H3C Fixed Port Campus Switches Configuration Examples-6W106
HomeSupportConfigure & DeployConfiguration ExamplesH3C Fixed Port Campus Switches Configuration Examples-6W106
Table of Contents
Related Documents
21-IPv6 IS-IS Configuration Examples
21-IPv6 IS-IS Configuration Examples 114.86 KB
Introduction
This document provides IPv6 IS-IS configuration examples.
This document assumes that you have basic knowledge of IPv6 IS-IS.
Example: Configuring IPv6 IS-IS
As shown in Figure 1, the company's headquarters and the branch run IPv6 IS-IS. The partner runs OSPFv3.
Configure the switches to meet the following requirements:
·     The Marketing department can reach the Finance department, the branch, and the partner.
·     The Finance department and the branch cannot reach each other, and the branch does not have a route to the Finance department.
Figure 1 Network diagram
Analysis
To meet the network requirements, you must perform the following tasks:
·     Configure Switch A and Switch B in Area 10 as Level-1 routers to allow communication between the Marketing department and the Finance department.
·     Configure route redistribution between IPv6 IS-IS and OSPFv3 on Switch D to allow communication between the Marketing department and the partner.
·     Configure Switch C to use a prefix list to advertise only network 3001:1::/64 to Level-2. So that the branch does not have a route to the Finance department.
Hardware
Software version
S6812 switch series
S6813 switch series
Release 6615Pxx, Release 6628Pxx
S6550XE-HI switch series
Release 6008 and later, Release 8106Pxx
S6526XE-HI[EI] switch series
Release 8341P02 and later
S6510 switch series
S6525XE-HI switch series
S5850 switch series
Release 8005 and later, Release 8106Pxx
S5570S-EI switch series
Release 11xx
S5560X-EI switch series
Release 63xx, Release 65xx, Release 6615Pxx, Release 6628Pxx
S5560X-HI switch series
S5500V2-EI switch series
MS4520V2-30F switch
MS4520V2-30C switch
MS4520V2-54C switch
MS4520V2-28S switch
MS4520V2-24TP switch
Release 63xx
S6520X-HI switch series
S6520X-EI switch series
S6520X-SI switch series
S6520-SI switch series
S5000-EI switch series
MS4600 switch series
ES5500 switch series
S5560S-EI switch series
S5560S-SI switch series
Release 63xx
S5500V3-24P-SI
S5500V3-48P-SI
Release 63xx
S5500V3-SI switch series (except S5500V3-24P-SI and S5500V3-48P-SI)
Release 11xx
S5170-EI switch series
Not supported
S5130S-HI switch series
S5130S-EI switch series
S5130S-SI switch series
S5130S-LI switch series
Not supported
S5120V2-SI switch series
S5120V2-LI switch series
Not supported
S5120V3-EI switch series
Not supported
S5120V3-36F-SI
S5120V3-28P-HPWR-SI
S5120V3-54P-PWR-SI
Not supported
S5120V3-SI switch series (S5120V3-36F-SI, S5120V3-28P-HPWR-SI, and S5120V3-54P-PWR-SI)
Not supported
S5120V3-LI switch series
Not supported
S3600V3-EI switch series
Release 11xx
S3600V3-SI switch series
Not supported
S3100V3-EI switch series
S3100V3-SI switch series
Not supported
S5110V2 switch series
Not supported
S5110V2-SI switch series
Not supported
S5000V3-EI switch series
S5000V5-EI switch series
Not supported
S5000E-X switch series
S5000X-EI switch series
Not supported
E128C switch
E152C switch
E500C switch series
E500D switch series
Not supported
MS4320V2 switch series
MS4320V3 switch series
MS4300V2 switch series
MS4320 switch series
MS4200 switch series
Not supported
WS5850-WiNet switch series
Release 63xx
WS5820-WiNet switch series
WS5810-WiNet switch series
Not supported
WAS6000 switch series
Not supported
IE4300-12P-AC switch
IE4300-12P-PWR switch
IE4300-M switch series
IE4320 switch series
Not supported
IE4520 switch series
Release 66xx
S5135S-EI switch series
Not supported
S5136S-EI switch series
Not supported
Procedures
Configuring Switch A
# Configure an IPv6 address for VLAN-interface 11.
[SwitchA-Vlan-interface11] ipv6 address 2001:1::1 64
# Configure IPv6 addresses for other interfaces, as shown in Figure 1. (Details not shown.)
# Configure IPv6 IS-IS.
[SwitchA] isis 1
[SwitchA-isis-1] is-level level-1
[SwitchA-isis-1] network-entity 10.3001.0001.0001.00
[SwitchA-isis-1] address-family ipv6
[SwitchA-isis-1-ipv6] quit
[SwitchA-isis-1] quit
[SwitchA–vlan-interface 11] isis ipv6 enable 1
[SwitchA–vlan-interface 11] quit
[SwitchA–Vlan-interface100] isis ipv6 enable 1
[SwitchA–Vlan-interface100] quit
Configuring Switch B
# Configure an IPv6 address for VLAN-interface 12.
[SwitchB] interface vlan-interface 12
[SwitchB-Vlan-interface12] ipv6 address 2001:2::1 64
[SwitchB-Vlan-interface12] quit
[SwitchB] isis 1
[SwitchB-isis-1] is-level level-1
[SwitchB-isis-1] network-entity 10.3001.0002.0001.00
[SwitchB-isis-1] address-family ipv6
[SwitchB-isis-1-ipv6] quit
[SwitchB-isis-1] quit
[SwitchB–Vlan-interface12] isis ipv6 enable 1
[SwitchB–Vlan-interface12] quit
[SwitchB–Vlan-interface 200] isis ipv6 enable 1
[SwitchB–Vlan-interface 200] quit
Configuring Switch C
[SwitchC] interface vlan-interface 11
[SwitchC-Vlan-interface11] ipv6 address 2001:1::2 64
[SwitchC-Vlan-interface11] quit
[SwitchC] isis 1
[SwitchC-isis-1] is-level level-1
[SwitchC-isis-1] network-entity 10.2001.0010.0001.00
[SwitchC-isis-1] address-family ipv6
[SwitchC-isis-1-ipv6] quit
[SwitchC-isis-1] quit
[SwitchC] interface vlan-interface 10
[SwitchC–Vlan-interface10] isis ipv6 enable 1
[SwitchC–Vlan-interface10] quit
[SwitchC–Vlan-interface11] isis ipv6 enable 1
[SwitchC–Vlan-interface11] quit
[SwitchC] interface vlan-interface 12
[SwitchC–Vlan-interface12] isis ipv6 enable 1
[SwitchC–Vlan-interface12] quit
# Configure route leaking from Level-1 to Level-2, and use prefix list 1 to advertise only network 3001:1::/64 to Level-2.
[SwitchC] ipv6 prefix-list 1 permit 3001:1:: 64
[SwitchC] isis 1
[SwitchC-isis-1-ipv6] import-route isisv6 level-1 into level-2 filter-policy prefix-list 1
Configuring Switch D
# Configure an IPv6 address for VLAN-interface 10.
<SwitchD> system-view
[SwitchD] interface vlan-interface 10
[SwitchD-Vlan-interface10] ipv6 address 2001:10::2 64
[SwitchD-Vlan-interface10] quit
[SwitchD] isis 1
[SwitchD-isis-1] is-level level-2
[SwitchD-isis-1] network-entity 20.2001.0020.0001.00
[SwitchD-isis-1] address-family ipv6
[SwitchD-isis-1-ipv6] quit
[SwitchD-isis-1] quit
[SwitchD–Vlan-interface10] isis ipv6 enable 1
[SwitchD–Vlan-interface10] quit
[SwitchD] interface vlan-interface 20
[SwitchD–Vlan-interface20] isis ipv6 enable 1
[SwitchD–Vlan-interface20] quit
# Configure OSPFv3.
[SwitchD] ospfv3
[SwitchD-ospfv3-1] router-id 4.4.4.4
[SwitchD-ospfv3-1] quit
[SwitchD–Vlan-interface20] ospfv3 1 area 0
# Redistribute OSPFv3 and direct routes into IPv6 IS-IS.
[SwitchD] isis 1
[SwitchD-isis-1-ipv6] import-route ospfv3
[SwitchD-isis-1-ipv6] import-route direct
# Redistribute IPv6 IS-IS and direct routes into OSPFv3.
[SwitchD] ospfv3 1
[SwitchD-ospfv3-1] import-route isisv6 1
[SwitchD-ospfv3-1] import-route direct
Configuring Switch E
# Configure an IPv6 address for VLAN-interface 20.
<SwitchE> system-view
[SwitchE] interface vlan-interface20
[SwitchE-Vlan-interface12] ipv6 address 2001:20::2 64
[SwitchE-Vlan-interface12] quit
# Configure OSPFv3.
[SwitchE] ospfv3
[SwitchE-ospfv3-1] router-id 5.5.5.5
[SwitchE-ospfv3-1] quit
[SwitchE] interface vlan-interface 20
[SwitchE–Vlan-interface 20] ospfv3 1 area 0
[SwitchE–Vlan-interface 20] quit
[SwitchE] interface vlan-interface 300
[SwitchE–Vlan-interface 300] ospfv3 1 area 0
[SwitchE–Vlan-interface 300] quit
# Verify that the branch can reach the Marketing department, but cannot reach the Finance department.
[SwitchD] display isis route ipv6
                         Level-2 IPv6 Forwarding Table
 Destination : 2001:10::                               PrefixLen: 64
 Flag        : D/L/-                                   Cost     : 10
 Next Hop    : Direct                                  Interface: Vlan10
 Destination : 2001:1::                                PrefixLen: 64
 Flag        : R/-/-                                   Cost     : 20
 Next Hop    : FE80::7625:8AFF:FE02:4D13               Interface: Vlan10
 Destination : 2001:2::                                PrefixLen: 64
 Destination : 3001:1::                                PrefixLen: 64
 Flag        : R/-/-                                   Cost     : 30
# Verify that the company can communicate with the partner.
·     Display the IPv6 IS-IS routing table on Switch C.
[SwitchC] display isis route ipv6 level-2
 Next Hop    : Direct                                  Interface: Vlan11
 Next Hop    : Direct                                  Interface: Vlan12
 Destination : 2001:20::                               PrefixLen: 64
 Flag        : R/L/-                                   Cost     : 20
 Next Hop    : FE80::BAAF:67FF:FE30:3304               Interface: Vlan10
 Destination : 3001:200::                              PrefixLen: 64
·     Ping 3001:200::1 from Switch A.
[SwitchA] ping ipv6 –a 3001:1::1 3001:200::1
Ping6(56 data bytes) 3001:1::1 --> 3001:200::1, press CTRL+C to break
56 bytes from 3001:200::1, icmp_seq=0 hlim=63 time=7.230 ms
56 bytes from 3001:200::1, icmp_seq=1 hlim=63 time=3.449 ms
56 bytes from 3001:200::1, icmp_seq=2 hlim=63 time=2.779 ms
56 bytes from 3001:200::1, icmp_seq=3 hlim=63 time=2.652 ms
56 bytes from 3001:200::1, icmp_seq=4 hlim=63 time=2.558 ms
--- Ping6 statistics for 3001:200::1 ---
round-trip min/avg/max/std-dev = 2.558/3.734/7.230/1.776 ms
Configuration files
·     Switch A:
isis 1
 is-level level-1
 address-family ipv6 unicast
vlan 11
vlan 100
interface Vlan-interface11
 isis ipv6 enable 1
 ipv6 address 2001:1::1/64
interface Vlan-interface100
 isis ipv6 enable 1
 ipv6 address 3001:1::1/64
·     Switch B:
isis 1
 is-level level-1
vlan 12
vlan 200
interface Vlan-interface12
 isis ipv6 enable 1
 ipv6 address 2001:2::1/64
interface Vlan-interface200
 isis ipv6 enable 1
 ipv6 address 3001:2::1/64
·     Switch C:
isis 1
vlan 10 to 12
 isis ipv6 enable 1
 ipv6 address 2001:10::1/64
 isis ipv6 enable 1
 ipv6 address 2001:1::2/64
 isis ipv6 enable 1
 ipv6 address 2001:2::2/64
 ipv6 prefix-list 1 index 10 permit 3001:1:: 64
·     Switch D:
isis 1
 is-level level-2
 import-route direct
 import-route ospfv3 1
ospfv3 1
 router-id 4.4.4.4
 area 0.0.0.0
 import-route direct
vlan 10
vlan 20
 isis ipv6 enable 1
 ipv6 address 2001:10::2/64
 ospfv3 1 area 0.0.0.0
 ipv6 address 2001:20::1/64
·     Switch E:
ospfv3 1
 router-id 5.5.5.5
 area 0.0.0.0
vlan 20
vlan 300
 ospfv3 1 area 0
 ipv6 address 2001:20::2/64
interface Vlan-interface300
 ospfv3 1 area 0
 ipv6 address 3001:200::1/64
