H3C WX6103 Access Controller Switch Interface Board Configuration Guide-6W102
HomeSupportWirelessWX6000 Series Access ControllersConfigure & DeployConfiguration GuidesH3C WX6103 Access Controller Switch Interface Board Configuration Guide-6W102
08-Port Security Configuration
08-Port Security Configuration 163.15 KB
When configuring port security, go to these sections for information you are interested in:
l          Introduction to Port Security
l          Port Security Configuration Task List
l          Displaying and Maintaining Port Security
l          Port Security Configuration Examples
l          Troubleshooting Port Security
The term switch in this document refers to a switch in a generic sense or an access controller configured with the switching function unless otherwise specified.
Port Security Overview
Port security is a MAC address-based security mechanism for network access controlling. It is an extension to the existing 802.1x authentication and MAC authentication. It controls the access of unauthorized devices to the network by checking the source MAC address of an inbound frame and the access to unauthorized devices by checking the destination MAC address of an outbound frame.
With port security, you can define various port security modes to make a device learn only legal source MAC addresses, so that you can implement different network security management as needed. When a port security-enabled device detects an illegal frame, it triggers the corresponding port security feature and takes a pre-defined action automatically. This reduces your maintenance workload and greatly enhances system security.
The following types of frames are classified as illegal:
l          Received frames with unknown source MAC addresses when MAC address learning is disabled.
l          Received frames with unknown source MAC addresses when the number of MAC addresses learned by the port has already reached the upper limit.
l          Frames from unauthenticated users.
Port Security Features
NTK
The need to know (NTK) feature checks the destination MAC addresses in outbound frames and allows frames to be sent to only devices passing authentication, thus preventing illegal devices from intercepting network traffic.
Intrusion protection
The intrusion protection feature checks the source MAC addresses in inbound frames and takes a pre-defined action accordingly upon detecting illegal frames. The action may be disabling the port temporarily, disabling the port permanently, or blocking frames with the MAC address for three minutes (unmodifiable).
Trap
The trap feature enables the device to send trap messages upon detecting specified frames that result from, for example, intrusion or user login/logout operations, helping you monitor special activities.
Port Security Modes
Table 1-1 details the port security modes.
Table 1-1 Port security modes
Security mode
Features
noRestrictions
Port security is disabled on the port and access to the port is not restricted.
In this mode, neither the NTK nor the intrusion protection feature is triggered.
autoLearn
In this mode, a port can learn a specified number of MAC addresses and save those addresses as secure MAC addresses. It permits only frames whose source MAC addresses are secure MAC addresses or static MAC addresses configured by using the mac-address static command.
When the number of secure MAC addresses reaches the upper limit, the port changes to work in secure mode.
In either mode, the device will trigger NTK and intrusion protection upon detecting an illegal frame.
secure
In this mode, a port is disabled from learning MAC addresses and permits only frames whose source MAC addresses are secure MAC addresses or static MAC addresses configured by using the mac-address static command.
userLogin
In this mode, a port performs 802.1x authentication of users in portbased mode.
In this mode, neither NTK nor intrusion protection will be triggered.
userLoginSecure
In this mode, a port performs 802.1x authentication of users in portbased mode and services only one user passing 802.1x authentication.
In any of these modes, the device will trigger NTK and intrusion protection upon detecting an illegal frame.
userLoginWithOUI
Similar to the userLoginSecure mode, a port in this mode performs 802.1x authentication of users and services only one user passing 802.1x authentication.
 A MAC address being a specified OUI (organizationally unique identifier) are also allowed on the port.
macAddressWithRadius
In this mode, a port performs MAC authentication of users.
macAddressOrUserLoginSecure
This mode is the combination of the userLoginSecure and macAddressWithRadius modes, with 802.1x authentication having a higher priority.
the port performs MAC authentication upon receiving non-8021.x frames and performs 802.1x authentication first upon receiving 802.1x frames. If 802.1x authentication fails, the port performs MAC authentication.
macAddressElseUserLoginSecure
This mode is the combination of the macAddressWithRadius and userLoginSecure modes, with MAC authentication having a higher priority.
l      Upon receiving a non-802.1x frame, a port in this mode performs only MAC authentication.
l      Upon receiving an 802.1x frame, the port performs MAC authentication and then, if MAC authentication fails, 802.1x authentication.
userLoginSecureExt
In this mode, a port performs 802.1x authentication of users in macbased mode and supports multiple concurrent users.
macAddressOrUserLoginSecureExt
This mode is similar to macAddressOrUserLoginSecure mode. The difference is that this mode allows a port to support multiple 802.1x and MAC authentication users.
macAddressElseUserLoginSecureExt
This mode is similar to macAddressElseUserLoginSecure mode. The difference is that this mode allows a port to support multiple 802.1x and MAC authentication users.
l          Currently, port security supports two authentication methods: 802.1x and MAC authentication. Different port security modes employ different authentication method or different combinations of authentication methods.
l          The maximum number of authenticated users that a port can support is the smaller one between the maximum number of secure MAC addresses and the maximum number of concurrent users that the mode of the port supports.
Complete the following tasks to configure port security:
Remarks
Enabling Port Security
Required
Setting the Maximum Number of Secure MAC Addresses
Optional
Setting the Port Security Mode
Required
Configuring Port Security Features
Configuring NTK
Optional
Choose one or more features as required.
Configuring Intrusion Protection
Configuring Trapping
Configuring Secure MAC Addresses
Optional
Ignoring the Authorization Information from the Server
Optional
Configuration Prerequisites
Before enabling port security, you need to disable 802.1x and MAC authentication globally.
Configuration Procedure
Follow these steps to enable port security:
To do…
Use the command…
Remarks
Enter system view
Enable port security
port-security enable
Required
Disabled by default
Note that:
1)        Enabling port security resets the following configurations on a port to the defaults bracketed, making them dependent completely on the port security mode:
l          802.1x (disabled), port access control method (macbased), and port access control mode (auto)
l          MAC authentication (disabled)
2)        Disabling port security resets the following configurations on a port to the defaults bracketed:
l          Port security mode (noRestrictions)
3)        Port security cannot be disabled if there is any user present on a port.
For configuration information about 802.1x authentication and MAC authentication, refer to 802.1x-HABP-MAC Authentication in H3C WX6103 Access Controller Switch Interface Board Configuration Guide.
With port security enabled, more than one authenticated user is allowed on a port. The number of authenticated users allowed, however, cannot exceed the specified upper limited.
By setting the maximum number of secure MAC addresses allowed on a port, you can
l          Control the maximum number of users who are allowed access the network through the port
l          Control the number of secure MAC addresses that can be added with port security
This configuration is different from that of the maximum number of MAC addresses that can be leaned by the port in MAC address management.
Follow these steps to set the maximum number of secure MAC addresses allowed on a port:
To do…
Use the command…
Remarks
Enter system view
Enter Ethernet port view
Set the maximum number of secure MAC addresses allowed on a port
port-security max-mac-count count-value
Required
Not limited by default
Before setting the port security mode, ensure that:
l          802.1x is disabled, the port access control method is macbased, and the port access control mode is auto.
l          MAC authentication is disabled.
Otherwise, you will see an error message and your configuration will fail.
On the other hand, after setting the port security mode on a port, you cannot change any of the above configurations.
l          With port security disabled, you can configure the port security mode but your configuration does not take effect.
l          With port security enabled, you can change the port security mode of a port only when the port is operating in noRestrictions mode, the default mode. You can use the undo port-security port-mode command to restore the default port security mode.
l          You cannot change the port security mode of a port when any user is present on the port.
l          Configuration of port security mode and aggregation are mutually exclusive. You cannot configure both of them on a port.
Enabling the autoLearn Mode
Configuration prerequisites
Before enabling the autoLearn mode, you need to set the maximum number of secure MAC addresses allowed on the port.
Configuration procedure
Follow these steps to enable the autoLearn mode:
To do…
Use the command…
Remarks
Enter system view
Enable the autoLearn mode
port-security port-mode autolearn
Required
By default, a port operates in noRestrictions mode.
When a port operates in autoLearn mode, you cannot change the maximum number of secure MAC addresses allowed on the port.
Enabling the userLoginWithOUI Mode
In userLoginWithOUI mode, a port supports one 802.1x user as well as users whose MAC addresses have an OUI value among the specified ones.
Follow these steps to enable the userLoginWithOUI mode:
To do…
Use the command…
Remarks
Enter system view
Set an OUI value for user authentication
port-security oui oui-value index index-value
Optional
Not configured by default
Enable the userLoginWithOUI mode
port-security port-mode userlogin-withoui
Required
l          An organizationally unique identifier (OUI), the left-most 24 bits of a MAC address, is a globally unique identifier assigned by IEEE to a certain manufacturer.
l          You can configure multiple OUI values.
Enabling any other Port Security Mode
Follow these steps to enable any other port security mode:
To do…
Use the command…
Remarks
Enter system view
Set the port security mode
port-security port-mode { mac-authentication | mac-else-userlogin-secure | mac-else-userlogin-secure-ext | secure | userlogin | userlogin-secure | userlogin-secure-ext | userlogin-secure-or-mac | userlogin-secure-or-mac-ext }
Required
On a port operating in either macAddressElseUserLoginSecure mode or macAddressElseUserLoginSecureExt mode, intrusion protection is triggered only after both MAC authentication and 802.1x authentication for the same frame fail.
Configuring NTK
Follow these steps to configure the NTK feature:
To do…
Use the command…
Remarks
Enter system view
Configure the NTK feature
port-security ntk-mode { ntk-withbroadcasts | ntk-withmulticasts | ntkonly }
Required
Be default, NTK is disabled on a port and all frames are allowed to be sent.
Follow these steps to configure the intrusion protection feature:
To do…
Use the command…
Remarks
Enter system view
Configure the intrusion protection feature
port-security intrusion-mode { blockmac | disableport | disableport-temporarily }
Required
By default, intrusion protection is disabled.
Return to system view
Set the silence timeout during which a port remains disabled
port-security timer disableport time-value
Optional
20 seconds by default
If you configure the port-security intrusion-mode command with the disableport-temporarily keyword, you can use the port-security timer disableport command to set the silence timeout during which a port remains disabled.
Follow these steps to configure port security trapping:
To do…
Use the command…
Remarks
Enter system view
Enable port security traps
port-security trap { addresslearned | dot1xlogfailure | dot1xlogoff | dot1xlogon | intrusion | ralmlogfailure | ralmlogoff | ralmlogon }
Required
By default, no port security trap is enabled.
Secure MAC addresses are special MAC addresses. They never age out or get lost if saved before the device restarts. One secure MAC address can be added to only one port in the same VLAN. Thus, you can bind a MAC address to one port in the same VLAN.
Secure MAC addresses can be learned by a port working in autoLearn mode. You can also manually configure them through the command line interface (CLI) or management information base (MIB).
l          Enable port security
l          Set the maximum number of secure MAC addresses allowed on the port
l          Set the port security mode to autoLearn
Follow these steps to configure a secure MAC address:
To do…
Use the command…
Remarks
Enter system view
Configure a secure MAC address
In system view
port-security mac-address security mac-address interface interface-type interface-number vlan vlan-id
Required
Use either approach
No secure MAC address is configured by default.
In Ethernet port view
port-security mac-address security mac-address vlan vlan-id
The configured secure MAC addresses are saved in the configuration file and will not get lost when the port goes up or goes down. After you save the configuration file, the secure MAC address saved in the configuration file are maintained even after the device restarts.
After an 802.1x user or MAC authenticated user passes RADIUS authentication, the RADIUS server delivers the authorization information to the device. You can configure a port to ignore the authorization information from the RADIUS server.
Follow these steps to configure a port to ignore the authorization information from the RADIUS server:
To do…
Use the command…
Remarks
Enter system view
Ignore the authorization information from the RADIUS server
port-security authorization ignore
Required
By default, a port uses the authorization information from the RADIUS server.
To do…
Use the command…
Remarks
Display port security configuration information, operation information, and statistics about one or more ports or all ports
display port-security [ interface interface-list ]
Available in any view
Display information about secure MAC addresses
display port-security mac-address security [ interface interface-type interface-number ] [ vlan vlan-id ] [ count ]
Display information about blocked MAC addresses
display port-security mac-address block [ interface interface-type interface-number ] [ vlan vlan-id ] [ count ]
Port Security Configuration for autoLearn Mode
Network requirements
Restrict port GigabitEthernet 0/0/1 of the switch as follows:
l          Allow up to 64 users to access the port without authentication and permit the port to learn and add the MAC addresses of the users as secure MAC addresses.
l          After the number of secure MAC addresses reaches 64, the port stops learning MAC addresses. If any frame with an unknown MAC address arrives, intrusion protection is triggered and the port is disabled and stays silence for 30 seconds.
Network diagram
Figure 1-1 Network diagram for port security configuration for autoLearn mode
1)        Configure port security
# Enable port security.
<AC> system-view
[AC] port-security enable
# Enable intrusion protection trap.
[AC] port-security trap intrusion
[AC] interface gigabitethernet 0/0/1
# Set the maximum number of secure MAC addresses allowed on the port to 64.
[AC-GigabitEthernet0/0/1] port-security max-mac-count 64
# Set the port security mode to autoLearn.
[AC-GigabitEthernet0/0/1] port-security port-mode autolearn
# Configure the port to be silent for 30 seconds after the intrusion protection feature is triggered.
[AC-GigabitEthernet0/0/1] port-security intrusion-mode disableport-temporarily
[AC-GigabitEthernet0/0/1] quit
[AC] port-security timer disableport 30
2)        Verify the configuration
After completing the above configurations, you can use the following command to view the port security configuration information:
<AC> display port-security interface gigabitethernet 0/0/1
 Equipment port-security is enabled
 Intrusion trap is enabled
 Disableport Timeout: 30s
 OUI value:
GigabitEthernet0/0/1 is link-up
   Port mode is autoLearn
   NeedToKnow mode is disabled
   Intrusion Protection mode is DisablePortTemporarily
   Max MAC address number is 64
   Stored MAC address number is 0
   Authorization is permitted
As shown in the output, the maximum number of secure MAC addresses allowed on the port is 64, the port security mode is autoLearn, the intrusion protection trap is enabled, and the intrusion protection action is to keep the port temporarily (DisablePortTemporarily) for 30 seconds.
You can also use the above command repeatedly to track the number of MAC addresses learned by the port, or use the display this command in Ethernet port view to display the secure MAC addresses learned, as shown below:
<AC> system-view
[AC-GigabitEthernet0/0/1] display this
interface GigabitEthernet0/0/1
 port-security mac-address security 0002-0000-0015 vlan 1
 port-security mac-address security 0002-0000-0014 vlan 1
 port-security mac-address security 0002-0000-0013 vlan 1
 port-security mac-address security 0002-0000-0012 vlan 1
 port-security mac-address security 0002-0000-0011 vlan 1
Issuing the display port-security interface command after the number of MAC addresses learned by the port reaches 64, you will see that the port security mode has changed to secure. When any frame with a new MAC address arrives, intrusion protection is triggered and you will see trap messages as follows:
#May  2 03:15:55:871 2000 AC PORTSEC/1/VIOLATION:Traph3cSecureViolation
 A intrusion occurs!
 IfIndex: 9437207
 Port: 9437207
 MAC Addr: 0.2.0.0.0.21
 VLAN ID: 1
 IfAdminStatus: 1
In addition, you will see that the port security feature has disabled the port if you issue the following command:
<AC-GigabitEthernet0/0/1> display interface gigabitethernet 0/0/1
 GigabitEthernet0/0/1 current state:  Port Security Disabled
 IP Packet Frame Type: PKTFMT_ETHNT_2, Hardware Address: 000f-cb00-5558
 Description: GigabitEthernet0/0/1 Interface
The port should be re-enabled 30 seconds later.
[AC-GigabitEthernet0/0/1] display interface gigabitethernet 0/0/1
 GigabitEthernet0/0/1 current state: UP
Now, if you manually delete several secure MAC addresses, the port security mode of the port will be restored to autoLearn, and the port will be able to learn MAC addresses again.
Port Security Configuration for userLoginWithOUI Mode
The client is connected to the switch through port GigabitEthernet 0/0/1. The switch authenticates the client by the RADIUS server. If the authentication succeeds, the client is authorized to access the Internet.
l          Allow only one 802.1x user to be authenticated.
l          Allow up to 16 OUI values to be configured and allow one additional user whose MAC address has an OUI among the configured ones to access the port.
Network diagram
Figure 1-2 Network diagram for port security configuration for userLoginWithOUI mode
l          The following configuration steps cover some AAA/RADIUS configuration commands.
l          Configurations on the host and RADIUS servers are omitted.
1)        Configure the RADIUS protocol
# Create a RADIUS scheme named radsun.
<AC> system-view
[AC] radius scheme radsun
# Set the IP addresses of the primary authentication and accounting servers to 192.168.1.1 and 192.168.1.2 respectively.
[AC-radius-radsun] primary authentication 192.168.1.1
[AC-radius-radsun] primary accounting 192.168.1.2
# Set the IP addresses of the secondary authentication and accounting servers to 192.168.1.2 and 192.168.1.1 respectively.
[AC-radius-radsun] secondary authentication 192.168.1.2
[AC-radius-radsun] secondary accounting 192.168.1.1
# Set the encryption key for the switch to use when interacting with the authentication server to name.
[AC-radius-radsun] key authentication name
# Set the encryption key for the switch to use when interacting with the accounting server to money.
[AC-radius-radsun] key accounting money
# Set the RADIUS server response timeout time to five seconds and the maximum number of RADIUS packet retransmission attempts to 5.
[AC-radius-radsun] timer response-timeout 5
[AC-radius-radsun] retry 5
# Set the interval at which the switch sends real-time accounting packets to the RADIUS server to 15 minutes.
[AC-radius-radsun] timer realtime-accounting 15
# Specify that the switch sends user names without domain names to the RADIUS server.
[AC-radius-radsun] user-name-format without-domain
[AC-radius-radsun] quit
# Create an ISP domain named sun and enter its view.
[AC] domain sun
# Configure the ISP domain to use RADIUS scheme radsun as its default RADIUS scheme.
[AC-isp-sun] authentication default radius-scheme radsun
# Allow the ISP domain to accommodate up to 30 users.
[AC-isp-sun] access-limit enable 30
[AC-isp-sun] quit
2)        Configure port security
# Add five OUI values.
[AC] port-security oui 1234-0100-1111 index 1
[AC] port-security oui 1234-0200-1111 index 2
[AC] port-security oui 1234-0300-1111 index 3
[AC] port-security oui 1234-0400-1111 index 4
[AC] port-security oui 1234-0500-1111 index 5
# Set the port security mode to userLoginWithOUI.
[AC-GigabitEthernet0/0/1] port-security port-mode userlogin-withoui
3)        Verify the configuration
After completing the above configurations, you can use the following command to view the configuration information of the RADIUS scheme named radsun:
<AC> display radius scheme radsun
SchemeName  = radsun
  Index = 0                           Type = standard
  Primary Auth IP  = 192.168.1.1      Port = 1812   State = active
  Primary Acct IP  = 192.168.1.2      Port = 1813   State = active
  Second  Auth IP  = 192.168.1.2      Port = 1812   State = active
  Second  Acct IP  = 192.168.1.1      Port = 1813   State = active
  Auth Server Encryption Key = name
  Acct Server Encryption Key = money
  Accounting-On packet disable, send times = 5 , interval = 3s
  Interval for timeout(second)                            = 5
  Retransmission times for timeout                        = 5
  Interval for realtime accounting(minute)                = 15
  Retransmission times of realtime-accounting packet      = 5
  Retransmission times of stop-accounting packet          = 500
  Quiet-interval(min)                                     = 5
  Username format                                         = without-domain
  Data flow unit                                          = Byte
  Packet unit                                             = one
Use the following command to view the configuration information of the ISP domain named sun:
<AC> display domain sun
   Domain = sun
   State = Active
   Access-limit = 30
   Accounting method = Required
   Default authentication scheme      : radius=radsun
   Default authorization scheme       : local
   Default accounting scheme          : local
   Domain User Template:
   Idle-cut = Disable
   Self-service = Disable
Use the following command to view the port security configuration information:
 Trap is disabled
 Disableport Timeout: 20s
 OUI value:
   Index is 1,  OUI value is 123401
   Index is 2,  OUI value is 123402
   Index is 3,  OUI value is 123403
   Index is 4,  OUI value is 123404
   Index is 5,  OUI value is 123405
   Port mode is userLoginWithOUI
   Intrusion Protection mode is NoAction
   Max MAC address number is not configured
After an 802.1x user gets online, you can see that the number of secure MAC addresses stored is 1. You can also use the following command to view information about 802.1x users:
<AC> display dot1x interface gigabitethernet 0/0/1
 Equipment 802.1X protocol is enabled
 CHAP authentication is enabled
 Configuration: Transmit Period   30 s,  Handshake Period       15 s
                Quiet Period      60 s,  Quiet Period Timer is disabled
                Supp Timeout      30 s,  Server Timeout        100 s
                The maximal retransmitting times    2
EAD quick deploy configuration:
                EAD timeout:   30 m
 The maximum 802.1X user resource number is 1024 per slot
 Total current used 802.1X resource number is 1
   Handshake is enabled
   The port is an authenticator
   Authentication Mode is Auto
   Port Control Type is Mac-based
   802.1X Multicast-trigger is enabled
   Guest VLAN: 0
   Max number of on-line users is 256
   EAPOL Packet: Tx 16331, Rx 102
   Sent EAP Request/Identity Packets : 16316
        EAP Request/Challenge Packets: 6
        EAP Success Packets: 4, Fail Packets: 5
   Received EAPOL Start Packets : 6
            EAPOL LogOff Packets: 2
            EAP Response/Identity Packets : 80
            EAP Response/Challenge Packets: 6
            Error Packets: 0
 1. Authenticated user : MAC address: 0002-0000-0011
   Controlled User(s) amount to 1
In addition, the port allows an additional user whose MAC address has an OUI among the specified OUIs to access the port. You can use the following command to view the related information:
<AC> display mac-address interface gigabitethernet 0/0/1
MAC ADDR        VLAN ID   STATE          PORT INDEX               AGING TIME(s)
1234-0300-0011  1         Learned        GigabitEthernet0/0/1    AGING
  ---  1 mac address(es) found  ---
Port Security Configuration for macAddressElseUserLoginSecure Mode
The client is connected to the switch through GigabitEthernet 0/0/1. The switch authenticates the client by the RADIUS server. If the authentication succeeds, the client is authorized to access the Internet.
l          Allow more than one MAC authenticated user to log on.
l          For 802.1x users, perform MAC authentication first and then, if MAC authentication fails, 802.1x authentication. Allow only one 802.1x user to log on.
l          For MAC-based authentication, allow usernames and passwords in self-defined formats. Set the total number of MAC authenticated users and 802.1x-authenticated users to 64.
l          Enable NTK to prevent frames from being sent to unknown MAC addresses.
Network diagram
See Figure 1-2.
The required RADIUS authentication/accounting configurations are the same as those in Port Security Configuration for userLoginWithOUI Mode.
<AC> system-view
# Configure a MAC authentication user, setting the user name and password to aaa and 123456 respectively.
[AC] mac-authentication user-name-format fixed account aaa password simple 123456
# Set the port security mode to macAddressElseUserLoginSecure.
[AC-GigabitEthernet0/0/1] port-security port-mode mac-else-userlogin-secure
# Set the NTK mode of the port to ntkonly.
[AC-GigabitEthernet0/0/1] port-security ntk-mode ntkonly
 Trap is disabled
 OUI value:
   Port mode is macAddressElseUserLoginSecure
   NeedToKnow mode is NeedToKnowOnly
Use the following command to view MAC authentication information:
<AC> display mac-authentication interface gigabitethernet 0/0/1
MAC address authentication is enabled.
 User name format is fixed account
 Fixed username:aaa
 Fixed password:123456
          Offline detect period is 300s
          Quiet period is 60s
          Server response timeout value is 100s
          The max allowed user number is 1024 per slot
          Current user number amounts to 0
          Current domain: not configured, use default domain
Silent MAC User info:
          MAC Addr         From Port                    Port Index
  Authenticate success: 3, failed: 1
  Current online user number is 3
    MAC Addr         Authenticate State           Auth Index
    1234-0300-0011   MAC_AUTHENTICATOR_SUCCESS     13
    1234-0300-0012   MAC_AUTHENTICATOR_SUCCESS     14
    1234-0300-0013   MAC_AUTHENTICATOR_SUCCESS     15
Use the following command to view 802.1x authentication information:
                EAD timeout:   30 m
   Guest VLAN: 0
            Error Packets: 0
In addition, since NTK is enabled, frames with unknown destination MAC addresses, multicast addresses, and broadcast addresses should be discarded.
Cannot Set the Port Security Mode
Symptom
Cannot set the port security mode.
 Error:When we change port-mode, we should first change it to noRestrictions, then change it to the other.
Analysis
For a port working in a port security mode other than noRestrictions, you cannot change the port security mode by using the port-security port-mode command directly.
Solution
Set the port security mode to noRestrictions first.
[AC-GigabitEthernet0/0/1] undo port-security port-mode
Cannot Configure Secure MAC Addresses
Symptom
Cannot configure secure MAC addresses.
[AC-GigabitEthernet0/0/1] port-security mac-address security 1-1-2 vlan 1
 Error:Can not operate security MAC address for current port mode is not autoLearn!
Analysis
No secure MAC address can be configured on a port operating in a port security mode other than autoLearn.
Solution
Cannot Change Port Security Mode When a User Is Online
Symptom
Port security mode cannot be changed when an 802.1x-authenticated or MAC authenticated user is online.
 Error:Cannot configure port-security for there is 802.1X user(s) on line on port GigabitEthernet0/0/1.
Analysis
Changing port security mode is not allowed when an 802.1x-authenticated or MAC authenticated user is online.
Solution
Use the cut command to forcibly disconnect the user from the port before changing the port security mode.
[AC-GigabitEthernet0/0/1] cut connection interface gigabitethernet 0/0/1
