的flood攻击防范统计信息。(IRF模式)
count:显示符合指定条件的被进行flood攻击检测的IPv4地址数目。
由于flood攻击不关心源地址,因此本命令显示的是对指定目的IPv4地址的攻击防范统计信息。
若未指定interfacelocal参数,则显示所有接口以及本机上的flood攻击防范统计信息。
# 显示所有类型的IPv4 flood攻击防范统计信息。(独立运行模式)
<Sysname> display attack-defense flood statistics ip
Slot 0:
IP address      VPN         Detected on  Detect type   State    PPS    Dropped
192.168.100.221 a0123456789 GE2/1/2      SYN-ACK-FLOOD Normal   1000   4294967295
201.55.7.45     asd         GE2/1/2      SYN-ACK-FLOOD Normal   1000   111111111
192.168.11.5    --          GE2/1/3      ACK-FLOOD     Normal   1000   222222222
201.55.7.44     --          GE2/1/4      DNS-FLOOD     Normal   1000   111111111
192.168.11.4    --          GE2/1/5      ACK-FLOOD     Normal   1000   22222222
# 显示所有类型的IPv4 flood攻击防范统计信息。(IRF模式)
Slot 0 in chassis 1:
192.168.100.221 a0123456789 GE1/2/1/2      SYN-ACK-FLOOD Normal   1000   4294967295
201.55.7.45     asd         GE1/2/1/2 SYN-ACK-FLOOD Normal   1000   111111111
192.168.11.5    --          GE1/2/1/3 ACK-FLOOD     Normal   1000   222222222
201.55.7.44     --          GE1/2/1/4 DNS-FLOOD     Normal   1000   111111111
192.168.11.4    --          GE1/2/1/5 ACK-FLOOD     Normal   1000   22222222
# 显示所有类型的flood攻击检测的IPv4地址数目。(独立运行模式)
<Sysname> display attack-defense flood statistics ip count
Slot 0:
Totally 2 flood entries.
# 显示所有类型的flood攻击检测的IPv4地址数目。(IRF模式)
Slot 0:
表1-1 display attack-defense flood statistics ip命令显示信息描述表
IP address
被检测的目的IPv4地址
VPN
目的IPv4地址所属的MPLS L3VPN实例名称,属于公网时显示为“--”
Detected on
进行攻击检测的位置,包括接口和本机(Local)
Detect type
检测的flood攻击类型
接口或本机是否处于攻击状态,可包括以下取值:
·     Attacked:受攻击状态
·     Normal:正常状态(当前并未受到攻击)
PPS
指定的目的IPv4地址收到flood攻击报文的速率(单位为报文每秒)
Dropped
接口或本机丢弃的flood攻击报文数目
被检测的IPv4地址数目
独立运行模式:
display attack-defense { ack-flood | dns-flood | fin-flood | flood | icmp-flood | rst-flood | syn-flood | syn-ack-flood | udp-flood } statistics ip [ ip-address [vpn vpn-instance-name ] ] [ security-zone zone-name ] [ slot slot-number ] [ count ]
IRF模式:
display attack-defense { ack-flood | dns-flood | fin-flood | flood | icmp-flood | rst-flood | syn-flood | syn-ack-flood | udp-flood } statistics ip [ ip-address [vpn vpn-instance-name ] ] [ security-zone zone-name ] [ chassis chassis-number slot slot-number] [ count ]
vpn vpn-instance-name:指定IPv4地址所属的VPN实例。其中,vpn-instance-name表示MPLS L3VPN的VPN实例名称,为1~31个字符的字符串,区分大小写。若未指定本参数,则表示该IPv4地址属于公网。
count:仅显示符合指定条件的被进行flood攻击检测的IPv4地址数目。
security-zone zone-name:显示指定安全域的flood攻击防范统计信息,zone-name表示安全域名称,为1~31个字符的字符串,不区分大小写,不能包含字符“-”。
slot slot-number:显示指定slot上的flood攻击防范统计信息,slot-number表示槽位号(固定取值为0)。若未指定本参数,则表示显示所有slot上的flood攻击防范统计信息命令执行结果相同。(独立运行模式)
chassis chassis-number slot slot-number:显示指定成员设备的指定slot上的flood攻击防范统计信息,chassis-number表示设备在IRF中的成员编号,slot-number表示槽位号(固定取值为0)。若未指定本参数,则表示显示所有slot成员设备上的flood攻击防范统计信息。(IRF模式)
slot 0:
192.168.100.221 a0123456789 Trust1       SYN-ACK-FLOOD Normal   1000   4294967295
201.55.7.45     asd         Trust1       SYN-ACK-FLOOD Normal   1000   111111111
192.168.11.5    --          Trust2       ACK-FLOOD     Normal   1000   222222222
201.55.7.44     --          Trust3       DNS-FLOOD     Normal   1000   111111111
192.168.11.4    --          Trust4       ACK-FLOOD     Normal   1000   22222222
                01234567890
123456789
Slot 0:
表1-2 display attack-defense flood statistics ip命令显示信息描述表
IP address
被检测的目的IPv4地址
VPN
Detect type
检测的flood攻击类型
Detected on
进行攻击检测的位置
安全域是否处于攻击状态,可包括以下取值:
·     Attacked:受攻击状态
PPS
指定的目的IPv4地址收到报文的速率(单位为报文每秒)
Dropped
安全域丢弃的flood攻击报文数目
被检测的IPv4地址数目
display attack-defense flood statistics ipv6命令用来显示IPv6 flood攻击防范统计信息。
独立运行模式:
display attack-defense { ack-flood | dns-flood | fin-flood | flood | http-flood | icmpv6-flood | rst-flood | syn-flood | syn-ack-flood | udp-flood } statistics ipv6 [ ipv6-address [ vpn vpn-instance-name ] ] [ [ interface interface-type interface-number | local ] [ slot slot-number ] ] [ count ]
IRF模式:
display attack-defense { ack-flood | dns-flood | fin-flood | flood | http-flood | icmpv6-flood | rst-flood | syn-flood | syn-ack-flood | udp-flood } statistics ipv6 [ ipv6-address [ vpn vpn-instance-name ] ] [ [ interface interface-type interface-number | local ] [ chassis chassis-number slot slot-number ] ] [ count ]
ack-flood:显示指定ACK flood类型统计信息。
dns-flood:显示指定DNS flood类型统计信息。
fin-flood:显示指定FIN flood类型统计信息。
flood:显示所有类型的IPv6 flood攻击防范统计信息。
icmpv6-flood:显示指定ICMPv6 flood类型统计信息。
rst-flood:显示指定RST flood类型统计信息。
syn-flood:显示指定SYN flood类型统计信息。
udp-flood:显示指定UDP flood类型统计信息。
ipv6-address:显示指定目的IPv6地址的flood攻击防范统计信息。若未指定本参数,则显示指定接口或本机上的所有flood攻击防范统计信息。
vpn vpn-instance-name:指定IPv6地址所属的VPN实例。其中,vpn-instance-name表示MPLS L3VPN的VPN实例名称,为1~31个字符的字符串,区分大小写。若未指定本参数,则表示该IPv6地址属于公网。
slot slot-number:显示指定slot上的flood攻击防范统计信息,slot-number表示槽位号(固定取值为0)。该参数仅在指定本机或指定显示全局接口(例如Tunnel接口)时可见。若未指定本参数,则表示显示本机上所有slot或指定全局接口在所有slot上的flood攻击防范统计信息命令执行结果相同。(独立运行模式)
count:仅显示符合指定条件的被进行flood攻击检测的IPv6地址数目。
由于flood攻击不关心源地址,因此本命令显示的是对指定目的IPv6地址的攻击防范统计信息。
# 显示所有类型的IPv6 flood攻击防范统计信息。(独立运行模式)
<Sysname> display attack-defense flood statistics ipv6
Slot 0:
IPv6 address    VPN         Detected on  Detect type   State    PPS    Dropped
2000::1011      a0123456789 GE2/1/2      SYN-FLOOD     Normal   0      4294967295
1::2            1222232     GE2/1/2      DNS-FLOOD     Normal   1000   111111111
1::3            --          GE2/1/3      SYN-ACK-FLOOD Normal   1000   222222222
1::4            --          GE2/1/4      ACK-FLOOD     Normal   1000   111111111
1::5            --          GE2/1/5      SYN-FLOOD     Normal   1000   22222222
# 显示所有类型的IPv6 flood攻击防范统计信息。(IRF模式)
2000::1011      a0123456789 GE1/2/1/2      SYN-FLOOD     Normal   0      4294967295
1::2            1222232     GE1/2/1/2 DNS-FLOOD     Normal   1000   111111111
1::3            --          GE1/2/1/3      SYN-ACK-FLOOD Normal   1000   222222222
1::4            --          GE1/2/1/4 ACK-FLOOD     Normal   1000   111111111
1::5            --          GE1/2/1/5 SYN-FLOOD     Normal   1000   22222222
# 显示所有类型的flood攻击检测的IPv6地址数目。(独立运行模式)
<Sysname> display attack-defense flood statistics ipv6 count
Slot 0:
Totally 5 flood entries.
# 显示所有类型的flood攻击检测的IPv6地址数目。(IRF模式)
Totaly 5 flood entries.
表1-3 display attack-defense flood statistics ipv6命令显示信息描述表
IPv6 address
被检测的目的IPv6地址
VPN
目的IPv6地址所属的MPLS L3VPN实例名称,属于公网时显示为“--”
Detected on
Detect type
检测的flood攻击类型
·     Attacked:受攻击状态
PPS
指定的目的IPv6地址收到报文的速率(单位为报文每秒)
Dropped
接口或本机丢弃的flood攻击报文数目
被检测的IPv6地址数目
独立运行模式:
display attack-defense { ack-flood | dns-flood | fin-flood |flood | http-flood | icmpv6-flood | rst-flood | syn-flood | syn-ack-flood | udp-flood } statistics ipv6 [ ipv6-address [ vpn vpn-instance-name ] ] [ security-zone zone-name ] [ slot slot-number ] [ count ]
IRF模式:
display attack-defense { ack-flood | dns-flood | fin-flood |flood | http-flood | icmpv6-flood | rst-flood | syn-flood | syn-ack-flood | udp-flood } statistics ipv6 [ ipv6-address [ vpn vpn-instance-name ] ] [ security-zone zone-name ] [ chassis chassis-number slot slot-number ] [ count ]
Ipv6-address:显示指定目的IPv6地址的flood攻击防范统计信息。
chassis chassis-number slot slot-number:显示指定成员设备指定slot的flood攻击防范统计信息,chassis-number表示设备在IRF中的成员编号,slot-number表示槽位号(固定取值为0)。若未指定本参数,则表示显示所有slot成员设备上的flood攻击防范统计信息。(IRF模式)
Slot 0:
2000::1011      a0123456789 Trust1       SYN-FLOOD     Normal   0      4294967295
1::2            1222232     Trust1       DNS-FLOOD     Normal   1000   111111111
1::3            --          Trust2       SYN-ACK-FLOOD Normal   1000   222222222
1::4            --          Trust3       ACK-FLOOD     Normal   1000   111111111
1::5            --          Trust4       SYN-FLOOD     Normal   1000   22222222
Slot 0:
表1-4 display attack-defense flood statistics ipv6命令显示信息描述表
IPv6 address
被检测的目的IPv6地址
VPN
Detect type
检测的flood攻击类型
Detected on
进行攻击检测的位置
·     Attacked:受攻击状态
PPS
Dropped
安全域丢弃的flood攻击报文数目
被检测的IPv6地址数目
display attack-defense policy用来显示攻击防范策略的配置信息。
display attack-defense policy [ policy-name ]
policy-name:攻击防范策略名称,为1~31个字符的字符串,不区分大小写。若未指定本参数,则表示显示所有攻击防范策略的摘要信息。
本命令显示的内容主要包括各类型攻击防范的使能情况、对攻击报文的处理方式和相关的阈值参数。
# 显示攻击防范策略abc的配置信息。
<Sysname> display attack-defense policy abc
          Attack-defense Policy Information
Policy name                        : abc
Applied list                       : GE2/1/1
                                     Vlan1
Exempt IPv4 ACL:                  : Not configured
Exempt IPv6 ACL:                  : vip
  Actions: CV-Client verify  BS-Block source  L-Logging  D-Drop  N-None
Signature attack defense configuration:
Signature name                     Defense      Level             Actions
Fragment                           Enabled      Info              L
Impossible                         Enabled      Info              L
Teardrop                           Disabled     Info              L
Tiny fragment                      Disabled     Info              L
IP option abnormal                 Disabled     Info              L
Smurf                              Disabled     Info              N
Traceroute                         Disabled     Medium            L,D
Ping of death                      Disabled     Low               L
Large ICMP                         Disabled     Medium            L,D
  Max length                       4000 bytes
Large ICMPv6                       Disabled     Low               L
TCP invalid flags                  Disabled     medium            L,D
TCP null flag                      Disabled     Low               L
TCP all flags                      Enabled      Info              L
TCP SYN-FIN flags                  Disabled     Info              L
TCP FIN only flag                  Enabled      Info              L
TCP Land                           Disabled     Info              L
Winnuke                            Disabled     Info              L
UDP Bomb                           Disabled     Info              L
UDP Snork                          Disabled     Info              L
UDP Fraggle                        Enabled      Info              L
IP option record route             Disabled     Info              L
IP option internet timestamp       Enabled      Info              L
IP option security                 Disabled     Info              L
IP option loose source routing     Enabled      Info              L
IP option stream ID                Disabled     Info              L
IP option strict source routing    Disabled     Info              L
IP option route alert              Disabled     Info              L
ICMP echo request                  Disabled     Info              L
ICMP echo reply                    Disabled     Info              L
ICMP source quench                 Disabled     Info              L
ICMP destination unreachable       Enabled      Info              L
ICMP redirect                      Enabled      Info              L
ICMP time exceeded                 Enabled      Info              L
ICMP parameter problem             Disabled     Info              L
ICMP timestamp request             Disabled     Info              L
ICMP timestamp reply               Disabled     Info              L
ICMP information request           Disabled     Info              L
ICMP information reply             Disabled     Medium            L,D
ICMP address mask request          Disabled     Medium            L,D
ICMP address mask reply            Disabled     Medium            L,D
ICMPv6 echo request                Enabled      Medium            L,D
ICMPv6 echo reply                  Disabled     Medium            L,D
ICMPv6 group membership query      Disabled     Medium            L,D
ICMPv6 group membership report     Disabled     Medium            L,D
ICMPv6 group membership reduction  Disabled     Medium            L,D
ICMPv6 destination unreachable     Enabled      Medium            L,D
ICMPv6 time exceeded               Enabled      Medium            L,D
ICMPv6 parameter problem           Disabled     Medium            L,D
ICMPv6 packet too big              Disabled     Medium            L,D
Scan attack defense configuration:
 Defense: Disabled
 Level: Medium
 Actions: L
Flood attack defense configuration:
Flood type      Global thres(pps)  Global actions  Service ports   Non-specific
SYN flood       1000               -               -               Disabled
ACK flood       1000               -               -               Enabled
SYN-ACK flood   1000               -               -               Disabled
RST flood       200                -               -               Enabled
FIN flood       1000               L,D             -               Disabled
UDP flood       1000               -               -               Disabled
ICMP flood      1000               -               -               Disabled
ICMPv6 flood    1000               CV              -               Disabled
DNS flood       10000              -               30,61 to 62     Enabled
HTTP flood      10000              -               80,8080         Enabled
Flood attack defense for protected IP addresses:
 Address                 VPN instance Flood type    Thres(pps)  Actions Ports
 1::1                    --           FIN-FLOOD     10          L,D     -
 192.168.1.1             A01234567890 SYN-ACK-FLOOD 10          -       -
                         123456789012
                         3456789
 1::1                    --           FIN-FLOOD     -           L       -
 2013:2013:2013:2013:    A0123456789  DNS-FLOOD     100         L,CV    53
 2013:2013:2013:2013
表1-5 display attack-defense policy命令显示信息描述表
Policy name
攻击防范策略名称
Applied list
攻击防范策略应用的对象列表,包括接口名称和本机(Local)
Exempt IPv4 ACL
IPv4例外列表
Exempt IPv6 ACL
IPv6例外列表
Actions
攻击防范的处理行为,包括以下取值:
·     CV:启用客户端验证
·     L:输出告警日志
·     D:丢弃报文
·     N:不采用任何处理行为
单包攻击防范配置信息
Signature name
单包的类型
Defense
单包攻击防范的开启状态
Level
单包攻击的级别,包括以下取值:
·     Info: 提示级别
·     low:低级别
·     medium:中级别
·     high:高级别(目前暂无实例)
Actions
单包攻击防范的处理行为,包括以下取值:
·     L:输出告警日志
·     D:丢弃报文
·     N:不采用任何处理行为
IP选项record route攻击
IP option security
IP选项security攻击
IP option stream ID
IP选项stream identifier攻击
IP选项 internet timestamp攻击
IP选项loose source routing攻击
IP选项strict source routing攻击
IP option abnormal
IP选项异常攻击
IP选项route alert攻击
Fragment
IP分片异常攻击
IP impossible
IP impossible攻击
Tiny fragment
IP tiny fragment攻击
Teardrop
IP teardrop攻击,又称IP overlapping fragments
Large ICMP
Large ICMP攻击
Max length
ICMP报文所允许的最大长度
Smurf
Smurf攻击
Traceroute
Traceroute攻击
Ping of death
Ping of death攻击
ICMP echo request
ICMP echo request攻击
ICMP echo reply
ICMP echo reply攻击
ICMP source quench
ICMP source quench攻击
ICMP redirect
ICMP redirect攻击
ICMP parameter problem攻击
ICMP timestamp request攻击
ICMP timestamp reply攻击
ICMP information request攻击
ICMP information reply攻击
ICMP address mask request攻击
ICMP address mask reply攻击
ICMP destination  unreachable攻击
ICMP time exceeded
ICMP time exceeded攻击
Large ICMPv6
Large ICMPv6攻击
ICMPv6 echo request
ICMPv6 echo request攻击
ICMPv6 echo reply
ICMPv6 echo reply攻击
ICMPv6 group membership query攻击
ICMPv6 group membership report攻击
ICMPv6 group membership reduction攻击
ICMPv6 destination unreachable攻击
ICMPv6 time exceeded攻击
ICMPv6 parameter problem攻击
ICMPv6 packet too big攻击
Winnuke
Winnuke攻击
TCP Land
Land攻击
TCP NULL flag
TCP NULL flag攻击
TCP invalid flags
TCP invalid flags攻击
TCP all flags
TCP所有标志位均被置位攻击,又称圣诞树攻击
TCP SYN-FIN flags
TCP SYN和FIN被同时置位攻击
TCP FIN only flag
TCP 只有FIN被置位的攻击
Fraggle
Fraggle攻击,又称UDP chargen DoS attack
UDP Bomb
UDP Bomb攻击
Snork
Snork攻击
扫描攻击防范配置信息
Defense
扫描攻击防范的开启状态
Level
扫描攻击的级别,包括以下取值:
·     low:低级别
·     medium:中级别
·     high:高级别
Actions
扫描攻击防范的处理行为,包括以下取值:
·     D:丢弃报文
·     L:输出告警日志
flood攻击防范配置信息
Flood type
flood攻击类型,包括以下取值:
·     ACK flood
·     DNS flood
·     FIN flood
·     ICMP flood
·     ICMPv6 flood
·     SYN flood
·     SYN-ACK flood
·     UDP flood
·     RST flood
·     HTTP flood
Global thres(pps)
flood攻击防范的全局触发阈值,单位为每秒报文数,默认值为1000pps
Global actions
flood攻击防范的全局处理行为,包括以下取值:
·     D:丢弃报文
·     L:输出告警日志,
·     CV:启用客户端验证
·     -:未配置
Service ports
flood攻击防范的全局检测端口号。该字段只对DNS flood攻击防范和HTTP flood攻击防范生效,对于其它flood攻击防范,显示为“-”
Non-specific
对非受保护IP地址开启SYN flood攻击防范检测的状态
对受保护IP地址的flood攻击防范配置
Address
指定的IP地址
VPN instance
所属的VPN实例名称,未配置时显示为“--”
Thres(pps)
攻击防范检测的触发阈值,单位为报文每秒,未配置时显示为“1000”
Actions
对指定IP地址采用的攻击防范处理行为,包括 取值:
·     CV:启用客户端验证
·     L:输出告警日志
·     D:丢弃报文
·     N:不采用任何处理行为
Ports
flood攻击防范的检测端口号。该字段只对DNS flood攻击防范和HTTP flood攻击防范生效,对于其他攻击防范,显示为“-”
# 显示所有攻击防范策略的概要配置信息。
           Attack-defense Policy Brief Information
Policy Name                        Applied list
Atk-policy-1                       GigabitEthernet2/1/1
                                   GigabitEthernet2/1/2
                                   GigabitEthernet2/1/3
P2                                 None
P123                               GigabitEthernet2/1/2
表1-6 display attack-defense policy命令显示信息描述表
Policy Name
攻击防范策略编号
Applied list
display attack-defense policy ip命令用来显示flood攻击防范的IPv4类型的受保护IP表项。
独立运行模式:
display attack-defense policy policy-name { ack-flood | dns-flood | fin-flood | flood | http-flood | icmp-flood | rst-flood | syn-ack-flood | syn-flood | udp-flood } ip [ ip-address [ vpn vpn-instance-name ] ] [ slot slot-number ] [ count ]
IRF模式:
display attack-defense policy policy-name { ack-flood | dns-flood | fin-flood | flood | http-flood | icmp-flood | rst-flood | syn-ack-flood | syn-flood | udp-flood } ip [ ip-address [ vpn vpn-instance-name ] ] [ chassis chassis-number slot slot-number ] [ count ]
ack-flood:显示ACK flood攻击防范受保护IP表项。
dns-flood:显示DNS flood攻击防范受保护IP表项。
fin-flood:显示FIN flood攻击防范受保护IP表项。
flood:显示所有类型的flood攻击防范受保护IP表项。
http-flood:显示HTTP flood攻击防范受保护IP表项。
icmp-flood:显示ICMP flood攻击防范受保护IP表项。
rst-flood:显示RST flood攻击防范受保护IP表项。
syn-ack-flood:显示SYN-ACK flood攻击防范受保护IP表项。
syn-flood:显示SYN flood攻击防范受保护IP表项。
udp-flood:显示UDP flood攻击防范受保护IP表项。
ip ip-address:显示指定IPv4地址的受保护IP表项。若未指定ip-address参数,则表示显示符合指定条件的所有受保护IP表项。
vpn-instance vpn-instance-name:显示指定VPN实例的受保护IP表项。其中vpn-instance-name表示MPLS L3VPN的VPN实例名称,为1~31个字符的字符串,区分大小写。若未指定本参数,则表示显示指公网的受保护IP表项。
slot slot-number:显示指定slot上的受保护IP表项,slot-number表示槽位号(固定取值为0)。如果不指定该参数,则表示显示所有slot上的受保护IP表项命令执行结果相同。(独立运行模式)
chassis chassis-number slot slot-number:显示指定成员设备上指定slot的受保护IP表项,chassis-number表示设备在IRF中的成员编号,slot-number表示槽位号(固定取值为0)。如果不指定该参数,则表示显示所有slot成员设备上的受保护IP表项。(IRF模式)
count:显示符合指定条件的flood受保护IP表项的数目。
# 显示攻击防范策略abc中所有flood攻击防范的IPv4类型受保护IP表项的信息。(独立运行模式)
<Sysname> display attack-defense policy abc flood ip
Slot 0:
IP address      VPN instance     Type Rate threshold(PPS) Dropped
123.123.123.123 a012345678901234 SYN-ACK-FLOOD 1000                4294967295
201.55.7.45     --               ICMP-FLOOD    100                 10
192.168.11.5    --               DNS-FLOOD 23                  100
# 显示攻击防范策略abc中所有flood攻击防范的IPv4类型受保护IP表项的信息。(IRF模式)
# 显示攻击防范策略abc中所有IPv4类型flood受保护IP表项的个数。(独立运行模式)
<Sysname> display attack-defense policy abc flood ip count
Slot 0:
Totally 3 flood protected IP addresses.
# 显示攻击防范策略abc中所有IPv4类型flood受保护IP表项的个数。(IRF模式)
表1-7 display attack-defense flood ip命令显示信息描述表
IPv4类型受保护IP表项数目
IP address
受保护的IPv4地址
VPN instance
受保护的IPv4地址所属的MPLS L3VPN实例名称,未指定时显示为“--”
flood攻击类型
Rate threshold(PPS)
配置的flood攻击防范触发阈值(单位为报文每秒),未配置时显示为“1000”
Dropped
检测到flood攻击后的丢包数,若只输出日志该项显示为0
display attack-defense policy ipv6命令用来显示flood攻击防范的IPv6类型的受保护IP表项。
独立运行模式:
display attack-defense policy policy-name { ack-flood | dns-flood | fin-flood | flood | http-flood | icmpv6-flood | rst-flood | syn-ack-flood | syn-flood | udp-flood } ipv6 [ ipv6-address [ vpn vpn-instance-name ] ] [ slot slot-number ] ] [ count ]
IRF模式:
display attack-defense policy policy-name { ack-flood | dns-flood | fin-flood | flood | http-flood | icmpv6-flood | rst-flood | syn-ack-flood | syn-flood | udp-flood } ipv6 [ ipv6-address [ vpn vpn-instance-name ] ] [ chassis chassis-number slot slot-number ] [ count ]
icmpv6-flood:显示ICMPv6 flood攻击防范受保护IP表项。
ipv6 ipv6-address:显示指定IPv6地址的受保护IP表项。若未指定ipv6-address参数,则表示显示符合指定条件的所有IPv6类型的受保护IP表项。
# 显示攻击防范策略abc中所有flood攻击防范的IPv6类型受保护IP表项。(独立运行模式)
<Sysname> display attack-defense policy abc flood ipv6
Slot 0:
IPv6 address    VPN instance     Type Rate threshold(PPS) Dropped
2013::127f      a012345678901234 SYN-ACK-FLOOD 1000                4294967295
2::5            --               ACK-FLOOD 100                 10
1::5            --               ACK-FLOOD 100                 23
# 显示攻击防范策略abc中所有flood攻击防范的IPv6类型受保护IP表项。(IRF模式)
# 显示攻击防范策略abc中所有flood攻击防范的IPv6类型受保护IP表项的个数。(独立运行模式)
<Sysname> display attack-defense policy abc flood ipv6 count
Slot 0:
# 显示攻击防范策略abc中所有flood攻击防范的IPv6类型受保护IP表项的个数。(IRF模式)
表1-8 display flood ipv6命令显示信息描述表
Totally3 flood protected IP addresses
IPv6类型受保护IP表项数目
IPv6 address
受保护的IPv6地址
VPN instance
受保护的IPv6地址所属的MPLS L3VPN实例名称,未指定时显示为“--”
flood攻击类型
Rate threshold(PPS)
Dropped
display attack-defense scan attacker ip命令用来显示扫描攻击者的IPv4地址表项。
display attack-defense scan attacker ip [ [ interface interface-type interface-number | local ] ] [ count ]
interface interface-type interface-number:显示指定接口上检测到的扫描攻击者的IPv4地址表项,interface-type interface-number表示接口类型和接口编号。
local:显示本机检测到的扫描攻击者IPv4地址表项。
count:显示符合指定条件的当前扫描攻击者的IPv4地址表项数目。
若未指定任何参数,则表示显示所有扫描攻击者的IPv4地址表项。
# 显示所有扫描攻击者的IPv4地址表项。
<Sysname> display attack-defense scan attacker ip
Slot 0:
IP addr(DslitePeer) VPN instance     Protocol      Detected on   Duration(min)
192.168.31.2(--)    --               TCP           GE2/1/2       1284
2.2.2.3(--)         --               UDP           GE2/1/2       23
表1-9 display attack-defense scan attacker ip命令显示信息描述表
Totally 3 attackers
扫描攻击者的数目
IP addr(DslitePeer)
发起攻击的IPv4地址,DS-Lite组网DslitePeer显示为DS-Lite隧道源IPv6地址,否则显示“--”
设备暂不支持本字段
VPN instance
Protocol
协议名称
Detected on
进行攻击检测的位置,包括接口或本机(Local)
Duration(min)
检测到攻击持续的时间,单位为分钟
·     display attack-defense scan victim ip
·     scan detect
独立运行模式:
display attack-defense scan attacker ip [ security-zone zone-name [ slot slot-number ] ] [ count ]
IRF模式:
display attack-defense scan attacker ip [ security-zone zone-name [ chassis chassis-number slot slot-number ] ] [ count ]
security-zone zone-name:显示指定安全域的扫描攻击者的IPv4地址表项,zone-name表示安全域名称,为1~31个字符的字符串,不区分大小写,不能包含字符“-”。
count:仅显示符合指定条件的当前扫描攻击者的数目。
slot slot-number:显示指定slot上的扫描攻击者的IPv4地址表项,slot-number表示槽位号(固定取值为0)。如果不指定该参数,则表示指定安全域在所有slot上的扫描攻击者的IPv4地址表项命令执行结果相同。(独立运行模式)
chassis chassis-number slot slot-number:显示指定成员设备的指定slot上的扫描攻击者的IPv4地址表项,chassis-number表示设备在IRF中的成员编号,slot-number表示槽位号(固定取值为0)。如果不指定该参数,则表示显示指定安全域在所有slot成员设备上的扫描攻击者的IPv4地址表项。(IRF模式)
# 显示所有扫描攻击者的IPv4地址表项。(独立运行模式)
Slot 0:
192.168.31.2(--)    --               TCP              DMZ          1284
2.2.2.3(--)         --               UDP              DMZ          23
# 显示所有扫描攻击者的IPv4地址表项。(IRF模式)
# 显示所有扫描攻击者的IPv4地址表项的个数。(独立运行模式)
<Sysname> display attack-defense scan attacker ip count
Slot 0:
Totally 3 attackers.
# 显示所有扫描攻击者的IPv4地址表项的个数。(IRF模式)
表1-10 display attack-defense scan attacker ip命令显示信息描述表
Total 3 attackers
攻击者的数目
IP addr(DslitePeer)
设备暂不支持本字段
VPN instance
Protocol
协议名称
Detected on
进行攻击检测的位置
Duration(min)
检测到攻击的持续时间,单位为分钟
·     scan detect
display attack-defense scan attacker ipv6命令用来显示扫描攻击者的IPv6地址表项。
display attack-defense scan attacker ipv6 [ [ interface interface-type interface-number | local ] ] [ count ]
interface interface-type interface-number:显示指定接口的扫描攻击者的IPv6地址表项,interface-type interface-number表示接口类型和接口编号。
local:显示本机检测到的扫描攻击者IPv6地址表项。
count:显示符合指定条件的当前扫描攻击者的IPv6地址表项数目。
若未指定任何参数,则表示显示所有扫描攻击者的IPv6地址表项。
# 显示扫描攻击者的IPv6地址表项。
<Sysname> display attack-defense scan attacker ipv6
Slot 0:
IPv6 address       VPN instance     Protocol Detected on      Duration(min)
2013::2            --               TCP GE2/1/4          1234
1230::22           --               UDP GE2/1/4          10
# 显示扫描攻击者的IPv6地址表项的个数。
<Sysname> display attack-defense scan attacker ipv6 count
Slot 0:
表1-11 display attack-defense scan attacker ipv6命令显示信息描述表
Totally 3 attackers
攻击者的数目
IPv6 address
发起攻击的IPv6地址
VPN instance
Protocol
协议名称
Detected on
Duration(min)
检测到攻击持续的时间,单位为分钟
·     display attack-defense scan victim ipv6
·     scan detect
独立运行模式:
display attack-defense scan attacker ipv6 [ security-zone zone-name [ slot slot-number ] ] [ count ]
IRF模式:
display attack-defense scan attacker ipv6 [ security-zone zone-name [chassis chassis-number slot slot-number ] ] [ count ]
security-zone zone-name:显示指定安全域的扫描攻击者的IPv6地址表项,zone-name表示安全域名称,为1~31个字符的字符串,不区分大小写,不能包含字符“-”。
slot slot-number:显示指定slot上的扫描攻击者的IPv6地址表项,slot-number表示槽位号(固定取值为0)。如果不指定该参数,则表示显示指定安全域在所有slot上的扫描攻击者的IPv6地址表项命令执行结果相同。(独立运行模式)
chassis chassis-number slot slot-number:显示指定成员设备的指定slot上的扫描攻击者的IPv6地址表项,chassis-number表示设备在IRF中的成员编号,slot-number表示槽位号(固定取值为0)。如果不指定该参数,则表示显示指定安全域在所有slot成员设备上的扫描攻击者的IPv6地址表项。(IRF模式)
# 显示扫描攻击者的IPv6地址表项。(独立运行模式)
Slot 0:
2013::2             --               TCP              DMZ          1234
1230::22            --               UDP              DMZ          10
# 显示所有扫描攻击者的IPv6地址表项。(IRF模式)
# 显示扫描攻击者的IPv6地址表项的个数。(独立运行模式)
Slot 0:
# 显示所有扫描攻击者的IPv6地址表项的个数。(IRF模式)
表1-12 display attack-defense scan attacker ipv6命令显示信息描述表
Totally 3 attackers
攻击者的数目
IPv6 address
发起攻击的IPv6地址
VPN instance
Protocol
协议名称
Detected on
进行攻击检测的位置
Duration(min)
检测到攻击的持续时间,单位为分钟
·     scan detect
display attack-defense scan victim ip命令用来显示扫描攻击被攻击者的IPv4地址表项。
display attack-defense scan victim ip  [ [ interface interface-type interface-number | local ] ] [ count ]
interface interface-type interface-number:显示指定接口的被攻击者的IPv4地址表项,interface-type interface-number表示接口类型和接口编号。
local:显示本机检测到的被攻击者的IPv4地址表项。
count:显示符合指定条件的被攻击者的IPv4地址表项数目。
若未指定任何参数,则表示显示所有扫描攻击的被攻击者的IPv4地址表项。
# 显示扫描攻击的被攻击者的IPv4地址表项。
<Sysname> display attack-defense scan victim ip
Slot 0:
IP address      VPN instance      Protocol      Detected on        Duration(min)
192.168.31.2    --                TCP           GE2/1/4            21
2.2.2.3         --                UDP           GE2/1/4            1234
# 显示扫描攻击的被攻击者的IPv4地址表项的个数。
<Sysname> display attack-defense scan victim ip count
Slot 0:
Totally 3 victim IP addresses.
表1-13 display attack-defense scan victim ip命令显示信息描述表
被攻击者的数目
IP address
被攻击的IPv4地址
VPN instance
Protocol
协议名称
Detected on
Duration(min)
检测到被攻击的持续时间,单位为分钟
·     display attack-defense scan attacker ip
·     scan detect
display attack-defense scan victim ip命令用来显示扫描被攻击者的IPv4地址表项。
独立运行模式:
display attack-defense scan victim ip [ security-zone zone-name [ slot slot-number ] ] [ count ]
IRF模式:
display attack-defense scan victim ip [ security-zone zone-name [ chassis chassis-number slot slot-number ] ] [ count ]
security-zone zone-name:显示指定安全域的被攻击者的IPv4地址表项,zone-name表示安全域名称,为1~31个字符的字符串,不区分大小写,不能包含字符“-”。
slot slot-number:显示指定slot上的被攻击者的IPv4地址表项,slot-number表示槽位号(固定取值为0)。如果不指定该参数,则表示显示指定安全域在所有slot上的被攻击者的IPv4地址表项命令执行结果相同。(独立运行模式)
chassis chassis-number slot slot-number:显示指定成员设备的指定slot上的被攻击者的IPv4地址表项,chassis-number表示设备在IRF中的成员编号,slot-number表示槽位号(固定取值为0)。如不指定该参数,则表示显示指定安全域在所有slot成员设备上的被攻击者的IPv4地址表项。(IRF模式)
# 显示扫描攻击的被攻击者的IPv4地址表项。(独立运行模式)
Slot 0:
192.168.31.2    --                TCP           DMZ                21
2.2.2.3         --                UDP           DMZ                1234
# 显示扫描攻击的被攻击者的IPv4地址表项。(IRF模式)
# 显示扫描攻击的被攻击者的IPv4地址表项的个数。(独立运行模式)
Slot 0:
# 显示扫描攻击的被攻击者的IPv4地址表项的个数。(IRF模式)
表1-14 display attack-defense scan victim ip命令显示信息描述表
被攻击者的数目
IP address
被攻击的IPv4地址
VPN instance
所属的VPN实例名称,属于公网时显示为“--”
Protocol
协议名称
Detected on
进行攻击检测的位置
Duration(min)
检测到攻击的持续时间,单位为分钟
·     scan detect
display attack-defense scan victim ipv6命令用来显示扫描攻击被攻击者IPv6表项。
display attack-defense scan victim ipv6 [ [ interface interface-type interface-number | local ] ] [ count ]
interface interface-type interface-number:显示指定接口的被攻击者的IPv6地址表项,interface-type interface-number表示接口类型和接口编号。
count:仅显示符合指定条件的当前被攻击者的数目。
local:显示本机检测到的被攻击者的IPv6地址表项。
若未指定任何参数,则表示显示所有扫描攻击的被攻击者的IPv6地址表项。
# 显示扫描攻击的被攻击者的IPv6地址表项。
<Sysname> display attack-defense scan victim ipv6
Slot 0:
2013::2           --               TCP           GE2/1/4          210
1230::22          --               UDP           GE2/1/4          13
# 显示扫描攻击的被攻击者的IPv6地址表项的个数。
<Sysname> display attack-defense scan victim ipv6 count
Slot 0:
表1-15 display attack-defense scan victim ipv6命令显示信息描述表
被攻击者的数目
IPv6 address
被攻击的IPv6地址
VPN instance
Protocol
协议名称
Detected on
Duration(min)
检测到被攻击的持续时间,单位为分钟
·     display attack-defense scan attacker ipv6
·     scan detect
display attack-defense scan victim ipv6命令用来显示扫描被攻击者IPv6表项。
独立运行模式:
display attack-defense scan victim ipv6 [ security-zone zone-name [ slot slot-number ] ] [ count ]
IRF模式:
display attack-defense scan victim ipv6 [ security-zone zone-name [ chassis chassis-number slot slot-number ] ] [ count ]
security-zone zone-name:显示指定安全域的扫描被攻击者的IPv6地址表项,zone-name表示安全域名称,为1~31个字符的字符串,不区分大小写,不能包含字符“-”。
count:仅显示符合指定条件的当前扫描被攻击者的数目。
slot slot-number:显示指定slot上的扫描被攻击者的IPv6地址表项,slot-number表示槽位号(固定取值为0)。如果不指定该参数,则表示显示指定安全域在所有slot上的被攻击者的IPv6地址表项命令执行结果相同。(独立运行模式)
chassis chassis-number slot slot-number:显示指定成员设备的指定slot上的扫描被攻击者的IPv6地址表项,chassis-number表示设备在IRF中的成员编号,slot-number表示槽位号(固定取值为0)。如果不指定该参数,则表示显示指定安全域在所有slot成员设备上的被攻击者的IPv6地址表项。(IRF模式)
若未指定任何参数,则表示显示所有扫描被攻击者的IPv6地址表项。
# 显示扫描被攻击者的IPv6地址表项。(独立运行模式)
Slot 0:
2013::2             --               TCP              Untrust      210
1230::22            --               UDP              Untrust      13
# 显示扫描被攻击者的IPv6地址表项。(IRF模式)
# 显示扫描被攻击者的IPv6地址表项的个数。(独立运行模式)
Slot 0:
# 显示扫描被攻击者的IPv6地址表项的个数。(IRF模式)
表1-16 display attack-defense scan victim ipv6命令显示信息描述表
被攻击者的数目
IPv6 address
被攻击的IPv6地址
VPN instance
Protocol
协议名称
Detected on
进行攻击检测的位置
Duration(min)
检测到被攻击的持续时间,单位为分钟
·     scan detect
display attack-defense statistics interface命令用来显示接口上的攻击防范统计信息。
display attack-defense statistics interface interface-type interface-number
interface-type interface-number:表示指定接口的接口类型和接口编号。
# 显示Slot 0的GigabitEthernet2/1/1上的攻击防范统计信息。
<Sysname> display attack-defense statistics interface gigabitethernet 2/1/1
Attack policy name: abc
Slot 0:
Scan attack defense statistics:
 AttackType                          AttackTimes Dropped
 Port scan                           2           23
 IP sweep                            3           33
 Distribute port scan                1           10
Flood attack defense statistics:
 SYN flood                           1           0
 ACK flood                           1           0
 SYN-ACK flood                       3           5000
 RST flood                           2           0
 FIN flood                           2           0
 UDP flood                           1           0
 ICMP flood                          1           0
 ICMPv6 flood                        1           0
 DNS flood                           1           0
 HTTP flood                          1           0
Signature attack defense statistics:
 IP option record route              1           100
 IP option security                  2           0
 IP option stream ID                 3           0
 IP option internet timestamp        4           1
 IP option loose source routing      5           0
 IP option strict source routing     6           0
 IP option route alert               3           0
 Fragment                            1           0
 Impossible                          1           1
 Teardrop                            1           1
 Tiny fragment                       1           0
 IP options abnormal                 3           0
 Smurf                               1           0
 Ping of death                       1           0
 Traceroute                          1           0
 Large ICMP                          1           0
 TCP NULL flag                       1           0
 TCP all flags                       1           0
 TCP SYN-FIN flags                   1           0
 TCP FIN only flag                   1           0
 TCP invalid flag                    1           0
 TCP Land                            1           0
 Winnuke                             1           0
 UDP Bomb                            1           0
 Snork                               1           0
 Fraggle                             1           0
 Large ICMPv6                        1           0
 ICMP echo request                   1           0
 ICMP echo reply                     1           0
 ICMP source quench                  1           0
 ICMP destination unreachable        1           0
 ICMP redirect                       2           0
 ICMP time exceeded                  3           0
 ICMP parameter problem              4           0
 ICMP timestamp request              5           0
 ICMP timestamp reply                6           0
 ICMP information request            7           0
 ICMP information reply              4           0
 ICMP address mask request           2           0
 ICMP address mask reply             1           0
 ICMPv6 echo request                 1           1
 ICMPv6 echo reply                   1           1
 ICMPv6 group membership query       1           0
 ICMPv6 group membership report      1           0
 ICMPv6 group membership reduction   1           0
 ICMPv6 destination unreachable      1           0
 ICMPv6 time exceeded                1           0
 ICMPv6 parameter problem            1           0
 ICMPv6 packet too big               1           0
表1-17 display attack-defense statistics interface 命令显示信息描述表
AttackType
攻击类型
AttackTimes
受到攻击的次数
Dropped
丢弃报文的数目
SYN flood
SYN flood攻击,当AttackTimes为0时,该列不显示
ACK flood
ACK flood攻击,当AttackTimes为0时,该列不显示
SYN-ACK flood
SYN-ACK flood攻击,当AttackTimes为0时,该列不显示
RST flood
RST flood攻击,当AttackTimes为0时,该列不显示
FIN flood
FIN flood攻击,当AttackTimes为0时,该列不显示
UDP flood
UDP flood 攻击,当AttackTimes为0时,该列不显示
ICMP flood
ICMP flood攻击,当AttackTimes为0时,该列不显示
ICMPv6 flood
ICMPv6 flood攻击,当AttackTimes为0时,该列不显示
DNS flood
DNS flood攻击,当AttackTimes为0时,该列不显示
HTTP flood
HTTP flood攻击,当AttackTimes为0时,该列不显示
Port scan
端口扫描攻击,当AttackTimes 为0时,该列不显示
IP Sweep
IP扫描攻击,当AttackTimes 为0时,该列不显示
分布式端口扫描攻击,当AttackTimes为0时,该列不显示
IP选项record route攻击,当AttackTimes为0时,该列不显示
IP option security
IP选项security攻击,当AttackTimes 为0时,该列不显示
IP option stream ID
IP选项stream identifier攻击,当AttackTimes 为0时,该列不显示
IP选项 internet timestamp攻击,当AttackTimes为0时,该列不显示
IP选项loose source routing攻击,当AttackTimes为0时,该列不显示
IP选项strict source routing攻击,当AttackTimes为0时,该列不显示
Fragment
IP分片异常攻击,当AttackTimes为0时,该列不显示
Impossible
IP impossible攻击,当AttackTimes为0时,该列不显示
Teardrop
IP teardrop攻击,又称IP overlapping fragments,当AttackTimes为0时,该列不显示
Tiny fragment
IP tiny fragment攻击
IP option abnormal
IP选项异常攻击,当AttackTimes为0时,该列不显示
Smurf
Smurf攻击,当AttackTimes为0时,该列不显示
Ping of death
Ping of death攻击,当AttackTimes为0时,该列不显示
Traceroute
Traceroute攻击,当AttackTimes为0时,该列不显示
Large ICMP
Large ICMP攻击,当AttackTimes为0时,该列不显示
TCP NULL flag
TCP NULL flag攻击,当AttackTimes为0时,该列不显示
TCP all flags
TCP所有标志位均被置位攻击,又称圣诞树攻击,当AttackTimes为0时,该列不显示
TCP SYN-FIN flags
TCP SYN和FIN被同时置位攻击,当AttackTimes为0时,该列不显示
TCP FIN only flag
TCP 只有FIN被置位的攻击,当AttackTimes为0时,该列不显示
TCP invalid flag
TCP 非法标志位攻击,当AttackTimes 为0时,该列不显示
TCP Land
TCP Land攻击,当AttackTimes为0时,该列不显示
Winnuke
Winnuke攻击,当AttackTimes为0时,该列不显示
UDP Bomb
UDP Bomb攻击,当AttackTimes为0时,该列不显示
Snork
UDP snork攻击,当AttackTimes为0时,该列不显示
Fraggle
Fraggle攻击,又称UDP chargen DoS attack,当AttackTimes为0时,该列不显示
Large ICMPv6
Large ICMPv6攻击,当AttackTimes为0时,该列不显示
ICMP echo request
ICMP echo request攻击,当AttackTimes为0时,该列不显示
ICMP echo reply
ICMP echo reply攻击,当AttackTimes为0时,该列不显示
ICMP source quench
ICMP source quench攻击,当AttackTimes为0时,该列不显示
ICMP destination unreachable攻击,当AttackTimes为0时,该列不显示
ICMP redirect
ICMP redirect攻击,当AttackTimes为0时,该列不显示
ICMP time exceeded
ICMP time exceeded攻击,当AttackTimes为0时,该列不显示
ICMP parameter problem攻击,当AttackTimes 为0时,该列不显示
ICMP timestamp request攻击,当AttackTimes为0时,该列不显示
ICMP timestamp reply攻击,当AttackTimes为0时,该列不显示
ICMP information request攻击,当AttackTimes为0时,该列不显示
ICMP information reply攻击,当AttackTimes为0时,该列不显示
ICMP address mask request攻击,当AttackTimes为0时,该列不显示
ICMP address mask reply攻击,当AttackTimes为0时,该列不显示
ICMPv6 echo request
ICMPv6 echo request攻击,当AttackTimes 为0时,该列不显示
ICMPv6 echo reply
ICMPv6 echo reply攻击,当AttackTimes为0时,该列不显示
ICMPv6 group membership query攻击,当AttackTimes为0时,该列不显示
ICMPv6 group membership report攻击,当AttackTimes为0时,该列不显示
ICMPv6 group membership reduction攻击,当AttackTimes为0时,该列不显示
ICMPv6 destination unreachable攻击,当AttackTimes为0时,该列不显示
ICMPv6 time exceeded攻击,当AttackTimes为0时,该列不显示
ICMPv6 parameter problem攻击,当AttackTimes为0时,该列不显示
ICMPv6 packet too big攻击,当AttackTimes为0时,该列不显示
display attack-defense statistics local命令用来显示本机攻击防范的统计信息。
独立运行模式:
display attack-defense statistics local [ slot slot-number ]
IRF模式:
display attack-defense statistics local [ chassis chassis-number slot slot-number ]
slot slot-number:显示本机攻击防范在指定slot上的统计信息,slot-number表示槽位号(固定取值为0)。如果不指定该参数,则表示显示所有slot上检测到的本机攻击防范统计信息命令执行结果相同。(独立运行模式)
chassis chassis-number slot slot-number:显示本机攻击防范在指定成员设备的指定slot上的统计信息,chassis-number表示设备在IRF中的成员编号,slot-number表示槽位号(固定取值为0)。如果不指定该参数,则表示显示所有slot成员设备上检测到的本机攻击防范统计信息。(IRF模式)
# 显示本机攻击防范统计信息。(独立运行模式)
<Sysname> display attack-defense statistics local
Slot 0:
 Port scan                           2           23
 IP sweep                            3           33
 SYN flood                           1           0
 ACK flood                           1           0
 RST flood                           2           0
 FIN flood                           2           0
 UDP flood                           1           0
 ICMP flood                          1           0
 ICMPv6 flood                        1           0
 DNS flood                           1           0
 HTTP flood                          1           0
 Fragment                            1           0
 Impossible                          1           1
 Teardrop                            1           1
 Tiny fragment                       1           0
 Smurf                               1           0
 Ping of death                       1           0
 Traceroute                          1           0
 Large ICMP                          1           0
 TCP NULL flag                       1           0
 TCP all flags                       1           0
 TCP Land                            1           0
 Winnuke                             1           0
 UDP Bomb                            1           0
 Snork                               1           0
 Fraggle                             1           0
 Large ICMPv6                        1           0
 ICMP echo reply                     1           0
 ICMP redirect                       2           0
# 显示本机攻击防范统计信息。(IRF模式)
 Port scan                           2           23
 IP sweep                            3           33
 SYN flood                           1           0
 ACK flood                           1           0
 RST flood                           2           0
 FIN flood                           2           0
 UDP flood                           1           0
 ICMP flood                          1           0
 ICMPv6 flood                        1           0
 DNS flood                           1           0
 HTTP flood                          1           0
 Fragment                            1           0
 Impossible                          1           1
 Teardrop                            1           1
 Tiny fragment                       1           0
 Smurf                               1           0
 Ping of death                       1           0
 Traceroute                          1           0
 Large ICMP                          1           0
 TCP NULL flag                       1           0
 TCP all flags                       1           0
 TCP Land                            1           0
 Winnuke                             1           0
 UDP Bomb                            1           0
 Snork                               1           0
 Fraggle                             1           0
 Large ICMPv6                        1           0
 ICMP echo reply                     1           0
 ICMP redirect                       2           0
表1-18 display attack-defense statistics local命令显示信息描述表
AttackType
攻击类型
AttackTimes
受到攻击的次数
Dropped
丢弃报文的数目
Port scan
IP Sweep
IP扫描攻击,当AttackTimes为0时,该列不显示
SYN flood
SYN flood攻击,当AttackTimes 为0时,该列不显示
ACK flood
ACK flood攻击,当AttackTimes 为0时,该列不显示
SYN-ACK flood
RST flood
FIN flood
UDP flood
ICMP flood
ICMPv6 flood
DNS flood
HTTP flood
IP option security
IP选项security攻击,当AttackTimes为0时,该列不显示
IP option stream ID
IP选项stream identifier攻击,当AttackTimes为0时,该列不显示
Fragment
Impossible
Teardrop
Tiny fragment
IP tiny fragment攻击
IP option abnormal
Smurf
Ping of death
Traceroute
Large ICMP
TCP NULL flag
TCP all flags
TCP SYN-FIN flags
TCP FIN only flag
TCP只有FIN被置位的攻击,当AttackTimes为0时,该列不显示
TCP invalid flag
TCP非法标志位攻击,当AttackTimes为0时,该列不显示
TCP Land
Winnuke
UDP Bomb
Snork
Snork攻击,当AttackTimes为0时,该列不显示
Fraggle
Large ICMPv6
ICMP echo request
ICMP echo request攻击,当AttackTimes 为0时,该列不显示
ICMP echo reply
ICMP source quench
ICMP redirect
ICMP time exceeded
ICMP parameter problem攻击,当AttackTimes为0时,该列不显示
ICMPv6 echo request
ICMPv6 echo reply
ICMPv6 group membership query攻击,当AttackTimes 为0时,该列不显示
·     reset attack-defense statistics local
display attack-defense statistics security-zone命令用来显示安全域上的攻击防范统计信息。
独立运行模式:
display attack-defense statistics security-zone zone-name [ slot slot-number ]
IRF模式:
display attack-defense statistics security-zone zone-name [ chassis chassis-number slot slot-number ]
zone-name:指定安全域的名称,为1~31个字符的字符串,不区分大小写,不能包含字符“-”。
slot slot-number:显示指定slot上的攻击防范统计信息,slot-number表示槽位号(固定取值为0)。如果不指定该参数,则表示显示所有slot上的攻击防范统计信息命令执行结果相同。(独立运行模式)
chassis chassis-number slot slot-number:显示指定成员设备的指定slot上的攻击防范统计信息,chassis-number表示设备在IRF中的成员编号,slot-number表示槽位号(固定取值为0)。如果不指定该参数,则表示显示所有slot成员设备上的攻击防范统计信息。(IRF模式)
# 显示Slot 0的Untrust上的攻击防范统计信息。(独立运行模式)
<Sysname> display attack-defense statistics security-zone untrust slot 0
Slot 0:
 Port scan                           2           23
 IP sweep                            3           33
 SYN flood                           1           0
 ACK flood                           1           0
 RST flood                           2           0
 FIN flood                           2           0
 UDP flood                           1           0
 ICMP flood                          1           0
 ICMPv6 flood                        1           0
 DNS flood                           1           0
 HTTP flood                          1           0
 Fragment                            1           0
 Impossible                          1           1
 Teardrop                            1           1
 Tiny fragment                       1           0
 Smurf                               1           0
 Ping of death                       1           0
 Traceroute                          1           0
 Large ICMP                          1           0
 TCP NULL flag                       1           0
 TCP all flags                       1           0
 TCP Land                            1           0
 Winnuke                             1           0
 UDP Bomb                            1           0
 Snork                               1           0
 Fraggle                             1           0
 Large ICMPv6                        1           0
 ICMP echo reply                     1           0
 ICMP redirect                       2           0
# 显示Chassis 1的slot 0 上Untrust上的攻击防范信息。(IRF模式)
<Sysname> display attack-defense statistics security-zone untrust chassis 1 slot 0
 Port scan                           2           23
 IP sweep                            3           33
 SYN flood                           1           0
 ACK flood                           1           0
 RST flood                           2           0
 FIN flood                           2           0
 UDP flood                           1           0
 ICMP flood                          1           0
 ICMPv6 flood                        1           0
 DNS flood                           1           0
 HTTP flood                          1           0
 Fragment                            1           0
 Impossible                          1           1
 Teardrop                            1           1
 Tiny fragment                       1           0
 Smurf                               1           0
 Ping of death                       1           0
 Traceroute                          1           0
 Large ICMP                          1           0
 TCP NULL flag                       1           0
 TCP all flags                       1           0
 TCP Land                            1           0
 Winnuke                             1           0
 UDP Bomb                            1           0
 Snork                               1           0
 Fraggle                             1           0
 Large ICMPv6                        1           0
 ICMP echo reply                     1           0
 ICMP redirect                       2           0
表1-19 display attack-defense statistics security-zone命令显示信息描述表
AttackType
攻击类型
AttackTimes
受到攻击的次数
Drops
丢弃报文的数目
SYN flood
ACK flood
SYN-ACK flood
SYN-ACK flood攻击,当AttackTimes 为0时,该列不显示
RST flood
RST flood攻击,当AttackTimes 为0时,该列不显示
FIN flood
FIN flood攻击,当AttackTimes 为0时,该列不显示
UDP flood
UDP flood 攻击,当AttackTimes 为0时,该列不显示
ICMP flood
ICMP flood攻击,当AttackTimes 为0时,该列不显示
ICMPv6 flood
ICMPv6 flood攻击,当AttackTimes 为0时,该列不显示
DNS flood
DNS flood攻击,当AttackTimes 为0时,该列不显示
HTTP flood
HTTP flood攻击,当AttackTimes 为0时,该列不显示
Port scan
IP Sweep
分布式端口扫描攻击,当AttackTimes 为0时,该列不显示
IP选项record route攻击,当AttackTimes 为0时,该列不显示
IP option security
IP option stream ID
IP选项 internet timestamp攻击,当AttackTimes 为0时,该列不显示
IP选项loose source routing攻击,当AttackTimes 为0时,该列不显示
IP选项strict source routing攻击,当AttackTimes 为0时,该列不显示
Fragment
IP分片异常攻击,当AttackTimes 为0时,该列不显示
Impossible
IP impossible攻击,当AttackTimes 为0时,该列不显示
Teardrop
IP teardrop攻击,又称IP overlapping fragments,当AttackTimes 为0时,该列不显示
Tiny fragment
IP tiny fragment攻击
IP option abnormal
IP选项异常攻击,当AttackTimes 为0时,该列不显示
Smurf
Smurf攻击,当AttackTimes 为0时,该列不显示
Ping of death
Ping of death攻击,当AttackTimes 为0时,该列不显示
Traceroute
Traceroute攻击,当AttackTimes 为0时,该列不显示
Large ICMP
Large ICMP攻击,当AttackTimes 为0时,该列不显示
TCP NULL flag
TCP NULL flag攻击,当AttackTimes 为0时,该列不显示
TCP all flags
TCP所有标志位均被置位攻击,又称圣诞树攻击,当AttackTimes 为0时,该列不显示
TCP SYN-FIN flags
TCP SYN和FIN被同时置位攻击,当AttackTimes 为0时,该列不显示
TCP FIN only flag
TCP 只有FIN被置位的攻击,当AttackTimes 为0时,该列不显示
TCP invalid flag
TCP Land
TCP Land攻击,当AttackTimes 为0时,该列不显示
Winnuke
Winnuke攻击,当AttackTimes 为0时,该列不显示
UDP Bomb
UDP Bomb攻击,当AttackTimes 为0时,该列不显示
Snork
UDP snork攻击,当AttackTimes 为0时,该列不显示
Fraggle
Fraggle攻击,又称UDP chargen DoS attack,当AttackTimes 为0时,该列不显示
Large ICMPv6
Large ICMPv6攻击,当AttackTimes 为0时,该列不显示
ICMP echo request
ICMP echo reply
ICMP echo reply攻击,当AttackTimes 为0时,该列不显示
ICMP source quench
ICMP source quench攻击,当AttackTimes 为0时,该列不显示
ICMP destination unreachable攻击,当AttackTimes 为0时,该列不显示
ICMP redirect
ICMP redirect攻击,当AttackTimes 为0时,该列不显示
ICMP time exceeded
ICMP time exceeded攻击,当AttackTimes 为0时,该列不显示
ICMP timestamp request攻击,当AttackTimes 为0时,该列不显示
ICMP timestamp reply攻击,当AttackTimes 为0时,该列不显示
ICMP information request攻击,当AttackTimes 为0时,该列不显示
ICMP information reply攻击,当AttackTimes 为0时,该列不显示
ICMP address mask request攻击,当AttackTimes 为0时,该列不显示
ICMP address mask reply攻击,当AttackTimes 为0时,该列不显示
ICMPv6 echo request
ICMPv6 echo reply
ICMPv6 echo reply攻击,当AttackTimes 为0时,该列不显示
ICMPv6 group membership report攻击,当AttackTimes 为0时,该列不显示
ICMPv6 group membership reduction攻击,当AttackTimes 为0时,该列不显示
ICMPv6 destination unreachable攻击,当AttackTimes 为0时,该列不显示
ICMPv6 time exceeded攻击,当AttackTimes 为0时,该列不显示
ICMPv6 parameter problem攻击,当AttackTimes 为0时,该列不显示
ICMPv6 packet too big攻击,当AttackTimes 为0时,该列不显示
display attack-defense top-attack-statistics命令用来显示Top10的攻击排名统计信息。
display attack-defense top-attack-statistics { last-1-hour | last-24-hours | last-30-days } [ by- attacker | by-type | by-victim ]
last-1-hour:显示最近1小时的统计信息。
last-24-hours:显示最近24小时的统计信息。
last-30-days:显示最近30天的统计信息。
by-attacker:显示基于攻击者IP地址的Top10排名统计信息。
by-type:显示基于攻击类型的统计信息。
by-victim:显示基于被攻击者IP地址的统计信息。
若未指定[ by-attacker | by-type | by-victim ]参数,则同时显示基于攻击者IP地址、被攻击者IP地址和攻击类型统计信息。
# 显示最近1小时的Top10排名统计信息
<Sysname> display attack-defense top-attack-statistics last-1-hour
Top attackers:
No.     VPN instance   Attacker IP         Attacks
1       vpn1           200.200.200.55 21
2       vpn1           200.200.200.21 16
3       vpn2           200.200.200.133 12
4       vpn3           200.200.200.19      10
5       vpn2           200.200.200.4       8
6       vpn2           200.200.200.155 8
7       vpn3           200.200.200.93 5
8       vpn2           200.200.200.67      3
9       vpn2           200.200.200.70 1
10      vpn1           200.200.200.23      1
Top victims:
No.     VPN instance   Victim IP            Attacks
1       vpn2           200.200.200.12       21
2       vpn2           200.200.200.32       16
3       vpn3           200.200.200.14       12
4       vpn2           200.200.200.251      12
5       vpn1           200.200.200.10       7
6       vpn1           200.200.200.77       6
7       vpn1           200.200.200.96       2
8       vpn1           200.200.200.22       2
9       vpn2           200.200.200.154      2
10      vpn3           200.200.200.18       1
Top attack types:
Attack type       Attacks
Scan              155
Syn               155
表1-20 display attack-defense top-attack-statistics命令显示信息描述表
Top attackers
No.
Top10排名
VPN instance
Attacker IP
攻击者的IP地址
Attacks
丢包数量
Top victims
基于被攻击者IP地址的统计信息
Victim IP
被攻击者的IP地址
Top attack types
基于攻击类型的统计信息
Attack type
攻击类型
·     attack-defense top-attack-statistics enable
display client-verify protected ip命令用来显示客户端验证的IPv4类型的受保护IP表项。
独立运行模式:
display client-verify { dns | http | tcp } protected ip [ ip-address [ vpn vpn-instance-name ] ] [ port port-number ] [ slot slot-number ] [ count ]
IRF模式:
display client-verify { dns | http | tcp } protected ip [ ip-address [ vpn vpn-instance-name ] ] [ port port-number ] [ chassis chassis-number slot slot-number ] [ count ]
dns:指定DNS客户端验证功能。
http:指定HTTP客户端验证功能。
tcp:指定TCP客户端验证功能。
vpn-instance vpn-instance-name:显示指定VPN实例的受保护IP表项。其中vpn-instance-name表示MPLS L3VPN的VPN实例名称,为1~31个字符的字符串,区分大小写。若未指定本参数,则表示显示公网中的受保护IP地址。
port port-number:显示指定端口号的受保护IP表项,port-number的取值范围为1~65535。若未指定本参数,对于DNS客户端验证的受保护IP,则表示端口53;对于HTTP客户端验证的受保护IP,则表示端口80;对于TCP客户端验证的受保护IP,则表示所有端口。
slot slot-number:显示指定slot上的受保护IP表项,slot-number表示槽位号(固定取值为0)。如果不指定该参数,则表示显示所有slot上的受保护IP表项命令执行结果相同。(独立运行模式)。
chassis chassis-number slot slot-number:显示指定成员设备上指定slot的受保护IP表项,chassis-number表示设备在IRF中的成员编号,slot-number表示槽位号(固定取值为0)。如果不指定该参数,则表示显示所有slot成员设备上的受保护IP表项。(IRF模式)。
count:显示符合指定条件的客户端验证受保护IP表项。
如果不指定任何参数,则显示所有的IPv4类型的客户端验证受保护IP表项。
# 显示所有IPv4类型TCP客户端验证的受保护IP表项。(独立运行模式)
<Sysname> display client-verify tcp protected ip
Slot 0:
IP address           VPN instance     Port  Type    Requested   Trusted
192.168.11.5         --               23    Dynamic 353452      555
201.55.7.45          --               10    Manual  15000       222
123.123.123.123      VPN1             65535 Dynamic 4294967295  15151
# 显示所有IPv4类型TCP客户端验证的受保护IP表项。(IRF模式)
# 显示所有IPv4类型TCP客户端验证的受保护IP表项的个数。(独立运行模式)
<Sysname> display client-verify tcp protected ip count
Slot 0:
Totally 3 protected IP addresses.
# 显示所有IPv4类型TCP客户端验证的受保护IP表项的个数。(IRF模式)
# 显示所有IPv4类型DNS客户端验证的受保护IP表项。(独立运行模式)
<Sysname> display client-verify dns protected ip
Slot 0:
192.168.11.5         --               53    Dynamic 353452      555
201.55.7.45          --               53    Manual  15000       222
123.123.123.123      VPN1             53    Dynamic 4294967295  15151
# 显示所有IPv4类型DNS客户端验证的受保护IP表项。(IRF模式)
# 显示所有IPv4类型DNS客户端验证的受保护IP表项的个数。(独立运行模式)
<Sysname> display client-verify dns protected ip count
Slot 0:
# 显示所有IPv4类型DNS客户端验证的受保护IP表项的个数。(IRF模式)
# 显示所有IPv4类型HTTP客户端验证的受保护IP表项。(独立运行模式)
<Sysname> display client-verify http protected ip
Slot 0:
192.168.11.5         --               80    Dynamic 353452      555
201.55.7.45          --               8080  Manual  15000       222
123.123.123.123      VPN1             80    Dynamic 4294967295  15151
# 显示所有IPv4类型HTTP客户端验证的受保护IP表项。(IRF模式)
# 显示所有IPv4类型HTTP客户端验证的受保护IP表项的个数。(独立运行模式)
<Sysname> display client-verify http protected ip count
Slot 0:
# 显示所有IPv4类型HTTP客户端验证的受保护IP表项的个数。(IRF模式)
表1-21 display client-verify protected ip命令显示信息描述表
IPv4类型受保护IP表项数目
IP address
受保护IPv4地址
VPN instance
受保护IP地址所属的MPLS L3VPN实例名称,属于公网时显示为“--”
Port
TCP连接的目的端口
any表示对该IP地址的所有端口的TCP连接请求都做代理
受保护IP地址的添加方式,取值包括Dynamic和Manual
Requested
收到的匹配该受保护IP地址的报文数目
Trusted
通过验证的TCP连接请求报文数目
·     client-verify protected ip
1.1.41  display client-verify protected ipv6
display client-verify protected ipv6命令用来显示客户端验证的IPv6类型的受保护IP表项。
独立运行模式:
display client-verify { dns | http | tcp } protected ipv6 [ ipv6-address [ vpn vpn-instance-name ] ] [ port port-number ] [ slot slot-number ] [ count ]
IRF模式:
display client-verify { dns | http | tcp } protected ipv6 [ ipv6-address [ vpn vpn-instance-name ] ] [ port port-number ] [ chassis chassis-number slot slot-number ] [ count ]
dns:指定DNS客户端验证功能。
http:指定HTTP客户端验证功能。
tcp:指定TCP客户端验证功能。
count:显示符合指定条件的客户端验证受保护IP表项个数。
如果不指定任何参数,则显示所有的IPv6类型的客户端验证受保护IP表项。
# 显示所有IPv6类型的TCP客户端验证的受保护IP表项。(独立运行模式)
<Sysname> display client-verify tcp protected ipv6
Slot 0:
IPv6 address         VPN instance     Port  Type    Requested   Trusted
1:2:3:4:5:6:7:8      --               100   Manual  14478       5501
1023::1123           vpn1             65535 Dynamic 4294967295  15151
# 显示所有IPv6类型TCP客户端验证的受保护IP表项。(IRF模式)
# 显示所有IPv6类型的TCP客户端验证的受保护IP表项的个数。(独立运行模式)
Slot 0:
Totally 3 protected IPv6 addresses.
# 显示所有IPv6类型TCP客户端验证的受保护IP表项的个数。(IRF模式)
# 显示所有IPv6类型DNS客户端验证的受保护IP表项。(独立运行模式)
<Sysname> display client-verify dns protected ipv6
Slot 0:
1:2:3:4:5:6:7:8      --               53    Manual  14478       5501
1023::1123           vpn1             53    Dynamic 4294967295  15151
# 显示所有IPv6类型DNS客户端验证的受保护IP表项。(IRF模式)
# 显示所有IPv6类型DNS客户端验证的受保护IP表项的个数。(独立运行模式)
<Sysname> display client-verify dns protected ipv6 count
Slot 0:
# 显示所有IPv6类型DNS客户端验证的受保护IP表项的个数。(IRF模式)
Totally 3 protected entries.
# 显示所有IPv6类型HTTP客户端验证的受保护IP表项。(独立运行模式/IRF模式)
<Sysname> display client-verify http protected ipv6
Slot 0:
1:2:3:4:5:6:7:8      --               8080  Manual  14478       5501
1023::1123           vpn1             80    Dynamic 4294967295  15151
# 显示所有IPv6类型HTTP 客户端验证的受保护IP表项。(IRF模式)
# 显示所有IPv6类型HTTP客户端验证的受保护IP表项的个数。(独立运行模式/IRF模式)
<Sysname> display client-verify http protected ipv6 count
Slot 0:
# 显示所有IPv6类型HTTP 客户端验证的受保护IP表项的个数。(IRF模式)
表1-22 display client-verify protected ipv6命令显示信息描述表
IPv6类型受保护IP表项数目
IPv6 address
受保护IPv6地址
VPN instance
受保护IP地址所属的VPN实例名称,属于公网时显示为“--”
Port
TCP连接的目的端口
Requested
收到的匹配该受保护IP地址的报文数目
Trusted
通过验证的TCP连接请求报文数目
·     client-verify protected ipv6
1.1.42  display client-verify trusted ip
display client-verify trusted ip命令用来显示客户端验证的IPv4类型的信任IP表项。
独立运行模式:
display client-verify { dns | http | tcp } trusted ip [ ip-address [ vpn vpn-instance-name ] ] [ slot slot-number ] [ count ]
IRF模式:
display client-verify { dns | http | tcp } trusted ip [ ip-address [ vpn vpn-instance-name ] ] [ chassis chassis-number slot slot-number ] [ count ]
dns:指定DNS客户端验证功能。
http:指定HTTP客户端验证功能。
tcp:指定TCP客户端验证功能。
ip-address:显示指定IPv4地址的信任IP表项。
vpn-instance vpn-instance-name:显示指定VPN实例的信任IP表项。其中vpn-instance-name表示MPLS L3VPN的VPN实例名称,为1~31个字符的字符串,区分大小写。若未指定本参数,则表示信任IP表项位于公网。
slot slot-number:显示指定slot上的信任IP表项,slot-number表示槽位号(固定取值为0)。如果不指定该参数,则表示显示所有slot上的信任IP表项命令执行结果相同。(独立运行模式)。
chassis chassis-number slot slot-number:显示指定成员设备上指定slot的信任IP表项,chassis-number表示设备在IRF中的成员编号,slot-number表示槽位号(固定取值为0)。如果不指定该参数,则表示显示所有slot成员设备上的信任IP表项。(IRF模式)。
count:仅显示符合指定条件的信任IP表项的个数。
如果不指定任何参数,则显示所有的IPv4类型的客户端验证信任IP表项。
# 显示所有IPv4类型DNS 客户端验证的信任IP表项。(独立运行模式)
<Sysname> display client-verify dns trusted ip
Slot 0:
IP address      VPN instance        DS-Lite tunnel peer    TTL(sec)
11.1.1.2        vpn1                --                     3600
123.123.123.123 a012345678901234567 1234:1234::1234:1234   3550
# 显示所有IPv4类型DNS 客户端验证的信任IP表项。(IRF模式)
# 显示所有IPv4类型DNS 客户端验证的信任IP表项的个数。(独立运行模式)
<Sysname> display client-verify dns trusted ip count
Slot 0:
Totally 3 trusted IP addresses.
# 显示所有IPv4类型DNS 客户端验证的信任IP表项的个数。(IRF模式)
# 显示所有IPv4类型HTTP客户端验证的信任IP表项。(独立运行模式)
<Sysname> display client-verify http trusted ip
Slot 0:
# 显示所有IPv4类型HTTP客户端验证的信任IP表项。(IRF模式)
# 显示所有IPv4类型HTTP 客户端验证的信任IP表项的个数。(独立运行模式)
<Sysname> display client-verify http trusted ip count
Slot 0:
# 显示所有IPv4类型HTTP 客户端验证的信任IP表项的个数。(IRF模式)
# 显示所有IPv4类型的TCP客户端验证的信任IP表项。(独立运行模式)
<Sysname> display client-verify tcp trusted ip
Slot 0:
# 显示所有IPv4类型的TCP客户端验证的信任IP表项。(IRF模式)
# 显示所有IPv4类型TCP客户端验证的信任IP表项的个数。(独立运行模式)
<Sysname> display client-verify tcp trusted ip count
Slot 0:
# 显示所有IPv4类型TCP客户端验证的信任IP表项的个数。(IRF模式)
表1-23 display client-verify trusted ip命令显示信息描述表
IPv4类型信任IP表项的个数
IP address
信任IPv4地址
VPN instance
信任IP地址所属的MPLS L3VPN实例名称,属于公网时显示为“--”
DS-Lite tunnel peer
DS-Lite隧道对端地址。DS-Lite组网下,若本设备为AFTR,此列表示报文来自具体的哪个B4,如果不在DS-Lite组网或本设备不为AFTR,则该字段无意义,显示为“--”
 设备暂不支持本字段
TTL(sec)
信任IP地址的剩余老化时间,单位为秒。若未指定老化时间,则显示“Never”
1.1.43  display client-verify trusted ipv6
display client-verify trusted ipv6命令用来显示客户端验证的IPv6类型的信任IP表项。
独立运行模式:
display client-verify { dns | http | tcp } trusted ipv6 [ ipv6-address [ vpn vpn-instance-name ] ] [ slot slot-number ] ] [ count ]
IRF模式:
display client-verify { dns | http | tcp } trusted ipv6 [ ipv6-address [ vpn vpn-instance-name ] ] [ chassis chassis-number slot slot-number ] [ count ]
dns:指定DNS客户端验证功能。
http:指定HTTP客户端验证功能。
tcp:指定TCP客户端验证功能。
ipv6-address:显示指定IPv6地址的信任IP表项。
count:仅显示符合指定条件的信任IP地址的个数。
如果不指定任何参数,则显示所有IPv6类型的客户端验证的信任IP表项。
# 显示所有IPv6类型的DNS客户端验证的信任IP表项。(独立运行模式)
<Sysname> display client-verify dns trusted ipv6
Slot 0:
IPv6 address                            VPN instance     TTL(sec)
1::3                                    vpn1             1643
1234::1234                              a012345678901234 1234
# 显示所有IPv6类型的DNS客户端验证的信任IP表项。(IRF模式)
1::3                                    vpn1             1643
# 显示所有IPv6类型的DNS客户端验证的信任IP表项的个数。(独立运行模式)
<Sysname> display client-verify dns trusted ipv6 count
Slot 0:
Totally 3 trusted IPv6 addresses.
# 显示所有IPv6类型的DNS客户端验证的信任IP表项的个数。(IRF模式)
# 显示所有IPv6类型HTTP客户端验证的信任IP表项。(独立运行模式)
<Sysname> display client-verify http trusted ipv6
Slot 0:
1::3                                    vpn1             1643
# 显示所有IPv6类型HTTP客户端验证的信任IP表项。(IRF模式)
1::3                                    vpn1             1643
# 显示所有IPv6类型的HTTP客户端验证的信任IP表项的个数。(独立运行模式)
<Sysname> display client-verify http trusted ipv6 count
Slot 0:
# 显示所有IPv6类型的HTTP客户端验证的信任IP表项的个数。(IRF模式)
# 显示所有IPv6类型TCP客户端验证的信任IP表项。(独立运行模式)
<Sysname> display client-verify tcp trusted ipv6
Slot 0:
1::3                                    vpn1             1643
# 显示所有IPv6类型TCP客户端验证信任IP表项。(IRF模式)
1::3                                    vpn1             1643
# 显示所有IPv6类型的TCP客户端验证的信任IP地址的个数。(独立运行模式)
<Sysname> display client-verify tcp trusted ipv6 count
Slot 0:
# 显示所有IPv6类型的TCP客户端验证的信任IP表项的个数。(IRF模式)
表1-24 display client-verify trusted ipv6命令显示信息描述表
IPv6类型信任IP表项的个数
IPv6 address
信任IPv6地址
TTL(sec)
VPN instance
1.1.44  dns-flood action
dns-flood action命令用来配置对DNS flood攻击防范的全局处理行为。
undo dns-flood action命令用来恢复缺省情况。
dns-flood action { client-verify | drop | logging } *
不对检测到的DNS flood攻击采取任何措施。
攻击防范策略视图
client-verify:表示自动将受到攻击的IP地址添加到DNS客户端验证的受保护IP列表中。若客户端验证功能已使能,则对客户端与受保护IP地址之间的连接进行代理。
drop:表示丢弃攻击报文,即设备检测到攻击发生后,向被攻击者发送的后续所有DNS报文都会被丢弃。
logging:表示输出告警日志,即设备检测到攻击发生时,生成告警信息,生成的告警信息将被发送到日志系统。
本命令中client-verify参数的使用需要和TCP客户端验证功能配合。开启了DNS客户端验证的接口或安全域检测到DNS flood攻击时,若本命令中指定了client-verify参数,则设备会将受攻击的IP地址动态添加到相应客户端验证的受保护IP列表中,并对与这些IP地址建立的连接进行代理。若接口或安全域上未开启相应的代理功能,则不会对任何连接进行代理。
# 在攻击防范策略atk-policy-1中配置对DNS flood攻击防范的全局处理行为是丢弃后续报文。
[Sysname] attack-defense policy atk-policy-1
[Sysname-attack-defense-policy-atk-policy-1] dns-flood action drop
·     dns-flood detect
·     dns-flood detect non-specific
·     dns-flood threshold
·     client-verify dns enable
1.1.45  dns-flood detect
dns-flood detect命令用来开启对指定IP地址的攻击防范检测,并配置DNS flood攻击防范检测的触发阈值和对DNS flood攻击的处理行为。
undo dns-flood detect命令用来关闭对指定IP地址的DNS flood攻击防范检测。
dns-flood detect { ip ipv4-address | ipv6 ipv6-address } [ vpn-instance vpn-instance-name ] [ port port-list ] [ threshold threshold-value ] [ action { { client-verify | drop | logging } * | none } ]
undo dns-flood detect { ip ipv4-address | ipv6 ipv6-address } [ vpn-instance vpn-instance-name ]
未对任何指定IP地址配置DNS flood攻击防范检测。
攻击防范策略视图
ip ipv4-address:指定要保护的IPv4地址。该IPv4地址不能为255.255.255.255或0.0.0.0。
ipv6 ipv6-address:指定要保护的IPv6地址。
vpn-instance vpn-instance-name:受保护IP地址所属的VPN实例。其中,vpn-instance-name表示MPLS L3VPN的VPN实例名称,为1~31个字符的字符串,区分大小写。若未指定本参数,则表示该保护IP地址属于公网。
port port-list:指定开启DNS flood攻击防范检测的端口列表,表示方式为{ start-port-number [ to end-port-number ] } &<1-65535>。&<1-65535>表示前面的参数最多可以输入65535次。end-port-number必须大于或等于start-port-number。若未指定本参数,则表示使用全局配置的检测端口列表。
threshold threshold-value:指定DNS flood攻击防范的触发阈值。其中,threshold-value为向指定IP地址每秒发送的DNS报文数目,取值范围为1~1000000。
action:设置对DNS flood攻击的处理行为。
none:表示不采取任何动作。
每个攻击防范策略下可以同时对多个IP地址配置DNS flood攻击防范检测。
使能DNS flood攻击防范后,设备处于攻击检测状态,当它监测到向指定IP地址发送DNS报文的速率持续达到或超过了触发阈值时,即认为该IP地址受到了DNS flood攻击,则进入攻击防范状态,并根据配置启动相应的防范措施。此后,当设备检测到向该服务器发送报文的速率低于恢复阈值(触发阈值的3/4)时,即认为攻击结束,则由攻击防范状态恢复为攻击检测状态,并停止执行防范措施。
# 在攻击防范策略atk-policy-1中开启对IP地址192.168.1.2的DNS flood攻击防范检测,并指定检测端口为53、触发阈值为2000。当设备监测到向该IP地址的53端口每秒发送的DNS报文数持续达到或超过2000时,启动DNS flood攻击防范。
[Sysname-attack-defense-policy-atk-policy-1] dns-flood detect ip 192.168.1.2 port 53 threshold 2000
·     dns-flood action
·     dns-flood port
1.1.46  dns-flood detect non-specific
dns-flood detect non-specific命令用来对所有非受保护IP地址开启DNS flood攻击防范检测。
undo dns-flood detect non-specific命令用来关闭对所有非受保护IP地址的DNS flood攻击防范检测。
未对任何非受保护IP地址开启DNS flood攻击防范检测。
攻击防范策略视图
对所有非受保护IP地址开启DNS flood攻击防范检测后,设备将采用全局的阈值设置(由dns-flood threshold命令设置)和处理行为(由dns-flood action命令配置)对这些IP地址进行保护。
# 在攻击防范策略atk-policy-1中,对所有非受保护IP地址开启DNS flood攻击防范检测。
[Sysname-attack-defense-policy-atk-policy-1] dns-flood detect non-specific
·     dns-flood action
·     dns-flood detect
1.1.47  dns-flood port
dns-flood port命令用来配置DNS flood攻击防范的全局检测端口号。
undo dns-flood port命令用来恢复缺省情况。
dns-flood port port-list
undo dns-flood port
DNS flood攻击防范的全局检测端口号为53。
攻击防范策略视图
设备只对指定检测端口上收到的报文进行DNS flood攻击检测。
对于所有非受保护IP地址,或未指定检测端口的受保护IP地址,设备采用全局的检测端口进行DNS flood攻击检测。对于所有指定检测端口的受保护IP地址,设备针对为每个受保护IP地址指定的端口进行DNS flood攻击检测。
# 在攻击防范策略atk-policy-1中配置DNS flood攻击防范的全局检测端口为53与61000,当设备检测到访问53端口或61000端口的DNS flood攻击时,启动攻击防范措施。
[Sysname-attack-defense-policy-atk-policy-1] dns-flood port 53 61000
·     dns-flood action
·     dns-flood detect
1.1.48  dns-flood threshold
dns-flood threshold命令用来配置DNS flood攻击防范的全局触发阈值。
undo dns-flood threshold命令用来恢复缺省情况。
dns-flood threshold threshold-value
DNS flood攻击防范的全局触发阈值为1000。
攻击防范策略视图
threshold-value:指定向某IP地址每秒发送的DNS报文数目,取值范围为1~1000000。使能DNS flood攻击防范后,设备处于攻击检测状态,当它监测到向某IP地址发送DNS报文的速率持续达到或超过了该触发阈值时,即认为该IP地址受到了DNS flood攻击,则进入攻击防范状态,并根据配置启动相应的防范措施。
对于未专门配置DNS flood攻击防范检测的IP地址,设备采用全局的阈值设置来进行保护。阈值的取值需要根据实际网络应用场景进行调整,对于正常情况下到被保护对象(DNS服务器)的DNS报文流量较大的应用场景,建议调大触发阈值,以免阈值太小对正常的业务流量造成影响;对于网络状况较差,且对攻击流量比较敏感的场景,可以适当调小触发阈值。
# 在攻击防范策略atk-policy-1中配置DNS flood攻击防范的全局触发阈值为100,即当设备监测到向某IP地址每秒发送的DNS报文数持续达到或超过100时,启动攻击防范措施。
[Sysname-attack-defense-policy-atk-policy-1] dns-flood threshold 100
·     dns-flood action
·     dns-flood detect ip
1.1.49  exempt acl
exempt acl命令用来配置攻击防范例外列表。
undo exempt acl命令用来恢复缺省情况。
exempt acl [ ipv6 ] { acl-number | name acl-name }
undo exempt acl [ ipv6 ]
未配置攻击防范例外列表。
攻击防范策略视图
ipv6:指定IPv6 ACL。如果未指定本参数,则表示IPv4 ACL。
acl-number:表示ACL的编号,取值范围及其代表的ACL类型如下:
·     2000~2999:若未指定ipv6关键字,表示IPv4基本ACL;否则表示IPv6基本ACL。
·     3000~3999:若未指定ipv6关键字,表示IPv4高级ACL;否则表示IPv6高级ACL。
name acl-name:指定ACL的名称。acl-name表示ACL的名称,为1~63个字符的字符串,不区分大小写,必须以英文字母a~z或A~Z开头。为避免混淆,ACL的名称不允许使用英文单词all。
通过配置例外列表,使用ACL过滤不需要进行攻击防范检测的主机报文。当接口或安全域上收到的报文与攻击防范例外列表引用的ACL中的permit规则匹配时,设备不对其进行攻击防范检测。该配置用于过滤某些被信任的安全主机发送的报文,可以有效的减小误报率,并提高服务器处理效率。
例外列表引用的ACL的permit规则中仅源地址、目的地址、源端口、目的端口、协议号、L3VPN和非首片分片标记参数用于匹配报文。
如果配置的攻击防范例外列表中引用的ACL不存在,或引用的ACL中未定义任何规则,例外列表不会生效。
# 在攻击防范策略atk-policy-1中配置例外列表ACL 2001,过滤来自主机1.1.1.1的报文,不对其进行攻击防范检测。
[Sysname] acl basic 2001
[attack-defense-policy-atk-policy-1] exempt acl 2001
·     attack-defense policy
1.1.50  fin-flood action
fin-flood action命令用来配置对FIN flood攻击防范的全局处理行为。
undo fin-flood action命令用来恢复缺省情况。
fin-flood action { client-verify | drop | logging } *
不对检测到的FIN flood攻击采取任何处理行为。
攻击防范策略视图
client-verify:表示自动将受到攻击的IP地址添加到TCP客户端验证的受保护IP列表中。若客户端验证功能已使能,则对客户端与受保护IP地址之间的连接进行代理。
drop:表示丢弃攻击报文,即设备检测到攻击发生后,向被攻击者发送的后续所有FIN报文都会被丢弃。
本命令中client-verify参数的使用需要和TCP客户端验证功能配合。开启了TCP客户端验证的接口或安全域检测到ACK flood攻击时,若本命令中指定了client-verify参数,则设备会将受攻击的IP地址动态添加到相应客户端验证的受保护IP列表中,并对与这些IP地址建立的连接进行代理。若接口或安全域上未开启相应的代理功能,则不会对任何连接进行代理。
#在攻击防范策略atk-policy-1配置对FIN flood攻击防范的全局处理行为是丢弃后续报文。
[Sysname-attack-defense-policy-atk-policy-1] fin-flood action drop
·     client-verify tcp enable
·     fin-flood detect
·     fin-flood detect non-specific
·     fin-flood threshold
1.1.51  fin-flood detect
fin-flood detect命令用来开启对指定IP地址的FIN flood攻击防范检测,并配置FIN flood攻击防范检测的触发阈值和对FIN flood攻击的处理行为。
undo fin-flood detect命令用来关闭对指定IP地址的FIN flood攻击防范检测。
fin-flood detect { ip ipv4-address | ipv6 ipv6-address } [ vpn-instance vpn-instance-name ] [ threshold threshold-value ] [ action { { client-verify | drop | logging } * | none } ]
undo fin-flood detect { ip ipv4-address | ipv6 ipv6-address } [ vpn-instance vpn-instance-name ]
未对任何指定IP地址配置FIN flood攻击防范检测。
攻击防范策略视图
threshold threshold-value:指定攻击防范的触发阈值。其中,threshold-value为向指定IP地址每秒发送的FIN报文数目,取值范围为1~1000000。
action:设置对FIN flood攻击的处理行为。
client-verify:表示当自动将受到攻击的IP地址添加到TCP客户端验证的受保护IP列表中。若客户端验证功能使能,则对客户端与受保护IP地址之间的连接进行代理。
none:表示不采取任何动作。
每个攻击防范策略下可以同时对多个IP地址配置FIN flood攻击防范检测。
使能FIN flood攻击防范后,设备处于攻击检测状态,当它监测到向指定IP地址发送FIN报文的速率持续达到或超过了触发阈值时,即认为该IP地址受到了FIN flood攻击,则进入攻击防范状态,并根据配置启动相应的防范措施。此后,当设备检测到向该服务器发送报文的速率低于恢复阈值(触发阈值的3/4)时,即认为攻击结束,则由攻击防范状态恢复为攻击检测状态,并停止执行防范措施。
# 在攻击防范策略atk-policy-1中开启对IP地址192.168.1.2的FIN flood攻击防范检测,并指定触发阈值为2000。当设备监测到向该IP地址每秒发送的FIN报文数持续达到或超过2000时,启动FIN flood攻击防范。
[Sysname-attack-defense-policy-atk-policy-1] fin-flood detect ip 192.168.1.2 threshold 2000
·     fin-flood action
1.1.52  fin-flood detect non-specific
fin-flood detect non-specific命令用来对所有非受保护IP地址开启FIN flood攻击防范检测。
undo fin-flood detect non-specific命令用来关闭对所有非受保护IP地址的FIN flood攻击防范检测。
未对任何非受保护IP地址开启FIN flood攻击防范检测。
攻击防范策略视图
对所有非受保护IP地址开启FIN flood攻击防范检测后,设备将采用全局的阈值设置(由fin-flood threshold命令设置)和处理行为(由fin-flood action命令配置)对这些IP地址进行保护。
# 在攻击防范策略atk-policy-1中,对所有非受保护IP地址开启FIN flood攻击防范检测。
[Sysname-attack-defense-policy-atk-policy-1] fin-flood detect non-specific
·     fin-flood action
·     fin-flood detect
1.1.53  fin-flood threshold
fin-flood threshold命令用来配置FIN flood攻击防范的全局触发阈值。
undo fin-flood threshold命令用来恢复缺省情况。
fin-flood threshold threshold-value
FIN flood攻击防范的全局触发阈值为1000。
攻击防范策略视图
threshold-value:指定向某IP地址每秒发送的FIN报文数目,取值范围为1~1000000。使能FIN flood攻击防范后,设备处于攻击检测状态,当它监测到向某IP地址发送FIN报文的速率持续达到或超过了该触发阈值时,即认为该IP地址受到了FIN flood攻击,则进入攻击防范状态,并根据配置启动相应的防范措施。
对于未专门配置FIN flood攻击防范检测的IP地址,设备采用全局的阈值设置来进行保护。阈值的取值需要根据实际网络应用场景进行调整,对于正常情况下到被保护对象(HTTP服务器或者FTP服务器)的FIN报文流量较大的应用场景,建议调大触发阈值,以免阈值太小对正常的业务流量造成影响;对于网络状况较差,且对攻击流量比较敏感的场景,可以适当调小触发阈值。
# 在攻击防范策略atk-policy-1中配置FIN flood攻击防范检测的全局触发阈值为100,即当设备监测到向某IP地址每秒发送的FIN报文数持续达到或超过100时,启动FIN flood攻击防范。
[Sysname-attack-defense-policy-atk-policy-1] fin-flood threshold 100
·     fin-flood action
·     fin-flood detect
1.1.54  http-flood action
http-flood action命令用来配置对HTTP flood攻击防范的全局处理行为。
undo http-flood action命令用来恢复缺省情况。
http-flood action { client-verify | drop | logging } *
不对检测到的HTTP flood攻击采取任何处理行为。
攻击防范策略视图
client-verify:表示自动将受到攻击的IP地址添加到HTTP客户端验证的受保护IP列表中。若客户端验证功能已使能,则对客户端与受保护IP地址之间的连接进行代理。
drop:表示丢弃攻击报文,即设备检测到攻击发生后,向被攻击者发送的后续所有HTTP报文都会被丢弃。
本命令中client-verify参数的使用需要和HTTP客户端验证功能配合。开启了HTTP客户端验证的接口或安全域检测到HTTP flood攻击时,若本命令中指定了client-verify参数,则设备会将受攻击的IP地址动态添加到相应客户端验证的受保护IP列表中,并对与这些IP地址建立的连接进行代理。若接口或安全域上未开启相应的代理功能,则不会对任何连接进行代理。
# 在攻击防范策略atk-policy-1中配置对HTTP flood攻击防范的全局处理行为是丢弃后续报文。
[Sysname-attack-defense-policy-atk-policy-1] http-flood action drop
·     client-verify http enable
·     http-flood detect non-specific
·     http-flood detect
·     http-flood threshold
1.1.55  http-flood detect
http-flood detect命令用来开启对指定IP地址的HTTP flood攻击防范检测,并配置HTTP flood攻击防范的触发阈值和对HTTP flood攻击的处理行为。
undo http-flood detect命令用来关闭对指定IP地址的HTTP flood攻击防范检测。
http-flood detect { ip ipv4-address | ipv6 ipv6-address } [ vpn-instance vpn-instance-name ] [ port port-list ] [ threshold threshold-value ] [ action { { client-verify | drop | logging } * | none } ]
undo http-flood detect { ip ipv4-address | ipv6 ipv6-address } [ vpn-instance vpn-instance-name ]
未对任何指定IP地址配置HTTP flood攻击防范检测。
攻击防范策略视图
port port-list:指定开启HTTP flood攻击防范检测的端口列表,表示方式为{ start-port-number [ to end-port-number ] } &<1-65535>。&<1-65535>表示前面的参数最多可以输入65535次。end-port-number必须大于或等于start-port-number。若未指定本参数,则表示使用全局配置的检测端口列表。
threshold threshold-value:指定攻击防范的触发阈值。其中,threshold-value为向指定IP地址每秒发送的HTTP报文数目,取值范围为1~1000000。
action:设置对HTTP flood攻击的处理行为。
none:表示不采取任何动作。
每个攻击防范策略下可以同时对多个IP地址配置HTTP flood攻击防范检测。
使能HTTP flood攻击防范后,设备处于攻击检测状态,当它监测到向指定IP地址发送HTTP报文的速率持续达到或超过了触发阈值时,即认为该IP地址受到了HTTP flood攻击,则进入攻击防范状态,并根据配置启动相应的防范措施。此后,当设备检测到向该服务器发送报文的速率低于恢复阈值(触发阈值的3/4)时,即认为攻击结束,则由攻击防范状态恢复为攻击检测状态,并停止执行防范措施。
# 在攻击防范策略atk-policy-1中开启对IP地址192.168.1.2的HTTP flood攻击防范检测,并指定检测端口为80与8080、触发阈值为2000。当设备监测到向该IP地址的80或8080端口每秒发送的HTTP报文数持续达到或超过2000时,启动HTTP flood攻击防范。
[Sysname-attack-defense-policy-atk-policy-1] http-flood detect ip 192.168.1.2 port 80 8080 threshold 2000
·     http-flood action
·     http-flood port
1.1.56  http-flood detect non-specific
http-flood detect non-specific命令用来对所有非受保护IPv4地址开启HTTP flood攻击防范检测。
undo http-flood detect non-specific命令用来关闭对所有非受保护IPv4地址的HTTP flood攻击防范检测。
未对任何非受保护IP地址开启HTTP flood攻击防范检测。
攻击防范策略视图
对所有非受保护IP地址开启HTTP flood攻击防范检测后,设备将采用全局的阈值设置(由http-flood threshold命令设置)和处理行为(由http-flood action命令配置)对这些IP地址进行保护。
# 在攻击防范策略atk-policy-1中,对所有非受保护IP地址开启HTTP flood攻击防范检测。
[Sysname-attack-defense-policy-atk-policy-1] http-flood detect non-specific
·     http-flood action
·     http-flood detect
1.1.57  http-flood port
http-flood port命令用来配置HTTP flood攻击防范的全局检测端口号。
undo http-flood port命令用来恢复缺省情况。
http-flood port port-list
HTTP flood攻击防范的全局检测端口号为80。
攻击防范策略视图
设备只对指定检测端口上收到的报文进行HTTP flood攻击检测。
对于所有非受保护IP地址,或未指定检测端口的受保护IP地址,设备采用全局的检测端口进行HTTP flood攻击检测。对于所有指定检测端口的受保护IP地址,设备针对为每个受保护IP地址指定的端口进行HTTP flood攻击检测。
# 在攻击防范策略atk-policy-1中配置DNS flood攻击防范的全局检测端口为80与8080,当设备检测到访问80端口或8080端口的HTTP flood攻击时,启动攻击防范措施。
[Sysname-attack-defense-policy-atk-policy-1] http-flood port 80 8080
·     http-flood action
·     http-flood detect
1.1.58  http-flood threshold
http-flood threshold命令用来配置HTTP flood攻击防范的全局触发阈值。
undo http-flood threshold命令用来恢复缺省情况。
http-flood threshold threshold-value
缺省情况下,HTTP flood攻击防范的全局触发阈值为1000。
攻击防范策略视图
threshold-value:指定向某IP地址每秒发送的HTTP报文数目,取值范围为1~1000000。使能HTTP flood攻击防范后,设备处于攻击检测状态,当它监测到向某IP地址发送HTTP报文的速率持续达到或超过了该触发阈值时,即认为该IP地址受到了HTTP flood攻击,则进入攻击防范状态,并根据配置启动相应的防范措施。
对于未专门配置HTTP flood攻击防范检测的IP地址,设备采用全局的阈值设置来进行保护。阈值的取值需要根据实际网络应用场景进行调整,对于正常情况下到被保护对象(HTTP服务器)的HTTP报文流量较大的应用场景,建议调大触发阈值,以免阈值太小对正常的业务流量造成影响;对于网络状况较差,且对攻击流量比较敏感的场景,可以适当调小触发阈值。
# 在攻击防范策略atk-policy-1中配置HTTP flood攻击防范的全局触发阈值为100, 即当设备监测到向某IP地址每秒发送的HTTP报文数持续达到或超过100时,启动HTTP flood攻击防范。
[Sysname-attack-defense-policy-atk-policy-1] http-flood threshold 100
·     http-flood action
·     http-flood detect
1.1.59  icmp-flood action
icmp-flood action命令用来配置对ICMP flood攻击防范的全局处理行为。
undo icmp-flood action命令用来恢复缺省情况。
icmp-flood action { drop | logging } *
不对检测到的ICMP flood攻击采取任何措施。
攻击防范策略视图
drop:表示丢弃攻击报文,即设备检测到攻击发生后,向被攻击者发送的后续所有ICMP报文都会被丢弃。
# 在攻击防范策略atk-policy-1中配置对ICMP flood攻击防范的全局处理行为是丢弃后续报文。
[Sysname-attack-defense-policy-atk-policy-1] icmp-flood action drop
·     icmp-flood detect non-specific
·     icmp-flood detect ip
·     icmp-flood threshold
1.1.60  icmp-flood detect ip
icmp-flood detect ip命令用来开启对指定IP地址的ICMP flood攻击防范检测,并配置ICMP flood攻击防范检测的触发阈值和对ICMP flood攻击的处理行为。
undo icmp-flood detect ip命令用来关闭对指定IP地址的ICMP flood攻击防范检测。
icmp-flood detect ip ip-address [ vpn-instance vpn-instance-name ] [ threshold threshold-value ] [ action { { drop | logging } * | none } ]
undo icmp-flood detect ip ip-address [ vpn-instance vpn-instance-name ]
未对任何指定IP地址配置ICMP flood 攻击防范触发阈值。
攻击防范策略视图
ip ip-address:指定要保护的IP地址。该IP地址不能为255.255.255.255或0.0.0.0。
threshold threshold-value:指定攻击防范的触发阈值。其中,threshold-value为向指定IP地址每秒发送的ICMP报文数目,取值范围为1~1000000。
action:设置对ICMP flood攻击的处理行为。
none:表示不采取任何动作。
每个攻击防范策略下可以同时对多个IP地址配置ICMP flood攻击防范检测。
使能ICMP flood攻击防范后,设备处于攻击检测状态,当它监测到向指定IP地址发送ICMP报文的速率持续达到或超过了触发阈值时,即认为该IP地址受到了ICMP flood攻击,则进入攻击防范状态,并根据配置启动相应的防范措施。此后,当设备检测到向该服务器发送报文的速率低于恢复阈值(触发阈值的3/4)时,即认为攻击结束,则由攻击防范状态恢复为攻击检测状态,并停止执行防范措施。
# 在攻击防范策略atk-policy-1中开启对IP地址192.168.1.2的ICMP flood攻击防范检测,并指定触发阈值为2000。当设备监测到向该IP地址每秒发送的ICMP报文数持续达到或超过2000时,启动ICMP flood攻击防范。
[Sysname-attack-defense-policy-atk-policy-1] icmp-flood detect ip 192.168.1.2 threshold 2000
·     icmp-flood action
1.1.61  icmp-flood detect non-specific
icmp-flood detect non-specific命令用来对所有非受保护IPv4地址开启ICMP flood攻击防范检测。
undo icmp-flood detect non-specific命令用来关闭对所有非受保护IPv4地址的ICMP flood攻击防范检测。
未对任何非受保护IPv4地址开启ICMP flood攻击防范检测。
攻击防范策略视图
对任何非受保护IPv4地址开启ICMP flood攻击防范检测后,设备将采用全局的阈值设置(由icmp-flood threshold命令设置)和处理行为(由icmp-flood action命令配置)对这些IP地址进行保护。
# 在攻击防范策略atk-policy-1中,对所有非受保护IPv4地址开启ICMP flood攻击防范检测。
[Sysname-attack-defense-policy-atk-policy-1] icmp-flood detect non-specific
·     icmp-flood action
1.1.62  icmp-flood threshold
icmp-flood threshold命令用来配置ICMP flood攻击防范的全局触发阈值。
undo icmp-flood threshold命令用来恢复缺省情况。
icmp-flood threshold threshold-value
ICMP flood攻击防范的全局触发阈值为1000。
攻击防范策略视图
threshold-value:指定向某IP地址每秒发送的ICMP报文数目,取值范围为1~1000000。使能ICMP flood攻击防范后,设备处于攻击检测状态,当它监测到向某IP地址发送ICMP报文的速率持续达到或超过了该触发阈值时,即认为该IP地址受到了ICMP flood攻击,则进入攻击防范状态,并根据配置启动相应的防范措施。
对于未专门配置ICMP flood攻击防范检测的IP地址,设备采用全局的阈值设置来进行保护。阈值的取值需要根据实际网络应用场景进行调整,对于正常情况下到被保护对象(HTTP服务器或者FTP服务器)的ICMP报文流量较大的应用场景,建议调大触发阈值,以免阈值太小对正常的业务流量造成影响;对于网络状况较差,且对攻击流量比较敏感的场景,可以适当调小触发阈值。
# 在攻击防范策略atk-policy-1中配置ICMP flood攻击防范检测的全局触发阈值为100,即当设备监测到向某IP地址每秒发送的ICMP报文数持续达到或超过100时,启动ICMP flood攻击防范。
[Sysname-attack-defense-policy-atk-policy-1] icmp-flood threshold 100
·     icmp-flood action
·     icmp-flood detect
1.1.63  icmpv6-flood action
icmpv6-flood action命令用来配置对ICMPv6 flood攻击防范的全局处理行为。
undo icmpv6-flood action命令用来恢复缺省情况。
icmpv6-flood action { drop | logging } *
不对检测到的ICMPv6 flood攻击采取任何防范措施。
攻击防范策略视图
drop:表示丢弃攻击报文,即设备检测到攻击发生后,向被攻击者发送的后续所有ICMPv6报文都会被丢弃。
# 在攻击防范策略atk-policy-1中配置对ICMPv6 flood攻击防范的全局处理行为是丢弃后续报文。
[Sysname-attack-defense-policy-atk-policy-1] icmpv6-flood action drop
·     icmpv6-flood detect ipv6
·     icmpv6-flood detect non-specific
·     icmpv6-flood threshold
1.1.64  icmpv6-flood detect ipv6
icmpv6-flood detect ipv6命令用来开启对指定IPv6地址的ICMPv6 flood攻击防范检测,并配置ICMPv6 flood攻击防范检测的触发阈值和对ICMPv6 flood攻击的处理行为。
undo icmpv6-flood detect ipv6命令用来关闭对指定IPv6地址的ICMPv6 flood攻击防范检测。
icmpv6-flood detect ipv6 ipv6-address [ vpn-instance vpn-instance-name ] [ threshold threshold-value ] [ action { { drop | logging } * | none } ]
undo icmpv6-flood detect ipv6 ipv6-address [ vpn-instance vpn-instance-name ]
未对任何指定IPv6地址配置ICMPv6 flood攻击防范检测。
攻击防范策略视图
threshold threshold-value:指定攻击防范的触发阈值。其中,threshold-value为向指定IP地址每秒发送的ICMPv6报文数目,取值范围为1~1000000。
action:设置对ICMPv6 flood攻击的处理行为。
none:表示不采取任何动作。
每个攻击防范策略下可以同时对多个IPv6地址配置ICMPv6 flood攻击防范检测。
使能ICMPv6 flood攻击防范后,设备处于攻击检测状态,当它监测到向指定IP地址发送ICMPv6报文的速率持续达到或超过了触发阈值时,即认为该IP地址受到了ICMPv6 flood攻击,则进入攻击防范状态,并根据配置启动相应的防范措施。此后,当设备检测到向该服务器发送报文的速率低于恢复阈值(触发阈值的3/4)时,即认为攻击结束,则由攻击防范状态恢复为攻击检测状态,并停止执行防范措施。
# 在攻击防范策略atk-policy-1中开启对IP地址2012::12的ICMPv6 flood攻击防范检测,并指定触发阈值为2000。当设备监测到向该IP地址每秒发送的ICMP报文数持续达到或超过2000时,启动ICMPv6 flood攻击防范。
[Sysname-attack-defense-policy-atk-policy-1] icmpv6-flood detect ipv6 2012::12 threshold 2000
·     icmpv6-flood action
1.1.65  icmpv6-flood detect non-specific
icmpv6-flood detect non-specific命令用来对所有非受保护IPv6地址开启ICMPv6 flood攻击防范检测。
undo icmpv6-flood detect non-specific命令用来关闭对所有非受保护IPv6地址的ICMPv6 flood攻击防范检测。
未对任何非受保护IPv6地址开启ICMPv6 flood攻击防范检测。
攻击防范策略视图
对所有非受保护IPv6地址开启ICMPv6 flood攻击防范检测后,设备将采用全局的阈值设置(由icmpv6-flood threshold命令设置)和处理行为(由icmpv6-flood action命令配置)对这些IP地址进行保护。
# 在攻击防范策略atk-policy-1中,对所有非受保护IPv6地址开启ICMPv6 flood攻击防范检测。
[Sysname-attack-defense-policy-atk-policy-1] icmpv6-flood detect non-specific
1.1.66  icmpv6-flood threshold
icmpv6-flood threshold命令用来配置ICMPv6 flood攻击防范的全局触发阈值。
undo icmpv6-flood threshold命令用来恢复缺省情况。
icmpv6-flood threshold threshold-value
ICMPv6 flood攻击防范的全局触发阈值为1000。
攻击防范策略视图
threshold-value:指定向某IP地址每秒发送的ICMPv6报文数目,取值范围为1~1000000。使能ICMPv6 flood攻击防范后,设备处于攻击检测状态,当它监测到向某IP地址发送ICMPv6报文的速率持续达到或超过了该触发阈值时,即认为该IP地址受到了ICMPv6 flood攻击,则进入攻击防范状态,并根据配置启动相应的防范措施。
对于未专门配置ICMPv6 flood攻击防范检测的IP地址,设备采用全局的阈值设置来进行保护。阈值的取值需要根据实际网络应用场景进行调整,对于正常情况下到被保护对象(HTTP服务器或者FTP服务器)的ICMPv6报文流量较大的应用场景,建议调大触发阈值,以免阈值太小对正常的业务流量造成影响;对于网络状况较差,且对攻击流量比较敏感的场景,可以适当调小触发阈值。
# 在攻击防范策略atk-policy-1中配置ICMPv6 flood攻击防范检测的全局触发阈值为100,即当设备监测到向某IP地址每秒发送的ICMPv6报文数持续达到或超过100时,启动ICMPv6 flood攻击防范。
[Sysname-attack-defense-policy-atk-policy-1] icmpv6-flood threshold 100
1.1.67  reset attack-defense policy flood
reset attack-defense policy flood命令用来清除flood攻击防范受保护IP表项的统计信息。
reset attack-defense policy policy-name flood protected { ip | ipv6 } statistics
policy-name:攻击防范策略名称,为1~31个字符的字符串,不区分大小写。合法取值包括大写字母、小写字母、数字、特殊字符“_”和“-”。
ip:指定IPv4类型的flood受保护IP表项。
ipv6:指定IPv6类型的flood受保护IP表项。
statistics:清除指定类型的flood受保护IP表项的统计信息。
# 清除攻击防范策略abc中所有IPv4类型的flood保护IP表项的统计信息
<Sysname> reset attack-defense policy abc flood protected ip statistics
# 清除攻击防范策略abc中所有IPv6类型的flood保护IP表项的统计信息
<Sysname> reset attack-defense policy abc flood protected ipv6 statistics
·     display attack-defense policy ip
·     display attack-defense policy ipv6
1.1.68  reset attack-defense statistics interface
reset attack-defense statistics interface命令用来清除接口上的攻击防范统计信息。
reset attack-defense statistics interface interface-type interface-number
本命令会将指定接口上攻击防范的所有统计信息清零。
# 清除接口GigabitEthernet2/1/1上的攻击防范的统计信息。
<Sysname> reset attack-defense statistics interface gigabitethernet 2/1/1
1.1.69  reset attack-defense top-attack-statistics
reset attack-defense top-attack-statistics命令用来清除Top10的攻击排名统计信息。
# 清除Top10的攻击排名统计信息。
<Sysname> reset attack-defense top-attack-statistics
·     display attack-defense top-attack-statistics
1.1.70  reset attack-defense statistics local
reset attack-defense statistics local命令用来清除本机攻击防范的统计信息。
# 清除本机上所有攻击防范的统计信息。
<Sysname> reset attack-defense statistics local
·     display attack-defense statistics local
1.1.71  reset attack-defense statistics security-zone
reset attack-defense statistics security-zone命令用来清除安全域上的攻击防范的统计信息。
reset attack-defense statistics security-zone zone-name
本命令会将指定安全域上攻击防范的所有统计信息清零。
# 清除安全域DMZ上所有攻击防范的统计信息。
<Sysname> reset attack-defense statistics security-zone dmz
1.1.72  reset client-verify protected statistics
reset client-verify protected statistics命令用来清除客户端验证的受保护IP地址的统计信息。
reset client-verify { dns | http | tcp } protected { ip | ipv6 } statistics
dns:指定DNS客户端验证功能。
http:指定HTTP客户端验证功能。
tcp:指定TCP客户端验证功能。
ip:清除所有IPv4类型客户端验证的受保护IP地址的统计信息。
ipv6:清除所有IPv6类型客户端验证的受保护IP地址的统计信息。
# 清除TCP客户端验证的受保护IP地址的统计信息。
<Sysname> reset client-verify tcp protected ip statistics
·     display client-verify protected ip
·     display client-verify protected ipv6
1.1.73  reset client-verify trusted
reset client-verify trusted命令用来清除客户端验证的信任IP表项。
reset client-verify { dns | http | tcp } trusted { ip | ipv6 }
dns:指定DNS客户端验证功能。
http:指定HTTP客户端验证功能。
tcp:指定TCP客户端验证功能。
ip:清除所有IPv4类型客户端验证的信任IP表项。
ipv6:清除所有IPv6类型客户端验证的信任IP表项。
# 清除所有IPv4类型DNS客户端验证的信任IP表项。
<Sysname> reset client-verify dns trusted ip
·     display client-verify trusted ip
·     display client-verify trusted ipv6
1.1.74  rst-flood action
rst-flood action命令用来配置对RST flood攻击防范的全局处理行为。
undo rst-flood action命令用来恢复缺省情况。
rst-flood action { client-verify | drop | logging } *
不对检测到的RST flood攻击采取任何措施。
攻击防范策略视图
drop:表示丢弃攻击报文,即设备检测到攻击发生后,向被攻击者发送的后续所有RST报文都会被丢弃。
本命令中client-verify参数的使用需要和TCP客户端验证功能配合。使能了TCP客户端验证的接口或安全域检测到ACK flood攻击时,若本命令中指定了client-verify参数,则设备会将受攻击的IP地址动态添加到相应客户端验证的受保护IP列表中,并对与这些IP地址建立的连接进行代理。若接口或安全域上未使能相应的代理功能,则不会对任何连接进行代理。
# 在攻击防范策略atk-policy-1中配置对RST flood攻击防范的全局处理行为是丢弃后续报文。
[Sysname-attack-defense-policy-atk-policy-1] rst-flood action drop
·     rst-flood detect
·     rst-flood detect non-specific
·     rst-flood threshold
1.1.75  rst-flood detect
rst-flood detect命令用来开启对指定IP地址的RST flood攻击防范检测,并配置RST flood攻击防范的触发阈值和对RST flood攻击的处理行为。
undo rst-flood命令用来关闭对指定IP地址的RST flood攻击防范检测。
rst-flood detect { ip ipv4-address | ipv6 ipv6-address } [ vpn-instance vpn-instance-name ] [ threshold threshold-value ] [ action { { client-verify | drop | logging } * | none } ]
undo rst-flood detect { ip ipv4-address | ipv6 ipv6-address } [ vpn-instance vpn-instance-name ]
未对任何指定IP地址配置RST flood攻击防范检测。
攻击防范策略视图
threshold threshold-value:指定攻击防范的触发阈值。其中,threshold-value为向指定IP地址每秒发送的RST报文数目,取值范围为1~1000000。
action:设置对RST flood攻击的处理行为。
none:表示不采取任何动作。
每个攻击防范策略下可以同时对多个IP地址配置RST flood攻击防范检测。
使能RST flood攻击防范后,设备处于攻击检测状态,当它监测到向指定IP地址发送RST报文的速率持续达到或超过了触发阈值时,即认为该IP地址受到了RST flood攻击,则进入攻击防范状态,并根据配置启动相应的防范措施。此后,当设备检测到向该服务器发送报文的速率低于恢复阈值(触发阈值的3/4)时,即认为攻击结束,则由攻击防范状态恢复为攻击检测状态,并停止执行防范措施。
# 在攻击防范策略atk-policy-1中开启对IP地址192.168.1.2的RST flood攻击防范检测,并指定触发阈值为2000。当设备监测到向该IP地址每秒发送的RST报文数持续达到或超过2000时,启动RST flood攻击防范。
[Sysname-attack-defense-policy-atk-policy-1] rst-flood detect ip 192.168.1.2 threshold 2000
·     rst-flood action
1.1.76  rst-flood detect non-specific
rst-flood detect non-specific命令用来对所有非受保护IP地址开启RST flood攻击防范检测。
undo rst-flood detect non-specific命令用来关闭对所有非受保护IP地址的RST flood攻击防范检测。
未对任何非受保护IP地址开启RST flood攻击防范检测。
攻击防范策略视图
对所有非受保护IP地址开启RST flood攻击防范检测后,设备将采用全局的阈值设置(由rst-flood threshold命令设置)和处理行为(由rst-flood action命令配置)对这些IP地址进行保护。
# 在攻击防范策略atk-policy-1中,对所有非受保护IP地址开启RST flood攻击防范检测。
[Sysname-attack-defense-policy-atk-policy-1] rst-flood detect non-specific
·     rst-flood action
·     rst-flood detect
1.1.77  rst-flood threshold
rst-flood threshold命令用来配置RST flood攻击防范的全局触发阈值。
undo rst-flood threshold命令用来恢复缺省情况。
rst-flood threshold threshold-value
RST flood攻击防范的全局触发阈值为1000。
攻击防范策略视图
threshold-value:指定向某IP地址每秒发送的RST报文数目,取值范围为1~1000000。使能RST flood攻击防范后,设备处于攻击检测状态,当它监测到向某IP地址发送RST报文的速率持续达到或超过了该触发阈值时,即认为该IP地址受到了RST flood攻击,则进入攻击防范状态,并根据配置启动相应的防范措施。
对于未专门配置RST flood攻击防范检测的IP地址,设备采用全局的阈值设置来进行保护。阈值的取值需要根据实际网络应用场景进行调整,对于正常情况下到被保护对象(HTTP服务器或者FTP服务器)的RST报文流量较大的应用场景,建议调大触发阈值,以免阈值太小对正常的业务流量造成影响;对于网络状况较差,且对攻击流量比较敏感的场景,可以适当调小触发阈值。
# 在攻击防范策略atk-policy-1中配置RST flood攻击防范检测的全局触发阈值为100,即当设备监测到向某IP地址每秒发送的RST报文数持续达到或超过100时,启动RST flood攻击防范。
[Sysname-attack-defense-policy-atk-policy-1] rst-flood threshold 100
·     rst-flood action
·     rst-flood detect
1.1.78  scan detect
scan detect命令用来配置开启指定级别的扫描攻击防范。
undo scan detect命令用来关闭指定级别的扫描攻击防范。
scan detect level { high | low | medium } action { drop | logging } *
undo scan detect level { high | low | medium }
扫描攻击防范处于关闭状态。
攻击防范策略视图
level:指定攻击防范的检测级别。
low:表示低防范级别,该级别提供基本的扫描攻击检测,有很低的误报率,但对于一些扫描攻击类型不能检出。该级别的扫描攻击统计周期为60秒。
high:表示高防范级别,该级别能检测出大部分的扫描攻击,但对活跃主机误报率较高,即将可提供服务的主机的报文错误判断为攻击报文的概率比较高。该级别的扫描攻击统计周期为600秒。
medium:表示中防范级别,该级别有适中的攻击检出率与误报率,通常能够检测出Filtered Scan等攻击。该级别的扫描攻击统计周期为90秒。
action:设置对扫描攻击的处理行为。
drop:表示丢弃攻击报文,即设备检测到攻击发生后,由该攻击者发送的报文都将被丢弃。
logging:表示输出告警日志,即设备检测到攻击发生时,生成记录告警信息,生成的告警信息将被发送到日志系统。
# 在攻击防范策略atk-policy-1中配置扫描攻击的检测级别为低级别,处理行为是丢弃后续报文。
[Sysname-attack-defense-policy-atk-policy-1] scan detect level low action drop
block-source timeout 10
1.1.79  signature { large-icmp | large-icmpv6 } max-length
signature { large-icmp | large-icmpv6 } max-length命令用来配置启动Large ICMP攻击防范的ICMP报文长度的最大值。
undo signature level detect命令用来恢复缺省情况。
signature { large-icmp | large-icmpv6 } max-length length
undo signature { large-icmp  | large-icmpv6 } max-length
启动Large ICMP攻击防范的ICMP报文和ICMPv6报文长度的最大值均为4000字节。
攻击防范策略视图
large-icmp:表示超大ICMP报文攻击防范。
large-icmpv6:表示超大ICMPv6报文攻击防范。
length:表示ICMP报文长度的最大值,ICMP报文取值范围为28~65534,ICMPv6报文取值范围为48~65534,单位为字节。
# 在攻击防范策略atk-policy-1中配置启动Large ICMP攻击防范的ICMP报文长度的最大值为50000字节。
[Sysname-attack-defense-policy-atk-policy-1] signature large-icmp max-length 50000
·     signature detect
1.1.80  signature detect
signature detect命令用来开启指定类型单包攻击报文的特征检测,并设置攻击防范的处理行为。
undo signature detect命令用来关闭对指定类型的单包攻击报文的特征检测。
signature detect { fraggle | fragment | impossible | land | large-icmp | large-icmpv6 | smurf | snork | tcp-all-flags | tcp-fin-only | tcp-invalid-flags | tcp-null-flag | tcp-syn-fin | tiny-fragment | traceroute | udp-bomb | winnuke | ip-option-abnormal | ping-of-death | teardrop } [ action { { drop | logging } * | none } ]
undo signature detect { fraggle | fragment | impossible | land | large-icmp | large-icmpv6 | smurf | snork | tcp-all-flags | tcp-fin-only | tcp-invalid-flags | tcp-null-flag | tcp-syn-fin | tiny-fragment | traceroute | udp-bomb | winnuke | ip-option-abnormal | ping-of-death | teardrop }
signature detect icmp-type { icmp-type-value | address-mask-reply | address-mask-request | destination-unreachable | echo-reply | echo-request | information-reply | information-request | parameter-problem | redirect | source-quench | time-exceeded | timestamp-reply | timestamp-request } [ action { { drop | logging } * | none } ]
undo signature detect icmp-type { icmp-type-value | address-mask-reply | address-mask-request | destination-unreachable | echo-reply | echo-request | information-reply | information-request | parameter-problem | redirect | source-quench | time-exceeded | timestamp-reply | timestamp-request }
signature detect icmpv6-type { icmpv6-type-value | destination-unreachable | echo-reply | echo-request | group-query | group-reduction | group-report | packet-too-big | parameter-problem | time-exceeded } [ action { { drop | logging } * | none } ]
undo signature detect icmpv6-type { icmpv6-type-value | destination-unreachable | echo-reply | echo-request | group-query | group-reduction | group-report | packet-too-big | parameter-problem | time-exceeded }
signature detect ip-option { option-code | internet-timestamp | loose-source-routing | record-route | route-alert | security | stream-id | strict-source-routing } [ action { { drop | logging } * | none } ]
undo signature detect ip-option { option-code | internet-timestamp | loose-source-routing | record-route | route-alert | security | stream-id | strict-source-routing }
signature detect ipv6-ext-header ext-header-value [ action { { drop | logging } * | none } ]
undo signature detect ipv6-ext-header next-header-value
所有类型的单包攻击报文的特征检测均处于关闭状态。
攻击防范策略视图
fraggle:表示Fraggle类型的报文攻击。
fragment:表示IP分片报文攻击。
icmp-type:表示ICMP类型的报文攻击。可以指定报文的类型值,或者指定报文的类型关键字。
·     icmp-type-value:表示ICMP报文类型的数值,取值范围为0~255。
·     address-mask-reply:表示ICMP address mask reply类型的报文攻击。
·     address-mask-request:表示ICMP address mask request类型的报文攻击。
·     destination-unreachable:表示ICMP destination unreachable类型的报文攻击。
·     echo-reply:表示ICMP echo reply类型的报文攻击。
·     echo-request:表示ICMP echo request类型的报文攻击。
·     information-reply:表示ICMP information reply类型的报文攻击。
·     information-request:表示ICMP information request类型的报文攻击。
·     parameter-problem:表示ICMP para problem类型的报文攻击。
·     redirect:表示ICMP redirect类型的报文攻击。
·     source-quench:表示ICMP source quench类型的报文攻击。
·     time-exceeded:表示ICMP time exceeded类型的报文攻击。
·     timestamp-reply:表示ICMP timestamp reply类型的报文攻击。
·     timestamp-request:表示ICMP timestamp request类型的报文攻击。
icmpv6-type:表示ICMPv6类型的报文攻击。可以指定报文的类型值,或者指定报文的类型关键字。
·     icmpv6-type-value:表示ICMPv6报文类型的数值,取值范围为0~255。
·     destination-unreachable:表示ICMPv6 destination unreachable类型的报文攻击。
·     echo-reply:表示ICMPv6 echo reply类型的报文攻击。
·     echo-request:表示ICMPv6 echo request类型的报文攻击。
·     group-query:表示ICMPv6 group query类型的报文攻击。
·     group-reduction:表示ICMPv6 group reduction类型的报文攻击。
·     group-report:表示ICMPv6 group report类型的报文攻击。
·     packet-too-big:表示ICMPv6 packet too big类型的报文攻击。
·     parameter-problem:表示ICMPv6 para problem类型的报文攻击。
·     time-exceeded:表示ICMPv6 time exceeded类型的报文攻击。
impossible:表示IP不可信报文的攻击。
ip-option:表示IP选项类型的报文攻击。可以指定IP选项代码值,或者指定IP选项关键字。
·     option-code:表示IP选项代码值,取值范围为0~255。
·     internet-timestamp:表示IP选项timestamp类型的报文攻击。
·     loose-source-routing:表示IP选项loose source route类型的报文攻击。
·     record-route:表示IP选项record packet route类型的报文攻击。
·     route-alert:表示IP选项route alert类型的报文攻击。
·     security:表示IP选项security类型的报文攻击。
·     stream-id:表示IP选项stream identifier类型的报文攻击。
·     strict-source-routing:表示IP选项strict source route类型的报文攻击。
ip-option-abnormal:表示IP选项异常类型的报文攻击。
ipv6-ext-header ext-header-value:表示IPv6扩展头参数值,取值范围在0~255。
land:表示Land类型的报文攻击。
large-icmp:表示超大ICMP报文的攻击。
large-icmpv6:表示超大ICMPv6报文的攻击。
ping-of-death:表示Ping-of-death类型的报文攻击。
smurf:表示Smurf类型的报文攻击。
snork:表示UDP Snork attack类型的报文攻击。
tcp-all-flags:表示TCP所有标志位均置位的报文攻击。
tcp-fin-only:表示TCP仅FIN标志被置位的报文攻击。
tcp-invalid-flags:表示TCP 标志位非法的报文攻击。
tcp-null-flag:表示TCP 标志位为零的报文攻击。
tcp-syn-fin:表示TCP SYN和FIN标志位被同时置位的报文攻击。
teardrop:表示teardrop类型的报文攻击。
tiny-fragment:表示IP分片报文的攻击。
traceroute:表示Trace route类型的报文攻击。
udp-bomb:表示UDP Bomb attack类型的报文攻击。
winnuke:表示WinNuke类型的报文攻击。
action:对指定报文攻击所采取的攻击防范处理行为。若未指定本参数,则采用该攻击报文所属的攻击防范级别所对应的默认处理行为。
·     drop:设置单包攻击的处理行为为丢弃报文。
·     logging:设置单包攻击的处理行为为发送日志。
·     none:不采取任何动作。
可以通过多次执行本命令开启多种类型的单包攻击报文的特征检测。
若通过数值指定了报文类型,则当指定的数值为标准的报文类型值时,在显示信息中将会显示该数值对应的报文类型字符串,否则显示为数值。
# 在攻击防范策略atk-policy-1中开启对Smurf攻击报文的特征检测,并指定攻击防范处理行为为为丢弃报文。
[Sysname-attack-defense-policy-atk-policy-1] signature detect smurf action drop
·     signature level action
1.1.81  signature level action
signature level action命令用来配置指定级别单包攻击的处理行为。
undo signature level action命令用来恢复缺省情况。
signature level { high | info | low | medium } action { { drop | logging } * | none }
undo signature level { high | info | low | medium } action
对提示级别和低级别的单包攻击的处理行为是发送日志;对中级别的单包攻击的处理行为是发送日志并丢包;对高级别的单包攻击的处理行为是发送日志并丢包。
攻击防范策略视图
high:表示高级别的单包攻击,暂无实例。
info:表示提示级别的单包攻击,例如Large ICMP。
low:表示低级别的单包攻击,例如Traceroute。
medium:表示中级别的单包攻击,例如Winnuke。
none:不采取任何动作。
系统根据单包攻击结果的严重程度由低到高将其划分为四个攻击级别:提示、低级、中级、高级。开启某一个级别的单包攻击报文的特征检测,相当于批量开启了属于该级别的所有类型的单包攻击报文的特征检测。针对某一级别的单包攻击的处理行为由signature level action命令指定。
若同时通过signature detect命令开启了具体类型的单包攻击报文的特征检测,则以signature detect命令配置的参数为准。
# 在攻击防范策略atk-policy-1中配置对提示级别的单包攻击的处理行为是丢弃后续报文。
[Sysname] attack-defense policy 1
[Sysname-attack-defense-policy-1] signature level info action drop
·     signature detect
·     signature level detect
1.1.82  signature level detect
signature level detect命令用来开启指定级别单包攻击报文的特征检测。
undo signature level detect命令用来关闭对指定级别的单包攻击报文的特征检测。
signature level { high | info | low | medium } detect
undo signature level { high | info | low | medium } detect
未开启任何级别的单包攻击报文的特征检测。
攻击防范策略视图
info:表示提示级别的单包攻击,例如Large ICMP报文攻击。
low:表示低级别的单包攻击,例如Traceroute报文攻击。
medium:表示中级别的单包攻击,例如Winnuke报文攻击。
系统根据单包攻击结果的严重程度将其划分为四个级别:提示、低级、中级、高级。开启某一个级别的单包攻击报文的特征检测,相当于批量开启了属于该级别的所有单包攻击报文的特征检测。针对某一级别的单包攻击的处理行为由signature level action命令指定。若通过signature detect命令开启了具体的单包攻击报文的特征检测,则对该类攻击报文的处理行为以signature detect命令配置的参数为准。
可通过display attack-defense policy命令查看各类型单包攻击所属的级别。
# 在攻击防范策略atk-policy-1中开启提示级别的单包攻击报文的特征检测。
[Sysname-attack-defense-policy-1] signature level info detect
·     signature detect
1.1.83  syn-ack-flood action
syn-ack-flood action命令用来配置对SYN-ACK flood攻击防范的全局处理行为。
undo syn-ack-flood action命令用来恢复缺省情况。
syn-ack-flood action { client-verify | drop | logging }*
不对检测到的 SYN-ACK flood攻击采取任何措施。
攻击防范策略视图
drop:表示丢弃攻击报文,即设备检测到攻击发生后,向被攻击者发送的后续所有SYN-ACK报文都会被丢弃。
# 在攻击防范策略atk-policy-1中配置对SYN-ACK flood攻击防范的全局处理行为是丢弃后续报文。
[Sysname-attack-defense-policy-atk-policy-1] syn-ack-flood action drop
·     syn-ack-flood detect
·     syn-ack-flood detect non-specific
·     syn-ack-flood threshold
1.1.84  syn-ack-flood detect
syn-ack-flood detect命令用来对指定IP地址的SYN-ACK flood攻击防范检测,并配置SYN-ACK flood攻击防范检测触发阈值和防范行为。
undo syn-ack-flood detect命令用来关闭对指定IP地址的SYN-ACK flood攻击防范检测。
syn-ack-flood detect { ip ipv4-address | ipv6 ipv6-address } [ vpn-instance vpn-instance-name ] [ threshold threshold-value ] [ action { { client-verify | drop | logging } * | none } ]
undo syn-ack-flood detect { ip ipv4-address | ipv6 ipv6-address } [ vpn-instance vpn-instance-name ]
未对任何指定IP地址配置SYN-ACK flood攻击防范检测。
攻击防范策略视图
threshold threshold-value:指定SYN-ACK flood攻击防范的触发阈值。其中,threshold-value为向指定IP地址每秒发送的SYN-ACK报文数目,取值范围为1~1000000。
action:设置对SYN-ACK flood攻击的处理行为。
none:表示不采取任何动作。
每个攻击防范策略下可以同时对多个IP地址配置SYN-ACK flood攻击防范检测。
使能SYN-ACK flood攻击防范后,设备处于攻击检测状态,当它监测到向指定IP地址发送SYN-ACK报文的速率持续达到或超过了触发阈值时,即认为该IP地址受到了SYN-ACK flood攻击,则进入攻击防范状态,并根据配置启动相应的防范措施。此后,当设备检测到向该服务器发送报文的速率低于恢复阈值(触发阈值的3/4)时,即认为攻击结束,则由攻击防范状态恢复为攻击检测状态,并停止执行防范措施。
# 开启对IP地址192.168.1.2的SYN-ACK flood攻击防范检测,并指定触发阈值为2000。当设备监测到向该IP地址每秒发送的SYN-ACK报文数持续达到或超过2000时,启动SYN-ACK攻击防范。
[Sysname-attack-defense-policy-atk-policy-1] syn-ack-flood detect ip 192.168.1.2 threshold 2000
·     syn-ack-flood action
1.1.85  syn-ack-flood detect non-specific
syn-ack-flood detect non-specific命令用来对所有非受保护IP地址开启SYN-ACK flood攻击防范检测。
undo syn-ack-flood detect non-specific命令用来关闭对所有非受保护IP地址的SYN-ACK flood攻击防范检测。
未对任何非受保护IP地址开启SYN-ACK flood攻击防范检测。
攻击防范策略视图
对所有非受保护IP地址开启SYN-ACK flood攻击防范检测后,设备将采用全局的阈值设置(由syn-ack-flood threshold命令设置)和处理行为(由syn-ack-flood action命令配置)对这些IP地址进行保护。
# 在攻击防范策略atk-policy-1中,对所有非受保护IP地址开启UDP flood攻击防范检测。
[Sysname-attack-defense-policy-atk-policy-1] syn-ack-flood detect non-specific
·     syn-ack flood action
1.1.86  syn-ack-flood threshold
syn-ack-flood threshold命令用来配置SYN-ACK flood攻击防范的全局触发阈值。
undo syn-ack-flood threshold命令用来恢复缺省情况。
syn-ack-flood threshold threshold-value
SYN-ACK flood攻击防范的全局触发阈值为1000。
攻击防范策略视图
threshold-value:指定向某IP地址每秒发送的SYN-ACK报文数目,取值范围为1~1000000。使能SYN-ACK flood攻击防范后,设备处于攻击检测状态,当它监测到向某IP地址发送SYN-ACK报文的速率持续达到或超过了该触发阈值时,即认为该IP地址受到了SYN-ACK flood攻击,则进入攻击防范状态,并根据配置启动相应的防范措施。
对于未专门配置SYN-ACK flood攻击防范检测的IP地址,设备采用全局的阈值设置来进行保护。阈值的取值需要根据实际网络应用场景进行调整,对于正常情况下到被保护对象(HTTP服务器或者FTP服务器)的SYN-ACK报文流量较大的应用场景,建议调大触发阈值,以免阈值太小对正常的业务流量造成影响;对于网络状况较差,且对攻击流量比较敏感的场景,可以适当调小触发阈值。
# 在攻击防范策略atk-policy-1中配置SYN-ACK flood攻击防范的全局触发阈值为100,即当设备监测到向某IP地址每秒发送的SYN-ACK报文数持续达到或超过100时,启动SYN-ACK flood攻击防范。
[Sysname-attack-defense-policy-atk-policy-1] syn-ack-flood threshold 100
1.1.87  syn-flood action
syn-flood action命令用来配置对SYN flood攻击防范的全局处理行为。
undo syn-flood action命令用来恢复缺省情况。
syn-flood action { client-verify | drop | logging } *
不对检测到的SYN flood攻击采取任何措施。
攻击防范策略视图
drop:表示丢弃攻击报文,即设备检测到攻击发生后,向被攻击者发送的后续所有SYN报文都会被丢弃。
本命令中client-verify参数的使用分别需要和TCP客户端验证功能配合。开启了TCP客户端验证的接口或安全域检测到ACK flood攻击时,若本命令中指定了client-verify参数,则设备会将受攻击的IP地址动态添加到相应客户端验证的受保护IP列表中,并对与这些IP地址建立的连接进行代理。若接口或安全域上未开启相应的代理功能,则不会对任何连接进行代理。
# 在攻击防范策略atk-policy-1中配置对SYN flood攻击防范的全局处理行为是丢弃后续报文。
[Sysname-attack-defense-policy-atk-policy-1] syn-flood action drop
·     syn-flood detect non-specific
·     syn-flood detect
·     syn-flood threshold
1.1.88  syn-flood detect
syn-flood detect命令用来开启对指定IP地址的SYN flood攻击防范检测,并配置SYN flood攻击防范检测的触发阈值和对SYN flood攻击的处理行为。
undo syn-flood detect命令用来关闭对指定IP地址的SYN flood攻击防范检测。
syn-flood detect { ip ipv4-address | ipv6 ipv6-address } [ vpn-instance vpn-instance-name ] [ threshold threshold-value ] [ action { { client-verify | drop | logging } * | none } ]
undo syn-flood detect { ip ipv4-address | ipv6 ipv6-address } [ vpn-instance vpn-instance-name ]
未对任何指定IP地址配置SYN flood攻击防范检测。
攻击防范策略视图
threshold threshold-value:指定SYN flood攻击防范的触发阈值。其中,threshold-value为向指定IP地址每秒发送的SYN报文数目,取值范围为1~1000000。
action:设置对SYN flood攻击的处理行为。
none:表示不采取任何动作。
每个攻击防范策略下可以同时对多个IP地址配置SYN flood攻击防范检测。
使能SYN flood攻击防范后,设备处于攻击检测状态,当它监测到向指定IP地址发送SYN报文的速率持续达到或超过了触发阈值时,即认为该IP地址受到了SYN flood攻击,则进入攻击防范状态,并根据配置启动相应的防范措施。此后,当设备检测到向该服务器发送报文的速率低于恢复阈值(触发阈值的3/4)时,即认为攻击结束,则由攻击防范状态恢复为攻击检测状态,并停止执行防范措施。
# 在攻击防范策略atk-policy-1中开启对IP地址192.168.1.2的SYN flood攻击防范检测,并指定触发阈值为2000。当设备监测到向该IP地址每秒发送的SYN报文数持续达到或超过2000时,启动SYN flood攻击防范。
[Sysname-attack-defense-policy-atk-policy-1] syn-flood detect ip 192.168.1.2 threshold 2000
·     syn-flood action
1.1.89  syn-flood detect non-specific
syn-flood detect non-specific命令用来对所有非受保护IP地址开启SYN flood攻击防范检测。
undo syn-flood detect non-specific命令用来关闭对所有非受保护IP地址的SYN flood攻击防范检测。
未对任何非受保护IP地址开启SYN flood攻击防范检测。
攻击防范策略视图
对所有非受保护IP地址开启SYN flood攻击防范检测后,设备将采用全局的阈值设置(由syn-flood threshold命令设置)和处理行为(由syn-flood action命令配置)对这些IP地址进行保护。
# 在攻击防范策略atk-policy-1中,对所有非受保护IP地址开启SYN flood攻击防范检测。
[Sysname-attack-defense-policy-atk-policy-1] syn-flood detect non-specific
·     syn-flood action
·     syn-flood detect
1.1.90  syn-flood threshold
syn-flood threshold命令用来配置SYN flood攻击防范的全局触发阈值。
undo syn-flood threshold命令用来恢复缺省情况。
syn-flood threshold threshold-value
SYN flood攻击防范的全局触发阈值为1000。
攻击防范策略视图
threshold-value:指定向某IP地址每秒发送的SYN报文数目,取值范围为1~1000000。使能SYN flood攻击防范后,设备处于攻击检测状态,当它监测到向某IP地址发送SYN报文的速率持续达到或超过了该触发阈值时,即认为该IP地址受到了SYN flood攻击,则进入攻击防范状态,并根据配置启动相应的防范措施。
对于未专门配置SYN flood攻击防范检测的IP地址,设备采用全局的阈值设置来进行保护。阈值的取值需要根据实际网络应用场景进行调整,对于正常情况下到被保护对象(HTTP服务器或者FTP服务器)的SYN报文流量较大的应用场景,建议调大触发阈值,以免阈值太小对正常的业务流量造成影响;对于网络状况较差,且对攻击流量比较敏感的场景,可以适当调小触发阈值。
# 在攻击防范策略atk-policy-1中配置SYN flood攻击防范的全局触发阈值为100,即当设备监测到向某IP地址每秒发送的SYN报文数持续达到或超过100时,启动SYN flood攻击防范。
[Sysname-attack-defense-policy-atk-policy-1] syn-flood threshold 100
·     syn-flood action
·     syn-flood detect
1.1.91  udp-flood action
udp-flood action命令用来配置对UDP flood攻击防范的全局处理行为。
undo udp-flood action命令用来恢复缺省情况。
udp-flood action { drop | logging } *
不对检测到的UDP flood攻击进行任何处理。
攻击防范策略视图
drop:表示丢弃攻击报文,即设备检测到攻击发生后,向被攻击者发送的后续所有UDP报文都会被丢弃。
# 在攻击防范策略atk-policy-1中配置对UDP flood攻击防范的全局处理行为是丢弃后续报文。
[Sysname-attack-defense-policy-atk-policy-1] udp-flood action drop
·     udp-flood detect
·     udp-flood detect non-specific
·     udp-flood threshold
1.1.92  udp-flood detect
udp-flood detect命令用来开启对指定IP地址的UDP flood攻击防范检测,并配置UDP flood攻击防范检测的触发阈值和对UDP flood攻击的处理行为。
undo udp-flood detect命令用来关闭对指定IP地址的UDP flood攻击防范检测。
udp-flood detect { ip ipv4-address | ipv6 ipv6-address } [ vpn-instance vpn-instance-name ] [ threshold threshold-value ] [ action { { drop | logging } * | none } ]
undo udp-flood detect { ip ipv4-address | ipv6 ipv6-address } [ vpn-instance vpn-instance-name ]
未对任何指定IP地址配置UDP flood攻击防范检测。
攻击防范策略视图
threshold threshold-value:指定UDP flood攻击防范的触发阈值。其中,threshold-value为向指定IP地址每秒发送的UDP报文数目,取值范围为1~64000。
action:设置对UDP flood攻击的处理行为。
none:表示不采取任何动作。
每个攻击防范策略下可以同时对多个IP地址配置UDP flood攻击防范参数。
使能UDP flood攻击防范后,设备处于攻击检测状态,当它监测到向指定IP地址发送UDP报文的速率持续达到或超过了触发阈值时,即认为该IP地址受到了UDP flood攻击,则进入攻击防范状态,并根据配置启动相应的防范措施。此后,当设备检测到向该服务器发送报文的速率低于恢复阈值(触发阈值的3/4)时,即认为攻击结束,则由攻击防范状态恢复为攻击检测状态,并停止执行防范措施。
# 在攻击防范策略atk-policy-1中开启对IP地址192.168.1.2的UDP flood攻击防范检测,并指定触发阈值为2000。当设备监测到向该IP地址每秒发送的UDP报文数持续达到或超过2000时,启动UDP flood攻击防范。
[Sysname-attack-defense-policy-atk-policy-1] udp-flood detect ip 192.168.1.2 threshold 2000
·     udp-flood action
1.1.93  udp-flood detect non-specific
udp-flood detect non-specific命令用来对所有非受保护IP地址开启UDP flood攻击防范检测。
undo udp-flood detect non-specific命令用来关闭对所有非受保护IP地址的UDP flood攻击防范检测。
未对任何非受保护IP地址开启UDP flood攻击防范检测。
攻击防范策略视图
对所有非受保护IP地址开启UDP flood攻击防范检测后,设备将采用全局的阈值设置(由udp-flood threshold命令设置)和处理行为(由udp-flood action命令配置)对这些IP地址进行保护。
[Sysname-attack-defense-policy-atk-policy-1] udp-flood detect non-specific
·     udp-flood action
·     udp-flood detect
1.1.94  udp-flood threshold
udp-flood threshold命令用来配置UDP flood攻击防范的全局触发阈值。
undo udp-flood threshold命令用来恢复缺省情况。
udp-flood threshold threshold-value
UDP flood攻击防范的全局触发阈值为1000。
攻击防范策略视图
threshold-value:指定向某IP地址每秒发送的UDP报文数目,取值范围为1~1000000。使能UDP flood攻击防范后,设备处于攻击检测状态,当它监测到向某IP地址发送UDP报文的速率持续达到或超过了该触发阈值时,即认为该IP地址受到了UDP flood攻击,则进入攻击防范状态,并根据配置启动相应的防范措施。
对于未专门配置UDP flood攻击防范检测的IP地址,设备采用全局的阈值设置来进行保护。阈值的取值需要根据实际网络应用场景进行调整,对于正常情况下到被保护对象(HTTP服务器或者FTP服务器)的UDP报文流量较大的应用场景,建议调大触发阈值,以免阈值太小对正常的业务流量造成影响;对于网络状况较差,且对攻击流量比较敏感的场景,可以适当调小触发阈值。
# 在攻击防范策略atk-policy-1中配置UDP flood攻击防范的全局触发阈值为100,即当设备监测到向某IP地址每秒发送的UDP报文数持续达到或超过100时,启动UDP flood攻击防范。
[Sysname-attack-defense-policy-atk-policy-1] udp-flood threshold 100
·     udp-flood action
·     udp-flood detect
1.1.95  whitelist enable (interface view)
whitelist enable命令用来开启接口上的白名单过滤功能。
undo whitelist enable命令用来关闭接口上的白名单过滤功能。
whitelist enable
接口上的白名单过滤功能处于关闭状态。
若全局的白名单过滤功能处于开启状态,则所有接口上的白名单过滤功能均处于开启状态。
若全局的白名单过滤功能处于关闭状态,则接口上的白名单过滤功能由本命令决定是否开启。
# 开启接口GigabitEthernet2/1/1上的白名单过滤功能。
[Sysname] interface gigabitethernet 2/1/1
[Sysname-GigabitEthernet2/1/1] whitelist enable
1.1.96  whitelist enable (security zone view)
whitelist enable命令用来开启安全域上的白名单过滤功能。
undo whitelist enable命令用来关闭安全域上的白名单过滤功能。
whitelist enable
安全域上的白名单过滤功能处于关闭状态。
安全域视图
若全局的白名单过滤功能处于开启状态,则所有安全域上的白名单过滤功能均处于开启状态。
若全局的白名单过滤功能处于关闭状态,则安全域上的白名单过滤功能由本命令决定是否开启。
# 开启安全域Untrust上的白名单过滤功能。
[Sysname] security-zone name untrust
[Sysname-security-zone-Untrust] whitelist enable
1.1.97  whitelist global enable
whitelist global enable命令用来开启全局白名单过滤功能。
undo whitelist global enable命令用来关闭全局白名单过滤功能。
全局白名单过滤功能处于关闭状态。
开启全局白名单过滤功能表示开启所有接口或安全域上的白名单过滤功能。
# 开启全局白名单过滤功能。
[Sysname] whitelist global enable
1.1.98  whitelist object-group
whitelist object-group命令通过引用地址对象组配置白名单。
undo whitelist object-group命令用来恢复缺省情况。
whitelist object-group object-group-name
未引用地址对象组。
object-group-name:地址对象组名称,为1~31个字符的字符串,不区分大小写。
本命令需要和地址对象组功能配合使用,有关地址对象组功能的详细介绍,请参见“安全配置指导”中的“对象组”。
多次执行本命令,最后一次执行的命令生效。
# 通过引用地址对象组object-group1配置白名单。
[Sysname] whitelist object-group object-group1
