20-NAT命令参考
01-NAT命令
本章节下载 01-NAT命令  (576.78 KB)
01-NAT命令
  录
1 NAT
1.1 NAT配置命令
1.1.1 address
1.1.2 block-size
1.1.3 display nat address-group
1.1.4 display nat all
1.1.5 display nat dns-map
1.1.6 display nat eim
1.1.7 display nat eim statistics
1.1.8 display nat instance
1.1.9 display nat log
1.1.10 display nat no-pat
1.1.11 display nat outbound
1.1.12 display nat outbound port-block-group
1.1.13 display nat port-block
1.1.14 display nat port-block-group
1.1.15 display nat server
1.1.16 display nat server-group
1.1.17 display nat session
1.1.18 display nat static
1.1.19 display nat statistics
1.1.20 display nat user-information
1.1.21 failover-group
1.1.22 global-ip-pool
1.1.23 inside ip
1.1.24 local-ip-address
1.1.25 nat address-group
1.1.26 nat alg
1.1.27 nat attack-defense
1.1.28 nat centralized-backup auto switchback disable
1.1.29 nat centralized-backup enable
1.1.30 nat centralized-backup manual switch
1.1.31 nat dns-map
1.1.32 nat extended-port-block report-radius enable
1.1.33 nat hairpin enable
1.1.34 nat instance
1.1.35 nat log enable
1.1.36 nat log flow-active
1.1.37 nat log flow-begin
1.1.38 nat log flow-end
1.1.39 nat log port-alloc-fail
1.1.40 nat log port-block port-usage threshold
1.1.41 nat log port-block usage threshold
1.1.42 nat log port-block-alloc-fail
1.1.43 nat log port-block-assign
1.1.44 nat log port-block-withdraw
1.1.45 nat mapping-behavior endpoint-independent
1.1.46 nat outbound
1.1.47 nat outbound ds-lite-b4
1.1.48 nat outbound easy-ip failover-group
1.1.49 nat outbound port-block-group
1.1.50 nat port-block flow-trigger enable
1.1.51 nat port-block-group
1.1.52 nat server(接口NAT)
1.1.53 nat server(全局NAT)
1.1.54 nat server-group
1.1.55 nat service
1.1.56 nat static enable
1.1.57 nat static outbound
1.1.58 nat static outbound net-to-net
1.1.59 nat work-mode
1.1.60 port-block
1.1.61 port-limit
1.1.62 port-range
1.1.63 reset nat eim
1.1.64 reset nat session
1.1.65 service-instance-group
1 NAT
1.1  NAT配置命令
1.1.1  address
address命令用来添加一个地址成员。
undo address命令用来删除一个地址成员。
address start-address end-address
undo address start-address end-address
不存在地址成员。
NAT地址组视图
start-address end-address:地址成员的起始IP地址和结束IP地址。end-address必须大于或等于start-address,如果start-addressend-address相同,则表示只有一个地址。start-addressend-address之间的IP地址数量不能超过65536个。
一个NAT地址组/地址池是多个地址成员的集合。当需要对到达外部网络的数据报文进行地址转换时,报文的源地址将被转换为地址成员中的某个地址。
多次执行本命令添加的地址成员不能互相重叠。
如果公网地址成员与NAT端口块静态映射中的公网地址成员重叠,请确保NAT端口块静态映射中的端口范围与NAT端口块动态映射中的端口范围不重叠。否则当用户上线时,如果设备为两个不同的用户分配了相同的公网IP地址和端口块,可能会导致无法为其中一个用户创建NAT会话。
当NAT地址组被地址转换规则引用时,无法通过undo address命令删除该地址组中的地址成员。
# 在NAT地址组2中添加地址成员。
[Sysname] nat address-group 2
[Sysname-address-group-2] address 10.1.1.1 10.1.1.15
[Sysname-address-group-2] address 10.1.1.20 10.1.1.30
·     nat address-group
1.1.2  block-size
block-size命令用来设置端口块大小。
undo block-size命令用来恢复缺省情况。
block-size block-size
undo block-size
一个端口块中包含256个端口。
NAT端口块组视图
block-size:端口块大小,即一个端口块中所包含的端口数,取值范围为1~65535。
在一个端口块组中,需要根据私网IP地址个数,以及公网IP地址个数及其端口范围,确定一个合理的端口块大小值。端口块大小值不能超过公网地址的端口范围值。
# 配置端口块组1的端口块大小为1024。
[Sysname] nat port-block-group 1
[Sysname-port-block-group-1] block-size 1024
·     nat port-block-group
display nat address-group命令用来显示NAT地址组配置信息。
display nat address-group [ group-id ]
group-id:地址组的编号,取值范围为0~65535。如果不设置该值,则显示所有地址组。
# 显示所有地址组的配置信息。
<Sysname> display nat address-group
NAT address group information:
  Totally 5 NAT address groups.
  Address group 1:
    Port range: 1-65535
    Failover group name: nat
    Address information:
      Start address         End address
      202.110.10.10         202.110.10.15
  Address group 2:
    Port range: 1-65535
    Failover group name: trans
      202.110.10.20         202.110.10.25
      202.110.10.30         202.110.10.35
  Address group 3:
    Port range: 1024-65535
      202.110.10.40         202.110.10.50
  Address group 4:
    Port range: 10001-65535
    Port block size: 500
    Extended block number: 1
      202.110.10.60         202.110.10.65
  Address group 5:
    Port block size: 6400
    Extended block size: 64
      202.110.10.70         202.110.10.75
  Address group 6:
    Port range: 1-65535
# 显示指定地址组的配置信息。
<Sysname> display nat address-group 1
  Address group 1:
    Port range: 1-65535
表1-1 display nat address-group命令显示信息描述表
NAT地址组信息
Totally n NAT address groups
当前有n个地址组
Address group
地址组的编号
Port range
地址的端口范围
Block size
端口块大小。如果未配置,则不显示
Failover group name
NAT地址组绑定的备份组的名称。如果未配置,则不显示
增量端口块数。如果未配置,则不显示
Extended block size
每个增量端口块中包含的端口数。如果未配置,则不显示
Address information
地址组成员信息
Start address
地址组成员的起始地址。如果未配置,则显示”---”
End address
地址组成员的结束地址。如果未配置,则显示”---”
·     nat address-group
display nat all命令用来显示所有的NAT配置信息。
display nat all
# 显示所有的NAT配置信息。(接口NAT)(独立运行模式)
<Sysname> display nat all
  Address group 1:
    Port range: 1-65535
  Address group 2:
    Port range: 1-65535
    Failover group name: group1
  Address group 3:
    Failover group name: abc
  Address group 4:
  Address group 5:
  Address group 6:
    Port range: 1-65535
NAT server group information:
  Totally 3 NAT server groups.
  Group Number        Inside IP             Port        Weight
  1                   192.168.0.26          23          100
                      192.168.0.27          23          500
  2                   ---                   ---         ---
  3                   192.168.0.26          69          100
NAT outbound information:
  Totally 2 NAT outbound rules.
  Interface: GigabitEthernet3/1/2
    ACL: 2036         Address group: 1      Port-preserved: Y
    NO-PAT: N         Reversible: N
    Config status: Inactive
    Reasons for inactive status:
      The following items don't exist or aren't effective: address group, and ACL.
    ACL: 2037         Address group: 1      Port-preserved: N
    NO-PAT: Y         Reversible: Y
    VPN instance: vpn_nat
    Config status: Active
NAT internal server information:
  Totally 4 internal servers.
  Interface: GigabitEthernet3/1/3
    Protocol: 6(TCP)
    Global IP/port: 50.1.1.1/23
    Local IP/port : 192.168.10.15/23
    ACL           : 2000
    Service card  : Slot 3
    Config status : Active
  Interface: GigabitEthernet3/1/4
    Protocol: 6(TCP)
    Global IP/port: 50.1.1.1/23-30
    Local IP/port : 192.168.10.15-192.168.10.22/23
    Global VPN    : vpn1
    Local VPN     : vpn3
    Protocol: 255(Reserved)
    Global IP/port: 50.1.1.100/---
    Local IP/port : 192.168.10.150/---
    Global VPN    : vpn2
    Local VPN     : vpn4
    ACL           : 3000
    Config status : Inactive
      The following items don't exist or aren't effective: local VPN, and ACL.
  Interface: GigabitEthernet3/1/5
    Protocol: 17(UDP)
    Global IP/port: 50.1.1.2/23
    Local IP/port : server group 1
                    192.168.0.26/23       (Connections: 10)
                    192.168.0.27/23       (Connections: 20)
    Global VPN    : vpn1
    Local VPN     : vpn3
Static NAT mappings:
  Totally 2 outbound static NAT mappings.
  Net-to-net:
    Local IP     : 1.1.1.1 - 1.1.1.255
    Global IP    : 2.2.2.0
    Netmask      : 255.255.255.0
    Local VPN    : vpn1
    Global VPN   : vpn2
    ACL          : 2000
    Reversible   : Y
  IP-to-IP:
    Local IP     : 4.4.4.4
    Global IP    : 5.5.5.5
    Local VPN    : vpn1
    Global VPN   : vpn2
    ACL:         : 2001
    Reversible   : Y
      The following items don't exist or aren't effective: ACL.
Interfaces enabled with static NAT:
  Totally 2 interfaces enabled with static NAT.
  Interface: GigabitEthernet3/1/6
    Service card : ---
NAT DNS mappings:
  Totally 2 NAT DNS mappings.
  Domain name  : www.server.com
  Global IP    : 6.6.6.6
  Global port  : 23
  Protocol     : TCP(6)
  Domain name  : www.service.com
  Global IP    : ---
  Global port  : 12
  Protocol     : TCP(6)
    The following items don't exist or aren't effective: interface IP address.
NAT logging:
  Log enable               : Enabled
  Flow-begin               : Disabled
  Flow-end                 : Disabled
  Flow-active              : Disabled
  Port-block-assign        : Disabled
  Port-block-withdraw      : Disabled
  Port-alloc-fail          : Enabled
  Port-block-alloc-fail    : Disabled
  Port-usage               : Disabled
  Port-block-usage         : Enabled(40%)
NAT hairpinning:
  Totally 2 interfaces enabled with NAT hairpinning.
NAT mapping behavior:
  Mapping mode : Connection-dependent
NAT ALG:
  DNS        : Disabled
  FTP        : Enabled
  H323       : Disabled
  ICMP-ERROR : Enabled
  ILS        : Disabled
  MGCP       : Disabled
  NBT        : Disabled
  PPTP       : Disabled
  RTSP       : Enabled
  RSH        : Disabled
  SCCP       : Disabled
  SIP        : Disabled
  SQLNET     : Disabled
  TFTP       : Disabled
  XDMCP      : Disabled
NAT port block group information:
  Totally 3 NAT port block groups.
  Port block group 1:
    Port range: 1-65535
    Block size: 256
    Local IP address information:
      Start address        End address          VPN instance
      172.16.1.1           172.16.1.254         ---
      192.168.1.1          192.168.1.254        vpna
      192.168.3.1          192.168.3.254        vpna
    Global IP pool information:
      201.1.1.1            201.1.1.10
      201.1.1.21           201.1.1.25
  Port block group 2:
    Port range: 10001-30000
    Block size: 500
      10.1.1.1             10.1.10.255          vpnb
      202.10.10.101        202.10.10.120
  Port block group 3:
    Port range: 1-65535
    Block size: 256
NAT outbound port block group information:
  Totally 2 outbound port block group items.
    Port-block-group: 2
    Port-block-group: 10
      The following items don't exist or aren't effective: port block group.
上述显示信息是目前所有NAT配置信息的集合。由于部分NAT配置(nat address-groupnat server-groupnat outboundnat servernat staticnat static net-to-netnat static enablenat dns-mapnat lognat port-block-groupnat outbound port-block-group)有自己独立的显示命令,且此处显示信息的格式与各命令对应的显示信息的格式相同的,所以此处不对这些配置的显示字段的含义进行详细解释,如有需要,请参考各独立的显示命令。下面的表格将给出相关显示命令的参见信息并仅解释nat hairpin enablenat mapping-behaviornat alg配置的显示字段的含义。
表1-2 display nat all命令显示信息描述表
NAT地址组的配置信息,详细字段解释请参见“表1-1
NAT Instance information
NAT实例的配置信息,详细字段请参见“表1-6
NAT内部服务器组的配置信息,详细字段解释请参见“表1-15
出方向动态地址转换的配置信息,详细字段解释请参见“表1-9
NAT内部服务器的配置信息,详细字段解释请参见“表1-14
Static NAT mappings
静态地址转换的配置信息,详细字段解释请参见“表1-17
NAT DNS mappings
NAT DNS mapping的配置信息,详细字段解释请参见“表1-3
NAT logging
NAT日志功能的配置信息,详细字段解释请参见“表1-7
NAT hairpinning
NAT hairpin功能。如果未配置,则不显示该字段
Totally n interfaces enabled NAT hairpinning
当前有n个接口开启NAT hairpin功能
开启NAT hairpin功能的接口
Service card
显示提供NAT处理的业务板。如果接口下没有指定业务板,则显示为“---”
Config status
显示NAT hairpin配置的状态:Active:生效
NAT Mapping mode
PAT方式下的地址转换模式
·     Endpoint-Independent:表示不关心对端地址和端口的转换模式
·     Connection-dependent:表示关心对端地址和端口的非共享转换模式
NAT ALG
各协议的NAT ALG功能开启信息
NAT端口块组的配置信息,详细字段解释请参见“表1-13
NAT端口块静态映射的配置信息,详细字段解释请参见“表1-10
display nat dns-map命令用来显示NAT DNS mapping配置信息。
display nat dns-map
# 显示NAT DNS mapping的配置信息。
<Sysname> display nat dns-map
NAT DNS mapping information:
  Global IP    : 6.6.6.6
  Global port  : 23
  Protocol     : TCP(6)
  Global IP    : ---
  Global port  : 12
  Protocol     : TCP(6)
表1-3 display nat dns-map命令显示信息描述表
NAT DNS mapping配置信息
Totally n NAT DNS mappings
当前有n条DNS mapping配置
Domain name
DNS域名
Global IP
外网地址。如果配置使用的是Easy IP方式,则此处显示指定的接口的地址。“---”表示接口下未配置外网地址
Global port
外网端口号
Protocol
协议名称以及协议编号
Config status
显示DNS mapping配置的状态
·     Active:生效
·     Inactive:不生效
当Config status字段为Inactive时,显示DNS mapping配置不生效的原因
·     The following items don't exist or aren't effective: interface IP address:引用的接口未配置IP地址
·     nat dns-map
display nat eim命令用来显示NAT EIM表项信息。
独立运行模式:
display nat eim [ slot slot-number ] [ protocol { icmp | tcp | udp } ] [ local-ip { b4 ipv6-address | local-ip } ] [ local-port local-port ] [ global-ip global-ip ] [ global-port global-port ]
IRF模式:
display nat eim [ chassis chassis-number slot slot-number ] [ protocol { icmp | tcp | udp } ] [ local-ip { b4 ipv6-address | local-ip } ] [ local-port local-port ] [ global-ip global-ip ] [ global-port global-port ]
slot slot-number:显示指定单板上的EIM表项信息,slot-number表示单板所在的槽位号。若不指定该参数,则表示显示所有单板上的EIM表项信息。(独立运行模式)
chassis chassis-number slot slot-number:显示指定成员设备的指定单板上的EIM表项信息,chassis-number表示设备在IRF中的成员编号,slot-number表示单板所在的槽位号。若不指定该参数,则表示显示所有成员设备的所有单板上的EIM表项信息。(IRF模式)
protocol:显示指定协议类型的EIM表项信息。
icmp:显示ICMP协议类型的EIM表项信息。
tcp:显示TCP协议类型的EIM表项信息。
udp:显示UDP协议类型的EIM表项信息。
local-ip local-ip:显示指定内网IP地址的EIM表项信息,local-ip表示内网IP地址。
local-ip b4 ipv6-address显示指定B4设备IPv6地址的EIM表项信息,ipv6-address表示B4设备的IPv6地址。
local-port local-port:显示指定内网端口号的EIM表项信息,local-port表示内网端口号,取值范围为0~65535。
global-ip global-ip:显示指定公网IP地址的EIM表项信息,global-ip表示公网IP地址。
global-port global-port:显示指定公网端口号的EIM表项信息,global-port表示公网端口号,取值范围为0~65535。
EIM三元组表项是报文在进行Endpoint-Independent Mapping方式的PAT转换时创建的,它记录了内网和外网的转换关系(内网地址和端口<-->NAT地址和端口),该表项有以下两个作用:
·     保证后续来自相同源地址和源端口的新建连接与首次连接使用相同的转换关系。
·     允许外网主机向NAT地址和端口发起的新建连接根据EIM表项进行反向地址转换。
# 显示指定slot上的NAT EIM表项信息。
<Sysname> display nat eim slot 3
Slot 3:
Local  IP/port: 192.168.100.100/1024
Global IP/port: 200.100.1.100/2048
DS-Lite tunnel peer: -
Local  VPN: vpn1
Global VPN: vpn2
Protocol: TCP(6)
Local  IP/port: 192.168.100.200/2048
Global IP/port: 200.100.1.200/4096
Protocol: UDP(17)
Total entries found: 2
# 显示指定slot上协议为TCP的NAT EIM表项信息。
<Sysname> display nat eim slot 3 protocol tcp
Slot 3:
Local  VPN: vpn1
Global VPN: vpn2
Protocol: TCP(6)
Total entries found: 1
表1-4 display nat eim命令显示信息描述表
DS-Lite tunnel peer
DS-Lite B4端隧道地址。会话不属于任何DS-Lite隧道时,本字段显示为“-”
Local VPN
内网地址所属的MPLS L3VPN的VPN实例名称。如果不属于任何VPN实例,则不显示该字段
Global VPN
外网地址所属的MPLS L3VPN的VPN实例名称。如果不属于任何VPN实例,则不显示该字段
Protocol
协议名称以及协议编号
Failover group name
备份组的名称。如果未绑定任何备份组,本字段显示为“-”
Total entries found
当前查找到的EIM表项的个数
·     nat mapping-behavior
·     nat outbound
display nat eim statistics命令用来显示NAT EIM表项的统计信息。
独立运行模式:
display nat eim statistics [ slot slot-number ]
IRF模式:
display nat eim statistics [ chassis chassis-number slot slot-number ]
slot slot-number:显示指定单板上的EIM表项统计信息,slot-number表示单板所在的槽位号。若不指定该参数,则表示显示所有单板上的EIM表项统计信息。(独立运行模式)
chassis chassis-number slot slot-number:显示指定成员设备的指定单板上的EIM表项统计信息,chassis-number表示设备在IRF中的成员编号,slot-number表示单板所在的槽位号。若不指定该参数,则表示显示所有成员设备的所有单板上的EIM表项统计信息。(IRF模式)
通过本命令可以查看NAT EIM表项的统计信息,包括EIM表项的数量、传输层协议为TCP或UDP的EIM表项创建速率等信息。
# 显示指定slot上NAT EIM的统计信息。
<Sysname> display nat eim statistics slot 3
EIM: Total EIM entries.
TCP: Total EIM entries for TCP.
UDP: Total EIM entries for UDP.
Rate: Creating rate of EIM entries.
TCP rate: Creating rate of EIM entries for TCP.
UDP rate: Creating rate of EIM entries for UDP.
Slot EIM       TCP       UDP       Rate          TCP rate      UDP rate
                                  (entries/s)   (entries/s)   (entries/s)
2    0         0         0         0             0             0
表1-5 display nat eim statistics命令显示信息描述表
Total EIM entries
EIM表项个数
传输层协议为TCP的EIM表项个数
传输层协议为UDP的EIM表项个数
EIM表项的创建速率
传输层协议为TCP的EIM表项创建速率
传输层协议为UDP的EIM表项创建速率
display nat instance命令用来显示NAT实例的配置信息。
display nat instance [instance-name ]
instance-name:显示指定NAT实例的配置信息。instance-name表示NAT实例的名称,为1~31个字符的字符串,区分大小写。如果未指定本参数,将显示所有NAT实例的配置信息。
# 显示所有NAT实例的配置信息。
<Sysname> display nat instance
NAT Instance information:
  Totally 2 NAT instance.
  Instance instance1:
    Instance ID: 10
    service-instance-group sgrp
    flow trigger alloc port block
    nat outbound 3000 address-group 1
    nat outbound port-block-group 1
    nat centralized-backup switch
    nat centralized-backup switchback disable
  Instance instance2:
    Instance ID: 11
    service-instance-group group1
# 显示指定NAT实例的配置信息。
<Sysname> display nat instance instance1
  Instance instance1:
    Instance ID: 10
    nat outbound acl 3000 address-group 1
表1-6 display nat instance命令显示信息描述表
Totally n NAT instances
NAT实例的总数为n
Instance xxx
名称为xxx的NAT实例
Instance ID
NAT实例的ID
出方向动态地址转换的配置
出方向NAT端口块静态映射的配置
NAT实例关联的业务实例组的名称
流量触发分配端口块开关。如果未开启流量触发分配端口块功能,则不显示该字段
开启了集中式备份分布式CGN功能
将分布式部署CGN设备上的流量手工强制切换到集中式部署CGN设备上进行地址转换的配置
nat centralized-backup atuo switchback disable
禁止集中式备份分布式CGN设备上的流量自动回切到分布式部署CGN设备上进行地址转换的配置
·     nat instance
display nat log命令用来显示NAT日志功能的配置信息。
display nat log
# 显示NAT日志功能的配置信息。
<Sysname> display nat log
NAT logging:
  Flow-end                 : Disabled
表1-7 display nat log命令显示信息描述表
NAT logging
NAT日志功能的配置信息
Log enable
NAT日志开关
·     Enabled:表示处于开启状态。如果指定了ACL,则同时显示指定的ACL编号或名称
·     Disabled:表示处于关闭状态
Flow-begin
NAT会话新建日志功能开关
·     Enabled:表示处于开启状态
·     Disabled:表示处于关闭状态
Flow-end
NAT会话删除日志功能开关
·     Enabled:表示处于开启状态
·     Disabled:表示处于关闭状态
Flow-active
NAT活跃流日志功能开关
·     Enabled:表示处于开启状态。该状态下,将同时显示配置的生成活跃流日志的时间间隔(单位为分)
·     Disabled:表示处于关闭状态
Port-block-assign
端口块分配的NAT444用户日志功能开关
·     Enabled:表示处于开启状态
·     Disabled:表示处于关闭状态
Port-block-withdraw
端口块回收的NAT444用户日志功能开关
·     Enabled:表示处于开启状态
·     Disabled:表示处于关闭状态
Port-alloc-fail
端口分配失败的日志功能开关
·     Enabled:表示处于开启状态
·     Disabled:表示处于关闭状态
端口块分配失败的日志功能开关
·     Enabled:表示处于开启状态
·     Disabled:表示处于关闭状态
Port-usage
端口块中端口使用率的日志功能开关
·     Enabled:表示处于开启状态。该状态下,将同时显示配置的端口使用率的阈值(单位为百分比)
·     Disabled:表示处于关闭状态
Port-block-usage
端口块使用率的日志功能处于开启(Enabled)状态,同时显示配置的端口块使用率的阈值(单位为百分比),缺省值为90%
·     nat log enable
·     nat log flow-active
·     nat log flow-begin
display nat no-pat命令用来显示NAT NO-PAT表项信息。
独立运行模式:
display nat no-pat [ slot slot-number ]
IRF模式:
display nat no-pat [ chassis chassis-number slot slot-number ]
slot slot-number:显示指定单板上的NO-PAT表项信息,slot-number表示单板所在的槽位号。若不指定该参数,则表示显示所有单板上的NO-PAT表项信息。(独立运行模式)
chassis chassis-number slot slot-number:显示指定成员设备的指定单板上的NO-PAT表项信息,chassis-number表示设备在IRF中的成员编号,slot-number表示单板所在的槽位号。若不指定该参数,则表示显示所有成员设备的所有单板上的NO-PAT表项信息。(IRF模式)
NO-PAT表项记录了动态分配的一对一地址映射关系,该表项有两个作用:
·     保证后续同方向的新连接使用与第一个连接相同的地址转换关系。
·     反方向的新连接可以使用NO-PAT表进行地址转换。
# 显示指定slot的NAT NO-PAT表项。
<Sysname> display nat no-pat slot 3
Slot 3:
Global  IP: 200.100.1.100
Local   IP: 192.168.100.100
Global VPN: vpn2
Local  VPN: vpn1
Reversible: N
Type      : Outbound
表1-8 display nat no-pat命令显示信息描述表
Local VPN
内网地址所属的MPLS L3VPN的实例名称。如果不属于任何VPN实例,则该行不显示
Global VPN
外网地址所属的MPLS L3VPN的实例名称。如果不属于任何VPN实例,则该行不显示
Reversible
是否允许反向地址转换。若其值为“Y”,则表示在某方向上发起的连接已成功建立地址转换表项的情况下,允许反方向发起的连接使用已建立的地址转换表项进行地址转换;若其值为“N”,则表示不允许
NO-PAT表项类型
·     Outbound:出方向动态地址转换过程中创建的NO-PAT表项
Total entries found
当前查找到的NO-PAT表项的个数
·     nat outbound
display nat outbound命令用来显示出方向动态地址转换的配置信息。
# 显示出方向动态地址转换的配置信息。
<Sysname> display nat outbound
  Interface: GigabitEthernet3/1/1
    Service card: Slot 3
    ACL: 2037         Address group: 2      Port-preserved: N
      The following items don't exist or aren't effective: global VPN, and ACL.
    DS-Lite B4 ACL: 2100         Address group: 0      Port-preserved: N
表1-9 display nat outbound命令显示信息描述表
出方向动态地址转换的配置信息
Totally n NAT outbound rules
当前存在n条出方向动态地址转换
出方向动态地址转换配置所在的接口
ACL
引用的IPv4 ACL编号或名称。如果未配置,则显示“---”
DS-Lite B4 ACL
DS-Lite B4引用的IPv6 ACL编号或名称
Address group
出方向动态地址转换使用的地址组。如果未配置,则显示“---”
Port-preserved
PAT方式下,是否尽量不转换端口
NO-PAT
是否使用NO-PAT方式进行转换。若其值为“N”,则表示使用PAT方式
Reversible
VPN instance
地址组所属的MPLS L3VPN的VPN实例名称。如果不属于任何VPN实例,则不显示该字段
Service card
显示提供NAT处理的业务板。如果接口下未指定业务板,则显示为“---”
Config status
显示配置的状态
·     Active:生效
·     Inactive:不生效
当Config status字段为Inactive时,显示配置不生效的原因
·     The following items don't exist or aren't effective: global VPN, interface IP address, address group, and ACL:配置中地址组所属的VPN实例、接口地址、地址组、ACL不存在或不生效
·     NAT address conflicts:NAT地址冲突
·     nat outbound
display nat outbound port-block-group命令用来显示NAT端口块静态映射的配置信息。
# 显示NAT端口块静态映射的配置信息。
<Sysname> display nat outbound port-block-group
    Port-block-group: 2
表1-10 display nat outbound port-block-group 命令显示信息描述表
NAT端口块静态映射的配置信息
Totally n outbound port block group items
当前存在n条NAT端口块静态映射配置
NAT端口块静态映射配置所在的接口
port-block-group
端口块组编号
Config status
显示配置的状态
·     Active:生效
·     Inactive:不生效
·     The following items don't exist or aren't effective: port block group:配置中端口块组不存在或不生效
·     nat outbound port-block-group
display nat port-block命令用来显示端口块表项。
独立运行模式:
display nat port-block { dynamic [ ds-lite-b4 ] | static } [ ip ipv4-source-address ] [ slot slot-number ] [ verbose ]
display nat port-block dynamic ds-lite-b4 [ ipv6 ipv6-source-address ] [ slot slot-number ] ] [ verbose ]
IRF模式:
display nat port-block { dynamic [ ds-lite-b4 ] | static } [ ip ipv4-source-address ] [ chassis chassis-number slot slot-number ] [ verbose ]
display nat port-block { dynamic [ ds-lite-b4 ] | static }[ ipv6 ipv6-source-address ] [ chassis chassis-number slot slot-number ] [ verbose ]
dynamic:显示动态端口块表项。
ds-lite-b4:显示基于DS-Lite B4地址的端口块表项。
static:显示静态端口块表项。
ip ipv4-source-address:显示指定IPv4源地址的端口块表项。ipv4-source-address表示源地址,该地址必须是创建端口块表项的报文的源地址。
ipv6 ipv6-source-address:显示指定IPv6源地址的端口块表项。ipv6-source-address表示源地址,该地址必须是创建端口块表项的报文的源地址。
slot slot-number:显示指定单板上的端口块表项信息,slot-number表示单板所在的槽位号。若不指定该参数,则表示显示所有单板上的端口块表项信息。(独立运行模式)
chassis chassis-number slot slot-number:显示指定成员设备的指定单板上的端口块表项信息,chassis-number表示设备在IRF中的成员编号,slot-number表示单板所在的槽位号。若不指定该参数,则表示显示所有成员设备的所有单板上的端口块表项信息。(IRF模式)
verbose:显示单板上的端口块表项的详细信息。若不指定该参数,则显示端口块表项的概要信息。
# 显示指定slot上的静态端口块表项。(独立运行模式)
<Sysname> display nat port-block static slot 3
Slot 3:
Local VPN     Local IP         Global IP        Port block   Connections  Extend
---           100.100.100.111  202.202.100.101  10001-10256  0            ---
---           100.100.100.112  202.202.100.101  10257-10512  0            ---
---           100.100.100.113  202.202.100.101  10513-10768  0            ---
vpn01         100.100.100.113  202.202.100.101  10769-11024  0            ---
---           100.100.100.114  0.0.0.0          ---          0            ---
Total mappings found: 5
# 显示指定slot上静态端口块表项的详细信息。(独立运行模式)
<Sysname> display nat port-block static slot 3 verbose
Slot 3:
    Static port block entry
Local IP         : 200.1.24.219
Local vpn        : ---(0)
Global IP        : 202.2.1.8
Global vpn       : ---(0)
Port block       : 24774-26023
Connections      : 0
FailgroupID      : 16
PortLimit TCP    : N/A
PortLimit UDP    : N/A
PortLimit ICMP   : N/A
PortLimit total  : 100
PortUsed  TCP    : 0
PortUsed  UDP    : 0
PortUsed  ICMP   : 0
PortUsed  total  : 0
Extend port block: N
Local IP         : 200.1.40.231
Local vpn        : ---(0)
Global IP        : 0.0.0.0
Global vpn       : ---(0)
Port block       : ---
Connections      : 0
FailgroupID      : 16
PortLimit TCP    : N/A
PortLimit UDP    : N/A
PortUsed  TCP    : 0
PortUsed  UDP    : 0
PortUsed  ICMP   : 0
PortUsed  total  : 0
Total mappings found: 2
# 显示指定slot上的动态端口块表项。
<Sysname> display nat port-block dynamic slot 3
Slot 3:
---           101.1.1.12       192.168.135.201  10001-11024  1            ---
Total mappings found: 1
# 显示指定slot上的基于DS-Lite B4地址的端口块表项。
<Sysname> display nat port-block dynamic ds-lite-b4 slot 3
Slot 3:
Local VPN    DS-Lite B4 addr      Global IP       Port block  Connections Extend
---          2000::2              192.168.135.201 10001-11024 1           ---
# 显示指定slot上动态端口块表项的详细信息。
<Sysname> display nat port-block dynamic slot 3 verbose
Slot 3:
Dynamic port block entry
Local vpn        : ---(0)
Global vpn       : ---(0)
Connections      : 0
FailgroupID      : 16
PortLimit TCP    : N/A
PortLimit UDP    : N/A
PortUsed  TCP    : 0
PortUsed  UDP    : 0
PortUsed  ICMP   : 0
PortUsed  total  : 0
Local vpn        : ---(0)
Global IP        : 202.2.1.10
Global vpn       : ---(0)
Port block       : 32274-33523
Connections      : 0
FailgroupID      : 16
PortLimit TCP    : N/A
PortLimit UDP    : N/A
PortUsed  TCP    : 0
PortUsed  UDP    : 0
PortUsed  ICMP   : 0
PortUsed  total  : 0
Slot 3:
Local vpn        : ---(0)
Global vpn       : ---(0)
Connections      : 0
FailgroupID      : 16
PortLimit TCP    : N/A
PortLimit UDP    : N/A
PortUsed  TCP    : 0
PortUsed  UDP    : 0
PortUsed  ICMP   : 0
PortUsed  total  : 0
Local vpn        : ---(0)
Global IP        : 0.0.0.0
Global vpn       : ---(0)
Port block       : ---
Connections      : 0
FailgroupID      : 16
PortLimit TCP    : N/A
PortLimit UDP    : N/A
PortUsed  TCP    : 0
PortUsed  UDP    : 0
PortUsed  ICMP   : 0
PortUsed  total  : 0
表1-11 display nat port-block命令显示信息描述表
Local VPN
私网IP地址所属VPN实例,“---”表示不属于任何VPN实例
Local IP
私网IP地址
DS-Lite B4 addr
DS-Lite B4设备的IPv6地址
Global IP
公网IP地址。显示为0.0.0.0表示公网资源不足,未能分配到公网IP地址
Port block
端口块(起始端口-结束端口)。当公网资源不足时,本字段显示为“---”
Connections
当前使用本端口块中的端口建立的连接数
Extend
是否为增量端口块:
·     Ext:表示是增量端口块
·     ---:表示非增量端口块
当前查找到的端口块表项的个数
表1-12 display nat port-block verbose命令详细显示信息描述表
Local IP
私网IP地址
Local vpn
私网IP地址所属VPN实例,“---(0)”表示不属于任何VPN实例
Global IP
Global vpn
公网IP地址所属VPN实例,“---(0)”表示不属于任何VPN实例
Port block
Connections
当前使用本端口块中的端口建立的连接数
FailgroupID
端口块表项所属的备份组
PortLimit TCP
最多可分配给TCP协议的端口数量
PortLimit UDP
最多可分配给UDP协议的端口数量
PortLimit ICMP
最多可分配给ICMP协议的端口数量
PortLimit total
最多可分配的端口数量
PortUsed  TCP
TCP报文分配的端口数
PortUsed  UDP
UDP报文分配的端口数
PortUsed  ICMP
ICMP报文分配的端口数
PortUsed  total
分配的端口总数
Extend port block
是否为增量端口块:
·     Y:表示是增量端口块
·     N:表示非增量端口块
当前查找到的端口块表项的个数
display nat port-block-group命令用来显示NAT端口块组配置信息。
display nat port-block-group [ group-id ]
group-id:端口块组的编号,取值范围为0~65535。如果不设置该值,则显示所有端口块组的配置信息。
# 显示所有端口块组的配置信息。
<Sysname> display nat port-block-group
  Port block group 1:
    Port range: 1-65535
    Block size: 256
  Port block group 2:
    Block size: 500
  Port block group 3:
    Port range: 1-65535
    Block size: 256
# 显示端口块组1的配置信息。
<Sysname> display nat port-block-group 1
  Port block group 1:
    Port range: 1-65535
    Block size: 256
表1-13 display nat port-block-group 命令显示信息描述表
NAT端口块组信息
Totally n NAT port block groups
当前有n个端口块组
Port block group
端口块组的编号
Port range
公网地址的端口范围
Block size
端口块大小
Failover group name
NAT端口块组绑定的备份组的名称。如果未配置,则不显示
私网IP地址成员信息
公网IP地址成员信息
Start address
私网/公网IP地址成员的起始IP地址。如果未配置,则显示“---”
End address
私网/公网IP地址成员的成员结束IP地址。如果未配置,则显示“---”
VPN instance
私网IP地址成员所属的VPN实例。如果未配置,则显示“---”
display nat server命令用来显示NAT内部服务器的配置信息。
display nat server
# 显示NAT内部服务器的信息。
<Sysname> display nat server
    Protocol: 6(TCP)
    Protocol: 6(TCP)
    Global VPN    : vpn1
    Local VPN     : vpn3
      The following items don't exist or aren't effective: local VPN.
    Global VPN    : vpn2
    Local VPN     : vpn4
    Protocol: 17(UDP)
                    1.1.1.1/21            (Connections: 10)
                    192.168.100.200/80    (Connections: 20)
    Global VPN    : vpn1
    Local VPN     : vpn10
表1-14 display nat server命令显示信息描述表
NAT内部服务器的配置信息
Totally n internal servers
当前存在n条内部服务器配置
内部服务器配置所在的接口
Protocol
内部服务器的协议编号以及协议名称
Global IP/port
内部服务器的外网地址/端口号
·     Global IP可以是单个地址,也可以是一个连续的地址段。如果使用Easy IP方式,则此处显示指定的接口的地址;如果接口下未配置地址,则Global IP显示为“---”
·     port可以是单个端口,也可以是一个连续的端口段。如果指定的协议没有端口的概念,则port显示为“---”
Local IP/port
对于普通内部服务器,显示服务器的内网地址/端口号
·     Local IP可以是单个地址,也可以是一个连续的地址段
对于负载分担内部服务器,显示内部服务器组编号以及服务器组成员的IP地址、端口和连接数
Global VPN
Local VPN
内网地址所属的MPLS L3VPN的VPN实例名称。 如果不属于任何VPN实例,则不显示该字段
ACL
引用的ACL编号或名称。如果未配置,则不显示该字段
Service card
Config status
显示配置的状态
·     Active:生效
·     Inactive:不生效
·     The following items don't exist or aren't effective: local VPN, global VPN, interface IP address, server group, and ACL:配置中内网地址所属的VPN实例、外网地址所属的VPN实例、接口地址、服务器组、ACL不存在或不生效
·     Server configuration conflicts:NAT内部服务器配置冲突
·     nat server
display nat server-group命令用来显示NAT内部服务器组的配置信息。
display nat server-group [ group-id ]
group-id:NAT内部服务器组的编号,取值范围为0~65535。如果不指定该参数,则显示所有内部服务器组。
# 显示所有NAT内部服务器组的配置信息。
<Sysname> display nat server-group
                      192.168.0.27          23          500
  2                   ---                   ---         ---
# 显示指定NAT内部服务器组的配置信息。
<Sysname> display nat server-group 1
                      192.168.0.27          23          500
表1-15 display nat server-group命令显示信息描述表
NAT内部服务器组信息
Totally n NAT server groups
当前有n个内部服务器组
Group Number
内部服务器组的编号
Inside IP
内部服务器组成员在内网的IP地址。如果未配置,则显示“---”
Port
内部服务器组成员在内网的端口。如果未配置,则显示“---”
Weight
内部服务器组成员的权重值。如果未配置,则显示“---”
·     nat server-group
display nat session命令用来显示NAT会话,即经过NAT地址转换处理的会话。
独立运行模式:
display nat session [ { source-ip source-ip | destination-ip destination-ip } * [ vpn-instance vpn-instance-name ] ] [ slot slot-number ] [ brief | verbose ]
IRF模式:
display nat session [ { source-ip source-ip | destination-ip destination-ip } * [ vpn-instance vpn-instance-name ] ] [ chassis chassis-number slot slot-number ] [ brief | verbose ]
source-ip source-ip:显示指定源地址的会话。source-ip表示源地址,该地址必须是创建会话的报文的源地址。
destination-ip destination-ip:显示指定目的地址的会话。destination-ip表示目的地址,该地址必须是创建会话的报文的目的地址。
vpn-instance vpn-instance-name:显示指定目的VPN实例的会话。vpn-instance-name表示MPLS L3VPN的VPN实例名称,为1~31个字符的字符串,区分大小写。该VPN实例必须是报文中携带的VPN实例。如果不指定该参数,则显示目的IP不属于任何VPN实例的会话。
slot slot-number:显示指定单板上的NAT会话,slot-number表示单板所在的槽位号。若不指定该参数,则显示所有单板上的NAT会话(独立运行模式)
chassis chassis-number slot slot-number:显示指定成员设备的指定单板上的NAT会话,chassis-number表示设备在IRF中的成员编号,slot-number表示单板所在的槽位号。若不指定该参数,则显示所有成员设备的所有单板上的NAT会话。(IRF模式)
brief:显示NAT会话的简要信息。
verbose:显示NAT会话的详细信息。若不指定该参数,则显示会话的概要信息。
如果不指定任何参数,则显示所有的NAT会话的详细信息。
# 显示指定slot上NAT会话的详细信息。
<Sysname> display nat session slot 3 verbose
Slot 3:
Initiator:
  Source      IP/port: 192.168.1.18/1877
  Destination IP/port: 192.168.1.55/22
  VPN instance/VLAN ID/VLL ID: -/-/-
  Protocol: TCP(6)
  Inbound interface: GigabitEthernet3/1/1
Responder:
  Source      IP/port: 192.168.1.55/22
  Destination IP/port: 192.168.1.10/1877
  Protocol: TCP(6)
  Inbound interface: GigabitEthernet3/1/2
State: TCP_SYN_SENT
Application: SSH
Role: Standby
Failover group ID: 1
Start time: 2017-10-18 11:22:45
Initiator->Responder:         1 packets         48 bytes
Responder->Initiator:         0 packets          0 bytes
Total sessions found: 1
# 显示指定slot上NAT会话的简要信息。
<Sysname> display nat session slot 3 brief
Slot 3:
Protocol   Source IP/port      Destination IP/port    Global IP/port
TCP        10.2.1.58/2477      20.1.1.2/1025          30.2.4.9/226
表1-16 display nat session命令显示信息描述表
Source IP/port
源IP地址/端口号
Destination IP/port
目的IP地址/端口号
DS-Lite tunnel peer
DS-Lite隧道对端地址。会话不属于任何DS-Lite隧道时,本字段显示为“-”
会话所属的MPLS L3VPN/二层转发时会话所属的VLAN ID/二层转发时会话所属的INLINE。如果未指定则显示“-/-/-”
Protocol
传输层协议类型,包括:DCCP、ICMP、Raw IP 、SCTP、TCP、UDP、UDP-Lite
Inbound interface
报文的入接口
会话状态
Application
应用层协议类型,取值包括:FTP、DNS等,OTHER表示未知协议类型,其对应的端口为非知名端口
Role
slot在备份组中的角色:
·     Master:备份组的主节点
·     Standby:备份组的备节点
Failover group ID
备份组ID,当备份组中的主节点处理业务时,备节点上创建了会话,此时显示为“-”
Start time
会话创建时间
发起方到响应方的报文数、报文字节数
响应方到发起方的报文数、报文字节数
当前查找到的会话的总数
Source IP/port
发起方的源IP地址/端口号
Destination IP/port
发起方的目的IP地址/端口号
Global IP/port
公网IP地址/端口号
·     reset nat session
display nat static命令用来显示NAT静态地址转换的配置信息。
display nat static
# 显示NAT静态地址转换的配置信息。
<Sysname> display nat static
  Net-to-net:
    Global IP    : 2.2.2.0
    Local VPN    : vpn1
    Global VPN   : vpn2
    ACL          : 2000
    Reversible   : Y
  IP-to-IP:
    Local IP     : 4.4.4.4
    Global IP    : 5.5.5.5
    Local VPN    : vpn4
    Global VPN   : vpn3
    ACL:         : 2000
    Reversible   : Y
      The following items don't exist or aren't effective: local VPN, and global VPN.
表1-17 display nat static命令显示信息描述表
Static NAT mappings
静态地址转换的配置信息
Totally n outbound static NAT mappings
当前存在n条出方向静态地址转换的配置
Net-to-net
网段到网段的静态地址转换映射
IP-to-IP
IP到IP的静态地址转换映射
Local IP
内网IP地址或地址范围
Global IP
外网IP地址或地址范围
Netmask
IP地址掩码
Local VPN
Global VPN
ACL
Reversible
如果未配置,则不显示该字段
静态地址转换在接口下的开启情况
Totally n interfaces enabled with static NAT
当前有n个接口开启了静态地址转换
开启静态地址转换功能的接口
Service card
显示提供NAT服务的业务板。如果接口下未指定业务板,则不显示该字段
Config status
显示配置的状态
·     Active:生效
·     Inactive:不生效
·     The following items don't exist or aren't effective: local VPN, global VPN, and ACL:配置中内网地址所属的VPN实例、外网地址所属的VPN实例、ACL不存在或不存在
·     nat static
·     nat static net-to-net
·     nat static enable
display nat statistics命令用来显示NAT统计信息。
独立运行模式:
display nat statistics [ summary ] [ slot slot-number ]
IRF模式:
display nat statistics [ summary ] [ chassis chassis-number slot slot-number ]
summary:显示NAT统计信息的摘要信息。不指定该参数时,显示NAT统计信息的详细信息。
slot slot-number:显示指定单板上的NAT统计信息,slot-number表示单板所在的槽位号。若不指定该参数,则显示所有单板上的NAT统计信息。(独立运行模式)
chassis chassis-number slot slot-number:显示指定成员设备的指定单板上的NAT统计信息,chassis-number表示设备在IRF中的成员编号,slot-number表示单板所在的槽位号。若不指定该参数,则显示所有成员设备的所有单板上的NAT统计信息。(IRF模式)
# 显示所有NAT统计信息的详细信息。
<Sysname> display nat statistics
Slot 3:
  Total session entries: 100
  Total EIM entries: 1
  Total inbound NO-PAT entries: 0
  Total outbound NO-PAT entries: 0
  Total static port block entries: 10
  Total dynamic port block entries: 15
  Active static port block entries: 0
  Active dynamic port block entries: 0
表1-18 display nat statistics命令显示信息描述表
NAT会话表项个数
Total EIM entries
EIM表项个数
入方向的NO-PAT表项个数
出方向的NO-PAT表项个数
当前配置创建的静态端口块表项个数
当前配置可创建的动态端口块表项个数,即可分配的动态端口块总数,包括已分配的端口块和尚未分配的端口块。如果用户设置的端口块参数中增量端口块与预分配端口块大小不同,系统将按照端口块大小为64来计算可创建的动态端口块表项个数
当前正在使用的静态端口块表项个数
当前已创建的动态端口块表项个数,即已分配的动态端口块个数
# 显示所有NAT统计信息的概要信息。
<Sysname> display nat statistics summary
SPB: Total static port block entries.
DPB: Total dynamic port block entries.
ASPB: Active static port block entries.
ADPB: Active dynamic port block entries.
Slot Sessions  EIM       SPB       DPB       ASPB      ADPB
2    0         0         0         1572720   0         0
表1-19 display nat statistics summary命令显示信息描述表
Sessions
NAT会话表项个数
EIM
EIM表项个数
SPB
当前配置创建的静态端口块表项个数
DPB
ASPB
当前正在使用的静态端口块表项个数
ADPB
display nat user-information命令用来显示已上线用户的信息。
(独立运行模式)
display nat user-information [ local { ipv4 ipv4-address | ipv6 ipv6address } | user-id user-id | user-name user-name | nat-instance instance-name ] [ slot slot-number ] [ verbose ]
display nat user-information [ local { ipv4 ipv4-address | ipv6 ipv6address } | user-id user-id | user-name user-name | nat-instance instance-name ] [ chassis chassis-number slot slot-number ] [ verbose ]
local ipv4 ipv4-address:显示指定内网IPv4地址的已上线用户的信息。
local ipv6 ipv6-address:显示指定内网IPv6地址的已上线用户的信息。
user-id user-id:显示指定用户ID的上线用户信息。user-id表示用户ID,取值范围为十六进制数1~FFFFFFFF。
user-name user-name:显示指定用户名的已上线用户信息。user-name表示用户名称,取值范围为1~253个字符的字符串。
nat-instance instance-name:显示指定NAT实例名称的已上线用户的信息。instance-name表示NAT实例名称,取值范围为1~31个字符的字符串。
slot slot-number:显示指定单板上的上线用户信息。slot-number表示单板所在的槽位号。如果不指定本参数,则显示所有单板上已上线用户的信息。(独立运行模式)
chassis chassis-number slot slot-number:显示指定成员设备的指定单板上已上线用户的信息。chassis-number表示设备在IRF中的成员编号,slot-number表示单板所在的槽位号。如果不指定本参数,则显示所有成员设备的所有单板上已上线用户的信息。(IRF模式)
verbose:显示已上线用户的详细信息。如果未指定本参数,则显示已上线用户的概要信息。
本命令用于查看NAT与BRAS联动场景中的已上线用户信息。
在NAT与BRAS联动的场景中,在PPPoE或IPoE用户上线后,如果想指定user-iduser-name参数查看已上线用户的信息,请执行如下步骤:
(1)     通过display ppp access-user命令查看已上线用户的用户ID和用户名。
(2)     在display nat user-information user-id user-id命令中将user-id指定为上一步查看到的用户ID,或在display nat user-information user-name user-name命令中将user-name指定为上一步查看到的用户名。
# 显示指定slot上已上线用户的概要信息。
<Sysname> display nat user-information slot 3
Slot 3:
User ID                                            : 0x382005a0
Local IP                                           : 1.1.8.192
VPN instacne                                       : ---(0)
Address group                                      : 9
NAT instance                                       : 1
Global IP                                          : 6.1.1.123
Start port                                         : 13003
Block size                                         : 1001
Port total                                         : 1001
Extend port alloc times                            : 0
Extend port alloc number                           : 0
First/Second/Third/Fourth/Fifth extend port start  : 0/0/0/0/0
Total/TCP/UDP/ICMP port limit                      : ---/---/---/---
TCP/UDP/ICMP port current                          : 0/0/0/0
Total/TCP/UDP/ICMP sessions                        : 0/0/0/0
User ID                                            : 0x38200443
Local IP                                           : 1.1.5.90
Address group                                      : 9
NAT instance                                       : 1
Global IP                                          : 6.1.1.237
Start port                                         : 13003
Block size                                         : 1001
Port total                                         : 1001
Total Users found: 2
# 显示指定slot上已上线用户的详细信息。
<Sysname> display nat user-information slot 3 verbose
Slot: 3
User type                                          : NAT444
User ID                                            : 0x382016e8
Local IP                                           : 1.1.1.11
Address group                                      : 9
NAT instance                                       : 9
Global IP                                          : 6.1.1.130
Start port                                         : 35025
Block size                                         : 1001
Port total                                         : 1001
TCP/UDP/ICMP port current                          : 2/0/2/0
Port limit discard count                           : 0
Total/TCP/UDP/ICMP sessions                        : 2/0/2/0
Total/TCP/UDP/ICMP reverse sessions                : 0/0/0/0
User type                                          : NAT444
User ID                                            : 0x382016e7
Local IP                                           : 1.1.1.10
Address group                                      : 9
NAT instance                                       : 9
Global IP                                          : 6.1.1.239
Start port                                         : 29019
Block size                                         : 1001
Port total                                         : 1001
表1-20 display nat user-information命令显示信息描述表
User type
用户类型:
·     NAT444
·     DS-Lite
User ID
用户ID:
·     在NAT与BRAS联动的情况下,显示为用户指定的ID
·     非NAT与BRAS联动的情况下,显示为“---”
Local IP
用户私网IP地址
VPN instance
用户所在VPN的实例名称。“---(0)”表示不属于任何VPN实例
Address group
用户所使用的NAT动态地址组编号
Port block group
用户所使用的NAT静态端口块组编号
NAT instance
用户所使用的NAT实例名称。对于接口NAT,该字段显示为空
Global IP
用户经过NAT转化后的公网IP地址
Start port
给用户预分配的起始端口号
Block size
给用户预分配的端口块大小
Port total
给用户预分配的端口总数
分配增量端口块的次数
分配增量端口块的个数
第一、二、三、四、五次分配增量端口块的起始端口
通过port-limit命令限制分配给协议的端口数量
当前TCP/UDP/ICMP协议已经使用的NAT端口数。EIM模式下,可以为不同的协议分配相同的端口号
NAT端口超限后,无法为新连接分配端口块的次数。显示为“0”表示未发生NAT端口超限事件
当前各个协议新建的正向会话总数/TCP协议新建的正向会话数/UDP协议新建的正向会话数/ICMP协议新建的正向会话数
当前各个协议新建的反向会话总数/TCP协议新建的反向会话数/UDP协议新建的反向会话数/ICMP协议新建的反向会话数
Total Users found
已上线的用户总数
failover-group命令用来配置NAT地址组或NAT端口块组与备份组绑定。
undo failover-group命令用来恢复缺省情况。
failover-group group-name [ user-group user-group-name ]
undo failover-group
NAT地址组或NAT端口块组未绑定任何备份组。
NAT地址组视图
NAT端口块组视图
group-name:备份组的名称,为1~63个字符的字符串,区分大小写。绑定的备份组可以不存在,但要使配置生效,必须通过failover group命令创建备份组。
user-group user-group-name:指定与备份组绑定的用户组的名称,为1~32个字符的字符串,不区分大小写。
使用CGN单板提供NAT功能的环境中,对于动态地址转换或NAT端口块地址转换,需要将NAT地址组与节点为CGN单板的备份组绑定。
NAT地址组或NAT端口块组与备份组绑定后,不能通过nat service命令来指定处理NAT业务的slot。
在NAT控制与转发分离的组网环境中,DP设备上需要将NAT地址组与备份组绑定,并指定用户组(指定的用户组可以不存在,但要使配置生效,必须通过user-group命令创建用户组)。当PPPoE或IPoE用户上线成功后,DP设备通过用户的用户组将用户流量引到该用户组绑定的备份组,在备份组的主节点上进行地址转换。关于备份组的详细介绍,请参见“可靠性配置指导”中的“备份组”;关于用户组的详细介绍,请参见“BRAS业务配置指导”中的“AAA”。
本命令与nat instance命令互斥,不能同时配置。
# 将NAT地址组与名称为nat-failover的备份组绑定。
[Sysname] nat address-group 1
[Sysname-nat-address-group-1] failover-group nat-failover
# 将NAT端口块组与名称为nat-failover的备份组绑定。
[Sysname-port-block-group-1] failover-group nat-failover
·     failover group(可靠性命令参考/备份组)
·     nat instance
·     nat service
·     user-group(BRAS业务命令参考/AAA)
global-ip-pool命令用来添加一个公网地址成员。
undo global-ip-pool命令用来删除一个公网地址成员。
global-ip-pool start-address end-address
undo global-ip-pool start-address
不存在公网地址成员。
NAT端口块组视图
start-address end-address:公网地址成员的起始IP地址和结束IP地址。end-address必须大于或等于start-address;如果start-addressend-address相同,则表示只有一个地址。
在NAT端口块静态映射中,端口基于公网地址成员的IP地址为私网地址成员的IP地址分配端口块。一个公网IP地址可对应的端口块个数,由端口块组配置的公网地址端口范围和端口块大小决定(端口范围除以端口块大小)。
一个端口块组内,一次添加的公网地址成员的数量不能超过255个,且各公网地址成员之间的IP地址不能重叠。
使用接口NAT方式进行地址转换的情况下,请注意:
不同端口块组间的公网地址成员的IP地址可以重叠,但要保证在有地址重叠时端口范围不重叠。
使用全局NAT方式进行地址转换时,不同端口块组间的公网地址成员的IP地址不可以重叠。
# 在端口块组1中添加一个公网地址成员,IP地址从202.10.1.1到202.10.1.10。
[Sysname-port-block-group-1] global-ip-pool 202.10.1.1 202.10.1.10
·     nat instance
1.1.23  inside ip
inside ip命令用来添加一个内部服务器组成员。
undo inside ip命令用来删除一个内部服务器组成员。
inside ip inside-ip port port-number [ weight weight-value ]
undo inside ip inside-ip port port-number
内部服务器组内没有内部服务器组成员。
内部服务器组视图
inside-ip:内部服务器组成员的IP地址。
port port-number:内部服务器组成员提供服务的端口号,取值范围为1~65535(FTP数据端口号20除外)。
weight weight-value:内部服务器组成员的权重。weight-value表示权值,取值范围为1~1000,缺省值为100。内部服务器组成员按照权重比例对外提供服务,权重值越大的内部服务器组成员对外提供服务的比重越大。
# 为内部服务器组1添加一个内部服务器组成员,其IP地址为10.1.1.2,服务端口号为30。
[Sysname] nat server-group 1
[Sysname-nat-server-group-1] inside ip 10.1.1.2 port 30
·     nat server-group
local-ip-address命令用来添加私网地址成员。
undo local-ip-address命令用来删除私网地址成员。
local-ip-address start-address end-address [ vpn-instance vpn-instance-name ]
undo local-ip-address start-address end-address [ vpn-instance vpn-instance-name ]
不存在私网地址成员。
NAT端口块组视图
start-address end-address:私网地址成员的起始IP地址和结束IP地址。end-address必须大于或等于start-address;如果start-addressend-address相同,则表示只有一个地址。
vpn-instance vpn-instance-name:私网地址成员所属的VPN实例。vpn-instance-name表示MPLS L3VPN的VPN实例名称,为1~31个字符的字符串,区分大小写。如果未指定本参数,则表示私网地址成员不属于任何一个VPN实例。
私网地址成员的IP地址作为端口块的使用者,基于端口块组配置的公网地址成员的IP地址为其分配端口块。在一个端口块组内,一个私网IP地址只分配一个端口块。
同一个端口块组内,可配置多个私网地址成员:
·     属于同一VPN实例的各私网地址成员之间的IP地址不能重叠。
·     不属于任何VPN实例的私网地址成员之间的IP地址不能重叠。
不同端口块组内,执行本命令且指定相同的VPN实例时,配置的私网地址成员的IP地址不要重叠,否则可能导致无法正确处理NAT业务。
如果一个端口块组中的私网地址总数超过可分配的端口块总数(端口范围除以端口块大小),则在进行NAT端口块静态映射时,超出部分的私网地址将无法分配到端口块。
# 在端口块组1中添加一个私网地址成员,IP地址从172.16.1.1到172.16.1.255,所属VPN实例为vpn1。
[Sysname-port-block-group-1] local-ip-address 172.16.1.1 172.16.1.255 vpn-instance vpn1
nat address-group命令用来创建地址组,并进入地址组视图。如果指定的地址组已经存在,则直接进入地址组视图。
undo nat address-group命令用来删除指定的地址组。
nat address-group group-id
undo nat address-group group-id
不存在地址组。
group-id:地址组编号,取值范围为0~65535。
一个地址组是多个地址组成员的集合,各个地址组成员通过address命令配置。当需要对数据报文进行动态地址转换时,其源地址将被转换为地址组成员中的某个地址。
地址组被地址转换的配置引用时,无法通过undo nat address-group命令删除该地址组。
# 创建一个地址组,编号为1。
·     address
·     display nat address-group
·     display nat all
·     nat outbound
1.1.26  nat alg
nat alg命令用来开启指定或所有协议类型的NAT ALG功能。
undo nat alg命令用来关闭指定或所有协议类型的NAT ALG功能。
nat alg { all | dns | ftp | h323 | icmp-error | ils | mgcp | nbt | pptp | rsh | rtsp | sccp | sip | sqlnet | tftp | xdmcp }
undo nat alg { all | dns | ftp | h323 | icmp-error | ils | mgcp | nbt | pptp | rsh | rtsp | sccp | sip | sqlnet | tftp | xdmcp }
FTP协议、ICMP差错控制报文和RTSP协议的NAT ALG功能处于开启状态,其他协议类型的NAT ALG功能处于关闭状态。
all:所有可指定的协议的ALG功能。
dns:表示DNS协议的ALG功能。
ftp:表示FTP协议的ALG功能。
h323:表示H323协议的ALG功能。
icmp-error:表示ICMP差错控制报文的ALG功能。
ils:表示ILS(Internet Locator Service,互联网定位服务)协议的ALG功能。
mgcp:表示MGCP(Media Gateway Control Protocol,媒体网关控制协议)协议的ALG功能。
nbt:表示NBT(NetBIOS over TCP/IP,基于TCP/IP的网络基本输入输出系统)协议的ALG功能。
pptp:表示PPTP(Point-to-Point Tunneling Protocol,点到点隧道协议)协议的ALG功能。
rsh:表示RSH(Remote Shell,远程外壳)协议的ALG功能。
rtsp:表示RTSP(Real Time Streaming Protocol,实时流协议)协议的ALG功能。
sccp:表示SCCP(Skinny Client Control Protocol,瘦小客户端控制协议)协议的ALG功能。
sip:表示SIP(Session Initiation Protocol,会话初始协议)协议的ALG功能。
sqlnet:表示SQLNET协议的ALG功能。
tftp:表示TFTP协议的ALG功能。
xdmcp:表示XDMCP(X Display Manager Control Protocol,X显示监控)协议的ALG功能。
ALG(Application Level Gateway,应用层网关)主要完成对应用层报文的解析和处理。通常情况下,NAT只对报文头中的IP地址和端口信息进行转换,不对应用层数据载荷中的字段进行分析和处理。然而对于一些应用层协议,它们的报文的数据载荷中可能包含IP地址或端口信息,这些载荷信息也必须进行有效的转换,否则可能导致功能不正常。
例如,FTP应用由数据连接和控制连接共同完成,而数据连接使用的地址和端口由控制连接协商报文中的载荷信息决定,这就需要ALG利用NAT的相关转换配置来完成载荷信息的转换,以保证后续数据连接的正确建立。
如果使用nat mapping-behavior endpoint-independent命令配置了在PAT方式出方向地址转换中仅创建EIM表项(即未指定tcp-5-tupleudp-5-tuple参数),则无法配置nat alg h323命令。
# 开启FTP协议的ALG功能。
[Sysname] nat alg ftp
·     display nat all
·     nat mapping-behavior endpoint-independent
nat attack-defense命令用来限制CGN单板上各类报文上送CPU的速率。
undo nat attack-defense命令用来恢复缺省情况。
(独立运行模式)
nat attack-defense { alg | other | tcp | tcp-syn } rate rate slot slot-number
nat attack-defense { forward | reverse } udp rate rate slot slot-number
undo nat attack-defense { alg | other | tcp | tcp-syn } rate slot slot-number
undo nat attack-defense { forward | reverse } udp rate slot slot-number
nat attack-defense { alg | other | tcp | tcp-syn } rate rate chassis chassis-number slot slot-number
nat attack-defense { forward | reverse } udp rate rate chassis chassis-number slot slot-number
undo nat attack-defense  udp rate chassis chassis-number slot slot-number
undo nat attack-defense { forward | reverse } udp rate chassis chassis-number  slot slot-number
采用设备默认值限速。
alg:限制ALG解析的报文上送CPU的速率。
other:其他类型报文(包括分片报文、RawIP协议等)上送CPU的速率。
tcp:限制TCP报文(正向TCP SYN报文除外)上送CPU的速率。
tcp-syn:限制正向TCP SYN报文上送CPU的速率。
forward:限制从会话发起方收到的报文上送CPU的速率,即限制正向报文上送CPU的速率。
reverse:限制从会话响应方收到的报文上送CPU的速率,即限制反向报文上送CPU的速率。
udp:限制UDP报文上送CPU的速率。
rate rate-number:指定报文上送CPU的速率,整数形式,取值范围为1~4000。对于other类型的报文,速率单位为Mbps;对于tcp-syntcpalg类型的报文,速率单位为Kpps;对于udp类型的报文,正向UDP报文上送CPU的速率为Kpps,反向UDP报文上送CPU的速率为Mbps。
slot slot-number:配置指定单板上报文上送CPU的速率,slot-number表示单板所在的槽位号。(独立运行模式)
chassis chassis-number slot slot-number:配置指定成员设备的指定单板上报文上送CPU的速率,chassis-number表示设备在IRF中的成员编号,slot-number表示单板所在的槽位号。(IRF模式)
当CGN单板上的报文上送CPU的速率超过限定值时,CGN单板认为存在攻击,进入攻击防范状态,丢弃后续收到的报文。通过上述机制可防止CPU因处理大量报文导致的资源耗尽。
通过display session statistics命令可以查看系统创建单播会话的速率,以及创建各会话的速率,当某创建会话的速率过高时,可以使用本命令限制该报文上送CPU的速率。
# 限制指定slot上正向UDP报文上送CPU的速率为20Kpps。
[Sysname] nat attack-defense forward udp rate 20 slot 2
·     display session statistics
nat centralized-backup auto switchback disable命令用来禁止集中式备份分布式CGN设备上的流量自动回切到分布式部署CGN设备上进行地址转换。
undo nat centralized-backup auto switchback disable命令用来恢复缺省情况。
允许集中式备份分布式CGN设备上的流量回切到分布式部署CGN设备上进行地址转换。
NAT实例视图
在集中式备份分布式CGN组网环境中,有如下两种方式可以使流量切换到集中式部署CGN的设备上进行地址转换:
·     自动切换。配置nat centralized-backup enable命令后,当分布式部署CGN设备的CGN单板故障时,流量会自动切换到集中式部署CGN的设备上进行地址转换。
·     手工切换。执行nat centralized-backup manual switch命令后,流量将被强制切换到集中式部署CGN设备上进行地址转换。
如果希望不管CGN单板故障是否恢复、分布式部署CGN设备是否可用,都需要在集中式部署CGN设备上进行地址转换,请在分布式部署CGN设备上配置本命令。若无特殊需求,建议用户不要配置本命令。
只有开启集中式备份分布式CGN功能(通过nat centralized-backup enable命令)之后,才能配置本命令。
# 在NAT实例cgn1下禁止集中式备份分布式CGN设备上的流量自动回切到分布式部署CGN设备上进行地址转换。
[Sysname] nat instance cgn1 id 1
[Sysname-nat-instance- cgn1] nat centralized-backup enable
[Sysname-nat-instance- cgn1] nat centralized-backup auto switchback disable
·     nat centralized-backup enable
·     nat centralized-backup manual switch
nat centralized-backup enable命令用来开启集中式备份分布式CGN功能。
undo nat centralized-backup enable命令用来关闭集中式备份分布式CGN功能。
集中式备份分布式CGN功能处于关闭状态。
NAT实例视图
在集中式备份分布式CGN组网环境中,开启本功能后,当分布式部署CGN设备的CGN业务板故障时,将流量引到集中式部署CGN设备上的QoS策略或策略路由生效,使得流量自动切换到集中式部署CGN的设备上进行地址转换。当分布式部署的CGN单板故障恢复时,将流量引到集中式部署CGN设备上的QoS策略或策略路由不再生效,流量将自动回切到分布式部署CGN的设备上进行地址转换。流量切换或回切期间已上线的用户不会下线。
存在nat centralized-backup manual switchnat centralized-backup auto switchback disable中任意一种配置时,无法配置undo nat centralized-backup enable命令。
在系统视图下开启本功能后,将无法创建NAT实例。反之,如果存在NAT实例,将无法在系统视图下开启本功能。
# 开启集中式备份分布式CGN功能。
[Sysname] nat centralized-backup enable
# 在名称为cgn、编号为1的NAT实例下开启集中式备份分布式CGN功能。
[Sysname] nat instance cgn id 1
[Sysname-nat-instance-cgn] nat centralized-backup enable
·     nat centralized-backup auto switchback disable
·     nat instance
nat centralized-backup manual switch命令用来将分布式部署CGN设备上的流量手工强制切换到集中式部署CGN设备上进行地址转换。
undo nat centralized-backup manual switch命令用来取消手工强制切换流量的配置,允许流量自动回切到分布式部署CGN设备上进行地址转换。
仅在分布式部署CGN设备上的CGN单板故障时,流量才会切换到集中式部署CGN的设备上进行地址转换。
NAT实例视图
在集中式备份分布式CGN场景中,需要对分布式部署CGN的设备进行网络或硬件升级等操作时,会导致分布式部署CGN设备暂时不可用,为了不影响NAT业务,请在分布式部署CGN的设备上执行本命令。执行本命令后,切换到集中式部署CGN设备上的流量不会自动回切到分布式部署CGN的设备上进行地址转换。当分布式部署CGN的设备可用时,建议用户通过undo nat centralized-backup manual switch命令允许流量自动回切到分布式部署CGN的设备上进行地址转换。在流量切换期间,已上线的用户不会下线。
执行nat centralized-backup manual switch命令后,仅会强制切换相应NAT实例下的流量,不会强制切换其他NAT实例下的流量。
# 将NAT实例cgn1下的流量手工强制切换到集中式部署CGN的设备上进行地址转换。
[Sysname] nat instance cpe1 id 1
[Sysname-nat-instance-cgn1] nat centralized-backup enable
[Sysname-nat-instance-cgn1] nat centralized-backup manual switch
1.1.31  nat dns-map
nat dns-map命令用来配置一条域名到内部服务器的映射。
undo nat dns-map命令用来删除一条域名到内部服务器的映射。
nat dns-map domain domain-name protocol pro-type { interface interface-type interface-number | ip global-ip } port global-port
undo nat dns-map domain domain-name
不存在域名到内部服务器的映射。
domain domain-name:指定内部服务器的合法域名。domain-name表示内部服务器的域名,由“.”分隔的字符串组成(如aabbcc.com),每个字符串的长度不超过63个字符,包括“.”在内的总长度不超过253个字符。不区分大小写,字符串中可以包含字母、数字、“-”、“_”或“.”。
protocol pro-type:指定内部服务器的协议类型。pro-type表示具体的协议类型,取值为tcpudp
interface interface-type interface-number:表示使用指定接口的地址作为内部服务器的外网地址。interface-type interface-number表示接口类型和接口编号。
ip global-ip:指定内部服务器提供给外部网络访问的IP地址。global-ip表示外网IP地址。
port global-port:指定内部服务器提供给外部网络访问的服务端口号,可输入的形式如下:
·     数字:取值范围为1~65535。
·     协议名称:为1~15个字符的字符串,例如ftptelnet等。
NAT的DNS mapping功能需要和内部服务器配合使用,主要应用于DNS服务器在外网,应用服务器在内网(在NAT设备上有对应的nat server配置),内网用户需要通过域名访问内网应用服务器的场景。NAT设备对来自外网的DNS响应报文进行DNS ALG处理时,由于载荷中只包含域名和应用服务器的外网IP地址(不包含传输协议类型和端口号),当接口上存在多条NAT服务器配置且使用相同的外网地址而内网地址不同时,DNS ALG仅使用IP地址来匹配内部服务器可能会得到错误的匹配结果。因此需要借助DNS mapping的配置,指定域名与应用服务器的外网IP地址、端口和协议的映射关系,由域名获取应用服务器的外网IP地址、端口和协议,进而(在当前NAT接口上)精确匹配内部服务器配置获取应用服务器的内网IP地址。
设备可支持配置多条域名到内部服务器的映射。
# 某公司内部对外提供Web服务,内部服务器的域名为www.server.com,对外的IP地址为202.112.0.1,服务端口号为12345。配置一条域名到内部服务器的映射,使得公司内部用户可以通过域名访问内部Web服务器。
[Sysname] nat dns-map domain www.server.com protocol tcp ip 202.112.0.1 port 12345
·     display nat all
·     display nat dns-map
·     nat server
nat extended-port-block report-radius enable命令用来开启NAT设备将用户私网IP与扩展端口块的映射关系上报给RADIUS服务器的功能。
undo nat extended-port-block report-radius enable命令用来恢复缺省情况。
NAT设备将用户私网IP与扩展端口块的映射关系上报给RADIUS服务器的功能处于关闭状态。
NAT实例视图
在NAT与BRAS联动的场景中,用户通过RADIUS认证并分配得到私网地址之后,设备会为其预先分配公网IP和端口块,并创建地址映射关系,然后通过RADIUS报文将上线用户获得的私网IP地址及其对应的公网IP和端口块等信息上报给RADIUS服务器。RADIUS服务器获得用户的地址映射关系后,将这些信息记录到在线用户信息中,以提供用户溯源服务。之后,如果用户向公网发起的连接使用了增量端口块,设备并不会将私网IP地址及其对应的公网IP和扩展端口块等信息上报给RADIUS服务器,导致无法对使用增量端口块的用户进行溯源。开启本功能可以避免上述问题的产生。
全局NAT配置环境下,本功能在NAT实例视图下开启。接口NAT配置环境下,本功能在系统视图下开启。
当存在PPPoE或IPoE在线用户时,无法改变本功能的开启或关闭状态。
# 全局NAT配置环境下,开启NAT设备将用户私网IP与增量端口块的映射关系上报给RADIUS服务器的功能。
[Sysname-nat-instance-cgn1] nat outbound 2001 address-group 2
[Sysname-nat-instance-cgn1] nat extended-port-block report-radius enable
# 接口NAT配置环境下,开启NAT设备将用户私网IP与增量端口块的映射关系上报给RADIUS服务器的功能。
[Sysname-address-group-2] port-block block-size 256 extended-block-number 1
[Sysname-address-group-2] quit
[Sysname] interface gigabitethernet 3/1/1
[Sysname-GigabitEthernet3/1/1] nat outbound 2001 address-group 2
[Sysname-GigabitEthernet3/1/1] quit
[Sysname] nat extended-port-block report-radius enable
·     port-block block-size
nat hairpin enable命令用来开启NAT hairpin功能。
undo nat hairpin enable用来关闭NAT hairpin功能。
nat hairpin enable
NAT hairpin功能处于关闭状态。
NAT hairpin功能用于满足位于内网侧的用户之间或用户与服务器之间通过NAT地址进行访问的需求,需要与内部服务器(nat server)、出方向动态地址转换(nat outbound)或出方向静态地址转换(nat static outbound)配合工作。开启NAT hairpin的内网侧接口上会对报文同时进行源地址和目的地址的转换。
在接口视图下配置本命令后,将无法在系统视图下配置nat instance命令。反之,如果在系统视图下配置了nat instance命令,将无法在接口视图下配置本命令。
# 在GigabitEthernet3/1/1接口下开启NAT hairpin功能。
[Sysname-GigabitEthernet3/1/1] nat hairpin enable
·     display nat all
·     nat instance
1.1.34  nat instance
nat instance命令用来创建NAT实例并进入NAT实例视图。如果指定的NAT实例已经存在,则直接进入NAT实例视图。
undo nat instance命令用来删除指定的NAT实例。
nat instance instance-name [ id id ]
undo nat instance instance-name
不存在任何NAT实例。
instance-name:NAT实例名称,长度为1~31个字符的字符串,区分大小写。如果该值中包含空格,需要在值的首末添加英文格式的引号,形如"xxx xxx"。
id id:表示NAT实例编号,取值范围为1~127。创建NAT实例时,该参数为必选;进入已经存在的NAT实例时,该参数可选。
根据NAT规则的应用范围,将NAT地址转换方式为全局NAT:
·     接口NAT。该方式下,需要在接口上配置静态地址转换、接口上的动态地址转换等NAT规则。此种方式适用于出接口比较固定的场景。
·     全局NAT。该方式下,需要配置NAT实例,并在NAT实例中配置NAT规则以及指定与该NAT实例关联的业务实例组,同时还需要通过QoS策略将需要进行地址转换的流量引到NAT实例中,由NAT实例关联的业务实例组中的slot进行地址转换。此种方式适用于出接口不固定的场景,当出接口发生变化时,用户无需更改相关配置。
NAT实例满足如下条件时才能生效:
·     NAT实例与业务实例组关联。
·     NAT实例关联的业务实例组和备份组关联,且该备份组中的主节点可以正常处理业务。
NAT实例名称与实例编号一一对应,不同名称的NAT实例不能使用同一个编号。
最多可创建16个NAT实例。
如果已经有与某NAT实例绑定的用户上线,则无法删除该NAT实例。
在接口视图下配置如下命令后,无法配置本命令;反之,如果配置了本命令,则无法在接口视图下配置如下命令:
·     nat hairpin enable
·     nat outbound
·     nat outbound ds-lite-b4
·     nat outbound easy-ip failover-group
·     nat server(接口NAT)
·     nat service
·     nat static enable
# 创建一个NAT实例,名称为cgn1,实例编号为1,并进入该NAT实例的视图。
·     display nat instance
·     nat outbound
·     nat server
·     nat service
·     nat static enable
nat log enable命令用来开启NAT日志功能。
undo nat log enable用来关闭NAT日志功能。
nat log enable [ acl { ipv4-acl-number | name ipv4-acl-name } ]
undo nat log enable
NAT日志功能处于关闭状态。
acl:指定ACL的编号或名称。
ipv4-acl-number:ACL的编号,取值范围为2000~3999。
name ipv4-acl-name:ACL的名称,为1~63个字符的字符串,不区分大小写,必须以英文字母a~z或A~Z开头。为避免混淆,ACL的名称不允许使用英文单词all。
必须开启NAT日志功能,NAT会话日志功能(包括NAT新建会话、NAT删除会话和NAT活跃流的日志功能)、NAT444用户日志功能(包括NAT444端口块分配和NAT444端口块回收的日志功能)和NAT444告警信息日志功能才能生效。
acl参数只对NAT会话日志功能有效,对其他NAT日志功能无效。如果指定了ACL,则只有符合ACL permit规则的数据流才有可能触发输出NAT会话日志;如果没有指定ACL,则表示对所有被NAT处理过的数据流都有可能触发输出NAT会话日志。
# 开启NAT日志功能。
[Sysname] nat log enable
·     display nat all
·     display nat log
·     nat log flow-end
·     nat log port-alloc-fail
·     nat log port-block-alloc-fail
·     nat log port-block-assign
·     nat log port-block-withdraw
nat log flow-active命令用来开启NAT活跃流日志功能,并设置生成活跃流日志的时间间隔。
undo nat log flow-active命令用来关闭NAT活跃流的日志功能。
nat log flow-active time-value
NAT活跃流的日志功能处于关闭状态。
time-value:表示触发输出NAT活跃流日志的时间间隔,取值范围为10~120,单位为分钟。
对于一些长时间没有断开的NAT会话(即活跃流),如果需要定期记录其连接情况,则可以通过活跃流日志功能来实现。
开启NAT活跃流日志功能后,对于NAT活跃流,每经过指定的时间间隔,设备就会记录一次NAT日志。
只有开启NAT日志功能(通过nat log enable命令)之后,活跃流日志功能才能生效。
# 开启NAT活跃流日志功能,并设置输出NAT活跃流日志的时间间隔为10分钟。
[Sysname] nat log flow-active 10
·     display nat all
·     display nat log
·     nat log enable
nat log flow-begin命令用来开启NAT新建会话的日志功能,即新建NAT会话时,输出NAT日志。
undo nat log flow-begin命令用来关闭NAT新建会话的日志功能。
nat log flow-begin
NAT新建会话的日志功能处于关闭状态。
只有开启NAT日志功能(通过nat log enable命令)之后,NAT新建会话的日志功能才能生效。
# 开启NAT新建会话的日志功能。
[Sysname] nat log flow-begin
·     display nat all
·     display nat log
·     nat log enable
nat log flow-end命令用来开启NAT删除会话的日志功能。
undo nat log flow-end命令用来关闭NAT删除会话的日志功能。
nat log flow-end
NAT删除会话的日志功能处于关闭状态。
只有开启NAT日志功能(通过nat log enable命令)之后,NAT删除会话的日志功能才能生效。
# 开启NAT删除会话的日志功能。
[Sysname] nat log flow-end
·     display nat all
·     display nat log
·     nat log enable
nat log port-alloc-fail命令用来开启NAT端口分配失败的日志功能。
undo nat log port-alloc-fail命令用来关闭NAT端口分配失败的日志功能。
NAT端口分配失败的日志功能处于关闭状态。
开启本功能后,当动态方式的NAT地址转换发生端口分配失败的情况时,系统会输出端口分配失败的日志。通常,端口块中所有的端口资源都被占用时会导致端口分配失败。
只有开启NAT日志功能(通过nat log enable命令)之后,本命令才能生效。
# 开启NAT端口分配失败的日志功能。
[Sysname] nat log port-alloc-fail
·     display nat all
·     display nat log
·     nat log enable
nat log port-block port-usage threshold命令用来开启NAT端口块中端口使用率的日志信息功能,并设置NAT端口使用率的阈值。
undo nat log port-block port-usage threshold命令用来关闭NAT端口块中端口使用率的日志信息功能。
nat log port-block port-usage threshold value
NAT端口块中端口使用率的日志信息功能处于关闭状态。
value:告警阈值,取值范围为40~100,单位为百分比。
开启本功能后,当端口块中端口数的使用率超过设定的百分比时,系统将会输出日志信息。
# 开启NAT端口块中端口使用率的日志信息功能,并设置NAT端口使用率的阈值为90%。
[Sysname] nat log port-block port-usage threshold 90
·     display nat all
·     display nat log
·     nat log enable
nat log port-block usage threshold命令用来配置NAT端口块使用率的阈值。
undo nat log port-block usage threshold命令恢复缺省情况。
nat log port-block usage threshold value
NAT端口块使用率的阈值为90%。
value:端口使用率的阈值,取值范围为40~100,单位为百分比。
当端口块的使用率超过设定的百分比时,系统将会输出日志信息。
# 配置NAT端口块的使用率告警阈值为80%。
[Sysname] nat log port-block usage threshold 80
·     display nat all
·     display nat log
·     nat log enable
nat log port-block-alloc-fail命令用来开启NAT端口块分配失败的日志功能。
undo nat log port-block-alloc-fail命令用来关闭NAT端口块分配失败的日志功能。
NAT端口块分配失败的日志功能处于关闭状态。
开启本功能后,当NAT端口块地址转换发生端口块分配失败的情况时,系统会输出端口块分配失败的日志。
# 开启NAT端口块分配失败的日志功能。
[Sysname] nat log port-block-alloc-fail
·     display nat all
·     display nat log
·     nat log enable
nat log port-block-assign命令用来开启端口块分配的NAT444用户日志功能。
undo nat log port-block-assign命令用来关闭端口块分配的NAT444用户日志功能。
端口块分配的NAT444用户日志功能处于关闭状态。
端口块静态映射方式下,在某私网IP地址的第一个新建连接通过端口块进行地址转换时,如果开启了端口块分配的NAT444用户日志功能,则会输出日志。
端口块动态映射方式下,在为某私网IP地址分配端口块或增量端口块时,如果开启了端口块分配的NAT444用户日志功能,则会输出日志。
只有开启NAT日志功能(通过nat log enable命令)之后,端口块分配的NAT444用户日志功能才能生效。
# 开启端口块分配的NAT444用户日志功能。
[Sysname] nat log port-block-assign
·     display nat all
·     display nat log
·     nat log enable
nat log port-block-withdraw命令用来开启端口块回收的NAT444用户日志功能。
undo nat log port-block-withdraw命令用来关闭端口块回收的NAT444用户日志功能。
端口块回收的NAT444用户日志功能处于关闭状态。
端口块静态映射方式下,在某私网IP地址的最后一个连接拆除时,如果开启了端口块回收的NAT444用户日志功能,则会输出日志。
端口块动态映射方式下,在释放端口块资源(并删除端口块表项)时,如果开启了端口块回收的NAT444用户日志功能,则会输出日志。
只有开启NAT日志功能(通过nat log enable命令)之后,端口块回收的NAT444用户日志功能才能生效。
# 开启端口块回收的NAT444用户日志功能。
[Sysname] nat log port-block-withdraw
·     display nat all
·     display nat log
·     nat log enable
nat mapping-behavior endpoint-independent命令用来配置PAT方式出方向动态地址转换的模式为Endpoint-Independent Mapping。
undo nat mapping-behavior endpoint-independent命令用来恢复缺省情况。
nat mapping-behavior endpoint-independent { tcp [ tcp-5-tuple ] | udp [ udp-5-tuple ] } *
PAT出方向动态方式地址转换的模式为Connection-Dependent Mapping。
tcp:表示配置设备为传输层协议类型为TCP的报文在PAT方式出方向地址转换创建EIM表项。
udp:表示配置设备为传输层协议类型为UDP的报文在PAT方式出方向地址转换创建EIM表项。
tcp-5-tuple:表示配置设备为传输层协议类型为TCP的报文在PAT方式出方向地址转换中创建五元组(源地址、源端口号、协议类型、目的地址、目的端口号)类型的会话表项。如果不指定该参数,则表示仅创建EIM表项。
udp-5-tuple:表示配置设备为传输层协议类型为UDP的报文在PAT方式出方向地址转换中创建五元组(源地址、源端口号、协议类型、目的地址、目的端口号)类型的会话表项。如果不指定该参数,则表示仅创建EIM表项。
PAT方式出方向动态地址转换支持两种模式:
·     Endpoint-Independent Mapping(不关心对端地址和端口的转换模式):只要是来自相同源地址和源端口号的报文,不论其目的地址是否相同,通过PAT映射后,其源地址和源端口号都被转换为同一个外部地址和端口号,该映射关系会被记录下来并生成一个EIM表项;并且NAT网关设备允许外部网络的主机通过该转换后的地址和端口来访问这些内部网络的主机。这种模式可以很好的支持位于不同NAT网关之后的主机间进行互访。
·     Connection-Dependent Mapping(关心对端地址和端口的非共享转换模式):来自同一源地址和源端口号并且去往特定目的地址和端口号的报文,通过PAT映射后,其源地址和源端口号都被转换为同一个外部地址和端口号。同一源地址和源端口号并且去往不同目的地址和端口号的报文,通过PAT映射后,其源地址和源端口号被转换为不同的外部地址和端口号。与Endpoint-Independent Mapping模式不同的是,这种模式安全性好,即NAT设备只允许这些目的地址对应的外部网络的主机可以通过该转换后的地址和端口来访问这些内部网络的主机。
存在nat servernat static outboundnat static outbound net-to-netnat alg h323中任意一种或几种配置的情况下,无法配置nat mapping-behavior endpoint-independent tcpnat mapping-behavior endpoint-independent udp命令。
配置本命令后,对于ICMP报文,始终会创建EIM表项和五元组类型的会话表项。
存在NO-PAT方式的动态地址转换配置的情况下,配置PAT方式出方向动态地址转换的模式为Endpoint-Independent Mapping后,新增和当前已存在的NO-PAT方式的动态地址转换配置均无法生效。
# 对TCP报文以Endpoint-Independent Mapping模式进行地址转换,且仅创建EIM表项。
[Sysname] nat mapping-behavior endpoint-independent tcp
·     display nat eim
·     display nat eim statistics
·     nat outbound
·     nat server
·     nat static outbound
·     nat static outbound net-to-net
1.1.46  nat outbound
nat outbound命令用来配置出方向动态地址转换。
undo nat outbound命令用来删除指定的出方向动态地址转换。
不存在动态地址转换配置。
·     NO-PAT方式
nat outbound [ ipv4-acl-number | name ipv4-acl-name ] address-group group-id [ vpn-instance vpn-instance-name ] no-pat [ reversible ]
undo nat outbound [ ipv4-acl-number | name ipv4-acl-name ]
·     PAT方式
nat outbound [ ipv4-acl-number | name ipv4-acl-name ] [ address-group group-id ] [ vpn-instance vpn-instance-name ] [ port-preserved ]
NAT实例视图
address-group group-id:指定地址转换使用的地址组。group-id为地址组的编号,取值范围为0~65535。如果不指定该参数,则直接使用该接口的IP地址作为转换后的地址,即实现Easy IP功能。
vpn-instance vpn-instance-name:指定地址组中的地址所属的VPN实例。vpn-instance-name表示MPLS L3VPN中的VPN实例名称,为1~31个字符的字符串,区分大小写。如果未指定本参数,则表示地址组中的地址不属于任何一个VPN实例。
no-pat:表示使用NO-PAT方式进行转换,即转换时不使用报文的端口信息;如果未指定本参数,则表示使用PAT方式进行转换,即转换时使用报文的端口信息。PAT方式仅支持TCP、UDP和ICMP查询报文,由于ICMP报文没有端口的概念,我们将ICMP ID作为ICMP报文的源端口。
reversible:表示允许反向地址转换。即,在内网用户主动向外网发起连接并成功触发建立地址转换表项的情况下,允许外网向该内网用户发起的连接使用已建立的地址转换表项进行目的地址转换。
port-preserved:PAT方式分配端口时尽量不转换端口。port-preserved参数对NAT444端口块动态映射无效。
一般情况下,出方向动态地址转换配置在和外部网络连接的接口上,一个接口下可同时配置多条出方向地址转换。动态地址转换有两种转换方式:
·     PAT方式:对于从内网到外网的报文,如果符合ACL permit规则,则使用地址组中的地址或该接口的地址(Easy IP方式)进行源地址转换,同时转换源端口(IP1/port1转换为IP2/port2);如果同时配置了PAT方式下的地址转换模式为EIM(Endpoint-Independent Mapping),则外网可以通过IP2/port2主动访问内网,NAT设备根据EIM表项转换目的地址和端口(IP2/port2转换为IP1/port1)。
·     NO-PAT方式:对于从内网到外网的报文,如果符合ACL permit规则,则使用地址组中的地址进行源地址转换,不转换源端口(IP1转换为IP2);如果同时配置了reversible,则允许外网通过IP2主动访问内网,对于此类报文,需要进行ACL反向匹配(提取报文的源地址/端口和目的地址/端口,并将目的地址转换为IP1,然后将源地址/端口和目的地址/端口互换去匹配ACL),只有反向匹配ACL的报文才能进行转换(将目的地址IP2转换为IP1),否则不予转换。NAT端口块动态映射不支持该方式
指定出方向和入方向动态地址转换引用的地址组时,需要注意:
·     一个地址组被PAT方式的nat outbound配置引用后,不能再被NO-PAT方式的nat outbound配置引用,反之亦然。
·     如果PAT方式的nat outbound所引用的地址组中配置了端口范围和端口块参数,则将对匹配的报文进行NAT端口块动态映射。
·     当PAT方式出方向动态地址转换的模式为Endpoint-Independent Mapping时,NO-PAT方式的配置将无法生效。
指定出方向动态地址转换引用的ACL时,需要注意:
·     在一个接口下,一个ACL只能被一个nat outbound引用。
·     配置多条出方向动态地址转换时,只有一个nat outbound可以不引用ACL。
·     不指定ACL编号或名称的情况下,不对转换对象进行限制。
·     对于同一接口下的出方向动态地址转换配置,指定了ACL的配置的优先级高于未指定ACL的配置的优先级;对于指定了ACL的出方向动态地址转换配置,其生效优先级由ACL编号的大小决定,编号越大,优先级越高。
·     NAT端口块动态映射环境下,在同一接口下新增出方向动态转换的配置时,如果已经有流量与已存在配置中的ACL规则匹配,那么新增配置中的ACL规则不要与已存在配置中的ACL规则有重叠。
在VPN组网中,配置出方向动态地址转换时需要指定vpn-instance参数,且VPN实例的名称必须与该接口关联的VPN实例一致。
配置NAT实例中的出方向动态地址转换时,必须指定address-group参数。不同的NAT实例中的出方向动态地址转换不能使用同一个NAT地址组。
# 配置ACL 2001,允许对10.110.10.0/24网段的主机报文进行地址转换。
[Sysname] acl basic 2001
[Sysname-acl-ipv4-basic-2001] rule permit source 10.110.10.0 0.0.0.255
[Sysname-acl-ipv4-basic-2001] rule deny
# 配置地址组1,并添加地址组成员:202.110.10.10、202.110.10.11、202.110.10.12。
[Sysname-address-group-1] address 202.110.10.10 202.110.10.12
[Sysname-address-group-1] quit
# 在接口GigabitEthernet3/1/1上配置出方向动态地址转换,允许对匹配ACL 2001的报文使用地址组1中的地址进行地址转换,且在转换的时候使用TCP/UDP的端口信息。
[Sysname-GigabitEthernet3/1/1] nat outbound 2001 address-group 1
# 如果在接口GigabitEthernet3/1/1上不使用TCP/UDP的端口信息进行地址转换,可以使用如下配置。
[Sysname-GigabitEthernet3/1/1] nat outbound 2001 address-group 1 no-pat
# 如果直接使用接口GigabitEthernet3/1/1接口的IP地址进行地址转换,可以使用如下的配置。
[Sysname-GigabitEthernet 3/1/1] nat outbound 2001
[Sysname-GigabitEthernet 3/1/1] quit
# 内网10.110.10.0/24网段的主机使用地址组1中的地址作为转换后的地址访问外部网络。如果要在内网用户向外网主动发起访问之后,允许外网用户主动向10.110.10.0/24网段的主机发起访问,并利用已建立的地址转换表项进行反向地址转换,可以使用如下配置。
[Sysname-GigabitEthernet3/1/1] nat outbound 2001 address-group 1 no-pat reversible
·     display nat eim
·     display nat outbound
·     nat instance
nat outbound ds-lite-b4命令用来配置DS-Lite B4端口块映射。
undo nat outbound ds-lite-b4命令用来删除指定的DS-Lite B4端口块映射。
nat outbound ds-lite-b4 { ipv6-acl-number | name ipv6-acl-name } address-group group-id
undo nat outbound ds-lite-b4 { ipv6-acl-number | name ipv6-acl-name }
不存在DS-Lite B4端口块映射。
NAT实例视图
ipv6-acl-number:用于匹配B4设备IPv6地址的IPv6 ACL编号,取值范围为2000~3999。
name ipv6-acl-name:用于匹配B4设备IPv6地址的IPv6 ACL名称,为1~63个字符的字符串,不区分大小写,必须以英文字母a~z或A~Z开头。为避免混淆,ACL的名称不允许使用英文单词all。
在使用DS-Lite隧道技术实现通过IPv6网络连接IPv4网络的组网环境下,DS-Lite B4端口块映射配置在NAT444网关设备连接外部网络的接口上,通常用于在NAT444网关设备已知B4设备或DS-Lite主机的IPv6地址的情况下为DS-Lite用户提供NAT地址转换。
通过在NAT网关设备上配置DS-Lite B4地址转换,可以实现基于端口块的公网IP地址复用,使一个DS-Lite B4 IPv6地址在一个时间段内独占一个公网IP地址的某个端口块。
 # 配置IPv6 ACL 2100,允许对2000::/64网段的主机报文进行地址转换。
[Sysname] acl ipv6 basic 2100
[Sysname-acl-ipv6-basic-2100] rule permit source 2000::/64
[Sysname-acl-ipv6-basic-2100] quit
# 配置地址组1,并添加地址组成员:202.110.10.10~202.110.10.12。
[Sysname-nat-address-group-1] address 202.110.10.10 202.110.10.12
# 配置地址组1的端口块参数,端口块大小为256。
[Sysname-nat-address-group-1] port-block block-size 256
[Sysname-nat-address-group-1] quit
# 在接口GigabitEthernet3/1/1上配置DS-Lite B4端口块映射,允许对匹配IPv6 ACL 2100的报文使用地址组1中的地址进行地址转换。
[Sysname-GigabitEthernet3/1/1] nat outbound ds-lite-b4 2100 address-group 1
·     nat instance
nat outbound easy-ip failover-group命令用来为Easy IP方式的动态地址转换指定备份组。
undo nat outbound easy-ip failover-group命令用来恢复缺省情况。
nat outbound easy-ip failover-group group-name
没有为Easy IP方式的动态地址转换指定备份组。
配置该命令后,设备会将需要进行动态地址转换的流量引到指定的备份组进行处理。
如果设备上创建了手动备份组,则只能指定手动备份组,不允许再指定自动备份组。
本命令与nat service命令互斥,不能同时配置。
# 在接口GigabitEthernet3/1/1上为出方向动态地址转换指定名字为nat-failover的备份组。
[Sysname-GigabitEthernet3/1/1] nat outbound easy-ip failover-group nat-failover
·     nat instance
·     nat service
nat outbound port-block-group命令用来配置NAT端口块静态映射。
undo nat outbound port-block-group命令用来删除指定的NAT端口块静态映射配置。
nat outbound port-block-group group-id
undo nat outbound port-block-group group-id
不存在NAT端口块静态映射配置。
NAT实例视图
该配置在接口下引用指定的端口块组,根据端口块组内的配置数据,按照固定的算法为每个私网IP地址分配一个静态端口块并创建静态端口块表项。当某私网IP地址向公网发起连接时,通过该私网IP地址查找静态端口块表项,使用表项中记录的公网IP地址进行地址转换,并从对应的端口块中动态分配一个端口进行TCP/UDP端口转换。
一个接口下可以配置多条基于不同端口块组的NAT端口块静态映射。
不同的NAT实例不能引用同一个端口块组。
# 在接口GigabitEthernet3/1/1的出方向上配置基于端口组1的NAT端口块静态映射。
[Sysname-GigabitEthernet3/1/1] nat outbound port-block-group 1
·     display nat all
·     display nat outbound port-block-group
·     display nat port-block
·     nat instance
1.1.50  nat port-block flow-trigger enable
nat port-block flow-trigger enable命令用来开启流量触发分配端口块功能。
undo nat port-block flow-trigger enable命令用来关闭流量触发分配端口块功能。
流量触发分配端口块功能处于关闭状态。
NAT实例视图
此命令只用于集中式备份分布式CGN组网环境中。当BRAS设备的CGN业务板故障时,只有在集中式部署CGN的设备上开启此功能,设备才能为用户分配地址和端口块资源。
以下情况无法更改流量触发分配端口块功能的开启或关闭状态:
·     存在在线用户
·     存在使用NAT实例进行地址转换创建的表项
在系统视图下配置本命令后,将无法配置nat instance命令。反之,如果配置了nat instance命令,将无法在系统视图下配置本命令。
# 开启流量触发分配端口块功能。
[Sysname] nat port-block flow-trigger enable
·     nat instance
1.1.51  nat port-block-group
nat port-block-group命令用来创建NAT端口块组,并进入NAT端口块组视图。如果指定的NAT端口块组已经存在,则直接进入NAT端口块组视图。
undo nat port-block-group命令用来删除指定的NAT端口块组。
nat port-block-group group-id
undo nat port-block-group group-id
不存在NAT端口块组。
group-id:NAT端口块组的编号,取值范围为0~65535。
创建的NAT端口块组用于配置NAT端口块静态映射。一个端口块组中包含如下内容:
·     一个或多个私网地址成员,通过local-ip-address命令配置。
·     一个或多个公网地址成员,通过global-ip-pool命令配置。
·     公网地址的端口范围,通过port-range命令配置。
·     端口块大小,通过block-size命令配置。
在进行NAT端口块静态映射时,系统根据相应端口块组的配置计算出私网IP地址到公网IP地址、端口块的静态映射关系,并创建静态端口块表项。
# 创建一个NAT端口块组,编号为1。
·     block-size
·     display nat all
·     display nat port-block-group
·     global-ip-pool
·     local-ip-address
·     port-range
1.1.52  nat server(接口NAT)
nat server命令用来配置NAT内部服务器,即定义内部服务器的外网地址和端口与内网地址和端口的映射表项。
undo nat server命令用来删除指定的内部服务器配置。
(1)     普通内部服务器
·     外网地址单一,未使用外网端口或外网端口单一
nat server [ protocol pro-type ] global { global-address | current-interface | interface interface-type interface-number } [ global-port ] [ vpn-instance global-vpn-instance-name ] inside local-address [ local-port ] [ vpn-instance local-vpn-instance-name ] [ acl { ipv4-acl-number | name ipv4-acl-name } ] [ reversible ]
undo nat server [ protocol pro-type ] global { global-address | current-interface | interface interface-type interface-number } [ global-port ] [ vpn-instance global-vpn-instance-name ]
·     外网地址单一,外网端口连续
nat server protocol pro-type global { global-address | current-interface | interface interface-type interface-number } global-port1 global-port2 [ vpn-instance global-vpn-instance-name ] inside { { local-address | local-address1 local-address2 } local-port | local-address local-port1 local-port2 } [ vpn-instance local-vpn-instance-name ] [ acl { ipv4-acl-number | name ipv4-acl-name } ]
undo nat server protocol pro-type global { global-address | current-interface | interface interface-type interface-number } global-port1 global-port2 [ vpn-instance global-vpn-instance-name ]
·     外网地址连续,未使用外网端口或外网端口单一
nat server protocol pro-type global global-address1 global-address2 [ global-port ] [ vpn-instance global-vpn-instance-name ] inside { local-address | local-address1 local-address2 } [ local-port ] [ vpn-instance local-vpn-instance-name ] [ acl { ipv4-acl-number | name ipv4-acl-name } ]
undo nat server protocol pro-type global global-address1 global-address2 [ global-port ] [ vpn-instance global-vpn-instance-name ]
·     外网地址连续,外网端口单一
nat server protocol pro-type global global-address1 global-address2 global-port [ vpn-instance global-vpn-instance-name ] inside local-address local-port1 local-port2 [ vpn-instance local-vpn-instance-name ] [ acl { ipv4-acl-number | name ipv4-acl-name } ]
undo nat server protocol pro-type global global-address1 global-address2 global-port [ vpn-instance global-vpn-instance-name ]
(2)     负载均衡内部服务器
nat server protocol pro-type global { { global-address | current-interface | interface interface-type interface-number } { global-port | global-port1 global-port2 } | global-address1 global-address2 global-port } [ vpn-instance global-vpn-instance-name ] inside server-group group-id [ vpn-instance local-vpn-instance-name ] [ acl { ipv4-acl-number | name ipv4-acl-name } ]
undo nat server protocol pro-type global { { global-address | current-interface | interface interface-type interface-number } { global-port | global-port1 global-port2 } | global-address1 global-address2 global-port } [ vpn-instance global-vpn-instance-name ]
(3)     基于ACL的内部服务器
nat server global { ipv4-acl-number | name ipv4-acl-name } inside local-address [ local-port ] [ vpn-instance local-vpn-instance-name ]
undo nat server global { ipv4-acl-number | name ipv4-acl-name }
不存在内部服务器。
protocol pro-type:指定协议类型。只有当协议类型是TCP、UDP协议时,配置的内部服务器才能带端口参数。如果不指定协议类型,则表示对所有协议类型的报文都生效。pro-type可输入以下形式:
·     数字:取值范围为1~255。
·     协议名称:取值包括icmptcpudp
global:指定服务器向外提供服务的外网信息。
global-address:内部服务器向外提供服务时对外公布的外网IP地址。
global-address1global-address2:外网IP地址范围,所包含的地址数目不能超过256。global-address1表示起始地址,global-address2表示结束地址。global-address2必须大于global-address1
current-interface:使用当前接口的主用IP地址作为内部服务器的外网地址,即实现Easy IP方式的内部服务器。
interface interface-type interface-number:表示使用指定接口的主用IP地址作为内部服务器的外网地址,即实现Easy IP方式的内部服务器。interface-type interface-number表示接口类型和接口编号。目前只支持Loopback接口。
global-port1global-port2:外网端口范围,和内部主机的IP地址范围构成一一对应的关系。global-port1表示起始端口,global-port2表示结束端口。global-port2必须大于global-port1,且端口范围中的端口数目不能大于256。外网端口可输入以下形式:
·     数字:取值范围为1~65535。起始端口和结束端口均支持此形式。
·     协议名称:为1~15个字符的字符串,例如httptelnet等。仅起始端口支持该形式。
inside:指定服务器的内网信息。
local-address1local-address2:定义一组连续的内网IP地址范围,和外网端口范围构成一一对应的关系。local-address1表示起始地址,local-address2表示结束地址。local-address2必须大于local-address1。该地址范围的数量必须和global-port1global-port2定义的端口数量相同。
local-port:内部服务器的内网端口号,可输入以下形式:
·     数字:取值范围为1~65535(FTP数据端口号20除外)。
global-port:外网端口号,缺省值以及取值范围的要求和local-port的规定一致。
local-address:服务器的内网IP地址。
vpn-instance global-vpn-instance-name:对外公布的外网地址所属的VPN实例。global-vpn-instance-name表示MPLS L3VPN的VPN实例名称,为1~31个字符的字符串,区分大小写。如果未指定本参数,则表示对外公布的外网地址不属于任何一个VPN实例。
vpn-instance local-vpn-instance-name:内部服务器所属的VPN实例。local-vpn-instance-name表示MPLS L3VPN的VPN实例名称,为1~31个字符的字符串,区分大小写。如果未指定本参数,则表示内部服务器不属于任何一个VPN实例。
server-group group-id:服务器在内网所属的服务器组。若指定了该参数,则表示要配置一个负载分担内部服务器。group-id表示内部服务器组的编号,取值范围为0~65535。
acl:指定ACL的编号或名称。若指定了该参数,则表示与指定的ACL permit规则匹配的报文才可以使用内部服务器的映射表进行地址转换。
reversible:表示支持私网侧内部服务器主动访问外网。内部服务器主动访问外网时,将私网地址转换为内部服务器向外提供服务的外网IP地址。
通过该配置可以利用NAT设备将一些内部网络的服务器提供给外部网络使用,例如内部的Web服务器、FTP服务器、Telnet服务器、POP3服务器、DNS服务器等。这些内部服务器可以位于普通的内网内,也可以位于MPLS VPN实例内。
NAT内部服务器通常配置在NAT设备的外网侧接口上。外网用户可以通过global-address定义的外网地址和global-port定义的外网端口来访问内网地址和内网端口分别为local-addresslocal-port的内部服务器。当pro-type不是TCP(协议号为6)或UDP(协议号为17)时,用户只能设置内部IP地址与外部IP地址的一一对应的关系,无法设置端口号之间的映射。需要注意的是,请不要将global-addresslocal-address指定为相同的IP地址,否则会导致NAT功能异常或报文丢弃。
NAT内部服务器支持以下几种内网和外网的地址、端口映射关系。
表1-21 NAT内部服务器的地址与端口映射关系
外网
内网
一个外网地址
一个内网地址
一个外网地址、一个端口号
一个内网地址、一个内网端口号
一个外网地址,N个连续的外网端口号
·     一个内网地址,一个内网端口
·     N个连续的内网地址,一个内网端口号
·     一个内网地址,N个连续的内网端口号
N个连续的外网地址
·     一个内网地址
·     N个连续的内网地址
N个连续的外网地址连续,一个外网端口号
·     一个内网地址,一个内网端口号
·     N个连续的内网地址,一个内网端口号
·     一个内网地址,N个连续的内网端口号
一个外网地址,一个外网端口号
一个内部服务器组
一个外网地址,N个连续的外网端口号
N个连续的外网地址,一个外网端口号
外网地址(通过ACL进行匹配)
·     一个内网地址
·     一个内网地址、一个内网端口号
一个接口下允许配置的nat server命令个数与设备的型号有关。对于同一个接口下配置的NAT服务器,其协议类型、外网地址和外网端口号的组合必须是唯一的,否则认为是配置冲突。本规则同样适用于Easy IP方式的NAT服务器。每个nat server命令下可以配置的NAT内部服务器数目为global-port2global-port1的差值,即配置多少个外网端口就对应多少个NAT内部服务器。
由于Easy IP方式的NAT内部服务器使用了当前接口或其它接口的IP地址作为它的外网地址,因此强烈建议在配置了Easy IP方式的NAT内部服务器之后,其它NAT内部服务器不要再配置该接口的IP地址作为它的外网地址,反之亦然。
对于Easy IP方式的NAT服务器,如果其引用的接口的IP地址发生改变,导致跟现有的其它非Easy IP方式的NAT服务器冲突,则Easy IP方式的NAT服务器配置失效;如果接口地址又修改为不冲突的IP,或者之前与之冲突的NAT服务器被删除,则Easy IP方式的NAT配置重新生效。
在配置负载均衡内部服务器时,若配置一个外网地址,N个连续的外网端口号对应一个内部服务器组,或N个连续的外网地址,一个外网端口号对应一个内部服务器组,则内部服务器组的成员个数不能小于N,即同一用户不能通过不同的外网地址或外网端口号访问相同内网服务器的同一服务。
在VPN组网中,配置NAT内部服务器时需要指定vpn-instance参数,且VPN实例的名称必须与该接口关联的VPN实例一致。
# 在接口GigabitEthernet3/1/1上配置NAT内部服务器,指定局域网内部的Web服务器的IP地址是10.110.10.10,希望外部通过http://202.110.10.10:8080可以访问Web服务器。
[Sysname-GigabitEthernet3/1/1] nat server protocol tcp global 202.110.10.10 8080 inside 10.110.10.10 http
# 在接口GigabitEthernet3/1/1上配置NAT内部服务器,指定MPLS VPN实例vrf10内部的FTP服务器的IP地址是10.110.10.11,希望外部通过ftp://202.110.10.10可以访问FTP服务器。
[Sysname-GigabitEthernet3/1/1] nat server protocol tcp global 202.110.10.10 21 inside 10.110.10.11 vpn-instance vrf10
# 在接口GigabitEthernet3/1/1上配置NAT内部服务器,指定一个VPN实例vrf10内部的主机10.110.10.12,希望外部网络的主机可以利用ping 202.110.10.11命令ping通它。
[Sysname-GigabitEthernet3/1/1] nat server protocol icmp global 202.110.10.11 inside 10.110.10.12 vpn-instance vrf10
# 在接口GigabitEthernet3/1/1上配置NAT内部服务器,指定一个外部地址202.110.10.10,从端口1001~1100分别映射MPLS VPN实例vrf10内主机10.110.10.1~10.110.10.100的telnet服务。202.110.10.10:1001访问10.110.10.1,202.110.10:1002访问10.110.10.2,依此类推。
[Sysname-GigabitEthernet3/1/1] nat server protocol tcp global 202.110.10.10 1001 1100 inside 10.110.10.1 10.110.10.100 telnet vpn-instance vrf10
# 正确的服务器地址为10.0.0.172,用户配置的错误地址为192.168.0.0/24网段的地址,在接口GigabitEthernet3/1/1上配置基于ACL的内部服务器对这部分用户的配置错误进行纠正。
[Sysname] acl advanced 3000
[Sysname-acl-ipv4-adv-3000] rule 5 permit ip destination 192.168.0.0 0.0.0.255
[Sysname-GigabitEthernet3/1/1] nat server global 3000 inside 10.0.0.172
·     display nat all
·     display nat server
·     nat server-group
1.1.53  nat server(全局NAT)
·     外网地址单一,未使用外网端口
nat server global global-address [ vpn-instance global-vpn-instance-name ] inside local-address [ vpn-instance local-vpn-instance-name ] [ reversible ]
undo nat server global global-address [ vpn-instance global-vpn-instance-
name ]
·     外网地址单一,外网端口单一
nat server protocol pro-type global { global-address | interface interface-type interface-number } [ global-port ] [ vpn-instance global-vpn-instance-name ] inside local-address [ local-port ] [ vpn-instance local-vpn-instance-name ] [ reversible ]
undo nat server protocol pro-type global { global-address | interface interface-type interface-number } [ global-port ] [ vpn-instance global-vpn-instance-name ]
·     外网地址使用接口的地址,外网端口单一
nat server protocol pro-type global interface interface-type interface-number global-port [ vpn-instance global-vpn-instance-name ] inside local-address local-port [ vpn-instance local-vpn-instance-name ] [ reversible ]
undo nat server protocol pro-type global interface interface-type interface-number global-port [ vpn-instance global-vpn-instance-name ]
不存在内部服务器。
NAT实例视图
protocol pro-type:指定协议类型。只有当协议类型是TCP、UDP协议时,配置的内部服务器才能带端口参数。pro-type可输入以下形式:
·     数字:取值范围为1~255。
·     协议名称:取值包括icmp、tcp和udp。
inside:指定服务器的内网信息。
global-port:外网端口号,输入形式的要求和local-port的规定一致。
表1-22 NAT内部服务器的地址与端口映射关系
外网
内网
一个外网地址
一个内网地址
一个外网地址、一个端口号
一个内网地址、一个内网端口号
对于同一个NAT实例下配置的NAT服务器,其协议类型、外网地址和外网端口号的组合必须是唯一的,否则认为是配置冲突。本规则同样适用于Easy IP方式的NAT服务器。
由于Easy IP方式的NAT内部服务器使用了接口的IP地址作为外网地址,因此强烈建议在配置了Easy IP方式的NAT内部服务器之后,其它NAT内部服务器不要再配置该接口的IP地址作为它的外网地址,反之亦然。
在VPN组网中,配置NAT内部服务器时需要指定vpn-instance参数,且外公布的外网地址所属的VPN实例必须与出接口关联的VPN实例一致、内部服务器所属的VPN实例必须与入接口关联的VPN实例一致。
全局NAT方式下,如果硬件资源不足,nat server命令可能无法生效。
# 在NAT实例inst上配置NAT内部服务器,指定局域网内部的Web服务器的IP地址是10.110.10.10,希望外部通过http://202.110.10.10:8080可以访问Web服务器。
[Sysname] nat instance inst id 1
[Sysname-nat-instance-inst] nat server protocol tcp global 202.110.10.10 8080 inside 10.110.10.10 http
·     display nat all
·     nat server-group
1.1.54  nat server-group
nat server-group命令用来创建内部服务器组,并进入内部服务器组视图。如果指定的内部服务器组已经存在,则直接进入内部服务器组视图。
undo nat server-group命令用来删除指定的内部服务器组。
nat server-group group-id
undo nat server-group group-id
不存在内部服务器组。
group-id:服务器组编号,取值范围为0~65535。
一个内部服务器组中可以包括多个内部服务器组成员(通过inside ip命令配置)。
# 配置一个内部服务器组,编号为1。
·     display nat all
·     display nat server-group
·     inside ip
·     nat server
1.1.55  nat service
nat service命令用来指定处理NAT业务的slot。
undo nat service命令用来恢复缺省情况。
独立运行模式:
nat service slot slot-number
undo nat service slot
IRF模式:
nat service chassis chassis-number slot slot-number
undo nat service chassis
未指定处理NAT业务的slot。
slot slot-number:指定单板所在的槽位号。slot-number表示单板所在的槽位号。(独立运行模式)
chassis chassis-number slot slot-number:指定成员设备上指定单板的槽位号。chassis-number表示设备在IRF中的成员编号,slot-number表示单板所在的槽位号。(IRF模式)
如果需要使用具有NAT能力的业务板进行NAT处理,必须在配置了NAT业务的接口上指定提供NAT处理的slot。否则接口的NAT功能不生效。
一个接口上的NAT业务只能由一个slot处理,该slot可以是设备上的任意可提供NAT处理的slot。通常,如果接口所在的slot具有NAT处理能力,那么建议将接口所在slot指定为处理NAT业务的slot。
多个接口引用了同一个地址组或外网地址时,这些接口必须指定同一个slot进行NAT处理。否则,可能会出现配置成功但实际不生效的情况,并且在配置恢复(由设备重启、软件升级等原因导致)时可能会造成配置丢失。
在接口上,不能通过重复执行本命令来修改接口上指定处理NAT业务的slot。如需修改,请先通过undo nat service命令取消指定的slot,再执行nat service命令。
接口上配置本命令后,该接口的动态地址转换(包括出方向动态地址转换、Easy IP方式的动态地址转换和NAT端口块动态映射)和NAT端口块静态映射中,不能将地址组/端口块组与备份组绑定。
# 指定slot 3作为提供NAT业务处理的slot。
[Sysname-GigabitEthernet3/1/1] nat service slot 3
·     failover-group
·     nat instance
1.1.56  nat static enable
nat static enable命令用来开启接口上的NAT静态地址转换功能。
undo nat static enable命令用来关闭接口上的NAT静态地址转换功能。
nat static enable
NAT静态地址转换功能处于关闭状态。
接口下开启NAT静态地址转换功能后,所有已配置的静态地址转换映射都会在该接口上生效。
# 配置内网IP地址192.168.1.1到外网IP地址2.2.2.2的出方向一对一静态地址转换,并且在接口GigabitEthernet3/1/1上开启静态地址转换功能。
[Sysname] nat static outbound 192.168.1.1 2.2.2.2
[Sysname-GigabitEthernet3/1/1] nat static enable
·     display nat all
·     display nat static
·     nat instance
·     nat static
1.1.57  nat static outbound
nat static outbound命令用来配置出方向一对一静态地址转换映射。
undo nat static outbound命令用来删除出方向一对一静态地址转换映射。
nat static outbound local-ip [ vpn-instance local-vpn-instance-name ] global-ip [ vpn-instance global-vpn-instance-name ] [ acl { ipv4-acl-number | name ipv4-acl-name } [ reversible ] ] [ failover-group group-name ]
undo nat static outbound local-ip [ vpn-instance local-vpn-instance-name ]
不存在任何地址转换映射。
local-ip:内网IP地址。
vpn-instance local-vpn-instance-name:内网IP地址所属的VPN实例。local-vpn-instance-name表示MPLS L3VPN的VPN实例名称,为1~31个字符的字符串,区分大小写。如果未指定本参数,则表示内网IP地址不属于任何一个VPN实例。
global-ip:外网IP地址。
vpn-instance global-vpn-instance-name:外网IP地址所属的VPN实例。global-vpn-instance-name表示MPLS L3VPN的VPN实例名称,为1~31个字符的字符串,区分大小写。如果未指定本参数,则表示外网IP地址不属于任何一个VPN实例。
acl:指定ACL的编号或名称,本参数用于控制内网主机可以访问的目的地址。
ipv4-acl-number:ACL的编号,取值范围为3000~3999。
reversible:表示从外网主动访问内网的报文必须通过ACL反向匹配,才能使用该配置进行目的地址转换。
failover-group group-name:指定该地址转换映射绑定的备份组。group-name表示备份组的名称,为1~63个字符的字符串,区分大小写。有关备份组的详细介绍,请参见“可靠性配置指导”中的“备份组”。
对于从内网到外网的报文,将其源地址local-ip转换为global-ip;对于从外网到内网的报文,将其目的地址global-ip转换为local-ip
指定引用的ACL时,需要注意:
·     如果没有指定ACL,则所有从内网到外网的报文都可以使用该配置进行源地址转换;所有从外网到内网的报文都可以使用该配置进行目的地址转换。
·     如果仅指定了ACL,没有指定ACL反向匹配(即没有配置reversible),对于从内网到外网的报文,只有报文符合ACL permit规则,才能使用该配置进行源地址转换;对于从外网主动访问内网的报文,不能使用该配置进行目的地址转换。
·     如果既指定了ACL,又指定了ACL反向匹配(即配置了reversible),对于从内网到外网的报文,只有报文符合ACL permit规则,才能使用该配置进行源地址转换;对于从外网主动访问内网的报文,需要进行ACL反向匹配(提取报文的源地址/端口和目的地址/端口,并根据配置转换目的地址,然后将源地址/端口和目的地址/端口互换去匹配ACL),只有反向匹配ACL的报文才能使用该配置进行转换,否则不予转换。
如果接口下既配置了NAT动态地址转换,又配置了NAT静态地址转换,则优先使用静态地址转换。
设备可支持配置多条出方向静态地址转换映射(包括nat static outboundnat static outbound net-to-net)。
在VPN组网中,配置出方向静态地址转换时需要指定vpn-instance参数,且VPN实例的名称必须与该接口关联的VPN实例一致。
使用CGN单板处理NAT业务的环境中,需要将出方向一对一静态地址转换映射与节点为CGN单板的备份组绑定,否则会导致反向报文地址转换失败。
在系统视图下配置nat static outbound命令后,将无法配置nat instance命令。反之,如果配置了nat instance命令,将无法在系统视图下配置nat static outbound命令。
# 配置内网IP地址192.168.1.1到外网IP地址2.2.2.2的出方向静态地址转换映射。
# 配置出方向静态地址转换映射,允许内网用户192.168.1.1访问外网网段3.3.3.0/24时,使用外网IP地址2.2.2.2。
[Sysname] acl advanced 3001
[Sysname-acl-ipv4-adv-3001] rule permit ip destination 3.3.3.0 0.0.0.255
[Sysname-acl-ipv4-adv-3001] quit
[Sysname] nat static outbound 192.168.1.1 2.2.2.2 acl 3001
·     display nat all
·     nat instance
·     nat static enable
1.1.58  nat static outbound net-to-net
nat static outbound net-to-net命令用来配置出方向网段到网段的静态地址转换映射。
undo nat static outbound net-to-net命令用来删除出方向网段到网段的静态地址转换映射。
nat static outbound net-to-net local-start-address local-end-address [ vpn-instance local-vpn-instance-name ] global global-network { mask-length | mask } [ vpn-instance global-vpn-instance-name ] [ acl { ipv4-acl-number | name ipv4-acl-name } [ reversible ] ] [ failover-group group-name ]
undo nat static outbound net-to-net local-start-address local-end-address [ vpn-instance local-vpn-instance-name ]
不存在任何地址转换映射。
local-start-address local-end-address:内网地址范围,所包含的地址数目不能超过255。local-start-address 表示起始地址,local-end-address表示结束地址。local-end-address必须大于或等于local-start-address,如果二者相同,则表示只有一个地址。
global-network:外网网段地址。
mask-length:外网网络地址的掩码长度,取值范围为8~31。
mask:外网网络地址掩码。
内网网段通过起始地址和结束地址来指定,外网网段通过外网地址和掩码来指定。
对于从内网到外网的报文,使用其源地址匹配内网地址,将源地址转换为外网地址;对于从外网到内网的报文,使用其目的地址匹配外网地址,将目的地址转换为内网地址。
内网结束地址不能大于内网起始地址和外网掩码所决定的网段中的最大IP地址。比如:外网地址配置为2.2.2.0,掩码为255.255.255.0,内网起始地址为1.1.1.100,则内网结束地址不应该大于1.1.1.0/24网段中可用的最大IP地址,即1.1.1.255。
指定引用的ACL时,需要注意:
使用CGN单板处理NAT业务的环境中,需要将出方向网段到网段的静态地址转换映射与节点为CGN单板的备份组绑定,否则会导致反向报文地址转换失败。
在系统视图下配置nat static outbound net-to-net命令后,将无法配置nat instance命令。反之,如果配置了nat instance命令,将无法在系统视图下配置nat static outbound net-to-net命令。
# 配置内网网段192.168.1.0/24到外网网段2.2.2.0/24的出方向静态地址转换映射。
[Sysname] nat static outbound net-to-net 192.168.1.1 192.168.1.255 global 2.2.2.0 24
# 配置出方向网段到网段的静态地址转换映射,允许内网192.168.1.0/24网段的用户访问外网网段3.3.3.0/24时,使用外网网段2.2.2.0/24中的地址。
[Sysname] nat static outbound net-to-net 192.168.1.1 192.168.1.255 global 2.2.2.0 24 acl 3001
·     display nat all
·     nat instance
·     nat static enable
1.1.59  nat work-mode
nat work-mode命令用来配置NAT的工作模式。
undo nat work-mode命令用来恢复缺省情况。
nat work-mode data-plane
undo nat work-mode
NAT工作在普通模式。
data-plane:配置NAT的工作模式为转发模式。
在NAT应用中,NAT设备有以下三种工作模式,本设备当前仅支持普通模式和转发模式:
·     普通模式:该模式下,NAT模块的控制业务及数据转发业务均由本设备完成。NAT模块的控制业务包括NAT地址以及端口块分配等。NAT模块的数据转发业务包括用户数据报文转发、NAT ALG等。
·     控制模式:该模式下,仅NAT模块的控制业务由本设备完成。
·     转发模式:该模式下,仅NAT模块的数据转发业务由本设备完成。
在NAT控制与转发分离的组网环境中,DP设备上应将NAT的工作模式配置为转发模式。
当存在PPPoE或IPoE在线用户时,无法进行工作模式切换。只有在所有用户下线后,才能进行工作模式切换。
# 配置NAT的工作模式为转发模式。
<Sysname> system
[Sysname] nat work-mode data-plane
1.1.60  port-block
port-block命令用来配置NAT地址组的端口块参数。
undo port-block命令用来恢复缺省情况。
port-block block-size block-size [ extended-block-number extended-block-number [ extended-block-size extended-block-size ] ]
undo port-block
未配置NAT地址组/地址池的端口块参数。
NAT地址组视图
block-size block-size:端口块大小,即一个端口块中所包含的端口数,取值范围为1~65535。如果要指定extended-block-size参数,则本参数的取值必须为64的整数倍。同一NAT地址组内,该参数的值不能超过port-range参数的值。
extended-block-number extended-block-number:增量端口块数,取值范围为1~5。当分配端口块中的端口资源耗尽(所有端口都被使用)时,如果对应的私网IP地址向公网发起新的连接,则无法从分配端口块中获取端口。此时,如果分配端口块的公网IP地址所属的NAT地址组中配置了增量端口块数,则可以为对应的私网IP地址进行增量端口块分配。一个私网IP地址最多可同时占有1+extended-block-number个端口块。
extended-block-size extended-block-size:增量端口块大小,即增量端口块中所包含的端口数,取值范围为64~8192,为64的整数倍。如果未指定本参数,则每一个增量端口块中的端口数与block-size的取值相同。同一NAT地址组内,该参数的值不能超过port-range参数的值。
对于端口块动态映射,触发设备分配端口块的条件如下:
·     在NAT与BRAS联动的场景中,用户认证上线时会触发设备为其分配端口块。
·     在非NAT与BRAS联动的场景中,用户访问外网的首次连接进行源地址转换时会触发设备为其分配端口块。
以上为内网用户分配端口块的方式称为端口块预分配。当预分配的端口资源耗尽时,如果配置了增量端口块,系统将为用户申请增量端口块资源。当用户释放增量端口块中的所有端口资源时,该增量端口块将被系统回收。
端口块动态映射方式下,配置出方向地址转换所引用的NAT地址组中必须配置端口块参数。
# 配置NAT地址组2的端口块参数,端口块大小为256,增量端口块数为1。
[Sysname] nat address-group 2
·     nat address-group
1.1.61  port-limit
port-limit命令用来限制分配给协议的端口数量。
undo port-limit命令用来取消分配给协议的端口数量的限制。
port-limit { icmp | tcp | total | udp } number
undo port-limit { icmp | tcp | total | udp }
不对分配给协议的端口数量做限制。
NAT地址组视图
NAT端口块组视图
icmp:限制分配给ICMP协议的端口数量。
tcp:限制分配给TCP协议的端口数量。
total:限制分配给所有协议的端口数量。
udp:限制分配给UDP协议的端口数量。
number:指定最多分配给协议的端口数量,取值范围为0~65535。
# 配置地址组1最多可分配给TCP协议的端口数量为10。
[Sysname-address-group-1] port-limit tcp 10
# 配置端口块组1最多可分配给TCP协议的端口数量为10。
[Sysname] nat port-block-group 1
[Sysname-port-block-group-1] port-limit tcp 10
·     nat address-group
·     nat port-block group
1.1.62  port-range
port-range命令用来配置公网IP地址的端口范围。
undo port-range命令用来恢复缺省情况。
port-range start-port-number end-port-number
undo port-range
公网IP地址的端口范围为1~65535。
NAT地址组视图
NAT端口块组视图
start-port-number end-port-number:公网IP地址端口的起始端口号和结束端口号。end-port-number必须大于或等于start-port-number。建议将start-port-number配置为大于或等于1024的数值,避免出现应用协议识别错误的问题。
在NAT地址组/NAT端口块组视图下配置端口范围后,该NAT地址组/NAT端口块组内的所有公网IP地址可用于地址转换的端口都必须位于所指定的端口范围之内。
在NAT端口块组内配置端口范围时,端口范围不能小于端口块大小。在NAT地址组内配置端口范围时,如果地址组/地址池配置了端口块参数,则端口范围也不能小于端口块大小。
# 配置NAT地址组1的公网IP地址端口范围为1024~65535。
[Sysname-address-group-1] port-range 1024 65535
# 配置NAT端口块组1的公网IP地址端口范围为30001~65535。
[Sysname-port-block-group-1] port-range 30001 65535
·     nat address-group
·     nat port-block-group
1.1.63  reset nat eim
reset nat eim命令用来删除NAT EIM表项信息。
独立运行模式:
reset nat eim [ protocol { icmp | tcp | udp } ] [ local-ip { b4 ipv6-address | local-ip } ] [ local-port local-port ] [ global-ip global-ip ] [ global-port global-port ] [ slot slot-number ]
IRF模式:
reset nat eim [ protocol { icmp | tcp | udp } ] [ local-ip { b4 ipv6-address | local-ip } ] [ local-port local-port ] [ global-ip global-ip ] [ global-port global-port ] [ chassis chassis-number slot slot-number ]
protocol:删除指定协议类型的EIM表项信息。如果未指定本参数,则表示删除所有协议类型的EIM表项信息。
icmp:删除ICMP协议类型的EIM表项信息。
tcp:删除TCP协议类型的EIM表项信息。
udp:删除UDP协议类型的EIM表项信息。
local-ip b4 ipv6-address删除指定B4设备IPv6地址的EIM表项信息,ipv6-address表示B4设备的IPv6地址。
local-ip local-ip:删除指定内网IP地址的EIM表项信息,local-ip表示内网IP地址。
local-port local-port:删除指定内网端口号的EIM表项信息,local-port表示内网端口号,取值范围为0~65535。
global-ip global-ip:删除指定公网IP地址的EIM表项信息,global-ip表示公网IP地址。
global-port global-port:显示指定公网端口号的EIM表项信息,global-port表示公网端口号,取值范围为0~65535。
slot slot-number:删除指定单板上的EIM表项信息,slot-number表示单板所在的槽位号。若不指定该参数,则表示删除所有单板上的EIM表项信息。(独立运行模式)
chassis chassis-number slot slot-number:删除指定单板上的EIM表项信息,chassis-number表示设备在IRF中的成员编号,slot-number表示单板所在的槽位号。若不指定该参数,则表示删除所有单板上的EIM表项信息。(IRF模式)
# 删除指定slot上的NAT EIM表项信息。
<Sysname> reset nat eim slot 3
·     display nat eim
1.1.64  reset nat session
reset nat session命令用来删除NAT会话。
独立运行模式:
reset nat session [ protocol { tcp | udp } ] [ slot slot-number ]
IRF模式:
reset nat session [ protocol { tcp | udp } ] [ chassis chassis-number slot slot-number ]
protocol:删除指定协议类型的NAT会话。如果未指定本参数,则表示删除所有协议类型的NAT会话。
tcp:删除TCP协议类型的NAT会话。
udp:删除UDP协议类型的NAT会话。
slot slot-number:删除指定单板上的NAT会话,slot-number表示单板所在的槽位号。如果不指定该参数,则表示删除所有单板上的NAT会话。(独立运行模式)。
chassis chassis-number slot slot-number:删除指定成员设备上指定单板的NAT会话,chassis-number表示设备在IRF中的成员编号,slot-number表示单板所在的槽位号。如果不指定该参数,则表示删除所有成员设备的所有单板上的NAT会话。(IRF模式)
NAT会话被删除之后,与其相关的NAT EIM表和NO-PAT表也会同时删除。
# 删除指定slot上的NAT会话。
<Sysname> reset nat session slot 3
·     display nat session
1.1.65  service-instance-group
service-instance-group命令用来将NAT实例与业务实例组关联。
undo service-instance-group命令用来取消NAT实例与业务实例组的关联关系。
service-instance-group service-instance-group-name
undo service-instance-group service-instance-group-name
NAT实例未关联任何业务实例组。
NAT实例视图
service-instance-group-name:业务实例组的名称,取值范围为1~31个字符的字符串,区分大小写。如果该值中包含空格,需要在值的首末添加英文格式的引号,形如"xxx xxx"。关联的业务组实例可以不存在,但要使配置生效,必须通过service-instance-group命令创建业务实例组。关于业务实例组的详细介绍,请参见“可靠性配置指导”中的“业务实例组”。
对于和NAT实例中的NAT规则匹配的流量,系统将使用NAT实例关联的业务实例组中的slot进行地址转换。
一个NAT实例只能关联一个业务实例组。不同的NAT实例不能关联同一个业务实例组。
在NAT与BRAS联动的场景中,存在在线用户时,无法取消NAT实例与业务实例组的关联关系,只有在所有用户下线后,才能取消NAT实例与业务实例组的关联关系。
其他场景中,存在使用NAT实例进行地址转换创建的表项时,可以取消NAT实例与业务实例组的关联关系,系统会将相应的NAT表项全部删除,请谨慎操作。
# 将NAT实例cgn1与业务实例组group1相关联。
[Sysname ] nat instance cgn1 id 1
[Sysname-nat-instance-cgn1] service-instance-group group1
·     nat instance
·     service-instance-group(可靠性命令参考/业务实例组)
