- H3C Fixed Port Campus Switches Configuration Examples-6W106
- 00-Applicable hardware and software versions
- 01-Login Management Configuration Examples
- 02-RBAC Configuration Examples
- 03-Software Upgrade Examples
- 04-ISSU Configuration Examples
- 05-Software Patching Examples
- 06-Ethernet Link Aggregation Configuration Examples
- 07-Port Isolation Configuration Examples
- 08-Spanning Tree Configuration Examples
- 09-VLAN Configuration Examples
- 10-VLAN Tagging Configuration Examples
- 11-DHCP Snooping Configuration Examples
- 12-Cross-Subnet Dynamic IP Address Allocation Configuration Examples
- 13-IPv6 over IPv4 Tunneling with OSPFv3 Configuration Examples
- 14-IPv6 over IPv4 GRE Tunnel Configuration Examples
- 15-GRE with OSPF Configuration Examples
- 16-OSPF Configuration Examples
- 17-IS-IS Configuration Examples
- 18-BGP Configuration Examples
- 19-Policy-Based Routing Configuration Examples
- 20-OSPFv3 Configuration Examples
- 21-IPv6 IS-IS Configuration Examples
- 22-Routing Policy Configuration Examples
- 23-IGMP Snooping Configuration Examples
- 24-IGMP Configuration Examples
- 25-MLD Snooping Configuration Examples
- 26-IPv6 Multicast VLAN Configuration Examples
- 27-ACL Configuration Examples
- 28-Traffic Policing Configuration Examples
- 29-GTS and Rate Limiting Configuration Examples
- 30-Traffic Filtering Configuration Examples
- 31-AAA Configuration Examples
- 32-Port Security Configuration Examples
- 33-Portal Configuration Examples
- 34-SSH Configuration Examples
- 35-IP Source Guard Configuration Examples
- 36-Ethernet OAM Configuration Examples
- 37-CFD Configuration Examples
- 38-DLDP Configuration Examples
- 39-VRRP Configuration Examples
- 40-BFD Configuration Examples
- 41-NTP Configuration Examples
- 42-SNMP Configuration Examples
- 43-NQA Configuration Examples
- 44-Mirroring Configuration Examples
- 45-sFlow Configuration Examples
- 46-OpenFlow Configuration Examples
- 47-MAC Address Table Configuration Examples
- 48-Static Multicast MAC Address Entry Configuration Examples
- 49-IP Unnumbered Configuration Examples
- 50-MVRP Configuration Examples
- 51-MCE Configuration Examples
- 52-Attack Protection Configuration Examples
- 53-Smart Link Configuration Examples
- 54-RRPP Configuration Examples
- 55-BGP Route Selection Configuration Examples
- 56-IS-IS Route Summarization Configuration Examples
- 57-VXLAN Configuration Examples
- 58-DRNI Configuration Examples
- 59-IRF 3.1 Configuration Examples
- 60-PTP Configuration Examples
- 61-S-MLAG Configuration Examples
- 62-Puppet Configuration Examples
- 63-802.1X Configuration Examples
- 64-MAC Authentication Configuration Examples
- 65-ISATAP Tunnel and 6to4 Tunnel Configuration Examples
- 66-BIDIR-PIM Configuration Examples
- 67-Congestion Avoidance and Queue Scheduling Configuration Examples
- 68-Basic MPLS Configuration Examples
- 69-MPLS L3VPN Configuration Examples
- 70-MPLS OAM Configuration Examples
- 71-EVPN-DCI over an MPLS L3VPN Network Configuration Examples
- 72-DRNI and EVPN Configuration Examples
- 72-M-LAG and EVPN Configuration Examples
- 73-Multicast VPN Configuration Examples
- 74-MPLS TE Configuration Examples
- 75-Control Plane-Based QoS Policy Configuration Examples
- 76-Priority Mapping and Queue Scheduling Configuration Examples
- 77-ARP Attack Protection Configuration Examples
- 78-IRF Software Upgrade Configuration Examples
- 79-IRF Member Replacement Configuration Examples
- 80-Layer 3 Multicast on Multicast Source-Side DR System Configuration Examples
- 80-Layer 3 Multicast on Multicast Source-Side M-LAG System Configuration Examples
- 81-EVPN Multicast Configuration Examples
- 82-Priority Marking and Queue Scheduling Configuration Examples
- 83-EAA Configuration Examples
- 84-GRE Tunnel Access to MPLS L3VPN Configuration Examples
- 85-MC-NAT Configuration Examples
- 86-M-LAG Configuration Examples (Applicable to M-LAG Versions)
- 87-MOD Configuration Examples
- 88-MPLS L2VPN Configuration Examples
- 89-VPLS Configuration Examples
- 90-SR-MPLS Configuration Examples
- 91-VCF Fabric Configuration Examples
- 92-NetStream Configuration Examples
- 93-Configuration Example for Software Upgrade with Zero Packet Loss by Using GIR in VXLAN M-LAG Network
- 94-Configuration Example for Software Upgrade with Zero Packet Loss by Using GIR in VXLAN DRNI Network
| 58-DRNI Configuration Examples | 476.62 KB |
Example: Configuring DRNI at the access Layer
DRNI restrictions and guidelines
VRRP restrictions and guidelines
Interface restrictions and guidelines
Example: Configuring DRNI at the distribution Layer
Example: Configuring IPv4 and IPv6 dual-active VLAN interfaces on a DR system
Introduction
This document provides DRNI configuration examples.
Distributed Resilient Network Interconnect (DRNI) virtualizes two physical devices into one system through multichassis link aggregation. The standard for DRNI is IEEE P802.1AX-REV™/D4.4c, Draft Standard for Local and Metropolitan Area Networks.
The following information is provided based on the assumption that you have basic knowledge of DRNI.
As shown in Figure 1:
· Configure Device A and Device B as a DR system to establish one multichassis aggregate link with Device F and one with Device C and Device D.
· Set up a keepalive link between GigabitEthernet 1/0/5 of Device A and GigabitEthernet 1/0/5 of Device B, and exclude the interfaces from the shutdown action by DRNI MAD.
· Configure two VRRP groups on Device C and Device D to provide gateway services for VLAN 10 and VLAN 20.
¡ Configure VRRP group 1 to provide gateway services for hosts in VLAN 10 (Area A). Add Device C and Device D to the group as the master and backup devices, respectively.
¡ Configure VRRP group 2 to provide gateway services for hosts in VLAN 20 (Area B). Add Device D and Device C to the group as the master and backup devices, respectively.
· Configure OSPF on Device C, Device D, and Device E for the hosts to communicate with external networks at Layer 3.
Device |
IP address |
Device |
IP address |
Device A |
GE 1/0/5 |
1.1.1.1/24 |
Device B |
GE1/0/5 |
1.1.1.2/24 |
Device C |
VLAN-interface 100 |
100.1.1.1/24 |
Device D |
200.1.1.1/24 |
VLAN-interface 10 |
10.1.1.1/24 |
VLAN-interface 10 |
10.1.1.2/24 |
VLAN-interface 20 |
20.1.1.1/24 |
VLAN-interface 20 |
20.1.1.2/24 |
Virtual IP 1 |
10.1.1.100/24 |
Virtual IP 1 |
10.1.1.100/24 |
Virtual IP 2 |
20.1.1.100/24 |
Virtual IP 2 |
20.1.1.100/24 |
Device E |
100.1.1.2/24 |
VLAN-interface 200 |
200.1.1.2/24 |
VLAN-interface 30 |
30.1.1.1/24 |
Analysis
For the secondary DR device to monitor the state of the primary device, establish a Layer 3 keepalive link between the DR member devices.
To balance traffic between two VRRP gateway devices, you can assign them to two VRRP groups with different priorities. In this example, Device C is assigned a higher priority than Device D in VRRP group 1 so Device C can become the master in this group. Device D is assigned a higher priority than Device C in VRRP group 2 so Device D can become the master in this group.
Hardware |
Software version |
S6812 switch series S6813 switch series |
Release 6615Pxx, Release 6628Pxx |
S6550XE-HI switch series |
Release 6008 and later |
S6526XE-HI[EI] switch series |
Release 8341P02 and later |
S6510 switch series |
S6525XE-HI switch series |
S5850 switch series |
Not supported |
S5570S-EI switch series |
Not supported |
S5560X-EI switch series |
Release 63xx, Release 65xx, Release 6615Pxx, Release 6628Pxx |
S5560X-HI switch series |
S5500V2-EI switch series |
MS4520V2-30F switch |
MS4520V2-30C switch MS4520V2-54C switch |
MS4520V2-28S switch MS4520V2-24TP switch |
Not supported |
S6520X-HI switch series S6520X-EI switch series |
S6520X-SI switch series S6520-SI switch series |
S5000-EI switch series |
MS4600 switch series |
ES5500 switch series |
S5560S-EI switch series S5560S-SI switch series |
Not supported |
S5500V3-24P-SI switch S5500V3-48P-SI switch |
Not supported |
S5500V3-SI switch series (except S5500V3-24P-SI and S5500V3-48P-SI) |
Not supported |
S5170-EI switch series |
Not supported |
S5130S-HI switch series S5130S-EI switch series S5130S-SI switch series S5130S-LI switch series |
Not supported |
S5120V2-SI switch series S5120V2-LI switch series |
Not supported |
S5120V3-EI switch series |
Not supported |
S5120V3-36F-SI switch S5120V3-28P-HPWR-SI switch S5120V3-54P-PWR-SI switch |
Not supported |
S5120V3-SI switch series (except S5120V3-36F-SI, S5120V3-28P-HPWR-SI, and S5120V3-54P-PWR-SI) |
Not supported |
S5120V3-LI switch series |
Not supported |
S3600V3-EI switch series |
Not supported |
S3600V3-SI switch series |
Not supported |
S3100V3-EI switch series S3100V3-SI switch series |
Not supported |
S5110V2 switch series |
Not supported |
S5110V2-SI switch series |
Not supported |
S5000V3-EI switch series S5000V5-EI switch series |
Not supported |
S5000E-X switch series S5000X-EI switch series |
Not supported |
E128C switch E152C switch E500C switch series E500D switch series |
Not supported |
MS4320V2 switch series MS4320V3 switch series MS4300V2 switch series MS4320 switch series MS4200 switch series |
Not supported |
WS5850-WiNet switch series |
Not supported |
WS5820-WiNet switch series WS5810-WiNet switch series |
Not supported |
WAS6000 switch series |
Not supported |
IE4300-12P-AC switch IE4300-12P-PWR switch IE4300-M switch series IE4320 switch series |
Not supported |
IE4520 switch series |
Not supported |
S5135S-EI switch series |
Not supported |
For the DR member devices to be identified as one DR system, you must configure the same DR system MAC address and DR system priority on them. You must assign different DR system numbers to the DR member devices.
A DR member device can have only one IPP.
For correct keepalive detection, you must exclude the interfaces used for keepalive detection from the shutdown action by DRNI MAD.
You cannot specify the virtual IP address as any of the following IP addresses:
· All-zero address (0.0.0.0).
· Broadcast address (255.255.255.255).
· Loopback address.
· IP address of other than Class A, Class B, and Class C.
· Invalid IP address (for example, 0.0.0.1).
The virtual IP address of an IPv4 VRRP group must be on the same subnet as the downlink interface IP addresses of the VRRP group members to ensure successful traffic forwarding.
For the S5570S-EI, S5500V3-SI, S3600V3-EI, and S3600V3-SI switch series, before switching a Layer 2 Ethernet interface to a Layer 3 Ethernet interface or creating a Layer 3 aggregate interface, use the reserve-vlan-interface command to reserve local VLAN interface resources. For more information about the reserve-vlan-interface command, see the VLAN configuration and VLAN commands for your product.
Procedures
Configuring Device A
# Configure DR system settings.
[DeviceA] drni system-mac 1-1-1
Changing the system MAC might flap the intra-portal link and cause DR system setup failure. Continue? [Y/N]:y
[DeviceA] drni system-number 1
Changing the system number might flap the intra-portal link and cause DR system setup failure. Continue? [Y/N]:y
[DeviceA] drni system-priority 123
Changing the system priority might flap the intra-portal link and cause DR system setup failure. Continue? [Y/N]:y
# Configure DR keepalive packet parameters.
[DeviceA] drni keepalive ip destination 1.1.1.2 source 1.1.1.1
# Configure GigabitEthernet 1/0/5 as a routed (Layer 3) interface and assign the interface an IP address. The IP address will be used as the source IP address of keepalive packets.
[DeviceA] interface gigabitethernet 1/0/5
[DeviceA-GigabitEthernet1/0/5] port link-mode route
[DeviceA-GigabitEthernet1/0/5] ip address 1.1.1.1 24
[DeviceA-GigabitEthernet1/0/5] quit
# Exclude the interface used for DR keepalive detection (GigabitEthernet 1/0/5) from the shutdown action by DRNI MAD.
[DeviceA] drni mad exclude interface gigabitethernet 1/0/5
# Create VLAN 10 and VLAN 20.
[DeviceA] vlan 10
[DeviceA-vlan10] quit
[DeviceA] vlan 20
[DeviceA-vlan20] quit
# Create Layer 2 dynamic aggregate interface Bridge-Aggregation 1.
[DeviceA] interface bridge-aggregation 1
[DeviceA-Bridge-Aggregation1] link-aggregation mode dynamic
[DeviceA-Bridge-Aggregation1] quit
# Assign GigabitEthernet 1/0/6 and GigabitEthernet 1/0/7 to aggregation group 1.
[DeviceA] interface gigabitethernet 1/0/6
[DeviceA-GigabitEthernet1/0/6] port link-aggregation group 1
[DeviceA-GigabitEthernet1/0/6] quit
[DeviceA] interface gigabitethernet 1/0/7
[DeviceA-GigabitEthernet1/0/7] port link-aggregation group 1
[DeviceA-GigabitEthernet1/0/7] quit
# Set the link type of Bridge-Aggregation 1 to trunk and assign it to VLAN 10 and VLAN 20.
[DeviceA-Bridge-Aggregation1] port link-type trunk
Configuring GigabitEthernet1/0/6 done.
Configuring GigabitEthernet1/0/7 done.
[DeviceA-Bridge-Aggregation1] port trunk permit vlan 10 20
# Create Layer 2 dynamic aggregate interface Bridge-Aggregation 3 and specify it as the IPP.
[DeviceA] interface bridge-aggregation 3
[DeviceA-Bridge-Aggregation3] link-aggregation mode dynamic
[DeviceA-Bridge-Aggregation3] port drni intra-portal-port 1
[DeviceA-Bridge-Aggregation3] quit
# Assign GigabitEthernet 1/0/3 and GigabitEthernet 1/0/4 to aggregation group 3.
[DeviceA-GigabitEthernet1/0/3] port link-aggregation group 3
[DeviceA] interface gigabitethernet 1/0/4
[DeviceA-GigabitEthernet1/0/4] port link-aggregation group 3
[DeviceA-GigabitEthernet1/0/4] quit
# Set the link type of Bridge-Aggregation 3 to trunk and assign it to VLAN 10 and VLAN 20.
[DeviceA-Bridge-Aggregation3] port link-type trunk
Configuring GigabitEthernet1/0/3 done.
Configuring GigabitEthernet1/0/4 done.
[DeviceA-Bridge-Aggregation3] port trunk permit vlan 10 20
# Create Layer 2 dynamic aggregate interface Bridge-Aggregation 4 and assign it to DR group 4.
[DeviceA] interface bridge-aggregation 4
[DeviceA-Bridge-Aggregation4] link-aggregation mode dynamic
[DeviceA-Bridge-Aggregation4] port drni group 4
[DeviceA-Bridge-Aggregation4] quit
# Assign GigabitEthernet 1/0/1 and GigabitEthernet 1/0/2 to aggregation group 4.
[DeviceA-GigabitEthernet1/0/1] port link-aggregation group 4
[DeviceA-GigabitEthernet1/0/2] port link-aggregation group 4
# Set the link type of Bridge-Aggregation 4 to trunk and assign it to VLAN 10 and VLAN 20.
[DeviceA-Bridge-Aggregation4] port link-type trunk
Configuring GigabitEthernet1/0/1 done.
Configuring GigabitEthernet1/0/2 done.
[DeviceA-Bridge-Aggregation4] port trunk permit vlan 10 20
Configuring Device B
[DeviceB] drni system-mac 1-1-1
[DeviceB] drni system-number 2
[DeviceB] drni system-priority 123
[DeviceB] drni keepalive ip destination 1.1.1.1 source 1.1.1.2
[DeviceB] interface gigabitethernet 1/0/5
[DeviceB-GigabitEthernet1/0/5] port link-mode route
[DeviceB-GigabitEthernet1/0/5] ip address 1.1.1.2 24
[DeviceB-GigabitEthernet1/0/5] quit
[DeviceB] drni mad exclude interface gigabitethernet 1/0/5
[DeviceB] vlan 10
[DeviceB-vlan10] quit
[DeviceB] vlan 20
[DeviceB-vlan20] quit
# Create Layer 2 dynamic aggregate interface Bridge-Aggregation 2.
[DeviceB] interface bridge-aggregation 2
[DeviceB-Bridge-Aggregation2] link-aggregation mode dynamic
[DeviceB-Bridge-Aggregation2] quit
# Assign GigabitEthernet 1/0/6 and GigabitEthernet 1/0/7 to aggregation group 2.
[DeviceB] interface gigabitethernet 1/0/6
[DeviceB-GigabitEthernet1/0/6] port link-aggregation group 2
[DeviceB-GigabitEthernet1/0/6] quit
[DeviceB] interface gigabitethernet 1/0/7
[DeviceB-GigabitEthernet1/0/7] port link-aggregation group 2
[DeviceB-GigabitEthernet1/0/7] quit
# Set the link type of Bridge-Aggregation 2 to trunk and assign it to VLAN 10 and VLAN 20.
[DeviceB-Bridge-Aggregation2] port link-type trunk
[DeviceB-Bridge-Aggregation2] port trunk permit vlan 10 20
[DeviceB] interface bridge-aggregation 3
[DeviceB-Bridge-Aggregation3] link-aggregation mode dynamic
[DeviceB-Bridge-Aggregation3] port drni intra-portal-port 1
[DeviceB-Bridge-Aggregation3] quit
[DeviceB] interface gigabitethernet 1/0/3
[DeviceB-GigabitEthernet1/0/3] port link-aggregation group 3
[DeviceB] interface gigabitethernet 1/0/4
[DeviceB-GigabitEthernet1/0/4] port link-aggregation group 3
[DeviceB-GigabitEthernet1/0/4] quit
[DeviceB-Bridge-Aggregation3] port link-type trunk
[DeviceB-Bridge-Aggregation3] port trunk permit vlan 10 20
[DeviceB] interface bridge-aggregation 4
[DeviceB-Bridge-Aggregation4] link-aggregation mode dynamic
[DeviceB-Bridge-Aggregation4] port drni group 4
[DeviceB-Bridge-Aggregation4] quit
[DeviceB-GigabitEthernet1/0/1] port link-aggregation group 4
[DeviceB-GigabitEthernet1/0/2] port link-aggregation group 4
[DeviceB-Bridge-Aggregation4] port link-type trunk
[DeviceB-Bridge-Aggregation4] port trunk permit vlan 10 20
Configuring Device C
# Create VLAN 10, VLAN 20, and VLAN 100.
<DeviceC> system-view
[DeviceC] vlan 10
[DeviceC-vlan10] quit
[DeviceC] vlan 20
[DeviceC-vlan20] quit
[DeviceC] vlan 100
# Assign GigabitEthernet 1/0/3 to VLAN 100.
[DeviceC] vlan 100
[DeviceC-vlan100] port gigabitethernet 1/0/3
[DeviceC-vlan100] quit
[DeviceC] interface bridge-aggregation 1
[DeviceC-Bridge-Aggregation1] link-aggregation mode dynamic
[DeviceC-Bridge-Aggregation1] quit
# Assign GigabitEthernet 1/0/1 and GigabitEthernet1/0/2 to aggregation group 1.
[DeviceC] interface range gigabitethernet 1/0/1 to gigabitethernet 1/0/2
[DeviceC-if-range] port link-aggregation group 1
[DeviceC-if-range] quit
[DeviceC-Bridge-Aggregation1] port link-type trunk
[DeviceC-Bridge-Aggregation1] port trunk permit vlan 10 20
# Create uplink interface VLAN-interface 100 and assign it an IP address.
[DeviceC] interface vlan-interface 100
[DeviceC-Vlan-interface100] ip address 100.1.1.1 24
[DeviceC-Vlan-interface100] quit
# Create VLAN-interface 10 and VLAN-interface 20 and assign an IP address to each of them.
[DeviceC-vlan-interface10] ip address 10.1.1.1 24
[DeviceC-vlan-interface10] quit
[DeviceC] interface vlan-interface 20
[DeviceC-vlan-interface20] ip address 20.1.1.1 24
[DeviceC-vlan-interface20] quit
# Create VRRP group 1 on VLAN-interface 10 and set its virtual IP address to 10.1.1.100.
[DeviceC-Vlan-interface10] vrrp vrid 1 virtual-ip 10.1.1.100
# Set the priority of Device C to 200 for it to become the master in VRRP group 1.
[DeviceC-Vlan-interface10] vrrp vrid 1 priority 200
[DeviceC-Vlan-interface10] quit
# Create VRRP group 2 on VLAN-interface 20 and set its virtual IP address to 20.1.1.100.
[DeviceC-Vlan-interface20] vrrp vrid 2 virtual-ip 20.1.1.100
# Configure Device C to operate in preemptive mode in VRRP group 1. Set the preemption delay to 500 centiseconds to avoid frequent status switchover.
[DeviceC-Vlan-interface10] vrrp vrid 1 preempt-mode delay 500
# Create track entry 1 to monitor the upstream link status of GigabitEthernet 1/0/3.
[DeviceC] track 1 interface gigabitethernet 1/0/3
# Configure Device C in VRRP group 1 to monitor track entry 1, and decrease its priority by 150 when the track entry transits to Negative.
[DeviceC-Vlan-interface10] vrrp vrid 1 track 1 priority reduced 150
# Configure OSPF.
[DeviceC] ospf
[DeviceC-ospf-1] area 0
[DeviceC-ospf-1-area-0.0.0.0] network 10.1.1.0 0.0.0.255
[DeviceC-ospf-1-area-0.0.0.0] network 20.1.1.0 0.0.0.255
[DeviceC-ospf-1-area-0.0.0.0] network 100.1.1.0 0.0.0.255
[DeviceC-ospf-1-area-0.0.0.0] quit
[DeviceC-ospf-1] quit
Configuring Device D
# Create VLAN 10, VLAN 20, and VLAN 200.
<DeviceD> system-view
[DeviceD] vlan 10
[DeviceD-vlan10] quit
[DeviceD] vlan 20
[DeviceD-vlan20] quit
[DeviceD] vlan 200
# Assign GigabitEthernet 1/0/3 to VLAN 200.
[DeviceD] vlan 200
[DeviceD-vlan200] port gigabitethernet 1/0/3
[DeviceD-vlan200] quit
[DeviceD] interface bridge-aggregation 2
[DeviceD-Bridge-Aggregation2] link-aggregation mode dynamic
[DeviceD-Bridge-Aggregation2] quit
# Assign GigabitEthernet 1/0/1 and GigabitEthernet 1/0/2 to aggregation group 2.
[DeviceD] interface range gigabitethernet 1/0/1 to gigabitethernet 1/0/2
[DeviceD-if-range] port link-aggregation group 2
[DeviceD-if-range] quit
[DeviceD-Bridge-Aggregation2] port link-type trunk
[DeviceD-Bridge-Aggregation2] port trunk permit vlan 10 20
# Create uplink interface VLAN-interface 200 and assign it an IP address.
[DeviceD] interface vlan-interface 200
[DeviceD-Vlan-interface200] ip address 200.1.1.1 24
[DeviceD-Vlan-interface200] quit
[DeviceD] interface vlan-interface 10
[DeviceD-vlan-interface10] ip address 10.1.1.2 24
[DeviceD-vlan-interface10] quit
[DeviceD-vlan-interface20] ip address 20.1.1.2 24
[DeviceD-vlan-interface20] quit
[DeviceD-Vlan-interface10] vrrp vrid 1 virtual-ip 10.1.1.100
[DeviceD-Vlan-interface20] vrrp vrid 2 virtual-ip 20.1.1.100
# Set the priority of Device D to 200 for it to become the master in VRRP group 2.
[DeviceD-Vlan-interface20] vrrp vrid 2 priority 200
# Configure Device D to operate in preemptive mode in VRRP group 2. Set the preemption delay to 500 centiseconds to avoid frequent status switchover.
[DeviceD-Vlan-interface20] vrrp vrid 2 preempt-mode delay 500
[DeviceD-Vlan-interface20] quit
# Create track entry 2 to monitor the upstream link status of GigabitEthernet 1/0/3.
[DeviceD] track 2 interface gigabitethernet 1/0/3
# Configure Device D in VRRP group 2 to monitor track entry 2, and decrease its priority by 150 when the track entry transits to Negative.
[DeviceD-Vlan-interface20] vrrp vrid 2 track 2 priority reduced 150
# Configure OSPF.
[DeviceD] ospf
[DeviceD-ospf-1] area 0
[DeviceD-ospf-1-area-0.0.0.0] network 10.1.1.0 0.0.0.255
[DeviceD-ospf-1-area-0.0.0.0] network 20.1.1.0 0.0.0.255
[DeviceD-ospf-1-area-0.0.0.0] network 200.1.1.0 0.0.0.255
[DeviceD-ospf-1-area-0.0.0.0] quit
[DeviceD-ospf-1] quit
Configuring Device E
# Create VLAN 100 and assign GigabitEthernet 1/0/1 to the VLAN.
<DeviceE> system-view
[DeviceE] vlan 100
[DeviceE-vlan100] port gigabitethernet 1/0/1
[DeviceE-vlan100] quit
# Create VLAN-interface 100 and assign it an IP address.
[DeviceE] interface vlan-interface 100
[DeviceE-vlan-interface100] ip address 100.1.1.2 24
[DeviceE-vlan-interface100] quit
# Create VLAN 200 and assign GigabitEthernet 1/0/2 to the VLAN.
[DeviceE] vlan 200
[DeviceE-vlan200] port gigabitethernet 1/0/2
[DeviceE-vlan200] quit
# Create VLAN-interface 200 and assign it an IP address.
[DeviceE] interface vlan-interface 200
[DeviceE-vlan-interface200] ip address 200.1.1.2 24
[DeviceE-vlan-interface200] quit
# Create VLAN 30 and assign GigabitEthernet 1/0/3 to the VLAN.
[DeviceE] vlan 30
[DeviceE-vlan30] port gigabitethernet 1/0/3
[DeviceE-vlan30] quit
# Create VLAN-interface 30 and assign it an IP address.
[DeviceE] interface vlan-interface 30
[DeviceE-vlan-interface30] ip address 30.1.1.1 24
[DeviceE-vlan-interface30] quit
# Configure OSPF.
[DeviceD] ospf
[DeviceD-ospf-1-area-0.0.0.0] network 100.1.1.0 0.0.0.255
[DeviceD-ospf-1-area-0.0.0.0] network 30.1.1.0 0.0.0.255
Configuring Device F
[DeviceF] vlan 10
[DeviceF-vlan10] quit
[DeviceF] vlan 20
[DeviceF-vlan20] quit
# Create Layer 2 dynamic aggregate interface Bridge-Aggregation 4.
[DeviceF] interface bridge-aggregation 4
[DeviceF-Bridge-Aggregation4] link-aggregation mode dynamic
[DeviceF-Bridge-Aggregation4] quit
# Assign GigabitEthernet 1/0/1 through GigabitEthernet 1/0/4 to aggregation group 4.
[DeviceF] interface range gigabitethernet 1/0/1 to gigabitethernet 1/0/4
[DeviceF-if-range] port link-aggregation group 4
[DeviceF-if-range] quit
[DeviceF-Bridge-Aggregation4] port link-type trunk
[DeviceF-Bridge-Aggregation4] port trunk permit vlan 10 20
This configuration example uses the output from Release 6615P03. The command output varies by software version.
# Verify that Device A and Device B have formed a DR system.
[DeviceA] display drni summary
Flags: A -- Aggregate interface down, B -- No peer DR interface configured
C -- Configuration consistency check failed
IPP: BAGG3
IPP state (cause): UP
Keepalive link state (cause): UP
DR interface information
DR interface DR group Local state (cause) Peer state Remaining down time (s)
BAGG4 4 UP UP -
[DeviceA] display drni verbose
Flags: A -- Home_Gateway, B -- Neighbor_Gateway, C -- Other_Gateway,
D -- IPP_Activity, E -- DRCP_Timeout, F -- Gateway_Sync,
G -- Port_Sync, H -- Expired
IPP/IPP ID: BAGG3/1
State: UP
Cause: -
Local DRCP flags/Peer DRCP flags: ABDFG/ABDFG
Local Selected ports (index): GE1/0/3 (260), GE1/0/4 (261)
Peer Selected ports indexes: 260, 261
DR interface/DR group ID: BAGG4/4
Local DR interface state: UP
Peer DR interface state: UP
DR group state: UP
Local DR interface down cause: -
Remaining DRNI DOWN time: -
Local DR interface LACP MAC: Config=0001-0001-0001, Effective=0001-0001-0001
Peer DR interface LACP MAC: Config=0001-0001-0001, Effective=0001-0001-0001
Local DR interface LACP priority: Config=123, Effective=123
Peer DR interface LACP priority: Config=123, Effective=123
Local Selected ports (index): GE1/0/1 (258), GE1/0/2 (259)
Peer Selected ports indexes: 258, 259
# Verify that all member ports of aggregation group 4 are in Selected state on Device F, which indicates a successful link aggregation between the DR system and Device F.
[DeviceF] display link-aggregation verbose
Port: A -- Auto port, M -- Management port, R -- Reference port
G -- Defaulted, H -- Expired
Aggregate Interface: Bridge-Aggregation4
Creation Mode: Manual
Aggregation Mode: Dynamic
Management VLANs: None
System ID: 0x8000, 1eba-3c46-0300
Local:
Port Status Priority Index Oper-Key Flag
GE1/0/1 S 32768 1 1 {ACDEF}
GE1/0/2 S 32768 2 1 {ACDEF}
GE1/0/3 S 32768 3 1 {ACDEF}
GE1/0/4 S 32768 4 1 {ACDEF}
Remote:
Actor Priority Index Oper-Key SystemID Flag
GE1/0/1(R) 32768 16385 40004 0x7b , 0001-0001-0001 {ACDEF}
GE1/0/2 32768 16388 40004 0x7b , 0001-0001-0001 {ACDEF}
GE1/0/3 32768 32769 40004 0x7b , 0001-0001-0001 {ACDEF}
GE1/0/4 32768 32772 40004 0x7b , 0001-0001-0001 {ACDEF}
# Verify that Device C is the master in VRRP group 1 and Device D is the master in VRRP group 2.
[DeviceC] display vrrp
Running mode : Standard
Interface VRID State Running Adver Auth Virtual
Pri Timer Type IP
Vlan10 1 Master 200 100 None 10.1.1.100
Vlan20 2 Backup 100 100 None 20.1.1.100
[DeviceD] display vrrp
Pri Timer Type IP
Vlan10 1 Backup 100 100 None 10.1.1.100
Vlan20 2 Master 200 100 None 20.1.1.100
# Verify that Device E has established OSPF neighbor relationships with Device C and Device D.
[DeviceE] display ospf peer
OSPF Process 1 with Router ID 200.1.1.2
Neighbor Brief Information
Area: 0.0.0.0
Router ID Address Pri Dead-Time State Interface
100.1.1.1 100.1.1.1 1 35 Full/BDR Vlan100
200.1.1.1 200.1.1.1 1 33 Full/BDR Vlan200
# Verify that the host in Area A can ping VLAN-interface 30 (30.1.1.1) on Device E.
C:\Documents and Settings\Administrator>ping 30.1.1.1
Pinging 30.1.1.1 with 32 bytes of data:
Reply from 30.1.1.1: bytes=32 time=1ms TTL=126
Ping statistics for 30.1.1.1:
Configuration files
IMPORTANT: Support for the port link-mode bridge command depends on the device model. |
· Device A:
vlan 10
vlan 20
interface Bridge-Aggregation1
port trunk permit vlan 1 10 20
interface Bridge-Aggregation3
interface Bridge-Aggregation4
port drni group 4
interface GigabitEthernet1/0/5
ip address 1.1.1.1 255.255.255.0
interface GigabitEthernet1/0/4
interface GigabitEthernet1/0/6
interface GigabitEthernet1/0/7
drni system-mac 0001-0001-0001
drni mad exclude interface GigabitEthernet1/0/5
· Device B:
vlan 10
vlan 20
interface Bridge-Aggregation2
port drni group 4
ip address 1.1.1.2 255.255.255.0
· Device C:
ospf 1
area 0.0.0.0
vlan 10
vlan 20
vlan 100
interface Vlan-interface10
interface Vlan-interface20
ip address 20.1.1.1 255.255.255.0
interface Vlan-interface100
ip address 100.1.1.1 255.255.255.0
port access vlan 100
track 1 interface GigabitEthernet1/0/3
· Device D:
ospf 1
area 0.0.0.0
vlan 10
vlan 20
vlan 200
ip address 20.1.1.2 255.255.255.0
interface Vlan-interface200
ip address 200.1.1.1 255.255.255.0
port access vlan 200
track 2 interface GigabitEthernet1/0/3
· Device E:
ospf 1
area 0.0.0.0
vlan 30
vlan 100
vlan 200
interface Vlan-interface30
ip address 30.1.1.1 255.255.255.0
ip address 100.1.1.2 255.255.255.0
ip address 200.1.1.2 255.255.255.0
port access vlan 30
· Device F:
vlan 10
vlan 20
As shown in Figure 2:
· Configure Device A and Device B as a DR system to establish one multichassis aggregate link with Device C and Device D.
· Configure two VRRP groups on Device A and Device B to provide gateway services for VLAN 100 and VLAN 101.
¡ Configure VRRP group 1 to provide gateway services for hosts in VLAN 100 (Area A). Add Device A and Device B to the group as the master and backup devices, respectively.
¡ Configure VRRP group 2 to provide gateway services for hosts in VLAN 101 (Area B). Add Device B and Device A to the group as the master and backup devices, respectively.
· Configure OSPF on Device A, Device B, and Device E for the hosts to communicate with external networks at Layer 3.
Device |
IP address |
Device |
IP address |
Device A |
GE 1/0/5 |
1.1.1.1/24 |
Device B |
GE 1/0/5 |
1.1.1.2/24 |
100.1.1.1/24 |
100.1.1.2/24 |
VLAN-interface 101 |
101.1.1.1/24 |
101.1.1.2/24 |
VLAN-interface 10 |
10.1.1.1/24 |
VLAN-interface 20 |
20.1.1.1/24 |
Virtual IP 1 |
100.1.1.100/24 |
Virtual IP 1 |
100.1.1.100/24 |
Virtual IP 2 |
101.1.1.100/24 |
Virtual IP 2 |
101.1.1.100/24 |
Device E |
VLAN-interface 10 |
10.1.1.2/24 |
VLAN-interface 20 |
20.1.1.2/24 |
VLAN-interface 30 |
30.1.1.1/24 |
Analysis
For Device A to be the master in VRRP group 1, assign it a higher priority than Device B. For Device B to be the master in VRRP group 2, assign it a higher priority than Device A.
Hardware |
Software version |
Release 6615Pxx |
Not supported |
Not supported |
Release 63xx, Release 65xx, Release 6615Pxx |
Not supported |
Not supported |
Not supported |
Not supported |
Not supported |
Not supported |
Not supported |
Not supported |
Not supported |
Not supported |
Not supported |
Not supported |
Not supported |
Not supported |
Not supported |
Not supported |
Not supported |
Not supported |
Not supported |
Not supported |
Not supported |
Not supported |
Not supported |
Not supported |
Not supported |
Not supported |
To balance traffic between two VRRP gateway devices, you can assign them to two VRRP groups with different priorities. In this example, Device A is assigned a higher priority than Device B in VRRP group 1 so Device A can become the master in this group. Device B is assigned a higher priority than Device A in VRRP group 2 so Device B can become the master in this group.
· Loopback address.
Procedures
# Create Layer 2 dynamic aggregate interface Bridge-Aggregation 125 and specify it as the IPP.
[DeviceA] interface bridge-aggregation 125
[DeviceA-Bridge-Aggregation125] link-aggregation mode dynamic
[DeviceA-Bridge-Aggregation125] port drni intra-portal-port 1
[DeviceA-Bridge-Aggregation125] quit
# Assign GigabitEthernet 1/0/3 and GigabitEthernet 1/0/4 to aggregation group 125.
[DeviceA-GigabitEthernet1/0/3] port link-aggregation group 125
[DeviceA-GigabitEthernet1/0/4] port link-aggregation group 125
# Create Layer 2 dynamic aggregate interface Bridge-Aggregation 100 and assign it to DR group 1.
[DeviceA] interface bridge-aggregation 100
[DeviceA-Bridge-Aggregation100] link-aggregation mode dynamic
[DeviceA-Bridge-Aggregation100] port drni group 1
[DeviceA-Bridge-Aggregation100] quit
# Assign GigabitEthernet 1/0/1 to aggregation group 100.
[DeviceA-GigabitEthernet1/0/1] port link-aggregation group 100
# Create Layer 2 dynamic aggregate interface Bridge-Aggregation 101 and assign it to DR group 2.
[DeviceA] interface bridge-aggregation 101
[DeviceA-Bridge-Aggregation101] link-aggregation mode dynamic
[DeviceA-Bridge-Aggregation101] port drni group 2
[DeviceA-Bridge-Aggregation101] quit
# Assign GigabitEthernet 1/0/2 to aggregation group 101.
[DeviceA-GigabitEthernet1/0/2] port link-aggregation group 101
# Create VLAN 10, VLAN 100, and VLAN 101.
[DeviceA] vlan 10
[DeviceA] vlan 100
[DeviceA-vlan100] quit
[DeviceA] vlan 101
[DeviceA-vlan101] quit
# Assign GigabitEthernet 1/0/6 to VLAN 10.
[DeviceA] vlan 10
[DeviceA-vlan10] port gigabitethernet 1/0/6
# Set the link type of Bridge-Aggregation 100 to trunk and assign it to VLAN 100.
[DeviceA-Bridge-Aggregation100] port link-type trunk
[DeviceA-Bridge-Aggregation100] port trunk permit vlan 100
# Set the link type of Bridge-Aggregation 101 to trunk and assign it to VLAN 101.
[DeviceA-Bridge-Aggregation101] port link-type trunk
[DeviceA-Bridge-Aggregation101] port trunk permit vlan 101
# Set the link type of Bridge-Aggregation 125 to trunk and assign it to VLAN 100 and VLAN 101.
[DeviceA-Bridge-Aggregation125] port link-type trunk
[DeviceA-Bridge-Aggregation125] port trunk permit vlan 100 101
# Create VLAN-interface 10, VLAN-interface 100, and VLAN-interface 101 and assign an IP address to each of them.
[DeviceA-vlan-interface10] ip address 10.1.1.1 24
[DeviceA-vlan-interface10] quit
[DeviceA] interface vlan-interface 100
[DeviceA-vlan-interface100] ip address 100.1.1.1 24
[DeviceA-vlan-interface100] quit
[DeviceA] interface vlan-interface 101
[DeviceA-vlan-interface101] ip address 101.1.1.1 24
[DeviceA-vlan-interface101] quit
# Configure OSPF.
[DeviceA] ospf
[DeviceA-ospf-1] area 0
[DeviceA-ospf-1-area-0.0.0.0] network 10.1.1.0 0.0.0.255
[DeviceA-ospf-1-area-0.0.0.0] network 100.1.1.0 0.0.0.255
[DeviceA-ospf-1-area-0.0.0.0] network 101.1.1.0 0.0.0.255
[DeviceA-ospf-1-area-0.0.0.0] quit
[DeviceA-ospf-1] quit
# Create VRRP group 1 on VLAN-interface 100 and set its virtual IP address to 100.1.1.100.
[DeviceA-Vlan-interface100] vrrp vrid 1 virtual-ip 100.1.1.100
# Set the priority of Device A to 200 for it to become the master in VRRP group 1.
[DeviceA-Vlan-interface100] vrrp vrid 1 priority 200
[DeviceA-Vlan-interface100] quit
# Create VRRP group 2 on VLAN-interface 101 and set its virtual IP address to 101.1.1.100.
[DeviceA-Vlan-interface101] vrrp vrid 2 virtual-ip 101.1.1.100
[DeviceA-Vlan-interface101] quit
# Configure Device A to operate in preemptive mode in VRRP group 1. Set the preemption delay to 500 centiseconds to avoid frequent status switchover.
[DeviceA-Vlan-interface100] vrrp vrid 1 preempt-mode delay 500
# Create track entry 1 to monitor the upstream link status of GigabitEthernet 1/0/6.
[DeviceA] track 1 interface gigabitethernet 1/0/6
# Configure Device A in VRRP group 1 to monitor track entry 1, and decrease its priority by 150 when the track entry transits to Negative.
[DeviceA-Vlan-interface100] vrrp vrid 1 track 1 priority reduced 150
[DeviceB] interface bridge-aggregation 125
[DeviceB-Bridge-Aggregation125] link-aggregation mode dynamic
[DeviceB-Bridge-Aggregation125] port drni intra-portal-port 1
[DeviceB-Bridge-Aggregation125] quit
[DeviceB-GigabitEthernet1/0/3] port link-aggregation group 125
[DeviceB-GigabitEthernet1/0/4] port link-aggregation group 125
[DeviceB] interface bridge-aggregation 100
[DeviceB-Bridge-Aggregation100] link-aggregation mode dynamic
[DeviceB-Bridge-Aggregation100] port drni group 1
[DeviceB-Bridge-Aggregation100] quit
# Assign GigabitEthernet 1/0/2 to aggregation group 100.
[DeviceB-GigabitEthernet1/0/2] port link-aggregation group 100
[DeviceB] interface bridge-aggregation 101
[DeviceB-Bridge-Aggregation101] link-aggregation mode dynamic
[DeviceB-Bridge-Aggregation101] port drni group 2
[DeviceB-Bridge-Aggregation101] quit
# Assign GigabitEthernet 1/0/1 to aggregation group 101.
[DeviceB-GigabitEthernet1/0/1] port link-aggregation group 101
# Create VLAN 20, VLAN 100, and VLAN 101.
[DeviceB] vlan 20
[DeviceB] vlan 100
[DeviceB-vlan100] quit
[DeviceB] vlan 101
[DeviceB-vlan101] quit
# Assign GigabitEthernet 1/0/6 to VLAN 20.
[DeviceB] vlan 20
[DeviceB-vlan20] port gigabitethernet 1/0/6
[DeviceB-Bridge-Aggregation100] port link-type trunk
[DeviceB-Bridge-Aggregation100] port trunk permit vlan 100
[DeviceB-Bridge-Aggregation101] port link-type trunk
[DeviceB-Bridge-Aggregation101] port trunk permit vlan 101
[DeviceB-Bridge-Aggregation125] port link-type trunk
[DeviceB-Bridge-Aggregation125] port trunk permit vlan 100 101
# Create VLAN-interface 20, VLAN-interface 100, and VLAN-interface 101 and assign an IP address to each of them.
[DeviceB] interface vlan-interface 20
[DeviceB-vlan-interface20] ip address 20.1.1.1 24
[DeviceB-vlan-interface20] quit
[DeviceB] interface vlan-interface 100
[DeviceB-vlan-interface100] ip address 100.1.1.2 24
[DeviceB-vlan-interface100] quit
[DeviceB] interface vlan-interface 101
[DeviceB-vlan-interface101] ip address 101.1.1.2 24
[DeviceB-vlan-interface101] quit
# Configure OSPF.
[DeviceB] ospf
[DeviceB-ospf-1] area 0
[DeviceB-ospf-1-area-0.0.0.0] network 20.1.1.0 0.0.0.255
[DeviceB-ospf-1-area-0.0.0.0] network 100.1.1.0 0.0.0.255
[DeviceB-ospf-1-area-0.0.0.0] network 101.1.1.0 0.0.0.255
[DeviceB-ospf-1-area-0.0.0.0] quit
[DeviceB-ospf-1] quit
[DeviceB-Vlan-interface100] vrrp vrid 1 virtual-ip 100.1.1.100
[DeviceB-Vlan-interface100] quit
[DeviceB-Vlan-interface101] vrrp vrid 2 virtual-ip 101.1.1.100
# Set the priority of Device B to 200 for it to become the master in VRRP group 2.
[DeviceB-Vlan-interface101] vrrp vrid 2 priority 200
# Configure Device B to operate in preemptive mode in VRRP group 2. Set the preemption delay to 500 centiseconds to avoid frequent status switchover.
[DeviceB-Vlan-interface101] vrrp vrid 2 preempt-mode delay 500
[DeviceB-Vlan-interface101] quit
# Create track entry 2 to monitor the upstream link status of GigabitEthernet 1/0/6.
[DeviceB] track 2 interface gigabitethernet 1/0/6
# Configure Device B in VRRP group 2 to monitor track entry 2, and decrease its priority by 150 when the track entry transits to Negative.
[DeviceB-Vlan-interface101] vrrp vrid 2 track 2 priority reduced 150
# Create VLAN 100.
[DeviceC] vlan 100
[DeviceC] interface gigabitethernet 1/0/3
[DeviceC-GigabitEthernet1/0/3] port access vlan 100
[DeviceC-GigabitEthernet1/0/3] quit
# Create Layer 2 dynamic aggregate interface Bridge-Aggregation 100.
[DeviceC] interface bridge-aggregation 100
[DeviceC-Bridge-Aggregation100] link-aggregation mode dynamic
[DeviceC-Bridge-Aggregation100] quit
# Assign GigabitEthernet 1/0/1 and GigabitEthernet 1/0/2 to aggregation group 100.
[DeviceC-if-range] port link-aggregation group 100
[DeviceC-Bridge-Aggregation100] port link-type trunk
[DeviceC-Bridge-Aggregation100] port trunk permit vlan 100
# Create VLAN 101.
[DeviceD] vlan 101
[DeviceD-vlan101] quit
# Assign GigabitEthernet 1/0/3 to VLAN 101.
[DeviceD] interface gigabitethernet 1/0/3
[DeviceD-GigabitEthernet1/0/3] port access vlan 101
[DeviceD-GigabitEthernet1/0/3] quit
# Create Layer 2 dynamic aggregate interface Bridge-Aggregation 101.
[DeviceD] interface bridge-aggregation 101
[DeviceD-Bridge-Aggregation101] link-aggregation mode dynamic
[DeviceD-Bridge-Aggregation101] quit
# Assign GigabitEthernet 1/0/1 and GigabitEthernet 1/0/2 to aggregation group 101.
[DeviceD-if-range] port link-aggregation group 101
[DeviceD-Bridge-Aggregation101] port link-type trunk
[DeviceD-Bridge-Aggregation101] port trunk permit vlan 101
# Create VLAN 10 and assign GigabitEthernet 1/0/1 to the VLAN.
[DeviceE] vlan 10
[DeviceE-vlan10] port gigabitethernet 1/0/1
[DeviceE-vlan10] quit
# Create VLAN-interface 10 and assign it an IP address.
[DeviceE-vlan-interface10] ip address 10.1.1.2 24
[DeviceE-vlan-interface10] quit
# Create VLAN 20 and assign GigabitEthernet 1/0/2 to the VLAN.
[DeviceE] vlan 20
[DeviceE-vlan20] port gigabitethernet 1/0/2
[DeviceE-vlan20] quit
# Create VLAN-interface 20 and assign it an IP address.
[DeviceE-vlan-interface20] ip address 20.1.1.2 24
[DeviceE-vlan-interface20] quit
[DeviceE] vlan 30
# Configure OSPF.
[DeviceE] ospf
[DeviceE-ospf-1] area 0
[DeviceE-ospf-1-area-0.0.0.0] network 10.1.1.0 0.0.0.255
[DeviceE-ospf-1-area-0.0.0.0] network 20.1.1.0 0.0.0.255
[DeviceE-ospf-1-area-0.0.0.0] network 30.1.1.0 0.0.0.255
[DeviceE-ospf-1-area-0.0.0.0] quit
[DeviceE-ospf-1] quit
IPP: BAGG125
BAGG100 1 UP UP -
BAGG101 2 UP UP -
IPP/IPP ID: BAGG125/1
State: UP
Cause: -
Local Selected ports (index): GE1/0/3 (261), GE1/0/4 (262)
Peer Selected ports indexes: 261, 262
DR interface/DR group ID: BAGG100/1
DR group state: UP
Local Selected ports (index): GE1/0/1 (259)
Peer Selected ports indexes: 259
DR interface/DR group ID: BAGG101/2
DR group state: UP
Local Selected ports (index): GE1/0/2 (260)
# Verify that all member ports of aggregation group 100 are in Selected state on Device C, which indicates a successful link aggregation between the DR system and Device C.
[DeviceC] display link-aggregation verbose
Aggregate Interface: Bridge-Aggregation100
System ID: 0x8000, 8e33-8e4a-0300
Local:
Remote:
GE1/0/1(R) 32768 16386 40001 0x7b , 0001-0001-0001 {ACDEF}
GE1/0/2 32768 32770 40001 0x7b , 0001-0001-0001 {ACDEF}
# Verify that all member ports of aggregation group 101 are in Selected state on Device D, which indicates a successful link aggregation between the DR system and Device D.
[DeviceD] display link-aggregation verbose
Aggregate Interface: Bridge-Aggregation101
System ID: 0x8000, 8e33-9400-0400
Local:
Remote:
GE1/0/1(R) 32768 16387 40002 0x7b , 0001-0001-0001 {ACDEF}
GE1/0/2 32768 32771 40002 0x7b , 0001-0001-0001 {ACDEF}
# Verify that Device A is the master in VRRP group 1 and Device B is the master in VRRP group 2.
[DeviceA] display vrrp
Pri Timer Type IP
Vlan100 1 Master 200 100 None 100.1.1.100
Vlan101 2 Backup 100 100 None 101.1.1.100
[DeviceB] display vrrp
Pri Timer Type IP
Vlan100 1 Backup 100 100 None 100.1.1.100
Vlan101 2 Master 200 100 None 101.1.1.100
# Verify that Device E has established OSPF neighbor relationships with Device A and Device B.
OSPF Process 1 with Router ID 30.1.1.1
Area: 0.0.0.0
101.1.1.1 10.1.1.1 1 34 Full/DR Vlan10
101.1.1.2 20.1.1.1 1 36 Full/DR Vlan20
# Verify that a host in Area A can ping the host at 101.1.1.4 in Area B.
C:\Documents and Settings\Administrator>ping 101.1.1.4
Pinging 101.1.1.4 with 32 bytes of data:
Reply from 101.1.1.4: bytes=32 time=1ms TTL=126
Ping statistics for 101.1.1.4:
# Verify that a host in Area A can ping VLAN-interface 30 (30.1.1.1) on Device E.
Configuration files
· Device A:
ospf 1
area 0.0.0.0
vlan 10
vlan 100 to 101
interface Bridge-Aggregation100
port trunk permit vlan 1 100
port drni group 1
interface Bridge-Aggregation101
port trunk permit vlan 1 101
port drni group 2
interface Bridge-Aggregation125
port trunk permit vlan 1 100 to 101
interface Vlan-interface101
ip address 101.1.1.1 255.255.255.0
port access vlan 10
track 1 interface GigabitEthernet1/0/6
· Device B:
ospf 1
area 0.0.0.0
vlan 20
vlan 100 to 101
port drni group 1
port drni group 2
ip address 101.1.1.2 255.255.255.0
port access vlan 20
track 2 interface GigabitEthernet1/0/6
· Device C:
vlan 100
· Device D:
vlan 101
· Device E:
ospf 1
area 0.0.0.0
vlan 10
vlan 20
vlan 30
port access vlan 10
port access vlan 20
port access vlan 30
As shown in Figure 3, set up a DR system with Device A and Device B as follows.
· Attach Device D to DR interfaces on the DR system.
· Configure ECMP routes between the DR system and Device C.
· Configure dual-active VLAN interfaces on the DR system to provide IPv4 and IPv6 gateway services for the servers.
IP address |
Peer device and interface |
Device A |
GE1/0/1 |
Device D: GE1/0/1 |
GE1/0/2 |
Device D: GE1/0/2 |
GE1/0/3 |
Device B: GE1/0/3 |
GE1/0/4 |
Device B: GE1/0/4 |
GE1/0/5 |
IPv4: 21.1.1.1 IPv6: 21::1 |
Device B: GE1/0/5 |
GE1/0/6 |
Device C: GE1/0/1 |
Vlan-int100 |
IPv4: 100.1.1.100/24 IPv6: 100::100/64 |
Vlan-int101 |
IPv4: 101.1.1.1/24 IPv6: 101::1/64 |
Device B: Vlan-int101 · IPv4: 101.1.1.2/24 · IPv6: 101::2/64 |
Vlan-int32 |
IPv4: 32.1.1.1/24 IPv6: 32::1/64 |
Device C: Vlan-int32 · IPv4: 32.1.1.2/24 · IPv6: 32::2/64 |
Device B |
GE1/0/1 |
Device D: GE1/0/3 |
GE1/0/2 |
Device D: GE1/0/4 |
GE1/0/3 |
Device A: GE1/0/3 |
GE1/0/4 |
Device A: GE1/0/4 |
GE1/0/5 |
IPv4: 21.1.1.2 IPv6: 21::2 |
Device A: GE1/0/5 |
GE1/0/6 |
Device C: GE1/0/6 |
Vlan-int100 |
Vlan-int101 |
IPv4: 101.1.1.2/24 IPv6: 101::2/64 |
Device A: Vlan-int101 · IPv4: 101.1.1.1/24 · IPv6: 101::1/64 |
Vlan-int33 |
IPv4: 33.1.1.1/24 IPv6: 33::1/64 |
Device C: Vlan-int33 · IPv4: 33.1.1.2/24 · IPv6: 33::2/64 |
Device C |
GE1/0/1 |
Device A: GE1/0/6 |
GE1/0/2 |
Device B: GE1/0/6 |
GE1/0/3 |
Network 1 |
Vlan-int22 |
IPv4: 22.1.1.1/24 IPv6: 22::1/64 |
Network 1 |
Vlan-int32 |
IPv4: 32.1.1.2/24 IPv6: 32::2/64 |
Device A: Vlan-int32 · IPv4: 32.1.1.1/24 · IPv6: 32::1/64 |
Vlan-int33 |
IPv4: 33.1.1.2/24 IPv6: 33::2/64 |
Device B: Vlan-int33 · IPv4: 33.1.1.1/24 · IPv6: 33::1/64 |
Device D |
GE1/0/1 |
Device A: GE1/0/1 |
GE1/0/2 |
Device A: GE1/0/2 |
GE1/0/3 |
Device B: GE1/0/1 |
GE1/0/4 |
Device B: GE1/0/2 |
Analysis
To configure IPv4 and IPv6 dual-active VLAN interfaces, perform the following tasks:
· Assign the same IPv4 address, MAC address, IPv6 address, and IPv6 link-local address to VLAN-interface 100 interfaces on Device A and Device B.
· Create VLAN-interface 101 on both Device A and Device B for them to have Layer 3 connectivity. When an uplink to Device C fails, all traffic will be processed by the available DR member device.
Hardware |
Software version |
Not supported |
Not supported |
Not supported |
Not supported |
Not supported |
Not supported |
Not supported |
Not supported |
Not supported |
Not supported |
Not supported |
Not supported |
Not supported |
Not supported |
Not supported |
Not supported |
Not supported |
Not supported |
Not supported |
Not supported |
Not supported |
Not supported |
Not supported |
Not supported |
Not supported |
Not supported |
Not supported |
Not supported |
Not supported |
Not supported |
For two DR member devices to be identified as one DR system, you must configure the same DR system MAC address on them. Make sure DR systems use unique DR system MAC addresses.
Procedures
[DeviceA] drni system-mac 0002-0002-0002
[DeviceA] drni keepalive ip destination 21.1.1.2 source 21.1.1.1
# Configure GigabitEthernet 1/0/5 as a routed (Layer 3) interface and assign the interface an IPv4 address and an IPv6 address. The IP addresses will be used as the source IP addresses of keepalive packets.
[DeviceA-GigabitEthernet1/0/5] ip address 21.1.1.1 255.255.255.0
[DeviceA-GigabitEthernet1/0/5] ipv6 address 21::1 64
# Assign GigabitEthernet 1/0/3 and GigabitEthernet 1/0/4 to aggregation group 1.
# Configure Bridge-Aggregation 1 as the IPP.
[DeviceA-Bridge-Aggregation1] port drni intra-portal-port 1
[DeviceA-Bridge-Aggregation1] undo port trunk permit vlan 1
# Create Layer 2 dynamic aggregate interface Bridge-Aggregation 3, and assign it to DR group 1.
[DeviceA-Bridge-Aggregation3] port drni group 1
# Assign GigabitEthernet 1/0/1 and GigabitEthernet 1/0/2 to aggregation group 3.
[DeviceA-GigabitEthernet1/0/1] port link-aggregation group 3
[DeviceA-GigabitEthernet1/0/2] port link-aggregation group 3
# Create VLAN 100 and VLAN 101.
[DeviceA] vlan 100
[DeviceA] vlan 101
# Set the link type of Bridge-Aggregation 3 to trunk, and assign it to VLAN 100.
[DeviceA-Bridge-Aggregation3] port trunk permit vlan 100
[DeviceA-Bridge-Aggregation3] undo port trunk permit vlan 1
# Create VLAN-interface 100, and assign it an IPv4 address and a MAC address for it to act as an IPv4 gateway.
[DeviceA-Vlan-interface100] ip address 100.1.1.100 255.255.255.0
[DeviceA-Vlan-interface100] mac-address 0000-0010-0010
# Assign VLAN-interface 100 an IPv6 address and a link-local address for it to act as an IPv6 gateway.
[DeviceA-Vlan-interface100] ipv6 address 100::100 64
[DeviceA-Vlan-interface100] ipv6 address FE80::80 link-local
# Exclude VLAN-interface 100 from the shutdown action by DRNI MAD.
[DeviceA] drni mad exclude interface vlan-interface100
# Create VLAN-interface 101 and assign it an IPv4 address and an IPv6 address for the device to communicate with the DR peer at Layer 3.
[DeviceA-Vlan-interface101] ip address 101.1.1.1 255.255.255.0
[DeviceA-Vlan-interface101] ipv6 address 101::1 64
# Exclude VLAN-interface 101 from the shutdown action by DRNI MAD.
[DeviceA] drni mad exclude interface vlan-interface101
# Configure the router ID as 3.3.3.3.
[DeviceA] router id 3.3.3.3
# Configure OSPF on VLAN-interface 100 and VLAN-interface 101. Disable VLAN-interface 100 from receiving and sending OSPF packets. The OSPF configuration enables the DR member devices to have IPv4 connectivity.
[DeviceA] ospf 1
[DeviceA-ospf-1] silent-interface vlan-interface 100
[DeviceA-ospf-1] import-route direct
[DeviceA-Vlan-interface100] ospf 1 area 0.0.0.0
[DeviceA-Vlan-interface101] ospf 1 area 0.0.0.0
# Configure OSPFv3 on VLAN-interface 100 and VLAN-interface 101. Disable VLAN-interface 100 from receiving and sending OSPFv3 packets. The OSPFv3 configuration enables the DR member devices to have IPv6 connectivity.
[DeviceA] ospfv3 1
[DeviceA-ospfv3-1] silent-interface vlan-interface 100
[DeviceA-ospfv3-1] import-route direct
[DeviceA-ospfv3-1] area 0
[DeviceA-ospfv3-1-area-0.0.0.0] quit
[DeviceA-ospfv3-1] quit
[DeviceA-Vlan-interface100] ospfv3 1 area 0.0.0.0
[DeviceA-Vlan-interface101] ospfv3 1 area 0.0.0.0
# Create VLAN 32, and assign GigabitEthernet 1/0/6 to the VLAN. The interface is an uplink member interface of the DR interface.
[DeviceA] vlan 32
[DeviceA-vlan32] quit
[DeviceA-GigabitEthernet1/0/6] port link-type trunk
[DeviceA-GigabitEthernet1/0/6] port trunk permit vlan 32
[DeviceA-GigabitEthernet1/0/6] undo port trunk permit vlan 1
# Create VLAN-interface 32, and assign the interface an IPv4 address and an IPv6 address. Enable OSPF and OSPFv3 on the interface.
[DeviceA] interface vlan-interface 32
[DeviceA-Vlan-interface32] ip address 32.1.1.1 255.255.255.0
[DeviceA-Vlan-interface32] ipv6 address 32::1 64
[DeviceA-Vlan-interface32] ospf 1 area 0
[DeviceA-Vlan-interface32] ospfv3 1 area 0
[DeviceA-Vlan-interface32] quit
[DeviceB] drni system-mac 0002-0002-0002
[DeviceB] drni keepalive ip destination 21.1.1.1 source 21.1.1.2
[DeviceB-GigabitEthernet1/0/5] ip address 21.1.1.2 255.255.255.0
[DeviceB-GigabitEthernet1/0/5] ipv6 address 21::2 64
[DeviceB-Bridge-Aggregation1] link-aggregation mode dynamic
[DeviceB-Bridge-Aggregation1] quit
[DeviceB-Bridge-Aggregation1] port drni intra-portal-port 1
[DeviceB-Bridge-Aggregation1] undo port trunk permit vlan 1
[DeviceB-Bridge-Aggregation3] port drni group 1
[DeviceB-GigabitEthernet1/0/1] port link-aggregation group 3
[DeviceB-GigabitEthernet1/0/2] port link-aggregation group 3
[DeviceB] vlan 100
[DeviceB] vlan 101
[DeviceB-Bridge-Aggregation3] port trunk permit vlan 100
[DeviceB-Bridge-Aggregation3] undo port trunk permit vlan 1
[DeviceB-Vlan-interface100] ip address 100.1.1.100 255.255.255.0
[DeviceB-Vlan-interface100] mac-address 0000-0010-0010
[DeviceB-Vlan-interface100] ipv6 address 100::100 64
[DeviceB-Vlan-interface100] ipv6 address FE80::80 link-local
[DeviceB] drni mad exclude interface vlan-interface100
[DeviceB-vlan-interface101] ipv6 address 101::2 64
[DeviceB] drni mad exclude interface vlan-interface101
# Configure the router ID as 4.4.4.4.
[DeviceB] router id 4.4.4.4
[DeviceB] ospf 1
[DeviceB-ospf-1] silent-interface vlan-interface100
[DeviceB-ospf-1] import-route direct
[DeviceB-Vlan-interface100] ospf 1 area 0.0.0.0
[DeviceB-Vlan-interface101] ospf 1 area 0.0.0.0
[DeviceB] ospfv3 1
[DeviceB-ospfv3-1] import-route direct
[DeviceB-ospfv3-1] area 0
[DeviceB-ospfv3-1-area-0.0.0.0] quit
[DeviceB-ospfv3-1] quit
[DeviceB-vlan-interface100] ospfv3 1 area 0
[DeviceB-vlan-interface101] ospfv3 1 area 0
# Create VLAN 33, and assign GigabitEthernet 1/0/6 to the VLAN. The interface is an uplink member interface of the DR interface.
[DeviceB] vlan 33
[DeviceB-vlan33] quit
[DeviceB-GigabitEthernet1/0/6] port link-type trunk
[DeviceB-GigabitEthernet1/0/6] port trunk permit vlan 33
[DeviceB-GigabitEthernet1/0/6] undo port trunk permit vlan 1
# Create VLAN-interface 33, and assign the interface an IPv4 address and an IPv6 address. Enable OSPF and OSPFv3 on the interface.
[DeviceB] interface vlan-interface 33
[DeviceB-Vlan-interface33] ip address 33.1.1.1 255.255.255.0
[DeviceB-Vlan-interface33] ipv6 address 33::1 64
[DeviceB-Vlan-interface33] ospf 1 area 0
[DeviceB-Vlan-interface33] ospfv3 1 area 0
[DeviceB-Vlan-interface33] quit
# Create VLAN 32 and assign GigabitEthernet 1/0/1 (attached to Device A) to the VLAN. Create VLAN-interface 32 and assign it an IPv4 address and an IPv6 address.
[DeviceC] vlan 32
[DeviceC-vlan32] quit
[DeviceC-GigabitEthernet1/0/1] port trunk permit vlan 32
[DeviceC-GigabitEthernet1/0/1] undo port trunk permit vlan 1
[DeviceC-GigabitEthernet1/0/] quit
[DeviceC] interface vlan-interface 32
[DeviceC-Vlan-interface32] ip address 32.1.1.2 24
[DeviceC-Vlan-interface32] ipv6 address 32::2 64
[DeviceC-Vlan-interface32] quit
# Create VLAN 33 and assign GigabitEthernet 1/0/2 (attached to Device B) to the VLAN. Create VLAN-interface 33 and assign it an IPv4 address and an IPv6 address.
[DeviceC] vlan 33
[DeviceC-vlan33] quit
[DeviceC-GigabitEthernet1/0/2] port link-type trunk
[DeviceC-GigabitEthernet1/0/2] port trunk permit vlan 33
[DeviceC-GigabitEthernet1/0/2] undo port trunk permit vlan 1
[DeviceC] interface vlan-interface 33
[DeviceC-Vlan-interface33] ip address 33.1.1.2 24
[DeviceC-Vlan-interface33] ipv6 address 33::2 64
[DeviceC-Vlan-interface33] quit
# Configure the router ID as 5.5.5.5.
[DeviceC] router id 5.5.5.5
# Enable OSPF on VLAN-interface 32 and VLAN-interface 33.
[DeviceC] ospf 1
[DeviceC-ospf-1] import-route direct
[DeviceC-Vlan-interface32] ospf 1 area 0
[DeviceC-Vlan-interface33] ospf 1 area 0
# Enable OSPFv3 on VLAN-interface 32 and VLAN-interface 33.
[DeviceC] ospfv3 1
[DeviceC-ospfv3-1] import-route direct
[DeviceC-ospfv3-1] area 0
[DeviceC-ospfv3-1-area-0.0.0.0] quit
[DeviceC-ospfv3-1] quit
[DeviceC-Vlan-interface32] ospfv3 1 area 0
[DeviceC-Vlan-interface33] ospfv3 1 area 0
# Create VLAN 22, and assign GigabitEthernet 1/0/3 (attached to the upstream network) to the VLAN. Create VLAN-interface 22 and assign it an IPv4 address and an IPv6 address.
[DeviceC] vlan 22
[DeviceC-vlan22] quit
[DeviceC-GigabitEthernet1/0/3] port link-type trunk
[DeviceC-GigabitEthernet1/0/3] port trunk permit vlan 22
[DeviceC-GigabitEthernet1/0/3] undo port trunk permit vlan 1
[DeviceC] interface vlan-interface 22
[DeviceC-Vlan-interface22] ip address 22.1.1.1 24
[DeviceC-Vlan-interface22] ipv6 address 22::1 64
[DeviceC-Vlan-interface22] quit
# Create Layer 2 dynamic aggregate interface Bridge-Aggregation 3.
[DeviceD] interface bridge-aggregation 3
[DeviceD-Bridge-Aggregation3] link-aggregation mode dynamic
[DeviceD-Bridge-Aggregation3] quit
# Assign GigabitEthernet 1/0/1 through GigabitEthernet 1/0/4 to aggregation group 3.
[DeviceD] interface range gigabitethernet 1/0/1 to gigabitethernet 1/0/4
[DeviceD-if-range] port link-aggregation group 3
# Create VLAN 100.
[DeviceD] vlan 100
[DeviceD-vlan100] quit
[DeviceD-Bridge-Aggregation3] port link-type trunk
[DeviceD-Bridge-Aggregation3] port trunk permit vlan 100
[DeviceD-Bridge-Aggregation3] undo port trunk permit vlan 1
Verifying the DRNI configuration
The following tasks use Device A as an example.
# Verify that Device A has formed a DR system with Device B.
IPP: BAGG1
BAGG3 1 UP UP -
# Verify that the keepalive link is operating correctly.
[DeviceA] display drni keepalive
Neighbor keepalive link status: Up
Neighbor is alive for: 64765 s 28 ms
Keepalive packet transmission status:
Sent: Successful
Received: Successful
Last received keepalive packet information:
Source IP address: 21.1.1.2
Time: 2021/01/17 17:10:52
Action: Accept
Distributed relay keepalive parameters:
Destination IP address: 21.1.1.2
Source IP address: 21.1.1.1
Keepalive UDP port : 6400
Keepalive VPN name : N/A
Keepalive interval : 1000 ms
Keepalive timeout : 5 sec
Keepalive hold time: 3 sec
# Verify that the DR system is operating correctly.
<Sysname> display drni system
System information
Local system number: 1 Peer system number: 2
Local system MAC: 0002-0002-0002 Peer system MAC: 0002-0002-0002
Local system priority: 123 Peer system priority: 123
Local bridge MAC: 3cd4-3ce1-0200 Peer bridge MAC: 3cd4-437d-0300
Local effective role: Primary Peer effective role: Secondary
Health level: 0
Standalone mode on split: Disabled
In standalone mode: No
System timer information
Timer State Value (s) Remaining time (s)
Auto recovery Disabled - -
Restore delay Disabled 30 -
Consistency-check delay Disabled 15 -
Standalone delay Disabled - -
Role to None delay Disabled 60 -
# Verify that the interfaces used by DRNI are operating correctly.
IPP/IPP ID: BAGG1/1
State: UP
Cause: -
Local Selected ports (index): GE1/0/3 (27), GE1/0/4 (32)
Peer Selected ports indexes: 125, 130
DR interface/DR group ID: BAGG3/1
DR group state: UP
Local DR interface LACP MAC: Config=N/A, Effective=0002-0002-0002
Peer DR interface LACP MAC: Config=N/A, Effective=0002-0002-0002
Local DR interface LACP priority: Config=32768, Effective=123
Peer DR interface LACP priority: Config=32768, Effective=123
Local Selected ports (index): GE1/0/1 (12), GE1/0/2 (13)
Peer Selected ports indexes: 56, 57
Verifying routing configuration
# Verify that Device A have established OSPF neighbor relationships.
[DeviceA] display ospf peer
Area: 0.0.0.0
4.4.4.4 101.1.1.2 1 36 Full/DR Vlan101
5.5.5.5 32.1.1.2 1 38 Full/DR Vlan32
# Verify that Device A have established OSPFv3 neighbor relationships.
[DeviceA] display ospfv3 peer
OSPFv3 Process 1 with Router ID 3.3.3.3
Area: 0.0.0.0
Router ID Pri State Dead-Time InstID Interface
4.4.4.4 1 Full/DR 00:00:36 0 Vlan101
5.5.5.5 1 Full/DR 00:00:35 0 Vlan32
# Verify that Device B have established OSPF neighbor relationships.
[DeviceB] display ospf peer
OSPF Process 1 with Router ID 4.4.4.4
Area: 0.0.0.0
3.3.3.3 101.1.1.1 1 32 Full/BDR Vlan101
5.5.5.5 33.1.1.2 1 33 Full/DR Vlan33
# Verify that Device B have established OSPFv3 neighbor relationships.
[DeviceB] display ospfv3 peer
OSPFv3 Process 1 with Router ID 4.4.4.4
Area: 0.0.0.0
3.3.3.3 1 Full/BDR 00:00:35 0 Vlan101
5.5.5.5 1 Full/DR 00:00:38 0 Vlan33
# Verify that Device C have established OSPF neighbor relationships.
[DeviceC] display ospf peer
OSPF Process 1 with Router ID 5.5.5.5
Area: 0.0.0.0
3.3.3.3 32.1.1.1 1 32 Full/DR Vlan32
4.4.4.4 33.1.1.1 1 38 Full/DR Vlan33
# Verify that Device C have established OSPFv3 neighbor relationships.
[DeviceC] display ospfv3 peer
OSPFv3 Process 1 with Router ID 5.5.5.5
Area: 0.0.0.0
3.3.3.3 1 Full/DR 00:00:37 0 Vlan32
4.4.4.4 1 Full/DR 00:00:34 0 Vlan33
Verifying network connectivity
Verify that Server 1 and Server 2 have both IPv4 and IPv6 connectivity to the upstream network connected to Device C.
Verifying traffic failover
Disconnect the uplink interface on Device A and verify that Server 1 and Server 2 have connectivity to the upstream network connected to Device C. Transient traffic loss will occur during traffic failover.
Configuration files
· Device A:
router id 3.3.3.3
ospf 1
import-route direct
silent-interface Vlan-interface100
area 0.0.0.0
ospfv3 1
import-route direct
area 0.0.0.0
vlan 1
vlan 32
vlan 100 to 101
port trunk permit vlan 2 to 4094
port drni group 1
interface Vlan-interface32
ospf 1 area 0.0.0.0
ipv6 address 32::1/64
ospf 1 area 0.0.0.0
ipv6 address 100::100/64
ospf 1 area 0.0.0.0
ipv6 address 101::1/64
combo enable fiber
combo enable fiber
ipv6 address 21::1/64
drni mad exclude interface Vlan-interface100
drni mad exclude interface Vlan-interface101
· Device B:
router id 4.4.4.4
ospf 1
import-route direct
area 0.0.0.0
ospfv3 1
import-route direct
area 0.0.0.0
vlan 1
vlan 33
vlan 100 to 101
port trunk permit vlan all
port drni group 1
interface Vlan-interface33
ospf 1 area 0.0.0.0
ipv6 address 33::1/64
ospf 1 area 0.0.0.0
ospf 1 area 0.0.0.0
ipv6 address 101::2/64
combo enable fiber
combo enable fiber
ipv6 address 21::2/64
· Device C:
router id 5.5.5.5
ospf 1
import-route direct
area 0.0.0.0
ospfv3 1
import-route direct
area 0.0.0.0
vlan 1
vlan 22
vlan 32 to 33
interface Vlan-interface22
ip address 22.1.1.1 255.255.255.0
ipv6 address 22::1/64
ospf 1 area 0.0.0.0
ipv6 address 32::2/64
ip address 33.1.1.2 255.255.255.0
ospf 1 area 0.0.0.0
ipv6 address 33::2/64
· Device D:
vlan 1
vlan 100
