H3C Fixed Port Campus Switches Configuration Examples-6W106
HomeSupportConfigure & DeployConfiguration ExamplesH3C Fixed Port Campus Switches Configuration Examples-6W106
Table of Contents
Related Documents
84-GRE Tunnel Access to MPLS L3VPN Configuration Examples
Introduction
In an MPLS L3VPN, a CE is typically connected to a PE directly. In some networks, a direct connection might not be available between a CE and a PE. In such scenarios, you can configure a GRE tunnel between the CE and PE to establish a virtual point-to-point link. This setup allows the CE and PE to communicate as if they were directly connected.
The following information is provided based on the assumption that you have basic knowledge MPLS L3VPN and GRE.
Example: Configuring GRE tunnel access to an MPLS L3VPN
As shown in Figure 1, Customer A and Customer B belong to VPN 1. Deploy an MPLS L3VPN to securely transmit user data between Customer A and Customer B through the VPN.
·     PE 1 and PE 2 are edge devices of the MPLS backbone network.
·     CE 1 and CE 2 are customer edge devices for VPN 1.
·     A network (VPN 2) exists between CE 1 and PE 1. CE 1 and CE 2 are able to route to each other.
Figure 1 Network diagram
Analysis
·     To transfer packets on the MPLS network, configure an IGP routing protocol on the MPLS backbone, and use LDP to distribute public network (outer) labels to VPN packets.
·     To transport VPN routes and allocate VPN (inner) labels, establish an MP-IBGP peer relationship between the PEs.
·     To establish a logical direct connection between CE 1 and PE 1, configure a GRE tunnel between them.
Hardware
Software version
S6812 switch series
S6813 switch series
Release 6615Pxx, Release 6628Pxx
S6550XE-HI switch series
Release 6008 and later, Release 8106Pxx
S6526XE-HI[EI] switch series
Release 8341P02 and later
S6510 switch series
Not supported
S6525XE-HI switch series
S5850 switch series
Not supported
S5570S-EI switch series
Not supported
S5560X-EI switch series
Release 65xx, Release 6615Pxx, Release 6628Pxx
S5560X-HI switch series
S5500V2-EI switch series
MS4520V2-30F switch
MS4520V2-30C switch
MS4520V2-54C switch
MS4520V2-28S 1 switch
MS4520V2-24TP switch
Not supported
S6520X-HI switch series
S6520X-EI switch series
S6520X-SI switch series
S6520-SI switch series
S5000-EI switch series
MS4600 switch series
ES5500 switch series
S5560S-EI switch series
S5560S-SI switch series
Not supported
S5500V3-24P-SI switch
S5500V3-48P-SI switch
Not supported
S5500V3-SI switch series (except S5500V3-24P-SI and S5500V3-48P-SI)
Not supported
S5170-EI switch series
Not supported
S5130S-HI switch series
S5130S-EI switch series
S5130S-SI switch series
S5130S-LI switch series
Not supported
S5120V2-SI switch series
S5120V2-LI switch series
Not supported
S5120V3-EI switch series
Not supported
S5120V3-36F-SI switch
S5120V3-28P-HPWR-SI switch
S5120V3-54P-PWR-SI
Not supported
S5120V3-SI switch series (except S5120V3-36F-SI, S5120V3-28P-HPWR-SI, and S5120V3-54P-PWR-SI)
Not supported
S5120V3-LI switch series
Not supported
S3600V3-EI switch series
Not supported
S3600V3-SI switch series
Not supported
S3100V3-EI switch series
S3100V3-SI switch series
Not supported
S5110V2 switch series
Not supported
S5110V2-SI switch series
Not supported
S5000V3-EI switch series
S5000V5-EI switch series
Not supported
S5000E-X switch series
S5000X-EI switch series
Not supported
E128C 1 switch
E152C switch
E500C switch series
E500D switch series
Not supported
MS4320V2 switch series
MS4320V3 switch series
MS4300V2 switch series
MS4320 switch series
MS4200 switch series
Not supported
WS5850-WiNet switch series
Not supported
WS5820-WiNet switch series
WS5810-WiNet switch series
Not supported
WAS6000 switch series
Not supported
IE4300-12P-AC switch
IE4300-12P-PWR switch
IE4300-M switch series
IE4320 switch series
Not supported
IE4520 switch series
Not supported
S5135S-EI switch series
Not supported
S5136S-EI switch series
Not supported
When an interface is bound to a VPN instance, the settings (including IP address) on the interface will be cleared. Therefore, bind an interface to a VPN instance before you configure other settings on the interface.
For the S5570S-EI, S5500V3-SI, S3600V3-EI, and S3600V3-SI switch series, before switching a Layer 2 Ethernet interface to a Layer 3 Ethernet interface or creating a Layer 3 aggregate interface, use the reserve-vlan-interface command to reserve local VLAN interface resources. For more information about the reserve-vlan-interface command, see the VLAN configuration and VLAN commands for your product.
Procedures
Configuring an IGP on the MPLS backbone
This example uses OSPF to implement IP connectivity between the PE and P devices on the MPLS backbone.
1.     Configure PE 1:
# Configure IP addresses for the loopback interface and the backbone network interfaces.
<PE1> system-view
[PE1] interface loopback 0
[PE1-LoopBack0] ip address 1.1.1.9 32
[PE1-LoopBack0] quit
[PE1] vlan 2
[PE1-vlan2] port GigabitEthernet 1/0/2
[PE1-vlan2] quit
[PE1] interface vlan-interface 2
[PE1-Vlan-interface2] ip address 10.1.1.1 24
[PE1-Vlan-interface2] quit
# Enable OSPF on the interfaces attached to the backbone network.
[PE1] ospf
[PE1-ospf-1] area 0
[PE1-ospf-1-area-0.0.0.0] network 10.1.1.0 0.0.0.255
[PE1-ospf-1-area-0.0.0.0] network 1.1.1.9 0.0.0.0
[PE1-ospf-1] quit
2.     Configure P:
<P> system-view
[P] interface loopback 0
[P-LoopBack0] ip address 2.2.2.9 32
[P-LoopBack0] quit
[P] vlan 2
[P-vlan2] port GigabitEthernet 1/0/2
[P-vlan2] quit
[P] vlan 5
[P-vlan5] port GigabitEthernet 1/0/3
[P-vlan5] quit
[P] interface vlan-interface 2
[P-Vlan-interface2] ip address 10.1.1.2 24
[P-Vlan-interface2] quit
[P] interface vlan-interface 5
[P-Vlan-interface5] ip address 10.1.4.1 24
[P-Vlan-interface5] quit
[P] ospf
[P-ospf-1] area 0
[P-ospf-1-area-0.0.0.0] network 10.1.1.0 0.0.0.255
[P-ospf-1-area-0.0.0.0] network 10.1.4.0 0.0.0.255
[P-ospf-1-area-0.0.0.0] network 2.2.2.9 0.0.0.0
[P-ospf-1-area-0.0.0.0] quit
[P-ospf-1] quit
3.      Configure PE 2:
<PE2> system-view
[PE2] interface loopback 0
[PE2-LoopBack0] ip address 3.3.3.9 32
[PE2-LoopBack0] quit
[PE2] vlan 5
[PE2-vlan5] port GigabitEthernet 1/0/1
[PE2-vlan5] quit
[PE2] interface vlan-interface 5
[PE2-Vlan-interface5] ip address 10.1.4.2 24
[PE2-Vlan-interface5] quit
[PE2] ospf
[PE2-ospf-1] area 0
[PE2-ospf-1-area-0.0.0.0] network 10.1.4.0 0.0.0.255
[PE2-ospf-1-area-0.0.0.0] network 3.3.3.9 0.0.0.0
[PE2-ospf-1] quit
After the configuration is completed, PE 1, P, and PE 2 can establish OSPF neighbor relationships. Execute the display ospf peer command to verify that the neighbors are in full state. Execute the display ip routing-table command to verify that the PEs have learned the routes to the loopback interfaces of each other.
Use PE 1 as an example:
[PE1] display ospf peer verbose
          OSPF Process 1 with Router ID 1.1.1.9
                  Neighbors
 Area 0.0.0.0 interface 10.1.1.1(Vlan-interface2)'s neighbors
 Router ID: 2.2.2.9          Address: 10.1.1.2        GR State: Normal
   State: Full  Mode: Nbr is Master  Priority: 1
   DR: 10.1.1.2  BDR: 10.1.1.1  MTU: 0
   Dead timer due in 38  sec
   Neighbor is up for 17:30:25
   BFD status: Disabled
[PE1] display ip routing-table protocol ospf
Summary Count : 5
Summary Count : 3
Destination/Mask    Proto  Pre  Cost         NextHop         Interface
2.2.2.9/32          OSPF   10   1            10.1.1.2        Vlan2
3.3.3.9/32          OSPF   10   2            10.1.1.2        Vlan2
10.1.4.0/24         OSPF   10   2            10.1.1.2        Vlan2
Summary Count : 2
1.1.1.9/32          OSPF   10   0            1.1.1.9         Loop0
10.1.1.0/24         OSPF   10   1            10.1.1.1        Vlan2
Configuring basic MPLS and MPLS LDP on the MPLS backbone to establish LDP LSPs
1.     Configure PE 1:
[PE1] mpls lsr-id 1.1.1.9
[PE1] mpls ldp
[PE1-ldp] quit
[PE1-Vlan-interface2] mpls enable
[PE1-Vlan-interface2] mpls ldp enable
2.     Configure P:
[P] mpls lsr-id 2.2.2.9
[P] mpls ldp
[P-ldp] quit
[P-Vlan-interface2] mpls enable
[P-Vlan-interface2] mpls ldp enable
[P-Vlan-interface5] mpls enable
[P-Vlan-interface5] mpls ldp enable
3.     Configure PE 2:
[PE2] mpls lsr-id 3.3.3.9
[PE2] mpls ldp
[PE2-ldp] quit
[PE2-Vlan-interface5] mpls enable
[PE2-Vlan-interface5] mpls ldp enable
Execute the display mpls ldp peer command to verify that LDP sessions in Operational state have been established between PE 1, P, and PE 2. Execute the display mpls ldp lsp command to verify that the LSPs have been established by LDP.
Use PE1 as an example.
[PE1] display mpls ldp peer
Total number of peers: 1
Peer LDP ID             State         Role     GR   MD5  KA Sent/Rcvd
2.2.2.9:0               Operational   Passive  Off  Off  5/5
[PE1] display mpls ldp lsp
Status Flags: * - stale, L - liberal, B - backup
FECs: 4            Ingress: 1          Transit: 1      Egress: 3
FEC                In/Out Label        Nexthop         OutInterface
1.1.1.9/32         3/-
                   -/1151(L)
2.2.2.9/32         -/3                 10.1.1.2        Vlan2
                   1151/3              10.1.1.2        Vlan2
3.3.3.9/32         -/1150              10.1.1.2        Vlan2
                   1150/1150           10.1.1.2        Vlan2
Configuring VPN instances on PE 1 and CE 1 and establishing a GRE tunnel to connect CE 1 to PE 1
1.     Configure PE 1:
# Create a VPN instance named vpn1 on PE 1.
[PE1] ip vpn-instance vpn1
# Configure the RD of the VPN instance as 100:1.
[PE1-vpn-instance-vpn1] route-distinguisher 100:1
# Configure route targets for the VPN instance.
[PE1-vpn-instance-vpn1] vpn-target 100:1 import-extcommunity
[PE1-vpn-instance-vpn1] vpn-target 100:1 export-extcommunity
[PE1-vpn-instance-vpn1] quit
# Bind VLAN-interface 100 to the VPN instance.
[PE1] vlan 100
[PE1-vlan100] port GigabitEthernet 1/0/1
[PE1-vlan100] quit
[PE1] interface vlan-interface 100
[PE1-Vlan-interface100] ip binding vpn-instance vpn1
[PE1-Vlan-interface100] ip address 200.1.1.2 24
[PE1-Vlan-interface100] quit
2.     Configure CE 1:
# Create a VPN instance named vpn1 on CE 1.
[CE1] ip vpn-instance vpn1
[CE1-vpn-instance-vpn1] route-distinguisher 100:1
[CE1-vpn-instance-vpn1] vpn-target 100:1 import-extcommunity
[CE1-vpn-instance-vpn1] vpn-target 100:1 export-extcommunity
[CE1-vpn-instance-vpn1] quit
# Bind VLAN-interface 101 to the VPN instance.
[CE1] vlan 101
[CE1-vlan101] port GigabitEthernet 1/0/1
[CE1-vlan101] quit
[CE1] interface vlan-interface 101
[CE1-Vlan-interface101] ip binding vpn-instance vpn1
[CE1-Vlan-interface101] ip address 100.1.1.1 24
[CE1-Vlan-interface101] quit
Configuring a GRE tunnel between CE 1 and PE 1
1.     Configure CE 1:
# Create service loopback group 1 and configure the service type as tunnel. Assign interface GigabitEthernet 1/0/3 to service loopback group 1. (For the S6550XE-HI, S6525XE-HI, and S5850 switch series, you must create a tunnel-type service loopback group to enable the reception and transmission of tunnel packets.)
[CE1] service-loopback group 1 type tunnel
# Assign interface GigabitEthernet 1/0/3 to service loopback group 1.
[CE1] interface GigabitEthernet 1/0/3
[CE1-GigabitEthernet1/0/3] port service-loopback group 1
[CE1-GigabitEthernet1/0/3] quit
# Create tunnel interface Tunnel 0, and specify the tunnel mode as GRE/IPv4.
[CE1] interface tunnel 0 mode gre
# Specify a VPN instance for the tunnel source address.
[CE1-Tunnel0] ip binding vpn-instance vpn1
# Assign an IP address to interface Tunnel 0.
[CE1-Tunnel0] ip address 20.1.1.1 255.255.255.0
# Configure the tunnel source address as the IP address of VLAN-interface 101 on CE 1.
[CE1-Tunnel0] source vlan-interface 101
# Configure the tunnel destination address as the IP address of VLAN-interface 100 on PE 1.
[CE1-Tunnel0] destination 200.1.1.2
# Specify a VPN instance for the tunnel destination address.
[CE1-Tunnel0] tunnel vpn-instance vpn1
[CE1-Tunnel0] quit
# Configure a static route for Customer A to reach Customer B via Tunnel 0.
[CE1] ip route-static vpn-instance vpn1 172.2.0.0 24 tunnel 0
2.     Configure PE 1:
[PE1] service-loopback group 1 type tunnel
[PE1] interface GigabitEthernet 1/0/3
[PE1-GigabitEthernet1/0/3] port service-loopback group 1
[PE1-GigabitEthernet1/0/3] quit
[PE1] interface tunnel 0 mode gre
[PE1-Tunnel0] ip binding vpn-instance vpn1
[PE1-Tunnel0] ip address 20.1.1.2 255.255.255.0
# Configure the tunnel source address as the IP address of VLAN-interface 100 on PE 1.
[PE1-Tunnel0] source vlan-interface 100
# Configure the tunnel destination address as the IP address of VLAN-interface 101 on CE 1.
[PE1-Tunnel0] destination 100.1.1.1
[PE1-Tunnel0] tunnel vpn-instance vpn1
[PE1-Tunnel0] quit
# Configure a static route for Customer B to reach Customer A via Tunnel 0.
[PE1] ip route-static vpn-instance vpn1 172.1.0.0 24 Tunnel 0
Configuring a VPN instance on PE 2 to allow CE 2 access to PE 2
1.     Configure PE 2:
# Create a VPN instance named vpn1 on PE 2.
[PE2] ip vpn-instance vpn1
# Configure an RD of the VPN instance.
[PE2-vpn-instance-vpn1] route-distinguisher 100:1
# Configure the import target and export target for the VPN instance, which must be the same as the export target and import target on PE 1.
[PE2-vpn-instance-vpn1] vpn-target 100:1 import-extcommunity
[PE2-vpn-instance-vpn1] vpn-target 100:1 export-extcommunity
[PE2-vpn-instance-vpn1] quit
[PE2] vlan 101
[PE2-vlan101] port GigabitEthernet 1/0/2
[PE2-vlan101] quit
[PE2] interface vlan-interface 101
[PE2-Vlan-interface101] ip binding vpn-instance vpn1
[PE2-Vlan-interface101] ip address 101.1.1.1 24
[PE2-Vlan-interface101] quit
2.     Configure CE 2:
Configure IP addresses for interfaces on CE 2 as shown in Figure 1. (Details not shown.)
After the configuration is completed, execute the display ip vpn-instance command on PE 2 to view the VPN instance configuration. PE 2 can ping the connected CE 2.
[PE2] display ip vpn-instance
  VPN-Instance Name               RD                     Create time
  vpn1                            100:1                  2016/06/22 13:20:08
[PE2] ping -vpn-instance vpn1 101.1.1.2
Ping 10.1.4.2 (101.1.1.2): 56 data bytes, press CTRL_C to break
56 bytes from 101.1.1.2: icmp_seq=0 ttl=255 time=1.000 ms
56 bytes from 101.1.1.2: icmp_seq=1 ttl=255 time=2.000 ms
56 bytes from 101.1.1.2: icmp_seq=2 ttl=255 time=0.000 ms
56 bytes from 101.1.1.2: icmp_seq=3 ttl=255 time=1.000 ms
56 bytes from 101.1.1.2: icmp_seq=4 ttl=255 time=0.000 ms
--- Ping statistics for 10.1.1.1 ---
round-trip min/avg/max/std-dev = 0.000/0.800/2.000/0.748 ms
Establishing EBGP peers between PEs and CEs to redistributing VPN routes
1.     Configure PE 1:
# Create BGP process 100 on PE 1.
[PE1] bgp 100
# Specify CE 1 as the peer. Redistribute the direct routes in the routing table of PE 1 into the routing table of the BGP-VPN instance.
[PE1-bgp-default-vpn1] peer 20.1.1.1 as-number 65410
[PE1-bgp-default-ipv4-vpn1] peer 20.1.1.1 enable
[PE1-bgp-default-ipv4-vpn1] import-route direct
[PE1-bgp-default-vpn1] quit
2.     Configure PE 2:
# Create BGP process 100 on PE 2.
[PE2] bgp 100
# Specify CE 2 as the peer. Redistribute the direct routes in the routing table of PE 2 into the routing table of the BGP-VPN instance.
[PE2-bgp-default-vpn1] peer 101.1.1.2 as-number 65410
[PE2-bgp-default-ipv4-vpn1] peer 101.1.1.2 enable
[PE2-bgp-default-ipv4-vpn1] import-route direct
[PE2-bgp-default-vpn1] quit
3.     Configure CE 1:
# Create BGP process 65410 on CE 1. Specify PE 1 as the peer with AS number 100.
<CE1> system-view
[CE1] bgp 65410
[CE1-bgp-default] peer 20.1.1.2 as-number 100
# Enable CE 1 to exchange IPv4 unicast routing information with peer 20.1.1.2.
[CE1-bgp-default-ipv4] peer 20.1.1.2 enable
# Redistribute the direct routes of CE 1 into EBGP.
[CE1-bgp-default-ipv4] quit
[CE1-bgp-default] quit
4.     Configure CE 2:
# Create BGP process 65410 on CE 2. Specify PE 2 as the peer with AS number 100.
<CE2> system-view
[CE2] bgp 65410
[CE2-bgp-default] peer 101.1.1.1 as-number 100
# Enable CE 2 to exchange IPv4 unicast routing information with peer 101.1.1.1.
[CE2-bgp-default-ipv4] peer 101.1.1.1 enable
# Redistribute the direct routes of CE 2 into EBGP.
[CE2-bgp-default-ipv4] import-route direct
[CE2-bgp-default-ipv4] quit
[CE2-bgp-default] quit
Execute the display bgp peer ipv4 vpn-instance command on PE 2 to verify that PE 2 has a BGP peer in Established state with CE 2.
[PE2] display bgp peer ipv4 vpn-instance vpn1
 BGP local router ID: 3.3.3.9
 Local AS number: 100
 Total number of peers: 1                  Peers in established state: 1
  Peer                  AS          MsgRcvd  MsgSent OutQ PrefRcv Up/Down  State
  101.1.1.2             65430        4        4    0       2 13:35:25      Established
Establishing MP-IBGP peers between PEs
1.     Configure PE 1:
# On PE 1, specify PE 2 as the BGP peer, and specify Loopback 0 as the source interface for TCP connections to the peer.
[PE1] bgp 100
# Enter BGP VPNv4 address family view, and specify PE 2 as the peer.
[PE1-bgp-default-vpnv4] quit
[PE1-bgp-default] quit
2.     Configure PE 2:
# On PE 2, specify PE 1 as the BGP peer, and specify Loopback 0 as the source interface for TCP connections to the peer.
[PE2] bgp 100
[PE2-bgp-default] peer 1.1.1.9 as-number 100
[PE2-bgp-default] peer 1.1.1.9 connect-interface loopback 0
# Enter BGP VPNv4 address family view, and specify PE 1 as the peer.
[PE2-bgp-default-vpnv4] peer 1.1.1.9 enable
[PE2-bgp-default-vpnv4] quit
[PE2-bgp-default] quit
# Execute the display bgp peer vpnv4 command to verify that the PEs have BGP peers in Established state with each other.
[PE1] display bgp peer vpnv4
 BGP local router ID: 1.1.1.9
  3.3.3.9                100        8        8    0       0 00:00:08 Established
# Execute the display ip routing-table vpn-instance command on a PE to view the route destined to the peer CE.
Use VPN instance vpn1 on PE 1 as an example:
[PE1] display ip routing-table vpn-instance vpn1
Destinations : 13        Routes : 13
0.0.0.0/32          Direct 0    0            127.0.0.1       InLoop0
20.1.1.0/24         Direct  0   0            20.1.1.2        Tun0
20.1.1.0/32         Direct  0   0            20.1.1.2        Tun0
20.1.1.2/32         Direct  0   0            127.0.0.1       InLoop0
200.1.1.0/24        Direct 0    0            200.1.1.2       Vlan100
200.1.1.0/32        Direct 0    0            200.1.1.2       Vlan100
200.1.1.2/32        Direct 0    0            127.0.0.1       InLoop0
200.1.1.255/32      Direct 0    0            100.1.1.2       Vlan100
101.1.1.0/24        BGP    255  0            3.3.3.9         Vlan2
127.0.0.1/32        Direct 0    0            127.0.0.1       InLoop0
224.0.0.0/4         Direct 0    0            0.0.0.0         NULL0
224.0.0.0/24        Direct 0    0            0.0.0.0         NULL0
255.255.255.255/32  Direct 0    0            127.0.0.1       InLoop0
Configuration files
·     PE 1
ospf 1
 area 0.0.0.0
 mpls lsr-id 1.1.1.9
vlan 2
vlan 100
mpls ldp
interface LoopBack0
 ip address 1.1.1.9 255.255.255.255
interface Vlan-interface2
 mpls enable
 mpls ldp enable
interface Vlan-interface100
 ip address 200.1.1.2 255.255.255.0
 port link-mode bridge
 port access vlan 100
 port access vlan 2
interface Tunnel0 mode gre
 source Vlan-interface100
bgp 100
 peer 3.3.3.9 connect-interface LoopBack0
  peer 3.3.3.9 enable
   import-route direct
 ip route-static vpn-instance vpn1 172.1.0.0 24 Tunnel0
·     P
ospf 1
 area 0.0.0.0
 mpls lsr-id 2.2.2.9
vlan 2
vlan 5
mpls ldp
interface LoopBack0
 ip address 2.2.2.9 255.255.255.255
 mpls enable
 mpls ldp enable
interface Vlan-interface5
 ip address 10.1.4.1 255.255.255.0
 mpls enable
 mpls ldp enable
 port access vlan 2
 port access vlan 5
·     PE 2
ospf 1
 area 0.0.0.0
 mpls lsr-id 3.3.3.9
 lldp global enable
vlan 5
vlan 101
mpls ldp
interface LoopBack0
 ip address 3.3.3.9 255.255.255.255
 ip address 10.1.4.2 255.255.255.0
 mpls enable
 mpls ldp enable
interface Vlan-interface101
 ip address 101.1.1.1 255.255.255.0
 port access vlan 5
 port access vlan 101
bgp 100
 peer 1.1.1.9 connect-interface LoopBack0
  peer 1.1.1.9 enable
   import-route direct
·     CE 1
vlan 101
 ip address 100.1.1.1 255.255.255.0
 source Vlan-interface101
bgp 65410
  import-route direct
 ip route-static vpn-instance vpn1 172.2.0.0 24 Tunnel0
·     CE 2
vlan 101
 ip address 101.1.1.2 255.255.255.0
bgp 65410
  import-route direct
