H3C Fixed Port Campus Switches Configuration Examples-6W106
HomeSupportConfigure & DeployConfiguration ExamplesH3C Fixed Port Campus Switches Configuration Examples-6W106
Table of Contents
Related Documents
64-MAC Authentication Configuration Examples
64-MAC Authentication Configuration Examples 657.43 KB
Introduction
The following information provides examples for configuring MAC authentication to ensure network access security.
The following information is provided based on the assumption that you have basic knowledge of MAC authentication.
Example: Configuring local MAC authentication
As shown in Figure 1, the device performs local MAC authentication on GigabitEthernet 1/0/1 to control Internet access of users.
Configure the device to meet the following requirements:
·     Detect whether a user has gone offline every 180 seconds.
·     Deny a user for 180 seconds if the user fails MAC authentication.
·     Authenticate all users in ISP domain bbb.
·     Use the MAC address of each user as both the username and password for authentication. The MAC addresses are in hexadecimal notation with hyphens, and letters are in lower case. In this example, both the username and password are 08-00-27-00-98-d2.
Figure 1 Network diagram
Hardware
Software version
S6812 switch series
S6813 switch series
Release 6615Pxx, Release 6628Pxx
S6550XE-HI switch series
Release 6008 and later, Release 8106Pxx
S6526XE-HI[EI] series
Release 8341P02 and later
S6510 series
S6525XE-HI switch series
S5850 switch series
Release 8005 and later, Release 8106Pxx
S5570S-EI switch series
Release 11xx
S5560X-EI switch series
Release 63xx, Release 65xx, Release 6615Pxx, Release 6628Pxx
S5560X-HI switch series
S5500V2-EI switch series
MS4520V2-30F switch
MS4520V2-30C switch
MS4520V2-54C switch
MS4520V2-28S switch
MS4520V2-24TP switch
S6520X-HI switch series
S6520X-EI switch series
S6520X-SI switch series
S6520-SI switch series
S5000-EI switch series
MS4600 switch series
ES5500 switch series
S5560S-EI switch series
S5560S-SI switch series
Release 63xx
S5500V3-24P-SI switch
S5500V3-48P-SI switch
Release 63xx
S5500V3-SI switch series (except the S5500V3-24P-SI and S5500V3-48P-SI switches)
Release 11xx
S5170-EI switch series
Release 11xx
S5130S-HI switch series
S5130S-EI switch series
S5130S-SI switch series
S5130S-LI switch series
Release 63xx
S5120V2-SI switch series
S5120V2-LI switch series
Release 63xx
S5120V3-EI switch series
Release 11xx
S5120V3-36F-SI switch
S5120V3-28P-HPWR-SI switch
S5120V3-54P-PWR-SI switch
Release 11xx
S5120V3-SI switch series (except the S5120V3-36F-SI, S5120V3-28P-HPWR-SI, and S5120V3-54P-PWR-SI switches)
Release 63xx
S5120V3-LI switch series
Release 63xx
S3600V3-EI switch series
Release 11xx
S3600V3-SI switch series
Release 11xx
S3100V3-EI switch series
S3100V3-SI switch series
Release 63xx
S5110V2 switch series
Release 63xx
S5110V2-SI switch series
Release 63xx
S5000V3-EI switch series
S5000V5-EI switch series
Release 63xx
S5000E-X switch series
S5000X-EI switch series
Release 63xx
E128C switch
E152C switch
E500C switch series
E500D switch series
Release 63xx
MS4320V2 switch series
MS4320V3 switch series
MS4300V2 switch series
MS4320 switch series
MS4200 switch series
Release 63xx
WS5850-WiNet switch series
Release 63xx
WS5820-WiNet switch series
WS5810-WiNet switch series
Release 63xx
WAS6000 switch series
Release 63xx
IE4300-12P-AC switch
IE4300-12P-PWR switch
IE4300-M switch series
IE4320 switch series
Release 63xx
IE4520 switch series
Release 66xx
S5135S-EI switch
Release 6810 and later
·     To avoid valid users from being blocked, do not enable MAC authentication globally before you finish all settings.
·     When you create a local user, the username and password must match the user account policy for MAC authentication. If MAC-based accounts are used, make sure the username and password of each user account are the same as the MAC address of the corresponding MAC authentication user.
Procedures
# Add a network access user, set both the username and password to the MAC address of the host, and allow the user to use the LAN access service.
[Device] local-user 08-00-27-00-98-d2 class network
[Device-luser-network-08-00-27-00-98-d2] password simple 08-00-27-00-98-d2
[Device-luser-network-08-00-27-00-98-d2] service-type lan-access
[Device-luser-network-08-00-27-00-98-d2] quit
# Configure ISP domain bbb to use local authentication for LAN users.
[Device] domain bbb
[Device-isp-bbb] authentication lan-access local
[Device-isp-bbb] quit
# Specify ISP domain bbb as the global MAC authentication domain.
[Device] mac-authentication domain bbb
# Configure MAC authentication timers.
[Device] mac-authentication timer offline-detect 180
[Device] mac-authentication timer quiet 180
# Use the MAC address of each user as both the username and password for MAC authentication. The MAC addresses are in hexadecimal notation with hyphens, and letters are in lower case.
[Device] mac-authentication user-name-format mac-address with-hyphen lowercase
# Enable MAC authentication on interface GigabitEthernet 1/0/1.
[Device-GigabitEthernet1/0/1] mac-authentication
# Enable MAC authentication globally.
IMPORTANT
IMPORTANT:
Support for VSI- and microsegment-related fields depends on the device model.
# Display MAC authentication settings and statistics.
<Device> display mac-authentication
   MAC authentication                         : Enabled
   Authentication method                      : PAP
   Username format                            : MAC address in lowercase(xx-xx-xx-xx-xx-xx)
           Username                           : mac
           Password                           : Not configured
   MAC range accounts                         : 0
          MAC address          Mask                 Username
   Offline detect period                      : 180 s
   Quiet period                               : 180 s
   Server timeout                             : 100 s
   Reauth period                              : 3600 s
   User aging period for critical VLAN        : 1000 s
   User aging period for critical VSI         : 1000 s
   User aging period for guest VLAN           : 1000 s
   User aging period for guest VSI            : 1000 s
   User aging period for critical microsegment: 1000 s
   Authentication domain                      : bbb
   HTTP proxy port list                       : Not configured
   HTTPS proxy port list                      : Not configured
 Online MAC-auth wired users                  : 1
 Silent MAC users:
          MAC address       VLAN ID  From port               Port index
 GigabitEthernet1/0/1  is link-up
   Carry User-IP                    : Disabled
   Authentication domain            : Not configured
   Auth-delay timer                 : Disabled
   Periodic reauth                  : Disabled
   Re-auth server-unreachable       : Logoff
   Guest VLAN                       : Not configured
   Guest VLAN reauthentication      : Enabled
     Guest VLAN auth-period         : 30 s
   Critical VLAN                    : Not configured
   Critical voice VLAN              : Disabled
   Host mode                        : Single VLAN
   Offline detection                : Enabled
   Authentication order             : Default
   User aging                       : Enabled
   Server-recovery online-user-sync : Disabled
   Guest VSI                        : Not configured
   Guest VSI reauthentication       : Enabled
     Guest VSI auth-period          : 30 s
   Critical VSI                     : Not configured
   Critical microsegment ID         : Not configured
   URL user logoff                  : No
   Auto-tag feature                 : Disabled
   VLAN tag configuration ignoring  : Disabled
   Max online users                 : 4294967295
   Authentication attempts          : successful 1, failed 0
   Current online users             : 1
          MAC address       Auth state
          0800-2700-98d2    Authenticated
Configuration files
 mac-authentication
domain bbb
 password cipher $c$3$rTXB/eL1h+bXc/t2nyQOrhDMC0PWfyiPb93BqMCK+JFYwvn5
mac-authentication
Example: Configuring MAC authentication with authorization VSI assignment
As shown in Figure 2:
·     Configure the device to use the RADIUS servers to perform authentication, authorization, and accounting for the user on the host that is connected to GigabitEthernet 1/0/1.
·     Enable MAC authentication on GigabitEthernet 1/0/1 to control Internet access.
·     Configure the RADIUS servers to assign VSI bbb to the user when the user passes MAC authentication. After that, the user can access resources in the VXLAN created on the VSI. In this example, the VXLAN is VXLAN 5.
·     Authenticate the user in ISP domain 2000.
·     Use the MAC address of the host as both the username and password for MAC authentication. The MAC address is in hexadecimal notation with hyphens, and letters are in lower case. In this example, both the username and password are d4-85-64-be-c6-3e.
IMC acts as the RADIUS servers.
Figure 2 Network diagram
Analysis
·     For the device to use IMC as the RADIUS servers for user authentication, authorization, and accounting, perform the following tasks on IMC:
a.     Add the device to IMC as an access device.
b.     Add an access policy.
c.     Add an access service and specify the access policy in the access service.
d.     Add an access user and specify the access service for the access user.
·     For the device to perform RADIUS-based authentication, authorization, and accounting for the MAC authentication access user, configure AAA settings on the device, including ISP domain settings and RADIUS scheme settings.
·     To assign a VSI to the user after the user passes authentication and allow the user to access resources in the VXLAN created on the VSI, perform the following tasks:
¡     On IMC, specify the VSI for the user when you add an access policy for the user.
¡     On the device, create the VSI and its VXLAN.
Hardware
Software version
S6812 switch series
S6813 switch series
S6510 series
Not supported
S5850 switch series
Not supported
Not supported
MS4520V2-30F switch
MS4520V2-30C switch
MS4520V2-54C switch
MS4520V2-28S switch
Not supported
Not supported
Not supported
Not supported
Not supported
Not supported
Not supported
Not supported
Not supported
Not supported
Not supported
Not supported
Not supported
Not supported
Not supported
Not supported
Not supported
Not supported
E128C switch
E152C switch
E500C switch series
E500D switch series
Not supported
Not supported
Not supported
Not supported
Not supported
Not supported
Release 66xx
S5135S-EI switch
Not supported
·     When you add an access user on IMC, make sure the user account on IMC matches the MAC authentication user account policy on the device. If MAC-based accounts are used, make sure the username and password of each user account are the same as the MAC address of the corresponding MAC authentication user.
·     In standard RADIUS protocol, the authentication port on RADIUS servers is UDP port 1812. If an H3C device is used as a RADIUS server, the authentication port on the RADIUS server is UDP port 1645.
Procedures
If an ADCAM server is used for authentication and authorization, configure VSIs on the server. The server will assign these VSIs to the device. You do not need to configure VSIs on the device.
Configuring the RADIUS server
This example uses IMC PLAT 7.3 (E0506), IMC EIA 7.3 (E0503), and IMC EIP 7.3 (E0503) to describe the procedure.
Adding the device to the IMC Platform as an access device
1.     Log in to IMC.
2.     Click the User tab.
3.     From the navigation pane, select User Access Policy > Access Device Management > Access Device.
4.     Click Add.
5.     On the page that opens, configure access device parameters.
a.     Set the ports for authentication and accounting to 1812 and 1813, respectively.
b.     Select H3C (General) from the Access Device Type list.
c.     Set the shared key to expert for secure authentication and accounting communication.
d.     Select an access device from the device list or manually add an access device. In this example, the IP address of the access device is 10.1.1.2.
e.     Use the default values for other parameters.
f.     Click OK.
The IP address of the access device specified on IMC must be the same as the source IP address of the RADIUS packets sent from the device. On the device, the source IP address is chosen in the following order:
a.     IP address specified by using the nas-ip command.
b.     IP address specified by using the radius nas-ip command.
c.     IP address of the outbound interface (the default).
In this example, the device uses the IP address of the outbound interface as the source IP address of RADIUS packets.
Figure 3 Adding an access device
Adding an access policy
1.     Click the User tab.
2.     From the navigation pane, select User Access Policy > Access Policy.
3.     Click Add.
4.     On the page that opens, configure access policy parameters.
a.     Enter access policy name MACauth.
b.     Set the name of the VSI to be deployed to bbb.
c.     Configure other parameters as needed.
d.     Click OK.
Figure 4 Adding an access policy
Adding an access service
2.     From the navigation pane, select User Access Policy > Access Service.
3.     Click Add.
4.     On the page that opens, configure access service parameters.
a.     Enter service name MACauth Service and set the service suffix to 2000. The service suffix is the authentication domain for the MAC authentication user.
IMPORTANT
IMPORTANT:
With the service suffix configured, you must configure the device to send usernames that include the domain name to the RADIUS servers.
b.     Select MACauth from the Default Access Policy list.
d.     Click OK.
Figure 5 Adding an access service
Adding an access user
2.     From the navigation pane, select Access User > Access User.
3.     Click Add.
4.     On the page that opens, configure access user parameters.
a.     Select the user or add a user named test.
b.     Enter account name d4-85-64-be-c6-3e and password d4-85-64-be-c6-3e.
c.     Select MACauth Service in the Access Service area.
d.     Configure other parameters as needed.
e.     Click OK.
Figure 6 Adding an access user
Configuring the device
# Configure a RADIUS scheme.
IMPORTANT
IMPORTANT:
With the service suffix configured on IMC, you must configure the device to send usernames that include the domain name to the RADIUS servers. By default, the device includes the domain name in the usernames sent to a RADIUS server.
[Device] radius scheme bbb
[Device-radius-bbb] primary authentication 10.1.1.1
[Device-radius-bbb] primary accounting 10.1.1.2
[Device-radius-bbb] key authentication simple expert
[Device-radius-bbb] key accounting simple expert
[Device-radius-bbb] user-name-format with-domain
[Device-radius-bbb] quit
# Configure ISP domain 2000.
[Device] domain 2000
[Device-isp-2000] authentication lan-access radius-scheme bbb
[Device-isp-2000] authorization lan-access radius-scheme bbb
[Device-isp-2000] accounting lan-access radius-scheme bbb
[Device-isp-2000] quit
# Enable MAC-based traffic match mode for dynamic Ethernet service instances on interface GigabitEthernet 1/0/1.
[Device-GigabitEthernet1/0/1] mac-based ac
# Enable L2VPN.
[Device] l2vpn enable
# Create a VSI named bbb and the associated VXLAN.
[Device] vsi bbb
[Device-vsi-bbb] vxlan 5
[Device-vsi-bbb-vxlan-5] quit
[Device-vsi-bbb] quit
# Specify ISP domain 2000 as the global MAC authentication domain.
[Device] mac-authentication domain 2000
# Verify that VSI bbb is assigned to the MAC authentication user after the user passes authentication.
[Device] display mac-authentication connection
Total connections: 1
Slot ID: 1
User MAC address: d485-64be-c63e
Username: d4-85-64-be-c6-3e
User access state: Successful
Authentication domain: 2000
IPv4 address: 192.168.1.1
Initial VLAN: 1
Authorization untagged VLAN: N/A
Authorization VSI: bbb
Authorization microsegment ID: N/A
Authorization ACL ID: N/A
Authorization CAR:
  Average input rate: 102400 bps
  Peak input rate: 204800 bps
  Average output rate: 102400 bps
  Peak output rate: 204800 bps
Authorization URL: N/A
Termination action: N/A
Session timeout period: N/A
Offline detection: 100 sec (server-assigned)
Online from: 2016/06/13 09:06:37
Online duration: 0h 0m 35s
# Verify that a dynamic AC is created for MAC address d485-64be-c63e.
[Device] display l2vpn forwarding ac verbose
VSI Name: bbb
  Interface: GE1/0/1  Service Instance: 1
    Link ID      : 0
    Access Mode  : VLAN
    Encapsulation: untagged
    Type         : Dynamic (MAC-based)
    MAC address  : d485-64be-c63e
Configuration files
radius scheme bbb
 key authentication cipher $c$3$+zuETC3Y0LHiW3bxzBb+UNEuWlxHkQ==
 key accounting cipher $c$3$2b8hx6mbWlnMMQY82TeUzgh0VnWXbg==
domain 2000
 mac-authentication
 mac-based ac
vsi bbb
 vxlan 5
 l2vpn enable
 mac-authentication
Example: Configuring MAC authentication with ACL assignment
As shown in Figure 7:
·     Use an ACL to deny the user to access the FTP server at 10.0.0.1 after the user passes authentication.
Figure 7 Network diagram
Analysis
·     To use an ACL to restrict the user's network access behaviors after the user passes authentication, perform the following tasks:
¡     On IMC, specify the ACL number for the user when you add an access policy for the user.
¡     On the device, create the ACL and configure its rules.
Hardware
Software version
S6812 switch series
S6813 switch series
S6510 series
S5850 switch series
Release 11xx
MS4520V2-30F switch
MS4520V2-30C switch
MS4520V2-54C switch
MS4520V2-28S switch
Release 63xx
Release 63xx
Release 63xx
Release 11xx
Release 11xx
Release 63xx
Release 63xx
Release 11xx
Release 11xx
Release 63xx
Release 63xx
Release 11xx
Release 11xx
Release 63xx
Release 63xx
Release 63xx
Release 63xx
Release 63xx
E128C switch
E152C switch
E500C switch series
E500D switch series
Release 63xx
Release 63xx
Release 63xx
Release 63xx
Release 63xx
Release 63xx
Release 66xx
S5135S-EI switch
Procedures
1.     Log in to IMC.
4.     Click Add.
f.     Click OK.
Figure 8 Adding an access device
3.     Click Add.
b.     Select Deploy ACL and manually enter ACL number 3000.
d.     Click OK.
Figure 9 Adding an access policy
6
3.     Click Add.
a.     Enter service name MACauth Services and set the service suffix to bbb. The service suffix is the authentication domain for the MAC authentication user.
IMPORTANT
IMPORTANT:
d.     Click OK.
Figure 10 Adding an access service
3.     Click Add.
c.     Select MACauth Services in the Access Service area.
e.     Click OK.
Figure 11 Adding an access user
1.     Configure advanced ACL 3000 to deny packets destined for 10.0.0.1.
[Device] acl advanced 3000
[Device-acl-ipv4-adv-3000] rule 0 deny ip destination 10.0.0.1 0
2.     Configure RADIUS-based MAC authentication:
IMPORTANT
IMPORTANT:
[Device] radius scheme 2000
[Device-radius-2000] primary authentication 10.1.1.1 1812
[Device-radius-2000] primary accounting 10.1.1.2 1813
[Device-radius-2000] key authentication simple expert
[Device-radius-2000] key accounting simple expert
[Device-radius-2000] user-name-format with-domain
[Device-radius-2000] quit
# Create ISP domain bbb and configure the ISP domain to use RADIUS scheme 2000 for user authentication, authorization, and accounting.
[Device] domain bbb
[Device-isp-bbb] authentication default radius-scheme 2000
[Device-isp-bbb] authorization default radius-scheme 2000
[Device-isp-bbb] accounting default radius-scheme 2000
IMPORTANT
IMPORTANT:
   DR member configuration conflict           : Unknown
           Username                           : mac
   Offline detect period                      : 300 s
   Quiet period                               : 60 s
   Temporary user aging period         : 60 s
 Silent MAC users:
   Server-recovery online-user-sync : Enabled
          0800-2712-3456    Authenticated
# Verify that you cannot ping the FTP server from the host.
C:\>ping 10.0.0.1
Pinging 10.0.0.1 with 32 bytes of data:
Request timed out.
Request timed out.
Request timed out.
Request timed out.
Ping statistics for 10.0.0.1:
   Packets: Sent = 4, Received = 0, Lost = 4 (100% loss),
The output shows that ACL 3000 has been assigned to GigabitEthernet 1/0/1 to deny access to the FTP server.
Configuration files
acl advanced 3000
 radius scheme 2000
 key authentication cipher $c$3$PJM7Px3rbC96Kvh8RyFWHMLatExagQ==
 key accounting cipher $c$3$rr7AO7ZuSNZ+b+deWrfb/Qg1JPc97g==
 domain bbb
 mac-authentication
 mac-authentication
