H3C Data Center Switches M-LAG Configuration Guide-6W101
HomeSupportConfigure & DeployConfiguration GuidesH3C Data Center Switches M-LAG Configuration Guide-6W101
16-Cascaded M-LAG Systems with Attached Multicast Source and Receivers Configuration Examples
Example: Setting up two cascaded M-LAG systems with directly attached multicast source and receivers· 2
Network configuration· 2
Applicable product matrix· 3
Analysis· 3
Procedure summary· 4
Configuring M-LAG·· 4
Configuring the dual-active gateways· 9
Configuring Layer 3 multicast 11
Traffic forwarding models· 13
Underlay traffic characteristics· 13
Forwarding models· 13
Testing network convergence upon single points of failure· 14
Verifying the configuration· 15
Verifying the status of the M-LAG system·· 15
Verifying multicast forwarding information· 16
Upgrading the devices· 20
Checking the environment 20
Verifying the traffic interruption time during the upgrade· 20
Verifying the upgrade result 20
Replacing hardware· 20
Replacing a service module· 20
Replacing a switching fabric module· 21
Replace a device· 21
Example: Setting up two cascaded M-LAG systems with multicast source and receivers attached via intermediate devices· 23
Network configuration· 23
Applicable product matrix· 25
Analysis· 25
Procedure summary· 26
Configuring M-LAG·· 26
Configuring the dual-active gateways· 30
Configuring OSPF for establishing Layer 3 connectivity between M-LAG member devices· 33
Configuring Layer 3 multicast 36
Traffic forwarding models· 38
Underlay traffic characteristics· 38
Forwarding models· 39
Testing network convergence upon single points of failure· 39
Verifying the configuration· 39
Verifying the status of the M-LAG system·· 39
Verifying routing configuration· 41
Upgrading the devices· 46
Checking the environment 46
Verifying the traffic interruption time during the upgrade· 46
Verifying the upgrade result 47
Replacing hardware· 47
Replacing a service module· 47
Replacing a switching fabric module· 47
Replace a device· 48
To improve network reliability, set up a two-tier cascaded M-LAG structure to support Layer 3 multicast services, as shown in Figure 1. The receivers receive video-on-demand traffic through multicast. PIM protocol is enabled on each device interface, and the entire PIM domain uses SM non-administrative domain mode.
Multicast receivers can be singlehomed to the receiver side M-LAG member devices or be attached to M-LAG interfaces. The multicast source is connected to an M-LAG system through M-LAG interfaces.
Figure 1 Network diagram
Device
IP address
Peer device and interface
Device A
WGE1/0/11
IPv4: 221.1.2.1/24
Device B: WGE1/0/11
Vlan-int20
IPv4: 20.1.1.1/24
Receiver 2
Vlan-int21
IPv4: 21.1.1.1/24
Receiver 1
Loopback0
IPv4: 3.3.3.3/32
N/A
HGE1/0/28
IPv4: 11.2.1.2/24
Device C: HGE1/0/4
HGE1/0/29
IPv4: 12.2.1.2/24
Device D: HGE1/0/4
Device B
WGE1/0/11
IPv4: 221.1.2.2/24
Device A: WGE1/0/11
Vlan-int20
IPv4: 20.1.1.1/24
Receiver 2
Loopback0
IPv4: 4.4.4.4/32
N/A
HGE1/0/28
IPv4: 11.3.1.2/24
Device C: HGE1/0/5
HGE1/0/29
IPv4: 12.3.1.2/24
Device D: HGE1/0/5
Device C
HGE1/0/6
IPv4: 220.1.1.1/24
Device D: HGE1/0/6
Vlan-int10
IPv4: 10.1.1.1/24
Source
Loopback0
IPv4: 1.1.1.1/32
N/A
HGE1/0/4
IPv4: 11.2.1.1/24
Device A: HGE1/0/28
HGE1/0/5
IPv4: 11.3.1.1/24
Device B: HGE1/0/28
Device D
HGE1/0/6
IPv4: 220.1.1.2/24
Device C: HGE1/0/6
Vlan-int10
IPv4: 10.1.1.1/24
Source
Loopback0
IPv4: 2.2.2.2/32
N/A
HGE1/0/4
IPv4: 12.2.1.1/24
Device A: HGE1/0/29
HGE1/0/5
IPv4: 12.3.1.1/24
Device B: HGE1/0/29
IMPORTANT
IMPORTANT:
In addition to running an applicable software version, you must also install the most recent patch, if any.
Device
Software version
S6805, S6825, S6850, S9850
R6710
S9820-64H, S9820-8C
Not supported
S6800, S6860, S6900
Not supported
S12500X-AF, S12500F-AF, S6890
R2825
S12500R
Not supported
S12500G-AF
R7625
S6812, S6813
F6628P22
Analysis
·     Set up one M-LAG system with Device A and Device B and another with Device C and Device D.
·     Create one VLAN interface for the same VLAN on Device A and Device B, respectively. In this example, create VLAN-interface 20. Allocate the same IPv4 addresses and MAC address to the VLAN interfaces for them to act as gateway interfaces. Assign M-LAG interfaces to the VLAN of the VLAN interfaces.
·     Create one VLAN interface for the same VLAN on Device C and Device D, respectively. In this example, create VLAN-interface 10. Allocate the same IPv4 addresses and MAC address to the VLAN interfaces for them to act as gateway interfaces. Assign M-LAG interfaces to the VLAN of the VLAN interfaces.
·     Enable IP multicast forwarding and IGMP snooping on Device A through Device D. A device with IGMP snooping enabled forwards multicast traffic of known multicast groups to the designated receivers instead of broadcasting the multicast traffic. Configure PIM on interfaces of the devices.
·     Create VLAN-interface 21 on Device A to accommodate Receiver 1, which is singlehomed to the device.
Procedure summary
·     Configuring M-LAG
·     Configuring the dual-active gateways
·     Configuring Layer 3 multicast
Configuring M-LAG
For the S12500X-AF, S12500F-AF, and S6890 series switches, first configure the MAC base address, and then assign MAC addresses on each device in the M-LAG systems based on the MAC base address. For more information about MAC address configuration, see M-LAG network planning.
Configuring Device A and Device B
Device A
Device B
Remarks
m-lag system-mac 1-1-2
Configure the M-LAG system MAC address.
You must configure the same M-LAG system MAC address for devices in the same M-LAG system.
m-lag system-number 1
m-lag system-number 2
Set the M-LAG system number.
You must set different M-LAG system numbers for devices in the same M-LAG system.
m-lag system-priority 122
Set the M-LAG system priority.
You must set the same M-LAG system priority for devices in the same M-LAG system.
m-lag standalone enable
Enable M-LAG standalone mode.
N/A
m-lag keepalive ip destination 221.1.2.2 source 221.1.2.1
m-lag keepalive ip destination 221.1.2.1 source 221.1.2.2
Configure the destination and source IP addresses of keepalive packets.
N/A
interface Twenty-FiveGigE1/0/11
Enter the view of the interface used for setting up the keepalive link.
N/A
port link-mode route
Configure the keepalive link interface to operate in route mode as a Layer 3 interface.
N/A
ip address 221.1.2.1 24
ip address 221.1.2.2 24
Assign an IP address to the keepalive link interface.
N/A
Return to system view.
N/A
m-lag mad exclude interface Twenty-FiveGigE1/0/11
Exclude the interface used for M-LAG keepalive detection from the shutdown action by M-LAG MAD.
N/A
interface HundredGigE1/0/28
Enter Ethernet interface view.
N/A
Configure the Ethernet interface to operate in route mode as a Layer 3 interface.
N/A
ip address 11.2.1.2/24
ip address 11.3.1.2/24
Assign an IP address to the interface.
N/A
N/A
interface HundredGigE1/0/29
N/A
N/A
ip address 12.2.1.2/24
ip address 12.3.1.2/24
N/A
N/A
m-lag mad exclude interface HundredGigE1/0/28
Exclude an interface-facing a peer M-LAG system from the shutdown action by M-LAG MAD.
N/A
m-lag mad exclude interface HundredGigE1/0/29
N/A
interface bridge-aggregation 1000
Create the Layer 2 aggregate interface to be used as the peer-link interface and enter Layer 2 aggregate interface view.
N/A
N/A
Interface HundredGigE 1/0/26
interface HundredGigE 1/0/26
Enter the view of a physical interface used for setting up the peer link.
N/A
port link-aggregation group 1000
Assign the physical interface to the aggregation group of the peer link.
N/A
N/A
Enter the view of the aggregation group for the peer link.
N/A
undo mac-address static source-check enable
Disable source MAC check on the interface.
N/A
link-aggregation mode dynamic
Configure the peer-link aggregate interface to operate in dynamic mode.
N/A
port m-lag peer-link 1
Specify the aggregate interface as the peer-link interface.
N/A
N/A
Create an aggregate interface.
N/A
Configure the aggregate interface to operate in dynamic mode.
N/A
port m-lag group 1
port m-lag group 1
Assign the aggregate interface to M-LAG group 1.
N/A
N/A
interface HundredGigE1/0/30
N/A
Assign the interface to the aggregation group of an M-LAG interface.
N/A
N/A
Configuring Device C and Device D
Device C
Device D
Remarks
m-lag system-mac 1-1-1
m-lag system-priority 121
N/A
m-lag keepalive ip destination 220.1.1.2 source 220.1.1.1
m-lag keepalive ip destination 220.1.1.1 source 220.1.1.2
N/A
interface HundredGigE1/0/6
N/A
N/A
ip address 220.1.1.1 24
ip address 220.1.1.2 24
N/A
N/A
m-lag mad exclude interface HundredGigE1/0/6
N/A
interface HundredGigE1/0/4
N/A
N/A
ip address 11.2.1.1/24
ip address 11.3.1.1/24
N/A
N/A
interface HundredGigE1/0/5
N/A
N/A
ip address 12.2.1.1/24
ip address 12.3.1.1/24
N/A
N/A
m-lag mad exclude interface HundredGigE1/0/4
N/A
m-lag mad exclude interface HundredGigE1/0/5
N/A
N/A
N/A
Interface HundredGigE 1/0/8
interface HundredGigE 1/0/8
N/A
N/A
N/A
N/A
N/A
N/A
Configure the aggregate interface as the peer-link interface.
N/A
N/A
N/A
N/A
port m-lag group 1
port m-lag group 1
N/A
N/A
interface HundredGigE 1/0/7
N/A
N/A
N/A
Device A
Device B
vlan 20
vlan 20
Create VLAN 20.
Enter aggregate interface view.
port link-type trunk
Set the link type of the Layer 2 aggregate interface to trunk.
port trunk permit vlan 20
Assign the interface to VLAN 20.
undo port trunk permit vlan 1
Remove the interface from VLAN 1.
interface vlan-interface 20
Create VLAN-interface 20.
ip address 20.1.1.1 255.255.255.0
Assign an IPv4 address to VLAN-interface 20.
mac-address 0020-0020-0020
Assign a MAC address to VLAN-interface 20.
m-lag mad exclude  interface Vlan-interface20
Exclude VLAN-interface 20 from the shutdown action by M-LAG MAD.
vlan 21
Create VLAN 21.
Set the link type of the interface to trunk.
port trunk permit vlan 21
Assign the interface to VLAN 21.
interface vlan-interface 21
Create VLAN-interface 21.
ip address 21.1.1.1 255.255.255.0
Assign an IPv4 address to VLAN-interface 21.
mac-address 0020-0020-0021
Assign a MAC address to VLAN-interface 21.
m-lag mad exclude  interface Vlan-interface21
Exclude VLAN-interface 21 from the shutdown action by M-LAG MAD.
Device C
Device D
vlan 10
vlan 10
Create VLAN 10.
port trunk permit vlan 10
Assign the interface to VLAN 10.
interface vlan-interface 10
Create VLAN-interface 10.
Assign an IPv4 address to VLAN-interface 10.
mac-address 0010-0010-0010
Assign a MAC address to VLAN-interface 10.
m-lag mad exclude  interface Vlan-interface10
Exclude VLAN-interface 10 from the shutdown action by M-LAG MAD.
Device A
Device B
multicast routing
multicast routing
Enable IP multicast routing.
igmp-snooping
igmp-snooping
Enable IGMP snooping.
Vlan 20
Vlan 20
Enter VLAN view.
igmp-snooping enable
Enable IGMP snooping in the VLAN.
Enable VLAN interface view.
pim sm
pim sm
Enable PIM SM.
igmp enable
igmp enable
Enable IGMP.
pim distributed-dr
pim distributed-dr
Configure the interface as a DR interface to forward multicast traffic.
This command is not supported by the S12500X-AF, S12500F-AF, or S6890 switches.
pim passive
pim passive
Enable PIM passive mode for the interface to forward multicast traffic.
Execute this command only on the S12500X-AF, S12500F-AF, or S6890 switch.
Return to the upper-level view.
pim sm
Enable PIM SM.
igmp enable
Enable IGMP.
pim sm
pim sm
Enable PIM SM.
pim sm
pim sm
Enable PIM SM.
interface LoopBack0
interface LoopBack0
Enter loopback interface view.
pim sm
pim sm
Enable PIM SM.
pim sm
pim sm
Enable PIM SM.
pim
pim
Enter PIM view.
static-rp 4.4.4.4
static-rp 4.4.4.4
Configure a static RP.
Device C
Device D
multicast routing
multicast routing
igmp-snooping
igmp-snooping
Vlan 10
Vlan 10
Enter VLAN view.
pim sm
pim sm
Enable PIM SM.
pim distributed-dr
pim distributed-dr
pim passive
pim passive
pim sm
pim sm
Enable PIM SM.
pim sm
pim sm
Enable PIM SM.
interface LoopBack0
interface LoopBack0
pim sm
pim sm
Enable PIM SM.
pim sm
pim sm
Enable PIM SM.
pim
pim
Enter PIM view.
static-rp 4.4.4.4
static-rp 4.4.4.4
The forwarding model matrix provides the following characteristics of underlay traffic:
·     No.—Traffic number in the U-X-XXX format:
¡     U—Underlay traffic.
¡     X—Protocol number, which can be 4 (IPv4)
¡     XXX—Traffic sequence number.
·     Traffic type—Type of underlay traffic, which can only be IPv4 known multicast
·     Direction—Direction of underlay traffic. The value is south-north, which indicates traffic from the south to north.
·     Forwarding path—Nodes that underlay traffic traverses.
·     Traffic simulation—Traffic simulation method. Typically, a tester is used to simulate server traffic.
·     Load—Traffic size, which can be light (less than 1000 flows) and heavy (more than 1000 flows).
·     Traffic direction to firewalls/LB—No firewalls or LBs are used in this example. This field is not involved.
Forwarding models
No.
Traffic type
Direction
Forwarding path
Traffic simulation
Load
U-4-101
South-north
100 multicast groups
Source > Device C and Device D > Device A and Device B > Receiver 2
Tester
Light
N/A
U-4-102
IPv4 known mutlicsat
South-north
Source > Device C and Device D > Device A and Device B > Receiver 1
Tester
Light
N/A
Table 1 Network convergence upon single points of failure
Device
Failure type
Traffic interruption time (U-4-101/U-4-102)
M-LAG
Multicast source-side single point of failure on M-LAG member links
≤ 100 ms
Multicast source-side single point of failure restored on M-LAG member links
≤ 100 ms
Multicast source-side peer link failure
≤ 500 ms
Multicast source-side peer link failure restored
≤ 100 ms
Multicast source-side keepalive link failure
0 ms
Multicast source-side keepalive link failure restored
0 ms
Multicast source-side keepalive link and peer link failure
≤ 500 ms
Multicast source-side keepalive link and peer link failure restored
≤ 500 ms
Single ECMP link failure between the M-LAG systems
≤ 500 ms/1000 ms
Single ECMP link restored between the M-LAG systems
≤ 100 ms
Multicast-receiver side single point of failure on M-LAG member links
≤ 100 ms/0 ms
Multicast-receiver side single point of failure restored on M-LAG member links
≤ 100 ms/0 ms
Multicast-receiver side peer link failure
≤ 100 ms/0 ms
Multicast-receiver side peer link failure restored
≤ 100 ms/0 ms
Multicast-receiver side keepalive link failure
0 ms
Multicast-receiver side keepalive link failure restored
0 ms
Multicast-receiver side keepalive link and peer link failure
≤ 500 ms/0 ms
Multicast-receiver side keepalive link and peer link restored
≤ 500 ms/0 ms
Upgrade
≤ 10000 ms (upgrade the M-LAG member devices one after another)
Hardware replacement
Fixed-port device replacement: ≤ 10000 ms
Verify that the M-LAG system is working correctly on Device A and Device B. Use Device A as an example. The verification procedure is the same for Device B, Device C, and Device D.
# Display summary information about the peer-link interface and M-LAG interface.
[Device A]display m-lag summary
Flags: A -- Aggregate interface down, B -- No peer M-LAG interface configured
       C -- Configuration consistency check failed
Peer-link interface: BAGG1000
Peer-link interface state (cause): UP
Keepalive link state (cause): UP
                     M-LAG interface information
M-LAG IF    M-LAG group  Local state (cause)  Peer state  Remaining down time(s)
BAGG1       1            UP                   UP          -
# Verify that keepalive link is working correctly.
[Device A]display m-lag keepalive
Neighbor keepalive link status (cause): Up
Neighbor is alive for: 256 s 620 ms
Keepalive packet transmission status:
  Sent: Successful
  Received: Successful
Last received keepalive packet information:
  Source IP address: 221.1.2.2
  Time: 2023/06/13 05:00:51
  Action: Accept
M-LAG keepalive parameters:
Destination IP address: 221.1.2.2
Source IP address: 221.1.2.1
Keepalive UDP port : 6400
Keepalive VPN name : N/A
Keepalive interval : 1000 ms
Keepalive timeout  : 5 sec
Keepalive hold time: 3 sec
# Display the M-LAG system information.
[Device A]display m-lag system
                     System information
Local system number: 1                      Peer system number: 2
Local system MAC: 0001-0001-0002            Peer system MAC: 0001-0001-0002
Local system priority: 122                  Peer system priority: 122
Local bridge MAC: dcda-8037-2bc0            Peer bridge MAC: bc22-4720-d5b9
Local effective role: Secondary             Peer effective role: Primary
Health level: 0
Standalone mode on split: Enabled
In standalone mode: No
                     System timer information
Timer                      State       Value (s)    Remaining time (s)
Auto recovery              Disabled    -            -
Restore delay              Disabled    60           -
Consistency-check delay    Disabled    30           -
Standalone delay           Disabled    0            -
Role to None delay         Disabled    60           -
# Display detailed information about the peer-link interface and M-LAG interfaces.
[Device A]display m-lag verbose
Flags: A -- Home_Gateway, B -- Neighbor_Gateway, C -- Other_Gateway,
       D -- PeerLink_Activity, E -- DRCP_Timeout, F -- Gateway_Sync,
       G -- Port_Sync, H -- Expired
Peer-link interface/Peer-link interface ID: BAGG1000/1
State: UP
Cause: -
Local DRCP flags/Peer DRCP flags: ABDFG/ABDFG
Local Selected ports (index): HGE1/0/26 (30)
Peer Selected ports indexes: 225
M-LAG interface/M-LAG group ID: BAGG1/1
Local M-LAG interface state: UP
Peer M-LAG interface state: UP
M-LAG group state: UP
Local M-LAG interface down cause: -
Remaining M-LAG DOWN time: -
Local M-LAG interface LACP MAC: Config=N/A, Effective=0001-0001-0002
Peer M-LAG interface LACP MAC: Config=N/A, Effective=0001-0001-0002
Local M-LAG interface LACP priority: Config=32768, Effective=122
Peer M-LAG interface LACP priority: Config=32768, Effective=122
Local Selected ports (index): HGE1/0/30 (50)
Peer Selected ports indexes: 245
# Verify that PIM neighbor relationships are established correctly.
[Device A]display pim neighbor
 Total Number of Neighbors = 3
 Neighbor        Interface           Uptime   Expires  DR-Priority Mode
 221.1.2.2       WGE1/0/11           00:06:12 00:01:37 1           P
 11.2.1.1        HGE1/0/28           2d:00h   00:01:44 1           P
 12.2.1.1        HGE1/0/29           00:15:52 00:01:44 1           P
[Device B]display pim neighbor
 221.1.2.1       WGE1/0/11           00:06:40 00:01:35 1           P
 11.3.1.1        HGE1/0/28           2d:00h   00:01:44 1           P
 12.3.1.1        HGE1/0/29           2d:00h   00:01:32 1           P
[Device C]display pim neighbor
 11.2.1.2        HGE1/0/4            2d:00h   00:01:42 1           P
 11.3.1.2        HGE1/0/5            2d:00h   00:01:27 1           P
 220.1.1.2       HGE1/0/6            00:19:34 00:01:37 1           P
[Device D]display pim neighbor
 12.2.1.2        HGE1/0/4            00:16:32 00:01:26 1           P
 12.3.1.2        HGE1/0/5            2d:00h   00:01:20 1           P
 220.1.1.1       HGE1/0/6            00:19:38 00:01:26 1           P
# Verify that multicast forwarding entries are created correctly.
[Device A]dis igmp group
IGMP groups in total: 200
 Vlan-interface20(20.1.1.1):
  IGMP groups reported in total: 100
   Group address   Last reporter   Uptime      Expires
   225.0.0.1       20.1.1.2        00:07:34    00:03:04
   225.0.0.2       20.1.1.2        00:07:26    00:03:03
   225.0.0.3       20.1.1.2        00:07:30    00:03:07
   225.0.0.98      20.1.1.2        00:07:28    00:03:07
   225.0.0.99      20.1.1.2        00:07:27    00:03:10
   225.0.0.100     20.1.1.2        00:07:26    00:03:06
 Vlan-interface21(21.1.1.1):
   226.0.0.1       21.1.1.2        00:32:50    00:04:17
   226.0.0.2       21.1.1.2        00:32:50    00:02:12
   226.0.0.3       21.1.1.2        00:32:50    00:02:12
   226.0.0.98      21.1.1.2        00:32:50    00:04:15
   226.0.0.99      21.1.1.2        00:32:50    00:04:18
   226.0.0.100     21.1.1.2        00:32:50    00:02:11
# Verify that PIM routing entries are created correctly.
[Device A]dis pim routing-table
 Total 200 (*, G) entries; 200 (S, G) entries
 (*, 225.0.0.1)
     RP: 4.4.4.4
     Protocol: pim-sm, Flag: WC
     UpTime: 00:08:57
     Upstream interface: HundredGigE1/0/29
         Upstream neighbor: 12.2.1.1
         RPF prime neighbor: 12.2.1.1
     Downstream interface information:
         1: Vlan-interface20
             Protocol: igmp, UpTime: 00:08:57, Expires: -
 (10.1.1.2, 225.0.0.1)
     RP: 4.4.4.4
     Protocol: pim-sm, Flag: SPT ACT 2MVPN
     UpTime: 00:41:07
         1: Vlan-interface20
             Protocol: pim-sm, UpTime: 00:08:57, Expires: -
(*, 226.0.0.1)
     RP: 4.4.4.4
     UpTime: 00:34:27
         1: Vlan-interface21
             Protocol: igmp, UpTime: 00:34:27, Expires: -
 (10.1.1.2, 226.0.0.1)
     RP: 4.4.4.4
     UpTime: 00:37:01
         1: Vlan-interface21
             Protocol: pim-sm, UpTime: 00:34:27, Expires: -
[Device B]display pim routing-table
 Total 200 (*, G) entries; 201 (S, G) entries
 (*, 225.0.0.1)
     RP: 4.4.4.4 (local)
     UpTime: 00:15:09
     Upstream interface: Register-Tunnel0
         Upstream neighbor: NULL
         RPF prime neighbor: NULL
     Total number of downstream interfaces: 2
         1: HundredGigE1/0/29
             Protocol: pim-sm, UpTime: 00:10:02, Expires: 00:03:28
         2: Vlan-interface20
             Protocol: igmp, UpTime: 00:15:09, Expires: -
     RP: 4.4.4.4 (local)
     Protocol: pim-sm, Flag: SPT 2MSDP ACT 2MVPN
     UpTime: 00:44:11
         Upstream neighbor: 12.3.1.1
         RPF prime neighbor: 12.3.1.1
         1: Vlan-interface20
             Protocol: pim-sm, UpTime: 00:15:09, Expires: -
(*, 226.0.0.1)
     RP: 4.4.4.4 (local)
     UpTime: 00:23:10
             Protocol: pim-sm, UpTime: 00:20:31, Expires: 00:02:58
     RP: 4.4.4.4 (local)
     Protocol: pim-sm, Flag: RPT 2MSDP ACT 2MVPN
     UpTime: 00:45:34
     Downstream interface information: None
Execute the commands in "Verifying the configuration" and the following commands to verify that the devices are available for an upgrade.
M-LAG 1
M-LAG 2
display device
display device
Displays device information.
display boot-loader
display boot-loader
Displays current software images and startup software images.
display version
display version
Displays system version information.
See H3C Switches M-LAG System Upgrade & Replacement & Expansion Guide.
See "Testing network convergence upon single points of failure."
Execute the commands in "Verifying the configuration" and the following commands to verify that the device is upgraded successfully.
M-LAG 1
M-LAG 2
display device
display device
display boot-loader
display boot-loader
display version
display version
Replacing hardware
Execute the commands in "Verifying the configuration" and the following commands to verify that the device is available for a replacement.
M-LAG 1
M-LAG 2
display device
display device
display boot-loader
display boot-loader
display version
display version
Replacing hardware
Switch service and management traffic on the target service module to other service modules.
Power off the device and replace the service module, or replace the service module when the device is running. For more information, see the installation guides for the service module.
For details, see H3C Switches M-LAG System Upgrade & Replacement & Expansion Guide.
For more information, see "Testing network convergence upon single points of failure."
Verifying the replacement result
Execute the commands in "Checking the environment."
M-LAG 1
M-LAG 2
display device
display device
display boot-loader
display boot-loader
display version
display version
Replacing hardware
Power off the device and replace the switching fabric module, or replace the switching fabric module when the device is running. For more information, see the installation guides for the switching fabric module.
Replace a device
M-LAG 1
M-LAG 2
display device
display device
display boot-loader
display boot-loader
display version
display version
Replacing hardware
To improve network reliability, set up a two-tier cascaded M-LAG structure to support Layer 3 multicast services, as shown in Figure 2. The receivers receive video-on-demand traffic through multicast. PIM protocol is enabled on each device interface, and the entire PIM domain uses SM non-administrative domain mode.
Configure M-LAG dual-active gateways, and run the OSPF protocol in the network to establish dynamic routing neighbors between the two-tier cascaded M-LAG systems and between the M-LAG systems and user-side devices. OSPF reduces the difficulty of network operation and enhances flexible deployment capabilities.
Enable M-LAG standalone mode and set the priority of aggregate interfaces for the following purposes:
·     When an access link fails, traffic can be quickly switched to another link to ensure reliability.
·     The two access links can forward user traffic simultaneously to increase bandwidth, and traffic load can be shared between the two access links.
·     If multiple link failures cause an M-LAG system to split, M-LAG switches to standalone mode. Only the designated device forwards business traffic to avoid abnormal traffic forwarding.
Figure 2 Network diagram
Device
IP address
Device A
HGE1/0/25
IPv4: 221.1.3.1/24
Device B: HGE1/0/25
Vlan-int10
IPv4: 10.1.1.1/24
Device F: Vlan-int10
Vlan-int20
IPv4: 20.1.1.1/24
Device C and Device D: Vlan-int20
Loopback0
IPv4: 5.5.5.5/32
N/A
Device B
HGE1/0/25
IPv4: 221.1.3.2/24
Device A:  HGE1/0/25
Vlan-int10
IPv4: 10.1.1.1/24
Vlan-int20
IPv4: 20.1.1.1/24
Loopback0
IPv4: 6.6.6.6/32
N/A
Device C
HGE1/0/25
IPv4: 221.1.2.1/24
Device D: HGE1/0/25
Vlan-int20
IPv4: 20.1.1.2/24
Device A and Device B: Vlan-int20
Vlan-int30
IPv4: 30.1.1.1/24
Device E: Vlan-int30
Loopback0
IPv4: 3.3.3.3/32
N/A
Device D
HGE1/0/25
IPv4: 221.1.2.2/24
Device C: HGE1/0/25
Vlan-int20
IPv4: 20.1.1.2/24
Vlan-int30
IPv4: 30.1.1.1/24
Loopback0
IPv4: 4.4.4.4/32
N/A
Device E
Vlan-int30
IPv4: 30.1.1.3/24
Device C and Device D: Vlan-int30
Vlan-int40
IPv4: 40.1.0.1/16
N/A
Loopback0
IPv4: 1.1.1.1/32
N/A
Device F
Vlan-int10
IPv4: 10.1.1.2/24
Device A and Device B: Vlan-int10
Vlan-int50
IPv4: 50.1.1.1/24
N/A
Loopback0
IPv4: 2.2.2.2/32
N/A
IMPORTANT
IMPORTANT:
Device
Software version
S6805/S6825/S6850/S9850
R6710
S9820-64H/S9820-8C
Not supported
S6800/S6860/S6900
Not supported
S12500X-AF/S12500F-AF/S6890
R2825
S12500R
Not supported
S12500G-AF
R7625
S6812/S6813
F6628P22
Analysis
·     Create one VLAN interface for the same VLAN on Device A and Device B, respectively. In this example, create VLAN-interface 10. Allocate the same IPv4 addresses and MAC address to the VLAN interfaces for them to act as gateway interfaces. Assign M-LAG interfaces to the VLAN of the VLAN interfaces.
·     Create one VLAN interface for the same VLAN on Device C and Device D, respectively. In this example, create VLAN-interface 20. Allocate the same IPv4 addresses and MAC address to the VLAN interfaces for them to act as gateway interfaces. Assign M-LAG interfaces to the VLAN of the VLAN interfaces.
·     Assign M-LAG virtual IP addresses to the VLAN interfaces for the M-LAG member devices to set up OSPF neighbor relationships among them and with Device E and Device F.
·     Enable IP multicast forwarding and IGMP snooping on Device A through Device F. A device with IGMP snooping enabled forwards multicast traffic of known multicast groups to the designated receivers instead of broadcasting the multicast traffic. Configure PIM on interfaces of the devices.
Procedure summary
·     Configuring M-LAG
·     Configuring OSPF for establishing Layer 3 connectivity between M-LAG member devices
Configuring M-LAG
Device A
Device B
Remarks
m-lag system-mac 5-5-5
m-lag system-priority 123
N/A
m-lag keepalive ip destination 221.1.3.2 source 221.1.3.1
m-lag keepalive ip destination 221.1.3.1 source 221.1.3.2
N/A
interface HundredGigE 1/0/25
N/A
N/A
ip address 221.1.3.1 24
ip address 221.1.3.2 24
N/A
N/A
m-lag mad exclude interface HundredGigE 1/0/25
N/A
interface bridge-aggregation 3
N/A
N/A
N/A
port link-aggregation group 3
N/A
N/A
N/A
N/A
N/A
N/A
N/A
N/A
N/A
port m-lag group 1
port m-lag group 1
N/A
N/A
interface bridge-aggregation 2
N/A
N/A
port m-lag group 2
port m-lag group 2
Assign the aggregate interface to M-LAG group 2.
N/A
N/A
interface range HundredGigE 1/0/27 HundredGigE 1/0/29
N/A
N/A
N/A
interface HundredGigE 1/0/30
N/A
port link-aggregation group 2
N/A
N/A
Device C
Device D
Remarks
m-lag system-mac 3-3-3
m-lag system-mac 3-3-3-
N/A
m-lag keepalive ip destination 221.1.2.1 source 221.1.1.2
N/A
N/A
N/A
N/A
N/A
N/A
N/A
N/A
N/A
N/A
N/A
N/A
N/A
N/A
N/A
N/A
N/A
N/A
port m-lag group 1
port m-lag group 1
N/A
N/A
N/A
N/A
port m-lag group 2
port m-lag group 2
N/A
N/A
N/A
N/A
N/A
interface undredGigE 1/0/30
Enter the view of the interface connecting to Device A and Device B.
N/A
N/A
N/A
Device A
Device B
Remarks
vlan 10 20
vlan 10 20
Create VLAN 10 and VLAN 20.
N/A
N/A
N/A
N/A
N/A
port lacp system-priority 101
port lacp system-priority 100
Set the LACP priority.
Set different LACP priorities for different M-LAG member devices, so that only member ports with a higher priority are selected upon brain split.
N/A
N/A
N/A
N/A
N/A
N/A
N/A
Assign an IPv4 address to VLAN-interface 10. The VLAN interface will act as a dual-active gateway interface.
N/A
mac-address 0010-0010-0070
N/A
N/A
m-lag mad exclude  interface vlan-interface10
N/A
N/A
N/A
mac-address 0010-0010-0071
N/A
N/A
m-lag mad exclude interface vlan-interface20
N/A
Device C
Device D
Remarks
vlan 20 30
vlan 20 30
Create VLAN 20 and VLAN 30.
N/A
N/A
N/A
N/A
N/A
N/A
N/A
N/A
port trunk permit vlan 30
Assign the interface to VLAN 30.
N/A
N/A
N/A
N/A
ip address 20.1.1.2 255.255.255.0
Assign an IPv4 address to VLAN-interface 20. The VLAN interface will act as a dual-active gateway interface.
N/A
mac-address 0010-0010-0080
N/A
N/A
N/A
interface vlan-interface 30
Create VLAN-interface 30.
N/A
ip address 30.1.1.1 255.255.255.0
Assign an IPv4 address to VLAN-interface 30.
N/A
mac-address 0010-0010-0081
Assign a MAC address to VLAN-interface 30.
N/A
N/A
m-lag mad exclude  interface vlan-interface30
Exclude VLAN-interface 30 from the shutdown action by M-LAG MAD.
N/A
Device A
Device B
Remarks
router id 5.5.5.5
router id 6.6.6.6
Configure a router ID.
N/A
ospf 1
ospf 1
Enable an OSPF process.
N/A
area 0
area 0
Configure an OSPF area.
N/A
N/A
Enter VLAN interface view.
N/A
port m-lag virtual-ip 10.1.1.100 255.255.255.0 active
port m-lag virtual-ip 10.1.1.101 255.255.255.0 active
Assign an M-LAG virtual IP address to the VLAN interface.
The IPv4 address is used to set up an OSPF neighbor relationship with Device F.
ospf 1 area 0.0.0.0
ospf 1 area 0.0.0.0
Enable OSPF on the interface.
N/A
ospf peer sub-address enable 10.1.1.100
ospf peer sub-address enable 10.1.1.101
Enable OSPF to establish neighbor relationships through the secondary IP addresses of the interface.
Because the same gateway interface on different M-LAG member devices use the same IP address and MAC address, the M-LAG member devices cannot establish a routing neighbor relationship with other devices by using their primary IP addresses. You must enable OSPF to establish neighbor relationships through the secondary IP addresses of the interface.
N/A
N/A
port m-lag virtual-ip 20.1.1.100 255.255.255.0 active
port m-lag virtual-ip 20.1.1.101 255.255.255.0 active
The IPv4 address is used to set up OSPF neighbor relationships with Device C and Device D.
ospf 1 area 0.0.0.0
ospf 1 area 0.0.0.0
N/A
ospf peer sub-address enable 20.1.1.100
ospf peer sub-address enable 20.1.1.101
N/A
Device C
Device D
Remarks
router id 3.3.3.3
router id 4.4.4.4
N/A
ospf 1
ospf 1
N/A
area 0
area 0
N/A
N/A
N/A
port m-lag virtual-ip 20.1.1.102 255.255.255.0 active
port m-lag virtual-ip 20.1.1.103 255.255.255.0 active
The IPv4 address is used to set up OSPF neighbor relationships with Device A and Device B.
ospf 1 area 0.0.0.0
ospf 1 area 0.0.0.0
N/A
ospf peer sub-address enable 20.1.1.102
ospf peer sub-address enable 20.1.1.103
N/A
N/A
port m-lag virtual-ip 30.1.1.100 255.255.255.0 active
port m-lag virtual-ip 30.1.1.101 255.255.255.0 active
ospf 1 area 0.0.0.0
ospf 1 area 0.0.0.0
N/A
ospf peer sub-address enable 30.1.1.100
ospf peer sub-address enable 30.1.1.101
N/A
Configuring Device E
Device E
router id 1.1.1.1
ospf 1
area 0
network 30.1.1.0 0.0.0.255
Enable OSPF for a network.
network 40.1.0.0 0.0.255.255
Configuring Device F
Device F
router id 2.2.2.2
ospf 1
area 0
network 10.1.1.0 0.0.0.255
network 50.1.1.0 0.0.0.255
Device A
Device B
multicast routing
multicast routing
igmp-snooping
igmp-snooping
Vlan 10
Vlan 10
N/A
Vlan 20
Vlan 20
N/A
pim sm
pim sm
Enable PIM SM.
pim distributed-dr
pim distributed-dr
(Optional.) Configure the interface as a DR interface to forward multicast traffic.
pim passive
pim passive
(Optional.) Enable PIM passive mode for the interface to forward multicast traffic.
N/A
pim sm
pim sm
Enable PIM SM.
pim distributed-dr
pim distributed-dr
pim passive
pim passive
N/A
pim
pim
Enter PIM view.
static-rp 5.5.5.5
static-rp 5.5.5.5
Device C
Device D
multicast routing
multicast routing
igmp-snooping
igmp-snooping
Vlan 20
Vlan 20
N/A
Vlan 30
Vlan 30
N/A
pim sm
pim sm
Enable PIM SM.
pim distributed-dr
pim distributed-dr
pim passive
pim passive
N/A
pim sm
pim sm
Enable PIM SM.
pim distributed-dr
pim distributed-dr
pim passive
pim passive
N/A
pim
pim
Enter PIM view.
static-rp 5.5.5.5
static-rp 5.5.5.5
Device E
multicast routing
igmp-snooping
Vlan 30
N/A
Vlan 40
N/A
pim sm
Enable PIM SM.
N/A
interface vlan-interface40
pim sm
Enable PIM SM.
igmp enable
Enable IGMP.
N/A
Device F
multicast routing
igmp-snooping
Vlan 10
N/A
Vlan 50
N/A
pim sm
Enable PIM SM.
N/A
interface vlan-interface50
pim sm
Enable PIM SM.
N/A
¡     X—Protocol number, which can be 4 (IPv4).
·     Traffic type—Type of underlay traffic, which can only be IPv4 known unicast
Forwarding models
No.
Traffic type
Direction
Forwarding path
Traffic simulation
Load
U-4-101
South-north
Device F > Device A and Device B > Device C and Device D > Device E
Tester
Light
N/A
Table 2 Network convergence upon single points of failure
Device
Failure type
M-LAG
Single point of failure on M-LAG member links
≤ 100 ms
Single point of failure restored on M-LAG member links
≤ 100 ms
Peer link failure
≤ 500 ms
Peer link failure restored
≤ 100 ms
Keepalive link failure
0 ms
Keepalive link failure restored
0 ms
Keepalive link and peer link failure
≤ 1000 ms
Keepalive link and peer link restored
≤ 10000 ms
Replacing hardware
Fixed-port device: ≤ 10000 ms
[DeviceA]display m-lag summary
Peer-link interface: BAGG3
BAGG1       1            UP                   UP          -
BAGG2       2            UP                   UP          -
[DeviceA]display m-lag keepalive
Neighbor is alive for: 102480 s 811 ms
  Sent: Successful
  Source IP address: 221.1.3.2
  Time: 2023/02/16 19:28:27
  Action: Accept
Destination IP address: 221.1.3.2
Source IP address: 221.1.3.1
[DeviceA]display m-lag system
                     System information
Local system MAC: 0001-0001-0003            Peer system MAC: 0001-0001-0003
Local system priority: 123                  Peer system priority: 123
Local bridge MAC: 00ec-fc00-050a            Peer bridge MAC: 00ec-fc00-050b
Local effective role: Primary               Peer effective role: Secondary
Health level: 0
[DeviceA]display m-lag verbose
Peer-link interface/Peer-link interface ID: BAGG3/1
State: UP
Cause: -
Local Selected ports (index): HGE1/0/26 (25)
Peer Selected ports indexes: 220
Local M-LAG interface LACP MAC: Config=N/A, Effective=0001-0001-0003
Peer M-LAG interface LACP MAC: Config=N/A, Effective=0001-0001-0003
Local M-LAG interface LACP priority: Config=32768, Effective=123
Peer M-LAG interface LACP priority: Config=32768, Effective=123
Local Selected ports (index): HGE1/0/27 (26), HGE1/0/30 (37)
Peer Selected ports indexes: 221, 232
M-LAG interface/M-LAG group ID: BAGG2/2
Local Selected ports (index): HGE1/0/30 (6)
Peer Selected ports indexes: 238
# Verify that OSPF neighbor relationships are correctly set up.
[DeviceA]dis ospf peer
         OSPF Process 1 with Router ID 5.5.5.5
               Neighbor Brief Information
 Area: 0.0.0.0
 Router ID       Address         Pri Dead-Time  State             Interface
 6.6.6.6         20.1.1.101      1   36         Full/BDR          Vlan20
 3.3.3.3         20.1.1.102      1   38         Full/DROther      Vlan20
 4.4.4.4         20.1.1.103      1   36         Full/DROther      Vlan20
 2.2.2.2         10.1.1.2        1   34         Full/BDR          Vlan10
 6.6.6.6         10.1.1.101      1   37         Full/DROther      Vlan10
[DeviceB]display ospf peer
         OSPF Process 1 with Router ID 6.6.6.6
 Area: 0.0.0.0
 5.5.5.5         20.1.1.100      1   32         Full/DR           Vlan20
 3.3.3.3         20.1.1.102      1   36         Full/DROther      Vlan20
 4.4.4.4         20.1.1.103      1   34         Full/DROther      Vlan20
 2.2.2.2         10.1.1.2        1   32         Full/BDR          Vlan10
 5.5.5.5         10.1.1.100      1   36         Full/DR           Vlan10
[DeviceC]display ospf peer
 Area: 0.0.0.0
 1.1.1.1         30.1.1.3        1   39         Full/DR           Vlan30
 4.4.4.4         30.1.1.101      1   38         Full/DROther      Vlan30
 5.5.5.5         20.1.1.100      1   38         Full/DR           Vlan20
 6.6.6.6         20.1.1.101      1   39         Full/BDR          Vlan20
 4.4.4.4         20.1.1.103      1   39         2-Way/ -          Vlan20
[DeviceD]display ospf peer
         OSPF Process 1 with Router ID 4.4.4.4
 Area: 0.0.0.0
 1.1.1.1         30.1.1.3        1   36         Full/DR           Vlan30
 3.3.3.3         30.1.1.100      1   38         Full/BDR          Vlan30
 5.5.5.5         20.1.1.100      1   35         Full/DR           Vlan20
 3.3.3.3         20.1.1.102      1   39         2-Way/ -          Vlan20
[DeviceE]dis ospf peer
 Area: 0.0.0.0
 3.3.3.3         30.1.1.100      1   39         Full/BDR          Vlan30
 4.4.4.4         30.1.1.101      1   37         Full/DROther      Vlan30
[DeviceF]display ospf peer
 Area: 0.0.0.0
 5.5.5.5         10.1.1.100      1   37         Full/DR           Vlan10
 6.6.6.6         10.1.1.101      1   35         Full/DROther      Vlan10
[DeviceA]display pim neighbor
 Total Number of Neighbors = 2
 20.1.1.2        Vlan20              08:24:02 00:01:33 1           P
 10.1.1.2        Vlan10              1d:00h   00:01:30 1           P
[DeviceB]display pim neighbor
 20.1.1.2        Vlan20              08:24:14 00:01:39 1           P
 10.1.1.2        Vlan10              09:17:11 00:01:17 1           P
[DeviceC]display pim neighbor
 30.1.1.3        Vlan30              02:13:33 00:01:24 1           P
 20.1.1.1        Vlan20              02:13:32 00:01:43 1           P
[DeviceD]display pim neighbor
 30.1.1.3        Vlan30              02:04:36 00:01:43 1           P
 20.1.1.1        Vlan20              02:04:50 00:01:31 1           P
[DeviceE]display pim neighbor
 Total Number of Neighbors = 1
 30.1.1.1        Vlan30              03:16:01 00:01:33 1           P
[DeviceF]display pim neighbor
 10.1.1.1        Vlan10              1d:00h   00:01:39 1           P
# Verify that multicast forwarding entries are generated.
<DeviceA> display multicast forwarding-table
Total 1 entries, 1 matched
00001. (10.1.1.2, 227.0.0.1)
     Flags: 0x0
     Incoming interface: Vlan-interface10
     List of 1 outgoing interfaces:
       1: Vlan-interface20
     Matched 19648 packets(20512512 bytes), Wrong If 0 packet
<DeviceB> display multicast forwarding-table
     Flags: 0x0
       1: Vlan-interface20
<DeviceC> display multicast forwarding-table
     Flags: 0x0
     Incoming interface: Vlan-interface20
       1: Vlan-interface30
<DeviceD> display multicast forwarding-table
     Flags: 0x0
       1: Vlan-interface30
# Verify that PIM multicast forwarding entries are generated.
<DeviceA> display pim routing-table
 Total 0 (*, G) entries; 1 (S, G) entries
     RP: 5.5.5.5
     Protocol: pim-sm, Flag: SPT LOC ACT
     UpTime: 02:54:43
     Upstream interface: Vlan-interface10
         1: Vlan-interface20
             Protocol: pim-sm, UpTime: 02:54:43, Expires: 00:02:47
<DeviceB> display pim routing-table
     RP: 5.5.5.5
     UpTime: 02:54:43
         1: Vlan-interface20
<DeviceC> display pim routing-table
     RP: 5.5.5.5
     UpTime: 02:54:43
     Upstream interface: Vlan-interface20
         1: Vlan-interface30
<DeviceD> display pim routing-table
     RP: 5.5.5.5
     UpTime: 02:54:43
         1: Vlan-interface30
M-LAG 1
M-LAG 2
display device
display device
display boot-loader
display boot-loader
display version
display version
M-LAG 1
M-LAG 2
display device
display device
display boot-loader
display boot-loader
display version
display version
Replacing hardware
M-LAG 1
M-LAG 2
display device
display device
display boot-loader
display boot-loader
display version
display version
Replacing hardware
M-LAG 1
M-LAG 2
display device
display device
display boot-loader
display boot-loader
display version
display version
Replacing hardware
Replace a device
M-LAG 1
M-LAG 2
display device
display device
display boot-loader
display boot-loader
display version
display version
Replacing hardware
