H3C Data Center Switches M-LAG Configuration Guide-6W101
HomeSupportConfigure & DeployConfiguration GuidesH3C Data Center Switches M-LAG Configuration Guide-6W101
11-Access to M-LAG Through Dynamic Routing and Distributed EVPN Gateways Configuration Example
Example: Access to M-LAG Through Dynamic Routing and Distributed EVPN Gateways Configuration Example
As shown in Figure 1:
·     Leaf 1 and Leaf 2 are distributed EVPN gateways that are virtualized into one M-LAG system. The peer link is an Ethernet aggregate link.
·     Spine 1 and Spine 2 act as RRs to reflect routes between the leaf devices and between the leaf and border devices.
·     Switch A and Switch B each is dual-homed to Leaf 1 and Leaf 2 through an Ethernet aggregate link. To avoid single points of failure, a Layer 2 Ethernet interface that contains member ports across devices is configured for the links connected to each VM.
·     Standalone device Leaf 3 is connected to Switch C through a Layer 2 aggregate link.
·     Switch D and Switch E each is single-homed to Leaf 1 and Leaf 2 through a physical link.
·     To forward VXLAN traffic from one M-LAG member to the other M-LAG member for single-homed ACs, the M-LAG member devices create VXLAN tunnels over the peer link.
·     For Layer 3 communication, enable a routing protocol for route advertisement between Leaf 1 and Leaf 2 and the user network. The underlay network is an IPv4 network and the overlay network is an IPv4 and IPv6 network.
Figure 1 Network diagram
Table 1 Topology and IP assignment
Device
IP address
Remarks
Leaf 1
Loopback 0
1.1.1.1/32
VTEP address
Used to establish BGP EVPN peer relationship
Loopback 1
1.2.3.4/32
Virtual VTEP address
VLAN-interface 4094
100.0.1.1/24
Attached to the link that forwards east-west traffic
HGE 1/0/25
N/A
Attached to the peer link
Connected to HGE 1/0/25 on Leaf 2
HGE 1/0/26
100.0.0.1/24
100::1/64
Attached to the keepalive link
Connected to HGE 1/0/26 on Leaf 2.
HGE 1/0/27
Borrowed from Loopback 0
Connected to HGE 1/0/4 on Spine 1.
HGE 1/0/28
Connected to HGE 1/0/4 on Spine 2.
HGE 1/0/32
N/A
AC interface
Connected to HGE 1/0/1 on Switch D
WGE 1/0/1
N/A
M-LAG group member port
Connected to Server A
WGE 1/0/2
N/A
Connected to Server B
VSI-interface 10
20.1.1.1/24
20:1:1:1::1/64
Virtual IP: 20.1.1.5/24
IPv6 virtual IP: 20:1:1:1::5/64
Gateway interface for VXLAN 100
VSI-interface 20
20.2.1.1/24
20:2:1:1::1/64
Virtual IP: 20.2.1.5/24
IPv6 virtual IP: 20:2:1:1::5/64
Gateway interface for VXLAN 101
VSI-interface 100
N/A
Associated with a L3 VXLAN ID
Leaf 2
Loopback 0
2.2.2.2/32
VTEP address
Loopback 1
1.2.3.4/32
VLAN-interface 4094
100.0.1.2/24
HGE 1/0/25
N/A
Connected to HGE 1/0/25 on Leaf 1
HGE 1/0/26
100.0.0.2/24
100::2/64
Connected to HGE 1/0/26 on Leaf 1
HGE 1/0/27
N/A
Connected to HGE 1/0/5 on Spine 1
HGE 1/0/28
N/A
Connected to HGE 1/0/5 on Spine 2
HGE 1/0/30
N/A
Single-homed AC interface
Connected to HGE 1/1/3 on Switch E
XGE 1/0/1
N/A
XGE 1/0/2
N/A
VSI-interface 10
20.1.1.1/24
20:1:1:1::1/64
Virtual IP: 20.1.1.6/24
IPv6 virtual IP: 20:1:1:1::6/64
VSI-interface 20
20.2.1.1/24
20:2:1:1::1/64
Virtual IP: 20.2.1.6/24
IPv6 virtual IP: 20:2:1:1::6/64
VSI-interface 100
N/A
Leaf 3
Loopback 0
3.3.3.3/32
VTEP address
HGE 1/0/27
Connected to HGE 1/0/6 on Spine 1
HGE 1/0/28
Connected to HGE 1/0/6 on Spine 2
XGE 1/0/1
N/A
Member port of a Layer 2 aggregate interface
Connected to Server 3
Spine 1
Loopback 0
4.4.4.4/32
VTEP address
HGE 1/0/4
N/A
Connected to HGE 1/0/27 on Leaf 1
HGE 1/0/5
N/A
Connected to HGE 1/0/27 on Leaf 2
HGE 1/0/6
N/A
Connected to HGE 1/0/27 on Leaf 3
HGE 1/0/9
30.0.0.1/24
Connected to HGE 1/0/25 on the border device
Spine 2
Loopback 0
5.5.5.5/32
VTEP address
HGE 1/0/4
N/A
Connected to HGE 1/0/28 on Leaf 1
HGE 1/0/5
N/A
Connected to HGE 1/0/28 on Leaf 2
HGE 1/0/6
N/A
Connected to HGE 1/0/28 on Leaf 3
HGE 1/0/9
31.0.0.1/24
Connected to HGE 1/0/26 on the border device
Border
Loopback 0
6.6.6.6/32
VTEP address
HGE 1/0/25
30.0.0.2/24
Connected to HGE 1/0/9 on Spine 1
HGE 1/0/26
31.0.0.2/24
Connected to HGE 1/0/9 on Spine 2
HGE 1/0/30
50.0.0.1/24
Connected to the external network
VSI-interface 100
N/A
Applicable product matrix
IMPORTANT
IMPORTANT:
In addition to running an applicable software version, you must also install the most recent patch, if any.
Role
Device
Software version
Spine
S12500X-AF
R2825
S12500R
R5210
S12500G-AF
R7625
Leaf or border
S12500G-AF (only border, not leaf)
R7625
S6800 and S6860
R6710
S6805, S6825, S6850, and S9850
R6710
S6890
R2825
S9820-64H (EVPN gateway not supported)
Not supported for EVPN gateway deployment
S9820-8C (EVPN not supported)
Not supported for EVPN deployment
S6812 and S6813
Not supported
SDN controller
N/A
Contact H3C support to verify version compatibility
Analysis
Leaf 1 and Leaf 2 form an M-LAG system and the same VSI interface on the leaf devices is assigned the same IP address and MAC address. As a result, the leaf devices cannot separately establish EBGP peer relationship with Switch A and Switch B. For Leaf 1 and Leaf 2 to separately establish EBGP peer relationship with the switches, you must assign different M-LAG virtual IP addresses to the same VSI interface on the leaf devices. Then, Leaf 1 and Leaf 2 each can use its own M-LAG virtual IP address to establish EBGP peer relationship with the switches. To configure an M-LAG virtual IP address on a VSI interface, use the port m-lag virtual-ip command.
For the servers to reach one another, configure Switch A through Switch E to import direct routes to EBGP.
M-LAG configuration
·     When Leaf 1 and Leaf 2 create VXLAN tunnels over the peer link, the tunnel source IP address is the virtual VTEP address of the M-LAG system. The tunnel destination IP address is the VTEP address of the local leaf device. When traffic from a single-homed server is forwarded from one M-LAG member to the other M-LAG member through a VXLAN tunnel created on the peer link, the latter M-LAG member cannot decapsulate the traffic. To resolve this issue, use the vxlan default-decapsulation source interface loopback 0 command on the latter M-LAG member so that the M-LAG member can decapsulate the traffic.
·     In this example, Leaf 1 is the primary device and Leaf 2 is the secondary device in the M-LAG system. When the peer link is disconnected, the links connecting Leaf 1 to Sever A and Sever B are also disconnected. However, the EBGP connections to Sever A and Sever B go down only when the BGP peer relationship expires. The convergence time is up to dozens seconds and even more than 100 seconds. To resolve this issue, use the m-lag mad include interface command on Leaf 1 to add the interfaces connected to Server A and Server B to the user-configured list of included ports. The interfaces will be shut down by M-LAG MAD when the M-LAG system splits.
·     When GIR is configured on an M-LAG member device and the M-LAG member device is isolated, traffic from single-homed interfaces on the M-LAG member device still can be forwarded to a leaf device.
·     In an EVPN distributed relay network, AC interfaces and VSI interfaces support QoS rate limit.
·     To avoid packet loss or other forwarding issues when the secondary device that has a large number of entries or is being upgraded joins the M-LAG system, use the m-lag restore-delay command to increase the data restoration interval.
Routing configuration
·     You can configure a router ID for an OSPF process or BGP instance. If you do not configure a router ID, the OSPF process or BGP instance uses the global router ID. Make sure the router ID for each device is unique in the network.
·     For the remote leaf and border devices to establish tunnels only with the M-LAG system (represented by the virtual VTEP address), use the nexthop evpn-m-lag group-address command in BGP EVPN address family view on the M-LAG member devices. When this command is used, the VXLAN tunnels established between the M-LAG member devices go down. To resolve this issue, configure a routing policy for each M-LAG member device to use its local VTEP address as the next hop of BGP EVPN routes advertised to the other M-LAG member device. The following information shows the settings:
route-policy 1 permit node 1
  if-match route-type bgp-evpn-ip-prefix
  apply ip-address next-hop 1.1.1.1
route-policy 1 deny node 10
bgp 20
  address-family l2vpn evpn
    peer 2.2.2.2 route-policy 1 export
·     As a best practice, use the nexthop evpn-m-lag group-address command. If you do not use this command, OSPF advertises the IP address of Loopback 0. When the peer link recovers from a failure or an M-LAG member device finishes reboot, the following issues exist:
¡     Traffic detour—When the peer link recovers from a failure or an M-LAG member device finishes reboot, the peer link comes up earlier than other links. The VLAN interfaces used to forward east-west traffic also come up. As a result, the tunnels between the failed M-LAG member and remote VTEPs come up before the failed M-LAG member recovers. Downstream traffic from the remote VTEPs to the failed M-LAG member is forwarded to the failed M-LAG member. Because the failed M-LAG member has not recovered, the failed M-LAG member forwards the traffic to the other M-LAG member through the peer link. In this process, detour exists for the traffic.
¡     Two traffic convergences—The first traffic convergence occurs when the peer link recovers and the second traffic convergence occurs when M-LAG MAD brings up the interfaces that were shut down when the M-LAG system split.
Procedures
Configuring leaf devices
Procedure summary
·     Configuring M-LAG settings
·     Configuring the links connected to the spine devices
·     Configuring the overlay network
·     Configuring links for dual-homed servers
·     Configuring links for single-homed servers
Leaf 1 (S6850)
Leaf 2 (S6805)
Configuration method
Remarks
m-lag system-mac cda-8037-1324
Manual or controller-based
Configure the M-LAG system MAC address.
For the M-LAG member devices to be identified as one M-LAG system, you must configure the same M-LAG system MAC address on them.
m-lag system-number 1
m-lag system-number 2
Set the M-LAG system number.
You must assign different M-LAG system numbers to the M-LAG member devices in an M-LAG system.
m-lag system-priority 100
Set the M-LAG system priority.
You must configure the same M-LAG system priority for the M-LAG member devices in an M-LAG system.
m-lag keepalive ip destination 100.0.0.2 source 100.0.0.1
m-lag keepalive ip destination 100.0.0.1 source 100.0.0.2
Specify the destination and source IP addresses of keepalive packets.
N/A
interface hundredgige 1/0/26
Enter the view of HundredGigE 1/0/26. The interface is attached to the keepalive link.
N/A
port link-mode route
Set the link mode of the keepalive interface to Layer 3.
N/A
ip address 100.0.0.1 24
ip address 100.0.0.2 24
Assign an IP address to HundredGigE 1/0/26. This IP address is the source IP address of keepalive packets.
N/A
N/A
N/A
N/A
m-lag mad default-action none
Configure M-LAG MAD to not shut down any network interfaces when the M-LAG system splits, except the interfaces configured manually or by the system to be shut down by M-LAG MAD.
N/A
m-lag restore-delay 300
Set the data restoration interval to 300 seconds.
N/A
m-lag mad include interface hundredgige 1/0/27
Add HundredGigE 1/0/27 to the user-configured list of included ports, which will be shut down by M-LAG MAD when the M-LAG system splits
N/A
m-lag mad include interface hundredgige 1/0/28
Add HundredGigE 1/0/28 to the user-configured list of included ports, which will be shut down by M-LAG MAD when the M-LAG system splits
N/A
vlan all
vlan all
Create all VLANs.
N/A
interface vlan-interface 4094
Create VLAN-interface 4094 and enter its view.
VLAN-interface 4094 is used to forward east-west traffic. The VLAN interface cannot borrow IP addresses from loopback interfaces.
ip address 100.0.1.1 24
ip address 100.0.1.2 24
Assign an IP address to the interface.
N/A
ospf 1 area 0
ospf 1 area 0
Enable OSPF process 1 on the interface.
N/A
N/A
N/A
interface bridge-aggregation 1
Create Layer 2 aggregate interface Bridge-Aggregation 1. This aggregate interface will be used as the peer-link interface.
N/A
N/A
N/A
interface hundredgige 1/0/25
Enter the view of the physical interface that will be assigned to the peer-link interface.
N/A
port link-aggregation group 1
Assign the physical interface to Bridge-Aggregation 1. Bridge-Aggregation 1 will be configured as the peer-link interface.
N/A
N/A
N/A
Enter the view of Bridge-Aggregation 1.
N/A
link-aggregation mode dynamic
Configure the aggregate interface to operate in dynamic aggregation mode
N/A
port m-lag peer-link 1
Specify the aggregate interface as the peer-link interface.
N/A
port link-type trunk
Set the link type of the aggregate interface to trunk.
N/A
port trunk permit vlan all
Assign the aggregate interface to all VLANs.
N/A
port trunk pvid vlan 4094
Set the PVID of the aggregate interface to 4094.
VLAN 4094 is a VLAN used to provide services when all services become unavailable.
undo mac-address static source-check enable
Enable the static source check feature.
No need to configure this command on the S6890 switches.
flow-interval 5
flow-interval 5
Set the statistics polling interval to 5 seconds on the aggregate interface.
N/A
N/A
N/A
Leaf 1 (S6850)
Leaf 2 (S6805)
Leaf 3 (S6805)
Remarks
Create interface Loopback 0 and enter its view.
N/A
ip address 1.1.1.1 32
ip address 2.2.2.2 32
ip address 3.3.3.3 32
This IP address will be used as the VTEP address. Make sure each device is assigned a unique VTEP address.
N/A
N/A
interface loopback 1
N/A
Create interface Loopback 1 and enter its view.
 N/A
ip address 1.2.3.4 32
N/A
Specify this IP address as the virtual VTEP address when you enable EVPN distributed relay.
N/A
N/A
N/A
ospf 1 router-id 1.1.1.1
ospf 1 router-id 2.2.2.2
ospf 1 router-id 3.3.3.3
Enable OSPF process 1 and enter OSPF process view.
N/A
non-stop-routing
non-stop-routing
non-stop-routing
Enable NSR for the OSPF process.
N/A
stub-router include-stub on-startup 900
Configure the router as a stub router during reboot and specify the timeout time to 900 seconds to accelerate network convergence.
N/A
area 0.0.0.0
area 0.0.0.0
area 0.0.0.0
Create an OSPF area and enter OSPF area view or OSPF IPv4 unicast topology area view.
N/A
network 1.1.1.1 0.0.0.0
network 2.2.2.2 0.0.0.0
network 3.3.3.3 0.0.0.0
Enable OSPF on the interface attached to the specified network in the area.
N/A
network 1.2.3.4 0.0.0.0
N/A
N/A
N/A
N/A
N/A
N/A
interface range hundredgige 1/0/27 hundredgige 1/0/28
Enter the interface range view of the interfaces connected to the spine devices.
N/A
Set the link mode of the interfaces to Layer 3.
N/A
flow-interval 5
flow-interval 5
flow-interval 5
Set the statistics polling interval to 5 seconds on the interfaces.
N/A
ip address unnumbered interface loopback 0
Configure the interfaces to borrow the IP address of interface Loopback 0.
N/A
ospf network-type p2p
Set the OSPF network type to P2P on the interfaces.
N/A
ospf 1 area 0.0.0.0
ospf 1 area 0.0.0.0
ospf 1 area 0.0.0.0
Enable OSPF process 1 on the interfaces.
N/A
ospf peer hold-max-cost duration 20000
Enable OSPF to advertise the maximum link cost to neighbors within 20000 milliseconds.
Route convergence optimization.
lldp management-address arp-learning
Configure the interfaces to generate an ARP entry after receiving an LLDP frame that carries a management address TLV.
N/A
lldp tlv-enable basic-tlv management-address-tlv interface loopback 0
Configure the types of advertisable TLVs on the interfaces.
N/A
Disable the static source check feature.
N/A
N/A
N/A
bgp 20
bgp 20
bgp 20
Create BGP instance 20 and enter its view.
N/A
router-id 1.1.1.1
router-id 2.2.2.2
router-id 3.3.3.3
Specify a router ID for the BGP instance.
N/A
peer 4.4.4.4 as-number 20
Create BGP peer 4.4.4.4 and specify AS number 20 for the peer.
N/A
peer 4.4.4.4 connect-interface loopback 0
Specify Loopback 0 as the source interface for establishing TCP connections to peer 4.4.4.4.
N/A
peer 5.5.5.5 as-number 20
Create BGP peer 5.5.5.5 and specify AS number 20 for the peer.
N/A
peer 5.5.5.5 connect-interface loopback 0
Specify Loopback 0 as the source interface for establishing TCP connections to peer 5.5.5.5.
N/A
Enter BGP EVPN address family view.
N/A
Enable the device to replace the next hop in advertised BGP EVPN routes with the virtual VTEP address.
N/A
peer 4.4.4.4 enable
peer 4.4.4.4 enable
peer 4.4.4.4 enable
Enable the local router to exchange unicast routing information with peer 4.4.4.4.
N/A
peer 5.5.5.5 enable
peer 5.5.5.5 enable
peer 5.5.5.5 enable
Enable the local router to exchange unicast routing information with peer 5.5.5.5.
N/A
N/A
N/A
N/A
N/A
Leaf 1 (S6850)
Leaf 2 (S6805)
Leaf 3 (S6805)
Remarks
ip vpn-instance vpn1
Create VPN instance vpn1 and enter its view, or directly enter the view of the VPN instance if the VPN instance already exists.
N/A
route-distinguisher 1:100
route-distinguisher 1:101
route-distinguisher 1:102
Configure an RD for the VPN instance.
N/A
address-family ipv4
address-family ipv4
address-family ipv4
Enter VPN instance IPv4 address family view.
N/A
vpn-target 1:100
vpn-target 1:100
vpn-target 1:100
Configure a route target for the VPN instance.
N/A
address-family ipv6
address-family ipv6
address-family ipv6
Enter VPN instance IPv6 address family view.
N/A
vpn-target 1:100
vpn-target 1:100
vpn-target 1:100
N/A
address-family evpn
address-family evpn
address-family evpn
Enter VPN instance EVPN view.
N/A
vpn-target 1:100
vpn-target 1:100
vpn-target 1:100
Configure a route target for EVPN.
N/A
N/A
N/A
N/A
N/A
l2vpn enable
l2vpn enable
l2vpn enable
Enable L2VPN.
N/A
l2vpn m-lag peer-link ac-match-rule vxlan-mapping
N/A
Enable the device to create frame match criteria based on VXLAN IDs for the dynamic ACs on the Ethernet aggregate link peer link.
N/A
Disable remote-MAC address learning.
N/A
vxlan tunnel arp-learning disable
Disable remote ARP learning for VXLANs.
N/A
vxlan tunnel nd-learning disable
Disable remote ND learning for VXLANs.
N/A
evpn m-lag group 1.2.3.4
N/A
Enable EVPN distributed relay and specify the virtual VTEP address.
N/A
evpn global-mac 1-1-1
evpn global-mac 2-2-2
Configure the EVPN global MAC address.
N/A
Enable default IPv4 VXLAN decapsulation.
N/A
interface vsi-interface 10
interface vsi-interface 30
Create VSI-interface 10 and enter its view.
N/A
ip binding vpn-instance vpn1
Associate VPN instance vpn1 with the VSI interface.
N/A
ip address 20.1.1.1 24
ip address 20.3.1.1 24
Assign an IP address to the VSI interface.
N/A
mac-address 0001-0001-0002
mac-address 0001-0001-0004
Assign a MAC address to the VSI interface.
N/A
local-proxy-arp enable
Enable local proxy ARP.
N/A
ipv6 address 20:1:1:1::1/64
ipv6 address 20:3:1:1::1/64
Assign an IPv6 global unicast address to the VSI interface.
N/A
distributed-gateway local
Specify the VSI interface as a distributed gateway.
N/A
N/A
N/A
interface vsi-interface 20
N/A
Create VSI-interface 20 and enter its view.
N/A
N/A
N/A
ip address 20.2.1.1 24
N/A
N/A
mac-address 0001-0001-0003
N/A
N/A
N/A
N/A
ipv6 address 20:2:1:1::1/64
N/A
N/A
N/A
N/A
N/A
N/A
N/A
interface vsi-interface 100
Create VSI-interface 100 and enter its view.
N/A
description L3_vni
description L3_vni
description L3_vni
Configure a description for the VSI interface.
N/A
N/A
l3-vni 1000
l3-vni 1000
l3-vni 1000
Associate Layer 3 VXLAN ID 1000 with the VSI interface.
N/A
N/A
N/A
vsi vni_100
vsi vni_100
vsi vni_102
Create a VSI and enter its view, or directly enter the view of the VSI if the VPN instance already exists.
N/A
gateway vsi-interface 10
gateway vsi-interface 30
Specify a gateway for the VSI.
N/A
vxlan 100
vxlan 100
vxlan 102
Create a VXLAN and enter its view, or enter the view of the VXLAN if the VXLAN already exists.
N/A
N/A
N/A
evpn encapsulation vxlan
Create an EVPN instance on the VSI.
N/A
Configure an RD for the EVPN instance.
N/A
vpn-target 1:100 both
vpn-target 1:102 both
Configure route targets for the EVPN instance.
N/A
N/A
N/A
N/A
N/A
vsi vni_101
vsi vni_101
N/A
N/A
gateway vsi-interface 20
N/A
N/A
vxlan 101
vxlan 101
N/A
N/A
N/A
N/A
N/A
N/A
N/A
N/A
N/A
vpn-target 1:101 both
N/A
N/A
N/A
N/A
N/A
N/A
N/A
N/A
Leaf 1 (S6850)
Leaf 2 (S6805)
Leaf 3 (S6805)
Remarks
interface bridge-aggregation 2
Create a Layer 2 aggregate interface and enter its view. The Layer 2 aggregate interface on each device is connected to a server.
N/A
Configure the Layer 2 aggregation group to operate in dynamic aggregation mode.
N/A
port m-lag group 1
port m-lag group 1
N/A
Assign Bridge-Aggregation 2 to M-LAG group 1.
N/A
stp edged-port
stp edged-port
stp edged-port
Configure the Layer 2 aggregate interface as an edge port for the spanning tree feature.
N/A
Set the link type of the Layer 2 aggregate interface to trunk.
N/A
undo port trunk permit vlan 1
Remove the Layer 2 aggregate  interface from VLAN 1.
N/A
port trunk permit vlan 10 20
port trunk permit vlan 30
Assign the Layer 2 aggregate  interface to the specified VLANs.
N/A
service-instance 10
service-instance 10
service-instance 30
Create an Ethernet service instance.
N/A
encapsulation s-vid 10
encapsulation s-vid 30
Configure a frame match criterion for the Ethernet service instance.
N/A
xconnect vsi vni_100
xconnect vsi vni_102
Map the Ethernet service instance to a VSI.
N/A
N/A
N/A
N/A
service-instance 20
service-instance 20
N/A
N/A
encapsulation s-vid 20
N/A
N/A
xconnect vsi vni_101
N/A
N/A
N/A
N/A
N/A
N/A
interface twenty-fivegige 1/0/1
interface ten-gigabitethernet 1/0/2
interface ten-gigabitethernet 1/0/1
Enter the view of a physical interface connected to a server.
N/A
speed 10000
N/A
N/A
Set the interface speed to 10 Gbps.
N/A
flow-interval 5
flow-interval 5
flow-interval 5
Set the statistics polling interval to 5 seconds on the interface.
N/A
Set the link type of the interface to trunk.
N/A
Remove the interface from VLAN 1.
N/A
Assign the interface to the specified VLANs.
N/A
port link-aggregation group 2
Assign the interface to the Layer 2 aggregate interface created for server connection.
N/A
N/A
N/A
interface bridge-aggregation 3
N/A
Create Bridge-Aggregation 3. The aggregate interface is connected to a server.
N/A
interface twenty-fivegige 1/0/2
N/A
N/A
speed 10000
N/A
N/A
N/A
flow-interval 5
flow-interval 5
N/A
N/A
N/A
N/A
N/A
N/A
N/A
N/A
port link-aggregation group 3
N/A
Assign the interface to a Layer 2 aggregate interface.
N/A
N/A
N/A
N/A
N/A
Enter the view of VSI-interface 10.
N/A
port m-lag virtual-ip 20.1.1.5 24 active
port m-lag virtual-ip 20.1.1.6 24 active
N/A
Assign an M-LAG virtual IPv4 address to the VSI interface.
Make sure you assign different M-LAG virtual IPv4 addresses to the same VSI interface on the M-LAG member devices in one M-LAG system.
port m-lag ipv6 virtual-ip 20:1:1:1::5 64 active
port m-lag ipv6 virtual-ip 20:1:1:1::6 64 active
N/A
Assign an M-LAG virtual IPv6 address to the VSI interface.
Make sure you assign different M-LAG virtual IPv6 addresses to the same VSI interface on the M-LAG member devices in one M-LAG system.
N/A
N/A
N/A
N/A
Enter the view of VSI-interface 20.
N/A
port m-lag virtual-ip 20.2.1.5 24 active
port m-lag virtual-ip 20.2.1.6 24 active
N/A
port m-lag ipv6 virtual-ip 20:2:1:1::5 64 active
port m-lag ipv6 virtual-ip 20:2:1:1::6 64 active
N/A
N/A
N/A
N/A
bgp 20
bgp 20
bgp 20
Enter BGP instance view.
N/A
Create BGP-VPN instance vpn1 and enter BGP-VPN instance view.
N/A
peer 20.1.1.10 as-number 10
peer 20.3.1.10 as-number 10
Create a BGP peer and specify its AS number.
Leaf 3 does not form an M-LAG system with any device. Leaf 3 uses the primary IP address of the VSI interface to establish BGP peer relationship with other devices.
peer 20.1.1.10 source-address 20.1.1.5
peer 20.1.1.10 source-address 20.1.1.6
peer 20:3:1:1::10 as-number 10
Specify a source IPv4 address for establishing TCP connections to a peer.
N/A
peer 20.2.1.10 as-number 10
N/A
Create a BGP peer for the server at 20.2.1.10 and specify its AS number.
N/A
peer 20.2.1.10 source-address 20.2.1.5
peer 20.2.1.10 source-address 20.2.1.6
N/A
Specify a source IPv4 address for establishing TCP connections to peer 20.2.1.10.
N/A
peer 20:1:1:1::10 as-number 10
N/A
Create a BGP peer for the server at 20:1:1:1::10 and specify its AS number.
N/A
peer 20:1:1:1::10 source-address 20:1:1:1::5
peer 20:1:1:1::10 source-address 20:1:1:1::6
N/A
Specify a source IPv6 address for establishing TCP connections to peer 20:1:1:1::10.
N/A
peer 20:2:1:1:: 10 as-number 10
N/A
Create a BGP peer for the server at 20:2:1:1:: 10 and specify its AS number.
N/A
peer 20:2:1:1::10 source-address 20:2:1:1::5
peer 20:2:1:1::10 source-address 20:2:1:1::6
N/A
Specify a source IPv6 address for establishing TCP connections to peer 20:2:1:1::10.
N/A
address-family ipv4 unicast
Create the BGP-VPN IPv4 unicast address family view and enter its view.
N/A
balance 4
balance 4
balance 4
Enable load balancing and set the maximum number of BGP ECMP routes used for load balancing to 4.
This step is optional for Leaf 3.
peer 20.1.1.10 enable
peer 20.3.1.10 enable
Enable the local router to exchange unicast routing information with a peer.
N/A
peer 20.2.1.10 enable
N/A
N/A
N/A
N/A
address-family ipv6 unicast
Create the BGP-VPN IPv6 unicast address family and enter its view.
N/A
balance 4
balance 4
balance 4
peer 20:1:1:1::10 enable
peer 20:3:1:1::10 enable
N/A
peer 20:2:1:1::10 enable
N/A
N/A
N/A
N/A
N/A
N/A
N/A
N/A
Leaf 1 (S6850)
Leaf 2 (S6805)
Remarks
interface hundredgige 1/0/32
Interface hundredgige 1/0/30
Enter the view of the interface connected to Switch.
N/A
flow-interval 5
flow-interval 5
N/A
stp edged-port
stp edged-port
Configure the interface as an edge port for the spanning tree feature.
N/A
N/A
N/A
Assign the interface to VLAN 10.
N/A
service-instance 10
service-instance 10
Create Ethernet service instance 10.
N/A
Configure the Ethernet service instance to match traffic in VLAN 10.
N/A
Map the Ethernet service instance to VSI vni_100.
N/A
N/A
N/A
N/A
N/A
N/A
N/A
interface hundredgige  1/0/30
Enter the view of the interface connected to a server.
N/A
port trunk permit vlan 20
Assign the interface to VLAN 20.
N/A
service-instance 20
service-instance 20
Create Ethernet service instance 20.
N/A
Configure the Ethernet service instance to match traffic in VLAN 20.
N/A
Map the Ethernet service instance to VSI vni_101.
N/A
N/A
N/A
N/A
N/A
N/A
N/A
Create a routing policy and enter its view, and specify the permit match mode for the routing policy node.
N/A
Configure the node to match IP prefix advertisement routes of BGP EVPN.
Permit the subnet of the single-homed server.
apply ip-address next-hop 2.2.2.2
Set a next hop for the matching IPv4 routes.
Specify the VTEP address of each leaf device as the next hop for the leaf devices to establish tunnels between them.
N/A
N/A
N/A
Create a routing policy and enter its view, and specify the deny match mode for the routing policy node.
Deny addresses in other subnets except the subnet of the single-homed server.
N/A
N/A
N/A
bgp 20
bgp 20
N/A
peer 2.2.2.2 as-number 20
peer 1.1.1.1 as-number 20
Configure EVPN settings between the leaf devices.
peer 2.2.2.2 connect-interface loopback 0
peer 1.1.1.1 connect-interface loopback 0
Specify a source interface for establishing TCP connections to a peer or peer group.
Specify Loopback 0 as the source interface for establishing TCP connection between the leaf devices.
N/A
peer 2.2.2.2 enable
peer 1.1.1.1 enable
N/A
peer 1.1.1.1 route-policy 1 export
Apply a routing policy to routes outgoing to a peer in order to filter the routes and modify the route attributes.
N/A
N/A
N/A
N/A
Enter BGP-VPN instance view.
N/A
peer 20.1.1.11 as-number 10
Create BGP peer 20.1.1.11 and specify AS number 10 for the peer.
N/A
peer 20.1.1.11 source-address 20.1.1.5
peer 20.1.1.11 source-address 20.1.1.6
Specify a source IPv4 address  for establishing TCP connections to peer 20.1.1.11.
Specify the M-LAG virtual IPv4 address on each leaf device as the source IPv4 address for establishing TCP connections to a peer single-homed to the M-LAG system.
peer 20.2.1.11 as-number 10
Create BGP peer 20.2.1.11 and specify AS number 10 for the peer.
N/A
peer 20.2.1.11 source-address 20.2.1.5
peer 20.2.1.11 source-address 20.2.1.6
Specify a source IPv4 address for establishing TCP connections to peer 20.2.1.11.
peer 20:1:1:1::11 as-number 10
Create BGP peer 20:1:1:1::11 and specify AS number 10 for the peer.
N/A
peer 20:1:1:1::11 source-address 20:1:1:1::5
peer 20:1:1:1::11 source-address 20:1:1:1::6
Specify a source IPv6 address  for establishing TCP connections to peer 20:1:1:1::11.
Specify the M-LAG virtual IPv6 address on each leaf device as the source IPv6 address for establishing TCP connections to a peer single-homed to the M-LAG system.
peer 20:2:1:1::11 as-number 10
Create BGP peer 20:2:1:1::11 and specify AS number 10 for the peer.
N/A
peer 20:2:1:1::11 source-address 20:2:1:1::5
peer 20:2:1:1::11 source-address 20:2:1:1::6
Specify a source IPv6 address  for establishing TCP connections to peer 20:2:1:1::11.
Enter BGP-VPN IPv4 unicast address family view.
N/A
peer 20.1.1.11 enable
Enable the local router to exchange unicast routing information with peer 20.1.1.11.
N/A
peer 20.2.1.11 enable
Enable the local router to exchange unicast routing information with peer 20.2.1.11.
N/A
Enter BGP-VPN IPv6 unicast address family view.
N/A
peer 20:1:1:1::11 enable
Enable the local router to exchange unicast routing information with peer 20:1:1:1::11.
N/A
peer 20:2:1:1::11 enable
Enable the local router to exchange unicast routing information with peer 20:2:1:1::11.
N/A
Configuring spine devices
Procedure summary
·     Configuring the links connected to the leaf devices
·     Configuring the link connected to the border device
Spine 1
Spine 2
Remarks
ospf 1 router-id 4.4.4.4
ospf 1 router-id 5.5.5.5
N/A
non-stop-routing
non-stop-routing
N/A
N/A
N/A
N/A
N/A
Create interface Loopback 0 and enter loopback interface view.
N/A
ip address 4.4.4.4 32
ip address 5.5.5.5 32
This IP address will be used as the VTEP address for each spine device. Make sure the VTEP address of each spine device is unique in the network.
ospf 1 area 0
ospf 1 area 0
N/A
N/A
N/A
N/A
interface range hundredgige 1/0/4 to hundredgige 1/0/6
Enter the interface range view of the interfaces connected to the leaf devices.
N/A
N/A
flow-interval 5
flow-interval 5
N/A
N/A
Specify the OSPF network type for the interfaces as P2P.
N/A
ospf 1 area 0.0.0.0
ospf 1 area 0.0.0.0
N/A
N/A
N/A
N/A
N/A
N/A
bgp 20
bgp 20
Create BGP instance 20 and enter BGP instance view.
N/A
non-stop-routing
non-stop-routing
Enable NSR for the BGP instance.
N/A
router-id 4.4.4.4
router-id 5.5.5.5
Specify a unique router ID for the BGP instance on each spine device.
This step is optional.
group evpn internal
group evpn internal
Create IBGP peer group evpn.
N/A
peer evpn connect-interface loopback 0
Specify source interface Loopback 0 for establishing TCP connections to the peer group.
N/A
peer 1.1.1.1 group evpn
Add peer 1.1.1.1 to peer group evpn.
N/A
peer 2.2.2.2 group evpn
Add peer 2.2.2.2 to peer group evpn.
N/A
peer 3.3.3.3 group evpn
Add peer 3.3.3.3 to peer group evpn.
N/A
N/A
undo policy vpn-target
Disable route target filtering for BGP EVPN routes.
N/A
peer evpn enable
peer evpn enable
Enable the local router to exchange unicast routing information with peer group evpn.
N/A
peer evpn reflect-client
Configure the device as a route reflector and specify peer group evpn as a client.
N/A
N/A
N/A
N/A
N/A
N/A
N/A
Spine 1
Spine 2
Remarks
interface hundredgige 1/0/9
Enter the view of the interface connected to the border device.
N/A
flow-interval 5
flow-interval 5
N/A
ip address 30.0.0.1 24
ip address 31.0.0.1 24
N/A
ospf 1 area 0
ospf 1 area 0
N/A
N/A
N/A
N/A
bgp 20
bgp 20
N/A
peer 6.6.6.6 as-number 30
N/A
peer 6.6.6.6 connect-interface loopback 0
Specify source interface Loopback 0 for establishing TCP connections to peer 6.6.6.6.
N/A
peer 6.6.6.6 ebgp-max-hop 64
Enable BGP to establish EBGP sessions to indirectly connected EBGP peer 6.6.6.6, and set the maximum hop count to 64.
N/A
N/A
peer 6.6.6.6 enable
peer 6.6.6.6 enable
Enable the local router to exchange unicast routing information with a peer or peer group.
N/A
peer 6.6.6.6 next-hop-invariable
Configure the device to not change the next hop of routes advertised to an EBGP peer or peer group.
The border and spine devices establish EBGP peer relationship. For the leaf devices to establish tunnels with the border devices, you must perform this task.
N/A
N/A
N/A
Configuring the border device
Procedure summary
·     Configuring routing for communication with the external network
Border
Remarks
Create VPN instance vpn1 and enter VPN instance view.
N/A
route-distinguisher 1:106
N/A
address-family ipv4
N/A
Configure route targets for the VPN instance.
N/A
N/A
N/A
N/A
address-family ipv6
N/A
N/A
N/A
N/A
N/A
address-family evpn
N/A
Configure route targets for EVPN.
N/A
N/A
N/A
N/A
N/A
N/A
N/A
Create VSI-interface100 and enter VSI interface view.
N/A
description L3_vni
N/A
N/A
l3-vni 1000
N/A
N/A
N/A
N/A
Border
Remarks
ospf 1 router-id 6.6.6.6
N/A
non-stop-routing
N/A
N/A
N/A
N/A
N/A
N/A
ip address 6.6.6.6 32
This IP address will be used as the VTEP address of the device. Make sure the VTEP address is unique in the network.
ospf 1 area 0
N/A
N/A
N/A
N/A
Enter the view of the interface connected to Spine 1.
N/A
Set the link mode of the interface to Layer 3.
N/A
flow-interval 5
N/A
ip address 30.0.0.2 24
N/A
ospf 1 area 0
N/A
N/A
N/A
N/A
Enter the view of the interface connected to Spine 2.
N/A
N/A
flow-interval 5
N/A
ip address 31.0.0.2 24
N/A
ospf 1 area 0
N/A
N/A
N/A
N/A
bgp 30
Create BGP instance 30 and enter its view.
N/A
non-stop-routing
N/A
router-id 6.6.6.6
N/A
group spine external
Create an EBGP peer group named spine.
N/A
peer spine as-number 20
Specify AS number 20 for the peer group.
N/A
peer spine connect-interface loopback 0
N/A
peer spine ebgp-max-hop 64
Enable the local router to establish EBGP sessions to indirectly connected EBGP peers in peer group spine, and set the maximum hop count to 64.
N/A
peer 4.4.4.4 group spine
Add peer 4.4.4.4 to peer group spine.
N/A
peer 5.5.5.5 group spine
Add peer 5.5.5.5 to peer group spine.
N/A
N/A
peer spine enable
Enable the local router to exchange unicast routing information with peer group spine.
N/A
N/A
N/A
N/A
N/A
N/A
N/A
Border
Remarks
Enter the view of the interface connected to the external network.
N/A
N/A
Associate VPN instance vpn1 with the interface.
N/A
ip address 50.0.0.1 24
Assign an IPv4 address to the interface.
N/A
ipv6 address 50::1/64
Assign an IPv6 address to the interface.
N/A
N/A
N/A
N/A
ip route-static vpn-instance vpn1 50.0.0.0 16 50.0.0.2
Configure a static route.
N/A
ipv6 route-static vpn-instance vpn1 50:: 32 50::2
Configure an IPv6 static route.
N/A
bgp 30
N/A
N/A
Create the BGP-VPN IPv4 unicast address family and enter its view.
N/A
default-route imported
Enable default route redistribution into the BGP routing table.
N/A
balance 4
N/A
import-route static
Import static routes to the BGP routing table for BGP to advertise the imported routes.
N/A
N/A
N/A
balance 4
N/A
import-route static
N/A
N/A
N/A
N/A
Overlay traffic forwarding models
Overlay traffic characteristics
The following table describes overlay traffic characteristics:
Parameter
No.
Overlay traffic number in the format of O-4-xxx or O-6-xxx.
O represents overlay, 4 represents IPv4, 6 represents IPv6, and xxx represents a number.
Traffic type
Traffic types include broadcast, Layer 2 unicast, Layer 2 unknown unicast, Layer 2 multicast, Layer 2 unknown multicast, IPv4 known unicast, IPv6 known unicast, IPv4 multicast, IPv6 multicast, DHCP, and MPLS.
Direction
Traffic direction.
Traffic can be forwarded from south to north, north to south, from east to west, or from east to west. The traffic can pass through one leaf device or multiple leaf devices or within a data center or across data centers.
Forwarding path
List of nodes that the traffic passes through, for example, Server A > Leaf 1 & 2 > Spine 2 > Leaf 2 > Server B.
Traffic simulation
Traffic simulation in the test.
The name of IPv4 traffic is suffixed with V4_ and the name of IPv6 traffic is suffixed with V6_. Use a switch and a tester to simulate a server.
The following types of traffic is injected:
·     Server A sends 10K ARP or ND request traffic to Server B.
·     Server B replies to the ARP or ND request traffic of Server A. The traffic amount is also 10K.
·     Traffic is sent between the servers and between the servers and the external network. The source port of each flow changes 100th times.
·     20K traffic is sent from each server to the external network through the border.
Load
Traffic load is light or heavy.
If the number of flows is less than 1000, the load is light.
If the number of flows is more than 1000, the load is heavy. If the load is heavy, enter the actual load for the load parameter.
Traffic direction to  firewalls/LB
Enter the method used to direct traffic to firewalls or LBs. The value can be N/A, PBR, M-LAG and VRRP, or static route.
Overlay IPv4 traffic forwarding models
No.
Traffic type
Direction
Forwarding path
Traffic simulation
Load
O-4-001
Broadcast
N/A
Server A > Leaf 1
Tester
Light
N/A
O-4-002
IPv4 known unicast
From a server dual-homed to one leaf device to the other server dual-homed to the same leaf device
East to west
Server A > Leaf 1 & 2 > Server B
Tester
Light
N/A
O-4-003
IPv4 known unicast
From a server dual-homed to one leaf device to a server single-homed to another leaf device
East to west
Server A > Leaf 1 & 2 > Spine > Leaf 3 > Server C
Tester
Light
N/A
O-4-004
IPv4 known unicast
From a server dual-homed to one leaf device to a server single-homed to the same leaf device
East to west
Server A > Leaf 1 & 2 > Leaf 1 > Server D
Tester
Light
N/A
O-4-005
IPv4 known unicast
South to north
Server A > Leaf 1 & 2 > Spine > External network
Tester
Light
N/A
O-4-006
IPv4 known unicast
East to west
Server A > Leaf 1 & 2 > Leaf 2 > Server E
Tester
Light
N/A
O-4-007
IPv4 known unicast
East to west
Server B > Leaf 1 & 2 > Server A
Tester
Light
N/A
O-4-008
IPv4 known unicast
East to west
Server B > Leaf 1 & 2 > Spine > Leaf 3 > Server C
Tester
Light
N/A
O-4-009
IPv4 known unicast
East to west
Server B > Leaf 1 & 2 > Leaf 1 > Server D
Tester
Light
N/A
O-4-010
IPv4 known unicast
South to north
Server B > Leaf 1 & 2 > Spine > External network
Tester
Light
N/A
O-4-011
IPv4 known unicast
East to west
Server B > Leaf 1 & 2 > Leaf 2 > Server E
Tester
Light
N/A
O-4-012
IPv4 known unicast
From a server single-homed to one leaf device to a server dual-homed to another leaf device
East to west
Server C > Leaf 3 > Spine > Leaf 1 & 2 > Server A
Tester
Light
N/A
O-4-013
IPv4 known unicast
East to west
Server C > Leaf 3 > Spine > Leaf 1 & 2 > Server B
Tester
Light
N/A
O-4-014
IPv4 known unicast
From a server single-homed to one leaf device to a server single-homed to another leaf device
East to west
Server C > Leaf 3 > Spine > Leaf 1 & 2 > Leaf 1 > Server D
Tester
Light
N/A
O-4-015
IPv4 known unicast
South to north
Server C > Leaf 3 > Spine > Border > External network
Tester
Light
N/A
O-4-016
IPv4 known unicast
East to west
Server C > Leaf 3 > Spine > Leaf 1 & 2 > Leaf 2 > Server E
Tester
Light
N/A
O-4-017
IPv4 known unicast
From a server single-homed to one leaf device to a server dual-homed to the same leaf device
East to west
Server D > Leaf 1 > Server A
Tester
Light
N/A
O-4-018
IPv4 known unicast
East to west
Server D > Leaf 1 & 2 > Server B
Tester
Light
N/A
O-4-019
IPv4 known unicast
East to west
Server D > Leaf 1 > Spine > Leaf 3 > Server C
Tester
Light
N/A
O-4-020
IPv4 known unicast
South to north
Server D > Leaf 1 > Spine > Border > External network
Tester
Light
N/A
O-4-021
IPv4 known unicast
From a server single-homed to one leaf device to a server single-homed to the same leaf device
East to west
Server D > Leaf 1 > Leaf 2 > Server E
Tester
Light
N/A
O-4-022
IPv4 known unicast
North to south
External network > Border > Spine > Leaf 1 & 2 > Server A
Tester
Light
N/A
O-4-023
IPv4 known unicast
North to south
External network > Border > Spine > Leaf 1 & 2 > Server B
Tester
Light
N/A
O-4-024
IPv4 known unicast
North to south
External network > Border > Spine > Leaf 3 > Server C
Tester
Light
N/A
O-4-025
IPv4 known unicast
North to south
External network > Border > Spine > Leaf 1 & 2 > Leaf 1 > Server D
Tester
Light
N/A
O-4-026
IPv4 known unicast
North to south
External network > Border > Spine > Leaf 1 & 2 > Leaf 2 > Server E
Tester
Light
N/A
O-4-027
IPv4 known unicast
East to west
Server E > Leaf 2 > Server A
Tester
Light
N/A
O-4-028
IPv4 known unicast
East to west
Server E > Leaf 2 > Server B
Tester
Light
N/A
O-4-029
IPv4 known unicast
East to west
Server E > Leaf 2 > Spine > Leaf 3 > Server C
Tester
Light
N/A
O-4-030
IPv4 known unicast
East to west
Server E > Leaf 2 > Leaf 1 > Server D
Tester
Light
N/A
O-4-031
IPv4 known unicast
South to north
Server E > Leaf 2 > Spine > Border > External network
Tester
Light
N/A
Overlay IPv6 traffic forwarding models
No.
Traffic type
Direction
Forwarding path
Traffic simulation
Load
O-6-001
Broadcast
N/A
Server A > Leaf 1
Tester
Light
N/A
O-6-002
IPv6 known unicast
East to west
Tester
Light
N/A
O-6-003
IPv6 known unicast
East to west
Tester
Light
N/A
O-6-004
IPv6 known unicast
East to west
Tester
Light
N/A
O-6-005
IPv6 known unicast
South to north
Tester
Light
N/A
O-6-006
IPv6 known unicast
East to west
Tester
Light
N/A
O-6-007
IPv6 known unicast
East to west
Tester
Light
N/A
O-6-008
IPv6 known unicast
East to west
Tester
Light
N/A
O-6-009
IPv6 known unicast
East to west
Tester
Light
N/A
O-6-010
IPv6 known unicast
South to north
Tester
Light
N/A
O-6-011
IPv6 known unicast
East to west
Tester
Light
N/A
O-6-012
IPv6 known unicast
East to west
Tester
Light
N/A
O-6-013
IPv6 known unicast
East to west
Tester
Light
N/A
O-6-014
IPv6 known unicast
East to west
Tester
Light
N/A
O-6-015
IPv6 known unicast
South to north
Tester
Light
N/A
O-6-016
IPv6 known unicast
East to west
Tester
Light
N/A
O-6-017
IPv6 known unicast
East to west
Tester
Light
N/A
O-6-018
IPv6 known unicast
East to west
Tester
Light
N/A
O-6-019
IPv6 known unicast
East to west
Tester
Light
N/A
O-6-020
IPv6 known unicast
South to north
Tester
Light
N/A
O-6-021
IPv6 known unicast
East to west
Tester
Light
N/A
O-6-022
IPv6 known unicast
North to south
Tester
Light
N/A
O-6-023
IPv6 known unicast
North to south
Tester
Light
N/A
O-6-024
IPv6 known unicast
North to south
Tester
Light
N/A
O-6-025
IPv6 known unicast
North to south
Tester
Light
N/A
O-6-026
IPv6 known unicast
North to south
Tester
Light
N/A
O-6-027
IPv6 known unicast
East to west
Tester
Light
N/A
O-6-028
IPv6 known unicast
East to west
Tester
Light
N/A
O-6-029
IPv6 known unicast
East to west
Tester
Light
N/A
O-6-030
IPv6 known unicast
East to west
Tester
Light
N/A
O-6-031
IPv6 known unicast
South to north
Tester
Light
N/A
Testing network convergence
Overlay IPv4 network convergence
Device
Failure type
Traffic interruption time
Recovery type
Leaf
Single point of failure for ECMP uplinks
< 500 ms
Recovery from single point of failure for ECMP uplinks
< 150 ms
Single point of failure for M-LAG member links
< 500 ms
Recovery from single point of failure for M-LAG member links
< 150 ms
Peer link failure
< 500 ms
Peer link failure recovery
< 150 ms
Keepalive link failure
0 ms
Keepalive link failure recovery
0 ms
Device rebooting
< 500 ms
Device reboot recovery
< 150 ms
Upgrading a device
< 500 ms
N/A
N/A
Expanding the network
< 500 ms
N/A
N/A
Replacing hardware
< 500 ms
N/A
N/A
Spine
Device rebooting
< 500 ms
< 150 ms
Upgrading a device
< 500 ms
N/A
N/A
Overlay IPv6 network convergence
Device
Failure type
Recovery type
Leaf
< 500 ms
< 150 ms
< 500 ms
< 150 ms
Peer link failure
< 500 ms
< 150 ms
0 ms
Recovery from keepalive link failure
0 ms
Device rebooting
< 500 ms
< 150 ms
Spine
Device rebooting
< 500 ms
< 150 ms
Verification commands
Leaf 1
Leaf 2
display m-lag summary
Displays summary information about the peer-link interface and M-LAG interfaces.
display m-lag system
Displays the M-LAG system settings.
display m-lag keepalive
Displays M-LAG keepalive packet statistics.
display m-lag role
display m-lag role
Displays M-LAG role information.
display m-lag consistency { type1 | type2 }
Displays information about the configuration consistency check done by M-LAG.
display m-lag consistency-check status
Displays the configuration consistency check status.
display interface Bridge-Aggregation [ brief ]
Displays information about Layer 2 aggregate interfaces.
display m-lag virtual-ip
Displays M-LAG virtual IP addresses.
display stp brief
display stp brief
Displays brief spanning tree status and statistics.
# On Leaf 1, verify that Leaf 1 and Leaf 2 have formed an M-LAG system.
<Leaf 1> display m-lag summary
Flags: A -- Aggregate interface down, B -- No peer M-LAG interface configured
       C -- Configuration consistency check failed
Peer-link interface: BAGG1
Peer-link interface state (cause): UP
Keepalive link state (cause): UP
                     M-LAG interface information
M-LAG interface  M-LAG group  Local state (cause)  Peer state  Remaining down time(s)
BAGG2              1              UP                      UP          -
BAGG3              2              UP                      UP          -
# On Leaf 1, display the M-LAG system settings.
<Leaf 1> display m-lag system
                     System information
Local system number: 1                      Peer system number: 2
Local system MAC: dcda-8037-1324            Peer system MAC: dcda-8037-1324
Local system priority: 100                  Peer system priority: 100
Local bridge MAC: dcda-8037-1324            Peer bridge MAC: 2019-1010-1000
Local effective role: Primary               Peer effective role: Secondary
Health level: 0
Standalone mode on split: Disabled
In standalone mode: No
                     System timer information
Timer                      State       Value (s)    Remaining time (s)
Auto recovery              Disabled    -            -
Restore delay              Disabled    180          -
Consistency-check delay    Disabled    90           -
Standalone delay           Disabled    -            -
Role to None delay         Disabled    60           -
# On Leaf 1, display M-LAG keepalive packet statistics..
<Leaf 1> display m-lag keepalive
Neighbor keepalive link status (cause): Up
Neighbor is alive for: 76743 s 787 ms
Keepalive packet transmission status:
  Sent: Successful
  Received: Successful
Last received keepalive packet information:
  Source IP address: 100.0.0.2
  Time: 2001/01/20 02:26:37
  Action: Accept
M-LAG keepalive parameters:
Destination IP address: 100.0.0.2
Source IP address: 100.0.0.1
Keepalive UDP port : 6400
Keepalive VPN name : N/A
Keepalive interval : 1000 ms
Keepalive timeout  : 5 sec
Keepalive hold time: 3 sec
# On Leaf 1, display the configuration consistency check status.
<Leaf 1> display m-lag consistency-check status
                 Global Consistency Check Configuration
Local status     : Enabled           Peer status     : Enabled
Local check mode : Strict            Peer check mode : Strict
                 Consistency Check on Modules
Module           Type1           Type2
LAGG             Check           Check
VLAN             Check           Check
STP              Check           Check
MAC              Not Check       Check
L2VPN            Not Check       Check
PORTSEC          Not Check       Not Check
DOT1X            Not Check       Not Check
MACA             Not Check       Not Check
WEBAUTH          Not Check       Not Check
NETANALYSIS      Not Check       Check
                 Type1 Consistency Check Result
Global consistency check result: SUCCESS
Inconsistent global modules: -
M-LAG interface     M-LAG group ID     Check Result      Inconsistency modules
BAGG2                 1                     SUCCESS           -
BAGG3                 2                     SUCCESS           -
# On Leaf 1, display information about Layer 2 aggregate interfaces.
<Leaf 1> display interface Bridge-Aggregation brief
Speed: (a) - auto
Interface            Link Speed     Duplex Type PVID Description
BAGG1                UP   100G(a)    F(a)   T     4094
BAGG2                UP   20G(a)     F(a)   A     1
BAGG3                UP   20G(a)     F(a)   A     1
# On Leaf 1, display M-LAG virtual IP addresses.
<Leaf 1> display m-lag virtual-ip
Interface   IP address                MAC address       Effective state
Vsi10       20.1.1.5/24               N/A                 ACTIVE
             20:1:1:1::5/64           N/A                 ACTIVE
Vsi20       20.2.1.5/24               N/A                ACTIVE
             20:2:1:1::5/64           N/A                ACTIVE
# On Leaf 1, display brief spanning tree status and statistics.
<Leaf 1> display stp brief
 MST ID   Port                                Role  STP State   Protection
 0        Bridge-Aggregation2 (DR)         DESI  FORWARDING  NONE
 0        Bridge-Aggregation3 (DR)         DESI  FORWARDING  NONE
 0        HundredGigE1/0/32                 DESI  FORWARDING  NONE
Upgrading the devices
Upgrading the leaf devices
Checking the environment
Execute the commands in "Verification commands" and the following commands to verify that the target device is available for an upgrade.
Leaf 1
Leaf 2
display device
display device
Displays device information.
display boot-loader
display boot-loader
Displays current software images and startup software images.
display version
display version
Displays system version information.
See H3C Switches M-LAG System Upgrade & Replacement & Expansion Guide.
Verifying the traffic interruption time during the upgrade
Verify that the traffic interruption time is shorter than 500 ms during the upgrade.  For more information, see "Testing network convergence."
Verifying the upgrade result
Execute the commands in "Verification commands" and the following commands to verify that the device is upgraded successfully.
Leaf 1
Leaf 2
display device
display device
display boot-loader
display boot-loader
display version
display version
Upgrading the spine devices
Spine 1
Spine 2
display device
display device
display boot-loader
display boot-loader
display version
display version
1.     Use the display version command to obtain the current BootWare image version and startup software version.
2.     Use the release notes for the upgrade software version to evaluate the upgrade impact on your network and verify the following items:
¡     Software and hardware compatibility.
¡     Version and size of the upgrade software.
¡     Compatibility of the upgrade software with the current BootWare image and startup software image.
3.     Use the release notes to verify whether the software images require a license. If licenses are required, register and activate licenses for each license-based software image.
4.     Use the dir command to verify that the device has sufficient storage space for the upgrade images. If the storage space is not sufficient, delete unused files by using the delete command.
5.     Use FTP or TFTP to transfer the upgrade image file to the root directory of a file system.
6.     Upgrade the device according to the configuration guides for the device.
Leaf 1
Leaf 2
display device
display device
display boot-loader
display boot-loader
display version
display version
Upgrading the border device
Border 1
Border 2
display device
display device
display boot-loader
display boot-loader
display version
display version
Verify that the south-north traffic is interrupted during the upgrade. Other traffic is not interrupted or is interrupted transiently.
Leaf 1
Leaf 2
display device
display device
display boot-loader
display boot-loader
display version
display version
An expansion operation adds two leaf devices.
Adding a leaf device
Execute the commands in "Verification commands" and the following commands to verify that the device is available for an expansion.
Leaf 1
Leaf 2
display device
display device
display boot-loader
display boot-loader
display version
display version
Adding the device to the leaf tier
1.     Disconnect the device from network management systems.
2.     Upgrade the software of the device as needed.
3.     Preconfigure the device.
4.     Connect the device to network management systems.
5.     Incorporate the device on the controller.
Verifying the expansion result
Execute the following commands to verify that the device is added successfully.
Leaf 1
Leaf 2
display device
display device
display boot-loader
display boot-loader
display version
display version
Replacing hardware
Replacing a leaf device
Execute the commands in "Verification commands" and the following commands to verify that the target device is available for a replacement.
Leaf 1
Leaf 2
display device
display device
display boot-loader
display boot-loader
display version
display version
Replacing the device
Traffic interruption time is the same for replacing and upgrading operations. For more information, see the traffic interruption time for upgrading a leaf device in "Testing network convergence."
Verifying the replacement result
Execute the commands in "Verification commands" and the following commands to verify that the device is replaced successfully.
Leaf 1
Leaf 2
display device
display device
display boot-loader
display boot-loader
display version
display version
