10-可靠性命令参考
08-Track命令
本章节下载 08-Track命令  (322.17 KB)
08-Track命令
Track
1.1  Track配置命令
1.1.1  display track
display track命令用来显示Track项信息。
display track { track-entry-number | all [ negative | positive ] } [ brief ]
track-entry-number:显示指定Track项的信息。track-entry-number为Track项的序号,取值范围为1~1024。
all:显示所有Track项的信息。
negative:显示Negative状态的Track项的信息。
positive:显示Positive状态的Track项的信息。
brief:显示Track项的简要信息。
# 显示所有Track项的信息。‌
<Sysname> display track all
Track ID: 1
  State: Positive
  Duration: 0 days 0 hours 0 minutes 7 seconds
  Tracked object type: NQA
  Notification delay: Positive 20, Negative 30 (in seconds)
  Tracked object:
    NQA entry: admin test
    Reaction: 10
    Remote IP/URL: --
    Local IP: --
    Interface: --
Track ID: 2
  State: NotReady
  Tracked object type: BFD echo
  Tracked object:
    BFD session mode: Echo
    Outgoing interface: Vlan-interface2
    VPN instance name: --
    Remote IP: 192.168.40.1
    Local IP: 192.168.40.2
Track ID: 3
  State: Negative
  Tracked object type: BFD ctrl
  Tracked object:
    BFD session mode: Ctrl
    Remote IPv6: 1000::1
    Local IPv6: 1000::2
Track ID: 4
  State: Negative
  Tracked object type: interface
  Tracked object:
    Interface:  Vlan-interface3
    Protocol: IPv4
Track ID: 6
  State: Positive
  Tracked object type: Route
  Tracked object:
    IP route: 0.0.0.0/0 reachability
    Protocol: Static
    Nexthop interface : Vlan-Interface4
Track ID: 7
  State: Positive
  Tracked object type: LLDP
  Tracked object:
    LLDP interface: Vlan-interface4
Track ID: 8
  State: Positive
  Tracked object type: Percentage threshold list
  Threshold: Positive 40, Negative 30
  Percentage of positive objects: 50%
  Tracked objects:
    Object 1: Positive
    Object 3: Negative
Track ID: 9
  State: Positive
  Tracked object type: Weight threshold list
  Threshold: Positive 50, Negative 30
  Positive weight/total weight: 50/80
  Tracked objects:
    Object 1: Positive, Weight: 50
    Object 3: Negative, Weight: 30
Track ID: 10
  State: Positive
  Tracked object type: Boolean and list
  Tracked objects:
    Object 1: Positive
    Object 3: Negative(not)
    Object 10: NotReady(not)
Track ID: 11
  State: Negative
  Duration: 0 days 0 hours 44 minutes 8 seconds
  Notification delay: Positive 0, Negative 0 (in seconds)
  Tracked object:
    IP route: 20.0.0.0/24 ecmp-number greater-equal 2 less-equal 3
    Protocol: N/A
    Nexthop interface: N/A
# 显示所有Negative状态的Track项的简要信息。‌
<Sysname> display track all negative brief
ID   Status   Type      Remote IP/URL   Local IP        Interface
1    Negative Interface --              --              Vlan2
10   Negative Interface --              --              Vlan3
12   Negative BFD Echo  1000:1000:1000: 1000:1000:1000: Vlan2
                        1000:1000::1    1000:1000::2
13   Negative List      --              --              --
表1-1 display track命令输出信息描述
Track ID
Track项序号
ID
Track项序号
Track项的状态,取值包括:
·     Positive:表示状态正常
·     Positive (notify XX seconds later):表示Track项的状态已经变成了Positive,但要等XX秒后再通知引用该Track项的应用模块Track项的状态变化。只有配置了Track项状态延迟通告功能,且Track项被业务模块引用后,才支持该取值
·     NotReady:表示无效值
·     Negative:表示状态异常
·     Negative (notify XX seconds later):表示Track项的状态已经变成了Negative,但要等XX秒后再通知引用该Track项的应用模块Track项的状态变化。只有配置了Track项状态延迟通告功能,且Track项被业务模块引用后,才支持该取值
Duration
Track项处于当前状态的持续时间
Track项的关联类型,本信息只在配置命令display track brief时显示,取值包括:
·     BFD ctrl:表示控制会话的BFD类型
·     BFD echo:表示Echo会话的BFD类型
·     BFD static:表示BFD静态会话类型
·     Interface:表示接口类型
·     Route:表示路由类型
·     NQA:表示NQA类型
·     LLDP:表示LLDP类型
·     M-LAG_MAD_STATUS:表示M-LAG MAD类型
·     List:表示列表类型
·     PTP:表示PTP类型
Tracked object type
Track关联探测项类型,取值包括:
·     Interface:表示接口类型
·     Route:表示路由类型。ecmp-number表示监测等价路由数目;greater-equal表示大于等于;less-equal表示小于等于
·     LLDP:表示LLDP类型
·     NQA:表示NQA类型
·     Boolean and list:表示布尔与列表类型
·     Boolean or list:表示布尔或列表类型
·     Percentage threshold list:表示比例列表类型
·     Weight threshold list:表示权重列表类型
·     PTP:表示PTP类型
通知延迟:
·     Track项状态变为Positive后,延迟20秒通知应用模块
·     Track项状态变为Negative后,延迟30秒通知应用模块
门限值,包括Positive状态门限值和Negative状态门限值
只有比例列表和权重列表类型的Track项才显示该字段
关联列表中所有Positive对象所占比例,只有比例列表类型的Track项才显示该字段
关联列表中所有Positive状态对象的权重之和/所有对象的权重值,只有权重列表类型的Track项才显示该字段
Tracked object
Track项关联的对象
PTP object type
Track项关联的PTP联动项类型,取值包括:
·     source-state:表示Track项关联PTP时钟源状态
·     time-state:表示Track项关联PTP时间状态
Instance ID
Track项关联的PTP实例的ID
NQA entry
Track项关联的NQA测试组
Reaction
Track项关联的联动项
BFD session mode
BFD会话的模式
Outgoing interface
出接口
VPN instance name
VPN实例的名称。如果属于公网,则显示为“--”
Remote IP/URL
远端IP/IPv6地址或URL路径,不存在时则显示“--”
Local IP
本地IP/IPv6地址,不存在时则显示“--”
Track项关联的接口,不存在时则显示“--”
Protocol
监视接口的链路状态或网络层协议状态,取值包括:
·     None:监视接口的链路状态
·     IPv4:监视三层接口的IPv4协议状态
·     IPv6:监视三层接口的IPv6协议状态
CFD service instance
(暂不支持)CFD服务实例的编号
MEP ID
(暂不支持)CFD MEP的编号
IP route
Track项关联的路由
VPN instance name
Track项关联路由的VPN实例名称,如果关联的是公网的路由,则显示为“--”
Protocol
关联路由的协议类型,如果路由不存在,则显示为“N/A”
Nexthop interface
关联路由的下一跳,如果路由不存在,则显示为“N/A”
LLDP interface
监视LLDP邻居状态的接口
Tracked objects:
  Object 1: Positive
列表型Track项下绑定的Track项,包括其状态值和权重值。仅列表型Track项支持显示该字段。Object n中的n表示Track项的序号。如果关联类型不是权重列表,则不显示权重。(not)表示其是反状态。状态的取值包括:
·     Positive:表示状态正常
·     NotReady:表示无效值
·     Negative:表示状态异常
Tracked by:
  Track-list 6
Track项被列表型Track项绑定,作为列表型Track项的对象时,显示该字段。Track-list n中的n表示列表型Track项的序号
1.1.2  object
object命令用来向列表中添加与单个监测项联动的Track项。
undo object命令用来删除与单个监测项联动的Track项。
object track-entry-number [ not ] [ weight weight ]
undo object track-entry-number
列表中不存在与单个监测项联动的Track项。
Track视图
track-entry-number:Track项序号,取值范围为1~1024。
not:Track项的反状态,例如:如果Track项的状态为Positive,则其反状态为Negative。该参数只在与布尔类型列表的Track视图下可配。
weight weight:Track项的权重,取值范围为1~255该参数只在权重类型列表Track视图下可配,缺省权重值为10。
·     Track视图中不能添加与Track视图序号相同的Track对象。
·     一个列表类型的track项中最多只能添加16个Track对象。
·     Track项不能互相关联形成环路。例如:如果Track项1中添加Track对象2,Track项2中添加Track对象3,那么Track项3中不能再添加Track对象1。
# 创建与类型的布尔列表关联的Track项100,并进入Track视图。添加与单个监测对象联动的Track对象1,添加与单个监测对象联动的Track对象2的反状态。
[Sysname] track 100 list boolean and
[Sysname-track-100] object 1
[Sysname-track-100] object 2 not
·     track list boolean
·     track list threshold percentage
·     track list threshold weight
1.1.3  threshold percentage
threshold percentage命令用来在比例型列表Track项中配置状态门限值。
undo threshold percentage命令用来恢复缺省情况。
threshold percentage { negative negative-threshold | positive positive-threshold } *
Negative状态门限值为0%,Positive状态门限值为1%。
Track视图
negative negative-threshold:指定Track项状态变为Negative所要达到的门限,以百分数形式表示。negative-threshold表示Negative门限值,取值范围为0~99。当关联列表中Positive对象所占比例小于或等于Negative参数指定值时,Track项状态变为Negative。
positive positive-threshold:指定Track项状态变为Positive所要达到的门限,以百分数形式表示。positive-threshold表示Positive门限值,取值范围为1~100。当关联列表中Positive对象所占比例大于或等于Positive参数指定值时,Track项状态变为Positive。配置的Positive门限值需大于Negative门限值。
工作机制
Track项的状态由Track列表中Positive对象所占比例和threshold percentage命令配置的门限值的大小决定。
·     当列表中Positive对象所占百分比大于或等于Positive门限值时,Track项状态变为Positive。
·     当列表中Positive对象所占百分比小于或等于Negative门限值时,Track项状态变为Negative。
·     当列表中Positive对象所占百分比小于Positive门限值且大于Negative门限值时,Track项状态保持不变。
注意事项
该命令只适用于比例类型列表Track项。
配置的Positive门限值需大于Negative门限值。如果不指定positive参数,仅配置negative参数,则negative参数取值只能为0,等效于缺省情况。
# 创建和比例类型列表关联的Track项1,并进入Track视图。配置Track项1的Negative门限值为30%,Positive门限值为50%。
[Sysname] track 1 list threshold percentage
[Sysname-track-1] threshold percentage negative 30 positive 50
1.1.4  threshold weight
threshold weight命令用来在权重型列表Track项中配置状态门限值权重。
undo threshold weight命令用来恢复缺省情况。
threshold weight { negative negative-threshold | positive positive-threshold } *
Negative门限值权重为0,Positive门限值权重为1。
Track视图
negative negative-threshold:指定Track项状态变为Negative所要达到的门限值,以权重形式表示。negative-threshold表示Negative门限值,取值范围为0~254。当关联列表中当处于Positive的监测项的权重之和小于或等于Negative参数指定值时,Track项状态变为Negative。
positive positive-threshold:指定Track项状态变为Positive所要达到的门限值,以权重形式表示。positive-threshold表示Positive门限值,取值范围为1~255。当关联列表中处于Positive的监测项的权重之和大于或等于Positive参数指定值时,Track项状态变为Positive。配置的Positive权重门限需大于Negative权重门限。
工作机制
Track项的状态由Track列表中Positive对象的总权重(Track列表所有处于Positive状态的Track项的权重之和)和threshold weight命令配置的权重值的大小决定。每个加入列表的Track对象都拥有一个权重值:
·     当Track列表中Positive对象的总权重大于或等于Positive门限值时,Track项状态变为Positive。
·     当Track列表中Positive对象的总权重小于或等于Negative门限值时,Track项状态变为Negative。
·     当Track列表中Positive对象的总权重小于Positive门限值且大于Negative门限值时,Track项状态保持不变。
注意事项
该命令只适用于权重类型列表Track项。
# 创建和权重类型列表关联的Track项1,并进入Track视图。设置Track项1的Negative门限值权重为30,Positive门限值权重为50。
[Sysname] track 1 list threshold weight
[Sysname-track-1] threshold weight negative 30 positive 50
1.1.5  track bfd ctrl
track bfd ctrl命令用来创建和控制报文方式的BFD会话关联的Track项,并进入Track视图。如果指定的Track项已经存在,则直接进入Track视图。
undo track命令用来删除指定的Track项及Track视图下所有配置。
track track-entry-number bfd ctrl [ interface interface-type interface-number | vpn-instance vpn-instance-name ] remote { ip remote-ipv4-address | ipv6 remote-ipv6-address } local { ip local-ipv4-address | ipv6 local-ipv6-address }
undo track track-entry-number
不存在Track项。
track-entry-number:Track项的序号,取值范围为1~1024。
interface interface-type interface-number:指定BFD会话所在的本地接口。interface-type interface-number表示接口类型和接口编号。如果指定本参数,将对以该接口为出接口、以remote ip/remote ipv6为下一跳的链路进行单跳检测,否则进行多跳检测。
vpn-instance vpn-instance-name:指定BFD会话所属的VPN实例,vpn-instance-name表示MPLS L3VPN的VPN实例名称,为1~31个字符的字符串,区分大小写。如果未指定本参数,表示BFD会话属于公网实例。
remote:BFD会话探测的远端地址。
ip remote-ipv4-address:远端IPv4地址,该地址为直连接口的地址。
ipv6 remote-ipv6-address:远端IPv6地址,该地址为直连接口的地址。
local:BFD会话探测的本地地址。
ip local-ipv4-address:本地IPv4地址,该地址为直连接口的地址。
ipv6 local-ipv6-address:本地IPv6地址,该地址为直连接口的地址。
创建Track项时,必须指定Track项的关联类型。可以通过track track-entry-number进入已创建的Track项的视图,而无需指定关联类型。
不能通过重复执行本命令修改Track项关联的内容。如需修改Track项关联的内容,请先通过undo track命令删除Track项,再执行track bfd ctrl命令。
配置Track与BFD联动时,VRRP备份组的虚拟IP地址不能作为BFD会话探测的本地地址和远端地址。
# 创建与控制报文方式的BFD会话关联的Track项1,并进入Track视图。BFD会话使用控制报文进行探测,BFD会话所在的本地接口为VLAN接口2,远端IP地址为192.168.1.1,本地IP地址为192.168.1.2。‌
[Sysname] track 1 bfd ctrl interface vlan-interface 2 remote ip 192.168.1.1 local ip 192.168.1.2
[Sysname-track-1]
·     delay
·     display track
1.1.6  track bfd echo
track bfd echo命令用来创建和Echo报文方式的BFD会话关联的Track项,并进入Track视图。如果指定的Track项已经存在,则直接进入Track视图。
track track-entry-number bfd echo interface interface-type interface-number remote { ip remote-ipv4-address | ipv6 remote-ipv6-address } local { ip local-ipv4-address | ipv6 local-ipv6-address } [ ignore-rx-interface ]
不存在Track项。
interface interface-type interface-number:BFD会话报文的出接口。interface-type interface-number为接口类型和接口编号。
local:BFD会话探测的本地地址。
ignore-rx-interface:表示不检查Echo响应报文的入接口和Echo报文的出接口是否一致。缺省情况下,设备会检查Echo响应报文的入接口,如果Echo响应报文的入接口和Echo报文的出接口不同,则设备会认为该Echo响应报文非法,从而丢弃该Echo响应报文,BFD会话Down。当BFD会话存在多条报文通路时,建议配置本参数,以免设备发送Echo报文的接口和接收echo响应报文的接口不一致时,影响BFD会话的状态。
不能通过重复执行本命令修改Track项关联的内容。如需修改Track项关联的内容,请先通过undo track命令删除Track项,再执行track bfd echo命令。
如果创建不同Track项(即track-entry-number取值不同),但关联的BFD会话相同(interfaceremotelocal参数取值均相同时,表示同一BFD会话),则要求ignore-rx-interface参数配置也必须一致,否则,后配置Track项会创建失败。
# 创建与Echo报文方式的BFD会话关联的Track项1,并进入Track视图。BFD会话使用Echo报文进行探测,出接口为VLAN接口2,远端IP地址为1.1.1.1,本地IP地址为1.1.1.2。‌
[Sysname] track 1 bfd echo interface vlan-interface 2 remote ip 1.1.1.1 local ip 1.1.1.2
[Sysname-track-1]
·     delay
·     display track
1.1.7  track bfd static
track bfd static命令用来创建和静态BFD会话关联的Track项,并进入Track视图。如果指定的Track项已经存在,则直接进入Track视图。
track track-entry-number bfd static bfd-session-name
不存在Track项。
bfd-session-name:BFD会话名称,为1~64个字符的字符串,区分大小写。
不能通过重复执行本命令修改Track项关联的内容。如需修改Track项关联的内容,请先通过undo track命令删除Track项,再执行track bfd static命令。
# 创建与静态BFD会话aa关联的Track项1,并进入Track视图。
[Sysname] track 1 bfd static aa
[Sysname-track-1]
·     delay
·     display track
1.1.8  track mlag-mad-status
track mlag-mad-status命令用来创建与M-LAG MAD关联的Track项,并进入Track视图。如果指定的Track项已经存在,则直接进入Track视图。
track track-entry-number mlag-mad-status
不存在Track项。
在M-LAG组网中,如果peer-link链路故障,M-LAG提供MAD(Multi-Active Detection,多Active检测)机制,将设备上部分接口置为M-LAG MAD DOWN状态,不允许此类接口转发流量,避免流量错误转发,从而尽量减少对业务影响。当peer-link链路故障恢复后,在延迟恢复时间到达时,将处于M-LAG MAD DOWN状态的接口将恢复为up状态。关于M-LAG MAD的详细描述,请参见“二层技术-以太网交换”中的“M-LAG”。
配置本命令后,Track项会关联M-LAG MAD DOWN事件和M-LAG MAD DOWN恢复事件。
·     当设备上部分接口被置为M-LAG MAD DOWN状态时,Track项的状态变成Negtive。
·     当处于M-LAG MAD DOWN状态的接口恢复为up状态时,Track项的状态变成Positive。
·     未触发或未收到M-LAG MAD DOWN事件和M-LAG MAD DOWN恢复事件时,Track项的状态为NotReady。
创建Track项时,必须指定Track项的关联类型。可以通过track track-entry-number进入已创建的Track视图,而无需指定关联类型。
不能通过重复执行本命令修改Track项关联的内容。如需修改Track项关联的内容,请先通过undo track命令删除Track项,再执行track mlag-mad-status命令。
# 创建与M-LAG联动的M-LAG MAD关联的Track项1,并进入Track视图。
[Sysname] track 1 mlag-mad-status
[Sysname-track-1]
·     delay
·     display track
1.1.9  track interface
track interface命令用来创建与接口链路状态关联的Track项,并进入Track视图。如果指定的Track项已经存在,则直接进入Track视图。
track track-entry-number interface interface-type interface-number
不存在Track项。
interface-type interface-number:监视的接口类型和接口编号。
创建与接口链路状态关联的Track项后,接口的链路状态为up时,Track项的状态为Positive;接口的链路状态为down时,Track项的状态为Negative。通过display ip interface brief命令可以查看接口的链路状态。
不能通过重复执行本命令修改Track项关联的内容。如需修改Track项关联的内容,请先通过undo track命令删除Track项,再执行track interface命令。
# 创建与VLAN接口10的链路状态关联的Track项1,并进入Track视图。‌
[Sysname] track 1 interface vlan-interface 10
[Sysname-track-1]
·     delay
·     display ip interface brief(三层技术-IP业务命令参考/IP地址)
·     display track
1.1.10  track interface physical
track interface physical命令用来创建与接口物理状态关联的Track项,并进入Track视图。如果指定的Track项已经存在,则直接进入Track视图。
track track-entry-number interface interface-type interface-number physical
不存在Track项。
不能通过重复执行本命令修改Track项关联的内容。如需修改Track项关联的内容,请先通过undo track命令删除Track项,再执行track interface physical命令。
# 创建与VLAN接口2的物理状态关联的Track项1,并进入Track视图。‌
[Sysname] track 1 interface vlan-interface 2 physical
[Sysname-track-1]
·     delay
·     display track
1.1.11  track interface protocol
track interface protocol命令用来创建与接口网络层协议状态关联的Track项,并进入Track视图。如果指定的Track项已经存在,则直接进入Track视图。
track track-entry-number interface interface-type interface-number protocol { ipv4 | ipv6 }
不存在Track项。
ipv4:监视接口的IPv4协议状态。接口的IPv4协议状态为up时,Track项的状态为Positive;接口的IPv4协议状态为down时,Track项的状态为Negative。通过display ip interface brief命令可以查看接口的IPv4协议状态。
ipv6:监视接口的IPv6协议状态。接口的IPv6协议状态为up时,Track项的状态为Positive;接口的IPv6协议状态为down时,Track项的状态为Negative。通过display ipv6 interface brief命令可以查看接口的IPv6协议状态。
不能通过重复执行本命令修改Track项关联的内容。如需修改Track项关联的内容,请先通过undo track命令删除Track项,再执行track interface protocol命令。
# 创建与VLAN接口2的IPv4协议状态关联的Track项1,并进入Track视图。‌
[Sysname] track 1 interface vlan-interface 2 protocol ipv4
[Sysname-track-1]
·     delay
·     display ipv6 interface brief(三层技术-IP业务命令参考/IPv6基础)
·     display track
1.1.12  track ip route
track ip route创建与路由管理关联的Track项,并进入Track视图。如果指定的Track项已经存在,则直接进入Track视图。
track track-entry-number ip route [ vpn-instance vpn-instance-name ] ip-address { mask-length | mask } { ecmp-number { greater-equal min-ecmp-number | less-equal max-ecmp-number } * | reachability }
不存在Track项。
vpn-instance vpn-instance-name:在指定VPN实例中创建和路由条目关联的Track项。vpn-instance-name表示MPLS L3VPN的VPN实例名称,为1~31个字符的字符串,区分大小写。如果未指定本参数,则表示在公网中创建和路由关联的Track项。
ip-address:路由条目中的IP地址,点分十进制格式。
mask-length/mask:IP地址掩码长度/掩码,以整数形式表示掩码长度或以点分十进制格式表示掩码。当用整数形式时,取值范围为0~32。
ecmp-number { greater-equal min-ecmp-number | less-equal max-ecmp-number } *:监测等价路由数目。
·     greater-equal表示大于等于,min-ecmp-number表示指定的最小等价路由数目。取值范围为1~128。
·     less-equal表示小于等于,max-ecmp-number表示指定的最大等价路由数目。取值范围为1~128。
reachability:监测路由可达。
不能通过重复执行本命令修改Track项关联的内容。如需修改Track项关联的内容,请先通过undo track命令删除Track项,再执行track ip route reachability命令。
当发生主备设备倒换或者RIB进程倒换后,如果路由协议进程平滑重启一直未结束,并且此时路由条目发生变化,路由管理不会立刻向Track模块通知路由变化信息,通过配置路由管理的不间断路由功能,可以解决上述问题。
# 创建与路由管理关联的Track项1,并进入Track视图,路由条目目的地址10.1.1.0,掩码长度为24。
[Sysname] track 1 ip route 10.1.1.0 24 reachability
[Sysname-track-1]
# 创建与路由管理关联的Track项2并进入Track视图,路由条目目的地址10.1.1.0,掩码长度为24,监测的等价路由数目为大于等于2、小于等于3。
[Sysname] track 2 ip route 10.1.1.0 24 ecmp-number greater-equal 2 less-equal 3
[Sysname-track-2]
·     delay
·     display ip routing-table(三层技术-IP路由命令参考/IP路由基础)
·     display track
·     ecmp mode(三层技术-IP路由命令参考/IP路由基础)
1.1.13  track list boolean
track list boolean命令用来创建布尔类型列表Track项,并进入Track视图。如果指定的Track项已经存在,则直接进入Track视图。
track track-entry-number list boolean { and | or }
不存在Track项。
and:使用布尔与运算决定Track项的状态。
or:使用布尔或运算决定Track项的状态。
本命令创建布尔类型列表Track项,Track项的状态由Track列表中对象状态的布尔运算结果决定,共有两种类型的布尔列表:
·     布尔与列表类型:基于列表中对象状态的布尔与运算结果决定Track项的状态。如果关联列表中的所有对象的状态都是Positive,那么此Track项的状态为Positive;如果有一个或多个对象的状态为Negative,那么此Track项的状态为Negative。
·     布尔或列表类型:基于列表中对象状态的布尔或运算结果决定Track项的状态。如果关联列表中至少有一个对象的状态是Positive,那么此Track项的状态为Positive;如果所有的对象的状态都是Negative,那么此Track项的状态为Negative。
不能通过重复执行本命令修改Track项的关联类型。如需修改Track项的关联类型,请先通过undo track命令删除Track项,再执行track list boolean命令。
# 创建布尔类型列表Track项101,并进入Track视图。Track项101使用布尔或运算。
[Sysname] track 101 list boolean or
[Sysname-track-101]
·     delay
·     object
1.1.14  track list threshold percentage
track list threshold percentage命令用来创建比例类型列表Track项,并进入Track视图。如果指定的Track项已经存在,则直接进入Track视图。
track track-entry-number list threshold percentage
不存在Track项。
本命令创建比例类型列表Track项,Track项的状态由Track列表中Positive对象/所有对象的总比例和threshold percentage命令配置的门限值的大小决定。
不能通过重复执行本命令修改Track项的关联类型。如需修改Track项的关联类型,请先通过undo track命令删除Track项,再执行track list threshold percentage命令。
# 创建比例类型列表Track项101,并进入Track视图。
[Sysname] track 101 list threshold percentage
[Sysname-track-101]
·     delay
·     object
·     threshold percentage
1.1.15  track list threshold weight
track list threshold weight命令用来创建权重类型列表Track项,并进入Track视图。如果指定的Track项已经存在,则直接进入Track视图。
track track-entry-number list threshold weight
不存在Track项。
本命令创建权重类型列表Track项,Track项的状态由Track列表中Positive对象的总权重和threshold weight命令配置的权重值的大小决定。
不能通过重复执行本命令修改Track项的关联类型。如需修改Track项的关联类型,请先通过undo track命令删除Track项,再执行track list threshold weight命令。
# 创建权重类型列表Track项101,并进入Track视图。
[Sysname] track 101 list threshold weight
[Sysname-track-101]
·     delay
·     object
·     threshold weight
1.1.16  track lldp neighbor
track lldp neighbor 命令用来创建与接口的LLDP邻居状态关联的Track项,并进入Track视图。如果指定的Track项已经存在,则直接进入Track视图。
track track-entry-number lldp neighbor interface interface-type interface-number
不存在Track项。
interface interface-type interface-number:监视LLDP邻居状态的接口,interface-type interface-number为接口类型和接口编号。
不能通过重复执行本命令修改Track项关联的内容。如需修改Track项关联的内容,请先通过undo track命令删除Track项,再执行track lldp neighbor命令。
# 创建与接口HundredGigE1/1/1的LLDP邻居状态关联的Track项,并进入Track视图。
[Sysname] track 1 lldp neighbor interface hundredgige 1/1/1
[Sysname-track-1]
·     delay
·     display track
1.1.17  track nqa
track nqa命令用来创建与NQA测试组中指定联动项关联的Track项,并进入Track视图。如果指定的Track项已经存在,则直接进入Track视图。
track track-entry-number nqa entry admin-name operation-tag reaction item-number
不存在Track项。
entry admin-name operation-tag:指定与Track项关联的NQA测试组。其中,admin-name为创建NQA测试组的管理员的名字,为1~32个字符的字符串,不区分大小写;operation-tag为NQA测试操作的标签,为1~32个字符的字符串,不区分大小写。
reaction item-number:指定与Track项关联的联动项。其中,item-number为联动项的序号,取值范围为1~10。
不能通过重复执行本命令修改Track项关联的内容。如需修改Track项关联的内容,请先通过undo track命令删除Track项,再执行track nqa命令。
# 创建与NQA测试组(admin–test)中联动项3关联的Track项1,并进入Track视图。
[Sysname] track 1 nqa entry admin test reaction 3
[Sysname-track-1]
·     delay
·     display track
1.1.18  track ptp
track ptp命令用来创建与PTP模块联动的Track项,并进入Track视图。如果指定的Track项已经存在,则直接进入Track视图。
track track-entry-number ptp { source-state [ instance ptp-instance-id ] | time-state }
不存在Track项。
source-state [ instance ptp-instance-id ]:在创建和指定PTP实例中时钟源状态关联的Track项。ptp-instance-id表示PTP实例的编号,取值范围为1~3。不指定该参数时,表示PTP实例0。
time-state:创建和PTP时间状态关联的Track项。
应用场景
配置Track与PTP联动,然后再将该Track项和EAA策略联动,可实现自动监控PTP时钟源和PTP时钟的状态,使得设备在PTP正常工作时,使用PTP同步系统时钟;当PTP不能正常工作时,使用NTP同步系统时钟。
工作机制
配置本命令后,设备会创建和PTP联动的Track项,Track项的状态由指定PTP联动项的状态决定。设备支持以下两种PTP联动项:
·     时钟源状态联动项:基于指定实例中的时钟源状态决定Track项的状态。
¡     如果指定的PTP实例中PTP时钟源存在(即设备上存在Slave接口,本设备不是组网的GM时钟),那么此Track项的状态为Positive;
¡     如果指定的PTP实例中PTP时钟源丢失(即本设备成为组网的GM时钟),那么此Track项的状态为Negative。
·     PTP时间状态联动项:基于PTP时间状态决定Track项的状态。
¡     如果PTP时间状态为Lock(锁定状态),那么此Track项的状态为Positive;
¡     如果PTP时间状态为Unlock(非锁定状态),那么此Track项的状态为Negative。
注意事项
不能通过重复执行本命令修改Track项关联的内容。如需修改Track项关联的内容,请先通过undo track命令删除Track项,再执行track ptp命令。
# 创建与PTP实例1时钟源状态关联的Track项1,并进入Track视图。
[Sysname] track 1 ptp source-state instance 1
[Sysname-track-1]
·     delay
·     display track
