12-IPv6 PIM Snooping配置
本章节下载: 12-IPv6 PIM Snooping配置 (210.06 KB)
1 IPv6 PIM Snooping························································································································· 1-1
1.1 IPv6 PIM Snooping简介·········································································································· 1-1
1.2 配置IPv6 PIM Snooping·········································································································· 1-2
1.3 IPv6 PIM Snooping显示和维护································································································ 1-3
1.4 IPv6 PIM Snooping典型配置举例····························································································· 1-3
1.5 常见配置错误举例···················································································································· 1-6
1.5.1 路由器不能实现IPv6 PIM Snooping功能········································································· 1-6
1.5.2 部分下游IPv6 PIM路由器无法收到IPv6组播数据····························································· 1-6
设备支持两种运行模式:独立运行模式和IRF模式,缺省情况下为独立运行模式。有关IRF模式的介绍,请参见“IRF配置指导”中的“IRF”。
IPv6 PIM Snooping是IPv6 Protocol Independent Multicast Snooping(IPv6协议无关组播窥探)的简称,运行IPv6 PIM Snooping的二层设备通过对收到的IPv6 PIM协议报文进行分析,将有接收需求的端口添加到相应的IPv6组播转发表项中,以实现IPv6组播报文的精确转发。
图1-1 二层设备运行IPv6 PIM Snooping前后的对比
如图1-1所示,IPv6组播源Source 1和Source 2分别向IPv6组播组G1和G2发送IPv6组播数据,而Receiver 1和Receiver 2则分别是G1和G2的接收者,二层设备上连接各IPv6 PIM路由器的端口都属于同一个VLAN:
· 当二层设备只运行MLD Snooping时,它通过监听IPv6 PIM路由器发出的IPv6 PIM Hello报文来维护路由器端口,并将所有IPv6 组播数据报文向VLAN内的所有路由器端口转发;而对于其它类型的IPv6 PIM协议报文,则在VLAN内广播。因此,无论IPv6 PIM路由器是否有接收需求,都会收到所有的IPv6 PIM协议报文和IPv6组播数据报文。
· 当二层设备同时运行了MLD Snooping和IPv6 PIM Snooping时,它通过监听IPv6 PIM路由器发出的IPv6 PIM协议报文来了解其接收需求,从而将有接收需求的IPv6 PIM路由器所在的端口加入到相应的IPv6组播转发表项中,使IPv6 PIM协议报文和IPv6组播数据报文能够被精确转发给有接收需求的IPv6 PIM路由器,从而节约了网络带宽。
· 有关MLD Snooping和路由器端口的详细介绍,请参见“IP组播配置指导”中的“MLD Snooping”。
· 有关IPv6 PIM的详细介绍,请参见“IP组播配置指导”中的“IPv6 PIM”。
在配置某VLAN内的IPv6 PIM Snooping时,需要在路由器上先全局使能MLD Snooping,然后在该VLAN内使能MLD Snooping和IPv6 PIM Snooping。
进入系统视图 |
system-view |
全局使能MLD Snooping,并进入MLD-Snooping视图 |
mld-snooping |
必选 缺省情况下,MLD Snooping处于关闭状态 |
退回系统视图 |
quit |
进入VLAN视图 |
vlan vlan-id |
在VLAN内使能MLD Snooping |
mld-snooping enable |
必选 缺省情况下,VLAN内的MLD Snooping处于关闭状态 |
在VLAN内使能IPv6 PIM Snooping |
pim-snooping ipv6 enable |
必选 缺省情况下,VLAN内的IPv6 PIM Snooping处于关闭状态 |
· 有关mld-snooping和mld-snooping enable命令的详细介绍,请参见“IP组播命令参考”中的“MLD Snooping”。
· 在VLAN内使能了IPv6 PIM Snooping之后,IPv6 PIM Snooping功能只在属于该VLAN的端口上生效。
· 在IPv6组播VLAN的子VLAN内使能IPv6 PIM Snooping无效。有关IPv6组播VLAN的详细介绍,请参见“IP组播配置指导”中的“IPv6组播VLAN”。
在完成上述配置后,在任意视图下执行display命令可以显示配置后IPv6 PIM Snooping的运行情况,通过查看显示信息验证配置的效果。
在用户视图下执行reset命令可以清除IPv6 PIM Snooping的统计信息。
表1-2 IPv6 PIM Snooping显示和维护
查看IPv6 PIM Snooping的邻居信息(独立运行模式) |
display pim-snooping ipv6 neighbor [ vlan vlan-id ] [ slot slot-number ] [ | { begin | exclude | include } regular-expression ] |
查看IPv6 PIM Snooping的邻居信息(IRF模式) |
display pim-snooping ipv6 neighbor [ [ vlan vlan-id ] [ chassis chassis-number slot slot-number ] [ | { begin | exclude | include } regular-expression ] |
查看IPv6 PIM Snooping的路由信息(独立运行模式) |
display pim-snooping ipv6 routing-table [ vlan vlan-id ] [ slot slot-number ] [ | { begin | exclude | include } regular-expression ] |
查看IPv6 PIM Snooping的路由信息(IRF模式) |
display pim-snooping ipv6 routing-table [ [ vlan vlan-id ] [ chassis chassis-number slot slot-number ] [ | { begin | exclude | include } regular-expression ] |
查看IPv6 PIM Snooping监听到的PIM报文的统计信息 |
display pim-snooping ipv6 statistics [ | { begin | exclude | include } regular-expression ] |
清除IPv6 PIM Snooping监听到的PIM报文的统计信息 |
reset pim-snooping ipv6 statistics |
· 如图1-2所示,Router A和Router B各自的GigabitEthernet3/1/1接口分别连接IPv6组播源Source 1和Source 2;Router C和Router D各自的GigabitEthernet3/1/1接口分别连接接收者Receiver 1和Receiver 2;Router A、Router B、Router C和Router D各自的GigabitEthernet3/1/2接口都通过Router E互连。
· Source 1和Source 2分别通过IPv6组播组FF1E::101和FF2E::101发送IPv6组播数据,Receiver 1和Receiver 2则分别接收来自IPv6组播组FF1E::101和FF2E::101的IPv6组播数据;Router C和Router D各自的GigabitEthernet3/1/1接口上都运行MLD,Router A、Router B、Router C和Router D上都运行IPv6 PIM-SM,并由Router A的GigabitEthernet3/1/2接口充当C-BSR和C-RP。
· 通过在Router E上配置MLD Snooping和IPv6 PIM Snooping,使Router E将IPv6 PIM协议报文和IPv6组播数据报文只转发给有接收需求的路由器。
图1-2 IPv6 PIM Snooping典型配置组网图
(1) 使能IPv6转发功能,并配置IPv6地址
使能各设备的IPv6转发功能,并按照图1-2配置各接口的IPv6地址和前缀长度,具体配置过程略。
(2) 配置Router A
# 使能IPv6组播路由,在各接口上使能IPv6 PIM-SM,并将接口GigabitEthernet3/1/2配置为C-BSR和C-RP。
[RouterA] multicast ipv6 routing-enable
[RouterA] interface GigabitEthernet 3/1/1
[RouterA-GigabitEthernet3/1/1] pim ipv6 sm
[RouterA-GigabitEthernet3/1/1] quit
[RouterA] interface GigabitEthernet 3/1/2
[RouterA-GigabitEthernet3/1/2] pim ipv6 sm
[RouterA-GigabitEthernet3/1/2] quit
[RouterA] pim ipv6
[RouterA-pim6] c-bsr 1001::1
[RouterA-pim6] c-rp 1001::1
(3) 配置Router B
# 使能IPv6组播路由,在各接口上使能IPv6 PIM-SM。
<RouterB> system-view
[RouterB] multicast ipv6 routing-enable
[RouterB] interface GigabitEthernet 3/1/1
[RouterB-GigabitEthernet3/1/1] pim ipv6 sm
[RouterB-GigabitEthernet3/1/1] quit
[RouterB] interface GigabitEthernet 3/1/2
[RouterB-GigabitEthernet3/1/2] pim ipv6 sm
(4) 配置Router C
# 使能IPv6组播路由,在各接口上使能IPv6 PIM-SM,并在接口GigabitEthernet3/1/1上使能MLD。
<RouterC> system-view
[RouterC] multicast ipv6 routing-enable
[RouterC] interface GigabitEthernet 3/1/1
[RouterC-GigabitEthernet3/1/1] pim ipv6 sm
[RouterC-GigabitEthernet3/1/1] mld enable
[RouterC-GigabitEthernet3/1/1] quit
[RouterC] interface GigabitEthernet 3/1/2
[RouterC-GigabitEthernet3/1/2] pim ipv6 sm
(5) 配置Router D
Router D的配置与Router C相似,配置过程略。
(6) 配置Router E
# 全局使能MLD Snooping。
<RouterE> system-view
[RouterE] mld-snooping
[RouterE-mld-snooping] quit
# 将端口GigabitEthernet3/1/1到GigabitEthernet3/1/4的链路模式切换到二层模式,然后创建VLAN 100,把上述端口添加到该VLAN中;在该VLAN内使能MLD Snooping和IPv6 PIM Snooping。
[RouterE] interface GigabitEthernet 3/1/1
[RouterE-GigabitEthernet3/1/1] port link-mode bridge
[RouterE-GigabitEthernet3/1/1] quit
[RouterE] interface GigabitEthernet 3/1/2
[RouterE-GigabitEthernet3/1/2] port link-mode bridge
[RouterE-GigabitEthernet3/1/2] quit
[RouterE] interface GigabitEthernet 3/1/3
[RouterE-GigabitEthernet3/1/3] port link-mode bridge
[RouterE-GigabitEthernet3/1/3] quit
[RouterE] interface GigabitEthernet 3/1/4
[RouterE-GigabitEthernet3/1/4] port link-mode bridge
[RouterE-GigabitEthernet3/1/4] quit
[RouterE] vlan 100
[RouterE-vlan100] port GigabitEthernet 3/1/1 to GigabitEthernet 3/1/4
[RouterE-vlan100] mld-snooping enable
[RouterE-vlan100] pim-snooping ipv6 enable
[RouterE-vlan100] quit
(7) 检验配置效果
# 查看Router E上VLAN 100内IPv6 PIM Snooping的邻居信息。
[RouterE] display pim-snooping ipv6 neighbor vlan 100
Total number of neighbors: 4
VLAN ID: 100
Neighbor Port Expires Option Flags
FE80::1 GE3/1/1 02:02:23 LAN Prune Delay
FE80::2 GE3/1/2 03:00:05 LAN Prune Delay
FE80::3 GE3/1/3 02:22:13 LAN Prune Delay
FE80::4 GE3/1/4 03:07:22 LAN Prune Delay
由此可见,Router A、Router B、Router C和Router D之间都建立起了IPv6 PIM Snooping邻居关系。
# 查看Router E上VLAN 100内IPv6 PIM Snooping的路由信息。
[RouterE] display pim-snooping ipv6 routing-table vlan 100
Total 2 entry(ies)
FSM Flag: NI-no info, J-join, PP-prune pending
VLAN ID: 100
Total 2 entry(ies)
(*, FF1E::101)
Upstream neighbor: FE80::1
Total number of downstream ports: 1
1: GE3/1/3
(*, FF2E::101)
Upstream neighbor: FE80::2
1: GE3/1/4
由此可见,Router E将向Router C转发IPv6组播组FF1E::101的IPv6组播数据,向Router D转发IPv6组播组FF2E::101的IPv6组播数据。
路由器不能实现IPv6 PIM Snooping功能。
MLD Snooping或IPv6 PIM Snooping没有使能。
(1) 使用display current-configuration命令查看MLD Snooping和IPv6 PIM Snooping的运行状态。
(2) 如果没有使能MLD Snooping,请先在系统视图下使用mld-snooping命令全局使能MLD Snooping,然后在VLAN视图下分别使用mld-snooping enable和pim-snooping ipv6 enable命令使能VLAN内的MLD Snooping和IPv6 PIM Snooping。
(3) 如果没有使能IPv6 PIM Snooping,请在VLAN视图下使用pim-snooping ipv6 enable命令使能VLAN内的IPv6 PIM Snooping。
在有分片加入/剪枝报文的网络中,部分下游IPv6 PIM路由器无法收到IPv6组播数据。
IPv6 PIM Snooping不能对分片报文进行重组,因此无法维护分片加入/剪枝报文中携带的下游状态。为了保证系统功能正常,只能将分片加入/剪枝报文在VLAN内广播,因此需要在VLAN内连接IPv6 PIM Snooping路由器的所有IPv6 PIM路由器上都禁止加入报文抑制能力,以保证加入报文不被广播的分片加入/剪枝报文所抑制。假如存在未禁止该能力的IPv6 PIM路由器,被广播的分片加入/剪枝报文就会影响其它IPv6 PIM路由器的加入状态:如果某IPv6 PIM路由器有IPv6组播接收需求,但其发送的加入报文被抑制,那么该路由器将无法收到IPv6组播数据。
(1) 在IPv6 PIM路由器连接IPv6 PIM Snooping路由器的接口上使用pim ipv6 hello-option neighbor-tracking命令使能邻居跟踪功能。
(2) 如果存在不能够使能邻居跟踪功能的IPv6 PIM路由器,则需关闭IPv6 PIM Snooping路由器上的IPv6 PIM Snooping功能。
