H3C S5500-SI系列以太网交换机 命令手册(V1.01)
14-组播协议命令
本章节下载  (278.38 KB)
14-组播协议命令
第1章 IGMP Snooping配置命令
1.1 IGMP Snooping配置命令
1.1.1 display igmp-snooping group
1.1.2 display igmp-snooping statistics
1.1.3 fast-leave
1.1.4 group-policy
1.1.5 host-aging-time
1.1.6 igmp-snooping
1.1.7 igmp-snooping drop-unknown
1.1.8 igmp-snooping enable
1.1.9 igmp-snooping fast-leave
1.1.10 igmp-snooping general-query source-ip
1.1.11 igmp-snooping group-limit
1.1.12 igmp-snooping group-policy
1.1.13 igmp-snooping host-aging-time
1.1.14 igmp-snooping host-join
1.1.15 igmp-snooping last-member-query-interval
1.1.16 igmp-snooping max-response-time
1.1.17 igmp-snooping overflow-replace
1.1.18 igmp-snooping querier
1.1.19 igmp-snooping query-interval
1.1.20 igmp-snooping router-aging-time
1.1.21 igmp-snooping source-deny
1.1.22 igmp-snooping special-query source-ip
1.1.23 igmp-snooping static-group
1.1.24 igmp-snooping static-router-port
1.1.25 igmp-snooping version
1.1.26 last-member-query-interval
1.1.27 max-response-time
1.1.28 overflow-replace
1.1.29 report-aggregation
1.1.30 reset igmp-snooping group
1.1.31 reset igmp-snooping statistics
1.1.32 router-aging-time
1.1.33 source-deny
第2章 MLD Snooping配置命令
2.1 MLD Snooping配置命令
2.1.1 display mld-snooping group
2.1.2 display mld-snooping statistics
2.1.3 fast-leave
2.1.4 group-policy
2.1.5 host-aging-time
2.1.6 last-listener-query-interval
2.1.7 max-response-time
2.1.8 mld-snooping
2.1.9 mld-snooping drop-unknown
2.1.10 mld-snooping enable
2.1.11 mld-snooping fast-leave
2.1.12 mld-snooping general-query source-ip
2.1.13 mld-snooping group-limit
2.1.14 mld-snooping group-policy
2.1.15 mld-snooping host-aging-time
2.1.16 mld-snooping host-join
2.1.17 mld-snooping last-listener-query-interval
2.1.18 mld-snooping max-response-time
2.1.19 mld-snooping overflow-replace
2.1.20 mld-snooping querier
2.1.21 mld-snooping query-interval
2.1.22 mld-snooping router-aging-time
2.1.23 mld-snooping source-deny
2.1.24 mld-snooping special-query source-ip
2.1.25 mld-snooping static-group
2.1.26 mld-snooping static-router-port
2.1.27 mld-snooping version
2.1.28 overflow-replace
2.1.29 report-aggregation
2.1.30 reset mld-snooping group
2.1.31 reset mld-snooping statistics
2.1.32 router-aging-time
2.1.33 source-deny
第3章 组播VLAN配置命令
3.1 组播VLAN配置命令
3.1.1 display multicast-vlan
3.1.2 multicast-vlan enable
3.1.3 multicast-vlan subvlan
第4章 IPv6组播VLAN配置命令
4.1 IPv6组播VLAN配置命令
4.1.1 display multicast-vlan ipv6
4.1.2 multicast-vlan ipv6 enable
4.1.3 multicast-vlan ipv6 subvlan
display igmp-snooping group [ vlan vlan-id ] [ verbose ]
vlan vlan-id:查看指定VLAN内的IGMP Snooping转发表项信息。vlan-id为指定VLAN的编号,取值范围为1~4094。
verbose:查看IGMP Snooping转发表项的详细信息。
【描述】
display igmp-snooping group命令用来查看IGMP Snooping转发表项信息。
如果不指定VLAN,将显示所有VLAN内IGMP Snooping转发表项信息。
# 查看VLAN 2内IGMP Snooping转发表项的详细信息。
<Sysname> display igmp-snooping group vlan 2 verbose
    Total 1 IP Group(s).
    Total 1 IP Source(s).
    Total 1 MAC Group(s).
  Port flags: D-Dynamic port, S-Static port, A-Aggregation port, C-Copy port
  Subvlan flags: R-Real VLAN, C-Copy VLAN
  Vlan(id):2.
    Router port(s):total 1 port.
            GE1/0/2               (D) ( 00:01:30 )
    IP group(s):the following ip group(s) match to one mac group.
      IP group address:224.1.1.1
        (1.1.1.1, 224.1.1.1):
          Attribute:    Host Port
          Host port(s):total 1 port.
            GE1/0/1               (D) ( 00:03:23 )
    MAC group(s):
      MAC group address:0100-5e01-0101
            GE1/0/1
表1-1 display igmp-snooping group命令显示信息描述表
IP组播组的数量
IP组播源的数量
MAC组播组的数量
端口标志:D代表动态端口,S代表静态端口,A代表汇聚端口,C代表由(*,G)表项拷贝到(S,G)下的端口
子VLAN标志:R代表本表项下的真实出口子VLAN,C代表由(*,G)表项拷贝到(S,G)表项下的出口子VLAN
Router port(s)
路由器端口数量
IP group address
IP组播组的地址
MAC group address
MAC组播组的地址
Attribute
IP组播组的属性
Host port(s)
主机成员端口数量
无
【描述】
display igmp-snooping statistics命令用来查看IGMP Snooping窥探到的IGMP报文的统计信息。
# 查看IGMP Snooping窥探到的IGMP报文的统计信息。
<Sysname> display igmp-snooping statistics
  Received IGMP general queries:0.
  Received IGMPv1 reports:0.
  Received IGMPv2 reports:19.
  Received IGMP leaves:0.
  Received IGMPv2 specific queries:0.
  Sent     IGMPv2 specific queries:0.
  Received IGMPv3 reports:1.
  Received IGMPv3 reports with right and wrong records:0.
  Received IGMPv3 specific queries:0.
  Received IGMPv3 specific sg queries:0.
  Sent     IGMPv3 specific queries:0.
  Sent     IGMPv3 specific sg queries:0.
  Received error IGMP messages:19.
表1-2 display igmp-snooping statistics命令显示信息描述表
general queries
普遍组查询报文
specific queries
特定组查询报文
reports
报告报文
leaves
离开报文
包含错误和正确纪录的报告报文
specific sg queries
特定源组查询报文
error IGMP messages
错误的IGMP报文
1.1.3  fast-leave
fast-leave [ vlan vlan-list ]
undo fast-leave [ vlan vlan-list ]
IGMP-Snooping视图
vlan vlan-list:在指定VLAN内配置端口快速离开功能。vlan-list为VLAN列表,表示多个VLAN。其表示方式为vlan-list = { vlan-id [ to vlan-id ] }&<1-10>,其中,vlan-id为指定VLAN的编号,取值范围为1~4094。&<1-10>表示前面的参数最多可以输入10次。
【描述】
fast-leave命令用来全局使能端口快速离开功能。undo fast-leave命令用来全局关闭端口快速离开功能。
缺省情况下,端口快速离开功能处于关闭状态。
如果不指定VLAN,则该配置将对所有VLAN有效;如果指定了VLAN,则该配置只对指定VLAN有效。
相关配置可参考命令igmp-snooping fast-leave。
# 使能VLAN 2内的端口快速离开功能。
[Sysname] igmp-snooping
[Sysname-igmp-snooping] fast-leave vlan 2
1.1.4  group-policy
group-policy acl-number [ vlan vlan-list ]
undo group-policy [ vlan vlan-list ]
IGMP-Snooping视图
acl-number:指定基本访问控制列表编号,取值范围为2000~2999。
vlan vlan-list:在指定VLAN内配置组播组过滤器。vlan-list为VLAN列表,表示多个VLAN。其表示方式为vlan-list = { vlan-id [ to vlan-id ] }&<1-10>,其中,vlan-id为指定VLAN的编号,取值范围为1~4094。&<1-10>表示前面的参数最多可以输入10次。
【描述】
group-policy命令用来配置全局组播组过滤器。undo group-policy命令用来关闭全局组播组过滤器。
缺省情况下,没有配置全局组播组过滤器,即主机可以加入任一组播组。
l              如果不指定VLAN,则该配置将对所有VLAN有效;如果指定了VLAN,则该配置只对指定VLAN有效。
l              当指定的ACL不存在或者其规则为空时,将过滤掉所有的组播组。
l              可以为端口在不同的VLAN内配置不同的ACL规则,但在相同VLAN内所配置的新规则会取代旧规则。
相关配置可参考命令igmp-snooping group-policy。
# 配置ACL 2000为VLAN 2内的组播组过滤器。
[Sysname-igmp-snooping] group-policy 2000 vlan 2
host-aging-time interval
undo host-aging-time
IGMP-Snooping视图
interval:成员端口的老化时间,取值范围为200~1000,单位为秒。
【描述】
host-aging-time命令用来全局配置成员端口的老化时间。undo host-aging-time命令用来恢复缺省情况。
缺省情况下,成员端口的老化时间为260秒。
本命令只对使能了IGMP Snooping的VLAN有效,而对相应VLAN接口上使能了IGMP的VLAN无效。
相关配置可参考命令igmp-snooping host-aging-time。
# 全局配置成员端口的老化时间为300秒。
[Sysname-igmp-snooping] host-aging-time 300
1.1.6  igmp-snooping
igmp-snooping
undo igmp-snooping
无
【描述】
igmp-snooping命令用来全局使能IGMP Snooping,并进入IGMP-Snooping视图。undo igmp-snooping命令用来全局关闭IGMP Snooping。
缺省情况下,IGMP Snooping处于关闭状态。
相关配置可参考命令igmp-snooping enable。
# 全局使能IGMP Snooping,并进入IGMP-Snooping视图。
undo igmp-snooping drop-unknown
VLAN视图
无
【描述】
igmp-snooping drop-unknown命令用来在VLAN内使能丢弃未知组播数据报文的功能。undo igmp-snooping drop-unknown命令用来在VLAN内关闭丢弃未知组播数据报文的功能。
缺省情况下,丢弃未知组播数据报文的功能处于关闭状态,即对未知组播数据报文进行广播。
只有在VLAN内使能了IGMP Snooping后,本命令才能生效。
# 在VLAN 2内使能丢弃未知组播数据报文的功能。
[Sysname] vlan 2
[Sysname-vlan2] igmp-snooping drop-unknown
undo igmp-snooping enable
VLAN视图
无
【描述】
igmp-snooping enable命令用来在VLAN内使能IGMP Snooping。undo igmp-snooping enable命令用来在VLAN内关闭IGMP Snooping。
缺省情况下,VLAN内的IGMP Snooping处于关闭状态。
在VLAN内使能IGMP Snooping之前,必须先全局使能IGMP Snooping,否则将无法在VLAN内使能IGMP Snooping。
相关配置可参考命令igmp-snooping。
# 在VLAN 2内使能IGMP Snooping。
[Sysname-igmp-snooping] quit
[Sysname] vlan 2
[Sysname-vlan2] igmp-snooping enable
igmp-snooping fast-leave [ vlan vlan-list ]
undo igmp-snooping fast-leave [ vlan vlan-list ]
以太网端口视图/端口组视图
【描述】
igmp-snooping fast-leave命令用来在端口上使能端口快速离开功能。undo igmp-snooping fast-leave命令用来在端口上关闭端口快速离开功能。
l              如果在以太网端口视图下配置时不指定VLAN,则不论该端口属于哪个VLAN,该配置都有效;如果指定了VLAN,则只有当该端口属于指定VLAN时,该配置才有效。
l              如果在手工端口组视图下配置时不指定VLAN,则不论端口组内的各端口分别属于哪些VLAN,该配置对该端口组内的所有端口都有效;如果指定了VLAN,则该配置只对该端口组内属于指定VLAN的那些端口有效。
l              聚合端口组视图下的配置只对其主端口有效,而对非主端口无效。如果在聚合端口组视图下配置时不指定VLAN,则不论其主端口属于哪个VLAN,该配置都有效;如果指定了VLAN,则只有当其主端口属于指定VLAN时,该配置才有效。
相关配置可参考命令fast-leave。
# 在GigabitGigabitEthernet1/0/1上使能端口快速离开功能,GigabitGigabitEthernet1/0/1属于VLAN 2。
[Sysname-GigabitGigabitEthernet1/0/1] igmp-snooping fast-leave vlan 2
igmp-snooping general-query source-ip { current-interface | ip-address }
undo igmp-snooping general-query source-ip
VLAN视图
current-interface:指定当前VLAN接口的IP地址作为IGMP普遍组查询报文的源IP地址。如果当前VLAN的接口没有IP地址,则采用缺省的IP地址0.0.0.0作为IGMP普遍组查询报文的源IP地址。
ip-address:指定任意合法IP地址作为发送IGMP普遍组查询报文时的源IP地址。
【描述】
igmp-snooping general-query source-ip命令用来配置IGMP普遍组查询报文的源IP地址。undo igmp-snooping general-query source-ip命令用来恢复缺省情况。
缺省情况下,IGMP普遍组查询报文的源IP地址为0.0.0.0。
# VLAN 2接口的IP地址为10.1.1.1,子网掩码为255.255.255.0,指定其作为IGMP普遍组查询报文的源IP地址。
[Sysname-Vlan-interface2] ip address 10.1.1.1 255.255.255.0
[Sysname-Vlan-interface2] quit
[Sysname] vlan 2
[Sysname-vlan2] igmp-snooping general-query source-ip current-interface
igmp-snooping group-limit limit [ vlan vlan-list ]
undo igmp-snooping group-limit [ vlan vlan-list ]
以太网端口视图/端口组视图
limit:允许端口加入的组播组最大数量,取值范围为1~128。
vlan vlan-list:在指定VLAN内允许端口加入的组播组最大数量。vlan-list为VLAN列表,表示多个VLAN。其表示方式为vlan-list = { vlan-id [ to vlan-id ] }&<1-10>,其中,vlan-id为指定VLAN的编号,取值范围为1~4094。&<1-10>表示前面的参数最多可以输入10次。如果不指定本参数,则本配置将对端口所属的每个VLAN分别生效,即对允许端口加入的组播组最大数量在其所属的每个VLAN内分别进行限制。
【描述】
igmp-snooping group-limit命令用来配置允许端口加入的组播组最大数量。undo igmp-snooping group-limit命令用来恢复缺省情况。
缺省情况下,允许端口加入的组播组最大数量为128。
l              如果在以太网端口视图下配置时不指定VLAN,则不论端口属于哪个VLAN,该配置对这个端口都有效;如果指定了VLAN,则只有当该端口属于指定VLAN时,该配置对这个端口才有效。
l              如果在端口组视图下配置时不指定VLAN,则不论端口组内的各端口分别属于哪些VLAN,该配置对该端口组内的所有端口都有效;如果指定了VLAN,则该配置只对该端口组内属于指定VLAN的那些端口有效。
# 配置允许端口GigabitGigabitEthernet1/0/1在VLAN 2内加入的组播组最大数量为10个,GigabitEthernet1/0/1属于VLAN 2。
[Sysname-GigabitEthernet1/0/1] igmp-snooping group-limit 10 vlan 2
igmp-snooping group-policy acl-number [ vlan vlan-list ]
undo igmp-snooping group-policy [ vlan vlan-list ]
以太网端口视图/端口组视图
【描述】
igmp-snooping group-policy命令用来在端口上配置组播组过滤器。undo igmp-snooping group-policy命令用来在端口上关闭组播组过滤器。
缺省情况下,端口上没有配置组播组过滤器,即主机可以加入任一组播组。
相关配置可参考命令group-policy。
# 在GigabitEthernet1/0/1上将ACL 2000配置为组播组过滤器,GigabitEthernet1/0/1属于VLAN 2。
[Sysname-GigabitEthernet1/0/1] igmp-snooping group-policy 2000 vlan 2
igmp-snooping host-aging-time interval
undo igmp-snooping host-aging-time
VLAN视图
【描述】
igmp-snooping host-aging-time命令用来在VLAN内配置成员端口的老化时间。undo igmp-snooping host-aging-time命令用来恢复缺省情况。
相关配置可参考命令host-aging-time。
# 在VLAN 2内配置成员端口的老化时间为300秒。
[Sysname] vlan 2
[Sysname-vlan2] igmp-snooping host-aging-time 300
igmp-snooping host-join group-address [ source-ip source-address ] vlan vlan-id
undo igmp-snooping host-join group-address [ source-ip source-address ] vlan vlan-id
以太网端口视图/端口组视图
group-address:模拟主机要加入的组播组的地址,取值范围为224.0.1.0~239.255.255.255。
source-address:模拟主机要加入的组播源的地址,取值为有效的单播地址或0.0.0.0。如果取值为0.0.0.0,表示不指定组播源。
vlan vlan-id:指定以太网端口所属的VLAN。vlan-id为指定VLAN的编号,取值范围为1~4094。
【描述】
igmp-snooping host-join命令用来使能模拟主机加入组播组或组播源组的功能。undo igmp-snooping host-join命令用来关闭模拟主机加入组播组或组播源组的功能。
缺省情况下,模拟主机加入组播组或组播源组的功能处于关闭状态。
l              本命令对使能了IGMP Snooping的VLAN或相应VLAN接口上使能了IGMP的VLAN都有效,且模拟主机所采用的IGMP版本与VLAN内的IGMP Snooping或VLAN接口上的IGMP版本保持一致。
l              只有当IGMP Snooping的版本为3时,配置参数source-ip source-address才会有实际的意义;当IGMP Snooping的版本为2时,虽然也可以配置参数source-ip source-address,但模拟主机在收到查询报文时并不会进行响应。
l              在以太网端口视图下进行配置时,只有当该端口属于指定VLAN时,该配置对这个端口才有效。
l              在端口组视图下进行配置时,该配置只对该端口组内属于指定VLAN的那些端口有效。
# 在GigabitEthernet1/0/1上使能模拟主机加入组播源组的功能,该以太网端口属于VLAN 2,要加入的组播源为1.1.1.1,要加入的组播组为224.1.1.1。
[Sysname] vlan 2
[Sysname-vlan2] igmp-snooping version 3
[Sysname-vlan2] quit
[Sysname-GigabitEthernet1/0/1] igmp-snooping host-join 224.1.1.1 source-ip 1.1.1.1 vlan 2
igmp-snooping last-member-query-interval interval
undo igmp-snooping last-member-query-interval
VLAN视图
interval:发送IGMP特定组查询报文的时间间隔,取值范围为1~5,单位为秒。
【描述】
igmp-snooping last-member-query-interval命令用来在VLAN内配置发送IGMP特定组查询报文的时间间隔。undo igmp-snooping last-member-query-interval命令用来恢复缺省情况。
缺省情况下,发送IGMP特定组查询报文的时间间隔为1秒。
相关配置可参考命令last-member-query-interval。
# 在VLAN 2内配置发送IGMP特定组查询报文的时间间隔为3秒。
[Sysname] vlan 2
[Sysname-vlan2] igmp-snooping last-member-query-interval 3
igmp-snooping max-response-time interval
undo igmp-snooping max-response-time
VLAN视图
interval:IGMP普遍组查询的最大响应时间,取值范围为1~25,单位为秒。
【描述】
igmp-snooping max-response-time命令用来在VLAN内配置IGMP普遍组查询的最大响应时间。undo igmp-snooping max-response-time命令用来恢复缺省情况。
缺省情况下,IGMP普遍组查询的最大响应时间为10秒。
相关配置可参考命令max-response-time和igmp-snooping query-interval。
# 在VLAN 2内配置IGMP普遍组查询的最大响应时间为5秒。
[Sysname] vlan 2
[Sysname-vlan2] igmp-snooping max-response-time 5
igmp-snooping overflow-replace [ vlan vlan-list ]
undo igmp-snooping overflow-replace [ vlan vlan-list ]
以太网端口视图/端口组视图
vlan vlan-list:在指定VLAN内配置组播组替换功能。vlan-list为VLAN列表,表示多个VLAN。其表示方式为vlan-list = { vlan-id [ to vlan-id ] }&<1-10>,其中,vlan-id为指定VLAN的编号,取值范围为1~4094。&<1-10>表示前面的参数最多可以输入10次。
【描述】
igmp-snooping overflow-replace命令用来在端口上使能组播组替换功能。undo igmp-snooping overflow-replace命令用来关闭端口上的组播组替换功能。
缺省情况下,组播组替换功能处于关闭状态。
相关配置可参考命令overflow-replace。
# 在GigabitEthernet1/0/1上使能组播组替换功能,GigabitEthernet1/0/1属于VLAN 2。
[Sysname-GigabitEthernet1/0/1] igmp-snooping overflow-replace vlan 2
undo igmp-snooping querier
VLAN视图
无
【描述】
igmp-snooping querier命令用来使能IGMP Snooping查询器。undo igmp-snooping querier命令用来关闭IGMP Snooping查询器。
缺省情况下,IGMP Snooping查询器处于关闭状态。
# 在VLAN 2内使能IGMP Snooping查询器。
[Sysname] vlan 2
[Sysname-vlan2] igmp-snooping querier
igmp-snooping query-interval interval
undo igmp-snooping query-interval
VLAN视图
interval:发送IGMP普遍组查询报文的时间间隔,取值范围为2~300,单位为秒。
【描述】
igmp-snooping query-interval命令用来配置发送IGMP普遍组查询报文的时间间隔。undo igmp-snooping query-interval命令用来恢复缺省情况。
缺省情况下,发送IGMP普遍组查询报文的时间间隔为60秒。
相关配置可参考命令igmp-snooping querier、igmp-snooping max-response-time和max-response-time。
# 在VLAN 2内配置发送IGMP普遍组查询报文的时间间隔为20秒。
[Sysname] vlan 2
[Sysname-vlan2] igmp-snooping query-interval 20
igmp-snooping router-aging-time interval
undo igmp-snooping router-aging-time
VLAN视图
interval:路由器端口的老化时间,取值范围为1~1000,单位为秒。
【描述】
igmp-snooping router-aging-time命令用来在VLAN内配置路由器端口的老化时间。undo igmp-snooping router-aging-time命令用来恢复缺省情况。
缺省情况下,路由器端口的老化时间为105秒。
相关配置可参考命令router-aging-time。
# 在VLAN 2内配置路由器端口的老化时间为100秒。
[Sysname] vlan 2
[Sysname-vlan2] igmp-snooping router-aging-time 100
undo igmp-snooping source-deny
以太网端口口视图/端口组视图
无
【描述】
igmp-snooping source-deny命令用来使能组播数据报文源端口过滤功能。undo igmp-snooping source-deny命令用来关闭组播数据报文源端口过滤功能。
缺省情况下,组播数据报文源端口过滤功能处于关闭状态。
# 在GigabitEthernet1/0/1上使能组播数据报文源端口过滤功能。
[Sysname] interface GigabitEthernet1/0/1
[Sysname- GigabitEthernet1/0/1] igmp-snooping source-deny
igmp-snooping special-query source-ip { current-interface | ip-address }
undo igmp-snooping special-query source-ip
VLAN视图
current-interface:指定当前VLAN接口的IP地址作为IGMP特定组查询报文的源IP地址。如果当前VLAN的接口没有IP地址,则采用缺省的IP地址0.0.0.0作为IGMP特定组查询报文的源IP地址。
ip-address:指定IP地址作为发送IGMP特定组查询报文时的源IP地址。
【描述】
igmp-snooping special-query source-ip命令用来配置IGMP特定组查询报文的源IP地址。undo igmp-snooping special-query source-ip命令用来恢复缺省情况。
缺省情况下,IGMP特定组查询报文的源IP地址为0.0.0.0。
# VLAN 2接口的IP地址为10.1.1.1,子网掩码为255.255.255.0,指定其作为IGMP特定组查询报文的源IP地址。
[Sysname] vlan 2
[Sysname-vlan2] igmp-snooping special-query source-ip current-interface
igmp-snooping static-group group-address [ source-ip source-address ] vlan vlan-id
undo igmp-snooping static-group group-address [ source-ip source-address ] vlan vlan-id
以太网端口视图/端口组视图
group-address:静态加入的组播组地址,取值范围为224.0.1.0~239.255.255.255。
source-address:静态加入的组播源地址,取值为有效的单播地址或0.0.0.0。如果取值为0.0.0.0,表示不指定组播源。
【描述】
igmp-snooping static-group命令用来使能静态成员端口,即静态加入组播组或组播源组的功能。undo igmp-snooping static-group命令用来关闭静态成员端口功能。
缺省情况下,静态成员端口功能处于关闭状态。
l              只有当IGMP Snooping的版本为3时,配置参数source-ip source-address才会有实际的意义;当IGMP Snooping的版本为2时,虽然也可以配置参数source-ip source-address,但该配置将不能生效。
# 在GigabitEthernet1/0/1上使能静态加入组播源组的功能,该以太网端口属于VLAN 2,要加入的组播源为1.1.1.1,要加入的组播组为224.1.1.1。
[Sysname] vlan 2
[Sysname-GigabitEthernet1/0/1] igmp-snooping static-group 224.1.1.1 source-ip 1.1.1.1 vlan 2
igmp-snooping static-router-port vlan vlan-id
undo igmp-snooping static-router-port vlan vlan-id
以太网端口视图/端口组视图
vlan vlan-id:在指定VLAN内配置静态路由器端口。vlan-id为指定VLAN的编号,取值范围为1~4094。
【描述】
igmp-snooping static-router-port命令用来使能静态路由器端口功能。undo igmp-snooping static-router-port命令用来关闭静态路由器端口功能。
缺省情况下,静态路由器端口功能处于关闭状态。
# 在GigabitEthernet1/0/1上使能静态路由器端口功能,该端口属于VLAN 2。
[Sysname-GigabitEthernet1/0/1] igmp-snooping static-router-port vlan 2
igmp-snooping version version-number
undo igmp-snooping version
VLAN视图
version-number:表示IGMP Snooping的版本号,取值范围为2~3。
【描述】
igmp-snooping version命令用来配置IGMP Snooping的版本。undo igmp-snooping version命令用来恢复缺省情况。
缺省情况下,IGMP Snooping的版本为2。
# 在VLAN 2内使能IGMP Snooping,并将其版本配置为3。
[Sysname] vlan 2
undo last-member-query-interval
IGMP-Snooping视图
【描述】
last-member-query-interval命令用来全局配置发送IGMP特定组查询报文的时间间隔。undo last-member-query-interval命令用来恢复缺省情况。
相关配置可参考命令igmp-snooping last-member-query-interval。
# 全局配置发送IGMP特定组查询报文的时间间隔为3秒。
[Sysname-igmp-snooping] last-member-query-interval 3
undo max-response-time
IGMP-Snooping视图
【描述】
max-response-time命令用来全局配置IGMP普遍组查询的最大响应时间。undo max-response-time命令用来恢复缺省情况。
相关配置可参考命令igmp-snooping max-response-time和igmp-snooping query-interval。
# 全局配置IGMP普遍组查询的最大响应时间为5秒。
[Sysname-igmp-snooping] max-response-time 5
undo overflow-replace [ vlan vlan-list ]
IGMP-Snooping视图
【描述】
overflow-replace命令用来全局使能组播组替换功能。undo overflow-replace命令用来全局关闭组播组替换功能。
相关配置可参考命令igmp-snooping overflow-replace。
# 在VLAN 2内全局使能组播组替换功能。
[Sysname-igmp-snooping] overflow-replace vlan 2
report-aggregation
undo report-aggregation
IGMP-Snooping视图
无
【描述】
report-aggregation命令用来使能IGMP成员关系报告报文抑制功能。undo report-aggregation命令用来关闭IGMP成员关系报告报文抑制功能。
缺省情况下,IGMP成员关系报告报文抑制功能处于使能状态。
# 关闭IGMP成员关系报告报文抑制功能。
[Sysname-igmp-snooping] undo report-aggregation
reset igmp-snooping group { group-address | all } [ vlan vlan-id ]
group-address:清除指定组播组对应的IGMP Snooping转发表项信息,取值范围为224.0.1.0~239.255.255.255。
all:清除所有IGMP Snooping转发表项的信息。
vlan vlan-id:清除指定VLAN内的IGMP Snooping转发表项信息。vlan-id为指定VLAN的编号,取值范围为1~4094。
【描述】
reset igmp-snooping group命令用来清除IGMP Snooping转发表项信息。
l              本命令只对使能了IGMP Snooping的VLAN有效,而对相应VLAN接口上使能了IGMP的VLAN无效。
l              通过本命令不能够清除通过配置以静态方式加入的IGMP Snooping转发表项。
# 清除交换机保存的所有IGMP Snooping转发表项信息。
<Sysname> reset igmp-snooping group all
无
【描述】
reset igmp-snooping statistics命令用来清除IGMP Snooping窥探到的所有IGMP报文的统计信息。
# 清除IGMP Snooping窥探到的所有IGMP报文的统计信息。
<Sysname> reset igmp-snooping statistics
undo router-aging-time
IGMP-Snooping视图
【描述】
router-aging-time命令用来全局配置路由器端口的老化时间。undo router-aging-time命令用来恢复缺省情况。
相关配置可参考命令igmp-snooping router-aging-time。
# 全局配置路由器端口的老化时间为100秒。
[Sysname-igmp-snooping] router-aging-time 100
1.1.33  source-deny
undo source-deny port interface-list
IGMP-Snooping视图
interface-list:以太网端口列表,表示一个或多个以太网端口。表示方式为interface-list = { interface-type interface-number [ to interface-type interface-number ] }。其中,interface-type为接口类型,interface-number为接口编号。
【描述】
source-deny命令用来使能组播数据报文源端口过滤功能,即过滤掉所有收到的组播数据报文。undo source-deny命令用来关闭组播数据报文源端口过滤功能。
# 使能从GigabitEthernet1/0/1到 GigabitEthernet1/0/5上的组播数据报文源端口过滤功能。
[Sysname-igmp-snooping] source-deny port GigabitEthernet1/0/1 to GigabitEthernet1/0/5
display mld-snooping group [ vlan vlan-id ] [ verbose ]
vlan vlan-id:查看指定VLAN内的MLD Snooping转发表项信息。vlan-id为指定VLAN的编号,取值范围为1~4094。
verbose:查看MLD Snooping转发表项的详细信息。
【描述】
display mld-snooping group命令用来查看MLD Snooping转发表项信息。
如果不指定VLAN,将显示所有VLAN内的MLD Snooping转发表项信息。
# 查看VLAN 2内MLD Snooping转发表项的详细信息。
<Sysname> display mld-snooping group vlan 2 verbose
  Vlan(id):2.
      IP group address:FF1E::101
        (::, FF1E::101):
    MAC group(s):
        MAC group address:3333-0000-0101
            GE1/0/1
表2-1 display mld-snooping group命令显示信息描述表
IPv6组播组的数量
IPv6组播源的数量
MAC组播组的数量
Router port(s)
路由器端口数量
IP group address
IPv6组播组的地址
MAC group address
MAC组播组的地址
Attribute
IPv6组播组的属性
Host port(s)
主机成员端口数量
无
【描述】
display mld-snooping statistics命令用来查看MLD Snooping窥探到的MLD报文的统计信息。
# 查看MLD Snooping窥探到的所有MLD报文的统计信息。
<Sysname> display mld-snooping statistics
  Received MLD general queries:0.
  Received MLDv1 specific queries:0.
  Received MLDv1 reports:0.
  Received MLD dones:0.
  Sent     MLDv1 specific queries:0.
  Received MLDv2 reports:0.
  Received MLDv2 reports with right and wrong records:0.
  Received MLDv2 specific queries:0.
  Received MLDv2 specific sg queries:0.
  Sent     MLDv2 specific queries:0.
  Sent     MLDv2 specific sg queries:0.
  Received error MLD messages:0.
表2-2 display mld-snooping statistics命令显示信息描述表
general queries
普遍组查询报文
specific queries
特定组查询报文
reports
报告报文
dones
离开报文
包含错误和正确纪录的报告报文
specific sg queries
特定源组查询报文
error MLD messages
错误的MLD报文
2.1.3  fast-leave
MLD-Snooping视图
【描述】
相关配置可参考命令mld-snooping fast-leave。
[Sysname] mld-snooping
[Sysname-mld-snooping] fast-leave vlan 2
2.1.4  group-policy
group-policy acl6-number [ vlan vlan-list ]
MLD-Snooping视图
acl6-number:指定基本IPv6访问控制列表编号,取值范围为2000~2999。
vlan vlan-list:在指定VLAN内配置IPv6组播组过滤器。vlan-list为VLAN列表,表示多个VLAN。其表示方式为vlan-list = { vlan-id [ to vlan-id ] }&<1-10>,其中,vlan-id为指定VLAN的编号,取值范围为1~4094。&<1-10>表示前面的参数最多可以输入10次。
【描述】
group-policy命令用来配置全局IPv6组播组过滤器。undo group-policy命令用来关闭全局IPv6组播组过滤器。
缺省情况下,没有配置全局IPv6组播组过滤器,即主机可以加入任一IPv6组播组。
l              当指定的IPv6 ACL不存在或者其规则为空时,将过滤掉所有的IPv6组播组。
l              可以为端口在不同的VLAN内配置不同的IPv6 ACL规则,但在相同VLAN内所配置的新规则会取代旧规则。
相关配置可参考命令mld-snooping group-policy。
# 配置ACL 2000为VLAN 2内的IPv6组播组过滤器。
[Sysname-mld-snooping] group-policy 2000 vlan 2
MLD-Snooping视图
【描述】
相关配置可参考命令mld-snooping host-aging-time。
[Sysname-mld-snooping] host-aging-time 300
undo last-listener-query-interval
MLD-Snooping视图
interval:发送MLD特定组查询报文的时间间隔,取值范围为1~5,单位为秒。
【描述】
last-listener-query-interval命令用来全局配置发送MLD特定组查询报文的时间间隔。undo last-listener-query-interval命令用来恢复缺省情况。
缺省情况下,发送MLD特定组查询报文的时间间隔为1秒。
相关配置可参考命令mld-snooping last-listener-query-interval。
# 全局配置发送MLD特定组查询报文的时间间隔为3秒。
[Sysname-mld-snooping] last-listener-query-interval 3
MLD-Snooping视图
interval:MLD普遍组查询的最大响应时间,取值范围为1~25,单位为秒。
【描述】
max-response-time命令用来全局配置MLD普遍组查询的最大响应时间。undo max-response-time命令用来恢复缺省情况。
缺省情况下,MLD普遍组查询的最大响应时间为10秒。
相关配置可参考命令mld-snooping max-response-time和mld-snooping query-interval。
# 全局配置MLD普遍组查询的最大响应时间为5秒。
[Sysname-mld-snooping] max-response-time 5
2.1.8  mld-snooping
mld-snooping
undo mld-snooping
无
【描述】
mld-snooping命令用来全局使能MLD Snooping,并进入MLD-Snooping视图。undo mld-snooping命令用来全局关闭MLD Snooping。
缺省情况下,MLD Snooping处于关闭状态。
相关配置可参考命令mld-snooping enable。
# 全局使能MLD Snooping,并进入MLD-Snooping视图。
undo mld-snooping drop-unknown
VLAN视图
无
【描述】
mld-snooping drop-unknown命令用来在VLAN内使能丢弃未知IPv6组播数据报文的功能。undo mld-snooping drop-unknown命令用来在VLAN内关闭丢弃未知IPv6组播数据报文的功能。
缺省情况下,丢弃未知IPv6组播数据报文的功能处于关闭状态,即对未知IPv6组播数据报文进行广播。
只有在VLAN内使能了MLD Snooping后,本命令才能生效。
# 在VLAN 2内使能丢弃未知IPv6组播数据报文的功能。
[Sysname] vlan 2
[Sysname-vlan2] mld-snooping drop-unknown
mld-snooping enable
undo mld-snooping enable
VLAN视图
无
【描述】
mld-snooping enable命令用来在VLAN内使能MLD Snooping。undo mld-snooping enable命令用来在VLAN内关闭MLD Snooping。
缺省情况下,VLAN内的MLD Snooping处于关闭状态。
在VLAN内使能MLD Snooping之前,必须先全局使能MLD Snooping,否则将无法在VLAN内使能MLD Snooping。
相关配置可参考命令mld-snooping。
# 在VLAN 2内使能MLD Snooping。
[Sysname-mld-snooping] quit
[Sysname] vlan 2
[Sysname-vlan2] mld-snooping enable
undo mld-snooping fast-leave [ vlan vlan-list ]
以太网端口视图/端口组视图
【描述】
mld-snooping fast-leave命令用来在端口上使能端口快速离开功能。undo mld-snooping fast-leave命令用来在端口上关闭端口快速离开功能。
# 在GigabitEthernet1/0/1上使能端口快速离开功能,GigabitEthernet1/0/1属于VLAN 2。
[Sysname-GigabitEthernet1/0/1] mld-snooping fast-leave vlan 2
mld-snooping general-query source-ip { current-interface | ipv6-address }
undo mld-snooping general-query source-ip
VLAN视图
current-interface:指定当前VLAN接口的IPv6链路本地地址作为MLD普遍组查询报文的源IPv6地址。如果当前VLAN的接口没有IPv6地址,则采用缺省的IPv6地址FE80::02FF:FFFF:FE00:0001作为MLD普遍组查询报文的源IPv6地址。
ipv6-address:指定合法的IPv6链路本地地址作为发送MLD普遍组查询报文时的源IPv6地址。
【描述】
mld-snooping general-query source-ip命令用来配置MLD普遍组查询报文的源IPv6地址。undo mld-snooping general-query source-ip命令用来恢复缺省情况。
缺省情况下,MLD普遍组查询报文的源IPv6地址为FE80::02FF:FFFF:FE00:0001。
# 在VLAN 2内,指定FE80:0:0:1::1作为MLD普遍组查询报文的源IPv6地址。
[Sysname] vlan 2
[Sysname-vlan2] mld-snooping general-query source-ip fe80:0:0:1::1
undo mld-snooping group-limit [ vlan vlan-list ]
以太网端口视图/端口组视图
limit:允许端口加入的IPv6组播组最大数量,取值范围为1~128。
vlan vlan-list:在指定VLAN内允许端口加入的IPv6组播组最大数量。vlan-list为VLAN列表,表示多个VLAN。其表示方式为vlan-list = { vlan-id [ to vlan-id ] }&<1-10>,其中,vlan-id为指定VLAN的编号,取值范围为1~4094。&<1-10>表示前面的参数最多可以输入10次。如果不指定本参数,则本配置将对端口所属的每个VLAN分别生效,即对允许端口加入的IPv6组播组最大数量在其所属的每个VLAN内分别进行限制。
【描述】
mld-snooping group-limit命令用来配置允许端口加入的IPv6组播组最大数量。undo mld-snooping group-limit命令用来恢复缺省情况。
缺省情况下,允许端口加入的IPv6组播组最大数量为512。
# 配置允许端口GigabitEthernet1/0/1在VLAN 2内加入的IPv6组播组最大数量为10个,GigabitEthernet1/0/1属于VLAN 2。
[Sysname-GigabitEthernet1/0/1] mld-snooping group-limit 10 vlan 2
mld-snooping group-policy acl6-number [ vlan vlan-list ]
undo mld-snooping group-policy [ vlan vlan-list ]
以太网端口视图/端口组视图
【描述】
mld-snooping group-policy命令用来在端口上配置IPv6组播组过滤器。undo mld-snooping group-policy命令用来在端口上关闭IPv6组播组过滤器。
缺省情况下,端口上没有配置IPv6组播组过滤器,即主机可以加入任一IPv6组播组。
# 在GigabitEthernet1/0/1上将ACL 2000配置为IPv6组播组过滤器,GigabitEthernet1/0/1属于VLAN 2。
[Sysname-GigabitEthernet1/0/1] mld-snooping group-policy 2000 vlan 2
mld-snooping host-aging-time interval
undo mld-snooping host-aging-time
VLAN视图
【描述】
mld-snooping host-aging-time命令用来在VLAN内配置成员端口的老化时间。undo mld-snooping host-aging-time命令用来恢复缺省情况。
[Sysname] vlan 2
[Sysname-vlan2] mld-snooping host-aging-time 300
undo mld-snooping host-join ipv6-group-address [ source-ip ipv6-source-address ] vlan vlan-id
以太网端口视图/端口组视图
ipv6-group-address:模拟主机要加入的IPv6组播组的地址,取值范围为FFxy::/16(但不包括下列地址:FFx0::/16、FFx1::/16、FFx2::/16和FF0y::),其中x和y均代表0~F的任意一个十六进制数。
ipv6-source-address:模拟主机要加入的IPv6组播源的地址。
【描述】
mld-snooping host-join命令用来使能模拟主机加入IPv6组播组或IPv6组播源组的功能。undo mld-snooping host-join命令用来关闭模拟主机加入IPv6组播组或IPv6组播源组的功能。
缺省情况下,模拟主机加入IPv6组播组或IPv6组播源组的功能处于关闭状态。
l              只有当MLD Snooping的版本为2时,配置参数source-ip ipv6-source-address才会有实际的意义;当MLD Snooping的版本为1时,虽然也可以配置参数source-ip ipv6-source-address,但模拟主机在收到查询报文时并不会进行响应。
# 在GigabitEthernet1/0/1上使能模拟主机加入IPv6组播源组的功能,该以太网端口属于VLAN 2,要加入的IPv6组播源为2002::22,要加入的IPv6组播组为FF1E::101。
[Sysname] vlan 2
[Sysname-vlan2] mld-snooping version 2
[Sysname-GigabitEthernet1/0/1] mld-snooping host-join ff1e::101 source-ip 2002::22 vlan 2
undo mld-snooping last-listener-query-interval
VLAN视图
【描述】
mld-snooping last-listener-query-interval命令用来在VLAN内配置发送MLD特定组查询报文的时间间隔。undo mld-snooping last-listener-query-interval命令用来恢复缺省情况。
相关配置可参考命令last-listener-query-interval。
# 在VLAN 2内配置发送MLD特定组查询报文的时间间隔为3秒。
[Sysname] vlan 2
[Sysname-vlan2] mld-snooping last-listener-query-interval 3
mld-snooping max-response-time interval
undo mld-snooping max-response-time
VLAN视图
【描述】
mld-snooping max-response-time命令用来在VLAN内配置MLD普遍组查询的最大响应时间。undo mld-snooping max-response-time命令用来恢复缺省情况。
相关配置可参考命令max-response-time和mld-snooping query-interval。
# 在VLAN 2内配置MLD普遍组查询的最大响应时间为5秒。
[Sysname] vlan 2
[Sysname-vlan2] mld-snooping max-response-time 5
undo mld-snooping overflow-replace [ vlan vlan-list ]
以太网端口视图/端口组视图
vlan vlan-list:在指定VLAN内配置IPv6组播组替换功能。vlan-list为VLAN列表,表示多个VLAN。其表示方式为vlan-list = { vlan-id [ to vlan-id ] }&<1-10>,其中,vlan-id为指定VLAN的编号,取值范围为1~4094。&<1-10>表示前面的参数最多可以输入10次。
【描述】
mld-snooping overflow-replace命令用来在端口上使能IPv6组播组替换功能。undo mld-snooping overflow-replace命令用来关闭端口上的IPv6组播组替换功能。
缺省情况下,IPv6组播组替换功能处于关闭状态。
# 在GigabitEthernet1/0/1上使能IPv6组播组替换功能,GigabitEthernet1/0/1属于VLAN 2。
[Sysname-GigabitEthernet1/0/1] mld-snooping overflow-replace vlan 2
undo mld-snooping querier
VLAN视图
无
【描述】
mld-snooping querier命令用来使能MLD Snooping查询器。undo mld-snooping querier命令用来关闭MLD Snooping查询器。
缺省情况下,MLD Snooping查询器处于关闭状态。
# 在VLAN 2内使能MLD Snooping查询器。
[Sysname] vlan 2
[Sysname-vlan2] mld-snooping querier
undo mld-snooping query-interval
VLAN视图
interval:发送MLD普遍组查询报文的时间间隔,取值范围为2~300,单位为秒。
【描述】
mld-snooping query-interval命令用来配置发送MLD普遍组查询报文的时间间隔。undo mld-snooping query-interval命令用来恢复缺省情况。
缺省情况下,发送MLD普遍组查询报文的时间间隔为125秒。
相关配置可参考命令mld-snooping querier、mld-snooping max-response-time和max-response-time。
# 在VLAN 2内配置发送MLD普遍组查询报文的时间间隔为20秒。
[Sysname] vlan 2
[Sysname-vlan2] mld-snooping query-interval 20
mld-snooping router-aging-time interval
undo mld-snooping router-aging-time
VLAN视图
【描述】
mld-snooping router-aging-time命令用来在VLAN内配置路由器端口的老化时间。undo mld-snooping router-aging-time命令用来恢复缺省情况。
缺省情况下,路由器端口的老化时间为260秒。
[Sysname] vlan 2
[Sysname-vlan2] mld-snooping router-aging-time 100
undo mld-snooping source-deny
以太网接口视图/端口组视图
无
【描述】
mld-snooping source-deny命令用来使能IPv6组播数据报文源端口过滤功能。undo mld-snooping source-deny命令用来关闭IPv6组播数据报文源端口过滤功能。
缺省情况下,IPv6组播数据报文源端口过滤功能处于关闭状态。
# 在GigabitEthernet1/0/1上使能IPv6组播数据报文源端口过滤功能。
[Sysname- GigabitEthernet1/0/1] mld-snooping source-deny
mld-snooping special-query source-ip { current-interface | ipv6-address }
undo mld-snooping special-query source-ip
VLAN视图
current-interface:指定当前VLAN接口的IPv6链路本地地址作为MLD特定组查询报文的源IPv6地址。如果当前VLAN的接口没有IPv6地址,则采用缺省的IPv6地址FE80::02FF:FFFF:FE00:0001作为MLD特定组查询报文的源IPv6地址。
ipv6-address:指定合法的IPv6链路本地地址作为发送MLD特定组查询报文时的源IPv6地址。
【描述】
mld-snooping special-query source-ip命令用来配置MLD特定组查询报文的源IPv6地址。undo mld-snooping special-query source-ip命令用来恢复缺省情况。
缺省情况下,MLD特定组查询报文的源IPv6地址为FE80::02FF:FFFF:FE00:0001。
# 在VLAN 2内,指定FE80:0:0:1::1作为MLD特定组查询报文的源IPv6地址。
[Sysname] vlan 2
[Sysname-vlan2] mld-snooping special-query source-ip fe80:0:0:1::1
undo mld-snooping static-group ipv6-group-address [ source-ip ipv6-source-address ] vlan vlan-id
以太网端口视图/端口组视图
ipv6-group-address:静态加入的IPv6组播组地址,取值范围为FFxy::/16(但不包括下列地址:FFx0::/16、FFx1::/16、FFx2::/16和FF0y::),其中x和y均代表0~F的任意一个十六进制数。
ipv6-source-address:静态加入的IPv6组播源地址。
【描述】
mld-snooping static-group命令用来使能静态成员端口,即静态加入IPv6组播组或IPv6组播源组的功能。undo mld-snooping static-group命令用来关闭静态成员端口功能。
l              只有当MLD Snooping的版本为2时,配置参数source-ip ipv6-source-address才会有实际的意义;当MLD Snooping的版本为1时,虽然也可以配置参数source-ip ipv6-source-address,但该配置将不能生效。
# 在GigabitEthernet1/0/1上使能静态加入IPv6组播源组的功能,该以太网端口属于VLAN 2,要加入的IPv6组播源为2002::22,要加入的IPv6组播组为FF1E::101。
[Sysname] vlan 2
[Sysname-GigabitEthernet1/0/1] mld-snooping static-group ff1e::101 source-ip 2002::22 vlan 2
undo mld-snooping static-router-port vlan vlan-id
以太网端口视图/端口组视图
【描述】
mld-snooping static-router-port命令用来使能静态路由器端口功能。undo mld-snooping static-router-port命令用来关闭静态路由器端口功能。
[Sysname-GigabitEthernet1/0/1] mld-snooping static-router-port vlan 2
undo mld-snooping version
VLAN视图
version-number:表示MLD Snooping的版本号,取值范围为1~2。
【描述】
mld-snooping version命令用来配置MLD Snooping的版本。undo mld-snooping version命令用来恢复缺省情况。
缺省情况下,MLD Snooping的版本为1。
# 在VLAN 2内使能MLD Snooping,并将其版本配置为2。
[Sysname] vlan 2
MLD-Snooping视图
【描述】
overflow-replace命令用来全局使能IPv6组播组替换功能。undo overflow-replace命令用来全局关闭IPv6组播组替换功能。
相关配置可参考命令mld-snooping overflow-replace。
# 在VLAN 2内全局使能IPv6组播组替换功能。
[Sysname-mld-snooping] overflow-replace vlan 2
report-aggregation
MLD-Snooping视图
无
【描述】
report-aggregation命令用来使能MLD成员关系报告报文抑制功能。undo report-aggregation命令用来关闭MLD成员关系报告报文抑制功能。
缺省情况下,MLD成员关系报告报文抑制功能处于使能状态。
# 关闭MLD成员关系报告报文抑制功能。
[Sysname-mld-snooping] undo report-aggregation
reset mld-snooping group { ipv6-group-address | all } [ vlan vlan-id ]
ipv6-group-address:清除指定IPv6组播组对应的MLD Snooping转发表项信息,取值范围为FFxy::/16(但不包括下列地址:FFx0::/16、FFx1::/16、FFx2::/16和FF0y::),其中x和y均代表0~F的任意一个十六进制数。
all:清除所有MLD Snooping转发表项的信息。
vlan vlan-id:清除指定VLAN内的MLD Snooping转发表项信息。vlan-id为指定VLAN的编号,取值范围为1~4094。
【描述】
reset mld-snooping group命令用来清除MLD Snooping转发表项信息。
通过本命令不能够清除通过配置以静态方式加入的MLD Snooping转发表项。
# 清除交换机保存的所有MLD Snooping转发表项信息。
<Sysname> reset mld-snooping group all
无
【描述】
reset mld-snooping statistics命令用来清除MLD Snooping窥探到的所有MLD报文的统计信息。
# 清除MLD Snooping窥探到的所有MLD报文的统计信息。
<Sysname> reset mld-snooping statistics
MLD-Snooping视图
【描述】
相关配置可参考命令mld-snooping router-aging-time。
# 全局配置路由器端口老化的时间为100秒。
[Sysname-mld-snooping] router-aging-time 100
2.1.33  source-deny
MLD-Snooping视图
【描述】
source-deny命令用来使能IPv6组播数据报文源端口过滤功能,即过滤掉所有收到的IPv6组播数据报文。undo source-deny命令用来关闭IPv6组播数据报文源端口过滤功能。
# 使能从GigabitEthernet1/0/1到 GigabitEthernet1/0/5上的IPv6组播数据报文源端口过滤功能。
[Sysname-mld-snooping] source-deny port GigabitEthernet1/0/1 to GigabitEthernet1/0/5
第3章  组播VLAN配置命令
3.1  组播VLAN配置命令
display multicast-vlan [ vlan-id ]
vlan-id:查看指定组播VLAN及其子VLAN的信息,取值范围为1~4094。如果不指定该参数,将显示所有组播VLAN及其子VLAN的信息。
【描述】
display multicast-vlan命令用来查看组播VLAN及其子VLAN的信息。
# 查看所有组播VLAN及其子VLAN的信息。
<Sysname> display multicast-vlan
 multicast vlan 100's subvlan list:
   vlan 2 4-8
multicast-vlan vlan-id enable
undo multicast-vlan vlan-id enable
vlan-id:指定VLAN的ID号,取值范围为1~4094。
【描述】
multicast-vlan enable命令用来使能指定VLAN为组播VLAN。undo multicast-vlan enable命令用来取消指定VLAN为组播VLAN。
缺省情况下,VLAN不是组播VLAN。
l              所指定的VLAN必须存在。
l              如果设备上已使能了IP组播路由,则不允许在该设备上配置组播VLAN。
l              在配置成为组播VLAN的VLAN内必须使能IGMP Snooping,才能实现组播VLAN功能;而在组播VLAN的子VLAN内不必使能IGMP Snooping。
# 配置VLAN 100为组播VLAN。
[Sysname] multicast-vlan 100 enable
multicast-vlan vlan-id subvlan vlan-list
undo multicast-vlan vlan-id subvlan vlan-list
vlan-id:指定组播VLAN的ID号,取值范围为1~4094。
vlan-list:指定子VLAN列表,表示多个子VLAN。其表示方式为vlan-list = { vlan-id [ to vlan-id ] }&<1-10>,其中,vlan-id为指定子VLAN的ID号,取值范围为1~4094。&<1-10>表示前面的参数最多可以输入10次。
【描述】
multicast-vlan subvlan命令用来为指定组播VLAN配置子VLAN。undo multicast-vlan subvlan命令用来删除指定组播VLAN内的子VLAN。
缺省情况下,组播VLAN内没有子VLAN。
l              要配置的组播VLAN及其子VLAN必须存在;
l              要配置的组播VLAN的子VLAN不能是组播VLAN;
l              要配置的组播VLAN的子VLAN不能是其它组播VLAN的子VLAN;
l              组播VLAN的子VLAN总数不能超过系统限制(S5500-SI系列以太网交换机支持1个组播VLAN,每个组播VLAN下最多支持63个子VLAN)。
# 配置VLAN 10到VLAN 15为组播VLAN 100的子VLAN。
[Sysname] multicast-vlan 100 subvlan 10 to 15
第4章  IPv6组播VLAN配置命令
4.1  IPv6组播VLAN配置命令
display multicast-vlan ipv6 [ vlan-id ]
vlan-id:查看指定IPv6组播VLAN及其子VLAN的信息,取值范围为1~4094。如果不指定该参数,将显示所有IPv6组播VLAN及其子VLAN的信息。
【描述】
display multicast-vlan ipv6命令用来查看IPv6组播VLAN及其子VLAN的信息。
# 查看所有IPv6组播VLAN及其子VLAN的信息。
<Sysname> display multicast-vlan ipv6
 IPv6 multicast vlan 100's subvlan list:
    vlan 2  4-8
multicast-vlan ipv6 vlan-id enable
undo multicast-vlan ipv6 vlan-id enable
【描述】
multicast-vlan ipv6 enable命令用来使能指定VLAN为IPv6组播VLAN。undo multicast-vlan ipv6 enable命令用来取消指定VLAN为IPv6组播VLAN。
缺省情况下,VLAN不是IPv6组播VLAN。
l              所指定的VLAN必须存在。
l              如果设备上已使能了IPv6组播路由,则不允许在该设备上配置IPv6组播VLAN。
l              在配置成为IPv6组播VLAN的VLAN内必须使能MLD Snooping,才能实现IPv6组播VLAN功能;而在IPv6组播VLAN的子VLAN内不必使能MLD Snooping。
# 配置VLAN 100为IPv6组播VLAN。
[Sysname] multicast-vlan ipv6 100 enable
multicast-vlan ipv6 vlan-id subvlan vlan-list
undo multicast-vlan ipv6 vlan-id subvlan vlan-list
vlan-id:指定IPv6组播VLAN的ID号,取值范围为1~4094。
【描述】
multicast-vlan ipv6 subvlan命令用来为指定IPv6组播VLAN配置子VLAN。undo multicast-vlan ipv6 subvlan命令用来删除指定IPv6组播VLAN内的子VLAN。
缺省情况下,IPv6组播VLAN内没有子VLAN。
l              要配置的IPv6组播VLAN及其子VLAN必须存在;
l              要配置的IPv6组播VLAN的子VLAN不能是IPv6组播VLAN;
l              要配置的IPv6组播VLAN的子VLAN不能是其它IPv6组播VLAN的子VLAN;
l              IPv6组播VLAN的子VLAN总数不能超过系统限制(S5500-SI系列以太网交换机支持1个IPv6组播VLAN,组播VLAN下最多支持63个子VLAN)。
# 配置VLAN 10到VLAN 15为IPv6组播VLAN 100的子VLAN。
[Sysname] multicast-vlan ipv6 100 subvlan 10 to 15
