02-NetStream命令参考
02-IPv6 NetStream命令
本章节下载 02-IPv6 NetStream命令  (166.52 KB)
02-IPv6 NetStream命令
1 IPv6 NetStream
1.1  IPv6 NetStream配置命令
1.1.1  display ipv6 netstream cache
display ipv6 netstream cache命令用来查看IPv6 NetStream流缓存区的配置和状态信息。
display ipv6 netstream cache [ verbose ]
verbose:显示IPv6 NetStream流缓冲区的详细信息。
# 查看IPv6 NetStream流缓冲区信息。
<Sysname> display ipv6 netstream cache verbose
IPv6 NetStream cache information:
  Active flow timeout             : 60 min
  Inactive flow timeout           : 10 sec
  Max number of entries           : 1000
  IPv6 active flow entries        : 1
  MPLS active flow entries        : 2
  IPL2 active flow entries        : 1
  IPv6 flow entries counted       : 10
  MPLS flow entries counted       : 20
  IPL2 flow entries counted       : 20
  Last statistics resetting time  : 08/18/2016 at 11:45:13
IPv6 packet size distribution (2931057 packets in total):
 1-32   64   96  128  160  192  224  256  288  320  352  384  416  448  480
 .000 .000 .000 .000 .000 .000 .000 .000 .000 .000 .000 .000 .000 .000 .000
  512  544  576 1024 1536 2048 2560 3072 3584 4096 4608 >4608
 .885 .000 .000 .011 .089 .000 .000 .000 .000 .000 .000 .000
Protocol          Total Packets    Flows  Packets Active(sec) Idle(sec)
                  Flows /sec       /sec   /flow   /flow       /flow
TCP-Telnet      2656855     372        4       86        49        27
TCP-FTP         5900082      86        9        9        11        33
TCP-FTPD        3200453    1006        5      193        45        33
TCP-WWW       546778274   11170      887       12         8        32
TCP-other      49148540    3752       79       47        30        32
UDP-DNS       117240379     570      190        3         7        34
UDP-other      45502422    2272       73       30         8        37
ICMP           14837957     125       24        5        12        34
IP-other          77406       5        0       47        52        27
Type DstIP(Port)     SrcIP(Port)     Pro TC  FlowLbl APPID If(Direct)  Pkts
     DstMAC(VLAN)        SrcMAC(VLAN)
     TopLblType(IP/MASK) Lbl-Exp-S-List
IP   2001::1(1024)   2002::1(21)     6   0   0x6000  0x0   GE1/0/1(I)  42996
MPLS LDP(3.3.3.3/24)    1:18-6-0                           GE1/0/2(O)  291
                        2:24-6-0
                        3:30-6-1
IP&  2010::1(1024)   2020::1(67)     17  0  0x12345 0x0     GE1/0/3(I)  1848
MPLS LDP(4.4.4.4/24)    1:55-6-0
                        2:16-6-1
                        2:0-0-0
表1-1 display ipv6 netstream cache命令显示信息描述表
IPv6 NetStream流缓存区信息
Active flow  timeout
活跃流的老化时间,单位为分钟
不活跃流的老化时间,单位为秒
IPv6 NetStream流缓存区中允许的最大流数
IPv6 NetStream流缓存区中活跃的IPv6流数
IPv6 NetStream流缓存区中活跃的MPLS流数
IPv6 NetStream流缓存区中活跃的二层和三层流数
已经被统计的IPv6流数
已经被统计的MPLS流数
已经被统计的二层和三层流数
上次清除统计的时间
该字段只在执行了reset ipv6 netstream statistics命令后才会显示为时间,否则显示为Never
IPv6 packet size distribution (1103746 packets in total):
IPv6报文按大小分布情况,括号中为IPv6报文总数。分布值按各项占报文总数的比率显示,只显示3位小数,如“.027”表示占IPv6报文总数的0.027
320  352  384  416  448  480 512  544  576
IPv6报文尺寸区间(报文长度不包括二层链路层的头)。长度不超过576字节时,以32字节为单位递增,例如:“1-32”是长度为1~32个字节的报文数目,“64”是长度为33~64字节的报文数。长度超过1024字节时,以512字节为单位递增,例如“1536”是长度为1025~1536字节的报文数。长度为577~1024间的报文记录存放在1024项中。
Protocol     Total Flows     Packets/Sec
Flow/Sec   Packets/flow
Active(sec)/ flow   Idle(sec)/flow
按协议分类的报文统计信息:协议类型、总流数、每秒的报文数、每秒的流数、平均每条流的报文数、平均每条流的活跃时间、平均每条流的非活跃时间
当前流缓存区中活跃流的IP层信息: 流的类型、目的IPv6地址(目的端口号)、源IPv6地址(源端口号)、协议号、流量分类、流标签、应用协议ID、接口名(方向)、包数
其中流的类型有四种:IP流(IP)、二三层混合流(IPL2)、不带IP选项的MPLS流(MPLS)、带IP选项的MPLS流(IP&MPLS)
需要注意的是,对于ICMPv6报文只有Type和Code字段,因此用目的端口号的高8位为Type字段、低8位为Code字段,源端口号为0
当前流缓存区中活跃流的二层信息:目的MAC地址、目的VLAN ID、源MAC地址、源VLAN ID
当前流缓存区中活跃流的MPLS信息:栈顶标签的类型(栈顶标签对应的IP地址及掩码长度)、标签列表
标签主要的三部分:
·     20比特的Label字段表示标签值
·     3比特的EXP字段用来实现QoS
·     1比特S字段置1表示已达栈底
TcpFlag:
DstMask:   SrcMask:
DstAS:       SrcAS:
NextHop:
BGPNextHop:
OutVRF:     InVRF:
SamplerMode:                  SamplerInt:
Active:       Bytes/Pkt:
当前流缓存区中活跃流的其它信息:TCP标记、目的掩码、源掩码、目的自治系统、源自治系统、路由下一跳、BGP下一跳、出方向报文转发使用的VPN 、入方向报文转发使用的VPN、采样模式、采样间隔、流活跃时间、平均每个包的字节数
NetStream采样模式,目前支持三种:
·     0:表示不采样,统计所有报文
·     1:表示固定采样
·     2:表示随机采样
(暂不支持源自治系统、目的自治系统、BGP下一跳)
1.1.2  display ipv6 netstream export
display ipv6 netstream export命令用来查看IPv6 NetStream统计输出报文的各种信息。
不同的聚合方式使用不同的模板,使用该命令显示当前配置的所有聚合方式的统计输出报文的信息。
# 查看IPv6 NetStream统计输出信息。
<Sysname> display ipv6 netstream export
protocol-port aggregation export information:
Flow source interface                           : GigabitEthernet1/0/1
Flow destination VPN instance                   : Not specified
Flow destination IPv6 address (UDP)             : 40::1 (5000)
Version 9 exported flow number                  : 25576
Version 9 exported UDP datagram number (failed) : 1612 (0)
表1-2 display ipv6 netstream export命令显示信息描述表
协议-端口聚合 NetStream统计输出信息
输出信息的源接口
输出信息的目的地址所在的VPN
输出信息的目的IP地址(UDP端口号)
Version 9 exported flows number
使用版本9格式发送的流信息数
Version 9 exported UDP datagrams number (failed)
使用版本9格式发送的UDP报文数(发送失败的报文数)
1.1.3  display ipv6 netstream template
display ipv6 netstream template命令用来查看IPv6 NetStream模板的配置和状态信息。
不同的聚合方式使用不同的模板,使用该命令显示当前配置的所有聚合方式的模板信息。
# 查看IPv6 NetStream模板信息。
<Sysname> display ipv6 netstream template
Flow template refresh frequency            : 20
Flow template refresh interval             : 30 min
Active flow templates                      : 4
Created flow templates                     : 6
Protocol-port outbound template:
Template ID                : 3299
Field count                : 16
Field type                   Field length (bytes)
Flows                        4
Out packets                  8
Out bytes                    8
First forwarded              4
Last forwarded               4
Protocol                     1
IP protocol version          1
Direction                    1
PAD                          1
L4 source port               2
L4 destination port          2
Sampling algorithm           1
PAD                          1
PAD                          1
PAD                          1
Sampling interval            4
Protocol-port inbound template:
Template ID                : 3298
Field count                : 16
Flows                        4
In packets                   8
In bytes                     8
First forwarded              4
Last forwarded               4
Protocol                     1
Direction                    1
PAD                          1
L4 source port               2
PAD                          1
PAD                          1
PAD                          1
Sampling interval            4
L3 outbound template:
Template ID                : 3305
Field count                : 28
Out packets                  8
Out bytes                    8
First forwarded              4
Last forwarded               4
Input Interface Index        4
Output Interface Index       4
IPv6 source address          16
IPv6 destination address     16
IPv6 NextHop                 16
PAD                          1
IPv6 flow label              3
Source AS                    4
Destination AS               4
L4 source port               2
TCP flags                    1
Protocol                     1
Source ToS                   1
IPv6 source mask             1
IPv6 destination mask        1
Direction                    1
Forwarding offset            1
Out VPN ID                   2
PAD                          1
Sampling interval            4
APP ID                       4
L3 inbound template:
Template ID                : 3304
Field count                : 28
In packets                   8
In bytes                     8
First forwarded              4
Last forwarded               4
IPv6 NextHop                 16
PAD                          1
IPv6 flow label              3
Source AS                    4
Destination AS               4
L4 source port               2
TCP flags                    1
Protocol                     1
Source ToS                   1
IPv6 source mask             1
Direction                    1
Forwarding offset            1
In VPN ID                    2
PAD                          1
Sampling interval            4
APP ID                       4
表1-3 display ipv6 netstream template命令显示信息描述表
模板的包刷新率
模板的时间刷新率,单位为分钟
当前激活的模板数
创建的模板总数
Protocol-port 出方向模板信息
Protocol-port 入方向模板信息
Template ID
模板ID
Packets
使用该模板的发送报文数
Last template export time
该模板最近的一次输出时间
Field count
模板的域总数
Field type
域类型
域长度,单位为字节
Flows
流数量
Out packets
输出的数据包个数
In packets
输入的数据包个数
Out bytes
输出的数据个数,单位为字节
In bytes
输入的数据个数,单位为字节
First forwarded
记录转发第一个报文时的系统时间,时间精确到毫秒
Last forwarded
记录转发最后一个报文时的系统时间,时间精确到毫秒
Source AS
源AS号(暂不支持)
Destination AS
目的AS (暂不支持)
Input interface index
输入接口的索引
Output interface index
输出接口的索引
Direction
方向字段
Sampling algorithm
采样算法
PAD
空白占位符
Sampling interval
采样率
1.1.4  enable
enable命令用来开启当前聚合视图对应的聚合功能。
undo enable命令用来关闭当前聚合视图对应的聚合功能。
enable
undo enable
当前聚合视图对应的聚合功能处于关闭状态。
IPv6 NetStream聚合视图
# 开启IPv6 NetStream的协议-端口聚合功能。
[Sysname] ipv6 netstream aggregation protocol-port
[Sysname-ns6-aggregation-protocol-port] enable
·     ipv6 netstream aggregation
1.1.5  ipv6 netstream
ipv6 netstream命令用来开启IPv6 NetStream功能。
undo ipv6 netstream命令用来关闭NetStream功能。
ipv6 netstream
undo ipv6 netstream
IPv6 NetStream功能处于关闭状态。
# 在GigabitEthernet1/0/1接口上开启IPv6 NetStream功能。
[Sysname-GigabitEthernet1/0/1] ipv6 netstream
1.1.6  ipv6 netstream sampler
ipv6 netstream sampler命令用来开启IPv6 NetStream采样功能。
undo ipv6 netstream sampler命令用来关闭IPv6 NetStream采样功能。
ipv6 netstream sampler sampler-name
IPv6 NetStream采样功能处于关闭状态。
sampler sampler-name:采样器名称,为1~31个字符的字符串,不区分大小写。
# 在接口GigabitEthernet1/0/1上开启IPv6 NetStream采样功能,使用名为abc的采样器对报文进行采样,Netstream根据采样结果进行报文统计。
 [Sysname-GigabitEthernet1/0/1] ipv6 netstream sampler abc
1.1.7  ipv6 netstream aggregation
ipv6 netstream aggregation命令用来设置IPv6 NetStream流聚合方式,并进入相应的IPv6 NetStream聚合视图。如果指定的IPv6 NetStream流聚合方式已经存在,则直接进入相应的IPv6 NetStream聚合视图。
undo ipv6 netstream aggregation命令用来关闭IPv6 NetStream流聚合方式,并删除流聚合方式相应的配置。
ipv6 netstream aggregation { destination-prefix | prefix | protocol-port | source-prefix }
undo ipv6 netstream aggregation { destination-prefix | prefix | protocol-port | source-prefix }
未配置IPv6 NetStream流聚合方式。
destination-prefix:目的前缀聚合,根据IPv6 NetStream流的目的自治系统号、目的掩码长度、目的前缀和输出接口索引4个关键项对流分类。
prefix:源和目的前缀聚合,根据IPv6 NetStream流的源自治系统号、目的自治系统号、源掩码长度、目的掩码长度,源前缀、目的前缀、输入接口索引和输出接口索引8个关键项对流分类。
protocol-port:协议-端口聚合,根据IPv6 NetStream流的协议号、源端口和目的端口3个关键项对流分类。
source-prefix:源前缀聚合,根据IPv6 NetStream流的源自治系统号、源掩码长度、源前缀和输入接口索引4个关键项对流分类。
在聚合视图下,可以开启或关闭聚合功能,以及设置IPv6 NetStream统计输出报文源接口、目的IPv6地址以及目的端口号。
如果一条流同时满足多个聚合方式,则该流会被统计到多个聚合流中。
# 进入IPv6 NetStream协议-端口聚合视图。
[Sysname-ns-aggregation-protocol-port]
·     enable
1.1.8  ipv6 netstream export host
ipv6 netstream export host命令用来配置IPv6 NetStream统计输出报文的目的地址和目的UDP端口号。
undo ipv6 netstream export host命令用来删除已有配置。
ipv6 netstream export host { ipv4-address | ipv6-address } udp-port [ vpn-instance vpn-instance-name ]
undo ipv6 netstream export host [ ipv4-address | ipv6-address [ vpn-instance vpn-instance-name ] ]
未配置目的地址和目的UDP端口号。
IPv6 NetStream聚合视图
Ipv4-address:IPv6 NetStream统计输出报文的IPv4目的地址。
Ipv6-address:IPv6 NetStream统计输出报文的IPv6目的地址。
udp-port:IPv6 NetStream统计输出报文的目的UDP端口号,取值范围为0~65535。
vpn-instance vpn-instance-name:指定IPv6 NetStream统计输出报文的目的地址所属的VPN。vpn-instance-name表示MPLS L3VPN的VPN实例名称,为1~31个字符的字符串,区分大小写。如果未指定本参数,则表示IPv6 NetStream统计输出报文的目的地址位于公网中。
若没有使能某类聚合功能,则无法通过display ipv6 netstream export命令查看它的相关信息(包括目的地址的目的UDP端口号)。
执行undo ipv6 netstream export host命令时未指定地址,表示取消指定本视图下配置的所有地址。
不同聚合视图下可以配置相同的目的地址和目的UDP端口号。
若聚合视图下未配置目的地址和目的UDP端口号,则使用系统视图下的配置;若聚合视图下配置了目的地址和目的UDP端口号,则使用聚合视图下的配置。
一个视图下最多可配置4组IPv4目的地址,包括不同VPN实例。在同一视图下,若先后配置了IPv4地址相同、UDP端口号不同的目的地址,则后配置的目的地址生效。在用户配置了不同的VPN实例名称时,允许配置相同的IP地址和UDP端口号。
一个视图下最多可配置4组IPv6目的地址,包括不同VPN实例。在同一视图下,若先后配置了IPv6地址相同、UDP端口号不同的目的地址,则后配置的目的地址生效。在用户配置了不同的VPN实例名称时,允许配置相同的IPv6地址和UDP端口号。
普通流统计输出报文会发给系统视图下配置的所有目的地址。聚合流统计输出报文会发给聚合类型对应的聚合视图下配置的所有目的地址。为了减少对网络带宽的占用,可以只在聚合视图下配置ipv6 netstream export host命令,此时设备只会输出聚合流信息。
# 配置全局IPv6 NetStream统计输出报文的目的IP地址为40::1,UDP端口号为5000。
[Sysname] ipv6 netstream export host 40::1 5000
# 配置IPv6 NetStream协议-端口聚合统计输出报文的目的地址为40::1,UDP端口号为6000。
[Sysname] ipv6 netstream aggregation Protocol-port
[Sysname-ns6-aggregation-Protocol-port] ipv6 netstream export host 40::1 6000
·     ipv6 netstream export source
1.1.9  ipv6 netstream export rate
ipv6 netstream export rate命令用来配置输出速率限制,即限制每秒钟输出的报文数。
undo ipv6 netstream export rate命令用来恢复缺省情况。
ipv6 netstream export rate rate
NetStream统计输出报文的输出速率不受限制。
rate:IPv6 NetStream统计输出报文的输出速率限制,取值范围为1~1000,单位为每秒最多允许输出的报文个数。
当设备每秒生成的IPv6 NetStream报文数量超过限制,设备会将这些报文保存到缓冲区稍候发送。如果设备生成IPv6 NetStream报文速率过快,会导致缓冲区被占满。此时,为避免IPv6 NetStream报文丢失,该命令将暂时失效,设备会尽力发送IPv6 NetStream报文,直到缓冲区能正常工作为止。
# 设置每秒最多允许10个报文被输出。
[Sysname] ipv6 netstream export rate 10
1.1.10  ipv6 netstream export source
ipv6 netstream export source命令用来配置IPv6 NetStream统计输出报文的源接口。
undo ipv6 netstream export source命令用来恢复缺省情况。
ipv6 netstream export source interface interface-type interface-number
采用统计输出报文的出接口作为源接口。
IPv6 NetStream聚合视图
interface-type interface-number:IPv6 NetStream统计输出报文的源接口,由接口类型和接口编号组成。
通过本命令配置源接口后,会将NetStream统计输出报文的源IPv6地址设置为该接口的IPv6地址。
不同聚合视图下可以配置不同的源接口。
聚合视图下若未配置源接口,则使用系统视图下的配置。
建议使用以太网管理接口作为源接口,与服务器相连,并向服务器输出统计信息。
# 将全局IPv6 NetStream统计输出报文源接口设置为GigabitEthernet1/0/1。
[Sysname] ipv6 netstream export source interface gigabitethernet 1/0/1
1.1.11  ipv6 netstream export v9-template refresh-rate packet
ipv6 netstream export v9-template refresh-rate packet命令用来配置IPv6 NetStream统计输出报文版本9模板的包刷新率。
undo ipv6 netstream export v9-template refresh-rate packet命令用来恢复缺省情况。
ipv6 netstream export v9-template refresh-rate packet packets
每隔20个包设备发送一次版本9模板。
packets:IPv6 NetStream统计输出报文版本9模板的包刷新率,取值范围为1~600,单位为上报报文的个数,即每隔多少个包发送一次模板,通知NetStream服务器最新的版本9模版格式。
版本9是基于模板方式的、可支持自定义格式,所以设备上需要定期刷新模板,并通知NetStream服务器最新的版本9模版格式。用户可以根据实际情况,配置版本9模板的包刷新率,及时更新模板。
可以同时配置包刷新率和时间刷新率,只要满足任意一个刷新条件,设备就会将符合条件的模板发送给NetStream服务器。
# 将IPv6 NetStream统计输出报文版本9模板的包刷新率设为100。
[Sysname] ipv6 netstream export v9-template refresh-rate packet 100
·     ipv6 netstream export v9-template refresh-rate time
1.1.12  ipv6 netstream export v9-template refresh-rate time
ipv6 netstream export v9-template refresh-rate time命令用来配置IPv6 NetStream统计输出报文版本9模板的时间刷新率。
undo ipv6 netstream export v9-template refresh-rate time命令用来恢复缺省情况。
ipv6 netstream export v9-template refresh-rate time minutes
每隔30分钟设备发送一次版本9模板。
minutes:IPv6 NetStream统计输出报文版本9模板的时间刷新率,取值范围为1~3600,单位为分钟,即每隔多少分钟更新一次模板,通知NetStream服务器最新的V9模版格式。
V9版本是基于模板方式的、可支持自定义格式,所以设备上需要定期刷新模板,并通知NetStream服务器最新的V9模版格式。用户可以根据实际情况,配置版本9模板的时间刷新率,及时更新模板。
# 将IPv6 NetStream统计输出报文版本9模板的时间刷新率设为60分钟。
[Sysname] ipv6 netstream export v9-template refresh-rate time 60
·     ipv6 netstream export v9-template refresh-rate packet
1.1.13  ipv6 netstream export version 9
ipv6 netstream export version 9命令用来配置IPv6 NetStream版本9。
undo ipv6 netstream export version命令用来恢复缺省情况。
IPv6普通流信息、IPv6聚合统计流信息都通过版本9的NetStream统计输出报文发送。
IPv6 NetStream流信息中会记录流的源IPv6地址、目的IPv6地址。
# 将IPv6 NetStream统计信息输出版本设置为版本9
[Sysname] ipv6 netstream export version 9
1.1.14  ipv6 netstream timeout active
ipv6 netstream timeout active命令用来配置流的活跃老化时间。
undo ipv6 netstream timeout active命令用来恢复缺省情况。
ipv6 netstream timeout active minutes
流的活跃老化时间为30分钟。
minutes:流的活跃老化时间,取值范围为1~60,单位为分钟。
从采集到的第一个报文开始,该流在指定的时间内能被采集到,则该流属于活跃的流,指定的时间称为流的活跃老化时间。
# 将流的活跃老化时间设置为60分钟。
[Sysname] ipv6 netstream timeout active 60
·     ipv6 netstream timeout inactive
1.1.15  ipv6 netstream timeout inactive
ipv6 netstream timeout inactive命令用来配置流的不活跃老化时间。
undo ipv6 netstream timeout inactive命令用来恢复缺省情况。
ipv6 netstream timeout inactive seconds
流的不活跃老化时间为30秒。
seconds:流的不活跃老化时间,取值范围为10~600,单位为秒。
从采集到的最后一个报文开始,该流在指定的时间内没有被采集到,则该流属于不活跃的流,指定的时间称为流的不活跃老化时间。
# 将流的不活跃老化时间设置为60秒。
[Sysname] ipv6 netstream timeout inactive 60
·     ipv6 netstream timeout active
1.1.16  reset ipv6 netstream statistics
reset ipv6 netstream statistics命令用来将流缓存区中所有流强制老化,输出报文信息,并清空IPv6 NetStream缓冲区的状态信息。
在执行清除缓冲区中老化流的动作时,命令行会给出提示,告知用户这个动作可能要持续几分钟,在这段时间内不能统计。
# 将流缓存区中所有流老化,并清空IPv6 NetStream缓冲区的状态信息和输出报文信息。
<Sysname> reset ipv6 netstream statistics
This process may take a few minutes.
NetStream statistic function is disabled during this process.
