- H3C Fixed Port Campus Switches Configuration Examples-6W106
- 00-Applicable hardware and software versions
- 01-Login Management Configuration Examples
- 02-RBAC Configuration Examples
- 03-Software Upgrade Examples
- 04-ISSU Configuration Examples
- 05-Software Patching Examples
- 06-Ethernet Link Aggregation Configuration Examples
- 07-Port Isolation Configuration Examples
- 08-Spanning Tree Configuration Examples
- 09-VLAN Configuration Examples
- 10-VLAN Tagging Configuration Examples
- 11-DHCP Snooping Configuration Examples
- 12-Cross-Subnet Dynamic IP Address Allocation Configuration Examples
- 13-IPv6 over IPv4 Tunneling with OSPFv3 Configuration Examples
- 14-IPv6 over IPv4 GRE Tunnel Configuration Examples
- 15-GRE with OSPF Configuration Examples
- 16-OSPF Configuration Examples
- 17-IS-IS Configuration Examples
- 18-BGP Configuration Examples
- 19-Policy-Based Routing Configuration Examples
- 20-OSPFv3 Configuration Examples
- 21-IPv6 IS-IS Configuration Examples
- 22-Routing Policy Configuration Examples
- 23-IGMP Snooping Configuration Examples
- 24-IGMP Configuration Examples
- 25-MLD Snooping Configuration Examples
- 26-IPv6 Multicast VLAN Configuration Examples
- 27-ACL Configuration Examples
- 28-Traffic Policing Configuration Examples
- 29-GTS and Rate Limiting Configuration Examples
- 30-Traffic Filtering Configuration Examples
- 31-AAA Configuration Examples
- 32-Port Security Configuration Examples
- 33-Portal Configuration Examples
- 34-SSH Configuration Examples
- 35-IP Source Guard Configuration Examples
- 36-Ethernet OAM Configuration Examples
- 37-CFD Configuration Examples
- 38-DLDP Configuration Examples
- 39-VRRP Configuration Examples
- 40-BFD Configuration Examples
- 41-NTP Configuration Examples
- 42-SNMP Configuration Examples
- 43-NQA Configuration Examples
- 44-Mirroring Configuration Examples
- 45-sFlow Configuration Examples
- 46-OpenFlow Configuration Examples
- 47-MAC Address Table Configuration Examples
- 48-Static Multicast MAC Address Entry Configuration Examples
- 49-IP Unnumbered Configuration Examples
- 50-MVRP Configuration Examples
- 51-MCE Configuration Examples
- 52-Attack Protection Configuration Examples
- 53-Smart Link Configuration Examples
- 54-RRPP Configuration Examples
- 55-BGP Route Selection Configuration Examples
- 56-IS-IS Route Summarization Configuration Examples
- 57-VXLAN Configuration Examples
- 58-DRNI Configuration Examples
- 59-IRF 3.1 Configuration Examples
- 60-PTP Configuration Examples
- 61-S-MLAG Configuration Examples
- 62-Puppet Configuration Examples
- 63-802.1X Configuration Examples
- 64-MAC Authentication Configuration Examples
- 65-ISATAP Tunnel and 6to4 Tunnel Configuration Examples
- 66-BIDIR-PIM Configuration Examples
- 67-Congestion Avoidance and Queue Scheduling Configuration Examples
- 68-Basic MPLS Configuration Examples
- 69-MPLS L3VPN Configuration Examples
- 70-MPLS OAM Configuration Examples
- 71-EVPN-DCI over an MPLS L3VPN Network Configuration Examples
- 72-DRNI and EVPN Configuration Examples
- 72-M-LAG and EVPN Configuration Examples
- 73-Multicast VPN Configuration Examples
- 74-MPLS TE Configuration Examples
- 75-Control Plane-Based QoS Policy Configuration Examples
- 76-Priority Mapping and Queue Scheduling Configuration Examples
- 77-ARP Attack Protection Configuration Examples
- 78-IRF Software Upgrade Configuration Examples
- 79-IRF Member Replacement Configuration Examples
- 80-Layer 3 Multicast on Multicast Source-Side DR System Configuration Examples
- 80-Layer 3 Multicast on Multicast Source-Side M-LAG System Configuration Examples
- 81-EVPN Multicast Configuration Examples
- 82-Priority Marking and Queue Scheduling Configuration Examples
- 83-EAA Configuration Examples
- 84-GRE Tunnel Access to MPLS L3VPN Configuration Examples
- 85-MC-NAT Configuration Examples
- 86-M-LAG Configuration Examples (Applicable to M-LAG Versions)
- 87-MOD Configuration Examples
- 88-MPLS L2VPN Configuration Examples
- 89-VPLS Configuration Examples
- 90-SR-MPLS Configuration Examples
- 91-VCF Fabric Configuration Examples
- 92-NetStream Configuration Examples
- 93-Configuration Example for Software Upgrade with Zero Packet Loss by Using GIR in VXLAN M-LAG Network
- 94-Configuration Example for Software Upgrade with Zero Packet Loss by Using GIR in VXLAN DRNI Network
| 17-IS-IS Configuration Examples | 116.73 KB |
Introduction
This document provides IS-IS configuration examples.
This document assumes that you have basic knowledge of IS-IS.
Example: Configuring IS-IS
As shown in Figure 1, the company's headquarters and the branch run IS-IS. The partner runs OSPF.
Configure the switches to meet the following requirements:
· The marketing department can reach the finance department, the branch, and the partner.
· The finance department and the branch cannot reach each other, and the branch does not have a route to the finance department.
· When the IS-IS process on Switch C restarts, the communication is not interrupted.
Analysis
To allow communication between the marketing department and the finance department, configure Switch A and Switch B in Area 10 as Level-1 routers.
To allow communication between the marketing department and the partner, configure route redistribution between IS-IS and OSPF on Switch D.
To ensure that the branch does not have a route to the finance department, configure Switch C to use a prefix list to advertise only network 10.100.1.0/24 to Level-2.
To ensure that the communication is not interrupted when the IS-IS process on Switch C restarts, enable IS-IS Graceful Restart (GR) on Switch C.
Hardware |
Software version |
S6812 switch series S6813 switch series |
Release 6615Pxx, Release 6628Pxx |
S6550XE-HI switch series |
Release 6008 and later, Release 8106Pxx |
S6526XE-HI[EI] switch series |
Release 8341P02 and later |
S6510 switch series |
S6525XE-HI switch series |
S5850 switch series |
Release 8005 and later, Release 8106Pxx |
S5570S-EI switch series |
Release 11xx |
S5560X-EI switch series |
Release 63xx, Release 65xx, Release 6615Pxx, Release 6628Pxx |
S5560X-HI switch series |
S5500V2-EI switch series |
MS4520V2-30F switch |
MS4520V2-30C switch MS4520V2-54C switch |
MS4520V2-28S switch MS4520V2-24TP switch |
Release 63xx |
S6520X-HI switch series S6520X-EI switch series |
S6520X-SI switch series S6520-SI switch series |
S5000-EI switch series |
MS4600 switch series |
ES5500 switch series |
S5560S-EI switch series S5560S-SI switch series |
Release 63xx |
S5500V3-24P-SI switch S5500V3-48P-SI switch |
Release 63xx |
S5500V3-SI switch series (except S5500V3-24P-SI and S5500V3-48P-SI) |
Release 11xx |
S5170-EI switch series |
Not supported |
S5130S-HI switch series S5130S-EI switch series S5130S-SI switch series S5130S-LI switch series |
Not supported |
S5120V2-SI switch series S5120V2-LI switch series |
Not supported |
S5120V3-EI switch series |
Not supported |
S5120V3-36F-SI switch S5120V3-28P-HPWR-SI switch S5120V3-54P-PWR-SI switch |
Not supported |
S5120V3-SI switch series (except S5120V3-36F-SI, S5120V3-28P-HPWR-SI, and S5120V3-54P-PWR-SI) |
Not supported |
S5120V3-LI switch series |
Not supported |
S3600V3-EI switch series |
Release 11xx |
S3600V3-SI switch series |
Not supported |
S3100V3-EI switch series S3100V3-SI switch series |
Not supported |
S5110V2 switch series |
Not supported |
S5110V2-SI switch series |
Not supported |
S5000V3-EI switch series S5000V5-EI switch series |
Not supported |
S5000E-X switch series S5000X-EI switch series |
Not supported |
E128C switch E152C switch E500C switch series E500D switch series |
Not supported |
MS4320V2 switch series MS4320V3 switch series MS4300V2 switch series MS4320 switch series MS4200 switch series |
Not supported |
WS5850-WiNet switch series |
Release 63xx |
WS5820-WiNet switch series WS5810-WiNet switch series |
Not supported |
WAS6000 switch series |
Not supported |
IE4300-12P-AC switch IE4300-12P-PWR switch IE4300-M switch series IE4320 switch series |
Not supported |
IE4520 switch series |
Release 66xx |
S5135S-EI switch series |
Not supported |
S5136S-EI switch series |
Not supported |
To avoid blackhole routes, do not change the network topology during the IS-IS GR process.
Procedures
Configuring Switch A
# Configure an IP address for VLAN-interface 11.
[SwitchA-Vlan-interface11] ip address 192.168.1.1 24
# Configure IP addresses for other interfaces, as shown in Figure 1. (Details not shown.)
# Configure IS-IS.
[SwitchA] isis 1
[SwitchA-isis-1] is-level level-1
[SwitchA-isis-1] network-entity 10.1921.6800.1001.00
[SwitchA-isis-1] quit
[SwitchA–Vlan-interface11] isis enable 1
[SwitchA–Vlan-interface11] quit
[SwitchA–Vlan-interface100] isis enable 1
[SwitchA–Vlan-interface100] quit
Configuring Switch B
# Configure an IP address for VLAN-interface 12.
[SwitchB] interface vlan-interface 12
[SwitchB-Vlan-interface12] ip address 192.168.2.1 24
[SwitchB-Vlan-interface12] quit
# Configure IS-IS.
[SwitchB] isis 1
[SwitchB-isis-1] is-level level-1
[SwitchB-isis-1] network-entity 10.1921.6800.2001.00
[SwitchB-isis-1] quit
[SwitchB–Vlan-interface12] isis enable 1
[SwitchB–Vlan-interface12] quit
[SwitchB–Vlan-interface 200] isis enable 1
[SwitchB–Vlan-interface 200] quit
Configuring Switch C
[SwitchC] interface vlan-interface 11
[SwitchC-Vlan-interface11] ip address 192.168.1.2 24
[SwitchC-Vlan-interface11] quit
# Configure IS-IS.
[SwitchC] isis 1
[SwitchC-isis-1] network-entity 10.1921.6801.0001.00
[SwitchC-isis-1] quit
[SwitchC] interface vlan-interface 10
[SwitchC–Vlan-interface10] isis enable 1
[SwitchC–Vlan-interface10] quit
[SwitchC–Vlan-interface11] isis enable 1
[SwitchC–Vlan-interface11] quit
[SwitchC] interface vlan-interface 12
[SwitchC–Vlan-interface12] isis enable 1
[SwitchC–Vlan-interface12] quit
# Configure route leaking from Level-1 to Level-2, and use prefix list 1 to advertise only network 10.100.1.0/24 to Level-2.
[SwitchC] ip prefix-list 1 permit 10.100.1.0 24
[SwitchC] isis 1
[SwitchC-isis-1] address-family ipv4
[SwitchC-isis-1-ipv4] import-route isis level-1 into level-2 filter-policy prefix-list 1
[SwitchC-isis-1-ipv4] quit
# Enable IS-IS GR.
[SwitchC-isis-1] graceful-restart
Configuring Switch D
# Configure an IP address for VLAN-interface 10.
<SwitchD> system-view
[SwitchD] interface vlan-interface 10
[SwitchD-Vlan-interface10] ip address 192.168.10.2 24
[SwitchD-Vlan-interface10] quit
# Configure IS-IS.
[SwitchD] isis 1
[SwitchD-isis-1] is-level level-2
[SwitchD-isis-1] network-entity 10.1921.6802.0001.00
[SwitchD-isis-1] quit
[SwitchD–Vlan-interface10] isis enable 1
[SwitchD–Vlan-interface10] quit
[SwitchD] interface vlan-interface 20
[SwitchD–Vlan-interface20] isis enable 1
[SwitchD–Vlan-interface20] quit
# Configure OSPF.
[SwitchD] ospf
[SwitchD-ospf-1] area 0
[SwitchD-ospf-1-area-0.0.0.0] network 192.168.20.0 0.0.0.255
[SwitchD-ospf-1] quit
# Redistribute OSPF and direct routes into IS-IS
[SwitchD] isis 1
[SwitchD-isis-1] address-family ipv4
[SwitchD-isis-1-ipv4] import-route ospf
[SwitchD-isis-1-ipv4] import-route direct
[SwitchD-isis-1-ipv4] quit
# Redistribute IS-IS and direct routes into OSPF.
[SwitchD] ospf 1
[SwitchD-ospf-1] import-route isis 1
[SwitchD-ospf-1] import-route direct
Configuring Switch E
# Configure an IP address for VLAN-interface 20.
<SwitchE> system-view
[SwitchE] interface vlan-interface20
[SwitchE-Vlan-interface12] ip address 192.168.20.2 24
[SwitchE-Vlan-interface12] quit
# Configure OSPF.
[SwitchE] ospf
[SwitchE-ospf-1] area 0
[SwitchE-ospf-1-area-0.0.0.0] network 192.168.20.0 0.0.0.255
[SwitchE-ospf-1-area-0.0.0.0] network 10.200.1.0 0.0.0.255
[SwitchE-ospf-1-area-0.0.0.0] quit
[SwitchE-ospf-1] quit
# Verify that the branch can reach the marketing department, but cannot reach the finance department.
[SwitchD] display isis route
Level-2 IPv4 Forwarding Table
IPv4 Destination IntCost ExtCost ExitInterface NextHop Flags
192.168.10.0/24 10 NULL Vlan10 Direct D/L/-
192.168.1.0/24 20 NULL Vlan10 192.168.10.1 R/-/-
10.100.1.0/24 30 NULL Vlan10 192.168.10.1 R/-/-
192.168.2.0/24 20 NULL Vlan10 192.168.10.1 R/-/-
# Verify that the marketing department can communicate with the partner.
· Display the IS-IS routing table on Switch C.
[SwitchC] display isis route
Level-1 IPv4 Forwarding Table
192.168.1.0/24 10 NULL Vlan11 Direct D/L/-
10.100.1.0/24 20 NULL Vlan11 192.168.1.1 R/L/-
10.100.2.0/24 20 NULL Vlan12 192.168.2.1 R/-/-
192.168.2.0/24 10 NULL Vlan12 Direct D/L/-
10.200.1.0/24 10 0 Vlan10 192.168.10.2 R/-/-
192.168.20.0/24 10 0 Vlan10 192.168.10.2 R/-/-
· Ping 10.200.1.1 from Switch A.
[SwitchA] ping 10.200.1.1
Ping 10.200.1.1 (10.200.1.1): 56 data bytes, press CTRL+C to break
56 bytes from 10.200.1.1: icmp_seq=0 ttl=254 time=1.862 ms
56 bytes from 10.200.1.1: icmp_seq=1 ttl=254 time=2.969 ms
56 bytes from 10.200.1.1: icmp_seq=2 ttl=254 time=1.402 ms
56 bytes from 10.200.1.1: icmp_seq=3 ttl=254 time=1.324 ms
56 bytes from 10.200.1.1: icmp_seq=4 ttl=254 time=1.510 ms
--- Ping statistics for 10.200.1.1 ---
round-trip min/avg/max/std-dev = 1.324/1.813/2.969/0.606 ms
# Verify that the communication is not interrupted when the IS-IS process restarts.
· Ping Switch B from Switch A.
[SwitchA] ping -c 10000 10.100.2.1
Ping 10.100.2.1 (10.100.2.1): 56 data bytes, press CTRL+C to break
56 bytes from 10.100.2.1: icmp_seq=0 ttl=254 time=1.185 ms
56 bytes from 10.100.2.1: icmp_seq=1 ttl=254 time=1.087 ms
· Restart the IS-IS process on Switch C.
[SwitchC] reset isis all graceful-restart
Reset IS-IS process? [Y/N] :y
# Ping Switch B from Switch A.
56 bytes from 13.13.13.3: icmp_seq=2 ttl=254 time=1.672 ms
56 bytes from 13.13.13.3: icmp_seq=3 ttl=254 time=1.751 ms
56 bytes from 13.13.13.3: icmp_seq=4 ttl=254 time=1.816 ms
56 bytes from 13.13.13.3: icmp_seq=5 ttl=254 time=1.814 ms
# Check the IS-IS GR state on Switch C.
[SwitchC] display isis graceful-restart status
Restart status: COMPLETE
Restart phase: Finish
SA Bit: supported
Level-1 restart information
Total number of interfaces: 3
Number of waiting LSPs: 0
Level-2 restart information
Configuration files
· Switch A:
isis 1
is-level level-1
vlan 11
vlan 100
interface Vlan-interface11
isis enable 1
interface Vlan-interface100
ip address 10.100.1.1 255.255.255.0
isis enable 1
· Switch B:
isis 1
is-level level-1
vlan 12
vlan 200
interface Vlan-interface12
ip address 192.168.2.1 255.255.255.0
isis enable 1
interface Vlan-interface200
ip address 10.100.2.1 255.255.255.0
isis enable 1
· Switch C:
isis 1
graceful-restart
address-family ipv4 unicast
vlan 10 to 12
ip address 192.168.10.1 255.255.255.0
isis enable 1
ip address 192.168.1.2 255.255.255.0
isis enable 1
ip address 192.168.2.2 255.255.255.0
isis enable 1
ip prefix-list 1 index 10 permit 10.100.1.0 24
· Switch D:
isis 1
is-level level-2
network-entity 20.1921.6802.0001.00
import-route direct
import-route ospf 1
ospf 1
import-route direct
import-route isis 1
area 0.0.0.0
vlan 10
vlan 20
ip address 192.168.10.2 255.255.255.0
isis enable 1
ip address 192.168.20.1 255.255.255.0
· Switch E:
ospf 1
area 0.0.0.0
vlan 20
vlan 300
ip address 192.168.20.2 255.255.255.0
interface Vlan-interface300
ip address 10.200.1.1 255.255.255.0
