H3C Data Center Switches M-LAG Configuration Guide-6W101
HomeSupportConfigure & DeployConfiguration GuidesH3C Data Center Switches M-LAG Configuration Guide-6W101
02-Multi-Layer M-LAG+STP+Dual-Active VLAN Gateway Configuration Examples
Example: Configuring multi-layer M-LAG+STP+dual-active VLAN gateways
As shown in Figure 1, the user network uses a three-layer architecture: core-aggregation-access. To improve network availability, deploy two devices separately on the core layer, aggregation layer, and access layer. Two devices on each layer form an M-LAG system.
·     Device A and Device B form M-LAG system 1, which acts as an access device and connects to Server.
·     Device C and Device D form M-LAG system 2, which acts as an aggregation device.
·     Device E and Device F form M-LAG system 3, which acts as the core device and connects to VM.
To meet the network access requirements of VM and Server, make sure the M-LAG member devices on the core layer act as both the IPv4 gateway and IPv6 gateway of VM and Server.
To avoid loops between aggregation member ports over a peer link because the M-LAG system splits, the cables are connected incorrectly, or the configuration is incorrect, perform he following tasks:
·     Configure STP on the M-LAG member devices.
·     Configure the M-LAG member devices on the core layer (Device E and Device F) as the root bridges of STP. If you do not do that, when new devices are added to the STP network, they might dynamically preempt the STP root bridge roles. As a result, the STP network will flap.
This document uses three-layer M-LAG+STP+dual-active VLAN gateways as an example to describe how to configure a multi-layer M-LAG network. The configuration procedure for a two-layer M-LAG+STP+dual-active VLAN gateways is similar.
Figure 1 Network diagram
Device
IP address
Peer device and interface
Device A
XGE1/0/24
IPv4: 220.1.1.1/24
Device B XGE2/0/24
Device B
XGE2/0/24
IPv4: 220.1.1.2/24
Device A: XGE1/0/24
Device C
WGE1/0/11
IPv4: 220.1.1.3/24
Device D: WGE2/0/11
Device D
WGE2/0/11
IPv4: 220.1.1.4/24
Device C: WGE1/0/11
Device E
XGE1/4/5
IPv4: 220.1.1.5/24
Device F: XGE2/4/5
Vlan-int20
IPv4: 20.1.1.2/24
IPv6: 20:1::2/64
N/A
Vlan-int30
IPv4: 30.1.1.1/24
IPv6: 30:1::1/64
N/A
Device F
XGE2/4/5
IPv4: 220.1.1.6/24
Device E: XGE1/4/5
Vlan-int20
IPv4: 20.1.1.2/24
IPv6: 20:1::2/64
N/A
Vlan-int30
IPv4: 30.1.1.1/24
IPv6: 30:1::1/64
N/A
Applicable product matrix
IMPORTANT
IMPORTANT:
In addition to running an applicable software version, you must also install the most recent patch, if any.
Device
Software version
S6805, S6825, S6850, S9850, S9820-64H, S9820-8C
R6710
S6800, S6860
R6710
S12500X-AF, S6890
R2825
S12500R
R5210
S12500G-AF
Under verification. To obtain the latest images, contact Technical Support.
S6812, S6813
F6628P22 and higher versions.
Analysis
On Device E and Device F, configure an IPv4 address and an IPv6 address for VLAN-interface 20, which will act as the IPv4 gateway address and IPv6 gateway address of Server, respectively. Configure an IPv4 address and an IPv6 address for VLAN-interface 30, which will act as the IPv4 gateway address and IPv6 gateway address of VM, respectively, so that both IPv4 users and IPv6 users can access the external network through these gateways.
On Device E and Device F, configure the M-LAG member devices as the STP root bridges to eliminate the loops between the M-LAG systems.
Configuring the M-LAG systems
Procedure summary
·     Configuring M-LAG
·     Configuring the dual-active gateways
Configuring M-LAG
Configuring Device A and Device B
Device A
Device B
Remarks
stp global enable
stp global enable
Enable the spanning tree protocol globally.
By default, this feature is enabled on fixed-port switches.
m-lag role priority 10
m-lag role priority 20
Set the M-LAG role priority of an M-LAG member device.
M-LAG assigns the primary or secondary role to an M-LAG member device based on its M-LAG role priority. The smaller the priority value, the higher the priority. The device with the higher priority is the primary device.
m-lag system-mac 2-2-2
Configure the M-LAG system MAC address.
You must configure the same M-LAG system MAC address for devices in the same M-LAG system.
m-lag system-number 1
m-lag system-number 2
Set the M-LAG system number.
You must set different M-LAG system numbers for devices in the same M-LAG system.
m-lag system-priority 123
Set the M-LAG system priority.
You must set the same M-LAG system priority for devices in the same M-LAG system.
m-lag standalone enable
Enable M-LAG standalone mode.
N/A
m-lag keepalive ip destination 220.1.1.2 source 220.1.1.1
m-lag keepalive ip destination 220.1.1.1 source 220.1.1.2
Configure the destination and source IP addresses of keepalive packets.
N/A
interface Ten-GigabitEthernet 1/0/24
interface Ten-GigabitEthernet 2/0/24
Enter the interface view for the keepalive link.
N/A
port link-mode route
Configure the interface for the keepalive link to operate in route mode as a Layer 3 interface.
N/A
ip address 220.1.1.1 24
ip address 220.1.1.2 24
Assign an IP address to a keepalive link interface.
N/A
Return to system view.
N/A
m-lag mad exclude interface Ten-GigabitEthernet 1/0/24
m-lag mad exclude interface Ten-GigabitEthernet 2/0/24
Exclude the interface used for M-LAG keepalive detection from the shutdown action by M-LAG MAD.
N/A
vlan 20
vlan 20
Create VLAN 20.
N/A
N/A
interface bridge-aggregation 1
Create the Layer 2 aggregate interface to be used as the peer-link interface and enter Layer 2 aggregate interface view.
N/A
N/A
interface HundredGigE 1/0/28
interface HundredGigE 2/0/28
Enter the view of physical interfaces on the peer link.
N/A
port link-aggregation group 1
Assign the physical interfaces on the peer link to the aggregation group for the peer link (aggregation group 1).
N/A
N/A
Enter the view of the aggregation group for the peer link.
N/A
undo mac-address static source-check enable
Disable source MAC check on an interface.
N/A
link-aggregation mode dynamic
Configure the aggregate interface to operate in dynamic mode.
N/A
port m-lag peer-link 1
Specify the aggregate interface (Bridge-Aggregation 1) as the peer-link interface.
N/A
N/A
interface bridge-aggregation 2
Create an aggregate interface connecting to Server.
N/A
Configure the aggregate interface connecting to Server to operate in dynamic mode.
N/A
port m-lag group 2
port m-lag group 2
Assign the Layer 2 aggregate interface (Bridge-Aggregation 2) to M-LAG group 2.
N/A
N/A
interface bridge-aggregation 3
Create an aggregate interface connecting to Device C and Device D.
N/A
Configure the aggregate interface connecting to Device C and Device D to operate in dynamic mode.
N/A
port m-lag group 3
port m-lag group 3
Assign the Layer 3 aggregate interface (Bridge-Aggregation 3) to M-LAG group 2.
N/A
N/A
interface HundredGigE 1/0/27
interface HundredGigE 2/0/27
Enter the view of the physical interfaces connecting the M-LAG system to Server.
N/A
port link-aggregation group 2
Assign the interfaces to an M-LAG group.
N/A
N/A
Enter the view of an aggregate interface.
N/A
port link-type trunk
Set the link type of the aggregate interface to trunk.
N/A
undo port trunk permit vlan 1
Remove the trunk port from VLAN 1.
N/A
port trunk permit vlan 20
Assign the interface to the specified VLAN.
N/A
stp edged-port
stp edged-port
Specify the aggregate interface as an STP edge port.
N/A
N/A
interface range HundredGigE 1/0/25 HundredGigE 1/0/26
interface range HundredGigE 2/0/25 HundredGigE 2/0/26
Enter the view of the physical interfaces connecting the M-LAG system to Device C and Device D.
N/A
port link-aggregation group 3
N/A
N/A
N/A
N/A
N/A
N/A
N/A
link-aggregation global load-sharing algorithm 7
Configure a link aggregation load sharing algorithm.
To identify whether traffic is load-shared among aggregation member ports, use the display counters command to view the traffic on each aggregation group member port. If traffic is not well load-shared, you can use this command to specify a proper link aggregation load sharing algorithm.
This command is not supported on the S6812 and S6813 switches.
Configuring Device C and Device D
Device C
Device D
Remarks
stp global enable
stp global enable
m-lag system-mac 1-1-1
m-lag system-priority 124
N/A
m-lag keepalive ip destination 220.1.1.4 source 220.1.1.3
m-lag keepalive ip destination 220.1.1.3 source 220.1.1.4
N/A
interface Twenty-FiveGigE 1/0/11
interface Twenty-FiveGigE 2/0/11
N/A
N/A
ip address 220.1.1.3 24
ip address 220.1.1.4 24
Assign an IP address to the interface for the keepalive link.
N/A
N/A
m-lag mad exclude interface Twenty-FiveGigE 1/0/11
m-lag mad exclude interface Twenty-FiveGigE 2/0/11
N/A
vlan 20
vlan 20
Create VLAN 20.
N/A
N/A
N/A
N/A
interface HundredGigE 1/0/26
interface HundredGigE 2/0/26
N/A
N/A
N/A
N/A
N/A
N/A
N/A
Create an aggregate interface connecting to Device E and Device F.
N/A
Configure the aggregate interface connecting to Device E and Device F to operate in dynamic mode.
N/A
port lacp system-priority 101
port lacp system-priority 100
Set the LACP priority.
Set different LACP priorities for different M-LAG member devices, so that only member ports with a higher priority are selected upon brain split.
port m-lag group 2
port m-lag group 2
N/A
N/A
Create an aggregate interface connecting to Device A and Device B.
N/A
Configure the aggregate interface connecting to Device A and Device B to operate in dynamic mode.
N/A
port m-lag group 3
port m-lag group 3
Assign the Layer 3 aggregate interface (Bridge-Aggregation 3) to M-LAG group 3.
N/A
N/A
interface range HundredGigE 1/0/28 HundredGigE 1/0/29
interface range HundredGigE 2/0/28 HundredGigE 2/0/29
Enter the view of the physical interfaces connecting the M-LAG system to Device E and Device F.
N/A
N/A
N/A
N/A
N/A
N/A
N/A
interface range HundredGigE 1/0/30 HundredGigE 1/0/31
interface range HundredGigE 2/0/30 HundredGigE 2/0/31
Enter the view of the physical interfaces connecting the M-LAG system to Device A and Device B.
N/A
N/A
N/A
N/A
N/A
N/A
N/A
N/A
Configuring Device E and Device F
Device E
Device F
Remarks
stp global enable
stp global enable
m-lag system-mac 1-2-3
m-lag system-priority 122
N/A
m-lag keepalive ip destination 220.1.1.6 source 220.1.1.5
m-lag keepalive ip destination 220.1.1.5 source 220.1.1.6
N/A
interface Ten-GigabitEthernet 1/4/5
interface Ten-GigabitEthernet 2/4/5
N/A
N/A
ip address 220.1.1.5 24
ip address 220.1.1.6 24
N/A
N/A
m-lag mad exclude interface Ten-GigabitEthernet 1/4/5
m-lag mad exclude interface Ten-GigabitEthernet 2/4/5
N/A
N/A
N/A
Interface HundredGigE 1/1/8
interface HundredGigE 2/1/8
N/A
N/A
N/A
N/A
N/A
N/A
N/A
N/A
N/A
N/A
port m-lag group 2
port m-lag group 2
N/A
N/A
Create an aggregate interface connecting to Device G.
N/A
Configure the aggregate interface connecting to Device G to operate in dynamic mode.
N/A
port m-lag group 3
port m-lag group 3
N/A
N/A
interface range HundredGigE 1/0/4 HundredGigE 1/0/5
interface range HundredGigE 2/0/4 HundredGigE 2/0/5
N/A
N/A
N/A
interface HundredGigE1/0/6
interface HundredGigE2/0/6
Enter the view of the physical interfaces connecting the M-LAG system to VM.
N/A
N/A
N/A
stp instance 0 root primary
Configure the device as the root bridge.
N/A
Device E
Device F
Remarks
vlan 20 30
vlan 20 30
Create VLANs 20 and 30.
N/A
Enter the view of the aggregate interface connecting to Device D.
N/A
Set the link type of the Layer 2 aggregate interface (Bridge-Aggregation 2) to trunk.
N/A
Assign the interface to VLAN 20.
N/A
Remove the interface from VLAN 1.
N/A
N/A
Enter the view of the aggregate interface connecting to Device G.
N/A
Set the link type of the Layer 2 aggregate interface to trunk.
N/A
port trunk permit vlan 30
Assign the interface to VLAN 30.
N/A
N/A
N/A
interface vlan-interface 30
Create VLAN-interface 30.
N/A
ip address 30.1.1.1 255.255.255.0
Assign an IPv4 address to VLAN-interface 30, which is to act as an IPv4 gateway address.
N/A
mac-address 0030-0030-0030
Assign a MAC address to VLAN-interface 30.
N/A
ipv6 address 30:1::1 64
Assign an IPv6 address to VLAN-interface 30, which is to act as an IPv6 gateway address.
N/A
N/A
m-lag mad exclude interface Vlan-interface 30
Exclude VLAN-interface 30 from the shutdown action by M-LAG MAD.
N/A
interface vlan-interface 20
Create VLAN-interface 20.
N/A
ip address 20.1.1.1 255.255.255.0
Assign an IPv4 address to VLAN-interface 20, which is to act as an IPv4 gateway address.
N/A
mac-address 0020-0020-0021
Assign a MAC address to VLAN-interface 20.
N/A
ipv6 address 20:1::1 64
Assign an IPv6 address to VLAN-interface 20, which is to act as an IPv6 gateway address.
N/A
N/A
m-lag mad exclude interface Vlan-interface 20
Exclude VLAN-interface 20 from the shutdown action by M-LAG MAD.
N/A
Configuring the uplink device
Device G
vlan 30
Create VLAN 30.
Create an aggregate interface.
Interface range HundredGigE 2/0/1 HundredGigE 2/0/2
Enter the view of the physical interfaces connecting to Device E and Device F.
Assign physical interfaces to an aggregation group.
Assign the aggregate interface to VLAN 30.
Interface HundredGigE 2/0/64
Enter the view of the physical interface connecting to VM.
port access vlan 30
Set the link type of the interface to access, and assign it to VLAN 30
Traffic forwarding models
Underlay traffic characteristics
The forwarding model matrix provides the following characteristics of underlay traffic:
·     No.—Traffic number in the U-X-XXX format:
¡     U—Underlay traffic.
¡     X—Protocol number, which can be 4 (IPv4) or 6 (IPv6).
¡     XXX—Traffic sequence number.
·     Traffic type—Type of underlay traffic, which can be IPv4 known unicast or IPv6 known unicast.
·     Direction—Direction of underlay traffic. The value is south-north, which indicates traffic from the south to north.
·     Forwarding path—Nodes that underlay traffic traverses.
·     Traffic simulation—Traffic simulation method. Typically, a tester is used to simulate server traffic.
·     Load—Traffic size, which can be light (less than 1000 flows) and heavy (more than 1000 flows).
Underlay traffic forwarding models
No.
Traffic type
Direction
Forwarding path
Traffic simulation
Load
U-4-101
IPv4 known unicast
South to north
Server > M-LAG system 1 > M-LAG system 2 > M-LAG system 3 > VM
Tester
Light
N/A
U-6-101
IPv6 known unicast
South to north
Tester
Light
N/A
Testing network convergence upon single points of failure
Table 1 Network convergence upon single points of failure
Device
Failure type
Traffic interruption time
M-LAG
Single point of failure on M-LAG member links
≤ 100 ms
Single point of failure restored on M-LAG member links
≤ 100 ms
Peer link failure
≤ 500 ms
Peer link failure restored
0 ms
Keepalive link failure
0 ms
Keepalive link failure restored
0 ms
Keepalive link and peer link failure
≤ 3000 ms
Keepalive link and peer link restored
≤ 4000 ms
Upgrading the devices
≤ 500ms (legacy method, in which two M-LAG member devices are separately upgraded)
Expanding the network
0 ms
Replacing hardware
Fixed-port device: ≤ 500 ms
Modular device:
·     Device replacement: ≤ 1000 ms.
·     Switching fabric module replacement: 0 ms.
·     Service module replacement: ≤ 500 ms.
Verifying the status of the M-LAG system
Verify that the M-LAG system is working correctly on Device E and Device F. Use Device E as an example. Configure Device F in the same way Device E is configured.
# Display summary information about the peer-link interface and M-LAG interface.
[DeviceE] display m-lag summary
Flags: A -- Aggregate interface down, B -- No peer M-LAG interface configured
       C -- Configuration consistency check failed
Peer-link interface: BAGG1
Peer-link interface state (cause): UP
Keepalive link state (cause): UP
                     M-LAG interface information
M-LAG IF    M-LAG group  Local state (cause)  Peer state  Remaining down time(s)
BAGG2       2            UP                   UP          -
BAGG3       3            UP                   UP          -
# Verify that keepalive link is working correctly.
[DeviceE] display m-lag keepalive
Neighbor keepalive link status (cause): Up
Neighbor is alive for: 774 s 381 ms
Keepalive packet transmission status:
  Sent: Successful
  Received: Successful
Last received keepalive packet information:
  Source IP address: 220.1.1.2
  Time: 2022/02/07 06:50:17
  Action: Accept
M-LAG keepalive parameters:
Destination IP address: 220.1.1.6
Source IP address: 220.1.1.5
Keepalive UDP port : 6400
Keepalive VPN name : N/A
Keepalive interval : 1000 ms
Keepalive timeout  : 5 sec
Keepalive hold time: 3 sec
# Display the M-LAG system information.
[DeviceE] display m-lag system
                     System information
Local system number: 1                      Peer system number: 2
Local system MAC: 0001-0002-0003            Peer system MAC: 0001-0002-0003
Local system priority: 122                  Peer system priority: 122
Local bridge MAC: 5cc9-995f-7d7e            Peer bridge MAC: 5cc9-995f-79fa
Local effective role: Secondary             Peer effective role: Primary
Health level: 0
Standalone mode on split: Enabled
In standalone mode: No
                     System timer information
Timer                      State       Value (s)    Remaining time (s)
Auto recovery              Disabled    -            -
Restore delay              Disabled    180          -
Consistency-check delay    Disabled    90           -
Standalone delay           Disabled    0            -
Role to None delay         Disabled    60           -
# Display detailed information about the peer-link interface and M-LAG interfaces.
[DeviceE] display m-lag verbose
Flags: A -- Home_Gateway, B -- Neighbor_Gateway, C -- Other_Gateway,
       D -- PeerLink_Activity, E -- DRCP_Timeout, F -- Gateway_Sync,
       G -- Port_Sync, H -- Expired
Peer-link interface/Peer-link interface ID: BAGG1/1
State: UP
Cause: -
Local DRCP flags/Peer DRCP flags: ABDFG/ABDFG
Local Selected ports (index): HGE1/1/8 (40)
Peer Selected ports indexes: 235
M-LAG interface/M-LAG group ID: BAGG2/2
Local M-LAG interface state: UP
Peer M-LAG interface state: UP
M-LAG group state: UP
Local M-LAG interface down cause: -
Remaining M-LAG DOWN time: -
Local M-LAG interface LACP MAC: Config=N/A, Effective=0001-0002-0003
Peer M-LAG interface LACP MAC: Config=N/A, Effective=0001-0002-0003
Local M-LAG interface LACP priority: Config=32768, Effective=122
Peer M-LAG interface LACP priority: Config=32768, Effective=122
Local Selected ports (index): HGE1/1/4 (20), HGE1/1/5 (25)
Peer Selected ports indexes: 215, 220
M-LAG interface/M-LAG group ID: BAGG3/3
Local Selected ports (index): FGE1/2/1 (45)
Peer Selected ports indexes: 240
Verifying that the STP state is normal
# Display the STP state after the M-LAG systems are cascaded. On Device A, Device B, Device C, Device D, Device E, and Device F, the STP state of each aggregate interface is FORWARDING, and the root bridge is 0.0001-0002-0003.
[DeviceE] display stp brief
MST ID   Port                                   Role  STP State   Protection
0        Bridge-Aggregation2 (M-LAG)            DESI  FORWARDING  NONE
0        Bridge-Aggregation3 (M-LAG)            DESI  FORWARDING  NONE
[DeviceE] display stp root
MST ID   Root Bridge ID        ExtPathCost IntPathCost Root Port
0        0.0001-0002-0003      0           0
[DeviceF] display stp brief
[DeviceF] display stp root
[DeviceC] display stp brief
0        Bridge-Aggregation2 (M-LAG)            ROOT  FORWARDING  NONE
[DeviceC] display stp root
0        0.0001-0002-0003      1           0           BAGG2
[DeviceD] display stp brief
[DeviceD] display stp root
[DeviceA] display stp brief
[DeviceA] display stp root
[DeviceB] display stp brief
[DeviceB] display stp root
This section describes how to upgrade the software for M-LAG member devices.
Checking the environment
Execute the commands in "Verifying the configuration" and the following commands to verify that the devices are available for an upgrade.
M-LAG 1
M-LAG 2
display device
display device
Displays device information.
display boot-loader
display boot-loader
Displays current software images and startup software images.
display version
display version
Displays system version information.
See H3C Switches M-LAG System Upgrade & Replacement & Expansion Guide.
Verifying the traffic interruption time during the upgrade
Verify that the legacy upgrade method is used, in which the two M-LAG member devices are upgraded one by one. Verify that the traffic downtime of a member device is less than 500 ms upon failover and 150 ms upon fallback. For more information, see “Testing network convergence upon single points of failure.”
Verifying the upgrade result
Execute the commands in "Verifying the configuration" and the following commands to verify that the device is upgraded successfully.
M-LAG 1
M-LAG 2
display device
display device
display boot-loader
display boot-loader
display version
display version
An expansion operation adds two leaf devices.
Execute the commands in "Verifying the configuration" and the following commands to verify that the device is available for an expansion.
M-LAG 1
M-LAG 2
display device
display device
Displays summary information about the peer-link interface and M-LAG interfaces.
display boot-loader
display boot-loader
display version
display version
1.     Disconnect the device from network management systems.
2.     Upgrade the software of the device as needed.
3.     Preconfigure the device.
4.     Connect the device to network management systems.
5.     Incorporate the device on the controller.
Verifying the expansion result
Execute the following commands to verify that the device is added successfully.
M-LAG 1
M-LAG 2
display device
display device
display boot-loader
display boot-loader
display version
display version
Replacing hardware
Replacing a service module
Execute the commands in "Verifying the configuration" and the following commands to verify that the device is available for a replacement.
M-LAG 1
M-LAG 2
display device
display device
display boot-loader
display boot-loader
display version
display version
Replacing hardware
Switch service and management traffic on the target service module to other service modules.
Power off the device and replace the service module, or replace the service module when the device is running. For more information, see the installation guides for the service module.
For details, see H3C Switches M-LAG System Upgrade & Replacement & Expansion Guide.
Verifying the replacement result
Execute the commands in "Checking the environment."
Replacing a switching fabric module
M-LAG 1
M-LAG 2
display device
display device
display boot-loader
display boot-loader
display version
display version
Replacing hardware
Power off the device and replace the switching fabric module, or replace the switching fabric module when the device is running. For more information, see the installation guides for the switching fabric module.
Replace a device
M-LAG 1
M-LAG 2
display device
display device
display boot-loader
display boot-loader
display version
display version
Replacing hardware
