- H3C Data Center Switches M-LAG Configuration Guide-6W101
- 00-M-LAG network planning
- 01-M-LAG+IPv4 and IPv6 Dual-Active VLAN Gateway Configuration Example
- 02-Multi-Layer M-LAG+STP+Dual-Active VLAN Gateway Configuration Examples
- 03-Multi-Layer M-LAG+Dual-Active VLAN Gateway+OSPF Configuration Examples
- 04-Multi-tier M-LAG+Spine Gateways+ECMP Paths to External Network Configuration Example
- 05-M-LAG and VRRP Configuration Example
- 06-M-LAG+RDMA Configuration Example
- 07-M-LAG and EVPN Distributed Gateway (IS-IS for underlay routing) Configuration Example
- 08-M-LAG and EVPN Distributed Gateway (BGP for Underlay Routing) Configuration Example
- 09-M-LAG+EVPN Distributed Gateway (OSPF on Underlay Network)+DHCP Relay+Microsegmentation+Service Chain Configuration Example
- 10-M-LAG+EVPN Centralized Gateway Configuration Example
- 11-Access to M-LAG Through Dynamic Routing and Distributed EVPN Gateways Configuration Example
- 12-M-LAG+EVPN+Monitor Link Configuration Examples
- 13-M-LAG and MVXLAN Configuration Example
- 14-M-LAG and DCI Configuration Example
- 15-M-LAG+EVPN DC Switchover Upon Border Failure Configuration Examples
- 16-Cascaded M-LAG Systems with Attached Multicast Source and Receivers Configuration Examples
| 10-M-LAG+EVPN Centralized Gateway Configuration Example | 720.43 KB |
Example: Deploying M-LAG and centralized EVPN gateway
Configuring S6800 switches as leaf nodes
Configuring the links towards the spine tier
Configuring the links towards the bare metal servers
Configure the spanning tree feature
Configuring an underlay BGP instance
Configuring an EVPN BGP instance
Configuring S6850 switches as border nodes
Configuring the interfaces connected to the spine nodes
Configuring the routed interfaces connected to the external network
Configuring the overlay network
Configuring S12500X-AF switches as spine nodes
Configuring the downlinks towards the leaf tier
Configuring the uplinks towards the border nodes
As shown in Figure 1, deploy two border devices as an M-LAG system and use it as a centralized gateway. The M-LAG system provides intra-DC connectivity, external connectivity, and DCI.
The following is the network configuration:
· Use M-LAG to build the two border devices into an M-LAG system. Configure the M-LAG system as a centralized EVPN gateway to provide L3 forwarding for VXLANs and as a border node to provide connectivity to the external network.
· Deploy two S12500X-AF switches at the spine tier. Configure them as route reflectors (RRs) to reflect BGP EVPN routes among border and leaf devices.
· Use M-LAG to deploy two pairs of access switches (ToR) switches as M-LAG systems at the leaf tier. They provide EVPN access services to connect servers (for example, bare metal servers) to their overlay networks.
Device |
IP address |
Remarks |
Leaf 1 |
XGE 1/0/7 |
N/A |
Member port of an M-LAG interface, on which Ethernet service instances are configured to act as attachment circuits (ACs). Connected to Server A (bare metal). |
XGE 1/0/8 |
N/A |
Member port of an M-LAG interface, on which Ethernet service instances are configured to act as attachment circuits (ACs). Connected to Server C (bare metal). |
HGE 1/0/49 |
N/A |
Peer-link interface for peer link establishment between M-LAG member devices. Connected to HGE 2/0/49 on Leaf 2. |
HGE 1/0/50 |
N/A |
Member port of the peer-link interface. Connected to HGE 2/0/50 on Leaf 2. |
XGE 1/0/47 |
1.0.0.1/30 |
Keepalive link between M-LAG member devices. Connected to XGE 2/0/47 on Leaf 2. |
HGE 1/0/53 |
N/A |
IP address borrowed from Loopback 0. Connected to HGE 1/0/25 on Spine 1. |
XGE 1/0/17 |
N/A |
IP address borrowed from Loopback 0. Connected to XGE 1/0/1 on Spine 2. |
Loopback 0 |
10.182.224.111/32 |
VTEP IP address for establishing BGP EVPN peering. |
Loopback 1 |
10.182.226.111/32 |
Virtual VTEP address for the M-LAG system to establish VXLAN tunnels to remote devices. |
Vlan-interface 1999 |
192.168.220.1/30 |
IP address for establishing Layer 3 connectivity with the peer M-LAG member device. |
Leaf 2 |
XGE 2/0/7 |
N/A |
Member port of an M-LAG interface, on which Ethernet service instances are configured to act as attachment circuits (ACs). Connected Server A (bare metal). |
XGE 2/0/8 |
N/A |
HGE 2/0/49 |
N/A |
Peer-link interface for peer link establishment between M-LAG member devices. Connected to HGE 1/0/49 on Leaf 1. |
HGE 2/0/50 |
N/A |
Peer-link interface for peer link establishment between M-LAG member devices. Connected to HGE 1/0/50 on Leaf 1. |
XGE 2/0/47 |
1.0.0.2/30 |
Keepalive link between M-LAG member devices. Connected to XGE 1/0/47 on Leaf 1. |
HGE 2/0/54 |
N/A |
IP address borrowed from Loopback 0. Connected to HGE 1/0/28 on Spine 1. |
XGE 2/0/17 |
N/A |
IP address borrowed from Loopback 0. Connected to XGE 1/0/2 on Spine 2. |
Loopback 0 |
10.182.224.246/32 |
Loopback 1 |
10.182.226.111/32 |
192.168.220.2/30 |
Leaf 3 |
XGE 1/0/7 |
N/A |
Member port of an M-LAG interface, on which Ethernet service instances are configured to act as attachment circuits (ACs). Connected Server B (bare metal). |
XGE 1/0/21 |
N/A |
Member port of the peer-link interface for peer link establishment between M-LAG member devices. Connected to XGE 2/0/21 on Leaf 4. |
XGE 1/0/22 |
N/A |
Member port of the peer-link interface for peer link establishment between M-LAG member devices. Connected to XGE 2/0/22 on Leaf 4. |
XGE 1/0/17 |
1.1.0.1/30 |
Keepalive link. Connected to XGE 2/0/17 on Leaf 4. |
XGE 1/0/3 |
N/A |
IP address borrowed from Loopback 0. Connected to XGE 2/0/5 on Spine 1. |
XGE 1/0/1 |
N/A |
IP address borrowed from Loopback 0. Connected to XGE 1/0/3 on Spine 2. |
Loopback 0 |
10.182.224.121/32 |
Loopback 1 |
10.182.226.121/32 |
192.168.220.9/30 |
Leaf 4 |
XGE 2/0/7 |
N/A |
Member port of an M-LAG interface, on which Ethernet service instances are configured to act as attachment circuits (ACs). Connected to a bare metal server. |
XGE 2/0/21 |
N/A |
Member port of the peer-link interface for peer link establishment between M-LAG member devices. Connected to XGE 1/0/21 on Leaf 3. |
XGE 2/0/22 |
N/A |
Member port of the peer-link interface for peer link establishment between M-LAG member devices. Connected to XGE 1/0/22 on Leaf 3. |
XGE 2/0/17 |
1.1.0.2/30 |
Keepalive link between M-LAG member devices. Connected to XGE 1/0/17 on Leaf 3. |
XGE 2/0/3 |
N/A |
IP address borrowed from Loopback 0. Connected to XGE 2/0/7 on Spine 1. |
XGE 2/0/1 |
N/A |
IP address borrowed from Loopback 0. Connected to XGE 1/0/4 on Spine 2. |
Loopback 0 |
10.182.224.122/32 |
Loopback 1 |
10.182.226.121/32 |
192.168.220.10/30 |
Spine 1 |
HGE 1/0/25 |
N/A |
IP address borrowed from Loopback 0. Connected to HGE 1/0/53 on Leaf 1. |
HGE 1/0/28 |
N/A |
IP address borrowed from Loopback 0. Connected to HGE 2/0/54 on Leaf 2. |
XGE 2/0/5 |
N/A |
IP address borrowed from Loopback 0. Connected to XGE 1/0/3 on Leaf 3. |
XGE 2/0/7 |
N/A |
IP address borrowed from Loopback 0. Connected to XGE 2/0/3 on Leaf 4. |
XGE 2/0/1 |
10.182.221.0/31 |
Connected to WGE 1/0/53 on Border 1. |
XGE 2/0/2 |
10.182.221.10/31 |
Connected to WGE 1/0/53 on Border 2. |
Loopback 0 |
10.182.224.90/32 |
IP address for underlay routing. |
Loopback 1 |
10.182.226.90/32 |
IP address for overlay routing. |
Spine 2 |
XGE 1/0/1 |
N/A |
IP address borrowed from Loopback 0. Connected to XGE 1/0/17 on Leaf 1. |
XGE 1/0/2 |
N/A |
IP address borrowed from Loopback 0. Connected to XGE 2/0/17 on Leaf 2. |
XGE 1/0/3 |
N/A |
IP address borrowed from Loopback 0. Connected to XGE 1/0/1 on Leaf 3. |
XGE 1/0/4 |
N/A |
IP address borrowed from Loopback 0. Connected to XGE 2/0/1 on Leaf 4. |
XGE 1/0/21 |
10.182.221.4/31 |
Connected to WGE 1/0/55 on Border 1. |
XGE 1/0/22 |
10.182.221.14/31 |
Connected to WGE 1/0/55 on Border 2. |
Loopback 0 |
10.182.224.89/32 |
Loopback 1 |
10.182.226.89/32 |
Border 1 |
WGE 1/0/53 |
10.182.221.1/31 |
Connected to XGE 2/0/1 on Spine 1. |
WGE 1/0/55 |
10.182.221.5/31 |
Connected to XGE 1/0/21 on Spine 2. |
HGE 1/0/25 |
N/A |
Peer-link interface for peer link establishment between M-LAG member devices. Connected to HGE 1/0/25 on Border 2. |
HGE 1/0/26 |
N/A |
Peer-link interface for peer link establishment between M-LAG member devices. Connected to HGE 1/0/26 on Border 2. |
WGE 1/0/1 |
2.0.0.1/31 |
Keepalive link between M-LAG member devices. Connected to WGE 1/0/1 on Border 2. |
WGE 1/0/33 |
192.101.1.1/31 |
Connected to the L3 switch. |
Loopback 0 |
10.182.234.1/32 |
IP address for the device to establish IGP and BGP peering as an edge device (ED). |
Loopback 1 |
10.182.236.1/32 |
Virtual IP address for the M-LAG system to establish IGP and BGP peering as an ED. |
Vlan-interface 1001 |
192.101.1.101/31 |
Border 2 |
WGE 1/0/53 |
10.182.221.11/31 |
Connected to XGE 2/0/2 on Spine 1. |
WGE 1/0/55 |
10.182.221.15/31 |
Connected to XGE 1/0/22 on Spine 2. |
HGE 1/0/25 |
N/A |
Peer-link interface for peer link establishment between M-LAG member devices. Connected to HGE 1/0/25 on Border 1. |
HGE 1/0/26 |
N/A |
Peer-link interface for peer link establishment between M-LAG member devices. Connected to HGE 1/0/26 on Border 1. |
WGE 1/0/1 |
2.0.0.2/31 |
WGE 1/0/33 |
192.101.1.3/31 |
Loopback 0 |
10.182.234.2/32 |
IP address for the device to establish IGP and BGP peering as an ED. |
Loopback 1 |
10.182.236.1/32 |
192.101.1.100/31 |
IP address for establishing a peer link with the peer M-LAG member device. |
Overlay connectivity models
The following are the types of connectivity between bare metal servers and between a bare metal server and the external network:
· Layer 2 connectivity between bare metal servers attached to the same M-LAG system at the leaf tier.
· Layer 3 connectivity between bare metal servers attached to the same M-LAG system at the leaf tier.
· Layer 2 connectivity between bare metal servers attached to different M-LAG systems at the leaf tier.
· Layer 3 connectivity between bare metal servers attached to different M-LAG systems at the leaf tier.
· Layer 3 connectivity between bare metal servers and the external network.
Applicable product matrix
IMPORTANT: In addition to running an applicable software version, you must also install the most recent patch, if any. |
Role |
Devices |
Software version |
Spine |
S12500X-AF This example uses S12500X-AF switches. |
R2825 |
S12500R |
R5210 |
S12500G-AF |
R7625 |
Leaf or border |
S6800, S6860 This example uses S6800 switches as leaf nodes. |
R6710 |
S6812, S6813 (only as leaf nodes) |
F6628P22 and later versions |
S6805, S6825, S6850, S9850 This example uses S6850 switches as border nodes. |
R6710 |
S6890 |
Not recommended. |
S9820-64H (EVPN gateway not supported). S9820-8C (EVPN not supported). |
Not supported. |
SDN controller |
Contact H3C Support for version compatibility. |
This example describes the procedure to deploy nodes Leaf 1 and Leaf 2. The same procedure applies to nodes Leaf 3 and Leaf 4.
Procedure summary
· Configuring the links towards the spine tier
· Configuring the links towards the bare metal servers
· Configure the spanning tree feature
· Configuring an underlay BGP instance
Configuring resource modes
Leaf 1 |
Leaf 2 |
Purpose |
Remarks |
hardware-resource routing-mode IPv6-128 |
Enable support for IPv6 routes with prefixes longer than 64 bits. |
N/A |
Reboot the device for this setting to take effect. The S12500R, S6812, and S6813 switches do not support this command. |
hardware-resource vxlan l2gw |
Set the VXLAN hardware resource mode to Layer 2 gateway mode. |
N/A |
Configuring OSPF
Leaf 1 |
Leaf 2 |
Purpose |
Remarks |
ospf 1 router-id 10.182.224.111 |
ospf 1 router-id 10.182.224.246 |
Enable an OSPF process and enter its view. |
N/A |
N/A |
spf-schedule-interval 1 10 10 |
Set the maximum OSPF SPF calculation interval to 1 second, the minimum OSPF SPF calculation interval to 10 milliseconds, and the incremental OSPF SPF calculation interval to 10 milliseconds. |
Shorten the SPF calculation interval to accelerate route convergence. |
N/A |
lsa-generation-interval 1 10 10 |
Set the maximum interval for LSA generation to 1 second, the minimum interval to 10 milliseconds, and the incremental interval to 10 milliseconds. |
Enable quicker LSA regeneration upon network topology change to accelerate route convergence. |
N/A |
area 0.0.0.0 |
area 0.0.0.0 |
Create OSPF area 0. |
N/A |
N/A |
fast-reroute lfa |
fast-reroute lfa |
Enable OSPF FRR and use the LFA algorithm for calculation of the backup next hop. |
This feature minimizes service interruption by fast rerouting traffic to the backup path when a link or node fails. |
N/A |
quit |
quit |
Return to system view. |
N/A |
N/A |
interface LoopBack0 |
Create interface Loopback 0 and enter its view. |
N/A |
N/A |
ip address 10.182.224.111 255.255.255.255 |
ip address 10.182.224.246 255.255.255.255 |
Assign an IP address to the interface. |
N/A |
ospf 1 area 0.0.0.0 |
Enable OSPF on the interface. |
N/A |
N/A |
quit |
quit |
N/A |
N/A |
interface LoopBack1 |
Create interface Loopback 1 and enter its view. |
N/A |
N/A |
ip address 10.182.226.111 255.255.255.255 |
N/A |
N/A |
N/A |
quit |
quit |
N/A |
N/A |
vlan 1999 |
vlan 1999 |
Create the VLAN for configuring the VLAN interface used for establishing L3 connectivity between the peer M-LAG member devices. |
N/A |
N/A |
interface Vlan-interface1999 |
Create VLAN-interface 1999 and enter its view. |
Specify the IP addresses for establishing L3 connectivity between the peer M-LAG member devices. |
When the uplink on one M-LAG member device fails, the uplink traffic that arrives on that member device can traverse the established L3 connectivity to the other M-LAG member device and go outside. |
ip address 192.168.220.1 255.255.255.252 |
ip address 192.168.220.2 255.255.255.252 |
N/A |
N/A |
ospf network-type broadcast |
Set the OSPF network type of the interface to broadcast. |
N/A |
N/A |
N/A |
N/A |
quit |
quit |
N/A |
N/A |
Leaf 1 |
Leaf 2 |
Purpose |
Remarks |
interface Ten-GigabitEthernet1/0/17 |
interface Ten-GigabitEthernet2/0/17 |
Configure the interface connected to Spine 2. |
N/A |
N/A |
port link-mode route |
Configure the interface to operate in route mode as a Layer 3 interface. |
N/A |
N/A |
ip address unnumbered interface LoopBack0 |
Configure the interface to borrow the IP address of Loopback 0. |
N/A |
N/A |
N/A |
N/A |
ospf network-type p2p |
Set the OSPF network type of the interface to P2P. |
N/A |
interface HundredGigE1/0/53 |
Configure the interface connected to Spine 1. |
N/A |
N/A |
N/A |
N/A |
N/A |
N/A |
Enable the OSPF on the interface. |
N/A |
N/A |
N/A |
N/A |
Configuring L2VPN
Leaf 1 |
Leaf 2 |
Purpose |
Remarks |
l2vpn enable |
l2vpn enable |
Enable L2VPN. |
N/A |
N/A |
vxlan tunnel mac-learning disable |
Disable remote MAC address learning for VXLANs. |
This setting avoids the conflict between automatically learned MAC address entries and MAC address entries advertised through BGP EVPN. |
N/A |
vxlan tunnel arp-learning disable |
Disable remote ARP learning for VXLANs. |
This setting avoids the conflict between automatically learned ARP entries and ARP entries advertised through BGP EVPN. |
N/A |
vxlan tunnel nd-learning disable |
Disable remote ND learning for VXLANs. |
This setting avoids the conflict between automatically learned ND entries and ND entries advertised through BGP EVPN. |
N/A |
mac-address timer aging 3600 |
Set the aging timer to 3600 seconds for dynamic MAC address entries. |
If the M-LAG system has a large number of MAC address entries, increase the MAC aging timer value to ensure complete synchronization of MAC address entries when one of the M-LAG member devices restarts. |
This setting must be consistent between the peer member devices in an M-LAG system. |
mac-address mac-move fast-update |
Enable ARP fast update for MAC address moves. |
This setting helps accelerate VM migration across the network. |
N/A |
Configuring M-LAG
Leaf 1 |
Leaf 2 |
Purpose |
Remarks |
l2vpn m-lag peer-link ac-match-rule vxlan-mapping |
Enable the device to create frame match criteria based on VXLAN IDs for the dynamic ACs on the Ethernet aggregate peer link. |
N/A |
N/A |
evpn m-lag group 10.182.226.111 |
Enable EVPN M-LAG and set the virtual VTEP address. |
The M-LAG member devices (VTEPs) use the virtual VTEP address to establish tunnels with the remote VTEPs. |
You must specify the same virtual VTEP address on both VTEPs in the same M-LAG system. |
evpn m-lag local 10.182.224.111 remote 10.182.224.246 |
evpn m-lag local 10.182.224.246 remote 10.182.224.111 |
Specify the IP addresses of the local and peer VTEPs in the EVPN M-LAG system. |
You must execute this command if an M-LAG system uses an Ethernet aggregate link as the peer link and has ACs (called single-armed ACs) attached to only one of the member devices. It enables the VTEPs in the M-LAG system to set the next hop of the routes for single-armed ACs to their local VTEP IP addresses when they advertise the routes. This mechanism ensures that the traffic destined for a single-armed AC is forwarded towards its attached VTEP instead of the other VTEP. |
The specified local and remote VTEP addresses must each belong to an interface on the local or peer VTEP in the M-LAG system, respectively. Make sure the local VTEP address on one VTEP is the remote VTEP address on the other. |
evpn global-mac 00e0-fc00-580a |
Configure an EVPN global MAC address. |
N/A |
You must specify the same EVPN global MAC address on the devices in the same M-LAG system. Do not use a reserved MAC address as the EVPN global MAC address. |
m-lag system-mac 00e0-fc00-5800 |
Set the MAC address of the M-LAG system. |
Required. |
You must assign the same M-LAG system MAC address to the member devices in an M-LAG system. |
m-lag system-number 1 |
m-lag system-number 2 |
Set the M-LAG system number. |
Required. |
You must assign different M-LAG system numbers to the member devices in an M-LAG system. |
m-lag system-priority 100 |
(Optional.) Set the M-LAG system priority. |
N/A |
You must set the same M-LAG system priority on the member devices in an M-LAG system. |
m-lag standalone enable |
Enable M-LAG standalone mode. |
N/A |
N/A |
interface Ten-GigabitEthernet 1/0/47 |
interface Ten-GigabitEthernet 2/0/47 |
Enter the interface view for the keepalive link. |
Required. |
N/A |
Configure the interface for keepalive detection to operate in route mode as a Layer 3 interface. |
Required. |
N/A |
ip address 1.0.0.1 24 |
ip address 1.0.0.2 24 |
Assign an IP address to the interface as planned. |
Required. |
N/A |
quit |
quit |
N/A |
N/A |
m-lag keepalive ip destination 1.0.0.2 source 1.0.0.1 |
m-lag keepalive ip destination 1.0.0.1 source 1.0.0.2 |
Configure the source and destination IP addresses of keepalive packets. |
Required. |
For correct keepalive detection, you must exclude the interfaces that own the IP addresses used for keepalive detection from the shutdown action. |
m-lag mad default-action none |
Set the M-LAG MAD action to none. When the M-LAG system splits, M-LAG MAD will not shut down any network interfaces, except the interfaces configured manually or by the system to be shut down on the secondary device. |
N/A |
N/A |
m-lag mad include interface HundredGigE1/0/53 |
m-lag mad include interface HundredGigE2/0/54 |
Configure M-LAG MAD to shut down the interface upon an M-LAG system split if the device is the secondary M-LAG member device. |
N/A |
N/A |
m-lag mad include interface Ten-GigabitEthernet1/0/17 |
m-lag mad include interface Ten-GigabitEthernet2/0/17 |
N/A |
N/A |
m-lag restore-delay 200 |
Set the data restoration interval. |
This command specifies the maximum amount of time for the secondary M-LAG member device to synchronize data with the primary M-LAG member device during M-LAG system setup. Within the data restoration interval, the secondary M-LAG member device sets all network interfaces to M-LAG MAD DOWN state except those excluded from the MAD shutdown action. To avoid packet loss and forwarding failure, increase the data restoration interval if the amount of data is large, for example, when the device has a large number of routes and interfaces. |
N/A |
interface Bridge-Aggregation11 |
Create the Layer 2 aggregate interface to be used as the peer-link interface and enter its interface view. |
Configure the Layer 2 aggregation interfaces that act as the peer-link interfaces at the two ends of the peer link. |
N/A |
port link-type trunk |
Set the link type of the interface to trunk. |
N/A |
N/A |
port trunk permit vlan all |
Configure the interface to permit all VLANs to pass through. |
N/A |
N/A |
quit |
quit |
N/A |
N/A |
interface HundredGigE 1/0/49 |
Enter the interface view for the port to be used as a member port of the peer-link interface. |
Configure the member ports of the Layer 2 aggregation interfaces that act as the peer-link interfaces at the two ends of the peer link. |
N/A |
Set the link type of the port to trunk. |
N/A |
N/A |
Configure the port to permit all VLANs to pass through. |
N/A |
N/A |
port link-aggregation group 11 |
Assign the port to the link aggregation group for the peer-link interface (aggregation group 11). |
N/A |
N/A |
interface HundredGigE 1/0/50 |
N/A |
N/A |
N/A |
N/A |
N/A |
N/A |
N/A |
Enter the interface view for the peer-link interface (Bridge-Aggregation 11). |
Specify the aggregate interface (Bridge-Aggregation 11) as the peer-link interface. |
N/A |
link-aggregation mode dynamic |
Configure the aggregate interface to operate in dynamic mode. |
N/A |
N/A |
port m-lag peer-link 1 |
Specify the aggregate interface as the peer-link interface. |
N/A |
N/A |
undo mac-address static source-check enable |
Disable the static source check feature on the interface. |
This command ensures that the M-LAG member devices can correctly forward the Layer 3 traffic received from each other over the peer link. |
You must disable static source check on the peer-link interfaces of all leaf nodes and their uplink ports connected to the spine tier. |
quit |
quit |
N/A |
N/A |
N/A |
NOTE: If an M-LAG system uses an Ethernet aggregate link as the peer link, each M-LAG member device creates a dynamic AC on the peer link when an AC (Ethernet service instance) is configured on a site-facing interface. The dynamic AC and the site-facing AC have the same frame match criteria and VSI mapping. If two site-facing ACs on different interfaces have the same frame match criteria but different VSI mappings, the dynamic ACs created for the site-facing ACs will conflict with each other. To prevent this issue, use the l2vpn m-lag peer-link ac-match-rule vxlan-mapping command to enable the M-LAG member devices to create frame match criteria based on VXLAN IDs for the dynamic ACs on the peer link. |
Leaf 1 |
Leaf 2 |
Purpose |
Remarks |
interface Bridge-Aggregation1 |
Create an aggregate interface to be used as an M-LAG interface. |
Configure the M-LAG interfaces connected to the bare metal servers. |
N/A |
N/A |
N/A |
N/A |
port m-lag group 1 |
Assign the aggregate interface to an M-LAG group. |
N/A |
N/A |
interface Ten-GigabitEthernet1/0/7 |
interface Ten-GigabitEthernet 2/0/7 |
Enter the view of a member physical interface of the M-LAG interface. |
N/A |
N/A |
N/A |
N/A |
port link-aggregation group 1 |
Add the physical interface to the link aggregation group for the M-LAG interface. |
N/A |
N/A |
quit |
quit |
N/A |
N/A |
N/A |
Leaf 1 |
Leaf 2 |
Purpose |
stp global enable |
stp global enable |
Enable the spanning tree feature globally. |
N/A |
interface Bridge-Aggregation 1 |
Enter the view of the M-LAG interface connected to the bare metal servers. |
N/A |
stp edged-port |
stp edged-port |
N/A |
Configure the M-LAG interface as an edge port to exclude the port from spanning tree calculation for rapid state transition. |
IMPORTANT: · Make sure the M-LAG member devices are consistent in global, peer-link interface-specific, and M-LAG-interface-specific spanning tree settings. Inconsistent spanning tree settings might cause network flapping. · Peer-link interfaces in the M-LAG system do not participate in spanning tree calculation. · After the M-LAG system splits, the M-LAG member devices still use the M-LAG system MAC address to send BPDUs, resulting in incorrect spanning tree calculation. To avoid this issue, enable M-LAG standalone mode on the M-LAG member devices. |
Leaf 1 |
Leaf 2 |
Purpose |
Remarks |
bgp 65105 |
bgp 65105 |
Enable a BGP instance. |
N/A |
N/A |
Specify a unique router ID for the BGP instance on each BGP device. |
To run BGP, a BGP instance must have a router ID. If you do not specify a router ID for the BGP instance on a device, it uses the global router ID. In this situation, you must make sure a global router ID is set on the device. |
N/A |
group spines internal |
Create an IBGP peer group. |
N/A |
N/A |
peer spines connect-interface LoopBack0 |
Specify a source interface for establishing TCP connections to the peer group. |
N/A |
N/A |
peer spines route-update-interval 0 |
Specify an interval for sending the same update to the peer group. |
Enable the device to fast send updates to the peer group upon route changes to accelerate route convergence. |
Execute this command only for IBGP peers. |
peer 10.182.226.89 group spines |
Add the specified spine device to the peer group. |
N/A |
N/A |
peer 10.182.226.90 group spines |
N/A |
N/A |
address-family IPv4 unicast |
Create the BGP IPv4 unicast address family and enter its view. |
N/A |
N/A |
balance 8 |
balance 8 |
Enable load balancing and set the maximum number of BGP ECMP routes for load balancing. |
import-route direct |
Configure BGP to redistribute direct routes in the BGP instance. |
N/A |
N/A |
peer spines enable |
Enable the device to exchange routes with the peer group. |
N/A |
N/A |
quit |
quit |
Exit the BGP IPv4 unicast address family view. |
N/A |
N/A |
Leaf 1 |
Leaf 2 |
Purpose |
Remarks |
bgp 65001 instance EVPN |
N/A |
N/A |
N/A |
group evpn internal |
N/A |
N/A |
peer evpn connect-interface LoopBack0 |
N/A |
N/A |
peer evpn route-update-interval 0 |
Enable the device to fast send updates to the peer group upon route changes to accelerate route convergence after an M-LAG primary/secondary switchover occurs. |
peer 10.182.226.89 group evpn |
N/A |
N/A |
peer 10.182.226.90 group evpn |
N/A |
N/A |
address-family l2vpn evpn |
Create the BGP EVPN address family and enter its view. |
N/A |
N/A |
peer evpn enable |
peer evpn enable |
N/A |
N/A |
undo policy vpn-target |
Disable filtering incoming BGP EVPN routes based on route targets. |
quit |
quit |
Exit the BGP EVPN address family view. |
N/A |
N/A |
Configuring VSIs and ACs
Leaf 1 |
Leaf 2 |
Remarks |
vsi vpn-trusted-7 |
vsi vpn-trusted-7 |
Create a VSI and enter its view. |
N/A |
arp suppression enable |
Enable ARP flood suppression. |
N/A |
vxlan 7 |
vxlan 7 |
Create a VXLAN and enter its view. |
N/A |
evpn encapsulation vxlan |
Create a VXLAN EVPN instance on the VSI and enter its view. |
N/A |
route-distinguisher auto |
Configure the device to automatically generate an RD for the EVPN instance. |
N/A |
vpn-target auto export-extcommunity |
Configure the device to automatically generate an export RT for the EVPN instance. |
N/A |
vpn-target auto import-extcommunity |
Configure the device to automatically generate an import RT for the EVPN instance. |
N/A |
quit |
quit |
N/A |
vsi vpn-trusted-522 |
N/A |
N/A |
vxlan 522 |
vxlan 522 |
N/A |
N/A |
N/A |
N/A |
N/A |
quit |
quit |
N/A |
Enter the view of the site-facing interface on which Ethernet instances will be created. |
N/A |
undo port trunk permit vlan 1 |
Remove the interface from VLAN 1. |
N/A |
port trunk permit vlan 7 522 |
Assign the interface to VLANs 7 and 522. |
N/A |
service-instance 7 |
Create an Ethernet service instance and enter its view. |
N/A |
encapsulation s-vid 7 |
Configure the Ethernet service instance to match traffic sent from the specified VLAN. |
N/A |
xconnect vsi vpn-trusted-7 |
Map the Ethernet service instance to the specified VSI. |
N/A |
service-instance 522 |
N/A |
encapsulation s-vid 522 |
N/A |
xconnect vsi vpn-trusted-522 |
N/A |
quit |
quit |
N/A |
N/A |
Procedure summary
· Configuring the interfaces connected to the spine nodes
· Configuring the routed interfaces connected to the external network
· Configuring an EVPN BGP instance
· Configuring the overlay network
Configure basic settings
Border 1 |
Border 2 |
Purpose |
Remarks |
N/A |
N/A |
ip address 10.182.234.1 255.255.255.255 |
ip address 10.182.234.2 255.255.255.255 |
VTEP IP |
N/A |
quit |
quit |
N/A |
N/A |
N/A |
N/A |
N/A |
ip address 10.182.236.1 255.255.255.255 |
Configure the virtual VTEP IP address. |
N/A |
quit |
quit |
N/A |
N/A |
ip vpn-instance vpn-trusted |
Create a VPN instance. |
N/A |
N/A |
route-distinguisher 65001:10 |
route-distinguisher 65002:10 |
Configure the device to automatically generate an RD for the VPN instance. |
N/A |
N/A |
address-family IPv4 |
Enter VPN instance IPv4 address family view. |
N/A |
N/A |
vpn-target 65001:1 import-extcommunity |
Configure the IPv4 import target for the VPN instance. |
N/A |
N/A |
vpn-target 65001:1 export-extcommunity |
Configure the IPv4 export target for the VPN instance. |
N/A |
N/A |
address-family IPv6 |
Enter VPN instance IPv6 address family view. |
N/A |
N/A |
Configure the IPv6 import target for the VPN instance. |
N/A |
N/A |
Configure the IPv6 export target for the VPN instance. |
N/A |
N/A |
address-family evpn |
Enter VPN instance EVPN address family view. |
N/A |
N/A |
N/A |
N/A |
N/A |
N/A |
quit |
quit |
N/A |
N/A |
Configuring OSPF
Border 1 |
Border 2 |
Purpose |
Remarks |
ospf 100 router-id 10.182.234.1 vpn-instance vpn-trusted |
Create an OSPF process and enter its view. |
N/A |
N/A |
Redistribute direct routes in the OSPF process. |
N/A |
N/A |
Set the maximum SPF calculation interval to 1 second, the minimum SPF calculation interval to 10 milliseconds, and the incremental SPF calculation interval to 10 milliseconds for OSPF. |
N/A |
N/A |
area 0.0.0.1 |
area 0.0.0.1 |
Create OSPF area 1. |
N/A |
N/A |
fast-reroute lfa |
fast-reroute lfa |
This feature minimizes service interruption by fast rerouting traffic to the precalculated backup next hop when a link or node fails. |
N/A |
quit |
quit |
N/A |
N/A |
N/A |
vlan 1001 |
vlan 1001 |
Create the VLAN for configuring the VLAN interface used for establishing L3 connectivity between the border nodes. |
N/A |
N/A |
interface Vlan-interface1001 |
Create VLAN-interface 1001 and enter its view. |
Specify the IP addresses for establishing L3 connectivity between the peer M-LAG member devices. When the uplink on one M-LAG member device fails, the uplink traffic that arrives on that member device can traverse the established L3 connectivity to the other M-LAG member device and go outside. |
N/A |
ip binding vpn-instance vpn-trusted |
N/A |
N/A |
N/A |
ip address 192.101.1.101 255.255.255.252 |
ip address 192.101.1.100 255.255.255.252 |
N/A |
N/A |
N/A |
N/A |
N/A |
quit |
quit |
N/A |
N/A |
Border 1 (S12508X-AF) |
Border 2 (S12508X-AF) |
Purpose |
Remarks |
stp global enable |
stp global enable |
N/A |
N/A |
Border 1 |
Border 2 |
Purpose |
Remarks |
interface Twenty-FiveGigE1/0/53 |
N/A |
N/A |
N/A |
N/A |
ip address 10.182.221.1 255.255.255.254 |
ip address 10.182.221.11 255.255.255.254 |
N/A |
N/A |
link-delay up 60 |
link-delay up 60 |
Configure the interface to suppress link-up events for 60 seconds. |
N/A |
N/A |
quit |
quit |
N/A |
N/A |
interface Twenty-FiveGigE1/0/55 |
N/A |
N/A |
N/A |
N/A |
ip address 10.182.221.5 255.255.255.254 |
ip address 10.182.221.15 255.255.255.254 |
N/A |
N/A |
link-delay up 60 |
link-delay up 60 |
N/A |
N/A |
quit |
quit |
N/A |
N/A |
N/A |
Configuring L2VPN
Border 1 |
Border 2 |
Purpose |
Remarks |
l2vpn enable |
l2vpn enable |
Enable L2VPN. |
N/A |
N/A |
N/A |
N/A |
N/A |
N/A |
N/A |
N/A |
N/A |
N/A |
mac-address timer aging 900 |
Set the aging timer for dynamic MAC address entries to 900 seconds . |
If the M-LAG system has a large number of MAC entries, increase the aging timer value for dynamic MAC address entries to ensure complete synchronization of MAC address entries when one of the M-LAG member devices restarts. This setting helps accelerate VM migration across the network. |
IMPORTANT: If an M-LAG system in a VXLAN or EVPN environment uses an Ethernet aggregate link as the peer link, each M-LAG member device creates a dynamic AC on the peer link when an AC (Ethernet service instance) is configured on a site-facing interface. The dynamic AC and the site-facing AC have the same frame match criteria and VSI mapping. If two site-facing ACs on different interfaces have the same frame match criteria but different VSI mappings, the dynamic ACs created for the site-facing ACs will conflict with each other. To prevent this issue, use the l2vpn m-lag peer-link ac-match-rule vxlan-mapping command to enable the M-LAG member devices to create frame match criteria based on VXLAN IDs for the dynamic ACs on the peer link. |
Configuring M-LAG
Border 1 |
Border 2 |
Purpose |
Remarks |
m-lag restore-delay 180 |
Set the data restoration interval. This parameter specifies the maximum amount of time for the secondary M-LAG member device to synchronize data with the primary M-LAG member device during M-LAG system setup. |
N/A |
m-lag role priority 10 |
m-lag role priority 20 |
Set the M-LAG role priority of the device. |
N/A |
An M-LAG member device is assigned the primary or secondary role based on its M-LAG role priority. The lower the priority value, the higher the priority. |
m-lag system-mac 0002-0002-0001 |
N/A |
N/A |
m-lag system-priority 10 |
N/A |
N/A |
N/A |
Required. |
N/A |
m-lag mad include interface Twenty-FiveGigE1/0/33 |
Configure M-LAG MAD to shut down the uplink interface upon an M-LAG system split if the device is the secondary M-LAG member device. |
N/A |
N/A |
m-lag mad include interface Twenty-FiveGigE1/0/53 |
Configure M-LAG MAD to shut down the downlink interface upon an M-LAG system split if the device is the secondary M-LAG member device. |
N/A |
N/A |
m-lag mad include interface Twenty-FiveGigE1/0/55 |
Configure M-LAG MAD to shut down the downlink interface when the M-LAG system splits. |
N/A |
N/A |
m-lag keepalive ip destination 2.0.0.2 source 2.0.0.1 |
m-lag keepalive ip destination 2.0.0.1 source 2.0.0.2 |
This example uses the IP addresses of management Ethernet interfaces to set up the keepalive link. By default, management Ethernet interfaces are excluded from the M-LAG MAD DOWN action. |
If the interfaces belong to a VPN instance, specify that VPN instance when you specify source and destination IP addresses for keepalive packets. If the interfaces that own the IP addresses are not excluded from the M-LAG MAD DOWN action by default, manually exclude them from that action. |
evpn m-lag group 10.182.236.1 |
Enable EVPN M-LAG and specify the virtual VTEP address. |
N/A |
N/A |
evpn global-mac 00e0-fc00-0201 |
N/A |
interface Bridge-Aggregation1024 |
Create the Layer 2 aggregate interface to be used as the peer-link interface, and enter interface view. This example uses interface Bridge-Aggregation 1024 as the peer-link interface on each member device. |
N/A |
N/A |
N/A |
N/A |
N/A |
N/A |
N/A |
N/A |
interface HundredGigE1/0/25 |
Assign the physical port to the aggregation group for the peer-link interface. |
N/A |
N/A |
N/A |
N/A |
N/A |
N/A |
port link-aggregation group 1024 |
Assign the port to the link aggregation group for the peer-link interface. |
N/A |
N/A |
interface HundredGigE1/0/26 |
N/A |
N/A |
N/A |
N/A |
N/A |
N/A |
N/A |
N/A |
quit |
quit |
N/A |
N/A |
N/A |
Enter the Layer 2 aggregate interface view for the peer-link interface. |
N/A |
N/A |
N/A |
N/A |
quit |
quit |
N/A |
N/A |
N/A |
IMPORTANT: If you use a VXLAN tunnel as the peer link in an EVPN environment, you must retain a large number of logical interfaces (for example, tunnel and loopback interfaces) in up state. To simplify configuration, set the default M-LAG MAD action to NONE and execute the m-lag mad include interface command to specify interfaces that must be shut down by M-LAG MAD if they are not in the system-defined included port list for MAD shutdown. |
Border 1 |
Border 2 |
Purpose |
N/A |
N/A |
N/A |
Associate the interface with the specified VPN instance. |
N/A |
ip address 192.101.1.1 255.255.255.254 |
ip address 192.101.1.3 255.255.255.254 |
N/A |
ospf 100 area 0.0.0.1 |
N/A |
ospf peer hold-max-cost duration 300000 |
On the interface, enable OSPF to advertise the maximum link cost to neighbors within 300000 milliseconds. |
N/A |
Border 1 |
Border 2 |
Purpose |
Remarks |
bgp 65031 |
bgp 65031 |
N/A |
N/A |
router-id 10.182.234.1 |
router-id 10.182.234.2 |
N/A |
group spine external |
Create an EBGP peer group. |
N/A |
N/A |
peer spine as-number 65105 |
Specify an AS number for the EBGP peer group. |
N/A |
N/A |
peer spine route-update-interval 0 |
N/A |
peer 10.182.221.0 group spines |
peer 10.182.221.10 group spines |
N/A |
N/A |
peer 10.182.221.4 group spines |
peer 10.182.221.14 group spines |
N/A |
N/A |
peer 100.5.1.2 as-number 65031 |
peer 100.5.1.1 as-number 65031 |
Configure EBGP peering for establishing Layer 3 connectivity between the M-LAG member devices. |
N/A |
peer 100.5.1.2 route-update-interval 0 |
peer 100.5.1.1 route-update-interval 0 |
N/A |
N/A |
N/A |
balance 8 |
balance 8 |
N/A |
N/A |
N/A |
N/A |
network 10.182.234.1 255.255.255.255 |
network 10.182.234.2 255.255.255.255 |
Advertise the IP address of interface Loopback 0. |
N/A |
N/A |
network 10.182.236.1 255.255.255.255 |
Advertise the IP address of interface Loopback 1. |
N/A |
N/A |
peer spine enable |
peer spine enable |
N/A |
N/A |
peer 100.5.1.2 enable |
peer 100.5.1.1 enable |
N/A |
N/A |
quit |
quit |
N/A |
N/A |
Border 1 |
Border 2 |
Purpose |
Remarks |
Enable the specified BGP instance and enter its view. |
N/A |
N/A |
Specify a unique router ID for the BGP instance on the device. |
N/A |
N/A |
N/A |
The IBGP peer group name must be evpn. |
N/A |
N/A |
N/A |
N/A |
N/A |
N/A |
N/A |
N/A |
N/A |
N/A |
peer evpn enable |
peer evpn enable |
N/A |
N/A |
nexthop evpn-m-lag group-address |
Enable the M-LAG member devices to replace the next hop in advertised BGP EVPN routes with the virtual VTEP address. |
This step is required on the EDs in an EVPN DCI environment if the EDs are M-LAG systems. |
N/A |
quit |
quit |
N/A |
N/A |
Border 1 |
Border 2 |
Purpose |
Remarks |
interface Vsi-interface7 |
Create a VSI interface and enter its view. |
N/A |
N/A |
Associate the VSI interface with the specified VPN instance. |
N/A |
N/A |
ip address 10.182.7.254 255.255.252.0 |
Assign an IP address to the interface. This IP address will be the gateway IP address. |
N/A |
N/A |
proxy-arp enable |
proxy-arp enable |
Enable common proxy ARP. |
N/A |
N/A |
quit |
quit |
N/A |
N/A |
interface Vsi-interface522 |
N/A |
N/A |
N/A |
N/A |
ip address 10.180.43.254 255.255.252.0 |
N/A |
N/A |
proxy-arp enable |
proxy-arp enable |
N/A |
N/A |
quit |
quit |
N/A |
N/A |
interface Vsi-interface10001 |
N/A |
N/A |
Bind the VSI interface to the specified VPN instance. |
N/A |
N/A |
IPv6 address auto link-local |
Configure the system to automatically generate a link-local address for the interface. |
N/A |
N/A |
quit |
quit |
N/A |
N/A |
vsi vpn-trusted-7 |
vsi vpn-trusted-7 |
N/A |
N/A |
gateway vsi-interface 7 |
Specify the gateway interface for the VSI. |
N/A |
N/A |
N/A |
N/A |
vxlan 7 |
vxlan 7 |
N/A |
N/A |
N/A |
N/A |
N/A |
N/A |
Configure the IPv6 export target for the EVPN instance. |
N/A |
N/A |
Configure the IPv6 import target for the EVPN instance. |
N/A |
N/A |
quit |
quit |
Return to VSI view. |
N/A |
N/A |
quit |
quit |
N/A |
N/A |
N/A |
N/A |
gateway vsi-interface 522 |
N/A |
N/A |
N/A |
N/A |
vxlan 522 |
vxlan 522 |
N/A |
N/A |
N/A |
N/A |
N/A |
N/A |
N/A |
N/A |
N/A |
N/A |
quit |
quit |
N/A |
N/A |
quit |
quit |
N/A |
N/A |
Procedure summary
· Configuring the downlinks towards the leaf tier
· Configuring the uplinks towards the border nodes
Configuring OSPF
Spine 1 |
Spine 2 |
Purpose |
Remarks |
ospf 1 router-id 10.182.224.90 |
ospf 1 router-id 10.182.224.89 |
N/A |
N/A |
N/A |
Set the maximum interval for LSP generation to 1 second, the minimum interval to 10 milliseconds, and the incremental interval to 10 milliseconds. |
Enable quicker LSP regeneration upon network topology change to accelerate route convergence. |
N/A |
N/A |
N/A |
area 0.0.0.0 |
area 0.0.0.0 |
Create an OSPF area. |
N/A |
N/A |
quit |
quit |
Return to OSPF view. |
N/A |
N/A |
quit |
quit |
N/A |
N/A |
The following information uses one port for example to describe the configuration procedure.
Spine 1 |
Spine 2 |
Purpose |
Remarks |
Enter interface view. |
Configure the interface connected to Leaf 1. |
N/A |
N/A |
N/A |
N/A |
N/A |
N/A |
N/A |
N/A |
N/A |
quit |
quit |
N/A |
N/A |
The following information uses one port for example to describe the configuration procedure. All uplink ports connected to the spine nodes use the same configuration except that their IP addresses must be different.
Spine 1 |
Spine 2 |
Purpose |
Remarks |
interface Ten-GigabitEthernet 2/0/1 |
interface Ten-GigabitEthernet 1/0/21 |
Configure the interface connected to Border 1. |
N/A |
N/A |
N/A |
ip address 10.182.221.0 255.255.255.254 |
ip address 10.182.221.4 255.255.255.254 |
N/A |
N/A |
quit |
quit |
N/A |
N/A |
Border 1 |
Border 2 |
Purpose |
Remarks |
bgp 65105 |
bgp 65105 |
Enable a BGP instance and enter its view. |
N/A |
N/A |
N/A |
N/A |
compare-different-as-med |
Enable MED comparison for routes from peers in different ASs. |
N/A |
N/A |
group gw external |
group gw external |
Create an EBGP peer group for establishing EBGP peering with the border nodes. |
N/A |
N/A |
peer gw as-number 65031 |
N/A |
N/A |
peer gw route-update-interval 0 |
Specify the interval for sending the same update to the peer group. |
N/A |
group leafs internal |
Create an IBGP peer group for establishing IBGP peering with the leaf nodes. |
N/A |
N/A |
peer leafs connect-interface LoopBack0 |
N/A |
N/A |
peer leafs route-update-interval 0 |
N/A |
peer 10.182.221.1 group gw |
peer 10.182.221.5 group gw |
Add the specified peer to the peer group. |
Establish BGP peering with Border 1. |
N/A |
peer 10.182.221.11 group gw |
peer 10.182.221.15 group gw |
Establish BGP peering with Border 2. |
N/A |
peer 10.182.224.111 group leafs |
Establish BGP peering with Leaf 1. |
N/A |
peer 10.182.224.121 group leafs |
Establish BGP peering with Leaf 3. |
N/A |
peer 10.182.224.122 group leafs |
Establish BGP peering with Leaf 4. |
N/A |
peer 10.182.224.246 group leafs |
Establish BGP peering with Leaf 2. |
N/A |
N/A |
N/A |
balance 8 |
balance 8 |
N/A |
N/A |
balance as-path-neglect |
Enable BGP to ignore the AS_PATH attribute when it performs load balancing. |
This enables load balancing across routes with different AS_PATH attribute values. |
N/A |
N/A |
N/A |
peer gw enable |
peer gw enable |
N/A |
N/A |
peer leafs enable |
peer leafs enable |
N/A |
N/A |
peer leafs reflect-client |
Configure the spine nodes as route reflectors and configure the specified peer group as a client. |
N/A |
N/A |
quit |
quit |
Return to BGP instance view. |
N/A |
N/A |
quit |
quit |
N/A |
N/A |
Spine 1 |
Spine 2 |
Purpose |
Remarks |
N/A |
N/A |
router-id 10.182.226.90 |
router-id 10.182.226.89 |
N/A |
N/A |
N/A |
N/A |
peer evpn connect-interface LoopBack1 |
N/A |
N/A |
peer 10.182.224.111 group evpn |
N/A |
peer 10.182.224.121 group evpn |
N/A |
peer 10.182.224.122 group evpn |
N/A |
peer 10.182.224.246 group evpn |
N/A |
peer 10.182.234.1 group evpn |
N/A |
peer 10.182.234.2 group evpn |
N/A |
N/A |
N/A |
N/A |
quit |
quit |
Return to BGP view. |
N/A |
N/A |
Enter BGP EVPN address family view. |
N/A |
N/A |
Disable target-based filtering of incoming BGP EVPN routes. |
N/A |
N/A |
peer evpn enable |
peer evpn enable |
N/A |
N/A |
peer evpn reflect-client |
N/A |
N/A |
quit |
quit |
N/A |
N/A |
quit |
quit |
N/A |
N/A |
Traffic model
About the traffic model
The traffic model contains the following information:
· ID—Traffic ID, in O-X-XXX format. The first segment (O) represents overlay traffic. The second segment (X) represents the IP version (4 for IPv4 and 6 for IPv6). The third segment (XXX) represents a unique number for the traffic.
· Type—Traffic type, such as known unicast/IPV4 and unicast/L2.
· Direction—Traffic direction, such as inter-leaf east-west traffic, north-west traffic, and inter-DC traffic.
· Path—The nodes that the traffic traverses from the source to the destination.
· Simulation method—Traffic simulation method. Testers are used to simulate the patterns of traffic on the network set up in this example.
· Load—The network is tested under light load (fewer than 1000 simulation traffic flows).
Overlay traffic
ID |
Type |
Direction |
Path |
Simulation method |
Load |
O-4-001 |
Unicast/L2 |
East-west traffic between bare metal servers attached to the same leaf M-LAG system. |
Server A > Leaf 1&2 > Server C |
Bond4 mode + tester |
Light |
Layer 2 connectivity between bare metal servers attached to the same M-LAG systems at the leaf tier. |
O-4-002 |
Unicast/L2 |
Server C > Leaf 1&2 > Server A |
Light |
Layer 2 connectivity between bare metal servers. |
O-4-003 |
Known unicast/IPv4 |
Server A > Leaf 1&2 > Spine 1&2 > Border 1&2 > Spine 1&2 > Leaf 1&2 > Server C |
Light |
Layer 3 connectivity between bare metal servers. |
O-4-004 |
Server C > Leaf 1&2 > Spine 1&2 > Border 1&2 > Spine 1&2 > Leaf 1&2 > Server A |
Light |
O-4-005 |
Unicast/L2 |
East-west traffic between bare metal servers attached to different leaf M-LAG systems. |
Server A > Leaf 1&2 > Spine 1&2 > Leaf 3&4 > Server B |
Light |
O-4-006 |
Unicast/L2 |
Server B > Leaf 3&4 > Spine 1&2 > Leaf 1&2 > Server A |
Light |
O-4-007 |
Server A > Leaf 1&2 > Spine 1&2 > Border 1&2 > Spine 1&2 > Leaf 3&4 > Server B |
Light |
O-4-008 |
Server B > Leaf 3&4 > Spine 1&2 > Border 1&2 > Spine 1&2 > Leaf 1&2 > Server A |
Light |
O-4-009 |
North-south traffic |
Server A > Leaf 1&2 > Spine 1&2 > Border 1&2 > public |
Light |
Layer 3 connectivity between bare metal servers and the external network. |
O-4-010 |
Public > Border 1&2 > Spine 1&2 > Leaf 1&2 > Server A |
Light |
Convergence performance test results
Failure test results
Table 1 Link failure test results
Device |
Failure cause |
Traffic downtime |
Recovery event |
Traffic downtime |
Leaf |
Single ECMP uplink failure |
< 200 ms |
Recovery from a single ECMP uplink failure |
0 ms |
Single member link failure of an M-LAG interface |
< 30 ms |
Recovery from a single M-LAG interface member link failure |
< 20 ms |
Peer link failure |
< 60 ms |
Recovery from peer link failure |
< 60 ms |
M-LAG keepalive link failure |
0 ms |
Recovery from M-LAG keepalive link failure |
0 ms |
Device restart |
< 200 ms |
Device restart upon recovery |
< 200 ms |
Upgrade |
< 500 ms (upgrade the M-LAG member devices one by one) |
N/A |
N/A |
Node expansion |
< 500 ms |
N/A |
N/A |
Hardware replacement |
Fixed-port device replacement: < 500 ms Modular device: · Device replacement: < 1000 ms · Switching fabric module replacement: 0 ms · Service module replacement: < 500 ms |
N/A |
N/A |
Spine |
< 5 ms |
0 ms |
Single ECMP downlink failure |
< 15 ms |
0 ms |
Device restart upon exception |
~1 second |
< 10 ms |
Upgrade |
< 100 ms |
N/A |
N/A |
Border |
Single uplink failure |
< 30 ms |
Recovery from a single uplink failure |
0 ms |
< 5 ms |
0 ms |
Peer link failure |
< 20 ms |
< 20 ms |
0 ms |
0 ms |
< 20 ms |
0 ms |
Upgrade |
< 30 ms (upgrade the M-LAG member devices one after another) |
N/A |
N/A |
Node expansion |
< 30 ms |
N/A |
N/A |
Fixed-port device replacement: < 30 ms Modular device: · Device replacement: < 1000 ms · Switching fabric module replacement: 0 ms · Service module replacement: < 500 ms |
N/A |
N/A |
Verification commands
Leaf 1 |
Leaf 2 |
display m-lag summary |
Displays summary information about the peer-link interface and M-LAG interfaces in the M-LAG system. |
display m-lag system |
Displays M-LAG system settings. |
display m-lag keepalive |
Displays M-LAG keepalive packet statistics. |
display m-lag role |
Displays M-LAG role information. |
display m-lag consistency-check status |
Displays the configuration consistency check status. |
# Verify that the M-LAG system that contains Border 1 and Border 2 is operating correctly.
[border1]dis m-lag summary
Flags: A -- Aggregate interface down, B -- No peer M-LAG interface configured
C -- Configuration consistency check failed
Peer-link interface: BAGG1024
Peer-link interface state (cause): UP
Keepalive link state (cause): UP
# Verify the M-LAG system settings on Border 1.
[border1]display m-lag system
System information
Local system number: 1 Peer system number: 2
Local system MAC: 0002-0002-0001 Peer system MAC: 0002-0002-0001
Local system priority: 10 Peer system priority: 10
Local bridge MAC: dcda-8040-0520 Peer bridge MAC: b044-14cc-8270
Local effective role: Primary Peer effective role: Secondary
Health level: 0
Standalone mode on split: Enabled
In standalone mode: No
System timer information
Timer State Value (s) Remaining time (s)
Auto recovery Disabled - -
Restore delay Disabled 90 -
Consistency-check delay Disabled 45 -
Standalone delay Disabled 0 -
Role to None delay Disabled 60 -
# Verify that Border 1 can send and receive keepalive packets.
[border1]dis m-lag keepalive
Neighbor keepalive link status (cause): Up
Neighbor is alive for: 952908 s 870 ms
Keepalive packet transmission status:
Sent: Successful
Received: Successful
Last received keepalive packet information:
Source IP address: 2.0.0.2
Time: 2001/02/01 05:55:23
Action: Accept
M-LAG keepalive parameters:
Destination IP address: 2.0.0.2
Source IP address: 2.0.0.1
Keepalive UDP port : 6400
Keepalive VPN name : N/A
Keepalive interval : 1000 ms
Keepalive timeout : 5 sec
Keepalive hold time: 3 sec
# Verify that Border 1 and Border 2 are the primary and secondary nodes, respectively, in the M-LAG system.
[border1]dis m-lag role
Effective role information
Factors Local Peer
Effective role Primary Secondary
Initial role Primary None
MAD DOWN state No No
Health level 0 0
Role priority 32768 32768
Bridge MAC dcda-8040-0520 b044-14cc-8270
Effective role trigger: Peer link calculation
Effective role reason: Single None role
Configured role information
Factors Local Peer
Configured role Primary Secondary
Role priority 20 30
# Verify the configuration consistency status on Border 1.
[border1]display m-lag consistency-check status
Global Consistency Check Configuration
Local status : Enabled Peer status : Enabled
Local check mode : Strict Peer check mode : Strict
Consistency Check on Modules
Module Type1 Type2
LAGG Check Check
VLAN Check Check
STP Check Check
MAC Not Check Check
L2VPN Not Check Check
Type1 Consistency Check Result
Global consistency check result: SUCCESS
Inconsistent global modules: N/A
Upgrading the devices
Upgrading a leaf device
Verifying that all upgrade requirements are met
Execute the commands in "Verification commands" and the following commands to verify that all upgrade requirements are met.
Leaf 1 |
Leaf 2 |
display device |
display device |
Displays device information. |
display boot-loader |
Displays the current software images and startup software images. |
display version |
display version |
Displays system version information. |
See H3C Switches M-LAG System Upgrade & Replacement & Expansion Guide.
Estimating upgrade downtime
To minimize the impact on services, use information provided in "Convergence performance test results" to estimate downtime when you schedule an upgrade.
When you upgrade the M-LAG member devices one by one while the traffic volume is light, traffic downtime of a member device is less than 200 ms upon failover and 60 ms upon fallback.
Verifying the upgrade result
Execute the commands in "Verification commands" and the following commands to verify that the device is upgraded successfully.
Leaf 1 |
Leaf 2 |
display device |
display device |
display version |
display version |
Upgrading a spine device
Leaf 1 |
Leaf 2 |
display device |
display device |
display version |
display version |
1. Execute the display version command to verify the current BootWare image version and startup software version.
2. Use the release notes for the upgrade software version to evaluate the upgrade impact on your network and verify the following items:
¡ Software and hardware compatibility.
¡ Version and size of the upgrade software.
¡ Compatibility of the upgrade software with the current BootWare image and startup software image.
3. Use the release notes to verify whether the upgrade software images require a license. If licenses are required, check the system for availability of valid licenses. If no valid licenses are available, register and activate licenses for each license-based software image.
4. Use the dir command to verify that the device has sufficient storage space for the upgrade images. If the storage space is not sufficient, delete unused files by using the delete command. Make sure that all MPUs in the system have sufficient storage space.
5. Use FTP or TFTP to transfer the upgrade image file to the root directory of a file system.
6. Upgrade the software. For more information about the software upgrade procedure, see the fundamentals configuration guide for the device.
To minimize the impact on services, use information provided in "Convergence performance test results" to estimate upgrade downtime when you schedule an upgrade.
When you upgrade the M-LAG member devices one by one with reboot while the traffic volume is light, traffic downtime of a member device is less than 500 ms upon failover and 150 ms upon fallback.
Spine 1 |
Spine 2 |
display device |
display device |
display version |
display version |
Upgrading a border device
Border 1 |
Border 2 |
display device |
display device |
display version |
display version |
Upgrade procedure
To minimize the impact on services, use information provided in "Convergence performance test results" to estimate the downtime when you schedule an upgrade.
When you upgrade the M-LAG member devices one by one while the traffic volume is light, traffic downtime of a member device is less than 30 ms upon failover and 20 ms upon fallback.
Execute the commands in "Verification commands" and the following commands to verify that the upgrade has been done correctly.
Table 2 Post-upgrade verification commands
Border 1 |
Border 2 |
display device |
display device |
display version |
display version |
Expanding the network
An expansion operation adds two leaf devices.
Adding a leaf device
Verifying that all expansion requirements are met
Execute the commands in "Verification commands" and the following commands to verify that all requirements are met for an expansion.
Leaf 1 |
Leaf 2 |
display device |
display device |
display version |
display version |
Adding the expansion device to the network
1. Make sure the expansion device is not connected to network management systems.
2. Upgrade the device to the target software version.
3. Preconfigure the device.
4. Connect the device to the network management systems.
5. Incorporate the device into the controller.
Estimating expansion downtime
To minimize the impact on services, use information provided in "Convergence performance test results" to estimate the downtime when you schedule a node expansion.
Verifying the expansion result
Execute the following commands to verify that the device has been added successfully.
Leaf 1 |
Leaf 2 |
display device |
display device |
display version |
display version |
Replacing hardware
Replacing an interface module
Verifying that all replacement requirements are met
Execute the commands in "Verification commands" and the following commands to verify that all requirements are met for a replacement.
Leaf 1 |
Leaf 2 |
display device |
display device |
display version |
display version |
Replacing hardware
Before you replace an interface module, make sure the service and management traffic has switched over to other interface modules that are operating correctly.
Replace the interface modules online while the system is operating or power off the system before you do the replacement, depending on the evaluation of the conditions.
For details, see H3C Switches M-LAG System Upgrade & Replacement & Expansion Guide.
Estimated replacement downtime
To minimize the impact on services, use information provided in "Convergence performance test results" to estimate the downtime when you schedule a hardware replacement.
Verifying the replacement result
Use the same commands for pre-replacement verification to verify that the system can operate correctly after the hardware replacement.
Replacing a switching fabric module
Leaf 1 |
Leaf 2 |
display device |
display device |
display version |
display version |
Replacing hardware
Replace the switching fabric module online while the system is operating or power off the system before you do the replacement, depending on the evaluation of the conditions.
Estimating replacement downtime
Verifying that the replacement is successful
