06-系统维护命令
本章节下载: 06-系统维护命令 (118.28 KB)
ping检查网络是否连通,可以很好地帮助我们分析和判定网络故障。
Ping -I,-c,-I,-s,-t-vrf-WORD
缺省情况下,ping不带参数。
-I Set source address 带源IP ping
-c Stop after sending count ECHO_REQUEST packets 设置发包个数(1-10000)
-i Set the interval of every packet 探测数目(1-10)
-s Specifies the number of data bytes to be sent 所发送数据包的报文大小(64-65500)
-t Set the IP Time to Live 指定数据包探测条数(1-255)
-vrf Select VPN routing instance ping vrf里地址,需带vrf名称
WORD Ping destination address or hostname 直接ping 域名或者目的IP,使用默认参数
# 使用本机ip 访问114
host# ping -I 192.168.2.73 114.114.114.114
PING 114.114.114.114 (114.114.114.114) from 192.168.2.73 : 56(84) bytes of data.
seq ttl time(ms)
1 75 24.540
2 70 24.923
3 70 25.317
4 84 24.465
5 88 24.156
--- 114.114.114.114 ping statistics ---
5 packets transmitted, 5 received, 0% packet loss, time 4006ms
rtt min/avg/max/mdev = 24.156/24.680/25.317/0.413 msdisplay user-policy app-local-cache
# 设备ping一个报文到114
host# ping -c 1 114.114.114.114
PING 114.114.114.114 (114.114.114.114) 56(84) bytes of data.
seq ttl time(ms)
1 90 14.201
1 packets transmitted, 1 received, 0% packet loss, time 0ms
rtt min/avg/max/mdev = 14.201/14.201/14.201/0.000 ms
# 设备2秒ping一个报文到114
host# ping -i 2 114.114.114.114
seq ttl time(ms)
1 80 14.508
2 86 14.238
3 65 14.001
4 80 14.311
5 80 14.186
5 packets transmitted, 5 received, 0% packet loss, time 8009ms
rtt min/avg/max/mdev = 14.001/14.248/14.508/0.223 ms
# 设备ping一个1000字节报文到114
host# ping -s 1000 114.114.114.114
PING 114.114.114.114 (114.114.114.114) 1000(1028) bytes of data.
seq ttl time(ms)
1 54 14.805
2 54 14.931
3 54 14.417
4 54 14.766
5 54 14.727
5 packets transmitted, 5 received, 0% packet loss, time 4003ms
rtt min/avg/max/mdev = 14.417/14.729/14.931/0.186 ms
Traceroute用来追踪设备所经过的跳数
traceroute (-i imcp) (-s source address) (-u udp)name
缺省情况下,默认使用udp探测追踪路由。
#视图
-i Use ICMP ECHO instead of UDP datagrams icmp探测
-s Chooses an alternative source address 带源地址探测
-u Udp port detect udp探测
WORD Trace route to destination address or hostname 探测目标域名或者ip
需要设备网络连通。
# 带源地址探测到114的跳数
host# traceroute -s 192.168.2.73 114.114.114.114
traceroute to 114.114.114.114 (114.114.114.114) from 192.168.2.73, 30 hops max, 46 byte packets
1 192.168.2.1 (192.168.2.1) 3.225 ms 9.781 ms 9.923 ms
2 192.168.77.1 (192.168.77.1) 9.910 ms 9.897 ms 220.249.52.177 (220.249.52.177) 9.941 ms
3 165.165.202.1.static.bjtelecom.net (1.202.165.165) 19.803 ms 9.765 ms 9.934 ms
4 245.235.120.106.static.bjtelecom.net (106.120.235.245) 9.917 ms 9.816 ms 9.932 ms
5 bj141-135-162.bjtelecom.net (219.141.135.162) 9.925 ms 9.830 ms *
6 124.65.194.173 (124.65.194.173) 14.803 ms 202.97.85.6 (202.97.85.6) 39.923 ms 123.126.0.233 (123.126.0.233) 19.874 ms
7 218.2.182.30 (218.2.182.30) 39.897 ms 29.802 ms 39.934 ms
8 * 60.217.43.14 (60.217.43.14) 23.572 ms 19.821 ms
9 * * *
Traceroute WORD
tcpSyn命令用来探测目标开放的端口
Tcpsyn (-c Set packet count option ) (-w Set packet timeout option) hostname
#视图
-c Set packet count option 数据包计数选项(1.1000)默认3
-w Set packet timeout option 数据包超时选项(1-1000)默认1
HOSTNAME Destination domain 探测域名或者地址后面跟端口范围(0-65535)
配置探测目标
# tcp探测百度是否开放80端口
host# tcpsyn www.baidu.com 80
tcpsyn to 115.239.211.112:80
1 TCP ACK from 115.239.211.112:80
2 TCP ACK from 115.239.211.112:80
3 TCP ACK from 115.239.211.112:80!
