- H3C Fixed Port Campus Switches Configuration Examples-6W106
- 00-Applicable hardware and software versions
- 01-Login Management Configuration Examples
- 02-RBAC Configuration Examples
- 03-Software Upgrade Examples
- 04-ISSU Configuration Examples
- 05-Software Patching Examples
- 06-Ethernet Link Aggregation Configuration Examples
- 07-Port Isolation Configuration Examples
- 08-Spanning Tree Configuration Examples
- 09-VLAN Configuration Examples
- 10-VLAN Tagging Configuration Examples
- 11-DHCP Snooping Configuration Examples
- 12-Cross-Subnet Dynamic IP Address Allocation Configuration Examples
- 13-IPv6 over IPv4 Tunneling with OSPFv3 Configuration Examples
- 14-IPv6 over IPv4 GRE Tunnel Configuration Examples
- 15-GRE with OSPF Configuration Examples
- 16-OSPF Configuration Examples
- 17-IS-IS Configuration Examples
- 18-BGP Configuration Examples
- 19-Policy-Based Routing Configuration Examples
- 20-OSPFv3 Configuration Examples
- 21-IPv6 IS-IS Configuration Examples
- 22-Routing Policy Configuration Examples
- 23-IGMP Snooping Configuration Examples
- 24-IGMP Configuration Examples
- 25-MLD Snooping Configuration Examples
- 26-IPv6 Multicast VLAN Configuration Examples
- 27-ACL Configuration Examples
- 28-Traffic Policing Configuration Examples
- 29-GTS and Rate Limiting Configuration Examples
- 30-Traffic Filtering Configuration Examples
- 31-AAA Configuration Examples
- 32-Port Security Configuration Examples
- 33-Portal Configuration Examples
- 34-SSH Configuration Examples
- 35-IP Source Guard Configuration Examples
- 36-Ethernet OAM Configuration Examples
- 37-CFD Configuration Examples
- 38-DLDP Configuration Examples
- 39-VRRP Configuration Examples
- 40-BFD Configuration Examples
- 41-NTP Configuration Examples
- 42-SNMP Configuration Examples
- 43-NQA Configuration Examples
- 44-Mirroring Configuration Examples
- 45-sFlow Configuration Examples
- 46-OpenFlow Configuration Examples
- 47-MAC Address Table Configuration Examples
- 48-Static Multicast MAC Address Entry Configuration Examples
- 49-IP Unnumbered Configuration Examples
- 50-MVRP Configuration Examples
- 51-MCE Configuration Examples
- 52-Attack Protection Configuration Examples
- 53-Smart Link Configuration Examples
- 54-RRPP Configuration Examples
- 55-BGP Route Selection Configuration Examples
- 56-IS-IS Route Summarization Configuration Examples
- 57-VXLAN Configuration Examples
- 58-DRNI Configuration Examples
- 59-IRF 3.1 Configuration Examples
- 60-PTP Configuration Examples
- 61-S-MLAG Configuration Examples
- 62-Puppet Configuration Examples
- 63-802.1X Configuration Examples
- 64-MAC Authentication Configuration Examples
- 65-ISATAP Tunnel and 6to4 Tunnel Configuration Examples
- 66-BIDIR-PIM Configuration Examples
- 67-Congestion Avoidance and Queue Scheduling Configuration Examples
- 68-Basic MPLS Configuration Examples
- 69-MPLS L3VPN Configuration Examples
- 70-MPLS OAM Configuration Examples
- 71-EVPN-DCI over an MPLS L3VPN Network Configuration Examples
- 72-DRNI and EVPN Configuration Examples
- 72-M-LAG and EVPN Configuration Examples
- 73-Multicast VPN Configuration Examples
- 74-MPLS TE Configuration Examples
- 75-Control Plane-Based QoS Policy Configuration Examples
- 76-Priority Mapping and Queue Scheduling Configuration Examples
- 77-ARP Attack Protection Configuration Examples
- 78-IRF Software Upgrade Configuration Examples
- 79-IRF Member Replacement Configuration Examples
- 80-Layer 3 Multicast on Multicast Source-Side DR System Configuration Examples
- 80-Layer 3 Multicast on Multicast Source-Side M-LAG System Configuration Examples
- 81-EVPN Multicast Configuration Examples
- 82-Priority Marking and Queue Scheduling Configuration Examples
- 83-EAA Configuration Examples
- 84-GRE Tunnel Access to MPLS L3VPN Configuration Examples
- 85-MC-NAT Configuration Examples
- 86-M-LAG Configuration Examples (Applicable to M-LAG Versions)
- 87-MOD Configuration Examples
- 88-MPLS L2VPN Configuration Examples
- 89-VPLS Configuration Examples
- 90-SR-MPLS Configuration Examples
- 91-VCF Fabric Configuration Examples
- 92-NetStream Configuration Examples
- 93-Configuration Example for Software Upgrade with Zero Packet Loss by Using GIR in VXLAN M-LAG Network
- 94-Configuration Example for Software Upgrade with Zero Packet Loss by Using GIR in VXLAN DRNI Network
| 80-Layer 3 Multicast on Multicast Source-Side DR System Configuration Examples | 229.65 KB |
Example: Configuring Layer 3 IPv4 multicast on a DR system attached to multicast sources
Assigning IP addresses and configuring unicast routing
Example: Configuring Layer 3 IPv6 multicast on a DR system attached to multicast sources
Assigning IPv6 addresses and configuring unicast routing
Introduction
This document provides examples for configuring Layer 3 multicast on a DR system attached to multicast sources.
Distributed Resilient Network Interconnect (DRNI) virtualizes two physical devices into one system through multichassis link aggregation. You can configure PIM on a DR system attached to multicast receivers or multicast sources to prevent single points of failure from interrupting multicast forwarding.
This document assumes that you have basic knowledge of DRNI and Layer 3 multicast.
As shown in Figure 1:
· OSPF runs on the network.
· VOD streams are sent to receiver hosts in multicast. The receivers of different subnets form stub networks, and a minimum of one receiver host exist on each stub network.
· The entire PIM-SM domain contains only one BSR.
· Device C is a Layer 2 device attached to the multicast source. Switch A and Switch B are virtualized into a DR system, which is connected to Switch C through a multichassis aggregate link. VLAN-interface 20 interfaces on the DR system are the gateway for the multicast source.
· Host A is a multicast data receiver attached to Device D.
· The GigabitEthernet 1/0/3 interfaces on Device A and Device B are excluded from the shutdown action by DRNI MAD to set up the keepalive link.
· A VRRP group is configured on VLAN-interface 20 interfaces. In the VRRP group, Device A is the master.
· DR interfaces on Switch A and Switch B permit packets from VLAN 20 to pass through. PIM is enabled on VLAN-interface 20 of Switch A and Switch B.
· IP multicast routing is enabled on Switch A and Switch B.
Device |
IP address |
Device |
IP address |
Device A |
Vlan-int20 |
20.0.0.1/24 |
Device D |
Vlan-int10 |
100.0.0.2/24 |
GE1/0/3 |
200.0.0.1/24 |
Vlan-int30 |
30.0.0.2/24 |
Vlan-int10 |
100.0.0.1/24 |
Vlan-int40 |
40.0.0.2/24 |
Loop0 |
1.1.1.1 |
Device B |
Vlan-int20 |
20.0.0.2/24 |
GE1/0/3 |
200.0.0.2/24 |
Vlan-int30 |
30.0.0.1/24 |
Loop0 |
2.2.2.2 |
Hardware |
Software version |
S6812 switch series S6813 switch series |
Release 6615Pxx, Release 6628Pxx |
S6550XE-HI switch series |
Release 6008 or later, Release 8106Pxx |
S6526XE-HI[EI] switch series |
Not supported |
S6510 switch series |
Not supported |
S6525XE-HI switch series |
S5850 switch series |
Not supported |
S5570S-EI switch series |
Not supported |
S5560X-EI switch series |
S5560X-HI switch series |
S5500V2-EI switch series |
MS4520V2-30F switch |
MS4520V2-30C switch MS4520V2-54C switch |
MS4520V2-28S switch MS4520V2-24TP switch |
Not supported |
S6520X-HI switch series S6520X-EI switch series |
S6520X-SI switch series S6520-SI switch series |
S5000-EI switch series |
MS4600 switch series |
ES5500 switch series |
S5560S-EI switch series S5560S-SI switch series |
Not supported |
S5500V3-24P-SI switch S5500V3-48P-SI switch |
Not supported |
S5500V3-SI switch series (except S5500V3-24P-SI and S5500V3-48P-SI) |
Not supported |
S5170-EI switch series |
Not supported |
S5130S-HI switch series S5130S-EI switch series S5130S-SI switch series S5130S-LI switch series |
Not supported |
S5120V2-SI switch series S5120V2-LI switch series |
Not supported |
S5120V3-EI switch series |
Not supported |
S5120V3-36F-SI switch S5120V3-28P-HPWR-SI switch S5120V3-54P-PWR-SI switch |
Not supported |
S5120V3-SI switch series (except S5120V3-36F-SI, S5120V3-28P-HPWR-SI, and S5120V3-54P-PWR-SI) |
Not supported |
S5120V3-LI switch series |
Not supported |
S3600V3-EI switch series |
Not supported |
S3600V3-SI switch series |
Not supported |
S3100V3-EI switch series S3100V3-SI switch series |
Not supported |
S5110V2 switch series |
Not supported |
S5110V2-SI switch series |
Not supported |
S5000V3-EI switch series S5000V5-EI switch series |
Not supported |
S5000E-X switch series S5000X-EI switch series |
Not supported |
E128C switch E152C switch E500C switch series E500D switch series |
Not supported |
MS4320V2 switch series MS4320V3 switch series MS4300V2 switch series MS4320 switch series MS4200 switch series |
Not supported |
WS5850-WiNet switch series |
Not supported |
WS5820-WiNet switch series WS5810-WiNet switch series |
Not supported |
WAS6000 switch series |
Not supported |
IE4300-12P-AC switch IE4300-12P-PWR switch IE4300-M switch series IE4320 switch series |
Not supported |
S5135S-EI switch series |
Not supported |
S5136S-EI switch series |
Not supported |
Procedures
Assign an IP address and subnet mask to each interface as shown in Figure 1, and configure OSPF on the switches in the PIM-SM domain. (Details not shown.)
Configuring Device A
# Configure the DR system settings.
[DeviceA] drni system-mac 1-1-1
[DeviceA] drni system-number 1
[DeviceA] drni system-priority 123
# Configure DR keepalive packet parameters.
[DeviceA] drni keepalive ip destination 200.0.0.2 source 200.0.0.1
# Exclude the interface used for DR keepalive detection (GigabitEthernet 1/0/3) from the shutdown action by DRNI MAD.
[DeviceA] drni mad exclude interface gigabitethernet 1/0/3
# Create Layer 2 dynamic aggregate interface Bridge-Aggregation 1.
[DeviceA] interface bridge-aggregation 1
[DeviceA-Bridge-Aggregation1] link-aggregation mode dynamic
[DeviceA-Bridge-Aggregation1] quit
# Assign GigabitEthernet 1/0/1 and GigabitEthernet 1/0/2 to aggregation group 1.
[DeviceA-GigabitEthernet1/0/1] port link-aggregation group 1
[DeviceA-GigabitEthernet1/0/2] port link-aggregation group 1
# Create Layer 2 dynamic aggregate interface Bridge-Aggregation 2.
[DeviceA] interface bridge-aggregation 2
[DeviceA-Bridge-Aggregation2] link-aggregation mode dynamic
[DeviceA-Bridge-Aggregation2] quit
# Assign GigabitEthernet 1/0/5 and GigabitEthernet 1/0/6 to aggregation group 1.
[DeviceA] interface gigabitethernet 1/0/5
[DeviceA-GigabitEthernet1/0/5] port link-aggregation group 2
[DeviceA-GigabitEthernet1/0/5] quit
[DeviceA] interface gigabitethernet 1/0/6
[DeviceA-GigabitEthernet1/0/6] port link-aggregation group 2
[DeviceA-GigabitEthernet1/0/6] quit
# Configure Bridge-Aggregation 1 as a trunk port, assign it to all VLANs, and specify it as the IPP.
[DeviceA-Bridge-Aggregation1] port link-type trunk
[DeviceA-Bridge-Aggregation1] port trunk permit vlan all
[DeviceA-Bridge-Aggregation1] port drni intra-portal-port 1
# Configure Bridge-Aggregation 2 as a trunk port, and assign it to VLAN 20 and a DR group.
[DeviceA-Bridge-Aggregation2] port link-type trunk
[DeviceA-Bridge-Aggregation2] port trunk permit vlan 20
[DeviceA-Bridge-Aggregation2] port drni group 1
# Configure VRRP group 1 on VLAN-interface 20, and set the priority of Device A to 200 for it to be the master in the VRRP group.
[DeviceA] vlan 20
[DeviceA-vlan20] quit
[DeviceA] interface vlan-interface 20
[DeviceA-Vlan-interface20] vrrp vrid 1 virtual-ip 20.0.0.10
[DeviceA-Vlan-interface20] vrrp vrid 1 priority 200
[DeviceA-Vlan-interface20] quit
# Enable IP multicast routing, enable IGMP and PIM on VLAN-interface 10, and enable PIM-SM on other interfaces as required.
[DeviceA] multicast routing
[DeviceA-mrib] quit
[DeviceA-Vlan-interface10] igmp enable
[DeviceA-Vlan-interface10] pim sm
[DeviceA-Vlan-interface20] pim sm
[DeviceA] interface loopback 0
[DeviceA-LoopBack0] pim sm
[DeviceA-LoopBack0] quit
# Specify the IP address of Loopback 0 as a C-RP and a C-BSR.
[DeviceA] pim
[DeviceA-pim] c-rp 1.1.1.1
[DeviceA-pim] c-bsr 1.1.1.1
[DeviceA-pim] quit
Configuring Device B
Configure Device B in the same way you configure Device A. (Details not shown.)
Configuring Device C
<DeviceC> system-view
[DeviceC] interface bridge-aggregation 1
[DeviceC-Bridge-Aggregation1] link-aggregation mode dynamic
[DeviceC-Bridge-Aggregation1] quit
# Assign GigabitEthernet 1/0/1 through GigabitEthernet 1/0/4 to aggregation group 1.
[DeviceC] interface range gigabitethernet 1/0/1 to gigabitethernet 1/0/4
[DeviceC-if-range] port link-aggregation group 1
[DeviceC-if-range] quit
# Configure Bridge-Aggregation 2 as a trunk port, and assign it to VLAN 20.
[DeviceC-Bridge-Aggregation1] port link-type trunk
[DeviceC-Bridge-Aggregation1] port trunk permit vlan 20
# Assign GigabitEthernet 1/0/5 to VLAN 20.
[DeviceC] interface gigabitethernet 1/0/5
[DeviceC-GigabitEthernet1/0/5] port access vlan 20
[DeviceC-GigabitEthernet1/0/5] quit
Configuring Device D
# Assign GigabitEthernet 1/0/1, GigabitEthernet 1/0/2, and GigabitEthernet 1/0/3 to VLAN 10, VLAN 30, and VLAN 40, respectively.
<DeviceD> system-view
[DeviceD] vlan 10
[DeviceD-vlan10] quit
[DeviceD] interface gigabitethernet1/0/1
[DeviceD-GigabitEthernet1/0/1] port access vlan 10
[DeviceD-GigabitEthernet1/0/1] quit
[DeviceD] vlan 40
[DeviceD-vlan40] quit
[DeviceD] interface gigabitethernet1/0/3
[DeviceD-GigabitEthernet1/0/3] port access vlan 40
[DeviceD] vlan 30
[DeviceD-vlan30] quit
[DeviceD] interface gigabitethernet1/0/2
[DeviceD-GigabitEthernet1/0/2] port access vlan 30
# Enable IP multicast routing, and enable PIM-SM on VLAN-interface 10 and VLAN-interface 30.
[DeviceD] multicast routing
[DeviceD-mrib] quit
[DeviceD] interface vlan-interface 10
[DeviceD-Vlan-interface10] pim sm
[DeviceD-Vlan-interface10] quit
[DeviceD] vlan 30
[DeviceD] interface vlan-interface 30
# Enable IGMPv2 on VLAN-interface 40.
[DeviceD] interface vlan-interface 40
[DeviceD-Vlan-interface40] igmp enable
[DeviceD-Vlan-interface40] igmp version 2
[DeviceD-Vlan-interface40] quit
# Verify that Device B sends and receives keepalive packets correctly.
<DeviceB> display drni keepalive
Neighbor keepalive link status (cause): Up
Neighbor is alive for: 176 s 237 ms
Keepalive packet transmission status:
Sent: Successful
Received: Successful
Last received keepalive packet information:
Source IP address: 200.0.0.1
Time: 2021/12/21 15:12:43
Action: Accept
Distributed relay keepalive parameters:
Destination IP address: 200.0.0.1
Source IP address: 200.0.0.2
Keepalive UDP port : 6400
Keepalive VPN name : N/A
Keepalive interval : 1000 ms
Keepalive timeout : 5 sec
Keepalive hold time: 3 sec
# Verify that interfaces used by DRNI operate correctly on Device B.
<DeviceB> display drni summary
Flags: A -- Aggregate interface down, B -- No peer DR interface configured
C -- Configuration consistency check failed
IPP: BAGG1
IPP state (cause): UP
Keepalive link state (cause): UP
DR interface information
DR interface DR group Local state (cause) Peer state Remaining down time(s)
BAGG2 1 UP UP -
# Verify that the DR interface on Device B operates correctly.
<DeviceB> display link-aggregation verbose bridge-aggregation 2
Port: A -- Auto port, M -- Management port, R -- Reference port
G -- Defaulted, H -- Expired
Aggregate Interface: Bridge-Aggregation2
Creation Mode: Manual
Aggregation Mode: Dynamic
Management VLANs: None
System ID: 0x7b, 0001-0001-0001
Local:
Port Status Priority Index Oper-Key Flag
GE1/0/5(R) S 32768 32770 40001 {ACDEF}
GE1/0/6 S 32768 32770 40001 {ACDEF}
Remote:
Actor Priority Index Oper-Key SystemID Flag
GE1/0/5 32768 2 1 0x8000, 84c4-42e5-0300 {ACDEF}
GE1/0/6 32768 2 1 0x8000, 84c4-42e5-0300 {ACDEF}
# Verify that the IGMP group information on Device D is correct.
<DeviceD> display igmp group
IGMP groups in total: 1
Vlan-interface40(40.0.0.2):
IGMP groups reported in total: 1
Group address Last reporter Uptime Expires
225.0.0.1 40.0.0.10 00:02:04 00:01:15
# Verify that PIM routing entries have been created on Device B.
<DeviceB> display pim routing-table
Total 1 (*, G) entries; 1 (S, G) entries
(*, 225.0.0.1)
RP: 2.2.2.2 (local)
Protocol: pim-sm, Flag: WC
UpTime: 00:00:20
Upstream interface: Register-Tunnel0
Upstream neighbor: NULL
RPF prime neighbor: NULL
Downstream interface information:
1: Vlan-interface30
Protocol: pim-sm, UpTime: 00:00:20, Expires: -
(20.0.0.100, 225.0.0.1)
RP: 2.2.2.2 (local)
Protocol: pim-sm, Flag: SPT ACT 2MVPN
UpTime: 00:00:19
Upstream interface: Vlan-interface20
1: Vlan-interface30
Protocol: pim-sm, UpTime: 00:00:19, Expires: -
# Verify that multicast forwarding entries have been created on Device B.
<DeviceB> display multicast forwarding-table
Total 1 entries, 1 matched
00001. (20.0.0.100, 225.0.0.1)
Flags: 0x0
Uptime: 00:00:55, Timeout in: 00:03:18
Incoming interface: Vlan-interface20
List of 1 outgoing interfaces:
1: Vlan-interface30
Matched 1293 packets(36204 bytes), Wrong If 0 packets
Forwarded 1291 packets(36148 bytes)
# Verify that Device A does not create PIM routing entries or multicast forwarding entries, which indicates that Device B forwards all multicast traffic to the receiver. (Details not shown.)
Configuration files
· Device A:
sysname DeviceA
ospf 1
router-id 2.2.2.2
area 0.0.0.0
vlan 1
vlan 10
vlan 20
interface Bridge-Aggregation1
interface Bridge-Aggregation2
port trunk permit vlan 1 20
port drni group 1
interface LoopBack0
ospf 1 area 0.0.0.0
pim sm
ip address 1.1.1.1 255.255.255.255
interface Vlan-interface10
ospf 1 area 0.0.0.0
pim sm
ip address 100.0.0.1 255.255.255.0
interface Vlan-interface20
ospf 1 area 0.0.0.0
pim sm
ip address 20.0.0.1 255.255.255.0
ip address 200.0.0.1 255.255.255.0
interface GigabitEthernet1/0/5
interface GigabitEthernet1/0/6
interface GigabitEthernet1/0/4
port access vlan 10
multicast routing
pim
c-bsr 1.1.1.1
c-rp 1.1.1.1
drni system-mac 0001-0001-0001
drni mad exclude interface GigabitEthernet1/0/3
· Device B:
sysname DeviceB
ospf 1
router-id 3.3.3.3
area 0.0.0.0
area 0.0.0.9
vlan 20
vlan 30
port drni group 1
interface LoopBack0
ospf 1 area 0.0.0.0
pim sm
ip address 2.2.2.2/32
ospf 1 area 0.0.0.0
pim sm
ip address 20.0.0.2 255.255.255.0
vrrp vrid 1 priority 100
interface Vlan-interface30
ospf 1 area 0.0.0.0
pim sm
ip address 30.0.0.1 255.255.255.0
ospf 1 area 0.0.0.0
ip address 200.0.0.2 255.255.255.0
port access vlan 30
multicast routing
pim
c-bsr 1.1.1.1
c-rp 1.1.1.1
drni system-number 2
drni keepalive ipv6 destination 200.0.0.1 source 200.0.0.2
· Device C:
sysname DeviceC
vlan 1
vlan 20
interface LoopBack1
ip address 3.3.3.3 255.255.255.255
port access vlan 20
· Device D:
sysname DeviceD
ospf 1
router-id 4.4.4.4
area 0.0.0.0
vlan 10
vlan 40
vlan 30
ospf 1 area 0.0.0.0
pim sm
ip address 100.0.0.2 255.255.255.0
interface Vlan-interface40
ospf 1 area 0.0.0.0
ip address 40.0.0.2 255.255.255.0
igmp enable
igmp version 2
ospf 1 area 0.0.0.0
pim sm
ip address 30.0.0.2 255.255.255.0
port access vlan 40
port access vlan 10
port access vlan 30
multicast routing
As shown in Figure 2:
· OSPFv3 runs on the network.
· The entire IPv6 PIM-SM domain contains only one BSR.
· IPv6 multicast routing is enabled on Switch A and Switch B.
Device |
IP address |
Device |
IP address |
Device A |
Vlan-int20 |
2000::1/80 |
Device D |
Vlan-int10 |
2003::2/80 |
GE1/0/3 |
2002::1/80 |
Vlan-int30 |
2004::2/80 |
Vlan-int10 |
2003::1/80 |
Vlan-int40 |
20::1/80 |
Loop0 |
1111::1111/128 |
Device B |
Vlan-int20 |
2000::2/80 |
GE1/0/3 |
2002::2/80 |
Vlan-int30 |
2004::1/80 |
Loop0 |
2222::2222/128 |
Hardware |
Software version |
Not supported |
Not supported |
Not supported |
Not supported |
Not supported |
Not supported |
Not supported |
Not supported |
Not supported |
Not supported |
Not supported |
Not supported |
Not supported |
Not supported |
Not supported |
Not supported |
Not supported |
Not supported |
Not supported |
Not supported |
Not supported |
Not supported |
Not supported |
Not supported |
Not supported |
Not supported |
Not supported |
Not supported |
Not supported |
Not supported |
Procedures
Assign an IPv6 address and prefix to each interface as shown in Figure 2, and configure OSPFv3 on the switches in the IPv6 PIM-SM domain. (Details not shown.)
[DeviceA] drni keepalive ipv6 destination 2002::2 source 2002::1
# Configure Bridge-Aggregation 2 as a trunk port, assign it to VLAN 20, and assign it to a DR group.
# Configure VRRP group 1 on VLAN-interface 20, and set the priority of Device A to 200 for it to become the master in the VRRP group.
[DeviceA-Vlan-interface20] vrrp ipv6 vrid 1 virtual-ip FE80::10 link-local
[DeviceA-Vlan-interface20] vrrp ipv6 vrid 1 virtual-ip 2000::10
[DeviceA-Vlan-interface20] vrrp ipv6 vrid 1 priority 200
# Enable IPv6 multicast routing, enable MLD and IPv6 PIM on VLAN-interface 10, and enable IPv6 PIM-SM on other interfaces as required.
[DeviceA] ipv6 multicast routing
[DeviceA-mrib6] quit
[DeviceA-Vlan-interface10] mld enable
[DeviceA-Vlan-interface10] ipv6 pim sm
[DeviceA-Vlan-interface20] ipv6 pim sm
[DeviceA-LoopBack0] ipv6 pim sm
# Specify the IPv6 address of Loopback 0 as a C-RP and a C-BSR.
[DeviceA] ipv6 pim
[DeviceA-pim6] c-rp 1111::1111
[DeviceA-pim6] c-bsr 1111::1111
[DeviceA-pim6] quit
[DeviceD] vlan 10
[DeviceD] vlan 40
[DeviceD] vlan 30
# Enable IPv6 multicast routing, and enable IPv6 PIM-SM on VLAN-interface 10 and VLAN-interface 30.
[DeviceD] ipv6 multicast routing
[DeviceD-mrib6] quit
[DeviceD-Vlan-interface10] ipv6 pim sm
[DeviceD] vlan 30
[DeviceD-Vlan-interface30] ipv6 pim sm
[DeviceD-Vlan-interface30] quit
# Enable MLDv2 on VLAN-interface 40.
[DeviceD-Vlan-interface40] mld enable
[DeviceD-Vlan-interface40] mld version 2
Neighbor is alive for: 2128 s 421 ms
Sent: Successful
Source IP address: 2002::1
Time: 2021/12/21 15:45:15
Action: Accept
Destination IP address: 2002::1
Source IP address: 2002::2
IPP: BAGG1
BAGG2 1 UP UP -
Local:
Remote:
# Verify that the MLD group information on Device D is correct.
<DeviceD> display mld group
MLD groups in total: 1
Vlan-interface40(FE80::200:FCFF:FE00:3472):
MLD groups reported in total: 1
Group address: FF08::2
Last reporter: FE80::1
Uptime: 01:56:46
Expires: 00:02:43
# Verify that IPv6 PIM routing entries have been created on Device B.
<DeviceB> display ipv6 pim routing-table
(*, FF08::2)
RP: 2222::2222(local)
UpTime: 00:17:51
1: Vlan-interface30
Protocol: pim-sm, UpTime: 00:17:51, Expires: 00:02:39
(2000::111, FF08::2)
Protocol: pim-sm, Flag: SPT LOC ACT 2MVPN
UpTime: 00:17:54
1: Vlan-interface30
Protocol: pim-sm, UpTime: 00:17:54, Expires: 00:02:36
# Verify that IPv6 multicast forwarding entries have been created on Device B.
<DeviceB> display ipv6 multicast forwarding-table
00001. (2000::111, FF08::2)
Flags: 0x0
Uptime: 00:08:27, Timeout in: 00:03:27
1: Vlan-interface30
Matched 5 packets(71681 bytes), Wrong If 0 packets
Forwarded 5 packets(71681 bytes)
# Verify that Device A does not create IPv6 PIM routing entries or multicast forwarding entries, which indicates that Device B forwards all multicast traffic to the receiver. (Details not shown.)
Configuration files
· Device A:
sysname DeviceA
ospfv3 1
router-id 2.2.2.2
area 0.0.0.0
vlan 10
vlan 20
port drni group 1
interface LoopBack0
ospfv3 1 area 0.0.0.0
ipv6 pim sm
ipv6 address 1111::1111/128
ipv6 pim sm
ipv6 address 2003::1/80
ipv6 pim sm
ipv6 address 2000::1/80
ipv6 address 2002::1/80
port access vlan 10
ipv6 pim
c-bsr 1111::1111
c-rp 1111::1111
· Device B:
sysname DeviceB
ospfv3 1
router-id 3.3.3.3
area 0.0.0.0
vlan 20
vlan 30
port drni group 1
interface LoopBack0
ipv6 pim sm
ipv6 address 2222::2222/128
ipv6 pim sm
ipv6 address 2000::2/80
vrrp ipv6 vrid 1 priority 100
ipv6 pim sm
ipv6 address 2004::1/80
ipv6 address 2002::2/80
port access vlan 30
ipv6 pim
c-bsr 2222::2222
c-rp 2222::2222
drni keepalive ipv6 destination 2002::1 source 2002::2
· Device C:
sysname DeviceC
vlan 20
interface LoopBack1
ipv6 address FE80::2 link-local
port access vlan 20
· Device D:
sysname DeviceD
ospfv3 1
router-id 4.4.4.4
area 0.0.0.0
vlan 10
vlan 40
vlan 30
ipv6 pim sm
ipv6 address 2003::2/80
ipv6 address 20::1/80
mld enable
mld version 2
ipv6 pim sm
ipv6 address 2004::2/80
port access vlan 40
port access vlan 10
port access vlan 30
pim
