H3C Fixed Port Campus Switches Configuration Examples-6W106
HomeSupportConfigure & DeployConfiguration ExamplesH3C Fixed Port Campus Switches Configuration Examples-6W106
Table of Contents
Related Documents
83-EAA Configuration Examples
83-EAA Configuration Examples 167.80 KB
Introduction
This document describes typical configurations for EAA.
This document assumes you are familiar with EAA features. For the same requirement, the implementation effects of TCL and CLI monitoring strategies are consistent. You can choose either strategy based on preference.
Example: Configuring an EAA TCL monitoring policy
Configure a TCL monitoring policy for the device to execute the following actions when the incoming traffic on Ten-GigabitEthernet1/0/1 reaches or exceeds 500 Mbps:
·     Generate logs for traffic that exceeds the range.
·     Display the current CPU state and save it to a file.
·     Display the state of Ten-GigabitEthernet1/0/1 and save it to a file.
If the subsequent incoming traffic reaches or exceeds 200Mbps, monitoring will restart. When the incoming traffic on the interface is detected to exceed 500Mbps again, the aforementioned operations are executed again.
Table 1 Applicable hardware and software versions
Product
Software version
S6812 series
S6813 series
Release 6628Pxx
S6550XE-HI series
Release 8106Pxx
S6526XE-HI[EI] switch series
Release 8341P02 and later
S6510 switch series
S6525XE-HI series
Release 8106Pxx
S5850 series
Release 8106Pxx
S5570S-EI series
Release 11xx
S5560X-EI series
Release 6628Pxx
S5560X-HI series
Release 6628Pxx
S5500V2-EI series
Release 6628Pxx
MS4520V2-30F
Release 6628Pxx
MS4520V2-30C
MS4520V2-54C
Release 6628Pxx
MS4520V2-28S
MS4520V2-24TP
Release 63xx
S6520X-HI series
S6520X-EI series
Release 6628Pxx
S6520X-SI series
S6520-SI series
Release 6628Pxx
S5000-EI series
Release 6628Pxx
MS4600 series
Release 6628Pxx
ES5500 series
Release 6628Pxx
S5560S-EI series
S5560S-SI series
Release 63xx
S5500V3-24P-SI
S5500V3-48P-SI
Release 63xx
S5500V3-SI series (excluding S5500V3-24P-SI and S5500V3-48P-SI)
Release 11xx
S5170-EI series
Release 11xx
S5130S-HI series
S5130S-EI series
S5130S-SI series
S5130S-LI series
Release 63xx
S5120V2-SI series
S5120V2-LI series
Release 63xx
S5120V3-EI series
Release 11xx
S5120V3-36F-SI
S5120V3-28P-HPWR-SI
S5120V3-54P-PWR-SI
Release 11xx
S5120V3-SI series (excluding S5120V3-36F-SI, S5120V3-28P-HPWR-SI, and S5120V3-54P-PWR-SI)
Release 63xx
S5120V3-LI series
Release 63xx
S3600V3-EI series
Release 11xx
S3600V3-SI series
Release 11xx
S3100V3-EI series
S3100V3-SI series
Release 63xx
S5110V2 series
Release 63xx
S5110V2-SI series
Release 63xx
S5000V3-EI series
S5000V5-EI series
Release 63xx
S5000E-X series
S5000X-EI series
Release 63xx
E128C
E152C
E500C series
E500D series
Release 63xx
MS4320V2 series
MS4320V3 series
MS4300V2 series
MS4320 series
MS4200 series
Release 63xx
WS5850-WiNet series
Release 63xx
WS5820-WiNet series
WS5810-WiNet series
Release 63xx
WAS6000 series
Release 63xx
IE4300-12P-AC & IE4300-12P-PWR
IE4300-M series
IE4320 series
Release 63xx
IE4520 series
IE4520 series
S5135S-EI series
Release 6810 and later
S5136S-EI switch series
Release 6817 and later
Procedures
Editing the TCL script
# Use Notepad to edit the test.tcl file as follows:
# Define the monitored event. Configure interface Ten-GigabitEthernet1/0/1 to focus on inbound traffic. When the inbound traffic reaches or exceeds 500 Mbps, configure the device to execute the specified action. The condition to re-enable polling is when the interface traffic reaches or exceeds 200Mbps.
::comware::rtm::event_register interface ten-gigabitethernet1/0/1 monitor-obj rcv-bps start-op ge start-val 500000000 restart-op ge restart-val 200000000 user-role network-admin
# Configure the action to take when the monitored event occurs: Send log message XGE1/0/1 input rate exceeded 500000000bps with priority level 1 and device number local1.
::comware::rtm::action syslog priority 1 facility local1 msg "XGE1/0/1 input rate exceeded 500000000bps"
# Create the execution action for the monitored event.
::comware::create-cli
# Configure the device to execute the display cpu-usage command to display CPU usage statistics and save the information in XGE0_info.txt when the event occurs.
::comware::write-cli cli0 "display cpu-usage >> XGE0_info.txt"
# Configure the device to execute the display interface ten-gigabitetherne 1/0/1 command to display the current operating state and related information of Ten-GigabitEthernet1/0/1 and save the information in XGE0_info.txt when the event occurs.
::comware::write-cli cli0 "display interface ten-gigabitethernet1/0/1 >> XGE0_info.txt"
::comware::write-cli cli0 "end"
Configuring the device
# Configure the IP address of Ten-GigabitEthernet1/0/1.
[Device-Ten-GigabitEthernet1/0/1] port link-mode route
[Device-Ten-GigabitEthernet1/0/1] ip address 192.168.100.66 255.255.255.0
[Device] quit
# Download test.tcl to the device through TFTP.
<Device> tftp 192.168.100.14 get test.tcl
  % Total    % Received % Xferd  Average Speed   Time    Time     Time  Current
                                 Dload  Upload   Total   Spent    Left  Speed
100   189  100   189    0     0   7900      0 --:--:-- --:--:-- --:--:-- 12600
# Create and enable a TCL monitoring policy, and bind the policy to TCL script test.tcl.
[Device] rtm tcl-policy test test.tcl
[Device] quit
# Use the display rtm policy registered command to view the policy named test with the type Tcl.
<Device> display rtm policy registered
Total number: 1
Type  Event      TimeRegistered        PolicyName
TCL   INTERFACE  May 05 06:46:20 2019  test
# When the inbound traffic on interface Ten-GigabitEthernet1/0/1 reaches or exceeds 500 Mbps, check all files and folder information in the device for the existence of XGE0_info.txt.
<Device> dir
Directory of cfa0:
   0 -rw-        3227 Nov 19 2019 17:28:36   1.cfg
   1 -rw-        2296 Apr 26 2019 18:55:08   5660_data.ak
   2 -rw-        2304 Apr 26 2019 18:54:56   5660_security.ak
   3 -rw-        2298 Apr 26 2019 18:55:16   5660_voice.ak
   4 -rw-        3227 Nov 19 2019 17:15:19   STARTUP110.CFG
   5 drw-           - Mar 10 2019 04:10:10   diagfile
   6 -rw-         567 Jul 17 2019 14:25:00   dsakey
   7 -rw-         223 Jul 17 2019 14:25:00   ecdsakey
   8 -rw-         278 Jul 17 2019 14:25:00   XGE0_info.txt
   9 -rw-         735 Jul 17 2019 14:25:00   hostkey
  10 -rw-         492 Nov 18 2019 16:40:50   ifindex.dat
  11 -rw-         276 Apr 23 2019 19:00:00   lauth.dat
  12 drw-           - Jul 17 2019 11:26:34   license
  13 drw-           - Apr 24 2019 12:39:38   logfile
  14 -rw-    18839552 Nov 14 2019 16:42:12   msr56-cmw710-boot-r000706.bin
  15 -rw-     1150976 Nov 14 2019 16:43:00   msr56-cmw710-data-r000706.bin
  16 -rw-    47470592 Nov 14 2019 16:42:24   msr56-cmw710-system-r000706.bin
  17 -rw-     2975744 Nov 14 2019 16:42:56   msr56-cmw710-voice-r000706.bin
  18 -rw-    70445056 Nov 14 2019 17:41:08   msr56.ipe
  19 -rw-    70445056 Nov 14 2019 16:40:00   msr56NN.ipe
  20 drw-           - Aug 21 2019 16:23:10   pkey
  21 -rw-         189 Nov 19 2019 17:49:34   test.tcl
  22 drw-           - Mar 10 2019 04:10:10   seclog
  23 -rw-         591 Jul 17 2019 14:25:00   serverkey
  24 -rw-        3227 Nov 18 2019 16:40:50   startup.cfg
507492 KB total (298412 KB free)
# Use the TFTP method to copy file XGE0_info.txt to the TFTP server.
<Device> tftp 192.168.100.14 put XGE0_info.txt
# View file XGE0_info.txt to display the current state of the CPU and interface Ten-GigabitEthernet1/0/1.
Unit CPU usage:
      15% in last 5 seconds
      14% in last 1 minute
      13% in last 5 minutes
Current state: UP
Line protocol state: UP
Description:  Ten-GigabitEthernet1/0/1 Interface
Bandwidth: 1000000 kbps
Allow jumbo frames to pass
Broadcast max-ratio: 100%
Multicast max-ratio: 100%
Unicast max-ratio: 100%
Internet address: 192.168.100.66/24 (primary)
IP packet frame type: Ethernet II, hardware address: 5cdd-7000-a07c
IPv6 packet frame type: Ethernet II, hardware address: 5cdd-7000-a07c
Loopback is not set
Media type is twisted pair, port hardware type is 1000_BASE_T
Port priority: 0
1000Mbps-speed mode, Full-duplex mode
Flow-control is not enabled
Maximum frame length: 9216
Last link flapping: 0 hours 0 minutes 14 seconds
 Peak input rate: 4 bytes/sec, at 2019-09-21 15:09:37
 Peak output rate: 1 bytes/sec, at 2019-09-21 15:09:37
 Last 300 seconds input rate: 568710000.25 bytes/sec, 64970 bits/sec, 4.96 packets/sec
 Last 300 seconds output rate: 568710000.25 bytes/sec, 64970 bits/sec, 4.96 packets/sec Input (total):  1703 packets, 2336882000 bytes
          0 unicasts, 0 broadcasts, 4 multicasts, 0 pauses
 Input (normal):  1703 packets, - bytes
          0 CRC, 0 frame, - overruns, 0 aborts
          - ignored, - parity errors
 Output (total): 1706 packets,  2337062000 bytes
          0 unicasts, 5 broadcasts, 0 multicasts, 0 pauses
 Output (normal): 1706 packets, - bytes
          0 lost carrier, - no carrier
Configuration files
·     Script text for test.tcl:
·     Device:
Example: Configuring an EAA CLI monitoring policy
Configure a CLI monitoring policy for the device to execute the following actions when the incoming traffic on Ten-GigabitEthernet1/0/1 reaches or exceeds 500 Mbps:
Table 2 Applicable hardware and software versions
Product
Software version
S6812 series
S6813 series
Release 6628Pxx
S6550XE-HI series
Release 8106Pxx
S6510 switch series
S6525XE-HI series
Release 8106Pxx
S5850 series
Release 8106Pxx
S5570S-EI series
Release 11xx
S5560X-EI series
Release 6628Pxx
S5560X-HI series
Release 6628Pxx
S5500V2-EI series
Release 6628Pxx
MS4520V2-30F
Release 6628Pxx
MS4520V2-30C
MS4520V2-54C
Release 6628Pxx
MS4520V2-28S
MS4520V2-24TP
Release 63xx
S6520X-HI series
S6520X-EI series
Release 6628Pxx
S6520X-SI series
S6520-SI series
Release 6628Pxx
S5000-EI series
Release 6628Pxx
MS4600 series
Release 6628Pxx
ES5500 series
Release 6628Pxx
S5560S-EI series
S5560S-SI series
Release 63xx
S5500V3-24P-SI
S5500V3-48P-SI
Release 63xx
Release 11xx
S5170-EI series
Release 11xx
S5130S-HI series
S5130S-EI series
S5130S-SI series
S5130S-LI series
Release 63xx
S5120V2-SI series
S5120V2-LI series
Release 63xx
S5120V3-EI series
Release 11xx
S5120V3-36F-SI
S5120V3-28P-HPWR-SI
S5120V3-54P-PWR-SI
Release 11xx
Release 63xx
S5120V3-LI series
Release 63xx
S3600V3-EI series
Release 11xx
S3600V3-SI series
Release 11xx
S3100V3-EI series
S3100V3-SI series
Release 63xx
S5110V2 series
Release 63xx
S5110V2-SI series
Release 63xx
S5000V3-EI series
S5000V5-EI series
Release 63xx
S5000E-X series
S5000X-EI series
Release 63xx
E128C
E152C
E500C series
E500D series
Release 63xx
MS4320V2 series
MS4320V3 series
MS4300V2 series
MS4320 series
MS4200 series
Release 63xx
WS5850-WiNet series
Release 63xx
WS5820-WiNet series
WS5810-WiNet series
Release 63xx
WAS6000 series
Release 63xx
IE4300-M series
IE4320 series
Release 63xx
IE4520 series
IE4520 series
S5135S-EI series
·     For a policy, you can configure only one trigger event and one running time. When you repeatedly execute the event or running-time commands, the most recently configured and committed changes take effect.
·     If the number of the newly configured action matches an existing action number, execute the commit command for the most recent configuration to take effect.
·     After configuring the event, action, user role, and running time for the CLI monitoring policy, you must execute the commit command to enable the policy and activate its configurations.
Procedures
# Create CLI policy 1.
[Device] rtm cli-policy 1
# Configure the monitored event. Configure the device to execute the specified action when the inbound traffic on interface Ten-GigabitEthernet1/0/1 reaches or exceeds 500 Mbps. The condition to re-enable polling is when the interface traffic reaches or exceeds 200Mbps.
[Device-rtm-1] event interface ten-gigabitethernet 1/0/1 monitor-obj rcv-bps start-op ge start-val 500000000 restart-op ge restart-val 200000000
# Configure the action to take when the monitored event occurs: Send log message XGE1/0/1 input rate exceeded 500000000bps with priority level 1 and log recording tool local1.
[Device-rtm-1] action 1 syslog priority 1 facility local1 msg "XGE1/0/1 input rate exceeded 500000000bps"
[Device-rtm-1] action 2 cli display cpu-usage >> XGE0_info.txt
[Device-rtm-1] action 3 cli display interface ten-gigabitethernet 1/0/1 >> XGE0_info.txt
# Set the policy running time to 30 seconds.
[Device-rtm-1] running-time 30
# Specify user role network-admin for the execution of CLI monitoring policy 1.
[Device-rtm-1] user-role network-admin
# Enable CLI monitoring policy 1.
[Device-rtm-1] commit
[Device-rtm-1] quit
# Use the display rtm policy registered command to view policy 1 with the type CLI.
Total number: 1
CLI   INTERFACE  May 04 00:12:40 2019  1
<Device> dir
Directory of cfa0:
Unit CPU usage:
Current state: UP
Loopback is not set
Port priority: 0
Configuration files
rtm cli-policy 1
 event interface Ten-GigabitEthernet1/0/1 monitor-obj rcv-bps start-op ge start-val 500000000 restart-op ge restart-val 200000000
 running-time 30
Example: Configuring EAA and track entry association
Device A has established BGP sessions with Device D and Device E. Normally, traffic from Device D and Device E to the Internet is forwarded through Device A. Configure EAA and track entry association to achieve the following: When the state of interface Ten-GigabitEthernet1/0/1 connecting Device A to Device C changes to Down, Device A automatically detects the port down event and blocks BGP sessions with Device D and Device E. Consequently, traffic from Device D and Device E to the external network can be rerouted through Device B.
Figure 1 Network diagram
Table 3 Applicable hardware and software versions
Product
Software version
S6812 series
S6813 series
Release 6628Pxx
S6550XE-HI series
Release 8106Pxx
S6510 switch series
S6525XE-HI series
Release 8106Pxx
S5850 series
Release 8106Pxx
S5570S-EI series
Release 11xx
S5560X-EI series
Release 6628Pxx
S5560X-HI series
Release 6628Pxx
S5500V2-EI series
Release 6628Pxx
MS4520V2-30F
Release 6628Pxx
MS4520V2-30C
MS4520V2-54C
Release 6628Pxx
MS4520V2-28S
MS4520V2-24TP
Release 63xx
S6520X-HI series
S6520X-EI series
Release 6628Pxx
S6520X-SI series
S6520-SI series
Release 6628Pxx
S5000-EI series
Release 6628Pxx
MS4600 series
Release 6628Pxx
ES5500 series
Release 6628Pxx
S5560S-EI series
S5560S-SI series
Release 63xx
S5500V3-24P-SI
S5500V3-48P-SI
Release 63xx
Release 11xx
S5170-EI series
Release 11xx
S5130S-HI series
S5130S-EI series
S5130S-SI series
S5130S-LI series
Release 63xx
S5120V2-SI series
S5120V2-LI series
Release 63xx
S5120V3-EI series
Release 11xx
S5120V3-36F-SI
S5120V3-28P-HPWR-SI
S5120V3-54P-PWR-SI
Release 11xx
Release 63xx
S5120V3-LI series
Release 63xx
S3600V3-EI series
Release 11xx
S3600V3-SI series
Release 11xx
S3100V3-EI series
S3100V3-SI series
Release 63xx
S5110V2 series
Release 63xx
S5110V2-SI series
Release 63xx
S5000V3-EI series
S5000V5-EI series
Release 63xx
S5000E-X series
S5000X-EI series
Release 63xx
E128C
E152C
E500C series
E500D series
Release 63xx
MS4320V2 series
MS4320V3 series
MS4300V2 series
MS4320 series
MS4200 series
Release 63xx
WS5850-WiNet series
Release 63xx
WS5820-WiNet series
WS5810-WiNet series
Release 63xx
WAS6000 series
Release 63xx
IE4300-M series
IE4320 series
Release 63xx
IE4520 series
IE4520 series
S5135S-EI series
Procedures
# View the current state and statistics of the BGP peers.
<DeviceA> display bgp peer ipv4
 BGP local router ID: 1.1.1.1
 Local AS number: 100
 Total number of peers: 3                  Peers in established state: 3
  * - Dynamically created peer
  Peer                    AS  MsgRcvd  MsgSent OutQ PrefRcv Up/Down  State
  10.2.1.2                200       13       16    0       0 00:16:12 Established
  10.3.1.2                300       13       16    0       0 00:10:34 Established
  10.3.2.2                300       13       16    0       0 00:10:38 Established
# Configure a track item to monitor the state of Ten-GigabitEthernet1/0/1.
[DeviceA] track 1 interface ten-gigabitethernet 1/0/1
# Configure a TCL monitoring policy for Device A to automatically detect Ten-GigabitEthernet1/0/1 down events and prevent BGP sessions from being established with Device D and Device E.
[DeviceA] rtm cli-policy test
[DeviceA-rtm-test] event track 1 state negative
[DeviceA-rtm-test] action 0 cli system-view
[DeviceA-rtm-test] action 1 cli bgp 100
[DeviceA-rtm-test] action 2 cli peer 10.3.1.2 ignore
[DeviceA-rtm-test] action 3 cli peer 10.3.2.2 ignore
[DeviceA-rtm-test] user-role network-admin
[DeviceA-rtm-test] commit
[DeviceA-rtm-test] quit
# Disable Ten-GigabitEthernet1/0/1.
[DeviceA-Ten-GigabitEthernet1/0/1] shutdown
# View the state and statistics of BGP peers. Verify that the number of BGP peers is 0.
 Total number of peers: 0                  Peers in established state: 0
Configuration files
rtm cli-policy test
 user-role network-operator
