15-可靠性命令参考
06-负载均衡命令
本章节下载: 06-负载均衡命令  (1.01 MB)
06-负载均衡命令
1 负载均衡
1.1 负载均衡配置命令
1.1.1 activate (link group view)
1.1.2 activate (server farm view)
1.1.3 bandwidth busy-protection enable (DNS proxy view)
1.1.4 bandwidth busy-protection enable (virtual server pool view)
1.1.5 bandwidth busy-protection enable (virtual server view)
1.1.6 bandwidth busy-rate (link view)
1.1.7 bandwidth busy-rate (real server view)
1.1.8 bandwidth interface statistics enable
1.1.9 bandwidth weight
1.1.10 case-insensitive
1.1.11 check all-packet
1.1.12 class
1.1.13 compression level
1.1.14 connection-limit max (link view)
1.1.15 connection-limit max (real server view)
1.1.16 connection-limit (virtual server view)
1.1.17 connection-sync enable (DNS proxy view)
1.1.18 connection-sync enable (virtual server view)
1.1.19 content
1.1.20 content length-threshold
1.1.21 content maxparse-length
1.1.22 content rewrite
1.1.23 cookie
1.1.24 cookie secondary name
1.1.25 cost
1.1.26 cost weight
1.1.27 default dns-server-pool
1.1.28 default link-group
1.1.29 default server-farm
1.1.30 default-class action
1.1.31 description
1.1.32 display loadbalance action
1.1.33 display loadbalance alg
1.1.34 display loadbalance class
1.1.35 display loadbalance dns-cache
1.1.36 display loadbalance dns-listener
1.1.37 display loadbalance dns-listener statistics
1.1.38 display loadbalance dns-map
1.1.39 display loadbalance dns-map statistics
1.1.40 display loadbalance dns-proxy
1.1.41 display loadbalance dns-proxy statistics
1.1.42 display loadbalance dns-server
1.1.43 display loadbalance dns-server statistics
1.1.44 display loadbalance dns-server-pool
1.1.45 display loadbalance hot-backup statistics
1.1.46 display loadbalance isp
1.1.47 display loadbalance limit-policy
1.1.48 display loadbalance link
1.1.49 display loadbalance link out-interface statistics
1.1.50 display loadbalance link statistics
1.1.51 display loadbalance link-group
1.1.52 display loadbalance local-dns-server parse-fail-record
1.1.53 display loadbalance policy
1.1.54 display loadbalance proximity
1.1.55 display loadbalance reverse-zone
1.1.56 display loadbalance snat-pool
1.1.57 display loadbalance virtual-server-pool
1.1.58 display loadbalance zone
1.1.59 display parameter-profile
1.1.60 display real-server
1.1.61 display real-server statistics
1.1.62 display server-farm
1.1.63 display sticky
1.1.64 display sticky-group
1.1.65 display virtual-server
1.1.66 display virtual-server statistics
1.1.67 dns-server-pool (action view)
1.1.68 dns-server-pool (DNS server view)
1.1.69 domain-name
1.1.70 exceed-mss
1.1.71 expire
1.1.72 fail-action (link group view)
1.1.73 fail-action (server farm view)
1.1.74 fallback
1.1.75 fallback-action continue
1.1.76 forward all
1.1.77 header
1.1.78 header delete
1.1.79 header delete request accept-encoding
1.1.80 header exceed-length
1.1.81 header insert
1.1.82 header insert response vary
1.1.83 header maxparse-length
1.1.84 header modify per-request
1.1.85 header rewrite
1.1.86 inherit vpn-instance disable (link view)
1.1.87 inherit vpn-instance disable (real server view)
1.1.88 ip
1.1.89 ip address (DNS proxy view)
1.1.90 ip address (DNS server view)
1.1.91 ip address (DNS listener view)
1.1.92 ip address (ISP view)
1.1.93 ip address (real server view)
1.1.94 ip mask
1.1.95 ip range (snat pool view)
1.1.96 ipv6
1.1.97 ipv6 address (DNS listener view)
1.1.98 ipv6 address (DNS proxy view)
1.1.99 ipv6 address (DNS server view)
1.1.100 ipv6 address (ISP view)
1.1.101 ipv6 address (real server view)
1.1.102 ipv6 prefix
1.1.103 ipv6 range
1.1.104 isp
1.1.105 lb-limit-policy
1.1.106 lb-policy (DNS proxy view)
1.1.107 lb-policy (virtual server view)
1.1.108 limit
1.1.109 link (DNS server view)
1.1.110 link-group (action view)
1.1.111 link-group (link view)
1.1.112 loadbalance action
1.1.113 loadbalance alg
1.1.114 loadbalance alg all-enable
1.1.115 loadbalance class
1.1.116 loadbalance dns-listener
1.1.117 loadbalance dns-map
1.1.118 loadbalance dns-proxy
1.1.119 loadbalance dns-server
1.1.120 loadbalance dns-server-pool
1.1.121 loadbalance isp file
1.1.122 loadbalance isp name
1.1.123 loadbalance limit-policy
1.1.124 loadbalance link
1.1.125 loadbalance link-group
1.1.126 loadbalance local-dns-server parse-fail-record max-number
1.1.127 loadbalance local-dns-server parse-faill-record type
1.1.128 loadbalance local-dns-server schedule-test ip
1.1.129 loadbalance local-dns-server schedule-test ipv6
1.1.130 loadbalance log enable bandwidth-busy
1.1.131 loadbalance log enable base
1.1.132 loadbalance log enable nat
1.1.133 loadbalance policy
1.1.134 loadbalance proximity
1.1.135 loadbalance region
1.1.136 loadbalance reverse-zone
1.1.137 loadbalance schedule-test ip
1.1.138 loadbalance schedule-test ipv6
1.1.139 loadbalance snat-pool
1.1.140 loadbalance test pcre
1.1.141 loadbalance test rewrite
1.1.142 loadbalance virtual-server-pool
1.1.143 loadbalance zone
1.1.144 match acl
1.1.145 match app-group
1.1.146 match class
1.1.147 match content
1.1.148 match cookie
1.1.149 match default probe
1.1.150 match destination
1.1.151 match destination domain-name
1.1.152 match domain-name
1.1.153 match header
1.1.154 match isp
1.1.155 match method
1.1.156 match probe
1.1.157 match radius-attribute
1.1.158 match source
1.1.159 match url
1.1.160 max-bandwidth (link view)
1.1.161 max-bandwidth (real server view)
1.1.162 max-number
1.1.163 memory-size
1.1.164 min-ttl
1.1.165 override-limit enable
1.1.166 parameter
1.1.167 parameter-profile
1.1.168 payload
1.1.169 port (DNS proxy view)
1.1.170 port (DNS server view)
1.1.171 port (real server view)
1.1.172 port (virtual server view)
1.1.173 predictor (DNS server pool view)
1.1.174 predictor (link group view)
1.1.175 predictor (server farm view)
1.1.176 predictor (virtual server pool view)
1.1.177 prefer-method
1.1.178 primary-nameserver
1.1.179 priority (DNS server view)
1.1.180 priority (link view)
1.1.181 priority (real server view)
1.1.182 probe (DNS server pool view)
1.1.183 probe (DNS server view)
1.1.184 probe (link group view)
1.1.185 probe (link view)
1.1.186 probe (real server view)
1.1.187 probe (server farm view)
1.1.188 proximity enable (link group view)
1.1.189 proximity enable (server farm view)
1.1.190 radius-attribute
1.1.191 rate-limit bandwidth (link view)
1.1.192 rate-limit bandwidth (real server view)
1.1.193 rate-limit bandwidth (virtual server view)
1.1.194 rate-limit connection (link view)
1.1.195 rate-limit connection (real server view)
1.1.196 rate-limit connection (virtual server view)
1.1.197 real-server
1.1.198 rebalance per-request
1.1.199 record
1.1.200 record ptr
1.1.201 redirect relocation (action view)
1.1.202 redirect relocation (virtual server view)
1.1.203 redirect return-code (action view)
1.1.204 redirect return-code (virtual server view)
1.1.205 refresh
1.1.206 request-version all
1.1.207 reset loadbalance connections
1.1.208 reset loadbalance dns-cache
1.1.209 reset loadbalance dns-listener statistics
1.1.210 reset loadbalance dns-map statistics
1.1.211 reset loadbalance dns-proxy statistics
1.1.212 reset loadbalance dns-server statistics
1.1.213 reset loadbalance hot-backup statistics
1.1.214 reset loadbalance link statistics
1.1.215 reset loadbalance local-dns-server parse-fail-record
1.1.216 reset loadbalance proximity
1.1.217 reset real-server statistics
1.1.218 reset virtual-server statistics
1.1.219 responsible-mail
1.1.220 retry
1.1.221 route-advertisement enable
1.1.222 router ip
1.1.223 router ipv6
1.1.224 rtt weight
1.1.225 rule
1.1.226 secondary-cookie delimiters
1.1.227 secondary-cookie start
1.1.228 selected-link
1.1.229 selected-server (DNS server pool view)
1.1.230 selected-server (server farm view)
1.1.231 serial
1.1.232 server-connection reuse
1.1.233 server-farm (action view)
1.1.234 server-farm (real server view)
1.1.235 server-farm (system view)
1.1.236 service enable (DNS listener view)
1.1.237 service enable (DNS proxy view)
1.1.238 service enable (DNS map view)
1.1.239 service enable (virtual server view)
1.1.240 set ip tos (action view)
1.1.241 set ip tos (parameter profile view)
1.1.242 shutdown (link view)
1.1.243 shutdown (real server view)
1.1.244 skip current-dns-proxy
1.1.245 slow-online (server farm view)
1.1.246 slow-shutdown enable (real server view)
1.1.247 snat-pool (link group view)
1.1.248 snat-pool (server farm view)
1.1.249 snmp-agent trap enable loadbalance
1.1.250 soa
1.1.251 ssl session-id
1.1.252 ssl url rewrite
1.1.253 ssl-client-policy (action view)
1.1.254 ssl-client-policy (virtual server view)
1.1.255 ssl-server-policy
1.1.256 sticky-group
1.1.257 sticky-sync enable (DNS proxy view)
1.1.258 sticky-sync enable (virtual server view)
1.1.259 success-criteria (DNS server pool view)
1.1.260 success-criteria (DNS server view)
1.1.261 success-criteria (link group view)
1.1.262 success-criteria (link view)
1.1.263 success-criteria (real server view)
1.1.264 success-criteria (server farm view)
1.1.265 tcp connection idle-timeout
1.1.266 tcp connection time-wait timeout
1.1.267 tcp mss
1.1.268 tcp window-size
1.1.269 timeout (proximity view)
1.1.270 timeout (sticky group view)
1.1.271 topology region
1.1.272 transparent enable (link group view)
1.1.273 transparent enable (server farm view)
1.1.274 ttl (DNS map view)
1.1.275 ttl (DNS zone view)
1.1.276 ttl weight
1.1.277 udp per-packet
1.1.278 virtual ip address
1.1.279 virtual ipv6 address
1.1.280 virtual-server (system view)
1.1.281 virtual-server (virtual server pool view)
1.1.282 virtual-server-pool
1.1.283 vpn-instance (DNS listener view)
1.1.284 vpn-instance (DNS proxy view)
1.1.285 vpn-instance (link view)
1.1.286 vpn-instance (real server view)
1.1.287 vpn-instance (virtual server view)
1.1.288 weight (DNS server view)
1.1.289 weight (link view)
1.1.290 weight (real server view)
1.1.291 window-size
1 负载均衡
1.1  负载均衡配置命令
activate命令用来配置链路组的可用条件。
undo activate命令用来恢复缺省情况。
activate lower lower-percentage upper upper-percentage
undo activate
链路组中只要有一个链路可用,该链路组就被认为可用。
链路组视图
context-admin
lower lower-percentage:最小可用百分比,取值范围为1~99。
upper upper-percentage:最大可用百分比,取值范围为1~99,且必须大于等于最小可用百分比。
当主用链路组中可用的链路数量占链路总数量的百分比低于最小可用百分比时,该链路组将被认为不可用,从而切换到备用链路组;当主用链路组中可用的链路数量占链路总数量的百分比高于最大可用百分比时,将从备用链路组切换回主用链路组。
需要注意的是,当虚服务器上未配置备用链路组时,本配置无效。
# 配置链路组lg的最小可用百分比为20,最大可用百分比为80。
[Sysname] loadbalance link-group lg
[Sysname-lb-lgroup-lg] activate lower 20 upper 80
activate命令用来配置实服务组的可用条件。
undo activate
实服务组中只要有一个实服务器可用,该实服务组就被认为可用。
实服务组视图
context-admin
lower lower-percentage:最小可用百分比,取值范围为1~99。当主用实服务组中可用的实服务器数量占实服务器总数量的百分比低于此值时,该实服务组将被认为不可用,从而切换到备用实服务组。
upper upper-percentage:最大可用百分比,取值范围为1~99,且必须大于等于最小可用百分比。当主用实服务组中可用的实服务器数量占实服务器总数量的百分比高于此值时,将从备用实服务组切换回主用实服务组。
需要注意的是,当虚服务器上未配置备用实服务组时,本配置无效。
# 配置实服务组sf的最小可用百分比为20,最大可用百分比为80。
[Sysname] server-farm sf
[Sysname-sfarm-sf] activate lower 20 upper 80
·            default server-farm
bandwidth busy-protection enable命令用来开启DNS服务器对应链路的带宽繁忙保护功能。
undo bandwidth busy-protection enable命令用来关闭DNS服务器对应链路的带宽繁忙保护功能。
DNS服务器对应链路的带宽繁忙保护功能处于关闭状态。
DNS透明代理视图
context-admin
开启带宽繁忙保护功能后,DNS透明代理设备从DNS服务器池中选择DNS服务器时,会查看DNS服务器使用的链路的繁忙比例是否超过配置的带宽繁忙比例,如果超出则不选择该DNS服务器。
当DNS服务器池中的所有DNS服务器对应的链路都达到了带宽繁忙比例时,带宽繁忙保护功能自动失效;只要此DNS服务器池中有一个DNS服务器对应链路恢复到配置的带宽繁忙比例以下,则该DNS服务器重新参与调度,带宽繁忙保护功能自动生效。
# 在名称为dns-proxy1的DNS透明代理视图下,开启DNS服务器对应链路的带宽繁忙保护功能。
[Sysname] loadbalance dns-proxy dns-proxy1
[Sysname-lb-dp-udp-dns-proxy1] bandwidth busy-protection enable
·            bandwidth busy-rate(link view)
bandwidth busy-protection enable命令用来开启虚服务器池的繁忙保护功能。
undo bandwidth busy-protection enable命令用来关闭虚服务器池的繁忙保护功能。
虚服务器池繁忙保护功能处于关闭状态。
虚服务器池视图
context-admin
开启繁忙保护功能后,虚服务器池根据用户配置的调度方式选择虚服务器成员时,会查看所选取的虚服务器成员对应的链路是否超过配置的繁忙比例,如果超出则不选择该虚服务器成员。
# 开启虚服务器池local-pool的繁忙保护功能。
[Sysname] loadbalance virtual-server-pool local-pool
[Sysname-lb-vspool-local-pool] bandwidth busy-protection enable
bandwidth busy-protection enable命令用来开启链路的带宽繁忙保护功能。
undo bandwidth busy-protection enable命令用来关闭链路的带宽繁忙保护功能。
链路的带宽繁忙保护功能处于关闭状态。
虚服务器视图
context-admin
带宽繁忙保护功能仅在链路的接口带宽统计功能开启的情况下生效。
# 在IP类型的虚服务器vs3中开启链路带宽繁忙保护功能。
<Sysname>system-view
[Sysname] virtual-server vs3 type ip
[Sysname-vs-ip-vs3] bandwidth busy-protection enable
相关命令】
·            bandwidth interface statistics enable
bandwidth busy-rate命令用来配置链路的带宽繁忙比。
undo bandwidth busy-rate命令用来恢复缺省情况。
bandwidth [ inbound | outbound ] busy-rate busy-rate-number [ recovery recovery-rate-number ]
undo bandwidth [ inbound | outbound ] busy-rate
带宽繁忙比例为70。
链路视图
context-admin
inbound:表示入方向的带宽繁忙比。
outbound:表示出方向的带宽繁忙比。
busy-rate-number:链路的带宽繁忙比例,取值范围为1~100。
recovery recovery-rate-number:链路带宽繁忙恢复比例,取值范围为1~100。缺省情况下,当带宽繁忙比例大于10时,带宽繁忙恢复比例为带宽繁忙比例减去10;当带宽繁忙比例小于等于10时,带宽繁忙恢复比例等于带宽繁忙比例。
若未指定inbound或outbound关键字,则表示设置链路的总带宽繁忙比例。
带宽繁忙比例为当前链路实际带宽与用户配置最大带宽的百分比值,若最大带宽设置为不受限,则使用其可设置的最大值进行计算。
当链路的带宽超过该链路的带宽繁忙比例与最大期望带宽的乘积时,链路进入繁忙状态,不再参与调度。当链路的带宽低于带宽繁忙恢复比例与最大期望带宽的乘积时,链路解除繁忙状态,重新参与调度。
同一链路的带宽繁忙恢复比例必须小于等于带宽繁忙比例。
本命令只在新建会话时生效,对已经存在的会话不生效。
# 配置链路lk1的总带宽繁忙比例为90,带宽繁忙恢复比例为85。
[Sysname] loadbalance link lk1
[Sysname-lb-link-link1] bandwidth busy-rate 90 recovery 85
·            display loadbalance link
·            max-bandwidth(link view)
bandwidth busy-rate命令用来配置实服务器的带宽繁忙比。
带宽繁忙比为70。
实服务器视图
context-admin
busy-rate-number:实服务器的带宽繁忙比,取值范围为1~100。
recovery recovery-rate-number:实服务器的带宽繁忙恢复比例,取值范围为1~100。缺省情况下,当带宽繁忙比例大于10时,带宽繁忙恢复比例为带宽繁忙比例减去10;当带宽繁忙比例小于等于10时,带宽繁忙恢复比例等于带宽繁忙比例。
若未指定inbound和outbound关键字,则表示设置总带宽繁忙比。
带宽繁忙比为当前带宽与最大带宽的百分比值,如果最大带宽配置为不受限制,则使用其可配置的最大值进行计算。
当访问某个实服务器的链路流量超过该链路的带宽繁忙比例与最大期望带宽的乘积时,实服务器进入繁忙状态,不再参与调度。当该链路流量低于带宽繁忙恢复比例与最大期望带宽的乘积时,实服务器解除繁忙状态,重新参与调度。
同一实服务器的带宽繁忙恢复比例必须小于等于带宽繁忙比例。
# 在实服务器rs中配置总带宽繁忙比例为20,带宽繁忙恢复比例为10。
[Sysname] real-server rs
[Sysname-rserver-rs] bandwidth busy-rate 20 recovery 10
·            display real-server
·            max-bandwidth (real server view)
bandwidth interface statistics enable命令用来开启链路的接口带宽统计功能。
undo bandwidth interface statistics enable命令用来关闭链路的接口带宽统计功能。
接口带宽统计功能处于关闭状态。
虚服务器视图
context-admin
# 在IP类型的虚服务器vs3上,并开启链路的接口带宽统计功能。
[Sysname-vs-ip-vs3] bandwidth interface statistics enable
bandwidth weight命令用来配置就近性计算的带宽权值。
undo bandwidth weight命令用来恢复缺省情况。
bandwidth { inbound | outbound } weight bandwidth-weight
undo bandwidth { inbound | outbound } weight
就近性计算的出、入方向带宽权值均为100。
就近性视图
context-admin
inbound:表示入方向的带宽权值。
outbound:表示出方向的带宽权值。
bandwidth-weight:就近性计算的带宽权值,取值范围为0~255,数值越大权重越大。
# 配置就近性计算的入方向带宽权值为200。
[Sysname] loadbalance proximity
[Sysname-lb-proximity] bandwidth inbound weight 200
# 配置就近性计算的出方向带宽权值为200。
[Sysname-lb-proximity] bandwidth outbound weight 200
case-insensitive命令用来配置匹配字符串时对大小写不敏感。
undo case-insensitive命令用来恢复缺省情况。
case-insensitive
匹配字符串时对大小写敏感。
参数模板视图
context-admin
本命令只在HTTP类型的参数模板视图下支持。
本命令将影响以下内容:
·            对于类匹配,影响HTTP首部的取值、HTTP Cookie的名称和取值、URL。
·            对于HTTP首部持续性方法,影响首部的取值、URL以及用于生成持续性表项的Key值。
·            对于Cookie截取持续性方法,影响Cookie的名称和取值的匹配以及用于生成持续性表项的Key值。
# 在HTTP类型的参数模板pp1中,配置匹配字符串时对大小写不敏感。
[Sysname] parameter-profile pp1 type http
[Sysname-para-http-pp1] case-insensitive
check all-packet命令用来配置检查所有报文。
undo check all-packet命令用来恢复缺省情况。
check all-packet
不检查所有报文。
持续性组视图
context-admin
本命令只在HTTP Cookie类型的持续性组视图下支持。需要注意的是:
·            当持续性方法为Cookie截取时,本命令用来配置是否从所有HTTP应答报文中截取Cookie。如果未配置本命令,则在一次连接中只从首个应答报文中截取一次Set-Cookie信息,后续应答报文不再截取。
·            当持续性方法为Cookie重写时,本命令用来配置是否在所有HTTP应答报文中重写Cookie。如果未配置本命令,则在一次连接中只在首个应答报文中重写Set-Cookie信息,后续应答报文不再重写。
·            当持续性方法为Cookie插入时,本命令用来配置是否向所有HTTP应答报文中插入Cookie。如果未配置本命令,则在一次连接中只向首个应答报文中插入Set-Cookie信息,后续应答报文不再插入。
# 在HTTP Cookie类型的持续性组sg3中,配置检查所有报文。
[Sysname] sticky-group sg3 type http-cookie
[Sysname-sticky-http-cookie-sg3] check all-packet
1.1.12  class
class命令用来为负载均衡类指定负载均衡动作。
undo class命令用来删除指定的负载均衡类。
class class-name [ insert-before before-class-name ] action action-name
undo class class-name
没有为负载均衡类指定负载均衡动作。
负载均衡策略视图
context-admin
class-name:负载均衡类的名称,为1~63个字符的字符串,不区分大小写。
insert-before before-class-name:表示插入到指定的负载均衡类之前(该负载均衡类必须已被当前负载均衡策略引用)。before-class-name为1~63个字符的字符串,不区分大小写。
action-name:负载均衡动作的名称,为1~63个字符的字符串,不区分大小写。
通过本命令可以为匹配特定负载均衡类的报文指定其执行的负载均衡动作。
不同的负载均衡类可以与同一负载均衡动作组成匹配规则。
DNS类型的负载均衡策略只能引用DNS类型的负载均衡动作;通用类型的负载均衡策略只能引用通用类型的负载均衡类和负载均衡动作;HTTP类型的负载均衡策略则无此限制。
# 在通用类型的负载均衡策略lbp1中,为负载均衡类lbc1指定负载均衡动作为lba1,并将lbc1插入到负载均衡类lbc0之前。
[Sysname] loadbalance policy lbp1 type generic
[Sysname-lbp-generic-lbp1] class lbc1 insert-before lbc0 action lba1
compression level命令用来设置应答报文的压缩级别。
undo compression level命令用来恢复缺省情况。
compression level level
应答报文的压缩级别为1。
HTTP压缩参数模板视图
context-admin
level:压缩级别,取值范围为1~9,数值越大表示压缩速度越慢、压缩比越高。
# 创建HTTP压缩类型的参数模板pa1,并配置压缩等级为6。
[Sysname] parameter-profile pa1 type http-compress
[Sysname-para-http-compress-pa1] compression level 6
connection-limit max命令用来配置链路所允许的最大连接数。
undo connection-limit max命令用来恢复缺省情况。
connection-limit max max-number
链路所允许的最大连接数为0,即不受限制。
链路视图
context-admin
max-number:最大连接数,取值范围为0~4294967295,0表示链路所允许的最大连接数不受限制。
# 配置链路的最大连接数为10000。
[Sysname-lb-link-lk] connection-limit max 10000
connection-limit max命令用来配置实服务器所允许的最大连接数。
实服务器所允许的最大连接数为0,即不受限制。
实服务器视图
context-admin
max-number:最大连接数,取值范围为0~4294967295,0表示实服务器所允许的最大连接数不受限制。
# 配置实服务器rs所允许的最大连接数为10000。
[Sysname-rserver-rs] connection-limit max 10000
connection-limit命令用来配置虚服务器所允许的最大连接数。
undo connection-limit命令用来恢复缺省情况。
虚服务器所允许的最大连接数为0,即不受限制。
虚服务器视图
context-admin
max-number:最大连接数,取值范围为0~4294967295,0表示虚服务器所允许的最大连接数不受限制。
# 配置IP类型的虚服务器vs3所允许的最大连接数为10000。
[Sysname-vs-ip-vs3] connection-limit max 10000
connection-sync enable命令用来开启DNS透明代理的会话扩展信息备份功能。
undo connection-sync enable命令用来关闭DNS透明代理的会话扩展信息备份功能。
DNS透明代理的会话扩展信息备份功能处于关闭状态。
DNS透明代理视图
context-admin
在DNS透明代理视图下开启会话扩展信息备份功能,可以备份会话信息,保证主备切换时业务不中断。
# 在名称为dns_proxy1的DNS透明代理视图下,开启DNS透明代理的会话扩展信息备份功能。
[Sysname-lb-dp-udp-dns-proxy1] connection-sync enable
connection-sync enable命令用来开启虚服务器的会话扩展信息备份功能。
undo connection-sync enable命令用来关闭虚服务器的会话扩展信息备份功能。
虚服务器的会话扩展信息备份功能处于关闭状态。
虚服务器视图
context-admin
本命令在HTTP类型的虚服务器视图下不支持。
# 开启IP类型的虚服务器vs3的会话扩展信息备份功能。
[Sysname-vs-ip-vs3] connection-sync enable
1.1.19  content
content命令用来配置HTTP实体持续性方法。
undo content命令用来删除HTTP实体持续性方法。
content [ offset offset ] [ start start-string ] [ end end-string | length length ]
undo content
不存在任何持续性方法。
持续性组视图
context-admin
offset offset:实体基于HTTP报文起始位置的偏移量,取值范围为0~1000,缺省值为0。
start start-string:实体开始标记的正则表达式,即从offset起到本标记为开始,为1~127字符的字符串,不支持正则元字符?。
end end-string:实体结束标记的正则表达式,即从start-string起到本标记为结束,为1~127字符的字符串,不支持正则元字符?。
length length:实体的长度,取值范围为0~1000,缺省值为0,表示所有长度。
本命令只在HTTP实体类型的持续性组视图下支持。
本命令用来根据offset、start-string、end-string及length获取生成持续性表项的HTTP实体信息。start-string和end-string将不计入持续性表项信息中。
HTTP实体持续性只能对实体内的所有内容进行持续性处理,对于chunk及multipart形式的实体内容,HTTP实体持续性不能根据具体内容进行明确的持续性处理。
快速HTTP类型的虚服务器不支持引用HTTP实体持续性方法。
# 在HTTP实体类型的持续性组sg2中,配置HTTP实体持续性方法为:从HTTP报文起始位置的第30个字节起,以abc为开始、长度为20个字节的HTTP实体来生成持续性表项。
[Sysname] sticky-group sg2 type http-content
[Sysname-sticky-http-content-sg2] content offset 30 start abc length 20
content length-threshold命令用来设置进行压缩的应答报文体最小长度。
undo content length-threshold命令用来恢复缺省情况。
content length-threshold length
压缩的应答报文的报文体最小长度为1024字节。
HTTP压缩参数模板视图
context-admin
length:报文体长度值,取值范围为0~4294967295,单位字节。
如果应答报文中携带Content-Length首部,则报文体的长度必须达到配置的最小长度才会进行压缩,否则不进行压缩。如果应答报文中不携带Content-Length首部,此配置不生效,即无论报文多大都会进行压缩。
# 创建HTTP压缩类型的参数模板http1,并设置进行压缩的应答报文体最小长度为2000字节。
[Sysname] parameter-profile http1 type http-compression
[Sysname-para-http-compression-http1] content length-threshold 2000
content maxparse-length命令用来配置HTTP实体的最大解析长度。
undo content maxparse-length命令用来恢复缺省情况。
content maxparse-length length
HTTP实体的最大解析长度为4096。
参数模板视图
context-admin
length:HTTP实体的最大解析长度,取值范围为1~65535。
需要注意的是,快速HTTP类型的虚服务器不支持本功能。
# 在HTTP类型的参数模板pp1中,配置HTTP实体的最大解析长度为8192。
[Sysname-para-http-pp1] content maxparse-length 8192
content rewrite命令用来设置对HTTP应答报文体中的指定内容进行替换。
undo content rewrite命令用来恢复缺省情况。
content rewrite value value replace replace-string
不替换HTTP应答报文体中指定内容。
HTTP负载均衡动作视图
context-admin
value value:要被替换的HTTP报文体的内容,为1~127个字符的字符串,不支持字符?。
replace replace-string:替换后的内容,为1~127个字符的字符串。
此配置只对HTTP应答报文格式是text/* 的报文进行替换修改。
如果待匹配的报文内容长度超过4096字节,则替换操作不生效。
替换的内容串支持配置%[1-9],表示按照value中匹配上的内容替换成%[1-9]中对应()中的内容。例如:执行命令content rewrite value (Wel)(co)(me) replace %2操作后,将把Welcome字符串替换为第2个括号"(co)"中的内容。
一个HTTP负载均衡动作视图下,只允许配置一次该功能。
# 在HTTP类型的负载均衡动作replace中,将HTTP应答报文体中的内容2000::1替换为2.3.4.5。
[Sysname] loadbalance action replace type http
[Sysname- lba-http-replace] content rewrite value 2000::1 replace 2.3.4.5
1.1.23  cookie
cookie命令用来配置HTTP Cookie持续性方法。
undo cookie命令用来恢复缺省情况。
cookie { get name cookie-name [ offset offset ] [ start start-string] [ end end-string | length length ] | { insert | rewrite } [ name cookie-name ] }
undo cookie { get | insert | rewrite }
未配置任何HTTP Cookie持续性方法。
持续性组视图
context-admin
get:表示持续性方法为Cookie截取,即在服务器发送的HTTP应答报文中截取Set-Cookie字段用于持续性处理。
cookie-name:HTTP Cookie的名称,为1~63个字符的字符串,区分大小写。
offset offset:Cookie基于HTTP报文起始位置的偏移量,取值范围为0~1000,缺省值为0。
start start-string:Cookie开始标记的正则表达式,即从offset起到本标记为开始,为1~127字符的字符串,不支持正则元字符?。
end end-string:Cookie结束标记的正则表达式,即从start-string起到本标记为结束,为1~127字符的字符串,不支持正则元字符?。
length length:Cookie的长度,取值范围为0~1000,缺省值为0,表示所有长度。
insert:表示持续性方法为Cookie插入,即在服务器发送的HTTP应答报文中插入Set-Cookie字段用于持续性处理。
rewrite:表示持续性方法为Cookie重写,即改写服务器发送的HTTP应答报文所携带的Set-Cookie字段用于持续性处理。
name cookie-name:HTTP Cookie的名称,为1~63个字符的字符串,区分大小写,缺省值为X-LB。
cookie get命令用来根据offset、start-string、end-string及length获取生成持续性表项的HTTP Cookie信息。start-string和end-string将不计入持续性表项信息中。
当持续性方法为Cookie重写时,需要与HTTP服务器配合,即服务器发送的HTTP应答报文中应携带指定名称Cookie的Set-Cookie首部信息;此外,系统仅修改Set-Cookie中Cookie的名称和值,不会修改其它属性(如Expires等)。
当持续性方法为Cookie插入或Cookie重写时,所配置的持续性老化时间不为会话老化(持续性表项的超时时间为0时),会在对应插入或重写的Value值后加入Expires字段。如果服务器发送的HTTP应答报文也携带此属性,负载均衡模块不会修改服务器所携带的该属性,而是在Value值后新增用户配置的Expires信息。因此在与服务器配合设置Cookie重写持续性方法时,建议服务器对于被负载均衡模块重写的Set-Cookie首部不要携带任何表征超时的属性。
# 在HTTP Cookie类型的持续性组sg3中,配置持续性方法为Cookie截取,即:截取从HTTP报文起始位置的第10个字节起,长度为32个字节的名为user的HTTP Cookie来生成持续性表项。
[Sysname-sticky-http-cookie-sg3] cookie get name user offset 10 length 32
# 在HTTP Cookie类型的持续性组sg3中,配置持续性方法为Cookie插入。
[Sysname-sticky-http-cookie-sg3] cookie insert
cookie secondary name命令用来指定需在URI中查找的Secondary Cookie名称。
undo cookie secondary name命令用来恢复缺省情况。
cookie secondary name value
未指定需在URI中查找的Secondary Cookie名称。
持续性组视图
context-admin
value:Secondary Cookie的名称,为1~63个Token字符,区分大小写,不包括(、)、<、>、@、,、;、:、\、"、/、[、]、?、=、{、}、SP(空格符)、HT(水平制表符),以及ASCII码小于或等于31,大于或等于127的字符。
需要注意的是,本命令只对Cookie截取持续性方法生效。即:当配置了Cookie截取持续性方法时,如果也配置了本命令,此时系统如果未能在HTTP请求报文首部找到指定名称的Cookie,便会查找出现在URI中的Secondary Cookie。
# 在HTTP Cookie类型的持续性组sg3中,指定需在URI中查找的Secondary Cookie名称为sid。
[Sysname-sticky-http-cookie-sg3] cookie secondary name sid
1.1.25  cost
cost命令用来配置就近性计算的链路成本。
undo cost命令用来恢复缺省情况。
cost cost-value
undo cost
就近性计算的链路成本为0。
链路视图
context-admin
cost-value:就近性计算的链路成本,取值范围为0~10240。
# 在链路lk1中配置就近性计算的链路成本为200。
[Sysname-lb-link-lk1] cost 200
1.1.26  cost weight
cost weight命令用来配置就近性计算的成本权值。
undo cost weight命令用来恢复缺省情况。
cost weight cost-weight
undo cost weight
就近性计算的成本权值为100。
就近性视图
context-admin
cost-weight:就近性计算的成本权值,取值范围为0~255,数值越大权重越大。
# 配置就近性计算的费用权值为200。
[Sysname-lb-proximity] cost weight 200
default dns-server-pool命令用来指定DNS透明代理引用的缺省DNS服务器池。
undo default dns-server-pool命令用来恢复缺省情况。
default dns-server-pool pool-name [ sticky sticky-name ]
undo default dns-server-pool pool-name
未指定DNS透明代理引用的缺省DNS服务器池。
DNS透明代理视图
context-admin
pool-name:DNS服务器池名字,为1~63个字符的字符串,不区分大小写。
sticky sticky-name:持续性组的名称,为1~63个字符的字符串,不区分大小写。若未指定该参数,则DNS服务器池不对应持续性组。
每个DNS透明代理只能引用一个DNS服务器池。
# 在名称为dns-proxy1的DNS透明代理视图下,配置DNS透明代理引用的缺省DNS服务器池为dns-pool1,持续性组名称为st1。
[Sysname-lb-dp-udp-dns-proxy1] default dns-server-pool dns-pool1 sticky st1
default link-group命令用来指定缺省链路组。
undo default link-group命令用来恢复缺省情况。
default link-group link-group-name [ backup backup-link-group-name ] [ sticky sticky-name ]
未指定缺省的链路组。
Link-IP类型虚服务器视图
context-admin
link-group-name:主用链路组的名称,为1~63个字符的字符串,不区分大小写。
backup backup-link-group-name:备用链路组的名称,为1~63个字符的字符串,不区分大小写。
当主用链路组可用(该链路组存在且有可用的链路)时,虚服务器通过主用链路组转发报文;当主用链路组不可用而备用链路组可用时,虚服务器通过备用链路组转发报文。
# 为Link-IP类型的虚服务器vs3指定缺省的主用链路组为link1,备用链路组为link2,持续性组名称为sg1。
[Sysname] virtual-server vs3 type link-ip
[Sysname--vs-link-ip-vs3] default link-group link1 backup link2 sticky sg1
default server-farm命令用来指定缺省的实服务组。
undo default server-farm命令用来恢复缺省情况。
default server-farm server-farm-name [ backup backup-server-farm-name ] [ sticky sticky-name ]
未指定缺省的实服务组。
快速HTTP虚服务器视图/HTTP虚服务器视图/IP虚服务器视图/TCP虚服务器视图/UDP虚服务器视图
context-admin
server-farm-name:主用实服务组的名称,为1~63个字符的字符串,不区分大小写。
backup backup-server-farm-name:备用实服务组的名称,为1~63个字符的字符串,不区分大小写。
当主用实服务组可用(该实服务组存在且有可用的实服务器)时,虚服务器通过主用实服务组进行转发;当主用实服务组不可用而备用实服务组可用时,虚服务器通过备用实服务组进行转发。
# 为IP类型的虚服务器vs3指定缺省的主用实服务组为sf,备用实服务组为sfb,持续性组名称为sg1。
[Sysname-vs-ip-vs3] default server-farm sf backup sfb sticky sg1
default-class action命令用来配置缺省的负载均衡动作。
undo default-class命令用来恢复缺省情况。
default-class action action-name
undo default-class
未配置缺省的负载均衡动作。
负载均衡策略视图
context-admin
通过本命令可以为未匹配任何负载均衡类的报文指定其执行的缺省动作。
DNS类型的负载均衡策略只能引用DNS类型的负载均衡动作作为其缺省负载均衡动作;通用类型的负载均衡策略只能用通用类型的负载均衡动作作为其缺省的负载均衡动作;HTTP类型的负载均衡策略则无此限制。
# 在通用类型的负载均衡策略lbp1中,配置缺省的负载均衡动作为lba1。
[Sysname-lbp-generic-lbp1] default-class action lba1
1.1.31  description
description命令用来配置描述信息。
undo description命令用来恢复缺省情况。
未配置描述信息。
ISP视图/负载均衡动作视图/负载均衡类视图/负载均衡策略视图/负载均衡限制策略视图/参数模板视图/实服务器视图/实服务组视图/SNAT地址池视图/持续性组视图/虚服务器视图/链路组视图/链路视图/DNS服务器池视图/DNS服务器视图
context-admin
text:描述信息,为1~127个字符的字符串,区分大小写。
# 配置通用类型的负载均衡动作lba1的描述信息为“LB action LBA1”。
[Sysname] loadbalance action lba1 type generic
[Sysname-lba-generic-lba1] description LB action LBA1
# 配置通用类型的负载均衡类lbc1的描述信息为“LB class LBC1”。
[Sysname] loadbalance class lbc1 type generic
[Sysname-lbc-generic-lbc1] description LB class LBC1
# 配置通用类型的负载均衡策略lbp1的描述信息为“LB policy LBP1”。
[Sysname-lbp-generic-lbp1] description LB policy LBP1
# 配置IP类型的参数模板pp2的描述信息为“Parameter profile PP2”。
[Sysname] parameter-profile pp2 type ip
[Sysname-para-ip-pp2] description Parameter profile PP2
# 配置实服务器rs的描述信息为“Real server RS”。
[Sysname-rserver-rs] description Real server RS
# 配置实服务组sf的描述信息为“Server farm SF”。
[Sysname-sfarm-sf] description Server farm SF
# 配置SNAT地址池lbsp的描述信息为“SNAT pool LBSP”。
[Sysname] loadbalance snat-pool lbsp
[Sysname-lbsnat-pool-lbsp] description SNAT pool LBSP
# 配置持续性组sg1的描述信息为“Sticky group SG1”。
[Sysname] sticky-group sg1 type address-port
[Sysname-sticky-address-port-sg1] description Sticky group SG1
# 配置IP类型的虚服务器vs3的描述信息为“Virtual server VS”。
[Sysname-vs-ip-vs3] description Virtual server VS
# 配置ISP isp1的描述信息为“LB ISP 1”。
[Sysname] loadbalance isp name isp1
[Sysname-lbisp-isp1] description LB ISP 1
# 配置链路组lg的描述信息为“Link group lg”。
[Sysname-lb-lgroup-lg] description Link group lg
# 配置DNS服务器池dns-pool的描述信息为“DNS server pool”。
[Sysname] loadbalance dns-server-pool dns-pool
[Sysname-lb-dspool-dns-pool] description DNS server pool
# 配置DNS服务器ds1的描述信息为“DNS server A”。
[Sysname] loadbalance dns-server ds1
[Sysname-lb-ds-ds1] description DNS server A
display loadbalance action命令用来显示负载均衡动作的信息。
display loadbalance action [ name action-name ]
context-admin
context-operator
name action-name:显示指定负载均衡动作的信息。action-name为负载均衡动作的名称,为1~63个字符的字符串,不区分大小写。如果未指定本参数,将显示所有负载均衡动作的信息。
# 显示所有负载均衡动作的信息。
<Sysname> display loadbalance action
LB action: lba1
  Description:
  Type: Generic
  State: Inactive
  Forward type: Drop
  IP ToS:
LB action: lba2
  Description:
  Type: HTTP
  State: Active
  Forward type: Server farm
  Server farm: sf (in use)
  Backup server farm: sfb
  Sticky: sg3
  IP ToS: 20
  SSL client policy:
  Header delete:
    Direction: Request
  Header insert:
    Value: 1234567890123456789012345678901234567890123456789012345678901234567890
    Direction: Both
  Header insert:
    Value: dd
    Direction: Request
  Header rewrite:
    Value: dd
    Replacement: ff
    Direction: Response
  SSL URL rewrite:
    Value: 12
    Clear port: 12
    SSL port: 123
LB action: lba3
  Description: sina
  Type: Link-generic
  State: Active
  Forward type: link-group
  Link group: lg1 (in use)
  Backup link group: lg2
  Sticky:
  IP ToS:
LB action: lba4
   Description: xx
   Type: DNS
   State: Active
   Forward type: DNS server pool
   DNS server pool: dsp1
   Sticky: st
   IP ToS:
   Fallback-action: Disabled
LB action: lba5
  Description:
  Type: HTTP
  State: Active
  Forward type: Redirect
  IP ToS:
  SSL client policy:
  Content rewrite:
    Value:
    Replacement:
  Redirect relocation: www.h3c.com
  Redirect return-code: 302
表1-1 display loadbalance action命令显示信息描述表
LB action
负载均衡动作的名称
负载均衡动作的描述信息
负载均衡动作的类型,包括:
·         DNS:表示DNS类型
·         Generic:表示通用类型
·         HTTP:表示HTTP类型
·         Link-generic:表示链路类型
·         RADIUS:表示RADIUS类型
负载均衡动作的状态,包括:
·         Active:可用
·         Inactive:不可用
Forward type
负载均衡动作中的报文转发模式,包括:
·         Drop:丢弃
·         Forward:正常转发
·         Server farm:通过实服务组指导转发(Generic\HTTP\Radius类型的负载均衡动作)
·         Link group:链路组(Link-generic类型的负载均衡动作)
·         DNS server pool:通过DNS服务器池指导转发(DNS类型的负载均衡动作)
·         Skip current DNS proxy:跳过当前DNS透明代理(DNS类型的负载均衡动作)
·         Redirect:重定向类型
Server farm
指导转发的主用实服务组名称,(in use)表示该实服务组正被使用。只有当报文转发模式为server farm时才会显示本字段
Backup server farm
指导转发的备用实服务组名称,(in use)表示该实服务组正被使用。只有当报文转发模式为server farm时才会显示本字段
Link group
缺省的链路组,如果包含(in use)代表链路组是当前正在使用
Backup link group
备份的链路组,如果包含(in use)代表实链路组是当前正在使用
Sticky
指导转发的持续性组名称,只有当报文转发模式为server farm和DNS server pool时才会显示本字段
IP ToS
IP报文的ToS字段值
SSL client policy
SSL客户端策略的名称,只有HTTP类型的负载均衡动作才会显示本字段
Header delete
删除HTTP首部的配置,其中:
·         Name:HTTP报文首部的名称
·         Direction:HTTP报文的方向,包括Both、Request和Response
只有配置了header delete命令才会显示本字段
Header insert
插入HTTP首部的配置,其中:
·         Name:要插入HTTP报文中的首部名称
·         Value:要插入HTTP报文中的首部内容
只有配置了header insert命令才会显示本字段
Header rewrite
重写HTTP首部的配置,其中:
·         Name:HTTP报文首部的名称
·         Value:要被重写的HTTP报文首部的内容
·         Replacement:重写后的内容
只有配置了header rewrite命令才会显示本字段
SSL URL rewrite
重写服务器发送的HTTP应答报文Location首部的URL的配置,其中:
·         Value:Location首部URL的正则表达式
·         Clear port:原HTTP端口号
·         SSL port:重写后的SSL端口号
只有配置了ssl url rewrite命令才会显示本字段
DNS server pool
指导转发的DNS服务器池名称,只有当报文转发模式为DNS server pool时才会显示本字段
display loadbalance alg用来显示所有协议的负载均衡ALG(Application Level Gateway,应用层网关)状态。
context-admin
context-operator
# 显示所有协议的负载均衡ALG状态。
<Sysname> display loadbalance alg
LB ALG:
  DNS         : Enable
  FTP         : Enable
  H323        : Disabled
  ICMP-ERROR  : Enable
  ILS         : Disabled
  MGCP        : Disabled
  NBT         : Disabled
  PPTP        : Enable
  RSH         : Disabled
  RTSP        : Enable
  SCCP        : Disabled
  SIP         : Disabled
  SQLNET      : Disabled
  TFTP        : Disabled
  XDMCP       : Disabled
display loadbalance class命令用来显示负载均衡类的信息。
display loadbalance class [ name class-name ]
context-admin
context-operator
name class-name:显示指定负载均衡类的信息。class-name为负载均衡类的名称,为1~63个字符的字符串,不区分大小写。如果未指定本参数,将显示所有负载均衡类的信息。
# 显示所有负载均衡类的信息。
<Sysname> display loadbalance class
LB class: lbc1
  Description:
  Type: HTTP
  Match type: Match-all
  Match rule:
    match 1 source ip address 1.2.3.0 24
    match 2 source ipv6 address 1::2
    match 3 cookie abc value 123
    match 4 header def value 12
    match 5 method ext xde
    match 6 method rfc CONNECT
    match 7 class cla2
    match 8 url 2q3
    match 9 acl ipv4 number 2000
    match 10 acl ipv6 number 2001
    match 11 acl ipv4 name aaa
    match 12 acl ipv6 name bbb
    match 13 isp name isp1
LB class: lbc2
  Description:
  Type: Generic
  Match type: Match-any
  Match rule:
    match 1 class cla2
    match 2 source ip address 1.2.23.0 24
    match 3 source ipv6 address 1::12
    match 4 acl ipv4 number 3000
    match 5 acl ipv6 number 3001
    match 6 acl ipv4 name ccc
    match 7 acl ipv6 name ddd
    match 8 isp name isp2
LB class: lbc3
  Description:
  Type: Link-generic
  Match rule:
    match 1 class cla3
    match 2 source ip address 1.2.3.0 24
    match 4 acl ipv4 number 3002
    match 5 acl ipv6 number 3003
LB class: lbc4
  Description:
  Type: DNS
  Match rule:
    match 1 class cla2
    match 8 destination ip address 1.2.3.0 24
    match 9 destination ipv6 address 1::12
    match 10 domain-name www.h3c.com
表1-2 display loadbalance class命令显示信息描述表
LB class
负载均衡类的名称
负载均衡类的描述信息
负载均衡类的类型,包括:
·         DNS:表示DNS类型
·         Generic:表示通用类型
·         HTTP:表示HTTP类型
·         RADIUS:表示RADIUS类型
Match type
负载均衡类的匹配类型,包括:
·         Match-all:表示需要匹配所有规则才算匹配该类
·         Match-any:表示只需匹配任一规则就算匹配该类
Match rule
负载均衡类包含的匹配规则
display loadbalance dns-cache命令用来显示DNS缓存信息。
display loadbalance dns-cache [ domain-name domain-name ] [ slot slot-number ]
context-admin
context-operator
domain-name domain-name:显示指定域名的DNS缓存信息。domain-name为域名,为1~253个字符的字符串,不区分大小写。如果未指定本参数,将显示所有域名的DNS缓存信息。
slot slot-number:显示指定成员设备上的DNS缓存信息,slot-number表示设备在IRF中的成员编号。如果未指定本参数,将显示所有成员设备上的DNS缓存信息。
DNS缓存信息用于记录域名和IP地址的对应关系。
# 显示所有DNS缓存信息。
<Sysname> display loadbalance dns-cache
Slot 1:
Domain name: www.aaa.com
IPv4 addresses: 6.3.5.2
                4.5.6.3
                192.169.41.8
IPv6 addresses: 4:4:4::7
Domain name: www.bbb.com
IPv4 addresses: 5.5.5.5
                3.4.5.9
表1-3 display loadbalance dns-cache命令显示信息描述表
Domain name
域名
IPv4 addresses
域名对应的IPv4地址
IPv6 addresses
域名对应的IPv6地址
display loadbalance dns-listener命令用来显示DNS监听器的信息。
display loadbalance dns-listener [ name listener-name ]
context-admin
context-operator
name listener-name:指定DNS监听器的信息。listener-name为DNS监听器的名称,为1~63个字符的字符串,不区分大小写。如果未指定本参数,将显示所有DNS监听器的信息。
使用本命令可以查看系统的DNS 监听器信息,主要包含服务状态、IPv4、监听端口号及监听到不存在域名的处理方式。
# 显示DNS监听器listener1的信息。
<Sysname> display loadbalance dns-listener name listener1
DNS listener name:listener1
Service state:Enabled
IPv4 address: 1.1.1.2
Port: 53
IPv6 address: --
IPv6 Port: 53
Fallback: Reject
VPN instance:
表1-4 display loadbalance dns-listener命令显示信息描述
DNS listener name
DNS监听器名称
Service state
DNS监听器是否开启:
·         Enabled:表示DNS监听器处于开启状态
·         Disabled:表示DNS监听器处于关闭状态
IPv4 address
DNS监听器的IPv4地址信息
Port
DNS监听器的监听端口号
IPv6 address
DNS监听器的IPv6地址信息
IPv6 Port
DNS监听器的IPv6监听端口号
Fallback
DNS监听器无法找到响应DNS请求的服务器时的处理方式:
·         No-response:不回应DNS请求
·         Reject:回应一个DNS拒绝报文
VPN instance
DNS监听器所属的VPN实例名称
display loadbalance dns-listener statistics命令用来显示DNS监听器的统计信息。
display loadbalance dns-listener statistics [ name dns-listener-name ] [ slot slot-number ]
context-admin
context-operator
name dns-listener-name:指定一个DNS监听器的名称,dns-listener-name表示DNS监听器的名称,为1~63个字符的字符串,不区分大小写。若不指定该参数,则表示显示所有的DNS监听器的统计信息。
slot slot-num:显示指定成员设备上的DNS监听器统计信息,slot-number表示设备在IRF中的成员编号。如果未指定本参数,将显示所有成员设备上的信息。
# 显示DNS监听器dl的统计信息。
<Sysname> display loadbalance dns-listener statistics name dl
DNS listener: dl
Received requests: 100
Received valid requests: 70
Unresponded requests: 10
Rejected requests: 20
DNS proxy requests: 0
  RCVR - Received requests, RVR - Received valid requests,
  UR - Unresponded requests, RJTR - Rejected requests
  Type        RCVR        RVR       UR          RJTR         PR
  A           50          50        0           0            0
  AAAA        0           0         0           0            0
  CNAME       10          5         5           0            0
  MX          20          5         5           10           0
  NS          10          5         0           5            0
  PTR         10          5         0           5            0
  SOA         0           0         0           0            0
  TXT         10          5         0           5            0
  SRV         0           0         0           0            0
表1-5 display loadbalance dns-listener statistics命令显示信息描述表格内容
DNS listener
DNS监听器的名称
Received requests
DNS监听器接收到的DNS请求报文数
DNS监听器接收到的DNS正常请求数
DNS监听器未应答DNS请求报文数
Rejected requests
DNS监听器拒绝的DNS请求报文数
DNS proxy requests
DNS监听器通过DNS代理回应请求报文的数目
请求报文类型,包括:
·         MX:邮件交换类型
·         CNAME:别名类型
·         NS:名字服务器类型
·         SOA:原始权威服务器类型
·         PTR:指针记录类型
·         A:主机记录类型
·         AAAA:AAAA记录类型
·         SRV:服务类型
·         TXT:文本类型
display loadbalance dns-map命令用来显示DNS映射的配置信息。
display loadbalance dns-map [ name dns-map-name ]
context-admin
context-operator
dns-map-name:DNS映射名,为1~63个字符的字符串,不区分大小写。如果未指定本参数,将显示所有DNS映射的配置信息。
使用本命令可以查看系统的DNS映射配置信息,主要包含服务状态、映射的域名、引用虚服务器池。
# 显示指定DNS映射dm1的配置信息。
<Sysname> display loadbalance dns-map name dm1
DNS mapping name: dm1
Service state: Enabled
TTL: 3600s
Domain name list: www.h3c.domain.com
Virtual server pool: pool1
表1-6 display loabalance dns-map命令显示信息描述表
DNS mapping name
DNS映射的名称
Service state
DNS映射服务是否开启:
·         Enabled:表示映射服务处于开启状态
·         Disabled:表示映射服务处理关闭状态
TTL
DNS应答报文所填充的域名记录的缓存时间,单位为秒
Domain name list
DNS映射的DNS域名
Virtual server pool
DNS映射引用的虚服务器池名称
display loadbalance dns-map statistics命令用来显示DNS映射的统计信息。
display loadbalance dns-map statistics [ name dns-map-name ] [ slot slot-number ]
context-admin
context-operator
name dns-map-name:指定一个DNS映射的名称,为1~63个字符的字符串,不区分大小写。如果不指定该参数,将显示所有DNS映射的统计信息。
slot slot-num:显示指定成员设备上的DNS映射统计信息,slot-number表示设备在IRF中的成员编号。如果未指定本参数,将显示所有成员设备上的信息。
# 显示DNS映射名dm的统计信息。
<Sysname> display loadbalance dns-map statistics name dm
DNS map: dm
Matched DNS requests: 100
表1-7 display loadbalance dns-map statistics命令显示信息描述表
DNS map
DNS映射名称
DNS映射匹配的DNS请求数
display loadbalance dns-proxy命令用来显示DNS透明代理的信息。
display loadbalance dns-proxy [ brief | name dns-proxy-name ]
context-admin
context-operator
brief:显示DNS透明代理的简要信息。如果未指定本参数,将显示DNS透明代理的详细信息。
name dns-proxy-name:DNS透明代理名字,为1~63个字符的字符串,不区分大小写。如果未指定本参数,则显示所有DNS透明代理的信息。
# 显示所有DNS透明代理的简要信息。
<Sysname> display loadbalance dns-proxy brief
DNS proxy     State       Type    VPN instance    IP address     Port
dns-proxy1    Active      UDP                     1.2.3.0/24     53
dns-proxy2    Inactive    UDP                     --             5353
# 显示DNS透明代理dns-proxy1的信息
<Sysname> display loadbalance dns-proxy name dns-proxy1
DNS proxy:dns-proxy1
  Type: UDP
  State: Active
  VPN instance:
  IPv4 address: 1.2.3.0/24
  IPv6 address: --
  Port: 53
  DNS server pool: dns-pool1
  Sticky: st
  LB policy: dns-policy1
  Connection synchronization: Enabled
  Sticky synchronization: Enabled
  Bandwidth busy protection: Disabled
表1-8 display loadbalance dns-proxy命令显示信息描述表格内容
DNS proxy
DNS透明代理名称
DNS透明代理类型,目前仅支持UDP类型
DNS透明代理的状态,包括:
·         Active:可用
·         Inactive:不可用
·         Inactive (disabled):不可用(由于未开启DNS透明代理功能)
Service State
DNS透明代理是否使能:
·         Enabled:使能
·         Disabled:未使能
VPN instance
DNS透明代理所属的VPN实例名称
IPv4 address
DNS透明代理的IPv4地址
IPv6 address
DNS透明代理的IPv6地址
Port
DNS透明代理的端口号
DNS server pool
DNS透明代理缺省使用的DNS服务器池
Sticky
DNS透明代理引用的持续性组
LB policy
DNS透明代理引用的负载均衡策略
DNS透明代理会话扩展信息备份功能的状态,包括:
·         Enabled:开启
·         Disabled:关闭
DNS透明代理持续性表项备份功能的状态,包括:
·         Enabled:开启
·         Disabled:关闭
链路带宽繁忙保护功能的状态,包括:
·         Enabled:开启
·         Disabled:关闭
display loadbalance dns-proxy statistics命令用来显示DNS透明代理的统计信息。
display loadbalance dns-proxy statistics [ name dns-proxy-name ] [ slot slot-number ]
context-admin
context-operator
name dns-proxy-name:显示指定DNS透明代理的统计信息。dns-proxy-name为DNS透明代理的名称,为1~63个字符的字符串,不区分大小写。如果未指定本参数,将显示所有DNS透明代理的统计信息。
slot slot-number:显示指定成员设备上的统计信息,slot-number表示设备在IRF中的成员编号。如果未指定本参数,将显示所有成员设备上的统计信息。
# 显示指定DNS透明代理dns-proxy1的统计信息。
<Sysname> display loadbalance dns-proxy statistics name dns-proxy1
DNS proxy: dns-proxy1
Dropped requests: 2
Received responses: 98
Dropped responses: 0
表1-9 display dns-proxy statistic命令显示信息描述表格内容
DNS proxy
DNS透明代理名称
Received requests
DNS透明代理接受DNS请求报文的数目
Dropped requests
DNS透明代理丢弃DNS请求报文的数目
Received responses
DNS透明代理接受DNS应答报文的数目
Dropped responses
DNS透明代理丢弃DNS应答报文的数目
display loadbalance dns-server用来显示DNS服务器的信息。
display loadbalance dns-server [ brief | name dns-server-name ]
context-admin
context-operator
brief:显示DNS服务器的简要信息。若未指定本参数,将显示DNS服务器的详细信息。
name dns-server-name:显示指定DNS服务器的详细信息。其中,dns-server-name表示DNS服务器名,为1~63个字符的字符串,不区分大小写。
若不指定任何参数,则显示所有DNS服务器的详细信息。
# 显示所有DNS服务器的简要信息。
<Sysname> display loadbalance dns-server brief
DNS server   Address          Port    Link         State         DNS server pool
ds1          10.150.100.100   0       link1        Active        dns_pool
ds2          20.150.100.100   5353    link2        Probe-failed  dns_pool
ds3          --               0       link3        Inactive      dns_pool
# 显示DNS服务器ds1的详细信息。
<Sysname> display loadbalance dns-server name ds1
DNS server: ds1
  Description:
  State: Active
  IPv4 address: 10.150.100.100
  IPv6 address: --
  Port: 0
  Link: link1
  Weight: 100
  Priority: 4
Probe information:
Probe success criteria: All
Probe method      State
t4                Succeeded
表1-10 display loadbalance dns-server命令显示信息描述表
DNS server
DNS服务器的名称
Address
DNS服务器的IPv4地址
Link
DNS服务器对应的链路
DNS服务器的状态,包括:
·         Active:可用
·         Busy:繁忙(当DNS服务器处于Active状态,且开启繁忙保护功能时,若达到带宽繁忙阈值则显示为繁忙状态)
·         Inactive:不可用(由于配置不完全、未被引用)
·         Probe-failed:健康检测失败
DNS服务器的描述信息
IPv4 address
DNS服务器的IPv4地址
IPv6 address
DNS服务器的IPv6地址
Port
DNS服务器的端口号
Weight
DNS服务器的权值
Priority
DNS服务器的优先级
Probe information
DNS服务器健康检测的详细信息
DNS服务器健康检测的成功条件:
·         All:只有全部方法都通过检测才认为健康检测成功
·         At least:健康检测成功所需通过检测的最少方法数
Probe method
健康检测方法所使用的NQA模板名称
健康检测方法的状态,包括:
·         Failed:健康检测失败
·         In progress:正在进行健康检测
·         Invalid:健康检测不可用(因其所使用的NQA模板配置不完全),或者DNS服务器不可用
·         Succeeded:健康检测成功
display loadbalance dns-server statistics命令用来显示DNS服务器的统计信息。
display loadbalance dns-server statistics [ name dns-server-name ] [ slot slot-number ]
context-admin
context-operator
name dns-server-name:显示指定DNS服务器的统计信息。dns-server-name为DNS服务器的名称,为1~63个字符的字符串,不区分大小写。如果未指定本参数,将显示所有DNS服务器的统计信息。
# 显示指定DNS服务器ds1的统计信息。
<Sysname> display loadbalance dns-server statistics name ds1
DNS server: ds1
Send requests: 98
Dropped requests: 2
Send responses: 98
表1-11 display loadbalance dns-server statistic命令显示信息描述表
DNS server
DNS服务器名字
Received requests
DNS服务器接受DNS请求报文的数目
Send requests
DNS服务器分发DNS请求报文的数目
Dropped requests
DNS服务器丢弃DNS请求报文的数目
Received responses
DNS服务器接受DNS应答报文的数目
Send responses
DNS服务器分发DNS应答报文的数目
Dropped responses
DNS服务器丢弃DNS应答报文的数目
display loadbalance dns-server-pool命令用来显示DNS服务器池的信息。
display loadbalance dns-server-pool [ brief | name pool-name ]
context-admin
context-operator
brief:显示DNS服务器池的简要信息。如果未指定本参数,将显示DNS服务池的详细信息。
name pool-name:显示指定DNS服务器池的详细信息。其中,pool-name为DNS服务器池的名称,为1~63个字符的字符串,不区分大小写。
若不指定任何参数,则显示所有DNS服务器池的详细信息。
# 显示所有DNS服务器池的简要信息。
<Sysname> display loadbalance dns-server-pool brief
Predictor: RR - Round robin, RD - Random,
           BW - Bandwidth, MBW - Max bandwidth,
           IBW - Inbound bandwidth, OBW - Outbound bandwidth,
           MIBW - Max inbound bandwidth, MOBW - Max outbound bandwidth,
           HASH(SIP) - Hash address source IP,
           HASH(DIP) - Hash address destination IP,
           HASH(SIP-PORT) - Hash address source IP-port
DNS server pool    Predictor     Total    Active
dns-pool           RR            3        2
dns-pool1          RR            0        0
dns-pool2          RD            3        0
# 显示DNS服务器池dns-pool的详细信息。
<Sysname> display loadbalance dns-server-pool name dns-pool
Description:
Predictor: Round robin
Selected server: Enabled
Min servers: 3
  Max servers: 5
Probe information:
  Probe success criteria: At-least 2
  Probe method: t4
Total DNS servers: 3
Active DNS servers: 0
DNS server list:
Name        State         Address          port    Link        Weight   Priority
ds1         Active        10.150.100.100   0       link1       100      4
ds2         Probe-failed  20.150.100.100   5353    link2       100      4
ds3         Inactive      --               0       link3       100      4
表1-12 display loadbalance dns-server-pool命令显示信息描述表
Predictor
DNS服务器池的调度算法,包括:
·         RR:加权轮转算法
·         RD:随机算法
·         BW:总带宽算法
·         IBW:入方向带宽算法
·         OBW:出方向带宽算法
·         MBW:最大总带宽算法
·         MIBW:最大入方向带宽算法
·         MOBW:最大出方向带宽算法
·         HASH(SIP):根据源IP地址进行的哈希算法
·         HASH(DIP):根据目的IP地址进行的哈希算法
·         HASH(SIP-PORT):根据源IP地址和端口号进行的哈希算法
DNS server pool
DNS服务器池的名称
Total
包含的DNS服务器总数
Active
活跃的DNS服务器数量
DNS服务器池的描述信息
Predictor
DNS服务器池的调度算法,包括:
·         Round robin:加权轮转算法
·         Random:随机算法
·         Bandwidth:总带宽算法
·         Inbound bandwidth:入方向带宽算法
·         Outbound bandwidth:出方向带宽算法
·         Max bandwidth:最大总带宽算法
·         Max inbound bandwidth:最大入方向带宽算法
·         Max outbound bandwidth:最大出方向带宽算法
·         Hash address source IP:根据源IP地址进行的哈希算法
·         Hash address source IP-port:根据源IP地址和端口号进行的哈希算法
·         Hash address destination IP:根据目的IP地址进行的哈希算法
Selected server
DNS服务器池中可被调度算法调用的DNS服务器数量限制功能的状态,包括Disabled(关闭)和Enabled(开启)两种。在开启状态下还会显示:
·         Min servers:可被调度算法调用的DNS服务器最小数量
·         Max servers:可被调度算法调用的DNS服务器最大数量
Probe information
DNS服务器池健康检测的详细信息
健康检测的成功条件:
Probe method
健康检测方法所使用的NQA模板名称
Total DNS servers
包含的DNS服务器数量
Active DNS servers
活跃的DNS服务器数量
DNS server list
DNS服务器列表
Name
DNS服务器的名称
DNS服务器的状态,包括:
·         Active:可用
·         Busy:繁忙(当DNS服务器处于Active或Ramp状态,且开启繁忙保护功能时,若达到带宽繁忙阈值则显示为繁忙状态)
Address
DNS服务器的IPv4地址和IPv6地址
Port
DNS服务器的端口号
Link
DNS服务器对应的链路的名称
Weight
DNS服务器的权值
Priority
DNS服务器的调用优先级
display loadbalance hot-backup statistics命令用来显示负载均衡热备份的统计信息。
display loadbalance hot-backup statistics [ slot slot-number ]
context-admin
context-operator
slot slot-number:显示指定成员设备上的信息,slot-number表示设备在IRF中的成员编号。如果未指定本参数,将显示所有成员设备上的信息。
# 显示负载均衡热备份的统计信息。
<Sysname> display loadbalance hot-backup statistics
Slot 2:
               TryAdd    TryDel    AckDel    AckOK     AckNO     NotSpt
  StiSnd       1         0         0         0         0         0
  StiRcv       0         0         0         0         0         0
  StiSndFail   0         0         0         0         0         0
  StiRcvFail   0         0         0         0         0         0
  MsgSnd       1         0         0         0         0         0
  MsgRcv       0         0         0         0         0         0
  MsgSndFail   0         0         0         0         0         0
  MsgRcvFail   0         0         0         0         0         0
  MAllocFail   0         0         0         0         0         0
  SesBkTotal : 0
  SesBkFail  : 0
  SesResTotal: 0
  SesResFail : 0
  SesUpdate  : 0
表1-13 display loadbalance hotbackup statistics命令显示信息描述表
TryAdd
持续性表项添加消息
TryDel
持续性表项删除消息
AckDel
持续性表项确认删除消息
AckOK
持续性表项可以删除消息
AckNO
持续性表项不能删除消息
NotSpt
不支持的持续性表项消息
StiSnd
发送条数
StiRcv
接收条数
StiSndFail
发送失败条数
StiRcvFail
接收失败条数
MsgSnd
报文发送次数
MsgRcv
报文接收次数
MsgSndFail
报文发送失败次数
MsgRcvFail
报文发送失败次数
MAllocFail
内存申请失败次数
SesBkTotal
会话备份次数
SesBkFail
会话备份失败次数
SesResTotal
会话恢复次数
SesResFail
会话恢复失败次数
SesUpdate
会话更新次数
display loadbalance isp命令用来显示ISP的信息。
display loadbalance isp [ ip ipv4-address | ipv6 ipv6-address | name isp-name ]
context-admin
context-operator
ip ipv4-address:显示指定IPv4地址所对应ISP的信息。
ipv6 ipv6-address:显示指定IPv6地址所对应ISP的信息。
name isp-name:显示指定名称的ISP的信息,isp-name为1~63个字符的字符串,不区分大小写。
如果未指定任何可选参数,将显示所有ISP的信息。
# 显示所有ISP的信息。
<Sysname> display loadbalance isp
(*) - User-defined object
LB ISP: isp1
    Description: ISP1
    IPv4 address/Mask length: --
    IPv6 address/Prefix length: --
LB ISP: isp2(*)
    Description:
        1.2.3.0/32(*)           1.2.3.4/32              3.3.3.6/32(*)
        192.168.6.131/32(*)     192.168.195.189/32(*)
        1::2/128
        FFFF:FFFF:FFFF:FFFF:FFFF:FFFF:FFFF:FFFF/128(*)
# 显示IPv4地址1.2.3.0所对应ISP的信息。
<Sysname> display loadbalance isp ip 1.2.3.0
ISP name            Source                   IPv4 address/Mask length
isp2                user-set                 1.2.3.0/28
isp2                user-set                 1.2.3.0/29
isp2                user-set                 1.2.3.0/30
isp2                file-load                1.2.3.0/31
isp2                file-load & user-set     1.2.3.0/32
# 显示IPv6地址1::1234所对应ISP的信息。
<Sysname> display loadbalance isp ipv6 1::1234
ISP name            Source                   IPv6 address/Prefix length
isp2                user-set                 1::1234/126
isp2                user-set                 1::1234/127
isp2                file-load                1::1234/128
表1-14 display loadbalance isp命令显示信息描述表
(*)表示该ISP信息仅由用户手动配置而来。如果ISP信息既是手工配置又是文件导入时,不显示(*)
LB ISP
ISP的名称
ISP的描述信息
ISP的IPv4地址和掩码长度
ISP的IPv6地址和前缀长度
ISP name
ISP的名称
Source
ISP的来源,包括:
·         user-set:表示由用户手工配置
·         file-load:表示由文件导入
·         file-load & user-set:表示既是手动配置又是文件导入
display loadbalance limit-policy命令用来显示负载均衡连接数限制策略配置信息。
display loadbalance limit-policy [ name policy-name ]
context-admin
context-operator
policy-name:连接数限制策略的名称,为1~63个字符的字符串,不区分大小写。
# 显示限制策略名称为lptest的配置。
<Sysname> display loadbalance limit-policy name lptest
Limit-policy: lptest
  Description:
  Limit rule:
limit lptest acl 3000 amount 10 10
表1-15 display loadbalance limit-policy命令显示信息描述表
Limit-Policy
限制策略名称
限制策略的描述信息
Limit rule
限制规则
display loadbalance link命令用来显示链路的信息。
display loadbalance link [ brief | name link-name ]
context-admin
context-operator
brief:显示所有链路的简要信息。如果未指定本参数,将显示链路的详细信息。
name link-name:显示指定链路的详细信息。link-name为链路的名称,为1~63个字符的字符串,不区分大小写。
如果未指定任何参数,则表示显示所有链路的详细信息。
# 显示所有链路的简要信息。
<Sysname> display loadbalance link brief
Link         Router IP          State        VPN instance     Link group
Lk1          192.168.1.1        Busy         vpn1             lg
Lk2          192.168.2.1        Active       vpn1             lg
Lk3          192.168.3.1        Inactive     vpn1             lg
# 显示链路lk的详细信息。
<Sysname> display loadbalance link name lk
Link: lk
  Description: lk
  State: Busy
  VPN instance: vpn1(Inherit)
  Inherit VPN: Enabled
  Router IP: 1.2.3.4
  Router IPv6: --
  Link-group: lg
  Weight: 100
  Priority: 4
  Cost: 0
  Slow-shutdown: Disabled
  Connection limit: 0
  Rate limit:
    Connections: 10000
    Bandwidth: 10000 Kbytes/s
    Inbound bandwidth: 5000 Kbytes/s
    Outbound bandwidth: 5000 Kbytes/s
Bandwidth busy:
    Max bandwidth: 10000 Kbytes/s
    Max inbound bandwidth: 5000 Kbytes/s
    Max outbound bandwidth: 5000 Kbytes/s
    Busy rate: 80
    Inbound busy rate: 70
    Outbound busy rate: 60
    Busy recovery rate: 60
    Inbound busy recovery rate: 60
    Outbound busy recovery rate: 60
Probe information:
    Probe method                    State
    t4                              Inactive
Link: lk2
  Description: link2
  State: Inactive
  VPN instance: vpn2(Config)
  Inherit VPN: Disabled
  Router IP: 1.2.3.4
  Router IPv6: 2002::2
  Link group: lg
  Weight: 150
  Priority: 3
  Cost: 100
  Slow shutdown: Enabled
  Connection limit: 10000
  Rate limit:
    Connections: 10000
  Bandwidth busy:
    Busy rate: 80
Probe information:
  Probe method      State
  t4                Inactive
表1-16 display loadbalance link命令显示信息描述表
Link
链路的名称
链路的描述信息
链路的状态,包括:
·         Active:可用
·         Busy:繁忙
·         Inactive:不可用(由于配置不完全、未被引用或虚服务器尚未开启)
·         Ramp:温暖上线的爬升阶段
·         Shutdown:关闭
·         Standby:温暖上线的准备阶段
VPN instance
链路所属VPN实例的来源,包括
·         Config:手动配置
·         Inherit:继承
Inherit VPN
链路所属VPN实例继承功能的状态,包括:
·         Enabled:开启
·         Disabled:关闭
Router IP
链路的网关IPv4地址
Router IPv6
链路的网关IPv6地址
Link group
链路所属链路组的名称
Weight
链路的权值
Priority
链路在所属链路组内的优先级
Cost
就近性计算的链路成本
Slow shutdown
链路的慢宕的状态,包括:
·         Disabled:关闭
·         Enabled:开启
Connection limit
链路所允许的最大连接数
Rate limit
链路的速率限制
Connections
链路所允许的每秒最大连接数
Bandwidth
链路所允许的最大总带宽,单位为千字节/秒
Inbound bandwidth
链路所允许的最大入带宽,单位为千字节/秒
Outbound bandwidth
链路所允许的最大出带宽,单位为千字节/秒
Bandwidth busy
带宽繁忙比例
Max bandwidth
带宽繁忙阈值所允许的最大总带宽,单位为千字节/秒
带宽繁忙阈值所允许的最大入带宽,单位为千字节/秒
带宽繁忙阈值所允许的最大出带宽,单位为千字节/秒
Busy rate
链路的总带宽繁忙比例
Inbound busy rate
链路的入带宽繁忙比例
Outbound busy rate
链路的出带宽繁忙比例
Busy recovery rate
链路的总带宽繁忙恢复比例
入方向链路带宽繁忙恢复比例
出方向链路带宽繁忙恢复比例
Probe information
链路健康检测的详细信息
链路健康检测的成功条件:
·         At-least:健康检测成功所需通过检测的最少方法数
Probe method
健康检测方法所使用的NQA模板名称
健康检测方法的状态,包括:
·         Failed:健康检测失败
·         Invalid:健康检测不可用(因其所使用的NQA模板配置不完全),或者实服务器不可用
·         Succeeded:健康检测成功
display loadbalance link out-interface statistics显示链路出接口的统计信息。
display loadbalance link out-interface statistics [ name link-name ]
context-admin
context-operator
name link-name:显示指定链路出接口的统计信息。link-name为链路的名称,为1~63个字符的字符串,不区分大小写。如果未指定本参数,将显示所有链路出接口的统计信息。
当链路出接口为逻辑口时,速率统计信息是利用接口流量自行计算得出。
# 显示链路lk1的出接口统计信息。
<Sysname> display loadbalance link out-interface statistics name lk1
Loadbalance link: lk1
Input rate: 1524 bytes/s
  Output rate: 90 bytes/s
表1-17 display loadbalance out-interface link statistics命令显示信息描述表
Loadbalance link
链路的名称
Input rate
链路出接口入方向速率,单位为字节/秒
Output rate
链路出接口出方向速率,单位为字节/秒
display loadbalance link statistics显示链路的统计信息。
display loadbalance link statistics [ name link-name ] [ slot slot-number ]
context-admin
context-operator
name link-name:显示指定链路的统计信息。link-name为链路名称,长度为1~63个字符的字符串,不区分大小写。
slot slot-number:显示指定成员设备上的链路统计信息,slot-number表示设备在IRF中的成员编号。如果未指定本参数,将显示所有成员设备上的链路统计信息。
# 显示链路lk1的统计信息
<Sysname> display loadbalance link statistics name lk1
  Total connections: 1798
  Active connections: 788
  Max connections: 803
  Connections per second: 157
  Max connections per second: 163
  Downstream traffic: 333332 bytes
  Upstream traffic: 472054 bytes
  Throughput: 4396 bytes/s
  Inbound throughput: 1214 bytes/s
  Outbound throughput: 3128 bytes/s
  Max throughput: 4564 bytes/s
  Max inbound throughput: 1214 bytes/s
  Max outbound throughput: 3320 bytes/s
  Received packets: 1798
  Sent packets: 0
  Dropped packets: 0
表1-18 display loadbalance link statistics命令显示信息描述表
Loadbalance link
链路的名称
Total connections
总连接数
Active connections
当前活动的连接数
Max connections
最大连接数
每秒连接数
最大每秒连接数
Downstream traffic
链路的下行流量,LB设备收到的流量,单位为字节
Upstream traffic
链路的上行流量,LB设备发送的流量,单位为字节
Throughput
报文的总吞吐量,单位为字节/秒
Inbound throughput
报文的入吞吐量,单位为字节/秒
Outbound throughput
报文的出吞吐量,单位为字节/秒
Max throughput
报文的最大总吞吐量,单位为字节/秒
报文的最大入吞吐量,单位为字节/秒
报文的最大出吞吐量,单位为字节/秒
Received packets
收到的报文数
Sent packets
发出的报文数
Dropped packets
丢弃的报文数
display loadbalance link-group命令用来显示链路组的信息。
display loadbalance link-group [ brief | name link-group-name ]
context-admin
context-operator
brief:显示所有链路组的简要信息。如果未指定本参数,将显示链路组的详细信息。
name link-group-name:显示指定链路组的信息。link-group-name为链路组的名称,为1~63个字符的字符串,不区分大小写。如果未指定本参数,将显示所有链路组的信息。
如果链路组配置不完整,链路组未被引用或虚服务未开启,则链路状态将显示为不可用,但并不代表该链路本身不可用。
# 显示所有链路组的简要信息。
<Sysname> display loadbalance link-group brief
Predictor: RR - Round robin, RD - Random, LC - Least connection,
           BW – Bandwidth, MBW – Max bandwidth,
           IBW – Inbound bandwidth, OBW – Outbound bandwidth,
           MIBW – Max inbound bandwidth, MOBW – Max outbound bandwidth,
NAT/SNAT: Y - Enabled, N - Disabled
Link group       Predictor    NAT   SNAT  Total  Active
lg               RR           Y     N     3      3
# 显示所有链路组的详细信息。
Link group: lg1
  Description:
  Predictor: Hash address
  Proximity: Disabled
  NAT: Enabled
  SNAT pool:
  Failed action: Keep
  Active threshold: Enabled
    Lower: 80
    Upper: 90
  Slow-online: Enabled
  Standby time: 5s
  Ramp-up time: 10s
  Selected link: Enabled
    Min link: 100
    Max link: 600
  Probe information:
    Probe method:
    aaa
    ddd
Total link: 1
  Active link: 1
  Link list:
  Name             State         VPN instance    Router IP    Weight    Priority
  Link1            Inactive      vpn1            1.2.3.4      4         100
表1-19 display loadbalance link-group命令显示信息描述表
Link group
链路组的名称
链路组的描述信息
Predictor
链路组的调度算法,包括:
·         Random:随机算法
·         Least connection:加权最小连接算法
·         Bandwidth:总带宽算法
Proximity
链路组中就近性功能的状态,包括:
·         Disabled:关闭
·         Enabled:开启
NAT
链路组中NAT功能的状态,包括:
·         Disabled:关闭
·         Enabled:开启
SNAT pool
链路组引用的SNAT地址池名称
Failed action
链路组的故障处理方式,包括:
·         Keep:保持已有连接
·         Reschedule:重定向连接
·         Reset:断开已有连接
Active threshold
链路组可用条件的状态,包括Disabled(关闭)和Enabled(开启)两种。在开启状态下还会显示:
·         Lower:最小可用百分比
·         Upper:最大可用百分比
Slow-online
链路组中链路温暖上线功能的状态,包括Disabled(关闭)和Enabled(开启)两种。在开启状态下还会显示:
·         Standby time:准备时间
·         Ramp-up time:爬升时间
Selected link
链路组中可被调度算法调用的链路数量限制功能的状态,包括Disabled(关闭)和Enabled(开启)两种。在开启状态下还会显示:
·         Min link:可被调度算法调用的链路最小数量
·         Max link:可被调度算法调用的链路最大数量
链路组健康检测的成功条件:
·         At least X:健康检测成功所需通过检测的最少方法数为X
Probe method
链路组健康检测方法所使用的NQA模板名称
Total link
包含的链路数量
Active link
活跃的链路数量
Link list
链路列表
Name
链路的名称
链路的状态,包括:
·         Active:可用
·         Busy:繁忙(当链路处于Active或Ramp状态,且开启接口获取带宽功能和繁忙保护功能时,若达到带宽繁忙阈值则显示为繁忙状态)
·         Ramp:温暖上线的爬升阶段
·         Shutdown:关闭
·         Standby:温暖上线的准备阶段
VPN instance
链路所属的VPN实例
Router IP
链路的IPv4和IPv6地址
Weight
链路的权值
Priority
链路的调用优先级
display loadbalance local-dns-server parse-fail-record命令用来显示解析失败的DNS请求报文的信息。
display loadbalance local-dns-server parse-fail-record [ type { a | aaaa | cname | mx | ns | soa | srv | txt } ] [ domain domain-name ] | ptr [ ip address { ipv4-address | ipv6-address } ] ] [ vpn-instance vpn-instance-name ] [ slot slot-number ]
context-admin
context-operator
domain domain-name:显示指定域名的解析失败的DNS请求报文信息,不区分大小写,由“.”分隔的字符串组成,每个字符串的长度不超过63个字符,如果该域名为绝对域名,则包括“.”在内的总长度不超过254个字符,如果该域名为非绝对域名,则总长度不超过253个字符。
ip address { ipv4-address | ipv6-address }:显示指定IP地址的解析失败的DNS请求报文信息。该地址为PTR类型DNS请求报文中用于反向解析的IP地址。若未指定本参数,则显示所有IP地址的解析失败的DNS请求报文信息。
type { a | aaaa | cname | mx | ns | ptr | soa | srv | txt }:显示指定类型的解析失败的DNS请求报文信息,包括A、AAAA、CNAME、MX、NS、PTR、SOA、SRV和TXT九种类型。若未指定本参数,则显示所有类型的解析失败的DNS请求。
vpn-instance vpn-instance-name:显示指定VPN实例中解析失败的DNS请求报文信息。vpn-instance-name为VPN实例名称,为1~31个字符的字符串,区分大小写。如果未指定本参数,则显示公网中解析失败的DNS请求报文信息。
slot slot-number:测试指定成员设备,slot-number表示设备在IRF中的成员编号。如果未指定本参数,将测试所有成员设备。
# 显示所有解析失败的DNS请求报文的信息。
<Sysname> display loadbalance local-dns-server parse-fail-record
Slot 0:
  ID  Time         Type    SIP/Port      DIP/Port   VPN instance   Domain        Failure cause
  1   03 Nov 2016 A     1.2.3.4/5001  2.2.2.2/53  vpn1  www.aaa.com    No matched virtual
      19:09:52                                                        server member.
  2   03 Nov 2016  AAAA   1.2.3.4/5001   2.2.2.2/53  vpn1   www.lb.com     No matched.
      19:09:43                                                             DNS mapping
  3   03 Nov 2016 MX    1.2.3.5/5001  2.2.2.2/53  vpn1   mail.aaa.com  No matched record.
      20:09:41
  4   04 Nov 2016 NS    1.2.3.4/5001  2.2.2.2/53  vpn1   ns.aaa.com    No matched record.
      11:15:40
  5   05 Nov 2016 CNAME 1.2.3.4/5001  2.2.2.2/53  vpn1   www.aaa.com   No matched DNS
      11:16:35                                                        zone.
  6   05 Nov 2016 SOA   01.2.3.4/5001  2.2.2.2/53  vpn1   www.aaa.com  No matched DNS
      12:16:25                                                        zone.
  7   05 Dec 2016 PTR   1.2.3.4/5001  2.2.2.2/53  vpn1   1.2.3.4       No matched record.
      15:19:16
表1-20 display loadbalance local-dns-server parse-fail-record命令显示信息描述表
ID
记录序号
Time
接收到DNS请求报文的时间
资源记录的类型,包括:
·         A:主机记录类型
·         AAAA:AAAA记录类型
·         MX:邮件交换类型
·         CNAME:别名类型
·         NS:名字服务器类型
·         SOA:原始权威服务器类型
·         TXT:文本类型
·         SRV:服务类型
·         PTR:指针记录类型
SIP/Port
源IP地址/端口号
DIP/Port
目的IP地址/端口号
VPN instance
VPN实例
Domain
域名
Failure cause
调度失败原因,包括:
·         --:成功
·         No matched DNS listener:无匹配的DNS监听器
·         No matched DNS mapping:无匹配的DNS映射
·         No matched virtual server pool:无匹配的DNS虚服务池
·         No matched DNS zone:无匹配的DNS区域
·         Failed to get buffer:压缩缓冲区无效
·         No matched record:无匹配的DNS资源记录
·         No enough memory resource:无充足的可申请内存
·         Failed to parse domain:域名解析失败
·         Failed to find DNS listener by ID:通过ID无法匹配DNS监听器
·         No scheduling content:调度算法无调度内容
·         Scheduling failed:调度内容存在,调度失败
·         No matched virtual server member:无匹配的虚服务
display loadbalance policy命令用来显示负载均衡策略的信息。
display loadbalance policy [ name policy-name ]
context-admin
context-operator
name policy-name:显示指定负载均衡策略的信息。policy-name为负载均衡策略的名称,为1~63个字符的字符串,不区分大小写。如果未指定本参数,将显示所有负载均衡策略的信息。
# 显示所有负载均衡策略的信息。
<Sysname> display loadbalance policy
LB policy: lbp1
  Description:
  Type: Generic
  Class: lbc1
   Action: lba1
  Default class action: lba0
LB policy: lbp2
  Description:
  Type: HTTP
LB policy: lbp3
  Description:
  Type: Link-generic
  Class: lbc3
  Action: lba3
  Default class action: lba3
LB policy: lbp4
  Description:
  Type: DNS
  Class: lbc4
  Action: lba4
  Default class action: lba4
表1-21 display loadbalance policy命令显示信息描述表
LB policy
负载均衡策略的名称
负载均衡策略的描述信息
负载均衡策略的类型,包括:
·         DNS:表示DNS类型
·         Generic:表示通用类型
·         HTTP:表示HTTP类型
·         RADIUS:表示RADIUS类型
Class
负载均衡策略包含的负载均衡类
Action
负载均衡类对应的负载均衡动作
缺省的负载均衡动作
display loadbalance proximity命令用来显示就近性表项的信息。
display loadbalance proximity [ vpn-instance vpn-instance-name ] [ ip [ ipv4-address ] | ipv6 [ ipv6-address ] ] [ slot slot-number ]
context-admin
context-operator
vpn-instance vpn-instance-name:指定VPN实例中就近性表项的信息。vpn-instance-name为VPN实例名称,为1~31个字符的字符串,区分大小写。如果未指定本参数,则显示公网实例中就近性表项的信息。
ip [ ipv4-address ]:显示IPv4就近性表项的信息。如果指定了ipv4-address参数,将显示指定IPv4地址所对应就近性表项的详细信息;如果未指定ipv4-address参数,将显示所有IPv4就近性表项的简要信息。
ipv6 [ ipv6-address ]:显示IPv6就近性表项的信息。如果指定了ipv6-address参数,将显示指定IPv6地址所对应就近性表项的详细信息;如果未指定ipv6-address参数,将显示所有IPv6就近性表项的简要信息。
如果未指定vpn-instance、ip和ipv6关键字,将显示所有IPv4和IPv6就近性表项的简要信息。
# 显示公网实例中所有IPv4和IPv6就近性表项的简要信息。
<Sysname> display loadbalance proximity
(*) – Real server object
Slot :1
  IPv4 address/Mask length       Timeout     Best link
  1.2.3.0/24                     59          lk1
  1.2.15.0/24                    58          lk2
  IPv6 address/Prefix length     Timeout     Best link
  11:22::/96                     40          lk1
# 显示公网实例中所有IPv4就近性表项的简要信息。
<Sysname> display loadbalance proximity ip
  1.2.3.0/24                     59          lk1
  1.2.15.0/24                    58          lk2
# 显示公网实例中所有IPv6就近性表项的简要信息。
<Sysname> display loadbalance proximity ipv6
  11:22::/96                     40          lk1
# 显示公网实例中,IP地址为1.2.3.1的IPv4就近性表项的详细信息。
<Sysname> display loadbalance proximity ip 1.2.3.1
IPv4 address/Mask length: 1.2.3.0/24
Timeout: 40
Link list:
  lk1
  lk2
# 显示公网实例中,IPv6地址为11:22::的IPv6就近性表项的详细信息。
<Sysname> display loadbalance proximity ipv6 11:22::
IPv6 address/Prefix length: 11:22::/96
Timeout: 34
Link list:
  lk1
  lk2
# 显示VPN名称为vpn1,IPv6地址为11:22::的IPv6就近性表项的详细信息。
<Sysname> display loadbalance proximity vpn-instance vpn1 ipv6 11:22::
Timeout: 34
Link list:
  lk1
  lk2
表1-22 display loadbalance proximity命令显示信息描述表
(*)表示该链路对应对象是实服务器而非链路
就近性表项的IPv4地址和掩码长度
就近性表项的IPv6地址和前缀长度
Timeout
就近性表项的剩余老化时间,单位为秒
Best /link
就近性表项的最优链路
Link list
就近性表项的所有链路列表,优先级依次降低
display loadbalance reverse-zone命令用来显示DNS反向区域的信息。
display loadbalance reverse-zone { ip [ ipv4-address mask-length ] | ipv6 [ ipv6-address prefix-length ] }
context-admin
context-operator
ip:显示IPv4 DNS反向区域的信息。
ipv4-address mask-length:显示指定IPv4地址的DNS反向区域信息。ipv4-address表示IPv4地址;mask-length表示IPv4地址的掩码长度,取值范围为0~32。若未指定本参数,则显示所有IPv4 DNS反向区域的信息。
ipv6:显示IPv6 DNS反向区域的信息。
ipv6-address prefix-length:显示指定IPv6地址的DNS反向区域信息。Ipv6-address表示IPv6地址;prefix-length表示IPv6地址的前缀长度,取值范围为0~128。若未指定本参数,则显示所有IPv6 DNS反向区域的信息。
# 显示所有IPv4 DNS反向区域的信息。
<Sysname> display loadbalance reverse-zone ip
Reverse zone: 10.1.1.0/24
Record list:
Type      TTL      RDATA
PTR       3600     1.1.1.2  a.mail.h3c.com
PTR       2700     1.1.1.3  b.mail.h3c.com
# 显示所有IPv6 DNS反向区域的信息。
<Sysname> display loadbalance reverse-zone ipv6
Reverse zone: 1::/64
Record list:
Type      TTL     RDATA
PTR       3600    1::1  a.mail.h3c.com
PTR       2700    1::2  b.mail.h3c.com
表1-23 display loadbalance reverse-zone命令显示信息描述表
Reverse zone
DNS反向区域的IP地址及掩码/前缀长度
Record list
资源记录列表
资源记录类型(目前仅支持PTR类型的资源记录)
TTL
资源记录的缓存时间,单位为秒
RDATA
资源数据
display loadbalance snat-pool命令用来显示SNAT地址池的信息。
display loadbalance snat-pool [ name pool-name ]
context-admin
context-operator
name pool-name:显示指定SNAT地址池的信息。pool-name为SNAT地址池的名称,为1~63个字符的字符串,不区分大小写。如果未指定本参数,将显示所有SNAT地址池的信息。
# 显示所有SNAT地址池的信息。
<Sysname> display loadbalance snat-pool
SNAT pool: lbsp1
  Description:
  IPv4 range:
    Start address                       End address
    202.110.10.10                       202.110.10.15
  IPv6 range:
    2002::2                             2002::100
SNAT pool: lbsp2
  Description:
  IPv4 range:
    203.110.10.10                       203.110.10.15
  IPv6 range:
    2003::2                             2003::100
表1-24 display loadbalancesnat-pool命令显示信息描述表
SNAT pool
SNAT地址池的名称
SNAT地址池的描述信息
IPv4 range
IPv4地址段
IPv6 range
IPv6地址段
Start address
起始地址
End address
结束地址
display loadbalance virtual-server-pool命令用来显示虚服务器池的信息。
display loadbalance virtual-server-pool [ brief | name pool-name ]
context-admin
context-operator
brief:显示所有虚服务器池的简要信息。
name pool-name:显示指定虚服务器池的详细信息。
如果未指定任何参数,则表示显示所有虚服务器池的详细信息。
# 显示所有虚服务器池的简要信息。
<Sysname> display loadbalance virtual-server-pool brief
           TOP - Topology, PRO – Proximity
VSpool           Pre    Alt    Fbk    BWP     Total    Active
virtual-serve... RR     LC            Enabled  0        0
vpp              RR                   Enabled  0        0
vsp1             RD     TOP           Enabled  3        0
# 显示虚服务器池local-pool的详细信息。
<Sysname> display loadbalance virtual-server-pool name local-pool
Virtual-server pool: local-pool
  Predictor:
   Preferred RD
   Alternate TOP
   Fallback  --
Bandwidth busy-protection:Disabled
Total virtual servers: 3
Active virtual servers: 0
Virtual server list:
Name      State     Address       Port     Weight  Link
vs1       Active    192.168.1.1   0        150     ct-link1
vs2       Active    192.167.1.1   0        120     ct-link2
vs3       Active    192.169.1.1   0        80      cnc-link
表1-25 display loadbalance virtual-server-pool命令显示信息描述表
Virtual-server pool
虚服务器池的名称
Predictor
虚服务器池的调度算法
虚服务器池中繁忙保护功能的状态,包括:
·         Disabled:关闭
·         Enabled:开启
包含的虚服务器数量
活跃的虚服务器数量
Virtual server list
虚服务器列表
Name
虚服务器的名称
虚服务器的状态,包括:
·         Active:可用
·         Busy:繁忙(当链路处于Active,且开启繁忙保护功能时,若达到带宽繁忙阈值则显示为繁忙状态)
·         Inactive:不可用(由于配置不完全或关联link状态不可用)
Address
虚服务器的IPv4地址
Port
虚服务器的端口号
Weight
虚服务器的权值
Link
引用的链路的名称
1.1.58  display loadbalance zone
display loadbalance zone命令用来显示DNS正向区域的信息。
display loadbalance zone [ name domain-name ]
context-admin
context-operator
name domain-name:显示指定DNS正向区域的信息。domain-name为DNS正向区域的域名,不区分大小写,由“.”分隔的字符串组成,每个字符串的长度不超过63个字符,包括“.”在内的总长度不超过253个字符。字符串中可以包含字母、数字、“-”、“_”或“.”。如果未指定本参数,将显示所有DNS正向区域的信息。
# 显示所有DNS正向区域的信息。
<Sysname> display loadbalance zone
Zone: abc.com
  TTL: 3600s
  SOA:
    Primary name server: ns1.abc.com
    Responsible mail: root.ns1.abc.com
    Serial: 11812
    Retry: 14400s
    Expire: 604800s
    Min TTL: 86400s
  Record list:
    Type    TTL        RDATA
    NS      3600s      ns1.abc.com
    NS      4200s      ns2.abc.com
    NS      4200s      a.abc.com       ns2.abc.com
    MX      3600s      a.mail.abc.com  10
    MX      2700s      b.mail.abc.com  20
    CNAME   5000s      a.test.abc.com  abc1.abc.com
    CNMAE   3600s      b.test.abc.com  abc2.abc.com
    TXT     5000s      v=spf1 include:spf.abcmail.abc.com.cn -all
    SRV     --       _ http._tcp.example.com. www.example.com 5 10 80
表1-26 display loadbalance zone命令显示信息描述表
Zone
DNS正向区域的域名
TTL
DNS正向区域中资源记录的缓存时间,单位为秒
SOA
原始权威服务器的相关信息
Primary name server
主域名服务器的主机名
Responsible mail
管理员邮箱地址
Serial
序列号
Retry
重试时间,单位为秒
Expire
过期时间,单位为秒
Min TTL
最小生命周期,单位为秒
Record list
资源记录列表
资源记录类型,包括:
·         MX:邮件交换资源记录
·         CNAME:规范名称资源记录
·         NS:域名服务器资源记录
·         SRV:服务类型
·         TXT:文本类型
TTL
资源记录的缓存时间,单位为秒
RDATA
资源数据
1.1.59  display parameter-profile
display parameter-profile命令用来显示参数模板的信息。
display parameter-profile [ name parameter-name ]
context-admin
context-operator
name parameter-name:显示指定参数模板的信息。parameter-name为参数模板的名称,为1~63个字符的字符串,不区分大小写。如果未指定本参数,将显示所有参数模板的信息。
# 显示所有参数模板的信息。
<Sysname> display parameter-profile
Parameter profile: pp1
  Description:
  Type: IP
  IP ToS: 20
Parameter profile: pp2
  Description:
  Type: TCP
  Exceed MSS: Allow
  TCP window size:65535
  TCP connection idle-timeout: 10 sec
Parameter profile: pp3
  Description:
  Type: HTTP
  Rebalance per request: Enabled
  Server connection reuse: Enabled
  Case insensitive: Enabled
  Header modify per request: Enabled
  Content maximum parse length: 8192
  Header maximum parse length: 8192
  Secondary cookie delimiters: !@#$
  Secondary cookie start: ?
  Header exceed length: Drop
Parameter profile: compress
  Description:
  Type: HTTP compression
  Compression level: 1
  Prefer method: Gzip
  Content length threshold: 1024
  Memory size: 8KB
  Window size: 16KB
  Header Insert: Enabled
  Header Delete: Enabled
  Request version all: Disabled
  Rule 1: Permit url abc
表1-27 display parameter-profile命令显示信息描述表
Parameter profile
参数模板的名称
参数模板的描述信息
参数模板的类型,包括:
·         IP:表示IP类型
·         HTTP:表示HTTP类型
·         TCP:表示TCP类型
IP ToS
发往服务器的IP报文中的ToS字段
Exceed MSS
对客户端发来的HTTP请求报文中超出MSS的数据段的处理方式,包括:
·         Allow:表示允许超出MSS的数据段
·         Drop:表示丢弃超出MSS的数据段
是否开启对每个HTTP请求报文都进行负载均衡的功能,包括:
·         Disabled:关闭
·         Enabled:开启
是否开启允许负载均衡设备与服务器的连接复用的功能,包括:
·         Disabled:关闭
·         Enabled:开启
是否开启对每个HTTP请求或应答报文的首部都执行插入、删除或修改操作的功能,包括:
·         Disabled:关闭
·         Enabled:开启
Case insensitive
是否开启匹配字符串时对大小写不敏感的功能,包括:
·         Disabled:关闭
·         Enabled:开启
HTTP实体的最大解析长度
HTTP首部的最大解析长度
URL中分隔Secondary Cookie的字符
URL中Secondary Cookie的起始位置标示字符
当HTTP请求或应答报文首部超出最大长度时的处理方式,包括:
·         Continue:表示继续执行负载均衡操作
·         Drop:表示停止执行负载均衡操作,丢弃该报文并关闭连接
TCP window size
TCP连接中的本地最大窗口值
TCP连接的空闲超时时间,单位为秒
1.1.60  display real-server
display real-server命令用来显示实服务器的信息。
display real-server [ brief | name real-server-name ]
context-admin
context-operator
brief:显示实服务器的简要信息。如果未指定本参数,将显示实服务器的详细信息。
name real-server-name:显示指定实服务器的信息。real-server-name为实服务器的名称,为1~63个字符的字符串,不区分大小写。如果未指定本参数,将显示所有实服务器的信息。
# 显示所有实服务器的简要信息。
<Sysname> display real-server brief
Real server      Address              Port  State     VPN instance     Server farm
rs1              192.168.1.1          0     Active    vpn1           sf
rs2              192.168.1.2          0     Busy                     sf
rs3              192.168.1.3          0     Active                   sf
# 显示实服务器rs的详细信息。
<Sysname> display real-server name rs
Real server: rs
  Description: Real server RS
  State: Active
  IPv4 address: 1.1.1.1
  IPv6 address: 1001::1
  Port: 8080
  Server farm: sf
  Weight: 150
  Priority: 3
  Cost: 100
  Rate limit:
    Connections: 10000
  Bandwidth busy:
    Busy rate: 80
  Probe information:
    Probe method                    State
    t4                              Succeeded
表1-28 display real-server命令显示信息描述表
Real server
实服务器的名称
Address
实服务器的IPv4地址
Port
实服务器的端口号
实服务器的状态,包括:
·         Active:可用
·         Busy:繁忙(当实服务器处于Active或Ramp状态,且开启接口获取带宽功能和繁忙保护功能时,若达到带宽繁忙阈值则显示为繁忙状态)
·         Ramp:温暖上线的爬升阶段
·         Shutdown:关闭
·         Standby:温暖上线的准备阶段
VPN instance
实服务器所属的VPN实例名称
Server farm
实服务器所属的实服务组
实服务器的描述信息
IPv4 address
实服务器的IPv4地址
IPv6 address
实服务器的IPv6地址
Weight
实服务器的权值
Priority
实服务器的调用优先级
Cost
就近性计算的成本
Slow shutdown
实服务器慢宕功能的状态,包括:
·         Disabled:关闭
·         Enabled:开启
Connection limit
实服务器所允许的最大连接数
Rate limit
实服务器的速率限制
Connections
实服务器所允许的每秒最大连接数
Bandwidth
实服务器所允许的最大总带宽,单位为千字节/秒
Inbound bandwidth
实服务器所允许的最大上行带宽,单位为千字节/秒
Outbound bandwidth
实服务器所允许的最大下行带宽,单位为千字节/秒
Max bandwidth
实服务器繁忙所允许的最大总带宽,单位为千字节/秒
实服务器繁忙所允许的最大上行带宽,单位为千字节/秒
实服务器繁忙所允许的最大下行带宽,单位为千字节/秒
Busy rate
实服务器所允许的总带宽繁忙比
Inbound busy rate
实服务器所允许的上行带宽繁忙比
Outbound busy rate
实服务器所允许的下行带宽繁忙比
Busy recovery rate
实服务器所允许的总带宽繁忙恢复比
实服务器所允许的上行带宽繁忙恢复比
实服务器所允许的下行带宽繁忙恢复比
实服务器健康检测的成功条件:
Probe method
健康检测方法所使用的NQA模板名称
健康检测方法的状态,包括:
·         Failed:健康检测失败
·         Succeeded:健康检测成功
1.1.61  display real-server statistics
display real-server statistics命令用来显示实服务器的统计信息。
display real-server statistics [ name real-server-name ] [ slot slot-number ]
context-admin
context-operator
name real-server-name:显示指定实服务器的统计信息。real-server-name为实服务器的名称,为1~63个字符的字符串,不区分大小写。如果未指定本参数,将显示所有实服务器的统计信息。
# 显示实服务器rs的统计信息。
<Sysname> display real-server statistics name rs
Real server: rs
  Server input: 333332 bytes
  Server output: 472054 bytes
  Sent packets: 0
  Dropped packets: 0
  Received requests: 0
  Dropped requests: 0
  Sent responses: 0
  Connection failures: 1
表1-29 display real-server statistics命令显示信息描述表
Real server
实服务器的名称
Total connections
总连接数
Active connections
当前活动的连接数
Max connections
最大连接数
每秒连接数
最大每秒连接数
Server input
服务器收到的流量,单位为字节
Server output
服务器发出的流量,单位为字节
Throughput
报文的总吞吐量,单位为字节/秒
Inbound throughput
报文的入吞吐量,单位为字节/秒
Outbound throughput
报文的出吞吐量,单位为字节/秒
Max throughput
报文的最大总吞吐量,单位为字节/秒
报文的最大入吞吐量,单位为字节/秒
报文的最大出吞吐量,单位为字节/秒
Received packets
收到的报文数
Sent packets
发出的报文数
Dropped packets
丢弃的报文数
Received requests
接收的HTTP请求报文数量,只有七层实服务器才会显示本字段
Dropped requests
丢弃的HTTP请求报文数量,只有七层实服务器才会显示本字段
Sent responses
发出的HTTP应答报文数量,只有七层实服务器才会显示本字段
Dropped responses
丢弃的HTTP应答报文数量,只有七层实服务器才会显示本字段
Connection failures
建立连接失败
·            reset real-server statistics
1.1.62  display server-farm
display server-farm命令用来显示实服务组的信息。
display server-farm [ brief | name server-farm-name ]
context-admin
context-operator
brief:显示实服务组的简要信息。如果未指定本参数,将显示实服务组的详细信息。
name server-farm-name:显示指定实服务组的信息。server-farm-name为实服务组的名称,为1~63个字符的字符串,不区分大小写。如果未指定本参数,将显示所有实服务组的信息。
# 显示所有实服务组的简要信息。
<Sysname> display server-farm brief
Server farm       Predictor       NAT  SNAT  Total  Active
sf                RR              Y    N     3      3
# 显示所有实服务组的详细信息。
Server farm: sf1
  Description:
  Proximity: Disabled
  NAT: Enabled
  SNAT pool:
  Failed action: Keep
    Lower: 80
    Upper: 90
  Standby time: 5s
  Ramp-up time: 10s
    Min server: 100
    Max server: 600
  Probe information:
    Probe method:
    aaa
    bbb
    ccc
  Total real server: 1
  Active real server: 1
  Real server list:
  Name             State    VPN instance     Address              Port  Weight Priority
  rs1              Inactive                  1.2.3.4              0     4      100
表1-30 display server-farm命令显示信息描述表
Server farm
实服务组的名称
Predictor
实服务组的调度算法,包括:
·         RR:加权轮转算法
·         RD:随机算法
·         LC:加权最小连接算法
·         BW:总带宽算法
·         IBW:入方向带宽算法
·         OBW:出方向带宽算法
·         MBW:最大总带宽算法
·         MIBW:最大入方向带宽算法
·         MOBW:最大出方向带宽算法
NAT
实服务组中NAT功能的状态,Y表示开启,N表示关闭
SNAT
实服务组中SNAT功能的状态,Y表示开启,N表示关闭
Total
包含的实服务器数量
Active
活跃的实服务器数量
实服务组的描述信息
Predictor
实服务组的调度算法,包括:
·         Random:随机算法
·         Bandwidth:总带宽算法
Proximity
实服务器组中就近性功能的状态,包括:
·         Disabled:关闭
·         Enabled:开启
NAT
实服务组中NAT功能的状态,包括:
·         Disabled:关闭
·         Enabled:开启
·         Disabled (no license):因缺少License,NAT功能未使能
SNAT pool
实服务组引用的SNAT地址池名称
Failed action
实服务组的故障处理方式,包括:
·         Keep:保持已有连接
·         Reschedule:重定向连接
·         Reset:断开已有连接
Active threshold
实服务组可用条件的状态,包括Disabled(关闭)和Enabled(开启)两种。在开启状态下还会显示:
·         Lower:最小可用百分比
·         Upper:最大可用百分比
Slow-online
实服务组中实服务器温暖上线功能的状态,包括Disabled(关闭)和Enabled(开启)两种。在开启状态下还会显示:
·         Standby time:准备时间
·         Ramp-up time:爬升时间
Selected server
实服务组中可被调度算法调用的实服务器数量限制功能的状态,包括Disabled(关闭)和Enabled(开启)两种。在开启状态下还会显示:
·         Min server:可被调度算法调用的实服务器最小数量
·         Max server:可被调度算法调用的实服务器最大数量
实服务器健康检测的成功条件:
·         At least x:健康检测成功所需通过检测的最少方法数为x
Probe method
健康检测方法所使用的NQA模板名称
Total real server
包含的实服务器数量
Active real server
活跃的实服务器数量
Real server list
实服务器列表
Name
实服务器的名称
实服务器的状态,包括:
·         Active:可用
·         Ramp:温暖上线的爬升阶段
·         Shutdown:关闭
·         Standby:温暖上线的准备阶段
Address
实服务器的IPv4和IPv6地址
Port
实服务器的端口号
Weight
实服务器的权值
Priority
实服务器的调用优先级
1.1.63  display sticky
display sticky命令用来显示持续性表项的信息。
display sticky { dns-proxy [ dns-proxy-name ] | virtual-server [ virtual-server-name ] } [ class class-name | default-class | default-dns-server-pool | default-link-group | default-server-farm ] [ slot slot-number ]
context-admin
context-operator
dns-proxy dns-proxy-name:显示指定DNS透明代理的持续性表项信息。dns-proxy-name为DNS透明代理的名称,为1~63个字符的字符串,不区分大小写。如果未指定dns-proxy-name,将显示所有DNS透明代理的持续性表项信息。
virtual-server virtual-server-name:显示指定虚服务器的持续性表项信息。virtual-server-name为虚服务器的名称,为1~63个字符的字符串,不区分大小写。如果未指定virtual-server-name,将显示所有虚服务器的持续性表项信息。
class class-name:显示指定负载均衡类的持续性表项信息。class-name为负载均衡类的名称,为1~63个字符的字符串,不区分大小写。
default-class:显示缺省负载均衡动作的持续性表项信息。
default-dns-server-pool:显示缺省DNS服务器池的持续性表项信息。
default-link-group:显示缺省链路组的持续性表项信息。
default-server-farm:显示缺省实服务组的持续性表项信息。
# 显示所有虚服务的持续性表项信息。
<Sysname> display sticky virtual-server
Virtual server name: vs1
  Sticky zone type: Class
  Class name: lbc1
  Sticky group name: sg1
  Sticky method: Source IP and port
  Timeout: 60
Sticky entry                      Real server           Expired time Count
192.168.6.206/1566                192.168.6.206/0       53           0
192.168.6.206/1567                192.168.6.206/0       56           0
Virtual server name: vs2
  Sticky zone type: Default class
  Class name:
  Sticky group name: sg2
  Sticky method: Payload
  Timeout: 60
GET /index.html HTTP/1.1\0d\0aHo 192.168.6.206/0       54           0
st:                              2000::100/0
e3abdec0ed6195bf22942f5996f85f5a
Virtual server name: vs3
  Sticky zone type: Default server farm
  Class name:
  Sticky group name: sg3
  Sticky method: HTTP version
  Timeout: 60
1.0                              192.168.6.206/0       109          0
1.1                              192.168.6.206/0       97           0
0.9                              192.168.6.206/0       116          0
Virtual server name: vs4
  Sticky zone type: Default link group
  Class name:
  Sticky method: Both IP and port
  Timeout: 60
Sticky entry                      Link                  Expired time Count
192.168.6.206/2606                192.168.6.206/0       57           0
192.168.6.40/80
192.168.6.206/2605                192.168.6.206/0       55           0
192.168.6.40/80
# 显示所有DNS透明代理的持续性表项信息。
<Sysname> display sticky dns-proxy
DNS proxy name: dns-proxy1
  Sticky zone type: Default DNS server pool
  Sticky group name: st
  Timeout: 60
Sticky entry               DNS server           Expired time   Count
DNS proxy name: dns-proxy2
  Class name: class
  Timeout: 60
DNS proxy name: dns-proxy3
  Timeout: 60
表1-31 display sticky命令显示信息描述表
Virtual server name
虚服务器的名称
DNS proxy name
DNS透明代理的名称
Sticky zone type
持续性表项的来源,包括:
·         Class:由虚服务所引用策略中的类和动作生成
·         Default class:由虚服务所引用策略中的缺省动作生成
·         Default DNS server pool:由DNS透明代理缺省的DNS服务器池生成
·         Default link group:由虚服务下缺省的主用或备用链路组生成
·         Default server farm:由虚服务下缺省的主用或备用实服务组生成
Class name
如果该持续性由类和动作生成,显示对应负载均衡类的名称;否则显示为空
Sticky group name
生成该持续性表项的持续性组名称
Sticky method
该持续性表项对应的持续性方法,包括:
·         Source IP:源IPv4地址持续性方法
·         Source IPv6:源IPv6地址持续性方法
·         Source IP and port:源IPv4地址+源端口持续性方法
·         Source IPv6 and port:源IPv6地址+源端口持续性方法
·         Destination IP:目的IPv4地址持续性方法
·         Destination IPv6:目的IPv6地址持续性方法
·         Destination IP and port:目的IPv4地址+目的端口持续性方法
·         Destination IPv6 and port:目的IPv6地址+目的端口持续性方法
·         Both IP:源IPv4地址+目的IPv4地址持续性方法
·         Both IPv6:源IPv6地址+目的IPv6地址持续性方法
·         Both IP and port:源IPv4地址+源端口+目的IPv4地址+目的端口持续性方法
·         Both IPv6 and port:源IPv6地址+源端口+目的IPv6地址+目的端口持续性方法
·         HTTP URL:基于HTTP URL的持续性方法
·         HTTP header name:基于HTTP首部名称的持续性方法
·         HTTP version:基于HTTP版本的持续性方法
·         HTTP host:基于HTTP主机的持续性方法
·         HTTP method:基于HTTP Request-Method的持续性方法
·         HTTP content:HTTP实体持续性方法
·         HTTP cookie:HTTP Cookie持续性方法
·         Payload:HTTP载荷持续性方法
·         Framed-IP-Address:基于RADIUS报文Framed-IP-Address属性的持续性方法
·         User-Name:基于RADIUS报文中User-Name属性的持续性方法
·         Code=attribute-code:基于RADIUS报文中指定属性的持续性方法,属性编号为attribute-code
·         SSL session ID:SSL持续性方法为基于SSL会话ID
Timeout
持续性表项的超时时间,单位为秒
Sticky entry
持续性表项对应的Key值
DNS server
DNS服务器的IP地址和端口号
Real server
实服务器的IP地址和端口号。对于七层持续性方法,如果实服务器同时配置了IPv4和IPv6地址,则不论该持续性表项由哪种连接生成,都会同时显示这两个地址
Link
链路的IP地址和端口号
Expired time
持续性表项的老化剩余时间,如果引用计数不为0,则显示为配置值
Count
持续性表项的引用计数
1.1.64  display sticky-group
display sticky-group命令用来显示持续性组的信息。
display sticky-group [ name group-name ]
context-admin
context-operator
name group-name:显示指定持续性组的信息。group-name为持续性组的名称,为1~63个字符的字符串,不区分大小写。如果未指定本参数,将显示所有持续性组的信息。
# 显示所有持续性组的信息。
<Sysname> display sticky-group
Sticky group: sg1
  Description:
  Timeout: 60
  Sticky group type: Address-port
    Method: Both IP and port
      Mask: 32
Sticky group: sg2
  Description:
  Timeout: 60
  Sticky group type: HTTP header
    Method: HTTP header name
      Offset: 4
      Start: gzip
      Length: 10
Sticky group: sg3
  Description:
  Timeout: 60
  Sticky group type: RADIUS
    Method: User-Name
表1-32 display sticky-group命令显示信息描述表
Sticky group
持续性组的名称
持续性组的描述信息
Timeout
持续性表项的超时时间,单位为秒
Sticky group type
持续性组的类型,包括:
·         Address-port:表示地址端口类型
·         HTTP content:表示HTTP实体类型
·         HTTP cookie:表示HTTP Cookie类型
·         HTTP header:表示HTTP首部类型
·         Payload:表示HTTP载荷类型
·         RADIUS:表示RADIUS类型
·         SSL:表示SSL类型
各类型持续性组的具体内容,请参见表1-33
表1-33 各类型持续性组的具体内容
持续性组类型
Address-port
Method
持续性方法,包括:
Mask
持续性方法的掩码长度,只有IPv4持续性方法才会显示本字段
Prefix
持续性方法的前缀长度,只有IPv6持续性方法才会显示本字段
HTTP content
Offset
实体基于HTTP报文起始位置的偏移量
Start
实体开始标记的正则表达式
End
实体结束标记的正则表达式,不会与Length字段同时显示
Length
实体的长度,不会与End字段同时显示
HTTP cookie
Method
持续性方法,包括:
·         HTTP cookie insert:Cookie截取持续性方法
·         HTTP cookie rewrite:Cookie重写持续性方法
·         HTTP cookie get:Cookie插入持续性方法
只有指定了HTTP Cookie持续性方法才会显示本字段
Name
HTTP cookie的名称。只有指定了HTTP Cookie持续性方法才会显示本字段
Offset
Cookie基于HTTP报文起始位置的偏移量。只有指定了Cookie插入持续性方法才会显示本字段
Start
Cookie开始标记的正则表达式。只有指定了Cookie插入持续性方法才会显示本字段
End
Cookie结束标记的正则表达式,不会与Length字段同时显示。只有指定了Cookie插入持续性方法才会显示本字段
Length
Cookie的长度,不会与End字段同时显示。只有指定了Cookie插入持续性方法才会显示本字段
Cookie secondary name
需在URI中查找的Secondary Cookie名称。只有指定了Cookie插入持续性方法才会显示本字段
Check all packets
是否开启检查所有报文的功能,包括:
·         Disabled:关闭
·         Enabled:开启
HTTP header
Method
持续性方法,包括:
只有指定了HTTP首部持续性方法才会显示本字段
Name
HTTP首部的名称。只有指定了基于HTTP首部名称的持续性方法才会显示本字段
Offset
HTTP首部基于HTTP报文起始位置的偏移量。只有指定了基于HTTP主机或HTTP URL的持续性方法才会显示本字段
Start
HTTP首部开始标记的正则表达式。只有指定了基于HTTP主机或HTTP URL的持续性方法才会显示本字段
End
HTTP首部结束标记的正则表达式,不会与Length字段同时显示。只有指定了基于HTTP主机或HTTP URL的持续性方法才会显示本字段
Length
HTTP首部的长度,不会与End字段同时显示。只有指定了基于HTTP主机或HTTP URL的持续性方法才会显示本字段
Payload
Offset
HTTP载荷基于HTTP报文起始位置的偏移量
Start
HTTP载荷开始标记的正则表达式
End
HTTP载荷结束标记的正则表达式,不会与Length字段同时显示
Length
HTTP载荷的长度,不会与End字段同时显示
RADIUS
Method
持续性方法,包括:
·         Framed-IP-Address:基于RADIUS报文中Framed-IP-Address属性的持续性方法
若未指定基于RADIUS属性的持续性方法,则不显示该字段
SSL
Method
持续性方法,包括:
·         SSL session ID:基于SSL session ID的SSL持续性方法
只有指定了基于SSL会话ID的SSL持续性方法才会显示本字段
1.1.65  display virtual-server
display virtual-server命令用来显示虚服务器的信息。
display virtual-server [ brief | name virtual-server-name ]
context-admin
context-operator
brief:显示虚服务器的简要信息。如果未指定本参数,将显示虚服务器的详细信息。
name virtual-server-name:显示指定虚服务器的信息。virtual-server-name为虚服务器的名称,为1~63个字符的字符串,不区分大小写。如果未指定本参数,将显示所有虚服务器的信息。
# 显示所有虚服务器的简要信息。
<Sysname> display virtual-server brief
Virtual server   State    Type      VPN instance     Virtual address     Port
vs1              Inactive IP        vpn1             192.168.21.148/32   80
                                                     1111:2222:3333:4444
                                                     :5555:6666:7777:888
                                                     8/128
vs2              Active   HTTP                       61.159.4.100/32     8080
vs3              Active   LINK-IP                    51.139.4.100/32     0
# 显示虚服务器vs的详细信息。
<Sysname> display virtual-server name vs
Virtual server: vs
  Description: Virtual server VS
  Type: HTTP
  State: Active
  VPN instance: vpn1
  Virtual IPv4 address: 1.1.1.1/32
  Virtual IPv6 address: 1001::1/128
  Port: 8080
  Primary server farm: sf (in use)
  Sticky: sg3
  LB policy: lbp2
  HTTP parameter profile: pp1
  UDP per-packet: Enabled
  Rate limit:
    Connections: 10000
  SSL server policy: ssl-server
  SSL client policy: ssl-client
  Sticky synchronization: Disabled
  Interface bandwidth statistics: Disabled
  Route advertisement: Enabled
# 显示虚服务器lk的详细信息。
<Sysname> display virtual-server name lk
Virtual server: lk
  Description:
  Type: Link-IP
  State: Active
  VPN instance: vpn1
  Port: 0
  Primary link group: lg1 (in use)
  Sticky: sg3
  LB policy: lbp2
  LB limit-policy:
  Rate limit:
    Connections: 10000
  Route advertisement: Disabled
表1-34 display virtual-server命令显示信息描述表
Virtual server
虚服务器的名称
虚服务器的状态,包括:
·         Active:可用
·         Inactive:不可用
·         Inactive (no license):不可用(由于缺少License)
·         Inactive (disabled):不可用(由于未开启虚服务器功能)
虚服务器的类型,包括Fast HTTP、HTTP、IP、RADIUS、TCP、UDP和Link-IP
VPN instance
虚服务器所属的VPN实例名称
Virtual address
虚服务器的IPv4地址和掩码
Port
虚服务器的端口号
虚服务器的描述信息
虚服务器的IPv4地址和掩码
虚服务器的IPv6地址和前缀
Primary server farm
缺省的主用实服务组名称,(in use)表示该实服务组正被使用
Backup server farm
缺省的备用实服务组名称,(in use)表示该实服务组正被使用
Primary link group
缺省的主用链路组名称,(in use)表示该链路组正被使用
Backup link group
缺省的备用链路组名称,(in use)表示该链路组正被使用
Sticky
缺省的持续性组名称
LB policy
虚服务器引用的负载均衡策略
虚服务器引用的HTTP类型参数模板,只有配置了HTTP类型的参数模板才会显示本字段
IP parameter profile
虚服务器引用的IP类型参数模板,只有配置了IP类型的参数模板才会显示本字段
TCP parameter profile
虚服务器引用的TCP类型参数模板,只有配置了TCP类型的参数模板才会显示本字段
UDP per-packet
虚服务器UDP强制负载均衡功能的状态,包括:
·         Disabled:关闭
·         Enabled:开启
只有UDP类型的虚服务器才会显示本字段
Connection limit
虚服务器所允许的最大连接数
Rate limit
虚服务器的速率限制
Connections
虚服务器所允许的每秒最大连接数
Bandwidth
虚服务器所允许的最大总带宽,单位为千字节/秒
Inbound bandwidth
虚服务器所允许的最大入带宽,单位为千字节/秒
Outbound bandwidth
虚服务器所允许的最大出带宽,单位为千字节/秒
SSL server policy
SSL服务器端策略的名称,只有HTTP类型的虚服务器才会显示本字段
SSL client policy
SSL客户端策略的名称,只有HTTP类型的虚服务器才会显示本字段
Redirect relocation
重定向的URL,只有HTTP类型的虚服务器才会显示本字段
重定向报文中的状态码,只有HTTP类型的虚服务器才会显示本字段
虚服务器会话扩展信息备份功能的状态,包括:
·         Disabled:关闭
·         Enabled:开启
HTTP类型的虚服务器不会显示本字段
虚服务器持续性表项备份功能的状态,包括:
·         Disabled:关闭
·         Enabled:开启
链路的带宽繁忙保护功能的状态,包括:
·         Disabled:关闭
·         Enabled:开启
链路的接口带宽统计功能的状态,包括:
·         Disabled:关闭
·         Enabled:开启
Route advertisement
虚服务器IP地址下发功能的状态,包括:
·         Disabled:关闭
·         Enabled:开启
1.1.66  display virtual-server statistics
display virtual-server statistics命令用来显示虚服务器的统计信息。
display virtual-server statistics [ name virtual-server-name ] [ slot slot-number ]
context-admin
context-operator
name virtual-server-name:显示指定虚服务器的统计信息。virtual-server-name为虚服务器的名称,为1~63个字符的字符串,不区分大小写。如果未指定本参数,将显示所有虚服务器的统计信息。
# 显示虚服务器vs的统计信息。
<Sysname> display virtual-server statistics name vs
Virtual server: vs
  Total connections: 979
  Active connections: 618
  Max connections: 661
  Connections per second: 146
  Max connections per second: 156
  Client input: 333332 bytes
  Client output: 472054 bytes
  Throughput: 4088 bytes/s
  Outbound throughput: 2874 bytes/s
  Max throughput: 4368 bytes/s
  Max outbound throughput: 3154 bytes/s
  Received packets: 979
  Sent packets: 0
  Dropped packets: 0
  Dropped requests: 0
  Sent responses: 0
表1-35 display virtual-server staistics命令显示信息描述表
Virtual server
虚服务器的名称
Total connections
总连接数
Active connections
当前活动的连接数
Max connections
最大连接数
每秒连接数
最大每秒连接数
Client input
从客户端收到的流量,单位为字节
Client output
向客户端发出的流量,单位为字节
Throughput
报文的总吞吐量,单位为字节/秒
Inbound throughput
报文的入吞吐量,单位为字节/秒
Outbound throughput
报文的出吞吐量,单位为字节/秒
Max throughput
报文的最大总吞吐量,单位为字节/秒
报文的最大入吞吐量,单位为字节/秒
Max oubound throughput
报文的最大出吞吐量,单位为字节/秒
Received packets
收到的报文数
Sent packets
发出的报文数(虚服务器发给客户端的)
Dropped packets
丢弃的报文数
Received requests
收到的HTTP请求报文数量,只有HTTP类型的虚服务器才会显示本字段
Dropped requests
丢弃的HTTP请求报文数量,只有HTTP类型的虚服务器才会显示本字段
Sent responses
发出的HTTP应答报文数量,只有HTTP类型的虚服务器才会显示本字段
Dropped responses
丢弃的HTTP应答报文数量,只有HTTP类型的虚服务器才会显示本字段
·            reset virtual-server statistics
1.1.67  dns-server-pool (action view)
dns-server-pool命令用来指定指导转发的DNS服务器池。
undo dns-server-pool命令用来恢复缺省情况。
未指定指导转发的DNS服务器池。
DNS类型的负载均衡动作视图
context-admin
sticky sticky-name:DNS服务器池所对应持续性组的名称,为1~63个字符的字符串,不区分大小写,若未指定该参数,则DNS服务器池不对应持续性组。
本命令与forward all和skip current-dns-proxy命令互斥,当配置了其中一条后,另一条的配置将被自动取消。
# 在DNS类型的负载均衡动作lba1中,指定指导转发的DNS服务器池为dsp,持续性组为st1。
[Sysname] loadbalance action lba1 type dns
[Sysname-lba-dns-lba1] dns-server-pool dsp sticky st1
·            forward all
1.1.68  dns-server-pool (DNS server view)
dns-server-pool命令用来指定DNS服务器所属的DNS服务器池。
未指定DNS服务器所属的DNS服务器池。
DNS服务器视图
context-admin
pool-name:DNS服务器池的名称,为1~63个字符的字符串,不区分大小写。
指定DNS服务器池的名称时,可以是尚未创建的DNS服务器池。
# 指定DNS服务器ds1属DNS服务器池为dns-pool1。
[Sysname-lb-ds-ds1] dns-server-pool dns-pool1
·            display loadbalance dns-server
1.1.69  domain-name
domain-name命令添加DNS映射的DNS域名。
undo domain-name命令删除DNS映射的DNS域名。
undo domain-name domain-name
DNS映射不存在任何域名。
DNS映射视图
context-admin
domain-name:DNS域名,为1~253个字符的字符串,不区分大小写。
DNS映射视图下可以配置多个DNS域名。域名支持通配符配置,允许使用的通配字符包括问号“?”和星号“*”,通配符使用规则如下:
·            域名中允许使用多个问号“?”,问号“?”用于代替域名中的单个字符,域名中的点“.”除外;
·            域名中允许使用多个星号“*”,星号“*”用于代替域名中的多个字符,域名中的点“.”除外;
·            域名中允许同时使用问号“?”和星号“*”。
·            域名中以点“.”分隔的每个字符串最大长度为63个字符。
·            域名中起始字符与结束字符支持字母、数字、横线、下划线、通配符星号“*”与通配符问号“?”;中间字符支持字母、数字、横线、下划线、点号“.”、通配符星号“*”与通配符问号“?”。
# 为DNS映射dm1添加两个DNS映射域名。
[Sysname] loadbalance dns-map dm1
[Sysname-lb-dm-dm1] domain-name www.aaa.domain.com
[Sysname-lb-dm-dm1] domain-name ???.aaa.*.com
1.1.70  exceed-mss
exceed-mss命令用来配置对客户端发来的HTTP请求报文中超出MSS的数据段的处理方式。
undo exceed-mss命令用来恢复缺省情况。
exceed-mss { allow | drop }
undo exceed-mss
对客户端发来的HTTP请求报文中超出MSS的数据段的处理方式为允许超出MSS的数据段。
参数模板视图
context-admin
allow:允许超出MSS的数据段。
drop:丢弃超出MSS的数据段。
本命令只在TCP类型的参数模板视图下支持。
# 在TCP类型的参数模板pp3中,配置对客户端发来的HTTP请求报文中超出MSS的数据段的处理方式为丢弃超出MSS的数据段。
[Sysname] parameter-profile pp3 type tcp
[Sysname-para-tcp-pp3] exceed-mss drop
1.1.71  expire
expire命令用来配置过期时间。
undo expire命令用来恢复缺省情况。
expire expire-time
undo expire
过期时间为86400秒。
SOA视图
context-admin
expire-time:过期时间,取值范围为500~4294967295,单位为秒。
过期时间是指当辅助域名服务器与主域名服务器失去联系后,辅助域名服务器可继续进行DNS解析的时长。
# 对DNS正向区域abc.com,指定SOA资源记录的过期时间为7天。
[Sysname] loadbalance zone abc.com
[Sysname-lb-zone-abc.com] soa
[Sysname-lb-zone-abc.com-soa] expire 604800
·            display loadbalance zone
1.1.72  fail-action (link group view)
fail-action命令用来配置链路组的故障处理方式。
undo fail-action命令用来恢复缺省情况。
fail-action { keep | reschedule | reset }
undo fail-action
链路组的故障处理方式为保持已有连接。
链路组视图
context-admin
keep:保持已有连接,即不主动断开与故障链路的连接,连接继续保持还是断开将由协议自身的超时机制决定。
reschedule:重定向连接,即把连接重定向到链路组中其它可用的链路上。
reset:断开已有连接,即主动断开与故障链路的连接。对于TCP报文,将发送RST报文;对于其它类型的报文,将发送ICMP不可达报文。
当处理报文的链路发生故障的时,负载均衡设备根据配置的故障处理方式来决定报文的处理方式。
# 配置链路组lg的故障处理方式为重定向连接。
[Sysname] loadbalance link-group lg
[Sysname-lb-lgroup-lg] fail-action reschedule
1.1.73  fail-action (server farm view)
fail-action命令用来配置实服务组的故障处理方式。
undo fail-action
实服务组的故障处理方式为保持已有连接。
实服务组视图
context-admin
keep:保持已有连接,即不主动断开与故障实服务器的连接,连接继续保持还是断开将由协议自身的超时机制决定。
reschedule:重定向连接,即把连接重定向到实服务组中其它可用的实服务器上。
reset:断开已有连接,即主动断开与故障实服务器的连接。对于TCP报文,将发送RST报文;对于其它类型的报文,将发送ICMP不可达报文。
当处理报文的实服务器发生故障的时,负载均衡设备根据配置的故障处理方式来决定报文的处理方式。
# 配置实服务组sf的故障处理方式为重定向连接。
[Sysname] server-farm sf
[Sysname-sfarm-sf] fail-action reschedule
1.1.74  fallback
fallback命令用来指定DNS监听器查找DNS请求资源记录失败时的处理方式。
undo fallback命令用来恢复缺省情况。
fallback { dns-proxy | no-response | reject }
undo fallback
DNS监听器查找DNS请求资源记录失败时的处理方式为回应DNS拒绝报文。
DNS监听器视图
context-admin
dns-proxy:通过DNS代理回应请求报文。
no-response:不回应DNS请求。
reject:回应DNS拒绝报文。
# 指定DNS监听器查找DNS请求资源记录失败时的处理方式。
[Sysname] loadbalance dns-listener ct-listener
[Sysname-lb-dl-ct-listener] fallback no-response
1.1.75  fallback-action continue
fallback-action continue命令用来配置查找可用服务器失败时继续匹配下一条引用规则。
undo fallback-action continue命令用来恢复缺省情况。
根据当前动作查找可用服务器失败时,不再继续匹配下一条引用规则,直接丢弃报文。
负载均衡动作视图
context-admin
当配置该命令的动作在负载均衡策略中被引用时,在转发中根据该配置判断当前动作查找可用服务器失败时,可继续顺序匹配策略中的下一条引用规则。
# 在HTTP类型的负载均衡动作a1中,开启根据当前动作查找可用实服务器失败时继续匹配策略中的下一条规则功能。
[Sysname] loadbalance action a1 type http
[Sysname-lba-http-a1] fallback-action continue
# 在DNS类型的负载均衡动作a2中,开启根据当前动作查找可用DNS服务器失败时继续匹配策略中的下一条规则功能。
[Sysname] loadbalance action a2 type dns
[Sysname-lba-dns-a2] fallback-action continue
1.1.76  forward all
forward all命令用来配置报文的转发模式为转发。
undo forward命令用来恢复缺省情况。
forward all
undo forward
报文的转发模式为丢弃。
负载均衡动作视图
context-admin
本命令只在DNS、通用和Link-generic类型的负载均衡动作视图下支持。
在DNS类型的负载均衡动作视图下,本命令与dns-server-pool和skip current-dns-proxy命令互斥;在通用类型的负载均衡动作视图下,本命令与server-farm命令互斥;在Link-generic类型的负载均衡动作视图下,本命令与link-group命令互斥。当配置了其中一条后,另一条的配置将被自动取消。
# 在通用类型的负载均衡动作lba1中,配置报文的转发模式为转发。
[Sysname] loadbalance action lba1 type generic
[Sysname-lba-generic-lba1] forward all
·            server-farm (action view)
·            link-group (action view)
·            dns-server-pool
1.1.77  header
header命令用来配置HTTP首部持续性方法。
undo header命令用来恢复缺省情况。
header { { { host | name header-name | url } [ offset offset ] [ start start-string] [ end end-string | length length ] } | request-method | version }
undo header
未配置任何HTTP首部持续性方法。
持续性组视图
context-admin
host:基于HTTP主机的持续性方法。
name header-name:基于HTTP首部名称的持续性方法,为1~63个字符的字符串。
url:基于HTTP URL的持续性方法。
offset offset:HTTP首部基于HTTP报文起始位置的偏移量,取值范围为0~1000,缺省值为0。
start start-string:HTTP首部开始标记的正则表达式,即从offset起到本标记为开始,为1~127字符的字符串,不支持正则元字符?。
end end-string:HTTP首部结束标记的正则表达式,即从start-string起到本标记为结束,为1~127字符的字符串,不支持正则元字符?。
length length:HTTP首部的长度,取值范围为0~1000,缺省值为0,表示所有长度。
request-method:基于HTTP Request-Method的持续性方法。
version:基于HTTP版本的持续性方法。
本命令只在HTTP首部类型的持续性组视图下支持。
本命令用来根据offset、start-string、end-string及length获取生成持续性表项的HTTP首部信息。start-string和end-string将不计入持续性表项信息中。
# 在HTTP首部类型的持续性组sg4中,配置HTTP首部持续性方法为:基于HTTP主机来生成持续性表项。
[Sysname] sticky-group sg4 type http-header
[Sysname-sticky-http-header-sg4] header host
1.1.78  header delete
header delete命令用来删除HTTP首部。
undo header delete命令用来保留HTTP首部。
header delete { both | request | response } name header-name
undo header delete { both | request | response } name header-name
保留HTTP首部。
负载均衡动作视图
context-admin
both:请求和应答两个方向的HTTP报文。
request:请求方向的HTTP报文。
response:应答方向的HTTP报文。
name header-name:HTTP报文首部的名称,包括标准和自定义的首部,需要与报文中的首部完全匹配。为1~63个字符的字符串,不区分大小写。不包括(、)、<、>、@、,、;、:、\、"、/、[、]、?、=、{、}、SP(空格符)、HT(水平制表符),以及ASCII码中小于等于31、大于等于127的字符。
本命令只在HTTP类型的负载均衡动作视图下支持。
配置了本命令后,如果指定方向的HTTP报文中携带有指定名称的首部,系统会将该首部从报文中删除。
# 在HTTP类型的负载均衡动作lba2中,删除HTTP请求报文中名为host的首部。
[Sysname] loadbalance action lba2 type http
[Sysname-lba-http-lba2] header delete request name host
1.1.79  header delete request accept-encoding
header delete request accept-encoding命令配置删除请求中的Accept-Encoding首部。
undo header delete request accept-encoding命令用来保留请求中的Accept-Encoding首部。
HTTP压缩参数模板视图
context-admin
当客户端发送的请求报文中携带Accept-Encoding首部,并开启该功能后,由负载均衡设备发往服务器的报文会删除Accpet-Encoding首部。由服务器发往负载均衡设备的应答报文不会进行压缩,而由负载均衡设备发往客户端的应答报文在符合匹配规则的情况下进行了压缩。如果客户端发送的请求报文不携带Accept-Encoding首部,无论是否使能该功能,负载均衡设备都不会对应答报文进行压缩。
缺省情况下,负载均衡设备不会对请求报文做任何修改。如果服务器发往负载均衡设备的应答报文是压缩的,则负载均衡设备会直接转发给客户端;如果服务器发往负载均衡设备的报文是没有经过压缩的,则负载均衡设备会把符合匹配规则的报文进行压缩再发往客户端。
# 创建HTTP压缩类型的参数模板http1,并删除请求报文的Accept-Encoding首部。
[Sysname] parameter-profile http1 type http-compression
[Sysname-para-http-compression-http1] header delete request accept-encoding
1.1.80  header exceed-length
header exceed-length命令用来配置当HTTP请求或应答报文首部超出最大长度时的处理方式。
undo header exceed-length命令用来恢复缺省情况。
header exceed-length { continue | drop }
当HTTP请求或应答报文首部超出最大长度时,继续执行负载均衡操作。
参数模板视图
context-admin
continue:继续执行负载均衡操作。
drop:停止执行负载均衡操作,丢弃该报文并关闭连接。
本命令只在HTTP类型的参数模板视图下支持。快速HTTP类型的虚服务器不支持本功能。
当HTTP报文首部的长度超过负载均衡的处理能力时,系统将无条件使用drop方式处理该报文。
# 在HTTP类型的参数模板pp1中,配置当HTTP请求或应答报文首部超出最大长度时的处理方式为:停止执行负载均衡操作,丢弃该报文并关闭连接。
[Sysname] parameter-profile pp1 type http
[Sysname-para-http-pp1] header exceed-length drop
1.1.81  header insert
header insert命令用来插入HTTP首部。
undo header insert命令用来取消插入HTTP首部的配置。
header insert { both | request | response } name header-name value value
undo header insert { both | request | response } name header-name
不插入HTTP首部。
负载均衡动作视图
context-admin
name header-name:要插入HTTP报文中的首部名称,包括标准和自定义的首部。为1~63个字符的字符串,区分大小写。不包括(、)、<、>、@、,、;、:、\、"、/、[、]、?、=、{、}、SP(空格符)、HT(水平制表符),以及ASCII码中小于等于31、大于等于127的字符。
value value:要插入HTTP报文中的首部内容,为1~255个字符的字符串,也可以使用以下特定含义的字符串:
·            %is:源IP地址或源IPv6地址。
·            %ps:源端口号。
·            %id:目的IP地址或目的IPv6地址。
·            %pd:目的端口号。
配置了本命令后,系统将在指定方向的HTTP报文中插入指定名称和内容的首部。
# 在HTTP类型的负载均衡动作lba2中,将名为source、内容为源IP和源端口号的首部插入到HTTP请求报文中。
[Sysname-lba-http-lba2] header insert request name source value %is:%ps
1.1.82  header insert response vary
header insert命令用来设置在应答报文中插入Vary首部。
undo header insert命令用来取消在应答报文中插入Vary首部的配置。
undo header insert response vary
在应答报文中插入Vary首部。
HTTP压缩参数模板视图
context-admin
配置该功能后,无论应答本身是否携带Vary首部或应答没有进行压缩处理都会在应答头插入Vary首部,内容为Accept-Encoding再发往客户侧。
# 创建HTTP压缩类型的参数模板http1,并在应答报文中插入一个Vary首部。
[Sysname-para-http-compression-http1] header insert response vary
1.1.83  header maxparse-length
header maxparse-length命令用来设置HTTP首部的最大解析长度。
undo header maxparse-length命令用来恢复缺省情况。
header maxparse-length length
HTTP首部的最大解析长度为4096。
参数模板视图
context-admin
length:HTTP首部的最大解析长度,取值范围为1~65535。
# 在HTTP类型的参数模板pp1中,配置HTTP首部的最大解析长度为8192。
[Sysname-para-http-pp1] header maxparse-length 8192
1.1.84  header modify per-request
header modify per-request命令用来配置对每个HTTP请求或应答报文的首部都执行插入、删除或修改操作。
undo header modify per-request命令用来恢复缺省情况。
只对每个连接的第一个HTTP请求或应答报文的首部执行插入、删除或修改操作。
参数模板视图
context-admin
# 在HTTP类型的参数模板pp1中,配置对每个HTTP请求或应答报文的首部都执行插入、删除或修改操作。
[Sysname-para-http-pp1] header modify per-request
1.1.85  header rewrite
header rewrite命令用来重写HTTP首部。
undo header rewrite命令用来取消重写HTTP首部的配置。
header rewrite { both | request | response } name header-name value value replace replace
undo header rewrite { both | request | response } name header-name
不重写HTTP首部。
负载均衡动作视图
context-admin
value value:要被重写的HTTP报文首部的内容,为1~127个字符的字符串,不支持字符?。
replace replace:重写后的内容,为1~127个字符的字符串。
配置了本命令后,如果指定方向的HTTP报文中携带有指定名称的首部,系统会将该首部中的内容value重写为replace。
# 在HTTP类型的负载均衡动作lba2中,将HTTP请求报文名中为host的首部中的内容,由www/.(h3c)/.com重写为www.%1.com.cn。
[Sysname-lba-http-lba2] header rewrite request name host value www/.(h3c)/.com replace www.%1.com.cn
1.1.86  inherit vpn-instance disable (link view)
inherit vpn-instance disable命令用来关闭链路所属VPN实例的继承功能。
undo inherit vpn-instance disable命令用来开启链路所属VPN实例的继承功能。
链路所属VPN实例的继承功能处于开启状态。
链路视图
context-admin
若在链路视图下执行vpn-instance命令指定了链路所属的VPN实例,则链路属于该VPN实例。若未指定链路所属的VPN实例,当链路所属VPN实例的继承功能处于开启状态时,链路所属的VPN实例与虚服务器所属的VPN实例一致;当该功能处于关闭状态时,链路属于公网。
若需要指定链路属于某私有网络,建议通过执行链路视图下的vpn-instance命令进行配置。
可以通过执行display loadbalance link命令查看链路所属的VPN实例。
# 关闭链路lk1所属VPN实例的继承功能。
[Sysname] loadbalance link lk1
[Sysname-lb-link-lk1] inherit vpn-instance disable
·            display loadbalance link
·            vpn-instance (link view)
1.1.87  inherit vpn-instance disable (real server view)
inherit vpn-instance disable命令用来关闭实服务器所属VPN实例的继承功能。
undo inherit vpn-instance disable命令用来开启实服务器所属VPN实例的继承功能。
实服务器所属VPN实例的继承功能处于开启状态。
实服务器视图
context-admin
若在实服务器视图下执行vpn-instance命令指定了实服务器所属的VPN实例,则实服务器属于该VPN实例。若未指定实服务器所属的VPN实例,当实服务器所属VPN实例的继承功能处于开启状态,实服务器所属的VPN实例与虚服务器所属的VPN实例一致;当该功能处于关闭状态时,实服务器服务于公网。
# 关闭实服务器rs所属VPN实例的继承功能。
[Sysname] real-server rs
[Sysname-rserver-rs] inherit vpn-instance disable
·            vpn-instance (real server view)
·            vpn-instance (virtual server view)
1.1.88  ip
ip命令用来配置IPv4持续性方法。
undo ip命令用来恢复缺省情况。
ip [ port ] { both | destination | source } [ mask mask-length ]
undo ip
未配置IPv4持续性方法。
持续性组视图
context-admin
port:表示持续性方法为IPv4地址+端口。如果未指定本参数,表示持续性方法为IPv4地址。
both:当未指定port参数时,表示持续性方法为源IPv4地址+目的IPv4地址;当指定了port参数时,表示持续性方法为源IPv4地址+源端口+目的IPv4地址+目的端口。
destination:当未指定port参数时,表示持续性方法为目的IPv4地址;当指定了port参数时,表示持续性方法为目的IPv4地址+目的端口。
source:当未指定port参数时,表示持续性方法为源IPv4地址;当指定了port参数时,表示持续性方法为源IPv4地址+源端口。
mask mask-length:持续性方法的掩码长度。
# 在地址端口类型的持续性组sg1中,配置持续性方法为源IPv4地址。
[Sysname] sticky-group sg1 type address-port
[Sysname-sticky-address-port-sg1] ip source
# 在地址端口类型的持续性组sg1中,配置持续性方法为源IPv4地址+源端口。
[Sysname-sticky-address-port-sg1] ip port source
·            sticky-group
1.1.89  ip address (DNS proxy view)
ip address命令用来配置DNS透明代理的IPv4地址。
undo ip address命令用来恢复缺省情况。
ip address ipv4-address [ mask-length | mask ]
undo ip address
未配置DNS透明代理的IPv4地址。
DNS透明代理视图
context-admin
ipv4-address:IPv4地址,不能为环回地址、组播地址、广播地址和0.X.X.X(如果掩码长度不是32,则可以配置0.X.X.X)。
mask-length:IPv4地址的掩码长度,取值范围为0~32。
mask:IPv4地址的掩码。
只有当DNS请求的目的地址和端口号匹配DNS透明代理的IP地址和端口号时,才会进行DNS透明代理。
在同时配置DNS透明代理功能和服务器负载均衡功能的情况下,为避免影响DNS透明代理功能的正常使用,请避免将DNS透明代理的IP地址和端口号与UDP类型的虚服务器配置为同一地址和端口号。
在同一DNS透明代理视图下,多次执行本命令,最后一次执行的命令生效。
# 配置DNS透明代理dns-proxy1的IPv4地址为1.2.3.4/24。
[Sysname] loadbalance dns-proxy dns_proxy1
[Sysname-lb-dp-udp-dns-proxy1] ip address 1.2.3.4 24
1.1.90  ip address (DNS server view)
ip address命令用来配置DNS服务器的IPv4地址。
undo ip address
未配置DNS服务器的IPv4地址。
DNS服务器视图
context-admin
ipv4-address:IPv4地址,不能为环回地址、组播地址、广播地址和0.X.X.X。
在同一DNS服务器视图下,多次执行本命令,最后一次执行的命令生效。
# 配置DNS服务器ds1的IPv4地址为1.2.3.4。
[Sysname] loadbalance dns-server ds1
[Sysname-lb-ds-ds1] ip address 1.2.3.4
1.1.91  ip address (DNS listener view)
ip address命令用来指定DNS监听器的IPv4地址和端口。
ip address ipv4-address [ port port-number ]
undo ip address
未指定DNS监听器的IPv4地址和端口。
DNS监听器视图
context-admin
port-number:DNS监听端口号,取值范围为1~65535,缺省值为53。
每个DNS监听器只能配置一个IPv4地址。
在同一DNS监听器视图下,多次执行本命令,最后一次执行的命令生效。
未配置IPv4地址的DNS监听器不处理IPv4 DNS请求报文。
在同时配置入方向链路负载均衡功能和服务器负载均衡功能的情况下,为避免影响入方向链路负载均衡功能的正常使用,请不要将DNS监听器的IP地址与虚服务器的IP地址配置为同一地址。
# 配置DNS监听器的IPv4地址为1.2.3.4,端口号为8080。
[Sysname-lb-dl-ct-listener] ip address 1.2.3.4 port 8080
·            display loadbalance dns-listener
1.1.92  ip address (ISP view)
ip address命令用来为ISP配置IPv4地址信息。
ip address ipv4-address { mask-length | mask }
undo ip address ipv4-address { mask-length | mask }
ISP未配置IPv4地址信息。
ISP视图
context-admin
ipv4-address:IPv4地址。
mask:IPv4地址的掩码。
# 为名为isp1的ISP配置IPv4地址信息。
[Sysname] loadbalance isp name isp1
[Sysname-lbisp-isp1] ip address 1.1.1.1 24
1.1.93  ip address (real server view)
ip address命令用来配置实服务器的IPv4地址。
undo ip address
未配置实服务器的IPv4地址。
实服务器视图
context-admin
# 配置实服务器rs的IPv4地址为1.1.1.1。
[Sysname-rserver-rs] ip address 1.1.1.1
1.1.94  ip mask
ip mask命令用来配置IPv4就近性表项的掩码长度。
undo ip mask命令用来恢复缺省情况。
ip mask { mask-length | mask }
undo ip mask
IPv4就近性表项的掩码长度为24。
就近性视图
context-admin
mask-length:IPv4就近性表项的掩码长度,取值范围为0~32,其中0表示自然掩码。
mask:IPv4就近性表项的掩码。
# 配置IPv4就近性表项的掩码长度为30。
[Sysname] loadbalance proximity
[Sysname-lb-proximity] ip mask 30
1.1.95  ip range (snat pool view)
ip range命令用来配置SNAT地址池的IPv4地址范围。
undo ip range命令用来恢复缺省情况。
ip range start start-ipv4-address end end-ipv4-address
undo ip range
未配置SNAT地址池的IPv4地址范围。
SNAT地址池视图
context-admin
start start-ipv4-address:起始IPv4地址。
end end-ipv4-address:结束IPv4地址,必须大于等于起始IPv4地址。
一个SNAT地址池中最多允许有256个IPv4地址,且不同SNAT地址池中的IPv4地址不允许重叠。
# 配置SNAT地址池lbsp的IPv4地址范围为1.1.1.1~1.1.1.100。
[Sysname] loadbalance snat-pool lbsp
[Sysname-lbsnat-pool-lbsp] ip range start 1.1.1.1 end 1.1.1.100
1.1.96  ipv6
ipv6命令用来配置IPv6持续性方法。
undo ipv6命令用来恢复缺省情况。
ipv6 [ port ] { both | destination | source } [ prefix prefix-length ]
undo ipv6
未配置IPv6持续性方法。
持续性组视图
context-admin
port:表示持续性方法为IPv6地址+端口。如果未指定本参数,表示持续性方法为IPv6地址。
both:表示持续性方法为源IPv6地址+目的IPv6地址(未指定port参数时),或源IPv6地址+源端口+目的IPv6地址+目的端口(指定port参数时)。
destination:表示持续性方法为目的IPv6地址(未指定port参数时),或目的IPv6地址+目的端口(指定port参数时)。
source:表示持续性方法为源IPv6地址(未指定port参数时),或源IPv6地址+源端口(指定port参数时)。
prefix prefix-length:持续性方法的前缀长度。
# 在地址端口类型的持续性组sg1中,配置持续性方法为源IPv6地址。
[Sysname-sticky-address-port-sg1] ipv6 source
# 在地址端口类型的持续性组sg1中,配置持续性方法为源IPv6地址+源端口。
[Sysname-sticky-address-port-sg1] ipv6 port source
·            sticky-group
1.1.97  ipv6 address (DNS listener view)
ipv6 address命令用来指定DNS监听器的IPv6地址和端口。
undo ipv6 address命令用来恢复缺省情况。
ipv6 address ipv6-address [ port port-number ]
undo ipv6 address
未指定DNS监听器的IPv6地址和端口。
DNS监听器视图
context-admin
ipv6-address:DNS监听器的IPv6地址,不能为环回地址、IPv6组播地址、链路本地地址和全0地址。
port port-number:端口号,取值范围为1~65535,缺省值为53。
每个DNS监听器只能配置一个IPv6地址。
未配置IPv6地址的DNS监听器不能处理IPv6 DNS请求报文。
# 配置DNS监听器ct-listener的IPv6地址为1001::1,端口号为64。
[Sysname-lb-dl-ct-listener] ipv6 address 1001::1 port 64
1.1.98  ipv6 address (DNS proxy view)
ipv6 address命令用来配置DNS透明代理的IPv6地址。
ipv6 address ipv6-address [ prefix-length ]
undo ipv6 address
未配置DNS透明代理的IPv6地址。
DNS透明代理视图
context-admin
ipv6-address:IPv6地址,不能为环回地址、IPv6组播地址、链路本地地址和全0地址(如果前缀长度为0,则可以配置全0地址)。
prefix-length:IPv6地址的前缀长度,取值范围为0~128。
# 配置DNS透明代理dns-proxy1的IPv6地址为1::2:3/112。
[Sysname] loadbalance dns-proxy dns-proxy1
[Sysname-lb-dp-udp-dns-proxy1] ipv6 address 1::2:3 112
1.1.99  ipv6 address (DNS server view)
ipv6 address命令用来配置DNS服务器的IPv6地址。
undo ipv6 address
未指定DNS服务器的IPv6地址。
DNS服务器视图
context-admin
ipv6-address:IPv6地址,不能为环回地址、IPv6组播地址、链路本地地址和全0地址。
# 配置DNS服务器ds1的IPv6地址为1001::1。
[Sysname-lb-ds-ds1] ipv6 address 1001::1
1.1.100  ipv6 address (ISP view)
ipv6 address命令用来为ISP配置IPv6地址信息。
ipv6 address ipv6-address prefix-length
undo ipv6 address ipv6-address prefix-length
ISP未配置IPv6地址信息。
ISP视图
context-admin
ipv6-address:IPv6地址。
# 为名为isp1的ISP配置IPv6地址信息。
[Sysname-lbisp-isp1] ipv6 address 200::1 100
1.1.101  ipv6 address (real server view)
ipv6 address命令用来配置实服务器的IPv6地址。
undo ipv6 address
未配置实服务器的IPv6地址。
实服务器视图
context-admin
# 配置实服务器rs的IPv6地址为1001::1。
[Sysname-rserver-rs] ipv6 address 1001::1
1.1.102  ipv6 prefix
ipv6 prefix命令用来配置IPv6就近性表项的前缀长度。
undo ipv6 prefix命令用来恢复缺省情况。
ipv6 prefix prefix-length
undo ipv6 prefix
IPv6就近性表项的前缀长度为96。
就近性视图
context-admin
prefix-length:IPv6就近性表项的前缀长度,取值范围为0~128。
# 配置IPv6就近性表项的前缀长度为64。
[Sysname-lb-proximity] ipv6 prefix 64
1.1.103  ipv6 range
ip range命令用来配置SNAT地址池的IPv6地址范围。
ipv6 range start start-ipv6-address end end-ipv6-address
undo ipv6 range
未配置SNAT地址池的IPv6地址范围。
SNAT地址池视图
context-admin
start start-ipv6-address:起始IPv6地址。
end end-ipv6-address:结束IPv6地址,必须大于等于起始IPv6地址。
一个SNAT地址池中最多允许有65536个IPv6地址,且不同SNAT地址池中的IPv6地址不允许重叠。
# 配置SNAT地址池lbsp的IPv6地址范围为1001::1~1001::100。
[Sysname-lbsnat-pool-lbsp] ipv6 range start 1001::1 end 1001::100
1.1.104  isp
isp命令用来向区域中添加ISP信息。
undo isp命令用来删除区域中的指定ISP信息。
isp isp-name
undo isp isp-name
不存在任何ISP信息。
负载均衡区域视图
context-admin
isp-name:ISP信息的名称,为1~63个字符的字符串,不区分大小写。
# 在区域region-ct中添加ISP信息为isp-ct。
[Sysname] loadbalance region region-ct
[Sysname-lb-region-region-ct] isp isp-ct
·            loadbalance region
1.1.105  lb-limit-policy
lb-limit-policy命令用来指定虚服务器引用的负载均衡连接数限制策略。
undo lb-limit-policy命令用来恢复缺省情况。
lb-limit-policy policy-name
虚服务器没有引用任何负载均衡连接数限制策略。
虚服务器视图
context-admin
policy-name:负载均衡连接数限制策略的名称,为1~63个字符的字符串,不区分大小写。
配置虚服务器引用限制策略,达到对客户流量的分类限速处理。
负载均衡连接数限制策略只在新建会话时生效,对已经存在的会话不生效。
# 指定HTTP类型的虚服务器vs引用的负载均衡策略为llp。
[Sysname] virtual-server vs type http
[Sysname-vs-http-vs]lb-limit-policy llp
·            loadbalance limit-policy
1.1.106  lb-policy (DNS proxy view)
lb-policy命令用来配置DNS透明代理引用的负载均衡策略。
undo lb-poilcy命令用来恢复缺省情况。
lb-policy policy-name
undo lb-poilcy
DNS透明代理未引用负载均衡策略。
DNS透明代理视图
context-admin
policy-name:负载均衡策略的名称,为1~63个字符的字符串,不区分大小写。
通过在DNS透明代理视图下引用负载均衡策略,能够细化DNS请求的粒度。根据策略中的匹配规则,使命中DNS透明代理的报文根据不同的报文内容进行不同的负载均衡处理,从而有效地丰富了负载均衡的负载功能。
DNS透明代理只能引用DNS类型的策略模板。
# 在名称为dns-proxy1的DNS透明代理视图下,配置其引用的负载均衡策略为dns-policy1。
[Sysname-lb-dp-udp-dns-proxy1] lb-policy dns-policy1
1.1.107  lb-policy (virtual server view)
lb-policy命令用来指定虚服务器引用的负载均衡策略。
undo lb-poilcy
虚服务器没有引用任何负载均衡策略。
虚服务器视图
context-admin
虚服务器引用负载均衡策略,能够细化虚服务器负载均衡的粒度。根据策略中的匹配规则,使命中虚服务器的报文根据不同的报文内容进行不同的负载均衡处理,从而有效地丰富了负载均衡的负载功能。
虚服务器只能引用与自身类型相关的策略模板,如:快速HTTP和HTTP类型的虚服务器,可以引用通用或HTTP类型的策略模板;IP、TCP和UDP类型的虚服务器,只能引用通用类型的策略模板。
# 指定IP类型的虚服务器vs3引用的负载均衡策略为lbp1。
[Sysname] virtual-server vs3 type ip
[Sysname-vs-ip-vs3] lb-policy lbp1
1.1.108  limit
limit命令用来配置负载均衡连接数限制规则。
undo limit命令用来删除指定的负载均衡连接数限制规则。
limit limit-id acl [ ipv6 ] { acl-number | name acl-name } [ per-destination | per-service | per-source ] * amount max-amount min-amount
undo limit limit-id
负载均衡连接数限制策略中不存在任何限制规则。
负载均衡限制策略视图
context-admin
limit-id:连接数限制规则编号,取值范围为1~65535。
acl:指定用于匹配用户范围的ACL。该连接限制规则仅对匹配ACL规则的用户连接数进行统计和限制。
ipv6:表示引用IPv6 ACL。若不指定该参数,则表示引用IPv4 ACL。
acl-number:ACL的编号,取值范围为2000~3999。
name acl-name:引用的ACL名称
per-destination:按目的IP地址进行统计和限制。一个目的IP地址的连接数目将受到指定阈值的限制。
per-service:按服务统计和限制,即同一种服务(具有相同传输层协议和服务端口)的连接数目受限将受到指定阈值的限制。
per-source:按源地址统计和限制,即同一个源IP地址发起的连接数目受限将受到指定阈值的限制。
max-amount:指定的连接数上限,取值范围为1~4294967295。某范围或某种类型的连接数值超过此值时,用户将不能建立新的连接。
min-amount:指定的连接数下限,取值范围为1~4294967295,不能大于max-amount的取值。连接数的统计值降到此值之下时,允许用户建立新的连接。
每个连接数限制策略中可以定义多个规则,每个规则中需要指定引用的ACL、规则的类型以及统计的上下门限值。对于per-destination、per-source、per-service类型,可以在一条规则中单独指定其中之一或指定它们的组合。例如,同时指定per-destination和per-source,就表示同时按照连接的报文源地址和目的地址进行统计和限制,具有相同源和目的的连接属于同一类连接,该类连接的数目将受到指定的阈值的限制。
同一个连接数限制策略中的不同规则必须引用不同的ACL。
如果per-destination、per-service、per-source三个参数都不指定,则表示与本规则引用的ACL相匹配的所有连接将整体受到指定的阈值限制。
对设备上建立的连接与某连接数限制策略进行匹配时,将按照规则编号从小到大的顺序依次遍历该策略中的所有规则,直到找到一条匹配的规则为止。
当引用的ACL内容发生改变时,设备将按照新的连接数限制策略重新对已有连接进行统计和限制。
# 在负载均衡连接数限制策略1中创建一条规则,规则编号为1,引用ACL 3000,对匹配ACL 3000的连接同时按照报文的源地址和目的地址进行统计和限制,连接数的上限值为2000、下限值为1800。该规则用于限制192.168.0.0/24网段的每台主机最多只能同时向外网的同一个目的IP地址发起2000条连接,超过2000条时,需要等待连接数下降到1800以下之后,才允许新建连接。
[Sysname] acl advanced 3000
[Sysname-acl-ipv4-adv-3000] rule permit ip source 192.168.0.0 0.0.0.255
[Sysname] loadbalance limit-policy 1
[Sysname-lb-limit-policy-1] limit 1 acl 3000 per-destination per-source amount 2000 1800
1.1.109  link (DNS server view)
link命令用来指定与DNS服务器关联的链路。
undo link命令用来恢复缺省情况。
link link-name
undo link
未指定与DNS服务器关联的链路。
DNS服务器视图
context-admin
link-name:链路名称,为1~63个字符的字符串,不区分大小写。
每台DNS服务器仅支持与一条链路相关联,同一条链路可以关联多台DNS服务器。
# 指定与DNS服务器ds1关联的链路为link1。
[Sysname-lb-ds-ds1] link link1
1.1.110  link-group (action view)
link-group命令用来指定指导转发的链路组。
undo link-group命令用来恢复缺省情况。
link-group link-group-name [ backup backup-link-group-name ] [ sticky sticky-name ]
undo link-group
没有指定指导转发的链路组。
负载均衡动作视图
context-admin
link-group-name:主用链路组的名称,为1~63个字符的字符串,不区分大小写。
backup backup-link-group-name:备用链路组的名称,为1~63个字符的字符串,不区分大小写。
sticky sticky-name:链路组所对应持续性组的名称,为1~63个字符的字符串,不区分大小写。
本命令与forward all命令互斥,后配置的生效。
当主用链路组可用(该链路组存在且有可用的链路)时,使用主链路组指导转发;当主用链路组不可用而备用链路组可用时,使用备用链路组指导转发;而当主、备用链路组都不可用时,则丢弃报文。
# 在link-geneirc类型的负载均衡动作lba1中,指定指导转发的主用链路组为lg,备用链路组为lgb,持续性组为sg1。
[Sysname] loadbalance action lba1 type link-generic
[Sysname-lba1- link-generic-lba1] link-group lg backup lgb sticky sg1
·            forward all
1.1.111  link-group (link view)
link-group命令用来指定链路所属的链路组。
undo link-group
链路不属于任务链路组。
链路视图
context-admin
link-group-name:链路组的名称,为1~63个字符的字符串,不区分大小写。
设备对数据流量进行链路负载分担时,会在该流量所匹配的链路组中选定一条最佳链路进行转发。
# 配置链路lk1所属的链路组为lkg1。
[Sysname-lb-link-lk1] link-group lkg1
1.1.112  loadbalance action
loadbalance action命令用来创建负载均衡动作,并进入负载均衡动作视图。如果指定的负载均衡动作已经存在,则直接进入负载均衡动作视图。
undo loadbalance action命令用来删除指定的负载均衡动作。
loadbalance action action-name [ type { dns | generic | http | link-generic | radius } ]
undo loadbalance action action-name
不存在任何负载均衡动作。
context-admin
action-name:负载均衡动作的名称,为1~63个字符的字符串,不区分大小写。
type { dns | generic | http | link-generic | radius }:负载均衡动作的类型,dns表示DNS负载均衡动作类型,generic表示四层服务器负载均衡动作类型,http表示HTTP负载均衡动作类型,link-generic表示链路负载均衡动作类型,radius表示RADIUS负载均衡动作类型。
创建负载均衡动作时必须指定类型参数;而在进入已创建的负载均衡动作视图时可以不指定,但若要指定,则必须与创建时的类型一致。
当设备支持服务器负载均衡License功能但尚未安装License时,不允许配置Generic、HTTP和RADIUS类型的负载均衡动作;当设备不支持服务器负载均衡License功能,或支持服务器负载均衡License功能且安装有License时,才允许配置Generic、HTTP和RADIUS类型的负载均衡动作。
# 创建通用类型的负载均衡动作lba1,并进入负载均衡动作视图。
1.1.113  loadbalance alg
loadbalance alg命令用来开启指定协议的负载均衡ALG(Application Level Gateway,应用层网关)功能。
undo loadbalance alg命令用来关闭指定协议的负载均衡ALG功能。
loadbalance alg { dns | ftp | h323 | icmp-error | ils | mgcp | nbt | pptp | rsh | rtsp | sccp | sip | sqlnet | tftp | xdmcp }
undo loadbalance alg { dns | ftp | h323 | icmp-error | ils | mgcp | nbt | pptp | rsh | rtsp | sccp | sip | sqlnet | tftp | xdmcp }
dns、ftp、pptp、icmp-error和rtsp协议的负载均衡ALG功能均处于开启状态。
context-admin
dns:DNS协议。
ftp:FTP协议。
h323:H323协议。
icmp-error:ICMP-ERROR协议。
ils:ILS(Internet Locator Service,互联网定位服务)协议。
mgcp:MGCP(Media Gateway Control Protocol,媒体网关控制协议)协议。
nbt:NBT(NetBIOS over TCP/IP,基于TCP/IP的网络基本输入输出系统)协议。
pptp:PPTP(Point-to-Point Tunneling Protocol,点到点隧道协议)协议。
rsh:RSH(Remote Shell,远程外壳)协议。
rtsp:RTSP(Real Time Streaming Protocol,实时流协议)协议。
sccp:SCCP(Skinny Client Control Protocol,瘦小客户端控制协议)协议。
sip:SIP(Session Iniation Protocol,会话初始协议)协议。
sqlnet:SQLNET协议。
tftp:TFTP协议。
xdmcp:XDMCP(X Display Manager Control Protocol,X显示监控)协议。
负载均衡ALG功能用于将父、子会话分发到同一条链路上。
# 开启TFTP协议的负载均衡ALG功能。
[Sysname] loadbalance alg tftp
1.1.114  loadbalance alg all-enable
loadbalance alg all-enable命令用来开启支持的所有协议的负载均衡ALG(Application Level Gateway,应用层网关)功能。
loadbalance alg all-disable命令用来关闭支持的所有协议的负载均衡ALG(Application Level Gateway,应用层网关)功能。
ftp、dns、pptp、rtsp和icmp-error协议的负载均衡ALG功能均处于开启状态。
context-admin
# 开启所有协议的负载均衡ALG功能。
[Sysname] loadbalance alg all-enable
1.1.115  loadbalance class
loadbalance class命令用来创建负载均衡类,并进入负载均衡类视图。如果指定的负载均衡类已经存在,则直接进入负载均衡类视图。
undo loadbalance class命令用来删除指定的负载均衡类。
loadbalance class class-name [ type { dns | generic | http | link-generic | radius } [ match-all | match-any ] ]
undo loadbalance class class-name
不存在任何负载均衡类。
context-admin
class-name:负载均衡类的名称,为1~63个字符的字符串,不区分大小写。
type { dns | generic | http | link-generic | radius }:负载均衡类的类型,dns表示DNS负载均衡类型,generic表示四层服务器负载均衡类型,http表示HTTP负载均衡类型,link-generic表示链路负载均衡类型,radius表示RADIUS负载均衡类型。
[ match-all | match-any ]:match-all表示需要匹配所有规则才算匹配该类,match-any表示只需匹配任一规则就算匹配该类。缺省值为match-all。
创建负载均衡类时必须指定类型参数;而在进入已创建的负载均衡类视图时可以不指定,但若要指定,则必须与创建时的类型一致。
当设备支持服务器负载均衡License功能但尚未安装License时,不允许配置Generic、HTTP和RADIUS类型的负载均衡类;当设备不支持服务器负载均衡License功能,或支持服务器负载均衡License功能且安装有License时,才允许配置Generic、HTTP和RADIUS类型的负载均衡类。
# 创建通用类型的负载均衡类lbc1,并进入负载均衡类视图。
[Sysname] loadbalance class lbc1 type generic
[Sysname-lbc-generic-lbc1]
1.1.116  loadbalance dns-listener
loadbalance dns-listener命令用来创建DNS监听器,并进入DNS监听器视图。如果指定的DNS监听器已经存在,则直接进入DNS监听器视图。
undo loadbalance dns-listener命令用来删除指定的DNS监听器。
loadbalance dns-listener dns-listener-name
undo loadbalance dns-listener dns-listener-name
不存在DNS监听器。
context-admin
dns-listener-name:DNS监听器名称,为1~63个字符的字符串,不区分大小写。
DNS监听器用于监听负载均衡设备上收到的DNS请求。
# 创建名称为ct-istener的DNS监听器,并进入该DNS监听器视图。
1.1.117  loadbalance dns-map
loadbalance dns-map命令用来创建DNS映射,并进入DNS映射视图。如果指定的DNS映射已经存在,则直接进入DNS映射视图。
undo loadbalance dns-map命令用来删除指定的DNS映射。
loadbalance dns-map dns-map-name
undo loadbalance dns-map dns-map-name
不存在DNS映射。
context-admin
dns-map-name:DNS映射名称,为1~63个字符的字符串,不区分大小写。
一个DNS映射定义了待解析域名和虚服务器池IP地址之间的映射关系。一个域名只能与一个服务器池映射。
# 创建一个DNS映射dm1,并进入该DNS映射视图。
[Sysname-lb-dm-dm1]
1.1.118  loadbalance dns-proxy
loadbalance dns-proxy命令用来创建DNS透明代理,并进入DNS透明代理视图。如果指定的DNS透明代理已经存在,则直接进入DNS透明代理视图。
undo loadbalance dns-proxy命令用来删除指定的DNS透明代理。
loadbalance dns-proxy dns-proxy-name type udp
undo loadbalance dns-proxy dns-proxy-name
不存在DNS透明代理。
context-admin
dns-proxy-name:DNS透明代理名称,为1~63个字符的字符串,不区分大小写。
type udp:DNS透明代理的类型为UDP类型。
# 创建名称为dns-proxy1的DNS透明代理,并进入该DNS透明代理视图。
[Sysname] loadbalance dns-proxy dns-proxy1 type udp
·            display loadbalance dns-proxy
1.1.119  loadbalance dns-server
loadbalance dns-server命令用来创建DNS服务器,并进入DNS服务器视图。如果指定的DNS服务器已经存在,则直接进入DNS服务器视图。
undo loadbalance dns-server命令用来删除指定的DNS服务器。
loadbalance dns-server dns-server-name
undo loadbalance dns-server dns-server-name
不存在DNS服务器。
context-admin
dns-server-name:DNS服务器名,为1~63个字符的字符串,不区分大小写。
# 创建名为ds1的DNS服务器,并进入DNS服务器视图。
[Sysname-lb-ds-ds1]
1.1.120  loadbalance dns-server-pool
loadbalance dns-server-pool命令用来创建DNS服务器池,并进入DNS服务器池视图。如果指定的DNS服务器池已经存在,则直接进入DNS服务器池视图。
undo loadbalance dns-server-pool命令用来删除指定的DNS服务器池。
loadbalance dns-server-pool pool-name
undo loadbalance dns-server-pool pool-name
不存在DNS服务器池。
context-admin
# 创建名为dns-pool1的DNS服务器池,并进入DNS服务器池视图。
[Sysname] loadbalance dns-server-pool dns-pool1
[Sysname-lb-dspool-dns-pool1]
1.1.121  loadbalance isp file
loadbalance isp file命令用来导入ISP文件。
undo loadbalance isp file命令用来删除已经导入的ISP文件。
loadbalance isp file isp-file-name
context-admin
isp-file-name:ISP文件的名称,为1~255个字符的字符串,不区分大小写。
当导入的文件不存在、文件名不合法或文件解密失败时,系统将维持已有的导入内容不变。
当导入文件解析IP地址失败而退出导入操作时,系统将清空上次导入的内容,只保存本次已导入成功的内容。
不允许删除导入的ISP及其IPv4和IPv6地址,但如果手工配置的ISP与导入的ISP重合,则允许删除手工配置的ISP及其IPv4和IPv6地址。
如果要执行主备倒换操作,则备用主控板中也应有相同的ISP文件。
一次仅能导入一个ISP文件,新导入的将覆盖旧的ISP文件。
# 导入ISP文件isp2。
[Sysname] loadbalance isp file isp2
1.1.122  loadbalance isp name
loadbalance isp name命令用来创建ISP,并进入ISP视图。如果指定的ISP已经存在,则直接进入ISP视图。
undo loadbalance isp name命令用来删除指定的ISP。
loadbalance isp name isp-name
undo loadbalance isp name isp-name
不存在任何ISP。
context-admin
isp-name:ISP的名称,为1~63个字符的字符串,不区分大小写。
# 创建名为isp1的ISP,并进入ISP视图。
1.1.123  loadbalance limit-policy
loadbalance limit-policy命令用来创建连接数限制策略,并进入连接数限制策略视图。如果指定的连接数限制策略已经存在,则直接进入连接数限制策略视图。
undo loadbalance limit-policy命令用来删除指定的连接数限制策略。
loadbalance limit-policy policy-name
undo loadbalance limit-policy policy-name
不存在任何负载均衡连接数限制策略。
context-admin
policy-name:限制策略的名称,为1~63个字符的字符串,不区分大小写。
通过引用负载均衡连接数限制,可以对设备上建立的连接数进行统计和限制,能够有效解决因某些用户在短时间内经过设备向内部网络发起大量连接,导致设备系统或服务器资源迅速消耗,其它用户无法正常使用网络资源的问题,实现保护内部网络资源(主机或服务器)以及合理分配设备系统资源的目的。
# 创建名称为llp的负载均衡限制策略,并进入负载均衡限制策略视图。
[Sysname] loadbalance limit-policy llp
[Sysname-lb-limit-policy-llp]
1.1.124  loadbalance link
loadbalance link命令用来创建链路,并进入链路视图。如果指定的链路已经存在,则直接进入链路视图。
undo loadbalance link命令用来删除链路。
loadbalance link link-name
undo loadbalance link link-name
不存在链路。
context-admin
link-name:链路的名称,为1~63个字符的字符串,不区分大小写。
连接外部网络的每条物理链路对应一个链路。
# 创建链路lk1,并进入该链路视图。
1.1.125  loadbalance link-group
loadbalance link-group命令用来创建链路组,并进入链路组视图。如果指定的链路组已经存在,则直接进入链路组视图。
undo loadbalance link-group命令用来删除指定的链路组。
loadbalance link-group link-group-name
undo loadbalance link-group link-group-name
 缺省情况不存在任何链路组。
context-admin
link-group-name:链路组的名乐,为1~63个字符的字符串,不区分大小写。
为了便于对多条链路进行管理,可以依据这些链路的共有属性划分成不同的组,称为链路组。
# 创建链路组lg,并进入链路组视图。
1.1.126  loadbalance local-dns-server parse-fail-record max-number
loadbalance local-dns-server parse-fail-record max-number命令用来配置可记录的解析失败的DNS请求报文的最大数目。
undo loadbalance local-dns-server parse-fail-record max-number命令用来恢复缺省情况。
loadbalance local-dns-server parse-fail-record max-number max-number
可记录的解析失败的DNS请求报文的最大数目为10000条。
context-admin
max-number:可记录的解析失败的DNS请求报文的最大数目,取值范围为0~4294967295。
# 配置可记录的解析失败的DNS请求报文的最大数目为600条。
[Sysname] loadbalance local-dns-server parse-fail-record max-number 600
1.1.127  loadbalance local-dns-server parse-faill-record type
loadbalance local-dns-server parse-fail-record type命令用来配置可记录的解析失败的DNS请求报文的类型。
undo loadbalance local-dns-server parse-fail-record type命令用来恢复缺省情况。
loadbalance local-dns-server parse-fail-record type { a | aaaa | all-disable | all-enable | cname | mx | ns | ptr | soa | srv | txt }
undo loadbalance local-dns-server parse-fail-record type { a | aaaa | cname | mx | ns | ptr | soa | srv | txt }
可记录的解析失败的DNS请求报文的类型为全部类型。
context-admin
a:A(Host Address,主机地址)类型。
aaaa:AAAA类型。
all-disable:不记录任何类型。
all-enable:记录所有类型。
cname:CNAME(Canonical Name,规范名称)类型。
mx:MX(Mail Exchanger,邮件交换)类型。
ns:NS(Name Server,权威名称服务器)类型。
ptr:PTR(Pointer Record,指针记录)类型。
soa:SOA(Start of Authority,起始授权)类型。
srv:SRV(Service,服务)类型。
txt:TXT(Text,文本)类型。
# 配置可记录的解析失败的DNS请求报文的类型为A类型。
[Sysname] loadbalance local-dns-server parse-fail-record type a
1.1.128  loadbalance local-dns-server schedule-test ip
loadbalance local-dns-server schedule-test ip命令用来测试IPv4入方向链路负载均衡的DNS解析结果。
loadbalance local-dns-server schedule-test ip [ vpn-instance vpn-instance-name ] destination destination-address [ destination-port destination-port ] source source-address source-port source-port type { { a | aaaa | cname | mx | ns | soa | srv | txt } domain domain-name | ptr ip address { ipv4-address | ipv6-address } } [ slot slot-number ]
context-admin
vpn-instance vpn-instance-name:指定VPN实例。vpn-instance-name为VPN实例名称,为1~31个字符的字符串,区分大小写。如果未指定本参数,则表示公网。
destination destination-address:目的IPv4地址,即DNS监听器地址。
destination-port destination-port:目的端口号,取值范围为0~65535,缺省值为53。
source source-address:源IPv4地址。
source-port source-port:源端口号,取值范围为0~65535。
type:DNS请求报文的类型。
aaaa:AAAA类型。
txt:TXT(Text,文本)类型。
domain domain-name:待解析的域名,不区分大小写,由“.”分隔的字符串组成,每个字符串的长度不超过63个字符,如果该域名为绝对域名,则包括“.”在内的总长度不超过254个字符;如果该域名为非绝对域名,则总长度不超过253个字符。
ptr:PTR(Pointer Record,指针记录)类型,用来将IP地址解析为域名。
ip address { ipv4-address | ipv6-address }:待反向解析的IP地址。
slot slot-number:测试指定成员设备,slot-number表示设备在IRF中的成员编号。如果未指定本参数,将测试所有成员设备。
# 测试A类型DNS请求报文IPv4入方向链路负载均衡的DNS解析结果。
<Sysname> loadbalance local-dns-server schedule-test ip destination 7.7.7.7 destination-port 53 source 2.2.2.2 source-port 5 type a domain www.aaa.com
Slot 0:
    Matched DNS listener: dl2
    Matched zone: --
    Matched DNS mapping: dm2
    Matched virtual server pool: vsp2
    Preferred scheduling algorithm: Round robin
    Alternative scheduling algorithm: --
    Fallback scheduling algorithm: --
    Preferred algorithm failure cause: --
    Alternative algorithm failure cause: --
    Fallback algorithm failure cause: --
    Selected virtual server: vs2
    Response type: Send response
    Failure cause: --
# 测试MX类型DNS请求报文IPv4入方向链路负载均衡的DNS解析结果。
<Sysname> loadbalance local-dns-server schedule-test ip destination 7.7.7.7 destination-port 53 source 2.2.2.2 source-port 5 type mx domain www.aaa.com
Slot 0:
    Matched zone: h3c.com
    Failure cause: --
# 测试PTR类型DNS请求报文IPv4入方向链路负载均衡的DNS解析结果。
<Sysname> loadbalance local-dns-server schedule-test ip destination 7.7.7.7 destination-port 53 source 2.2.2.2 source-port 5 type ptr ip address 1.2.3.4
Slot 0:
    Matched zone: 1.2.3.0/24
    Failure cause: --
表1-36 loadbalance local-dns-server schedule-test ip命令显示信息描述表
匹配的DNS监听器名称
Matched zone
匹配的DNS区域(若DNS请求报文的类型为A、AAAA、CNAME、MX、NS、SOA、SRV或TXT类型,则该字段为DNS正向区域的域名;若DNS请求报文的类型为PTR类型,则该字段为DNS反向区域的域名)
Matched DNS mapping
匹配的DNS映射名称
匹配的虚服务池名称
选中的虚服务名称
虚服务器的首选调度算法,包括:
·         Round robin:加权轮转算法
·         Random:随机算法
·         Least connection:加权最小连接算法
·         Topology:静态就近性算法
·         Proximity:动态就近性算法
·         Bandwidth:总带宽算法
·         Inbound bandwidth:入方向带宽算法
·         Outbound bandwidth:出方向带宽算法
·         Max bandwidth:最大总带宽算法
·         Max inbound bandwidth:最大入方向带宽算法
·         Max outbound bandwidth:最大出方向带宽算法
·         Hash address source IP:根据源IP地址进行的哈希算法
·         Hash address destination IP:根据目的IP地址进行的哈希算法
·         Hash address source IP-port:根据源IP地址和端口号进行的哈希算法
虚服务器的次选调度算法,包括:
·         Random:随机算法
·         Topology:静态就近性算法
·         Proximity:动态就近性算法
·         Bandwidth:总带宽算法
虚服务器的备选调度算法,包括:
·         Random:随机算法
·         Topology:静态就近性算法
·         Proximity:动态就近性算法
·         Bandwidth:总带宽算法
首选调度失败原因,包括:
·         --:成功
·         No scheduling content:调度算法无调度内容
·         Scheduling failed:调度内容存在,调度失败
·         No matched virtual server member:无匹配的虚服务器
次选调度算法失败原因,包括:
·         --:成功
备选调度算法失败原因,包括:
·         --:成功
Response type
请求报文的回应类型,包括:
·         Send response:发送DNS应答报文
·         Send reject:回应一个DNS拒绝报文
·         No response:不回应DNS请求
Failure cause
请求报文解析失败原因,包括
·         --:解析成功
·         No matched DNS listener:无匹配的DNS监听器
·         No matched DNS mapping:无匹配的DNS映射
·         No matched virtual server pool:无匹配的DNS虚服务池
·         No matched DNS zone:无匹配的DNS区域
·         Failed to get buffer:压缩缓冲区无效
·         No matched record:无匹配的DNS资源记录
·         No enough memory resource:无充足的可申请内存
·         Failed to parse domain:域名解析失败
·         Failed to find DNS listener by ID:通过ID无法匹配DNS监听器
1.1.129  loadbalance local-dns-server schedule-test ipv6
loadbalance local-dns-server schedule-test ipv6命令用来测试IPv6入方向链路负载均衡的解析结果。
loadbalance local-dns-server schedule-test ipv6 [ vpn-instance vpn-instance-name ] destination destination-address [ destination-port destination-port ] source source-address source-port source-port type { { a | aaaa | cname | mx | ns | soa | srv | txt } domain domain-name | ptr ip address ipv4-address } [ slot slot-number ]
context-admin
destination destination-address:目的IPv6地址,即DNS监听器IPv6地址。
source source-address:源IPv6地址。
type:DNS请求报文的类型。
a:IPv4主机地址类型。
aaaa:IPv6主机地址类型。
txt:TXT(Text,文本)类型。
domain domain-name:待解析的域名,不区分大小写,由“.”分隔的字符串组成,每个字符串的长度不超过63个字符,包括“.”在内的总长度不超过253个字符,该域名为绝对域名(以“.”结束)。若指定DNS请求报文类型为PTR类型,则该域名为一IP地址。
# 测试A类型DNS请求报文IPv6入方向链路负载均衡的解析结果。
<Sysname> loadbalance local-dns-server schedule-test ipv6 destination 1::51 source 1::5 source-port 5 type a domain www.aaa.com
Slot 0:
    Matched zone: --
    Preferred algorithm failed cause: --
    Alternative algorithm failed cause: --
    Fallback algorithm failed cause: --
    Selected virtual server: vsa1
    Failure cause: --
# 测试MX类型DNS请求报文IPv6入方向链路负载均衡的解析结果。
<Sysname> loadbalance local-dns-server schedule-test ipv6 destination 1::51 destination-port 953 source 1::5 source-port 5 type mx domain www.aaa.com
Slot 0:
    Failure cause: --
# 测试PTR类型DNS请求报文IPv6入方向链路负载均衡的解析结果。
<Sysname> loadbalance local-dns-server schedule-test ipv6 destination 1::51 source 1::5 source-port 5 type ptr ip address 1.2.3.4
Slot 0:
    Failure cause: --
表1-37 loadbalance local-dns-server schedule-test ipv6命令显示信息描述表
匹配的DNS监听器名称
Matched zone
Matched DNS mapping
匹配的DNS映射名称
匹配的虚服务池
选中的虚服务名称
虚服务器的首选调度算法,包括:
·         Random:随机算法
·         Topology:静态就近性算法
·         Proximity:动态就近性算法
·         Bandwidth:总带宽算法
虚服务器的次选调度算法,包括:
·         Random:随机算法
·         Topology:静态就近性算法
·         Proximity:动态就近性算法
·         Bandwidth:总带宽算法
虚服务器的备选调度算法,包括:
·         Random:随机算法
·         Topology:静态就近性算法
·         Proximity:动态就近性算法
·         Bandwidth:总带宽算法
首选调度失败原因,包括:
·         --:成功
次选调度算法失败原因,包括:
·         --:成功
备选调度算法失败原因,包括:
·         --:成功
Response type
请求报文的回应类型,包括:
Failure cause
请求报文解析失败原因,包括:
·         --:解析成功
1.1.130  loadbalance log enable bandwidth-busy
loadbalance log enable bandwidth-busy命令用来开启负载均衡链路带宽繁忙日志功能。
undo loadbalance log enable bandwidth-busy命令用来关闭负载均衡链路带宽繁忙日志功能。
负载均衡链路带宽繁忙日志功能处于关闭状态。
context-admin
通过开启负载均衡链路带宽繁忙日志功能,实现对所有链路的繁忙状态进行记录。
# 开启负载均衡链路带宽繁忙日志功能。
[Sysname] loadbalance log enable bandwidth-busy
1.1.131  loadbalance log enable base
loadbalance log enable base命令用来开启负载均衡基本日志功能。
undo loadbalance log enable base命令用来关闭负载均衡基本日志功能。
负载均衡基本日志功能处于开启状态。
context-admin
通过开启负载均衡基本日志功能,可实现在以下几种情况下输出日志信息:
·            实服务器、实服务组、链路或链路组的状态变化。
·            实服务器或链路的健康检测结果发生变化。
·            实服务器、虚服务器或链路的连接数达到上限或者恢复到正常范围内。
·            实服务器、虚服务器或链路的连接速率达到上限或者恢复到正常范围内。
·            虚服务器引用的缺省实服务器组主备切换。
·            虚服务器引用的缺省链路组主备切换。
·            负载均衡动作引用的实服务器组主备切换。
·            负载均衡动作引用的链路组主备切换。
# 开启负载均衡基本日志功能。
[Sysname] loadbalance log enable base
1.1.132  loadbalance log enable nat
loadbalance log enable nat命令用来开启负载均衡NAT日志功能。
undo loadbalance log enable nat命令用来关闭负载均衡NAT日志功能。
负载均衡NAT日志功能处于关闭状态。
context-admin
通过开启负载均衡NAT日志功能,可以实现对源或目的地址进行过NAT转换的连接信息进行记录,包括IP地址及端口的转换信息、用户的访问信息等。
# 开启负载均衡NAT日志功能。
[Sysname] loadbalance log enable nat
1.1.133  loadbalance policy
loadbalance policy命令用来创建负载均衡策略,并进入负载均衡策略视图。如果指定的负载均衡策略已经存在,则直接进入负载均衡策略视图。
undo loadbalance policy命令用来删除指定的负载均衡策略。
loadbalance policy policy-name [ type { dns | generic | http | link-generic | radius } ]
undo loadbalance policy policy-name
不存在任何负载均衡策略。
context-admin
type { dns | generic | http | link-generic | radius }:负载均衡策略的类型,dns表示DNS负载均衡策略类型,generic表示四层服务器负载均衡策略类型,http表示HTTP负载均衡策略类型,link-generic表示链路负载均衡策略类型,radius表示RADIUS负载均衡策略类型。
创建负载均衡策略时必须指定类型参数;而在进入已创建的负载均衡策略视图时可以不指定,但若要指定,则必须与创建时的类型一致。
当设备支持服务器负载均衡License功能但尚未安装License时,不允许配置Generic、HTTP和RADIUS类型的负载均衡策略;当设备不支持服务器负载均衡License功能,或支持服务器负载均衡License功能且安装有License时,才允许配置Generic、HTTP和RADIUS类型的负载均衡策略。
# 创建通用类型的负载均衡策略lbp1,并进入负载均衡策略视图。
[Sysname] loadbalance policy lbp1 type generic
[Sysname-lbp-generic-lbp1]
1.1.134  loadbalance proximity
loadbalance proximity命令用来创建就近性,并进入就近性视图。如果指定的就近性已经存在,则直接进入就近性视图。
undo loadbalance proximity命令用来删除就近性视图及该视图下的所有配置。
loadbalance proximity [ vpn-instance vpn-instance-name ]
undo loadbalance proximity [ vpn-instance vpn-instance-name ]
context-admin
vpn-instance vpn-instance-name:指定VPN实例。vpn-instance-name为VPN实例名称,为1~31个字符的字符串,区分大小写。如果未指定本参数,则表示公网实例。
# 创建并进入VPN实例vpn1的就近性视图。
[Sysname] loadbalance proximity vpn vpn1
[Sysname-lb-proximity-vpn1]
1.1.135  loadbalance region
loadbalance region命令用来创建区域对象,并进入区域对象视图。如果指定的区域对象已经存在,则直接进入区域对象视图。
undo loadbalance region命令用来删除指定的区域对象。
loadbalance region region-name
undo loadbalance region region-name
不存在任何区域对象。
context-admin
region-name:区域对象的名称,为1~63个字符的字符串,不区分大小写。
区域对象中包含根据不同维度划分的地址段,目前仅支持按照运营商类别来划分地址段。
# 创建区域对象isp-ct,并进入该区域对象视图。
[Sysname] loadbalance region isp-ct
[Sysname-lb-region-isp-ct]
1.1.136  loadbalance reverse-zone
loadbalance reverse-zone命令用来创建DNS反向区域,并进入DNS反向区域视图。如果指定的DNS反向区域已经存在,则直接进入DNS反向区域视图。
undo loadbalance reverse-zone命令用来删除指定的DNS反向区域。
loadbalance reverse-zone { ip ipv4-address mask-length | ipv6 ipv6-address prefix-length }
undo loadbalance reverse-zone { ip ipv4-address mask-length | ipv6 ipv6-address prefix-length }
不存在DNS反向区域。
context-admin
ip ipv4-address mask-length:DNS反向区域的IPv4地址和掩码长度。ipv4-address为DNS反向区域的IPv4地址;mask-length为IPv4地址的掩码长度,取值范围为0~32。
ipv6 ipv6-address prefix-length:DNS反向区域的IPv6地址和掩码长度。ipv6-address为DNS反向区域的IPv6地址;prefix-length为IPv6地址的前缀长度,取值范围为0~128。
# 创建IPv4地址及掩码长度为10.11.2.0/24的DNS反向区域,并进入DNS反向区域视图。
[Sysname] loadbalance reverse-zone ip 10.11.2.0 24
[Sysname-lb-rzone-10.11.2.0/24]
# 创建IPv6地址及前缀长度为1001::0/64的DNS反向区域,并进入DNS反向区域视图。
[Sysname] loadbalance reverse-zone ipv6 1001::0 64
[Sysname-lb-rzone-1001::/64]
·            display loadbalance reverse-zone
1.1.137  loadbalance schedule-test ip
loadbalance schedule-test ip命令用来测试IPv4负载均衡的效果。
loadbalance schedule-test ip [ vpn-instance vpn-instance-name ] { application http { message-file file-name | method { get | post } url url [ header header ]&<1-10> [ content content-value ] } | protocol { protocol-number | icmp | tcp | udp } } destination destination-address destination-port destination-port source source-address source-port source-port [ slot slot-number ]
context-admin
application:测试的应用。
http:应用的类型为HTTP。
message-file file-name:指定HTTP报文内容所在的文件。file-name为文件名,为1~255字符的字符串,不区分大小写。HTTP报文内容所在文件的大小不能大于5000字节。
method:HTTP协议的请求方法。
get:HTTP协议的请求方法为GET。
post:HTTP协议的请求方法为POST。
url url:HTTP报文的URL,为1~255个字符的字符串,区分大小写,可以包含字母、数字、“-”“_”及“.”,不能出现连续“.”,不支持字符“?”。
[ header header ]&<1-10>:HTTP报文首部,为1~127个字符的字符串,不支持字符“?”。&<1-10>表示前面的参数最多可以重复输入10次。
content content-value:HTTP报文体的内容,为1~255个字符的字符串,不支持字符“?”。
protocol { protocol-number | icmp | tcp | udp }:测试的协议。protocol-number为协议编号,取值范围为0~255。其中,ICMP(1)、TCP(6)和UDP(17)这三种协议既可输入协议编号,也可输入协议名称。
destination destination-address:目的IPv4地址。
destination-port destination-port:目的端口号,取值范围为0~65535。并非所有协议都支持本参数。
source-port source-port:源端口号,取值范围为0~65535。并非所有协议都支持本参数。
# 测试TCP协议IPv4负载均衡的效果。
<Sysname> loadbalance schedule-test ip protocol tcp destination 7.7.7.7 destination-port 4 source 2.2.2.2 source-port 5
    Matched virtual server: vs2
    Matched default server farm: sf
    Forward type: Forwarding to real server
    Selected real server: rs2
        Scheduling algorithm: Predictor
    Matched default link group: lg
    Forward type: Forwarding to link
    Selected link: link2
表1-38 loadbalance schedule-test ip命令显示信息描述表
匹配的虚服务器名称
No matched virtual servers.
未匹配任何虚服务器
Matched class
匹配的负载均衡类名称
Matched the default class.
匹配了缺省负载均衡动作
匹配的缺省实服务组名称
匹配的缺省链路组名称
Forward type
转发类型,包括:
·         The destination address is not supported. Load balancing is not performed:不支持此目的地址,不进行负载均衡
·         Matching HTTP virtual server is not supported:匹配了HTTP类型的虚服务器,不支持负载均衡
·         Forward all:转发报文
·         Forwarding to real server:将报文转发给实服务器
·         Forwarding to link:将报文转发给链路
·         Drop:丢弃报文
·         Redirect:重定向
Drop reason
丢弃报文的原因,包括:
·         Number of connections or bandwidth for the virtual server exceeded the limit:虚服务器连接数或带宽受限
·         No class matched and no valid default server/link group farm configured:输入的五元组未匹配任何负载均衡类,且没有配置有效的缺省实服务器组/链路组
·         No valid real server/link in the server farm/link group:选择的实服务器组/链路组中没有可用的实服务器/链路
·         Action is drop:负载均衡动作为丢弃报文
·         A sticky entry was matched but the number of connections or bandwidth for the real server/link exceeded the limit:匹配的持续性表项所对应的实服务器/链路连接数或带宽受限
·         A class was matched but no valid server farm/link group exists in the action of the class:匹配的负载均衡类所对应的负载均衡动作中没有可用的实服务组/链路组
·         The HTTP message is not valid:HTTP报文的内容不合法
·         The HTTP request line is not valid:HTTP报文请求行不合法
·         The HTTP header is not valid:HTTP报文首部不合法
·         The chunk HTTP content is not valid:HTTP报文体的chunk编码不合法
选择的实服务器名称
Selected link
选择的链路名称
选择该实服务器的依据,包括:
·         Predictor:根据调度算法选择了该实服务器/链路
·         Sticky method:根据持续性方法选择了该实服务器/链路
·         Proximity:根据就近性方法选择了该实服务器/链路
1.1.138  loadbalance schedule-test ipv6
loadbalance schedule-test ipv6命令用来测试IPv6负载均衡效果。
loadbalance schedule-test ipv6 [ vpn-instance vpn-instance-name ] { application http { message-file file-name | method { get | post } url url [ header header ]&<1-10> [ content content-value ] } | protocol { protocol-number | icmpv6 | tcp | udp } } destination destination-address destination-port destination-port source source-address source-port source-port [ slot slot-number ]
context-admin
application:测试的应用。
http:应用的类型为HTTP。
message-file file-name:指定HTTP报文内容所在的文件。file-name为1~255字符的字符串,不区分大小写。HTTP报文内容所在文件的大小不能大于5000字节。
method:HTTP协议的请求方法。
protocol { protocol-number | icmp | tcp | udp }:测试的协议。protocol-number为协议编号,取值范围为0~255。其中,ICMPv6(58)、TCP(6)和UDP(17)这三种协议既可输入协议编号,也可输入协议名称。
destination destination-address:目的IPv6地址。
# 测试ICMPv6协议IPv6负载均衡的效果。
<Sysname> loadbalance schedule-test ipv6 protocol icmpv6 destination 10::1 source 12::2
表1-39 loadbalance schedule-test ipv6命令显示信息描述表
匹配的虚服务器名称
未匹配任何虚服务器
Matched class
匹配的负载均衡类名称
匹配了缺省负载均衡动作
匹配的缺省实服务组名称
匹配的缺省链路组名称
Forward type
转发类型,包括:
·         Forward all:转发报文
·         Forwarding to real server/link:将报文转发给实服务器/链路
·         Drop:丢弃报文
·         Redirect:重定向
Drop reason
丢弃报文的原因,包括:
·         No class matched and no valid default server farm/link group configured:输入的五元组未匹配任何负载均衡类,且没有配置有效的缺省实服务器组/链路组
Selected real server/link
选择的实服务器/链路名称
选择该实服务器/链路的依据,包括:
1.1.139  loadbalance snat-pool
loadbalance snat-pool命令用来创建SNAT地址池,并进入SNAT地址池视图。如果指定的SNAT地址池已经存在,则直接进入SNAT地址池视图。
undo loadbalance snat-pool命令用来删除指定的SNAT地址池。
loadbalance snat-pool pool-name
undo loadbalance snat-pool pool-name
不存在任何SNAT地址池。
context-admin
pool-name:SNAT地址池的名称,为1~63个字符的字符串,不区分大小写。
# 创建SNAT地址池lbsp,并进入SNAT地址池视图。
1.1.140  loadbalance test pcre
loadbalance test pcre命令用来测试PCRE正则表达式的匹配效果,并显示匹配结果。
loadbalance test pcre value value { string string | file file-name } [ offset offset ] [ case-insensitive ]
context-admin
value value:PCRE正则表达式,为1~255个字符的字符串,不支持正则元字符“?”。
string string:待测试的字符串,为1~255个字符。
file file-name:待测试的文件名,为1~255字符的字符串,不区分大小写。待测试的文件大小不能大于5000字节。
offset offset:基于待测试内容的偏移量,取值范围为0~255,缺省值为0。
case-insensitive:表示匹配正则表达式时对大小写不敏感。若未指定本参数,则匹配正则表达式时区分大小写。
当待测试的字符串或文件多次匹配输入的正则表达式时,只会显示出第一次匹配该正则表达式的内容。
当待测试内容为输入的字符串时,执行结果以字符串的形式显示出来;当待测试内容为指定文件中的内容时,匹配结果将以十六进制数和字符串的形式同时打印出来,其中,无法显示的字符用“.”来表示。
# 测试字符串内容的PCRE正则表达式匹配结果,匹配正则表达式时对大小写不敏感。
<Sysname> loadbalance test pcre value aaa string ABCDAAaefg case-insensitive
Matched string content: AAa
# 测试文件内容的PCRE正则表达式匹配结果。
<Sysname> loadbalance test pcre value dzckgjlfdsfdsfsdnfsdkjgnf file 123.txt
Matched file content:
64 7a 63 6b 67 6a 6c 66 64  73 66 64 73 66 73 64   dzckgjlf dsfdsfsd
6e 66 73 64 6b 6a 67 6e 66  64                     nfsdkjgn f
表1-40 loadbalance test pcre命令显示信息描述表
匹配PCRE正则表达式的字符串
匹配PCRE正则表达式的文件内容
1.1.141  loadbalance test rewrite
loadbalance test rewrite命令用来测试根据正则表达式重写的效果,并显示重写结果。
loadbalance test rewrite value value replace replace-string { string string | file file-name } [ offset offset ] [ case-insensitive ]
context-admin
value value:用于匹配待重写内容的正则表达式,为1~255个字符的字符串,不支持正则元字符“?”。也可以使用以下特定含义的字符串:%is表示源IP地址;%ps表示源端口号;%id表示目的IP地址;%pd表示目的端口号。
replace replace-string:重写后的内容,为1~255个字符的字符串。
offset offset:基于待处理内容的偏移量,取值范围为0~255,缺省值为0。
当待处理的字符串或文件匹配输入的正则表达式时,本命令将匹配成功的内容替换为重写后的内容。
当待处理的字符串或文件多次匹配输入的正则表达式时,只会显示出第一次匹配该正则表达式的字符串被替换后的内容。
当待处理内容以字符串的形式输入时,处理结果以字符串的形式显示出来,当待处理内容以文件的形式输入时,处理结果以十六进制数和字符串的形式同时显示印出来,其中,无法显示的字符用“.”来表示。
# 测试字符串内容重写的效果,匹配待重写内容的正则表达式时对大小写不敏感。
<Sysname> loadbalance test rewrite value %id replace ip:%id,port:%pd string ABCDAAaefg case-insensitive
Rewritten string content: ABCD172.0.0.1fg
# 测试文件内容重写的效果。
<Sysname> loadbalance test rewrite value dzckgjlfdsfdsfsdnfsdkjgnf replace ip:%id,port:%pd file 123.txt
Rewritten file content:
66 67 73 2d 61 47 76 61 73  64 64 73 61 67 76 62   fgs-aGva sddsagvb
64 6a 63 78 6b 6c 63 78 76  0d 0a 0d 0a 0d 0a 0d   djcxklcx v.......
0a 69 70 3a 31 37 32 2e 30  2e 30 2e 31 2c 70 6f   .ip:172. 0.0.1,po
72 74 3a 38 30 09 6a 6b 64  67 6e 66 64 6a 6b 67   rt:80.jk dgnfdjkg
6e 66 64 6b 6a 67 6e 66 64  6b 6e 67 76 73 64 66   nfdkjgnf dkngvsdf
6c 0d 0a 0d 0a 0d 0a 0d 0a  66 67 73 2b 61 67 76   l....... .fgs+agv
61 73 64 64 73 61 67 76 62  64 6a 63 78 6b 6c 63   asddsagv bdjcxklc
78 76 0d 0a 66 67 73 64 61  67 76 61 73 64 64 73   xv..fgsd agvasdds
61 67 76 62 64 6a 63 78 6b  6c 63 78 76            agvbdjcx klcxv
表1-41 loadbalance test rewrite命令显示信息描述表
重写后的字符串内容
重写后的文件内容
1.1.142  loadbalance virtual-server-pool
loadbalance virtual-server-pool命令用来创建虚服务器池,并进入虚服务器池视图。如果指定的虚服务器池已经存在,则直接进入虚服务器池视图。
undo loadbalance virtual-server-pool命令用来删除指定的虚服务器池。
loadbalance virtual-server-pool pool-name
undo loadbalance virtual-server-pool pool-name
不存在任何虚服务器池。
context-admin
pool-name:虚服务器池的名称,为1~63个字符的字符串,不区分大小写。
为了便于对多个虚服务器进行管理,可以依据这些虚服务器的共有属性划分成不同的池,称为虚服务器池。
# 创建虚服务器池local-pool,并进入虚服务器池视图。
[Sysname] loadbalance virtual-server-pool local-pool
[Sysname-lb-vspool-local-pool]
1.1.143  loadbalance zone
loadbalance zone命令用来创建DNS正向区域,并进入DNS正向区域视图。如果指定的DNS正向区域已经存在,则直接进入DNS正向区域视图。
undo loadbalance zone命令用来删除指定的DNS正向区域。
loadbalance zone domain-name
undo loadbalance zone domain-name
不存在DNS正向区域。
context-admin
domain-name:DNS正向区域的域名,不区分大小写,由“.”分隔的字符串组成,每个字符串的长度不超过63个字符,包括“.”在内的总长度不超过253个字符。字符串中可以包含字母、数字、“-”、“_”和“.”。
# 创建域名为abc.com的DNS正向区域,并进入DNS正向区域视图。
1.1.144  match acl
match acl命令用来创建ACL类型的匹配规则。如果指定的匹配规则已存在,则直接对其进行修改。
undo match命令用来删除指定的匹配规则。
match [ match-id ] acl [ ipv6 ] { acl-number | name acl-name }
undo match match-id
不存在匹配规则。
负载均衡类视图
context-admin
match-id:匹配规则的编号,取值范围为1~65535。若未指定本参数,系统将自动分配一个可用的最小编号。
ipv6:表示IPv6 ACL类型。如果未指定本参数,表示IPv4 ACL类型。
name acl-name:ACL的名称,为1~63个字符的字符串,不区分大小写,必须以英文字母a~z或A~Z开头。
如果指定编号或名称的ACL不存在,此匹配规则将不参与匹配。
一个负载均衡类中最多允许创建65535条匹配规则。
# 在通用类型的负载均衡类lbc1中,创建ACL类型的匹配规则。
[Sysname-lbc-generic-lbc1] match acl 2000
1.1.145  match app-group
match app-group命令用来创建应用类型的匹配规则。如果指定的匹配规则已存在,则直接对其进行修改。
undo match app-group命令用来删除指定的匹配规则。
match [ match-id ] app-group group-name
undo match match-id
负载均衡类中不存在匹配规则。
Link-Generic类型的负载均衡类视图
context-admin
app-group group-name:应用组的名称,为1~63个字符的字符串,不区分大小写。
如果匹配规则中指定的应用组不存在,则此规则不生效
# 在链路负载均衡类lbc1中,创建基于应用类型的匹配规则。
[Sysname] loadbalance class lbc1 type link-generic
[Sysname-lbc-link-generic-lbc1] match app-group http
·            app-group(安全命令参考/APR)
1.1.146  match class
match class命令用来创建嵌套类的匹配规则。如果指定的匹配规则已存在,则直接对其进行修改。
match [ match-id ] class class-name
undo match match-id
负载均衡类中不存在匹配规则。
负载均衡类视图
context-admin
class-name:要嵌套的负载均衡类名称,为1~63个字符的字符串,不区分大小写。不允许嵌套当前的负载均衡类。
在创建嵌套类的匹配规则时,最多只能嵌套一层。即本命令不能引用已嵌套的负载均衡类。
# 在通用类型的负载均衡类lbc1中,创建嵌套类的匹配规则为:嵌套负载均衡类lbc2。
[Sysname-lbc-generic-lbc1] match class lbc2
1.1.147  match content
match content命令用来创建HTTP实体类型的匹配规则。如果指定的匹配规则已存在,则直接对其进行修改V。
match [ match-id ] content content [ offset offset ]
undo match match-id
负载均衡类中不存在匹配规则。
HTTP类型的负载均衡类视图
context-admin
content content:HTTP实体的正则表达式,为1~255个字符的字符串,不支持正则元字符?。
offset offset:HTTP实体基于HTTP报文起始位置的偏移量,取值范围为0~1000,缺省值为0。
配置了本命令后,如果HTTP报文的实体部分在偏移了offset后能够匹配指定的正则表达式,便认为此报文匹配了该规则。
# 在HTTP类型的负载均衡类lbc2中,创建HTTP实体类型的匹配规则为:HTTP报文的实体部分偏移了10之后,包含字符串abc。
[Sysname] loadbalance class lbc2 type http
[Sysname-lbc-http-lbc2] match content abc.* offset 10
1.1.148  match cookie
match cookie命令用来创建HTTP Cookie类型的匹配规则。如果指定的匹配规则已存在,则直接对其进行修改。
match [ match-id ] cookie cookie-name value value
undo match match-id
负载均衡类中不存在匹配规则。
HTTP类型的负载均衡类视图
context-admin
cookie cookie-name:HTTP报文的Cookie名称,为1~63个字符的字符串,区分大小写。不包括(、)、<、>、@、,、;、:、\、"、/、[、]、?、=、{、}、SP(空格符)、HT(水平制表符),以及ASCII码中小于等于31、大于等于127的字符。
value value:Cookie值的正则表达式,为1~255个字符的字符串,不支持正则元字符?。
配置了本命令后,如果HTTP报文中携带有指定名称的Cookie,且Cookie值匹配了指定的正则表达式,便认为此报文匹配了该规则。
# 在HTTP类型的负载均衡类lbc2中,创建HTTP Cookie类型的匹配规则为:名为JSession-id的Cookie,其值中包含字符串abc。
[Sysname-lbc-http-lbc2] match cookie JSeesion-id value abc.*
1.1.149  match default probe
match default probe命令用来指定缺省就近性探测方法。
undo match default命令用来恢复缺省情况。
match default probe template-name
undo match default
未指定缺省就近性探测方法。
就近性视图
context-admin
template-name:就近性探测方法所使用的NQA模板名称,为1~32个字符的字符串,不区分大小写。
配置了match probe命令后,当流量匹配了指定类型的报文,就使用该类型报文所对应的就近性探测方法进行就近性探测。如果流量未匹配任何类型的报文,或者未配置match probe命令,则使用本命令所指定的缺省就近性探测方法进行就近性探测。
# 创建ICMP类型的NQA模板t4,并将其指定为缺省就近性探测方法。
[Sysname] nqa template icmp t4
[Sysname-nqatplt-icmp-t4] quit
[Sysname-lb-proximity] match default probe t4
·            match probe
1.1.150  match destination
match destination命令用来创建目的IP地址类型的匹配规则。如果指定的匹配规则已存在,则直接对其进行修改。
match [ match-id ] destination { ip address ipv4-address [ mask-length | mask ] | ipv6 address ipv6-address [ prefix-length ] }
undo match match-id
负载均衡类中不存在匹配规则。
负载均衡类视图
context-admin
ip address ipv4-address:IPv4地址。
mask-lengh:子网掩码长度,取值范围为0~32,缺省值为32。
mask:子网掩码,缺省值为255.255.255.255。
ipv6 address ipv6-address:IPv6地址。
prefix-length:前缀长度,取值范围为0~128,缺省值为128。
仅在DNS类型和Link-generic类型的负载均衡类视图下支持本命令。
# 在DNS类型的负载均衡类lbc1中,创建目的IP地址类型的匹配规则为:匹配IPv4地址1.1.1.1/32。
[Sysname] loadbalance class lbc1 type dns
[Sysname-lbc-dns-lbc1] match destination ip address 1.1.1.1
# 在Link-generic类型的负载均衡类lbc2中,创建目的IP地址类型的匹配规则为:匹配IPv4地址1.1.1.1/32。
[Sysname] loadbalance class lbc2 type link-generic
[Sysname-lbc-link-generic-lbc2] match destination ip address 1.1.1.1
1.1.151  match destination domain-name
match destination domain-name命令用来创建域名类型的匹配规则。如果指定编号的匹配规则已经存在,则直接对其进行修改。
match [ match-id ] destination domain-name domain-name
undo match match-id
负载均衡类中不存在匹配规则。
context-admin
domain-name:域名,为1~253个字符的字符串,不区分大小写。域名由“.”分隔的字符串组成,每个字符串的长度不超过63个字符,包括“.”在内的总长度不超过253个字符。域名字符串中可以包含字母、数字、“-”、“_”或“.”。域名支持通配符,允许使用的通配字符包括问号“?”和星号“*”,通配符使用规则如下:
·            问号“?”用于代替域名中的单个字符,域名中的点“.”除外,域名中允许使用多个问号“?”;
·            星号“*”用于代替域名中的多个字符,域名中的点“.”除外,域名中允许使用多个星号“*”;
# 在Link-generic类型的负载均衡类lbc1中,创建域名类型的匹配规则:匹配域名www.aaa.com。
[Sysname-lbc-link-generic-lbc1] match destination domain-name www.aaa.com
1.1.152  match domain-name
match domain-name命令用来创建域名类型的匹配规则。如果指定的匹配规则已存在,则直接对其进行修改。
undo domain-name命令用来删除指定的匹配规则。
match [ match-id ] domain-name domain-name
undo match match-id
负载均衡类中不存在匹配规则。
DNS类型的负载均衡类视图
context-admin
domain-name:域名,为1~253个字符的字符串,不区分大小写。由“.”分隔的字符串组成,每个字符串的长度不超过63个字符,包括“.”在内的总长度不超过253个字符。字符串中可以包含字母、数字、“-”、“_”或“.”。域名支持通配符配置,允许使用的通配字符包括问号“?”和星号“*”,通配符使用规则如下:
·            问号“? ”用于代替域名中的单个字符,域名中的点“.”除外,域名中允许使用多个问号“?”;
# 在DNS类型的负载均衡类lbc1中,创建域名类型的匹配规则:匹配域名www.abc.com。
[Sysname-lbc-dns-lbc1] match domain-name www.abc.com
1.1.153  match header
match header命令用来创建HTTP首部类型的匹配规则。如果指定编号的匹配规则已经存在,则直接对其进行修改。
match [ match-id ] header header-name value value
undo match match-id
负载均衡类中不存在匹配规则。
HTTP类型的负载均衡类视图
context-admin
header header-name:HTTP报文首部的名称,为1~63个字符的字符串,不区分大小写。不包括(、)、<、>、@、,、;、:、\、"、/、[、]、?、=、{、}、SP(空格符)、HT(水平制表符),以及ASCII码中小于等于31、大于等于127的字符。
value value:首部值的正则表达式,为1~255个字符的字符串,不支持正则元字符?。
配置了本命令后,如果HTTP报文中携带有指定名称的首部,且首部值匹配了指定的正则表达式,便认为此报文匹配了该规则。
# 在HTTP类型的负载均衡类lbc2中,创建HTTP首部类型的匹配规则为:名为user-agent的HTTP报文首部,其值为abcd。
[Sysname-lbc-http-lbc2] match header user-agent value abcd
1.1.154  match isp
match isp命令用来创建ISP类型的匹配规则。如果指定编号的匹配规则已经存在,则直接对其进行修改。
match [ match-id ] isp isp-name
undo match match-id
负载均衡类中不存在匹配规则。
负载均衡类视图
context-admin
如果指定名称的ISP不存在或未配置IP网段信息,此匹配规则将不参与匹配。
# 在通用类型的负载均衡类lbc1中,创建ISP类型的匹配规则,匹配名为isp1的ISP。
[Sysname-lbc-generic-lbc1] match isp isp1
1.1.155  match method
match method命令用来创建匹配报文方法类型的匹配规则。如果指定编号的匹配规则已经存在,则直接对其进行修改。
match [ match-id ] method { ext ext-type | rfc rfc-type }
undo match match-id
负载均衡类中不存在匹配规则。
HTTP类型的负载均衡类视图
context-admin
ext ext-type:扩展类型,即用户可以输入指定的字符串作为方法名。ext-type为1~63个字符,区分大小写。不包括(、)、<、>、@、,、;、:、\、"、/、[、]、?、=、{、}、SP(空格符)、HT(水平制表符),以及ASCII码中小于等于31、大于等于127的字符。
rfc rfc-type:RFC类型,即对HTTP请求报文中URI所标识资源的执行方法。rfc-type包括:
·            CONNECET:保留。
·            DELETE:请求删除URI所标识的资源。
·            GET:请求获取URI所标识的资源。
·            HEAD:请求获取URI所标识资源的响应消息首部。
·            OPTIONS:请求查询服务器支持的功能,即查询与URI所标识资源相关的选项和需求。
·            POST:在URI所标识的资源后附加新数据。
·            PUT:请求服务器存储一个资源,并用URI作为其标识。
·            TRACE:请求服务器回送收到的请求消息,主要用于测试或诊断。
# 在HTTP类型的负载均衡类lbc2中,创建匹配报文方法类型的匹配规则为扩展类型的user。
[Sysname-lbc-http-lbc2] match method ext user
# 在HTTP类型的负载均衡类lbc2中创建匹配报文方法类型的匹配规则为RFC类型的CONNECT。
[Sysname-lbc-http-lbc2] match method rfc CONNECT
1.1.156  match probe
match probe命令用来为不同类型的报文指定就近性探测方法。
undo match命令用来恢复缺省情况。
match [ match-id ] { tcp } probe template-name
undo match match-id
未指定就近性探测方法。
就近性视图
context-admin
tcp:为TCP类型的报文指定就近性探测方法。
配置了本命令后,当流量匹配了指定的报文类型,就使用该报文类型所对应的就近性探测方法进行就近性探测。如果流量未匹配任何报文类型,或者未配置本命令,则使用match default probe命令所指定的缺省就近性探测方法进行就近性探测。
每种报文类型只能指定一种就近性探测方法。
# 创建ICMP类型的NQA模板t4,并将其指定为TCP类型报文的就近性探测方法。
[Sysname-lb-proximity] match tcp probe t4
·            match default probe
1.1.157  match radius-attribute
match radius-attribute命令用来创建RADIUS属性的匹配规则。如果指定编号的匹配规则已经存在,则直接对其进行修改。
undo match命令用来删除指定的RADIUS属性匹配规则。
match [ match-id ] radius-attribute { code attribute-code | user-name } value attribute-value
undo match match-id
负载均衡类中不存在RADIUS属性的匹配规则。
RADIUS类型的负载均衡类视图
context-admin
code attribute-code:指定RADIUS属性类型的编号,取值范围为1~255。
user-name:指定RADIUS属性类型为User-Name(编号为1)。
value attribute-value:匹配RADIUS属性值的正则表达式,为1~255个字符的字符串。
# 在RADIUS类型的负载均衡类lbc1中,创建RADIUS属性类型为User-Name的匹配规则:属性值中包含字符串aaa。
[Sysname] loadbalance class lbc1 type radius
[Sysname-lbc-radius- lbc1] match radius-attribute user-name value aaa*
1.1.158  match source
match source命令用来创建源IP地址类型的匹配规则。如果指定编号的匹配规则已经存在,则直接对其进行修改。
match [ match-id ] source { ip address ipv4-address [ mask-length | mask ] | ipv6 address ipv6-address [ prefix-length ] }
undo match match-id
负载均衡类中不存在匹配规则。
负载均衡类视图
context-admin
# 在通用类型的负载均衡类lbc1中,创建源IP地址类型的匹配规则为:匹配IPv4地址1.1.1.1/32。
[Sysname-lbc-generic-lbc1] match source ip address 1.1.1.1
1.1.159  match url
match url命令用来创建HTTP URL类型的匹配规则。如果指定编号的匹配规则已经存在,则直接对其进行修改。
undo match命令用来在删除指定的匹配规则。
match [ match-id ] url url
undo match match-id
负载均衡类中不存在匹配规则。
HTTP类型的负载均衡类视图
context-admin
url url:URL的正则表达式,为1~255个字符的字符串,不支持正则元字符?。
# 在HTTP类型的负载均衡类lbc2中,创建HTTP URL类型的匹配规则为:.*.html。
[Sysname-lbc-http-lbc2] match url .*.html
1.1.160  max-bandwidth (link view)
max-bandwidth命令用来配置链路的最大期望带宽。
undo max-bandwidth命令用来恢复缺省情况。
max-bandwidth [ inbound | outbound ] bandwidth-value
undo max-bandwidth [ inbound | outbound ]
链路的最大期望带宽不受限制。
链路视图
context-admin
inbound:配置最大上行期望带宽,即入方向带宽。
outbound:配置最大下行期望带宽,即出方向带宽。
bandwidth-value:最大带宽值,取值范围为1~4294967295,单位为千字节/秒,0千字节/秒表示最大带宽不受限制。
如果未指定inbound和outbound参数,则最大总期望带宽,总带宽等于入带宽与出带宽之和。
本命令只在新建会话时生效,对已经存在的会话不生效。
通过本命令配置的最大期望带宽不仅用于带宽繁忙保护功能,还用于带宽算法、最大带宽算法和就近性中剩余带宽的计算。
# 配置链路lk1的最大总期望带宽为1千字节/秒。
[Sysname-lb-link-lk1] max-bandwidth 1
# 配置链路lk1的最大上行期望带宽为1千字节/秒。
[Sysname-lb-link-lk1] max-bandwidth inbound 1
# 配置链路lk1的最大下行期望带宽为1千字节/秒。
[Sysname-lb-link-lk1] max-bandwidth outbound 1
1.1.161  max-bandwidth (real server view)
max-bandwidth命令用来配置实服务器的最大期望带宽。
实服务器的最大期望带宽不受限制。
实服务器视图
context-admin
bandwidth-value:最大带宽值,取值范围为0~4294967295,单位为千字节/秒,0千字节/秒表示最大带宽不受限制。
通过本配置可以调整实服务器的带宽繁忙比,即当前带宽与最大带宽的百分比值,以及最大期望带宽。当访问某个实服务器的链路流量超过该实服务器的带宽繁忙比与最大期望带宽的乘积后,新建流量(非匹配持续性的流量)将不再向该链路分发,而原有流量则仍由该链路继续分发。
如果未指定inbound和outbound参数,则表示配置实服务器的最大期望总带宽等于上行带宽与下行带宽之和。
如果未配置本命令或配置为0(不受限),则繁忙保护带宽上限受实服务器允许的最大带宽rate-limit bandwidth (real server view)命令控制。
# 配置实服务器rs的最大期望总带宽为1千字节/秒。
[Sysname-rserver-rs] max-bandwidth 1
# 配置实服务器rs的最大上行期望带宽为1千字节/秒。
[Sysname-rserver-rs] max-bandwidth inbound 1
# 配置实服务器rs的最大下行期望带宽为1千字节/秒。
[Sysname-rserver-rs] max-bandwidth outbound 1
1.1.162  max-number
max-number命令用来配置就近性表项的最大个数。
undo max-number命令用来恢复缺省情况。
max-number number
undo max-number
不限制就近性表项的最大个数。
就近性视图
context-admin
number:就近性表项的最大个数,取值范围为0~10000000,缺省值为0,0表示不限制就近性表项的最大个数。
# 配置就近性表项的最大个数为100。
[Sysname-lb-proximity] max-number 100
1.1.163  memory-size
memory-size命令用来设置对应答报文压缩所占用的内存大小。
undo memory-size命令用来恢复缺省情况。
memory-size size
undo memory-size
应答报文压缩所占用的内存大小为8KB。
HTTP压缩参数模板视图
context-admin
# 创建HTTP压缩类型的参数模板pa1,并指定压缩使用的内存大小为32KB。
[Sysname] parameter-profile pa1 type http-compress
[Sysname-para-http-compress-pa1] memory-size 32
1.1.164  min-ttl
min-ttl命令用来配置最小生命周期。
undo min-ttl命令用来恢复缺省情况。
min-ttl ttl-value
undo min-ttl
最小生命周期为3600秒。
SOA视图
context-admin
ttl-value:最小生命周期,取值范围为0~4294967295,单位为秒。
最小生命周期是主域名服务器上的资源记录在辅助域名服务器上被缓存的时间。
# 对DNS正向区域abc.com,配置最小生命周期为1天。
[Sysname] loadbalance zone abc.com
[Sysname-lb-zone-abc.com] soa
[Sysname-lb-zone-abc.com-soa] min-ttl 86400
·            display loadbalance zone
1.1.165  override-limit enable
override-limit enable命令用来开启匹配持续性表项的会话不受连接数限制。
undo override-limit enable命令用来关闭匹配持续性表项的会话不受连接数限制。
匹配持续性表项的会话受连接数限制配置的影响。
持续性组视图
context-admin
开启该功能后,如果该连接匹配了已有的持续性表项,将不受实服务器/链路上带宽和连接参数的影响;不受实服务器/链路的带宽繁忙比与最大期望带宽的影响;也不受虚服务器上引用的负载均衡策略连接数限制的影响。
# 配置持续性组st使其对匹配了该持续性组生成的持续性表项的会话不受连接数限制影响。
[Sysname] sticky-group st type http-cookie
[Sysname-sticky-http-cookie-st] override-limit enable
1.1.166  parameter
parameter命令用来指定虚服务器引用的参数模板。
undo parameter命令用来恢复缺省情况。
parameter { http | http-compression | ip | tcp } profile-name
undo parameter { http | http-compression | ip | tcp }
虚服务器没有引用任何参数模板。
虚服务器视图
context-admin
{ http | http-compression | ip| tcp }:参数模板的类型,包括HTTP、HTTP压缩、IP和TCP四种类型。其中,http和tcp参数只在快速HTTP和HTTP类型的虚服务器视图下支持,http压缩参数只在HTTP类型的虚服务器视图下支持。
profile-name:参数模板的名称,为1~63个字符的字符串,不区分大小写。
参数模板用来对虚服务器上的流量进行比较深入的解析、处理和优化。虚服务器引用了参数模板后,就要根据该参数模板的配置对匹配流量进行相应的处理。
RADIUS类型的虚服务器只能引用IP类型的参数模板。
# 指定IP类型的虚服务器vs3引用IP类型的参数模板pp2。
[Sysname-vs-ip-vs3] parameter ip pp2
1.1.167  parameter-profile
parameter-profile命令用来创建参数模板,并进入参数模板视图。如果指定的参数模板已经存在,则直接进入参数模板视图。
undo parameter-profile命令用来删除指定的参数模板。
parameter-profile profile-name [ type { http | http-compression | ip | tcp } ]
undo parameter-profile profile-name
不存在任何参数模板。
context-admin
type { http | http-compression | ip | tcp }:参数模板的类型,包括HTTP、HTTP压缩、IP和TCP四种类型。创建参数模板时必须指定本参数;而在进入已创建的参数模板视图时可以不指定本参数,但若要指定本参数,则必须与创建时的类型一致。
通过配置参数模板可以进行一些高级参数的配置。这样,当参数模板被虚服务器引用之后,可以对虚服务器的业务流量进行更深入的解析、处理和优化。
当设备支持服务器负载均衡License功能但尚未安装License时,不允许配置HTTP或HTTP压缩类型的参数模板;当设备不支持服务器负载均衡License功能,或支持服务器负载均衡License功能且安装有License时,才允许配置HTTP或HTTP压缩类型的参数模板。
# 创建IP类型的参数模板pp2,并进入参数模板视图。
[Sysname] parameter-profile pp2 type ip
[Sysname-para-ip-pp2]
1.1.168  payload
payload命令用于配置HTTP载荷持续性方法。
undo payload命令用来删除HTTP载荷持续性方法。
payload [ offset offset ] [ start start-string ] [ end end-string | length length ]
undo payload
不存在任何持续性方法。
持续性组视图
context-admin
offset offset:HTTP载荷基于HTTP报文起始位置的偏移量,取值范围为0~1000,缺省值为0。
start start-string:HTTP载荷开始标记的正则表达式,即从offset起到本标记为开始,为1~127个字符的字符串,不支持正则元字符?。
end end-string:HTTP载荷结束标记的正则表达式,即从start-string起到本标记为结束,为1~127个字符的字符串,不支持正则元字符?。
length length:HTTP载荷的长度,取值范围为0~1000,缺省值为0,表示所有长度。
本命令只在HTTP载荷类型的持续性组视图下支持。
本命令用来根据offset、start-string、end-string及length获取生成持续性表项的HTTP载荷信息。start-string和end-string将不计入持续性表项信息中。
快速HTTP类型的虚服务器不支持引用HTTP载荷持续性方法。
# 在HTTP载荷类型的持续性组sg5中,配置HTTP载荷持续性方法为:从HTTP报文起始位置的第10个字节起,长度为20个字节HTTP载荷来生成持续性表项。
[Sysname] sticky-group sg5 type payload
[Sysname-sticky-payload-sg5] payload offset 10 length 20
1.1.169  port (DNS proxy view)
port命令用来配置DNS透明代理的端口号。
undo port命令用来恢复缺省情况。
port port-number
undo port
DNS透明代理的端口号为53。
DNS透明代理视图
context-admin
port-number:端口号,取值范围1~65535。
只有当用户发送的DNS请求报文的目的地址和端口号匹配DNS透明代理的地址和端口号,设备才进行DNS透明代理。
# 在名称为dns-proxy1的DNS透明代理视图下,配置其端口号为5353。
[Sysname-lb-dp-dns-proxy1] port 5353
1.1.170  port (DNS server view)
port命令用来配置DNS服务器的端口号。
port port-number
undo port
DNS服务器的端口号为0。
DNS服务器视图
context-admin
port-number:端口号,取值范围0~65535,0表示继续使用原报文携带的端口号。
# 配置DNS服务器的端口号为5353。
[Sysname-lb-ds-ds1] port 5353
1.1.171  port (real server view)
port命令用来配置实服务器的端口号。
port port-number
undo port
实服务器的端口号为0(表示继续使用原报文携带的端口号)。
实服务器视图
context-admin
port-number:端口号,取值范围为0~65535,0表示继续使用原报文携带的端口号。
只有当实服务组开启了NAT功能后,本配置才有效。
# 配置实服务器rs的端口号为8080。
[Sysname-rserver-rs] port 8080
·            transparent enable(server farm view)
1.1.172  port (virtual server view)
port命令用来配置虚服务器的端口号。
port { port-number [ to port-number ] } &<1-n>
undo port
IP/RADIUS/TCP/UDP类型虚服务器的端口号为0(表示任意端口号),快速HTTP/HTTP类型虚服务器的端口号为80。
虚服务器视图
context-admin
{ port-number [ to port-number ] } &<1-n>:表示一个或多个端口号。其中,port-number为端口号,对于IP/RADIUS/TCP/UDP类型的虚服务器,取值范围为0~65535,0表示任意端口号;对于快速HTTP/HTTP类型的虚服务器,取值范围为1~65535。&<1-n>表示前面的参数最多可以输入n次,对于IP/RADIUS/TCP/UDP类型的虚服务器,n的取值范围为1~8;对于快速HTTP/HTTP类型的虚服务器,n的取值只能为1。
如果虚服务器引用了SSL策略,则必须为其配置一个非缺省端口号(通常用443)。
# 配置IP类型的虚服务器vs3的端口号为8080。
[Sysname-vs-ip-vs3] port 8080
·            ssl-server-policy
1.1.173  predictor (DNS server pool view)
predictor命令用来配置DNS服务器池的调度算法。
undo predictor命令用来恢复缺省情况。
predictor hash address { destination | source | source-ip-port } [ mask mask-length ] [ prefix prefix-length ]
predictor { random | round-robin | { bandwidth | max-bandwidth } [ inbound | outbound ] }
undo predictor
DNS服务器池的调度算法为加权轮转算法。
DNS服务器池视图
context-admin
hash address:根据IP地址进行的哈希算法。
destination:根据目的IP地址进行的哈希算法。
source:根据源IP地址进行的哈希算法。
source-ip-port:根据源IP地址和端口号进行的哈希算法。
mask mask-length:哈希算法中IPv4地址的掩码长度,取值范围为0~32,缺省值为32。
prefix prefix-length:哈希算法中IPv6地址的前缀长度,取值范围为0~128,缺省值为128。
random:随机算法,即把DNS请求报文随机分发给每台DNS服务器。
round-robin:加权轮转算法,即根据DNS服务器权值的大小把DNS请求报文依次分发给每台DNS服务器,权值越大,分配的DNS请求报文越多。
bandwidth:带宽算法,即报文根据DNS服务器的权值与剩余带宽比例把DNS请求分发给每台DNS服务器。
max-bandwidth:最大带宽算法,即总是将DNS请求分发给处于空闲状态且剩余带宽最大的链路所对应的DNS服务器。
inbound:根据入方向带宽选择DNS服务器。
outbound:根据出方向带宽选择DNS服务器。
如果未指定inbound和outbound关键字,将根据总带宽来选择DNS服务器。
在带宽算法和最大剩余带宽算法中,剩余带宽为链路的最大期望带宽(max-bandwidth)与当前带宽的差值。若未配置最大期望带宽,剩余带宽为链路所允许的最大带宽(rate-limit bandwidth)与当前带宽的差值。
# 配置DNS服务器池dns-pool的优选调度算法为随机算法。
[Sysname-lb-dspool-dns-pool] predictor random
·            max-bandwidth (link view)
·            rate-limit bandwidth (link view)
1.1.174  predictor (link group view)
predictor命令用来配置链路组的调度算法。
predictor { least-connection | random | round-robin | { bandwidth | max-bandwidth } [ inbound | outbound ] }
undo predictor
链路组的调度算法为加权轮转算法。
链路组视图
context-admin
mask mask-length: IPv4地址的掩码长度,取值范围为0~32,缺省值为32。
prefix prefix-length:IPv6地址的前缀长度,取值范围为0~128,缺省值为128。
least-connection:加权最小连接算法,即总是把新连接分发给加权活动连接数(当前活动连接数/权值)最小的链路。
random:随机算法,即把新连接随机分发给每个链路。
round-robin:加权轮转算法,即根据链路权值的大小把新连接依次分发给每个链路,权值越大,分配的新连接越多。
bandwidth:带宽算法,即报文根据链路的权值与剩余带宽比例分发到各链路上。
max-bandwidth:最大带宽算法,即报文总是分发给处于空闲状态且剩余带宽最大的链路。
inbound:根据入方向带宽选择链路。
outbound:根据出方向带宽选择链路。
如果未指定inbound和outbound关键字,将根据总带宽来选择链路。
设备同时只能配置一种调度算法,多次配置此命令,新的配置会覆盖旧的配置。
# 配置链路组lg的调度算法为随机算法。
[Sysname] loadbalance link-group lg
[Sysname-lb-lgroup-lg] predictor random
1.1.175  predictor (server farm view)
predictor命令用来配置实服务组的调度算法。
undo predictor
实服务组的调度算法为加权轮转算法。
实服务组视图
context-admin
mask mask-length:IPv4地址的掩码长度,取值范围为0~32,缺省值为32。
least-connection:加权最小连接算法,即总是把新连接分发给加权活动连接数(当前活动连接数/权值)最小的实服务。
random:随机算法,即把新连接随机分发给每个实服务器。
round-robin:加权轮转算法,即根据实服务权值的大小把新连接依次分发给每个实服务器,权值越大,分配的新连接越多。
bandwidth:带宽算法,即报文根据实服务器的权值与剩余带宽比例分发到各实服务器上。
max-bandwidth:最大带宽算法,即总是将报文分发给处于空闲状态且剩余带宽最大的实服务器。
inbound:根据入方向带宽选择实服务器。
outbound:根据出方向带宽选择实服务器。
如果未指定inbound和outbound关键字,将根据总带宽来选择实服务器。
在带宽算法和最大剩余带宽算法中,剩余带宽为实服务器的最大期望带宽(max-bandwidth)与当前带宽的差值。若未配置最大期望带宽,剩余带宽为实服务器所允许的最大带宽(rate-limit bandwidth)与当前带宽的差值。
# 配置实服务组sf的调度算法为随机算法。
[Sysname] server-farm sf
[Sysname-sfarm-sf] predictor random
·            max-bandwidth (real server view)
·            rate-limit bandwidth (real server view)
1.1.176  predictor (virtual server pool view)
predictor命令用来配置虚服务器池的调度算法。
predictor { alternate | fallback | preferred } { least-connection | proximity | random | round-robin | topology | { bandwidth | max-bandwidth } [ inbound | outbound ] | hash address { source | source-ip-port | destination } [ mask mask-length | prefix prefix-length ] }
undo predictor { alternate | fallback }
虚服务器池的首选调度算法为加权轮转算法,不存在次选和备选调度算法。
虚服务器池视图
context-admin
alternate:指定虚服务器池的次选调度算法。
fallback:指定虚服务器池的备选调度算法。
preferred:指定虚服务器池的首选调度算法。
least-connection:加权最小连接算法,即总是把DNS请求分发给加权活动连接数(当前活动连接数/权值)最小的虚服务器。
proximity:动态就近性算法,即根据动态就近性表项把DNS请求分发给虚服务。
random:随机算法,即把DNS请求随机分发给每个虚服务器。
round-robin:加权轮转算法,即根据虚服务器权值的大小把DNS请求依次分发给每个虚服务器,权值越大,分配的DNS请求越多。
topology:静态就近性算法,即根据静态就近性表项把DNS请求分发给虚服务器。
bandwidth:带宽算法,即根据虚服务器的权值与剩余带宽的比例把DNS请求分发给每个虚服务器。
max-bandwidth:最大带宽算法,即总是将DNS请求分发给处于空闲状态且剩余带宽最大的链路所对应的虚服务器。
inbound:根据入方向带宽选择虚服务器。
outbound:根据出方向带宽选择虚服务器。
mask mask-length:哈希算法中IPv4地址的掩码长度。其中,mask-length的取值范围为0~32,缺省值为32。
prefix prefix-length:哈希算法中IPv6地址的掩码长度。其中,prefix-length的取值范围为0~128,缺省值为128。
选择带宽算法或最大带宽算法时,若未指定inbound和outbound关键字,则将根据总带宽来选择虚服务器。
# 配置虚服务器池local-pool的优选调度算法为随机算法,次选调度算法为最小连接数算法。
[Sysname-lb-vspool-local-pool] predictor preferred random
[Sysname-lb-vspool-local-pool] predictor alternate least-connection
1.1.177  prefer-method
prefer-method命令用来配置应答报文首选的压缩算法。
undo prefer-method命令用来恢复缺省情况。
prefer-method { deflate | gzip }
undo prefer-method
应答报文首选的压缩算法为gzip。
HTTP压缩参数模板视图
context-admin
deflate:deflate 压缩算法。
gzip:缺省的gzip压缩算法。
如果客户端的请求支持配置的压缩算法,则用配置的算法进行压缩,否则采用请求中携带的算法。
# 创建HTTP压缩类型的参数模板http1,并配置首选压缩算法为deflate。
[Sysname] parameter-profile http1 type http-compression
[Sysname-para-http-compression-http1] prefer-method deflate
1.1.178  primary-nameserver
primary-nameserver命令用来配置主域名服务器的主机名。
undo primary-nameserver命令用来恢复缺省情况。
primary-nameserver host-name
未配置主域名服务器的主机名。
SOA视图
context-admin
host-name:主域名服务器的主机名,不区分大小写,由“.”分隔的字符串组成。每个字符串的长度不超过63个字符,包括“.”在内的总长度不超过254个字符,可以包含字母、数字、“-”、“_”或“.”。
主域名服务器的主机名可以是相对域名(不以“.”结束),也可以是绝对域名(以“.”结束)。当主机名为绝对域名时,不会自动扩充主机名,其长度不能大于254个字符;当主机名为相对域名时,会进行自动扩充,在用户配置的主机名后自动添加当前区域名。主机名加区域名长度总和不能大于254个字符。
# 对DNS正向区域abc.com,配置主域名服务器的主机名为ns1.abc.com。
[Sysname-lb-zone-abc.com-soa] primary-nameserver ns1.abc.com
1.1.179  priority (DNS server view)
priority命令用来配置DNS服务器的调用优先级。
undo priority命令用来恢复缺省情况。
priority priority-value
undo priority
DNS服务器的调用优先级为4。
DNS服务器视图
context-admin
priority-value:优先级,取值范围为1~8,数值越大,越被优先调用。
在DNS服务器池范围内,优先级最高的DNS服务器参与调度,如果可用DNS服务器数量未到达预设的最低门限,则将次高优先级的DNS服务器均加入调度,依次类推,直至达到预设的最小参与调度个数或没有可用服务器为止。若将某一个优先级的DNS服务器均加入调度后,超出了预设的最大参与调度个数,则只加入部分此优先级的DNS服务器,此时最终参与调度的可用DNS服务器个数将为预设的最大参与调度个数。
本命令与DNS服务器池视图下的selected-server命令配合使用。
# 配置DNS服务器ds1的调用优先级为3。
[Sysname] loadbalance dns-server ds1
[Sysname-lb-ds-ds1] priority 3
·            selected-server (DNS server pool view)
1.1.180  priority (link view)
priority命令用来配置链路的调用优先级。
undo priority
链路的调用优先级为4。
链路视图
context-admin
priority-value:优先级。取值范围为1~8,数值越大,优先级越高。
通常使用负载分担时,优先使用高优先级的链路处理流量。如果最高优先级链路的个数少于配置的参与调度的最少个数,则在次高优先级中选择链路,达到配置的最少个数。
# 配置链路lk1的调用优先级为3。
[Sysname] loadbalance link lk1
[Sysname-lb-link-lk1] priority 3
·            selected-link
1.1.181  priority (real server view)
priority命令用来配置实服务器的调用优先级。
priority priority
undo priority
实服务器的调用优先级为4。
实服务器视图
context-admin
priority:实服务器调用优先级,取值范围为1~8。数值越大,越被优先调用。
通常使用负载分担时,优先使用高优先级的实服务器处理流量。如果最高优先级实服务器的个数少于配置的参与调度的最少个数,则在次高优先级中选择实服务器,达到配置的最少个数。
# 配置实服务器rs的调用优先级为3。
[Sysname] real-server rs
[Sysname-rserver-rs] priority 3
·            selected-server
1.1.182  probe (DNS server pool view)
probe命令用来指定DNS服务器池的健康检测方法。
undo probe命令用来恢复缺省情况。
probe template-name
undo probe template-name
未指定DNS服务器池的健康检测方法。
DNS服务器池视图
context-admin
template-name:健康检测方法所使用的NQA模板名称,为1~32个字符的字符串,不区分大小写。
使用nqa template命令创建健康检测方法所使用的NQA模板,通过健康检测可以对DNS服务器进行检测,保证其能够提供有效的服务。
用户既可在DNS服务器池视图下对池内的所有DNS服务器进行配置,也可在DNS服务器视图下只对当前DNS服务器进行配置,后者的配置优先级较高。
# 创建ICMP类型的NQA模板t4,并将其指定为DNS服务器池dns-pool的健康检测方法。
<Sysname>system-view
[Sysname-lb-dspool-dns-pool] probe t4
·            nqa template(网络管理和监控命令参考/NQA)
·            success-criteria (dns-server-pool view)
1.1.183  probe (DNS server view)
probe命令用来指定DNS服务器的健康检测方法。
probe template-name
未指定DNS服务器的健康检测方法。
DNS服务器视图
context-admin
请使用nqa template命令创建健康检测方法所使用的NQA模板。
# 创建ICMP类型的NQA模板t4,并将其指定为DNS服务器ds1的健康检测方法。
[Sysname-lb-ds-ds1] probe t4
·            success-criteria (DNS server view)
1.1.184  probe (link group view)
probe命令用来指定链路组的健康检测方法。
probe template-name
未指定链路组的健康检测方法。
链路组视图
context-admin
链路组采用所引用的NQA模板中定义的链路检测参数来对当前调用的链路进行检测,保证及时发现链路的可用性。
用户既可在链路组视图下对组内的所有链路进行配置,也可在链路图下只对当前链路进行配置,后者的配置优先级较高。
# 创建ICMP类型的NQA模板t4,并将其指定为链路组lg的健康检测方法。
[Sysname-lb-lgroup-lg] probe t4
·            success-criteria(link group view)
1.1.185  probe (link view)
probe命令用来指定链路的健康检测方法。
probe template-name
未指定链路的健康检测方法。
链路视图
context-admin
通过配置健康检测方法可以对链路进行检测,保证其能够提供有效的链路,健康检测方法所使用的NQA模板由nqa template命令配置。
同一个链路视图下,可以配置多个链路健康检测方法。系统缺省情况下,只有全部方法通过检测才认为健康检测成功,可通过success-criteria命令配置链路健康检测的成功条件。
# 创建ICMP类型的NQA模板t4,并将其指定为链路lk1的健康检测方法。
[Sysname-lb-link-lk1] probe t4
·            success-criteria((link view)
1.1.186  probe (real server view)
probe命令用来指定实服务器的健康检测方法。
probe template-name
未指定实服务器的健康检测方法。
实服务器视图
context-admin
请使用nqa template命令创建健康检测方法所使用的NQA模板,通过健康检测可以对实服务器进行检测,保证其能够提供有效的服务。
用户既可在实服务组视图下对组内的所有实服务器进行配置,也可在实服务器视图下只对当前实服务器进行配置,后者的配置优先级较高。
# 创建ICMP类型的NQA模板t4,并将其指定为实服务器rs的健康检测方法。
[Sysname-rserver-rs] probe t4
·            success-criteria (real server view)
1.1.187  probe (server farm view)
probe命令用来指定实服务组的健康检测方法。
undo probe命令用来删除指定实服务组的健康检测方法。
probe template-name
未指定实服务组的健康检测方法。
实服务组视图
context-admin
# 创建ICMP类型的NQA模板t4,并将其指定为实服务组sf的健康检测方法。
[Sysname-sfarm-sf] probe t4
·            success-criteria (server farm view)
1.1.188  proximity enable (link group view)
proximity enable命令用来在链路组中开启就近性功能。
undo proximity enable命令用来在链路组中关闭就近性功能。
proximity enable
链路组中的就近性功能处于关闭状态。
链路组视图
context-admin
在链路组中开启就近性功能后,负载均衡设备首先按照就近性选择组内的链路,就近性选择失败后再按照调度算法选择链路。
# 在链路组lg中开启就近性功能。
[Sysname-lb-lgroup-lg] proximity enable
1.1.189  proximity enable (server farm view)
proximity enable命令用来在实服务组中开启就近性功能。
undo proximity enable命令用来在实服务组中关闭就近性功能。
proximity enable
实服务器组中的就近性功能处于关闭状态。
实服务组视图
context-admin
在实服务器组中开启就近性功能后,负载均衡设备首先按照就近性选择组内的实服务器,就近性选择失败后再按照调度算法选择实服务器。
# 在实服务组sf中开启就近性功能。
[Sysname-sfarm-sf] proximity enable
1.1.190  radius-attribute
radius-attribute命令用来配置RADIUS属性持续性方法。
undo radius-attribute命令用来删除RADIUS属性持续性方法。
radius-attribute { code attribute-code | framed-ip-address | user-name }
不存在RADIUS属性持续性方法。
RADIUS类型的持续性组视图
context-admin
framed-ip-address:指定RADIUS属性类型为Framed-IP-Address(编号为8)。
RADIUS属性的持续性方法仅对RADIUS报文有效。
# 在持续性组s1中,配置RADIUS属性类型为User-Name的持续性方法。
[Sysname] sticky-group s1 type radius
[Sysname-sticky-radius-attribute-s1] radius-attribute user-name
1.1.191  rate-limit bandwidth (link view)
rate-limit bandwidth命令用来配置链路所允许的最大带宽。
undo rate-limit bandwidth命令用来恢复缺省情况。
rate-limit bandwidth [ inbound | outbound ] bandwidth-value
undo rate-limit bandwidth [ inbound | outbound ]
链路所允许的最大带宽不受限制。
链路视图
context-admin
inbound:配置最大入带宽。
outbound:配置最大出带宽。
如果未指定inbound和outbound参数,则配置最大总带宽,总带宽等于入带宽与出带宽之和。
本命令不仅在新建会话时生效,对已经存在的会话也生效。
# 配置链路lk1所允许的最大总带宽为1千字节/秒。
[Sysname-lb-link-lk1] rate-limit bandwidth 1
# 配置链路lk1所允许的最大入带宽为1千字节/秒。
[Sysname-lb-link-lk1] rate-limit bandwidth inbound 1
# 配置链路lk1所允许的最大出带宽为1千字节/秒。
[Sysname-lb-link-lk1] rate-limit bandwidth outbound 1
1.1.192  rate-limit bandwidth (real server view)
rate-limit bandwidth命令用来配置实服务器所允许的最大带宽。
实服务器所允许的最大带宽不受限制。
实服务器视图
context-admin
inbound:配置最大入带宽。
outbound:配置最大出带宽。
# 配置实服务器rs所允许的最大总带宽为1千字节/秒。
[Sysname-rserver-rs] rate-limit bandwidth 1
# 配置实服务器rs所允许的最大入带宽为1千字节/秒。
[Sysname-rserver-rs] rate-limit bandwidth inbound 1
# 配置实服务器rs所允许的最大出带宽为1千字节/秒。
[Sysname-rserver-rs] rate-limit bandwidth outbound 1
1.1.193  rate-limit bandwidth (virtual server view)
rate-limit bandwidth命令用来配置虚服务器所允许的最大带宽。
虚服务器所允许的最大带宽不受限制。
虚服务器视图
context-admin
inbound:最大入带宽。
outbound:最大出带宽。
# 配置IP类型的虚服务器vs3所允许的最大总带宽为1千字节/秒。
[Sysname-vs-ip-vs3] rate-limit bandwidth 1
# 配置IP类型的虚服务器vs3所允许的最大入带宽为1千字节/秒。
[Sysname-vs-ip-vs3] rate-limit bandwidth inbound 1
# 配置IP类型的虚服务器vs3所允许的最大出带宽为1千字节/秒。
[Sysname-vs-ip-vs3] rate-limit bandwidth outbound 1
1.1.194  rate-limit connection (link view)
rate-limit connection命令用来配置链路所允许的每秒最大连接数。
undo rate-limit connection命令用来恢复缺省情况。
rate-limit connection connection-number
链路所允许的每秒最大连接数为0。
链路视图
context-admin
connection-number:每秒最大连接数,取值范围为0~4294967295,0表示链路所允许的每秒最大连接数不受限制。
# 配置链路lk1所允许的每秒最大连接数为10000。
[Sysname-lb-link-lk1] rate-limit connection 10000
1.1.195  rate-limit connection (real server view)
rate-limit connection命令用来配置实服务器所允许的每秒最大连接数。
实服务器所允许的每秒最大连接数为0。
实服务器视图
context-admin
connection-number:每秒最大连接数,取值范围为0~4294967295,0表示实服务器所允许的每秒最大连接数不受限制。
# 配置实服务器rs所允许的每秒最大连接数为10000。
[Sysname-rserver-rs] rate-limit connection 10000
1.1.196  rate-limit connection (virtual server view)
rate-limit connection命令用来配置虚服务器所允许的每秒最大连接数。
虚服务器所允许的每秒最大连接数为0。
虚服务器视图
context-admin
connection-number:每秒最大连接数,取值范围为0~4294967295,0表示虚服务器所允许的每秒最大连接数不受限制。
# 配置IP类型的虚服务器vs3所允许的每秒最大连接数为10000。
[Sysname] virtual-server vs3 type ip
[Sysname-vs-ip-vs3] rate-limit connection 10000
1.1.197  real-server
real-server命令用来创建实服务器,并进入实服务器视图。如果指定的实服务器已经存在,则直接进入实服务器视图。
undo real-server命令用来删除指定的实服务器。
real-server real-server-name
undo real-server real-server-name
不存在任何实服务器。
context-admin
real-server-name:实服务器的名称,为1~63个字符的字符串,不区分大小写。
当设备支持服务器负载均衡License功能但尚未安装License时,不允许配置本命令;当设备不支持服务器负载均衡License功能,或支持服务器负载均衡License功能且安装有License时,才允许配置。
# 创建实服务器rs,并进入实服务器视图。
1.1.198  rebalance per-request
rebalance per-request命令用来配置对每个HTTP请求报文都进行负载均衡。
undo rebalance per-request命令用来恢复缺省情况。
只对一条连接的第一个HTTP请求报文进行负载均衡,其余请求报文的处理方式与第一个相同。
HTTP参数模板视图
context-admin
本命令只在HTTP类型的参数模板视图下支持。
# 在HTTP类型的参数模板pp1中,配置对每个HTTP请求报文都进行负载均衡。
[Sysname] parameter-profile pp1 type http
[Sysname-para-http-pp1] rebalance per-request
1.1.199  record
record命令用来配置指定类型的资源记录。
undo record命令用来删除指定的资源记录。
record { cname alias alias-name canonical canonical-name | mx [ host hostname ] exchanger exchanger-name preference preference | ns [ sub subname ] authority ns-name | srv [ service service-name ] host-offering-service hostname priority priority weight weight port  port-number | txt [ sub subname ] describe-txt description } [ ttl ttl-value ]
undo record { cname alias alias-name canonical canonical-name | mx [ host hostname ] exchanger exchanger-name | ns [ sub subname ] authority ns-name | srv [ service hostname ] host-offering-service hostname port port-number | txt [ sub subname ] describe-txt description }
不存在任何资源记录。
正向区域视图
context-admin
cname:CNAME(Canonical Name,规范名称)类型的资源记录。
alias alias-name:别名,不区分大小写,由“.”分隔的字符串组成。每个字符串的长度不超过63个字符,包括“.”在内的总长度不超过254个字符,可以包含字母、数字、“-”、“_”或“.”。
canonical canonical-name:正规主机名,不区分大小写,由“.”分隔的字符串组成。每个字符串的长度不超过63个字符,包括“.”在内的总长度不超过254个字符,可以包含字母、数字、“-”、“_”或“.”。
mx:MX(Mail Exchanger,邮件交换)类型的资源记录。
host hostname:MX资源记录主机名,不区分大小写,由“.”分隔的字符串组成。每个字符串的长度不超过63个字符,包括“.”在内的总长度不超过254个字符,可以包含字母、数字、“-”、“_”或“.”。
exchanger exchanger-name:邮件服务器的主机名,不区分大小写,由“.”分隔的字符串组成。每个字符串的长度不超过63个字符,包括“.”在内的总长度不超过254个字符,可以包含字母、数字、“-”、“_”或“.”。
preference preference:MX资源记录的优先级,取值范围为0~65535。该值越小,优先级越高。
ns:NS(Name Server,权威名称服务器)类型的资源记录。
sub subname:该区域的子域名,不区分大小写,由“.”分隔的字符串组成。每个字符串的长度不超过63个字符,如果该域名为绝对域名,则包括“.”在内的总长度不超过254个字符。如果该域名为非绝对域名,则总长度不超过253个字符。域名可以包含字母、数字、“-”、“_”或“.”。
authority ns-name:权威名称服务器的主机名,不区分大小写,由“.”分隔的字符串组成。每个字符串的长度不超过63个字符,包括“.”在内的总长度不超过254个字符,可以包含字母、数字、“-”、“_”或“.”。
srv:SRV(Service,服务)类型的资源记录。
service service-name:服务名称,不区分大小写,由“.”分隔的字符串组成。每个字符串的长度不超过63个字符,如果该服务名称为绝对域名,则包括“.”在内的总长度不超过254个字符。如果该域名为非绝对域名,则总长度不超过253个字符。域名可以包含字母、数字、“-”、“_”或“.”。为了与主机域名区分,应用名称和协议以下划线开始,例如:_ftp._tcp.movie.edu。若未指定本参数,则服务名称为DNS正向区域的域名。
host-offering-service host-name:提供此服务的主机名,不区分大小写,由“.”分隔的字符串组成。每个字符串的长度不超过63个字符,如果该服务名称为绝对域名,则包括“.”在内的总长度不超过254个字符。如果该域名为非绝对域名,则总长度不超过253个字符。域名可以包含字母、数字、“-”、“_”或“.”。
priority priority:优先级,取值范围为0~100,数值越小越优先。
weight weight-value:权值,取值范围为0~100。
port port-number:服务端口号,取值范围0~65535。
txt:TXT(Text,文本)类型的资源记录。
describe-txt description:文本描述,为1~255个字符的字符串,不区分大小写。
ttl ttl-value:资源记录的缓存时间,取值范围为0~4294967295,单位为秒,缺省值为3600。
资源记录指定的主机名可以是相对域名(不以“.”结束),也可以是绝对域名(以“.”结束)。当主机名为绝对域名时,不会自动扩充主机名,其长度不能大于254个字符;当主机名为相对域名时,会进行自动扩充,在用户配置的主机名后自动添加当前区域名。主机名加区域名长度总和不能大于254个字符。
若相同的服务有多条SRV记录,设备会先尝试连接优先级最低的记录。若存在多条SRV记录并且优先级也相同,那么用户会先尝试连接权重高的记录。
若在本命令中指定了资源记录的缓存时间则优先使用该缓存时间,否则使用DNS正向区域视图下配置的缓存时间。
在同一DNS正向区域内,可以配置多条资源记录。
# 在DNS正向区域abc.com中,配置MX类型资源记录:指定邮件服务器的主机名mail.abc.com,MX资源记录的优先级为10。
[Sysname-lb-zone-abc.com] record mx exchanger mail.abc.com preference 10
# 在DNS正向区域abc.com中,配置CNAME类型资源记录:指定正规主机名aaa.abc.com的别名为test.abc.com。
[Sysname-lb-zone-abc.com] record cname alias test.abc.com canonical aaa.abc.com
# 在DNS正向区域abc.com中,配置NS类型资源记录:指定权威名称服务器的主机名为ns1.abc.com。
[Sysname-lb-zone-abc.com] record ns authority ns1.abc.com
# 在DNS正向区域abc.com中,配置TXT类型资源记录。
[Sysname-lb-zone-abc.com] record txt sub hotline describe-txt
v=spf1 include:spf.abcmail.abc.com.cn -all
# 在DNS正向区域abc.com中,配置SRV类型资源记录。
[Sysname-lb-zone-abc.com] record srv service _http._tcp.example.com. host-offering-service www.example.com priority 5 weight 10 port 80
1.1.200  record ptr
record ptr命令用来配置PTR资源记录。
undo record ptr命令用来删除指定的PTR资源记录。
record ptr { ip ipv4-address | ipv6 ipv6-address } domain-name [ ttl ttl-value ]
undo record ptr { ip ipv4-address | ipv6 ipv6-address } domain-name
不存在PTR资源记录。
DNS反向区域视图
context-admin
ip ipv4-address:IPv4地址。
ipv6 ipv6-address:IPv6地址。
domain-name:域名,不区分大小写。由“.”分隔的字符串组成,每个字符串的长度不超过63个字符,包括“.”在内的总长度不超过253个字符。字符串中可以包含字母、数字、“-”、“_”或“.”。
ttl ttl-value:资源记录的缓存时间。其中,ttl-value的取值范围为0~4294967295,缺省值为3600,单位为秒。
用户可根据需求,对需要进行反向解析的IP地址配置PTR资源记录。
PTR资源记录中指定的IP地址应在其所属DNS反向区域的IP地址范围内。
同一DNS反向区域下,可配置多条PTR类型资源记录。
# 在DNS反向区域10.1.1.0/24中,配置PTR类型的资源记录。
[Sysname] loadbalance reverse-zone ip 10.1.1.0 24
[Sysname-lb-rzone-10.1.1.0/24] record ptr ip 10.1.1.1 mail.h3c.com
1.1.201  redirect relocation (action view)
redirect relocation命令用来开启动作的重定向功能并指定重定向URL。
undo redirect relocation命令用来关闭动作的重定向功能。
redirect relocation relocation
动作的重定向功能处于关闭状态。
HTTP类型的负载均衡动作视图
context-admin
relocation:重定向URL,为1~255个字符的字符串,区分大小写,也可以使用?和以下特定含义的字符串(各自只允许使用一次):
·            %h:表示客户端请求报文中的主机名。
·            %p:表示客户端请求报文中的URL。
本命令与server-farm命令互斥,当配置了其中一条后,另一条的配置将被自动取消。
在HTTP类型的负载均衡动作视图下开启了重定向功能后,所有匹配对应负载均衡类的HTTP请求报文都将被重定向到该URL。
# 在HTTP类型的负载均衡动作视图下开启重定向功能,并将请求重定向为HTTPS。
[Sysname] loadbalance action lba1 type http
[Sysname-lba-http-lba1] redirect relocation https://%h%p
1.1.202  redirect relocation (virtual server view)
redirect relocation命令用来开启虚服务器的重定向功能并指定重定向URL。
undo redirect relocation命令用来关闭虚服务器的重定向功能。
虚服务器的重定向功能处于关闭状态。
虚服务器视图
context-admin
relocation:指定重定向URL,开启了虚服务器的重定向功能后,所有匹配该虚服务器的请求报文都将被重定向到该URL。为1~255个字符的字符串,区分大小写。也可以使用?和以下特定含义的字符串(各自只允许使用一次):
·            %h:使用客户端请求报文中的主机名。
·            %p:使用客户端请求报文中的URL。
本命令只在HTTP类型的虚服务器视图下支持。
# 开启HTTP类型的虚服务器vs2的重定向功能,并将请求重定向为HTTPS。
[Sysname] virtual-server vs2 type http
[Sysname-vs-http-vs2] redirect relocation https://%h%p
1.1.203  redirect return-code (action view)
redirect return-code命令用来配置负载均衡设备返回给客户端的重定向报文中的状态码。
undo redirect return-code命令用来恢复缺省情况。
redirect return-code { 301 | 302 }
负载均衡设备返回给客户端的重定向报文中的状态码为302。
HTTP类型的负载均衡动作视图
context-admin
301:表示永久删除被请求的资源。
302:表示临时删除被请求的资源。
只有HTTP类型的负载均衡动作视图开启了重定向功能后,本命令才生效。
# 在HTTP类型的动作lba1上,配置负载均衡设备返回给客户端的重定向报文中的状态码为301。
[Sysname-lba-http-lba1] redirect return-code 301
·            redirect relocation
1.1.204  redirect return-code (virtual server view)
虚服务器视图
context-admin
301:状态码为301,表示永久删除被请求的资源。
302:状态码为302,表示临时删除被请求的资源。
本命令只有在开启了虚服务器的重定向功能后才会生效。
# 在HTTP类型的虚服务器vs2上,配置负载均衡设备返回给客户端的重定向报文中的状态码为301。
[Sysname-vs-http-vs2] redirect return-code 301
1.1.205  refresh
refresh命令用来配置刷新间隔。
undo refresh命令用来恢复缺省情况。
refresh refresh-interval
undo refresh
刷新间隔为3600秒。
SOA视图
context-admin
refresh-interval:刷新间隔,取值范围为300~2419200,单位为秒。
辅助域名服务器以刷新间隔为周期,从主域名服务器上获取SOA资源记录,然后和本地辅助域名服务器上的SOA资源记录相比较。
# 对DNS正向区域abc.com,指定刷新间隔为4小时。
[Sysname-lb-zone-abc.com-soa] refresh 14400
1.1.206  request-version all
request-version all命令用来配置对HTTP1.0的请求报文的应答进行压缩处理。
undo request-version all命令用来恢复缺省情况。
request-version all
不对HTTP1.0的报文进行压缩。
HTTP压缩参数模板视图
context-admin
# 创建HTTP压缩类型的参数模板http1,并使其对HTTP1.0的请求的应答进行压缩。
[Sysname-para-http-compression-http1] request-version all
1.1.207  reset loadbalance connections
reset loadbalance connections命令用来清除负载均衡的应用层连接。
context-admin
此命令会将当前所有负载均衡的应用层连接清除,包括连接复用中的空闲连接。
# 清除负载均衡应用层链接。
<Sysname> reset loadbalance connection
1.1.208  reset loadbalance dns-cache
reset loadbalance dns-cache命令用来清除DNS缓存信息。
reset loadbalance dns-cache [ domain-name domain-name ]
context-admin
domain-name domain-name:清除指定域名的DNS缓存信息,domain-name为1~253个字符的字符串,不区分大小写。如果未指定本参数,将清除所有域名的DNS缓存信息。
# 清除所有DNS缓存信息。
<Sysname> reset loadbalance dns-cache
1.1.209  reset loadbalance dns-listener statistics
reset loadbalance dns-listener statistics命令用来清除DNS监听器的统计信息。
reset loadbalance dns-listener statistics [ dns-listener-name ]
context-admin
dns-listener-name:DNS监听器名称,为1~63个字符的字符串,不区分大小写。如果未指定此参数,则清除所有DNS监听器的统计信息。
# 清除DNS监听器dl2的统计信息。
<Sysname> reset loadbalance dns-listener statistics dl2
# 清空所有DNS监听器的统计信息。
·            display loadbalance dns-listener statistics
1.1.210  reset loadbalance dns-map statistics
reset loadbalance dns-map statistics命令用来清除DNS映射的统计信息。
reset loadbalance dns-map statistics [ dns-map-name ]
context-admin
dns-map-name:DNS映射名称,为1~63个字符的字符串,不区分大小写。如果未指定此参数,则清除所有DNS映射的统计信息。
# 清除DNS映射dm2的统计信息。
<Sysname> reset loadbalance dns-map statistics dm2
# 清除所有DNS映射的统计信息。
·            display loadbalance dns-map statistics
1.1.211  reset loadbalance dns-proxy statistics
reset loadbalance dns-proxy statistics命令用来清除DNS透明代理的统计信息。
reset loadbalance dns-proxy statistics [ dns-proxy-name ]
context-admin
dns-proxy-name:DNS透明代理名称,为1~63个字符的字符串,不区分大小写。如果未指定此参数,则清除所有DNS透明代理的统计信息。
# 清除DNS透明代理dns-proxy1的统计信息
<Sysname> reset loadbalance dns-proxy statistics dns-proxy1
·            display loadbalance dns-proxy statistics
1.1.212  reset loadbalance dns-server statistics
reset loadbalance dns-server statistics命令用来清除DNS服务器的统计信息。
reset loadbalance dns-server statistics [ dns-server-name ]
context-admin
dns-server-name:清除指定DNS服务器的统计信息。其中,dns-server-name表示DNS服务器名字,为1~63个字符的字符串,不区分大小写。若未指定本参数,则清除所有DNS服务器的统计信息。
# 清除DNS服务器ds1的统计信息。
<Sysname> reset loadbalance dns-server statistics ds1
·            display loadbalance dns-server statistics
1.1.213  reset loadbalance hot-backup statistics
reset loadbalance hot-backup statistics命令用来清除负载均衡热备份的统计信息。
context-admin
# 清除负载均衡热备份的统计信息。
<Sysname> reset loadbalance hot-backup statistics
1.1.214  reset loadbalance link statistics
reset loadbalance link statistics命令用来清除链路的统计信息。
reset loadbalance link statistics [ link-name ]
context-admin
link-name:链路的名称,为1~63个字符的字符串,不区分大小写。如果未指定本参数,将清除所有链路的统计信息。
# 清除所有链路的统计信息
<Sysname> reset loadbalance link statistics
1.1.215  reset loadbalance local-dns-server parse-fail-record
reset loadbalance local-dns-server parse-fail-record命令用来清除当前记录的解析失败的DNS请求报文的信息。
context-admin
# 清除当前记录的解析失败的DNS请求报文的信息。
<Sysname> reset loadbalance local-dns-server parse-fail-record
1.1.216  reset loadbalance proximity
reset loadbalance proximity命令用来清除就近性表项的信息。
reset loadbalance proximity [ vpn-instance vpn-instance-name ] [ ip [ ipv4-address ] | ipv6 [ ipv6-address ] ]
context-admin
vpn-instance vpn-instance-name:指定VPN实例。vpn-instance-name为VPN实例名称,为1~31个字符的字符串,区分大小写。如果未指定本参数,则清除公网实例中的信息。
ip [ ipv4-address ]:清除IPv4就近性表项的信息。如果指定了ipv4-address参数,将清除指定IPv4地址所对应就近性表项的信息;如果未指定ipv4-address参数,将清除所有IPv4就近性表项的信息。
ipv6 [ ipv6-address ]:清除IPv6就近性表项的信息。如果指定了ipv6-address参数,将清除指定IPv6地址所对应就近性表项的信息;如果未指定ipv6-address参数,将清除所有IPv6就近性表项的信息。
如果未指定vpn-instance、ip和ipv6关键字,将清除公网实例中所有IPv4和IPv6就近性表项的信息。
# 清除VPN名称为vrf1下IP地址为1.1.1.1的就近性表项。
<Sysname> reset loadbalance proximity vpn vrf1 ip 1.1.1.1
# 清除公网实例中所有IPv6就近性表项。
<Sysname> reset loadbalance proximity ipv6
1.1.217  reset real-server statistics
reset real-server statistics命令用来清除实服务器的统计信息。
reset real-server statistics [ real-server-name ]
context-admin
real-server-name:清除指定实服务器的统计信息。real-server-name为实服务器的名称,为1~63个字符的字符串,不区分大小写。如果未指定本参数,将清除所有实服务器的统计信息。
# 清除所有实服务器的统计信息。
<Sysname> reset real-server statistics
·            display real-server statistics
1.1.218  reset virtual-server statistics
reset virtual-server statistics命令用来清除虚服务器的统计信息。
reset virtual-server statistics [ virtual-server-name ]
context-admin
virtual-server-name:清除指定虚服务器的统计信息。virtual-server-name为虚服务器的名称,为1~63个字符的字符串,不区分大小写。如果未指定本参数,将清除所有虚服务器的统计信息。
# 清除所有虚服务器的统计信息。
<Sysname> reset virtual-server statistics
·            display virtual-server statistics
1.1.219  responsible-mail
responsible-mail命令用来配置管理员的邮箱地址。
undo responsible-mail命令用来恢复缺省情况。
responsible-mail mail-address
未配置管理员的邮箱地址。
SOA视图
context-admin
mail-address:管理员的邮箱地址,不区分大小写。由“.”分隔的字符串组成,每个字符串的长度不超过63个字符,包括“.”在内的总长度不超过254个字符。字符串中可以包含字母、数字、“-”、“_”和“.”。
管理员邮箱地址可以是相对域名(不以“.”结束),也可以是绝对域名(以“.”结束)。当管理员邮箱地址为绝对域名时,不会自动扩充主机名,其长度不能大于254个字符;当管理员邮箱地址为相对域名时,会进行自动扩充,在用户配置的管理员邮箱地址后自动添加当前区域名。管理员邮箱地址加区域名长度总和不能大于254个字符。
# 对DNS正向区域abc.com,配置管理员的邮箱地址为root.ns1.abc.com。
[Sysname-lb-zone-abc.com-soa] responsible-mail root.ns1.abc.com
1.1.220  retry
retry命令用来指定重试时间。
undo retry命令用来恢复缺省情况。
retry retry-interval
undo retry
重试时间为600秒。
SOA视图
context-admin
retry-interval:重试时间,取值范围为500~1209600,单位为秒。
重试时间为辅助域名服务器进行区域复制失败后的等待时间。
# 对DNS正向区域abc.com,指定重试时间为30分钟。
[Sysname-lb-zone-abc.com-soa] retry 1800
1.1.221  route-advertisement enable
route-advertisement enable命令用来开启虚服务器IP地址下发功能。
undo route-advertisement enable命令用来关闭虚服务器IP地址下发功能。
虚服务器IP地址下发功能处于关闭状态。
虚服务器视图
context-admin
开启虚服务器IP地址下发功能后,设备会将虚服务器的IP地址发布给OSPF模块参与路由计算,
当数据中心进行切换的时候,保证访问虚服务器的流量也可以自动切换,从而提高负载均衡服务的可靠性。有关OSPF的配置请参见“三层技术-IP路由”中的“OSPF”。
# 开启虚服务器IP地址下发功能。
[Sysname] virtual-server vs type ip
[Sysname-vs-ip-vs] route-advertisement enable
1.1.222  router ip
router ip命令用来指定链路通往外网方向的下一跳IPv4地址。
undo router ip命令用来恢复缺省情况。
router ip ipv4-address
undo router ip
未配置链路通往外网方向的下一跳IPv4地址。
链路视图
context-admin
ipv4-address:IPv4地址,不能为环回地址、组播地址、广播地址和0.X.X.X。
一条链路只能配置一个通往外网方向的下一跳IPv4地址。
# 指定链路lk1通往外网方向的下一跳IPv4地址为1.2.3.4。
[Sysname-lb-link-lk1] router ip 1.2.3.4
1.1.223  router ipv6
router ipv6命令用来指定链路通往外网方向的下一跳IPv6地址。
undo router ipv6命令用来恢复缺省情况。
router ipv6 ipv6-address
undo router ipv6
未配置链路通往外网方向的下一跳IPv6地址。
链路视图
context-admin
ipv6-address:IPv6地址信息,不能配置全零地址,多播地址,环回地址,链路本地地址。
一条链路只能配置一个下一跳IPv6地址。
# 指定链路lk1通往外网方向的下一跳IPv6地址为8008::8。
[Sysname-lb-link-lk1] router ipv6 8008::8
1.1.224  rtt weight
rtt weight命令用来配置就近性计算的网络延迟权值。
undo rtt weight命令用来恢复缺省情况。
rtt weigt rtt-weight
undo rtt weight
就近性计算的网络延迟权值为100。
就近性视图
context-admin
rtt-weight:就近性计算的网络延迟权值,取值范围为0~255,数值越大权重越大。
# 配置就近性计算的网络延迟权值为200。
[Sysname-lb-proximity] rtt weight 200
1.1.225  rule
rule命令用来配置进行压缩的过滤条件。
undo rule命令用来恢复缺省情况。
rule [ rule-id ] { deny | permit } { content-type | url } expression
undo rule rule-id
未配置任何过滤条件。
HTTP压缩参数模板视图
context-admin
rule-id:规则的编号,取值范围为1~65535。如果指定编号的规则不存在,则创建一条新的规则;如果指定编号的规则已存在,则对其进行修改。如果未指定本参数,系统将自动分配一个可用的最小编号。
deny:对符合匹配规则的报文不进行压缩。
permit:符合匹配规则的报文进行压缩。
content-type:匹配范围限于content-type首部中携带的报文体类型。
url:匹配范围限于报文携带的URL。
expression:正则表达式,为1~255的字符串,不支持正则元字符?,表示匹配的内容,区分大小写。
# 创建HTTP压缩类型的参数模板http1,并配置对url中包含image的应答报文不进行压缩。
[Sysname-para-http-compression-http1] rule deny url image
1.1.226  secondary-cookie delimiters
secondary-cookie delimiters命令用来配置URL中分隔Secondary Cookie的字符。
undo secondary-cookie delimiters命令用来恢复缺省情况。
secondary-cookie delimiters text
URL中分隔Secondary Cookie的字符为“/”、“&”、“#”或“+”。
参数模板视图
context-admin
text:分隔字符,为1~4个字符的字符串,包括:!、"、#、;、<、>、?、[、\、]、^、`、|、:、@、&、$、+、*、'、(、)、,、/。该字符串中的每个字符都被认为是分隔字符。
# 在HTTP类型的参数模板pp1中,配置URL中分隔Secondary Cookie的字符为“/”、“@”、“#”或“$”。
[Sysname-para-http-pp1] secondary-cookie delimiters !@#$
1.1.227  secondary-cookie start
secondary-cookie start命令用来配置URL中Secondary Cookie的起始位置标示字符。
undo secondary-cookie start命令用来恢复缺省情况。
secondary-cookie start text
URL中Secondary Cookie的起始位置标示字符为“?”。
参数模板视图
context-admin
text:标示字符,为1~2个字符的字符串,包括:!、"、#、;、<、>、?、[、\、]、^、`、|。
# 在HTTP类型的参数模板pp1中,配置URL中Secondary Cookie的起始位置标示字符为“?”或“!”。
[Sysname-para-http-pp1] secondary-cookie start ?!
1.1.228  selected-link
selected-link命令用来配置链路组中可被调度算法调用的链路数量限制。
undo selected-link命令用来恢复缺省情况。
selected-link min min-number max max-number
undo selected-link
链路组中调用优先级最高的链路全部被调度算法调用。
链路组视图
context-admin
min min-number:可被调度算法调用的链路最小数量,取值范围为1~1000。
max max-number:可被调度算法调用的链路最大数量,取值范围1~1000,且必须大于等于min-number。
缺省情况下,一个链路组中调用优先级最高的链路全部可被调度算法调用。通过本命令可以限制可被调度算法调用的链路数量:
·            如果当前调用优先级最高的可用链路数量大于max-number,则只调用其中的max-number条链路。
·            如果当前调用优先级最高的可用链路数量小于min-number,除了调用全部优先级最高的可用链路外,还会调用优先级次高的可用链路,直至调用的可用链路数量达到min-number,或者没有可用的链路可调用为止。
# 配置链路组lg中可被调度算法调用的链路最小数量为20,最大数量为30。
[Sysname-lb-lgroup-lg] selected-link min 20 max 30
·            predictor(link group view)
·            priority(link view)
1.1.229  selected-server (DNS server pool view)
selected-server命令用来配置DNS服务器池中可被调度算法调用的DNS服务器数量限制。
undo selected-server命令用来恢复缺省情况。
selected-server min min-number max max-number
DNS服务器池中调用优先级最高的DNS服务器全部被调度算法调用。
DNS服务器池视图
context-admin
min min-number:可被调度算法调用的DNS服务器最小数量,取值范围为1~1000。
max max-number:可被调度算法调用的DNS服务器最大数量,取值范围1~1000,且必须大于等于min-number。
用户通过本命令可以限制可被调度算法调用的DNS服务器数量:
·            如果调用优先级最高的可用DNS服务器数量小于min-number时,除了调用全部优先级最高的可用DNS服务器外,还会调用优先级次高的可用DNS服务器,直至调用的可用DNS服务器数量达到min-number,或者没有可用的DNS服务器可调用为止。
·            如果调用某一优先级的可用DNS服务器后数量大于max-number时,则只选用max-number个DNS服务器。
# 配置DNS服务器池dns-pool中可被调度算法调用的DNS服务器最小数量为20,最大数量为30。
[Sysname] loadbalance dns-server-pool dns-pool
[Sysname-lb-dspool-dns-pool] selected-server min 20 max 30
1.1.230  selected-server (server farm view)
selected-server命令用来配置实服务组中可被调度算法调用的实服务器数量限制。
实服务组中调用优先级最高的实服务器全部被调度算法调用。
实服务组视图
context-admin
min min-number:可被调度算法调用的实服务器最小数量,取值范围为1~1000。
max max-number:可被调度算法调用的实服务器最大数量,取值范围1~1000,且必须大于等于min-number。
缺省情况下,一个实服务组中调用优先级最高的实服务器全部被调度算法调用。用户通过本命令可以限制可被调度算法调用的实服务器数量:
·            如果调用优先级最高的可用实服务器数量大于max-number时,则只选用max-number个实服务器。
·            如果调用优先级最高的可用实服务器数量小于min-number时,除了调用全部优先级最高的可用实服务器外,还会调用优先级次高的可用实服务器,直至调用的可用实服务器数量达到min-number,或者没有可用的实服务器可调用为止。
# 配置实服务组sf中可被调度算法调用的实服务器最小数量为20,最大数量为30。
[Sysname-sfarm-sf] selected-server min 20 max 30
·            predictor(server farm view)
·            priority(real server view)
1.1.231  serial
serial命令用来配置DNS正向区域的序列号。
undo serial命令用来恢复缺省情况。
serial number
undo serial
DNS正向区域的序列号为1。
SOA视图
context-admin
number:序列号,取值范围为1~4294967295。
序列号标识该区域配置的新旧,区域越新,序列号越大。
辅助域名服务器会周期性地查询主域名服务器上DNS正向区域的序列号,然后和本地的DNS正向区域序列号相比较。
# 对DNS正向区域abc.com,配置DNS正向区域的序列号为123。
[Sysname-lb-zone-abc.com-soa] serial 123
1.1.232  server-connection reuse
server-connection reuse命令用来配置允许负载均衡设备与服务器的连接复用。
undo server-connection reuse命令用来恢复缺省情况。
不允许负载均衡设备与服务器的连接复用。
参数模板视图
context-admin
允许负载均衡设备与服务器的连接复用,即允许负载均衡设备与服务器建立长连接,使多个客户端复用同一条与服务器的连接,以减少客户端与服务器之间打开的连接数。
快速HTTP类型的虚服务器不支持本功能。
# 在HTTP类型的参数模板pp1中,配置允许负载均衡设备与服务器的连接复用。
[Sysname-para-http-pp1] server-connection reuse
1.1.233  server-farm (action view)
server-farm命令用来指定指导转发的实服务组。
undo server-farm命令用来恢复缺省情况。
server-farm server-farm-name [ backup backup-server-farm-name ] [ sticky sticky-name ]
undo server-farm
未指定指导转发的实服务组。
负载均衡动作视图
context-admin
server-farm-name:主用实服务组的名称,为1~63个字符的字符串,不区分大小写。
backup backup-server-farm-name:备用实服务组的名称,为1~63个字符的字符串,不区分大小写。
sticky sticky-name:实服务组所对应持续性组的名称,为1~63个字符的字符串,不区分大小写。
本命令与forward all和redirect relocation命令互斥,当配置了其中一条后,另一条的配置将被自动取消。
当主用实服务组可用(该实服务组存在且有可用的实服务器)时,使用主用实服务组指导转发;当主用实服务组不可用而备用实服务组可用时,使用备用实服务组指导转发。
# 在通用类型的负载均衡动作lba1中,指定指导转发的主用实服务组为sf,备用实服务组为sfb,持续性组为sg1。
[Sysname] loadbalance action lba1 type generic
[Sysname-lba-generic-lba1] server-farm sf backup sfb sticky sg1
·            forward all
1.1.234  server-farm (real server view)
server-farm命令用来指定实服务器所属的实服务组。
undo server-farm
实服务器不属于任何实服务组。
实服务器视图
context-admin
server-farm-name:实服务组的名称,为1~63个字符的字符串,不区分大小写。
指定实服务组名称时,可以是尚未创建的实服务组。
# 指定实服务器rs属于实服务组sf。
[Sysname-rserver-rs] server-farm sf
1.1.235  server-farm (system view)
server-farm命令用来创建实服务组,并进入实服务组视图。如果指定的实服务组已经存在,则直接进入实服务组视图。
undo server-farm命令用来删除指定的实服务组。
undo server-farm server-farm-name
不存在任何实服务组。
context-admin
为了便于对多台服务器进行管理,可以依据这些服务器的共有属性划分成不同的组,称为实服务组。比如,可按存储内容的不同划分为歌曲服务器组、视频服务器组或图片服务器组等。
# 创建实服务组sf,并进入实服务组视图。
[Sysname-sfarm-sf]
1.1.236  service enable (DNS listener view)
service enable命令用来开启DNS监听功能。
undo service enable命令用来关闭DNS监听功能。
service enable
undo service enable
DNS监听功能处于关闭状态。
DNS监听器视图
context-admin
# 在名称为ct-listener的DNS监听器视图下,开启DNS监听功能。
[Sysname] loadbalance dns-listener ct-listener
[Sysname-lb-dl-ct-listener] service enable
1.1.237  service enable (DNS proxy view)
service enable命令用来开启DNS透明代理功能。
undo service enable命令用来关闭DNS透明代理功能。
service enable
undo service enable
DNS透明代理功能处于关闭状态。
DNS透明代理视图
context-admin
# 在名称为dns-proxy1的DNS透明代理视图下,开启DNS透明代理功能
[Sysname] loadbalance dns-proxy dns-proxy1
[Sysname-lb-dp-udp-dns-proxy1] service enable
1.1.238  service enable (DNS map view)
service enable命令用来开启DNS映射。
undo service enable命令关闭DNS映射。
service enable
undo service enable
DNS映射处于关闭状态。
DNS映射视图
context-admin
# 在名称为dm1的DNS映射视图下,开启DNS映射服务。
[Sysname] loadbalance dns-map dm1
[Sysname-lb-dm-dm1] service enable
1.1.239  service enable (virtual server view)
service enable命令用来开启虚服务器。
undo service enable命令用来关闭虚服务器。
service enable
undo service enable
虚服务器处于关闭状态。
虚服务器视图
context-admin
# 开启IP类型的虚服务器vs3。
[Sysname-vs-ip-vs3] service enable
1.1.240  set ip tos (action view)
set ip tos命令用来配置发往服务器的IP报文中的ToS字段。
undo set ip tos命令用来恢复缺省情况。
set ip tos tos-number
undo set ip tos
不改变发往服务器的IP报文中的ToS字段。
负载均衡动作视图
context-admin
tos-number:ToS字段值,取值范围为0~255。
# 在通用类型的负载均衡动作lba1中,配置发往服务器的IP报文中的ToS字段值为20。
[Sysname-lba-generic-lba1] set ip tos 20
1.1.241  set ip tos (parameter profile view)
set ip tos命令用来配置发往客户端的IP报文中的ToS字段。
undo set ip tos
不改变发往客户端的IP报文中的ToS字段。
参数模板视图
context-admin
tos-number:ToS字段值,取值范围0~255。
本命令只在IP类型的参数模板视图下支持。
# 在IP类型的参数模板pp2中,配置发往客户端的IP报文中的ToS字段值为20。
[Sysname-para-ip-pp2] set ip tos 20
1.1.242  shutdown (link view)
shutdown命令用来关闭当前链路。
undo shutdown命令用来开启当前链路。
shutdown
链路处于开启状态。
链路视图
context-admin
# 关闭链路lk1。
[Sysname-lb-link-lk1] shutdown
1.1.243  shutdown (real server view)
shutdown命令用来关闭实服务器。
undo shutdown命令用来开启实服务器。
shutdown
实服务器处于开启状态。
实服务器视图
context-admin
# 关闭实服务器rs。
[Sysname-rserver-rs] shutdown
1.1.244  skip current-dns-proxy
skip current-dns-proxy命令用来配置报文的转发模式为跳过当前DNS透明代理。
undo skip current-dns-proxy命令用来恢复缺省情况。
报文的转发模式为丢弃。
DNS类型的负载均衡动作视图
context-admin
配置报文的转发模式为跳过当前DNS透明代理,可使匹配了DNS透明代理的报文跳过当前DNS透明代理,并重新匹配DNS透明代理或虚服务器。
一个DNS请求最多只能跳过5个不同的DNS透明代理或虚服务器。
本命令与dns-server-pool和forward all命令互斥,当配置了其中一条后,另一条的配置将被自动取消。
# 在DNS类型的负载均衡动作lba1中,配置报文的转发模式为跳过当前DNS透明代理。
[Sysname] loadbalance action lba1 type dns
[Sysname-lba-dns-lba1] skip current-dns-proxy
1.1.245  slow-online (server farm view)
slow-online命令用来在实服务组中开启实服务器温暖上线功能。
undo slow-online命令用来在实服务组中关闭实服务器温暖上线功能。
slow-online [ standby-time standby-time ramp-up-time ramp-up-time ]
undo slow-online
实服务组中的实服务器温暖上线功能处于关闭状态。
实服务组视图
context-admin
standby-time standby-time:准备时间,取值范围为0~600,单位为秒,缺省为5秒。
ramp-up-time ramp-up-time:爬升时间,取值范围为3~600,单位为秒,缺省为5秒。
可以通过开启温暖上线功能,解决实服务组中新增实服务器无法立即承担大量业务的问题。当实服务组中新增一个可用实服务器后,在准备时间内,负载均衡设备不会向其分配任何业务;准备时间超时后,负载均衡设备在爬升时间内会逐步增加向其分配的业务量;爬升时间超时后,负载均衡设备开始向其正常分配业务。
# 在实服务组sf中开启实服务器温暖上线功能。
[Sysname-sfarm-sf] slow-online
1.1.246  slow-shutdown enable (real server view)
slow-shutdown enable命令用来开启实服务器的慢宕功能。
undo slow-shutdown enable命令用来关闭实服务器的慢宕功能。
实服务器的慢宕功能处于关闭状态。
实服务器视图
context-admin
通过shutdown命令可以立即中断实服务器的已有连接,而慢宕则不会立即中断实服务器的已有连接,而是让其自然老化,并且不再建立新的连接。
本命令需要与shutdown命令配合使用。必须开启了慢宕功能之后再关闭链路,该链路才会开始慢宕。如果先关闭链路,再开启慢宕功能,则慢宕功能不生效,链路处于关闭状态。
# 开启实服务器rs的慢宕功能。
[Sysname-rserver-rs] slow-shutdown enable
·            shutdown(real server view)
1.1.247  snat-pool (link group view)
snat-pool命令用来指定链路组引用的SNAT地址池。
undo snat-pool命令用来恢复缺省情况。
snat-pool pool-name
undo snat-pool
链路组没有引用任何SNAT地址池。
链路组视图
context-admin
SNAT地址池是一个地址范围,它被链路组引用之后,负载均衡设备将把收到报文的源地址修改为SNAT地址池中的地址后再转发出去。
# 配置链路组lg引用的SNAT地址池为lbsp。
[Sysname-lb-lgroup-lg] snat-pool lbsp
1.1.248  snat-pool (server farm view)
snat-pool命令用来指定实服务组引用的SNAT地址池。
snat-pool pool-name
undo snat-pool
实服务组未引用任何SNAT地址池。
实服务组视图
context-admin
SNAT地址池是一个地址范围,它被实服务组引用之后,负载均衡设备将把收到报文的源地址修改为SNAT地址池中的地址后再转发出去。
# 指定实服务组sf引用的SNAT地址池为lbsp。
[Sysname-sfarm-sf] snat-pool lbsp
1.1.249  snmp-agent trap enable loadbalance
snmp-agent trap enable loadbalance命令用来开启负载均衡的告警功能。
undo snmp-agent trap enable loadbalance命令用来关闭负载均衡的告警功能。
负载均衡的告警功能处于开启状态。
context-admin
开启了负载均衡的告警功能之后,负载均衡会生成告警信息,以向网管软件报告本模块的重要事件。该信息将发送至SNMP模块,通过设置SNMP中告警信息的发送参数,来决定告警信息输出的相关属性。有关告警信息的详细介绍,请参见“网络管理和监控配置指导”中的“SNMP”。
# 关闭负载均衡的告警功能。
[Sysname] undo snmp-agent trap enable loadbalance
1.1.250  soa
soa命令用来创建SOA类型的资源记录,并进入SOA视图。如果SOA类型的资源记录已经存在,则直接进入SOA视图。
undo soa命令用来删除SOA类型的资源记录与该记录下的所有配置。
soa
undo soa
不存在SOA类型的资源记录。
DNS正向区域视图
context-admin
# 对DNS正向区域abc.com,创建SOA类型的资源记录,并进入SOA视图。
1.1.251  ssl session-id
ssl session-id命令用来配置SSL持续性方法为基于SSL会话ID。
undo ssl session-id命令用来恢复缺省情况。
ssl session-id
undo ssl session-id
不存在任何持续性方法。
持续性组视图
context-admin
本命令只在SSL类型的持续性组视图下支持。
基于SSL会话ID的SSL持续性方法对HTTPS请求报文有效,并且需要指定虚服务器引用的SSL服务器端策略。
# 在SSL类型的持续性组sg6中,指定SSL的持续性方法为基于SSL会话ID。
[Sysname] sticky-group sg6 type ssl
[Sysname-sticky-ssl-sg6] ssl session-id
1.1.252  ssl url rewrite
ssl url rewrite命令用来重写服务器发送的HTTP应答报文Location首部的URL。
undo ssl url rewrite命令用来取消该配置。
ssl url rewrite location location [ clearport clear-port ] [ sslport ssl-port ]
undo ssl url rewrite location location [ clearport clear-port ]
不重写服务器发送的HTTP应答报文Location首部的URL。
负载均衡动作视图
context-admin
location location:Location首部URL的正则表达式,为1~255个字符的字符串。
clearport clear-port:原HTTP端口号,取值范围为1~65535,缺省值为80。
sslport ssl-port:重写后的SSL端口号,取值范围为1~65535,缺省值为443。
本命令只在HTTP类型的负载均衡动作视图下支持。
配置了本命令后,如果HTTP应答报文Location首部匹配了指定的location和clear-port,系统会将Location首部的URL由HTTP重写为HTTPS,并将clear-port重写为ssl-port。
# 在HTTP类型的负载均衡动作lba2中,将服务器发送的HTTP应答报文Location首部的URL,由http://www.ss.com:8080重写为https://www.ss.com:443。
[Sysname] loadbalance action lba2 type http
[Sysname-lba-http-lba2] ssl url rewrite location www.ss.com clearport 8080 sslport 443
1.1.253  ssl-client-policy (action view)
ssl-client-policy命令用来引用SSL客户端策略,以便对负载均衡设备(作为SSL客户端)与SSL服务器之间传输的流量进行加密传输。
undo ssl-client-policy命令用来恢复缺省情况。
ssl-client-policy policy-name
undo ssl-client-policy policy-name
未引用任何SSL客户端策略。
负载均衡动作视图
context-admin
policy-name:SSL客户端策略的名称,为1~31个字符的字符串,不区分大小写。
如需修改已被负载均衡动作引用的SSL客户端策略,在策略修改完成后,需在虚服务器视图下,先通过配置undo service enable命令关闭虚服务器,再通过配置service enable命令开启虚服务器,新的策略才能生效。
# 在HTTP类型的负载均衡动作lba2中,引用SSL客户端策略scp。
[Sysname-lba-http-lba2] ssl-client-policy scp
1.1.254  ssl-client-policy (virtual server view)
ssl-client-policy命令用来指定虚服务器引用的SSL客户端策略,以便对负载均衡设备(作为SSL客户端)与SSL服务器之间传输的流量进行加密传输。
虚服务器未引用任何SSL客户端策略。
虚服务器视图
context-admin
如需修改已被虚服务器引用的SSL客户端策略,在策略修改完成后,需在虚服务器视图下,先通过配置undo service enable命令关闭虚服务器,再通过配置service enable命令开启虚服务器,新的策略才能生效。
# 在HTTP类型的虚服务器vs2上,引用SSL客户端策略scp。
[Sysname-vs-http-vs2] ssl-client-policy scp
1.1.255  ssl-server-policy
ssl-server-policy命令用来指定虚服务器引用的SSL服务器端策略,以便对负载均衡设备(作为SSL服务器)与SSL客户端之间传输的流量进行加密传输。
undo ssl-server-policy命令用来恢复缺省情况。
ssl-server-policy policy-name
虚服务器没有引用任何SSL服务器端策略。
虚服务器视图
context-admin
本命令只在HTTP类型和TCP类型的虚服务器视图下支持。
如需修改已被虚服务器引用的SSL服务器端策略,在策略修改完成后,需在虚服务器视图下,先通过配置undo service enable命令关闭虚服务器,再通过配置service enable命令开启虚服务器,新的策略才能生效。
# 在HTTP类型的虚服务器vs2上,引用SSL服务器端策略ssp。
[Sysname-vs-http-vs2] ssl-server-policy ssp
1.1.256  sticky-group
sticky-group命令用来创建持续性组,并进入持续性组视图。如果指定的持续性组已经存在,则直接进入持续性组视图。
undo sticky-group命令用来删除指定的持续性组。
sticky-group group-name [ type { address-port | http-content | http-cookie | http-header | payload  | radius | ssl } ]
undo sticky-group group-name
不存在持续性组。
context-admin
group-name:持续性组的名称,为1~63个字符的字符串,不区分大小写。
type { address-port | http-content | http-cookie | http-header | payload  | radius | ssl }:持续性组的类型,包括地址端口、HTTP实体、HTTP Cookie、HTTP首部、HTTP载荷、RADIUS和SSL。创建持续性组时必须指定本参数;而在进入已创建的持续性组视图时可以不指定本参数,但若要指定本参数,则必须与创建时的类型一致。
持续性组的作用是根据某种持续性方法将具有一定相关性的会话都分配给同一个实服务器/链路处理。在一个会话中,当其首包通过持续性方法选择了实服务器/链路之后,后续包都会沿用这个选择结果。
当设备支持服务器负载均衡License功能但尚未安装License时,仅允许配置address-port类型的持续性组;当设备不支持服务器负载均衡License功能,或支持服务器负载均衡License功能且安装有License时,才允许配置所有类型的持续性组。
# 创建地址端口类型的持续性组sg1,并进入持续性组视图。
[Sysname] sticky-group sg1 type address-port
[Sysname-sticky-address-port-sg1]
1.1.257  sticky-sync enable (DNS proxy view)
sticky-sync enable命令用来开启DNS透明代理的持续性信息备份功能。
undo sticky-sync enable命令用来关闭DNS透明代理的持续性信息备份功能。
sticky-sync enable
DNS透明代理的持续性信息备份功能处于关闭状态。
DNS透明代理视图
context-admin
在DNS透明代理视图下开启持续性信息备份功能,可以备份持续性表项信息,保证主备切换时业务不中断。
# 开启DNS透明代理dns_proxy1的持续性信息备份功能。
[Sysname] loadbalance dns-proxy dns_proxy1 type udp
[Sysname-lb-dp-udp-dns_proxy1] sticky-sync enable
1.1.258  sticky-sync enable (virtual server view)
sticky-sync enable命令用来开启虚服务器的持续性表项备份功能。
undo sticky-sync enable命令用来关闭虚服务器的持续性表项备份功能。
sticky-sync enable
虚服务器的持续性表项备份功能处于关闭状态。
虚服务器视图
context-admin
在开启虚服务器的持续性表项备份功能之前,请确保主用和备用设备上均不存在持续性表项。可以通过先开启持续性表项备份功能,再引用持续性组,保证备份前设备上不存在持续性表项。
# 开启IP类型的虚服务器vs3的持续性表项备份。
[Sysname-vs-ip-vs3] sticky-sync enable
1.1.259  success-criteria (DNS server pool view)
success-criteria命令用来配置DNS服务器池健康检测的成功条件。
undo success-criteria命令用来恢复缺省情况。
success-criteria { all | at-least min-number }
只有全部方法都通过检测才认为健康检测成功。
DNS服务器池视图
context-admin
all:只有全部方法都通过检测才认为健康检测成功。
at-least min-number:健康检测成功所需通过检测的最少方法数,取值范围为1~4294967295。
当用户指定的最少方法数大于设备上实际存在的方法数时,只要实际存在的方法全部通过检测,设备就认为健康检测成功。
# 配置DNS服务器池dns-pool的健康检测成功所需通过检测的最少方法数为2个。
[Sysname-lb-dspool-dns-pool] success-criteria at-least 2
·            success-criteria(DNS server view)
1.1.260  success-criteria (DNS server view)
success-criteria命令用来配置DNS服务器健康检测的成功条件。
DNS服务器视图
context-admin
当用户指定的最少方法数大于设备上实际存在的方法数时,只要实际存在的方法全部通过检测,系统就认为健康检测成功。
# 配置DNS服务器ds1健康检测成功所需通过检测的最少方法数为2个。
[Sysname-lb-ds-ds1] success-criteria at-least 2
·            success-criteria(DNS server pool view)
1.1.261  success-criteria (link group view)
success-criteria命令用来配置链路组健康检测的成功条件。
链路组视图
context-admin
当用户指定的最少方法数大于设备上实际存在的方法数量时,系统也将认为健康检测成功。
用户既可在链路组视图下对组内的所有链路进行配置,也可在链路视图下只对当前链路进行配置,后者的配置优先级较高。
# 配置链路组lg的健康检测成功所需通过检测的最少方法数为2个。
[Sysname-lb-lgroup-lg] success-criteria at-least 2
·            success-criteria(link view)
1.1.262  success-criteria (link view)
success-criteria命令用来配置链路健康检测的成功条件。
只有全部方法通过检测才认为健康检测成功。
链路视图
context-admin
all:要求链路通过所有方式的健康检测。
at-least min-number:要求链路至少通过指定方式数目的健康检测,取值范围为1~4294967295。
当用户指定的最少方法数大于设备上实际存在的方法数量时,只要实际存在的全部方法通过检测,系统就认为健康检测成功。
# 配置链路健康检测的成功条件至少为2个。
[Sysname-lb-link-lk1] success-criteria at-least 2
1.1.263  success-criteria (real server view)
success-criteria命令用来配置实服务器健康检测的成功条件。
实服务器视图
context-admin
# 配置实服务器rs的健康检测成功所需通过检测的最少方法数为2个。
[Sysname-rserver-rs] success-criteria at-least 2
1.1.264  success-criteria (server farm view)
success-criteria命令用来配置实服务组健康检测的成功条件。
实服务组视图
context-admin
# 配置实服务组sf的健康检测成功所需通过检测的最少方法数为2个。
[Sysname-sfarm-sf] success-criteria at-least 2
1.1.265  tcp connection idle-timeout
tcp connection idle-timeout命令用来配置TCP连接的空闲超时时间。
undo tcp connection idle-time命令用来恢复缺省情况。
tcp connection idle-timeout value
undo tcp connection idle-timeout
TCP连接的空闲超时时间为0,即不超时。
【视图】­
TCP类型的参数模板视图
context-admin
value:TCP连接的空闲超时时间,取值范围为10~86400,单位为秒。
通过本命令可以自定义负载均衡设备与客户端以及服务器建立的TCP连接的空闲超时时间。若在TCP连接的空闲超时时间内没有应用数据传输,负载均衡设备会主动断开与客户端或服务器的TCP连接。
# 配置TCP连接的空闲超时时间为60秒。
[Sysname] parameter-profile pp1 type tcp
[Sysname-para-tcp-pp1] tcp connection idle-timeout 60
1.1.266  tcp connection time-wait timeout
tcp connection time-wait timeout命令用来配置TCP连接TIME-WAIT状态的超时时间。
undo tcp connection time-wait timeout命令用来恢复缺省情况。
tcp connection time-wait timeout value
TCP连接TIME-WAIT状态的超时时间为3秒。
TCP类型参数模板视图
value:TCP连接TIME-WAIT状态的超时时间,取值范围为1~65535,单位为秒。
TCP连接断开时,由于TCP协议的TIME-WAIT状态超时时间较长,导致TCP连接释放过慢,影响负载均衡业务处理效率。本命令用来灵活设置TIME-WAIT状态超时时间。
# 在TCP类型的参数模板pa1视图下,配置TCP连接TIME-WAIT状态的超时时间30秒。
[Sysname] parameter-profile pa1 type tcp
[Sysname-para-tcp-pa1] tcp connection time-wait timeout 30
1.1.267  tcp mss
tcp mss命令用来配置负载均衡设备与对端建立TCP连接时的MSS值。
undo tcp mss命令用来恢复缺省情况。
tcp mss value
undo tcp mss
未配置负载均衡设备与对端建立TCP连接时的MSS值。
TCP类型的参数模板视图
context-admin
value:MSS值,取值范围为128~1460,单位为字节。
本命令仅当快速HTTP类型和HTTP类型的虚服务器引用了TCP类型的参数模板时才会生效。
在客户端与负载均衡设备建立TCP连接时,客户端将MSS值通告给负载均衡设备,负载均衡设备会记录下这个MSS值,并将配置的MSS值发送给客户端,客户端与负载均衡设备将使用较小的MSS值作为双方通信的最大分段长度。
在负载均衡设备与服务器建立TCP连接时,负载均衡设备将配置的MSS值通告给服务器,服务器会记录下这个MSS值,并将自身的MSS值发送给负载均衡设备,负载均衡设备与服务器将使用较小的MSS值作为双方通信的最大分段长度。
# 配置负载均衡设备与对端建立TCP连接时的MSS值为1300。
[Sysname] parameter-profile tcp type tcp
[Sysname-para-tcp-tcp] tcp mss 1300
1.1.268  tcp window-size
tcp window-size命令用来配置TCP连接中的本地最大窗口值。
undo tcp window-size命令用来恢复缺省情况。
tcp window-size size
TCP连接中的本地最大窗口值为65535。
参数模板视图
context-admin
本命令只在TCP类型的参数模板视图下支持。
# 在TCP类型的参数模板pp3中,配置TCP连接中的本地最大窗口值为8192。
[Sysname] parameter-profile pp3 type tcp
[Sysname-para-tcp-pp3] tcp window-size 8192
1.1.269  timeout (proximity view)
timeout命令用来配置就近性表项的老化时间。
undo timeout命令用来恢复缺省情况。
timeout timeout-value
undo timeout
就近性表项的老化时间为60秒。
就近性视图
context-admin
timeout-value:就近性表项的老化时间,取值范围为60~3600,单位为秒。
# 配置就近性表项的老化时间为80秒。
[Sysname] loadbalance proximity
[Sysname-lb-proximity] timeout 80
1.1.270  timeout (sticky group view)
timeout命令用来配置持续性表项的超时时间。
undo timeout
对于HTTP Cookie类型的持续性组,持续性表项的超时时间为86400秒;对于其它类型的持续性组,持续性表项的超时时间为60秒。
持续性组视图
context-admin
timeout-value:超时时间。对于HTTP Cookie类型的持续性组,取值范围为0~31536000,单位为秒;对于其它类型的持续性组,取值范围为10~604800,单位为秒。对于HTTP Cookie类型的持续性组,当其持续性方法为Cookie插入或Cookie重写时,0表示该持续性为会话持续性;当其持续性方法为Cookie截取时,0表示此持续性表项的超时时间为0秒。
# 在地址端口类型的持续性组sg1中,配置持续性表项的超时时间为100秒。
[Sysname-sticky-address-port-sg1] timeout 100
1.1.271  topology region
topology region命令用来配置Topology。
undo topology region命令用来恢复缺省情况。
topology region region-name { ip ipv4-address [ mask-length | mask ] | ipv6 ipv6-address prefix-length } [ weight weight-value ]
undo topology region region-name [ ip ipv4-address [ mask-length | mask ] | ipv6 ipv6-address [ prefix-length ] ]
Topology(区域特征与IP网段的对应关系)不存在。
context-admin
region-name:区域名,为1~63个字符的字符串,不区分大小写。
ip ipv4-address:虚服务器的IPv4地址。
mask:IPv4掩码,缺省值为255.255.255.255。
ipv6 ipv6-address:虚服务器的IPv6地址。
prefix-length:IPv6地址的前缀长度,取值范围为1~128,缺省值为128。
weight weight-value:权值,取值范围为1~255,缺省值为100。
Topology定义了LDNS(本地DNS服务器)源地址区域特征与虚服务器所在IP网段的对应关系。
当虚服务器池中通过predictor命令指定调度算法为静态就近性调度算法时,需要配置此命令。
当DNS请求匹配多个Topology记录时,优先选择权重值高的记录。
通过重复执行本命令,可以为一个区域特征配置多个不同的IP网段。
若删除Topology时仅指定区域特征,则该区域特征对应的所有Topology均会被删除。
# 配置指定的源地址区域特征与IP网段的对应关系。
[Sysname] topology region region-ct ip 1.2.3.4 24 weight 200
·            predictor(virtual-server-pool view)
·            loadbalance region
1.1.272  transparent enable (link group view)
transparent enable命令用来在链路组中关闭NAT功能。
undo transparent enable命令用来在链路组中开启NAT功能。
transparent enable
链路组中的NAT功能处于开启状态。
链路组视图
context-admin
# 在链路组lg中关闭NAT功能。
[Sysname-lb-lgroup-sinalab] transparent enable
1.1.273  transparent enable (server farm view)
transparent enable命令用来在实服务组中关闭NAT功能。
undo transparent enable命令用来在实服务组中开启NAT功能。
transparent enable
实服务组中的NAT功能处于开启状态。
实服务组视图
context-admin
实服务组被HTTP类型的虚服务器引用时,即使关闭了NAT功能也将仍按照NAT模式处理。
# 在实服务组sf中关闭NAT功能。
[Sysname-sfarm-sf] transparent enable
1.1.274  ttl (DNS map view)
ttl命令用来配置缓存DNS域名解析记录的缓存时间。
undo ttl命令用来恢复缺省情况。
ttl ttl-value
undo ttl
域名解析记录的缓存时间缺省值为3600秒。
DNS映射视图
context-admin
ttl-value:缓存时间,取值范围为0~4294967295,单位为秒。
该命令指定DNS请求客户端本地保存域名解析记录的时间,当负载均衡策略变化、虚服务器配置变化时,用户可以通过配置小一些的缓存时间,使DNS请求客户端尽快获得新的解析记录;而在网络稳定的环境下,用户可将缓存时间设置为更大的值,提高域名的解析稳定性及速度。
# 在名称为dm1的DNS映射视图下,配置缓存DNS域名解析记录的缓存时间为4000秒。
[Sysname-lb-dm-dm1] ttl 4000
1.1.275  ttl (DNS zone view)
ttl命令用来配置资源记录的缓存时间。
undo ttl命令用来恢复缺省情况。
ttl ttl-value
undo ttl
资源记录的缓存时间为3600秒。
DNS正向区域视图
context-admin
ttl-value:资源记录的缓存时间,取值范围为0~4294967295,单位为秒。
# 对DNS正向区域abc.com,配置资源记录的缓存时间为1天。
[Sysname-lb-zone-abc.com] ttl 86400
1.1.276  ttl weight
ttl weight命令用来配置就近性计算的路由器跳数权值。
undo ttl weight命令用来恢复缺省情况。
ttl weight ttl-weight
undo ttl weight
就近性计算的路由器跳数权值为100。
就近性视图
context-admin
ttl-weight:就近性计算的路由器跳数权值,取值范围为0~255,数值越大权重越大。
# 配置就近性计算的路由器跳数权值为200。
[Sysname-lb-proximity] ttl weight 200
1.1.277  udp per-packet
udp per-packet命令用来开启虚服务器的UDP强制负载均衡功能。
undo udp per-packet命令用来关闭虚服务器的UDP强制负载均衡功能。
udp per-packet
undo udp per-packet
虚服务器的UDP强制负载均衡功能处于关闭状态。
虚服务器视图
context-admin
本命令只在UDP类型的虚服务器视图下支持。
当UDP强制负载均衡功能关闭时,匹配虚服务器的流量按照数据流来进行负载均衡,即一个应用的流量会被负载均衡到同一个实服务器上;而当UDP强制负载均衡功能开启后,匹配虚服务器的流量不再按照流来进行负载均衡,而是按照每报文来进行负载均衡。
UDP强制负载均衡功能开启后,需要注意的是:
·            虚服务器以及实服务器上与连接数相关的数据将不会被统计。
·            如果引用的实服务组未开启NAT功能,虚服务器以及实服务器上的发出的报文数量将不会被统计。
·            以下配置项仍将生效:虚服务器所引用实服务组上配置的调度算法、虚服务器引用实服务组时所配置的持续性组中的持续性方法。例如,实服务组的调度算法为哈希算法或者持续性方法为源IP地址持续性时,由于同一会话的五元组相同,哈希计算结果和持续性表项匹配结果都是相同的实服务器,因此属于同一会话的UDP报文仍将被送至同一个实服务器进行处理,而无法按照每报文进行负载均衡。
# 开启UDP类型的虚服务器vs5的UDP强制负载均衡功能。
[Sysname] virtual-server vs5 type udp
[Sysname-vs-udp-vs5] udp per-packet
1.1.278  virtual ip address
virtual ip address命令用来配置虚服务器的IPv4地址(即VSIP)。
undo virtual ip address命令用来恢复缺省情况。
virtual ip address ipv4-address [ mask-length | mask ]
虚服务器没有IPv4地址。
虚服务器视图
context-admin
ipv4-address:IPv4地址,不能为环回地址、组播地址、广播地址和0.X.X.X(如果掩码长度不是32,则可以配置0.X.X.X)。
mask-lengh:子网掩码长度,取值范围为0~32,缺省值为32。本参数在快速HTTP和HTTP类型的虚服务器视图下不支持。
mask:子网掩码,缺省值为255.255.255.255。本参数在快速HTTP和HTTP类型的虚服务器视图下不支持。
# 配置IP类型的虚服务器vs3的IP地址为1.1.1.1/24。
[Sysname-vs-ip-vs3] virtual ip address 1.1.1.1 24
1.1.279  virtual ipv6 address
virtual ipv6 address命令用来配置虚服务器的IPv6地址(即VSIP)。
undo virtual ipv6 address命令用来恢复缺省情况。
virtual ipv6 address ipv6-address [ prefix-length ]
虚服务器没有IPv6地址。
虚服务器视图
context-admin
ipv6-address:IPv6地址,不能为环回地址、IPv6组播地址、链路本地地址和全0地址(如果前缀长度为0,则可以配置全0地址)。
prefix-length:前缀长度,取值范围为0~128,缺省值为128。本参数在快速HTTP和HTTP类型的虚服务器视图下不支持。
# 配置IP类型的虚服务器vs3的IPv6地址为1001::1/64。
[Sysname-vs-ip-vs3] virtual ipv6 address 1001::1 64
1.1.280  virtual-server (system view)
virtual-server命令用来创建虚服务器,并进入虚服务器视图。如果指定的虚服务器已经存在,则直接进入虚服务器视图
undo virtual-server命令用来删除指定的虚服务器。
virtual-server virtual-server-name [ type { fast-http | http | ip | link-ip | radius | tcp | udp } ]
undo virtual-server virtual-server-name
不存在任何虚服务器。
context-admin
virtual-server-name:虚服务器的名称,为1~63个字符的字符串,不区分大小写。
type { fast-http | http | ip | link-ip | radius | tcp | udp }:虚服务器的类型,包括快速HTTP、HTTP、IP、LINK-IP、RADIUS、TCP和UDP五种类型。创建虚服务器时必须指定本参数;进入已创建的虚服务器视图时可以不指定本参数,若要指定本参数,则必须与创建时的类型一致。
当设备支持服务器负载均衡License功能但尚未安装License时,不允许配置快速HTTP、HTTP、RADIUS、TCP和UDP类型的虚服务器;当设备不支持服务器负载均衡License功能,或支持服务器负载均衡License功能且安装有License时,才允许配置快速HTTP、HTTP、RADIUS、TCP和UDP类型的虚服务器。
# 创建IP类型的虚服务器vs3,并进入虚服务器视图。
[Sysname-vs-ip-vs3]
1.1.281  virtual-server (virtual server pool view)
virtual-server命令用来向虚服务器池中添加虚服务器。
undo virtual-server命令用来从虚服务器池中删除指定的虚服务器。
virtual-server virtual-server-name link link-name [ weight weight-value ]
虚服务器池未添加任何虚服务器。
虚服务器池视图
context-admin
virtual-server-name:添加的虚服务器名称,为1~63个字符的字符串,不区分大小写。
link link-name:虚服务器关联的链路的名称,为1~63个字符的字符串,不区分大小写。
weight weight-value:虚服务器的调用权值。其中,weight-value的取值范围为1~255,缺省值为100。在加权轮转调度算法中,该数值越大,虚服务器的调用优先级越高。如果不指定此参数,添加的虚服务器的调用权值为其缺省值100。
虚服务器池中允许添加多个虚服务器。
如果同时配置入方向链路负载均衡功能和服务器负载均衡功能,请避免配置虚服务器的IP地址与DNS监听器地址为同一地址,以免影响入方向链路负载均衡功能的正常使用。
配置入方向链路负载均衡使用的虚服务器的IP地址时,要求配置32位掩码,且为非全0的单播地址。
# 向虚服务器池local-pool中添加虚服务器vs1,关联链路为link1。
[Sysname] loadbalance virtual-server-pool local-pool
[Sysname-lb-vspool-local-pool] virtual-server vs1 link link1
·            loadbalance virtual-server-pool
·            loadbalance link
1.1.282  virtual-server-pool
virtual-server-pool命令用来指定DNS映射使用的虚服务器池。
undo virtual-server-pool命令用来恢复缺省情况。
virtual-server-pool pool-name
undo virtual-server-pool pool-name
未指定DNS映射使用的虚服务器池。
DNS映射视图
context-admin
pool-name:虚服务器池名称,为1~63个字符的字符串,不区分大小写。
目前一个DNS映射视图中仅支持配置一个虚服务器池。
# 在名称为dm1的DNS映射视图下,使用的虚服务器池为pool1。
[Sysname-lb-dm-dm1] virtual-server-pool pool1
1.1.283  vpn-instance (DNS listener view)
vpn-instance命令用来指定DNS监听器所属的VPN实例。
undo vpn-instance命令来恢复缺省情况。
undo vpn-instance
DNS监听器属于公网。
DNS监听器视图
context-admin
vpn-instance-name:VPN实例名称,为1~31个字符的字符串,区分大小写。
# 指定DNS监听器ct-listener所属的VPN实例为vpn1。
[Sysname-lb-dl-ct-listener] vpn-instance vpn1
1.1.284  vpn-instance (DNS proxy view)
vpn-instance命令用来指定DNS透明代理所属的VPN实例。
undo vpn-instance命令用来恢复缺省情况。
undo vpn-instance
DNS透明代理所属的VPN实例为公网。
DNS透明代理视图
context-admin
# 在名称为dns-proxy1的DNS透明代理视图下,配置其所属VPN实例为vpn1。
[Sysname-lb-dp-udp-dns-proxy1] vpn-instance vpn1
1.1.285  vpn-instance (link view)
vpn-instance命令用来指定链路所属的VPN实例。
undo vpn-instance
链路属于公网。
链路视图
context-admin
在执行本命令前,用户需要执行ip vpn-instance命令来创建VPN实例。若指定的VPN实例为未创建的VPN实例,则链路状态为不可用。
# 指定链路lk1所属的VPN实例为vpn1。
[Sysname-lb-link-lk1] vpn-instance vpn1
·            ip vpn-instance
1.1.286  vpn-instance (real server view)
vpn-instance命令用来指定实服务器所属的VPN实例。
undo vpn-instance
当实服务器所属VPN实例的继承功能处于开启状态时,实服务器所属的VPN实例与虚服务器所属的VPN实例一致;当实服务器所属VPN实例的继承功能处于关闭状态时,实服务器服务于公网。
实服务器视图
context-admin
# 指定实服务器rs所属的VPN实例为vpn1。
[Sysname-rserver-rs] vpn-instance vpn1
·            inherit vpn-instance disable
1.1.287  vpn-instance (virtual server view)
vpn-instance命令用来指定虚服务器所属的VPN。
undo vpn-instance
虚服务器属于公网。
虚服务器视图
context-admin
# 指定IP类型的虚服务器vs3所属的VPN为vpn1。
[Sysname-vs-ip-vs3] vpn-instance vpn1
1.1.288  weight (DNS server view)
weight命令用来配置DNS服务器的权值,即加权轮转调度算法和带宽调度算法所使用的权值。
undo weight命令用于恢复缺省情况。
weight weight-value
DNS服务器的权值为100。
DNS服务器视图
context-admin
weight-value:权值,取值范围为1~255。在加权轮转调度和带宽调度时,该数值越大,DNS服务器越被优先调用。
# 配置DNS服务器ds1的权值为150。
[Sysname-lb-ds-ds1] weight 150
1.1.289  weight (link view)
weight命令用来配置链路的权值,即加权轮转和加权最小连接这两种调度算法所使用的权值。
undo weight命令用来恢复缺省情况。
weight weight-value
undo weight
链路的权值为100。
链路视图
context-admin
weight-value:权值,取值范围为1~255。在加权轮转和加权最小连接调度时,该数值越大,链路越被优先调用。
# 配置链路lk1的权值为150。
[Sysname-lb-link-lk1] weight 150
1.1.290  weight (real server view)
weight命令用来配置实服务器的权值,即加权轮转和加权最小连接这两种调度算法所使用的权值。
weight weight-value
undo weight
实服务器的权值为100。
实服务器视图
context-admin
weight-value:权值,取值范围为1~255。在加权轮转和加权最小连接调度时,该数值越大,实服务器越被优先调用。
# 配置实服务器rs的权值为150。
[Sysname-rserver-rs] weight 150
1.1.291  window-size
window-size命令用来配置压缩使用的窗口大小。
undo window-size命令用来恢复缺省情况。
window-size size
undo window-size
压缩窗口大小为16KB。
HTTP压缩参数模板视图
context-admin
# 创建HTTP压缩类型的参数模板pa1,并指定压缩使用的窗口大小为32KB。
[Sysname] parameter-profile pa1 type http-compress
[Sysname-para-http-compress-pa1] window-size 32
