H3C WX6103 Access Controller Switch Interface Board Configuration Guide-6W102
HomeSupportWirelessWX6000 Series Access ControllersConfigure & DeployConfiguration GuidesH3C WX6103 Access Controller Switch Interface Board Configuration Guide-6W102
18-DHCP Configuration
18-DHCP Configuration 378.79 KB
Table of Contents
1 DHCP Overview·· 1-1
Introduction to DHCP· 1-1
DHCP Address Allocation· 1-2
Allocation Mechanisms· 1-2
Dynamic IP Address Allocation Process· 1-2
IP Address Lease Extension· 1-3
DHCP Message Format 1-3
DHCP Options· 1-4
DHCP Options Overview· 1-4
Introduction to DHCP Options· 1-5
Self-Defined Options· 1-5
Protocols and Standards· 1-7
2 DHCP Relay Agent Configuration· 2-1
Introduction to DHCP Relay Agent 2-1
Application Environment 2-1
Fundamentals· 2-1
DHCP Relay Agent Support for Option 82· 2-2
Configuration Task List 2-3
Configuring the DHCP Relay Agent 2-3
Enabling DHCP· 2-3
Enabling the DHCP Relay Agent on an Interface· 2-4
Correlating a DHCP Server Group with a Relay Agent Interface· 2-4
Configuring the DHCP Relay Agent to Send a DHCP-Release Request 2-5
Configuring the DHCP Relay Agent Security Functions· 2-5
Configuring the DHCP Relay Agent to Support Option 82· 2-7
Displaying and Maintaining DHCP Relay Agent Configuration· 2-8
DHCP Relay Agent Configuration Example· 2-8
Troubleshooting DHCP Relay Agent Configuration· 2-9
3 DHCP Client Configuration· 3-1
Introduction to DHCP Client 3-1
Enabling the DHCP Client on an Interface· 3-1
Displaying and Maintaining the DHCP Client 3-2
DHCP Client Configuration Example· 3-2
4 DHCP Snooping Configuration· 4-1
DHCP Snooping Overview· 4-1
Function of DHCP Snooping· 4-1
Application Environment of Trusted Ports· 4-2
DHCP Snooping Support for Option 82· 4-3
Configuring DHCP Snooping Basic Functions· 4-4
Configuring DHCP Snooping to Support Option 82· 4-4
Prerequisites· 4-4
Displaying and Maintaining DHCP Snooping· 4-5
DHCP Snooping Configuration Example· 4-5
5 BOOTP Client Configuration· 5-1
Introduction to BOOTP Client 5-1
BOOTP Application· 5-1
Obtaining an IP Address Dynamically· 5-2
Protocols and Standards· 5-2
Configuring an Interface to Dynamically Obtain an IP Address Through BOOTP· 5-2
Displaying and Maintaining BOOTP Client Configuration· 5-3
BOOTP Client Configuration Example· 5-3
DHCP Overview
When configuring ARP, go to these sections for information you are interested in:
l          Introduction to DHCP
l          DHCP Address Allocation
l          DHCP Message Format
l          DHCP Options
l          Protocols and Standards
The term switch in this document refers to a switch in a generic sense or an access controller configured with the switching function unless otherwise specified.
The fast expansion and growing complexity of networks result in scarce IP addresses assignable to hosts. Meanwhile, with the wide application of wireless networks, the frequent movement of laptops across networks requires that the IP addresses be changed accordingly. Therefore, related configurations on hosts become more complex. Dynamic Host Configuration Protocol (DHCP) was introduced to solve these problems.
DHCP is built on a client-server model, in which the client sends a configuration request and then the server returns a reply to send configuration parameters such as an IP address to the client.
A typical DHCP application, as shown in Figure 1-1, includes a DHCP server and multiple clients (PCs and laptops).
Figure 1-1 A typical DHCP application
When residing in a different subnet from the DHCP server, the DHCP client can get the IP address and other configuration parameters from the server via a DHCP relay agent. For information about the DHCP relay agent, refer to Introduction to DHCP Relay Agent.
DHCP supports three mechanisms for IP address allocation.
l          Manual allocation: The network administrator assigns an IP address to a client like a WWW server, and DHCP conveys the assigned address to the client.
l          Automatic allocation: DHCP assigns a permanent IP address to a client.
l          Dynamic allocation: DHCP assigns an IP address to a client for a limited period of time, which is called a lease. Most clients obtain their addresses in this way.
Figure 1-2 Dynamic IP address allocation process
As shown in the figure above, a DHCP client obtains an IP address from a DHCP server via four steps:
1)        The client broadcasts a DHCP-DISCOVER message to locate a DHCP server.
2)        A DHCP server offers configuration parameters such as an IP address to the client in a DHCP-OFFER message. The sending mode of the DHCP-OFFER is determined by the flag field in the DHCP-DISCOVER message. Refer to DHCP Message Format for related information.
3)        If several DHCP servers send offers to the client, the client accepts the first received offer, and broadcasts it in a DHCP-REQUEST message to formally request the IP address.
4)        All DHCP servers receive the DHCP-REQUEST message, but only the server to which the client sent a formal request for the offered IP address returns a DHCP-ACK message to the client, confirming that the IP address has been allocated to the client, or returns a DHCP-NAK unicast message, denying the IP address allocation.
l          After the client receives the DHCP-ACK message, it will probe whether the IP address assigned by the server is in use by broadcasting a gratuitous ARP packet. If the client receives no response within specified time, the client can use this IP address. Otherwise, the client sends a DHCP-DECLINE message to the server to request an IP address again.
l          If there are multiple DHCP servers, IP addresses offered by other DHCP servers are assignable to other clients.
The IP address dynamically allocated by a DHCP server to a client has a lease. After the lease duration elapses, the IP address will be reclaimed by the DHCP server. If the client wants to use the IP address again, it has to extend the lease duration.
After the half lease duration elapses, the DHCP client will send the DHCP server a DHCP-REQUEST unicast message to extend the lease duration. Upon availability of the IP address, the DHCP server returns a DHCP-ACK unicast confirming that the client’s lease duration has been extended, or a DHCP-NAK unicast denying the request.
If the client receives the DHCP-NAK message, it will broadcast another DHCP-REQUEST message for lease extension after 7/8 lease duration elapses. The DHCP server will handle the request as above mentioned.
DHCP Message Format
Figure 1-3 gives the DHCP message format, which is based on the BOOTP message format and involves eight types. These types of messages have the same format except that some fields have different values. The numbers in parentheses indicate the size of each field in bytes.
Figure 1-3 DHCP message format
l          op: Message type defined in option field. 1 = REQUEST, 2 = REPLY
l          htype,hlen: Hardware address type and length of a DHCP client.
l          hops: Number of relay agents a request message traveled.
l          xid: Transaction ID, a random number chosen by the client to identify an IP address allocation.
l          secs: Filled in by the client, the number of seconds elapsed since the client began address acquisition or renewal process. Currently this field is reserved and set to 0.
l          flags: The leftmost bit is defined as the BROADCAST (B) flag. If this flag is set to 0, the DHCP server sent a reply back by unicast; if this flag is set to 1, the DHCP server sent a reply back by broadcast. The remaining bits of the flags field are reserved for future use.
l          ciaddr: Client IP address.
l          yiaddr: 'your' (client) IP address, assigned by the server.
l          siaddr: Server IP address, from which the clients obtained configuration parameters.
l          giaddr: The first relay agent IP address a request message traveled.
l          chaddr: Client hardware address.
l          sname: The server host name, from which the client obtained configuration parameters.
l          file: Bootfile name and routing information, defined by the server to the client.
l          options: Optional parameters field that is variable in length, which includes the message type, lease, DNS IP address, WINS IP address and so forth.
DHCP Options
The DHCP message adopts the same format as the Bootstrap Protocol (BOOTP) message for compatibility, but differs from it in the option field, which identifies new features for DHCP.
DHCP uses the option field in DHCP messages to carry control information and network configuration parameters, implementing dynamic address allocation and providing more network configuration information for clients.
Figure 1-4 shows the DHCP option format.
Figure 1-4 DHCP option format
The common DHCP options are:
l          Option 6: DNS server option. It specifies the DNS server IP address to be assigned to the client.
l          Option 51: IP address lease option.
l          Option 53: DHCP message type option. It identifies the type of the DHCP message.
l          Option 55: Parameter request list option. It is used by a DHCP client to request specified configuration parameters. The option contains values that correspond to the parameters requested by the client.
l          Option 66: TFTP server name option. It specifies a TFTP server to be assigned to the client.
l          Option 67: Bootfile name option. It specifies the bootfile name to be assigned to the client.
l          Option 150: TFTP server IP address option. It specifies the TFTP server IP address to be assigned to the client.
For more information about DHCP options, refer to RFC 2132.
Some options have no unified definitions in RFC 2132. The formats of some self-defined options are introduced as follows.
Relay agent option (Option 82)
Option 82 is the relay agent option in the option field of the DHCP message. It records the location information of the DHCP client. When a DHCP relay agent receives a client’s request, it adds Option 82 to the request message and sends it to the server.
The administrator can locate the DHCP client to further implement security control and accounting. The Option 82 supporting server can also use such information to define individual assignment policies of IP address and other parameters for the clients.
Option 82 involves at most 255 sub-options. At least one sub-option must be defined. Now the DHCP relay agent supports two sub-options: sub-option 1 (Circuit ID) and sub-option 2 (Remote ID).
Option 82 has no unified definition. Its padding formats vary with vendors. Currently the device supports two padding formats: normal and verbose.
1)        Normal padding format
The padding contents for sub-options in the normal padding format are:
l          sub-option 1: Padded with the VLAN ID and number of the port that received the client’s request. The following figure gives its format. The value of the sub-option type is 1, and that of the circuit ID type is 0.
Figure 1-5 Sub-option 1 in normal padding format
l          sub-option 2: Padded with the MAC address of the interface that received the client’s request. The following figure gives its format. The value of the sub-option type is 2, and that of the remote ID type is 0.
Figure 1-6 Sub-option 2 in normal padding format
2)        Verbose padding format:
The padding contents for sub-options in the verbose padding format are:
l          sub-option 1: Padded with the user-specified access node identifier (ID of the device that adds Option 82 in DHCP messages), and type, number, and VLAN ID of the port that received the client’s request. Its format is shown in the following figure.
Figure 1-7 Sub-option 1 in verbose padding format
In the above figure, except that the VLAN ID field has a fixed length of 2 bytes, all the other padding contents of sub-option 1 are length variable.
l          sub-option 2: Padded with the MAC address of the interface that received the client’s request. It has the same format as that in normal padding format, as shown in Figure 1-6.
Option 184
Option 184 is a reserved option, and parameters in the option can be defined as needed. The device supports Option 184 carrying the voice related parameters, so a DHCP client with voice functions can get an IP address along with specified voice parameters from the DHCP server.
Option 184 involves the following sub-options:
l          Sub-option 1: IP address of the primary network calling processor, which is a server serving as the network calling control source and providing program downloads.
l          Sub-option 2: IP address of the backup network calling processor that DHCP clients will contact when the primary one is unreachable.
l          Sub-option 3: Voice VLAN ID and the result whether DHCP clients take this ID as the voice VLAN or not.
l          Sub-option 4: Failover route that specifies the destination IP address and the called number (SIP users use such IP addresses and numbers to communicate with each other) that a SIP user uses to reach another SIP user when both the primary and backup calling processors are unreachable.
You must define the sub-option 1 to make other sub-options take effect.
l          RFC2131: Dynamic Host Configuration Protocol
l          RFC2132: DHCP Options and BOOTP Vendor Extensions
l          RFC1542: Clarifications and Extensions for the Bootstrap Protocol
l          RFC 3046: DHCP Relay Agent Information Option
When configuring the DHCP relay agent, go to these sections for information you are interested in:
l          Introduction to DHCP Relay Agent
l          Configuration Task List
l          Configuring the DHCP Relay Agent
l          Displaying and Maintaining DHCP Relay Agent Configuration
l          DHCP Relay Agent Configuration Example
l          Troubleshooting DHCP Relay Agent Configuration
l          The DHCP relay agent configuration is supported only VLAN interfaces.
l          DHCP Snooping must be disabled on the DHCP relay agent.
Since DHCP clients request IP addresses via broadcast messages, the DHCP server and clients must be on the same subnet. Therefore, a DHCP server must be available on each subnet. It is not practical.
DHCP relay agent solves the problem. Via a relay agent, DHCP clients communicate with a DHCP server on another subnet to obtain configuration parameters. Thus, DHCP clients on different subnets can contact the same DHCP server for ease of centralized management and cost reduction.
Fundamentals
Figure 2-1 shows a typical application of the DHCP relay agent.
Figure 2-1 DHCP relay agent application
No matter whether a relay agent exists or not, the DHCP server and client interact with each other in a similar way (see section Dynamic IP Address Allocation Process). The following describes the forwarding process on the DHCP relay agent.
Figure 2-2 DHCP relay agent work process
As shown in the figure above, the DHCP relay agent works as follows:
1)        After receiving a DHCP-DISCOVER or DHCP-REQUEST broadcast message from a DHCP client, the DHCP relay agent fills the giaddr field of the message with its IP address and forwards the message to the designated DHCP server in unicast mode.
2)        Based on the giaddr field, the DHCP server returns an IP address and other configuration parameters to the relay agent, which conveys them to the client.
Option 82 records the location information of the DHCP client. The administrator can locate the DHCP client to further implement security control and accounting. For more information, refer to Relay agent option (Option 82).
If the DHCP relay agent supports Option 82, it will handle a client’s request according to the contents defined in Option 82, if any. The handling strategies are described in the table below.
If a reply returned by the DHCP server contains Option 82, the DHCP relay agent will remove the Option 82 before forwarding the reply to the client.
If a client’s requesting message has…
Handling strategy
Padding format
The DHCP relay agent will…
Option 82
Drop
Random
Drop the message.
Keep
Random
Forward the message without changing Option 82.
Replace
normal
Forward the message after replacing the original Option 82 with the Option 82 padded in normal format.
verbose
Forward the message after replacing the original Option 82 with the Option 82 padded in verbose format.
no Option 82
normal
Forward the message after adding the Option 82 padded in normal format.
verbose
Forward the message after adding the Option 82 padded in verbose format.
Complete the following tasks to configure the DHCP relay agent:
Remarks
Enabling DHCP
Required
Required
Required
Optional
Optional
Optional
Enabling DHCP
Enable DHCP before performing other DHCP-related configurations.
Follow these steps to enable DHCP:
To do…
Use the command…
Remarks
Enter system view
Enable DHCP
dhcp enable
Required
Disabled by default.
With this task completed, upon receiving a DHCP request from the enabled interface, the relay agent will forward the request to a DHCP server for address allocation.
Follow these steps to enable the DHCP relay agent on an interface:
To do…
Use the command…
Remarks
Enter system view
Enter interface view
Interface interface-type interface-number
Enable the DHCP relay agent on the current interface
dhcp select relay
Required
With DHCP enabled, interfaces work in the DHCP server mode.
If the DHCP client obtains an IP address via the DHCP relay agent, the address pool of the subnet which the IP address of the DHCP relay agent belongs to must be configured on the DHCP server. Otherwise, the DHCP client cannot obtain a correct IP address.
To improve reliability, you can specify several DHCP servers as a group on the DHCP relay agent and correlate a relay agent interface with the server group. When the interface receives requesting messages from clients, the relay agent will forward them to all the DHCP servers of the group.
Follow these steps to correlate a DHCP server group with a relay agent interface:
To do…
Use the command…
Remarks
Enter system view
Create a DHCP server group and add a server into the group
dhcp relay server-group group-id ip ip-address
Required
Not created by default.
Correlate the DHCP server group with the current interface
dhcp relay server-select group-id
Required
By default, no interface is correlated with any DHCP server group.
l          You can specify at most twenty DHCP server groups on the relay agent and at most eight DHCP server addresses for each DHCP server group.
l          The IP addresses of DHCP servers and those of relay agent’s interfaces cannot be on the same subnet. Otherwise, the client cannot obtain an IP address.
l          A DHCP server group can correlate with one or multiple DHCP relay agent interfaces, while a relay agent interface can only correlate with one DHCP server group. Using the dhcp relay server-select command repeatedly overwrites the previous configuration. However, if the specified DHCP server group does not exist, the interface still uses the previous correlation.
l          The group-id in the dhcp relay server-select command was specified by the dhcp relay server-group command.
Sometimes, you need to release a client’s IP address manually on the DHCP relay agent. With this task completed, the DHCP relay agent can actively send a DHCP-RELEASE request that contains the client’s IP address to be released. Upon receiving the DHCP-RELEASE request, the DHCP server then releases the IP address for the client.
Follow these steps to configure the DHCP relay agent in system view to send a DHCP-RELEASE request:
To do…
Use the command…
Remarks
Enter system view
Configure the DHCP relay agent to send a DHCP-RELEASE request
dhcp relay release ip client-ip
Required
Creating static bindings and enabling IP address check
The DHCP relay agent can dynamically record clients’ IP-to-MAC bindings after clients get IP addresses. It also supports static bindings, which means you can manually configure IP-to-MAC bindings on the DHCP relay agent, so that users can access external network using fixed IP addresses.
For avoidance of invalid IP address configuration, you can configure the DHCP relay agent to check whether a requesting client’s IP and MAC addresses match a binding on it (both dynamic and static bindings). If not, the client cannot access outside networks via the DHCP relay agent.
Follow these steps to create a static binding and enable IP address check:
To do…
Use the command…
Remarks
Enter system view
Create a static binding
dhcp relay security static ip-address mac-address  [ interface interface-type interface-number ]
Optional
No static binding is created by default.
Enable invalid IP address check
dhcp relay address-check { disable | enable }
Required
l          The dhcp relay address-check enable command is independent of other commands of the DHCP relay agent. That is, the invalid address check takes effect when this command is executed, regardless of whether other commands are used.
l          You are recommended to configure IP address check on the interface enabled with the DHCP relay agent; otherwise, the valid DHCP clients may not be capable of accessing networks.
l          When using the dhcp relay security static command to bind a VLAN interface to a static binding entry, make sure that the VLAN interface is configured as a DHCP relay agent; otherwise, address entry conflicts may occur.
Configuring dynamic binding update interval
Via the DHCP relay agent, a DHCP client sends a DHCP-RELEASE unicast message to the DHCP server to relinquish its IP address. In this case the DHCP relay agent simply conveys the message to the DHCP server, thus it does not remove the IP address from its bindings. To solve this, the DHCP relay agent can update dynamic bindings at a specified interval.
The DHCP relay agent uses the IP address of a client and the MAC address of the DHCP relay interface to regularly send a DHCP-REQUEST message to the DHCP server.
l          If the server returns a DHCP-ACK message or does not return any message within a specified interval, which means the IP address is assignable now, the DHCP relay agent will update its bindings by aging out the binding entry of the IP address.
l          If the server returns a DHCP-NAK message, which means the IP address is still in use, the relay agent will not age it out.
Follow these steps to configure dynamic binding update interval:
To do…
Use the command…
Remarks
Enter system view
Configure binding update interval
dhcp relay security tracker { interval | auto }
Optional
auto by default. (auto interval is calculated by the relay agent according to the number of bindings.)
Enabling unauthorized DHCP servers detection
There are unauthorized DHCP servers on networks, which reply DHCP clients with wrong IP addresses.
With this feature enabled, upon receiving a DHCP request, the DHCP relay agent will record the IP address of the DHCP server which assigned an IP address to the DHCP client and the receiving interface. The administrator can use this information to check out any DHCP unauthorized servers.
Follow these steps to enable unauthorized DHCP server detection:
To do…
Use the command…
Remarks
Enter system view
Enable unauthorized DHCP server detection
dhcp relay server-detect
Required
With the unauthorized DHCP server detection enabled, the device puts a record once for each DHCP server. The administrator needs to find unauthorized DHCP servers from the log information. After the recorded information of a DHCP server is cleared, a new record will be put for the DHCP server.
You need to complete the following tasks before configuring the DHCP relay agent to support Option 82.
l          Enabling DHCP
l          Enabling the DHCP relay agent on the specified interface
l          Correlating a DHCP server group with relay agent interfaces
Configuring the DHCP relay agent to support Option 82
Follow these steps to configure the DHCP relay agent to support Option 82:
To do…
Use the command…
Remarks
Enter system view
Enable the relay agent to support Option 82
dhcp relay information enable
Required
Configure the handling strategy for requesting messages containing Option 82
Optional
replace by default.
Configure the padding format for Option 82
dhcp relay information format { normal | verbose [ node-identifier { mac | sysname | user-defined node-identifier } ] }
Optional
normal by default.
l          To support Option 82, it is required to perform related configuration on both the DHCP server and relay agent. Since the DHCP server configuration varies with devices, it is not mentioned here.
l          If the handling strategy of the DHCP relay agent is configured as replace, you need to configure a padding format for Option 82. If the handling strategy is keep or drop, you need not configure any padding format.
l          If sub-option 1 (node identifier) of Option 82 is padded with the device name (sysname) of a node, the device name must contain no spaces. Otherwise, the DHCP relay agent will drop the message.
To do…
Use the command…
Remarks
Display information about DHCP server groups correlated to a specified or all interfaces
display dhcp relay { all | interface interface-type interface-number }
Available in any view
Display information about bindings of DHCP relay agents
display dhcp relay security [ ip-address | dynamic | static ]
Display statistics information about bindings of DHCP relay agents
display dhcp relay security statistics
Display information about the refreshing interval for entries of dynamic IP-to-MAC bindings
display dhcp relay security tracker
Display information about the configuration of a specified or all DHCP server groups
display dhcp relay server-group { group-id | all }
Display packet statistics on relay agent
display dhcp relay statistics [ server-group { group-id | all } ]
Available in user view
Clear packet statistics from relay agent
reset dhcp relay statistics [ server-group group-id ]
Network requirements
VLAN-interface 1 on the DHCP relay agent (AC) connects to the network where DHCP clients reside. The IP address of VLAN-interface 1 is 10.10.1.1/24 and IP address of VLAN-interface 2 is 10.1.1.2/24 that communicates with the DHCP server 10.1.1.1/24. As shown in the figure below, AC forwards messages between DHCP clients and the DHCP server.
Network diagram
Figure 2-3 Network diagram for DHCP relay agent
Configuration procedure
# Enable DHCP.
<AC> system-view
[AC] dhcp enable
# Enable the DHCP relay agent on VLAN-interface 1.
[AC] interface vlan-interface 1
[AC-Vlan-interface1] dhcp select relay
[AC-Vlan-interface1] quit
# Configure DHCP server group 1 with the DHCP server 10.1.1.1, and correlate the DHCP server group 1 with VLAN-interface 1.
[AC] dhcp relay server-group 1 ip 10.1.1.1
[AC-Vlan-interface1] dhcp relay server-select 1
l          Performing the configuration on the DHCP server is also required to guarantee the client-server communication via the relay agent. Since the DHCP server configuration varies with devices, it is not mentioned here.
l          If the DHCP relay agent and server are on different subnets, routes in between must be reachable.
Symptom
DHCP clients cannot obtain any configuration parameters via the DHCP relay agent.
Analysis
Some problems may occur with the DHCP relay agent or server configuration. Enable debugging and execute the display command on the DHCP relay agent to view the debugging information and interface state information for locating the problem.
Solution
Check that:
l          The DHCP is enabled on the DHCP server and relay agent.
l          The address pool on the same subnet where DHCP clients reside is available on the DHCP server.
l          The routes between the DHCP server and DHCP relay agent are reachable.
l          The relay agent interface connected to DHCP clients is correlated with correct DHCP server group and IP addresses for the group members are correct.
When configuring the DHCP client, go to these sections for information you are interested in:
l          Introduction to DHCP Client
l          Enabling the DHCP Client on an Interface
l          Displaying and Maintaining the DHCP Client
l          DHCP Client Configuration Example
l          The DHCP client configuration is supported only on VLAN interfaces.
l          When multiple VLAN interfaces with the same MAC address use DHCP for IP address acquisition via a relay agent, the DHCP server cannot be a Windows 2000 Server or Windows 2003 Server.
l          You are not recommended to enable both the DHCP client and the DHCP Snooping on the same device. Otherwise, DHCP Snooping entries may fail to be generated, or the DHCP client may fail to obtain an IP address.
With the DHCP client enabled on an interface, the interface will use DHCP to obtain configuration parameters such as an IP address from the DHCP server.
Follow these steps to enable the DHCP client on an interface:
To do…
Use the command…
Remarks
Enter system view
Enable the DHCP client on the interface
ip address dhcp-alloc [ client-identifier mac interface-type interface-number ]
Required
l          An interface can be configured to acquire an IP address in multiple ways, but these ways are exclusive. The latest configuration will overwrite the previous configuration.
l          After the DHCP client is enabled on an interface, no secondary IP address is configurable for the interface.
l          If the IP address assigned by the DHCP server shares a network segment with the IP addresses of other interfaces on the device, the DHCP client enabled interface will not request any IP address of the DHCP server unless the conflicted IP address is manually deleted and the interface is made UP again by first executing the shutdown command and then the undo shutdown command or the DHCP client is enabled on the interface by executing the undo ip address dhcp-alloc and ip address dhcp-alloc  commands in sequence.
To do…
Use the command…
Remarks
Display specified configuration information
On a LAN, AC contacts the DHCP server via VLAN-interface 1 to obtain an IP address.
Network diagram
Figure 3-1 A DHCP network
The following is the configuration on AC shown in Figure 3-1.
# Enable the DHCP client on VLAN-interface 1.
<AC> system-view
[AC-Vlan-interface1] ip address dhcp-alloc
To implement the DHCP client-server model, you need to perform related configuration on the DHCP server. Since the DHCP server configuration varies with devices, it is not mentioned here.
When configuring DHCP snooping, go to these sections for information you are interested in:
l          DHCP Snooping Overview
l          Configuring DHCP Snooping Basic Functions
l          Configuring DHCP Snooping to Support Option 82
l          Displaying and Maintaining DHCP Snooping
l          DHCP Snooping Configuration Example
l          DHCP Snooping supports no link aggregation. If an Ethernet port is added into an aggregation group, DHCP Snooping configuration on it will not take effect. When the port is removed from the group, DHCP Snooping can take effect.
l          The DHCP snooping enabled device does not work if it is between the DHCP relay agent and DHCP server, and it can work when it is between the DHCP client and relay agent or between the DHCP client and server.
l          The DHCP Snooping enabled device cannot be a DHCP server or DHCP relay agent.
l          You are not recommended to enable the DHCP client, BOOTP client, and DHCP Snooping on the same device. Otherwise, DHCP Snooping entries may fail to be generated, or the BOOTP client/DHCP client may fail to obtain an IP address.
As a DHCP security feature, DHCP snooping can implement the following:
Recording IP-to-MAC mappings of DHCP clients
For security sake, a network administrator needs to record the mapping between a client’s IP address obtained from the DHCP server and the client’s MAC address. DHCP snooping can meet the need.
DHCP snooping records clients’ MAC and IP addresses by reading their DHCP-REQUEST and DHCP-ACK messages from trusted ports. The network administrator can check out which IP addresses are assigned to the DHCP clients with the display dhcp-snooping command.
Ensuring DHCP clients to obtain IP addresses from valid DHCP servers
If there is an unauthorized DHCP server on a network, the DHCP clients may obtain invalid IP addresses. With DHCP snooping, the ports of a device can be configured as trusted or untrusted, ensuring the clients to obtain IP addresses from authorized DHCP servers.
l          Trusted: A trusted port forwards DHCP messages, ensuring that DHCP clients can obtain valid IP addresses.
l          Untrusted: The DHCP-ACK or DHCP-OFFER packets received from an untrusted port are discarded, preventing DHCP clients from receiving invalid IP addresses.
Configuring a trusted port connected with a DHCP server
A port that is connected with a DHCP server directly or indirectly should be configured as a trusted port, so that the DHCP snooping device can forward reply messages from the DHCP server, ensuring the DHCP clients to obtain IP addresses from the authorized DHCP server.
As shown in Figure 4-1, GigabitEthernet 0/0/1 on AC is connected with a DHCP server. GigabitEthernet 0/0/1 should be configured as a trusted port, so that it can forward replies from the DHCP server.
Figure 4-1 Configure a trusted port connected with the DHCP sever
Configuring trusted ports in a cascaded network
In a cascaded network involving multiple DHCP snooping devices, the ports connected to other DHCP snooping devices should be configured as trusted ports.
To save system resources, you can disable the trusted ports, which are indirectly connected with DHCP clients, from recording clients’ IP-to-MAC bindings.
As shown in Figure 4-2, AC A, AC B, and AC C are DHCP snooping devices. GigabitEthernet 0/0/2 and GigabitEthernet 0/0/3 on AC A, GigabitEthernet 0/0/1 and GigabitEthernet 0/0/2 on AC B, and GigabitEthernet 0/0/2, GigabitEthernet 0/0/3, and GigabitEthernet 0/0/4 on AC C are configured as trusted ports. Disable the trusted ports, GigabitEthernet 0/0/3 on AC A, GigabitEthernet 0/0/1 on AC B, GigabitEthernet 0/0/3 and GigabitEthernet 0/0/4 on AC C, which are not directly connected to DHCP clients, from recording client’s IP-to-MAC bindings.
Figure 4-2 Configure trusted ports in a cascaded network
If DHCP snooping supports Option 82, it will handle a client’s request according to the contents defined in Option 82, if any. The handling strategies are described in the table below.
If a reply returned by the DHCP server contains Option 82, the DHCP snooping device will remove the Option 82 before forwarding the reply to the client. If the reply contains no Option 82, it forwards it directly.
Handling strategy
Padding format
The DHCP snooping device will…
Option 82
Drop
Random
Drop the message.
Keep
Random
Replace
normal
verbose
no Option 82
normal
verbose
The handling strategy and padding format for Option 82 on the DHCP-Snooping device are the same as those on the relay agent.
Follow these steps to configure DHCP snooping basic functions:
To do…
Use the command…
Remarks
Enter system view
Enable DHCP snooping
dhcp-snooping
Required
Enter Ethernet port view
Specify the port as trusted
dhcp-snooping trust
[ no-user-binding ]
Required
Untrusted by default.
l          You need to specify the ports connected to the valid DHCP servers as trusted to ensure that DHCP clients can obtain valid IP addresses. The trusted port and the port connected to the DHCP client must be in the same VLAN.
l          You are not recommended to configure both the DHCP snooping and selective Q-in-Q function on the switch, which may result in the DHCP snooping to function abnormally.
You need to enable the DHCP Snooping function before configuring DHCP Snooping to support Option 82.
Follow these steps to configure DHCP snooping to support Option 82:
To do…
Use the command…
Remarks
Enter system view
Enable DHCP Snooping to support Option 82
dhcp-snooping information enable
Required
dhcp-snooping information strategy { drop | keep | replace }
Optional
replace by default.
dhcp-snooping information format { normal | verbose [ node-identifier { mac | sysname | user-defined node-identifier } ] }
Optional
normal by default.
l          To support Option 82, it is required to perform related configuration on both the DHCP server and the device enabled with DHCP Snooping. Since the DHCP server configuration varies with devices, it is not mentioned here.
l          If the handling strategy of the DHCP-Snooping-enabled device is configured as replace, you need to configure a padding format for Option 82. If the handling strategy is keep or drop, you need not configure any padding format.
l          If the Option 82 is padded with the device name (sysname) of a node, the device name must contain no spaces. Otherwise, the DHCP-Snooping-enabled device will drop the message.
To do…
Use the command…
Remarks
Display DHCP snooping address binding information
Display information about trusted ports
display dhcp-snooping trust
Clear DHCP snooping  address binding information
reset dhcp-snooping { all | ip ip-address }
l          AC is connected to a DHCP server through GigabitEthernet 0/0/1, and to two DHCP clients through GigabitEthernet 0/0/2 and GigabitEthernet 0/0/3.
l          GigabitEthernet 0/0/1 forwards DHCP server responses while the other two do not.
l          AC records clients’ IP-to-MAC address bindings in DHCP-REQUEST messages and DHCP-ACK messages received from trusted ports.
l          AC supports Option 82. After receiving a DHCP request from the client, AC adds Option 82 padded in verbose format to the request message and forwards the message to the DHCP server.
Network diagram
Figure 4-3 Network diagram for DHCP snooping configuration
# Enable DHCP snooping.
<AC> system-view
[AC] dhcp-snooping
# Specify GigabitEthernet 0/0/1 as trusted port.
[AC] interface gigabitethernet0/0/1
[AC-GigabitEthernet0/0/1] dhcp-snooping trust
[AC-GigabitEthernet0/0/1] quit
# Configure DHCP snooping to support Option 82 on GigabitEthernet 0/0/2.
[AC] interface gigabitethernet0/0/2
[AC-GigabitEthernet0/0/2] dhcp-snooping information enable
# Configure the padding format as verbose for Option 82 on GigabitEthernet 0/0/2.
[AC-GigabitEthernet0/0/2] dhcp-snooping information format verbose node-identifier sysname
[AC-GigabitEthernet0/0/2] quit
# Configure DHCP snooping to support Option 82 on GigabitEthernet 0/0/3.
[AC] interface gigabitethernet0/0/3
[AC-GigabitEthernet0/0/3] dhcp-snooping information enable
# Configure the padding format as verbose for Option 82 on GigabitEthernet 0/0/3.
[AC-GigabitEthernet0/0/3] dhcp-snooping information format verbose node-identifier sysname
While configuring a BOOTP client, go to these sections for information you are interested in:
l          Introduction to BOOTP Client
l          Configuring an Interface to Dynamically Obtain an IP Address Through BOOTP
l          Displaying and Maintaining BOOTP Client Configuration
l          BOOTP client configuration only applies to VLAN interfaces.
l          If several VLAN interfaces sharing the same MAC address obtain IP addresses through a BOOTP relay agent, the BOOTP server cannot be a Windows 2000 Server or Windows 2003 Server.
l          You are not recommended to enable both the DHCP client and the DHCP Snooping on the same device. Otherwise, DHCP Snooping entries may fail to be generated, or the BOOTP client may fail to obtain an IP address.
This section covers these topics:
l          BOOTP Application
l          Obtaining an IP Address Dynamically
BOOTP Application
After you specify an interface of a device as a BOOTP client, the interface can use BOOTP to get information (such as IP address) from the BOOTP server, which simplifies your configuration.
Before using BOOTP, an administrator needs to configure a BOOTP parameter file for each BOOTP client on the BOOTP server. The parameter file contains information such as MAC address and IP address of a BOOTP client. When a BOOTP client originates a request to the BOOTP server, the BOOTP server will search for the BOOTP parameter file and return the corresponding configuration information.
Because you need to configure a parameter file for each client on the BOOTP server, BOOTP usually runs under a relatively stable environment. If the network changes frequently, DHCP is applicable.
Because a DHCP server can interact with a BOOTP client, you can use the DHCP server to configure an IP address for the BOOTP client, without any BOOTP server.
A DHCP server can take the place of the BOOTP server in the following dynamic IP address acquisition.
A BOOTP client dynamically obtains an IP address from a BOOTP server in the following way:
1)        The BOOTP client broadcasts a BOOTP request, which contains its own MAC address.
2)        The BOOTP server receives the request and searches the configuration file for the corresponding IP address according to the MAC address of the BOOTP client. The BOOTP server then returns a BOOTP response to the BOOTP client.
3)        The BOOTP client obtains the IP address from the received the response.
Some protocols and standards related to BOOTP include:
l          RFC 951: Bootstrap Protocol (BOOTP)
l          RFC 2132: DHCP Options and BOOTP Vendor Extensions
l          RFC 1542: Clarifications and Extensions for the Bootstrap Protocol
Follow these steps to configure an interface to dynamically obtain an IP address:
To do…
Use the command…
Remarks
Enter system view
Configure an interface to dynamically obtain IP address through BOOTP
ip address bootp-alloc
Required
By default, an interface does not use BOOTP to obtain an IP address.
To do…
Use the command…
Remarks
Display related information on a BOOTP client
Network requirement
AC’s port belonging to VLAN 1 is connected to the LAN. VLAN-interface 1 obtains an IP address from the DHCP server by using BOOTP.
Network diagram
See Figure 3-1.
The following describes only the configuration on AC serving as a client.
# Configure VLAN-interface 1 to dynamically obtain an IP address from the DHCP server.
<AC> system-view
[AC-Vlan-interface1] ip address bootp-alloc
To make the BOOTP client to obtain an IP address from the DHCP server, you need to perform additional configurations on the DHCP server. Since the DHCP server configuration varies with devices, it is not mentioned here.
