H3C Network Adapter Datasheet-6W103
HomeSupportServersNetwork AdapterProduct LiteratureCard DatasheetsH3C Network Adapter Datasheet-6W103
05-sLOM network adapter specifications
05-sLOM network adapter specifications 827.93 KB
The figures in this section are for illustration only.
sLOM network adapter list
Table 1 sLOM network adapters
Model
Specifications
NIC-GE-4P-360T-s2
4-port GE electrical interface sLOM network adapter
NIC-10GE-2P-530F-s3
2-port 10-GE optical interface sLOM network adapter (SFP+)
NIC-ETH561F-sL-2*10G
NIC-ETH561F-sL-4*10G
4-port 10-GE optical interface sLOM network adapter (SFP+)
NIC-ETH640F-L-2*25G
2-port 25-GE optical interface sLOM network adapter (SFP28)
NIC-ETH563T-SL-2P
2-port 10-GE electrical interface sLOM network adapter (RJ-45)
NIC-GE-4P-360T-s2
Figure 1 NIC-GE-4P-360T-s2
Ports and LEDs
Figure 2 NIC-GE-4P-360T-s2 front panel
(1) RJ-45 copper port LINK LED
(2) RJ-45 copper port ACT LED
(3) 1000Base-T Ethernet ports 1 through 4 (from left to right)
For information about the copper port LEDs, see Table 15.
Technical specifications
Table 2 NIC-GE-4P-360T-s2 technical specifications
Item
Specifications
Basic properties
Chip model
Intel NHI350AM4
Maximum power consumption
6 W
Bus type
PCIe 2.0 ×4
Form factor
Embedded sLOM (128 × 78 mm or 5.04 × 3.07 in)
Network properties
Connectors
4 × RJ-45
Data rate
10/100/1000 Mbit/s
Transmission media
STP cable
Duplex mode
Full duplex/half duplex
Standards
802.3, 802.3ab, 802.3u, 802.3x, 802.3ad, 802.1q, 802.3az
Features
Table 3 NIC-GE-4P-360T-s2 features
Feature
Supported
Jumbo Frames
Load Balancing
802.1Q VLANs
Auto-Negotiation
FCoE
iSCSI
SRIOV
VMDq
Multiple Rx Queues (RSS)
TCP/IP Stateless Offloading
TCP/IP Offload Engine (TOE)
Wake-on-LAN
RDMA over Converged Ethernet version 1 (RoCE v1)
RDMA over Converged Ethernet version 2 (RoCE v2)
Internet Wide Area RDMA Protocol (iWARP)
NPAR
NCSI
NIC bonding
DPDK
IPv6
LLDP
LLDP Pass-through
Remote boot
PXE Boot
FCoE Boot
iSCSI Boot
·     One asterisk (*) indicates that the feature is not available for VMware ESXi.
·     Three asterisks (***) indicate that the feature is available only for Linux and BSD.
·     Only one port on the network adapter supports NCSI at a time.
NIC-10GE-2P-530F-s3
Figure 3 NIC-10GE-2P-530F-s3
Ports and LEDs
Figure 4 NIC-10GE-2P-530F-s3 front panel
(1) SFP+ fiber port ACT LED
(2) SFP+ fiber port LINK LED
(3) 10-GE SFP+ fiber ports (2 in total)
For information about the fiber port LEDs, see Table 14.
Table 4 NIC-10GE-2P-530F-s3 technical specifications
Item
Specifications
Basic properties
Chip model
BCM57810S
10 W
Bus type
PCIe 2.0 ×8
Form factor
Network properties
Connectors
2 × 10-GE SFP+
Data rate
1/10 Gbit/s
Transmission media
Optical fiber
Duplex mode
Full duplex
Standards
Features
Table 5 NIC-10GE-2P-530F-s3 features
Feature
Supported
Jumbo Frames
Load Balancing
802.1Q VLANs
Auto-Negotiation
FCoE
iSCSI
SRIOV
VMDq
Wake-on-LAN
NPAR
NCSI
NIC bonding
DPDK
IPv6
LLDP
LLDP Pass-through
Remote boot
PXE Boot
FCoE Boot
iSCSI Boot
Ports and LEDs
Figure 5 NIC-ETH561F-sL-2*10G front panel
(1) SFP+ fiber port LED (one for each port)
(2) 10-GE SFP+ fiber ports (2 in total)
For information about the fiber port LED, see Table 16.
Table 6 NIC-ETH561F-sL-2*10G technical specifications
Item
Specifications
Basic properties
Chip model
Intel X710-BM2
10 W
Bus type
PCIe 3.0 ×8
Form factor
Network properties
Connectors
2 × 10-GE SFP+
Data rate
10 Gbit/s
Transmission media
Optical fiber
Duplex mode
Standards
802.3, 802.3ad, 802.1Qbg, 802.1as, 802.1Q, 802.1p
Features
Table 7 NIC-ETH561F-sL-2*10G features
Feature
Supported
Jumbo Frames
Load Balancing
802.1Q VLANs
Auto-Negotiation
FCoE
iSCSI
SRIOV
VMDq
Wake-on-LAN
NPAR
NCSI
NIC bonding
DPDK
IPv6
LLDP
LLDP Pass-through
Remote boot
PXE Boot
FCoE Boot
iSCSI Boot
·     A pound sign (#) indicates that the feature is available only in UEFI mode.
Figure 6 NIC-ETH561F-sL-4*10G
Ports and LEDs
Figure 7 NIC-ETH561F-sL-4*10G front panel
(2) 10-GE SFP+ fiber ports 1 through 4 (from left to right)
Table 8 NIC-ETH561F-sL-4*10G
Item
Specifications
Basic properties
Chip model
Intel XL710-BM1
13 W
Bus type
PCIe 3.0 ×8
Form factor
Network properties
Connectors
4 × 10-GE SFP+
Data rate
10 Gbit/s
Transmission media
Optical fiber
Duplex mode
Standards
Features
Table 9 NIC-ETH561F-sL-4*10G features
Feature
Supported
Jumbo Frames
Load Balancing
802.1Q VLANs
Auto-Negotiation
FCoE
iSCSI
SRIOV
VMDq
Wake-on-LAN
NPAR
NCSI
NIC bonding
DPDK
IPv6
LLDP
LLDP Pass-through
Remote boot
PXE Boot
FCoE Boot
iSCSI Boot
NIC-ETH640F-L-2*25G
Figure 8 NIC-ETH640F-L-2*25G
Ports and LEDs
Figure 9 NIC-ETH640F-L-2*25G front panel
(1) SFP28 fiber port ACT LED
(2) SFP28 fiber port LINK LED
(3) SFP28 fiber port (2 in total)
Table 10 NIC-ETH640F-L-2*25G technical specifications
Item
Specifications
Basic properties
Chip model
Mellanox ConnectX-4 Lx (MT27712A0-FDCF-AE)
9.2 W
Bus type
PCIe3.0 ×8
Form factor
Network properties
Connectors
2 × 25-GE SFP28
Data rate
10/25 Gbit/s
Transmission media
Optical fiber
Duplex mode
Full duplex
Standards
802.3, 802.3ad, 802.3az, 802.3ae, 802.3ap, 802.1Q, 802.1p, 802.1Qau, 802.1Qbb, 802.1Qbg, and IEEE802.3BYY2016
Available transceiver modules
See "About H3C Network Adapters."
Features
Table 11 NIC-ETH640F-L-2*25G features
Feature
Supported
Jumbo Frames
Load Balancing
802.1Q VLANs
Auto-Negotiation
FCoE
iSCSI
SRIOV
VMDq
Wake-on-LAN
NPAR
NCSI
NIC bonding
DPDK
IPv6
LLDP
LLDP Pass-through
Remote boot
PXE Boot
FCoE Boot
iSCSI Boot
NIC-ETH563T-sL-2P
Figure 10 NIC-ETH563T-sL-2P
Ports and LEDs
(3) RJ-45 copper ports (2 in total)
Table 12 NIC-ETH563T-sL-2P technical specifications
Item
Specifications
Basic properties
Chip model
Intel ELX550AT2SLL2E
16.2 W
Bus type
PCIE3.0 ×4
Form factor
Network properties
Connectors
2 × 10-GE RJ-45
Data rate
1/10 Gbit/s
Transmission media
STP cable
Duplex mode
Full duplex
Standards
802.3, 802.3ab, 802.3ad, 802.1q, 802.3az
Features
Table 13 NIC-ETH563T-sL-2P features
Feature
Supported
Jumbo Frames
Load Balancing
802.1Q VLANs
Auto-Negotiation
FCoE
iSCSI
SRIOV
VMDq
Wake-on-LAN
NPAR
NCSI
NIC bonding
DPDK
IPv6
LLDP
LLDP Pass-through
Remote boot
PXE Boot
FCoE Boot
iSCSI Boot
LEDs
Table 14 SFP+/SFP28 port status LED description
Status
LINK (amber)
ACT (green)
Steady on
Flashing
The port is sending or receiving data.
Steady on
Off
A link is present, but the port is not sending or receiving data.
Off
Off
No link is present.
Table 15 RJ-45 port status LED description
Status
LINK (green)
ACT (green)
Steady on
Flashing
Steady on
Off
Off
Off
No link is present.
Table 16 SFP+ port status LED description for NIC-ETH561F-sL-2*10G and NIC-ETH561F-sL-4*10G
Status
Steady green
A 10-GE link is present, but no data is being sent or received.
Flashing green
A 10-GE link is present, and the port is sending or receiving data.
Steady amber
A GE link is present, but no data is being sent or received.
Flashing amber
A GE link is present, and the port is sending or receiving data.
Off
No link is present.
