06-IPv6组播路由与转发命令
本章节下载: 06-IPv6组播路由与转发命令 (286.25 KB)
1.1.1 display ipv6 mrib interface
1.1.2 display ipv6 multicast boundary
1.1.3 display ipv6 multicast fast-forwarding cache
1.1.4 display ipv6 multicast forwarding df-info
1.1.5 display ipv6 multicast forwarding event
1.1.6 display ipv6 multicast forwarding-table
1.1.7 display ipv6 multicast forwarding-table df-list
1.1.8 display ipv6 multicast routing-table
1.1.9 display ipv6 multicast rpf-info
1.1.10 ipv6 multicast boundary
1.1.11 ipv6 multicast forwarding supervlan community
1.1.12 ipv6 multicast forwarding-table cache-unknown per-entry
1.1.13 ipv6 multicast forwarding-table cache-unknown total
1.1.15 ipv6 multicast rpf-fail-pkt bridging
1.1.16 ipv6 multicast rpf-fail-pkt flooding
1.1.17 ipv6 multicast rpf-fail-pkt trap-to-cpu
1.1.18 load-splitting (IPv6 MRIB view)
1.1.19 longest-match (IPv6 MRIB view)
1.1.20 reset ipv6 multicast fast-forwarding cache
1.1.21 reset ipv6 multicast forwarding event
1.1.22 reset ipv6 multicast forwarding-table
1.1.23 reset ipv6 multicast routing-table
display ipv6 mrib interface命令用来显示IPv6 MRIB(Multicast Routing Information Base,组播路由信息库)维护的接口信息。
display ipv6 mrib [ vpn-instance vpn-instance-name ] interface [ interface-type interface-number ]
vpn-instance vpn-instance-name:显示指定VPN实例的信息,vpn-instance-name表示MPLS L3VPN的VPN实例名称,为1~31个字符的字符串,区分大小写。如果未指定本参数,将显示公网实例的信息。
interface-type interface-number:显示指定接口上IPv6 MRIB维护的接口信息。如果未指定本参数,将显示所有接口上IPv6 MRIB维护的接口信息。
# 显示公网实例接口上IPv6 MRIB维护的接口信息。
<Sysname> display ipv6 mrib interface
Interface: GigabitEthernet1/0
Index: 0x00004444
Current state: up
MTU: 1500
Type: BROADCAST
Protocol: PIM-DM
PIM protocol state: Enabled
Address list:
1. Local address : FE80:7:11::1/10
Remote address: ::
Reference : 1
State : NORMAL
表1-1 display ipv6 mrib interface命令显示信息描述表
接口的名称 |
Index |
接口的索引号 |
Current state |
接口的状态,包括up和down |
MTU |
MTU(Maximum Transmission Unit,最大传输单元)值 |
Type |
接口的类型,包括: · BROADCAST:表示广播链路接口 · P2P:表示P2P接口 · LOOP:表示LoopBack接口 · REGISTER:表示注册接口 · NBMA:表示NBMA接口 · MTUNNEL:表示组播隧道接口 如果接口为NULL0接口,则该字段显示为空 |
Protocol |
接口的协议类型标记,包括PIM-DM、PIM-SM、MLD和PROXY |
PIM protocol state |
IPv6 PIM协议的使能状态,包括: · Enabled:表示使能 · Disabled:表示关闭 |
Address list |
接口地址列表 |
Local address |
本端的地址 |
Remote address |
远端的地址(仅Vlink类型接口有效) |
Reference |
地址被引用的次数 |
State |
接口地址的状态,包括NORMAL和DEL |
display ipv6 multicast boundary命令用来显示IPv6组播边界的信息。
display ipv6 multicast [ vpn-instance vpn-instance-name ] boundary { group [ ipv6-group-address [ prefix-length ] ] | scope [ scope-id ] } [ interface interface-type interface-number ]
group:显示IPv6组播组的组播边界信息。
ipv6-group-address:指定IPv6组播组的地址,取值范围为FFxy::/16,其中x和y均代表0~F的任意一个十六进制数。如果未指定本参数,将显示所有IPv6组播组的IPv6组播边界信息。
prefix-length:指定IPv6组播组地址的前缀长度,取值范围为8~128,缺省值为128。
scope:显示IPv6管理域的组播边界信息。
scope-id:指定IPv6管理域的编号,IPv6管理域为IPv6组播组地址中的scope字段,取值范围为3~15。如果未指定本参数,将显示所有IPv6管理域的IPv6组播边界信息。
interface interface-type interface-number:显示指定接口上的IPv6组播边界信息,interface-type interface-number表示接口类型和接口编号。如果未指定本参数,将显示所有接口上的IPv6组播边界信息。
# 显示公网实例所有接口上所有IPv6组播组的IPv6组播边界信息。
<Sysname> display ipv6 multicast boundary group
Boundary Interface
FF1E::/64 GE1/0
# 显示公网实例所有接口上所有IPv6管理域的IPv6组播边界信息。
<Sysname> display ipv6 multicast boundary scope
Boundary Interface
3 GigabitEthernet1/0
表1-2 display ipv6 multicast boundary命令显示信息描述表
Boundary |
表示IPv6组播边界对应的IPv6组播组或IPv6管理域 |
表示IPv6组播边界对应的接口 |
· ipv6 multicast boundary
display ipv6 multicast fast-forwarding cache命令用来显示IPv6组播快速转发表项信息。
(独立运行模式)
display ipv6 multicast [ vpn-instance vpn-instance-name ] fast-forwarding cache [ ipv6-source-address | ipv6-group-address ] *
display ipv6 multicast [ vpn-instance vpn-instance-name ] fast-forwarding cache [ ipv6-source-address | ipv6-group-address ] * [ slot slot-number ]
ipv6-source-address:IPv6组播源地址,显示包含指定IPv6组播源的IPv6组播快速转发项。
ipv6-group-address:IPv6组播组地址,显示指定IPv6组播组的IPv6组播快速转发项,取值范围为FFxy::/16(不包括FFx1::/16 和 FFx2::/1),其中x和y均代表0~F的任意一个十六进制数。
slot slot-number:显示指定成员设备上的信息,slot-number表示设备在IRF中的成员编号。如果未指定本参数,将显示主设备上的信息。(IRF模式)
# 显示公网实例组播快转表项的信息。
<Sysname> display ipv6 multicast fast-forwarding cache
Total 1 entries, 1 matched
(FE1F:60::200, FF0E::1)
Status : Enabled
Source port: 2001 Destination port: 2002
Protocol : 2 Flag : 0x2
Incoming interface: GigabitEthernet3/0
List of 1 outgoing interfaces:
GigabitEthernet2/0
Status: Enabled Flag: 0x14
表1-3 display ipv6 multicast fast-forwarding cache命令显示信息描述表
Total 1 entries, 1 matched |
组播快速转发表中(S,G)表项的总数和匹配数 |
(FE1F:60::200, FF0E::1) |
表示IPv6组播路由表的(S,G)表项 |
Source port |
源端口号 |
Destination port |
目的端口号 |
Protocol |
协议号 |
Flag |
(S,G)表项的状态,通过将不同的比特位置位来表示不同的状态 · 0x1:表示由板间透传的报文触发创建的表项 · 0x2:表示组播转发流程添加的表项 (S,G)表项出接口状态,通过将不同的比特位置位来表示不同的状态 · 0x1:表示由板间透传的报文触发创建的出接口 · 0x2:表示向已存在的快转表项增添的出接口 · 0x4:表示需要设置MAC地址 · 0x8:表示入VLAN口或者入Super VLAN口对应的出接口 · 0x10:表示出接口已经与会话建立关联关系 · 0x20:表示待删除的出接口 |
Status |
组播快转表项入cache和出cache的状态, 包括Enabled和Disabled |
Incoming interface |
表示(S,G)表项的入接口 |
List of 1 outgoing interfaces |
表示(S,G)表项的出接口列表 |
· reset ipv6 multicast fast-forwarding cache all
display ipv6 multicast forwarding df-info命令用来显示IPv6组播转发的DF信息。
(独立运行模式)
display ipv6 multicast [ vpn-instance vpn-instance-name ] forwarding df-info [ ipv6-rp-address ] [ verbose ]
display ipv6 multicast [ vpn-instance vpn-instance-name ] forwarding df-info [ ipv6-rp-address ] [ verbose ] [ slot slot-number ]
ipv6-rp-address:指定IPv6双向PIM的RP地址。
verbose:显示IPv6组播转发的DF详细信息。如果未指定本参数,将显示IPv6组播转发的DF概要信息。
在IPv6双向PIM域中,只有每个网段的DF才可以向组播组的RP转发组播数据. 有关DF的详细介绍, 请参见“IPv6 PIM配置指导”中的“IPv6 双向PIM” 。
# 显示ADVPN应用组网IPv6组播转发的DF概要信息。
<Sysname> display ipv6 multicast forwarding df-info
Total 1 RPs, 1 matched
00001. RP address: 2::2
Flags: 0x0
Uptime: 00:00:14
RPF interface: LoopBack0
List of 2 DF interfaces:
1: Tunnel2, FE80::1
2: Tunnel2, FE80::3
# 显示公网实例IPv6组播转发的DF概要信息。
00001. RP address: 7:11::1
Flags: 0x0
Uptime: 01:46:40
RPF interface: GigabitEthernet1/0
List of 1 DF interfaces:
1: GigabitEthernet2/0
# 显示公网实例IPv6组播转发的DF详细信息。
<Sysname> display ipv6 multicast forwarding df-info verbose
MID: 2, Flags: 0x0
Uptime: 00:03:53
Product information: 0x7a2f762f, 0x718fee9f, 0x4b82f137, 0x71c32184
Product information: 0xa567d6fc, 0xadeb03e3
Tunnel information: 0xdfb107d4, 0x7aa5d510
Product information: 0xa986152b, 0xb74a9a2f
Tunnel information: 0x297ca208, 0x76985b89
表1-4 display ipv6 multicast forwarding df-info命令显示信息描述表
Total 1 RPs, 1 matched |
RP的总数和匹配数 |
00001 |
RP表项的序号 |
RP address |
RP的地址 |
MID |
RP表项的标识,每个RP表项都有唯一的标识 |
Flags |
RP表项的状态,通过将不同的比特位置位来表示不同的状态: · 0x0:表示正常表项 · 0x4:表示表项下刷失败 · 0x8:表示有DF接口下刷失败 · 0x40:表示表项即将被删除 · 0x100:表示表项正在被删除 · 0x200:表示表项处于平滑状态 |
Uptime |
RP表项已存在的时间 |
Product information |
产品信息 |
Tunnel information |
隧道接口信息 |
RPF interface |
到达RP的RPF接口 |
List of 1 DF interfaces |
DF接口列表 |
Tunnel2, FE80::1 |
ADVPN隧道接口以及远端IPv6 link-local地址 |
display ipv6 multicast forwarding event命令用来显示IPv6组播转发的事件统计信息。
(独立运行模式)
display ipv6 multicast [ vpn-instance vpn-instance-name ] forwarding event
display ipv6 multicast [ vpn-instance vpn-instance-name ] forwarding event [ slot slot-number ]
# 显示公网实例IPv6组播转发的事件统计信息。
<Sysname> display ipv6 multicast forwarding event
Total active events sent: 0
Total inactive events sent: 0
Total NoCache events sent: 2
Total NoCache events dropped: 0
Total WrongIF events sent: 0
Total WrongIF events dropped: 0
Total SPT switch events sent: 0
NoCache rate limit: 1024 packets/s
WrongIF rate limit: 1 packets/10s
Total timer of register suppress timeout: 0
表1-5 display ipv6 multicast forwarding event命令显示信息描述表
Total active events sent |
表项活跃事件的发送次数 |
Total inactive events sent |
表项不活跃事件的发送次数 |
Total NoCache events sent |
NoCache事件的发送次数 |
Total NoCache events dropped |
NoCache事件的丢弃次数 |
Total WrongIF events sent |
WrongIF事件的发送次数 |
Total WrongIF events dropped |
WrongIF事件的丢弃次数 |
Total SPT switch events sent |
SPT切换事件的发送次数 |
NoCache rate limit |
NoCache事件的发送限速,单位为报文/秒 |
WrongIF rate limit |
WrongIF事件的发送限速,单位为报文/10秒 |
Total timer of register suppress timeout |
注册抑制超时的总次数 |
· reset ipv6 multicast forwarding event
display ipv6 multicast forwarding-table命令用来显示IPv6组播转发表的信息。
(独立运行模式)
display ipv6 multicast [ vpn-instance vpn-instance-name ] forwarding-table [ ipv6-source-address [ prefix-length ] | ipv6-group-address [ prefix-length ] | incoming-interface interface-type interface-number | outgoing-interface { exclude | include | match } interface-type interface-number | statistics ] *
display ipv6 multicast [ vpn-instance vpn-instance-name ] forwarding-table [ ipv6-source-address [ prefix-length ] | ipv6-group-address [ prefix-length ] | incoming-interface interface-type interface-number | outgoing-interface { exclude | include | match } interface-type interface-number | slot slot-number | statistics ] *
ipv6-source-address:IPv6组播源地址,显示包含指定IPv6组播源的IPv6组播转发项。
ipv6-group-address:IPv6组播组地址,显示指定IPv6组播组的IPv6组播转发项,取值范围为FFxy::/16,其中x和y均表示0~F的任意一个十六进制数。
prefix-length:指定IPv6组播组或IPv6组播源地址的前缀长度。对于IPv6组播组地址,其取值范围为8~128,缺省值为128;对于IPv6组播源地址,其取值范围为0~128,缺省值为128。
incoming-interface:显示指定入接口的IPv6组播转发项。
interface-type interface-number:显示指定接口类型和接口编号的入接口的IPv6组播转发项。
outgoing-interface:显示指定出接口的IPv6组播转发项。
exclude:显示出接口列表中不包含指定接口的IPv6组播转发项。
include:显示出接口列表中包含指定接口的IPv6组播转发项。
match:显示出接口列表中包含且仅包含指定接口的IPv6组播转发项。
slot slot-number:显示指定成员设备上的信息,slot-number表示设备在IRF中的成员编号。指定的成员设备若为IPv6组播流量的出口成员设备,则统计信息显示为0。如果未指定本参数,将显示主设备上的信息。(IRF模式)
statistics:显示IPv6组播转发表的统计信息。
# 显示ADVPN应用组网IPv6组播转发表的信息。
<Sysname> display ipv6 multicast forwarding-table
00001. (1::1, ff0e::1)
Flags: 0x0
Incoming interface: Tunnel1, FE80::20:11
1: Tunnel1, FE80::20:12
2: Tunnel1, FE80::20:13
Matched 19648 packets(20512512 bytes), Wrong If 0 packet
# 显示公网实例IPv6组播转发表的信息。
Flags: 0x0
Incoming interface: Vlan-interface10
Incoming sub-VLAN: VLAN 11
Outgoing sub-VLAN: VLAN 12
VLAN 13
1: Vlan-interface20
Sub-VLAN: VLAN 21
VLAN 22
Matched 19648 packets(20512512 bytes), Wrong If 0 packets
表1-6 display ipv6 multicast forwarding-table命令显示信息描述表
IPv6组播转发表中(S,G)表项的总数和匹配数 |
00001 |
表示(S,G)表项的序号 |
(1::1, ff0e::1) |
表示IPv6组播转发表的(S,G)表项 |
Flags |
(S,G)表项的状态,通过将不同的比特位置位来表示不同的状态: · 0x0:表示正常表项 · 0x1:表示表项处于Inactive状态 · 0x2:表示空转发表项 · 0x4:表示表项下刷失败 · 0x8:表示有出接口下刷失败 · 0x20:表示表项有注册出接口 · 0x40:表示表项即将被删除 · 0x80:表示表项处于注册抑制状态 · 0x100:表示表项正在被删除 · 0x200:表示表项处于平滑状态 · 0x400:表示表项中存在Super VLAN对应的VLAN接口 · 0x800:表示表项中存在到IPv6组播源地址的ND表项 · 0x4000000:表示表项由MLD代理下发创建 · 0x20000000:表示IPv6双向PIM的转发表项 |
Uptime |
表示(S,G)表项已存在时间 |
Timeout in |
表示(S,G)表项的超时剩余时间 |
表示(S,G)表项的入接口 |
Incoming sub-VLAN |
表示当(S,G)表项的入接口为Super VLAN对应的VLAN接口时,该Super VLAN的入Sub VLAN |
Outgoing sub-VLAN |
表示当(S,G)表项的入接口为Super VLAN对应的VLAN接口时,该Super VLAN的出Sub VLAN |
表示(S,G)表项的出接口列表 |
Sub-VLAN |
表示当(S,G)表项的出接口为Super VLAN对应的VLAN接口时,该Super VLAN的出Sub VLAN |
Tunnel1, FE80::20:12 |
Matched 19648 packets (20512512 bytes), Wrong If 0 packet |
(S,G)表项匹配的报文数量(字节数),发生入接口错误的报文个数 |
Forwarded 19648 packets (20512512 bytes) |
(S,G)表项已转发的IPv6组播报文数量(字节数) |
· reset ipv6 multicast forwarding-table
display ipv6 multicast forwarding-table df-list命令用来显示IPv6组播转发表的DF列表信息。
(独立运行模式)
display ipv6 multicast [ vpn-instance vpn-instance-name ] forwarding-table df-list [ ipv6-group-address ] [ verbose ]
display ipv6 multicast [ vpn-instance vpn-instance-name ] forwarding-table df-list [ ipv6-group-address ] [ verbose ] [ slot slot-number ]
ipv6-group-address:IPv6组播组地址,显示指定IPv6组播组的IPv6组播转发表的DF列表信息,取值范围为FFxy::/16(不包括FFx1::/16 和 FFx2::/1),其中x和y均表示0~F的任意一个十六进制数。
verbose:显示IPv6组播转发表的DF列表详细信息。如果未指定本参数,将显示IPv6组播转发表的DF列表概要信息。
# 显示公网实例IPv6组播转发表的DF列表概要信息。
<Sysname> display ipv6 multicast forwarding-table df-list
00001. (::, FF1E::1)
1: GigabitEthernet1/0
# 显示公网实例IPv6组播转发表的DF列表详细信息。
<Sysname> display ipv6 multicast forwarding-table df-list verbose
Product information: 0x347849f6, 0x14bd6837
Tunnel information: 0xc4857986, 0x128a9c8f
表1-7 display ipv6 multicast forwarding-table df-list命令显示信息描述表
表项总数和匹配数 |
00001 |
表项的序号 |
(::, FF1E::1) |
组播转发表的(*,G)表项 |
DF接口列表 |
产品信息 |
隧道接口信息 |
display ipv6 multicast routing-table命令用来显示IPv6组播路由表的信息。
display ipv6 multicast [ vpn-instance vpn-instance-name ] routing-table [ ipv6-source-address [ prefix-length ] | ipv6-group-address [ prefix-length ] | incoming-interface interface-type interface-number | outgoing-interface { exclude | include | match } interface-type interface-number ] *
ipv6-source-address:IPv6组播源地址,显示包含指定IPv6组播源的IPv6组播路由项。
ipv6-group-address:IPv6组播组地址,显示指定IPv6组播组的IPv6组播路由项,取值范围为FFxy::/16,其中x和y均代表0~F的任意一个十六进制数。
incoming-interface:显示指定入接口的IPv6组播路由项。
interface-type interface-number:显示指定接口类型和接口编号的入接口的IPv6组播路由项。
outgoing-interface:显示指定出接口的IPv6组播路由项。
exclude:显示出接口列表中不包含指定接口的IPv6组播路由项。
include:显示出接口列表中包含指定接口的IPv6组播路由项。
match:显示出接口列表中包含且仅包含指定接口的IPv6组播路由项。
IPv6组播路由表是进行IPv6组播数据转发的基础,通过查看该表可以了解(S,G)表项等的建立情况。
# 显示ADVPN应用组网IPv6组播路由表的信息。
<Sysname> display ipv6 multicast routing-table
Total 1 entries
00001. (2001::2, FFE3::101)
Uptime: 00:00:14
Upstream Interface: Tunnel1, FE80::20:11
List of 2 downstream interfaces
# 显示公网实例IPv6组播路由表的信息。
Total 1 entries
Uptime: 00:00:14
Upstream Interface: GigabitEthernet1/0
2: GigabitEthernet3/0
表1-8 display ipv6 multicast routing-table命令显示信息描述表
Total 1 entries |
IPv6组播路由表中(S,G)表项的总数 |
00001 |
表示(S,G)表项的序号 |
(2001::2, FFE3::101) |
Uptime |
表示(S,G)表项已经存在的时间 |
Upstream Interface |
表示(S,G)表项的上游接口,表示IPv6组播数据应该从此接口到达 |
List of 2 downstream interfaces |
下游接口列表,表示哪些接口需要进行组播转发 |
Tunnel11, FE80::20:12 |
· reset ipv6 multicast routing-table
display ipv6 multicast rpf-info命令用来显示IPv6组播源的RPF信息。
display ipv6 multicast [ vpn-instance vpn-instance-name ] rpf-info ipv6-source-address [ ipv6-group-address ]
ipv6-source-address:显示指定IPv6组播源的RPF信息。
ipv6-group-address:显示指定IPv6组播组的RPF信息,取值范围为FFxy::/16(但不包括下列地址: FFx1::/16、FFx2::/16),其中x和y均代表0~F的任意一个十六进制数。
# 显示公网IPv6组播源2001::101的全部RPF信息。
<Sysname> display ipv6 multicast rpf-info 2001::101
RPF information about source 2001::101:
RPF interface: GigabitEthernet1/0, RPF neighbor: FE80::A01:101:1
Referenced prefix/prefix length: 2001::/64
Referenced route type: igp
Load splitting rule: disable
Source AS: 0
C-multicast route target: 0x0000000000000000
表1-9 display ipv6 multicast rpf-info命令显示信息描述表
RPF information about source 2001::101 |
到IPv6组播源2001::101的RPF路径信息 |
RPF interface |
表示RPF接口名称 |
RPF neighbor |
表示RPF邻居的IPv6地址(链路本地地址) |
Referenced prefix/prefix length |
表示引用的路由及其前缀长度 |
Referenced route type |
表示引用的路由类型,可以是下列类型之一: · igp:IPv6单播路由(内部网关协议) · egp:IPv6单播路由(外部网关协议) · unicast (direct):IPv6单播路由(直连) · unicast:其它IPv6单播路由(如IPv6单播静态路由等) · mbgp:IPv6 MBGP路由 |
Route selection rule |
RPF路由选择规则,可以是根据路由协议的路由优先级进行选择,或者是按照目的地址对路由表进行最长匹配 |
Load splitting rule |
是否使能了负载分担规则 |
Source AS |
组播源所在PE的AS号 |
C-multicast route target |
C-multicast路由扩展团体属性 |
· display ipv6 multicast forwarding-table
· display ipv6 multicast routing-table
ipv6 multicast boundary命令用来配置IPv6组播转发边界。
undo ipv6 multicast boundary命令用来删除IPv6组播转发边界。
ipv6 multicast boundary { ipv6-group-address prefix-length | scope { scope-id | admin-local | global | organization-local | site-local } }
undo ipv6 multicast boundary { ipv6-group-address prefix-length | all | scope { scope-id | admin-local | global | organization-local | site-local } }
接口上不存在IPv6组播转发边界。
ipv6-group-address:指定IPv6组播组地址,取值范围为FFxy::/16,其中x和y均代表0~F的任意一个十六进制数。
prefix-length:指定IPv6组播组地址的前缀长度,取值范围为8~128。
all:删除该接口上配置所有IPv6组播转发边界。
scope-id:指定Scope字段的值,IPv6组播组地址中的scope字段表示IPv6管理域,取值范围为3~15。
admin-local:指定Scope字段为管理本地范围,对应的Scope值为4。
global:指定Scope字段为全局范围,对应的Scope值为14。
organization-local:指定Scope字段为机构本地范围,对应的Scope值为8。
site-local:指定Scope字段为站点本地范围,对应的Scope值为5。
IPv6组播转发边界为指定地址范围或Scope值的IPv6组播组划定了边界条件,如果IPv6组播报文的目的地址与边界条件匹配,就停止转发。
一个接口可以作为不同地址范围的IPv6组播组的转发边界,即允许在同一接口上多次执行本命令为不同地址范围的IPv6组播组设定转发边界;但一个接口只能作为特定Scope值的IPv6组播组的转发边界,若在同一接口上多次执行本命令为不同Scope值的IPv6组播组设定转发边界,则只有最后一次的配置生效。
执行本命令不需要使能IPv6组播路由。
假设A和B为不同地址范围的IPv6组播组的集合,且B是A的真子集:如果接口先配置为A的转发边界,再配置为B的转发边界,则该接口仍然为A的转发边界;如果接口先配置为B的转发边界,再配置为A的转发边界,则该接口将变为A的转发边界。
# 将接口GigabitEthernet1/0配置为地址范围为FF03::/16的IPv6组播组的转发边界。
[Sysname] interface gigabitethernet 1/0
[Sysname-GigabitEthernet1/0] ipv6 multicast boundary ff03:: 16
# 将接口GigabitEthernet1/0配置为Scope值为4的IPv6组播组的转发边界。
[Sysname-GigabitEthernet1/0] ipv6 multicast boundary scope 4
· display ipv6 multicast boundary
ipv6 multicast forwarding supervlan community命令用来配置IPv6组播数据在Super VLAN内的各Sub VLAN之间互通。
undo ipv6 multicast forwarding supervlan community命令用来恢复缺省情况。
IPv6组播数据在Super VLAN内的各Sub VLAN之间隔离。
VLAN接口视图
执行本命令后必须清除IPv6组播转发表中所有以该VLAN接口为入接口的转发项,否则本命令将不能生效。
利用reset ipv6 multicast forwarding-table命令来清除IPv6组播转发表中的表项。
# 配置IPv6组播数据在Super VLAN 2内的各Sub VLAN之间互通。
[Sysname-Vlan-interface2] ipv6 multicast forwarding supervlan community
ipv6 multicast forwarding-table cache-unknown per-entry命令用来设置对于同一个(S,G)表项,可缓存的最大未知IPv6组播数据报文数目。
undo ipv6 multicast forwarding-table cache-unknown per-entry命令用来恢复缺省情况。
ipv6 multicast forwarding-table cache-unknown per-entry per-entry-limit
对于同一个(S,G)表项,可缓存的最大未知IPv6组播数据报文数目为1。
per-entry-limit:对于同一个(S,G)表项,可缓存的最大未知IPv6组播数据报文数目,取值范围为0~256。当取值为0时,代表不可缓存未知IPv6组播数据报文。
# 设置对于同一个(S,G)表项,可缓存的最大未知IPv6组播数据报文数目为20。
[Sysname] ipv6 multicast forwarding-table cache-unknown per-entry 20
· ipv6 multicast forwarding-table cache-unknown total
ipv6 multicast forwarding-table cache-unknown total命令用来设置内存中可缓存的未知IPv6组播数据报文的最大数目。
undo multicast forwarding-table cache-unknown total命令用来恢复缺省情况。
ipv6 multicast forwarding-table cache-unknown total total-limit
undo ipv6 multicast forwarding-table cache-unknown total
内存中可缓存的未知IPv6组播数据报文的最大数目为1024。
total-limit:内存中可缓存的未知IPv6组播数据报文的最大数目,取值范围为0~65535。当取值为0时,代表不可缓存未知IPv6组播数据报文。
建议本命令配置的值要远远大于ipv6 multicast forwarding-table cache-unknown per-entry命令配置的值。
# 设置内存中可缓存的未知IPv6组播数据报文的最大数目为10000。
[Sysname] ipv6 multicast forwarding-table cache-unknown total 10000
· ipv6 multicast forwarding-table cache-unknown per-entry
ipv6 multicast routing命令用来使能IPv6组播路由,并进入IPv6 MRIB视图。
undo ipv6 multicast routing命令用来关闭IPv6组播路由。
ipv6 multicast routing [ vpn-instance vpn-instance-name ]
undo ipv6 multicast routing [ vpn-instance vpn-instance-name ]
IPv6组播路由处于关闭状态。
只有在公网实例或VPN实例中使能了IPv6组播路由,其它三层IPv6组播功能才能生效;没有使能IPv6组播路由前,设备不转发任何IPv6组播报文。
# 使能公网实例中的IPv6组播路由,并进入公网实例的IPv6 MRIB视图。
[Sysname] ipv6 multicast routing
[Sysname-mrib6]
# 使能VPN实例mvpn中的IPv6组播路由,并进入该VPN实例的IPv6 MRIB视图。
[Sysname] ipv6 multicast routing vpn-instance mvpn
[Sysname-mrib6-mvpn]
ipv6 multicast rpf-fail-pkt bridging命令用来配置在当前VLAN内组播RPF检查失败的IPv6组播数据报文。
undo ipv6 multicast rpf-fail-pkt bridging命令用来恢复缺省情况。
不在VLAN内组播RPF检查失败的IPv6组播数据报文。
VLAN接口视图
执行本命令时,需要注意:
· 执行本命令时,要先配置在所有VLAN内泛洪RPF检查失败的IPv6组播数据报文。
· 该VLAN内使能了MLD Snooping。
· 对应VLAN接口上配置有IPv6三层组播协议(MLD或IPv6 PIM)。
执行本命令后必须清除该VLAN内所有IPv6动态组播组的MLD Snooping转发表项,否则本命令将不能生效。
利用reset mld-snooping group来清除动态MLD Snooping转发表的信息。
执行本命令不需要使能IPv6组播路由。
# 配置在VLAN 2内组播RPF检查失败的IPv6组播数据报文。
[Sysname-Vlan-interface2] ipv6 multicast rpf-fail-pkt bridging
· ipv6 multicast rpf-fail-pkt flooding
· reset mld-snooping group(IP组播命令参考/MLD Snooping)
ipv6 multicast rpf-fail-pkt flooding命令用来配置在所有VLAN内泛洪RPF检查失败的IPv6组播数据报文。
undo ipv6 multicast rpf-fail-pkt flooding命令用来恢复缺省情况。
不在VLAN内泛洪RPF检查失败的IPv6组播数据报文。
执行本命令不需要使能IPv6组播路由。
执行本命令后必须清除IPv6组播转发表中的所有转发项,否则本命令将不能生效。
利用reset ipv6 multicast forwarding-table来清除IPv6组播转发表中的转发项。
# 配置在所有VLAN内泛洪RPF检查失败的IPv6组播数据报文。
[Sysname] ipv6 multicast rpf-fail-pkt flooding
ipv6 multicast rpf-fail-pkt trap-to-cpu命令用来配置把RPF检查失败的IPv6组播数据报文上送CPU处理。
undo ipv6 multicast rpf-fail-pkt trap-to-cpu命令用来恢复缺省情况。
不把RPF检查失败的IPv6组播数据报文上送CPU处理。
执行本命令不需要使能IPv6组播路由。
# 配置把RPF检查失败的IPv6组播数据报文上送CPU处理。
[Sysname] ipv6 multicast rpf-fail-pkt trap-to-cpu
load-splitting命令用来配置对IPv6组播流量进行负载分担。
undo load-splitting命令用来恢复缺省情况。
undo load-splitting
不对IPv6组播流量进行负载分担。
IPv6 MRIB视图
source:仅根据IPv6组播源对IPv6组播流量进行负载分担。
source-group:根据IPv6组播源组对IPv6组播流量进行负载分担。
本命令对IPv6双向PIM不生效。
# 在公网实例中配置仅根据IPv6组播源对IPv6组播流量进行负载分担。
[Sysname-mrib6] load-splitting source
longest-match命令用来配置按照最长匹配来选择RPF路由,即选择掩码最长的路由作为RPF路由。
undo longest-match命令用来恢复缺省情况。
longest-match
undo longest-match
选择路由优先级最高的路由作为RPF路由。
IPv6 MRIB视图
# 在公网实例中配置按照最长匹配原则选择RPF路由。
[Sysname-mrib6] longest-match
reset ipv6 multicast fast-forwarding cache命令用来清除IPv6组播快速转发表中的转发项。
(独立运行模式)
reset ipv6 multicast [ vpn-instance vpn-instance-name ] fast-forwarding cache { { ipv6-source-address | ipv6-group-address } * | all }
reset ipv6 multicast [ vpn-instance vpn-instance-name ] fast-forwarding cache { { ipv6-source-address | ipv6-group-address } * | all } [ slot slot-number ]
vpn-instance vpn-instance-name:清除指定VPN实例的信息,vpn-instance-name表示MPLS L3VPN的VPN实例名称,为1~31个字符的字符串,区分大小写。如果未指定本参数,将清除公网实例的信息。
ipv6-source-address:IPv6组播源地址,清除包含指定组播源的IPv6组播转发项。
ipv6-group-address:IPv6组播组地址,清除指定组播组的IPv6组播转发项,取值范围为FFxy::/16,其中x和y均表示0~F的任意一个十六进制数。
all:清除组播快速转发表中的所有组播转发项
#从公网实例IPv6组播快速转发表中清除所有组播转发表项。
<Sysname> reset ipv6 multicast fast-forwarding cache all
#从公网实例IPv6组播快速转发表中清除组播源组为(FE1F:20::2 ,FF0E::1)的转发表项。
<Sysname> reset ipv6 multicast fast-forwarding cache fe1f:20::2 ff0e::1
· display ipv6 multicast fast-forwarding cache
reset ipv6 multicast forwarding event命令用来清除IPv6组播转发的事件统计信息。
reset ipv6 multicast [ vpn-instance vpn-instance-name ] forwarding event
# 清除公网实例IPv6组播转发的事件统计信息。
<Sysname> reset ipv6 multicast forwarding event
· display ipv6 multicast forwarding event
reset ipv6 multicast forwarding-table命令用来清除IPv6组播转发表中的转发项。
reset ipv6 multicast [ vpn-instance vpn-instance-name ] forwarding-table { { ipv6-source-address [ prefix-length ] | ipv6-group-address [ prefix-length ] | incoming-interface { interface-type interface-number } } * | all }
ipv6-source-address:IPv6组播源地址,显示包含指定组播源的IPv6组播转发项。
ipv6-group-address:IPv6组播组地址,显示指定组播组的IPv6组播转发项,取值范围为FFxy::/16,其中x和y均表示0~F的任意一个十六进制数。
incoming-interface:清除指定入接口的IPv6组播转发项。
interface-type interface-number:清除指定接口类型和接口编号的入接口的IPv6组播转发项。
all:清除组播转发表中的所有IPv6组播转发项。
清除IPv6组播转发表中的转发项后,IPv6组播路由表中的相应表项也将随之被删除。
# 从公网实例IPv6组播转发表中清除组播组FF0E::1的相关转发表项。
<Sysname> reset ipv6 multicast forwarding-table ff0e::1
reset ipv6 multicast routing-table命令用来清除IPv6组播路由表中的路由项。
reset ipv6 multicast [ vpn-instance vpn-instance-name ] routing-table { { ipv6-source-address [ prefix-length ] | ipv6-group-address [ prefix-length ] | incoming-interface interface-type interface-number } * | all }
ipv6-source-address:IPv6组播源地址,清除包含指定IPv6组播源的IPv6组播路由项。
ipv6-group-address:IPv6组播组地址,清除指定IPv6组播组的IPv6组播路由项,取值范围为FFxy::/16,其中x和y均代表0~F的任意一个十六进制数。
incoming-interface:清除指定入接口的IPv6组播路由项。
interface-type interface-number:清除指定接口类型和接口编号的入接口的IPv6组播路由项。
all:清除IPv6组播路由表中的所有IPv6组播路由项。
清除IPv6组播路由表中的路由项后,IPv6组播转发表中的相应表项也将被随之删除。
# 从公网实例IPv6组播路由表中清除组播组FF03::101的相关路由项。
<Sysname> reset ipv6 multicast routing-table ff03::101
