H3C WX6103 Access Controller Switch Interface Board Configuration Guide-6W102
HomeSupportWirelessWX6000 Series Access ControllersConfigure & DeployConfiguration GuidesH3C WX6103 Access Controller Switch Interface Board Configuration Guide-6W102
15-LLDP Configuration
15-LLDP Configuration 119.51 KB
When configuring LLDP, go to these sections for information you are interested in:
l          LLDP Configuration Tasks List
l          Performing Basic LLDP Configuration
l          Configuring LLDP Trap
l          Displaying and Maintaining LLDP
l          LLDP Configuration Example
The term switch in this document refers to a switch in a generic sense or an access controller configured with the switching function unless otherwise specified.
Introduction to LLDP
Overview
Link Layer Discovery Protocol (LLDP) operates on data link layer. It stores and maintains the information about the local device and the devices directly connected to it for network administrators to manage networks through NMS (network management systems). In LLDP, device information is encapsulated in LLDPDUs in the form of TLV (meaning type, length, and value) triplets and is exchanged between directly connected devices. Information in LLDPDUs received is restored in standard MIB (management information base).
LLDP Fundamental
LLDP operating mode
LLDP can operate in one of the following modes.
l          TxRx mode. A port in this mode sends and receives LLDPDUs.
l          Tx mode. A port in this mode only sends LLDPDUs.
l          Rx mode. A port in this mode only receives LLDPDUs.
l          Disable mode. A port in this mode does not send or receive LLDPDUs.
LLDP is initialized when an LLDP-enabled port changes to operate in another LLDP operating mode. To prevent LLDP from being initialized too frequently, LLDP undergoes a period before being initialized on an LLDP-enabled port when the port changes to operate in another LLDP operating mode. The period is known as initialization delay, which is determined by the re-initialization delay timer.
Sending LLDPDUs
An LLDP-enabled device operating in the TxRx mode or Tx mode sends LLDPDUs to its directly connected devices periodically. It also sends LLDPDUs when the local configuration changes to inform the neighboring devices of the change timely. In any of the two cases, an interval exists between two successive operations of sending LLDPDUs. This prevents the network from being overwhelmed by LLDPDUs even if the LLDP operating mode changes frequently.
To enable the neighboring devices to be informed of the existence of a device or an LLDP operating mode change (from the disable mode to TxRx mode, or from the Rx mode to Tx mode) timely, a device can invoke the fast sending mechanism. In this case, the interval to send LLDPDUs changes to one second. After the device sends specific number of LLDPDUs, the interval restores to the normal. (A neighbor is discovered when a device receives an LLDPDU and no information about the sender is locally available.)
Receiving LLDPDUs
An LLDP-enabled device operating in the TxRx mode or Rx mode checks the TLVs carried in the LLDPDUs it receives and saves the valid neighboring information. An LLDPDU also carries a TTL (time to live) setting with it. The information about a neighboring device maintained locally ages out when the corresponding TTL expires.
The TTL of the information about a neighboring device is determined by the following expression:
TTL multiplier × LLDPDU sending interval.
You can set the TTL by configuring the TTL multiplier. Note that the TTL can be up to 65535 seconds. TTLs longer than it will be rounded off to 65535 seconds.
TLV Types
TLVs encapsulated in LLDPDUs fall into these categories: basic TLV, organization defined TLV, and MED (media endpoint discovery) related TLV. Basic TLVs are the base of device management. Organization specific TLVs and MED related TLVs are used for enhanced device management. They are defined in standards or by organizations and are optional to LLDPDUs.
Basic LLDP TLVs
Table 1-1 lists the basic LLDP TLV types that are currently in use.
Table 1-1 Basic LLDP TLVs
Remarks
End of LLDPDU TLV
Marks the end of an LLDPDU.
Required for LLDP
Chassis ID TLV
Carries the bridge MAC address of the sender
Port ID TLV
Carries the sending port. For devices that do not send MED TLVs, port ID TLVs carry sending port name. For devices that send MED TLVs, port ID TLVs carry the MAC addresses of the sending ports or bridge MAC addresses (if the MAC addresses of the sending ports are unavailable).
Time To Live TLV
Carries the TTL of device information
Port Description TLV
Carries Ethernet port description
Optional to LLDP
System Name TLV
Carries device name
System Description TLV
Carries system description
System Capabilities TLV
Carries information about system capabilities
Management Address TLV
Carries the management address, the corresponding port number, and OID (object identifier).
If the management address is not configured, it is the IP address of the interface of the VLAN with the least VLAN ID among those permitted on the port. If the IP address of the VLAN interface is not configured, IP address 127.0.0.1 is used as the management address.
Organization defined LLDP TLVs
1)        LLDP TLVs defined in IEEE802.1 include the following:
l          Port VLAN ID TLV, which carries port VLAN ID.
l          Port and protocol VLAN ID TLV, which carries port protocol VLAN ID.
l          VLAN name TLV, which carries port VLAN name.
l          Protocol identity TLV, which carries types of the supported protocols.
Currently, protocol identity TLVs can only be received on H3C devices.
2)        IEEE 802.3 defined LLDP TLVs include the following:
l          MAC/PHY configuration/status TLV, which carries port configuration, such as port speed, duplex state, whether port speed auto-negotiation is supported, the state of auto-negotiation, current speed , and current duplex state.
l          Power via MDI TLV, which carries information about power supply capabilities.
l          Link aggregation TLV, which carries the capability and state of link aggregation.
l          Maximum frame size TLV, which carries the maximum frame size supported, namely, MTU (maximum transmission unit).
MED related LLDP TLVs
l          LLDP-MED capabilities TLV, which carries the MED type of the current device and the types of the LLDP MED TLVs that can be encapsulated in LLDPDUs.
l          Network policy TLV, which carries port VLAN ID, supported applications (such as voice and video services), application priority, and the policy adopted.
l          Extended power-via-MDI TLV, which carries the information about the power supply capability of the current device.
l          Hardware revision TLV, which carries the hardware version of an MED device.
l          Firmware revision TLV, which carries the firmware version of an MED device.
l          Software revision TLV, which carries the software version of an MED device.
l          Serial number TLV, which carries the serial number of an MED device.
l          Manufacturer name TLV, which carries the manufacturer name of an MED device.
l          Model name TLV, which carries the model of an MED device.
l          Asset ID TLV, which carries the asset ID of an MED device. Asset ID is used for directory management and asset tracking.
l          Location identification TLV, which carries the location identification of a device. Location identification can be used in location-based applications.
For detailed information about LLDP TLV, refer to IEEE 802.1AB-2005 and ANSI/TIA-1057.
Protocols and Standards
l          IEEE 802.1AB-2005, Station and Media Access Control Connectivity Discovery
l          ANSI/TIA-1057, Link Layer Discovery Protocol for Media Endpoint Devices
Complete these tasks to configure LLDP:
Remarks
Basic LLDP configuration
Enabling LLDP
Required
Setting LLDP Operating Mode
Optional
Configuring LLDPDU TLVs
Optional
Enable LLDP Polling
Optional
Configuring the Parameters Concerning LLDPDU Sending
Optional
Optional
Enabling LLDP
Follow these steps to enable LLDP:
To do…
Use the command…
Remarks
Enter system view
Enable LLDP globally
lldp enable
Required
Enabled by default
Enter Ethernet interface view/port group view
Either of the two is required.
Configuration performed in Ethernet interface view applies to the current port only; configuration performed in port group view applies to all the ports in the corresponding port group.
Enter port group view
port-group { aggregation agg-id | manual port-group-name }
Enable LLDP
lldp enable
Optional
By default, LLDP is enabled on a port.
To make LLDP take effect, you need to enable it both globally and on the related ports.
Follow these steps to set LLDP operating mode:
To do…
Use the command…
Remarks
Enter system view
Set the initialization delay period
lldp timer reinit-delay value
Optional
2 seconds by default.
Set the LLDP operating mode
lldp admin-status { disable | rx | tx | txrx }
Optional
TxRx by default.
Follow these steps to configure LLDPDU TLVs:
To do…
Use the command…
Remarks
Enter system view
Set the TTL multiplier
lldp hold-multiplier value
Optional
4 by default.
Enable LLDP TLV sending for specific types of LLDP TLVs
lldp tlv-enable { basic-tlv { all | port-description | system-capability | system-description | system-name } | dot1-tlv { all | port-vlan-id | protocol-vlan-id [ vlan-id ] | vlan-name [ vlan-id ] } | dot3-tlv { all | link-aggregation | mac-physic | max-frame-size | power } | med-tlv { all | capability | location-id { civic-address device-type country-code { ca-type ca-value }&<1-10> | elin-address Tel-Number } | network-policy | power-over-ethernet | inventory } }
Optional
By default, all types of LLDP TLVs except location identification TLV are sent.
Specify the management address and specify to send the management address through LLDPDUs
lldp management-address-tlv [ ip-address ]
Optional
By default, the management address is sent through LLDPDUs, and the management address is the IP address of the interface of the VLAN with the least VLAN ID among those permitted on the port. If the IP address of the VLAN interface is not configured, IP address 127.0.0.1 is used as the management address. Refer to VLAN in H3C WX6103 Access Controller Switch Interface Board Configuration Guide for information about VLAN.
l          To enable MED related LLDP TLV sending, you need to enable LLDP-MED capabilities TLV sending first. Conversely, to disable LLDP-MED capabilities TLV sending, you need to disable the sending of other MED related LLDP TLVs.
l          To disable MAC/PHY configuration/status TLV sending, you need to disable LLDP-MED capabilities TLV sending first.
l          When executing the lldp tlv-enable command, specifying the all keyword for basic LLDP TLVs and organization defined LLDP TLVs (including IEEE 802.1 defined LLDP TLVs and IEEE 802.3 defined LLDP TLVs) enables sending of all the corresponding LLDP TLVs. For MED related LLDP TLVs, the all keyword enables sending of all the MED related LLDP TLVs except location identification TLVs.
l          Enabling sending of LLDP-MED capabilities TLVs also enables sending of MAC/PHY configuration/status TLVs.
Enable LLDP Polling
With LLDP polling enabled, a device checks for the local configuration changes periodically. Upon detecting a configuration change, the device sends LLDPDUs to inform the neighboring devices of the change.
Follow these steps to enable LLDP polling:
To do…
Use the command…
Remarks
Enter system view
Enable LLDP polling and set the polling interval
lldp check-change-interval value
Optional
Disabled by default
Configuring time-related parameters
Follow these steps to set time-related parameters:
To do…
Use the command…
Remarks
Enter system view
System-view
Set the interval to send LLDPDUs
lldp timer tx-interval value
Optional
30 seconds by default
Set the delay period to send LLDPDUs
lldp timer tx-delay value
Optional
To enable local device information to be updated on neighboring devices before being aged out, make sure the interval to send LLDPDUs is shorter than the TTL of the local device information.
Setting the number of the LLDPDUs to be sent when a new neighboring device is detected
Follow these steps to set the number of the LLDPDUs to be sent when a new neighboring device is detected
To do…
Use the command…
Remarks
Enter system view
Set the number of the LLDPDUs to be sent successively when a new neighboring device is detected
lldp fast-count value
Optional
3 by default
LLDP trap is used to notify NMS of the events such as new neighboring devices detected and link malfunctions.
LLDP traps are sent periodically and you can set the interval to send LLDP traps. In response to topology changes detected, a device sends LLDP traps according to the interval configured to inform the neighboring devices of the changes.
Follow these steps to configure LLDP trap:
To do…
Use the command…
Remarks
Enter system view
Enable LLDP trap sending
lldp notification remote-change enable
Required
Disabled by default
Quit to system view
Set the interval to send LLDP traps
lldp timer notification-interval value
Optional
5 seconds by default
To do…
Use the command…
Remarks
Display the global LLDP information or the information contained in the LLDP TLVs to be sent through a port
Available in any view
Display the information contained in the LLDP TLVs received through a port
display lldp neighbor-information [ interface interface-type interface-number ] [ brief ]
Display LLDP statistics
display lldp statistics [ global | interface interface-type interface-number ]
Display LLDP status of a port
display lldp status [ interface interface-type interface-number ]
Display the types of the LLDP TLVs that are currently sent
display lldp tlv-config [ interface interface-type interface-number ]
Network requirements
l          The NMS and AC are located in the same Ethernet. An MED device and Switch are connected to GigabitEthernet 0/0/1 and GigabitEthernet 0/0/2 of AC.
l          Enable LLDP on the ports of AC and Switch to monitor the link between AC and Switch and the link between AC and the MED device on the NMS.
Network diagram
Figure 1-1 Network diagram for LLDP configuration
Configuration procedure
1)        Configure AC.
# Enter system view.
<AC> system-view
# Enable LLDP globally.
[AC] lldp enable
# Enable LLDP on GigabitEthernet 0/0/1 and GigabitEthernet 0/0/2, setting the LLDP operating mode to Rx.
[AC] interface GigabitEthernet0/0/1
[AC-GigabitEthernet0/0/1] lldp enable
[AC-GigabitEthernet0/0/1] lldp admin-status rx
[AC-GigabitEthernet0/0/1] quit
[AC] interface GigabitEthernet0/0/2
[AC-GigabitEthernet0/0/2] lldp enable
[AC-GigabitEthernet0/0/2] lldp admin-status rx
[AC-GigabitEthernet0/0/2] quit
2)        Configure Switch.
<Switch> system-view
[Switch] lldp enable
# Enable LLDP on GigabitEthernet1/0/1, setting the LLDP operating mode to Tx.
[Switch] interface GigabitEthernet1/0/1
[Switch-GigabitEthernet1/0/1] lldp enable
[Switch-GigabitEthernet1/0/1] lldp admin-status tx
3)        Verify the configuration.
# Display the global LLDP status and port LLDP status on AC.
<AC> display lldp status
Global status of LLDP : Enable
The current number of neighbors : 2
Neighbor information last changed time : 0 days, 0 hours, 4 minutes, 40 seconds
Transmit interval               : 30s
Hold multiplier                 : 4
Reinit delay                    : 2s
Transmit delay                  : 2s
Trap interval                   : 5s
Fast start times                : 3
Port 0 [GigabitEthernet0/0/1] :
Port status of LLDP             : Enable
Admin status                    : Rx_Only
Trap flag                       : No
Roll time                       : 0s
Number of neighbors              : 1
Number of MED neighbors          : 1
Number of sent optional TLV      : 0
Number of received unknown TLV   : 0
Port 1 [GigabitEthernet0/0/2] :
Trap flag                       : No
Roll time                       : 0s
Number of MED neighbors          : 0
Number of received unknown TLV   : 3
# Tear down the link between AC and Switch and then display the global LLDP status and port LLDP status on AC.
The current number of neighbors : 1
Neighbor information last changed time : 0 days, 0 hours, 5 minutes, 20 seconds
Hold multiplier                 : 4
Reinit delay                    : 2s
Transmit delay                  : 2s
Trap interval                   : 5s
Trap flag                       : No
Roll time                       : 0s
Number of received unknown TLV   : 5
Trap flag                       : No
Roll time                       : 0s
Number of neighbors              : 0
