03-以太网接口命令
本章节下载: 03-以太网接口命令 (981.80 KB)
1.1.8 display ethernet statistics
1.1.10 display interface link-info
1.1.12 display interface split-capable
1.1.14 display priority-flow-control
1.1.17 flow-control receive enable
1.1.34 linkdown trap enable shutdown
1.1.38 port ifmonitor crc-error
1.1.40 port ifmonitor input-error
1.1.41 port ifmonitor input-usage
1.1.42 port ifmonitor output-error
1.1.43 port ifmonitor output-usage
1.1.45 port ifmonitor rx-pause
1.1.46 port ifmonitor sdh-b1-error
1.1.47 port ifmonitor sdh-b2-error
1.1.48 port ifmonitor sdh-error
1.1.49 port ifmonitor tx-pause
1.1.51 priority-flow-control (Ethernet interface view)
1.1.52 priority-flow-control (System view)
1.1.53 priority-flow-control deadlock auto-recover action
1.1.54 priority-flow-control deadlock auto-recover cos
1.1.55 priority-flow-control deadlock cos
1.1.56 priority-flow-control deadlock enable
1.1.57 priority-flow-control deadlock precision
1.1.58 priority-flow-control deadlock recover
1.1.59 priority-flow-control deadlock recover-mode
1.1.60 priority-flow-control deadlock threshold
1.1.61 priority-flow-control early-warning inpps
1.1.62 priority-flow-control early-warning outpps
1.1.63 priority-flow-control no-drop dot1p (Ethernet interface view)
1.1.64 priority-flow-control no-drop dot1p (System view)
1.1.65 reset counters interface
1.1.66 reset ethernet statistics
1.1.67 reset packet-drop interface
1.1.69 snmp-agent trap enable ifmonitor
1.2.5 storm-constrain enable log
1.2.6 storm-constrain enable trap
1.2.7 storm-constrain interval
1.3.3 traffic-statistic enable
bandwidth命令用来配置接口的期望带宽。
undo bandwidth命令用来恢复缺省情况。
bandwidth bandwidth-value
undo bandwidth
接口的期望带宽=接口的波特率÷1000(kbps)。
以太网接口视图
以太网子接口视图
bandwidth-value:表示接口的期望带宽,取值范围为1~400000000,单位为kbps。
期望带宽供业务模块使用,不会对接口实际带宽造成影响。
# 配置接口Ten-GigabitEthernet1/0/1的期望带宽为1000kbps。
[Sysname-Ten-GigabitEthernet1/0/1] bandwidth 1000
# 设置以太网子接口Ten-GigabitEthernet1/0/1.1的期望带宽为1000kbps。
[Sysname] interface ten-gigabitethernet 1/0/1.1
[Sysname-Ten-GigabitEthernet1/0/1.1] bandwidth 1000
· speed
broadcast-suppression命令用来开启端口广播风暴抑制功能,并设置广播风暴抑制阈值。
undo broadcast-suppression命令用来关闭端口广播风暴抑制功能。
所有接口不对广播流量进行抑制。
以太网接口视图
ratio:指定以太网接口允许通过的最大广播流量占该接口带宽的百分比,取值范围为0~100。数值越小,允许通过的广播流量也越小。
pps max-pps:指定以太网接口每秒允许转发的最大广播报文数,单位为pps(packets per second,每秒转发的报文数),取值范围为0~1.4881×接口带宽。
kbps max-kbps:指定以太网接口每秒允许转发的最大广播流量,单位为kbps(kilobits per second,每秒转发的千比特数),取值范围为0~接口带宽。
本命令设置的是接口允许通过的最大广播报文流量。当接口上的广播流量超过用户设置的值后,系统将丢弃超出广播流量限制的报文,从而使接口广播流量所占的比例控制在限定的范围内,以便保证业务的正常运行。
执行broadcast-suppression或storm-constrain命令都能开启端口的广播风暴抑制功能,storm-constrain命令通过软件对广播报文进行抑制,对设备性能有一定影响,broadcast-suppression通过芯片物理上对广播报文进行抑制,相对storm-constrain来说,对设备性能影响较小。请不要同时配置broadcast-suppression和storm-constrain命令,以免配置冲突,导致抑制效果不确定。
当风暴抑制阈值配置为kbps时,若配置值小于64,则实际生效的数值为64;若配置值大于64但不是64的整数倍,则实际生效的数值为大于且最接近于配置值的64的整数倍。请注意查看设备的提示信息。
# 在以太网接口Ten-GigabitEthernet1/0/1上,每秒最多允许10000kbps广播报文通过,对超出该范围的广播报文进行抑制。
[Sysname-Ten-GigabitEthernet1/0/1] broadcast-suppression kbps 10000
The actual value is 10048 on port Ten-GigabitEthernet1/0/1 currently.
以上信息表示:用户配置的值为10000kbps,因为芯片支持的步长为64,所以实际生效的值为10048kbps(64的157倍)。
· multicast-suppression
· unicast-suppression
dampening命令用来开启接口的dampening功能。
undo dampening命令用来恢复缺省情况。
undo dampening
接口的dampening功能处于关闭状态。
以太网接口视图
half-life:半衰期,取值范围为1~120,单位为秒,缺省值为54。
reuse:启用值,取值范围为200~20000,缺省值为750,必须要小于suppress的值。
suppress:抑制门限,取值范围为200~20000,缺省值为2000。
max-suppress-time:最大抑制时间,取值范围为1~255,单位为秒,缺省值为半衰期的3倍,即162。
以太网接口上不能同时配置本命令和link-delay命令。
本命令对使用shutdown命令手动关闭的接口无效。手工shutdown接口时,dampening的惩罚值恢复为初始值0。
对于使能了RRPP、MSTP或Smart Link的接口不建议使用该命令。
接口在抑制期发生up事件,通过display interface命令查看时,该接口的状态仍然为down。
# 按照缺省值开启接口Ten-GigabitEthernet1/0/1的dampening功能。
[Sysname-Ten-GigabitEthernet1/0/1] dampening
# 开启接口Ten-GigabitEthernet1/0/1的dampening功能,配置半衰期为2秒,启用值为800,抑制门限为3000,最大抑制时间为5秒。
[Sysname-Ten-GigabitEthernet1/0/1] dampening 2 800 3000 5
· display interface
· link-delay
default命令用来恢复当前接口的缺省配置。
default
以太网接口视图
以太网子接口视图
# 将以太网接口Ten-GigabitEthernet1/0/1恢复为缺省配置。
[Sysname-Ten-GigabitEthernet1/0/1] default
# 将以太网子接口Ten-GigabitEthernet1/0/1.1恢复为缺省配置。
[Sysname-Ten-GigabitEthernet1/0/1.1] default
description命令用来设置当前接口的描述信息。
undo description命令用来恢复缺省情况。
接口的描述信息为“接口名 Interface”,例如:Ten-GigabitEthernet1/0/1 Interface。
以太网接口视图
以太网子接口视图
text:接口的描述信息,为1~255个字符的字符串,区分大小写。
# 设置以太网接口Ten-GigabitEthernet1/0/1的描述信息为“lan-interface”。
[Sysname-Ten-GigabitEthernet1/0/1] description lan-interface
# 设置以太网子接口Ten-GigabitEthernet1/0/1.1的描述信息为“subinterface1/0/1.1”。
[Sysname-Ten-GigabitEthernet1/0/1.1] description subinterface1/0/1.1
display counters命令用来显示接口的流量统计信息。
display counters { inbound | outbound } interface [ interface-type [ interface-number ] ]
inbound:显示输入报文的流量统计信息。
outbound:显示输出报文的流量统计信息。
interface-type:指定接口类型。
interface-number:指定接口编号。
可通过命令reset counters interface清除以太网接口的统计信息。
如果不指定interface-type,则显示所有可统计的接口的流量统计信息。
如果指定interface-type而不指定interface-number,则显示该类型下所有接口的流量统计信息。
如果同时指定interface-type和interface-number,则显示指定接口的报文流量统计信息。
# 显示GigabitEthernet类型接口的报文输入流量统计信息。
<Sysname> display counters inbound interface gigabitethernet
Interface Total(pkt) Broadcast(pkt) Multicast(pkt) Err(pkt)
XGE1/0/1 100 100 0 0
XGE1/0/2 Overflow Overflow Overflow Overflow
Overflow: More than 14 digits (7 digits for column "Err").
--: Not supported.
表1-1 display counters命令显示信息描述表
接口名称缩写 |
Total(pkt) |
接口接收或发送报文的总数(单位为包) |
Broadcast(pkt) |
接口接收或发送广播报文的总数(单位为包) |
Multicast(pkt) |
接口接收或发送组播报文的总数(单位为包) |
Err (pkts) |
接口接收或发送错误报文的总数(单位为包) |
Overflow: More than 14 digits (7 digits for column "Err"). |
当某个统计信息的值为Overflow时,表示该项数据的长度超过了显示范围: · 对于Err项,Overflow表示数据的长度超过了7位十进制数 · 对于其它项,Overflow表示数据的长度超过了14位十进制数 |
--: Not supported. |
当某个统计信息的值为“--”时,表示设备不支持该项数据的统计 |
· reset counters interface
display counters rate命令用来显示最近一个统计周期内处于up状态的接口的报文速率统计信息。
display counters rate [ inbound | outbound ] interface [ interface-type [ interface-number ] ]
inbound:显示报文接收速率统计信息。
outbound:显示报文发送速率统计信息。
如果不指定inbound和outbound,则显示可统计所有或者指定接口类型中最近一个统计周期内处于up状态的接口接收和发送的报文速率统计信息。
如果不指定interface-type和interface-number,则显示所有可统计的接口类型中最近一个统计周期内处于up状态的接口的报文速率统计信息。
如果指定interface-type而不指定interface-number,则显示该类型下最近一个统计周期内处于up状态接口的报文速率统计信息。
如果同时指定interface-type和interface-number,则显示指定接口在最近一个统计周期内报文速率统计信息。如果该接口在最近一个统计周期内一直处于down状态,则提示接口不支持该操作。
关于统计周期的值,分为以下几种情况:
· 不支持flow-interval命令的设备,统计周期固定为5分钟。
· 对于支持flow-interval命令的设备,统计周期可以通过flow-interval命令来配置。
# 显示以太网接口Ten-GigabitEthernet1/0/1接收和发送报文速率统计信息。
<Sysname> display counters rate interface ten-gigabitethernet 1/0/1
Usage: Bandwidth utilization in percentage
Interface InUsage(%) InTotal(pps) OutUsage(%) OutTotal(pps)
XGE1/0/1 0 0 0 0
Overflow: More than 14 digits.
--: Not supported.
# 显示GigabitEthernet类型接口的报文接收速率统计信息。
<Sysname> display counters rate inbound interface gigabitethernet
Interface Usage(%) Total(pps) Broadcast(pps) Multicast(pps)
XGE1/0/1 3 200 100 100
--: Not supported.
表1-2 display counters rate命令显示信息描述表
接口名称缩写 |
Usage(%) |
在最近一个统计周期内,接口的带宽利用率(单位为百分比) |
Total(pps) |
在最近一个统计周期内,接口接收或发送所有类型报文的平均速率(单位为包/秒) |
InUsage(%) |
在最近一个统计周期内,接口接收所有类型报文的带宽利用率(单位为百分比),不足1%且有流量时显示1% |
InTotal(pps) |
在最近一个统计周期内,接口接收所有类型报文的平均速率(单位为包/秒) |
OutUsage(%) |
在最近一个统计周期内,接口发送所有类型报文的带宽利用率(单位为百分比),不足1%且有流量时显示1% |
OutTotal(pps) |
在最近一个统计周期内,接口发送所有类型报文的平均速率(单位为包/秒) |
Broadcast(pps) |
在最近一个统计周期内,接口接收或发送广播报文的平均速率(单位为包/秒) |
Multicast(pps) |
在最近一个统计周期内,接口接收或发送组播报文的平均速率(单位为包/秒) |
Overflow: More than 14 digits. |
当某个统计信息的值为Overflow时,表示该项数据的长度超过了14位十进制数 |
当某个统计信息的值为“--”时,则表示设备不支持该项数据的统计 |
· flow-interval
display ethernet statistics命令用来显示以太网软件模块收发报文的统计信息。
display ethernet statistics slot slot-number
slot slot-number:指定设备编号,取值只能为1。
# 显示指定slot上的以太网软件模块收发报文的统计信息。
<Sysname> display ethernet statistics slot 1
ETH receive packet statistics:
Totalnum : 10447 ETHIINum : 4459
SNAPNum : 0 RAWNum : 0
LLCNum : 0 UnknownNum : 0
ForwardNum : 4459 ARP : 0
MPLS : 0 ISIS : 0
ISIS2 : 0 IP : 0
IPV6 : 0
ETH receive error statistics:
NullPoint : 0 ErrIfindex : 0
ErrIfcb : 0 IfShut : 0
ErrAnalyse : 5988 ErrSrcMAC : 5988
ErrHdrLen : 0
ETH send packet statistics:
L3OutNum : 211 VLANOutNum : 0
FastOutNum : 155 L2OutNum : 0
ETH send error statistics:
MbufRelayNum : 0 NullMbuf : 0
ErrAdjFwd : 0 ErrPrepend : 0
ErrHdrLen : 0 ErrPad : 0
ErrQoSTrs : 0 ErrVLANTrs : 0
ErrEncap : 0 ErrTagVLAN : 0
IfShut : 0 IfErr : 0
表1-3 display ethernet statistics命令显示信息描述表
ETH receive packet statistics |
以太网软件模块接收到的以太网报文的统计信息: · Totalnum:接收报文的总个数 · ETHIINum:接收的ETHII封装格式报文个数 · SNAPNum:接收的SNAP封装格式报文个数 · RAWNum:接收的RAW封装格式报文个数 · ISISNum:接收的ISIS封装格式报文个数 · LLCNum:接收的LLC封装格式报文个数 · UnknowNum:接收的未知封装格式报文个数 · ForwardNum:二层转发或上送CPU的报文个数 · ARP:接收的ARP报文个数 · MPLS:接收的MPLS报文个数 · ISIS:接收的ISIS报文个数 · ISIS2:接收的ISIS2报文个数 · IP:接收的IP报文个数 · IPv6:接收的IPv6报文个数 |
ETH receive error statistics |
以太网软件模块接收错误的以太网报文的统计信息(可能是包本身包含错误或者是接收动作出错了): · NullPoint:接收报文时指针为空的报文的个数 · ErrIfindex:接收报文时接口索引错误的报文个数 · ErrIfcb:接收报文时接口控制块错误的报文个数 · IfShut:接收报文时接口shutdown的报文个数 · ErrAnalyse:接收报文时报文解析错误的报文个数 · ErrSrcMAC:接收的包含源MAC地址错误的报文个数 · ErrHdrLen:接收的包含报文头长度错误的报文个数 |
ETH send packet statistics |
以太网软件模块发送的以太网报文的统计信息: · L3OutNum:通过三层以太网接口发送的报文总个数 · VLANOutNum:通过VLAN接口发送的报文总个数 · FastOutNum:快速发送的报文总个数 · L2OutNum:通过二层以太网接口发送的报文总个数 · MbufRelayNum:透传发送的报文总个数 |
ETH send error statistics |
以太网软件模块发送的错误以太网报文的统计信息: · NullMbuf:发送报文时空指针错误的报文个数 · ErrAdjFwd:发送报文时邻接表错误的报文个数 · ErrPrepend:发送报文时扩展错误的报文个数 · ErrHdrLen:发送的包含报文头长度错误的报文个数 · ErrPad:发送报文时填充错误的报文个数 · ErrQoSTrs:发送报文时QoS发送失败的报文个数 · ErrVLANTrs:发送报文时VLAN发送失败的报文个数 · ErrEncap:发送报文时封装链路头失败的报文个数 · ErrTagVLAN:发送报文时封装VLAN TAG失败的报文个数 · IfShut:发送报文时端口shutdown的报文个数 · IfErr:发送报文时出接口错误的报文个数 |
· reset ethernet statistics
display interface命令用来显示接口的运行状态和相关信息。
display interface [ interface-type [ interface-number | interface-number.subnumber ] ] [ brief [ description | down ] ]
interface-number.subnumber:指定子接口编号。其中interface-number为主接口编号;subnumber为子接口编号,取值范围为1~4094。
description:用来显示用户配置的接口的全部描述信息。如果某接口的描述信息超过27个字符,不指定该参数时,只显示描述信息中的前27个字符,超出部分不显示。
如果仅指定接口类型,则显示所有该类型接口的信息。
# 查看三层以太网接口Ten-GigabitEthernet1/0/1的运行状态和相关信息。
<Sysname> display interface ten-gigabitethernet 1/0/1
Line protocol state: DOWN
Description: Ten-GigabitEthernet1/0/1 Interface
Bandwidth: 1000000 kbps
Allow jumbo frames to pass
Broadcast max-ratio: 100%
Multicast max-ratio: 100%
Unicast max-ratio: 100%
IP packet frame type: Ethernet II, hardware address: 3822-d666-bd0c
IPv6 packet frame type: Ethernet II, hardware address: 3822-d666-bd0c
Flow-control is not enabled
Loopback is not set
Media type is twisted pair, port hardware type is 1000_BASE_T
Port priority: 2
Last link flapping: 6 hours 39 minutes 28 seconds
Current system time:2017-10-27 15:10:03
Last time when physical state changed to up:-
Last time when physical state changed to down:2017-10-27 14:56:38
Last 300 seconds input: 0 packets/sec 0 bytes/sec 0 bits/sec 0.00%
Last 300 seconds output: 0 packets/sec 0 bytes/sec 0 bits/sec 0.00%
Input (total): 0 packets, 0 bytes
0 unicasts, 0 broadcasts, 0 multicasts, - pauses
Input (normal): 0 packets, 0 bytes
Input: 0 input errors, 0 runts, 0 giants, 0 throttles
- ignored, - parity errors
Output (normal): 0 packets, 0 bytes
- lost carrier, - no carrier
Peak input rate: 0 bytes/sec, at 2013-07-07 16:07:11
Peak output rate: 0 bytes/sec, at 2013-07-07 16:07:11
# 查看二层以太网接口Ten-GigabitEthernet1/0/1的运行状态和相关信息。
Current state: DOWN
IP packet frame type: Ethernet II, hardware address: 000c-2963-b767
Bandwidth: 100000 kbps
Loopback is not set
Media type is twisted pair,port hardware type is 1000_BASE_T_AN_SFP
Maximum frame length: 9216
Allow jumbo frame to pass
PVID: 1
MDI type: Automdix
Port link-type: Access
Tagged VLANs: None
UnTagged VLANs: 1
Port priority: 2
Last link flapping: 6 hours 39 minutes 25 seconds
Last clearing of counters: 14:34:09 Tue 11/01/2011
Peak input rate: 0 bytes/sec, at 2013-07-17 22:06:19
Peak output rate: 0 bytes/sec, at 2013-07-17 22:06:19
0 CRC, 0 frame, 0 overruns, 0 aborts
0 ignored, 0 parity errors
Output: 0 output errors, 0 underruns, 0 buffer failures
0 lost carrier, 0 no carrier
表1-4 display interface命令显示信息描述表
Ten-GigabitEthernet1/0/1 |
接口Ten-GigabitEthernet1/0/1的相关信息 |
Current state |
接口的物理状态,状态可能为: · Administratively DOWN:表示该接口已经通过shutdown命令被关闭,即管理状态为关闭 · DOWN:表示该接口的管理状态为开启,但物理状态为关闭(可能因为没有物理连线或者线路故障) · DOWN ( Link-Aggregation interface down ):表示该接口所属的聚合接口已经通过shutdown命令被关闭 · mac-address moving down:由于MAC地址迁移抑制导致接口被关闭 · Storm-Constrain:表示端口上因为未知单播、组播或广播报文中某类报文的流量大于其上限阈值而被关闭 · STP DOWN:表示接口由于触发了STP BPDU保护而自动关闭 · UP:该端口的管理状态和物理状态均为开启 |
Line protocol state |
接口的链路层协议状态。其值由链路层经过参数协商决定,取值为: · UP:表示数据链路层协议状态为开启 · UP(spoofing):表示该接口的数据链路层协议状态为开启,但实际可能没有对应的链路,或者所对应的链路不是永久存在而是按需建立。通常NULL、LoopBack等接口会具有该属性 · DOWN:表示数据链路层协议状态为关闭 · DOWN(protocols):表示接口的数据链路层被一个或者多个协议模块关闭。protocols为DLDP、OAM、LAGG、BFD的任意组合: ¡ DLDP:表示由于DLDP模块检测到单通而关闭接口的数据链路层 ¡ OAM:表示由于以太网OAM模块检测到远端链路故障而关闭接口的数据链路层 ¡ LAGG:表示聚合接口中没有选中的成员端口而关闭接口的数据链路层 ¡ BFD:表示由于BFD模块检测到链路故障而关闭接口的数据链路层 |
接口的描述信息 |
Bandwidth |
接口的期望带宽 |
Maximum transmission unit |
接口的MTU |
Internet protocol processing |
接口未配置IP地址时,接口的网络协议配置参数: · Disabled:不能处理IP报文 · Enabled:可以处理IP报文 |
Internet address: ip-address/mask-length (Type) |
接口IP地址。Type表示地址获取方式,取值如下: · Primary:手动配置的主地址 · Sub:手动配置的从地址。当配置了主地址时,仅显示主地址;仅配置从地址时,才显示本信息 · DHCP-allocated:通过DHCP获取的IP地址,详细介绍请参见“三层技术-IP业务配置指导”中的“DHCP” · BOOTP-allocated:通过BOOTP获取的IP地址,详细介绍请参见“三层技术-IP业务配置指导”中的“DHCP” · Unnumbered:借用其他接口的IP地址 · MTunnel:组播隧道接口的IP地址(采用的是MD源接口的IP地址),关于MD源接口的详细介绍请参见“IP组播配置指导”中的“组播VPN” |
IP packet frame type |
IPv4报文发送帧格式 |
hardware address |
接口的MAC地址 |
IPv6 packet frame type |
IPv6报文发送帧格式 |
Media type is |
接口的介质类型 |
Port hardware type is |
接口的硬件类型 |
Port priority |
接口优先级 |
Loopback is set internal |
以太网接口正在进行对内环回测试,该显示信息与用户的配置有关 |
Loopback is set external |
对以太网接口进行对外环回测试,该显示信息与用户的配置有关 |
Loopback is not set |
接口上未配置环回测试,该显示信息与用户的配置有关 |
1000Mbps-speed mode |
接口速率为1000Mbps,该显示信息与用户的配置以及链路参数的协商结果有关 |
10Gbps-speed mode |
接口速率为10Gbps,该显示信息与用户的配置以及链路参数的协商结果有关 |
40Gbps-speed mode |
接口速率为40Gbps,该显示信息与用户的配置以及链路参数的协商结果有关 |
100Gbps-speed mode |
接口速率为100Gbps,该显示信息与用户的配置以及链路参数的协商结果有关 |
Unknown-speed mode |
速率未知,可能因为速率协商失败或者接口物理未连通 |
full-duplex mode |
接口工作在全双工模式,该显示信息与用户的配置以及链路参数的协商结果有关 |
unknown-duplex mode |
未知双工模式,可能因为双工模式协商失败或者接口物理未连通 |
Link speed type is autonegotiation |
当用户配置了speed auto时显示该信息 |
Link speed type is force link |
当用户使用speed命令配置了具体的速率时显示该信息,例如10M或者100M等 |
link duplex type is autonegotiation |
当用户配置了duplex auto时显示该信息 |
link duplex type is force link |
当用户使用duplex命令配置了具体的双工模式时显示该信息,例如half或者full |
Flow-control is not enabled |
未配置流量控制功能,该显示信息与用户的配置以及链路参数的协商结果有关 |
Maximum frame length |
接口允许通过的最大以太网帧长度 |
Allow jumbo frame to pass |
允许长帧通过 |
Broadcast max- |
广播风暴抑制阈值,可能为ratio(百分比)、pps或者kbps,与用户的配置有关 |
Multicast max- |
组播风暴抑制阈值,可能为ratio(百分比)、pps或者kbps,与用户的配置有关 |
Unicast max- |
未知单播风暴抑制阈值,可能为ratio(百分比)、pps或者kbps,与用户的配置有关 |
PVID |
接口所在的缺省VLAN ID |
MDI type |
网线类型,取值为automdix、mdi或mdix,与用户的配置有关 |
Port link-type |
链路类型,取值为access、trunk或hybrid,与用户的配置有关 |
Tagged VLANs |
通过该接口后携带Tag的VLAN |
UnTagged VLANs |
通过该接口后不再携带Tag的VLAN |
VLAN Passing |
该接口实际可以通过的VLAN(接口允许通过并且已创建的VLAN) |
VLAN permitted |
接口允许通过的VLAN报文 |
Trunk port encapsulation |
Trunk接口的封装格式 |
Last link flapping |
接口最近一次物理状态改变到现在的时长。Never表示接口从设备启动后一直处于down状态(没有改变过) |
Last clearing of counters |
最近一次使用reset counters interface命令清除接口下的统计信息的时间(如果从设备启动一直没有执行reset counters interface命令清除过该接口下的统计信息,则显示Never) |
Current system time |
当前系统时间,时间显示格式为YYYY/MM/DD HH:MM:SS 如果配置了时区,时间显示格式为YYYY/MM/DD HH:MM:SS UTC±HH:MM:SS |
Last time when physical state changed to up |
最近一次接口物理状态变为UP的时刻 “-”表示接口物理状态没有发生过变化 |
Last time when physical state changed to down |
最近一次接口物理状态变为DOWN的时刻 “-”表示接口物理状态没有发生过变化 |
Last 300 seconds input: 0 packets/sec 0 bytes/sec 0 bits/sec 0.00% Last 300 seconds output: 0 packets/sec 0 bytes/sec 0 bits/sec 0.00% |
端口在最近一个统计周期内接收和发送报文的平均速率,单位分别为数据包/秒、字节/秒和比特/秒,以及实际速率和接口带宽的百分比。统计周期interval可以通过flow-interval命令设置 如果值显示为“-”,则表示不支持该统计项 |
Input(total): 0 packets, 0 bytes 0 unicasts, 0 broadcasts, 0 multicasts, 0 pauses |
端口接收报文的统计值,包括正常报文、异常报文和正常PAUSE帧的报文数、字节数 端口接收的单播报文、广播报文、组播报文和PAUSE帧的数量 如果值显示为“-”,则表示不支持该统计项 |
Input(normal): 0 packets, 0 bytes 0 unicasts, 0 broadcasts, 0 multicasts, 0 pauses |
端口接收的正常报文的统计值,包括正常报文和正常PAUSE帧的报文数、字节数 端口接收的正常单播报文、广播报文、组播报文和PAUSE帧的数量 如果值显示为“-”,则表示不支持该统计项 |
input errors |
端口接收的错误报文的统计值 |
runts |
接收到的超小帧的数量 超小帧是指长度小于64字节、格式正确且包含有效的CRC字段的帧 |
giants |
接收到的超大帧的数量 超大帧是指有效长度大于端口允许通过最大报文长度的帧: · 对于禁止长帧通过的以太网端口,超大帧是指有效长度大于1518字节(不带VLAN Tag)或大于1522字节(带VLAN Tag报文)的帧 · 对于允许长帧通过的以太网端口,超大帧是指有效长度大于指定最大长帧长度的帧 |
throttles |
接收到的长度为非整数字节的帧的个数 |
CRC |
接收到的CRC校验错误、长度正常的帧的数量 |
frame |
接收到的CRC校验错误、且长度不是整字节数的帧的数量 |
overruns |
当端口的接收速率超过接收队列的处理能力时,导致报文被丢弃 |
aborts |
接收到的非法报文总数,非法报文包括: · 报文碎片:长度小于64字节(长度可以为整数或非整数)且CRC校验错误的帧 · jabber帧:有效长度大于端口允许通过的最大报文长度,且CRC校验错误的帧(长度可以为整字节数或非整字节数)。如对于禁止长帧通过的以太网端口,jabber帧是指大于1518(不带VLAN Tag)或1522(带VLAN Tag)字节,且CRC校验错误的帧;对于允许长帧通过的以太网端口,jabber帧是指有效长度大于指定最大长帧长度,且CRC校验错误的帧 · 符号错误帧:报文中至少包含1个错误的符号 · 操作码未知帧:报文是MAC控制帧,但不是Pause帧 · 长度错误帧:报文中802.3长度字段与报文实际长度(46~1500字节)不匹配 |
ignored |
由于端口接收缓冲区不足等原因而丢弃的报文数量 |
parity errors |
接收到的奇偶校验错误的帧的数量 |
Output(total): 0 packets, 0 bytes 0 unicasts, 0 broadcasts, 0 multicasts, 0 pauses |
端口发送报文的统计值,包括正常报文、异常报文和正常PAUSE帧的报文数、字节数 端口发送的单播报文、广播报文、组播报文和PAUSE帧的数量 如果值显示为“-”,则表示不支持该统计项 |
Output(normal): 0 packets, 0 bytes 0 unicasts, 0 broadcasts, 0 multicasts, 0 pauses |
端口发送的正常报文的统计值,包括正常报文和正常PAUSE帧的报文数、字节数 端口发送的正常单播报文、广播报文、组播报文和PAUSE帧的数量 如果值显示为“-”,则表示不支持该统计项 |
output errors |
各种发送错误的报文总数 |
underruns |
当端口的发送速率超过了发送队列的处理能力,导致报文被丢弃,是一种非常少见的硬件异常 |
buffer failures |
由于端口发送缓冲区不足而丢弃的报文数量 |
aborts |
发送失败的报文总数,即报文已经开始发送,但由于各种原因(如冲突)而导致发送失败 |
deferred |
延迟报文的数量,延迟报文是指发送前检测到冲突而被延迟发送的报文 |
collisions |
冲突帧的数量,冲突帧是指在发送过程中检测到冲突的而停止发送的报文 |
late collisions |
延迟冲突帧的数量,延迟冲突帧是指帧的前512 bits已经被发送,由于检测到冲突,该帧被延迟发送 |
lost carrier |
载波丢失,一般适用于串行WAN接口,发送过程中,每丢失一个载波,此计数器加一 |
no carrier |
无载波,一般适用于串行WAN接口,当试图发送帧时,如果没有载波出现,此计数器加一 |
Peak input rate |
接口输入流量的峰值速率大小(单位为bytes/sec)以及峰值产生的时间 |
Peak output rate |
接口输出流量的峰值速率大小(单位为bytes/sec)以及峰值产生的时间 |
# 显示所有接口的概要信息。
Protocol: (s) – spoofing
XGE1/0/1 DOWN DOWN --
Loop0 UP UP(s) 2.2.2.9
NULL0 UP UP(s) --
Vlan1 UP DOWN --
Vlan999 UP UP 192.168.1.42
Speed: (a) - auto
Interface Link Speed Duplex Type PVID Description
XGE1/0/2 DOWN auto A A 1
XGE1/0/3 UP 1G(a) F(a) A 1 aaaaaaaaaaaaaaaaaaaaaaaaaaa
# 显示接口Ten-GigabitEthernet1/0/3的概要信息,包括用户配置的全部描述信息。
<Sysname> display interface ten-gigabitethernet 1/0/3 brief description
Speed: (a) - auto
XGE1/0/3 UP 1G(a) F(a) A 1 aaaaaaaaaaaaaaaaaaaaaaaaaaaaa
aaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaa
# 显示当前物理状态为down的接口的信息以及down的原因。
Interface Link Cause
XGE1/0/1 DOWN Not connected
XGE1/0/2 DOWN Not connected
表1-5 display interface brief命令显示信息描述表
Brief information on interfaces in route mode: |
三层模式下(route)接口的概要信息,即三层接口的概要信息 |
Link: ADM - administratively down; Stby - standby |
· 如果某接口的Link属性值为“ADM”,则表示该接口被管理员通过shutdown命令关闭,需要在该接口下执行undo shutdown命令才能恢复接口本身的物理状态 · 如果某接口的Link属性值为“Stby”,则表示该接口是一个处于Standby状态的备份接口,使用display interface-backup state命令可以查看该备份接口对应的主接口 |
Protocol: (s) - spoofing |
如果某接口的Protocol属性值中带有“(s)”,则表示该接口的数据链路层协议状态显示为UP,但实际可能没有对应的链路,或者对应的链路不是永久存在而是按需建立的。通常NULL、LoopBack等接口会具有该属性 |
接口名称缩写 |
Link |
接口物理连接状态,取值为: · UP:表示接口物理上是连通的 · DOWN:表示接口物理上不通 · ADM:表示接口被管理员通过shutdown命令关闭,需要执行undo shutdown命令才能恢复接口本身的物理状态 |
Protocol |
接口数据链路层协议状态,取值为: · UP:表示接口的数据链路层协议状态为开启 · DOWN:表示接口的数据链路层协议状态为关闭 · UP(s):表示接口的数据链路层协议状态显示为UP,但实际可能没有对应的链路,或者对应的链路不是永久存在而是按需建立的。通常NULL、LoopBack等接口会取该值 |
Primary IP |
接口主IP地址。取值为“--”时,表示接口尚未配置IP地址 |
接口的描述信息 |
Brief information of interfaces in bridge mode: |
二层模式下(bridge)的接口概要信息,即二层接口的概要信息 |
Speed: (a) - auto |
如果某接口的Speed属性值为“(a)”,则表示该接口的速率是通过自动协商获取的 如果某接口的Speed属性值为“auto”,则表示该接口的速率是通过自动协商获取的,但协商还未开始 |
Duplex: (a)/A - auto; H - half; F - full |
如果某接口的Duplex属性值为“(a)”或者“A”,则表示该接口的Duplex属性是通过自动协商获取的;取值为“H”则表示为半双工;取值为“F”则表示为全双工 当显示为“A”时表示该接口的Duplex属性是通过自动协商获取的,但协商还未开始 |
Type: A - access; T - trunk; H - hybrid |
接口的链路类型: · A:表示Access链路类型 · H:表示Hybrid链路类型 · T:表示Trunk链路类型 |
Speed |
接口的速率,单位为bps |
Duplex |
接口的双工模式,取值为: · A:表示双工模式由自动协商结果决定 · F:表示全双工 · F(a):表示自由协商的结果为全双工 · H:表示半双工 · H(a):表示自由协商的结果为半双工 |
Type |
PVID |
接口所在的缺省VLAN ID |
Cause |
接口物理连接状态为down的原因,取值为: · Administratively:表示本链路被手工关闭了(配置了shutdown命令),需要执行undo shutdown命令才能恢复真实的物理状态 · DOWN ( Link-Aggregation interface down ):聚合接口被关闭后,该聚合接口的所有成员端口的状态会显示为DOWN,down的原因会显示为DOWN ( Link-Aggregation interface down ) · DOWN (Loopback detection down):由于环路检测模块检测到环路而自动关闭接口 · DOWN ( Monitor-Link uplink down ):由于Monitor Link模块检测到上行链路down而自动关闭接口 · Not connected:表示没有物理连接(可能没有插网线或者网线故障) · Storm-Constrain:表示端口上因为未知单播、组播或广播报文中某类报文的流量大于其上限阈值而被关闭 · STP DOWN:由于触发了STP BPDU保护而自动关闭接口 |
display interface link-info命令用来显示接口的状态和报文统计等信息。
display interface link-info [ main ]
main:显示除子接口外的所有接口的状态和报文统计等信息。不指定该参数,显示所有接口的状态和报文统计等信息。
# 显示所有接口的状态和报文统计等信息。
<Sysname> display interface link-info
Interface Link Protocol InUsage OutUsage InErrs OutErrs
XGE1/0/1 UP UP 10.09% 0% 0 0
NULL0 UP UP(s) 0% 0% 0 0
Overflow: More than 7 digits.
--: Not supported.
表1-6 display interface link-info命令显示信息描述表
· 如果某接口的Link属性值为“ADM”,则表示该接口被管理员通过shutdown命令关闭,需要在该接口下执行undo shutdown命令才能恢复接口本身的物理状态 · 如果某接口的Link属性值为“Stby”,则表示该接口是一个处于Standby状态的备份接口 |
如果某接口的Protocol属性值中带有“(s)”,则表示该接口的数据链路层协议状态显示为UP,但实际可能没有对应的链路,或者对应的链路不是永久存在而是按需建立的。通常NULL、LoopBack、InLoopBack等接口会具有该属性 |
接口名简称 |
Link |
Protocol |
接口数据链路层协议状态,取值为: · UP:表示接口的数据链路层协议状态为开启 · DOWN:表示接口的数据链路层协议状态为关闭 · UP(s):表示接口的数据链路层协议状态显示为UP,但实际可能没有对应的链路,或者对应的链路不是永久存在而是按需建立的。通常NULL、LoopBack、InLoopBack等接口会取该值 |
InUsage |
接收方向最近一个统计周期的带宽利用率。接口接收方向最近一个统计周期内的带宽利用率=接口接收方向最近一个统计周期内平均速率/接口带宽。不足0.01%且有流量时显示0.01%。统计周期可以通过flow-interval命令进行设置 |
OutUsage |
发送方向最近一个统计周期的带宽利用率。接口发送方向最近一个统计周期内的带宽利用率=接口发送方向最近一个统计周期内平均速率/接口带宽。不足0.01%且有流量时显示0.01%。统计周期可以通过flow-interval命令进行设置 |
InErrs |
接口接收的错误报文总数(单位为包) |
OutErrs |
接口发送的错误报文总数(单位为包) |
Overflow: More than 7 digits. |
当某个统计信息的值为Overflow时,表示该项数据的长度超过了显示范围,Overflow表示数据的长度超过了7位十进制数 |
· flow-interval
display interface main命令用来显示除子接口以外的接口的运行状态和相关信息。
display interface [ interface-type ] [ brief [ description | down ] ] main
interface-type:指定接口类型。如果不指定本参数,则显示所有类型接口的信息。
# 查看除子接口以外的接口的运行状态和相关信息。
<Sysname> display interface main
IP packet frame type: Ethernet II, hardware address: 4005-6538-0100
Loopback is not set
PVID: 1
MDI type: Automdix
Tagged VLANs: None
Untagged VLANs: 1
Port priority: 2
Last link flapping: Never
Current system time:2018-04-11 10:20:24
Last time when physical state changed to down:2018-04-11 09:11:09
Peak input rate: 0 bytes/sec, at 00-00-00 00:00:00
Peak output rate: 0 bytes/sec, at 00-00-00 00:00:00
Ten-GigabitEthernet1/0/2
Description: Ten-GigabitEthernet1/0/2 Interface
IP packet frame type: Ethernet II, hardware address: 4005-6538-0107
IPv6 packet frame type: Ethernet II, hardware address: 4005-6538-0107
Last time when physical state changed to down:2018-04-11 09:33:52
# 显示除子接口以外所有接口的概要信息。
<Sysname> display interface brief main
NULL0 UP UP(s) --
Vlan1 UP DOWN --
Speed: (a) - auto
# 显示除子接口以外的接口的概要信息,包括用户配置的全部描述信息。
<Sysname> display interface brief description main
Speed: (a) - auto
XGE1/0/3 UP auto F(a) A 1 aaaaaaaaaaaaaaaaaaaaaaaaaaaaa
# 显示除子接口以外当前物理状态为down的接口的信息以及down的原因。
<Sysname> display interface brief down main
Vlan2 DOWN Not connected
display interface main命令显示信息描述请参见表1-4和表1-5。
display interface split-capable命令用来显示支持拆分的接口信息。
display interface split-capable [ slot slot-number ]
# 显示设备支持拆分的接口信息。
<Sysname> display interface split-capable
slot 1:
100-GE interfaces capable of being split into multiple 10-GE or 25-GE interfaces
HundredGigE1/0/25 HundredGigE1/0/26 HundredGigE1/0/27
HundredGigE1/0/28 HundredGigE1/0/29 HundredGigE1/0/30
40-GE interfaces capable of being split into four 10-GE interfaces:
表1-7 display interface split-capable命令显示信息描述表
100-GE interfaces capable of being split into multiple 10-GE or 25-GE interfaces |
支持拆分为多个10G接口或者25G接口的100G接口信息 |
40-GE interfaces capable of being split into four 10-GE interfaces |
支持拆分为4个10G接口的40G接口信息 |
display packet-drop命令用来显示接口丢弃的报文的信息。
display packet-drop { interface [ interface-type [ interface-number ] ] | summary }
interface-type:显示指定类型接口丢弃的报文的信息。
interface-number:显示指定编号接口丢弃的报文的信息。
summary:将所有支持本命令的接口的丢弃报文统计信息累计后再显示。
如果不指定接口类型和接口编号,则显示所有支持本命令的接口的丢弃报文信息。
如果仅指定接口类型,则显示该类型所有支持本命令的接口的丢弃报文的信息。
# 显示接口Ten-GigabitEthernet1/0/1丢弃报文的信息。
<Sysname> display packet-drop interface ten-gigabitethernet 1/0/1
Ten-GigabitEthernet1/0/1:
Packets dropped due to full GBP or insufficient bandwidth: 301
Packets dropped due to Fast Filter Processor (FFP): 261
Packets dropped due to STP non-forwarding state: 321
Packets dropped due to rate-limit: 143
Packets dropped due to broadcast-suppression: 301
Packets dropped due to unicast-suppression: 215
Packets dropped due to multicast-suppression: 241
Packets dropped due to Tx packet aging: 246
# 将所有支持本命令的接口的丢弃报文统计信息累计后再显示。
<Sysname> display packet-drop summary
All interfaces:
表1-8 display packet-drop命令显示信息描述表
Packets dropped due to full GBP or insufficient bandwidth |
由于芯片缓存满或者带宽不够导致的丢包数 |
Packets dropped due to Fast Filter Processor (FFP) |
由于数据包被过滤所导致的丢包数 |
Packets dropped due to STP non-forwarding state |
由于STP协议状态为discarding导致的丢包数 |
Packets dropped due to rate-limit |
由于速率限制导致的丢包数 |
Packets dropped due to broadcast-suppression |
由于广播抑制导致的丢包数 |
Packets dropped due to unicast-suppression |
由于未知单播抑制导致的丢包数 |
Packets dropped due to multicast-suppression |
由于组播抑制导致的丢包数 |
Packets dropped due to Tx packet aging |
由于出方向报文超时导致的丢包数 |
display priority-flow-control命令用来显示接口的PFC(Priority-based Flow Control,基于优先级的流量控制)信息。
display priority-flow-control interface [ interface-type [ interface-number ] ]
interface-type:显示指定类型接口的PFC信息。interface-type表示接口类型。不指定该参数时,则显示设备上所有以太网接口的PFC信息。
interface-number:显示指定接口的PFC信息。interface-number表示接口编号。不指定该参数时,显示设备上指定类型的以太网接口的PFC信息。
# 显示所有接口的PFC信息。
<Sysname> display priority-flow-control interface
Conf -- Configured mode Ne -- Negotiated mode P -- Priority
Interface Conf Ne Dot1pList P Recv Sent
XGE1/0/1 Off Off
表1-9 display priority-flow-control interface命令显示信息描述表
Conf -- Configured mode |
本地配置的PFC功能的状态 |
Ne -- Negotiated mode |
PFC功能状态的协商结果 |
P -- Priority |
开启PFC功能的802.1p优先级 |
接口简名 |
Conf |
本地配置的PFC功能的状态: · Auto表示接口与对端自动协商是否开启PFC功能 · Off表示接口下未开启PFC功能 · On表示接口下已开启PFC功能 |
Ne |
PFC功能状态的协商结果: · Off表示接口PFC处于未开启状态 · On表示接口PFC处于开启状态 |
Dot1pList |
开启PFC功能的802.1p优先级队列,共8个(0~7)优先级队列 |
P |
开启PFC功能的802.1p优先级队列中,有数据帧收发的优先级队列,收发帧数据为0的队列不显示 |
Recv |
收到的PFC PAUSE帧数 |
Sent |
发送的PFC PAUSE帧数 |
· priority-flow-control
· priority-flow-control no-drop dot1p
duplex命令用来设置以太网接口的双工模式。
undo duplex命令用来恢复缺省情况。
duplex { auto | full | half }
undo duplex
以太网接口的双工模式为auto(自协商)状态。
以太网接口视图
auto:接口与对端接口自动协商双工状态。
full:全双工状态,接口在发送数据包的同时可以接收数据包。
half:半双工状态,接口同一时刻只能发送数据包或接收数据包。仅管理以太网接口支持本参数。
# 将以太网接口Ten-GigabitEthernet1/0/1接口设置为全双工状态。
[Sysname-Ten-GigabitEthernet1/0/1] duplex full
flow-control命令用来开启以太网接口的流量控制功能。
undo flow-control命令用来关闭以太网接口流量控制功能。
flow-control
undo flow-control
以太网接口的流量控制功能处于关闭状态。
以太网接口视图
配置flow-control命令后,设备具有发送和接收流量控制报文的能力:
· 当本端发生拥塞时,设备会向对端发送流量控制报文。
· 当本端收到对端的流量控制报文后,会停止报文发送。
只有本端和对端设备都开启了流量控制功能,才能实现对本端以太网接口的流量控制。
本命令和priority-flow-control no-drop dot1p命令互斥。
# 开启以太网接口Ten-GigabitEthernet1/0/1的流量控制功能。
[Sysname-Ten-GigabitEthernet1/0/1] flow-control
flow-control receive enable命令用来开启以太网接口的接收流量控制功能。
undo flow-control命令用来关闭以太网接口的接收流量控制功能。
undo flow-control
以太网接口的接收流量控制功能处于关闭状态。
以太网接口视图
配置flow-control receive enable命令后,设备具有接收流量控制报文的能力,但不具有发送流量控制报文的能力。
开启以太网接口的接收流量控制功能后:
· 当设备收到对端的流量控制报文,会停止向对端发送报文。
· 当本端发生拥塞时,设备不能向对端发送流量控制报文。
如果要应对单向网络拥塞的情况,可以在一端配置flow-control receive enable,在对端配置flow-control;如果要求本端和对端网络拥塞都能处理,则两端都必须配置flow-control。
本命令和priority-flow-control、priority-flow-control no-drop dot1p互斥。
# 使能以太网接口Ten-GigabitEthernet1/0/1的接收流量控制功能。
[Sysname-Ten-GigabitEthernet1/0/1] flow-control receive enable
【相关配置】
· flow-control
flow-interval命令用来配置接口统计报文信息的时间间隔。
undo flow-interval命令用来恢复缺省情况。
flow-interval interval
undo flow-interval
接口统计报文信息的时间间隔为300秒。
以太网接口视图
interval:接口统计信息的时间间隔值。系统视图下取值范围为5~300,单位为秒,步长为5(即取值必须为5的整数倍);以太网接口视图下取值范围为1~300,单位为秒,步长为1。
用户可以通过系统视图和接口视图下的配置来配置以太网接口统计信息的时间间隔:
· 系统视图下的配置对所有以太网接口生效;
· 以太网接口视图下的配置对当前接口生效。
对于一个接口来说,优先采用该接口下的配置,只有该接口下未进行配置或配置为缺省值时,才采用全局的配置。
系统视图下的flow-interval命令建议采用缺省值。如果将该时间间隔配置过短,可能导致系统性能下降,统计的数据不准确。
修改接口统计信息的时间间隔后,需要等待两个统计周期,才能通过display interface命令的Last interval second input和Last interval second output字段查看正确的统计信息。
# 设置以太网接口Ten-GigabitEthernet1/0/1的统计信息时间间隔为100秒。
[Sysname-Ten-GigabitEthernet1/0/1] flow-interval 100
· display interface
ifmonitor crc-error命令用来全局配置CRC错误报文告警参数。
undo ifmonitor crc-error命令用来恢复缺省情况。
仅R3608及以上版本支持本命令。
ifmonitor crc-error slot slot-number high-threshold high-value low-threshold low-value interval interval [ shutdown ]
undo ifmonitor crc-error slot slot-number
CRC错误报文告警上限阈值为1000,下限阈值为100,数据收集和比较时间间隔为10秒。
high-threshold high-value:指定CRC错误报文告警上限阈值,取值范围为1~4294967295,单位为报文个数。
low-threshold low-value:指定CRC错误报文告警下限阈值,取值范围为1~4294967295,单位为报文个数。
interval interval:指定CRC错误报文数据收集和比较时间间隔,取值范围为1~65535,单位是秒。
shutdown:表示当接口接收到的CRC错误报文超出上限告警阈值时,关闭接口,该接口将停止转发所有报文。因CRC错误被关闭的接口不会自动恢复,需执行undo shutdown命令来恢复。未指定本参数时,表示当接口接收到的CRC错误报文超出上限告警阈值,接口将产生超上限告警,并进入告警状态。
slot slot-number:配置指定单板的参数。slot-number为单板所在的槽位号。
开启CRC错误报文告警功能后,当接口处于正常状态,并在指定的时间内接收的CRC错误报文超出告警上限阈值时,接口将产生超上限告警,并进入告警状态。当接口处于告警状态,且在指定时间间隔内接收的CRC错误报文数低于下限阈值时,接口将产生恢复告警,并恢复到正常状态。
用户可在系统视图和接口视图下配置CRC错误报文告警参数。
· 系统视图下的配置对指定slot的所有接口有效,接口视图下的配置只对当前接口有效。
· 对于接口来说,优先采用接口视图下的配置,当该接口未进行配置时,才采用系统视图下的配置。
多次执行本命令,最后一次执行的命令生效。
# 配置CRC错误报文告警上限阈值为5000,CRC错误报文告警下限阈值为400,CRC错误报文数据收集和比较时间间隔为6秒。
[Sysname] ifmonitor crc-error slot 1 high-threshold 5000 low-threshold 400 interval 6
· snmp-agent trap enable ifmonitor
ifmonitor giant命令用来全局配置超大帧告警参数。
undo ifmonitor giant命令用来恢复缺省情况。
仅R3608及以上版本支持本命令。
ifmonitor giant slot slot-number high-threshold high-value low-threshold low-value interval interval [ shutdown ]
undo ifmonitor giant slot slot-number
超大帧告警上限阈值为1000,下限阈值为100,数据收集和比较时间间隔为10秒。
high-threshold high-value:指定接口超大帧告警上限阈值,取值范围是1~4294967295。
low-threshold low-value:指定接口超大帧告警下限阈值,取值范围是1~4294967295。
interval interval:指定接口超大帧数据收集和比较时间间隔,取值范围为1~65535,单位是秒。
shutdown:表示当接口进入超大帧告警状态时,关闭接口,该接口将停止转发所有报文。因超大帧告警被关闭的接口不会自动恢复,需执行undo shutdown命令来恢复。
slot slot-number:指定单板。slot-number为单板所在的槽位号。如果不指定本参数,则表示指定主用主控板。
当接口处于正常状态,并在指定的时间内收到的超大帧个数超出告警上限阈值时,接口将进入告警状态,产生超大帧告警。当接口处于超大帧告警状态,并在指定的时间内收到的超大帧个数低于下限阈值时,接口将恢复到正常状态,产生超大帧恢复告警。
用户可在系统视图和接口视图下配置超大帧告警参数。
# 全局配置超大帧告警上限阈值为5,超大帧告警下限阈值为4,超大帧数据收集和比较时间间隔为6秒。
[Sysname] ifmonitor giant slot 1 high-threshold 5 low-threshold 4 interval 6
· port ifmonitor giant
ifmonitor input-error命令用来全局配置入方向错误报文告警参数。
undo ifmonitor input-error命令用来恢复缺省情况。
仅R3608及以上版本支持本命令。
ifmonitor input-error slot slot-number high-threshold high-value low-threshold low-value interval interval [ shutdown ]
undo ifmonitor input-error slot slot-number
入方向错误报文告警上限阈值为1000,下限阈值为100,数据收集和比较时间间隔为10秒。
high-threshold high-value:指定接口入方向错误报文告警上限阈值,取值范围为1~4294967295,单位为报文个数。
low-threshold low-value:指定接口入方向错误报文告警下限阈值,取值范围为1~4294967295,单位为报文个数。
interval interval:指定接口入方向错误报文数据收集和比较时间间隔,取值范围为1~65535,单位是秒。
shutdown:表示当接口入方向错误报文超出上限告警阈值时,关闭接口,该接口将停止转发所有报文。因入方向错误被关闭的接口不会自动恢复,需执行undo shutdown命令来恢复。未指定本参数时,表示当接口接收到的入方向错误报文超出上限告警阈值,接口将产生超上限告警,并进入告警状态。
开启入方向错误报文告警功能后,当接口处于正常状态,并在指定的时间内入方向错误报文超出告警上限阈值时,接口将产生超上限告警,并进入告警状态。当接口处于告警状态,且在指定时间间隔内入方向错误报文数低于下限阈值时,接口将产生恢复告警,并恢复到正常状态。
用户可在系统视图和接口视图下配置入方向错误报文告警参数。
# 配置入方向错误报文告警上限阈值为5000,入方向错误报文告警下限阈值为400,入方向错误报文数据收集和比较时间间隔为6秒。
[Sysname] ifmonitor input-error slot 1 high-threshold 5000 low-threshold 400 interval 6
ifmonitor input-usage命令用来全局配置入方向带宽利用率的告警参数。
undo ifmonitor input-usage命令用来恢复缺省情况。
仅R3608及以上版本支持本命令。
ifmonitor input-usage slot slot-number high-threshold high-value low-threshold low-value
undo ifmonitor input-usage slot slot-number
入方向带宽利用率告警的上限阈值为90,下限阈值为80。
high-threshold high-value:指定入方向带宽利用率告警上限阈值,取值范围是1~100,单位为百分比。
low-threshold low-value:指定入方向带宽利用率告警下限阈值,取值范围是1~100,单位为百分比。
当接口处于正常状态,并在最近一个统计周期内入方向带宽利用率达到告警上限阈值时,接口将产生超上限告警,并进入告警状态。当接口处于告警状态,且在最近一个统计周期内入方向带宽利用率低于下限阈值时,接口将产生恢复告警,并恢复到正常状态。
用户可在系统视图和接口视图下配置入方向带宽利用率告警参数。
本命令必须通过snmp-agent trap enable ifmonitor命令开启入方向带宽利用率告警功能后才能生效。
# 配置全局入方向带宽利用率告警上限阈值为95,入方向带宽利用率告警下限阈值为80。
[Sysname] ifmonitor input-usage slot 1 high-threshold 95 low-threshold 80
· flow-interval
ifmonitor output-error命令用来全局配置出方向错误报文告警参数。
undo ifmonitor output-error命令用来恢复缺省情况。
仅R3608及以上版本支持本命令。
ifmonitor output-error slot slot-number high-threshold high-value low-threshold low-value interval interval [ shutdown ]
undo ifmonitor output-error slot slot-number
出方向错误报文告警上限阈值为1000,下限阈值为100,数据收集和比较时间间隔为10秒。
high-threshold high-value:指定接口出方向错误报文告警上限阈值,取值范围为1~4294967295,单位为报文个数。
low-threshold low-value:指定接口出方向错误报文告警下限阈值,取值范围为1~4294967295,单位为报文个数。
interval interval:指定接口出方向错误报文数据收集和比较时间间隔,取值范围为1~65535,单位是秒。
shutdown:表示当接口出方向错误报文超出上限告警阈值时,关闭接口,该接口将停止转发所有报文。因出方向错误被关闭的接口不会自动恢复,需执行undo shutdown命令来恢复。未指定本参数时,表示当接口接收到的出方向错误报文超出上限告警阈值,接口将产生超上限告警,并进入告警状态。
开启出方向错误报文告警功能后,当接口处于正常状态,并在指定的时间内出方向错误报文超出告警上限阈值时,接口将产生超上限告警,并进入告警状态。当接口处于告警状态,且在指定时间间隔内出方向错误报文数低于下限阈值时,接口将产生恢复告警,并恢复到正常状态。
用户可在系统视图和接口视图下配置出方向错误报文告警参数。
# 配置出方向错误报文告警上限阈值为5000,出方向错误报文告警下限阈值为400,出方向错误报文数据收集和比较时间间隔为6秒。
[Sysname] ifmonitor output-error slot 1 high-threshold 5000 low-threshold 400 interval 6
ifmonitor output-usage命令用来全局配置出方向带宽利用率的告警参数。
undo ifmonitor output-usage命令用来恢复缺省情况。
仅R3608及以上版本支持本命令。
ifmonitor output-usage slot slot-number high-threshold high-value low-threshold low-value
undo ifmonitor output-usage slot slot-number
出方向的带宽利用率告警的上限阈值为90,下限阈值为80。
high-threshold high-value:指定出方向带宽利用率告警上限阈值,取值范围是1~100,单位为百分比。
low-threshold low-value:指定出方向带宽利用率告警下限阈值,取值范围是1~100,单位为百分比。
当接口处于正常状态,并在最近一个统计周期内出方向带宽利用率达到告警上限阈值时,接口将产生超上限告警,并进入告警状态。当接口处于告警状态,且在最近一个统计周期内出方向带宽利用率低于下限阈值时,接口将产生恢复告警,并恢复到正常状态。
用户可在系统视图和接口视图下配置出方向带宽利用率告警参数。
本命令必须通过snmp-agent trap enable ifmonitor命令开启出方向带宽利用率告警功能后才能生效。
# 配置全局出方向带宽利用率告警上限阈值为80,出方向带宽利用率告警下限阈值为60。
[Sysname] ifmonitor output-usage slot 1 high-threshold 80 low-threshold 60
· flow-interval
ifmonitor runt命令用来全局配置超小帧告警参数。
undo ifmonitor runt命令用来恢复缺省情况。
仅R3608及以上版本支持本命令。
ifmonitor runt slot slot-number high-threshold high-value low-threshold low-value interval interval [ shutdown ]
undo ifmonitor runt slot slot-number
超小帧告警上限阈值为1000,下限阈值为100,数据收集和比较时间间隔为10秒。
high-threshold high-value:指定接口超小帧告警上限阈值,取值范围是1~4294967295。
low-threshold low-value:指定接口超小帧告警下限阈值,取值范围是1~4294967295。
interval interval:指定接口超小帧数据收集和比较时间间隔,取值范围为1~65535,单位是秒。
shutdown:表示当接口进入超小帧告警状态时,关闭接口,该接口将停止转发所有报文。因超小帧告警被关闭的接口不会自动恢复,需执行undo shutdown命令来恢复。
当接口处于正常状态,并在指定的时间内收到的超小帧个数超出告警上限阈值时,接口将进入告警状态,产生超小帧告警。当接口处于超小帧告警状态,并在指定的时间内收到的超小帧个数低于下限阈值时,接口将恢复到正常状态,产生超小帧恢复告警。
用户可在系统视图和接口视图下配置超小帧告警参数。
# 全局配置超小帧告警上限阈值为5,超小帧告警下限阈值为4,超小帧数据收集和比较时间间隔为6秒。
[Sysname] ifmonitor runt slot 1 high-threshold 5 low-threshold 4 interval 6
· port ifmonitor runt
ifmonitor rx-pause命令用来全局配置接收PAUSE帧告警参数。
undo ifmonitor rx-pause命令用来恢复缺省情况。
仅R3608及以上版本支持本命令。
ifmonitor rx-pause slot slot-number high-threshold high-value low-threshold low-value interval interval
undo ifmonitor rx-pause slot slot-number
接收PAUSE帧告警的上限阈值为500,下限阈值为100,数据收集和比较时间间隔为10秒。
high-threshold high-value:指定接收PAUSE帧告警上限阈值,取值范围是1~4294967295,单位为帧个数。
low-threshold low-value:指定接收PAUSE帧告警下限阈值,取值范围是1~4294967295,单位为帧个数。
interval interval:指定接收PAUSE帧数据收集和比较时间间隔,取值范围为1~65535,单位是秒。
当接口处于正常状态,并在指定的时间内接收PAUSE帧的个数达到告警上限阈值时,接口将产生超上限告警,并进入告警状态。当接口处于告警状态,且在指定时间间隔内接收PAUSE帧的个数低于下限阈值时,接口将产生恢复告警,并恢复到正常状态。
用户可在系统视图和接口视图下配置接收PAUSE帧告警参数。
本命令必须通过snmp-agent trap enable ifmonitor命令开启接收PAUSE帧告警功能后才能生效。
# 配置接收PAUSE帧告警上限阈值为30,接收PAUSE帧告警下限阈值为20,接收PAUSE帧数据收集和比较时间间隔为4秒。
[Sysname] ifmonitor rx-pause slot 1 high-threshold 30 low-threshold 20 interval 4
ifmonitor sdh-b1-error命令用来全局配置SDH-B1错误报文告警参数。
undo ifmonitor sdh-b1-error命令用来恢复缺省情况。
仅R3608及以上版本支持本命令。
ifmonitor sdh-b1-error slot slot-number high-threshold high-value low-threshold low-value interval interval [ shutdown ]
undo ifmonitor sdh-b1-error slot slot-number
SDH-B1错误报文告警上限阈值为1000,下限阈值为100,数据收集和比较时间间隔为10秒。
high-threshold high-value:指定SDH-B1错误报文告警上限阈值,取值范围是1~4294967295,单位为报文个数。
low-threshold low-value:指定SDH-B1错误报文告警下限阈值,取值范围是1~4294967295,单位为报文个数。
interval interval:指定SDH-B1错误报文数据收集和比较时间间隔,取值范围为1~65535,单位是秒。
shutdown:表示当接口接收到的SDH-B1错误报文达到上限告警阈值时,关闭接口,该接口将停止转发所有报文。因SDH-B1错误而被关闭的接口不会自动恢复,需执行undo shutdown命令来恢复。未指定本参数时,表示当接口接收到的SDH-B1错误报文达到上限告警阈值,不会关闭该接口,同时接口将产生超上限告警,并进入告警状态。
当接口处于正常状态,并在指定的时间内SDH-B1错误报文达到告警上限阈值时,接口将产生超上限告警,并进入告警状态。当接口处于告警状态,且在指定时间间隔内SDH-B1错误报文数低于下限阈值时,接口将产生恢复告警,并恢复到正常状态。
用户可在系统视图和接口视图下配置SDH-B1错误报文告警参数。
本命令必须通过snmp-agent trap enable ifmonitor命令开启SDH-B1错误报文告警功能后才能生效。
# 配置SDH-B1错误报文告警上限阈值为65,SDH-B1错误报文告警下限阈值为25,SDH-B1错误报文数据收集和比较时间间隔为20秒。
[Sysname] ifmonitor sdh-b1-error slot 1 high-threshold 65 low-threshold 25 interval 20
ifmonitor sdh-b2-error命令用来全局配置SDH-B2错误报文告警参数。
undo ifmonitor sdh-b2-error命令用来恢复缺省情况。
仅R3608及以上版本支持本命令。
ifmonitor sdh-b2-error slot slot-number high-threshold high-value low-threshold low-value interval interval [ shutdown ]
undo ifmonitor sdh-b2-error slot slot-number
SDH-B2错误报文告警上限阈值为1000,下限阈值为100,数据收集和比较时间间隔为10秒。
high-threshold high-value:指定接口SDH-B2错误报文告警上限阈值,取值范围是1~4294967295,单位为报文个数。
low-threshold low-value:指定接口SDH-B2错误报文告警下限阈值,取值范围是1~4294967295,单位为报文个数。
interval interval:指定接口SDH-B2错误报文数据收集和比较时间间隔,取值范围为1~65535,单位是秒。
shutdown:表示当接口接收到的SDH-B2错误报文达到上限告警阈值时,关闭接口,该接口将停止转发所有报文。因SDH-B2错误被关闭的接口不会自动恢复,需执行undo shutdown命令来恢复。未指定本参数时,表示当接口接收到的SDH-B2错误报文达到上限告警阈值,不会关闭该接口,同时接口将产生超上限告警,并进入告警状态。
当接口处于正常状态,并在指定的时间内SDH-B2错误报文达到告警上限阈值时,接口将产生超上限告警,并进入告警状态。当接口处于告警状态,且在指定时间间隔内SDH-b2错误报文数低于下限阈值时,接口将产生恢复告警,并恢复到正常状态。
用户可在系统视图和接口视图下配置SDH-B2错误报文告警参数。
本命令必须通过snmp-agent trap enable ifmonitor命令开启SDH-B2错误报文告警功能后才能生效。
# 配置SDH-B2错误报文告警上限阈值为6,SDH-B2错误报文告警下限阈值为5,SDH-B2错误报文数据收集和比较时间间隔为2秒。
[Sysname] ifmonitor sdh-b2-error slot 1 high-threshold 6 low-threshold 5 interval 2
ifmonitor sdh-error命令用来全局配置SDH错误报文告警参数。
undo ifmonitor sdh-error命令用来恢复缺省情况。
仅R3608及以上版本支持本命令。
ifmonitor sdh-error slot slot-number high-threshold high-value low-threshold low-value interval interval [ shutdown ]
undo ifmonitor sdh-error slot slot-number
SDH错误报文告警上限阈值为1000,下限阈值为100,数据收集和比较时间间隔为10秒。
high-threshold high-value:指定SDH错误报文告警上限阈值,取值范围是1~4294967295,单位为报文个数。
low-threshold low-value:指定SDH错误报文告警下限阈值,取值范围是1~4294967295,单位为报文个数。
interval interval:指定SDH错误报文数据收集和比较时间间隔,取值范围为1~65535,单位为秒。
shutdown:表示当接口接收到SDH错误报文达到上限告警阈值时,关闭接口,该接口将停止转发所有报文。因SDH错误被关闭的接口不会自动恢复,需执行undo shutdown命令来恢复。未指定本参数时,表示当接口接收到的SDH错误报文达到上限告警阈值,不会关闭该接口,同时该接口将产生超上限告警,并进入告警状态。
当接口处于正常状态,并在指定的时间内SDH错误报文达到告警上限阈值时,接口将产生超上限告警,并进入告警状态。当接口处于告警状态,且在指定时间间隔内SDH错误报文数低于下限阈值时,接口将产生恢复告警,并恢复到正常状态。
用户可在系统视图和接口视图下配置SDH错误报文告警参数。
本命令必须通过snmp-agent trap enable ifmonitor命令开启SDH错误报文告警功能后才能生效。
# 配置SDH错误报文告警上限阈值为35,SDH错误报文告警下限阈值为20,SDH错误报文数据收集和比较时间间隔为8秒。
[Sysname] ifmonitor sdh-error slot 1 high-threshold 35 low-threshold 20 interval 8
ifmonitor tx-pause命令用来全局配置发送PAUSE帧告警参数。
undo ifmonitor tx-pause命令用来恢复缺省情况。
仅R3608及以上版本支持本命令。
ifmonitor tx-pause slot slot-number high-threshold high-value low-threshold low-value interval interval
undo ifmonitor tx-pause slot slot-number
发送PAUSE帧告警的上限阈值为500,下限阈值为100,数据收集和比较时间间隔为10秒。
high-threshold high-value:指定发送PAUSE帧告警上限阈值,取值范围是1~4294967295,单位为帧个数。
low-threshold low-value:指定发送PAUSE帧告警下限阈值,取值范围是1~4294967295,单位为帧个数。
interval interval:指定发送PAUSE帧数据收集和比较时间间隔,取值范围为1~65535,单位是秒。
当接口处于正常状态,并在指定的时间内发送PAUSE帧的个数达到告警上限阈值时,接口将产生超上限告警,并进入告警状态。当接口处于告警状态,且在指定时间间隔内发送PAUSE帧的个数低于下限阈值时,接口将产生恢复告警,并恢复到正常状态。
用户可在系统视图和接口视图下配置发送PAUSE帧告警参数。
本命令必须通过snmp-agent trap enable ifmonitor命令开启发送PAUSE帧告警功能后才能生效。
# 配置发送PAUSE帧告警上限阈值为20,发送PAUSE帧告警下限阈值为10,发送PAUSE帧数据收集和比较时间间隔为5秒。
[Sysname] ifmonitor tx-pause slot 1 high-threshold 20 low-threshold 10 interval 5
interface命令用来进入接口视图或创建子接口并进入子接口视图。如果指定的子接口已经存在,则直接进入子接口视图。
设备工作模式为二层增强模式时,创建三层以太网子接口后,需要在子接口下配置VLAN终结命令vlan-type dot1q vid vlan-id,否则无法使用该子接口转发流量。配置VLAN终结时vlan-id与子接口编号相同。有关设备工作模式的介绍,请参见“基础配置指导”中的“设备管理”。
# 进入以太网接口Ten-GigabitEthernet1/0/1视图。
# 创建以太网子接口Ten-GigabitEthernet1/0/1.1并进入该子接口的视图。
· vlan-type dot1q vid(二层技术-以太网交换命令参考/VLAN终结)
jumboframe enable命令用来允许超长帧通过。
undo jumboframe enable命令用来禁止超长帧通过。
undo jumboframe enable size命令用来恢复缺省情况。
jumboframe enable [ size ]
设备允许12288字节的超长帧通过。
二层以太网接口视图
三层以太网接口视图
# 允许超长帧通过以太网接口Ten-GigabitEthernet1/0/1。
[Sysname-Ten-GigabitEthernet1/0/1] jumboframe enable
link-delay命令用来配置以太网接口物理连接状态抑制功能。
undo link-delay命令用来恢复缺省情况。
undo link-delay { down | up }
接口状态改变时,系统会将接口状态改变立即上报CPU。
以太网接口视图
down:设置以太网接口物理连接down状态抑制功能。
up:设置以太网接口物理连接up状态抑制功能。
msec:表示配置的抑制时间为毫秒级。不指定该参数时,表示配置的抑制时间为秒级。
delay-time:接口物理连接状态抑制时间值,0表示不抑制,即接口状态改变时立即上报CPU。
· 未指定msec参数时,取值范围为0~30,单位为秒。
· 指定msec参数时,取值范围为0~10000,且为10的倍数,单位为毫秒。
使用该命令时,选取的参数不同,抑制效果不同:
· down:表示接口状态从up变成down时,不会立即上报CPU。而是等待delay-time时间后,再检查接口状态,如果状态仍然是down,再上报。
· up:表示接口状态从down变成up时,不会立即上报CPU。而是等待delay-time时间后,再检查接口状态,如果状态仍然是up,再上报。
同一接口下,接口状态从up变成down的抑制时间和接口状态从down变成up的抑制时间可以不同。在同一接口下,多次执行本命令:
· 可以分别配置抑制上报down状态和抑制上报up状态。
· 当配置的是同一状态的抑制时间时,则最新的配置生效。
对于开启了生成树协议、RRPP或Smart Link的端口不推荐使用该命令。
# 设置以太网接口物理连接down状态抑制时间为8秒。
[Sysname-Ten-GigabitEthernet1/0/1] link-delay down 8
# 设置以太网接口物理连接up状态抑制时间为800毫秒。
[Sysname-Ten-GigabitEthernet1/0/1] link-delay up msec 800
linkdown trap enable shutdown命令用来允许生成接口被关闭的LinkDown告警。
undo linkdown trap enable shutdown命令用来禁止生成接口被关闭的LinkDown告警。
在系统视图下配置snmp-agent trap enable standard linkdown命令,接口视图下配置enable snmp trap updown命令后,接口状态变成up,设备会发送LinkUp告警,接口状态变成down,设备会发送LinkDown告警。接口状态变成down的原因很多,对于因为接口被关闭接口状态变为AMD的这类LinkDown告警,使用本命令,可以允许或者禁止这类LinkDown告警的生成。
生成的告警信息会发送给设备的SNMP模块,SNMP模块可以将告警输出到NMS。
# 禁止生成接口被关闭的LinkDown告警。
[Sysname] undo linkdown trap enable shutdown
· enable snmp trap updown(网络管理和监控命令参考/SNMP)
· snmp-agent trap enable standard(网络管理和监控命令参考/SNMP)
开启环回功能后,接口将不能正常转发数据包,请按需配置。
loopback命令用来开启以太网接口的环回功能。
undo loopback命令用来关闭以太网接口的环回功能。
undo loopback
以太网接口的环回功能处于关闭状态。
以太网接口视图
external:开启以太网接口的外部环回功能。
internal:开启以太网接口的内部环回功能。
开启环回功能后,接口将自动切换到全双工模式,关闭环回功能后会自动恢复原有双工模式。
shutdown、port up-mode和loopback命令互斥,后配置的失败。
# 开启以太网接口Ten-GigabitEthernet1/0/1的内部环回功能。
[Sysname-Ten-GigabitEthernet1/0/1] loopback internal
multicast-suppression命令用来开启端口组播风暴抑制功能,并设置组播风暴抑制阈值。
undo multicast-suppression命令用来关闭端口组播风暴抑制功能。
所有接口不对组播流量进行抑制。
以太网接口视图
ratio:指定以太网接口允许通过的最大组播流量占该接口带宽的百分比。取值范围为0~100。数值越小,则允许通过的组播流量也越小。
pps max-pps:指定以太网接口每秒最多允许通过的组播报文数,取值范围为0~1.4881×接口带宽。
kbps max-kbps:指定以太网接口每秒最多允许通过的组播流量,单位为kbps,取值范围为0~接口带宽。
本命令设置的是接口允许通过的最大组播报文流量。当接口上的组播流量超过用户设置的值后,系统将丢弃超出组播流量限制的报文,从而使接口组播流量所占的比例控制在限定的范围内,以便保证业务的正常运行。
执行multicast-suppression或storm-constrain命令都能开启端口的组播风暴抑制功能,storm-constrain命令通过软件对组播报文进行抑制,对设备性能有一定影响,multicast-suppression通过芯片物理上对组播报文进行抑制,相对storm-constrain来说,对设备性能影响较小。请不要同时配置multicast-suppression和storm-constrain命令,以免配置冲突,导致抑制效果不确定。
# 在以太网接口Ten-GigabitEthernet1/0/1上,每秒最多允许10000kbps组播报文通过,对超出该范围的组播报文进行抑制。
[Sysname-Ten-GigabitEthernet1/0/1] multicast-suppression kbps 10000
· broadcast-suppression
port fec mode命令用来配置接口的FEC(Forward Error Correction,前向纠错)模式。
undo port fec mode命令用来恢复缺省情况。
port fec mode { auto | none | rs-fec }
undo port fec mode
接口的FEC模式为自协商模式。
100GE接口视图
auto:表示FEC自协商模式。
none:不进行前向纠错。
rs-fec:表示RS-FEC模式。
FEC用于报文纠错,它通过在发送端为数据报文附加纠错信息,在接收端利用纠错信息来纠正数据报文在传输时产生的错误码,以提高传输质量。用户需要根据实际情况来选择FEC模式。
用户需要保证链路两端使用的FEC模式一致。
# 配置以太网接口HundredGigE1/0/1的FEC模式为自协商模式。
[Sysname-HundredGigE1/0/1] port fec mode auto
port ifmonitor crc-error命令用来配置CRC错误报文告警参数。
undo port ifmonitor crc-error命令用来恢复缺省情况。
仅R3608及以上版本支持本命令。
接口采用的CRC错误报文告警参数与全局采用的CRC错误报文告警参数一致。
以太网接口视图
context-admin
ratio:表示以百分比形式配置告警阈值。不指定该参数时,表示配置的是告警阈值的大小。
high-threshold high-value:指定CRC错误报文告警上限阈值。指定ratio参数时,取值范围为1~100;未指定ratio参数时,取值范围为1~4294967295,单位为报文个数。
low-threshold low-value:指定CRC错误报文告警下限阈值。指定ratio参数时,取值范围为1~100;未指定ratio参数时,取值范围为1~4294967295,单位为报文个数。
# 在接口HundredGigE1/0/1上配置CRC错误报文告警上限阈值为5000,CRC错误报文告警下限阈值为400,CRC错误报文数据收集和比较时间间隔为6秒。
[Sysname-HundredGigE1/0/1] port ifmonitor crc-error high-threshold 5000 low-threshold 400 interval 6
port ifmonitor giant命令用来在接口下配置超大帧告警参数。
undo port ifmonitor giant命令用来恢复缺省情况。
仅R3608及以上版本支持本命令。
port ifmonitor giant high-threshold high-value low-threshold low-value interval interval [ shutdown ]
接口采用的超大帧告警参数与全局采用的超大帧告警参数一致。
以太网接口视图
context-admin
# 在接口HundredGigE1/0/1下配置超大帧告警上限阈值为5、超大帧告警下限阈值为4,超大帧数据收集和比较时间间隔为6秒。
[Sysname-HundredGigE1/0/1] port ifmonitor giant high-threshold 5 low-threshold 4 interval 6
· ifmonitor giant
port ifmonitor input-error命令用来配置入方向错误报文告警参数。
undo port ifmonitor input-error命令用来恢复缺省情况。
仅R3608及以上版本支持本命令。
接口采用的入方向错误报文告警参数与全局采用的入方向错误报文告警参数一致。
以太网接口视图
context-admin
# 在接口HundredGigE1/0/1上配置入方向错误报文告警上限阈值为5000,入方向错误报文告警下限阈值为400,入方向错误报文数据收集和比较时间间隔为6秒。
[Sysname-HundredGigE1/0/1] port ifmonitor input-error high-threshold 5000 low-threshold 400 interval 6
port ifmonitor input-usage命令用来配置入方向带宽利用率的告警参数。
undo port ifmonitor input-usage命令用来恢复缺省情况。
仅R3608及以上版本支持本命令。
接口采用的入方向带宽利用率告警参数与全局采用的入方向带宽利用率告警参数一致。
context-admin
high-threshold high-value:指定入方向带宽利用率告警的上限阈值,取值范围是1~100,单位为百分比。
low-threshold low-value:指定入方向带宽利用率告警的下限阈值,取值范围是1~100,单位为百分比。
# 在接口HundredGigE1/0/1上配置入方向带宽利用率告警上限阈值为80,入方向带宽利用率告警下限阈值为60。
[Sysname-HundredGigE1/0/1] port ifmonitor input-usage high-threshold 80 low-thershold 60
· flow-interval
port ifmonitor output-error命令用来配置出方向错误报文告警参数。
undo port ifmonitor output-error命令用来恢复缺省情况。
仅R3608及以上版本支持本命令。
接口采用的出方向错误报文告警参数与全局采用的出方向错误报文告警参数一致。
以太网接口视图
context-admin
# 在接口HundredGigE1/0/1上配置出方向错误报文告警上限阈值为5000,出方向错误报文告警下限阈值为400,出方向错误报文数据收集和比较时间间隔为6秒。
[Sysname-HundredGigE1/0/1] port ifmonitor output-error high-threshold 5000 low-threshold 400 interval 6
port ifmonitor output-usage命令用来配置出方向带宽利用率的告警参数。
undo port ifmonitor output-usage命令用来恢复缺省情况。
仅R3608及以上版本支持本命令。
接口采用的出方向带宽利用率告警参数与全局采用的出方向带宽利用率告警参数一致。
context-admin
high-threshold high-value:指定接口出方向带宽利用率告警的上限阈值,取值范围是1~100,单位为百分比。
high-threshold high-value:指定接口出方向带宽利用率告警的下限阈值,取值范围是1~100,单位为百分比。
# 在接口HundredGigE1/0/1上配置入方向带宽利用率告警上限阈值为9,入方向带宽利用率告警下限阈值为7。
[Sysname-HundredGigE1/0/1]port ifmonitor output-usage high-threshold 9 low-threshold 7
· flow-interval
port ifmonitor runt命令用来在接口下配置超小帧告警参数。
undo port ifmonitor runt命令用来恢复缺省情况。
仅R3608及以上版本支持本命令。
port ifmonitor runt high-threshold high-value low-threshold low-value interval interval [ shutdown ]
接口采用的超小帧告警参数与全局采用的超小帧告警参数一致。
以太网接口视图
context-admin
# 在接口HundredGigE1/0/1下配置超小帧告警上限阈值为5、超小帧告警下限阈值为4,超小帧数据收集和比较时间间隔为6秒。
[Sysname-HundredGigE1/0/1] port ifmonitor runt high-threshold 5 low-threshold 4 interval 6
· ifmonitor runt
port ifmonitor rx-pause命令用来配置接口接收PAUSE帧告警参数。
undo port ifmonitor rx-pause命令用来恢复缺省情况。
仅R3608及以上版本支持本命令。
port ifmonitor rx-pause high-threshold high-value low-threshold low-value interval interval
接口采用的接收PAUSE帧告警参数与全局采用的接收PAUSE帧告警参数一致。
以太网接口视图
context-admin
high-threshold high-value:指定接口接收PAUSE帧告警的上限阈值,取值范围是1~4294967295,单位为帧个数。
low-threshold low-value:指定接口接收PAUSE帧告警的下限阈值,取值范围是1~4294967295,单位为帧个数。
interval interval:指定接口接收PAUSE帧数据收集和比较时间间隔,取值范围为1~65535,单位是秒。
# 在接口HundredGigE1/0/1上配置接收PAUSE帧告警上限阈值为90,接收PAUSE帧告警下限阈值为50,接收PAUSE帧数据收集和比较时间间隔为5秒。
[Sysname-HundredGigE1/0/1] port ifmonitor rx-pause high-threshold 90 low-threshold 50 interval 5
port ifmonitor sdh-b1-error命令用来配置接口SDH-B1错误报文告警参数。
undo port ifmonitor sdh-b1-error命令用来恢复缺省情况。
仅R3608及以上版本支持本命令。
port ifmonitor sdh-b1-error high-threshold high-value low-threshold low-value interval interval [ shutdown ]
接口采用的SDH-B1错误告警参数与全局采用的SDH-B1错误告警参数一致。
以太网接口视图
context-admin
high-threshold high-value:指定接口SDH-B1错误报文告警的上限阈值,取值范围是1~4294967295,单位为报文个数。
low-threshold low-value:指定接口SDH-B1错误报文告警的下限阈值,取值范围是1~4294967295,单位为报文个数。
interval interval:指定接口SDH-B1错误报文数据收集和比较时间间隔,取值范围为1~65535,单位是秒。
shutdown:表示当接口接收到的SDH-B1错误报文达到上限告警阈值时,关闭接口,该接口将停止转发所有报文。因SDH-B1错误被关闭的接口不会自动恢复,需执行undo shutdown命令来恢复。未指定本参数时,表示当接口接收到的SDH-B1错误报文达到上限告警阈值,不会关闭该接口,同时接口将产生超上限告警,并进入告警状态。
# 在接口HundredGigE1/0/1上配置SDH-B1错误报文告警上限阈值为20,SDH-B1错误报文告警下限阈值为10,SDH-B1错误报文数据收集和比较时间间隔为10秒。
[Sysname-HundredGigE1/0/1] port ifmonitor sdh-b1-error high-threshold 20 low-threshold 10 interval 10
port ifmonitor sdh-b2-error命令用来配置接口SDH-B2错误报文告警参数。
undo port ifmonitor sdh-b2-error命令用来恢复缺省情况。
仅R3608及以上版本支持本命令。
port ifmonitor sdh-b2-error high-threshold high-value low-threshold low-value interval interval [ shutdown ]
接口采用的SDH-B2错误告警参数与全局采用的SDH-B2错误告警参数一致。
以太网接口视图
context-admin
high-threshold high-value:指定接口SDH-B2错误报文告警的上限阈值,取值范围是1~4294967295,单位为报文个数。
low-threshold low-value:指定接口SDH-B2错误报文告警的下限阈值,取值范围是1~4294967295,单位为报文个数。
# 在接口HundredGigE1/0/1上配置SDH-B2错误报文告警上限阈值为10,SDH-B2错误报文告警下限阈值为8,SDH-B2错误报文数据收集和比较时间间隔为3秒。
[Sysname-HundredGigE1/0/1] port ifmonitor sdh-b2-error high-threshold 10 low-threshold 8 interval 3
port ifmonitor sdh-error命令用来配置接口下SDH错误报文告警参数。
undo port ifmonitor sdh-error命令用来恢复缺省情况。
仅R3608及以上版本支持本命令。
port ifmonitor sdh-error high-threshold high-value low-threshold low-value interval interval [ shutdown ]
接口采用的SDH错误报文告警参数与全局采用的SDH错误报文告警参数一致。
以太网接口视图
context-admin
high-threshold high-value:指定接口SDH错误报文告警的上限阈值,取值范围是1~4294967295,单位为报文个数。
low-threshold low-value:指定接口SDH错误报文告警的下限阈值,取值范围是1~4294967295,单位为报文个数。
interval interval:指定接口SDH错误报文数据收集和比较时间间隔,取值范围为1~65535,单位为秒。
shutdown:表示当接口接收到的SDH错误报文达到上限告警阈值时,关闭接口,该接口将停止转发所有报文。因SDH错误被关闭的接口不会自动恢复,需执行undo shutdown命令来恢复。未指定本参数时,表示当接口接收到的SDH错误报文达到上限告警阈值,不会关闭该接口,同时接口将产生超上限告警,并进入告警状态。
# 在接口HundredGigE1/0/1上配置SDH错误报文告警上限阈值为50,SDH错误报文告警下限阈值为30,SDH错误报文数据收集和比较时间间隔为10秒。
[Sysname-HundredGigE1/0/1] port ifmonitor sdh-error high-threshold 50 low-threshold 30 interval 10
port ifmonitor tx-pause命令用来配置接口发送PAUSE帧告警参数。
undo port ifmonitor tx-pause命令用来恢复缺省情况。
仅R3608及以上版本支持本命令。
port ifmonitor tx-pause high-threshold high-value low-threshold low-value interval interval
接口采用的发送PAUSE帧告警参数与全局采用的发送PAUSE帧告警参数一致。
以太网接口视图
context-admin
high-threshold high-value:指定接口发送PAUSE帧告警的上限阈值,取值范围是1~4294967295,单位为帧个数。
low-threshold low-value:指定接口发送PAUSE帧告警的下限阈值,取值范围是1~4294967295,单位为帧个数。
interval interval:指定接口发送PAUSE帧数据收集和比较时间间隔,取值范围为1~65535,单位是秒。
# 在接口HundredGigE1/0/1上配置发送PAUSE帧告警上限阈值为50,发送PAUSE帧告警下限阈值为40,发送PAUSE帧数据收集和比较时间间隔为8秒。
[Sysname-HundredGigE1/0/1] port ifmonitor tx-pause high-threshold 50 low-threshold 40 interval 8
port link-mode命令用来切换以太网接口的工作模式。
undo port link-mode命令用来恢复缺省情况。
undo port link-mode
以太网接口工作在二层模式。
以太网接口视图
bridge:工作在二层模式。
route:工作在三层模式。
接口模式切换后,除了shutdown命令,该以太网接口下的其它所有命令都将恢复到新模式下的缺省情况。
以太网接口比较灵活,工作模式可以通过命令行设置。如果将工作模式设置为二层模式(bridge),则作为一个二层以太网接口使用,如果将工作模式设置为三层模式(route),则作为一个三层以太网接口使用。
执行本命令切换接口二三层模式或者在二层接口下执行default命令前,请先删除接口上的所有配置,避免接口模式切换失败。
# 使接口Ten-GigabitEthernet1/0/1工作在二层模式。
[Sysname-Ten-GigabitEthernet1/0/1] port link-mode bridge
· default
priority-flow-control命令用来配置开启PFC(Priority-based Flow Control,基于优先级的流量控制)功能。
undo priority-flow-control命令用来关闭PFC功能。
priority-flow-control { auto | enable }
PFC功能处于关闭状态。
以太网接口视图
auto:表示与对端自动协商是否开启PFC功能。
enable:表示强制开启PFC功能。
如果本端和对端设备的PFC功能处于使能状态,并配置了priority-flow-control no-drop dot1p dot1p-list命令,则当本端收到的802.1p优先级在dot1p-list范围内的报文发生拥塞时,会通知对端设备暂时停止向本端发送对应优先级的报文;拥塞解除后,再通知对端继续发送对应优先级的报文。从而保证本设备在转发802.1p优先级在dot1p-list范围内的报文时不丢包。
PFC功能支持在全局配置和接口配置两种方式。全局配置本命令后,系统会在所有接口下下发本命令。多次在系统视图和接口视图下执行本命令,最后一次执行的命令生效。
# 在以太网接口Ten-GigabitEthernet1/0/1上开启PFC功能。
[Sysname-Ten-GigabitEthernet1/0/1] priority-flow-control enable
· display priority-flow-control
· priority-flow-control (System view)
priority-flow-control命令用来配置开启所有接口的PFC功能。
undo priority-flow-control命令用来关闭所有接口的PFC功能。
PFC功能处于关闭状态。
enable:表示强制开启PFC功能。
# 开启所有接口的PFC功能。
[Sysname] priority-flow-control enable
· priority-flow-control (Ethernet interface view)
priority-flow-control deadlock auto-recover action命令用来配置设备在自动恢复PFC死锁检测的延迟时间内对报文的处理动作。
undo priority-flow-control deadlock auto-recover action命令用来恢复缺省情况。
仅R3608及以上版本支持本命令。
priority-flow-control deadlock auto-recover action { discard | forwarding }
设备在自动恢复PFC死锁的延迟时间内转发收到的数据报文。
discard:丢弃收到的数据报文。
forwarding:转发收到的数据报文。
当设备处于PFC死锁状态时,无法配置本命令。
# 配置当设备进入PFC死锁状态后对数据报文进行丢弃。
[Sysname] priority-flow-control deadlock auto-recover action discard
· priority-flow-control deadlock cos
· priority-flow-control deadlock enable
priority-flow-control deadlock auto-recover cos命令用来配置PFC死锁检测自动恢复的延迟周期。
undo priority-flow-control deadlock auto-recover cos命令用来删除PFC死锁检测自动恢复的延迟周期。
仅R3608及以上版本支持本命令。
priority-flow-control deadlock auto-recover slot slot-number cos cos-value delay delay-interval
undo priority-flow-control deadlock auto-recover slot slot-number cos [ cos-value ]
未配置PFC死锁检测的恢复周期。
cos cos-value:报文CoS值,取值范围为0~7。不同的CoS值对应不同的802.1p优先级,可以通过display qos map-table dot1p-lp命令查看。
delay delay-interval:PFC死锁检测自动恢复的延迟周期,取值范围为1~15。
PFC死锁检测功能可以按周期检测携带指定CoS值的报文是否发生死锁,在设备进入PFC死锁状态后,设备自动恢复时会在延迟时间结束后恢复PFC死锁检测功能。延迟恢复周期由delay delay-interval和PFC死锁检测定时器的精度共同决定,即延迟时间 = delay-interval * PFC死锁检测定时器的精度。
本命令仅在PFC死锁检测功能的恢复方式为自动恢复时生效。当设备处于PFC死锁状态时,无法配置本命令。
指定的CoS值必须在priority-flow-control no-drop dot1p命令配置的802.1p优先级内。
对于不同CoS值可以配置相同的延迟恢复周期。
对于同一CoS值,多次执行本命令,最后一次执行的命令生效。
# 配置CoS值为7的PFC死锁自动恢复的延迟周期为5。
[Sysname] priority-flow-control deadlock auto-recover slot 1 cos 7 delay 5
· display qos map-table dot1p-lp(ACL和QoS/优先级映射)
· priority-flow-control deadlock precision
priority-flow-control deadlock cos命令用来配置PFC死锁检测的周期。
undo priority-flow-control deadlock cos命令用来删除PFC死锁检测的周期。
仅R3608及以上版本支持本命令。
priority-flow-control deadlock slot slot-number cos cos-value interval interval
undo priority-flow-control deadlock slot slot-number cos [ cos-value ]
未配置PFC死锁检测的周期。
interval interval:PFC死锁检测周期,取值范围为1~15。
PFC死锁检测功能可以按周期检测携带指定CoS值的报文是否发生死锁。检测周期由interval interval和PFC死锁检测定时器的精度共同决定。
指定的CoS值必须在priority-flow-control no-drop dot1p命令配置的802.1p优先级内。不同的CoS值对应不同的802.1p优先级,可以通过display qos map-table dot1p-lp命令查看。
对于不同CoS值可以配置相同的检测周期。
# 配置CoS值为7的PFC死锁检测周期为5。
[Sysname] priority-flow-control deadlock slot 1 cos 7 interval 5
priority-flow-control deadlock enable命令用来开启PFC死锁检测功能。
undo priority-flow-control deadlock enable命令用来关闭PFC死锁检测功能。
仅R3608及以上版本支持本命令。
PFC死锁检测功能处于关闭状态。
以太网接口视图
开启指定802.1p优先级的PFC功能后(通过priority-flow-control和priority-flow-control no-drop dot1p命令配置),当指定优先级的报文形成环路时,会导致数据缓冲区内报文无法转发,此时设备进入PFC死锁状态。
通过配置本命令,可以定期检测设备是否处于PFC死锁状态,并解除PFC死锁状态。
# 在Ten-GigabitEthernet1/0/1下开启PFC死锁检测功能。
[Sysname-Ten-GigabitEthernet1/0/1] priority-flow-control deadlock enable
priority-flow-control deadlock precision命令用来配置PFC死锁检测定时器的精度。
undo priority-flow-control deadlock precision命令用来恢复缺省情况。
仅R3608及以上版本支持本命令。
priority-flow-control deadlock slot slot-number precision { high | low | normal }
undo priority-flow-control deadlock slot slot-number precision
PFC死锁检测定时器的精度为普通精度。
high:表示使用高精度的PFC死锁检测定时器,所代表的时间为1秒。
low:表示使用低精度的PFC死锁检测定时器,所代表的时间为3秒。
normal:表示使用普通精度的PFC死锁检测定时器,所代表的时间为2秒。
使用本命令可调整PFC死锁检测定时器的精度,从而控制PFC死锁检测时间。
# 配置PFC死锁检测定时器精度为高精度。
[Sysname] priority-flow-control deadlock slot 1 precision high
priority-flow-control deadlock recover命令用来手工恢复PFC死锁检测功能。
仅R3608及以上版本支持本命令。
以太网接口视图
在配置本命令前,需执行priority-flow-control deadlock recover-mode命令配置PFC死锁检测功能的恢复方式。
当配置了手工恢复方式,设备能解除死锁状态,但同时死锁检测功能和PFC功能会暂时失效,需要手工执行本命令来恢复PFC死锁检测功能。恢复PFC死锁检测功能的同时可以让PFC功能继续生效。
# 在Ten-GigabitEthernet1/0/1下恢复PFC死锁检测功能。
[Sysname-Ten-GigabitEthernet1/0/1] priority-flow-control deadlock recover
· priority-flow-control deadlock recover-mode
priority-flow-control deadlock recover-mode命令用来配置PFC死锁检测功能的恢复方式。
undo priority-flow-control deadlock recover-mode命令用来恢复缺省情况。
仅R3608及以上版本支持本命令。
priority-flow-control deadlock recover-mode { auto | manual }
PFC死锁检测功能恢复方式为自动恢复方式。
以太网接口视图
auto:配置PFC死锁检测功能的恢复方式为自动恢复。
manual:配置PFC死锁检测功能的恢复方式为手工恢复。
当设备检测到PFC死锁状态后,设备自动恢复时会在延迟周期结束后解除PFC死锁状态,恢复PFC功能和PFC死锁检测功能。在PFC死锁检测自动恢复的延迟周期内,设备将关闭PFC功能和PFC死锁检测功能,以便报文能够正常转发。PFC死锁状态解除后,用户可采用自动或手工方式来恢复PFC死锁检测功能。恢复PFC死锁检测功能会让PFC功能继续生效。所以,通常情况下,使用自动恢复方式即可。当报文环路无法消除,设备频繁处于PFC死锁状态时,用户可以使用手工恢复方式,并尽快排除故障,再执行priority-flow-control deadlock recover命令,恢复PFC死锁检测功能和PFC功能。
# 在Ten-GigabitEthernet1/0/1下配置PFC死锁检测功能恢复方式为手工恢复。
[Sysname-Ten-GigabitEthernet1/0/1] priority-flow-control deadlock recover-mode manual
priority-flow-control deadlock threshold命令用来配置在指定周期内发生PFC死锁的上限次数。
undo priority-flow-control deadlock threshold命令用来恢复缺省情况。
仅R3608及以上版本支持本命令。
priority-flow-control deadlock threshold slot slot-number cos cos-value period period count count
undo priority-flow-control deadlock threshold slot slot-number cos [ cos-value ]
未配置指定周期内发生PFC死锁的上限次数。
period period:发生PFC死锁次数的检测周期,取值范围为1~60,单位为秒。
count count:指定周期内发生PFC死锁的上限次数,取值范围为1~500,单位为次数。
当配置该命令后,在指定周期内端口发生PFC死锁的次数达到配置值时,设备将关闭对应端口对应优先级的PFC功能,此时用户需要排除故障手工执行undo priority-flow-control deadlock threshold命令恢复对应端口的PFC功能。
本命令配置的发生PFC死锁次数的检测周期需要大于priority-flow-control deadlock cos命令配置的PFC死锁检测周期,以便确认设备是否频繁处于PFC死锁状态。
# 配置5秒周期内发生PFC死锁的上限次数为100。
[Sysname] priority-flow-control deadlock threshold slot 1 cos 7 period 5 count 100
priority-flow-control early-warning inpps命令用来配置入方向PFC报文的预警门限。
undo priority-flow-control early-warning inpps命令用来删除入方向PFC报文的预警门限。
priority-flow-control early-warning dot1p dot1p-list inpps pps-value
undo priority-flow-control early-warning [ dot1p dot1p-list ] inpps
未配置入方向PFC报文的预警门限。
以太网接口视图
dot1p dot1p-list:802.1p优先级(dot1p优先级)列表,例如:1,3-5。(表示数值区间时使用连字符“-”,数值之间用英文格式的逗号“,”分隔,最多可配置16个字符)
inpps pps-value:指定接口每秒接收的PFC帧数量,取值范围为1~159783010,单位为pps(packets per second,每秒转发的报文数)。
用户可根据实际组网情况,配置接口入方向PFC报文的预警门限。预警门限用于PFC报文传输速率处于正常范围内,但需要提醒用户提前关注的情况。
当接口接收PFC报文的速率达到预警门限时,系统会生成Trap和日志信息来提醒用户,以提前发现网络中的一些异常问题。例如:
· 对端设备网卡故障,不停地持续高速发送PFC帧,可以配置入方向预警门限进行监控。
· 本设备故障后不停发送PFC帧,可以配置出方向预警门限进行监控。
· 如果有双向监控需求的,可以在入和出方向都配置预警门限进行监控。
仅当PFC功能处于开启状态时,才会统计该接口接收的PFC帧数量,本命令配置的预警门限才能生效。
# 配置入方向802.1p优先级为7的PFC报文的预警门限为80pps。
[Sysname-Ten-GigabitEthernet1/0/1] priority-flow-control early-warning dot1p 7 inpps 80
priority-flow-control early-warning outpps命令用来配置出方向PFC报文的预警门限。
undo priority-flow-control early-warning outpps命令用来删除出方向PFC报文的预警门限。
priority-flow-control early-warning dot1p dot1p-list outpps pps-value
undo priority-flow-control early-warning [ dot1p dot1p-list ] outpps
未配置出方向PFC报文的预警门限。
以太网接口视图
outpps pps-value:指定接口每秒发送PFC帧数量,取值范围为1~159783010,单位为pps(packets per second,每秒转发的报文数)。
用户可根据实际组网情况,配置接口出方向PFC报文的预警门限。预警门限用于PFC报文传输速率处于正常范围内,但需要提醒用户提前关注的情况。
当接口发送PFC报文的速率达到预警门限时,系统会生成Trap和日志信息来提醒用户,以提前发现网络中的一些异常问题。例如:
仅当PFC功能处于开启状态时,才会统计该接口发送的PFC帧数量,本命令配置的预警门限才能生效。
# 配置出方向802.1p优先级为1的PFC报文的预警门限为50pps。
[Sysname-Ten-GigabitEthernet1/0/1] priority-flow-control early-warning dot1p 1 outpps 50
priority-flow-control no-drop dot1p命令用来开启指定802.1p优先级的PFC功能。
undo priority-flow-control no-drop dot1p命令用来关闭指定802.1p优先级的PFC功能。
所有802.1p优先级的PFC功能都处于关闭状态。
以太网接口视图
如果本端和对端设备的PFC功能处于使能状态,并配置了本命令,则当本端收到的802.1p优先级在dot1p-list范围内的报文发生拥塞时,会通知对端设备暂时停止向本端发送对应优先级的报文;拥塞解除后,再通知对端继续发送对应优先级的报文。从而保证本设备在转发802.1p优先级在dot1p-list范围内的报文时不丢包。有关802.1p优先级的介绍,请参见“ACL和QoS配置指导”中的“QoS”。
本命令和flow-control、flow-control receive enable互斥。
# 在以太网接口Ten-GigabitEthernet1/0/1上配置PFC功能的开启模式为自动协商模式,并开启802.1p优先级5的PFC功能。
[Sysname-Ten-GigabitEthernet1/0/1] priority-flow-control auto
[Sysname-Ten-GigabitEthernet1/0/1] priority-flow-control no-drop dot1p 5
· flow-control
· flow-control receive enable
· priority-flow-control no-drop dot1p (System view)
priority-flow-control no-drop dot1p命令用来开启所有接口下指定802.1p优先级的PFC功能。
undo priority-flow-control no-drop dot1p命令用来关闭所有接口下指定802.1p优先级的PFC功能。
所有接口下802.1p优先级的PFC功能都处于关闭状态。
# 开启所有接口802.1p优先级5的PFC功能。
[Sysname] priority-flow-control no-drop dot1p 5
· priority-flow-control no-drop dot1p (Ethernet interface view)
reset counters interface命令用来清除接口的统计信息。
reset counters interface [ interface-type [ interface-number | interface-number.subnumber ] ]
interface-number.subnumber:指定子接口。其中interface-number为主接口编号;subnumber为子接口编号,取值范围为1~4094。
如果不指定interface-type和interface-number,则清除所有接口的统计信息;
如果指定interface-type而不指定interface-number,则清除所有该类型接口的统计信息。
# 清除以太网接口Ten-GigabitEthernet1/0/1的统计信息。
<Sysname> reset counters interface ten-gigabitethernet 1/0/1
· display interface
· display counters interface
· display counters rate interface
reset ethernet statistics命令用来清除以太网软件模块收发报文的统计信息。
reset ethernet statistics [ slot slot-number ]
# 清除指定slot上的以太网软件模块收发报文的统计信息。
<Sysname> reset ethernet statistics slot 1
· display ethernet statistics
reset packet-drop interface命令用来清除接口丢弃报文的统计信息。
reset packet-drop interface [ interface-type [ interface-number ] ]
interface-type:清除指定类型接口丢弃的报文的信息。不指定该参数时,清除所有接口丢弃的报文的信息。
interface-number:清除指定编号接口丢弃的报文的信息。不指定该参数时,清除该类型所有接口丢弃的报文的信息。
# 清除以太网接口Ten-GigabitEthernet1/0/1丢弃报文的统计信息。
<Sysname> reset packet-drop interface ten-gigabitethernet 1/0/1
# 清除所有接口丢弃报文的统计信息。
· display packet-drop
shutdown命令用来关闭以太网接口/子接口。
undo shutdown命令用来打开以太网接口/子接口。
shutdown
以太网接口/子接口处于关闭状态。
以太网接口视图
以太网子接口视图
执行本命令会导致使用该接口建立的链路中断,不能通信,请谨慎使用。
在某些特殊情况下(例如修改接口的工作参数),接口相关配置不能立即生效,需要关闭再打开接口后,才能生效。
# 关闭以太网接口Ten-GigabitEthernet1/0/1后打开该接口。
[Sysname-Ten-GigabitEthernet1/0/1] shutdown
[Sysname-Ten-GigabitEthernet1/0/1] undo shutdown
# 关闭以太网子接口Ten-GigabitEthernet1/0/1.1后打开该接口。
[Sysname] interface ten-gigabitethernet 1/0/1.1
[Sysname-Ten-GigabitEthernet1/0/1.1] shutdown
[Sysname-Ten-GigabitEthernet1/0/1.1] undo shutdown
snmp-agent trap enable ifmonitor命令用来开启接口告警功能。
undo snmp-agent trap enable ifmonitor命令用来关闭接口告警功能。
仅R3608及以上版本支持本命令。
snmp-agent trap enable ifmonitor [ crc-error | giant | input-error | input-usage | output-error | output-usage | runt | rx-pause | sdh-b1-error | sdh-b2-error | sdh-error | tx-pause ] *
undo snmp-agent trap enable ifmonitor [ crc-error | input-error | input-usage | output-error | output-usage | rx-pause | sdh-b1-error | sdh-b2-error | sdh-error | tx-pause ] *
接口告警功能处于开启状态。
crc-error:开启接口CRC错误报文告警功能。
giant:开启接口超大帧告警功能。
input-error:开启接口入方向错误报文告警功能。
input-usage:开启接口入方向宽带利用率告警功能。
output-error:开启接口出方向错误报文告警功能。
output-usage:开启接口出方向宽带利用率告警功能。
runt:开启接口超小帧告警功能。
rx-pause:开启接口接收PAUSE帧告警功能。
sdh-b1-error:开启接口SDH-B1错误报文告警功能。
sdh-b2-error:开启接口SDH-B2错误报文告警功能。
sdh-error:开启接口SDH错误报文告警功能。
tx-pause:开启接口发送PAUSE帧告警功能。
# 开启接口CRC错误报文告警功能。
[Sysname] snmp-agent trap enable ifmonitor crc-error
speed命令用来设置以太网接口的速率。
undo speed命令用来恢复缺省情况。
speed { 10 | 100 | 1000 | 10000 | 40000 | 100000 | auto }
undo speed
以太网接口的速率处于自协商模式。
以太网接口视图
10:表示接口速率为10Mbps。
100:表示接口速率为100Mbps。
1000:表示接口速率为1000Mbps。
10000:表示接口速率为10000Mbps。
40000:表示接口速率为40000Mbps。
100000:表示接口速率为100000Mbps。
auto:表示接口速率处于自协商状态。
对于S6890-44HF交换机,接口编号为37~40的10GE接口不支持安装1G光模块。
对于以太网电口来说,使用speed命令设置端口速率,目的是使其与对端进行速率匹配。不同类型的电口支持配置的参数不同,具体情况请在相关接口视图下执行speed ?命令查看。如果配置指定速率时设备未提示操作失败,则表示当前电口支持该速率。否则,当前电口不支持该速率。
对于光口来说,使用speed命令设置端口速率,目的是使其与可插拔光模块进行速率匹配。不同类型的光口支持配置的参数不同,具体情况请在相关接口视图下执行speed ?命令查看。如果配置指定速率时设备未提示操作失败,则表示当前光口支持该速率。否则,当前光口不支持该速率。同时需要根据所选用光模块类型,在光口下配置匹配的速率,以便正常使用光模块。如果光口所配置的速率光模块无法支持,则光模块无法使用。例如SFP+口插入SFP千兆光模块时配置speed 10000,或SFP+口插入万兆光模块时配置speed 1000,光模块都无法使用。
# 将以太网接口Ten-GigabitEthernet1/0/1的速率设置为自协商获得。
[Sysname-Ten-GigabitEthernet1/0/1] speed auto
unicast-suppression命令用来开启端口未知单播风暴抑制功能,并设置未知单播风暴抑制阈值。
undo unicast-suppression命令用来关闭端口未知单播风暴抑制功能。
所有接口不对未知单播流量进行抑制。
以太网接口视图
ratio:指定以太网接口最大未知单播流量占该接口带宽的百分比。取值范围为0~100。数值越小,则允许通过的未知单播流量也越小。
pps max-pps:指定以太网接口每秒最多允许通过的未知单播报文数,取值范围为0~1.4881×接口带宽。
kbps max-kbps:指定以太网接口每秒最多允许通过的未知单播流量,单位为kbps,取值范围为0~接口带宽。
本命令设置的是接口允许通过的最大未知单播报文流量。当接口上的未知单播流量超过用户设置的值后,系统将丢弃超出未知单播流量限制的报文,从而使接口未知单播流量所占的比例降低到限定的范围,保证网络业务的正常运行。
执行unicast-suppression或storm-constrain命令都能开启端口的未知单播风暴抑制功能,storm-constrain命令通过软件对未知单播报文进行抑制,对设备性能有一定影响,unicast-suppression通过芯片物理上对未知单播报文进行抑制,相对storm-constrain来说,对设备性能影响较小。请不要同时配置unicast-suppression和storm-constrain命令,以免配置冲突,导致抑制效果不确定。
当风暴抑制阈值配置为kbps时,若配置值小于64,则实际生效的数值为64;若配置值大于64但不是64的整数倍,则实际生效的数值为大于且最接近于配置值的64的整数倍。请注意查看设备的提示信息。
# 在以太网接口Ten-GigabitEthernet1/0/1上,每秒最多允许10000kbps未知单播报文通过,对超出该范围的未知单播报文进行抑制。
[Sysname-Ten-GigabitEthernet1/0/1] unicast-suppression kbps 10000
The actual value is 10048 on port Ten-GigabitEthernet1/0/1 currently.
以上信息表示:用户配置的值为10000kbps,因为芯片支持的步长为64,所以实际生效的值为10048kbps(64的157倍)。
· multicast-suppression
using hundredgige命令用来将从100GE接口拆分出来的10GE接口合并为一个100GE接口。
仅R3608及以上版本支持本命令。
using hundredgige
10GE拆分接口单独使用,不会合并。
10GE拆分接口视图
如果用户需要更大的带宽,可以将从100GE接口拆分出来的4个10GE接口合并为一个100GE接口使用。在任何一个10GE拆分接口下执行该命令均生效,无需在其它拆分接口上配置。
命令配置成功后,通过执行display interface brief命令就可以看到合并后的100GE接口。
# 将Ten-GigabitEthernet1/0/1:1~Ten-GigabitEthernet1/0/1:10接口合并。
[Sysname] interface ten-gigabitethernet 1/0/1:1
[Sysname-Ten-GigabitEthernet1/0/1:1]using hundredgige
The interfaces Ten-GigabitEthernet1/0/1:1 through Ten-GigabitEthernet1/0/1:10 will be deleted. Continue? [Y/N]:y
· using tengige
using tengige命令用来将一个高带宽的接口拆分成多个10GE接口。
仅R3608及以上版本支持本命令。
using tengige
高带宽的接口单独使用,不拆分。
100GE接口视图
为了提高端口密度,减少用户使用成本,增加组网灵活性,设备支持将一个高带宽的接口拆分成多个10GE接口使用。例如将100GE接口安装支持拆分的40GE光模块或线缆后,100GE接口HundredGigE1/0/1可以拆分成四个10GE接口Ten-GigabitEthernet1/0/1:1~Ten-GigabitEthernet1/0/1:4。
拆分出来的10GE接口除了接口编号方式外,支持的配置和特性均和普通10GE物理接口相同。
命令配置成功后,通过执行display interface brief命令就可以看到拆分后的10GE接口。
对于S6890系列交换机的100GE接口,拆分前接口下的队列为8个,对应的队列编号为0~7,拆分后各拆分接口下的队列为2个并且拆分后的接口不支持PFC相关功能。
# 将HundredGigE1/0/1接口拆分。
[Sysname-HundredGigE1/0/1] using tengige
The interface HundredGigE1/0/1 will be deleted. Continue? [Y/N]:y
· using hundredgige
display storm-constrain命令用来显示接口流量控制信息。
display storm-constrain [ broadcast | multicast | unicast ] [ interface interface-type interface-number ]
broadcast:只显示广播报文流量控制信息。
multicast:只显示组播报文流量控制信息。
unicast:只显示未知单播报文流量控制信息。
interface interface-type interface-number:显示指定接口的报文流量控制信息。interface-type interface-number指定接口类型和接口编号。不指定该参数时,显示所有接口报文的流量控制信息。
不指定broadcast、multicast和unicast参数时,则显示所有类型报文的流量控制信息。
# 显示系统当前所有接口的流量控制信息。
<Sysname> display storm-constrain
Abbreviation: BC - broadcast; MC - multicast; UC - unicast
FW - forwarding
Flow Statistic Interval: 5 (in seconds)
Port Type Lower Upper Unit CtrlMode Status Trap Log StateChanges
XGE1/0/1 MC 100 200 kbps shutdown shutdown off on 10
表1-10 display storm-constrain命令显示信息描述表
Flow Statistic Interval |
流量统计的时间间隔,单位为秒 |
Port |
接口名称缩写 |
Type |
进行流量阈值控制的报文类型: · BC:broadcast,表示广播报文 · MC:multicast,表示组播报文 · UC:unicast,表示未知单播报文 |
Lower |
用户配置的流量控制下限阈值或百分比 |
Upper |
用户配置的流量控制上限阈值或百分比 |
Unit |
用户配置的流量阀值的单位,为pps、kbps或百分比 |
CtrlMode |
用户配置的流量阈值超过上限的控制动作: · block表示阻塞方式 · shutdown表示关闭方式 · N/A表示未配置控制动作 |
Status |
接口报文转发状态,取值为: · FW表示该端口处于正常转发状态 · shutdown表示端口已被关闭 · block表示该端口对该类报文直接丢弃 |
Trap |
Trap信息输出开关: · on表示打开 · off表示关闭 |
Log |
Log信息输出开关: · on表示打开 · off表示关闭 |
StateChanges |
接口报文转发状态切换次数 当StateChanges达到65535次时,会自动跳转到0,重新计数 |
port up-mode命令用来强制开启光口。
undo port up-mode命令用来恢复缺省情况。
port up-mode
undo port up-mode
没有强制开启光口,光口的物理状态由光纤的物理状态决定。
以太网接口视图
强制开启光口后,不管实际的光纤链路是否连通,甚至没有插入光纤或光模块,光口的物理状态都会变为up。此时,只要光口上有一条光纤链路是连通的,就可以实现报文的单向转发,以达到节约传输链路的效果。
port up-mode、shutdown和loopback命令互斥,后配置的失败。
# 强制开启光口Ten-GigabitEthernet1/0/1。
[Sysname-Ten-GigabitEthernet1/0/1] port up-mode
storm-constrain命令用来开启端口流量阈值控制功能,并设置上限阈值与下限阈值。
undo storm-constrain命令用来关闭端口流量阈值控制功能。
storm-constrain { broadcast | multicast | unicast } { pps | kbps | ratio } upperlimit lowerlimit
undo storm-constrain { all | broadcast | multicast | unicast }
端口流量阈值控制功能处于关闭状态,即不对端口的报文流量进行抑制。
二层以太网接口视图
all:取消端口所有类型(未知单播、组播和广播)报文流量阈值配置。
broadcast:设置端口广播报文流量阈值。
multicast:设置端口组播报文流量阈值。
unicast:设置端口未知单播报文流量阈值。
pps:以包每秒为单位统计流量。
kbps:以千比特每秒为单位统计流量。
ratio:以每秒钟报文所占接口物理带宽的百分比来统计流量。
upperlimit:端口报文流量的上限阈值。当和pps一起使用时,该参数的取值范围为1~1.4881×接口带宽;当和kbps一起使用时,该参数的取值范围为1~接口带宽;当和ratio一起使用时,该参数的取值范围为为1~100。
lowerlimit:端口报文流量的下限阈值。当和pps一起使用时,该参数的取值范围为1~1.4881×接口带宽;当和kbps一起使用时,该参数的取值范围为1~接口带宽;当和ratio一起使用时,该参数的取值范围为为1~100。
执行本命令后,设备就会周期性地对接口收到的指定类型的报文进行统计,如果流量超过上限阈值,则采取一定的措施。其中,通过storm-constrain interval命令可以配置统计周期,通过storm-constrain control命令可以配置流量超过上限阈值时采取的控制方式。
执行storm-constrain与broadcast-suppression、multicast-suppression、unicast-suppression命令都能开启端口的风暴抑制功能。storm-constrain命令通过软件对报文流量进行抑制,对设备性能有一定影响,broadcast-suppression、multicast-suppression、unicast-suppression通过芯片物理上对报文流量进行抑制,相对storm-constrain来说,对设备性能影响较小。对于某种类型的报文流量,请不要同时配置这两种方式,以免配置冲突,导致抑制效果不确定。
配置时,upperlimit值必须大于lowerlimit值,建议不要配成相等值。
# 对Ten-GigabitEthernet1/0/1端口配置未知单播流量阈值,上限阈值为200pps、下限阈值为150pps。
[Sysname-Ten-GigabitEthernet1/0/1] storm-constrain unicast pps 200 150
# 对Ten-GigabitEthernet1/0/2端口配置广播流量阈值,上限阈值为2000kbps、下限阈值为1500kbps。
[Sysname-Ten-GigabitEthernet1/0/2] storm-constrain broadcast kbps 2000 1500
# 对Ten-GigabitEthernet1/0/3端口配置组播流量百分比阈值,上限为80%、下限为15%。
[Sysname] interface ten-gigabitethernet 1/0/3
[Sysname-Ten-GigabitEthernet1/0/3] storm-constrain multicast ratio 80 15
· storm-constrain control
· storm-constrain interval
storm-constrain control命令用来设置端口未知单播、组播或者广播流量超过上限阈值时采取的控制方式。
undo storm-constrain control命令用来恢复缺省情况。
不对端口流量进行控制。
二层以太网接口视图
block:block方式,即:当端口上未知单播、组播或广播报文中某类报文的流量大于其上限阈值时,端口将暂停转发该类报文(其它类型报文照常转发),端口处于阻塞状态,但仍会统计该类报文的流量。当该类报文的流量小于其下限阈值时,端口将自动恢复对此类报文的转发。
shutdown:shutdown方式,即:当端口上未知单播、组播或广播报文中某类报文的流量大于其上限阈值时,端口将被关闭,系统停止转发所有报文。当该类报文的流量小于其下限阈值时,端口状态不会自动恢复,此时可通过执行undo shutdown命令或取消端口上流量阈值的配置来恢复。
# 配置Ten-GigabitEthernet1/0/1端口,当流量超过上限阈值时,采用block方式控制。
[Sysname-Ten-GigabitEthernet1/0/1] storm-constrain control block
· storm-constrain
storm-constrain enable log命令用来配置端口流量大于上限阈值或者从超上限回落到小于下限阈值时输出Log信息。
undo storm-constrain enable log命令用来禁止端口流量大于上限阈值或者从超上限回落到小于下限阈值时输出Log信息。
二层以太网接口视图
# 当Ten-GigabitEthernet1/0/1端口流量大于上限阈值或者从超上限回落到小于下限阈值时输出Log信息。
[Sysname-Ten-GigabitEthernet1/0/1] storm-constrain enable log
storm-constrain enable trap命令用来配置端口流量大于上限阈值或者从超上限回落到小于下限阈值时输出Trap信息。
undo storm-constrain enable trap命令用来禁止端口流量大于上限阈值或者从超上限回落到小于下限阈值时输出Trap信息。
二层以太网接口视图
# 当Ten-GigabitEthernet1/0/1端口流量大于上限阈值或者从超上限回落到小于下限阈值时输出Trap信息。
[Sysname-Ten-GigabitEthernet1/0/1] storm-constrain enable trap
storm-constrain interval命令用来配置端口流量阈值控制模块流量统计的时间间隔。
undo storm-constrain interval命令用来恢复缺省情况。
storm-constrain interval interval
端口流量统计的时间间隔为10秒。
interval:端口流量统计的时间间隔,取值范围为1~300,单位为秒。为了保持网络状态的稳定,建议设置的时间间隔不低于10秒。
本命令设置的时间间隔专门为storm-constrain命令服务的,不同于flow-interval命令设置的时间间隔。虽然同样是统计端口流量,但是功能是分开的。
# 配置端口流量统计时间间隔为60秒。
[Sysname] storm-constrain interval 60
· storm-constrain
mac-address命令用来配置以太网接口的MAC地址。
undo mac-address命令用来恢复缺省情况。
mac-address mac-address
undo mac-address
未配置以太网接口的MAC地址。
以太网接口视图
mac-address:MAC地址,形式为H-H-H。
给子接口配置MAC地址时,请不要使用VRRP协议保留的MAC地址段。
# 配置三层以太网接口Ten-GigabitEthernet1/0/1的MAC地址为0001-0001-0001。
[Sysname-Ten-GigabitEthernet1/0/1] mac-address 1-1-1
mtu命令用来设置三层以太网接口/子接口的MTU值。
undo mtu命令用来恢复缺省情况。
mtu size [ spread ]
undo mtu [ spread ]
三层以太网接口/子接口的MTU值为1500字节。
三层以太网接口视图
三层以太网子接口视图
spread:批量修改子接口的MTU。子接口不支持指定本参数。
在当前接口配置的MTU值仅对CPU发送的报文生效,请合理配置网络中的MTU值,尽量避免报文分片。如果当前接口同时支持mtu和ip mtu命令,则设备会以ip mtu命令配置的接口发送IPv4报文的MTU值对报文进行分片,不会再按照mtu命令配置的MTU值对报文进行分片。有关ip mtu的详细介绍,请参见“三层技术-IP业务命令参考”中的“IP性能优化”。
在主接口视图下执行mtu size命令仅对主接口生效,在子接口视图下配置本命令仅对该子接口生效。
在主接口视图下执行mtu size spread命令可同时修改主接口和其下所有子接口的MTU,但子接口视图下单独配置的MTU值优先生效。
# 设置三层以太网接口Ten-GigabitEthernet1/0/1的最大传输单元为1430字节。
[Sysname-Ten-GigabitEthernet1/0/1] mtu 1430
# 设置三层以太网子接口Ten-GigabitEthernet1/0/1.1的最大传输单元为1430字节。
[Sysname-Ten-GigabitEthernet1/0/1.1] mtu 1430
# 设置三层以太网接口Ten-GigabitEthernet1/0/1的MTU值为1430字节,并同步修改子接口的MTU值。
[Sysname-Ten-GigabitEthernet1/0/1] mtu 1430 spread
This operation may take a long time to modify the MTU of subinterfaces on this interface. Continue? [Y/N]:y
traffic-statistic enable命令用来开启以太网子接口的报文统计功能。
undo traffic-statistic enable命令用来关闭以太网子接口的报文统计功能。
以太网子接口的报文统计功能处于关闭状态。
三层以太网子接口视图
配置本命令后,可以通过display interface命令的Input和Output字段或者display counters命令查看以太网子接口的统计信息。
# 开启三层以太网子接口Ten-GigabitEthernet1/0/1.1的报文统计功能。
[Sysname-Ten-GigabitEthernet1/0/1.1] traffic-statistic enable
· display counters
· display interface
