H3C Fixed Port Campus Switches Configuration Examples-6W106
HomeSupportConfigure & DeployConfiguration ExamplesH3C Fixed Port Campus Switches Configuration Examples-6W106
Table of Contents
Related Documents
89-VPLS Configuration Examples
89-VPLS Configuration Examples 686.80 KB
Overview
Virtual Private LAN Service (VPLS) delivers a point-to-multipoint L2VPN service over an MPLS or IP backbone. The provider backbone emulates a switch to connect all geographically dispersed sites of each customer network. The backbone is transparent to the customer sites. The sites can communicate with each other as if they were on the same LAN.
VPLS has the following networking models:
·     Full mesh—Suitable for MPLS backbone networks with a simple architecture and fewer PEs. The following networking modes are available under this model:
¡     LDP—Uses the LDP protocol as the signaling protocol, suitable for scenarios with a small number of sites and the number of sites is fixed.
¡     BGP auto-discovery with LDP signaling—Uses the BGP protocol to automatically discover remote PEs, and then uses the LDP protocol as the signaling protocol, suitable for scenarios with many sites but the number of sites is fixed.
¡     BGP—Uses extended BGP as the signaling protocol, suitable for scenarios with a large number of sites and the need for expansion.
·     H-VPLS—Suitable for MPLS backbone networks with a complex architecture and a large number of PEs. This model uses a hierarchical network structure that contains UPEs and NPEs. A UPE is responsible for customer site access and establishing connections with the nearest NPE, and NPEs are fully interconnected logically. UPEs exchange packets with remote sites through NPEs. The following networking modes are available under this model:
¡     LSP access—Packets are transmitted over an LSP tunnel, suitable for scenarios where UPEs support VPLS.
¡     QinQ access—Packets are encapsulated with an outer VLAN tag before being transmitted over an LSP tunnel, suitable for scenarios where UPE devices do not support VPLS.
The following information is provided based on the assumption that you have basic knowledge of VPLS.
Before you configure MPLS, you must change the device's operating mode by using the switch-mode command and restart the device for the following switches:
·     S6812 series
·     S6813 series
·     S5560X-EI series
·     S5560X-HI series
·     S5500V2-EI series
·     MS4520V2-30F
·     MS4520V2-30C
·     MS4520V2-54C
·     S6520X-HI series
·     S6520X-EI series
·     S6520X-SI series
·     S6520-SI series
·     S5000-EI series
·     MS4600 series
In a non-IRF environment, use the switch-mode 3 command to switch the device to MPLS mode.
In an IRF environment, use the switch-mode 4 command to switch the device to MPLS-IRF mode.
PEs do not transparently transmit LACP or LLDP protocol packets over a VPLS network.
If STP is globally enabled on a PE, the PE transparently transmits STP packets over the VPLS network only after you use the stp transparent enable command to enable BPDU transparent transmission on a port. For more information about the stp transparent enable command, see STP commands in Layer 2—LAN Switching Command Reference.
Example: Configuring full-mesh VPLS (LDP signaling)
As shown in Figure 1, a company has three offices in different locations: headquarters and two branches. The company requires the provider to offer a Layer 2 VPN service that interconnects the three offices at Layer 2, allowing them to share internal resources.
The company has few branches and will not expand further. To meet user requirements, configure LDP-based VPLS to enable communication between the three sites at Layer 2.
Figure 1 Network diagram
Analysis
·     Deploy MPLS on the backbone network and use LSP as the public tunnel.
·     Establish LDP PWs between the PEs for full-mesh VPLS.
·     Configure a service instance and corresponding match rules on the downlink port of each PE device to identify packets from the customer network that require a VPLS tunnel for transmission.
·     To achieve VLAN isolation between sites, create VSIs user_a and user_b and bind them to VLAN 100 and VLAN 200, respectively.
Table 1 Applicable hardware and software versions
Hardware
Software version
S6812 series
S6813 series
Release 6628Pxx series
S6550XE-HI series
Release 8106Pxx
S6526XE-HI[EI] switch series
Release 8341P02 and later
S6510 switch series
Unsupported
S6525XE-HI series
Release 8106Pxx
S5850 series
Unsupported
S5570S-EI series
Unsupported
S5560X-EI series
Release 6628Pxx
S5560X-HI series
Release 6628Pxx
S5500V2-EI series
MS4520V2-30F
MS4520V2-30C
MS4520V2-54C
MS4520V2-28S
MS4520V2-24TP
Unsupported
S6520X-HI series
S6520X-EI series
S6520X-SI series
S6520-SI series
S5000-EI series
MS4600 series
ES5500 series
S5560S-EI series
S5560S-SI series
Unsupported
S5500V3-24P-SI
S5500V3-48P-SI
Unsupported
S5500V3-SI series (excluding the S5500V3-24P-SI and S5500V3-48P-SI)
Unsupported
S5170-EI series
Unsupported
S5130S-HI series
S5130S-EI series
S5130S-SI series
S5130S-LI series
Unsupported
S5120V2-SI series
S5120V2-LI Series
Unsupported
S5120V3-EI series
Unsupported
S5120V3-36F-SI
S5120V3-28P-HPWR-SI
S5120V3-54P-PWR-SI
Unsupported
S5120V3-SI series (excluding S5120V3-36F-SI, S5120V3-28P-HPWR-SI, and S5120V3-54P-PWR-SI)
Unsupported
S5120V3-LI series
Unsupported
S3600V3-EI series
Unsupported
S3600V3-SI series
Unsupported
S3100V3-EI series
S3100V3-SI series
Unsupported
S5110V2 series
Unsupported
S5110V2-SI series
Unsupported
S5000V3-EI series
S5000V5-EI series
Unsupported
S5000E-X series
S5000X-EI series
Unsupported
E128C
E152C
E500C series
E500D series
Unsupported
MS4320V2 series
MS4320V3 series
MS4300V2 series
MS4320 series
MS4200 series
Unsupported
WS5850-WiNet series
Unsupported
WS5820-WiNet series
WS5810-WiNet series
Unsupported
WAS6000 series
Unsupported
IE4300-12P-AC & IE4300-12P-PWR
IE4300-M series
IE4320 series
Unsupported
S5135S-EI series
Unsupported
S5136S-EI series
Unsupported
Configuring IGP on the MPLS backbone network to enable communication between PEs and P devices on the backbone network
·     Configure PE 1:
# Configure a loopback interface address.
<PE1> system-view
[PE1] interface loopback 0
[PE1-LoopBack0] ip address 1.1.1.9 32
[PE1-LoopBack0] quit
# Create VLAN 2 and add Ten-GigabitEthernet 1/0/2 to VLAN 2.
[PE1] vlan 2
[PE1-vlan2] port ten-gigabitethernet 1/0/2
[PE1-vlan2] quit
# Create VLAN-interface 2.
[PE1] interface vlan-interface 2
[PE1-Vlan-interface2] ip address 10.1.1.1 24
[PE1-Vlan-interface2] quit
# Configure OSPF on PE 1 for establishing LSPs.
[PE1] ospf
[PE1-ospf-1] area 0
[PE1-ospf-1-area-0.0.0.0] network 10.1.1.0 0.0.0.255
[PE1-ospf-1-area-0.0.0.0] network 1.1.1.9 0.0.0.0
[PE1-ospf-1] quit
·     Configure PE 2:
<PE2> system-view
[PE2] interface loopback 0
[PE2-LoopBack0] ip address 3.3.3.9 32
[PE2-LoopBack0] quit
# Create VLAN 3 and add Ten-GigabitEthernet 1/0/1 to VLAN 3.
[PE2] vlan 3
[PE2-vlan3] port ten-gigabitethernet 1/0/1
[PE2-vlan3] quit
# Create VLAN-interface 3.
[PE2] interface vlan-interface 3
[PE2-Vlan-interface3] ip address 10.1.2.2 24
[PE2-Vlan-interface3] quit
# Configure OSPF on PE 2 for establishing LSPs.
[PE2] ospf
[PE2-ospf-1] area 0
[PE2-ospf-1-area-0.0.0.0] network 10.1.2.0 0.0.0.255
[PE2-ospf-1-area-0.0.0.0] network 3.3.3.9 0.0.0.0
[PE2-ospf-1] quit
·     Configure PE 3:
<PE3> system-view
[PE3] interface loopback 0
[PE3-LoopBack0] ip address 4.4.4.9 32
[PE3-LoopBack0] quit
# Create VLAN 4 and add Ten-GigabitEthernet 1/0/1 to VLAN 4.
[PE3] vlan 4
[PE3-vlan4] port ten-gigabitethernet 1/0/1
[PE3-vlan4] quit
# Create VLAN-interface 4.
[PE3] interface vlan-interface 4
[PE3-Vlan-interface4] ip address 10.1.3.2 24
[PE3-Vlan-interface4] quit
# Configure OSPF on PE 3 for establishing LSPs.
[PE3] ospf
[PE3-ospf-1] area 0
[PE3-ospf-1-area-0.0.0.0] network 10.1.3.0 0.0.0.255
[PE3-ospf-1-area-0.0.0.0] network 4.4.4.9 0.0.0.0
[PE3-ospf-1] quit
·     Configure the P device:
<P> system-view
[P] interface loopback 0
[P-LoopBack0] ip address 2.2.2.9 32
[P-LoopBack0] quit
[P] vlan 2
[P-vlan2] port ten-gigabitethernet 1/0/2
[P-vlan2] quit
# Configure VLAN-interface 2.
[P] interface vlan-interface 2
[P-Vlan-interface2] ip address 10.1.1.2 24
[P-Vlan-interface2] quit
# Create VLAN 3 and add Ten-GigabitEthernet 3/0/1 to VLAN 3.
[P] vlan 3
[P-vlan3] port ten-gigabitethernet 1/0/3
[P-vlan3] quit
# Configure VLAN-interface 3.
[P] interface vlan-interface 3
[P-Vlan-interface3] ip address 10.1.2.1 24
[P-Vlan-interface3] quit
# Create VLAN 4 and add Ten-GigabitEthernet 1/0/4 to VLAN 4.
[P] vlan 4
[P-vlan4] port ten-gigabitethernet 1/0/4
[P-vlan4] quit
# Configure VLAN-interface 4.
[P] interface vlan-interface 4
[P-Vlan-interface4] ip address 10.1.3.1 24
[P-Vlan-interface4] quit
# Configure OSPF on the P device for establishing LSPs.
[P] ospf
[P-ospf-1] area 0
[P-ospf-1-area-0.0.0.0] network 10.1.1.0 0.0.0.255
[P-ospf-1-area-0.0.0.0] network 10.1.2.0 0.0.0.255
[P-ospf-1-area-0.0.0.0] network 10.1.3.0 0.0.0.255
[P-ospf-1-area-0.0.0.0] network 2.2.2.9 0.0.0.0
[P-ospf-1-area-0.0.0.0] quit
[P-ospf-1] quit
Configuring basic MPLS and MPLS LDP on the MPLS backbone network to establish LDP LSPs
·     Configure PE 1:
# Configure an LSR ID.
[PE1] mpls lsr-id 1.1.1.9
# Enable LDP globally.
[PE1] mpls ldp
[PE1-ldp] quit
# Enable MPLS and LDP VLAN-interface 2.
[PE1-Vlan-interface2] mpls enable
[PE1-Vlan-interface2] mpls ldp enable
·     Configure PE 2:
[PE2] mpls lsr-id 3.3.3.9
[PE2] mpls ldp
[PE2-ldp] quit
# Enable MPLS and LDP on VLAN-interface 3.
[PE2-Vlan-interface3] mpls enable
[PE2-Vlan-interface3] mpls ldp enable
·     Configure PE 3:
[PE3] mpls lsr-id 4.4.4.9
[PE3] mpls ldp
[PE3-ldp] quit
# Enable MPLS and LDP on VLAN-interface 4.
[PE3-Vlan-interface4] mpls enable
[PE3-Vlan-interface4] mpls ldp enable
[P] mpls lsr-id 2.2.2.9
[P] mpls ldp
[P-ldp] quit
[P-Vlan-interface2] mpls enable
[P-Vlan-interface2] mpls ldp enable
[P-Vlan-interface3] mpls enable
[P-Vlan-interface3] mpls ldp enable
[P-Vlan-interface4] mpls enable
[P-Vlan-interface4] mpls ldp enable
Creating a VSI and configuring LDP PWs
·     Configure PE 1:
# Enable MPLS L2VPN globally.
[PE1] l2vpn enable
# Configure VSI user_a that uses LDP as the PW signaling protocol.
[PE1] vsi user_a
[PE1-vsi-user_a] pwsignaling ldp
# Establish PWs to PE 2 and PE 3.
[PE1-vsi-user_a-ldp] peer 3.3.3.9 pw-id 500
[PE1-vsi-user_a-ldp-3.3.3.9-500] quit
[PE1-vsi-user_a-ldp] peer 4.4.4.9 pw-id 500
[PE1-vsi-user_a-ldp-4.4.4.9-500] quit
[PE1-vsi-user_a-ldp] quit
[PE1-vsi-user_a] quit
# Configure VSI user_b that uses LDP as the PW signaling protocol.
[PE1] vsi user_b
[PE1-vsi-user_b] pwsignaling ldp
[PE1-vsi-user_b-ldp] peer 3.3.3.9 pw-id 600
[PE1-vsi-user_b-ldp-3.3.3.9-600] quit
[PE1-vsi-user_b-ldp] peer 4.4.4.9 pw-id 600
[PE1-vsi-user_b-ldp-4.4.4.9-600] quit
[PE1-vsi-user_b-ldp] quit
[PE1-vsi-user_b] quit
·     Configure PE 2:
[PE2] l2vpn enable
[PE2] vsi user_a
[PE2-vsi-user_a] pwsignaling ldp
# Establish PWs to PE 1 and PE 3.
[PE2-vsi-user_a-ldp] peer 1.1.1.9 pw-id 500
[PE2-vsi-user_a-ldp-1.1.1.9-500] quit
[PE2-vsi-user_a-ldp] peer 4.4.4.9 pw-id 500
[PE2-vsi-user_a-ldp-4.4.4.9-500] quit
[PE2-vsi-user_a-ldp] quit
[PE2-vsi-user_a] quit
[PE2] vsi user_b
[PE2-vsi-user_b] pwsignaling ldp
[PE2-vsi-user_b-ldp] peer 1.1.1.9 pw-id 600
[PE2-vsi-user_b-ldp-1.1.1.9-600] quit
[PE2-vsi-user_b-ldp] peer 4.4.4.9 pw-id 600
[PE2-vsi-user_b-ldp-4.4.4.9-600] quit
[PE2-vsi-user_b-ldp] quit
[PE2-vsi-user_b] quit
·     Configure PE 3:
[PE3] l2vpn enable
[PE3] vsi user_a
[PE3-vsi-user_a] pwsignaling ldp
# Establish PWs to PE 1 and PE 2.
[PE3-vsi-user_a-ldp] peer 1.1.1.9 pw-id 500
[PE3-vsi-user_a-ldp-1.1.1.9-500] quit
[PE3-vsi-user_a-ldp] peer 3.3.3.9 pw-id 500
[PE3-vsi-user_a-ldp-3.3.3.9-500] quit
[PE3-vsi-user_a-ldp] quit
[PE3-vsi-user_a] quit
[PE3] vsi user_b
[PE3-vsi-user_b] pwsignaling ldp
[PE3-vsi-user_b-ldp] peer 1.1.1.9 pw-id 600
[PE3-vsi-user_b-ldp-1.1.1.9-600] quit
[PE3-vsi-user_b-ldp] peer 3.3.3.9 pw-id 600
[PE3-vsi-user_b-ldp-3.3.3.9-600] quit
[PE3-vsi-user_b-ldp] quit
[PE3-vsi-user_b] quit
Configuring service instances for data from different VLANs and bind them to different VSIs
·     Configure PE 1:
# Create service instance 100 on Ten-GigabitEthernet 1/0/1 to match packets from VLAN 100, and bind it to VSI instance user_a.
[PE1-Ten-GigabitEthernet1/0/1] service-instance 100
[PE1-Ten-GigabitEthernet1/0/1-srv100] encapsulation s-vid 100
[PE1-Ten-GigabitEthernet1/0/1-srv100] xconnect vsi user_a
[PE1-Ten-GigabitEthernet1/0/1-srv100] quit
# Create service instance 200 on Ten-GigabitEthernet 1/0/1 to match packets from VLAN 200, and bind it to VSI instance user_b.
[PE1-Ten-GigabitEthernet1/0/1] service-instance 200
[PE1-Ten-GigabitEthernet1/0/1-srv200] encapsulation s-vid 200
[PE1-Ten-GigabitEthernet1/0/1-srv200] xconnect vsi user_b
[PE1-Ten-GigabitEthernet1/0/1-srv200] quit
·     Configure PE 2:
# Create service instance 100 on Ten-GigabitEthernet 2/0/2 to match packets from VLAN 100, and bind it to VSI instance user_a.
[PE2] interface ten-gigabitethernet 1/0/2
[PE2-Ten-GigabitEthernet1/0/2] service-instance 100
[PE2-Ten-GigabitEthernet1/0/2-srv100] encapsulation s-vid 100
[PE2-Ten-GigabitEthernet1/0/2-srv100] xconnect vsi user_a
[PE2-Ten-GigabitEthernet1/0/2-srv100] quit
# Create service instance 200 on Ten-GigabitEthernet 1/0/2 to match packets from VLAN 200, and bind it to VSI instance user_b.
[PE2-Ten-GigabitEthernet1/0/2] service-instance 200
[PE2-Ten-GigabitEthernet1/0/2-srv200] encapsulation s-vid 200
[PE2-Ten-GigabitEthernet1/0/2-srv200] xconnect vsi user_b
[PE2-Ten-GigabitEthernet1/0/2-srv200] quit
[PE2-Ten-GigabitEthernet1/0/2] quit
·     Configure PE 3:
# Create service instance 100 on Ten-GigabitEthernet 1/0/2 to match packets from VLAN 100, and bind it to VSI instance user_a.
[PE3] interface ten-gigabitethernet 1/0/2
[PE3-Ten-GigabitEthernet1/0/2] service-instance 100
[PE3-Ten-GigabitEthernet1/0/2-srv100] encapsulation s-vid 100
[PE3-Ten-GigabitEthernet1/0/2-srv100] xconnect vsi user_a
[PE3-Ten-GigabitEthernet1/0/2-srv100] quit
[PE3-Ten-GigabitEthernet1/0/2] service-instance 200
[PE3-Ten-GigabitEthernet1/0/2-srv200] encapsulation s-vid 200
[PE3-Ten-GigabitEthernet1/0/2-srv200] xconnect vsi user_b
[PE3-Ten-GigabitEthernet1/0/2-srv200] quit
[PE3-Ten-GigabitEthernet1/0/2] quit
Connecting CEs to PEs
# Configure the uplink interface to the PE to allow tagged packets from the site to pass through. The following uses CE 1 as an example. Configure CE2 and CE2 in the same way CE1 is configured.
<CE1> system-view
[CE1] vlan 100
[CE1-vlan100] quit
[CE1] vlan 200
[CE1-vlan200] quit
[CE1] interface ten-gigabitethernet 1/0/1
[CE1-Ten-GigabitEthernet1/0/1] port link-type trunk
[CE1-Ten-GigabitEthernet1/0/1] port trunk permit vlan 100 200
Verifying the public network LSPs
# Execute the display mpls ldp lsp command to verify that the LSPs have been established.
[PE1] display mpls ldp lsp
Status Flags: * - stale, L - liberal
Statistics:
  FECs: 4      Ingress LSPs: 3     Transit LSPs: 3     Egress LSPs: 1
FEC                In/Out Label    Nexthop         OutInterface
1.1.1.9/32         3/-
                   -/1151(L)
                   -/1151(L)
                   -/1151(L)
2.2.2.9/32         -/3             10.1.1.2        Vlan2
                   1151/3          10.1.1.2        Vlan2
                   -/1150(L)
                   -/1150(L)
3.3.3.9/32         -/1150          10.1.1.2        Vlan2
                   1150/1150       10.1.1.2        Vlan2
                   -/3(L)
                   -/1149(L)
4.4.4.9/32         -/1149          10.1.1.2        Vlan2
                   1149/1149       10.1.1.2        Vlan2
                   -/1149(L)
                   -/3(L)
Verifying PW status
# Execute the display l2vpn pw command on each PE. The output shows that a PW has been established and in up state.
[PE1] display l2vpn pw
Flags: M - main, B - backup, H - hub link, S - spoke link, N - no split horizon
Total number of PWs: 4
4 up, 0 blocked, 0 down, 0 defect, 0 idle, 0 duplicate
VSI Name: user_a
Peer            PW ID/Rmt Site    In/Out Label    Proto   Flag  Link ID  State
3.3.3.9         500               131198/131198   LDP     M     64       Up
4.4.4.9         500               131199/1150     LDP     M     65       Up
VSI Name: user_b
3.3.3.9         600               131196/131196   LDP     M     64       Up
4.4.4.9         600               131197/1147     LDP     M     65       Up
# Use ping to identify whether hosts within the same VLAN but at different sites can reach each other. If the ping operation succeeds, the VPLS is created successfully.
Configuration files
·     PE 1
ospf 1
 area 0.0.0.0
 mpls lsr-id 1.1.1.9
vlan 2
mpls ldp
 l2vpn enable
vsi user_a
 pwsignaling ldp
vsi user_b
 pwsignaling ldp
interface LoopBack0
 ip address 1.1.1.9 255.255.255.255
interface Vlan-interface2
 mpls enable
 mpls ldp enable
 port link-mode bridge
  xconnect vsi user_a
  xconnect vsi user_b
 port access vlan 2
·     PE 2
ospf 1
 area 0.0.0.0
 mpls lsr-id 3.3.3.9
vlan 3
mpls ldp
 l2vpn enable
vsi user_a
 pwsignaling ldp
vsi user_b
 pwsignaling ldp
interface LoopBack0
 ip address 3.3.3.9 255.255.255.255
interface Vlan-interface3
 ip address 10.1.2.2 255.255.255.0
 mpls enable
 mpls ldp enable
 port access vlan 3
  xconnect vsi user_a
  xconnect vsi user_b
·     PE 3
ospf 1
 area 0.0.0.0
 mpls lsr-id 4.4.4.9
vlan 4
mpls ldp
 l2vpn enable
vsi user_a
 pwsignaling ldp
vsi user_b
 pwsignaling ldp
interface LoopBack0
 ip address 4.4.4.9 255.255.255.255
interface Vlan-interface4
 ip address 10.1.3.2 255.255.255.0
 mpls enable
 mpls ldp enable
 port access vlan 4
  xconnect vsi user_a
  xconnect vsi user_b
·     P
ospf 1
 area 0.0.0.0
 mpls lsr-id 2.2.2.9
vlan 2 to 4
mpls ldp
interface LoopBack0
 ip address 2.2.2.9 255.255.255.255
 mpls enable
 mpls ldp enable
 ip address 10.1.2.1 255.255.255.0
 mpls enable
 mpls ldp enable
 ip address 10.1.3.1 255.255.255.0
 mpls enable
 mpls ldp enable
 port access vlan 2
 port access vlan 3
interface Ten-GigabitEthernet1/0/4
 port access vlan 4
·     CE 1 through CE 3
vlan 100
vlan 200
Example: Configuring full-mesh VPLS (BGP auto-discovery LDP signaling)
As shown in Figure 2, a company has multiple offices in different locations: headquarters and several branches. The company requires the provider to offer a Layer 2 VPN service that interconnects all offices at Layer 2, allowing them to share internal resources.
The company has many branches and will not expand further. To meet user requirements and reduce configuration and maintenance workload, use BGP auto-discovery LDP signaling to enable Layer 2 communication between all user sites.
Figure 2 Network diagram
Analysis
·     Configure and establish a BGP auto-discovery LDP signaling-based PW between any two PEs to achieve full mesh of PWs.
Table 2 Applicable hardware and software versions
Hardware
Software version
S6812 series
S6813 series
S6550XE-HI series
Release 8106Pxx
S6510 switch series
Unsupported
S6525XE-HI series
Release 8106Pxx
S5850 series
Unsupported
S5570S-EI series
Unsupported
S5560X-EI series
Release 6628Pxx
S5560X-HI series
Release 6628Pxx
S5500V2-EI series
MS4520V2-30F
MS4520V2-30C
MS4520V2-54C
MS4520V2-28S
MS4520V2-24TP
Unsupported
S6520X-HI series
S6520X-EI series
S6520X-SI series
S6520-SI series
S5000-EI series
MS4600 series
ES5500 series
S5560S-EI series
S5560S-SI series
Unsupported
S5500V3-24P-SI
S5500V3-48P-SI
Unsupported
Unsupported
S5170-EI series
Unsupported
S5130S-HI series
S5130S-EI series
S5130S-SI series
S5130S-LI series
Unsupported
S5120V2-SI series
S5120V2-LI Series
Unsupported
S5120V3-EI series
Unsupported
S5120V3-36F-SI
S5120V3-28P-HPWR-SI
S5120V3-54P-PWR-SI
Unsupported
Unsupported
S5120V3-LI series
Unsupported
S3600V3-EI series
Unsupported
S3600V3-SI series
Unsupported
S3100V3-EI series
S3100V3-SI series
Unsupported
S5110V2 series
Unsupported
S5110V2-SI series
Unsupported
S5000V3-EI series
S5000V5-EI series
Unsupported
S5000E-X series
S5000X-EI series
Unsupported
E128C
E152C
E500C series
E500D series
Unsupported
MS4320V2 series
MS4320V3 series
MS4300V2 series
MS4320 series
MS4200 series
Unsupported
WS5850-WiNet series
Unsupported
WS5820-WiNet series
WS5810-WiNet series
Unsupported
WAS6000 series
Unsupported
IE4300-M series
IE4320 series
Unsupported
S5135S-EI series
Unsupported
S5136S-EI series
Unsupported
·     Configure PE 1:
<PE1> system-view
[PE1] vlan 2
[PE1-vlan2] quit
[PE1] ospf
[PE1-ospf-1] area 0
[PE1-ospf-1] quit
·     Configure PE 2:
<PE2> system-view
[PE2] vlan 3
[PE2-vlan3] quit
[PE2] ospf
[PE2-ospf-1] area 0
[PE2-ospf-1] quit
·     Configure PE 3:
<PE3> system-view
[PE3] vlan 4
[PE3-vlan4] quit
[PE3] ospf
[PE3-ospf-1] area 0
[PE3-ospf-1] quit
<P> system-view
[P-LoopBack0] quit
[P] vlan 2
[P-vlan2] quit
[P] vlan 3
[P-vlan3] quit
[P] vlan 4
[P-vlan4] quit
[P] ospf
[P-ospf-1] area 0
[P-ospf-1] quit
·     Configure PE 1:
[PE1] mpls ldp
[PE1-ldp] quit
·     Configure PE 2:
[PE2] mpls ldp
[PE2-ldp] quit
·     Configure PE 3:
[PE3] mpls ldp
[PE3-ldp] quit
[P] mpls ldp
[P-ldp] quit
Creating a VSI and configuring BGP auto-discovery LDP PWs
·     Configure PE 1:
# Create an IBGP connection to PE 2 and PE 3, respectively.
[PE1] bgp 100
[PE1-bgp-default] peer 4.4.4.9 as-number 100
[PE1-bgp-default] peer 4.4.4.9 connect-interface loopback 0
# Enable BGP to advertise L2VPN information.
[PE1-bgp-default] address-family l2vpn
[PE1-bgp-default-l2vpn] peer 3.3.3.9 enable
[PE1-bgp-default-l2vpn] peer 4.4.4.9 enable
[PE1-bgp-default-l2vpn] quit
[PE1-bgp-default] quit
[PE1] l2vpn enable
# Create VSI user_a that automatically discovers neighbors through BGP.
[PE1] vsi user_a
[PE1-vsi-user_a] auto-discovery bgp
# Configure an RD and route target for the auto-discovery VSI.
[PE1-vsi-user_a-auto] route-distinguisher 100:1
[PE1-vsi-user_a-auto] vpn-target 111:1
# Use LDP to create a PW to an automatically discovered remote PE.
[PE1-vsi-user_a-auto] signaling-protocol ldp
# Configure a VPLS ID for the VSI.
[PE1-vsi-user_a-auto-ldp] vpls-id 100:100
[PE1-vsi-user_a-auto-ldp] quit
[PE1-vsi-user_a-auto] quit
# Create VSI user_b that automatically discovers neighbors through BGP.
[PE1] vsi user_b
[PE1-vsi-user_b] auto-discovery bgp
[PE1-vsi-user_b-auto] route-distinguisher 200:1
[PE1-vsi-user_b-auto] vpn-target 222:1
[PE1-vsi-user_b-auto] signaling-protocol ldp
[PE1-vsi-user_b-auto-ldp] vpls-id 200:200
[PE1-vsi-user_b-auto-ldp] quit
[PE1-vsi-user_b-auto] quit
·     Configure PE 2:
# Create an IBGP connection to PE 1 and PE 3, respectively.
[PE2] bgp 100
[PE2-bgp-default] peer 1.1.1.9 as-number 100
[PE2-bgp-default] peer 1.1.1.9 connect-interface loopback 0
[PE2-bgp-default] peer 4.4.4.9 as-number 100
[PE2-bgp-default] peer 4.4.4.9 connect-interface loopback 0
[PE2-bgp-default] address-family l2vpn
[PE2-bgp-default-l2vpn] peer 1.1.1.9 enable
[PE2-bgp-default-l2vpn] peer 4.4.4.9 enable
[PE2-bgp-default-l2vpn] quit
[PE2-bgp-default] quit
[PE2] l2vpn enable
[PE2] vsi user_a
[PE2-vsi-user_a] auto-discovery bgp
[PE2-vsi-user_a-auto] route-distinguisher 100:1
[PE2-vsi-user_a-auto] vpn-target 111:1
[PE2-vsi-user_a-auto] signaling-protocol ldp
[PE2-vsi-user_a-auto-ldp] vpls-id 100:100
[PE2-vsi-user_a-auto-ldp] quit
[PE2-vsi-user_a-auto] quit
[PE2] vsi user_b
[PE2-vsi-user_b] auto-discovery bgp
[PE2-vsi-user_b-auto] route-distinguisher 200:1
[PE2-vsi-user_b-auto] vpn-target 222:1
[PE2-vsi-user_b-auto] signaling-protocol ldp
[PE2-vsi-user_b-auto-ldp] vpls-id 200:200
[PE2-vsi-user_b-auto-ldp] quit
[PE2-vsi-user_b-auto] quit
·     Configure PE 3:
# Create an IBGP connection to PE 1 and PE 2, respectively.
[PE3] bgp 100
[PE3-bgp-default] peer 1.1.1.9 as-number 100
[PE3-bgp-default] peer 1.1.1.9 connect-interface loopback 0
[PE3-bgp-default] peer 3.3.3.9 as-number 100
[PE3-bgp-default] peer 3.3.3.9 connect-interface loopback 0
[PE3-bgp-default] address-family l2vpn
[PE3-bgp-default-l2vpn] peer 1.1.1.9 enable
[PE3-bgp-default-l2vpn] peer 3.3.3.9 enable
[PE3-bgp-default-l2vpn] quit
[PE3-bgp-default] quit
[PE3] l2vpn enable
[PE3] vsi user_a
[PE3-vsi-user_a] auto-discovery bgp
[PE3-vsi-user_a-auto] route-distinguisher 100:1
[PE3-vsi-user_a-auto] vpn-target 111:1
[PE3-vsi-user_a-auto] signaling-protocol ldp
[PE3-vsi-user_a-auto-ldp] vpls-id 100:100
[PE3-vsi-user_a-auto-ldp] quit
[PE3-vsi-user_a-auto] quit
[PE3] vsi user_b
[PE3-vsi-user_b] auto-discovery bgp
[PE3-vsi-user_b-auto] route-distinguisher 200:1
[PE3-vsi-user_b-auto] vpn-target 222:1
[PE3-vsi-user_b-auto] signaling-protocol ldp
[PE3-vsi-user_b-auto-ldp] vpls-id 200:200
[PE3-vsi-user_b-auto-ldp] quit
[PE3-vsi-user_b-auto] quit
·     Configure PE 1:
·     Configure PE 2:
·     Configure PE 3:
# Configure interfaces on other CEs in the same way Ten-GigabitEthernet1/0/2 is configured.
# Configure the uplink interface to the PE to allow tagged packets from the site to pass through. The following uses CE 1 as an example. Configure other CEs in the same way CE1 is configured.
<CE1> system-view
[CE1] vlan 100
[CE1-vlan100] quit
[CE1] vlan 200
[CE1-vlan200] quit
Statistics:
1.1.1.9/32         3/-
                   -/1148(L)
                   -/1151(L)
                   -/1151(L)
                   -/1150(L)
                   -/1150(L)
3.3.3.9/32         -/1146          10.1.1.2        Vlan2
                   1149/1146       10.1.1.2        Vlan2
                   -/1149(L)
                   -/3(L)
4.4.4.9/32         -/1147          10.1.1.2        Vlan2
                   1150/1147       10.1.1.2        Vlan2
                   -/3(L)
                   -/1149(L)
Verifying PW status
VSI Name: user_a
3.3.3.9         -                 131195/131195   LDP     M     64       Up
4.4.4.9         -                 131194/1145     LDP     M     65       Up
VSI Name: user_b
4.4.4.9         -                 131193/1143     LDP     M     64       Up
3.3.3.9         -                 131192/131192   LDP     M     65       Up
Configuration files
·     PE 1
ospf 1
 area 0.0.0.0
 mpls lsr-id 1.1.1.9
vlan 2
mpls ldp
 l2vpn enable
vsi user_a
 auto-discovery bgp
  vpn-target 111:1 export-extcommunity
  vpn-target 111:1 import-extcommunity
   vpls-id 100:100
vsi user_b
 auto-discovery bgp
  vpn-target 222:1 export-extcommunity
  vpn-target 222:1 import-extcommunity
   vpls-id 200:200
interface LoopBack0
 mpls enable
 mpls ldp enable
  xconnect vsi user_a
  xconnect vsi user_b
 port access vlan 2
bgp 100
 peer 3.3.3.9 connect-interface LoopBack0
 peer 4.4.4.9 connect-interface LoopBack0
  peer 3.3.3.9 enable
  peer 4.4.4.9 enable
·     PE 2
ospf 1
 area 0.0.0.0
 mpls lsr-id 3.3.3.9
vlan 3
mpls ldp
 l2vpn enable
vsi user_a
 auto-discovery bgp
   vpls-id 100:100
vsi user_b
 auto-discovery bgp
   vpls-id 200:200
interface LoopBack0
 mpls enable
 mpls ldp enable
 port access vlan 3
  xconnect vsi user_a
  xconnect vsi user_b
bgp 100
 peer 1.1.1.9 connect-interface LoopBack0
  peer 1.1.1.9 enable
  peer 4.4.4.9 enable
·     PE 3
ospf 1
 area 0.0.0.0
 mpls lsr-id 4.4.4.9
vlan 4
mpls ldp
 l2vpn enable
vsi user_a
 auto-discovery bgp
   vpls-id 100:100
vsi user_b
 auto-discovery bgp
   vpls-id 200:200
interface LoopBack0
 mpls enable
 mpls ldp enable
 port access vlan 4
  xconnect vsi user_a
  xconnect vsi user_b
bgp 100
  peer 1.1.1.9 enable
  peer 3.3.3.9 enable
·     P
ospf 1
 area 0.0.0.0
 mpls lsr-id 2.2.2.9
vlan 2 to 4
mpls ldp
interface LoopBack0
 mpls enable
 mpls ldp enable
 mpls enable
 mpls ldp enable
 mpls enable
 mpls ldp enable
 port access vlan 2
 port access vlan 3
 port access vlan 4
·     CE 1 through CE n
vlan 100
vlan 200
Example: Configuring full-mesh VPLS (BGP)
As shown in Figure 3, a company has 10 data centers located in different geographical areas and plans to add 15 more data centers. The company requires the provider to offer Layer 2 VPN services, enabling all data centers to interconnect at Layer 2 and share data resources.
The company has many data center sites and requires large-scale expansion. To meet user requirements, deploy BGP-based VPLS services.
Figure 3 Network diagram
Analysis
·     Deploy BGP-based VPLS service on PEs and configure label blocks to meet expansion requirements.
Table 3 Applicable hardware and software versions
Hardware
Software version
S6812 series
S6813 series
S6550XE-HI series
Release 8106Pxx
S6510 switch series
Unsupported
S6525XE-HI series
Release 8106Pxx
S5850 series
Unsupported
S5570S-EI series
Unsupported
S5560X-EI series
Release 6628Pxx
S5560X-HI series
Release 6628Pxx
S5500V2-EI series
MS4520V2-30F
MS4520V2-30C
MS4520V2-54C
MS4520V2-28S
MS4520V2-24TP
Unsupported
S6520X-HI series
S6520X-EI series
S6520X-SI series
S6520-SI series
S5000-EI series
MS4600 series
ES5500 series
S5560S-EI series
S5560S-SI series
Unsupported
S5500V3-24P-SI
S5500V3-48P-SI
Unsupported
Unsupported
S5170-EI series
Unsupported
S5130S-HI series
S5130S-EI series
S5130S-SI series
S5130S-LI series
Unsupported
S5120V2-SI series
S5120V2-LI Series
Unsupported
S5120V3-EI series
Unsupported
S5120V3-36F-SI
S5120V3-28P-HPWR-SI
S5120V3-54P-PWR-SI
Unsupported
Unsupported
S5120V3-LI series
Unsupported
S3600V3-EI series
Unsupported
S3600V3-SI series
Unsupported
S3100V3-EI series
S3100V3-SI series
Unsupported
S5110V2 series
Unsupported
S5110V2-SI series
Unsupported
S5000V3-EI series
S5000V5-EI series
Unsupported
S5000E-X series
S5000X-EI series
Unsupported
E128C
E152C
E500C series
E500D series
Unsupported
MS4320V2 series
MS4320V3 series
MS4300V2 series
MS4320 series
MS4200 series
Unsupported
WS5850-WiNet series
Unsupported
WS5820-WiNet series
WS5810-WiNet series
Unsupported
WAS6000 series
Unsupported
IE4300-M series
IE4320 series
Unsupported
S5135S-EI series
Unsupported
S5136S-EI series
Unsupported
·     Configure PE 1:
<PE1> system-view
[PE1] vlan 2
[PE1-vlan2] quit
[PE1] ospf
[PE1-ospf-1] area 0
[PE1-ospf-1] quit
·     Configure PE 2:
<PE2> system-view
[PE2] vlan 3
[PE2-vlan3] quit
[PE2] ospf
[PE2-ospf-1] area 0
[PE2-ospf-1] quit
·     Configure PE 3:
<PE3> system-view
[PE3] vlan 4
[PE3-vlan4] quit
[PE3] ospf
[PE3-ospf-1] area 0
[PE3-ospf-1] quit
<P> system-view
[P-LoopBack0] quit
[P] vlan 2
[P-vlan2] quit
[P] vlan 3
[P-vlan3] quit
[P] vlan 4
[P-vlan4] quit
[P] ospf
[P-ospf-1] area 0
[P-ospf-1] quit
·     Configure PE 1:
[PE1] mpls ldp
[PE1-ldp] quit
·     Configure PE 2:
[PE2] mpls ldp
[PE2-ldp] quit
·     Configure PE 3:
[PE3] mpls ldp
[PE3-ldp] quit
[P] mpls ldp
[P-ldp] quit
Creating a VSI and configuring BGP PWs
·     Configure PE 1:
[PE1] bgp 100
[PE1] l2vpn enable
[PE1] vsi user_a
# Use BGP to create a PW to an automatically discovered remote PE.
[PE1-vsi-user_a-auto] signaling-protocol bgp
# Configure the site number for PE 1 in this instance (using 1 as an example), and the number of PEs that can establish connections in this instance (the value should be 25, because there are 10 sites in the network and 15 more will be added).
[PE1-vsi-user_a-auto-bgp] site 1 range 25
[PE1-vsi-user_a-auto-bgp] quit
[PE1] vsi user_b
[PE1-vsi-user_b-auto] signaling-protocol bgp
[PE1-vsi-user_b-auto-bgp] site 1 range 25
[PE1-vsi-user_b-auto-bgp] quit
·     Configure PE 2:
[PE2] bgp 100
[PE2] l2vpn enable
[PE2] vsi user_a
[PE2-vsi-user_a-auto] signaling-protocol bgp
# Configure the site number for PE 2 in this instance (using 2 as an example), and the number of PEs that can establish connections in this instance (the value should be 25, because there are 10 sites in the network and 15 more will be added).
[PE2-vsi-user_a-auto-bgp] site 2 range 25
[PE2-vsi-user_a-auto-bgp] quit
[PE2] vsi user_b
[PE2-vsi-user_b-auto] signaling-protocol bgp
[PE2-vsi-user_b-auto-bgp] site 2 range 25
[PE2-vsi-user_b-auto-bgp] quit
·     Configure PE 3:
[PE3] bgp 100
[PE3] l2vpn enable
[PE3] vsi user_a
[PE3-vsi-user_a-auto] signaling-protocol bgp
# Configure the site number for PE 3 in this instance (using 3 as an example), and the number of PEs that can establish connections in this instance (the value should be 25, because there are 10 sites in the network and 15 more will be added).
[PE3-vsi-user_a-auto-bgp] site 3 range 25
[PE3-vsi-user_a-auto-bgp] quit
[PE3] vsi user_b
[PE3-vsi-user_b-auto] signaling-protocol bgp
[PE3-vsi-user_b-auto-bgp] site 3 range 25
[PE3-vsi-user_b-auto-bgp] quit
·     Configure PE 1:
·     Configure PE 2:
·     Configure PE 3:
# Create service instance 100 on Ten-GigabitEthernet 1/0/2 to match packets from VLAN 100, and bind it to VSI user_a.
<CE1> system-view
[CE1] vlan 100
[CE1-vlan100] quit
[CE1] vlan 200
[CE1-vlan200] quit
Statistics:
1.1.1.9/32         3/-
                   -/1151(L)
Verifying PW status
Total number of PWs: 2, 2 up, 0 blocked, 0 down, 0 defect
VSI Name: user_a
3.3.3.9         2                 131074/131073   BGP     M     257      Up
4.4.4.9         3                 131075/131073   BGP     M     258      Up
VSI Name: user_b
3.3.3.9         2                 131071/131070   BGP     M     257      Up
4.4.4.9         3                 131072/131070   BGP     M     258      Up
Configuration files
·     PE 1
ospf 1
 area 0.0.0.0
 mpls lsr-id 1.1.1.9
vlan 2
mpls ldp
 l2vpn enable
vsi user_a
 auto-discovery bgp
   site 1 range 25 default-offset 0
vsi user_b
 auto-discovery bgp
interface LoopBack0
 mpls enable
 mpls ldp enable
  xconnect vsi user_a
  xconnect vsi user_b
 port access vlan 2
bgp 100
  peer 3.3.3.9 enable
  peer 4.4.4.9 enable
·     PE 2
ospf 1
 area 0.0.0.0
 mpls lsr-id 3.3.3.9
vlan 3
mpls ldp
 l2vpn enable
vsi user_a
 auto-discovery bgp
   site 2 range 25 default-offset 0
vsi user_b
 auto-discovery bgp
interface LoopBack0
 mpls enable
 mpls ldp enable
 port access vlan 3
  xconnect vsi user_a
  xconnect vsi user_b
bgp 100
  peer 1.1.1.9 enable
  peer 4.4.4.9 enable
·     PE 3
ospf 1
 area 0.0.0.0
 mpls lsr-id 4.4.4.9
vlan 4
mpls ldp
 l2vpn enable
vsi user_a
 auto-discovery bgp
   site 3 range 25 default-offset 0
vsi user_b
 auto-discovery bgp
interface LoopBack0
 mpls enable
 mpls ldp enable
 port access vlan 4
  xconnect vsi user_a
  xconnect vsi user_b
bgp 100
  peer 1.1.1.9 enable
  peer 3.3.3.9 enable
·     P
ospf 1
 area 0.0.0.0
 mpls lsr-id 2.2.2.9
vlan 2 to 4
mpls ldp
interface LoopBack0
 mpls enable
 mpls ldp enable
 mpls enable
 mpls ldp enable
 mpls enable
 mpls ldp enable
 port access vlan 2
 port access vlan 3
 port access vlan 4
·     CE 1 through CE 10
vlan 100
vlan 200
Example: Configuring H-VPLS (LSP access)
A provider provides VPLS service, with numerous users in various locations. To simplify the network structure and reduce device load and maintenance workload, deploy H-VPLS on the network.
As shown in Figure 4, make sure the following requirements are met:
·     Branches at different locations connect to the carrier MPLS network through UPEs that support MPLS L2VPN.
·     NPEs connect to the UPEs by using the LSP access mode.
·     The UPEs are dual homed to two NPEs for increased reliability.
Figure 4 Network diagram
Device
IP address
Device
IP address
UPE 1
Loop0
11.1.1.1/32
UPE 2
Loop0
14.1.1.1/32
Vlan-int10
11.1.2.1/24
Vlan-int12
20.1.1.1/24
Vlan-int11
11.1.3.1/24
Vlan-int13
20.1.2.1/24
NPE 1
Loop0
1.1.1.1/32
NPE 3
Loop0
3.3.3.3/32
Vlan-int10
11.1.2.2/24
Vlan-int13
20.1.2.2/24
NPE 2
Loop0
2.2.2.2/32
NPE 4
Loop0
4.4.4.4/32
Vlan-int11
11.1.3.2/24
Vlan-int12
20.1.1.2/24
Analysis
·     To negotiate the inner labels, establish remote LDP peer relationships between the UPEs and all connected NPEs, as well as between any two NPEs.
·     On the UPEs, set up primary/backup peers to determine the primary and backup status of the links.
·     Configure a service instance and corresponding match rules on the downlink port of each UPE identify packets from the customer network that require a VPLS tunnel for transmission.
Table 4 Applicable hardware and software versions
Hardware
Software version
S6812 series
S6813 series
S6550XE-HI series
Release 8106Pxx
S6510 switch series
Unsupported
S6525XE-HI series
Release 8106Pxx
S5850 series
Unsupported
S5570S-EI series
Unsupported
S5560X-EI series
Release 6628Pxx
S5560X-HI series
Release 6628Pxx
S5500V2-EI series
MS4520V2-30F
MS4520V2-30C
MS4520V2-54C
MS4520V2-28S
MS4520V2-24TP
Unsupported
S6520X-HI series
S6520X-EI series
S6520X-SI series
S6520-SI series
S5000-EI series
MS4600 series
ES5500 series
S5560S-EI series
S5560S-SI series
Unsupported
S5500V3-24P-SI
S5500V3-48P-SI
Unsupported
Unsupported
S5170-EI series
Unsupported
S5130S-HI series
S5130S-EI series
S5130S-SI series
S5130S-LI series
Unsupported
S5120V2-SI series
S5120V2-LI Series
Unsupported
S5120V3-EI series
Unsupported
S5120V3-36F-SI
S5120V3-28P-HPWR-SI
S5120V3-54P-PWR-SI
Unsupported
Unsupported
S5120V3-LI series
Unsupported
S3600V3-EI series
Unsupported
S3600V3-SI series
Unsupported
S3100V3-EI series
S3100V3-SI series
Unsupported
S5110V2 series
Unsupported
S5110V2-SI series
Unsupported
S5000V3-EI series
S5000V5-EI series
Unsupported
S5000E-X series
S5000X-EI series
Unsupported
E128C
E152C
E500C series
E500D series
Unsupported
MS4320V2 series
MS4320V3 series
MS4300V2 series
MS4320 series
MS4200 series
Unsupported
WS5850-WiNet series
Unsupported
WS5820-WiNet series
WS5810-WiNet series
Unsupported
WAS6000 series
Unsupported
IE4300-M series
IE4320 series
Unsupported
S5135S-EI series
Unsupported
S5136S-EI series
Unsupported
Configuring basic network settings
1.     Create interfaces for UPE and NPE devices as shown in Figure 4 and configure IP addresses for them. (Details not shown.)
2.     Configure IGP on the MPLS backbone network to ensure that all interfaces on the NPEs and UPEs are reachable to each other. (Details not shown.)
3.     Configure basic MPLS and MPLS LDP on the backbone network to establish LDP LSPs. (Details not shown.)
4.     Configure interfaces on each CE that connect to UPEs as a trunk port and permit packets from VLAN 100 and VLAN 200 to pass through with tags. (Details not shown.)
Configuring UPE 1
# Configure basic MPLS.
<UPE1> system-view
[UPE1] mpls lsr-id 11.1.1.1
[UPE1] mpls ldp
[UPE1-ldp] quit
# Configure basic MPLS capability on the interface connected with NPE 1.
[UPE1] interface vlan-interface 10
[UPE1-Vlan-interface10] mpls enable
[UPE1-Vlan-interface10] mpls ldp enable
[UPE1-Vlan-interface10] quit
# Configure basic MPLS capability on the interface connected with NPE 2.
[UPE1] interface vlan-interface 11
[UPE1-Vlan-interface11] mpls enable
[UPE1-Vlan-interface11] mpls ldp enable
[UPE1-Vlan-interface11] quit
# Enable MPLS L2VPN.
[UPE1] l2vpn enable
[UPE1] vsi user_a
[UPE1-vsi-user_a] pwsignaling ldp
# Specify the switchover mode and set the wait time to 120 seconds for the switchover.
[UPE1-vsi-user_a-ldp] revertive wtr 120
# Configure a static PW between UPE 1 and NPE 1, and a backup static PW between UPE 1 and NPE 2.
[UPE1-vsi-user_a-ldp] peer 1.1.1.1 pw-id 500
[UPE1-vsi-user_a-ldp-1.1.1.1-500] backup-peer 2.2.2.2 pw-id 500
[UPE1-vsi-user_a-ldp-1.1.1.1-500-backup] quit
[UPE1-vsi-user_a-ldp-1.1.1.1-500] quit
[UPE1-vsi-user_a-ldp] quit
[UPE1-vsi-user_a] quit
[UPE1] vsi user_b
[UPE1-vsi-user_b] pwsignaling ldp
[UPE1-vsi-user_b-ldp] revertive wtr 120
[UPE1-vsi-user_b-ldp] peer 1.1.1.1 pw-id 600
[UPE1-vsi-user_b-ldp-1.1.1.1-600] backup-peer 2.2.2.2 pw-id 600
[UPE1-vsi-user_b-ldp-1.1.1.1-600-backup] quit
[UPE1-vsi-user_b-ldp-1.1.1.1-600] quit
[UPE1-vsi-user_b-ldp] quit
[UPE1-vsi-user_b] quit
# Create service instance 1000 on Ten-GigabitEthernet 1/0/1 connected to Site A to match packets from VLAN 100, and bind it to VSI user_a.
[UPE1] interface ten-gigabitethernet 1/0/1
[UPE1-Ten-GigabitEthernet1/0/1] service-instance 1000
[UPE1-Ten-GigabitEthernet1/0/1-srv1000] encapsulation s-vid 100
[UPE1-Ten-GigabitEthernet1/0/1-srv1000] xconnect vsi user_a
[UPE1-Ten-GigabitEthernet1/0/1-srv1000] quit
# Create service instance 2000 on Ten-GigabitEthernet 1/0/1 to match packets from VLAN 200, and bind it to VSI user_b.
[UPE1-Ten-GigabitEthernet1/0/1] service-instance 2000
[UPE1-Ten-GigabitEthernet1/0/1-srv2000] encapsulation s-vid 200
[UPE1-Ten-GigabitEthernet1/0/1-srv2000] xconnect vsi user_b
[UPE1-Ten-GigabitEthernet1/0/1-srv2000] quit
# Create two service instances on Ten-GigabitEthernet1/0/2 connected to Site B to match packets from VALN 100 and VLAN 200, respectively, and bind VLAN 100 to VSI user_a and VLAN 200 to VSI user_b.
[UPE1] interface ten-gigabitethernet 1/0/2
[UPE1-Ten-GigabitEthernet1/0/2] service-instance 1000
[UPE1-Ten-GigabitEthernet1/0/2-srv1000] encapsulation s-vid 100
[UPE1-Ten-GigabitEthernet1/0/2-srv1000] xconnect vsi user_a
[UPE1-Ten-GigabitEthernet1/0/2-srv1000] quit
[UPE1-Ten-GigabitEthernet1/0/2] service-instance 2000
[UPE1-Ten-GigabitEthernet1/0/2-srv2000] encapsulation s-vid 200
[UPE1-Ten-GigabitEthernet1/0/2-srv2000] xconnect vsi user_b
[UPE1-Ten-GigabitEthernet1/0/2-srv2000] quit
Configuring NPE 1
# Configure basic MPLS capability on the interface connected with UPE 1.
<NPE1> system-view
[NPE1] interface vlan-interface 10
[NPE1-Vlan-interface10] mpls enable
[NPE1-Vlan-interface10] mpls ldp enable
[NPE1-Vlan-interface10] quit
[NPE1] l2vpn enable
[NPE1] vsi user_a
[NPE1-vsi-user_a] pwsignaling ldp
# Specify UPE 1 as the peer.
[NPE1-vsi-user_a-ldp] peer 11.1.1.1 pw-id 500 no-split-horizon
[NPE1-vsi-user_a-ldp-11.1.1.1-500] quit
# Specify NPE 2, NPE 3, and NPE 4 as the peer NPEs.
[NPE1-vsi-user_a-ldp] peer 2.2.2.2 pw-id 500
[NPE1-vsi-user_a-ldp-2.2.2.2-500] quit
[NPE1-vsi-user_a-ldp] peer 3.3.3.3 pw-id 500
[NPE1-vsi-user_a-ldp-3.3.3.3-500] quit
[NPE1-vsi-user_a-ldp] peer 4.4.4.4 pw-id 500
[NPE1-vsi-user_a-ldp-4.4.4.4-500] quit
[NPE1-vsi-user_a-ldp] quit
[NPE1-vsi-user_a] quit
[NPE1] vsi user_b
[NPE1-vsi-user_b] pwsignaling ldp
[NPE1-vsi-user_b-ldp] peer 11.1.1.1 pw-id 600 no-split-horizon
[NPE1-vsi-user_b-ldp-11.1.1.1-500] quit
[NPE1-vsi-user_b-ldp] peer 2.2.2.2 pw-id 600
[NPE1-vsi-user_b-ldp-2.2.2.2-600] quit
[NPE1-vsi-user_b-ldp] peer 3.3.3.3 pw-id 600
[NPE1-vsi-user_b-ldp-3.3.3.3-600] quit
[NPE1-vsi-user_b-ldp] peer 4.4.4.4 pw-id 600
[NPE1-vsi-user_b-ldp-4.4.4.4-600] quit
[NPE1-vsi-user_b-ldp] quit
[NPE1-vsi-user_b] quit
Configuring NPE 2
The configuration for NPE 2 is similar to that for NPE 1 except that VLAN interfaces connected to UPE and the NPE peers for them are different. For more information about the configuration, see the configuration file.
Configuring UPE 2
<UPE2> system-view
[UPE2] mpls lsr-id 14.1.1.1
[UPE2] mpls ldp
[UPE2-ldp] quit
# Configure basic MPLS capability on the interface connected with NPE 3.
[UPE2] interface vlan-interface 13
[UPE2-Vlan-interface13] mpls enable
[UPE2-Vlan-interface13] mpls ldp enable
[UPE2-Vlan-interface13] quit
# Configure basic MPLS capability on the interface connected with NPE 4.
[UPE2] interface vlan-interface 12
[UPE2-Vlan-interface12] mpls enable
[UPE2-Vlan-interface12] mpls ldp enable
[UPE2-Vlan-interface12] quit
[UPE2] l2vpn enable
[UPE2] vsi user_a
[UPE2-vsi-user_a] pwsignaling ldp
[UPE2-vsi-user_a-ldp] revertive wtr 120
# Configure a static PW between UPE 2 and NPE 3, and a backup static PW between UPE 2 and NPE 4.
[UPE2-vsi-user_a-ldp] peer 3.3.3.3 pw-id 500
[UPE2-vsi-user_a-ldp-3.3.3.3-500] backup-peer 4.4.4.4 pw-id 500
[UPE2-vsi-user_a-ldp-3.3.3.3-500-backup] quit
[UPE2-vsi-user_a-ldp-3.3.3.3-500] quit
[UPE2-vsi-user_a-ldp] quit
[UPE2-vsi-user_a] quit
[UPE2] vsi user_b
[UPE2-vsi-user_b] pwsignaling ldp
[UPE2-vsi-user_b-ldp] revertive wtr 120
[UPE2-vsi-user_b-ldp] peer 3.3.3.3 pw-id 600
[UPE2-vsi-user_b-ldp-3.3.3.3-600] backup-peer 4.4.4.4 pw-id 600
[UPE2-vsi-user_b-ldp-3.3.3.3-600-backup] quit
[UPE2-vsi-user_b-ldp-3.3.3.3-600] quit
[UPE2-vsi-user_b-ldp] quit
[UPE2-vsi-user_b] quit
# Create service instance 1000 on Ten-GigabitEthernet 1/0/1 connected to Site E to match packets from VLAN 100, and bind it to VSI user_a.
[UPE2] interface ten-gigabitethernet 1/0/1
[UPE2-Ten-GigabitEthernet1/0/1] service-instance 1000
[UPE2-Ten-GigabitEthernet1/0/1-srv1000] encapsulation s-vid 100
[UPE2-Ten-GigabitEthernet1/0/1-srv1000] xconnect vsi user_a
[UPE2-Ten-GigabitEthernet1/0/1-srv1000] quit
[UPE2-Ten-GigabitEthernet1/0/1] service-instance 2000
[UPE2-Ten-GigabitEthernet1/0/1-srv2000] encapsulation s-vid 200
[UPE2-Ten-GigabitEthernet1/0/1-srv2000] xconnect vsi user_b
[UPE2-Ten-GigabitEthernet1/0/1-srv2000] quit
Configuring NPE 3
# Configure basic MPLS capability on the interface connected with UPE 2.
[NPE3] interface vlan-interface 13
[NPE3-Vlan-interface13] mpls enable
[NPE3-Vlan-interface13] mpls ldp enable
[NPE3-Vlan-interface13] quit
# Configure MPLS L2VPN.
[NPE3] l2vpn enable
[NPE3] vsi user_a
[NPE3-vsi-user_a] pwsignaling ldp
# Specify UPE 2 as the peer.
[NPE3-vsi-user_a-ldp] peer 14.1.1.1 pw-id 500 no-split-horizon
[NPE3-vsi-user_a-ldp-14.1.1.1-500] quit
# Specify NPE 1, NPE 2, and NPE 4 as the peer NPEs.
[NPE3-vsi-user_a-ldp] peer 1.1.1.1 pw-id 500
[NPE3-vsi-user_a-ldp-1.1.1.1-500] quit
[NPE3-vsi-user_a-ldp] peer 2.2.2.2 pw-id 500
[NPE3-vsi-user_a-ldp-2.2.2.2-500] quit
[NPE3-vsi-user_a-ldp] peer 4.4.4.4 pw-id 500
[NPE3-vsi-user_a-ldp-4.4.4.4-500] quit
[NPE3-vsi-user_a-ldp] quit
[NPE3-vsi-user_a] quit
[NPE3] vsi user_b
[NPE3-vsi-user_b] pwsignaling ldp
[NPE3-vsi-user_b-ldp] peer 14.1.1.1 pw-id 600 no-split-horizon
[NPE3-vsi-user_b-ldp-14.1.1.1-600] quit
[NPE3-vsi-user_b-ldp] peer 1.1.1.1 pw-id 600
[NPE3-vsi-user_b-ldp-1.1.1.1-600] quit
[NPE3-vsi-user_b-ldp] peer 2.2.2.2 pw-id 600
[NPE3-vsi-user_b-ldp-2.2.2.2-600] quit
[NPE3-vsi-user_b-ldp] peer 4.4.4.4 pw-id 600
[NPE3-vsi-user_b-ldp-4.4.4.4-600] quit
[NPE3-vsi-user_b-ldp] quit
[NPE3-vsi-user_b] quit
Configuring NPE 4
The configuration for NPE 4 is similar to that for NPE 3 except that VLAN interfaces connected to UPE and the NPE peers for them are different. For more information about the configuration, see the configuration file.
Verify the state of PWs on each UPE and NPE. The following uses UPE 1 and NPE 1 as an example.
# Use the display l2vpn pw command on UPE 1 to view the PW state.
[UPE1] display l2vpn pw
Total number of PWs: 4, 4 up, 0 blocked, 0 down, 0 defect
VSI Name: user_a
1.1.1.1         500               131199/131199   LDP     M     256      Up
2.2.2.2         500               131198/131199   LDP     B     257      Blocked
VSI Name: user_b
1.1.1.1         600               131195/131195   LDP     M     256      Up
2.2.2.2         600               131194/131195   LDP     B     257      Blocked
# Use the display l2vpn pw command on NPE 1 to view the PW state.
[NPE1] display l2vpn pw
VSI Name: user_a
2.2.2.2         500               131199/131199   LDP     M     256      Up
3.3.3.3         500               131198/131198   LDP     M     257      Up
4.4.4.4         500               131197/131197   LDP     M     258      Up
11.1.1.1        500               131196/131196   LDP     MN    259      Up
VSI Name: user_b
2.2.2.2         600               131195/131195   LDP     M     256      Up
3.3.3.3         600               131194/131194   LDP     M     257      Up
4.4.4.4         600               131193/131193   LDP     M     258      Up
11.1.1.1        600               131192/131192   LDP     MN    259      Up
Configuration files
Only the configuration file for H-VPLS is provided. The configuration for CEs and the routing protocol configuration between PEs are not shown.
·     UPE 1
vlan 10 to 11
mpls ldp
 l2vpn enable
vsi user_a
 pwsignaling ldp
  revertive wtr 120
vsi user_b
 pwsignaling ldp
  revertive wtr 120
interface LoopBack0
 ip address 11.1.1.1 255.255.255.255
interface Vlan-interface10
 ip address 11.1.2.1 255.255.255.0
 mpls enable
 mpls ldp enable
interface Vlan-interface11
 ip address 11.1.3.1 255.255.255.0
 mpls enable
 mpls ldp enable
  xconnect vsi user_a
  xconnect vsi user_b
  xconnect vsi user_a
  xconnect vsi user_b
·     NPE 1
 mpls lsr-id 1.1.1.1
vlan 10
mpls ldp
 l2vpn enable
vsi user_a
 pwsignaling ldp
vsi user_b
 pwsignaling ldp
interface LoopBack0
 ip address 1.1.1.1 255.255.255.255
 ip address 11.1.2.2 255.255.255.0
 mpls enable
 mpls ldp enable
·     NPE 2
 mpls lsr-id 2.2.2.2
vlan 11
mpls ldp
 l2vpn enable
vsi user_a
 pwsignaling ldp
vsi user_b
 pwsignaling ldp
interface LoopBack0
 ip address 2.2.2.2 255.255.255.255
 ip address 11.1.3.2 255.255.255.0
 mpls enable
 mpls ldp enable
·     UPE 2
vlan 12 to 13
mpls ldp
 l2vpn enable
vsi user_a
 pwsignaling ldp
  revertive wtr 120
vsi user_b
 pwsignaling ldp
  revertive wtr 120
interface LoopBack0
 ip address 14.1.1.1 255.255.255.255
interface Vlan-interface12
 ip address 20.1.1.1 255.255.255.0
 mpls enable
 mpls ldp enable
interface Vlan-interface13
 ip address 20.1.2.1 255.255.255.0
 mpls enable
 mpls ldp enable
  xconnect vsi user_a
  xconnect vsi user_b
·     NPE 3
 mpls lsr-id 3.3.3.3
vlan 13
mpls ldp
 l2vpn enable
vsi user_a
 pwsignaling ldp
vsi user_b
 pwsignaling ldp
interface LoopBack0
 ip address 3.3.3.3 255.255.255.255
 ip address 20.1.2.2 255.255.255.0
 mpls enable
 mpls ldp enable
·     NPE 4
 mpls lsr-id 4.4.4.4
vlan 12
mpls ldp
 l2vpn enable
vsi user_a
 pwsignaling ldp
vsi user_b
 pwsignaling ldp
interface LoopBack0
 ip address 4.4.4.4 255.255.255.255
 ip address 20.1.1.2 255.255.255.0
 mpls enable
 mpls ldp enable
Example: Configuring H-VPLS (QinQ access)
As shown in Figure 5, make sure the following requirements are met:
·     Branches at different locations connect to the carrier MPLS network through UPEs that do not support MPLS L2VPN.
·     NPEs connect to the UPEs by using the QinQ access mode.
Figure 5 Network diagram
Analysis
·     On the downlink port of each UPE, configure QinQ for NPEs identify user traffic by outer label.
·     Use STP to provide loop protection and redundancy for the links.
·     On the downlink port of each NPE, configure service instances to match user packets by outer label to transmit user packets over the associated PW.
·     To negotiate inner labels, establish remote LDP peer relationships between any two NPEs.
Table 5 Applicable hardware and software versions
Hardware
Software version
S6812 series
S6813 series
S6550XE-HI series
Release 8106Pxx
S6510 switch series
Unsupported
S6525XE-HI series
Release 8106Pxx
S5850 series
Unsupported
S5570S-EI series
Unsupported
S5560X-EI series
Release 6628Pxx
S5560X-HI series
Release 6628Pxx
S5500V2-EI series
MS4520V2-30F
MS4520V2-30C
MS4520V2-54C
MS4520V2-28S
MS4520V2-24TP
Unsupported
S6520X-HI series
S6520X-EI series
S6520X-SI series
S6520-SI series
S5000-EI series
MS4600 series
ES5500 series
S5560S-EI series
S5560S-SI series
Unsupported
S5500V3-24P-SI
S5500V3-48P-SI
Unsupported
Unsupported
S5170-EI series
Unsupported
S5130S-HI series
S5130S-EI series
S5130S-SI series
S5130S-LI series
Unsupported
S5120V2-SI series
S5120V2-LI Series
Unsupported
S5120V3-EI series
Unsupported
S5120V3-36F-SI
S5120V3-28P-HPWR-SI
S5120V3-54P-PWR-SI
Unsupported
Unsupported
S5120V3-LI series
Unsupported
S3600V3-EI series
Unsupported
S3600V3-SI series
Unsupported
S3100V3-EI series
S3100V3-SI series
Unsupported
S5110V2 series
Unsupported
S5110V2-SI series
Unsupported
S5000V3-EI series
S5000V5-EI series
Unsupported
S5000E-X series
S5000X-EI series
Unsupported
E128C
E152C
E500C series
E500D series
Unsupported
MS4320V2 series
MS4320V3 series
MS4300V2 series
MS4320 series
MS4200 series
Unsupported
WS5850-WiNet series
Unsupported
WS5820-WiNet series
WS5810-WiNet series
Unsupported
WAS6000 series
Unsupported
IE4300-M series
IE4320 series
Unsupported
S5135S-EI series
Unsupported
S5136S-EI series
Unsupported
1.     Configure IGP on the MPLS backbone network to ensure that all interfaces on NPEs are reachable to each other. (Details not shown.)
2.     Configure basic MPLS and MPLS LDP on the backbone network to establish LDP LSPs. (Details not shown.)
3.     Configure interfaces on each CE that connect to UPEs as a trunk port and permit packets from VLAN 100 and VLAN 200 to pass through with tags. (Details not shown.)
Configuring UPE 1
# Configure UPE1 to operate in PVST mode to avoid loops.
<UPE1> system-view
[UPE1] stp global enable
[UPE1] stp mode pvst
# Assign Ten-GigabitEthernet 1/0/1to access VLAN 1000 and enable QinQ on the interface.
[UPE1] vlan 1000
[UPE1-vlan1000] quit
[UPE1-Ten-GigabitEthernet1/0/1] port access vlan 1000
[UPE1-Ten-GigabitEthernet1/0/1] qinq enable
[UPE1-Ten-GigabitEthernet1/0/1] quit
# Assign Ten-GigabitEthernet 1/0/2 to access VLAN 1000 and enable QinQ on the interface.
[UPE1-Ten-GigabitEthernet1/0/2] port access vlan 1000
[UPE1-Ten-GigabitEthernet1/0/2] qinq enable
[UPE1-Ten-GigabitEthernet1/0/2] quit
# Configure Ten-GigabitEthernet 1/0/3 as a trunk port, and permit tagged packets from VLAN 1000 to be transmitted to NPE 1.
[UPE1] interface ten-gigabitethernet 1/0/3
[UPE1-Ten-GigabitEthernet1/0/3] port link-type trunk
[UPE1-Ten-GigabitEthernet1/0/3] port trunk permit vlan 1000
[UPE1-Ten-GigabitEthernet1/0/3] quit
# Configure Ten-GigabitEthernet 1/0/4 as a trunk port, and permit tagged packets from VLAN 1000 to be transmitted to NPE 2.
[UPE1] interface ten-gigabitethernet 1/0/4
[UPE1-Ten-GigabitEthernet1/0/4] port link-type trunk
[UPE1-Ten-GigabitEthernet1/0/4] port trunk permit vlan 1000
[UPE1-Ten-GigabitEthernet1/0/4] quit
Configuring NPE 1
[NPE1] l2vpn enable
[NPE1] vsi user_a
# Specify NPE 2, NPE 3, and NPE 4 as the remote peers.
# Create service instance 1000 on Ten-GigabitEthernet 1/0/1 that connects to UPE 1 to match packets from VLAN 1000 and bind the service instance to VSI user_a. Because upstream packets carry the service provider VLAN, the AC access mode must be VLAN (optional, defaulting to VLAN mode).
[NPE1] interface ten-gigabitethernet 1/0/1
[NPE1-Ten-GigabitEthernet1/0/1] service-instance 1000
[NPE1-Ten-GigabitEthernet1/0/1-srv1000] encapsulation s-vid 1000
[NPE1-Ten-GigabitEthernet1/0/1-srv1000] xconnect vsi user_a access-mode vlan
[NPE1-Ten-GigabitEthernet1/0/1-srv1000] quit
Configuring NPE 2
The configuration for NPE 2 is similar to that for NPE 1 except that the NPE peers for them are different. For more information about the configuration, see the configuration file.
Configuring UPE 2
# Configure UPE2 to operate in PVST mode to avoid loops.
<UPE2> system-view
[UPE2] stp global enable
[UPE2] stp mode pvst
[UPE2] vlan 1000
[UPE2-vlan1000] quit
[UPE2-Ten-GigabitEthernet1/0/1] port access vlan 1000
[UPE2-Ten-GigabitEthernet1/0/1] qinq enable
[UPE2-Ten-GigabitEthernet1/0/1] quit
# Configure Ten-GigabitEthernet 1/0/3 as a trunk port, and permit tagged packets from VLAN 1000 to be transmitted to NPE 3.
[UPE2] interface ten-gigabitethernet 1/0/3
[UPE2-Ten-GigabitEthernet1/0/3] port link-type trunk
[UPE2-Ten-GigabitEthernet1/0/3] port trunk permit vlan 1000
[UPE2-Ten-GigabitEthernet1/0/3] quit
# Configure Ten-GigabitEthernet 1/0/4 as a trunk port, and permit tagged packets from VLAN 1000 to be transmitted to NPE 4.
[UPE2] interface ten-gigabitethernet 1/0/4
[UPE2-Ten-GigabitEthernet1/0/4] port link-type trunk
[UPE2-Ten-GigabitEthernet1/0/4] port trunk permit vlan 1000
[UPE2-Ten-GigabitEthernet1/0/4] quit
Configuring NPE 3
[NPE3] l2vpn enable
[NPE3] vsi user_a
# Create service instance 1000 on Ten-GigabitEthernet 1/0/1 of UPE 2 to match packets from VLAN 1000 and bind the service instance to VSI user_a. Because upstream packets carry the carrier's VLAN, the AC access mode must be VLAN (optional, defaulting to VLAN mode).
[NPE3] interface ten-gigabitethernet 1/0/1
[NPE3-Ten-GigabitEthernet1/0/1] service-instance 1000
[NPE3-Ten-GigabitEthernet1/0/1-srv1000] encapsulation s-vid 1000
[NPE3-Ten-GigabitEthernet1/0/1-srv1000] xconnect vsi user_a access-mode vlan
[NPE3-Ten-GigabitEthernet1/0/1-srv1000] quit
Configuring NPE 4
The configuration for NPE 4 is similar to that for NPE 3 except that the NPE peers for them are different. For more information about the configuration, see the configuration file.
Verify the state of PWs on each NPE. The following uses NPE 1 as an example.
Total number of PWs: 3, 3 up, 0 blocked, 0 down, 0 defect
VSI Name: user_a
Configuration files
·     UPE 1
vlan 1000
 qinq enable
 qinq enable
 port trunk permit vlan 1 1000
·     NPE 1
 mpls lsr-id 1.1.1.1
mpls ldp
 l2vpn enable
vsi user_a
 pwsignaling ldp
  xconnect vsi user_a
·     NPE 2
 mpls lsr-id 2.2.2.2
mpls ldp
 l2vpn enable
vsi user_a
 pwsignaling ldp
  xconnect vsi user_a
·     UPE 2
vlan 1000
 qinq enable
·     NPE 3
 mpls lsr-id 3.3.3.3
mpls ldp
 l2vpn enable
vsi user_a
 pwsignaling ldp
  xconnect vsi user_a
·     NPE 4
 mpls lsr-id 4.4.4.4
mpls ldp
 l2vpn enable
vsi user_a
 pwsignaling ldp
  xconnect vsi user_a
