08-IP组播命令参考
06-PIM命令
本章节下载 06-PIM命令  (408.03 KB)
docurl=/cn/Service/Document_Software/Document_Center/Routers/Catalog/SR_Router/SR8800-X/Command/Command_Manual/H3C_SR8800-X_CR-R7951PXX-6W102/08/202011/1358816_30005_0.htm
06-PIM命令
  录
1 PIM
1.1 PIM配置命令
1.1.1 anycast-rp (PIM view)
1.1.2 auto-rp enable (PIM view)
1.1.3 bsm-fragment enable (PIM view)
1.1.4 bsm-reflection enable (PIM view)
1.1.5 bsr-policy (PIM view)
1.1.6 c-bsr (PIM view)
1.1.7 c-rp (PIM view)
1.1.8 crp-policy (PIM view)
1.1.9 display interface register-tunnel
1.1.10 display pim bsr-info
1.1.11 display pim claimed-route
1.1.12 display pim c-rp
1.1.13 display pim interface
1.1.14 display pim neighbor
1.1.15 display pim routing-table
1.1.16 display pim rp-info
1.1.17 display pim statistics
1.1.18 dscp
1.1.19 hello-option dr-priority (PIM view)
1.1.20 hello-option holdtime (PIM view)
1.1.21 hello-option lan-delay (PIM view)
1.1.22 hello-option neighbor-tracking (PIM view)
1.1.23 hello-option override-interval (PIM view)
1.1.24 holdtime join-prune (PIM view)
1.1.25 jp-pkt-size (PIM view)
1.1.26 pim
1.1.27 pim bfd enable
1.1.28 pim bsr-boundary
1.1.29 pim dm
1.1.30 pim hello-option dr-priority
1.1.31 pim hello-option holdtime
1.1.32 pim hello-option lan-delay
1.1.33 pim hello-option neighbor-tracking
1.1.34 pim hello-option override-interval
1.1.35 pim holdtime join-prune
1.1.36 pim join-policy
1.1.37 pim neighbor-policy
1.1.38 pim non-stop-routing
1.1.39 pim passive
1.1.40 pim require-genid
1.1.41 pim sm
1.1.42 pim state-refresh-capable
1.1.43 pim timer graft-retry
1.1.44 pim timer hello
1.1.45 pim timer join-prune
1.1.46 pim triggered-hello-delay
1.1.47 register-policy (PIM view)
1.1.48 register-suppression-timeout (PIM view)
1.1.49 register-whole-checksum (PIM view)
1.1.50 snmp-agent trap enable pim
1.1.51 source-lifetime (PIM view)
1.1.52 source-policy (PIM view)
1.1.53 spt-switch-threshold (PIM view)
1.1.54 ssm-policy (PIM view)
1.1.55 state-refresh-interval (PIM view)
1.1.56 state-refresh-rate-limit (PIM view)
1.1.57 state-refresh-ttl (PIM view)
1.1.58 static-rp (PIM view)
1.1.59 timer hello (PIM view)
1.1.60 timer join-prune (PIM view)
1 PIM
1.1  PIM配置命令
anycast-rp命令用来配置Anycast-RP。
undo anycast-rp命令用来删除Anycast-RP。
anycast-rp anycast-rp-address member-address
undo anycast-rp anycast-rp-address member-address
不存在Anycast-RP。
PIM视图
anycast-rp-address:指定Anycast-RP地址。必须是除127.0.0.0/8网段以外的合法单播IP地址。
member-address:指定Anycast-RP成员地址。必须是除127.0.0.0/8网段以外的合法单播IP地址。
多次执行本命令,可配置多个Anycast-RP。如果配置时指定了相同的Anycast-RP地址,则将Anycast-RP成员地址添加到该Anycast-RP地址所属的Anycast-RP集中。
Anycast-RP成员地址不能与Anycast-RP地址相同。
# 在公网实例中配置如下Anycast-RP集:Anycast-RP地址为1.1.0.0,两个成员的地址分别为1.1.0.1和1.2.0.1(前者为本地接口LoopBack1的地址)。
[Sysname] pim
[Sysname-pim] anycast-rp 1.1.0.0 1.1.0.1
[Sysname-pim] anycast-rp 1.1.0.0 1.2.0.1
·     display pim rp-info
auto-rp enable命令用来开启自动RP侦听功能。
undo auto-rp enable命令用来关闭自动RP侦听功能。
auto-rp enable
undo auto-rp enable
自动RP侦听功能处于关闭状态。
PIM视图
# 在公网实例中开启自动RP侦听功能。
[Sysname] pim
[Sysname-pim] auto-rp enable
bsm-fragment enable命令用来开启自举报文语义分片功能。
undo bsm-fragment enable命令用来关闭自举报文语义分片功能。
bsm-fragment enable
自举报文语义分片功能处于开启状态。
PIM视图
当PIM-SM域中存在不支持自举报文语义分片的设备时,请关闭本功能。
# 在公网实例中关闭自举报文语义分片功能。
[Sysname] pim
[Sysname-pim] undo bsm-fragment enable
bsm-reflection enable命令用来开启自举报文往报文入接口方向转发功能。
undo bsm-reflection enable命令用来关闭自举报文往报文入接口方向转发功能。
自举报文往报文入接口方向转发功能处于开启状态。
PIM视图
如果PIM-SM域中有设备的路由信息不一致,请关闭本功能。
# 在公网实例中关闭自举报文往报文入接口方向转发功能。
[Sysname] pim
[Sysname-pim] undo bsm-reflection enable
bsr-policy命令用来配置合法的BSR地址范围。
undo bsr-policy命令用来恢复缺省情况。
bsr-policy ipv4-acl-number
undo bsr-policy
BSR的地址范围不受限制,即认为来自任意源的自举报文都是合法的。
PIM视图
ipv4-acl-number:指定IPv4基本ACL的编号,取值范围为2000~2999。
配置合法的BSR地址范围可以防止BSR欺骗。
该ACL规则中的source参数用来指定自举报文中的BSR地址范围,并且该规则中除sourcefragmenttime-range以外的其它可选参数都将被忽略。
若ACL中指定了vpn-instance参数则该条规则不生效。
多次执行本命令,最后一次执行的命令生效。
# 在公网实例中配置合法的BSR地址范围,只允许网段10.1.1.0/24中的设备充当BSR。
[Sysname] acl basic 2000
[Sysname-acl-ipv4-basic-2000] rule permit source 10.1.1.0 0.0.0.255
[Sysname] pim
[Sysname-pim] bsr-policy 2000
·     c-bsr (PIM view)
c-bsr命令用来配置C-BSR。
undo c-bsr命令用来删除C-BSR的相关配置。
c-bsr ip-address [ scope group-address { mask-length | mask } ] [ hash-length hash-length | priority priority ] *
undo c-bsr ip-address [ scope group-address { mask-length | mask } ]
不存在C-BSR。
PIM视图
ip-address:指定C-BSR的IP地址,C-BSR的IP地址必须是本地接口的IP地址,且该接口上必须使能PIM,否则配置不会生效。
scope group-address:指定管理域C-BSR所服务的组播组地址,取值范围为239.0.0.0~239.255.255.255。如果未指定本参数,表示配置服务于Global域的C-BSR。
mask-length:指定组播组地址的掩码长度,取值范围为8~32。
mask:指定组播组地址的掩码。
hash-length hash-length:指定哈希掩码长度,取值范围为0~32,缺省值为30。
priority priority:指定C-BSR的优先级,取值范围为0~255,缺省值为64。数值越大,优先级越高。
如果对同一个域多次执行本命令,最后一次执行的命令生效。而针对不同域的C-BSR则允许指定相同的IP地址。
# 在公网实例中将IP地址为1.1.1.1的设备配置为Global域的C-BSR。
[Sysname] pim
[Sysname-pim] c-bsr 1.1.1.1
c-rp命令用来配置C-RP。
undo c-rp命令用来删除C-RP的相关配置。
c-rp ip-address [ advertisement-interval adv-interval | group-policy ipv4-acl-number  | holdtime hold-time | priority priority ] *
undo c-rp ip-address
不存在C-RP。
PIM视图
ip-address:指定C-RP的IP地址,C-RP的IP地址必须有对应的本地接口,且该接口上必须使能PIM,否则配置不会生效。
advertisement-interval adv-interval:指定发送宣告报文的间隔时间,取值范围为1~65535,单位为秒,缺省值为60。
group-policy ipv4-acl-number:指定IPv4基本ACL的编号,取值范围为2000~2999。如果指定了本参数,该C-RP将只为ACL规则所允许的组播组服务;如果未指定本参数、指定的ACL不存在或ACL中未配置有效规则,则该C-RP将为所有组播组服务。
holdtime hold-time:指定C-RP的超时时间,取值范围为1~65535,单位为秒,缺省值为150。
priority priority:指定C-RP的优先级,取值范围为0~255,缺省值为192。数值越大,优先级越低。
如果设备想要成为多个组范围的C-RP,则需要在配置group-policy所对应的ACL时将多个组范围用多个rule规则表示出来。
对于IPv4基本ACL,该ACL规则中的source参数用来指定C-RP宣告报文中的组播组地址范围,并且该规则中除sourcefragmenttime-range以外的其它可选参数都将被忽略。
如果对同一IP地址多次执行本命令,最后一次执行的命令生效。
# 在公网实例中将IP地址为1.1.1.1配置为225.1.0.0/16和226.2.0.0/16的C-RP,且C-RP的优先级为10。
[Sysname-acl-ipv4-basic-2000] rule permit source 225.1.0.0 0.0.255.255
[Sysname-acl-ipv4-basic-2000] rule permit source 226.2.0.0 0.0.255.255
[Sysname] pim
[Sysname-pim] c-rp 1.1.1.1 group-policy 2000 priority 10
crp-policy命令用来配置合法的C-RP地址范围及其服务的组播组范围。
undo crp-policy命令用来恢复缺省情况。
crp-policy ipv4-acl-number
undo crp-policy
C-RP地址范围及其服务的组播组范围不受限制,即认为所有收到的C-RP报文都是合法的。
PIM视图
ipv4-acl-number:指定IPv4高级ACL的编号,取值范围为3000~3999。
配置合法的C-RP地址范围及其服务的组播组范围可以防止C-RP欺骗。
本命令在对C-RP所宣告的组播组范围进行过滤时,只取其前缀部分进行匹配。例如,C-RP宣告的组播组范围为224.1.0.0/16,如果其前缀部分“224.1.0.0”能匹配上本命令所引用的ACL规则,就认为整个组播组范围“224.1.0.0/16”都通过了过滤。
该ACL规则中的source参数用来指定C-RP宣告报文中的C-RP地址范围,destination参数用来指定该C-RP所服务的组播组地址范围,并且该规则中除sourcedestinationfragmenttime-range以外的其它可选参数都将被忽略。
# 在公网实例中配置C-RP策略,只允许1.1.1.1/24范围内的设备充当C-RP,且只允许其为225.1.1.0/24范围内的组播组服务。
[Sysname] acl advanced 3000
[Sysname-acl-ipv4-adv-3000] rule permit ip source 1.1.1.1 0.0.0.255 destination 225.1.1.0 0.0.0.255
[Sysname] pim
[Sysname-pim] crp-policy 3000
·     c-rp (PIM view)
display interface register-tunnel命令用来显示Register-Tunnel接口的运行状态和相关信息。
display interface [ register-tunnel [ interface-number ] ] [ brief [ description | down ] ]
register-tunnel [ interface-number ]:指定Register-Tunnel接口的信息。interface-number为Register-Tunnel接口的编号。由于设备上只存在一个Register-Tunnel接口(即Register-Tunnel0),因此只要指定了register-tunnel参数,不论是否指定interface-number参数,都将显示接口Register-Tunnel0的相关信息。如果未指定接口类型,将显示设备支持的所有接口的信息。
brief:显示概要信息。如果未指定本参数,将显示详细信息。
description:当用户配置的接口描述信息超过27个字符时,在概要信息中显示完整的接口描述信息。如果未指定本参数,在概要信息中将只显示前27个字符,超出部分不会显示。
down:显示当前物理状态为down的接口的信息以及down的原因。如果未指定本参数,将不会根据接口物理状态来过滤显示信息。
Register-Tunnel接口是一种虚拟接口,由系统自动创建。用户不能对该接口进行配置和删除,但可使用本命令进行显示。
Register-Tunnel接口是在组播源注册过程初期,用于在组播源侧DR与RP之间建立一个传输注册报文的通道,具体过程为:当组播源侧DR第一次收到组播源发来的组播数据时,由于组播源侧DR与RP之间尚未建立SPT,于是组播源侧DR通过其Register-Tunnel接口将封装到注册报文中的组播数据发给RP,而RP也通过其Register-Tunnel接口接收注册报文,并将解封装后的组播数据转发给接收者。
在上述过程中,RP从组播数据中获取到了组播源的位置,于是向组播源方向发送加入报文并最终建立起SPT。此后,组播源侧DR便不再通过Register-Tunnel接口,而是通过SPT将组播数据发送给RP。
# 显示接口Register-Tunnel0的详细信息。
<Sysname> display interface register-tunnel 0
Register-Tunnel0
Current state: UP
Line protocol state: DOWN
Description: Register-Tunnel0 Interface
Maximum transmission unit: 1536
Physical: Unknown
# 显示接口Register-Tunnel0的概要信息。
<Sysname> display interface register-tunnel 0 brief
Protocol: (s) - spoofing
REG0                 UP   --       --
表1-1 display interface register-tunnel命令显示信息描述表
Current state
接口的物理状态,Register-Tunnel接口的物理状态始终为UP
Line protocol state
接口的链路状态,Register-Tunnel接口的链路状态始终为DOWN
接口的描述信息
接口的MTU
接口能否配置IP地址,始终为Disabled,表示不能
Physical
接口的物理类型,始终为Unknown,表示未知
最近300秒钟的平均输入速率,始终均为0
最近300秒钟的平均输出速率,始终均为0
Input
接口输入的报文数、字节数、丢弃报文数,始终均为0
Output
接口输出的报文数、字节数、丢弃报文数,始终均为0
Brief information on interfacesin route mode
三层接口的概要信息
接口的物理连接状态:
·     UP:表示接口在物理上连通
·     DOWN:表示接口在物理上不通
·     ADM:表示接口被手工关闭,需执行undo shutdown命令才能打开
·     Stby:表示接口为备份接口
如果某接口的Protocol属性值中带有“(s)”,表示该接口的数据链路层协议状态显示为UP,但实际可能没有对应的链路,或者对应的链路不是永久存在而是按需建立的。通常NULL、LoopBack等接口会具有该属性
Link
接口的链路状态,由于不依赖任何资源,所以可以直接UP
Protocol
接口的协议连接状态,对Register-Tunnel接口无意义,始终为“--”
Primary IP
接口的IP地址,不可配置。对Register-Tunnel接口无意义,始终为“--”
接口的描述,由于所有描述信息均不可配置,所以此处显示为空
·     reset counters interface register-tunnel
display pim bsr-info命令用来显示PIM-SM域中的BSR信息。
display pim [ vpn-instance vpn-instance-name ] bsr-info
vpn-instance vpn-instance-name:显示指定VPN实例的BSR信息,vpn-instance-name表示MPLS L3VPN的VPN实例名称,为1~31个字符的字符串,区分大小写。如果未指定本参数,将显示公网实例的BSR信息。
# 显示公网实例PIM-SM域中的BSR信息。
<Sysname> display pim bsr-info
 Scope: non-scoped
     State: Accept Preferred
     Bootstrap timer: 00:01:44
     Elected BSR address: 12.12.12.1
       Priority: 64
       Hash mask length: 30
       Uptime: 00:21:56
 Scope: 239.4.0.0/16
     State: Accept Any
     Scope-zone expiry timer: 00:21:12
 Scope: 239.1.0.0/16
     State: Elected
     Bootstrap timer: 00:00:26
     Elected BSR address: 17.1.11.1
       Priority: 64
       Uptime: 02:53:37
     Candidate BSR address: 17.1.11.1
       Priority: 64
 Scope: 239.2.2.0/24
     State: Candidate
     Bootstrap timer: 00:01:56
     Elected BSR address: 61.2.37.1
       Priority: 64
       Uptime: 02:53:32
     Candidate BSR address: 17.1.12.1
       Priority: 64
 Scope: 239.3.3.0/24
     State: Pending
     Bootstrap timer: 00:00:07
     Candidate BSR address: 17.1.13.1
       Priority: 64
表1-2 display pim bsr-info命令显示信息描述表
Scope
域状态
Bootstrap timer
BSR定时器
域老化定时器
Elected BSR address
当选BSR的地址
候选BSR的地址
Priority
BSR的优先级
Hash mask length
哈希掩码长度
Uptime
BSR已存在的时间
display pim claimed-route命令用来显示PIM所使用的路由信息。
display pim [ vpn-instance vpn-instance-name ] claimed-route [ source-address ]
vpn-instance vpn-instance-name:显示指定VPN实例的路由信息,vpn-instance-name表示MPLS L3VPN的VPN实例名称,为1~31个字符的字符串,区分大小写。如果未指定本参数,将显示公网实例的路由信息。
source-address:组播源的IP地址,显示到达指定组播源的路由信息。如果未指定本参数,将显示PIM所使用的所有路由信息。
# 显示PIM在公网实例中使用的所有路由信息。
<Sysname> display pim claimed-route
 RPF-route selecting rule: longest-match
 Route/mask: 7.11.0.0/16 (unicast (direct))
     RPF interface: GigabitEthernet3/1/1, RPF neighbor: 8.0.0.2
     Total number of (S,G) or (*,G) dependent on this route entry: 4
     (7.11.0.10, 225.1.1.1)
     (7.11.0.10, 226.1.1.1)
     (7.11.0.10, 227.1.1.1)
     (*, 228.1.1.1)
 Route/mask: 7.12.0.0/16 (multicast static)
     RPF interface: GigabitEthernet3/1/2, RPF neighbor: 8.0.0.3,
     Config NextHop: 8.0.0.5
     Total number of (S,G) or (*,G) dependent on this route entry: 2
     (7.12.0.10, 226.1.1.1)
     (7.12.0.10, 225.1.1.1)
表1-3 display pim claimed-route命令显示信息描述表
RPF路由的选择规则
Route/mask
路由项。括号内为路由类型,包括:
·     igp:单播路由(内部网关协议)
·     egp:单播路由(外部网关协议)
·     unicast (direct):单播路由(直连)
·     unicast:其它单播路由(如单播静态路由等)
·     mbgp:MBGP路由
·     multicast static:组播静态路由
RPF interface
RPF接口的名称
RPF neighbor
RPF邻居的IP地址
Config NextHop
配置的下一跳地址,本字段只在组播静态路由配置下一跳时显示
on this route entry
基于此RPF路由的(S,G)或(*,G)个数及列表
display pim c-rp命令用来显示PIM-SM域中的C-RP信息。
display pim [ vpn-instance vpn-instance-name ] c-rp [ local ]
vpn-instance vpn-instance-name:显示指定VPN实例的C-RP信息,vpn-instance-name表示MPLS L3VPN的VPN实例名称,为1~31个字符的字符串,区分大小写。如果未指定本参数,将显示公网实例的C-RP信息。
local:显示本地配置且生效的C-RP信息。如果未指定本参数,将显示所有学习到的C-RP信息。
只有当选的BSR上才会有学习到的C-RP信息,其它设备上只能查看到本地配置生效的C-RP信息。
# 显示公网实例中学习到的C-RP信息。
<Sysname> display pim c-rp
 Scope: non-scoped
     Group/MaskLen: 224.0.0.0/4
       C-RP address             Priority  HoldTime  Uptime    Expires
       1.1.1.1 (local)          192       150       03:01:36  00:02:29
       2.2.2.2                  192       150       1d:13h    00:02:02
# 显示本地配置生效的C-RP信息。
<Sysname> display pim c-rp local
 Candidate RP: 12.12.12.9(Loop1)
     Priority: 192
     HoldTime: 150
     Advertisement interval: 60
     Next advertisement scheduled at: 00:00:48
表1-4 display pim c-rp命令显示信息描述表
Scope
Group/MaskLen
C-RP所服务的组播组
C-RP address
C-RP的IP地址,local表示本地地址
Priority
C-RP的优先级
HoldTime
C-RP的超时时间
Uptime
C-RP已存在的时间,w表示星期,d表示天,h表示小时
Expires
C-RP/组播组的超时剩余时间
Candidate RP
本地C-RP的IP地址
本地C-RP发送通告报文时间间隔
本地C-RP发送下一个通告报文的剩余时间
display pim interface命令用来显示接口上的PIM信息。
display pim [ vpn-instance vpn-instance-name ] interface [ interface-type interface-number ] [ verbose ]
vpn-instance vpn-instance-name:显示指定VPN实例的PIM信息,vpn-instance-name表示MPLS L3VPN的VPN实例名称,为1~31个字符的字符串,区分大小写。如果未指定本参数,将显示公网实例的PIM信息。
interface-type interface-number:显示指定接口上的PIM信息。如果未指定本参数,将显示所有接口上的PIM信息。
# 显示公网实例所有接口上的PIM概要信息。
<Sysname> display pim interface
 Interface         NbrCnt  HelloInt  DR-Pri     DR-Address
 GE3/1/1           1       30        1          10.1.1.2
 GE3/1/2           0       30        1          172.168.0.2    (local)
 GE3/1/3           1       30        1          20.1.1.2
表1-5 display pim interface命令显示信息描述表
接口名称
NbrCnt
PIM邻居的数量
HelloInt
发送Hello报文的时间间隔
DR-Pri
竞选DR的优先级
DR-Address
DR的IP地址,local表示本地地址
# 显示公网实例接口GigabitEthernet3/1/1上的PIM详细信息。
<Sysname> display pim interface gigabitethernet 3/1/1 verbose
 Interface: GigabitEthernet3/1/1, 10.1.1.1
     PIM version: 2
     PIM mode: Sparse
     PIM DR: 10.1.1.2
     PIM DR Priority (configured): 1
     PIM neighbors count: 1
     PIM hello interval: 30 s
     PIM LAN delay (negotiated): 500 ms
     PIM LAN delay (configured): 500 ms
     PIM override interval (negotiated): 2500 ms
     PIM override interval (configured): 2500 ms
     PIM neighbor tracking (negotiated): disabled
     PIM neighbor tracking (configured): disabled
     PIM generation ID: 0xF5712241
     PIM require generation ID: disabled
     PIM hello hold interval: 105 s
     PIM assert hold interval: 180 s
     PIM triggered hello delay: 5 s
     PIM J/P interval: 60 s
     PIM J/P hold interval: 210 s
     PIM BSR domain border: disabled
     PIM BFD: disabled
PIM passive: disabled
     Number of routers on network not using DR priority: 0
     Number of routers on network not using LAN delay: 0
     Number of routers on network not using neighbor tracking: 2
表1-6 display pim interface verbose命令显示信息描述表
接口名称与IP地址
PIM version
PIM协议的版本号
PIM mode
PIM协议的模式,是密集模式还是稀疏模式
PIM DR
DR的IP地址
竞选DR优先级的配置值
PIM neighbors count
PIM邻居的总数
PIM hello interval
发送Hello报文的时间间隔
剪枝报文传输延迟的协商值
剪枝报文传输延迟的配置值
剪枝否决时间的协商值
剪枝否决时间的配置值
邻居跟踪开启与否的协商情况
邻居跟踪开启与否的配置情况
PIM generation ID
Generation_ID参数值
是否开启不接受无Generation ID的Hello报文
保持PIM邻居的可达状态的时间
保持断言状态的时间
发送Hello报文的最大延迟时间
PIM J/P interval
发送加入/剪枝报文的时间间隔
加入/剪枝状态的保持时间
该接口是否配置了BSR的服务边界
PIM BFD
该接口是否开启了PIM与BFD联动功能
PIM passive
该接口是否配置了PIM消极模式
该接口所在网段上没有使用DR优先级字段的路由器数量
该接口所在网段上未使用LAN-delay字段的路由器数量
该接口所在网段上未开启邻居跟踪的路由器数量
display pim neighbor命令用来显示PIM邻居信息。
display pim [ vpn-instance vpn-instance-name ] neighbor [ neighbor-address | interface interface-type interface-number | verbose ] *
vpn-instance vpn-instance-name:显示指定VPN实例的PIM邻居信息,vpn-instance-name表示MPLS L3VPN的VPN实例名称,为1~31个字符的字符串,区分大小写。如果未指定本参数,将显示公网实例的PIM邻居信息。
neighbor-address:PIM邻居的IP地址,显示指定PIM邻居的信息。如果未指定本参数,将显示所有PIM邻居的信息。
interface interface-type interface-number:接口类型和接口编号,显示指定接口上的PIM邻居信息。如果未指定本参数,将显示所有接口上的PIM邻居信息。
# 显示公网实例所有PIM邻居的概要信息。
<Sysname> display pim neighbor
 Total Number of Neighbors = 2
 Neighbor        Interface           Uptime Expires  DR-Priority Mode
 20.1.1.2        GE3/1/2             02:49:39 00:01:42 1           P
# 显示公网实例中IP地址为11.110.0.20的PIM邻居的详细信息。
<Sysname> display pim neighbor 11.110.0.20 verbose
 Neighbor: 11.110.0.20
     Interface: GigabitEthernet3/1/3
     Uptime: 00:00:10
     Expiry time: 00:00:30
     DR Priority: 1
     Generation ID: 0x2ACEFE15
     Holdtime: 105 s
     LAN delay: 500 ms
     Override interval: 2500 ms
     State refresh interval: 60 s
     Neighbor tracking: Disabled
     RPF proxy vector: Disabled
表1-7 display pim neighbor命令显示信息描述表
PIM邻居的总数
Neighbor
PIM邻居的IP地址
PIM邻居所在接口的名称
Uptime
PIM邻居已存在的时间
Expires/Expiry time
PIM邻居超时的剩余时间,never表示PIM邻居永不超时,即永远可达
DR-Priority/DR Priority
PIM邻居的优先级
Mode
PIM邻居的模式,P表示开启RPF代理向量功能,如果该字段显示为空则表示关闭RPF代理向量功能
Generation ID
PIM邻居的Generation ID(状态随机数)
Holdtime
PIM邻居的生存时间,forever表示PIM邻居永远存在,即永远可达
LAN delay
PIM报文在共享网段中的传输延迟
Override interval
剪枝否决的时间间隔
状态刷新的时间间隔,只有当PIM邻居工作在PIM-DM模式下且具备状态刷新能力时才会显示本字段
Neighbor tracking
邻居跟踪功能是否开启
RPF proxy vector
RPF代理向量功能(请参见“IP组播配置指导”中的“组播VPN”)是否开启
display pim routing-table命令用来显示PIM路由表的内容。
display pim [ vpn-instance vpn-instance-name ] routing-table [ group-address [ mask { mask-length | mask } ] | source-address [ mask { mask-length | mask } ] | flags flag-value | fsm | incoming-interface interface-type interface-number | mode mode-type | outgoing-interface { exclude | include | match } interface-type interface-number | proxy ] *
vpn-instance vpn-instance-name:显示指定VPN实例的PIM路由项,vpn-instance-name表示MPLS L3VPN的VPN实例名称,为1~31个字符的字符串,区分大小写。如果未指定本参数,将显示公网实例的PIM路由项。
group-address:组播组地址,显示指定组播组的PIM路由项,取值范围为224.0.0.0~239.255.255.255。如果未指定本参数,将显示所有组播组的PIM路由项。
source-address:组播源地址,显示包含指定组播源的PIM路由项。
mask-length:指定组播组或组播源地址的掩码长度,取值范围为0~32,缺省值为32。
mask:指定组播组或组播源地址的掩码,缺省值为255.255.255.255。
flags flag-value:PIM标志,显示包含指定标志的PIM路由项。如果未指定本参数,将显示包含所有标志的PIM路由项。flag-value的取值及含义如下
·     2msdp:表示准备向MSDP发出通知,在下一个SA报文中包含的PIM路由项;
·     2mvpn:表示准备向MVPN发送相关路由信息的PIM路由项;
·     act:表示已经有实际数据到达的PIM路由项;
·     del:表示计划删除的PIM路由项;
·     exprune:表示某些出接口被其它组播路由协议剪枝的PIM路由项;
·     ext:表示包含了由其它组播路由协议提供出接口的PIM路由项;
·     loc:表示在与组播源处于同一网段的路由器上的PIM路由项;
·     msdp:表示从MSDP的SA报文中学习到的PIM路由项;
·     niif:表示未确定入接口的PIM路由项;
·     nonbr:表示PIM邻居查找失败的PIM路由项;
·     rc:表示已经收到C-Multicast Route路由信息的PIM路由项;
·     rpt:表示向RP方向发送过(S,G)RPT位剪枝的PIM路由项;
·     rq:表示Data-MDT切换接收端的PIM路由项;
·     sc:表示准备向MVPN发送C-multicast A-D Route路由信息的PIM路由项;
·     spt:表示SPT上的PIM路由项;
·     sq:表示Data-MDT切换发起端的PIM路由项;
·     src-act:表示已经收到Source Active A-D Route路由信息的PIM路由项;
·     swt:表示正处于向SPT切换过程中的PIM路由项;
·     vxlan表示是vxlan的overlay表项;
·     wc:表示带WC通配符的PIM路由项。
fsm:显示有限状态机的详细信息。
incoming-interface interface-type interface-number:显示指定入接口的PIM路由项。如果未指定本参数,将显示所有入接口的PIM路由项。
mode mode-type:PIM模式,显示指定模式下的PIM路由项。如果未指定本参数,将显示所有模式下的PIM路由项。mode-type的取值及含义如下:
·     dm:表示PIM-DM模式;
·     sm:表示PIM-SM模式;
·     ssm:表示PIM-SSM模式。
outgoing-interface { exclude | include | match } interface-type interface-number:显示指定出接口的PIM路由项。其中,exclude表示不包含指定接口;include表示包含指定接口;match表示包含且仅包含指定接口。如果未指定本参数,将显示所有出接口的PIM路由项。
proxy:显示PIM路由项使用的RPF代理向量信息。
# 显示公网实例PIM路由表的内容。
<Sysname> display pim routing-table
 Total 0 (*, G) entries; 1 (S, G) entries
 (172.168.0.12, 227.0.0.1)
     RP: 2.2.2.2
     Protocol: pim-sm, Flag: SPT LOC ACT
     UpTime: 02:54:43
     Upstream interface: GigabitEthernet3/1/1
         Upstream neighbor: NULL
         RPF prime neighbor: NULL
     Downstream interface information:
         1: GigabitEthernet3/1/2
             Protocol: pim-sm, UpTime: 02:54:43, Expires: 00:02:47
表1-8 display pim routing-table命令显示信息描述表
PIM路由表中(S,G)表项的总数与(*,G)表项的总数
PIM路由表中的(S,G)表项
Protocol
PIM的模式
Flag
PIM路由表中(S,G)或(*,G)表项的标志:
·     2MSDP:表示准备向MSDP发出通知,在下一个SA报文中包含的PIM路由项
·     2MVPN表示准备向MVPN发送相关路由信息的PIM路由项
·     ACT:表示已有实际数据到达
·     DEL:表示计划要删除
·     EXPRUNE:表示某些出接口被其它组播路由协议剪枝
·     EXT:表示包含了由其它组播路由协议提供的出接口
·     LOC:表示与组播源处于同一网段
·     MSDP:表示从MSDP的SA报文中学习到的PIM路由项
·     NIIF:表示未确定入接口
·     NONBR:表示PIM邻居查找失败
·     RC:表示已经收到C-Multicast Route路由信息的PIM路由项
·     RPT:表示向RP方向发送过(S,G)RPT位剪枝
·     SC:表示准备向MVPN发送C-multicast A-D Route路由信息的PIM路由项
·     SPT:表示在SPT上
·     SQ:表示Data-MDT切换发起端的PIM路由项
·     SRC-ACT:表示已经收到Source Active A-D Route路由信息的PIM路由项
·     SWT:表示正在向SPT切换
·     VXLAN:表示是VXLAN的overlay表项
·     WC:表示带WC通配符
Uptime
(S,G)或(*,G)表项已存在的时间
Upstream interface
(S,G)或(*,G)表项的入接口
Upstream neighbor
(S,G)或(*,G)表项的上游邻居
RPF prime neighbor
(S,G)或(*,G)表项的RPF邻居:
·     对(*,G)表项来说,当该路由器是RP时,(*,G)表项的RPF邻居是NULL
·     对(S,G)表项来说,当该路由器直连源时,(S,G)表项的RPF邻居是NULL
RPF proxy vector
RPF代理向量,本字段只有在B类跨AS的MD VPN(请参见“IP组播配置指导”中的“组播VPN”)组网中才会显示
下游接口的信息,包括:
·     下游接口的总数
·     下游接口的名称
·     下游接口使用的协议类型
·     下游接口的存在时间
·     下游接口的超时时间
# 在PE设备上显示公网实例PIM路由项使用的RPF代理向量信息。
<Sysname> display pim routing-table proxy
 (100.0.0.8, 232.1.1.1)
    Proxy: 10:1/192.168.0.4
    Assigner: 0.0.0.0         Origin: BGP MDT
    Uptime: 02:08:18          Expires: Off
# 在P设备上显示公网实例PIM路由项使用的RPF代理向量信息。
    Assigner: 1.0.3.1         Origin: PIM
    Uptime: 02:19:33          Expires: 00:02:12
# 在ASBR设备上显示公网实例PIM路由项使用的RPF代理向量信息。
(100.0.0.1, 232.1.1.1)
    Proxy: 10:1/local
    Assigner: 1.0.5.9         Origin: PIM
    Uptime: 02:22:04          Expires: 00:02:35
    Proxy: 10:1/local
    Assigner: 1.0.4.1         Origin: PIM
    Uptime: 02:21:10          Expires: 00:02:35
表1-9 display pim routing-table proxy命令显示信息描述表
Proxy
代理向量信息,包括RD(Route Distinguisher,路由标识符)和RPF代理向量的地址,local表示RPF代理向量为本地地址(比如在ASBR上)
Assigner
分配RPF代理向量的设备地址:
·     在PE上,RPF代理向量是从BGP MDT路由中获取的,显示为0.0.0.0
·     在非PE上,RPF代理向量是从下游PIM邻居发来的PIM加入报文中学到的,显示为下游PIM邻居的接口地址
Origin
产生RPF代理向量的协议:
·     在PE上,RPF代理向量是从BGP MDT路由中获取的,显示为BGP MDT
·     在非PE上,RPF代理向量是从下游PIM邻居发来的PIM加入报文中学到的,显示为PIM
Uptime
RPF代理向量已存在的时间
Expires
RPF代理向量的超时剩余时间,Off表示该定时器关闭
display pim rp-info命令用来显示PIM-SM域中的RP信息。
display pim [ vpn-instance vpn-instance-name ] rp-info [ group-address ]
vpn-instance vpn-instance-name:显示指定VPN实例的RP信息,vpn-instance-name表示MPLS L3VPN的VPN实例名称,为1~31个字符的字符串,区分大小写。如果未指定本参数,将显示公网实例的RP信息。
group-address:组播组地址,显示指定组播组所对应的RP信息,取值范围为224.0.1.0~239.255.255.255。如果未指定本参数,将显示所有组播组对应的RP信息。
# 显示公网实例中组播组224.0.1.1所对应的RP信息。
<Sysname> display pim rp-info 224.0.1.1
 BSR RP address is: 2.2.2.2
     Priority: 192
     HoldTime: 180
     Uptime: 03:01:10
     Expires: 00:02:30
 Static RP address is: 3.3.3.5
     Preferred: Yes
     Configured ACL: 2003
 RP mapping for this group is: 3.3.3.5
 Anycast-RP 3.3.3.5 members:
     Member address           State
     1.1.0.1                  Active
     1.2.0.2                  Local
     1.2.0.1                  Remote
# 显示公网实例中所有组播组对应的RP信息。
 BSR RP information:
   Scope: non-scoped
       1.1.1.1 (local)          192       180       03:01:36  00:02:29
       2.2.2.2                  192       180       1d:13h    00:02:02
 Static RP information:
       RP address               ACL   Mode    Preferred
       3.3.3.1                  2000  pim-sm  No
       3.3.3.3                  2002  pim-sm  No
       3.3.3.4                        pim-sm  No
       3.3.3.5                  2002  pim-sm  Yes
 Anycast-RP information:
       RP address               Member address           State
       3.3.3.5                  1.1.0.1                  Active
       3.3.3.5                  1.1.0.2                  Local
       3.3.3.5                  1.2.0.1                  Remote
表1-10 display pim rp-info命令显示信息描述表
BSR RP address is
RP的IP地址
BSR RP information
BSR RP信息
Scope
Group/MaskLen
RP所服务的组播组
RP address
RP的IP地址,local表示本地地址
Priority
RP的优先级
HoldTime
RP的超时时间
Uptime
RP已存在的时间
Expires
RP超时的剩余时间
静态RP信息
Static RP address is/RP address
静态RP的IP地址
Preferred
是否指定了静态RP优先
Configured ACL/ACL
静态RP所服务的组播组列表
Mode
PIM-SM服务
服务于当前组播组的RP的IP地址
Anycast-RP 3.3.3.5的成员
Member address
Anycast-RP成员的IP地址
Anycast-RP成员地址的来源:
·     Active:表示本端激活接口的地址
·     Local:表示本端未激活接口的地址
·     Remote:表示远端的地址
Anycast-RP信息
display pim statistics命令用来显示PIM协议报文的统计信息。
# 显示PIM协议报文的统计信息。
<Sysname> display pim statistics
 Received PIM packets: 3295
 Sent PIM packets    : 5975
                Valid       Invalid        Succeeded   Failed
     Hello    : 3128        0              4333        0
     Reg      : 14          0              0           0
     Reg-stop : 0           0              0           0
     JP       : 151         0              561         0
     BSM      : 0           0              1081        0
     Assert   : 0           0              0           0
     Graft    : 0           0              0           0
     Graft-ACK: 0           0              0           0
     C-RP     : 0           0              0           0
     SRM      : 0           0              0           0
     DF       : 0           0              0           0
     AutoRP   : 0           0              0           0
表1-11 display pim statistics命令显示信息描述表
收到的PIM协议报文总数
Sent PIM packets
发出的PIM协议报文总数
Valid
收到的合法PIM协议报文数量
Invalid
收到的非法PIM协议报文数量
Succeeded
发送成功的PIM协议报文数量
Failed
发送失败的PIM协议报文数量
Hello
Hello报文统计
Reg
注册报文统计
Reg-stop
注册停止报文统计
JP
加入/剪枝报文统计
BSM
自举报文统计
Assert
断言报文统计
Graft
嫁接报文统计
Graft-ACK
嫁接应答报文统计
C-RP
C-RP报文统计
SRM
状态刷新报文统计
DF
指定转发者报文统计
AutoRP
自动RP报文统计
1.1.18  dscp
dscp命令用来配置PIM发送协议报文的DSCP优先级。
undo dscp命令用来恢复缺省情况。
dscp dscp-value
undo dscp
PIM发送协议报文的DSCP优先级为48。
PIM视图
dscp-value: DSCP值,取值范围为0~63。
DSCP的取值越大, PIM发送协议报文的DSCP优先级越高。
# 配置PIM报文的DSCP值为63。
[Sysname] pim
[Sysname-pim] dscp 63
hello-option dr-priority命令用来全局配置竞选DR的优先级。
undo hello-option dr-priority命令用来恢复缺省情况。
竞选DR的优先级为1。
PIM视图
priority:指定竞选DR的优先级,取值范围为0~4294967295。数值越大,优先级越高。
本配置既可在PIM视图又可在接口视图下进行,前者对所有接口都生效,而后者只对当前接口生效,但后者的配置优先级较高。
# 在公网实例中全局配置竞选DR的优先级为3。
[Sysname] pim
[Sysname-pim] hello-option dr-priority 3
·     pim hello-option dr-priority
hello-option holdtime命令用来全局配置保持PIM邻居可达状态的时间。
undo hello-option holdtime命令用来恢复缺省情况。
hello-option holdtime time
保持PIM邻居可达状态的时间为105秒。
PIM视图
time:指定保持PIM邻居可达状态的超时时间,取值范围为1~65535,单位为秒。如果指定为65535秒,则表示PIM邻居永远可达。
# 在公网实例中全局配置保持PIM邻居可达状态的时间为120秒。
[Sysname] pim
[Sysname-pim] hello-option holdtime 120
·     pim hello-option holdtime
hello-option lan-delay命令用来全局配置PIM报文在共享网段中的传输延迟。
undo hello-option lan-delay命令用来恢复缺省情况。
hello-option lan-delay delay
PIM报文在共享网段中的传输延迟为500毫秒。
PIM视图
delay:指定PIM报文在共享网段中的传输延迟,取值范围为1~32767,单位为毫秒。
# 在公网实例中全局配置PIM报文在共享网段中的传输延迟为200毫秒。
[Sysname] pim
[Sysname-pim] hello-option lan-delay 200
·     hello-option override-interval (PIM view)
·     pim hello-option lan-delay
·     pim hello-option override-interval
hello-option neighbor-tracking命令用来全局开启邻居跟踪功能。
undo hello-option neighbor-tracking命令用来全局关闭邻居跟踪功能。
邻居跟踪功能处于关闭状态。
PIM视图
# 在公网实例中全局开启邻居跟踪功能。
[Sysname] pim
[Sysname-pim] hello-option neighbor-tracking
·     pim hello-option neighbor-tracking
hello-option override-interval命令用来全局配置剪枝否决时间。
undo hello-option override-interval命令用来恢复缺省情况。
剪枝否决时间为2500毫秒。
PIM视图
interval:剪枝的否决时间,取值范围为1~65535,单位为毫秒。
# 在公网实例中全局配置剪枝否决时间为2000毫秒。
[Sysname] pim
[Sysname-pim] hello-option override-interval 2000
·     hello-option lan-delay (PIM view)
holdtime join-prune命令用来全局配置加入/剪枝状态的保持时间。
undo holdtime join-prune命令用来恢复缺省情况。
holdtime join-prune time
加入/剪枝状态的保持时间为210秒。
PIM视图
time:指定加入/剪枝状态的保持时间,取值范围为1~65535,单位为秒。
PIM接口向上游邻居发送加入/剪枝报文的时间间隔必须小于加入/剪枝状态的保持时间,以免上游邻居老化超时。
# 在公网实例中全局配置加入/剪枝状态的保持时间为280秒。
[Sysname] pim
[Sysname-pim] holdtime join-prune 280
·     pim holdtime join-prune
·     timer join-prune (PIM view)
jp-pkt-size命令用来配置加入/剪枝报文的最大长度。
undo jp-pkt-size命令用来恢复缺省情况。
jp-pkt-size size
undo jp-pkt-size
加入/剪枝报文的最大长度为1200字节。
PIM视图
# 在公网实例中配置加入/剪枝报文的最大长度为1500字节。
[Sysname] pim
[Sysname-pim] jp-pkt-size 1500
1.1.26  pim
pim命令用来进入PIM视图。
undo pim命令用来清除PIM视图下的所有配置。
undo pim [ vpn-instance vpn-instance-name ]
# 先使能公网实例中的IP组播路由,再进入公网实例的PIM视图。
[Sysname] multicast routing
[Sysname-mrib] quit
[Sysname] pim
[Sysname-pim]
# 先使能VPN实例mvpn中的IP组播路由,再进入该VPN实例的PIM视图。
[Sysname-mrib-mvpn] quit
[Sysname] pim vpn-instance mvpn
[Sysname-pim-mvpn]
pim bfd enable命令用来开启PIM与BFD联动功能。
undo pim bfd enable命令用来关闭PIM与BFD联动功能。
pim bfd enable
undo pim bfd enable
PIM与BFD联动功能处于关闭状态。
只有在接口上先使能了PIM-DM或PIM-SM,本命令才能生效。
# 使能公网实例中的IP组播路由,在接口GigabitEthernet3/1/1上使能PIM-DM,并开启PIM与BFD联动功能。
[Sysname-mrib] quit
[Sysname] interface gigabitethernet 3/1/1
[Sysname-GigabitEthernet3/1/1] pim dm
[Sysname-GigabitEthernet3/1/1] pim bfd enable
·     pim dm
·     pim sm
pim bsr-boundary命令用来配置BSR的服务边界,即PIM-SM域的边界。
undo pim bsr-boundary命令用来恢复缺省情况。
pim bsr-boundary
不存在BSR的服务边界。
# 配置接口GigabitEthernet3/1/1为BSR的服务边界。
[Sysname-GigabitEthernet3/1/1] pim bsr-boundary
·     c-bsr (PIM view)
·     multicast boundary(IP组播命令参考/组播路由与转发)
1.1.29  pim dm
pim dm命令用来使能PIM-DM。
undo pim dm命令用来关闭PIM-DM。
pim dm
undo pim dm
PIM-DM处于关闭状态。
只有在相应实例中先使能了IP组播路由,本命令才能生效。
# 使能公网实例中的IP组播路由,并在接口GigabitEthernet3/1/1上使能PIM-DM。
[Sysname-mrib] quit
·     multicast routing(IP组播命令参考/组播路由与转发)
pim hello-option dr-priority命令用来在接口上配置竞选DR的优先级。
undo pim hello-option dr-priority命令用来恢复缺省情况。
pim hello-option dr-priority priority
竞选DR的优先级为1。
# 在接口GigabitEthernet3/1/1上配置竞选DR的优先级为3。
[Sysname-GigabitEthernet3/1/1] pim hello-option dr-priority 3
·     hello-option dr-priority (PIM view)
pim hello-option holdtime命令用来在接口上配置保持PIM邻居的可达状态的时间。
undo pim hello-option holdtime命令用来恢复缺省情况。
pim hello-option holdtime time
time:指定保持PIM邻居可达状态的时间,取值范围为1~65535,单位为秒。如果指定为65535秒,则表示PIM邻居永远可达。
# 在接口GigabitEthernet3/1/1上配置保持PIM邻居可达状态的时间为120秒。
[Sysname-GigabitEthernet3/1/1] pim hello-option holdtime 120
·     hello-option holdtime (PIM view)
pim hello-option lan-delay命令用来在接口上配置PIM报文在共享网段中的传输延迟。
undo pim hello-option lan-delay命令用来恢复缺省情况。
pim hello-option lan-delay delay
# 在接口GigabitEthernet3/1/1上配置PIM报文在共享网段中的传输延迟为200毫秒。
[Sysname-GigabitEthernet3/1/1] pim hello-option lan-delay 200
pim hello-option neighbor-tracking命令用来在接口上开启邻居跟踪功能。
pim hello-option neighbor-tracking disable命令用来在全局开启了邻居跟踪功能的情况下,关闭接口上的邻居跟踪功能。
undo pim hello-option neighbor-tracking命令用来取消接口上的邻居跟踪功能配置,使得接口与全局配置保持一致。
接口上的邻居跟踪功能处于关闭状态。
# 在接口GigabitEthernet3/1/1上开启邻居跟踪功能。
[Sysname-GigabitEthernet3/1/1] pim hello-option neighbor-tracking
# 在公网实例全局开启了邻居跟踪功能的情况下,关闭接口GigabitEthernet3/1/1上的邻居跟踪功能。
[Sysname] pim
[Sysname-pim] quit
[Sysname-GigabitEthernet3/1/1] pim hello-option neighbor-tracking disable
·     hello-option neighbor-tracking (PIM view)
pim hello-option override-interval命令用来在接口上配置剪枝否决时间。
undo pim hello-option override-interval命令用来恢复缺省情况。
pim hello-option override-interval interval
剪枝否决时间为2500毫秒。
interval:指定剪枝的否决时间,取值范围为1~65535,单位为毫秒。
# 在接口GigabitEthernet3/1/1上配置剪枝否决时间为2000毫秒。
[Sysname-GigabitEthernet3/1/1] pim hello-option override-interval 2000
pim holdtime join-prune命令用来在接口上配置加入/剪枝状态的保持时间。
undo pim holdtime join-prune命令用来恢复缺省情况。
pim holdtime join-prune time
加入/剪枝状态的保持时间为210秒。
# 在接口GigabitEthernet3/1/1上配置加入/剪枝状态的保持时间为280秒。
[Sysname-GigabitEthernet3/1/1] pim holdtime join-prune 280
·     holdtime join-prune (PIM view)
·     pim timer join-prune
pim join-policy命令用来在接口上配置PIM加入/剪枝报文中加入信息的过滤规则。
undo pim join-policy命令用来恢复缺省情况。
pim join-policy { ipv4-acl-number | [ asm ipv4-acl-number | ssm ipv4-acl-number ] * }
不过滤PIM加入/剪枝报文中的加入信息。
ipv4-acl-number:指定IPv4基本或高级ACL的编号,其中基本IPv4 ACL的取值范围为2000~2999,高级IPv4 ACL的取值范围为3000~3999。当指定的ACL不存在或ACL中未配置有效规则,则过滤掉所有的加入信息。
asm ipv4-acl-number:过滤组地址在ASM范围内的加入信息,取值范围为2000~3999。如果未指定本参数、指定的ACL不存在或ACL中未配置有效规则,则过滤掉ASM范围内所有的加入信息。
ssm ipv4-acl-number:过滤组地址在SSM范围内的加入信息,取值范围为2000~3999。如果未指定本参数、指定的ACL不存在或ACL中未配置有效规则,则过滤掉SSM范围内所有的加入信息。
此命令对PIM-DM不生效。
为了防止设备受到非法PIM加入/剪枝报文攻击,通过本命令可以配置过滤规则,限制PIM加入/剪枝报文中加入信息的合法源地址范围和组地址范围,丢弃不合法的加入信息,不建立对应的(*,G)或(S,G)表项。
对于IPv4基本ACL,该ACL规则中的source参数用来指定PIM加入/剪枝报文中加入信息的组播组地址范围,并且该规则中除sourcefragmenttime-range以外的其它可选参数都将被忽略。
对于IPv4高级ACL,该ACL规则中的source参数用来指定PIM加入/剪枝报文中加入信息的组播源地址范围(对于(*,G)信息,其组播源地址为0.0.0.0),destination参数用来指定加入信息的组播组地址范围,并且该规则中除sourcedestinationfragmenttime-range以外的其它可选参数都将被忽略。
# 在接口GigabitEthernet3/1/1上配置过滤规则,只允许接收组地址范围是225.1.1.1/16的加入信息。
[Sysname] acl basic 2005
[Sysname-acl-ipv4-basic-2005] rule permit source 225.1.1.1 0.0.255.255
[Sysname-acl-ipv4-basic-2005] quit
[Sysname-GigabitEthernet3/1/1] pim join-policy 2005
pim neighbor-policy命令用来配置合法Hello报文的源地址范围。
undo pim neighbor-policy命令用来恢复缺省情况。
pim neighbor-policy ipv4-acl-number
Hello报文的源地址范围不受限制,即认为所有收到的Hello报文都是合法的。
配置合法Hello报文的源地址范围可以防止Hello报文欺骗。
该ACL规则中的source参数用来指定合法Hello报文的源地址范围,并且该规则中除sourcefragmenttime-range以外的其它可选参数都将被忽略。
# 在接口GigabitEthernet3/1/1上配置合法Hello报文的源地址范围,只允许与来自网段10.1.1.0/24中的设备建立PIM邻居关系。
[Sysname-GigabitEthernet3/1/1] pim neighbor-policy 2000
pim non-stop-routing命令用来开启PIM协议的NSR功能。
undo pim non-stop-routing命令用来关闭PIM协议的NSR功能。
PIM协议的NSR功能处于关闭状态。
# 开启PIM协议的NSR功能。
[Sysname] pim non-stop-routing
1.1.39  pim passive
pim passive命令用来在接口上开启PIM消极模式。
undo pim passive命令用来在接口上关闭PIM消极模式。
pim passive
undo pim passive
接口上的PIM消极模式处于关闭状态。
# 使能公网实例中的IP组播路由,在接口GigabitEthernet3/1/1上使能PIM-DM,并开启PIM消极模式。
[Sysname-mrib] quit
[Sysname-GigabitEthernet3/1/1] pim passive
pim require-genid命令用来配置拒绝无Generation ID的Hello报文。
undo pim require-genid命令用来恢复缺省情况。
pim require-genid
接受无Generation ID的Hello报文。
# 配置接口GigabitEthernet3/1/1拒绝无Generation ID的Hello报文。
[Sysname-GigabitEthernet3/1/1] pim require-genid
1.1.41  pim sm
pim sm命令用来使能PIM-SM。
undo pim sm命令用来关闭PIM-SM。
pim sm
undo pim sm
PIM-SM处于关闭状态。
# 使能公网实例中的IP组播路由,并在接口GigabitEthernet3/1/1上使能PIM-SM。
[Sysname-mrib] quit
[Sysname-GigabitEthernet3/1/1] pim sm
pim state-refresh-capable命令用来开启状态刷新能力。
undo pim state-refresh-capable命令用来关闭状态刷新能力。
状态刷新能力处于开启状态。
# 在接口GigabitEthernet3/1/1上关闭状态刷新能力。
[Sysname-GigabitEthernet3/1/1] undo pim state-refresh-capable
·     state-refresh-interval (PIM view)
·     state-refresh-rate-limit (PIM view)
·     state-refresh-ttl (PIM view)
pim timer graft-retry命令用来配置嫁接报文的重传时间。
undo pim timer graft-retry命令用来恢复缺省情况。
pim timer graft-retry interval
嫁接报文的重传时间为3秒。
interval:指定嫁接报文的重传时间,取值范围为1~65535,单位为秒。
# 在接口GigabitEthernet3/1/1上配置嫁接报文的重传时间为80秒。
[Sysname-GigabitEthernet3/1/1] pim timer graft-retry 80
pim timer hello命令用来在接口上配置发送Hello报文的时间间隔。
undo pim timer hello命令用来恢复缺省情况。
pim timer hello interval
发送Hello报文的时间间隔为30秒。
interval:指定发送Hello报文的时间间隔,取值范围为0~18000,单位为秒。0表示无穷大,即永不发送Hello报文。
# 在接口GigabitEthernet3/1/1上配置发送Hello报文的时间间隔为40秒。
[Sysname-GigabitEthernet3/1/1] pim timer hello 40
·     timer hello (PIM view)
pim timer join-prune命令用来在接口上配置发送加入/剪枝报文的时间间隔。
undo pim timer join-prune命令用来恢复缺省情况。
pim timer join-prune interval
发送加入/剪枝报文的时间间隔为60秒。
interval:指定发送加入/剪枝报文的时间间隔,取值范围为0~18000,单位为秒。0表示无穷大,即永不发送加入/剪枝报文。
本命令不会立即生效,新配置的发送间隔将在当前发送间隔完成后生效。
# 在接口GigabitEthernet3/1/1上配置发送加入/剪枝报文的时间间隔为80秒。
[Sysname-GigabitEthernet3/1/1] pim timer join-prune 80
pim triggered-hello-delay命令用来配置触发Hello报文的最大延迟时间。
undo pim triggered-hello-delay命令用来恢复缺省情况。
pim triggered-hello-delay delay
触发Hello报文的最大延迟时间为5秒。
delay:指定触发Hello报文的最大延迟时间,取值范围为1~60,单位为秒。
# 在接口GigabitEthernet3/1/1上配置触发Hello报文的最大延迟时间为3秒。
[Sysname-GigabitEthernet3/1/1] pim triggered-hello-delay 3
register-policy命令用来配置注册报文的过滤策略。
undo register-policy命令用来恢复缺省情况。
register-policy ipv4-acl-number
不存在注册报文的过滤策略,所有注册报文都是合法的。
PIM视图
该ACL规则中的source参数用来指定注册报文中的组播源地址范围,destination参数用来指定组播组地址范围,并且该规则中除sourcedestinationfragmenttime-range以外的其它可选参数都将被忽略。
# 在公网实例中配置RP上对注册报文的过滤策略,只接收来自10.10.0.0/16网段的组播源发向225.1.0.0/16网段的组播组的注册报文。
[Sysname-acl-ipv4-adv-3000] rule permit ip source 10.10.0.0 0.0.255.255 destination 225.1.0.0 0.0.255.255
[Sysname] pim
[Sysname-pim] register-policy 3000
register-suppression-timeout命令用来配置注册抑制时间。
undo register-suppression-timeout命令用来恢复缺省情况。
注册抑制时间为60秒。
PIM视图
interval:指定注册抑制时间,取值范围为1~65535,单位为秒。
# 在公网实例中配置注册抑制时间为70秒。
[Sysname] pim
[Sysname-pim] register-suppression-timeout 70
register-whole-checksum命令用来配置根据注册报文的全部内容来计算校验和。
undo register-whole-checksum命令用来恢复缺省情况。
仅根据注册报文头来计算校验和。
PIM视图
# 在公网实例中配置根据注册报文的全部内容来计算校验和。
[Sysname] pim
[Sysname-pim] register-whole-checksum
snmp-agent trap enable pim命令用来开启PIM的告警功能。
undo snmp-agent trap enable pim命令用来关闭PIM的告警功能。
snmp-agent trap enable pim [ candidate-bsr-win-election | elected-bsr-lost-election | neighbor-loss ] *
undo snmp-agent trap enable pim [ candidate-bsr-win-election | elected-bsr-lost-election | neighbor-loss ] *
PIM的告警功能处于开启状态。
candidate-bsr-win-election:表示C-BSR成功当选BSR的告警信息。
elected-bsr-lost-election:表示原BSR在新的选举中失败的告警信息。
neighbor-loss:表示邻居丢失的告警信息。
如果未指定可选参数,表示开启或关闭PIM的全部告警功能。
开启了PIM的告警功能之后,PIM会生成告警信息,以向网管软件报告本模块的重要事件。该信息将发送至SNMP模块,通过设置SNMP中告警信息的发送参数,来决定告警信息输出的相关属性。有关告警信息的详细介绍,请参见“网络管理和监控配置指导”中的“SNMP”。
# 关闭PIM的全部告警功能。
[Sysname] undo snmp-agent trap enable pim
source-lifetime命令用来配置组播源的生存时间。
undo source-lifetime命令用来恢复缺省情况。
source-lifetime time
组播源的生存时间为210秒。
PIM视图
time:指定组播源的生存时间,取值范围为0~31536000,单位为秒。0表示无穷大,即组播源永不老化。
# 在公网实例中配置组播源的生存时间为200秒。
[Sysname] pim
[Sysname-pim] source-lifetime 200
source-policy命令用来配置组播数据过滤器。
undo source-policy命令用来恢复缺省情况。
source-policy ipv4-acl-number
undo source-policy
不存在组播数据过滤器,不对组播数据进行过滤。
PIM视图
ipv4-acl-number:指定IPv4基本或高级ACL的编号,取值范围为2000~3999。
对于IPv4基本ACL,该ACL规则中的source参数用来指定组播数据报文的源地址范围,并且该规则中除sourcefragmenttime-range以外的其它可选参数都将被忽略。
对于IPv4高级ACL,该ACL规则中的source参数用来指定组播数据报文中的组播源地址范围,destination参数用来指定组播组地址范围,并且该规则中除sourcedestinationfragmenttime-range以外的其它可选参数都将被忽略。
# 在公网实例中配置接收组播源为10.10.1.2的组播数据,丢弃组播源为10.10.1.1的组播数据。
[Sysname-acl-ipv4-basic-2000] rule permit source 10.10.1.2 0
[Sysname-acl-ipv4-basic-2000] rule deny source 10.10.1.1 0
[Sysname] pim
[Sysname-pim] source-policy 2000
spt-switch-threshold命令用来配置发起SPT切换的条件。
undo spt-switch-threshold命令用来删除指定的发起SPT切换的条件。
spt-switch-threshold { immediacy | infinity } [ group-policy ipv4-acl-number ]
undo spt-switch-threshold [ immediacy | infinity ] [ group-policy ipv4-acl-number ]
设备收到第一个组播数据包后便立即向SPT切换。
PIM视图
immediacy:表示立即发起SPT切换。
infinity:表示永不发起SPT切换。
group-policy ipv4-acl-number:表示组策略列表中的一项,与该组策略匹配的组播组将应用本配置。ipv4-acl-number表示IPv4基本ACL的编号,取值范围为2000~2999。如果未指定本参数、指定的ACL不存在或ACL中未配置有效规则,则本配置将应用于所有组播组。
该ACL规则中的source参数用来指定组播组地址范围,并且该规则中除sourcefragmenttime-range以外的其它可选参数都将被忽略。
由于组播源侧DR在创建组播路由表项后,无法继续将组播报文封装在注册报文中发给RP,因此在可能成为RP的设备上仅支持配置立即发起SPT切换,否则会导致组播报文转发失败。
# 在接收者侧DR的公网实例中配置永不发起SPT切换。
[Sysname] pim
[Sysname-pim] spt-switch-threshold infinity
ssm-policy命令用来配置SSM组播组的范围。
undo ssm-policy命令用来恢复缺省情况。
ssm-policy ipv4-acl-number
undo ssm-policy
SSM组播组的范围为232.0.0.0/8。
PIM视图
ipv4-acl-number:指定基本ACL的编号,取值范围为2000~2999。
通过本命令可以定义允许或拒绝的组播组的地址范围:如果匹配通过,则组播运行模式为PIM-SSM,否则为PIM-SM。
该ACL规则中的source参数用来指定SSM组播组范围,并且该规则中除sourcefragmenttime-range以外的其它可选参数都将被忽略。
# 配置SSM组播组的范围232.1.0.0/16。
[Sysname-acl-ipv4-basic-2000] rule permit source 232.1.0.0 0.0.255.255
[Sysname] pim
[Sysname-pim] ssm-policy 2000
state-refresh-interval命令用来配置发送状态刷新报文的时间间隔。
undo state-refresh-interval命令用来恢复缺省情况。
发送状态刷新报文的时间间隔为60秒。
PIM视图
interval:指定发送状态刷新报文的时间间隔,取值范围为1~255,单位为秒。
# 在公网实例中配置发送状态刷新报文的时间间隔为70秒。
[Sysname] pim
[Sysname-pim] state-refresh-interval 70
·     pim state-refresh-capable
state-refresh-rate-limit命令用来配置接收新状态刷新报文的等待时间。
undo state-refresh-rate-limit命令用来恢复缺省情况。
state-refresh-rate-limit time
接收新状态刷新报文的等待时间为30秒。
PIM视图
time:指定接收新状态刷新报文的等待时间,取值范围为1~65535,单位为秒。
# 在公网实例中配置接收新状态刷新报文的等待时间为45秒。
[Sysname] pim
[Sysname-pim] state-refresh-rate-limit 45
state-refresh-ttl命令用来配置状态刷新报文的TTL值。
undo state-refresh-ttl命令用来恢复缺省情况。
state-refresh-ttl ttl-value
状态刷新报文的TTL值为255。
PIM视图
ttl-value:指定状态刷新报文的TTL值,取值范围为1~255。
# 在公网实例中配置状态刷新报文的TTL值为45。
[Sysname] pim
[Sysname-pim] state-refresh-ttl 45
static-rp命令用来配置静态RP。
undo static-rp命令用来删除静态RP。
static-rp rp-address [ ipv4-acl-number | preferred ] *
undo static-rp rp-address
不存在静态RP。
PIM视图
rp-address:指定静态RP的IP地址。该地址必须是实际存在且合法的单播IP地址,不能配置为127.0.0.0/8网段的地址。
ipv4-acl-number:指定IPv4基本ACL的编号,取值范围为2000~2999。如果指定了本参数,该静态RP将只为能够通过该过滤规则的组播组服务;如果未指定本参数、指定的ACL不存在或ACL中未配置有效规则,则该静态RP将为所有组播组服务。
preferred:表示当网络中同时存在动态RP和静态RP时,优先选择静态RP,只有当静态RP失效时,动态RP才能生效。如果未指定本参数,则表示优先选择动态RP,只有当未配置动态RP或动态RP失效时,静态RP才能生效。
作为静态RP的接口不必使能PIM。
该ACL规则中的source参数用来指定静态RP所服务的组播组范围,并且该规则中除sourcefragmenttime-range以外的其它可选参数都将被忽略。
当某个静态RP引用的ACL规则发生变化时,需要为所有组播组重新选举RP。
多次执行本命令,可以配置多个静态RP。但是,如果配置时所指定的静态RP地址或ACL规则相同,则最后一次执行的命令生效;如果存在多个静态RP服务于同一组播组的情况,则选择IP地址最大的静态RP为该组服务。
# 在公网实例中配置IP地址为11.110.0.6的接口为静态RP,为组播组225.1.1.0/24提供服务,并优先选择静态RP。
[Sysname] acl basic 2001
[Sysname-acl-ipv4-basic-2001] rule permit source 225.1.1.0 0.0.0.255
[Sysname] pim
[Sysname-pim] static-rp 11.110.0.6 2001 preferred
timer hello命令用来全局配置发送Hello报文的时间间隔。
undo timer hello命令用来恢复缺省情况。
undo timer hello
发送Hello报文的时间间隔为30秒。
PIM视图
# 在公网实例中全局配置发送Hello报文的时间间隔为40秒。
[Sysname] pim
[Sysname-pim] timer hello 40
·     pim timer hello
timer join-prune命令用来全局配置发送加入/剪枝报文的时间间隔。
undo timer join-prune命令用来恢复缺省情况。
发送加入/剪枝报文的时间间隔为60秒。
PIM视图
# 在公网实例中全局配置发送加入/剪枝报文的时间间隔为80秒。
[Sysname] pim
[Sysname-pim] timer join-prune 80
