H3C XE 200 2000语音服务器 命令手册(V3.02)
03-位置服务器配置命令
本章节下载  (298.45 KB)
03-位置服务器配置命令
第1 Location Server命令... 1-1
1.1 Location Server命令.. 1-1
1.1.1 authentication(LS-GW视图).. 1-1
1.1.2 bearer-capability(LS-GW视图).. 1-1
1.1.3 bearer-capability(LS-OFFICEGROUP-OFFICE视图).. 1-2
1.1.4 call-mode. 1-2
1.1.5 call-signal ip-address. 1-3
1.1.6 call-signal port 1-4
1.1.7 codec(LS-GW-PREFIX视图).. 1-4
1.1.8 codec(LS-GW-SUBSCRIBER视图).. 1-6
1.1.9 codec(LS-GW视图).. 1-7
1.1.10 codec(LS-OFFICEGROUP-OFFICE视图).. 1-8
1.1.11 codec(LS-OFFICEGROUP-PREFIX视图).. 1-9
1.1.12 debugging location-server 1-10
1.1.13 device-status(LS-GW视图).. 1-12
1.1.14 device-status(LS-OFFICEGROUP-OFFICE视图).. 1-12
1.1.15 device-type(LS-GW视图).. 1-13
1.1.16 device-type(LS-OFFICEGROUP-OFFICE视图).. 1-13
1.1.17 display debugging location-server 1-14
1.1.18 display location-server domain. 1-14
1.1.19 display location-server gateway. 1-15
1.1.20 display location-server office-group. 1-18
1.1.21 display location-server process-server 1-19
1.1.22 display location-server statistics. 1-21
1.1.23 display location-server tunnelpeer 1-23
1.1.24 dynamic-ip. 1-24
1.1.25 gateway(LS视图).. 1-25
1.1.26 heartbeat password(LS-PS视图).. 1-26
1.1.27 heartbeat-time-range. 1-26
1.1.28 ip-address(LS-GW视图).. 1-27
1.1.29 ip-address(LS-OFFICEGROUP-OFFICE视图).. 1-27
1.1.30 load-share. 1-28
1.1.31 ls-config. 1-28
1.1.32 manufacturer 1-29
1.1.33 multiplex(LS-GW视图).. 1-30
1.1.34 multiplex(LS-OFFICEGROUP-OFFICE视图).. 1-30
1.1.35 multiplex(LS-PS视图).. 1-31
1.1.36 office. 1-31
1.1.37 office-group. 1-32
1.1.38 otapc. 1-33
1.1.39 password(LS-GW视图).. 1-33
1.1.40 policy random-selection. 1-34
1.1.41 policy select-rule. 1-34
1.1.42 policy anonymous-device-codec. 1-35
1.1.43 policy unknown-device-admission. 1-36
1.1.44 port(LS-GW视图).. 1-37
1.1.45 port(LS-OFFICEGROUP-OFFICE视图).. 1-37
1.1.46 prefix(LS-GW视图).. 1-38
1.1.47 prefix(LS-OFFICEGROUP视图).. 1-39
1.1.48 priority(LS-GW视图).. 1-39
1.1.49 priority(LS-OFFICEGROUP-OFFICE视图).. 1-40
1.1.50 priority(Prefix视图).. 1-40
1.1.51 priority(Subscriber视图).. 1-41
1.1.52 process-server 1-42
1.1.53 psgroup-id(LS-GW视图).. 1-42
1.1.54 psgroup-id(LS-PS视图).. 1-43
1.1.55 register-check-strictly. 1-43
1.1.56 reset location-server statistics. 1-44
1.1.57 start 1-44
1.1.58 stop. 1-45
1.1.59 subscriber 1-45
1.1.60 transport(LS-GW视图).. 1-46
1.1.61 transport(LS-OFFICEGROUP-OFFICE视图).. 1-47
1.1.62 ttl 1-47
1.1.63 userinfoswitch(LS-GW视图/LS-OFFICEGROUP-OFFICE视图).. 1-48
1.1.64 vcx-phone hotline-number 1-48
第2 NAT/FW隧道穿越配置... 2-1
2.1 NAT/FW隧道穿越的配置命令.. 2-1
2.1.1 attribute. 2-1
2.1.2 belongto. 2-1
2.1.3 device-status forever-up attachedps. 2-2
2.1.4 domain. 2-2
2.1.5 nat&fw. 2-3
2.1.6 tunnel 2-3
2.1.7 tunnelpeer 2-4
第1章  Location Server命令
1.1.1  authenticationLS-GW视图)
authentication { disable | enable }
undo authentication
LS-GW视图
disable:设置网关设备不使用鉴权。
enable:设置网关设备使用鉴权。
【描述】
authentication命令用来设置网关设备的鉴权模式。undo authentication命令用来恢复默认配置。
默认情况下,不使用鉴权。
# 设置网关设备“gw01”使用鉴权。
[XE-ls-gw-gw01] authentication enable
1.1.2  bearer-capabilityLS-GW视图)
bearer-capability { audio | video }
undo bearer-capability
LS-GW视图
audio:配置网关承载能力类型为只支持语音。
video:配置网关承载能力类型为支持视频和语音。
【描述】
bearer-capability命令用来配置网关的承载能力类型,即发送给被叫的setup消息的Q.931头中信元Bearer capability的信息支持类型。
缺省情况下,网关的承载能力类型是video类型。
# 配置网关的承载能力类型为audio类型。
[XE-ls-gw-gw001] bearer-capability audio
1.1.3  bearer-capabilityLS-OFFICEGROUP-OFFICE视图)
audio:配置局向设备承载能力类型为只支持语音。
video:配置局向设备承载能力类型为支持视频和语音。
【描述】
bearer-capability命令用来配置局向设备的承载能力类型,即发送给被叫的setup消息的Q.931头中信元Bearer capability的信息支持类型。
缺省情况下,局向设备的承载能力类型是video类型。
# 配置局向设备的承载能力类型为audio类型。
[XE-ls-og-og01 of01] bearer-capability audio
1.1.4  call-mode
call-mode { h323 | sip } { redirect | routed }
undo call-mode { h323 | sip }
LS视图
h323:设置H.323的呼叫模式。
sip:设置SIP的呼叫模式。
redirect:设置位置服务器的呼叫模式为重定向呼叫。
routed:设置位置服务器的呼叫模式为路由呼叫。
【描述】
call-mode命令用来设置位置服务器的呼叫模式。undo call-mode命令用来恢复缺省配置。
缺省情况下,H.323SIP都采用路由呼叫模式。
# 设置位置服务器的呼叫模式为重定向方式。
[XE-ls] call-mode h323 redirect
[XE-ls] call-mode sip redirect
call-signal ip-address ip-address
undo call-signal ip-address
LS-GW视图
ip-address:对呼叫信令的IP地址进行设置。
ip-addressIP地址。
【描述】
call-signal命令用来对位置服务器下的网关设备的呼叫信令进行设置。undo call-signal命令用来恢复默认的呼叫信令设置。
当网关设备不支持动态IP地址上报或管理员在LS-GW视图下使用dynamic-ip disable命令停用动态IP地址上报功能,网关设备的状态为normalforever-up,需要在XE语音服务器上手工配置网关设备的呼叫信令地址,网关设备注册时上报其呼叫信令地址与该地址进行匹配。
缺省情况下,呼叫信令的IP地址由网关设备动态上报。
# 设置网关设备“gw001”的呼叫信令的IP地址为169.254.10.1
[XE-ls-gw-gw001] call-signal ip-address 169.254.10.1
call-signal port port
undo call-signal port
LS-GW视图
port:对呼叫信令的端口号进行设置。
port:端口号,取值范围是1~65535
【描述】
call-signal port命令用来对位置服务器下的网关设备的呼叫信令进行设置。undo call-signal port命令用来恢复默认的呼叫信令设置。
当网关设备不支持动态IP地址上报或管理员在LS-GW视图下使用dynamic-ip disable命令停用动态IP地址上报功能,网关设备的状态为normalforever-up,需要在XE语音服务器上手工配置网关设备的呼叫信令端口号,网关设备注册时上报其呼叫信令端口号与该端口号进行匹配。
缺省情况下,呼叫信令的端口号由网关设备动态上报。
port默认值为1720
# 设置网关设备“gw001”的呼叫信令的端口号为2000
[XE-ls-gw-gw001] call-signal port 2000
1.1.7  codecLS-GW-PREFIX视图)
codec { audio { g7231 | g729 | pcma | pcmu } [ packet-length packet-length ] } | { video { h261 | h263 } } | { data { t38fax | nte { nte-type | invalid } } }undo codec { audio | video | data { nte | t38fax } }
LS-GW-PREFIX视图
audio:配置音频编解码方式。
g7231G.723.1解码方式。
g729G.729解码方式。
pcmaG.711 A-law 64K解码方式。
pcmuG.711 u-law 64K解码方式。
packet-length:编解码的打包时长,取值范围为118,单位为10ms
video:配置视频编解码方式。
h263H263编解码方式。
h261H261编解码方式。
data:配置数据编码方式。
t38fax:支持T38传真。
nte nte-type:数据编码方式支持NTE带外传输模式,nte-type取值范围从96127的整数,默认为101
nte invalid:数据编码方式不支持NTE带外传输模式(消息中不会带NTE字段)。
【描述】
codec命令用来配置Gatekeeper主动向网关设备发起能力协商过程时该用户所采用的编解码方式,如果用户没有配置编解码方式则使用网关配置的编解码方式。undo codec命令用来恢复编解码的缺省配置。
缺省情况下,用户使用网关下配置的编解码方式。
# 配置Gatekeeper主动向网关设备发起能力协商过程时用户8801所采用的编解码方式为G.729,编解码打包时长为40ms,配置其视频编解码方式为H261
[XE-ls-gw-gw000 8801]codec audio g729 packet-length 4
[XE-ls-gw-gw000 8801]codec video h261
1.1.8  codecLS-GW-SUBSCRIBER视图)
LS-GW-SUBSCRIBER视图
audio:配置音频编解码方式。
g7231G.723.1解码方式。
g729G.729解码方式。
video:配置视频编解码方式。
h263H263编解码方式。
h261H261编解码方式。
data:配置数据编码方式。
t38fax:支持T38传真。
【描述】
[XE-ls-gw-gw000 #1 8801]codec audio g729 packet-length 4
[XE-ls-gw-gw000 #1 8801]codec video h261
1.1.9  codecLS-GW视图)
LS-GW视图
audio:配置音频编解码方式。
g7231G.723.1解码方式。
g729G.729解码方式。
video:配置视频编解码方式。
h263H263编解码方式。
h261H261编解码方式。
data:配置数据编码方式。
t38fax:支持T38传真。
【描述】
codec命令用来配置Gatekeeper主动向网关设备发起能力协商过程时所采用的编解码方式。undo codec命令用来恢复编解码的缺省配置。
缺省情况下,网关使用G.729音频编解码方式,编解码的默认打包时长为30ms,不支持视频和传真。
# 配置Gatekeeper主动向网关设备发起能力协商过程时所采用的编解码方式为G.729,编解码打包时长为40ms,配置其视频编解码方式为H261
[XE-ls-gw-gw000]codec audio g729 packet-length 4
[XE-ls-gw-gw000]codec video h261
1.1.10  codecLS-OFFICEGROUP-OFFICE视图)
audio:配置音频编解码方式。
g7231G.723.1解码方式。
g729G.729解码方式。
video:配置视频编解码方式。
h263H263编解码方式。
h261H261编解码方式。
data:配置数据编码方式。
t38fax:支持T38传真。
【描述】
codec命令用来配置Gatekeeper主动向局向设备发起能力协商过程时所采用的编解码方式。undo codec命令用来恢复编解码的缺省配置。
缺省情况下,局向设备使用G.729音频编解码方式,编解码的默认打包时长为30ms,不支持视频和传真。
# 配置Gatekeeper主动向局向设备发起能力协商过程时所采用的编解码方式为G.729,编解码打包时长为40ms,配置其视频编解码方式为H261
[XE-ls-og-og01 off000]codec audio g729 packet-length 4
[XE-ls-og-og01 off000]codec video h261
1.1.11  codecLS-OFFICEGROUP-PREFIX视图)
audio:配置音频编解码方式。
g7231G.723.1解码方式。
g729G.729解码方式。
video:配置视频编解码方式。
h263H263编解码方式。
h261H261编解码方式。
data:配置数据编码方式。
t38fax:支持T38传真。
【描述】
codec命令用来配置Gatekeeper主动向局向设备发起能力协商过程时该用户所采用的编解码方式。undo codec命令用来恢复编解码的缺省配置。
缺省情况下,设备使用当前局向设备下配置的编解码方式。
# 配置Gatekeeper主动向局向设备发起能力协商过程时用户8801所采用的编解码方式为G.729,编解码打包时长为40ms,配置其视频编解码方式为H261
[XE-ls-og-og01 8801]codec audio g729 packet-length 4
[XE-ls-og-og01 8801]codec video h261
debugging location-server { call | heartbeat | register |all } level level-number
undo debugging location-server { call | heartbeat | register |all }
call呼叫类相关的信息。
heartbeat心跳、备份管理和隧道等相关信息。
register注册相关的信息。
all所有调试信息。
level level-number:设置位置服务器的调试级别,取值范围为07。其中0表示关闭调试。
【描述】
debugging location-server命令用来设置位置服务器的调试级别。undo debugging location-server命令用来恢复缺省调试级别。其中call代表呼叫类相关信息,register代表注册类相关信息,heartbeat 代表心跳类相关信息,all则代表同时配置callregisterheartbeat三个模块的调试级别。
取值范围是07,缺省关闭所有级别的调试信息,如果设置为4,则说明打开14级调试信息。如果设置为0,则关闭此项调试信息,用来屏蔽用户暂时不想看到的调试信息。
level级别说明:
0级:关闭调试信息。
1级:DEBUG_LEVEL_EMERGENCY
          内存申请失败
          定时器申请失败
2级:DEBUG_LEVEL_ALERT
          指针为空,非法内存操作
          PSLS之间的连接状态切换信息
3级:DEBUG_LEVEL_ERROR
          控制块状态不正确/不匹配
          控制块索引非法/非期望值
          PID/Module ID非法/非期望值
          函数返回失败,影响主调函数功能
          消息类型非法
4级:DEBUG_LEVEL_WARNING
          函数返回失败,但不影响主调函数功能
          收到信息的消息头信息
          异常定时器超时信息
          状态跃迁信息
5级:DEBUG_LEVEL_NOTIFICATION
          运行正常,但环境有些异常
          关键业务流程信息
          发送消息的消息头信息
6级:DEBUG_LEVEL_INFORMATIONAL
          模块/函数的关键处理流程
          内存申请/释放
          正常定时器超时信息
          MD5算法中重要信息
          哈希算法中重要信息
7级:DEBUG_LEVEL_DEBUGGING
          一般流程信息
          可选IE的提取/添加等相关处理函数
          消息中的IE列表内容/消息内容
          函数入口的调用说明/函数返回值说明
# 设置位置服务器的所有调试级别为5
<XE> debugging location-server all level 5
1.1.13  device-statusLS-GW视图)
device-status { forever-up attachedps ps-id | normal | suspend }
undo device-status
LS-GW视图
forever-up:设置网关设备为永远在线状态。
attachedps:指明该永远在线设备所属的PS
ps-id:该永远在线设备所属PSID
normal:设置网关设备为普通状态。
suspend:设置网关设备为停用状态。
【描述】
device-status命令用来设置网关设备的设备状态。undo device-status命令用来恢复网关设备缺省设备状态。
缺省情况下,设备状态为normal
# 设置网关设备“gw001”设备状态为永远在线,并归属于名为default-psPS下。
[XE-ls-gw-gw001] device-status forever-up attachedps default-ps
1.1.14  device-statusLS-OFFICEGROUP-OFFICE视图)
device-status { forever | normal }
forever:永远在线状态
normal:普通状态
【描述】
device-status命令用来设置局向设备的状态。
缺省情况下,局向设备默认为forever状态。
# 设置局向设备的状态为normal
[XE-ls-og-og01 of1]device-status normal
1.1.15  device-typeLS-GW视图)
device-type { h323 | sip }
undo device-type
LS-GW视图
h323:设置网关设备类型为H.323
sip设置网关设备类型为SIP
【描述】
device-type命令用来设置网关设备类型。undo device-type命令用来恢复默认网关设备类型。
默认管理的网关设备类型是SIP
# 设置网关设备类型为H.323
[XE-ls-gw-gw001] device-type h323
1.1.16  device-typeLS-OFFICEGROUP-OFFICE视图)
device-type { h323-gk | h323-gw | sip }
undo device-type
h323-gk设置局向设备为H.323网守。
h323-gw设置局向设备为H.323网关。
sip设置局向设备为SIP类设备。
【描述】
命令device-type用来设置局向设备的设备类型。命令undo device-type
恢复默认的局向设备类型。
局向设备默认设备类型为SIP类设备。
# 设置局向设备“of1”为H.323网关。
[XE-ls-og-og01 of1] device-type h323-gw
【描述】
display debugging location-server命令用来显示位置服务器调试信息等级。
# 显示位置服务器调试信息等级。
<XE> display debugging location-server
 CALL           debugging level          3
 REGISTER       debugging level          3
 HEARTBEAT      debugging level          3
display location-server domain { domain-id | all }
domain-id:指定要显示的域标识。
All:显示所有域信息。
【描述】
display location-server domain命令用来显示位置服务器上的域信息。
# 显示PublicDomain域的信息。
[XE-ls] display location-server domain PublicDomain
-----------Domain Information -----------
 Domain Identifier:                     PublicDomain
 Domain Attribute:                      public
 process-server list:                   ps0
office-group list:
显示的信息表明,PublicDomain域的属性为public,归属于该域的处理服务器有ps0
display location-server gateway { device-id | all | h323 | sip | list }
all:显示所有网关设备信息。
device-id:指定要显示的网关设备标识。
h323:显示h323网关设备信息。
sip:显示sip网关设备信息。
list:列表显示网关设备标识、设备类型、注册状态和设备状态。
【描述】
display location-server gateway命令用来显示位置服务器上的网关设备信息。
# 显示所有网关设备信息。
<XE> display location-server gateway all
------------ Gateway Information ------------
 Identifier:                    gw02
 LoadShare:                     Disable
 SubsLine:                      4
 PsGroupID:
----------Static Information:
 Device Type:                   SIP-UA
 Ip-address:                    0.0.0.0:5060
 Call Ip-address:               0.0.0.0:1720
 Device Status:                 normal
 Device Manufacturer:           H3C
 Transport:                     udp
 Multiplex:                     disable
 DynamicIp:                     disable
 Subscriber count:              1
 Subscriber List:
                 #2 1002
 Static Alias Number:           0
 Device Priority:               10
 Registration Circle:           180 sec
 Authentication:                disable
 Password:                      GATEWAY
 Area Code Substitute:          enable
 Nation Code:
 Region Code:
----------Dynamic Information:
 Registration Status:           offline
 Registration Transport:        auto
 Dynamic Alias Number:           0
 Dynamic Alias Check Sum:       0
 Resource Can Use:              Yes
 Registration Call Identifier:
 RM handle:                     ffffffff
 CAI handle:                    ffffffff
 Notification Bitmap: Confirm:   1 Reject:   1 Blankout:   1 Challenge:   0
 Indication Bitmap:   Confirm:   0 Reject:   0 Blankout:   0 Challenge:   0
 Attached Process Server:
表1-1 display location-server gateway all显示字段含义
显示字段
含义
Identifier
网关设备标识
LoadShare
负载分担状态
SubsLine
语音用户线容量
PsGroupID
所属PS组标识
Device Type
网关设备类型
Ip-address
网关设备IP地址
Call Ip-address
呼叫信令IP地址
Device Status
网关设备状态
Device Manufacturer
设备制造商信息
Transport
网关设备传输方式
Multiplex
多路复用方式
DynamicIp
是否启用动态IP
Subscriber count
语音用户线号码信息个数
Subscriber List
语音用户线号码信息表
                  #2 1002
短号,长号
Static Alias Number
静态号码路由个数
Static Alias List
静态号码路由表
Device Priority
设备优先级
Registration Circle
注册间隔
Authentication
鉴权模式
Password
鉴权密码
基于地理位置的号码变换状态
Nation Code
国家码
Region Code
地区码
Registration Status
注册状态
注册传输方式
动态号码路由个数
动态号码路由检查总数
Resource Can Use
标识网关资源是否可用
注册呼叫标识
RM handle
注册模块句柄
CAI handle
CAI模块句柄
Notification Bitmap
通知标志位
Indication Bitmap
指示标志位
附属的处理服务器(通过该process-serverlocation-server注册)
display location-server office-group { all | officegroup-id | list }
all:显示所有局向组信息。
officegroup-id:指定要显示的局向组标识。
list:列表显示局向组信息。
【描述】
display location-server office-group命令用来显示位置服务器上的局向组信息。
# 显示所有局向组信息。
[XE-ls-og-og01 off000]display location-serve office-group all
-------------- Office-group Information --------------
 Identifier:                    og01
 Nation Code:
 Region Code:
 Area Code Substitute:          disable
Attached Domain Identifier:    default-domain
 Static Alias Number:           1
 Static Alias List:
  prefix 1...
 Office Number:         1
 Office List:
  office off000
   acct enable
表1-2 display location-server office-group all显示字段含义
显示字段
含义
Identifier
局向组标识
Nation Code
国家码
Region Code
地区码
基于地理位置的号码变换功能是否启用
该局向组所属的域
Static Alias Number
静态号码路由个数
Static Alias List
静态路由号码表
Office Number
局向设备的个数
Office List
局向设备列表
display location-server process-server { all | device-id | list }
all:显示位置服务器管理的所有处理服务器信息。
device-id:指定要显示的处理服务器标识。
list:列表显示PS设备标识和IP地址。
【描述】
display location-server process-server命令用来显示位置服务器管理的处理服务器信息。
# 显示处理服务器“ps0”的信息。
[XE]display location-server process-server ps0
----------- Process Server Information -----------
 Identifier:                    ps0
 RelativeCapability:            1
 Attached SubsLineNumber:       4
 SIP port:                      5060
 RAS port:                      1719
 Process Server Group Identifier:
 Tunnel function:               Disable
 HeartBeat Key:                 XEngine
 Transport:                     auto
 Ip-address:                    172.31.3.24
 Status:                        Authorized
 Attaching Gateway List:
表1-3 display location-server process-server显示字段含义
显示字段
含义
Identifier
处理服务器标识
RelativeCapability
处理服务器的相对能力
处理服务器支持的语音用户线个数
SIP port
处理服务器的SIP端口
RAS port
处理服务器的RAS端口
处理服务器组标识
该处理服务器所属域
Tunnel function
隧道功能是否启用
HeartBeat Key
处理服务器与位置服务器的心跳密码
Transport
处理服务器传输方式
Ip-address
处理服务器 IP地址
Status
处理服务器状态
通过处理服务器上注册的网关设备列表
# 列表显示PS设备标识和IP地址。
[XE-ls] display location-server process-server list
 Identifier                       IP address
 gkserver                         192.168.80.50:13580
【描述】
display location-server statistics命令用来显示位置服务器的统计信息。
# 显示位置服务器的统计信息。
<XE> display location-server statistics
CAI Message Statistics of LS:
   CAI Message                      total  rcv send  err dupr dups disc
            Register Query Device:     0    0    0    0    0    0    0
         Register Response Device:     0    0    0    0    0    0    0
          Register Notify Confirm:     0    0    0    0    0    0    0
           Register Notify Reject:     0    0    0    0    0    0    0
        Register Notify Challenge:     0    0    0    0    0    0    0
Register Indication Device Status:     0    0    0    0    0    0    0
         Register Notify BlankOut:     0    0    0    0    0    0    0
Register Indication Device Update:     0    0    0    0    0    0    0
       Call Query Number Analysis:     0    0    0    0    0    0    0
    Call Response Number Analysis:     0    0    0    0    0    0    0
            Call Notify Ring Back:     0    0    0    0    0    0    0
             Call Notify Redirect:     0    0    0    0    0    0    0
             Call Notify Off Hook:     0    0    0    0    0    0    0
                 Call Notify Talk:     0    0    0    0    0    0    0
              Call Notify Release:     0    0    0    0    0    0    0
     Call Notify Release Complete:     0    0    0    0    0    0    0
            Call Indication Refer:     0    0    0    0    0    0    0
          Call Indication Release:     0    0    0    0    0    0    0
     Call Indication Call Forward:     0    0    0    0    0    0    0
         Connect Notify HeartBeat:     0    0    0    0    0    0    0
     Connect Indication HeartBeat:     0    0    0    0    0    0    0
             Call Query Admission:     0    0    0    0    0    0    0
          Call Response Admission:     0    0    0    0    0    0    0
     Call Notify BandWidth Change:     0    0    0    0    0    0    0
 Call Indication BandWidth Change:     0    0    0    0    0    0    0
                      Invalid CAI:     0    0    0    0    0    0    0
 CAI Distribute Message Statistics of LS:
 CAI Distribute Message               total  rcv send  err dupr dups disc
CAI Distribute Message between PS and RM: 0    0    0    0    0    0    0
CAI Distribute Message between PS and CM: 0    0    0    0    0    0    0
            CAI Distribute Message of LS: 0    0    0    0    0    0    0
                             CAI Release: 0    0    0    0    0    0    0
                          CAI Invalid ID: 0    0    0    0    0    0    0
表1-4 display location-server statistics显示字段含义
显示字段
含义
PS查询设备信息
LS返回被查询设备的信息
通知LS注册成功
通知LS注册失败
Register Notfiy Challenge
通知LSChallenge消息
Register Indication DeviceStatus
LS提示注册状态(成功、失败或重定向)
通知LS注册超时
Register Indication DeviceUpdate
LS提示更新设备配置信息
Call Query NumberAnalysis
PS询问LS进行号码分析
Call Response NumberAnalysis
LS返回号码分析的结果
Call Notify RingBack
PS通知用户回铃
PS通知LS呼叫重定向
Call.Notify OffHook
PS通知被叫用户已经摘机
Call Notify Talk
PS通知用户已经在通话过程
Call Notify Release
通知LS准备拆线
Call Notify ReleaseComplete
通知呼叫释放过程结束
主被叫双方的信息(指示PS向呼叫双方发出邀请)
指示PS断开呼叫
Call Indication CallForward
LS指示触发遇忙前转和无应答前转业务
PSLS发送周期性心跳消息
LSPS发送周期性心跳消息
被叫接入请求
被叫接入请求的响应
带宽变更请求通知
带宽变更请求指示
display location-server tunnelpeer { tunnelpeer-id | all }
tunnelpeer-id:指定要显示的隧道对标识。
All:显示所有隧道对信息。
【描述】
display location-server tunnelpeer命令用来显示位置服务器上的隧道对信息。
# 显示所有隧道对的信息。
[XE-ls] display location-server tunnelpeer all
-------****------ TunnelPeer Information -------****------
 Tunnelpeer Identifier:                 tunnel01
 current state:                         initial
***Private Domain Process Server Information***
 belongto domain:                       PrivateDomain
 map to firewall IP:                    1.1.1.2
 map to firewall port:                  9600
***Public Domain Process Server Information***
 belongto domain:                       PublicDomain
 map to firewall IP:                    192.168.1.22
表1-5 display location-server tunnelpeer显示字段含义
显示字段
含义
隧道对ID
current state
隧道对的当前状态
belongto domain
该隧道对的私网PS所属的域
map to firewall IP
公网PS向私网PS发送IP报文的目的地址,一般为私网PS对应在防火墙上的公网IP地址
公网PS向私网PS发送IP报文的目的端口
belongto domain
该隧道对的公网PS所属的域
map to firewall IP
私网PS向公网PS发送IP报文的目的地址
私网PS向公网PS发送IP报文的目的端口
1.1.24  dynamic-ip
dynamic-ip { disable | enable }
undo dynamic-ip
LS-GW视图
enable允许网关设备的IP地址动态更新。
disable:禁止网关设备的IP地址动态更新。
【描述】
dynamic-ip命令用来设置网关设备IP地址动态更新开关。undo dynamic-ip命令用来恢复默认网关设备IP地址动态更新开关设置。
缺省情况下,禁止网关设备的IP地址动态更新。
&  说明:
l      当使用manufacturer命令配置网关设备的厂商为“other”时,系统将禁止网关设备的IP地址动态更新。
l      使用dynamic-ip命令配置网关设备启用IP地址动态更新后,用户不能使用manufacturer命令更改网关设备的厂商。
l      使用dynamic-ip命令配置网关设备启用IP地址动态更新后,ipportcall-signal ipcall-signal port等命令无效。
# 允许网关设备的IP地址动态更新。
[XE-ls-gw-gw001] dynamic-ip enable
1.1.25  gatewayLS视图)
gateway device-id
undo gateway { device-id | all }
LS视图
device-id网关设备标识,区分大小写。
all:删除所有网关设备。
【描述】
gateway 命令用来添加一个网关设备或进入某个网关设备视图。undo gateway命令用来删除一个或全部网关设备。
&  说明:
用户网络中,所有网关设备、PS设备、局向设备的device-id应保持唯一。
# 添加一个网关设备“gw001”。
[XE-ls] gateway gw001
[XE-ls-gw-gw001]
1.1.26  heartbeat passwordLS-PS视图)
heartbeat password password
undo heartbeat password
LS-PS视图
password:心跳密码,区分大小写,长度为116个字符。
【描述】
heartbeat password命令用来设置位置服务器上的处理服务器的心跳密码。undo heartbeat password命令用来恢复缺省密码。
缺省情况下,密码为"XEngine"
# 设置处理服务器“ps0”心跳密码为“pass1”。
[XE-ls-ps-ps0] heartbeat password pass1
heartbeat-time-range time
undo heartbeat-time-range
LS视图
timeLSPS/MS之间允许的时间差,取值范围是036000秒。
【描述】
heartbeat-time-range命令用来设置LSPS/MS之间允许的时间差。undo heartbeat-time-range命令用来恢复LSPS/MS之间允许的时间差的默认值。
缺省情况下,LSPS/MS之间允许的时间差为0,表示不对时间差进行限制。
# 设置LSPS/MS之间允许的时间差为3600秒。
[XE-ls] heartbeat-time-range 3600
1.1.28  ip-addressLS-GW视图)
undo ip-address
LS-GW视图
ip-addressIP地址。
【描述】
ip-address命令用来设置位置服务器上的网关设备的IP地址。
undo ip-address命令用来恢复缺省IP地址。
缺省情况下,使用IP地址为0.0.0.0
# 设置网关设备“gw001IP地址为192.168.1.33
[XE-ls-gw-gw001] ip-address 192.168.1.33
1.1.29  ip-addressLS-OFFICEGROUP-OFFICE视图)
undo ip-address
ip-addressIP地址。
【描述】
ip-address命令用来设置局向设备的IP地址。undo ip-address命令用来恢复局向设备默认的IP地址。
# 设置局向设备“of1IP地址为192.168.1.33
[XE-ls-og-og01 of1] ip-address 192.168.1.33
1.1.30  load-share
load-share { disable | enable }
undo load-share
LS-GW视图
enable允许网关设备进行负载分担。
disable禁止网关设备进行负载分担。
【描述】
load-share命令用来设置网关设备是否具有负载分担能力。undo load-share命令用来恢复网关默认负载分担设置。
默认状态下,网关设备不具有负载分担能力。
&  说明:
将网关设备设置为不具有负载分担能力的网关设备(即load-share disable),也会对系统负载分担策略产生影响。
# 设置网关设备具有负载分担能力。
[XE-ls-gw-gw0] load-share enable
1.1.31  ls-config
ls-config interface interface-type slot-number [ port port ]
undo ls-config
LS视图
interface:指定接口。
interface-type:接口类型。
slot-number:接口号。
port端口号,取值范围为165535
【描述】
ls-config命令用来设置位置服务器的接口和端口号。undo ls-config命令用来恢复缺省接口和端口号。
缺省情况下,XE200接口为“ethernet 0/0”(XE2000接口为“GigabitEthernet 0/0”),端口号为13579
# 设置位置服务器的接口和端口号。
[XE200-ls] ls-config interface ethernet 0/0 port 12345
1.1.32  manufacturer
manufacturer manufacturer
undo manufacturer
LS-GW视图
manufacturer:厂商名称。
【描述】
manufacturer命令用来设置位置服务器上网关设备的生产商。undo manufacturer命令用来恢复默认的生产商。
缺省情况下,网关设备的生产商为H3C
&  说明:
l      当使用manufacturer命令配置网关设备的厂商为非“H3C”(不区分大小写)时,系统将禁止网关设备的IP地址动态更新。
l      使用dynamic-ip命令配置网关设备启用IP地址动态更新后,用户不能使用manufacturer命令更改网关设备为非“H3C”(不区分大小写)的厂商。
# 设置网关设备“gw001”生产商为other
[XE-ls-gw-gw001] manufacturer other
1.1.33  multiplexLS-GW视图)
multiplex { disable | enable }
undo multiplex
LS-GW视图
disable:不使用多路复用。
enable:使用多路复用。
【描述】
multiplex命令用来设置位置服务器上的网关设备的多路复用模式。
缺省情况下,不使用多路复用。
# 设置网关设备“gw001”使用多路复用模式。
[XE-ls-gw-gw001] multiplex enable
1.1.34  multiplexLS-OFFICEGROUP-OFFICE视图)
undo multiplex
disable:不使用多路复用。
enable:使用多路复用。
【描述】
multiplex命令用来设置位置服务器上局向设备的多路复用模式。
缺省情况下,不使用多路复用。
# 设置局向设备“of1”使用多路复用模式。
[XE-ls-og-og01 of1] multiplex enable
1.1.35  multiplexLS-PS视图)
undo multiplex
LS-PS视图
disable:不使用多路复用。
enable:使用多路复用。
【描述】
multiplex命令用来设置位置服务器上的处理服务器的多路复用模式。
缺省情况下,不使用多路复用。
# 设置处理服务器“ps0”使用多路复用模式。
[XE-ls-ps-ps0] multiplex enable
1.1.36  office
office device-id
undo office { device-id | all }
LS-OFFICEGROUP视图
device-id:局向设备的标识,区分大小写。
all:删除所有局向。
【描述】
如果device-id对应的局向不存在,命令office用来在位置服务器下创建一个新的局向并进入LS-OFFICEGROUP-OFFICE视图,如果device-id对应的局向已经存在,则直接进入其LS-OFFICEGROUP-OFFICE视图。命令undo office命令用来删除局向。
配置局向首先要进入局向视图。
&  说明:
# 进入局向“of1”视图。
[XE-ls-og-og01] office of1
[XE-ls-og-og01 of1]
1.1.37  office-group
office-group office-group-id
undo office-group { office-group-id | all }
LS视图
office-group-id:局向组ID,区分大小写。
all:删除LS下所有局向组
【描述】
office-group命令用来创建一个局向组并进入LS-OFFICEGROUP视图,如果指定的局向组已经存在,则直接进入LS-OFFICEGROUP视图;undo office-group 命令用来删除指定的或所有局向组。
# 创建一个局向组og01,然后进入LS-OFFICEGROUP视图。
[XE2000-ls]office-group og01
[XE2000-ls-og-og01]
1.1.38  otapc
otapc
undo otapc { fxs | relay }
静态路由号码视图
fxs:指定静态路由号码的号码属性为用户号码。
relay:指定静态路由号码的号码属性为中继号码。
【描述】
otapc命令用来配置网关设备下静态路由号码的号码属性。undo otapc命令用来恢复网关设备下静态路由号码的号码属性为缺省属性。
缺省情况下,网关下静态路由号码的号码属性为用户号码。
# 配置网关gw01下静态路由号码9…的号码属性为中继号码。
[XE-ls]gateway gw02
[XE-ls-gw-gw02]prefix 9...
[XE-ls-gw-gw02 9...]otapc relay
1.1.39  passwordLS-GW视图)
password password
undo password
LS-GW视图
password:鉴权密码,长度为116个字符。
【描述】
password命令用来设置位置服务器上网关设备的鉴权密码。undo password命令用来恢复缺省密码。
缺省情况下,网关设备的默认鉴权密码为“GATEWAY”。
# 设置网关设备“gw001"的鉴权密码为“pass1”。
[XE-ls-gw-gw001] password pass1
policy random-selection { enable | disable }
LS视图
random-selection:配置随机号码选择功能。
enable:启用随机号码选择。
disable:停用随机号码选择。
【描述】
policy random-selection enable命令用来启用随机号码选择。policy random-selection disable命令用来停用随机号码选择。
缺省情况下,随机号码选择功能处于enable状态。
# 关闭随机号码选择功能。
[XE-LS] policy random-selection disable
policy select-rule {number-first | priority-first}
undo policy select-rule
LS视图
number-first号码匹配方式为最大长度匹配优先。
priority-first:号码匹配方式为号码优先级优先。
【描述】
policy select-rule 命令用来设置号码匹配方式为最大长度匹配优先或者号码优先级优先。undo policy select-rule用来将号码匹配方式设置为缺省状态。
缺省情况下,号码匹配方式为号码优先级优先。
# 设置号码匹配方式为最大长度匹配优先。
[XE-ls] policy select-rule number-first
[XE-ls]
policy anonymous-device-codec { audio { g7231 | g729 | pcma | pcmu } [ packet-length packet-length ] } | { data { null | t38fax | nte nte-type } } | { video { h261 | h263 | null } }
undo policy anonymous-device-codec { audio | data | video }
LS 视图
audio:配置音频编解码方式。
g7231G.723.1解码方式。
g729G.729解码方式。
packet-length:编解码的打包时长,取值范围为118,单位为10ms,不配置此项则缺省值为30ms
data:配置数据编码方式。
t38fax:支持T38传真。
null:不支持数据。
video:配置视频编解码方式。
h263H263编解码方式。
h261H261编解码方式。
null:不支持视频。
【描述】
policy anonymous-device-codec 命令用来配置匿名设备音频、视频或数据的编解码格式。
undo policy anonymous-device-codec 命令用来取消配置匿名设备音频、视频或数据的编解码格式,使之成为系统默认的编码格式。
在配置音频的编解码格式时,policy anonymous-device-codec audio { g7231 | g729 | pcma | pcmu } pocket-length 命令进一步设置了编码包的长度。
&  说明:
系统默认情况下匿名设备的音频编码格式为G.729 8k,包长度30ms
系统默认情况下数据编解码格式为Null,匿名设备不支持数据格式。
系统默认情况下视频编解码格式为Null,匿名设备不支持视频。
# 设置匿名设备的音频编码格式为G.711A律,并且包长度为50ms
[XE-ls] policy anonymous-device-codec audio pcma packet-length 5
policy unknown-device-admission {enable | disable}
undo policy unknown-device-admission
LS视图
enable:启用接受未知设备请求。
disable:禁用接受未知设备请求。
【描述】
policy unknown-device-admission 命令用来启用或禁用接受未知设备请求功能。命令undo policy unknown-device-admission用来恢复缺省状态。
缺省情况下,启用接受未知设备请求。
# 禁用接受未知设备请求功能。
[XE-ls]policy unknown-device-admission disable
[XE-ls]
1.1.44  portLS-GW视图)
port port
undo port
LS-GW视图
port:端口号,取值范围为165535,默认值为5060
【描述】
port命令用来设置位置服务器上网关设备的端口号。undo port命令用来恢复缺省端口。
H.323建议和SIP协议中规定的网关设备缺省端口号如下:
H.323网关设备端口号为:1719
SIP网关设备(User-Agent)端口号为:5060
# 设置网关设备“gw001”的端口号为1234
[XE-ls-gw-gw001] port 1234
1.1.45  portLS-OFFICEGROUP-OFFICE视图)
port port
undo port
【描述】
port命令用来设置位置服务器上局向设备的端口号,取值范围为165535undo port命令用来恢复缺省端口。
&  说明:
此端口号的默认值是5060,在dynamic-ip disable状态下,当设置网关设备类型为sip时,不需要更改端口号,当设置网关设备类型为h323-gw时,需要使用port命令配置端口号为1720,当设置网关设备类型为h323-gk时,需要使用port命令配置端口号为1719
# 设置局向设备“of1”的端口号为1720
[XE-ls-og-og01 of1] port 1720
1.1.46  prefixLS-GW视图)
prefix number
undo prefix { number | all }
LS-GW视图
number:静态路由号码,长度为131个字符,取值范围09ABCD*#
all:删除所有路由号码。
【描述】
prefix命令用来配置一条静态路由号码并进入静态路由号码视图。undo prefix命令用来删除网关设备下的静态路由号码。
# 在网关设备gw01下配置静态路由号码8801
[XE2000-ls-gw-gw01] prefix 8801
[XE2000-ls-gw-gw01 8801]
1.1.47  prefixLS-OFFICEGROUP视图)
prefix number
LS-OFFICEGROUP视图
all:删除所有路由号码。
【描述】
prefix命令用来配置一条静态路由号码并进入静态路由号码视图。undo prefix命令用来删除局向组下的静态路由号码。
# 在局向组og01下配置静态路由号码8803
[XE2000-ls-og-og01] prefix 8803
[XE2000-ls-og-og01 8803]
1.1.48  priorityLS-GW视图)
priority level
undo priority
LS-GW视图
level:网关设备的优先级,取值范围为01000,缺省为10
【描述】
priority命令用来设置位置服务器上的网关设备的优先级。undo priority命令用来恢复缺省优先级。数字越大,优先级越高。
缺省情况下,优先级为10
# 设置网关设备“gw001”优先级为11
[XE-ls-gw-gw001] priority 11
1.1.49  priorityLS-OFFICEGROUP-OFFICE视图)
priority priority-level
undo priority
level局向设备的优先级取值范围为01000。缺省为10
【描述】
priority命令用来设置位置服务器上的局向的优先级。undo priority命令用来恢复缺省优先级。数字越大,优先级越高。
缺省情况下,优先级为10
# 设置局向“of1”优先级为11
[XE-ls-og-og01 of1] priority 11
1.1.50  priorityPrefix视图)
undo priority
Prefix视图
level静态路由号码的优先级取值范围为01000。缺省情况下,使用网关的优先级。
【描述】
priority命令用来设置位置服务器上的静态路由号码的优先级。undo priority命令用来恢复缺省优先级。数字越大,优先级越高。
缺省情况下,静态路由号码使用网关设备或局向设备的优先级,请参考命令priorityLS-GW视图)。
# 设置静态路由号码1101的优先级为11
[XE2000-ls-gw-gw01] prefix 1101
[XE2000-ls-gw-gw01 1101] priority 11
1.1.51  prioritySubscriber视图)
undo priority
subscriber视图
level语音用户线号码信息的优先级取值范围为01000。缺省情况下,使用网关的优先级。
【描述】
priority命令用来设置位置服务器上的语音用户线号码信息的优先级。undo priority命令用来恢复缺省优先级。数字越大,优先级越高。
缺省情况下,语音用户线号码信息使用网关设备的优先级,请参考命令priorityLS-GW视图)。
# 设置语音用户线号码信息#01 9901的优先级为11
[XE-ls-gw-gw01] subscriber #01 9901
[XE-ls-gw-gw01 #01 9901] priority 11
process-server device-id
undo process-server { device-id | all }
LS视图
device-id:处理服务器的标识,区分大小写。
all:删除所有处理服务器。
【描述】
process-server命令用来增加一个PS,并进入位置服务器下的LS-PS视图,如果该PS已经存在则直接进入该PS对应的LS-PS视图。命令undo process-server命令用来删除位置服务器下的处理服务器。如果有永久在线网关隶属于此处理服务器,不允许删除该处理服务器,必须先修改网关状态。
配置处理服务器首先要进入LS-PS视图。
&  说明:
# 进入处理服务器“ps0”视图。
[XE-ls] process-server ps0
[XE-ls-ps-ps0]
1.1.53  psgroup-idLS-GW视图)
psgroup-id group-id  [master-ps ps-id ]
undo psgroup-id
LS-GW视图
group-id:网关设备归属的PS组标识,取值范围是132个字符。
master-ps:指明网关设备所属的PS组中的主用处理服务器。
ps-id:网关设备注册时使用的主用处理服务器的ID
【描述】
psgroup-id命令用来设置网关设备归属的PS组,并指定使用的主用处理服务器。undo psgroup-id命令用来恢复缺省PS组。
缺省情况下,网关设备不属于任何PS组。
# 设置网关设备gw0归属于PS组“group1”,并指定主要处理服务器为masterProcessServer
[XE-ls-gw-gw0] psgroup-id group1 master-ps masterProcessServer
1.1.54  psgroup-idLS-PS视图)
psgroup-id group-id
undo psgroup-id
LS-PS视图
group-id:处理服务器归属的PS组标识,取值范围是132个字符。
【描述】
psgroup-id命令用来设置处理服务器归属的PS组。undo psgroup-id命令用来恢复缺省PS组。
缺省情况下,处理服务器不属于任何PS组。
# 设置处理服务器ps0归属于PS组“group1”。
[XE-ls-ps-ps0] psgroup-id group1
register-check-strictly { disable | enable }
LS-GW视图
【描述】
register-check-strictly命令用来在网关设备下是否启用注册严格匹配策略。
缺省情况下,未起用注册严格匹配策略。
# 对于网关设备gw0,下面所有的号码配置都是语音用户线号码,配置注册严格匹配策略开启。
[XE-ls-gw-gw0] register-check-strictly enable
【描述】
reset location-server statistics命令用来清除位置服务器的统计信息,即清除使用display location-server statistics命令显示的位置服务器的信息。
# 清除位置服务器的统计信息。
<XE> reset location-server statistics
1.1.57  start
start
LS视图
【描述】
命令start用来启动位置服务器。
缺省情况下,未启动位置服务器。
# 启动位置服务器。
[XE-ls] start
1.1.58  stop
stop
LS视图
【描述】
命令stop用来停止位置服务器。
# 停止位置服务器。
[XE-ls] stop
1.1.59  subscriber
subscriber short-number long-number
undo subscriber { short-number long-number | all }
LS-GW视图
short-number:语音用户线号码信息短号,起始字母为“#”,取值范围是031,字符串长度为23位(包含“#”)。
long-number:语音用户线号码信息长号,取值范围是数字09*#,字母ABCD,号码长度为131位。
all:所有语音用户线号码信息。
【描述】
subscriber命令用来设置位置服务器上网关设备语音用户线号码信息。undo subscriber命令用来删除网关设备语音用户线号码信息。
# 在网关设备“gw001”增加一条语音用户线号码信息,短号为“#31”,长号为“68835641”。
[XE-ls-gw-gw001] subscriber #31 68835641
[XE-ls-gw-gw01 #31 68835641]
# 为上述长号为“68835641”的用户再增加一条语音用户线号码信息(多被叫),其短号为“#11”。
[XE-ls-gw-gw01 #31 68835641] quit
[XE-ls-gw-gw01]subscriber #11 68835641
[XE-ls-gw-gw01 #11 68835641]
1.1.60  transportLS-GW视图)
transport { auto | tcp | udp }
undo transport
LS-GW视图
auto自动选择传输方式。
tcpTCP方式。
udpUDP方式。
【描述】
transport命令用来设置位置服务器上的网关设备的传输方式。undo transport命令用来恢复缺省传输方式。
缺省情况下,采用UDP方式。
# 设置网关设备“gw001”传输方式为TCP
[XE-ls-gw-gw001] transport tcp
1.1.61  transportLS-OFFICEGROUP-OFFICE视图)
undo transport
auto自动选择传输方式。
tcpTCP方式。
udpUDP方式。
【描述】
transport命令用来设置位置服务器上的局向设备的传输方式。undo transport命令用来恢复缺省传输方式。
缺省情况下,采用UDP方式。
# 设置局向“of1”传输方式为TCP
[XE-ls-og-og01 of1] transport tcp
1.1.62  ttl
ttl time-length
undo ttl
LS-GW视图
time-length:有效时间长度,取值范围为1065535,单位为秒。
默认值为180秒。
【描述】
ttl命令用来设置位置服务器上网关设备的注册信息的有效时间。undo ttl命令用来恢复默认的有效时间。
# 设置网关设备gw001注册信息有效时间为200秒。
[XE-ls-gw-gw001] ttl 200
1.1.63  userinfoswitchLS-GW视图/LS-OFFICEGROUP-OFFICE视图)
userinfoswitch { open | close }
undo userinfoswitch
open:用户号码信息(,*)转换开关打开。
close用户号码信息(,*)转换开关关闭。
【描述】
userinfoswitch标志对设备的用户交互信息,是否需要进行转换的开关。此开关只用在“,*”之间的相互转换。
缺省情况下,用户号码信息(,*)转换开关为关闭状态。
# 在网关gw01下打开用户号码信息(,*)转换开关。
[XE-ls-gw-gw01]userinfoswitch open
vcx-phone hotline-number number
undo vcx-phone hotline-number
LS-GW视图
number设置热线号码,取值范围为131位阿拉伯数字。
【描述】
vcx-phone hotline-number命令用来在网关设备下设置热线号码同时启用热线功能。
undo vcx-phone hotline-number命令用来删除热线号码同时将热线功能设为默认的不启用状态。
# 为名称ep302EP302话机设备配置热线号码1001,此电话摘机后自动呼叫号码1001
[XE-ls-gw-ep302] vcx-phone hotline-number 1001
第2章  NAT/FW隧道穿越配置
2.1  NAT/FW隧道穿越的配置命令
2.1.1  attribute
attribute {private | public}
undo attribute
LS-DOMAIN视图
private:私网内的域,
public:公网内的域。
【描述】
attribute命令用来设置域属于私网或公网,undo attribute命令用来删除该域属性设置。
# 配置domain001域为私网内的域。
[XE-ls-domain-domain001] attribute private
2.1.2  belongto
belongto domain-id
undo belongto
LS-PS视图
LS-OFFICEGROUP视图
domain-id:指定PS或局向组所属的域标识。
【描述】
belongto命令用来配置PS设备或局向组所归属的域,undo belongto命令用来恢复PS设备或局向组所属的域为default-domain域。
缺省情况下,PS和局向组属于default-domain域。
# 配置ps0归属于domain001域。
[XE-ls-ps-ps0] belongto domain001
device-status forever-up attachedps ps-id
LS-GW视图
ps-id:网关设备所属的PSID
【描述】
本命令用来配置永久在线网关设备所属的PS的信息。
# 配置永久在线网关gw01属于ps01
[XE-ls-gw-gw01] device-status forever-up attachedps ps01
2.1.4  domain
domain domain-id
undo domain { domain-id | all } [ no-confirm ]
LS视图
domain-id:指定新创建的、或要进入的、或要删除的域标识,区分大小写。
all:删除所有的域。
no-confirm:删除域时无需用户确认。
【描述】
如果没有域标识为domain-id的域,本命令用来创建一个域,如果已经有域标识为domain-id的域,本命令用来进入此域视图。undo domain命令用来删除所有的域或指定的域,同时删除归属于该域的所有局向设备。
# 创建一个新的域。
[XE-ls] domain domain001
# 删除一个域。
[XE-ls] undo domain domain001
NOTICE:This command will delete all offices belonged to the domain! Continue?[Y/N]:y
Delete Domain domain001
# 无需用户确认直接删除一个域。
[XE-ls]undo domain domain002 no-confirm
Delete Domain domain002
[XE-ls]
2.1.5  nat&fw
nat&fw
LS视图
【描述】
本命令用来进入LS-NAT&FW视图。
# 进入LS-NAT&FW视图。
[XE-ls] nat&fw
2.1.6  tunnel
tunnel { enable | disable }
undo tunnel
LS-PS视图
enable:启用该PSNAT/FW隧道穿越功能,
disable:停用该PSNAT/FW隧道穿越功能。
【描述】
tunnel命令用来设置PS是否具有NAT/FW隧道穿越功能。undo tunnel命令用来恢复隧道穿越功能使能配置为默认配置。
缺省情况下,默认为停用PSNAT/FW隧道穿越功能。
# 启用PS0设备的NAT/FW隧道穿越功能。
[XE-ls-ps-ps0] tunnel enable
2.1.7  tunnelpeer
tunnelpeer tunnelpeer-id private private-ps-id private-to-public-add port private-to-public-port public public-ps-id public-to-private-add  port public-to-private-port
undo tunnelpeer { tunnelpeer-id | all }
LS-NAT&FW视图
tunnelpeer-id:要创建的隧道对标识
private-ps-id:私网PS的标识
private-to-public-add:私网PS向公网PS发送IP报文的目的地址。
private-to-public-port:私网PS向公网PS发送IP报文的目的端口。
public-ps-id:公网PS的标识
public-to-private-add:公网PS向私网PS发送IP报文的目的地址,一般为私网PS对应在防火墙上的公网IP地址。
public-to-private-port:公网PS向私网PS发送IP报文的目的端口,一般为私网PS对应的防火墙端口
【描述】
tunnelpeer命令配置一个隧道对,即一个私网PS和一个公网PS穿过防火墙的对应关系。undo tunnelpeer用来删除所有的或指定的隧道对。
# PS0位于私网内,其IP192.168.1.2PS1位于公网上,其IP220.10.10.2,公私网之间采用NAT,公网地址对于私网来说是可见的,在私网PS0和公网PS1之间建立隧道对,其服务端口均使用11998PS0在防火墙上映射到公网上的地址为:220.10.10.1,端口为11998
[XE-ls-nat&fw] tunnelpeer tunnelpeer01 private PS0 220.10.10.2 port 11998 public PS1 220.10.10.1 port 11998
