06-IP组播命令参考
12-IPv6组播路由与转发命令
本章节下载 12-IPv6组播路由与转发命令  (511.10 KB)
12-IPv6组播路由与转发命令
  录
1 IPv6组播路由与转发
1.1 IPv6组播路由与转发配置命令
1.1.1 acl (IPv6组播流策略视图)
1.1.2 bandwidth (IPv6组播流策略视图)
1.1.3 delete ipv6 rpf-route-static
1.1.4 display ipv6 mrib interface
1.1.5 display ipv6 multicast boundary
1.1.6 display ipv6 multicast fast-forwarding cache
1.1.7 display ipv6 multicast flow-policy info
1.1.8 display ipv6 multicast forwarding df-info
1.1.9 display ipv6 multicast forwarding event
1.1.10 display ipv6 multicast forwarding-table
1.1.11 display ipv6 multicast forwarding-table capability
1.1.12 display ipv6 multicast forwarding-table df-list
1.1.13 display ipv6 multicast replication-share info
1.1.14 display ipv6 multicast routing-table
1.1.15 display ipv6 multicast routing-table static
1.1.16 display ipv6 multicast rpf-info
1.1.17 flow-policy (IPv6 MRIB view)
1.1.18 flow-ucmp unicast reserve-bandwidth (IPv6 MRIB视图)
1.1.19 ipv6 multicast boundary
1.1.20 ipv6 multicast cpu-forwarding max-copy-count
1.1.21 ipv6 multicast flow-ucmp unicast reserve-bandwidth
1.1.22 ipv6 multicast forwarding-table cache-unknown per-entry
1.1.23 ipv6 multicast forwarding-table cache-unknown total
1.1.24 ipv6 multicast frr mode
1.1.25 ipv6 multicast frr monitor cycle
1.1.26 ipv6 multicast frr wtr
1.1.27 ipv6 multicast replication-share enable
1.1.28 ipv6 multicast routing
1.1.29 ipv6 rpf-route-static
1.1.30 load-splitting (IPv6 MRIB view)
1.1.31 longest-match (IPv6 MRIB view)
1.1.32 reset ipv6 multicast fast-forwarding cache
1.1.33 reset ipv6 multicast forwarding event
1.1.34 reset ipv6 multicast forwarding-table
1.1.35 reset ipv6 multicast routing-table
1 IPv6组播路由与转发
1.1  IPv6组播路由与转发配置命令
acl命令用来配置IPv6组播流策略生效的组播组范围。
undo acl命令用来恢复缺省情况。
acl { ipv6-acl-number | name ipv6-acl-name }
undo acl
未配置IPv6组播流策略生效的组播组范围,即IPv6组播流策略对所有的组播组均不生效。
IPv6组播流策略视图
ipv6-acl-number:指定IPv6基本或者高级ACL的编号,取值范围为2000~3999。当指定的ACL不存在或ACL中未配置有效规则,则组播流策略对所有的组播组均不生效。
name ipv6-acl-name:指定IPv6基本或者高级ACL的名称,为1~63个字符的字符串,不区分大小写,必须以英文字母a~z或A~Z开头。为避免混淆,ACL的名称不允许使用英文单词all。当指定的ACL不存在或ACL中未配置有效规则,则组播流策略对所有的组播组均不生效。
IPv6缺省组播流策略视图下不支持配置本命令。
通过本命令可以配置IPv6组播流策略生效的组播组范围。若某个组播组能够匹配ACL规则中permit的组播组地址,则认为该组播组对应的组播流的带宽为IPv6组播流策略视图下bandwidth命令配置的值。
对于基本ACL,本命令指定ACL规则中的source参数用来指定匹配该组播流策略的组播组地址范围,并且该规则中除sourcetime-range以外的其它可选参数都将被忽略。
对于高级ACL,本命令指定ACL规则中的source参数用来指定匹配该组播流策略的组播源地址范围,destination参数用来指定组播组地址范围,并且该规则中除sourcedestinationtime-range以外的其它可选参数都将被忽略。
在引用的ACL中,若某规则指定了vpn-instance参数,则该规则将不生效。
多次执行本命令,最后一次执行的命令生效。
# 配置名称为abc的IPv6组播流策略对IPv6组播组地址在FF03::101/128范围内的组播流生效。
[Sysname] acl ipv6 basic 2000
[Sysname-acl-ipv6-basic-2000] rule permit source ff03::101 128
[Sysname] ipv6 multicast routing
[Sysname-mrib6] flow-policy name abc
[Sysname-mrib6-flow-policy-abc] acl 2000
·     flow-policy (IPv6 MRIB view)
bandwidth命令用来配置IPv6组播流的预计带宽。
undo bandwidth命令用来恢复缺省情况。
bandwidth bandwidth { gbps | kbps | mbps }
undo bandwidth
未配置IPv6组播流的预计带宽,预计带宽为0。
IPv6组播流策略视图
bandwidth:IPv6组播流的预计带宽,取值范围为1~10000。
gbps:预计带宽的单位为Gbps。
kbps:预计带宽的单位为Kbps。
mbps:预计带宽的单位为Mbps。
IPv6组播流预计带宽的选择过程如下:
(1)     若IPv6组播流量的组播组与某个组播流策略中的ACL规则匹配,则该组播流预计带宽值为IPv6组播流策略视图下的bandwidth命令配置的值。
(2)     若IPv6组播流量的组播组没有匹配到任何组播流策略的ACL,则该组播流预计带宽值为IPv6缺省组播流策略视图下的bandwidth命令配置的值。
(3)     若IPv6缺省组播流策略视图下也未配置组播流预计带宽,则认为组播流预计带宽为0。
#在IPv6组播流策略abc下配置预计带宽为200Mbps。
[Sysname-mrib6-flow-policy-abc] bandwidth 200 mbps
delete ipv6 rpf-route-static命令用来删除所有IPv6组播静态路由。
delete ipv6 rpf-route-static [ vpn-instance vpn-instance-name ]
vpn-instance vpn-instance-name:指定VPN实例,vpn-instance-name表示MPLS L3VPN的VPN实例名称,为1~31个字符的字符串,区分大小写。如果未指定本参数,表示指定公网。
本命令用来删除所有的IPv6组播静态路由,而undo ipv6 rpf-route-static命令则用来删除指定的IPv6组播静态路由。
# 删除公网中的所有IPv6组播静态路由。
[Sysname] delete ipv6 rpf-route-static
This will erase all ipv6 multicast static routes and their configurations, you must reconfigure all ipv6 static routes.
Are you sure?[Y/N]:y
·     ipv6 rpf-route-static
display ipv6 mrib interface命令用来显示IPv6 MRIB(Multicast Routing Information Base,组播路由信息库)维护的接口信息。
display ipv6 mrib [ vpn-instance vpn-instance-name ] interface [ interface-type interface-number ]
vpn-instance vpn-instance-name:显示指定VPN实例的信息,vpn-instance-name表示MPLS L3VPN的VPN实例名称,为1~31个字符的字符串,区分大小写。如果未指定本参数,将显示公网实例的信息。
interface-type interface-number:显示指定接口上IPv6 MRIB维护的接口信息。如果未指定本参数,将显示所有接口上IPv6 MRIB维护的接口信息。
# 显示公网实例接口上IPv6 MRIB维护的接口信息。‌
<Sysname> display ipv6 mrib interface
 Interface: Vlan-interface1
     Index: 0x00004444
     Current state: up
     MTU: 1500
     Type: BROADCAST
     Protocol: PIM-DM
     PIM protocol state: Enabled
     Address list:
          1. Local address : FE80:7:11::1/10
             Remote address: ::
             Reference     : 1
             State         : NORMAL
             Flags         : 0x0
表1-1 display ipv6 mrib interface命令显示信息描述表
接口的名称
Index
接口的索引号
Current state
接口的状态,包括up和down
MTU
MTU(Maximum Transmission Unit,最大传输单元)值
接口的类型,包括:
·     BROADCAST:表示广播链路接口
·     LOOP:表示LoopBack接口
·     REGISTER:表示注册接口
·     MTUNNEL:表示组播隧道接口
如果接口为NULL0接口,则该字段显示为空
Protocol
接口的协议类型标记,包括PIM-DM、PIM-SM、MLD和PROXY
PIM protocol state
IPv6 PIM协议的使能状态,包括:
·     Enabled:表示使能
·     Disabled:表示关闭
Address list
接口地址列表
Local address
本端的地址
Remote address
远端的地址(仅Vlink类型接口有效)
Reference
地址被引用的次数
接口地址的状态,包括NORMAL和DEL
Flags
接口属性:
·     0x0:接口处于正常状态
·     0x1:接口地址正在被删除
display ipv6 multicast boundary命令用来显示IPv6组播边界的信息。
display ipv6 multicast [ vpn-instance vpn-instance-name ] boundary { group [ ipv6-group-address [ prefix-length ] ] | scope [ scope-id ] } [ interface interface-type interface-number ]
group:显示IPv6组播组的组播边界信息。
ipv6-group-address:指定IPv6组播组的地址,取值范围为FFxy::/16,其中x和y均代表0~F的任意一个十六进制数。如果未指定本参数,将显示所有IPv6组播组的IPv6组播边界信息。
prefix-length:指定IPv6组播组地址的前缀长度,取值范围为8~128,缺省值为128。
scope:显示IPv6管理域的组播边界信息。
scope-id:指定IPv6管理域的编号, IPv6管理域为IPv6组播组地址中的scope字段,取值范围为3~15。
如果未指定本参数,将显示所有IPv6管理域的IPv6组播边界信息。
interface interface-type interface-number:显示指定接口上的IPv6组播边界信息,interface-type interface-number表示接口类型和接口编号。如果未指定本参数,将显示所有接口上的IPv6组播边界信息。
# 显示公网实例所有接口上所有IPv6组播组的IPv6组播边界信息。‌
<Sysname> display ipv6 multicast boundary group
 Boundary                                                 Interface
 FF1E::/64                                                Vlan1
# 显示公网实例所有接口上所有IPv6管理域的IPv6组播边界信息。‌
<Sysname> display ipv6 multicast boundary scope
 Boundary            Interface
        3            Vlan-interface1
表1-2 display ipv6 multicast boundary命令显示信息描述表
Boundary
表示IPv6组播边界对应的IPv6组播组或IPv6管理域
表示IPv6组播边界对应的接口
·     ipv6 multicast boundary
display ipv6 multicast fast-forwarding cache命令用来显示IPv6组播快速转发表项信息。
display ipv6 multicast [ vpn-instance vpn-instance-name ] fast-forwarding cache [ ipv6-source-address | ipv6-group-address ] * [ slot slot-number ]
ipv6-source-address:IPv6组播源地址,显示包含指定IPv6组播源的IPv6组播快速转发项。
ipv6-group-address:IPv6组播组地址,显示指定IPv6组播组的IPv6组播快速转发项,取值范围为FFxy::/16(不包括FFx1::/16 和 FFx2::/1),其中x和y均代表0~F的任意一个十六进制数。
slot slot-number:指定设备编号,取值只能为1。
# 显示公网实例组播快转表项的信息。‌
<Sysname> display ipv6 multicast fast-forwarding cache
Total 1 entries, 1 matched
(FE1F:60::200, FF0E::1)
Status     : Enabled
Source port: 2001                   Destination port: 2002
Protocol   : 2                      Flag            : 0x2
Incoming interface: Vlan-interface1
List of 1 outgoing interfaces:
Vlan-interface2
Status: Enabled               Flag: 0x14
表1-3 display ipv6 multicast fast-forwarding cache命令显示信息描述表
组播快速转发表中(S,G)表项的总数和匹配数
表示IPv6组播路由表的(S,G)表项
Source port
源端口号
Destination port
目的端口号
Protocol
协议号
Flag
(S,G)表项的状态,通过将不同的比特位置位来表示不同的状态
·     0x1:表示由板间透传的报文触发创建的表项
·     0x2:表示组播转发流程添加的表项
(S,G)表项出接口状态,通过将不同的比特位置位来表示不同的状态
·     0x1:表示由板间透传的报文触发创建的出接口
·     0x2:表示向已存在的快转表项增添的出接口
·     0x4:表示需要设置MAC地址
·     0x8:表示入VLAN口或者入Super VLAN口对应的出接口
·     0x10:表示出接口已经与会话建立关联关系
·     0x20:表示待删除的出接口
Status
组播快转表项入cache和出cache的状态, 包括Enabled和Disabled
Incoming interface
表示(S,G)表项的入接口
表示(S,G)表项的出接口列表
·     reset ipv6 multicast fast-forwarding cache all
display ipv6 multicast flow-policy info命令用来显示基于IPv6组播流策略的选路信息。
display ipv6 multicast [ vpn-instance vpn-instance-name ] flow-policy info [ interface interface-type interface-number | source source-address | group group-address | policy { default | name policy-name } ] *
vpn-instance vpn-instance-name:指定VPN实例,vpn-instance-name表示MPLS L3VPN的VPN实例名称,为1~31个字符的字符串,区分大小写。如果未指定本参数,将表示指定公网。
interface interface-type interface-number:显示指定接口上基于IPv6组播流策略的选路信息,interface-type interface-number表示接口类型和接口编号。
source source-address:显示指定组播源的基于IPv6组播流策略的选路信息。
group group-address:显示指定组播组的基于IPv6组播流策略的选路信息,group-address为IPv6组播组地址,取值范围为FFxy::/16,其中x和y均表示0~F的任意一个十六进制数。
policy default:显示IPv6缺省组播流策略的选路信息。
policy name policy-name:显示指定IPv6组播流策略的选路信息,policy-name为IPv6组播流策略名称,为1~63个字符的字符串,不区分大小写。
如果未指定sourcegrouppolicy参数,将显示所有基于IPv6组播流策略的选路信息。
# 显示公网中所有基于IPv6组播流策略的选路信息。‌
<Sysname> display ipv6 multicast flow-policy info
Total 2 interfaces, 2 matched
  Vlan-interface100:
    Available bandwidth: 100M
    Used bandwidth: 30M (30%)
    Total 4 entries, 4 matched
    Flow bandwidth: 5M
      Total 2 entries, 2 matched
        (100::1, ff03::101)
        Flow policy: video1
        (100::1, ff03::102)
        Flow policy: audio2
    Flow bandwidth: 10M
       (100::1, ff03::111)
         Flow policy: audio1
       (100::1, ff03::112)
         Default flow policy
  Vlan-interface200:
    Used bandwidth: 10M (10%)
    Flow bandwidth: 10M
      (100::1, ff03::103)
        Flow policy: video3
表1-4 display ipv6 multicast flow-policy info命令显示信息描述表
开启IPv6 PIM功能的接口总数和匹配数
HundredGigE1/1/1
接口名称
Available bandwidth
该接口下当前可用的组播总带宽
Used bandwidth
该接口下当前已使用的组播带宽(已使用组播带宽占组播可用带宽的百分比)
Flow bandwidth
IPv6组播流策略的预计带宽
IPv6组播流对应的(S,G)表项
(100::1, ff03::101)
匹配IPv6组播流策略的(S,G)表项
Flow policy
IPv6组播流策略名称
Default flow policy
当前(S,G)表项匹配到IPv6缺省组播流策略名称
·     ipv6 flow-ucmp unicast reserve-bandwidth
display ipv6 multicast forwarding df-info命令用来显示IPv6组播转发的DF信息。
display ipv6 multicast [ vpn-instance vpn-instance-name ] forwarding df-info [ ipv6-rp-address ] [ verbose ] [ slot slot-number ]
ipv6-rp-address:指定IPv6双向PIM的RP地址。
verbose:显示IPv6组播转发的DF详细信息。如果未指定本参数,将显示IPv6组播转发的DF概要信息。
在IPv6双向PIM域中,只有每个网段的DF才可以向组播组的RP转发组播数据。有关DF的详细介绍,请参见“IPv6 PIM配置指导”中的“IPv6 双向PIM”。
# 显示公网实例IPv6组播转发的DF概要信息。‌
<Sysname> display ipv6 multicast forwarding df-info
Total 1 RPs, 1 matched
00001. RP address: 7:11::1
     Flags: 0x0
     Uptime: 01:46:40
     RPF interface: Vlan-interface1
     List of 1 DF interfaces:
       1: Vlan-interface2
# 显示公网实例IPv6组播转发的DF详细信息。‌
<Sysname> display ipv6 multicast forwarding df-info verbose
     MID: 2, Flags: 0x0
     Uptime: 00:03:53
       Product information: 0x7a2f762f, 0x718fee9f, 0x4b82f137, 0x71c32184
       Product information: 0xa567d6fc, 0xadeb03e3
       Tunnel  information: 0xdfb107d4, 0x7aa5d510
       1: Vlan-interface2
          Product information: 0xa986152b, 0xb74a9a2f
          Tunnel  information: 0x297ca208, 0x76985b89
表1-5 display ipv6 multicast forwarding df-info命令显示信息描述表
RP的总数和匹配数
00001
RP表项的序号
RP address
RP的地址
MID
RP表项的标识,每个RP表项都有唯一的标识
Flags
RP表项的状态,通过将不同的比特位置位来表示不同的状态:
·     0x0:表示正常表项
·     0x4:表示表项下刷失败
·     0x8:表示有DF接口下刷失败
·     0x40:表示表项即将被删除
·     0x100:表示表项正在被删除
·     0x200:表示表项处于平滑状态
Uptime
RP表项已存在的时间
Product information
产品信息
Tunnel  information
隧道接口信息
RPF interface
到达RP的RPF接口
DF接口列表
display ipv6 multicast forwarding event命令用来显示IPv6组播转发的事件统计信息。
display ipv6 multicast [ vpn-instance vpn-instance-name ] forwarding event [ slot slot-number ]
# 显示公网实例IPv6组播转发的事件统计信息。
<Sysname> display ipv6 multicast forwarding event
Total active events sent: 0
Total inactive events sent: 0
Total NoCache events sent: 2
Total NoCache events dropped: 0
Total WrongIF events sent: 0
Total WrongIF events dropped: 0
Total SPT switch events sent: 0
NoCache rate limit: 1024 packets/s
WrongIF rate limit: 1 packets/10s
Total timer of register suppress timeout: 0
表1-6 display ipv6 multicast forwarding event命令显示信息描述表
表项活跃事件的发送次数
表项不活跃事件的发送次数
NoCache事件的发送次数
NoCache事件的丢弃次数
WrongIF事件的发送次数
Total WrongIF events droppet
WrongIF事件的丢弃次数
SPT切换事件的发送次数
NoCache rate limit
NoCache事件的发送限速,单位为报文/秒
WrongIF rate limit
WrongIF事件的发送限速,单位为报文/10秒
注册抑制超时的总次数
·     reset ipv6 multicast forwarding event
display ipv6 multicast forwarding-table命令用来显示IPv6组播转发表的信息。
display ipv6 multicast [ vpn-instance vpn-instance-name ] forwarding-table [ ipv6-source-address [ prefix-length ] | ipv6-group-address [ prefix-length ] | incoming-interface interface-type interface-number | outgoing-interface { exclude | include | match } interface-type interface-number  | replicate replicate-index | frr frr-index | slot slot-number | statistics ] *
ipv6-source-address:IPv6组播源地址,显示包含指定IPv6组播源的IPv6组播转发项。
ipv6-group-address:IPv6组播组地址,显示指定IPv6组播组的IPv6组播转发项,取值范围为FFxy::/16,其中x和y均表示0~F的任意一个十六进制数。
prefix-length:指定IPv6组播组或IPv6组播源地址的前缀长度。对于IPv6组播组地址,其取值范围为8~128,缺省值为128;对于IPv6组播源地址,其取值范围为0~128,缺省值为128。
incoming-interface:显示指定入接口的IPv6组播转发项。
interface-type interface-number:显示指定接口类型和接口编号的入接口的IPv6组播转发项。
outgoing-interface:显示指定出接口的IPv6组播转发项。
exclude:显示出接口列表中不包含指定接口的IPv6组播转发项。
include:显示出接口列表中包含指定接口的IPv6组播转发项。
match:显示出接口列表中包含且仅包含指定接口的IPv6组播转发项。
replicate replicate-index:显示指定IPv6组播复制资源索引号的IPv6组播转发项。replicate-index表示IPv6组播复制资源索引号,取值范围为0x1~0xFFFFFFFF。
frr frr-index:显示指定组播FRR资源索引号的组播转发项。frr-index表示组播FRR资源索引号。组播VXLAN、双向PIM、组播VLAN环境不支持该功能。
statistics:显示IPv6组播转发表的统计信息。
# 显示公网IPv6组播转发表的信息。‌
<Sysname> display ipv6 multicast forwarding-table
00001. (1::1, ff0e::1)
     Flags: 0x0, FlagExts: 0x0
     Incoming interface: Vlan-interface10
          Incoming sub-VLAN: VLAN 11
          Outgoing sub-VLAN: VLAN 12
                             VLAN 13
     Backup incoming interface: Vlan-interface11
     FRR index: 0x2
     Replicate index: 1
       1: Vlan-interface20
          Sub-VLAN: VLAN 21
                    VLAN 22
     Matched 19648 packets(20512512 bytes), Wrong If 0 packets
表1-7 display ipv6 multicast forwarding-table命令显示信息描述表
IPv6组播转发表中(S,G)表项的总数和匹配数
00001
表示(S,G)表项的序号
(1::1, ff0e::1)
表示IPv6组播转发表的(S,G)表项
Flags
(S,G)表项的状态,通过将不同的比特位置位来表示不同的状态:
·     0x0:表示正常表项
·     0x1:表示表项处于Inactive状态
·     0x2:表示空转发表项
·     0x4:表示表项下刷失败
·     0x8:表示有出接口下刷失败
·     0x20:表示表项有注册出接口
·     0x40:表示表项即将被删除
·     0x80:表示表项处于注册抑制状态
·     0x100:表示表项正在被删除
·     0x200:表示表项处于平滑状态
·     0x400:表示表项中存在Super VLAN对应的VLAN接口
·     0x800:表示表项中存在到IPv6组播源地址的ND表项
·     0x4000000:表示表项由MLD代理下发创建
·     0x20000000:表示IPv6双向PIM的转发表项
FlagExts
(S,G)表项的状态,Flags字段的拓展:
·     0x1:表示VXLAN组播隧道的下一跳表项需要重新下驱动
·     0x2:表示表项FRR切换下驱动失败
·     0x4:表示组播VXLAN组网流量曾经来自M-LAG的peer-link链路或者M-LAG接口
·     0x8:表示组播VXLAN组网流量来自DCI实隧道
·     0x10:表示表项绑定复制资源下驱动成功
·     0x20: 表示表项在按需模式下创建
Uptime
表示(S,G)表项已存在时间
Timeout in
表示(S,G)表项的超时剩余时间
Incoming interface
表示(S,G)表项的入接口
Incoming sub-VLAN
表示当(S,G)表项的入接口为Super VLAN对应的VLAN接口时,该Super VLAN的入Sub VLAN
Outgoing sub-VLAN
表示当(S,G)表项的入接口为Super VLAN对应的VLAN接口时,该Super VLAN的出Sub VLAN
(S,G)表项的备入接口,当(S,G)表项的主入接口发生故障时,从备入接口到达的IPv6组播数据才会转发给接收者
FRR index
(S,G)表项对应的组播FRR资源索引号
Replicate index
(S,G)表项对应的组播复制资源索引号
表示(S,G)表项的出接口列表,如果某个出接口不参与组播数据转发,则会在该接口后面显示(inactive)
Sub-VLAN
表示当(S,G)表项的出接口为Super VLAN对应的VLAN接口时,该Super VLAN的出Sub VLAN
Matched 19648 packets (20512512 bytes), Wrong If 0 packet
(S,G)表项匹配的报文数量(字节数),发生入接口错误的报文个数
Forwarded 19648 packets (20512512 bytes)
(S,G)表项已转发的IPv6组播报文数量(字节数)
·     reset ipv6 multicast forwarding-table
display ipv6 multicast forwarding-table capability命令用来显示IPv6组播转发能力相关的信息。
display ipv6 multicast forwarding-table capability [ slot slot-number ]
# 显示所有IPv6组播转发能力相关的信息。
<Sysname> display ipv6 multicast forwarding-table capability
Local entries: 0/1000
Global entries: 500/2000/128000
Software entry index: 1000/6000
Capability  Slot number
8192        Slot 1
表1-8 display ipv6 multicast forwarding-table capability命令显示信息描述表
Local entries
(暂不支持)当前单板上的组播转发能力相关统计数据,包括:
·     第1个值:组播表项按需下发功能生效时,表示组播流量经本板进入的表项数量;组播表项按需下发功能未生效时,显示0
·     第2个值:组播表项按需下发功能生效时,组播流量经本板进入的表项数量上限;组播表项按需下发功能未生效时,无实际意义
Global entries
设备全局的组播转发能力相关统计数据,包括:
·     第1个值:已存在的表项数量
·     第2个值:当前业务板装配情况下的设备表项数量上限
·     第3个值:业务板满配情况下的设备表项数量上限
如果某台设备共可以安装4块业务板,当前仅安装了2块,那么:当前业务板装配情况为2块业务板,本字段第二个数值表示安装2块业务板时表项的数量上限;业务板满配情况为4块业务板,本字段第三个数值表示安装4块业务板时表项的数量上限
当前单板上的软件索引规格相关统计数据,包括:
·     第1个值:已分配的组播转发表项最大软件索引值
·     第2个值:软件索引数量上限
软件索引与组播转发表项一一对应,用于记录表项存储的位置
Capability
槽位号对应单板的组播转发表项数量上限
Slot number
槽位号
display ipv6 multicast forwarding-table df-list命令用来显示IPv6组播转发表的DF列表信息。
display ipv6 multicast [ vpn-instance vpn-instance-name ] forwarding-table df-list [ ipv6-group-address ] [ verbose ] [ slot slot-number ]
ipv6-group-address:IPv6组播组地址,显示指定IPv6组播组的IPv6组播转发表的DF列表信息,取值范围为FFxy::/16(不包括FFx1::/16 和 FFx2::/1),其中x和y均表示0~F的任意一个十六进制数。
verbose:显示IPv6组播转发表的DF列表详细信息。如果未指定本参数,将显示IPv6组播转发表的DF列表概要信息。
# 显示公网实例IPv6组播转发表的DF列表概要信息。‌
<Sysname> display ipv6 multicast forwarding-table df-list
00001. (::, FF1E::1)
       1: Vlan-interface1
# 显示公网实例IPv6组播转发表的DF列表详细信息。‌
<Sysname> display ipv6 multicast forwarding-table df-list verbose
         1: Vlan-interface1
            Product information: 0x347849f6, 0x14bd6837
            Tunnel  information: 0xc4857986, 0x128a9c8f
表1-9 display ipv6 multicast forwarding-table df-list命令显示信息描述表
表项总数和匹配数
00001
表项的序号
(::, FF1E::1)
组播转发表的(*,G)表项
DF接口列表
Product information
产品信息
Tunnel  information
隧道接口信息
display ipv6 multicast replication-share info命令用来显示IPv6组播复制资源信息。
display ipv6 multicast replication-share info [ outgoing-interface { exclude | include | match } interface-type interface-number | replicate replicate-index ] * [ slot slot-number ]
outgoing-interface:显示指定出接口的IPv6组播复制资源信息。
exclude:显示出接口列表中不包含指定接口的IPv6组播复制资源信息。
include:显示出接口列表中包含指定接口的IPv6组播复制资源信息。
match:显示出接口列表中包含且仅包含指定接口的IPv6组播复制资源信息。
interface-type interface-number:显示指定接口类型和接口编号的出接口的IPv6组播复制资源信息。
replicate replicate-index:显示指定IPv6组播复制资源索引号的IPv6组播复制资源信息。replicate-index表示IPv6组播复制资源索引号,取值范围为0x1~0xFFFFFFFF。
# 显示所有IPv6组播复制资源信息。
<Sysname> display ipv6 multicast replication-share info
multicast replication-share status: active
Total 5 entries, 5 matched
00001.Replicate index: 0x3
     Drv context: 0x11112222, 0x33330001
     Creation time: 00:21:20
     Flags: 0x1
     Match key: 120
     Reference count: 2
       1: HundredGigE1/1/2
00002.Replicate index: 0x5
     Drv context: 0x11112222, 0x33330002
     Creation time: 00:12:30
     Flags: 0x3
     Match key: 820
     Reference count: 3
     Outgoing slots (2 in total): 1-2
     List of 2 outgoing interfaces:
       1: Vlan-interface10
          List of 1 outgoing ports:
            1: HundredGigE1/1/1
       2: Vlan-interface20
          List of 2 outgoing ports:
            1: GigabitEthernet2/0/1
            2: GigabitEthernet2/0/2
00003.Replicate index: 0xb
     Drv context: 0x11112222, 0x33330003
     Creation time: 00:11:30
     Flags: 0x0
     Match key: 2020
     Reference count: 1
     Outgoing slots (1 in total): 2
     Incoming interface: Vlan-interface100
     Incoming sub-VLAN: VLAN 101
       1: Vlan-interface100
          Sub-VLAN: VLAN 101
              1: GigabitEthernet2/0/3
          Sub-VLAN: VLAN 102
              1: GigabitEthernet2/0/4
00004.Replicate index: 0x20
     Drv context: 0x11112222, 0x33330004
     Creation time: 00:10:30
     Flags: 0x4
     Match key: 2510
     Reference count: 1
     Outgoing slots (1 in total): 1
     Incoming interface: Vsi-interface1
       1: Vsi-interface1
          VSI instance: a
              1: HundredGigE1/1/3
          VSI instance: b
              1: HundredGigE1/1/4
       2: Vsi-interface2
          VSI instance: c
              1: HundredGigE1/1/5
              2: HundredGigE1/1/6
00005.Replicate index: 0x35
     Drv context: 0x11112222, 0x33330005
     Creation time: 00:09:20
     Flags: 0x3
     Match key: 33757175
     Reference count: 1
       1: MTunnel0 (VPN: a)
          Data-group: 225.2.2.1
表1-10 display ipv6 multicast replication-share info命令显示信息描述表
组播复制资源功能状态:
·     not configured:未配置
·     inactive:已配置,但未生效
·     active:生效
组播复制资源表项的总数和匹配数
00001
组播复制资源表项的序号
Replicate index
组播复制资源表项的索引号
Drv contex
设备硬件资源索引号
Creation time
组播复制资源表项创建时间
Flags
组播复制资源表项的状态,通过将不同的比特位置位来表示不同的状态:
·     0x0:表示正常的组播复制资源表项
·     0x1:表示创建组播复制资源失败
·     0x2:表示绑定组播复制资源失败
·     0x4:表示修改组播复制资源失败
Match key
组播复制资源表项的匹配关键值,用于快速匹配能复用的IPv6组播复制资源
Reference count
关联IPv6播复制资源的组播转发表项个数
Incoming interface
组播复制资源表项的入接口
Incoming sub-VLAN
组播复制资源表项的入接口为Super VLAN对应的VLAN接口时,该Super VLAN的入Sub VLAN
组播复制资源表项的出接口列表
Sub-VLAN
组播复制资源表项的出接口为Super VLAN对应的VLAN接口时,该Super VLAN的出Sub VLAN
Outgoing slots (0 in total)
·     本字段无实际意义‌
VLAN或VSI出接口下的组播出端口:
·     开启二层组播功能时,表示VLAN或VSI出接口下的成员端口或路由器端口
·     未开启二层组播功能时,表示VLAN或VSI出接口下所有的端口
MTunnel0 (VPN: a)
组播VPN隧道接口以及对应的VPN实例名
Data-group
组播VPN中的数据Data-Group
Incoming VSI instance
IPv6组播复制资源表项的入接口为MVXLAN-UPE类型时,入VSI实例的名称
·     display ipv6 multicast forwarding-table
display ipv6 multicast routing-table命令用来显示IPv6组播路由表的信息。
display ipv6 multicast [ vpn-instance vpn-instance-name ] routing-table [ ipv6-source-address [ prefix-length ] | ipv6-group-address [ prefix-length ] | incoming-interface interface-type interface-number | outgoing-interface { exclude | include | match } interface-type interface-number ] *
ipv6-source-address:IPv6组播源地址,显示包含指定IPv6组播源的IPv6组播路由项。
ipv6-group-address:IPv6组播组地址,显示指定IPv6组播组的IPv6组播路由项,取值范围为FFxy::/16,其中x和y均代表0~F的任意一个十六进制数。
incoming-interface:显示指定入接口的IPv6组播路由项。
interface-type interface-number:显示指定接口类型和接口编号的入接口的IPv6组播路由项。
outgoing-interface:显示指定出接口的IPv6组播路由项。
exclude:显示出接口列表中不包含指定接口的IPv6组播路由项。
include:显示出接口列表中包含指定接口的IPv6组播路由项。
match:显示出接口列表中包含且仅包含指定接口的IPv6组播路由项。
IPv6组播路由表是进行IPv6组播数据转发的基础,通过查看该表可以了解(S,G)表项等的建立情况。
# 显示公网IPv6组播路由表的信息。‌
<Sysname> display ipv6 multicast routing-table
 Total 1 entries
 00001. (2001::2, FFE3::101)
       Uptime: 00:00:14
       Upstream Interface: Vlan-interface1
       Backup Upstream Interface: Vlan-interface4
       List of 2 downstream interfaces
           1:  Vlan-interface2
           2:  Vlan-interface3
表1-11 display ipv6 multicast routing-table命令显示信息描述表
Total 1 entries
IPv6组播路由表中(S,G)表项的总数
00001
表示(S,G)表项的序号
表示IPv6组播路由表的(S,G)表项
Uptime
表示(S,G)表项已经存在的时间
Upstream Interface
表示(S,G)表项的上游接口,表示IPv6组播数据应该从此接口到达
(S,G)表项的上游备接口,当(S,G)表项的上游主接口发生故障时,从上游备入接口到达的组播数据才会转发给接收者
下游接口列表,表示哪些接口需要进行组播转发,如果某个出接口不参与组播数据转发,则会在该接口后面显示(inactive)
·     reset ipv6 multicast routing-table
display ipv6 multicast routing-table static命令用来显示IPv6组播静态路由表的信息。
display ipv6 multicast [ vpn-instance vpn-instance-name ] routing-table static [ ipv6-source-address [ prefix-length ] ]
vpn-instance vpn-instance-name:显示指定VPN实例的信息,vpn-instance-name表示MPLS L3VPN的VPN实例名称,为1~31个字符的字符串,区分大小写。如果未指定本参数,表示指定公网。
ipv6-source-address:显示指定组播源的IPv6组播静态路由信息。
prefix-length:指定IPv6组播源地址的前缀长度,取值范围为0~128,缺省值为128。
本命令只显示已生效的IPv6组播静态路由信息。
# 显示公网组播静态路由表的信息。‌
<Sysname> display ipv6 multicast routing-table static
Destinations: 2        Routes: 4
Destination/Prefix: 2::100/128
  Pre: 10
  RPF neighbor                             Interface
  100::2                                   Vlan11
  125:0:3::3                               Vlan12
 Destination/Prefix: 3::100/128
  Pre: 20
  100::3                                   Vlan13
  125:0:3::4                               Vlan14
表1-12 display ipv6 multicast routing-table static命令显示信息描述表
Destinations
目的IPv6地址个数
Routes
路由条数
Destination/Prefix
目的IPv6地址/前缀长度
Pre
路由优先级
RPF neighbor
可达目的地址的RPF邻居的IPv6地址
可达目的地址的出接口
display ipv6 multicast rpf-info命令用来显示IPv6组播源的RPF信息。
display ipv6 multicast [ vpn-instance vpn-instance-name ] rpf-info ipv6-source-address [ ipv6-group-address ]
ipv6-source-address:显示指定IPv6组播源的RPF信息。
ipv6-group-address:显示指定IPv6组播组的RPF信息,取值范围为FFxy::/16(但不包括下列地址: FFx1::/16、FFx2::/16),其中x和y均代表0~F的任意一个十六进制数。
# 显示公网IPv6组播源2001::101的全部RPF信息。‌
<Sysname> display ipv6 multicast rpf-info 2001::101
 RPF information about source 2001::101:
     RPF interface: Vlan-interface1, RPF neighbor: FE80::A01:101:1
     Backup RPF interface: Vlan-interface2, backup RPF neighbor: FE80::A01:101:2
     Referenced prefix/prefix length: 2001::/64
     Referenced route type: igp
     Load splitting rule: disable
     Source AS: 0
     C-multicast route target: 0x0000000000000000
表1-13 display ipv6 multicast rpf-info命令显示信息描述表
到IPv6组播源2001::101的RPF路径信息
RPF interface
表示RPF接口名称
备RPF接口名称
RPF neighbor
表示RPF邻居的IPv6地址(链路本地地址)
backup RPF neighbor
备份RPF邻居
表示引用的路由及其前缀长度
表示引用的路由类型,可以是下列类型之一:
·     igp:IPv6单播路由(内部网关协议)
·     egp:IPv6单播路由(外部网关协议)
·     unicast (direct):IPv6单播路由(直连)
·     unicast:其它IPv6单播路由(如IPv6单播静态路由等)
·     mbgp:IPv6 MBGP路由
RPF路由选择规则,可以是根据路由协议的路由优先级进行选择,或者是按照目的地址对路由表进行最长匹配
Load splitting rule
是否使能了负载分担规则
Source AS
组播源所在PE的AS号
C-multicast路由扩展团体属性
·     display ipv6 multicast routing-table
flow-policy命令用来配置IPv6组播流策略,并进入IPv6组播流策略视图。如果指定的IPv6组播流策略已经存在,则直接进入IPv6组播流策略视图。
undo flow-policy命令用来取消IPv6组播流策略配置。
flow-policy { default | name policy-name }
undo flow-policy { all | default | name policy-name }
不存在IPv6组播流策略。
IPv6 MRIB视图
default:IPv6缺省组播流策略。
policy-name:IPv6组播流策略名称,为1~63个字符的字符串,不区分大小写。
all:删除所有IPv6组播流策略。
工作机制
当下游设备与上游设备之间存在多条等价路由,且组播流量的负载分担方式为flow-ucmp(通过load-splitting命令配置)时,设备将选择组播流带宽利用率最小的链路作为优选链路,如果组播流带宽利用率相同,则选择下一跳IPv6地址大的链路。组播流带宽利用率=(已使用带宽+组播流预计带宽)/(接口总带宽*(1-单播预留带宽))。其中:
·     组播流预计带宽值通过IPv6组播流策略视图下的bandwidth命令配置。
·     接口总带宽通过接口视图下的bandwidth命令配置。
·     单播预留带宽通过flow-ucmp unicast reserve-bandwidthipv6 multicst flow-ucmp unicast reserve-bandwidth命令配置。
注意事项
配置本命令的同时,请通过load-splitting命令将组播流量负载分担方式配置为flow-ucmp,否则配置不生效。
新增、删除和修改组播流策略,以及修改组播流策略下的配置,都不会影响已有组播流的选路结果,只影响新增组播流的选路。因此,在将组播流量负载分担方式配置为flow-ucmp前,需要规划并完成组播流策略视图下的配置和单播预留带宽比的配置。
链路自身带宽配置变化、等价链路数量变化等不影响已有组播流量的选路结果。
组播源侧的选路、IPv6 PIM DM模式选路、IPv6 PIM SM模式的RPT选路、本地RP选路均不受本配置影响。
当网络中同时存在IPv4和IPv6组播流量时,请适当提高单播预留带宽比,以免造成链路拥塞。
# 创建一个名称为abc的IPv6组播流策略,并进入IPv6组播流策略视图。
# 创建IPv6组播流策略,并进入缺省IPv6组播流策略视图。
[Sysname-mrib6] flow-policy default
·     acl (IPv6组播流策略视图)
·     bandwidth
·     display ipv6 multicast flow-policy info
flow-ucmp unicast reserve-bandwidth命令用来全局配置IPv6单播流量预留带宽比。
undo flow-ucmp unicast reserve-bandwidth命令用来恢复缺省情况。
flow-ucmp unicast reserve-bandwidth percentage
未全局配置IPv6单播流量预留带宽比。
IPv6 MRIB视图
percentage:IPv6单播流量预留带宽比,取值范围为1~100,单位为百分比。
网络中IPv6单播流量和IPv6组播实时流量共存,可以通过本命令为IPv6单播流量配置预留带宽比。根据接口带宽以及本命令配置的IPv6单播预留带宽比,可以计算出接口IPv6组播流量的可用总带宽。比如,接口的总带宽为100Kbps,IPv6单播预留带宽比为20%(即20Kbps),则接口IPv6组播流量的可用总带宽为80Kbps。
本命令与ipv6 multicst flow-ucmp unicast reserve-bandwidth命令的功能相同,只是作用范围不同:IPv6 MRIB视图下的全局配置对所有接口都有效,接口视图下的配置只对当前接口有效,后者的配置优先级较高。
# 配置IPv6单播流量预留的带宽比为50%。
[Sysname-mrib6] flow-ucmp unicast reserve-bandwidth 50
·     ipv6 multicst flow-ucmp unicast reserve-bandwidth
ipv6 multicast boundary命令用来配置IPv6组播转发边界。
undo ipv6 multicast boundary命令用来删除IPv6组播转发边界。
ipv6 multicast boundary { ipv6-group-address prefix-length | scope { scope-id | admin-local | global | organization-local | site-local } }
undo ipv6 multicast boundary { ipv6-group-address prefix-length | all | scope { scope-id | admin-local | global | organization-local | site-local } }
接口上不存在IPv6组播转发边界。
ipv6-group-address:指定IPv6组播组地址,取值范围为FFxy::/16,其中x和y均代表0~F的任意一个十六进制数。
prefix-length:指定IPv6组播组地址的前缀长度,取值范围为8~128。
all:删除该接口上配置所有IPv6组播转发边界。
scope-id:指定Scope字段的值,IPv6组播组地址中的scope字段表示IPv6管理域,取值范围为3~15。
admin-local:指定Scope字段为管理本地范围,对应的Scope值为4。
global:指定Scope字段为全局范围,对应的Scope值为14。
organization-local:指定Scope字段为机构本地范围,对应的Scope值为8。
site-local:指定Scope字段为站点本地范围,对应的Scope值为5。
IPv6组播转发边界为指定地址范围或Scope值的IPv6组播组划定了边界条件,如果IPv6组播报文的目的地址与边界条件匹配,就停止转发。
一个接口可以作为不同地址范围的IPv6组播组的转发边界,即允许在同一接口上多次执行本命令为不同地址范围的IPv6组播组设定转发边界;但一个接口只能作为特定Scope值的IPv6组播组的转发边界,若在同一接口上多次执行本命令为不同Scope值的IPv6组播组设定转发边界,则只有最后一次的配置生效。
执行本命令不需要使能IPv6组播路由。
假设A和B为不同地址范围的IPv6组播组的集合,且B是A的真子集:如果接口先配置为A的转发边界,再配置为B的转发边界,则该接口仍然为A的转发边界;如果接口先配置为B的转发边界,再配置为A的转发边界,则该接口将变为A的转发边界。
# 将接口Vlan-interface100配置为地址范围为FF03::/16的IPv6组播组的转发边界。‌
[Sysname-Vlan-interface100] ipv6 multicast boundary ff03:: 16
# 将接口Vlan-interface100配置为Scope值为4的IPv6组播组的转发边界。‌
[Sysname-Vlan-interface100] ipv6 multicast boundary scope 4
·     display ipv6 multicast boundary
ipv6 multicast cpu-forwarding max-copy-count命令用来配置IPv6组播报文软转发复制份数的最大值。
undo ipv6 multicast cpu-forwarding max-copy-count命令用来恢复缺省情况。
ipv6 multicast cpu-forwarding max-copy-count count
IPv6组播报文软转发复制数量的最大值为5。
count:指定IPv6组播报文软转发复制份数的最大值,取值范围为1~36。
请您在工程师指导下谨慎使用该功能,不要自行配置。
若IPv6组播报文软转发复制数量的最大值配置过大,会导致CPU占用率过高,影响设备的转发性能;若配置过小,会导致IPv6组播报文转发出现丢包。
# 配置IPv6组播软转发复制数量的最大值为3。
[Sysname] ipv6 multicast cpu-forwarding max-copy-count 3
ipv6 multicst flow-ucmp unicast reserve-bandwidth命令用来在接口上配置IPv6单播流量预留带宽比。
undo ipv6 multicast flow-ucmp unicast reserve-bandwidth命令用来恢复缺省情况。
ipv6 multicast flow-ucmp unicast reserve-bandwidth percentage
未在接口上配置IPv6单播流量预留带宽比。
percentage:IPv6单播流量预留带宽,取值范围为0~100,单位为百分比。
本命令与flow-ucmp unicast reserve-bandwidth命令的功能相同,只是作用范围不同:接口视图下的配置只对当前接口有效,IPv6 MRIB视图下的全局配置对所有接口都有效,前者的配置优先级较高。
# 配置Vlan-interface100接口上IPv6单播流量预留带宽比为50%。‌
[Sysname-Vlan-interface100] ipv6 multicast flow-ucmp unicast reserve-bandwidth 50
·     flow-ucmp unicast reserve-bandwidth
ipv6 multicast forwarding-table cache-unknown per-entry命令用来设置对于同一个(S,G)表项,可缓存的最大未知IPv6组播数据报文数目。
undo ipv6 multicast forwarding-table cache-unknown per-entry命令用来恢复缺省情况。
ipv6 multicast forwarding-table cache-unknown per-entry per-entry-limit
对于同一个(S,G)表项,可缓存的最大未知IPv6组播数据报文数目为1。
per-entry-limit:对于同一个(S,G)表项,可缓存的最大未知IPv6组播数据报文数目,取值范围为0~256。当取值为0时,代表不可缓存未知IPv6组播数据报文。
# 设置对于同一个(S,G)表项,可缓存的最大未知IPv6组播数据报文数目为20。
[Sysname] ipv6 multicast forwarding-table cache-unknown per-entry 20
·     ipv6 multicast forwarding-table cache-unknown total
ipv6 multicast forwarding-table cache-unknown total命令用来设置内存中可缓存的未知IPv6组播数据报文的最大数目。
undo multicast forwarding-table cache-unknown total命令用来恢复缺省情况。
ipv6 multicast forwarding-table cache-unknown total total-limit
undo ipv6 multicast forwarding-table cache-unknown total
内存中可缓存的未知IPv6组播数据报文的最大数目为1024。
total-limit:内存中可缓存的未知IPv6组播数据报文的最大数目,取值范围为0~65535。当取值为0时,代表不可缓存未知IPv6组播数据报文。
建议本命令配置的值要远远大于ipv6 multicast forwarding-table cache-unknown per-entry命令配置的值。
# 设置内存中可缓存的未知IPv6组播数据报文的最大数目为10000。
[Sysname] ipv6 multicast forwarding-table cache-unknown total 10000
·     ipv6 multicast forwarding-table cache-unknown per-entry
ipv6 multicast frr mode命令用来配置IPv6组播FRR的工作模式。
undo ipv6 multicast frr mode命令用来恢复缺省情况。
ipv6 multicast frr mode [ by-entry | by-iif ]
IPv6组播FRR的工作模式为按表项检测模式。
by-entry:按表项检测模式。在此模式下,当开启了IPv6组播FRR功能后,设备将周期性的针对每条表项进行主备入接口流量的检测。
by-iif:按入接口检测模式。在此模式下,当开启了IPv6组播FRR功能后,设备会将主备入接口均相同的组播表项划分为一组,然后周期性对这组表项进行主备入接口流量的检测。
当设备上开启IPv6组播FRR(Fast Reroute,快速重路由)功能后,同一个(S,G)表项将会存在主备入接口,同时将会周期性检测主备入接口的组播流量。当检测到组播流量未从主入接口到达,表示主入接口存在故障,此时会将该表项的入接口切换到备份入接口。
目前只有IPv6 PIM支持IPv6组播FRR,有关IPv6 PIM FRR的详细介绍,请参见“IP组播配置指导”中的“IPv6 PIM”。
# 配置IPv6组播FRR的工作模式为按入接口检测模式。
[Sysname] ipv6 multicast frr mode by-iif
·     rpf-frr enable(IP组播命令参考/IPv6 PIM)
ipv6 multicast frr monitor cycle命令用来配置IPv6组播FRR监测主备链路状态的周期。
undo multicast frr monitor cycle命令用来恢复缺省情况。
ipv6 multicast frr monitor cycle monitor-time
undo ipv6 multicast frr monitor cycle
IPv6组播FRR监测主备链路状态的周期为200毫秒。
monitor-time:IPv6组播FRR监测主备链路状态的周期,取值范围为10、20、40、100、200和500,单位为毫秒。
在配置本功能前,请先通过rpf-frr enable命令开启公网的IPv6组播FRR功能。
当连接组播源的设备发生故障时,为了加快组播业务收敛速度,可以在连接接收者的设备上开启组播FRR功能。当设备上开启IPv6组播FRR功能后,设备将为同一个(S,G)表项保存主备两个入接口,并周期性检测主备入接口的组播流量。如果检测到组播流量未从主入接口到达,则表示主主链路存在故障,此时连接接收者的设备将选择接受从备份链路发来的组播流量。通过本命令,可以配置IPv6组播FRR监测主备链路状态的周期。
组播转发表项较多时,建议将监测主备链路状态的周期调大,避免在短时间内监测过多的组播表项对应的组播流量,导致CPU负载过重;当组播流量速率比较小时,也建议将监测主备链路状态的周期调大,避免监测周期过短监测过于频繁,造成链路故障的误判。
# 配置IPv6组播FRR监测主备链路状态的周期为20毫秒。
[Sysname] ipv6 multicast frr monitor cycle 20
·     rpf-frr enable (IPv6 PIM view)
ipv6 multicast frr wtr命令用来配置IPv6组播FRR中从备份链路回切到主链路功能。
undo multicast frr wtr命令用来恢复缺省情况。
ipv6 multicast frr wtr { wtr-time | disable }
undo ipv6 multicast frr wtr
IPv6组播FRR中组播流量从备份链路回切到主链路处于开启状态,回切的等待时间为600秒。
wtr-time:IPv6组播FRR中组播流量从备份链路回切到主链路的等待时间,取值范围为60~1800,单位为秒。
disable:IPv6组播FRR中组播流量不从备份链路回切到主链路。
在配置本功能前,请先通过rpf-frr enable命令开启公网的组播FRR功能。
在比较复杂的组播组网中,建议配置的IPv6组播FRR中组播流量从备份链路回切到主链路的等待时间不要过短,以免在主链路完成组播表项建立前,将组播流量回切到主链路,导致组播流量转发失败。
组播流量回切过程中,可能会导致部分组播业务出现多包或者丢包。在组播业务可靠性要求较高的场景下,建议配置为不回切。
链路实际回切的时间按回切前配置的时间生效,建议在链路回切前配置本命令。
# 配置IPv6组播FRR中组播流量从备份链路回切到主链路的等待时间为800秒。
[Sysname] ipv6 multicast frr wtr 800
ipv6 multicast replication-share enable命令用来开启IPv6组播复制资源复用功能。
undo ipv6 multicast replication-share enable命令用来关闭IPv6组播复制资源复用功能。
IPv6组播复制资源复用功能处于关闭状态。
IPv6组播复制资源是设备上一种硬件相关的资源,用于IPv6组播流量的复制转发。缺省情况下,出接口相同的多条不同(S,G)IPv6组播转发表项,将占用多条IPv6组播复制资源。
由于设备上的IPv6组播复制资源有限,可通过配置本命令,使得出接口相同的IPv6组播转发表项复用同一个IPv6组播复制资源,以便节省IPv6组播复制资源。
执行本命令后,需使用reboot命令重启设备,本命令才能生效。
# 开启IPv6组播复制资源复用功能。
[Sysname] ipv6 multicast replication-share enable
Configuring success. Please save the configuration first, then reboot the device to activate the function.
·     display ipv6 multicast replication-share info
ipv6 multicast routing命令用来使能IPv6组播路由,并进入IPv6 MRIB视图。
undo ipv6 multicast routing命令用来关闭IPv6组播路由。
ipv6 multicast routing [ vpn-instance vpn-instance-name ]
undo ipv6 multicast routing [ vpn-instance vpn-instance-name ]
IPv6组播路由处于关闭状态。
只有在公网实例或VPN实例中使能了IPv6组播路由,其它三层IPv6组播功能才能生效;没有使能IPv6组播路由前,设备不转发任何IPv6组播报文。
# 使能公网实例中的IPv6组播路由,并进入公网实例的IPv6 MRIB视图。
[Sysname-mrib6]
# 使能VPN实例mvpn中的IPv6组播路由,并进入该VPN实例的IPv6 MRIB视图。
[Sysname] ipv6 multicast routing vpn-instance mvpn
[Sysname-mrib6-mvpn]
ipv6 rpf-route-static命令用来配置IPv6组播静态路由。
undo ipv6 rpf-route-static命令用来删除指定的IPv6组播静态路由。
ipv6 rpf-route-static [ vpn-instance vpn-instance-name ] ipv6-source-address prefix-length { ipv6-gateway-address | interface-type interface-number } [ preference preference ]
undo ipv6 rpf-route-static [ vpn-instance vpn-instance-name ] ipv6-source-address prefix-length { ipv6-gateway-address | interface-type interface-number }
不存在IPv6组播静态路由。
ipv6-source-address:指定IPv6组播源地址。
ipv6-gateway-address:指定RPF邻居的IPv6地址。
interface-type interface-number:指定与RPF邻居相连接口的接口类型和接口编号。
preference:指定路由优先级,取值范围为1~255,缺省值为1。
只有点到点类型的接口才能使用指定接口的方式来指定RPF邻居,非点到点类型的接口(包括三层以太网接口、三层聚合接口、Loopback接口或VLAN接口等)不能使用此方式,只能使用指定地址的方式。
配置的IPv6组播静态路由并不一定会生效,因为可能出现指定的RPF邻居无法迭代出接口、指定的RPF接口不属于本实例、指定的RPF接口不是点到点类型或处于down状态等情况。此外,若在相同IPv6组播源地址范围下有多条配置,只有路由优先级最高的那条才能被激活。因此,配置完成后建议使用display ipv6 multicast routing-table static命令查看该IPv6组播静态路由是否已生效。
undo ipv6 rpf-route-static命令用来删除指定的IPv6组播静态路由,而delete ipv6 rpf-route-static命令则用来删除所有的IPv6组播静态路由。
# 在公网中配置到组播源101::0/64的IPv6组播静态路由,其RPF邻居的IPv6地址是106::7。
[Sysname] ipv6 rpf-route-static 101::0 64 106::7
·     delete ipv6 rpf-route-static
·     display ipv6 multicast routing-table static
load-splitting命令用来配置对IPv6组播流量进行负载分担。
undo load-splitting命令用来恢复缺省情况。
load-splitting { balance-ecmp | balance-ucmp | ecmp | flow-ucmp |source | source-group | ucmp }
undo load-splitting
不对IPv6组播流量进行负载分担。
IPv6 MRIB视图
balance-ecmp:根据等价路由均匀地对IPv6组播流量进行负载分担。
balance-ucmp:根据链路带宽均匀地对IPv6组播流量进行负载分担。
ecmp:根据等价路由对IPv6组播流量进行负载分担。
flow-ucmp:根据组播流的带宽利用率对IPv6组播流量进行负载分担。
source:仅根据IPv6组播源对IPv6组播流量进行负载分担。
source-group:根据IPv6组播源组对IPv6组播流量进行负载分担。
ucmp:根据链路带宽对IPv6组播流量进行负载分担。
本命令对IPv6双向PIM不生效。
使用flow-ucmp方式进行组播流量的均衡负载分担前,需要先配置好组播流策略和单播预留带宽比。选路后修改组播流策略和单播预留带宽比不会影响已有选路结果,只影响新的组播流的选路。
balance-ecmpecmpflow-ucmpsourcesource-group用于在等价链路环境中实现IPv6组播流量的负载分担;balance-ucmpucmp方式用于在非等价链路环境中实现IPv6组播流量的负载分担;flow-ucmp方式用于根据配置的组播流的带宽实现IPv6组播流量的负载分担:
·     配置ecmp方式后网络中等价链路的增删对IPv6组播流量的影响较大。
·     配置sourcesource-group方式后网络中链路增删对IPv6组播流量的影响较小,适合等价链路不稳定的情况。
·     balance-ecmpbalance-ucmp方式采用轮询机制分担,相比于ecmpucmp方式网络的稳定性及均衡性更好。
·     配置flow-ucmp方式后,网络中链路增删对组播流量的影响较小,适合等价链路不稳定的情况。相比于ucmp方式网络的稳定性和均衡性更好。
# 在公网实例中配置仅根据IPv6组播源对IPv6组播流量进行负载分担。
[Sysname-mrib6] load-splitting source
longest-match命令用来配置按照最长匹配来选择RPF路由,即选择掩码最长的路由作为RPF路由。
undo longest-match命令用来恢复缺省情况。
longest-match
undo longest-match
选择路由优先级最高的路由作为RPF路由。
IPv6 MRIB视图
# 在公网实例中配置按照最长匹配原则选择RPF路由。
[Sysname-mrib6] longest-match
reset ipv6 multicast fast-forwarding cache命令用来清除IPv6组播快速转发表中的转发项。
reset ipv6 multicast [ vpn-instance vpn-instance-name ] fast-forwarding cache { { ipv6-source-address | ipv6-group-address } * | all } [ slot slot-number ]
vpn-instance vpn-instance-name:清除指定VPN实例的信息,vpn-instance-name表示MPLS L3VPN的VPN实例名称,为1~31个字符的字符串,区分大小写。如果未指定本参数,将清除公网实例的信息。
ipv6-source-address:IPv6组播源地址,清除包含指定组播源的IPv6组播转发项。
ipv6-group-address:IPv6组播组地址,清除指定组播组的IPv6组播转发项,取值范围为FFxy::/16,其中x和y均表示0~F的任意一个十六进制数。
all:清除组播快速转发表中的所有组播转发项
#从公网实例IPv6组播快速转发表中清除所有组播转发表项。
<Sysname> reset ipv6 multicast fast-forwarding cache all
#从公网实例IPv6组播快速转发表中清除组播源组为(FE1F:20::2 ,FF0E::1)的转发表项。
<Sysname> reset ipv6 multicast fast-forwarding cache fe1f:20::2 ff0e::1
·     display ipv6 multicast fast-forwarding cache
reset ipv6 multicast forwarding event命令用来清除IPv6组播转发的事件统计信息。
reset ipv6 multicast [ vpn-instance vpn-instance-name ] forwarding event
# 清除公网实例IPv6组播转发的事件统计信息。
<Sysname> reset ipv6 multicast forwarding event
·     display ipv6 multicast forwarding event
reset ipv6 multicast forwarding-table命令用来清除IPv6组播转发表中的转发项。
reset ipv6 multicast [ vpn-instance vpn-instance-name ] forwarding-table { { ipv6-source-address [ prefix-length ] | ipv6-group-address [ prefix-length ] | incoming-interface { interface-type interface-number } } * | all }
ipv6-source-address:IPv6组播源地址,显示包含指定组播源的IPv6组播转发项。
ipv6-group-address:IPv6组播组地址,显示指定组播组的IPv6组播转发项,取值范围为FFxy::/16,其中x和y均表示0~F的任意一个十六进制数。
incoming-interface:清除指定入接口的IPv6组播转发项。
interface-type interface-number:清除指定接口类型和接口编号的入接口的IPv6组播转发项。
all:清除组播转发表中的所有IPv6组播转发项。
清除IPv6组播转发表中的转发项后,IPv6组播路由表中的相应表项也将随之被删除。
# 从公网实例IPv6组播转发表中清除组播组FF0E::1的相关转发表项。
<Sysname> reset ipv6 multicast forwarding-table ff0e::1
reset ipv6 multicast routing-table命令用来清除IPv6组播路由表中的路由项。
reset ipv6 multicast [ vpn-instance vpn-instance-name ] routing-table { { ipv6-source-address [ prefix-length ] | ipv6-group-address [ prefix-length ] | incoming-interface interface-type interface-number } * | all }
ipv6-source-address:IPv6组播源地址,清除包含指定IPv6组播源的IPv6组播路由项。
ipv6-group-address:IPv6组播组地址,清除指定IPv6组播组的IPv6组播路由项,取值范围为FFxy::/16,其中x和y均代表0~F的任意一个十六进制数。
incoming-interface:清除指定入接口的IPv6组播路由项。
interface-type interface-number:清除指定接口类型和接口编号的入接口的IPv6组播路由项。
all:清除IPv6组播路由表中的所有IPv6组播路由项。
清除IPv6组播路由表中的路由项后,IPv6组播转发表中的相应表项也将被随之删除。
# 从公网实例IPv6组播路由表中清除组播组FF03::101的相关路由项。
<Sysname> reset ipv6 multicast routing-table ff03::101
