17-VXLAN命令参考
01-VXLAN命令
本章节下载: 01-VXLAN命令  (645.23 KB)
01-VXLAN命令
1 VXLAN
1.1 VXLAN基础配置命令
1.1.1 ac statistics enable
1.1.2 arp suppression enable
1.1.3 bandwidth (Service instance view)
1.1.4 bandwidth (VSI view)
1.1.5 description
1.1.6 display arp suppression vsi
1.1.7 display hardware-resource vxlan
1.1.8 display igmp host group
1.1.9 display ipv6 nd suppression vsi
1.1.10 display l2vpn mac-address
1.1.11 display l2vpn service-instance
1.1.12 display l2vpn vsi
1.1.13 display vxlan tunnel
1.1.14 emulate-ping vxlan
1.1.15 encapsulation
1.1.16 flooding disable
1.1.17 group
1.1.18 hardware-resource vxlan
1.1.19 igmp host enable
1.1.20 ipv6 nd suppression enable
1.1.21 ipv6 nd suppression notify-ipsg
1.1.22 l2vpn enable
1.1.23 l2vpn mac-address software-learning enable
1.1.24 learning mode disable
1.1.25 mac-address mac-learning priority
1.1.26 mac-address static
1.1.27 mac-learning enable
1.1.28 mac-based ac
1.1.29 reserved vxlan
1.1.30 reset arp suppression vsi
1.1.31 reset ipv6 nd suppression vsi
1.1.32 reset l2vpn mac-address
1.1.33 reset l2vpn statistics ac
1.1.34 reset l2vpn statistics vsi
1.1.35 restrain
1.1.36 rewrite inbound tag
1.1.37 rewrite outbound tag
1.1.38 selective-flooding mac-address
1.1.39 service-instance
1.1.40 shutdown
1.1.41 statistics enable (Ethernet service instance view)
1.1.42 statistics enable (Tunnel interface view)
1.1.43 statistics enable (VSI view)
1.1.44 tunnel
1.1.45 tunnel bfd enable
1.1.46 tunnel global source-address
1.1.47 tunnel statistics vxlan auto
1.1.48 vsi
1.1.49 vxlan
1.1.50 vxlan default-decapsulation
1.1.51 vxlan invalid-udp-checksum discard
1.1.52 vxlan invalid-vlan-tag discard
1.1.53 vxlan local-mac report
1.1.54 vxlan tunnel mac-learning disable
1.1.55 vxlan udp-port
1.1.56 vxlan vlan-based
1.1.57 vxlan vni
1.1.58 vxlan-over-vxlan enable
1.1.59 xconnect vsi
1.2 VXLAN IP网关配置命令
1.2.1 arp distributed-gateway dynamic-entry synchronize
1.2.2 arp send-rate
1.2.3 bandwidth
1.2.4 default
1.2.5 description
1.2.6 display interface vsi-interface
1.2.7 distributed-gateway local
1.2.8 gateway subnet
1.2.9 gateway vsi-interface
1.2.10 interface vsi-interface
1.2.11 ipv6 nd distributed-gateway dynamic-entry synchronize
1.2.12 mac-address
1.2.13 mtu
1.2.14 reset counters interface vsi-interface
1.2.15 shutdown
1.2.16 vtep group member local
1.2.17 vtep group member remote
1.2.18 vxlan tunnel arp-learning disable
1.2.19 vxlan tunnel nd-learning disable
1.3 OVSDB-VTEP配置命令
1.3.1 ovsdb server bootstrap ca-certificate
1.3.2 ovsdb server enable
1.3.3 ovsdb server pki domain
1.3.4 ovsdb server pssl
1.3.5 ovsdb server ptcp
1.3.6 ovsdb server ssl
1.3.7 ovsdb server tcp
1.3.8 vtep access port
1.3.9 vtep enable
1.3.10 vxlan tunnel flooding-proxy
1 VXLAN
1.1  VXLAN基础配置命令
ac statistics enable命令用来开启VLAN下对应AC的统计功能。
undo ac statistics enable命令用来关闭VLAN下对应AC的统计功能。
VLAN下对应AC的统计功能处于关闭状态。
VLAN视图
采用VLAN与VXLAN关联方式时,开启VLAN下对应AC的统计功能后,可以对该VLAN下自动生成的AC进行报文统计。
开启本功能前,必须先执行vxlan vlan-based命令用来开启VLAN关联VXLAN功能。
# 配置VLAN 10关联VXLAN 100,并开启VLAN 10下对应AC的统计功能。
[Sysname] vlan 10
[Sysname -vlan10] vxlan vni 100
[Sysname -vlan10] ac statistics enable
·     display l2vpn service-instance
·     reset l2vpn statistics ac
·     vxlan vlan-based
arp suppression enable命令用来开启ARP泛洪抑制功能。
undo arp suppression enable命令用来关闭ARP泛洪抑制功能。
ARP泛洪抑制功能处于关闭状态。
VSI视图
为了避免广播发送的ARP请求报文过多占用核心网络带宽,VTEP从本地站点、VXLAN隧道接收到ARP请求和ARP应答报文后,根据该报文在本地建立ARP泛洪抑制表项。后续当VTEP收到本站点内虚拟机请求其它虚拟机MAC地址的ARP请求时,优先根据ARP泛洪抑制表项进行代答。如果没有对应的表项,则将ARP请求泛洪到核心网。ARP泛洪抑制功能可以大大减少ARP泛洪的次数。
# 在VSI vsi1下开启ARP泛洪抑制功能。
[Sysname] vsi vsi1
[Sysname-vsi-vsi1] arp suppression enable
·     display arp suppression vsi
·     reset arp suppression vsi
bandwidth命令用来配置AC上流量的最大带宽。
undo bandwidth命令用来恢复缺省情况。
bandwidth bandwidth
undo bandwidth
未配置AC上流量的最大带宽,即不限制AC上的流量。
以太网服务实例视图
bandwidth:AC上流量的最大带宽,取值范围为64~4194303,单位为kbps。
配置AC上流量的最大带宽后,设备仅对AC上的入方向流量进行限速,对于AC上的出方向流量不进行限速。当AC上入方向的流量总带宽超过配置的最大带宽后,将丢弃超过最大带宽的入方向流量。
如果在以太网服务实例视图和VSI视图下均执行了bandwidth命令,分别配置AC和VSI的流量最大带宽,则配置了bandwidth命令的AC单独限速,不占用VSI的带宽。例如,名为vsi1的VSI关联了AC 1、AC 2、AC 3和Tunnel 1,vsi1的流量最大带宽为为500kbps,AC 1上的流量最大带宽为120kbps,AC 2和AC 3上没有限制流量的带宽,则AC 1上流量的最大带宽为120kbps,AC 2、AC 3和Tunnel 1上所有流量的最大带宽为500kbps。
# 在以太网服务实例200上配置AC上流量的最大带宽值为10240kbps。
[Sysname-Ten-GigabitEthernet1/0/1] service-instance 200
[Sysname-Ten-GigabitEthernet1/0/1-srv200] encapsulation s-vid 200
[Sysname-Ten-GigabitEthernet1/0/1-srv200] bandwidth 10240
·     bandwidth (VSI view)
bandwidth命令用来配置VSI内流量的最大带宽。
bandwidth bandwidth
undo bandwidth
未配置VSI内流量的最大带宽,即不限制VSI内的流量。
VSI视图
bandwidth:VSI内流量的最大带宽,对于Release 2612P02以前的版本,本参数取值范围为64~4194303;对于Release 2612P02及以上版本,本参数取值范围为64~167772159,单位为kbps。
配置VSI内流量的最大带宽后,设备将对与该VSI关联的AC和VXLAN隧道上入方向的流量总和进行限制。入方向流量的总带宽超过配置的最大带宽后,从AC和VXLAN隧道上收到的流量将会被丢弃。
如果在以太网服务实例视图和VSI视图下均执行了bandwidth命令分别配置AC和VSI的流量最大带宽,则配置了bandwidth命令的AC单独限速,不占用VSI的带宽。例如,名为vsi1的VSI关联了AC 1、AC 2、AC 3和Tunnel 1,vsi1的流量最大带宽为500kbps,AC 1上的流量最大带宽为120kbps,AC 2和AC 3上没有限制流量的带宽,则AC 1上流量的最大带宽为120kbps,AC 2、AC 3和Tunnel 1上所有流量的最大带宽为500kbps。
如果在VSI视图下同时执行了bandwidth命令和restrain命令,则对于广播、组播或未知单播流量,仅通过restrain命令限制该类流量,bandwidth命令不能限制该类流量。bandwidth命令仅能控制未通过restrain命令限制的流量。
建议不要在VSI视图下同时执行bandwidth命令和selective-flooding mac-addres命令,以免影响报文的正常转发。
# 配置名为vpn1的VSI内流量的最大带宽值为10240kbps。
[Sysname] vsi vpn1
[Sysname-vsi-vpn1] bandwidth 10240
·     bandwidth (Service instance view)
·     display l2vpn vsi
1.1.5  description
description命令用来配置VSI的描述信息。
undo description命令用来恢复缺省情况。
未配置VSI的描述信息。
VSI视图
text:VSI的描述信息,为1~80个字符的字符串,区分大小写。
# 配置名为vpn1的VSI的描述信息为“vsi for vpn1”。
[Sysname] vsi vpn1
[Sysname-vsi-vpn1] description vsi for vpn1
·     display l2vpn vsi
display arp suppression vsi命令用来显示VSI的ARP泛洪抑制表项信息。
display arp suppression vsi [ name vsi-name ] [ slot slot-number ] [ count ]
name vsi-name:显示指定VSI的ARP泛洪抑制表项。vsi-name表示VSI的名称,为1~31个字符的字符串,区分大小写。如果不指定本参数,则显示所有VSI的ARP泛洪抑制表项。
slot slot-number:显示指定成员设备的ARP泛洪抑制表项。slot-number表示设备在IRF中的成员编号。如果不指定本参数,将显示主设备上的ARP泛洪抑制表项。
count:显示ARP泛洪抑制表项的个数。
# 显示VSI的ARP泛洪抑制表项信息。
<Sysname> display arp suppression vsi
IP address      MAC address    Vsi Name                        Link ID    Aging
1.1.1.2         000f-e201-0101 vsi1                            0x70000    14
1.1.1.3         000f-e201-0202 vsi1                            0x80000    18
1.1.1.4         000f-e201-0203 vsi2                            0x90000    10
# 显示VSI的ARP泛洪抑制表项个数。
<Sysname> display arp suppression vsi count
Total entries: 3
表1-1 display arp suppression vsi命令显示信息描述表
IP address
ARP泛洪抑制表项的IP地址
MAC address
ARP泛洪抑制表项的MAC地址
Vsi Name
VSI名称
Link ID
MAC表项的出链路标识符,用来在VSI内唯一标识一条AC或一条VXLAN隧道
Aging
ARP泛洪抑制表项的老化时间,单位为分钟
Total entries
ARP泛洪抑制表项的数目
·     arp suppression enable
display hardware-resource vxlan命令用来显示VXLAN的硬件资源模式。
display hardware-resource [ vxlan ]
S6800系列交换机中,产品代码为LS-6800-32Q、LS-6800-2C、LS-6800-4C、LS-6800-54QF或LS-6800-54QT的机型不支持本命令。
执行本命令时,如果不指定vxlan参数,则显示所有类型的硬件资源模式。
# 显示VXLAN的硬件资源模式。
<Sysname> display hardware-resource vxlan
Vxlan resource(vxlan), all supported modes:
  l2gw              L2 gateway--underlay/overlay 48K/0K
  l3gw8k            L3 gateway--underlay/overlay 40K/8K
  l3gw16k           L3 gateway--underlay/overlay 32K/16K
  l3gw24k           L3 gateway--underlay/overlay 24K/24K
  l3gw32k           L3 gateway--underlay/overlay 16K/32K
  l3gw40k           L3 gateway--underlay/overlay 8K/40K
  border8k          Border--underlay/overlay 40K/8K
  border16k         Border--underlay/overlay 32K/16K
  border24k         Border--underlay/overlay 24K/24K
  border32k         Border--underlay/overlay 16K/32K
  border40k         Border--underlay/overlay 8K/40K
  Default         Current         Next
  l2gw            border24k       border24k
表1-2 display hardware-resource vxlan命令显示信息描述表
设备支持的VXLAN硬件资源模式,取值包括:
·     l2gw:二层网关模式
·     l3gw8k:三层网关模式,此模式下Overlay网络的邻接表占用8K资源
·     l3gw16k:三层网关模式,此模式下Overlay网络的邻接表占用16K资源
·     l3gw24k:三层网关模式,此模式下Overlay网络的邻接表占用24K资源
·     l3gw32k:三层网关模式,此模式下Overlay网络的邻接表占用32K资源
·     l3gw40k:三层网关模式,此模式下Overlay网络的邻接表占用40K资源
·     border8k:Border模式,此模式下Overlay网络的邻接表占用8K资源
·     border16k:Border模式,此模式下Overlay网络的邻接表占用16K资源
·     border24k:Border模式,此模式下Overlay网络的邻接表占用24K资源
·     border32k:Border模式,此模式下Overlay网络的邻接表占用32K资源
·     border40k:Border模式,此模式下Overlay网络的邻接表占用40K资源
VXLAN的缺省硬件资源模式
Current
VXLAN的当前硬件资源模式
Next
最新配置的VXLAN硬件资源模式
·     hardware-resource vxlan
display igmp host group命令用来显示IGMP执行主机行为的所有组播组信息。
display igmp host group [ group-address | interface interface-type interface-number ] [ verbose ]
group-address:显示指定组播组的信息,取值范围为224.0.1.0~239.255.255.255。如果未指定本参数,则显示所有组播组的信息。
interface interface-type interface-number:显示指定接口上的信息。如果未指定本参数,则显示所有接口上的信息。
verbose:显示详细信息。如果未指定本参数,则显示简要信息。
采用组播路由方式泛洪流量时,VXLAN组播报文源IP地址所在的接口需要作为IGMP主机加入VXLAN所在的组播组。通过本命令可以查看接口是否加入组播组,及该组播组的信息。
# 显示IGMP执行主机行为的所有组播组的简要信息。
<Sysname> display igmp host group
IGMP host groups in total: 2
 Vlan-interface10(1.1.1.20):
   Group address      Member state      Expires
   225.1.1.1          Idle              Off
   225.1.1.2          Idle              Off
# 显示IGMP执行主机行为的所有组播组的详细信息。
<Sysname> display igmp host group verbose
   Group: 225.1.1.1
     Group mode: Exclude
     Member state: Idle
     Expires: Off
     Source list (sources in total: 0):
   Group: 225.1.1.2
     Group mode: Exclude
     Member state: Idle
     Expires: Off
表1-3 display igmp host group命令显示信息描述表
IGMP执行主机行为的组播组总数
IGMP执行主机行为的接口的名称和IP地址
当前接口下IGMP执行主机行为的组播组数目
Group address/Group
组播组地址
Member state
组播组成员的状态,取值包括:
·     Delay:表示加入了组播组,并对该组启动了延迟发送报告报文的定时器
·     Idle:表示加入了组播组,但对该组尚未启动延迟发送报告报文的定时器
延迟发送报告报文定时器的值不可配置
Expires
组播组延迟发送报告报文的剩余时间,Off表示该定时器关闭
Group mode
对组播源的过滤模式,取值包括:
·     Include:表示INCLUDE模式
·     Exclude:表示EXCLUDE模式
Source list
IGMP执行主机行为的组播组所包含的组播源列表
sources in total
组播源的总数
对本命令的显示信息更加详细的介绍,请参见“IP组播配置指导”中的“IGMP”。
·     igmp host enable
仅Release 2612P06及以上版本支持本命令。
display ipv6 nd suppression vsi命令用来显示VSI的ND泛洪抑制表项信息。
display ipv6 nd suppression vsi [ name vsi-name ] [ slot slot-number ] [ count ]
name vsi-name:显示指定VSI的ND泛洪抑制表项。vsi-name表示VSI的名称,为1~31个字符的字符串,区分大小写。如果不指定本参数,则显示所有VSI的ND泛洪抑制表项。
slot slot-number:显示指定成员设备的ND泛洪抑制表项。slot-number表示设备在IRF中的成员编号。如果不指定本参数,将显示主设备上的ND泛洪抑制表项。
count:显示ND泛洪抑制表项的个数。
# 显示VSI的ND泛洪抑制表项信息。
<Sysname> display ipv6 nd suppression vsi
IPv6 address            MAC address     VSI Name         Link ID    Aging (min)
1000::2                 000f-e201-0101 vsi1             0x70000    5
1000::3                 000f-e201-0202 vsi1             0x80000    5
1000::4                 000f-e201-0203 vsi2             0x90000    5
# 显示VSI的ND泛洪抑制表项个数。
<Sysname> display ipv6 nd suppression vsi count
Total entries: 3
表1-4 display ipv6 nd suppression vsi命令显示信息描述表
IPv6 address
ND泛洪抑制表项的IPv6地址
MAC address
ND泛洪抑制表项的MAC地址
VSI Name
VSI名称
Link ID
ND泛洪抑制表项的出链路标识符,用来在VSI内唯一标识一条AC或一条VXLAN隧道
Aging (min)
ND泛洪抑制表项的老化时间,单位为分钟
Total entries
ND泛洪抑制表项的数目
·     ipv6 nd suppression enable
·     reset ipv6 nd suppression vsi
display l2vpn mac-address命令用来显示VSI的MAC地址表信息。
display l2vpn mac-address [ vsi vsi-name ] [ dynamic ] [ count | verbose ]
vsi vsi-name:显示指定VSI的MAC地址表信息。vsi-name表示VSI的名称,为1~31个字符的字符串,区分大小写。如果不指定本参数,则显示所有VSI的MAC地址表信息。
dynamic:显示通过源MAC地址动态学习的MAC地址表项。如果不指定本参数,则显示所有类型的MAC地址表项,包括通过源MAC地址动态学习的本地和远端MAC地址表项、静态配置的本地和远端MAC地址表项、通过OpenFlow下发的远端MAC地址表项和通过OVSDB生成的远端MAC地址表项。
count:显示MAC地址表项的数目。
verbose:显示MAC地址表项的详细信息。
执行本命令时,如果没有指定count和verbose参数,则显示MAC地址表项的简要信息。
# 显示所有VSI的MAC地址表简要信息。
<Sysname> display l2vpn mac-address
MAC Address      State    VSI Name                        Link ID/Name  Aging
0000-0000-000b   Static   vpn1                            Tunnel10      NotAging
0000-0000-000c   Dynamic  vpn1                            Tunnel60      Aging
0000-0000-000d   Dynamic  vpn1                            Tunnel99      Aging
00e0-fc09-9993   EVPN     vpna                            Tunnel0       NotAging
0001-0001-0003   EVPN     vpna                            Tunnel0       NotAging
                                                          Tunnel1       NotAging
00e0-fc09-0001   EVPN     vpna                            0             NotAging
--- 6 mac address(es) found  ---
# 显示所有VSI的MAC地址表项总数。
<Sysname> display l2vpn mac-address count
表1-5 display l2vpn mac-address命令显示信息描述表
MAC Address
MAC地址
MAC地址的状态,取值包括:
·     Dynamic:表示通过源MAC地址动态学习的本地或远端MAC地址表项
·     Static:表示静态配置的本地或远端MAC地址表项
·     OpenFlow:表示通过OpenFlow下发的远端MAC地址表项
·     OVSDB:表示通过OVSDB生成的远端MAC地址表项
VSI Name
VSI名称
Link ID/Name
对于本端MAC地址,为MAC地址对应以太网服务实例所在接口的名称
对于远端MAC地址,为MAC地址对应的隧道接口名称
Aging
MAC地址表项是否老化,取值包括Aging和NotAging
XX mac address(es) found
VSI的MAC地址表项的总数
# 显示所有VSI的MAC地址表详细信息。
<Sysname> display l2vpn mac-address verbose
MAC Address : 0000-0000-000b
VSI Name    : vpn1
VXLAN ID    : 123
Interface   : XGE1/0/1
Link ID     : 1
State       : Dynamic
Aging       : Aging
MAC Address : 0001-0001-0003
VSI Name    : vpna
VXLAN ID    : 10
State       : EVPN
Aging       : NotAging
Interface       Link ID
Tunnel0         0x5000000
Tunnel1         0x5000001
表1-6 display l2vpn mac-address verbose命令显示信息描述表
MAC Address
MAC地址
VSI Name
MAC地址所属的VSI名称
VXLAN ID
VXLAN编号
对于本端MAC地址,为以太网服务实例所在接口的名称
Link ID
AC或VXLAN隧道在VSI内的链路标识符
MAC地址的状态,取值包括:
Aging
·     reset l2vpn mac-address
display l2vpn service-instance命令用来显示以太网服务实例的信息。
interface interface-type interface-number:显示指定二层以太网接口或二层聚合接口上的以太网服务实例信息。interface-type interface-number为接口类型和接口编号。如果未指定本参数,则显示所有二层以太网接口和二层聚合接口上的以太网服务实例信息。
service-instance instance-id:显示指定以太网服务实例的信息。instance-id为以太网服务实例的ID,取值范围为1~4096。如果指定了interface interface-type interface-number参数,未指定本参数,则显示指定二层以太网接口或二层聚合接口上所有以太网服务实例的信息。
# 显示所有以太网服务实例的简要信息。
<Sysname> display l2vpn service-instance
Total number of service-instances: 4, 4 up, 0 down
Total number of ACs: 2, 2 up, 0 down
Interface                SrvID Owner                           LinkID State Type
XGE1/0/1                 3     vsi12                           1      Up    VSI
XGE1/0/1                 4     vsi13                           1      Up    VSI
表1-7 display l2vpn service-instance命令显示信息描述表
以太网服务实例的总数,及处于up和down状态的以太网服务实例数目
Total number of ACs
AC的总数,及处于up和down状态的AC数目
二层以太网接口或二层聚合接口名称
SrvID
以太网服务实例的ID
Owner
VSI名称,如果以太网服务实例上尚未关联VSI,则该字段显示为空
LinkID
以太网服务实例在VSI内的链路标识符
以太网服务实例的状态,取值包括Up和Down
以太网服务实例所属的L2VPN类型,取值包括VSI和VPWS
# 显示二层以太网接口Ten-GigabitEthernet1/0/1上所有以太网服务实例的详细信息。
<Sysname> display l2vpn service-instance interface ten-gigabitethernet 1/0/1 verbose
Interface: XGE1/0/1
  Service Instance: 1
    Type          : Manual
    Encapsulation : s-vid 16
    Bandwidth     : Unlimited
    VSI Name      : vsi10
    Link ID       : 1
    State         : Up
    DF State      : BDF
    Statistics    : Enabled
    Input Statistics:
      Octets   :0
      Packets  :0
    Output Statistics:
      Octets   :0
      Packets  :0
表1-8 display l2vpn service-instance verbose命令显示信息描述表
二层以太网接口或二层聚合接口
Service Instance
以太网服务实例ID
以太网服务实例的类型和报文匹配方式,取值包括:
·     Dynamic (MAC-based):动态创建,采用MAC地址匹配方式
·     Manual:手工创建,采用VLAN匹配方式
Encapsulation
以太网服务实例的报文匹配规则,如果未配置报文匹配规则,则不显示本字段
Bandwidth
以太网服务实例对应AC上流量的最大带宽,单位为kbps
取值为Unlimited时,表示不限制AC上的流量
VSI Name
与以太网服务实例关联的VSI的名称
Link ID
以太网服务实例在VSI内的链路标识符
DF State
在EVPN多归属组网中,AC在DF(Designated Forwarder)选举中的角色,取值包括:
·     BDF:该AC转发角色是BDF(Backup DF)
·     DF:该AC转发角色是DF
若接口未配置ESI(Ethernet Segment Identifier),则不显示该字段
Statistics
是否使能以太网服务实例的统计功能,取值包括:
·     Enabled:使能了以太网服务实例的统计功能
·     Disabled:禁止以太网服务实例的统计功能
Input Statistics
入方向的以太网服务实例报文统计信息,包括入方向接收的字节数(Octets)、接收的报文数(Packets)
Output Statistics
出方向的以太网服务实例报文统计信息,包括出方向发送的字节数(Octets)、发送的报文数(Packets)
·     service-instance
display l2vpn vsi命令用来显示VSI的信息。
display l2vpn vsi [ name vsi-name ] [ verbose ]
name vsi-name:显示指定VSI的信息。vsi-name表示VSI的名称,为1~31个字符的字符串,区分大小写。如果不指定本参数,则显示所有VSI的信息。
verbose:显示VSI的详细信息。如果不指定本参数,则显示VSI的简要信息。
# 显示所有VSI的简要信息。
<Sysname> display l2vpn vsi
Total number of VSIs: 1, 1 up, 0 down, 0 admin down
VSI Name                        VSI Index       MTU    State
vpna                            0               1500   Up
表1-9 display l2vpn vsi命令显示信息描述表
VSI Name
VSI名称
VSI Index
VSI索引
MTU
VSI上配置的最大传输单元
VSI的状态,取值包括:
·     Up:up状态
·     Down:down状态
·     Admin down:通过shutdown命令手工关闭VSI
# 显示所有VSI的详细信息。
<Sysname> display l2vpn vsi verbose
VSI Name: vpna
  VSI Index               : 0
  VSI State               : Up
  Broadcast Restrain      : Unlimited
  Multicast Restrain      : Unlimited
  Unknown Unicast Restrain: Unlimited
  MAC Table Limit         : -
  MAC Learning rate       : -
  Drop Unknown            : -
  Input statistics:
    Octets   : 0
    Packets  : 0
    Errors   : 0
    Discards : 0
  Output statistics:
    Octets   : 0
    Packets  : 0
    Errors   : 0
    Discards : 0
  Gateway Interface       : VSI-interface 100
  VXLAN ID                : 10
  Tunnels:
    Tunnel Name          Link ID    State  Type      Flood proxy
    Tunnel1              0x5000001  Up     Manual    Disabled
    Tunnel2              0x5000002  Up     Manual    Disabled
    MTunnel0             0x6002710  Up     Auto      Disabled
  ACs:
    AC                               Link ID    State    Type
    XGE1/0/1 srv1000                 0          Up       Manual
    XGE100/0/1 srv10                 1          Up       Manual
表1-10 display l2vpn vsi verbose命令显示信息描述表
VSI Name
VSI名称
VSI Index
VSI索引
VSI Description
VSI的描述信息,如果不配置,则此行不显示
VSI State
VSI的状态,取值包括:
·     Up:up状态
·     Down:down状态
·     Administratively down:通过shutdown命令手工关闭VSI
MTU
VSI上配置的最大传输单元
Bandwidth
VSI内流量的最大带宽值,单位为kbps
取值为Unlimited时,表示不限制VSI内的流量
Broadcast Restrain
VSI的广播抑制带宽值,单位为kbps
Multicast Restrain
VSI的组播抑制带宽值,单位为kbps
VSI的未知单播抑制带宽值,单位为kbps
MAC Learning
是否使能了MAC地址学习功能
MAC Table Limit
‌(暂不支持)VSI内MAC地址表项的最大数目
MAC Learning Rate
(暂不支持)VSI内MAC地址表项的学习速率
Drop Unknown
‌(暂不支持)当VSI内学习到的MAC地址数达到最大值后,是否禁止转发源MAC地址不在MAC地址表里的报文
Flooding
是否使能VSI的泛洪功能,取值包括:
·     Enabled:表示使能了VSI的泛洪功能
·     Disabled:表示禁止VSI的泛洪功能
Statistics
是否使能VSI的统计功能,取值包括:
·     Enabled:使能了VSI的统计功能
·     Disabled:禁止VSI的统计功能
Input statistics
入方向的VSI报文统计信息,包括入方向接收的字节数(Octets)、接收的报文数(Packets)、接收的错误报文数(Errors)和丢弃的报文数(Discards)
Output statistics
出方向的VSI报文统计信息,包括出方向发送的字节数(Octets)、发送的报文数(Packets)、错误报文数(Errors)和丢弃的报文数(Discards)
Gateway Interface
VSI网关虚接口编号
S6800系列交换机中,产品代码为LS-6800-32Q、LS-6800-2C、LS-6800-4C、LS-6800-54QF或LS-6800-54QT的机型不支持本字段
VXLAN ID
VXLAN编号
Tunnels
与VXLAN关联的隧道信息
Tunnel Name
隧道名称
Link ID
隧道在VSI内的链路标识符
隧道状态,取值包括:
·     Up:Tunnel接口状态Up,隧道可正常转发数据
·     Blocked:该隧道为备用代理隧道,不进行数据转发,Tunnel接口状态Up
·     Defect:Tunnel接口状态Up,但是隧道的BFD检测功能检测到隧道故障,请检查VXLAN隧道配置及链路
·     Down:Tunnel接口状态Down,隧道停止数据转发
VXLAN和VXLAN隧道的关联方式,取值包括:
·     Auto:表示自动关联
¡     在组播路由方式下,自动创建用于转发泛洪流量的组播VXLAN隧道(MTunnel),并将其与VXLAN关联
¡     EVPN自动将VXLAN和VXLAN隧道关联
·     Manual:表示手动关联VXLAN和VXLAN隧道
Flood proxy
隧道是否开启了泛洪代理功能,取值包括:
·     Enabled:开启隧道的泛洪代理功能,即VXLAN内的广播、组播和未知单播流量将通过该Tunnel发送到代理服务器,由代理服务器进行复制并转发到其它远端VTEP
·     Disabled:关闭隧道的泛洪代理功能
ACs
VSI的AC列表
AC
接入电路
Link ID
AC在VSI内的链路标识符
AC的状态,取值包括Up和Down
display vxlan tunnel命令用来显示与VXLAN关联的VXLAN隧道的信息。
display vxlan tunnel [ vxlan-id vxlan-id ]
vxlan-id:显示与指定VXLAN关联的隧道的信息。vxlan-id为VXLAN的编号,取值范围为0~16777215。不指定此参数,则显示所有与VXLAN关联的隧道的信息。
# 显示所有与VXLAN关联的隧道的信息。
<Sysname> display vxlan tunnel
Total number of VXLANs: 1
VXLAN ID: 10, VSI name: vpna, Total tunnels: 3 (3 up, 0 down, 0 defect, 0 blocked)
Tunnel name          Link ID    State  Type         Flood proxy
# 显示与编号为10的VXLAN关联的隧道的信息。
<Sysname> display vxlan tunnel vxlan-id 10
表1-11 display vxlan tunnel命令显示信息描述表
已创建的VXLAN的总数
VXLAN ID
VXLAN ID
VSI name
VXLAN所属的VSI名称
Total tunnels
与VXLAN关联的隧道的总数,包括处于Up和Down状态的隧道总数
Tunnel name
隧道名称
Link ID
隧道在VXLAN内的链路标识符
隧道的状态,取值包括:
·     Auto:表示自动关联
Flood proxy
隧道是否开启了泛洪代理功能,取值包括:
·     Enabled:开启隧道的泛洪代理功能。即该VXLAN内的广播、组播和未知单播流量将通过该Tunnel发送到代理服务器,由代理服务器进行复制并转发到其它远端VTEP
·     tunnel
·     vxlan
emulate-ping vxlan命令用来检测VXLAN内远端虚拟机的连通性。
emulate-ping vxlan [ -c count | -m interval | -s packet-size | -t time-out ] * vxlan-id vxlan-id source-mac mac-address destination-mac mac-address
-c count:指定ICMP回显请求报文的发送次数,取值范围为1~4294967295,缺省值为5。
-m interval:指定发送ICMP回显请求报文的时间间隔,取值范围为1~65535,单位为毫秒,缺省值为200。
-s packet-size:指定发送的ICMP回显请求报文的长度(不包括IP和ICMP报文头),取值范围为20~8100,单位为字节,缺省值为56。
-t time-out:指定等待ICMP回显应答报文的超时时间,即设备发送ICMP回显请求报文time-out时长后,如果没有收到ICMP回显应答报文,则认为ICMP回显应答报文超时。time-out取值范围为0~65535,单位为毫秒,缺省值为2000。
vxlan-id vxlan-id:指定发送ICMP回显请求报文的VXLAN。vxlan-id表示VXLAN编号,取值范围为0~16777215。
source-mac mac-address:指定ICMP回显请求报文的源MAC地址。该地址必须是指定VXLAN的MAC地址表中已经存在的本端虚拟机MAC地址。
destination-mac mac-address:指定ICMP回显请求报文的目的MAC地址。该地址必须是指定VXLAN的MAC地址表中已经存在的远端虚拟机MAC地址。
执行本命令后,设备将模拟本端虚拟机向远端虚拟机发送ICMP回显请求报文,该报文封装在二层数据帧中,并在指定的VXLAN内发送。本端设备根据是否收到ICMP回显应答报文、收到ICMP回显应答报文的时间,判断在该VXLAN内指定远端虚拟机是否可达,并输出相应的统计信息。
# 检测VXLAN 100内从MAC地址为1ea3-c0be-0206的本端虚拟机到MAC地址为1ea3-b77b-0106的远端虚拟机的连通性。
<Sysname> emulate-ping vxlan vxlan-id 100 source-mac 1ea3-c0be-0206 destination-mac 1ea3-b77b-0106
Emulate ping in VXLAN 100: source MAC 1ea3-c0be-0206, destination MAC 1ea3-b77b-0106, 56 data bytes.
Press CTRL_C to break.
56 bytes from 100.1.2.1: ICMP_seq=0 time=1.114 ms
56 bytes from 100.1.2.1: ICMP_seq=1 time=1.073 ms
56 bytes from 100.1.2.1: ICMP_seq=2 time=1.123 ms
56 bytes from 100.1.2.1: ICMP_seq=3 time=1.781 ms
56 bytes from 100.1.2.1: ICMP_seq=4 time=0.933 ms
--- Ping statistics for VXLAN 100 ---
Round-trip min/avg/max/std-dev=0.933/1.205/1.781/0.296 ms
表1-12 emulate-ping vxlan命令显示信息描述表
检测VXLAN 100内从MAC地址为1ea3-c0be-0206的本端虚拟机到MAC地址为1ea3-b77b-0106的远端虚拟机的连通性,每个ICMP回显请求报文中的数据为56字节
按组合键Ctrl+C可以终止ping操作
收到IP地址为100.1.2.1的设备回复的ICMP回显应答报文,若超时仍没有收到ICMP回显应答报文,则不输出信息
·     bytes:表示ICMP回显应答报文中的数据字节数
·     ICMP_seq:表示报文序号,用来判断报文是否有分组丢失、失序或重复
·     time:表示响应时间
Ping操作中收发数据的统计结果
发送的ICMP回显请求报文数
5 packets received
收到的ICMP回显应答报文数
0.0% packet loss
未响应请求报文占发送的总请求报文的百分比
响应时间的最小值、平均值、最大值和标准方差,单位为毫秒
encapsulation命令用来配置以太网服务实例的报文匹配规则。
undo encapsulation命令用来恢复缺省情况。
encapsulation s-vid vlan-id [ c-vid { vlan-id-list | all } | only-tagged ]
encapsulation s-vid vlan-id-list [ c-vid vlan-id-list ]
encapsulation { default | tagged | untagged }
undo encapsulation
未配置报文匹配规则。
以太网服务实例视图
s-vid:匹配外层VLAN标签(Service VLAN ID)为指定值的报文。
c-vid:匹配内层VLAN标签(Customer VLAN ID)为指定值的报文。
vlan-id:VLAN的编号,取值范围为1~4094。
vlan-id-list:VLAN列表,表示一个或多个VLAN的编号。表示方式为vlan-id-list = { vlan-id [ to vlan-id ] }&<1-8>。其中,vlan-id为指定VLAN的编号,取值范围为1~4094。&<1-8>表示前面的参数最多可以输入8次。
only-tagged:表示只匹配携带VLAN标签的报文。当匹配的VLAN为缺省VLAN时,如果未指定本关键字,则会同时匹配所携带VLAN标签为缺省VLAN的报文和未携带VLAN标签的报文;如果指定了本参数,则只匹配所携带VLAN标签为缺省VLAN的报文。
all:所有VLAN。
default:表示缺省的报文匹配规则。同一个以太网接口下最多只能有一个服务实例采用缺省的报文匹配规则。如果接口下同时存在一个采用缺省报文匹配规则的服务实例和多个采用其他报文匹配规则的服务实例,则未与任何其他报文匹配规则匹配的报文将匹配缺省报文匹配规则;如果接口下只存在一个采用缺省报文匹配规则的服务实例,则该接口上的所有报文都匹配缺省报文匹配规则。
untagged:表示匹配未携带VLAN标签的报文。
如果同一接口的不同以太网服务实例上分别通过encapsulation s-vid vlan-id [ only-tagged ]命令和encapsulation s-vid vlan-id c-vid vlan-id命令配置匹配相同外层VLAN tag(s-vid)的报文匹配规则,则携带指定外层和内层VLAN tag的报文匹配encapsulation s-vid vlan-id c-vid vlan-id命令所属的以太网服务实例。
二层以太网接口/二层聚合接口上某个以太网服务实例的匹配规则为encapsulation untagged时,则该二层以太网接口上不能通过QoS策略配置Nest功能。有关Nest功能的详细介绍请参见“ACL和QoS配置指导”中的“QoS”。
二层以太网接口/二层聚合接口上某个以太网服务实例的匹配规则为encapsulation default且以太网服务实例的接入模式为Ethernet模式时,该二层以太网接口/二层聚合接口上还可以创建其他的以太网服务实例,且接口上接收到的报文优先匹配其他的以太网服务实例,最后匹配encapsulation default所在的以太网服务实例。
不能通过重复执行本命令修改报文匹配规则。如需修改报文匹配规则,请先通过undo encapsulation命令删除报文匹配规则,再执行encapsulation命令。
删除以太网服务实例下的报文匹配规则后,会自动取消以太网服务实例与VSI的关联。
在SDN组网中,如果执行本命令修改匹配的外层VLAN标签,则需要同时修改控制器通过Set-Field动作下发的VLAN ID,否则会导致命令行配置、发送到用户侧报文携带的VLAN标签与流表项不一致。
# 在二层以太网接口Ten-GigabitEthernet1/0/1的以太网服务实例1上配置如下报文匹配规则:匹配外层VLAN标签为111的报文。
[Sysname-Ten-GigabitEthernet1/0/1] service-instance 1
[Sysname-Ten-GigabitEthernet1/0/1-srv1] encapsulation s-vid 111
flooding disable命令用来关闭VSI的泛洪功能。
undo flooding disable命令用来开启VSI的泛洪功能。
flooding disable { all | { broadcast | unknown-multicast | unknown-unicast } * }
VSI的泛洪功能处于开启状态。
VSI视图
all:禁止广播、未知单播和未知组播数据帧向远端站点泛洪。
broadcast:禁止广播数据帧向远端站点泛洪。
unknown-multicast:禁止未知组播数据帧向远端站点泛洪。
unknown-unicast:禁止未知单播数据帧向远端站点泛洪。
缺省情况下,VTEP从本地站点内接收到目的MAC地址为广播、未知单播和未知组播的数据帧后,会在该VXLAN内除接收接口外的所有本地接口和VXLAN隧道上泛洪该数据帧,将该数据帧发送给VXLAN内的所有站点。如果用户希望把某类数据帧限制在本地站点内,不通过VXLAN隧道将其转发到远端站点,则可以通过本命令手工禁止该类数据帧向远端站点泛洪。
如果在VSI视图下同时执行了flooding disable命令和restrain命令且通过restrain命令配置的抑制带宽为0,则仅restrain命令生效。若通过restrain命令配置的抑制带宽为非0值,则两个功能同时生效。
# 关闭vsi1的广播数据帧泛洪功能。
[Sysname] vsi vsi1
[Sysname-vsi-vsi1] flooding disable broadcast
1.1.17  group
group命令用来配置VXLAN泛洪的组播地址和组播报文的源IP地址。
undo group命令用来恢复缺省情况。
group group-address source source-address
undo group group-address source source-address
未指定VXLAN泛洪的组播地址和组播报文的源IP地址,VXLAN采用单播路由方式泛洪。
VXLAN视图
group-address:VXLAN泛洪的组播地址,取值范围为224.0.1.0~239.255.255.255。
source source-address:指定VXLAN组播报文的源IP地址。
数据中心网络中需要通过IP核心网络进行二层互联的站点较多时,采用组播路由方式可以节省泛洪流量对核心网络带宽资源的占用。
组播路由泛洪方式支持如下两种实现模式:
·     PIM模式:在VTEP和核心设备上运行PIM协议,以建立组播转发表项。采用该模式时,可以使用Loopback接口地址作为组播报文的源IP地址。当VTEP存在多个网络侧接口时,PIM协议可以动态选择报文的出接口。
·     IGMP主机模式:在VTEP上使能IGMP协议的主机功能、在连接VTEP的核心设备上配置IGMP、在所有核心设备上运行PIM协议,以建立组播转发表项。采用该模式时,必须使用VTEP上网络侧接口的IP地址作为组播报文的源IP地址,并在该接口上使能IGMP协议的主机功能。当VTEP存在多个网络侧接口时,IGMP主机模式只能采用组播报文的源IP地址所在的接口作为报文的出接口。
同一VXLAN网络中的不同VTEP可以采用不同的实现模式。
为确保组播报文转发正常,VXLAN组播报文的源IP地址(source-address)需要指定为一个已创建且处于up状态的VXLAN隧道的源端地址。
可以为不同的VXLAN指定相同的组播地址。例如,多个VXLAN共用相同的VTEP设备时,为这些VXLAN指定相同的组播地址,通过VXLAN ID来区分报文所属的VXLAN,可以减少IP核心网络中建立的组播转发表项数目。为不同VXLAN指定相同的组播地址时,要求为其指定的源IP地址也必须相同。
在同一个VXLAN视图下多次执行本命令,最后一次执行的命令生效。
# 为VXLAN 100配置VXLAN泛洪的组播地址为233.1.1.1、VXLAN组播报文的源IP地址为2.1.1.1。
[Sysname] vsi aaa
[Sysname-vsi-aaa] vxlan 100
[Sysname-vsi-aaa-vxlan-100] group 233.1.1.1 source 2.1.1.1
·     igmp host enable
·     pim dm(IP组播命令参考/PIM)
·     pim sm(IP组播命令参考/PIM)
hardware-resource vxlan命令用来配置VXLAN的硬件资源模式。
undo hardware-resource vxlan命令用来恢复缺省情况。
hardware-resource vxlan { border8k | border16k | border24k | border32k | border40k | l2gw | l3gw8k | l3gw16k | l3gw24k | l3gw32k | l3gw40k }
VXLAN的硬件资源模式为二层网关模式。
l2gw:二层网关模式。
l3gw8k:三层网关模式,此模式下Overlay网络的邻接表占用8K资源。
l3gw16k:三层网关模式,此模式下Overlay网络的邻接表占用16K资源。
l3gw24k:三层网关模式,此模式下Overlay网络的邻接表占用24K资源。
l3gw32k:三层网关模式,此模式下Overlay网络的邻接表占用32K资源。
l3gw40k:三层网关模式,此模式下Overlay网络的邻接表占用40K资源。
border8k:Border模式,此模式下Overlay网络的邻接表占用8K资源。
border16k:Border模式,此模式下Overlay网络的邻接表占用16K资源。
border24k:Border模式,此模式下Overlay网络的邻接表占用24K资源。
border32k:Border模式,此模式下Overlay网络的邻接表占用32K资源。
border40k:Border模式,此模式下Overlay网络的邻接表占用40K资源。
不同类型的设备上配置的硬件资源模式不同:
·     仅对报文进行二层转发的VTEP设备上,需要配置VXLAN的硬件资源模式为l2gw模式。
·     对报文进行三层转发的VXLAN IP网关设备上,需要配置VXLAN的硬件资源模式为l3gw8k、l3gw16k、l3gw24k、l3gw32k、l3gw40k模式。
·     对报文进行三层转发的Border设备上,需要配置VXLAN的硬件资源模式为border8k、border16k、border24k、border32k、border40k模式。
修改VXLAN的硬件资源模式后,只有重启设备,修改后的硬件资源模式才会生效。
Border设备上不能通过arp mode uni命令配置接口为用户侧接口。关于arp mode uni命令的详细介绍,请参见“三层技术-IP业务命令参考”中的“ARP”。
# 配置VXLAN的硬件资源模式为三层网关模式,且Overlay网络的邻接表占用8K资源。
[Sysname] hardware-resource vxlan l3gw8k
·     display hardware-resource vxlan
igmp host enable命令用来在接口上开启IGMP协议的主机功能。
undo igmp host enable命令用来在接口上关闭IGMP协议的主机功能。
igmp host enable
接口上IGMP协议的主机功能处于关闭状态。
采用组播路由方式的IGMP主机模式泛洪流量时,必须在VXLAN组播报文源IP地址所在的接口上执行本命令,使得当前接口作为IGMP主机,即从该接口收到IGMP查询报文后,通过该接口发送组播组的报告报文,以便接收该组播组的报文。
只有通过multicast routing命令使能IP组播路由后,本命令才会生效。
# 使能公网实例中的IP组播路由,并在接口Vlan-interface10上开启IGMP协议的主机功能。
[Sysname] multicast routing
[Sysname-mrib] quit
[Sysname-Vlan-interface10] igmp host enable
·     display igmp host group
·     group
·     multicast routing(IP组播命令参考/组播路由与转发)
ipv6 nd suppression enable命令用来开启ND泛洪抑制功能。
undo ipv6 nd suppression enable命令用来关闭ND泛洪抑制功能。
ND泛洪抑制功能处于关闭状态。
VSI视图
为了避免组播发送的ND请求报文占用核心网络带宽,VTEP从本地站点或VXLAN隧道接收到ND请求和ND应答报文后,根据该报文在本地建立ND泛洪抑制表项。后续当VTEP收到本站点内用户终端请求其它用户终端MAC地址的ND请求时,优先根据ND泛洪抑制表项进行代答。如果没有对应的表项,则将ND请求泛洪到核心网。ND泛洪抑制功能可以大大减少ND泛洪的次数。
# 在VSI vsi1下开启ND泛洪抑制功能。
[Sysname] vsi vsi1
[Sysname-vsi-vsi1] ipv6 nd suppression enable
·     display ipv6 nd suppression vsi
ipv6 nd suppression notify-ipsg命令用来开启根据ND泛洪抑制表项生成IPv6 Source Guard动态绑定表项功能。
undo ipv6 nd suppression notify-ipsg命令用来关闭根据ND泛洪抑制表项生成IPv6 Source Guard动态绑定表项功能。
根据ND泛洪抑制表项生成IPv6 Source Guard动态绑定表项功能处于关闭状态。
开启本功能后,设备生成ND泛洪抑制表项的同时会通知IPv6 Source Guard,生成对应的IPv6 Source Guard动态绑定表项,该表项可以上报给特定的控制器,以便控制器了解用户的上下线情况。该表项不能用来过滤报文。
IPv6 Source Guard的详细介绍,请参见“安全配置指导”中的“IP Source Guard”。
# 开启根据ND泛洪抑制表项生成IPv6 Source Guard动态绑定表项功能。
[Sysname] ipv6 nd suppression notify-ipsg
·     display ipv6 source binding(安全命令参考/IP Source Guard)
1.1.22  l2vpn enable
l2vpn enable命令用来开启L2VPN功能。
undo l2vpn enable命令用来关闭L2VPN功能。
l2vpn enable
undo l2vpn enable
L2VPN功能处于关闭状态。
只有开启L2VPN功能后,才能进行L2VPN的相关配置。
# 开启L2VPN功能。
[Sysname] l2vpn enable
l2vpn mac-address software-learning enable命令用来开启接口的MAC地址软件学习功能。
undo l2vpn mac-address software-learning enable命令用来关闭接口的MAC地址软件学习功能。
接口的MAC地址软件学习功能处于关闭状态,设备采用硬件方式学习MAC地址。
二层以太网接口视图
二层聚合接口视图
本命令适用于SDN(Software Defined Network,软件定义网络)组网。
在SDN组网中,设备将接口学习到的MAC地址上传给控制器,控制器把收到的MAC地址下发给其它远端设备,以减少不必要的广播流量。
软件学习:接口通过软件学习MAC地址。软件把学到的MAC地址下发给硬件,同时上传控制器处理。软件学习方式下不需等待软件检查周期的到来,控制器获取MAC地址的速度较快。
需要注意的是,开启接口的MAC地址软件学习功能后,大量的MAC地址学习可能对系统造成冲击,不建议用户在大量MAC地址频繁变化的情况下开启本功能。
# 开启二层以太网接口的MAC地址软件学习功能。
[Sysname-Ten-GigabitEthernet1/0/1] l2vpn mac-address software-learning enable
learning mode disable命令用来关闭以太网服务实例的MAC地址自动学习功能。
undo learning mode命令用来开启以太网服务实例的MAC地址自动学习功能。
undo learning mode
以太网服务实例的MAC地址自动学习功能处于开启状态
以太网服务实例视图
开启以太网服务实例的MAC地址自动学习功能前,需要先在该以太网服务实例关联的VSI视图下执行mac-learning enable命令,开启VSI的MAC地址学习功能。
当关闭以太网服务实例的MAC地址自动学习功能后,只能通过mac-address static命令添加静态本地MAC地址表项。
# 关闭以太网服务实例200的MAC地址自动学习功能。
[Sysname] vsi vpn1
[Sysname-vsi-vpn1] mac-learning enable
[Sysname-vsi-vpn1] quit
[Sysname-Ten-GigabitEthernet1/0/1-srv200] learning mode disable
·     mac-address static
·     mac-learning enable
mac-address mac-learning priority命令用来配置以太网服务实例的MAC地址学习优先级。
undo mac-address mac-learning priority命令用来恢复缺省情况。
mac-address mac-learning priority { high | low }
MAC地址学习优先级为低优先级。
以太网服务实例视图
high:指定MAC地址学习优先级为高优先级。
low:指定MAC地址学习优先级为低优先级。
只有以太网服务实例与VSI关联后,本命令才会生效。
以太网服务实例(即AC)的MAC地址学习功能分为两个优先级:高优先级和低优先级。对于低优先级的AC,在学习MAC地址时需要查看高优先级AC是否已经学到该MAC地址,如果已经学到,则不允许学习该MAC地址;对于高优先级的AC,在学习MAC地址时如果已经有低优先级的AC或其他高优先级的AC学习到该MAC地址,则覆盖之前的MAC地址表项。
# 配置接口Ten-GigabitEthernet1/0/1上以太网服务实例1的MAC地址学习优先级为高优先级。
[Sysname-Ten-GigabitEthernet1/0/1] service-instace 1
[Sysname-Ten-GigabitEthernet1/0/1-srv1] mac-address mac-learning priority high
mac-address static命令用来添加静态MAC地址表项。
undo mac-address static命令用来删除指定的静态MAC地址表项。
mac-address static mac-address { interface interface-type interface-number service-instance instance-id | interface tunnel tunnel-number } vsi vsi-name
undo mac-address static [ mac-address ] [ interface interface-type interface-number service-instance instance-id | interface tunnel tunnel-number ] vsi vsi-name
不存在静态的MAC地址表项。
mac-address:MAC地址,格式为H-H-H,不支持组播MAC地址和全0的MAC地址。在配置时,用户可以省去MAC地址中每段开头的“0”,例如输入“f-e2-1”即表示输入的MAC地址为“000f-00e2-0001”。
interface interface-type interface-number service-instance instance-id:指定本地MAC地址对应的AC。interface-type interface-number为接口类型和接口编号;instance-id为以太网服务实例的编号,取值范围为1~4096。
interface tunnel tunnel-number:指定远端MAC地址对应的VXLAN隧道接口。tunnel-number为VXLAN隧道接口的编号,只能指定设备上已创建的Tunnel接口的编号。
vsi vsi-name:指定MAC地址所属的VSI。vsi-name表示VSI的名称,为1~31个字符的字符串,区分大小写。
本地MAC表项是指VTEP连接的本地站点内虚拟机的MAC地址。本地MAC地址既可以通过本命令静态配置,也可以通过报文中的源MAC地址动态学习。静态配置的本地MAC地址表项优先级高于源MAC地址动态学习的表项。
远端MAC地址是指VTEP连接的远端站点内虚拟机的MAC地址。远端MAC地址既可以通过本命令静态配置,也可以通过报文中的源MAC地址动态学习。静态配置的远端MAC地址表项优先级高于源MAC地址动态学习的表项。
对于本地MAC地址表项,本命令中指定的以太网服务实例必须与指定的VSI关联,且该VSI必须已经创建,否则配置将失败;对于远端MAC地址表项,interface tunnel interface-number参数指定的隧道接口必须与vsi vsi-name参数指定的VSI对应的VXLAN关联,且该VXLAN必须已经创建,否则配置将失败。
建议不要将EVPN动态创建的隧道接口指定为远端MAC地址对应的VXLAN隧道接口。否则,配置恢复时,EVPN会重新创建隧道,隧道接口的编号可能发生变化,从而导致静态远端MAC地址表项的配置无法恢复。
# 添加一条静态远端MAC地址表项:MAC地址为000f-e201-0101,VXLAN隧道接口为Tunnel1,MAC地址所属的VSI为vsi1。
[Sysname] mac-address static 000f-e201-0101 interface tunnel 1 vsi vsi1
# 添加一条静态本地MAC地址表项:MAC地址为000f-e201-0102,AC为接口Ten-GigabitEthernet1/0/1上的以太网服务实例1,MAC地址所属的VSI为vsi1。
[Sysname] mac-address static 000f-e201-0102 interface ten-gigabitethernet 1/0/1 service-instance 1 vsi vsi1
·     vxlan tunnel mac-learning disable
mac-learning enable命令用来开启VSI的MAC地址学习功能。
undo mac-learning enable命令用来关闭VSI的MAC地址学习功能。
mac-learning enable
VSI的MAC地址学习功能处于开启状态。
VSI视图
如果关闭了VSI的MAC地址学习功能,则设备接收到该VSI内的报文后不会学习该报文的源MAC地址。
# 关闭名为vpn1的VSI的MAC地址学习功能。
[Sysname] vsi vpn1
[Sysname-vsi-vpn1] undo mac-learning enable
·     display l2vpn vsi
1.1.28  mac-based ac
mac-based ac命令用来开启动态创建的以太网服务实例匹配MAC地址功能。
undo mac-based ac命令用来关闭动态创建的以太网服务实例匹配MAC地址功能。
mac-based ac
undo mac-based ac
动态创建的以太网服务实例匹配MAC地址功能处于关闭状态,即动态创建的以太网服务实例只匹配VLAN。
二层以太网接口视图
二层聚合接口视图
802.1X或MAC地址认证为用户下发授权VSI、Guest VSI、Auth-Fail VSI或Critical VSI后,将用户信息(接入端口、所属VLAN、MAC地址等)及VSI信息通知给VXLAN。VXLAN根据用户信息动态创建以太网服务实例,并将其与VSI关联。802.1X和MAC地址认证的详细介绍,请参见“安全配置指导”中的“802.1X”和“MAC地址认证”。
动态创建的以太网服务实例可以通过匹配MAC地址方式判断接口接收到的报文是否属于该AC,只有报文携带的VLAN ID、源MAC地址分别与太网服务实例匹配的VLAN ID、MAC地址相同,报文才属于该AC。
采用MAC地址方式,必须采用MAC地址认证或基于MAC接入控制的802.1X认证,并开启动态创建的以太网服务实例匹配MAC地址功能。
本命令仅对动态创建的以太网服务实例生效。通过service-instance命令创建的静态以太网服务实例只能通过encapsulation命令配置匹配的VLAN ID,不能匹配MAC地址。
若接口下已存在动态创建的以太网服务实例,则不能通过本命令修改动态创建以太网服务实例匹配MAC地址功能的开启、关闭状态。
# 开启动态创建的以太网服务实例匹配MAC地址功能。
[Sysname-Ten-GigabitEthernet1/0/1] mac-based ac
reserved vxlan命令用来配置保留VXLAN。
undo reserved vxlan命令用来恢复缺省情况。
reserved vxlan vxlan-id
undo reserved vxlan
未指定保留VXLAN。
vxlan-id:保留VXLAN的ID,取值范围为0~16777215。
只能在系统视图下配置一个全局保留VXLAN,该VXLAN不能与VSI下创建的VXLAN相同。
# 配置保留VXLAN为VXLAN 10000。
[Sysname] reserved vxlan 10000
reset arp suppression vsi命令用来清除VSI的ARP泛洪抑制表项。
reset arp suppression vsi [ name vsi-name ]
name vsi-name:清除指定VSI的ARP泛洪抑制表项。vsi-name表示VSI的名称,为1~31个字符的字符串,区分大小写。如果不指定本参数,则清除所有VSI的ARP泛洪抑制表项。
# 清除所有VSI的ARP泛洪抑制表项。
<Sysname> reset arp suppression vsi
This command will delete all entries. Continue? [Y/N]:y
reset ipv6 nd suppression vsi命令用来清除VSI的ND泛洪抑制表项。
reset ipv6 nd suppression vsi [ name vsi-name ]
name vsi-name:清除指定VSI的ND泛洪抑制表项。vsi-name表示VSI的名称,为1~31个字符的字符串,区分大小写。如果不指定本参数,则清除所有VSI的ND泛洪抑制表项。
# 清除所有VSI的ND泛洪抑制表项。
<Sysname> reset ipv6 nd suppression vsi
reset l2vpn mac-address命令用来清除通过源MAC地址动态学习的MAC地址表项。
reset l2vpn mac-address [ vsi vsi-name ]
vsi vsi-name:清除指定VSI动态学习的MAC地址表项。vsi-name表示VSI的名称,为1~31个字符的字符串,区分大小写。如果不指定本参数,则清除所有VSI动态学习的MAC地址表项。
VSI通过源MAC地址学习到错误的MAC地址表项,或学习的MAC地址表项数目达到最大值时,可以执行本命令,以便重新学习MAC地址表项。
# 清除名为vpn1的VSI通过源MAC地址动态学习的MAC地址表项。
<Sysname> reset l2vpn mac-address vsi vpn1
·     display l2vpn mac-address vsi
reset l2vpn statistics ac命令用来清除AC的报文统计信息。
reset l2vpn statistics ac [ interface interface-type interface-number service-instance instance-id ]
interface interface-type interface-number:清除指定二层接口上以太网服务实例的报文统计信息。interface-type interface-number表示接口类型和接口编号。
service-instance instance-id:清除指定以太网服务实例的报文统计信息。instance-id表示以太网服务实例的ID,取值范围为1~4096。
执行本命令时,如果未指定任何参数,则清除所有AC的报文统计信息。
# 清除接口Ten-GigabitEthernet1/0/1上以太网服务实例1的报文统计信息。
<Sysname> reset l2vpn statistics ac interface ten-gigabitethernet 1/0/1 service-instance 1
·     display l2vpn service-instance verbose
·     statistics enable (Ethernet service instance view)
reset l2vpn statistics vsi命令用来清除VSI的报文统计信息。
reset l2vpn statistics vsi [ name vsi-name ]
name vsi-name:清除指定VSI的报文统计信息。vsi-name表示VSI的名称,为1~31个字符的字符串,区分大小写。如果不指定本参数,则清除所有VSI的信息。
# 清除本设备上所有VSI报文统计信息。
<Sysname> reset l2vpn statistics vsi
·     statistics enable (VSI view)
1.1.35  restrain
restrain命令用来配置VSI的广播、组播或未知单播抑制带宽。
undo restrain命令用来恢复缺省情况。
restrain { broadcast | multicast | unknown-unicast } bandwidth
undo restrain { broadcast | multicast | unknown-unicast }
未配置VSI内广播、组播、未知单播的抑制带宽,即不限制VSI内的流量不限制。
VSI视图
broadcast:配置VSI的广播抑制带宽。
multicast:配置VSI的组播抑制带宽。
unknown-unicast:配置VSI的未知单播抑制带宽。未知单播报文是指在MAC地址表中不存在目的MAC地址对应表项的单播报文。
bandwidth:VSI的广播、组播或未知单播的抑制带宽值,对于Release 2612P02以前的版本,本参数取值范围为0、64~4194303;对于Release 2612P02及以上版本,本参数取值范围为0、64~167772159,单位为kbps。取值为0表示关闭泛洪功能,即不转发广播、组播或未知单播报文。
当VXLAN隧道入方向的广播、组播或未知单播流量超过配置的抑制带宽值时,将丢弃超过该值的广播、组播或未知单播流量。
如果在VSI视图下同时执行了restrain命令和selective-flooding命令,则restrain命令只对非选择性泛洪的流量生效。
如果在VSI视图下同时执行了restrain命令和flooding disable命令且通过restrain命令配置的抑制带宽为0,则仅restrain命令生效。若通过restrain命令配置的抑制带宽为非0值,则两个功能同时生效。
# 配置名为vpn1的VSI的广播、组播、未知单播抑制带宽均为100kbps。
[Sysname] vsi vpn1
[Sysname-vsi-vpn1] restrain broadcast 100
[Sysname-vsi-vpn1] restrain multicast 100
[Sysname-vsi-vpn1] restrain unknown-unicast 100
·     display l2vpn vsi
rewrite inbound tag命令用来配置入方向报文的处理规则。
undo rewrite inbound tag命令用来恢复缺省情况。
rewrite inbound tag { remark 1-to-1 s-vid vlan-id | strip s-vid }
不对入方向报文进行处理
以太网服务实例视图
remark:表示映射标签。
1-to-1:表示1:1标签映射,即将原有报文中的指定标签映射为指定的值。
s-vid:表示外层标签。
vlan-id:表示VLAN的编号,取值范围为1~4094。
strip:表示剥离标签。
配置本命令时,需要注意的是:
·     以太网服务实例的接入模式必须配置为Ethernet模式。
·     请勿配置以太网服务实例的报文匹配规则为encapsulation { default | tagged | untagged }。
·     请勿配置内层和外层VLAN tag相同的以太网服务实例报文匹配规则。
·     同一台设备上,如果某个以太网服务实例上配置了rewrite inbound tag命令,则与其关联相同VSI的以太网服务实例上不能配置rewrite outbound tag命令,反之亦然。
如果需要对入方向报文的VLAN tag进行处理,必须先配置本命令,再执行xconnect vsi命令将以太网服务实例与VSI关联。
不能通过重复执行本命令修改入方向报文的处理规则。如需修改入方向报文的处理规则,请先通过undo rewrite inbound tag命令删除入方向报文的处理规则,再执行rewrite inbound tag命令。
# 在二层以太网接口Ten-GigabitEthernet1/0/1的服务实例1上配置报文匹配规则和处理规则如下:对外层VLAN标签为10的入方向报文,将外层标签映射为VLAN标签100。
[Sysname-Ten-GigabitEthernet1/0/1-srv1] encapsulation s-vid 10
[Sysname-Ten-GigabitEthernet1/0/1-srv1] rewrite inbound tag remark 1-to-1 s-vid 100
rewrite outbound tag命令用来配置出方向报文的处理规则。
undo rewrite outbound tag命令用来恢复缺省情况。
rewrite outbound tag nest s-vid vlan-id
不对出方向报文进行处理
以太网服务实例视图
nest:表示添加标签。
s-vid:表示外层标签。
配置本命令时,需要注意的是:
·     如果报文不携带VLAN tag,则对该报文添加本命令中配置的VLAN tag;如果报文携带一层VLAN tag,则将该报文携带的VLAN tag替换为本命令中配置的VLAN tag;如果报文携带两层VLAN tag,则该命令对该报文不生效。
·     同一台设备上,如果某个以太网服务实例上配置了rewrite outbound tag命令,则与其关联相同VSI的以太网服务实例上不能配置rewrite inbound tag命令,反之亦然。
如果需要对出方向报文的VLAN tag进行处理,必须先配置本命令,再执行xconnect vsi命令将以太网服务实例与VSI关联。
不能通过重复执行本命令修改出方向报文的处理规则。如需修改出方向报文的处理规则,请先通过undo rewrite outbound tag命令删除出方向报文的处理规则,再执行rewrite outbound tag命令。
# 在二层以太网接口Ten-GigabitEthernet1/0/1的服务实例1上配置报文匹配规则和处理规则如下:对外层VLAN标签为10的出方向报文剥离其外层标签。
[Sysname-Ten-GigabitEthernet1/0/1-srv1] rewrite outbound tag nest s-vid 100
selective-flooding mac-addres命令用来配置VSI选择性泛洪的MAC地址。
undo selective-flooding mac-addres命令用来删除VSI的选择性泛洪MAC地址。
selective-flooding mac-addres mac-addres
undo selective-flooding mac-addres mac-addres
不存在VSI选择性泛洪MAC地址。
VSI视图
mac-address:选择性泛洪的MAC地址。该MAC地址不能为全F。
通过flooding disable命令关闭VSI的泛洪功能后,为了将某些单播或组播MAC地址的数据帧泛洪到远端站点以保证某些业务的流量在站点间互通,可以配置选择性泛洪的MAC地址。当数据帧的目的MAC地址匹配选择性泛洪的MAC地址时,该数据帧可以泛洪到远端站点。
建议不要在VSI视图下同时执行selective-flooding mac-addres命令和bandwidth命令,以免影响报文的正常转发。
# 在VSI vsi1下配置选择性泛洪的MAC地址为000f-e201-0101。
[Sysname] vsi vsi1
[Sysname-vsi-vsi1] selective-flooding mac-address 000f-e201-0101
·     flooding disable
service-instance命令用来创建以太网服务实例,并进入以太网服务实例视图。如果指定的以太网服务实例已经存在,则直接进入以太网服务实例视图。
undo service-instance命令用来删除指定的以太网服务实例。
undo service-instance instance-id
不存在以太网服务实例。
二层以太网接口视图
二层聚合接口视图
instance-id:以太网服务实例的编号,取值范围为1~4096。
# 在二层以太网接口Ten-GigabitEthernet1/0/1上创建以太网服务实例1,并进入以太网服务实例1的视图。
1.1.40  shutdown
shutdown命令用来关闭VSI。
undo shutdown命令用来开启VSI。
shutdown
VSI处于开启状态。
VSI视图
关闭VSI后,该VSI将不能提供二层交换服务。
关闭VSI功能通常用于暂时禁用二层交换服务,但还需要再次启用该服务的场景。关闭VSI后,该VSI所有已存在的配置保持不变。在关闭状态下还可以对VSI进行配置。VSI再次被开启后,基于最新的配置提供二层交换服务。
# 关闭名为vpn1的VSI。
[Sysname] vsi vpn1
[Sysname-vsi-vpn1] shutdown
·     display l2vpn vsi
statistics enable命令用来开启以太网服务实例的报文统计功能。
undo statistics enable命令用来关闭以太网服务实例的报文统计功能。
statistics enable
以太网服务实例的报文统计功能处于关闭状态。
以太网服务实例视图
只有为以太网服务实例配置了报文匹配方式并绑定了VSI实例,报文统计功能才会生效。如果在报文统计过程中修改报文匹配方式或绑定的VSI实例,则报文统计重新开始。
# 开启接口Ten-GigabitEthernet1/0/1上以太网服务实例200的报文统计功能。
[Sysname-Ten-GigabitEthernet1/0/1-srv200] statistics enable
仅R2612及以上版本支持本命令。
statistics enable命令用来开启手工创建VXLAN隧道或VXLAN-DCI隧道的报文统计功能。
undo statistics enable命令用来关闭手工创建VXLAN隧道或VXLAN-DCI隧道的报文统计功能。
statistics enable
手工创建VXLAN隧道和VXLAN-DCI隧道的报文统计功能处于关闭状态。
VXLAN模式或VXLAN-DCI模式的Tunnel接口视图
# 开启手工创建VXLAN隧道的报文统计功能。
[Sysname] interface tunnel 0 mode vxlan
[Sysname-Tunnel0] statistics enable
·     display interface tunnel(三层技术-IP业务命令参考/隧道)
·     reset counters interface tunnel(三层技术-IP业务命令参考/隧道)
·     tunnel statistics vxlan auto
statistics enable命令用来开启VSI的报文统计功能。
undo statistics enable命令用来关闭VSI的报文统计功能。
statistics enable
VSI的报文统计功能处于关闭状态。
VSI视图
# 开启名为vsi1的VSI的报文统计功能。
[Sysname] vsi vsi1
[Sysname-vsi-vsi1] statistics enable
·     display l2vpn vsi verbose
·     reset l2vpn statistics vsi
1.1.44  tunnel
tunnel命令用来配置VXLAN与VXLAN隧道关联。
undo tunnel命令用来取消VXLAN与指定隧道的关联。
tunnel { tunnel-number [ backup-tunnel tunnel-number | flooding-proxy ] | all }
undo tunnel { tunnel-number | all }
VXLAN未关联VXLAN隧道。
VXLAN视图
tunnel-number:关联指定的VXLAN隧道。tunnel-number为隧道接口的编号,取值范围为0~15359。指定的隧道必须是VXLAN模式的隧道。
backup-tunnel tunnel-number:指定备用隧道。tunnel-number为隧道接口的编号,取值范围为0~15359。指定的隧道必须是VXLAN模式的隧道。
flooding-proxy:开启隧道的泛洪代理功能,即该VXLAN内的广播、组播和未知单播流量将通过该Tunnel发送到代理服务器,由代理服务器进行复制并转发到其它远端VTEP。如果未指定本参数,则表示关闭隧道的泛洪代理功能。
all:关联所有VXLAN隧道。
在VXLAN组网中,用户可以手工将VXLAN与VXLAN隧道关联。VTEP接收到某个VXLAN的泛洪流量后,如果采用单播路由泛洪方式,则VTEP将在与该VXLAN关联的所有VXLAN隧道上发送该流量,以便将流量转发给所有的远端VTEP。
一个VXLAN可以关联多条VXLAN隧道;一条VXLAN隧道可以关联多个VXLAN。
执行本命令时,可以同时指定与VXLAN关联的主用VXLAN隧道和备用VXLAN隧道。备用VXLAN隧道为主用VXLAN隧道提供保护。当主用VXLAN隧道down时,VXLAN将启用备用VXLAN隧道。
配置泛洪代理功能时,需要注意:
·     不能通过重复执行本命令开启或关闭VXLAN隧道的泛洪代理功能。如需修改隧道的泛洪代理功能状态,请先通过undo tunnel命令取消VXLAN与指定隧道的关联,再执行tunnel命令。
·     一个VSI下可以配置多条开启泛洪代理功能的VXLAN隧道,第一个创建的VXLAN隧道作为主代理隧道,负责转发该VXLAN内的广播、组播和未知单播流量,其他隧道作为备用代理隧道,不转发流量。
只能通过tunnel tunnel-number命令逐一将VXLAN与每条VXLAN-DCI隧道关联。不能通过tunnel all命令将VXLAN与所有VXLAN-DCI隧道关联。
执行tunnel all命令关联所有VXLAN隧道后,不能通过undo tunnel tunnel-number命令取消关联其中的一条VXLAN隧道,只能执行undo tunnel all命令同时取消关联所有的VXLAN隧道。
# 配置VXLAN隧道Tunnel1和Tunnel2与VXLAN 10000关联。
[Sysname] vsi vpna
[Sysname-vsi-vpna] vxlan 10000
[Sysname-vsi-vpna-vxlan-10000] tunnel 1
[Sysname-vsi-vpna-vxlan-10000] tunnel 2
·     display vxlan tunnel
tunnel bfd enable命令用来开启隧道的BFD检测功能。
undo tunnel bfd enable命令用来关闭隧道的BFD检测功能。
tunnel bfd enable destination-mac mac-address
隧道的BFD检测功能处于关闭状态。
VXLAN模式Tunnel接口视图
destination-mac mac-address:指定BFD报文的目的MAC地址为VXLAN隧道对端VTEP的桥MAC地址或组播MAC地址。mac-address为BFD报文的目的MAC地址,格式为H-H-H。在配置时,用户可以省去MAC地址中每段开头的“0”,例如输入“f-e2-1”即表示输入的MAC地址为“000f-00e2-0001”。
隧道的BFD检测功能用来避免VTEP设备无法感知或无法及时感知隧道的故障,导致报文转发失败。隧道两端的VTEP设备上均需要开启该功能。VTEP设备周期性地通过VXLAN隧道向配置的目的MAC地址发送单跳BFD控制报文。如果在5秒内未接收到对端发送的BFD控制报文,则将隧道状态置为Defect,隧道接口状态仍为Up。VXLAN隧道故障排除后隧道状态将自动恢复为Up。
执行本命令的同时,还需要在系统视图下执行reserved vxlan命令配置保留VXLAN。否则,BFD会话无法up。
本命令不能与uRPF功能同时配置,否则,BFD会话无法up。关于uRPF功能的详细介绍请参见“安全配置指导”中的“uRPF”。
# 开启VXLAN隧道Tunnel9的BFD检测功能,并指定BFD报文的目的MAC地址为1-1-1。
[Sysname] interface tunnel 9 mode vxlan
[Sysname-Tunnel9] tunnel bfd enable destination-mac 1-1-1
tunnel global source-address命令用来配置VXLAN隧道的全局源地址。
undo tunnel global source-address命令用来恢复缺省情况。
tunnel global source-address ip-address
未配置VXLAN隧道的全局源地址。
ip-address:隧道的全局源IP地址。
目前仅VXLAN隧道支持全局源地址,其它类型的隧道(包括VXLAN-DCI隧道)不支持全局源地址。
如果隧道下未配置源地址或源接口,则隧道会使用全局源地址作为隧道的源地址。
采用OVSDB对VTEP设备进行部署和控制时,用户不能在VXLAN隧道的Tunnel接口下手工指定源地址,只能通过本命令指定全局源地址,否则会影响控制器对VTEP设备的管理。
# 配置VXLAN隧道的全局源地址为1.1.1.1。
[Sysname] tunnel global source-address 1.1.1.1
仅R2612及以上版本支持本命令。
tunnel statistics vxlan auto命令用来开启自动VXLAN隧道的报文统计功能。
undo tunnel statistics vxlan auto命令用来关闭自动VXLAN隧道的报文统计功能。
自动VXLAN隧道的报文统计功能处于关闭状态。
开启本功能后,设备会统计已经创建的自动VXLAN隧道上转发的流量,也会对之后创建的自动VXLAN隧道进行流量统计,直到删除VXLAN隧道或关闭本功能。
目前,开启本功能后,可以统计EVPN和OVSDB自动创建的VXLAN隧道上的流量。
# 开启自动VXLAN隧道的报文统计功能。
[Sysname] tunnel statistics vxlan auto
·     statistics enable (Tunnel interface view)
1.1.48  vsi
vsi命令用来创建一个VSI,并进入VSI视图。如果指定的VSI已经存在,则直接进入VSI视图。
undo vsi命令用来删除指定的VSI。
vsi vsi-name
undo vsi vsi-name
不存在VSI。
vsi-name:VSI的名称,为1~31个字符的字符串,区分大小写。
VSI是VTEP上为一个VXLAN提供二层交换服务的虚拟交换实例。VSI可以看做是VTEP上的一台基于VXLAN进行二层转发的虚拟交换机,它具有传统以太网交换机的所有功能,包括源MAC地址学习、MAC地址老化、泛洪等。VSI与VXLAN一一对应。
# 创建名为vxlan10的VSI,并进入VSI视图。
[Sysname] vsi vxlan10
[Sysname-vsi-vxlan10]
·     display l2vpn vsi
1.1.49  vxlan
vxlan命令用来创建VXLAN,并进入VXLAN视图。如果指定的VXLAN已经存在,则直接进入VXLAN视图。
undo vxlan命令用来恢复缺省情况。
vxlan vxlan-id
undo vxlan
不存在VXLAN。
VSI视图
vxlan-id:VXLAN ID,取值范围为0~16777215。
在一个VSI下只能创建一个VXLAN。不同VSI下创建的VXLAN,其VXLAN ID不能相同。
# 在名称为vpna的VSI下创建编号为10000的VXLAN,并进入VXLAN视图。
[Sysname] vsi vpna
·     vsi
仅Release 2612P02及以上版本支持本命令。
vxlan default-decapsulation命令用来配置缺省解封装指定VXLAN报文功能。
undo vxlan default-decapsulation命令用来恢复缺省情况。
vxlan default-decapsulation source interface interface-type interface-number
undo vxlan default-decapsulation source interface
缺省解封装指定VXLAN报文功能处于关闭状态。
source interface interface-type interface-number:指定缺省解封装VXLAN报文的源接口的接口类型和接口编号。
在仅建立单向VXLAN隧道的组网中,本端未建立指向对端的VXLAN隧道,对端建立指向本端的VXLAN隧道时,会导致本端从对端接收的VXLAN报文无法解封装而被丢弃。配置本功能后,本端可以解封装所有收到的目的地址为指定接口下配置的IP地址的VXLAN报文。
通过本命令指定的源接口必须是单向VXLAN隧道目的地址在本端对应的接口,且本端至少存在一条以该接口下的IP地址为源IP的VXLAN隧道。
只有当指定的接口下配置IP地址时,本功能才生效。
# 配置缺省解封装指定VXLAN报文功能。
[Sysname] vxlan default-decapsulation source interface ten-gigabitethernet 1/0/1
vxlan invalid-udp-checksum discard命令用来配置丢弃UDP校验和检查失败的VXLAN报文。
undo vxlan invalid-udp-checksum discard命令用来恢复缺省情况。
不会检查VXLAN报文的UDP校验和。
VTEP对二层数据帧进行封装时,将UDP校验和设置为0。缺省情况下,VTEP接收到VXLAN报文后,不会检查报文的UDP校验和。如果在VTEP上执行了本命令,则该VTEP会对接收的VXLAN报文的UDP校验和进行检查,校验和检查失败的报文将被丢弃。
为了兼容其他厂商的设备,UDP检验和为0和UDP检验和正确的报文均能通过VTEP的检查,被VTEP接收。
# 配置丢弃UDP校验和检查失败的VXLAN报文。
[Sysname] vxlan invalid-udp-checksum discard
·     vxlan invalid-vlan-tag discard
vxlan invalid-vlan-tag discard命令用来配置丢弃内层数据帧含有VLAN tag的VXLAN报文。
undo vxlan invalid-vlan-tag discard命令用来恢复缺省情况。
不会检查VXLAN报文内层封装的以太网数据帧是否携带VLAN tag。
远端VTEP上通过xconnect vsi命令的access-mode参数配置接入模式为ethernet时,VXLAN报文可能携带VLAN tag。这种情况下建议不要在本端VTEP上执行vxlan invalid-vlan-tag discard命令,以免错误地丢弃报文。
# 配置丢弃内层数据帧含有VLAN tag的VXLAN报文。
[Sysname] vxlan invalid-vlan-tag discard
·     vxlan invalid-udp-checksum discard
·     xconnect vsi
vxlan local-mac report命令用来配置VXLAN增删本地MAC地址时记录日志。
undo vxlan local-mac report命令用来恢复缺省情况。
VXLAN增删本地MAC地址时不会记录日志信息。
执行vxlan local-mac report命令后,VXLAN增加或删除本地MAC地址时,将产生日志信息。生成的日志信息将被发送到设备的信息中心,通过设置信息中心的参数,决定日志信息的输出规则(即是否允许输出以及输出方向)。
# 配置VXLAN增删本地MAC地址时记录日志。
[Sysname] vxlan local-mac report
vxlan tunnel mac-learning disable命令用来关闭远端MAC地址自动学习功能。
undo vxlan tunnel mac-learning disable命令用来开启远端MAC地址自动学习功能。
远端MAC地址自动学习功能处于开启状态。
如果网络中存在攻击,为了避免学习到错误的远端MAC地址,可以通过本命令手工关闭远端MAC地址自动学习功能。
# 关闭远端MAC地址自动学习功能。
[Sysname] vxlan tunnel mac-learning disable
vxlan udp-port命令用来配置VXLAN报文的目的UDP端口号。
undo vxlan udp-port命令用来恢复缺省情况。
vxlan udp-port port-number
undo vxlan udp-port
VXLAN报文的目的UDP端口号为4789。
port-number:VXLAN报文的目的UDP端口号,取值范围为1~65535。建议不要将VXLAN报文的目的UDP端口号配置为知名端口,即1~1023之间的端口。
属于同一个VXLAN的VTEP设备上需要配置相同的UDP端口号。
# 配置VXLAN报文的目的UDP端口号为6666。
[Sysname] vxlan udp-port 6666
undo vxlan vlan-based命令用来关闭VLAN关联VXLAN功能。
vxlan vlan-based
VLAN关联VXLAN功能处于关闭状态。
可以通过如下两种方式将指定VLAN的数据帧映射到特定VXLAN:
·     配置以太网服务实例关联VSI:在以太网服务实例下配置报文匹配规则匹配指定VLAN的数据帧后,将该以太网服务实例与VSI关联,可以实现将接口上收到的指定VLAN的数据帧映射到VSI对应的VXLAN。
·     配置VLAN关联VXLAN:执行本命令开启VLAN关联VXLAN功能,并在VLAN视图下执行vxlan vni命令配置与该VLAN关联的VXLAN后,如果存在属于该VLAN的接口,则自动在该接口上创建编号为当前VLAN ID、匹配外层VLAN tag为当前VLAN ID的以太网服务实例,并将该以太网服务实例与指定VXLAN对应的VSI关联。
上述两种方式不能同时配置。
# 开启VLAN关联VXLAN功能。
[Sysname] vxlan vlan-based
1.1.57  vxlan vni
vxlan vni命令用来配置VLAN与指定的VXLAN关联。
undo vxlan vni命令用来取消VLAN与VXLAN关联。
vxlan vni vxlan-id
undo vxlan vni
未指定与VLAN关联的VXLAN。
VLAN视图
vxlan-id:与VLAN关联的VXLAN ID,取值范围为0~16777215。
配置本命令前,需要先执行vxlan vlan-based命令开启VLAN关联VXLAN功能。
不能通过本命令配置VLAN 1与VXLAN关联。
本命令中指定的VXLAN ID不能为EVPN组网中的L3VNI。
本命令中指定的VXLAN ID可以不存在。在用户创建该VXLAN时,会自动创建AC,并将AC与VXLAN关联。
# 配置VLAN 10关联VXLAN 100。
[Sysname] vlan 10
[Sysname-vlan10] vxlan vni 100
·     vxlan vlan-based
vxlan-over-vxlan enable命令用来在接口上开启VXLAN over VXLAN功能。
undo vxlan-over-vxlan enable命令用来关闭接口的VXLAN over VXLAN功能。
VXLAN over VXLAN功能处于关闭状态。
二层以太网接口视图
二层聚合接口视图
在报文接收接口上开启VXLAN over VXLAN功能后,设备不会对VXLAN报文进行解封装。如果同时在该接口上创建以太网服务实例,并将其配置为AC,则设备可以对VXLAN报文再次进行VXLAN封装,从而实现VXLAN封装的嵌套。
# 在接口Ten-GigabitEthernet1/0/1上开启VXLAN over VXLAN功能。
[Sysname-Ten-GigabitEthernet1/0/1] vxlan-over-vxlan enable
·     vxlan udp-port
1.1.59  xconnect vsi
xconnect vsi命令用来将AC与VSI关联。
undo xconnect vsi命令用来恢复缺省情况。
xconnect vsi vsi-name [ access-mode { ethernet | vlan } ] [ track track-entry-number&<1-3> ]
undo xconnect vsi
AC未关联VSI。
以太网服务实例视图
access-mode:指定接入模式,缺省为VLAN接入模式。
ethernet:指定接入模式为Ethernet。
vlan:指定接入模式为VLAN。
track track-entry-number&<1-3>:配置AC与指定Track项联动。track-entry-number为Track项的序号,取值范围为1~1024;&<1-3>表示前面的参数最多可以输入3次。指定本参数后,仅当关联的Track项中至少有一个状态为positive时,AC的状态才会up;否则,AC的状态为down。
某个接口的以太网服务实例视图下执行本命令后,从该接口接收到的、符合以太网服务实例报文匹配规则的报文,将通过查找关联VSI的MAC地址表进行转发。
在以太网服务实例下配置该命令前,必须先配置encapsulation命令。
接入模式分为以下两种:
·     VLAN接入模式:从本地站点接收到的和发送给本地站点的以太网帧必须带有VLAN Tag。VTEP从本地站点接收到以太网帧后,删除该帧的所有VLAN Tag,再转发该数据帧;VTEP发送以太网帧到本地站点时,为其添加本地站点的VLAN Tag。采用该模式时,VTEP不会传递VLAN Tag信息,不同站点可以独立地规划自己的VLAN,不同站点的不同VLAN之间可以互通。
·     Ethernet接入模式:从本地站点接收到的和发送给本地站点的以太网帧可以携带VLAN Tag,也可以不携带VLAN Tag。VTEP从本地站点接收到以太网帧后,保持该帧的VLAN Tag信息不变,转发该数据帧;VTEP发送以太网帧到本地站点时,不会为其添加VLAN Tag。采用该模式时,VTEP会在不同站点间传递VLAN Tag信息,不同站点的VLAN需要统一规划,否则无法互通。
# 接口Ten-GigabitEthernet1/0/1下采用以太网服务实例200来匹配外层VLAN为200的报文,将该以太网服务实例与名为vpn1的VSI关联。
[Sysname] vsi vpn1
[Sysname-Ten-GigabitEthernet1/0/1-srv200] xconnect vsi vpn1
·     encapsulation
·     vsi
1.2  VXLAN IP网关配置命令
S6800系列交换机中,产品代码为LS-6800-32Q、LS-6800-2C、LS-6800-4C、LS-6800-54QF或LS-6800-54QT的机型不支持本功能。
arp distributed-gateway dynamic-entry synchronize命令用来开启分布式网关的动态ARP表项同步功能。
undo arp distributed-gateway dynamic-entry synchronize命令用来关闭分布式网关的动态ARP表项同步功能。
分布式网关的动态ARP表项同步功能处于关闭状态。
分布式VXLAN IP网关上开启本地代理ARP功能时,本地网关不会将目标IP地址为分布式网关VSI虚接口的ARP报文转发给其他网关,只有本地网关能够学习到ARP报文发送者的ARP表项。如果希望所有网关都能学习到该ARP表项,需要开启分布式网关的动态ARP表项同步功能。
分布式VXLAN IP网关之间也可以通过控制器或EVPN等在彼此之间同步ARP表项,此时无需开启本功能。
# 开启分布式网关的动态ARP表项同步功能。
[Sysname] arp distributed-gateway dynamic-entry synchronize
·     distributed-gateway local
·     local-proxy-arp enable(三层技术-IP业务命令参考/代理ARP)
1.2.2  arp send-rate
arp send-rate命令用来开启VSI虚接口的ARP报文发送限速功能。
undo arp send-rate命令用来关闭VSI虚接口的ARP报文发送限速功能。
arp send-rate pps
undo arp send-rate
VSI虚接口的ARP报文发送限速功能处于关闭状态。
VSI虚接口视图
pps:ARP报文发送限速速率,取值范围为1~500,单位为包每秒(pps)。
开启VSI虚接口的ARP报文发送限速功能后,如果VSI虚接口的ARP报文发送速率超过限制的值,则后续待发送的ARP报文将被丢弃,直到接口的APP发送速率低于限速速率。
虚拟机的报文处理能力较弱,通过本配置可以控制VTEP发往虚拟机的ARP报文速率,以免影响虚拟机工作。
# 配置VSI虚接口1的ARP报文发送限速为50pps。
<Sysname> system
[Sysname] interface vsi-interface 1
[Sysname-Vsi-interface1] arp send-rate 50
1.2.3  bandwidth
bandwidth命令用来配置接口的期望带宽。
bandwidth bandwidth-value
undo bandwidth
接口的期望带宽=接口的波特率÷1000(kbps)。
VSI虚接口视图
bandwidth-value:接口的期望带宽,取值范围为1~400000000,单位为kbps。
期望带宽供业务模块使用,不会对接口实际带宽造成影响。
# 配置接口VSI-interface100的期望带宽为10000kbps。
[Sysname] interface vsi-interface 100
[Sysname-Vsi-interface100] bandwidth 10000
1.2.4  default
default命令用来恢复接口的缺省配置。
default
VSI虚接口视图
# 将接口VSI-interface100恢复为缺省配置。
[Sysname-Vsi-interface100] default
This command will restore the default settings. Continue? [Y/N]:y
1.2.5  description
description命令用来配置接口的描述信息。
接口的描述信息为“接口名 Interface”,例如:Vsi-interface100 Interface。
VSI虚接口视图
text:接口的描述信息,为1~255个字符的字符串,区分大小写。
# 配置接口VSI-interface100的描述信息为“gateway for VXLAN 10”。
[Sysname-Vsi-interface100] description gateway for VXLAN 10
display interface vsi-interface命令用来显示VSI虚接口的相关信息。
display interface [ vsi-interface [ vsi-interface-id ] ] [ brief [ description | down ] ]
vsi-interface [ vsi-interface-id ]:指定VSI虚接口及其编号。vsi-interface-id为VSI虚接口的编号,只能指定设备上已创建的VSI虚接口的编号。如果不指定vsi-interface,则显示设备支持的所有接口的相关信息;如果指定vsi-interface,不指定vsi-interface-id,则显示所有VSI虚接口的信息。
brief:显示接口的概要信息。如果不指定该参数,则显示接口的详细信息。
down:显示当前物理状态为down的接口的信息以及down的原因。如果不指定该参数,则不会根据接口物理状态来过滤显示信息。
# 显示接口VSI-interface100的相关信息。
<Sysname> display interface vsi-interface 100
Vsi-interface100
Current state: UP
Line protocol state: UP
Description: Vsi-interface100 Interface
Bandwidth: 1000000 kbps
IP packet frame type: Ethernet II, hardware address: 0011-2200-0102
IPv6 packet frame type: Ethernet II, hardware address: 0011-2200-0102
Input (total):  0 packets, 0 bytes
Output (total):  0 packets, 0 bytes
表1-13 display interface vsi-interface命令显示信息描述表
Vsi-interface100
Current state
接口的物理状态和管理状态,取值包括:
·     DOWN:该接口的管理状态为开启,但物理状态为关闭
·     UP:该接口的管理状态和物理状态均为开启
Line protocol state
接口的链路层协议状态,取值包括:
·     UP:表示该接口的链路层协议状态为开启
·     UP(spoofing):表示该接口的链路层协议状态为开启,但实际可能没有对应的链路,或者所对应的链路不是永久存在而是按需建立
·     DOWN:表示该接口的链路层协议状态为关闭
接口的描述信息
Bandwidth
接口的期望带宽
接口的MTU
接口未配置IP地址,不能处理IP报文
Internet address
接口的主IP地址
IP报文发送帧格式
hardware address
硬件地址
(暂不支持)IPv6报文发送帧格式
Physical
接口的物理类型,取值为Unknown
baudrate
接口的波特率,单位为kbps
最近一次使用reset counters interface命令清除接口下的统计信息的时间(如果从设备启动一直未执行reset counters interface命令清除过该接口下的统计信息,则显示Never)
总计输入的报文数,总计输入的字节
总计输出的报文数,总计输出的字节
# 显示所有VSI虚接口的概要信息。
<Sysname> display interface vsi-interface brief
Protocol: (s) - spoofing
Interface            Link Protocol Primary IP      Description
Vsi100               DOWN DOWN     --
# 显示接口VSI-interface100的概要信息,包括用户配置的全部描述信息。
<Sysname> display interface vsi-interface 100 brief description
Brief information on interfaces in route mode:Brief information of interface(s) under route mode:
Vsi100               UP    UP      1.1.1.1         VSI-interface100
# 显示当前状态为down的接口的信息以及DOWN的原因。
Interface            Link   Cause
Vsi100               DOWN   Administratively
Vsi200               DOWN   Administratively
表1-14 display interface vsi-interface brief命令显示信息描述表
·     如果某接口的Link属性值为“ADM”,则表示该接口被管理员通过shutdown命令关闭,需要在该接口下执行undo shutdown命令才能恢复端口本身的物理状态
·     ‌(暂不支持)如果某接口的Link属性值为“Stby”,则表示该接口是一个处于Standby状态的备份接口,使用display interface-backup state命令可以查看该备份接口对应的主接口
如果某接口的Protocol属性值中带有“(s)”字符串,则表示该接口的网络层协议状态显示是UP的,但实际可能没有对应的链路,或者所对应的链路不是永久存在而是按需建立
接口名称缩写
Link
接口物理连接状态,取值包括:
·     UP:表示本链路物理上是连通的
·     DOWN:表示本链路物理上是不通的
·     ADM:表示本链路被管理员通过shutdown命令关闭,需要执行undo shutdown命令才能恢复接口本身的物理状态
Protocol
接口的链路层协议状态,取值包括:
·     UP (s):表示该接口的链路层协议状态为开启,但实际可能没有对应的链路,或者所对应的链路不是永久存在而是按需建立
Primary IP
接口主IP地址。取值为“--”时,表示接口尚未配置IP地址
接口的描述信息
Cause
接口物理连接状态为down的原因,取值为:
·     Administratively:表示本链路被手工关闭了(配置了shutdown命令),需要执行undo shutdown命令才能恢复真实的物理状态
·     Not connected:表示没有VSI关联该接口,或者关联该接口的VSI内没有AC或VXLAN隧道
·     reset counters interface vsi-interface
distributed-gateway local命令用来配置VSI虚接口为分布式网关接口。
undo distributed-gateway local命令用来恢复缺省情况。
VSI虚接口不是分布式网关接口。
VSI虚接口视图
在分布式VXLAN IP网关组网中,多个网关上同一VXLAN的VSI虚接口需要配置相同的IP地址。为了避免IP地址冲突,需要在VSI虚接口上执行本命令,以防止VSI虚接口上报地址冲突,导致VSI虚接口不可用。
# 配置接口Vsi-interface100为分布式网关接口。
[Sysname-Vsi-interface100] distributed-gateway local
gateway subnet命令用来配置VSI所属的子网网段。
undo gateway subnet命令用来删除VSI所属的子网网段。
gateway subnet { ipv4-address wildcard-mask | ipv6-address prefix-length }
undo gateway subnet { ipv4-address wildcard-mask | ipv6-address prefix-length }
未指定VSI所属的子网网段。
VSI视图
ipv4-address:IPv4子网网段地址,为点分十进制格式。
wildcard-mask:IPv4地址掩码的反码,即将IPv4地址的掩码取反(0变1,1变0)。例如:子网掩码255.0.0.0的反码为0.255.255.255。其中,反码中的“1”表示忽略IPv4地址中对应的位,“0”表示必须保留此位。
ipv6-address prefix-length:IPv6地址及前缀长度。prefix-length为IPv6前缀长度,取值范围为1~128。
在VSI视图下配置子网网段前,必须先为该VSI指定网关接口。取消为VSI指定网关接口时,会自动删除为该VSI指定的子网网段。
一个VSI视图下最多可以配置8个子网网段。
# 配置名称为vxlan的VSI所属的子网网段为100.0.10.0/24。
[Sysname] vsi vxlan
[Sysname-vsi-vxlan] gateway subnet 100.0.10.0 0.0.0.255
gateway vsi-interface命令用来为VSI指定网关接口。
undo gateway vsi-interface命令用来恢复缺省情况。
gateway vsi-interface vsi-interface-id
未指定VSI的网关接口。
VSI视图
vsi-interface-id:VSI网关虚接口的编号,取值范围为1~99999。
本命令中指定的VSI网关虚接口必须已经通过interface vsi-interface命令创建。如果将VSI虚接口指定为网关接口后,执行undo interface vsi-interface命令删除该VSI虚接口,则指定网关接口的配置也将删除。
一个VSI只能指定一个网关接口。
不同的VSI不能指定相同的网关接口。
# 为VSI指定网关接口为Vsi-interface100。
[Sysname] vsi vpna
[Sysname-vsi-vpna] gateway vsi-interface 100
·     interface vsi-interface
interface vsi-interface命令用来创建VSI虚接口,并进入VSI虚接口视图。如果指定的VSI虚接口已经存在,则直接进入VSI虚接口视图。
undo interface vsi-interface命令用来删除指定的VSI虚接口。
interface vsi-interface vsi-interface-id
undo interface vsi-interface vsi-interface-id
不存在VSI虚接口。
vsi-interface-id:VSI虚接口的编号,取值范围为1~99999。
如果通过gateway vsi-interface命令将VSI虚接口指定为网关接口后,执行undo interface vsi-interface命令删除该VSI虚接口,则指定网关接口的配置也将删除。
# 创建VSI虚接口100,并进入VSI虚接口视图。
·     gateway vsi-interface
ipv6 nd distributed-gateway dynamic-entry synchronize命令用来开启分布式网关的动态IPv6 ND表项同步功能。
undo ipv6 nd distributed-gateway dynamic-entry synchronize命令用来关闭分布式网关的动态IPv6 ND表项同步功能。
分布式网关的动态IPv6 ND表项同步功能处于关闭状态。
分布式VXLAN IP网关上开启本地ND代理功能时,本地网关不会将目标IP地址为分布式网关VSI虚接口的IPv6 ND报文转发给其他网关,只有本地网关能够学习到IPv6 ND报文发送者的ND表项。如果希望所有网关都能学习到该ND表项,需要开启分布式网关的动态IPv6 ND表项同步功能。
分布式VXLAN IP网关之间也可以通过控制器或EVPN等在彼此之间同步IPv6 ND表项,此时无需开启本功能。
# 开启分布式网关的动态IPv6 ND表项同步功能。
[Sysname] ipv6 nd distributed-gateway dynamic-entry synchronize
·     local-proxy-nd enable(三层技术-IP业务命令参考/IPv6基础)
1.2.12  mac-address
mac-address命令用来配置VSI虚接口的MAC地址。
undo mac-address命令用来恢复缺省情况。
mac-address mac-address
undo mac-address
同一设备上所有VSI虚接口的MAC地址均为一个固定的MAC地址,不同设备上VSI虚接口的MAC地址不同。
VSI虚接口视图
mac-address:MAC地址,形式为H-H-H。
# 配置VSI虚接口100的MAC地址为0001-0001-0001。
[Sysname-Vsi-interface100] mac-address 1-1-1
1.2.13  mtu
mtu命令用来配置接口的MTU值。
undo mtu命令用来恢复缺省情况。
mtu size
undo mtu
接口的MTU为1444字节。
VSI虚接口视图
为VSI虚接口配置的MTU值要至少比实际物理出接口的MTU值小36字节,以保证报文的正常转发。
# 配置接口VSI-interface100的MTU值为1430字节。
[Sysname-Vsi-interface100] mtu 1430
reset counters interface vsi-interface命令用来清除VSI虚接口的统计信息。
reset counters interface [ vsi-interface [ vsi-interface-id ] ]
vsi-interface [ vsi-interface-id ]:指定VSI虚接口及其编号。vsi-interface-id为VSI虚接口的编号,只能指定设备上已创建的VSI虚接口的编号。如果不指定vsi-interface,则清除设备支持的所有接口的统计信息;如果指定vsi-interface,不指定vsi-interface-id,则清除所有VSI虚接口的统计信息。
# 清除接口VSI-interface100的统计信息。
<Sysname> reset counters interface vsi-interface 100
·     display interface vsi-interface
1.2.15  shutdown
shutdown命令用来关闭VSI虚接口。
undo shutdown命令用来开启VSI虚接口。
shutdown
VSI虚接口均处于开启状态。
VSI虚接口视图
# 关闭接口VSI-interface100。
[Sysname-Vsi-interface100] shutdown
vtep group member local命令用来将本设备加入VXLAN IP网关保护组,并配置本设备的成员地址。
undo vtep group member local命令用来取消本设备加入指定的VXLAN IP网关保护组。
vtep group group-ip member local member-ip
undo vtep group group-ip member local
设备未加入VXLAN IP网关保护组。
group-ip:VXLAN IP网关保护组的VTEP IP地址,该地址必须是本设备上已经存在的地址。
member-ip:本设备在VXLAN IP网关保护组内的成员地址,该地址必须是设备上已经配置的地址。
成员地址不能和保护组的VTEP IP相同;同一个保护组中不同成员的成员地址也不能相同。
# 配置本设备加入VXLAN IP保护组,保护组的VTEP IP地址是1.1.1.1,本设备的成员地址为2.2.2.2。
[Sysname] vtep group 1.1.1.1 member local 2.2.2.2
·     vtep group member remote
vtep group member remote命令用来配置VXLAN IP网关保护组的成员地址列表。
undo vtep group member remote命令用来删除指定VXLAN IP网关保护组的成员地址列表。
vtep group group-ip member remote member-ip&<1-8>
undo vtep group group-ip member remote
未配置VXLAN IP网关保护组的成员地址列表。
group-ip:VXLAN IP网关保护组的VTEP IP地址。
member-ip&<1-8>:VXLAN IP网关保护组成员IP地址列表。&<1-8>表示最多可以输入8个IP地址,每个IP地址之间用空格分隔。
# 配置VXLAN IP网关保护组1.1.1.1包含的成员设备为2.2.2.2、3.3.3.3和4.4.4.4。
[Sysname] vtep group 1.1.1.1 member remote 2.2.2.2 3.3.3.3 4.4.4.4
·     vtep group member local
vxlan tunnel arp-learning disable命令用来关闭远端ARP自动学习功能。
undo vxlan tunnel arp-learning disable命令用来开启远端ARP自动学习功能。
远端ARP自动学习功能处于开启状态。
缺省情况下,设备从VXLAN隧道接收到报文后可以自动学习远端虚拟机的ARP信息,即远端ARP信息。在SDN控制器组网下,当控制器和设备间进行表项同步时,可以通过vxlan tunnel arp-learning disable命令暂时关闭远端ARP自动学习功能,以节省占用的设备资源。同步完成后,再执行undo vxlan tunnel arp-learning disable命令开启远端ARP自动学习功能。
建议用户只在控制器和设备间同步表项的情况下执行vxlan tunnel arp-learning disable命令。
# 关闭远端ARP自动学习功能。
<Sysname> system
[Sysname] vxlan tunnel arp-learning disable
vxlan tunnel nd-learning disable命令用来关闭远端ND自动学习功能。
undo vxlan tunnel nd-learning disable命令用来开启远端ND自动学习功能。
远端ND自动学习功能处于开启状态。
缺省情况下,设备从VXLAN隧道接收到报文后可以自动学习远端虚拟机的ND信息,即远端ND信息。在SDN控制器组网下,当控制器和设备间进行表项同步时,可以通过vxlan tunnel nd-learning disable命令暂时关闭远端ND自动学习功能,以节省占用的设备资源。同步完成后,再执行undo vxlan tunnel nd-learning disable命令开启远端ND自动学习功能。
建议用户只在控制器和设备间同步表项的情况下执行vxlan tunnel nd-learning disable命令。
# 关闭远端ND自动学习功能。
<Sysname> system
[Sysname] vxlan tunnel nd-learning disable
1.3  OVSDB-VTEP配置命令
ovsdb server bootstrap ca-certificate命令用来指定与控制器进行SSL通信时使用的CA证书文件。
undo ovsdb server bootstrap ca-certificate命令用来恢复缺省情况。
ovsdb server bootstrap ca-certificate ca-filename
与控制器进行SSL通信时使用PKI域中的CA证书文件。
ca-filename:表示与控制器进行SSL通信时使用的CA证书文件名称,不区分大小写,文件名称中不允许出现slot字样。只允许使用主用主控板的CA证书文件。
通过本命令指定与控制器进行SSL通信使用的CA证书文件时,如果已经开启了OVSDB服务器,则该配置不会生效。只有关闭并重新开启OVSDB服务器后,该配置才会生效。
本命令指定的只能是主用主控板中的CA证书文件。如果指定的文件存在,直接使用。否则,使用开启OVSDB服务器时通过SSL连接获取的自签名证书,并通过本命令指定证书文件名。
执行本命令后,优先使用本命令指定的CA证书文件,不使用PKI域中的CA证书。
# 指定与控制器进行SSL通信时使用的CA证书文件为ca-new。
[Sysname] ovsdb server bootstrap ca-certificate ca-new
·     ovsdb server enable
·     ovsdb server pki domain
·     ovsdb server pssl
·     ovsdb server ssl
1.3.2  ovsdb server enable
ovsdb server enable命令用来开启OVSDB服务器。
undo ovsdb server enable命令用来关闭OVSDB服务器。
ovsdb server enable
OVSDB服务器处于关闭状态。
开启OVSDB服务器后,OVSDB服务器可以与控制器建立连接,接收控制器通过OVSDB控制协议发送的数据,并保存到本地OVSDB数据库中,从而实现控制器对VTEP设备进行VXLAN相关配置。
为了保证OVSDB服务器能够与控制器建立连接,在开启OVSDB服务器前,必须先配置至少一条与控制器的连接。
# 开启OVSDB服务器。
[Sysname] ovsdb server enable
1.3.3  ovsdb server pki domain
ovsdb server pki domain命令用来指定与控制器进行SSL通信时使用的PKI域。
undo ovsdb bootstrap server pki domain命令用来恢复缺省情况。
ovsdb server pki domain domain-name
undo ovsdb server pki domain
未指定与控制器进行SSL通信时使用的PKI域。
domain-name:表示与控制器进行SSL通信时使用的PKI域名称,为1~31个字符的字符串,区分大小写。指定的PKI域必须存在,并且PKI域中包含完整的证书和密钥。PKI域的详细介绍,请参见“安全配置指导”中的“PKI”。
与控制器进行SSL通信时需通过本命令指定PKI域。
通过本命令指定与控制器进行SSL通信时使用的PKI域时,如果已经开启了OVSDB服务器,则该配置不会生效。只有关闭并重新开启OVSDB服务器后,该配置才会生效。
# 指定与控制器进行SSL通信时使用的PKI域为ovsdb_test。
[Sysname] ovsdb server pki domain ovsdb_test
·     ovsdb server bootstrap ca-certificate
·     ovsdb server pssl
·     ovsdb server ssl
1.3.4  ovsdb server pssl
ovsdb server pssl命令用来配置与控制器建立被动SSL连接。
undo ovsdb server pssl命令用来恢复缺省情况。
ovsdb server pssl [ port port-number ]
不会与控制器建立被动SSL连接。
port port-number:指定与控制器建立SSL连接的端口号,OVSDB服务器监听该端口上的SSL连接请求。port-number取值范围为1~65535。如果不指定本参数,则监听6640端口。
配置与控制器建立被动SSL连接前,需先指定SSL通信中使用的PKI域。
通过本命令配置与控制器建立被动SSL连接时,如果已经开启了OVSDB服务器,则该配置不会生效。只有关闭并重新开启OVSDB服务器后,该配置才会生效。
只能配置一个OVSDB服务器监听的SSL连接端口号。多次执行本命令,最后一次执行的命令生效。
# 配置与控制器建立被动SSL连接,监听端口号采用默认端口号。
[Sysname] ovsdb server pssl
·     ovsdb server ssl
1.3.5  ovsdb server ptcp
ovsdb server ptcp命令用来配置与控制器建立被动TCP连接。
undo ovsdb server ptcp命令用来恢复缺省情况。
ovsdb server ptcp [ port port-number ] [ acl acl-number ]
不会与控制器建立被动TCP连接。
port port-number:指定与控制器建立TCP连接的监听端口号,取值范围为1~65535,如果不指定本参数,则监听6640端口。
acl acl-number:指定用来过滤控制器的IPv4 ACL。acl-number表示IPv4基本ACL的编号,取值范围为2000~2999。仅Release 2612P06及以上版本支持acl参数。
通过本命令配置与控制器建立被动TCP连接时,如果已经开启了OVSDB服务器,则该配置不会生效。只有关闭并重新开启OVSDB服务器后,该配置才会生效。
只能配置一个OVSDB服务器监听的TCP连接端口号。多次执行本命令,最后一次执行的命令生效。
执行本命令时如果通过acl acl-number参数指定了IPv4 ACL,则OVSDB服务器接收到控制器发送的TCP连接请求后,将通过IPv4 ACL匹配该请求:
·     只有IPv4 ACL允许请求报文通过时,控制器才可以与本地的OVSDB服务器建立被动TCP连接。
·     请求报文未匹配IPv4 ACL或IPv4 ACL拒绝其通过时,OVSDB控制器不能与OVSDB服务器建立被动TCP连接。
如果未指定IPv4 ACL、指定的IPv4 ACL不存在或指定的IPv4 ACL下没有配置规则,则表示允许所有控制器与OVSDB服务器建立被动TCP连接。如果修改了指定的IPv4 ACL规则,则该规则仅对新建立的被动TCP连接生效。
# 配置与控制器建立被动TCP连接,监听端口号采用默认端口号。
[Sysname] ovsdb server ptcp
·     ovsdb server tcp
1.3.6  ovsdb server ssl
ovsdb server ssl命令用来配置与控制器建立主动SSL连接。
undo ovsdb server ssl命令用来删除指定的主动SSL连接。
ovsdb server ssl ip ip-address port port-number
undo ovsdb server ssl ip ip-address port port-number
不会与控制器建立主动SSL连接。
ssl ip-address:指定SSL连接的目的IP地址。
port port-number:指定SSL连接的目的端口号,取值范围为1~65535。
配置与控制器建立主动SSL连接前,需先指定SSL通信中使用的PKI域。
通过本命令配置与控制器建立主动SSL连接时,如果已经开启了OVSDB服务器,则该配置不会生效。只有关闭并重新开启OVSDB服务器后,该配置才会生效。
OVSDB服务器最多只能配置8个与控制器的SSL主动连接。
# 配置与控制器建立主动SSL连接,指定目的IP地址为192.168.12.2、目的端口号为6632。
[Sysname] ovsdb server ssl ip 192.168.12.2 port 6632
·     ovsdb server pssl
1.3.7  ovsdb server tcp
ovsdb server tcp命令用来配置与控制器建立主动TCP连接。
undo ovsdb server tcp命令用来删除指定的主动TCP连接。
ovsdb server tcp ip ip-address port port-number
undo ovsdb server tcp ip ip-address port port-number
不会与控制器建立主动TCP连接。
ip ip-address:指定TCP连接的目的IP地址。
port port-number:指定TCP连接的目的端口号。
通过本命令配置与控制器建立主动TCP连接时,如果已经开启了OVSDB服务器,则该配置不会生效。只有关闭并重新开启OVSDB服务器后,该配置才会生效。
OVSDB服务器最多只能配置8个与控制器的TCP主动连接。
# 配置与控制器建立主动TCP连接,指定目的IP地址为192.168.12.2、目的端口号为6632。
[Sysname] ovsdb server tcp ip 192.168.12.2 port 6632
·     ovsdb server ptcp
1.3.8  vtep access port
vtep access port命令用来指定当前接口为用户侧的接入端口。
undo vtep access port命令用来恢复缺省情况。
vtep access port
当前接口不是用户侧的接入端口。
二层以太网接口视图
二层聚合接口视图
只有将接口配置为用户侧的接入端口后,控制器上才能够显示该端口并对其进行控制。
# 指定二层以太网接口Ten-GigabitEthernet1/0/1为用户侧的接入端口。
[Sysname-Ten-GigabitEthernet1/0/1] vtep access port
1.3.9  vtep enable
vtep enable命令用来开启OVSDB VTEP服务。
undo vtep enabl命令用来关闭OVSDB VTEP服务。
vtep enable
undo vtep enable
OVSDB VTEP服务处于关闭状态。
# 开启设备的OVSDB VTEP服务。
[Sysname] vtep enable
1.3.10  vxlan tunnel flooding-proxy
vxlan tunnel flooding-proxy命令用来开启组播隧道泛洪代理功能。
undo vxlan tunnel flooding-proxy命令用来关闭组播隧道泛洪代理功能。
组播隧道泛洪代理功能处于关闭状态。
目前,仅采用VMware的NSX控制器作为OVSDB控制器时,设备支持组播隧道泛洪代理功能。
开启组播隧道泛洪代理功能后,系统会将控制器下发的组播隧道转换为具有泛洪代理功能的隧道。VXLAN内的广播、组播和未知单播流量将通过具有泛洪代理功能的隧道发送到泛洪代理服务器,由代理服务器进行复制并转发到其他远端VTEP。
采用泛洪代理(服务器复制)方式转发站点间的泛洪流量时,必须开启该功能。
执行undo vxlan tunnel flooding-proxy命令,不会改变已有隧道的泛洪代理模式。
# 开启组播隧道泛洪代理功能。
<Sysname> system
[Sysname] vxlan tunnel flooding-proxy
