H3C Fixed Port Campus Switches Configuration Examples-6W106
HomeSupportConfigure & DeployConfiguration ExamplesH3C Fixed Port Campus Switches Configuration Examples-6W106
Table of Contents
Related Documents
90-SR-MPLS Configuration Examples
90-SR-MPLS Configuration Examples 124.81 KB
Introduction
This document provides SR-MPLS configuration examples.
Segment Routing (SR) is a source routing technology. The source node selects a path for the packets, and then encodes the path in the packet header as an ordered list of segments. Each segment is identified by the segment identifier (SID). The SR nodes along the path forward the packets based on the SIDs in the packets. Only the source node needs to maintain the path status.
SR can operate with MPLS. In an MPLS network, SR uses MPLS labels as SIDs to forward packets on an LSP.
The following information is provided based on the assumption that you have basic knowledge of SR-MPLS.
Example: Configuring SR-MPLS over LDP for network connections
As shown in Figure 1, the SR-MPLS network is segmented by an LDP network. To enable communication between the two SR-MPLS network segments across the LDP network, establish label connectivity between the SR-MPLS and LDP networks. When Device A forwards traffic to Device E through the related SRLSP, you must configure both Device B and Device D to ensure that the two SR-MPLS network segments can communicate across the LDP network.
Figure 1 Network diagram
Device
IP address
Device
IP address
Device A
Loop1
1.1.1.1/32
Device B
Loop1
2.2.2.2/32
Vlan-Int100
10.0.0.1/24
Vlan-Int100
10.0.0.2/24
Device C
Loop1
3.3.3.3/32
Vlan-Int200
11.0.0.1/24
Vlan-Int100
12.0.0.1/24
Device D
Loop1
4.4.4.4/32
Vlan-Int200
11.0.0.2/24
Vlan-Int100
12.0.0.2/24
Device E
Loop1
5.5.5.5/32
Vlan-Int200
13.0.0.1/24
Vlan-Int200
13.0.0.2/24
Analysis
·     Configure Device A, Device B, Device C, Device D, and Device E to run IS-IS.
·      Configure Device B, Device C, and Device D to run LDP.
·     Configure Device A, Device B, Device D, and Device E to run SR-MPLS.
Product
Software version
S6812 switch series
S6813 switch series
Not supported
S6550XE-HI switch series
Release 8106Pxx
S6526XE-HI[EI] switch series
Release 8341P02 and later
S6510 switch series
Not supported
S6525XE-HI switch series
Release 8106Pxx
S5850 switch series
Not supported
S5570S-EI switch series
Not supported
S5560X-EI switch series
Not supported
S5560X-HI switch series
Not supported
S5500V2-EI switch series
Not supported
MS4520V2-30F switch
Not supported
MS4520V2-30C switch
MS4520V2-54C switch
Not supported
MS4520V2-28S switch
MS4520V2-24TP switch
Not supported
S6520X-HI switch series
S6520X-EI switch series
Not supported
S6520X-SI switch series
S6520-SI switch series
Not supported
S5000-EI switch series
Not supported
MS4600 switch series
Not supported
ES5500 switch series
Not supported
S5560S-EI switch series
S5560S-SI switch series
Not supported
S5500V3-24P-SI switch
S5500V3-48P-SI switch
Not supported
S5500V3-SI switch series (except S5500V3-24P-SI and S5500V3-48P-SI)
Not supported
S5170-EI switch series
Not supported
S5130S-HI switch series
S5130S-EI switch series
S5130S-SI switch series
S5130S-LI switch series
Not supported
S5120V2-SI switch series
S5120V2-LI switch series
Not supported
S5120V3-EI switch series
Not supported
S5120V3-36F-SI switch
S5120V3-28P-HPWR-SI switch
S5120V3-54P-PWR-SI switch
Not supported
S5120V3-SI switch series (except S5120V3-36F-SI, S5120V3-28P-HPWR-SI, and S5120V3-54P-PWR-SI)
Not supported
S5120V3-LI switch series
Not supported
S3600V3-EI switch series
Not supported
S3600V3-SI switch series
Not supported
S3100V3-EI switch series
S3100V3-SI switch series
Not supported
S5110V2 switch series
Not supported
S5110V2-SI switch series
Not supported
S5000V3-EI switch series
S5000V5-EI switch series
Not supported
S5000E-X switch series
S5000X-EI switch series
Not supported
E128C switch
E152C switch
E500C switch series
E500D switch series
Not supported
MS4320V2 switch series
MS4320V3 switch series
MS4300V2 switch series
MS4320 switch series
MS4200 switch series
Not supported
WS5850-WiNet switch series
Not supported
WS5820-WiNet switch series
WS5810-WiNet switch series
Not supported
WAS6000 switch series
Not supported
IE4300-12P-AC switch
IE4300-12P-PWR switch
IE4300-M switch series
IE4320 switch series
Not supported
S5135S-EI switch series
Not supported
S5136S-EI switch series
Not supported
Procedures
Configuring Device A
# Configure IP addresses and masks for interfaces. (Details not shown.)
# Configure IS-IS to achieve network level connectivity and set the IS-IS cost style to wide.
[DeviceA] isis 1
[DeviceA-isis-1] network-entity 00.0000.0000.0001.00
[DeviceA-isis-1] cost-style wide
[DeviceA-isis-1] quit
[DeviceA] interface vlan-interface 100
[DeviceA-Vlan-interface100] isis enable 1
[DeviceA-Vlan-interface100] quit
[DeviceA] interface loopback 1
[DeviceA-LoopBack1] isis enable 1
[DeviceA-LoopBack1] quit
# Configure an MPLS LSR ID.
[DeviceA] mpls lsr-id 1.1.1.1
# Enable SR-MPLS for IS-IS.
[DeviceA] isis 1
[DeviceA-isis-1] address-family ipv4
[DeviceA-isis-1-ipv4] segment-routing mpls
[DeviceA-isis-1-ipv4] quit
# Configure an MPLS SRGB.
[DeviceA-isis-1] segment-routing global-block 16000 16999
# Configure an IS-IS prefix SID.
[DeviceA-LoopBack1] isis prefix-sid index 10
Configuring Device B
[DeviceB] isis 1
[DeviceB-isis-1] network-entity 00.0000.0000.0002.00
[DeviceB-isis-1] cost-style wide
[DeviceB-isis-1] quit
[DeviceB] interface vlan-interface 100
[DeviceB-Vlan-interface100] isis enable 1
[DeviceB-Vlan-interface100] quit
[DeviceB] interface vlan-interface 200
[DeviceB-Vlan-interface200] isis enable 1
[DeviceB-Vlan-interface200] quit
[DeviceB] interface loopback 1
[DeviceB-LoopBack1] isis enable 1
[DeviceB-LoopBack1] quit
[DeviceB] mpls lsr-id 2.2.2.2
# Configure LDP.
[DeviceB] mpls ldp
[DeviceB-ldp] quit
[DeviceB-Vlan-interface200] mpls enable
[DeviceB-Vlan-interface200] mpls ldp enable
[DeviceB] isis 1
[DeviceB-isis-1] address-family ipv4
[DeviceB-isis-1-ipv4] segment-routing mpls
[DeviceB-isis-1-ipv4] quit
[DeviceB-isis-1] segment-routing global-block 17000 17999
[DeviceB-LoopBack1] isis prefix-sid index 20
Configuring Device C
<DeviceC> system-view
[DeviceC] isis 1
[DeviceC-isis-1] network-entity 00.0000.0000.0003.00
[DeviceC-isis-1] cost-style wide
[DeviceC-isis-1] quit
[DeviceC] interface vlan-interface 100
[DeviceC-Vlan-interface100] isis enable 1
[DeviceC-Vlan-interface100] quit
[DeviceC] interface vlan-interface 200
[DeviceC-Vlan-interface200] isis enable 1
[DeviceC-Vlan-interface200] quit
[DeviceC] interface loopback 1
[DeviceC-LoopBack1] isis enable 1
[DeviceC-LoopBack1] quit
[DeviceC] mpls lsr-id 3.3.3.3
# Configure LDP.
[DeviceC] mpls ldp
[DeviceC-ldp] quit
[DeviceC-Vlan-interface100] mpls enable
[DeviceC-Vlan-interface100] mpls ldp enable
[DeviceC-Vlan-interface200] mpls enable
[DeviceC-Vlan-interface200] mpls ldp enable
Configuring Device D
<DeviceD> system-view
[DeviceD] isis 1
[DeviceD-isis-1] network-entity 00.0000.0000.0004.00
[DeviceD-isis-1] cost-style wide
[DeviceD-isis-1] quit
[DeviceD] interface vlan-interface 100
[DeviceD-Vlan-interface100] isis enable 1
[DeviceD-Vlan-interface100] quit
[DeviceD] interface vlan-interface 200
[DeviceD-Vlan-interface200] isis enable 1
[DeviceD-Vlan-interface200] quit
[DeviceD] interface loopback 1
[DeviceD-LoopBack1] isis enable 1
[DeviceD-LoopBack1] quit
[DeviceD] mpls lsr-id 4.4.4.4
# Configure LDP.
[DeviceD] mpls ldp
[DeviceD-ldp] quit
[DeviceD-Vlan-interface1001] mpls enable
[DeviceD-Vlan-interface100] mpls ldp enable
[DeviceD] isis 1
[DeviceD-isis-1] address-family ipv4
[DeviceD-isis-1-ipv4] segment-routing mpls
[DeviceD-isis-1-ipv4] quit
[DeviceD-isis-1] segment-routing global-block 18000 18999
[DeviceD-LoopBack1] isis prefix-sid index 40
Configuring Device E
<DeviceE> system-view
[DeviceE] isis 1
[DeviceE-isis-1] network-entity 00.0000.0000.0005.00
[DeviceE-isis-1] cost-style wide
[DeviceE-isis-1] quit
[DeviceE] interface vlan-interface 200
[DeviceE-Vlan-interface200] isis enable 1
[DeviceE-Vlan-interface200] quit
[DeviceE] interface loopback 1
[DeviceE-LoopBack1] isis enable 1
[DeviceE-LoopBack1] quit
[DeviceE] mpls lsr-id 5.5.5.5
[DeviceE] isis 1
[DeviceE-isis-1] address-family ipv4
[DeviceE-isis-1-ipv4] segment-routing mpls
[DeviceE-isis-1-ipv4] quit
[DeviceE-isis-1] segment-routing global-block 19000 19999
[DeviceE-LoopBack1] isis prefix-sid index 50
# Display LDP LSP information on Device B.
[DeviceB] display mpls ldp lsp
Status Flags: * - stale, L - liberal, B - backup, N/A - unavailable
FECs: 5           Ingress: 3           Transit: 3           Egress: 2
FEC                In/Out Label        Nexthop         OutInterface
1.1.1.1/32         24116/-
                   -/24117(L)
2.2.2.2/32         3/-
                   -/24120(L)
3.3.3.3/32         -/3                 11.0.0.2        Vlan200
                   24121/3             11.0.0.2        Vlan200
4.4.4.4/32         -/24119             11.0.0.2        Vlan200
                   24118/24119         11.0.0.2        Vlan200
5.5.5.5/32         -/24118             11.0.0.2        Vlan200
                   24117/24118         11.0.0.2        Vlan200
# Display IS-IS SRLSP information on Device B.
[DeviceB] display mpls lsp protocol isis
FEC                         Proto       In/Out Label    Interface/Out NHLFE
1.1.1.1/32                  ISIS        17010/3         Vlan100
1.1.1.1/32                  ISIS        -/3             Vlan100
2.2.2.2/32                  ISIS        17020/-         -
4.4.4.4/32                  ISIS        17040/24119     Vlan200
4.4.4.4/32                  ISIS        -/24119         Vlan200
5.5.5.5/32                  ISIS        17050/24118     Vlan200
5.5.5.5/32                  ISIS        -/24118         Vlan200
The output shows that the IS-IS SRLSP entries for Device D and Device E are using LDP outgoing labels.
Configuration files
Device A
isis 1
 cost-style wide
 address-family ipv4 unicast
 mpls lsr-id 1.1.1.1
vlan 1
vlan 100
interface LoopBack1
 ip address 1.1.1.1 255.255.255.255
 isis enable 1
interface Vlan-interface100
 ip address 10.0.0.1 255.255.255.0
 isis enable 1
 port link-mode bridge
 port access vlan 100
 combo enable fiber
Device B
isis 1
 cost-style wide
 mpls lsr-id 2.2.2.2
vlan 1
vlan 100
vlan 200
mpls ldp
interface LoopBack1
 ip address 2.2.2.2 255.255.255.255
 isis enable 1
 ip address 10.0.0.2 255.255.255.0
 isis enable 1
interface Vlan-interface200
 ip address 11.0.0.1 255.255.255.0
 isis enable 1
 mpls enable
 mpls ldp enable
 combo enable fiber
 port access vlan 200
 combo enable fiber
Device C
isis 1
 cost-style wide
 mpls lsr-id 3.3.3.3
vlan 1
vlan 100
vlan 200
mpls ldp
interface LoopBack1
 ip address 3.3.3.3 255.255.255.255
 isis enable 1
 ip address 12.0.0.1 255.255.255.0
 isis enable 1
 mpls enable
 mpls ldp enable
 ip address 11.0.0.2 255.255.255.0
 isis enable 1
 mpls enable
 mpls ldp enable
 combo enable fiber
 combo enable fiber
Device D
isis 1
 cost-style wide
 mpls lsr-id 4.4.4.4
vlan 1
vlan 100
vlan 200
mpls ldp
interface LoopBack1
 ip address 4.4.4.4 255.255.255.255
 isis enable 1
 ip address 12.0.0.2 255.255.255.0
 isis enable 1
 mpls enable
 mpls ldp enable
 ip address 13.0.0.1 255.255.255.0
 isis enable 1
 combo enable fiber
 combo enable fiber
Device E
isis 1
 cost-style wide
 mpls lsr-id 5.5.5.5
vlan 1
vlan 200
interface LoopBack1
 ip address 5.5.5.5 255.255.255.255
 isis enable 1
 ip address 13.0.0.2 255.255.255.0
 isis enable 1
 combo enable fiber
