06-第6章-硬件管理和维护
本章节下载: 06-第6章-硬件管理和维护 (261.52 KB)
本章将为您介绍如何通过命令行,对S7000系列交换机的硬件进行配置、管理及维护。具体包括如下内容:
· 对于设备不同的软件版本,命令行及显示信息可能存在差异,请以设备的实际情况为准。关于命令行及显示信息的详细介绍,请参见软件版本对应的命令参考手册。
· 本章节中的单板型号指的是单板上的丝印。如果单板丝印为LSQ*,则该单板的对外型号为LSQM*,比如单板丝印为LSQ1SRPA8,则该单板的对外型号为LSQM1SRPA8。
通过执行display version命令,可查看到交换机软件及硬件版本信息。包括:系统当前运行软件及硬件的版本、设备的运行时间、各主控板及业务板的类型及运行时间等相关信息(本命令的显示信息与设备型号及软硬件版本有关,请以设备的实际情况为准)。
<Sysname> display version
H3C Comware Platform Software
Comware Software, Version 5.20, Release 7708P05
Copyright (c) 2004-2013 Hangzhou H3C Tech. Co., Ltd. All rights reserved.
H3C S7006 uptime is 0 week, 0 day, 6 hours, 57 minutes
MPU(M) 0:
Uptime is 0 weeks,0 days,6 hours,57 minutes
H3C S7006 MPU(M) with 1 BCM1125H Processor
BOARD TYPE: LSQ1SRPA8
DRAM: 512M bytes
FLASH: 64M bytes
NVRAM: 512K bytes
PCB 1 Version: VER.B
PCB 2 Version: VER.B
Bootrom Version: 300
CPLD 1 Version: 006
CPLD 2 Version: 006
Release Version: H3C S7006-7708P05
Patch Version : None
MPU(S) 1:
Uptime is 0 weeks,0 days,1 hours,23 minutes
H3C S7006 MPU(S) with 1 BCM1125H Processor
DRAM: 512M bytes
FLASH: 64M bytes
NVRAM: 512K bytes
Bootrom Version: 210
CPLD 1 Version: 006
CPLD 2 Version: 006
LPU 2:
Uptime is 0 weeks,0 days,6 hours,55 minutes
H3C S7006 LPU with 1 BCM1122 Processor
BOARD TYPE: LSQ1GT48SA8
DRAM: 512M bytes
FLASH: 0M bytes
NVRAM: 0K bytes
PCB 1 Version: VER.C
Bootrom Version: 205
CPLD 1 Version: 003
Slot 3 Without Board
Slot 4 Without Board
LPU 5:
Uptime is 0 weeks,0 days,6 hours,56 minutes
DRAM: 256M bytes
FLASH: 0M bytes
NVRAM: 0K bytes
Bootrom Version: 203
CPLD 1 Version: 002
CPLD 2 Version: 002
LPU 6:
DRAM: 512M bytes
FLASH: 0M bytes
NVRAM: 0K bytes
PCB 1 Version: NA
CPLD 1 Version: NA
LPU 7:
Uptime is 0 weeks,0 days,1 hours,25 minutes
DRAM: 512M bytes
FLASH: 0M bytes
NVRAM: 0K bytes
PCB 1 Version: NA
CPLD 1 Version: NA
表6-1 display version命令显示信息描述表
字段显示信息描述 |
H3C Comware Platform Software |
交换机软件的运行平台 |
Comware Software, Version 5.20, Release 7708P05 |
交换机软件的版本号:Version 5.20为平台版本号、Release 7708P05为产品版本号 |
Copyright (c) 2004-2013 Hangzhou H3C Tech. Co., Ltd. All rights reserved. |
交换机的版权信息 |
H3C S7006 uptime is 0 week, 0 day, 6 hours, 57 minutes |
交换机本次开机后已运行时间 |
MPU(M) 1: |
单板类型及单板所在槽位号: · MPU(M)为主用主控板 · MPU(S)为备用主控板 · LPU为业务板 |
Uptime is 0 weeks,0 days,1 hours,23 minutes |
交换机本次开机后,单板已运行时间 |
H3C S7006 MPU(M) with 1 BCM1125H Processor |
单板采用的CPU型号 |
BOARD TYPE: |
单板型号 |
DRAM: |
单板内存容量 |
FLASH: |
单板Flash容量 |
NVRAM: |
单板NVRAM(Nonvolatile Random-Access Memory,非易失性随机存取存储器)容量 |
PCB 1 Version: |
单板上1号PCB(Printed Circuit Board,印刷电路板)的版本 |
Bootrom Version: |
单板Bootrom的版本 |
CPLD 1 Version: |
单板上1号CPLD(Complex Programmable Logical Device,复杂可编程逻辑器件)的版本 |
Release Version: |
单板运行的软件版本号 |
Patch Version: |
单板运行的热补丁版本号 |
在日常维护或系统出现故障时,为了便于定位问题,需要查看各个功能模块的运行信息。在一般情况下,需要逐条运行相应的display命令。为便于一次性收集更多信息,您可以在任意视图下执行display diagnostic-information命令,显示或保存系统当前多个功能模块运行的统计信息。该命令一次性收集的信息等效于依次执行display clock、display version、display device、display current-configuration等命令后终端显示的信息。
· 将当前各个功能模块运行的统计信息保存到指定文件中。
Save or display diagnostic information (Y=save, N=display)? [Y/N]:y
Please input the file name(*.diag)[flash:/default.diag]:aa.diag
Diagnostic information is outputting to flash:/aa.diag.
Please wait...
Save succeeded.
在用户视图下执行“more aa.diag”命令,配合使用<Page Up>/<Page Down>键,可以查看aa.diag文件的记录的内容。
· 直接显示当前各功能模块运行的统计信息(显示信息多且与设备型号有关,请以设备的实际情况为准,此处略)。
08:54:16 UTC Fri 11/15/2012
……略……
通过执行display device verbose命令,可查看设备各槽位上单板的详细信息。包括:单板型号,运行状态、补丁状态,软件版本,PCB、FPGA、BootRom、CPLD等硬件的版本等。
<Sysname> display device verbose
Slot No. Brd Type Brd Status Subslot Num Sft Ver Patch Ver
0 LSQ1SRPA8 Master 0 S7000-7708P05 None
1 LSQ1SRPA8 Slave 0 S7000-7708P05 None
2 LSQ1GT48SA8 Normal 0 S7000-7708P05 None
3 LSQ1GT48SA8 Normal 0 S7000-7708P05 None
4 LSQ1GT48SA8 Normal 1 S7000-7708P05 None
5 LSQ1GT48SA8 Normal 0 S7000-7708P05 None
6 LSQ1GT48SA8 Normal 0 S7000-7708P05 None
7 LSQ1GT48SA8 Normal 0 S7000-7708P05 None
Slot 0 info:
Status : Master
Type : LSQ1SRPA8
Software Ver : S7000-7708P05
PCB 1 Ver : VER.B
PCB 2 Ver : VER.B
FPGA Ver : 001
BootRom Ver : 300
CPLD 1 Ver : 006
CPLD 2 Ver : 006
Slot 1 info:
Status : Slave
Type : LSQ1SRPA8
PCB 1 Ver : VER.B
PCB 2 Ver : VER.B
FPGA Ver : 001
BootRom Ver : 210
CPLD 1 Ver : 006
CPLD 2 Ver : 006
Slot 2 info:
Status : Normal
Type : LSQ1GT48SA8
PCB 1 Ver : VER.C
FPGA Ver : 001
BootRom Ver : 205
CPLD 1 Ver : 003
Chip : 0
Learning Mode: IVL
Chip : 1
Learning Mode: IVL
Slot 3 info:
Status : Normal
Type : LSQ1GT48SA8
PCB 1 Ver : VER.A
FPGA Ver : 001
Bootware Ver : 301
CPLD 1 Ver : 001
Chip : 0
Learning Mode: IVL
Slot 4 info:
Status : Normal
Type : LSQ1GT48SA8
PCB 1 Ver : VER.B
FPGA Ver : 001
BootRom Ver : 203
CPLD 1 Ver : 002
CPLD 2 Ver : 002
Chip : 0
Learning Mode: IVL
Slot 5 info:
Status : Normal
Type : LSQ1GT48SA8
PCB 1 Ver : VER.0
FPGA Ver : 001
BootRom Ver : 205
CPLD 1 Ver : 006
Chip : 0
Learning Mode: IVL
Slot 6 info:
Status : Normal
Type : LSQ1GT48SA8
PCB 1 Ver : VER.0
FPGA Ver : 001
BootRom Ver : 205
CPLD 1 Ver : 006
Chip : 0
Learning Mode: IVL
Slot 7 info:
Status : Normal
Type : LSQ1GT48SA8
PCB 1 Ver : VER.0
FPGA Ver : 001
BootRom Ver : 205
CPLD 1 Ver : 006
Chip : 0
Learning Mode: IVL
通过执行display device slot slot-number命令,可查看设备指定槽位上单板的详细信息。包括:单板型号、运行状态、软件版本、PCB、FPGA、BootRom、CPLD等硬件的版本等。
<Sysname> display device slot 0
Slot 0 info:
Status : Master
Type : LSQ1SRPA8
PCB 1 Ver : VER.B
PCB 2 Ver : VER.B
FPGA Ver : 001
BootRom Ver : 300
CPLD 1 Ver : 006
CPLD 2 Ver : 006
表6-2 display device命令显示信息描述表
字段显示信息描述 |
Slot No. |
单板的槽位号 |
Brd Type/Type |
单板型号,显示为NONE时表示该槽位中没有插入单板 |
Brd Status/Status |
单板运行状态: · Master表示该槽位单板是主用主控板 · Slave表示该槽位单板是备用主控板 · Absent表示该槽位没有插入单板 · Fault表示该槽位单板正在启动过程中或单板发生故障,不能正常启动 · Normal表示该槽位单板是业务板,该业务板处于正常工作状态 |
Subslot Num |
单板支持子卡的最大数量 |
Sft Ver/ Software Ver |
当前单板上运行的软件版本 |
Patch Ver |
当前单板上运行的热补丁版本,显示为NONE时表示该槽位中单板没有安装热补丁 |
PCB 1 Ver |
单板上1号PCB的版本 |
FPGA Ver |
单板FPGA(Field Programmable Gate Array,现场可编程门阵列)的版本 |
BootRom Ver |
单板BootRom的版本 |
CPLD 1 Ver |
单板上1号CPLD的版本 |
Chip |
单板芯片的编号 |
Learning Mode |
单板MAC地址的学习模式,分为: · IVL(Independant VLAN Learning):独立VLAN学习 · SVL(Shared VLAN Learning):共享VLAN学习 |
通过执行display device manuinfo命令,可查看到设备各槽位上单板的电子标签信息。
电子标签信息也叫做永久配置数据或档案信息等,包括单板的名称、生产序列号、MAC地址、制造商等信息。
<Sysname> display device manuinfo
Slot 0:
DEVICE_NAME : LSQ1SRPA8
DEVICE_SERIAL_NUMBER : 210231A73JB098000078
MAC_ADDRESS : 0023-895F-958B
MANUFACTURING_DATE : 2009-8-24
VENDOR_NAME : H3C
Slot 1:
DEVICE_SERIAL_NUMBER : 210231A73JB098000070
MAC_ADDRESS : 0023-895F-954F
VENDOR_NAME : H3C
Slot 2:
DEVICE_NAME : LSQ1GT48SA8
DEVICE_SERIAL_NUMBER : 210231A76HB095000082
MAC_ADDRESS : NONE
MANUFACTURING_DATE : 2009-10-15
VENDOR_NAME : H3C
Slot 3:
DEVICE_SERIAL_NUMBER : 210231A0EAX103000002
MAC_ADDRESS : NONE
MANUFACTURING_DATE : 2010-03-11
VENDOR_NAME : H3C
Slot 4:
DEVICE_SERIAL_NUMBER : 03A43E1111111111
MAC_ADDRESS : NONE
MANUFACTURING_DATE : 2007-11-4
VENDOR_NAME : H3C
Slot 5:
The operation is not supported on the specified board or subslot.
Slot 6:
Slot 7:
通过执行display device manuinfo slot slot-number命令,可查看到设备指定槽位上单板的电子标签信息。
<Sysname> display device manuinfo slot 0
Slot 0:
VENDOR_NAME : H3C
表6-3 display device manuinfo命令信息显示描述表
字段显示信息描述 |
DEVICE_NAME |
单板型号 |
DEVICE_SERIAL_NUMBER |
单板序列号 |
MAC_ADDRESS |
单板的MAC地址 · 主控板都有MAC地址 · 业务板均无MAC地址(显示为NONE) |
MANUFACTURING_DATE |
单板生产日期 |
VENDOR_NAME |
制造商名称 |
The operation is not supported on the specified board or subslot |
该单板为通过主控板虚拟出的业务板,不支持通过display device manuinfo查看单板的电子标签信息 |
通过执行display cpu-usage命令,可查看设备各槽位上单板CPU利用率的统计信息。
<Sysname> display cpu-usage
Slot 0 CPU usage:
2% in last 5 seconds
1% in last 1 minute
1% in last 5 minutes
Slot 1 CPU usage:
1% in last 5 seconds
1% in last 1 minute
Slot 2 CPU usage:
3% in last 5 seconds
2% in last 1 minute
2% in last 5 minutes
Slot 3 CPU usage:
2% in last 1 minute
Slot 4 CPU usage:
2% in last 1 minute
Slot 5 CPU usage:
2% in last 1 minute
Slot 6 CPU usage:
2% in last 1 minute
Slot 7 CPU usage:
2% in last 1 minute
表6-4 display cpu-usage命令显示信息描述表
字段显示信息描述 |
Slot 0 CPU usage |
0号槽位上单板的CPU利用率信息。 如果该槽位单板上有多个CPU:则“Slot 0 CPU usage”表示0号槽位上单板主CPU的利用率;“Slot 0 CPU 1 CPU usage”表示0号槽位上单板辅助CPU的利用率 |
1% in last 5 seconds |
显示最近一个5秒统计周期内CPU的平均利用率(设备启动后,会以5秒为周期计算并记录一次该5秒内的CPU的平均利用率) |
1% in last 1 minute |
显示最近一个1分钟统计周期内CPU的平均利用率(设备启动后,会以1分钟为周期计算并记录一次该1分钟内的CPU的平均利用率) |
1% in last 5 minutes |
显示最近一个5分钟统计周期内CPU的平均利用率(设备启动后,会以5分钟为周期计算并记录一次该5分钟内的CPU的平均利用率) |
通过执行display memory命令,可查看主用主控板内存的使用状况。
<Sysname> display memory
System Total Memory(bytes): 435927120
Total Used Memory(bytes): 100618856
Used Rate: 23%
通过执行display memory slot slot-number命令,可查看指定槽位上单板内存的使用状况。
<Sysname> display memory slot 0
System Total Memory(bytes): 435562480
Total Used Memory(bytes): 103701596
Used Rate: 23%
表6-5 display memory命令显示信息描述表
System Total Memory(bytes) |
该单板物理内存容量,单位为字节 |
Total Used Memory(bytes) |
该单板中已经使用的内存大小,单位为字节 |
Used Rate |
该单板中已经使用的内存占物理内存的比例 |
通过执行display fan命令,可查看设备内置风扇的工作状态。
<Sysname> display fan
Fan 1 State: Normal
表6-6 display fan命令显示信息描述表
Fan 1 |
风扇编号 |
State |
风扇状态: · Normal表示风扇工作正常 · Absent表示风扇不在位 · Fault表示风扇出现故障 |
通过执行display power命令,可查看设备电源的工作状态。
<Sysname> display power
Power 1 State: Normal
Power 2 State: Absent
表6-7 display power命令显示信息描述表
Power 1 |
电源编号 |
State |
电源状态: · Normal表示电源工作正常 · Absent表示电源不在位 · Fault表示电源出现故障 |
S7006交换机支持负载分担功能。当交换机中安装有两块主控板时,对于从某块业务板上接收到的需要进行跨板转发的流量,主控板的处理方式如下:
· 开启主控板的负载分担功能后,该流量将在主用主控板和备用主控板上进行负载分担。
· 关闭主控板的负载分担功能后,该流量只能通过主用主控板进行转发。
表6-8 开启设备的负载分担功能
进入系统视图 |
system-view |
开启主控板的负载分担功能 |
loadsharing enable |
可选 缺省情况下,主控板负载分担功能处于关闭状态 |
只有单播流量支持负载分担功能。
交换机在运行过程中,如果单板的温度过高或过低,都会影响交换机的正常工作。为了方便对单板温度的管理,您可以通过命令行来设置指定单板的温度告警门限。当单板的温度超出您设定的门限时,系统会发出Trap信息,便于您及时进行处理。
进入系统视图 |
system-view |
配置单板的温度告警门限 |
temperature-limit slot slot-number hotspot sensor-number lowerlimit warninglimit [ alarmlimit ] |
可选 缺省情况下 · 低温告警门限值为0 · Warning高温告警门限值为80 · Alarm高温告警门限值为97 高温告警门限必须大于低温告警门限;Alarm高温告警门限必须大于Warning高温告警门限。 |
查看设备单板的温度信息 |
display environment |
可选 该命令在任意视图下执行 |
Combo口是一个逻辑端口,一个Combo口分别对应单板上的一个SFP口和对应的RJ-45以太网端口。SFP口与对应RJ-45以太网端口均为光电复用关系,两者不能同时使用(当激活其中的一个端口时,另一个端口将自动变为禁用状态),用户可根据组网需求选用SFP口或RJ-45以太网端口。
(1) 执行display port combo命令查看设备上有哪些Combo口,以及每个Combo口是由哪两个端口组成。
[Sysname] display port combo
Combo-group Active Inactive
1 GigabitEthernet2/0/1 GigabitEthernet2/0/5
2 GigabitEthernet2/0/2 GigabitEthernet2/0/6
3 GigabitEthernet2/0/3 GigabitEthernet2/0/7
4 GigabitEthernet2/0/4 GigabitEthernet2/0/8
(2) 执行display interface interface-type interface-number命令查看Combo口的两个端口中,哪一个是SFP口、哪一个是RJ-45以太网端口。
· 如果显示信息中包含“Media type is not sure, Port hardware type is No connector”,则表示该端口为SFP口。如下所示,端口GigabitEthernet 2/0/1为SFP口。
[Sysname] display interface GigabitEthernet 2/0/1
GigabitEthernet2/0/1 current state: DOWN
IP Packet Frame Type: PKTFMT_ETHNT_2, Hardware Address: 0000-fc00-7506
Description: GigabitEthernet2/0/1 Interface
Loopback is not set
Media type is not sure,Port hardware type is No connector
· 如果显示信息中包含“Media type is twisted pair, Port hardware type is 1000_BASE_T”,则表示该端口为RJ-45以太网端口。如下所示,端口GigabitEthernet 2/0/5为RJ-45以太网端口。
[Sysname] display interface GigabitEthernet 2/0/5
GigabitEthernet2/0/5 current state: DOWN ( Administratively )
Description: GigabitEthernet2/0/5 Interface
Loopback is not set
表6-10 配置Combo口
进入系统视图 |
system-view |
进入Combo口的SFP口或RJ-45以太网端口视图 |
激活当前端口,使其成为可用端口 |
undo shutdown |
必选 |
· 组成Combo口的SFP口和对应的RJ-45以太网端口中,同一时刻只有一个可用(只有一个处于active状态,另一个处于inacitve状态)。缺省情况下,编号小的端口处于active状态。
· 如需使用Combo口中处于inactive状态的端口,首先要执行undo shutdown命令激活此端口。该端口激活后,Combo口中原来处于active状态的端口会自动关闭变为inactive状态。
可以通过显示可插拔接口模块的主要特征参数或者电子标签信息来识别可插拔接口模块。
· 可插拔接口模块的主要特征参数,包括模块型号、连接器类型、发送激光的中心波长、信号的有效传输距离、模块生产厂商名称等信息。
· 电子标签信息也可以称为永久配置数据或档案信息等,在模块调测(调试、测试)过程中被写入到存储器件中,包括序列号、调测日期、模块生产厂商名称等信息。
表6-11 识别可插拔接口模块信息
显示可插拔接口模块的主要特征参数 |
display transceiver interface [ interface-type interface-number ] [ | { begin | exclude | include } regular-expression ] |
显示可插拔接口模块的电子标签信息 |
display transceiver manuinfo interface [ interface-type interface-number ] [ | { begin | exclude | include } regular-expression ] |
电子标签信息的显示与可插拔接口模块的支持情况有关。
系统提供故障告警信息标志可插拔接口模块的故障来源,以便诊断和解决故障。同时,还提供了可插拔接口模块的数字诊断功能,其原理主要是对影响光模块工作的关键参数进行监控,这些关键参数包括:温度、电压、激光偏置电流、发送光功率和接收光功率等。当这些参数的值异常时,用户可以采取相应的措施,预防故障发生。
表6-12 诊断可插拔接口模块
显示可插拔接口模块的当前故障告警信息 |
display transceiver alarm interface [ interface-type interface-number ] [ | { begin | exclude | include } regular-expression ] |
显示可插拔接口模块的数字诊断参数的当前测量值 |
display transceiver diagnosis interface [ interface-type interface-number ] [ | { begin | exclude | include } regular-expression ] |
数字诊断参数的显示与可插拔接口模块的支持情况有关。
· 关于可插拔接口模块的详细介绍,请参见《H3C系列交换机 可插拔模块手册》。
· 关于可插拔接口模块相关命令的详细介绍,请参见《H3C S7000系列交换机命令参考》相关章节。
当系统检测到主用主控板或备用主控板软件运行过程中发生异常时(如系统指令异常、非法地址、数据溢出、空指针或除零操作等),可以采用以下两种处理方式:
· reboot:发生异常的主控板将立即重启,重启完成以后,该主控板恢复到正常运行状态。
· maintain:发生异常的主控板将保持当前状态,系统不会自动采取任何恢复措施。某些软件异常可能较难复现,打印出的信息在重启后会丢失,此时,可以使用该方式保持异常时的状态,以便进行问题定位。
表6-13 配置软件异常时的处理方式
进入系统视图 |
system-view |
配置主用主控板和备用主控板软件异常时的处理方式 |
system-failure { maintain | reboot } |
可选 缺省情况下,主用主控板和备用主控板软件异常时的处理方式为reboot |
· 在双主控环境下,主用主控板重启时,将触发主备倒换,原备用主控板倒换为新的主用主控板。
· 在单主控环境下,主控板重启时,将触发整机重起。
· 如果业务板出现软件运行异常的情况,处理方式始终为reboot,即重启故障业务板。
· 系统异常时的处理只针对故障单板,重启过程中不会影响其它单板的运行。
通过执行display system-failure命令,可查看系统异常时的处理方式。
<Sysname> display system-failure
System failure handling method: reboot
· 快速保存方式:执行不带safely参数的save命令。这种方式保存速度快,但是保存过程中如果设备重启或断电,原有配置文件可能会丢失。此方式推荐用于电源稳定程度较好的环境中。
· 安全方式:执行带safely参数的save命令。这种方式保存速度慢,即使保存过程中出现设备重启或断电,原有配置文件仍然会保存到设备中,不会丢失。此方式推荐用于电源环境恶劣或者远程维护等情况下。
表6-14 保存当前配置
将当前配置保存到指定文件,但不将该文件设置为下次启动使用的配置文件 |
save file-url [ all | slot slot-number ] |
二者必选其一 该命令可在任意视图下执行 |
将当前配置保存到主用主控板和备用主控板存储介质的根目录,并将该文件设置为下次启动使用的配置文件 |
save [ safely ] [ force ] |
· 配置文件名后缀必须为“.cfg”。
· 执行save命令时,如果出现设备重启或断电,可能会造成下次启动配置文件丢失,这时,设备将以空配置启动。设备启动后,您需要重新设置下次启动使用的配置文件。
当对设备的启动文件或配置文件进行升级及维护时,需要对设备重启,改变主控板或业务板的工作模式后,需要对相应单板进行重启。您可以使用以下几种方法对设备进行重启:
· 使用命令行reboot命令立即重启设备。
· 使用命令行定时重启设备。在该方式下,您可以设置一个时间点或时延,到达此时间点时,设备将自动进行重启。
· 通过断电并重新上电重启设备(该方式又称为硬件重启或者冷启动)。如果对运行中的设备进行强制断电,可能会造成数据丢失或者硬件损坏。一般情况下,建议不要使用这种方式。
表6-15 通过命令行立即重启设备
立即重启指定单板或整台设备 |
reboot [ slot slot-number ] |
必选 该命令在用户视图下执行 |
表6-16 通过命令行定时重启设备
指定设备重启的时间点,到达此时间点时,设备将自动进行重启 |
schedule reboot at hh:mm [ date ] |
二者必选其一 缺省情况下,设备定时重启功能处于关闭状态 两条命令均在用户视图下执行 |
指定设备重启的时延,延迟指定时间后,设备将自动进行重启 |
schedule reboot delay { hh:mm | mm } |
· 不能使用reboot命令重启备用主控板,如需重启备用主控板,请使用slave restart命令。
· 不指定slot参数时,会重启整个设备(包括主用主控板、备用主控板和业务板)。
· 如果主用启动文件不存在,则不能通过reboot命令重启设备或主用主控板。此时,可以先指定主用启动文件再对该主控板进行重启。
· 设备定时器的精度为1分钟。在到达您设定的重启时刻的前一分钟,设备会提示:“REBOOT IN ONE MINUTE(设备将在一分钟后重启)”,并在一分钟后重新启动。
· 设备在准备重启时,如果有用户正在进行文件操作,为了安全起见,系统将不会执行此次重启操作。
