H3C WX6103 Access Controller Switch Interface Board Configuration Guide-6W102
HomeSupportWirelessWX6000 Series Access ControllersConfigure & DeployConfiguration GuidesH3C WX6103 Access Controller Switch Interface Board Configuration Guide-6W102
00-Preface
00-Preface 93.32 KB
Preface
The H3C WX6103 Access Controller Switch Interface Board Configuration Guide describes the software features for the H3C WX6103 access controller switch Interface board and guides you through the software configuration procedures. It also provides configuration examples to help you apply software features to different network scenarios.
This preface includes:
l          Audience
l          Document Organization
l          Conventions
l          About the H3C WX6103 Documentation Set
l          Obtaining Documentation
l          Documentation Feedback
Audience
l          Network planners
l          Field technical support and servicing engineers
l          Network administrators working with the H3C WX6103 access controller switch interface board
The H3C WX6103 Access Controller Switch Interface Board Configuration Guide comprises these parts:
Content
Login
VLAN
IP Addressing and IP Performance
QinQ-BPDU Tunneling
Port Correlation
Link Aggregation
MAC Address Table Management
Port Security
MSTP
IP Routing-GR Overview
IPv4 Routing
IP Source Guard
DLDP
Multicast
LLDP
sFlow
ARP
DHCP
ACL
QoS
Port Mirroring
UDP Helper
SNMP-RMON
NTP
DNS
File System Management
Information Center
System Maintaining and Debugging
NQA
SSH
SSL-HTTPS
PKI
Track
Acronyms
Conventions
This section describes the conventions used in this documentation set.
Command conventions
Convention
Boldface
italic
{ x | y | ... }
[ x | y | ... ]
{ x | y | ... } *
Asterisk marked braces enclose a set of required syntax choices separated by vertical bars, from which you select at least one.
[ x | y | ... ] *
Asterisk marked square brackets enclose optional syntax choices separated by vertical bars, from which you may select multiple choices or none.
&<1-n>
GUI conventions
Convention
Boldface
Window names, button names, field names, and menu items are in Boldface. For example, the New User window appears; click OK.
Symbols
Convention
Means reader be extremely careful. Improper operation may cause bodily injury.
Means reader be careful. Improper operation may cause data loss or damage to equipment.
Means an action or information that needs special attention to ensure successful configuration or good performance.
Means a complementary description.
Means techniques helpful for you to make configuration with ease.
Network topology icons
Convention
The H3C WX6103 documentation set includes:
Manual
H3C WX6103 Access Controller Switch Interface Board Command Reference
Elaborates on the operation commands for the WX6103 access controller switch interface board. It covers the configuration commands for CLI, VLAN, MSTP, system maintaining and debugging, port basic configurations, multicast protocol, 802.1x, AAA, SSH, ACL, QoS, and a command index of the whole reference.
H3C WX6103 Access Controller  Installation Manual
It introduces the installation process, startup, hardware and software maintenance, and monitoring of the WX6103 access controller.
H3C WX Series Access Controllers  Operation Manual
Provides a guide to the operation of H3C series access controllers. It covers configurations of CLI, VLAN, system maintenance and debugging, WLAN, IPv4, IPv6, port basic configurations, multicast protocols, 802.1x, AAA, SSH, ACL, QoS, and description of the acronyms used throughout the guide.
H3C WX Series Access Controllers  Command Manual
Elaborates on the operation commands for H3C series access controllers. It covers the configuration commands for VLAN, system maintenance and debugging, WLAN, IPv4, IPv6, port basic configurations, multicast protocols, 802.1x, AAA, SSH, ACL, QoS, and a command index of the whole reference.
You can access the most up-to-date H3C product documentation on the World Wide Web at http://www.h3c.com.
Click the links on the top navigation bar to obtain different categories of product documentation:
[Technical Support & Documents > Technical Documents] – Provides hardware installation, software upgrading, and software feature configuration and maintenance documentation.
[Products & Solutions] – Provides information about products and technologies, as well as solutions.
[Technical Support & Documents > Software Download] – Provides the documentation released with the software version.
We appreciate your comments.
