H3C Network Adapter Datasheet-6W103
HomeSupportServersNetwork AdapterProduct LiteratureCard DatasheetsH3C Network Adapter Datasheet-6W103
01-About H3C Network Adapters
01-About H3C Network Adapters 363.61 KB
H3C provides network adapters of multiple types for different application scenarios. The network adapters help servers process networking data to reduce the load on processors, improving server stability.
Table 1 lists H3C network adapters.
A row might contain multiple network adapter models, which essentially correspond to the same physical network adapter.
The model name of a network adapter in this document might differ slightly from its model name label. A model name in this document might be simplified. For example, the CNA-10GE-2P-510F-B2-1-X network adapter represents network adapter labels including UN-CNA-10GE-2P-510F-B2-1-X and UN-CNA-10GE-2P-510F-B2-1.
Table 1 Network adapters
Model
Connector
Feature
Applicable scenarios
·     CNA-10GE-2P-510F-B2
·     CNA-10GE-2P-510F-B2-1-X
PCIe
2 × 10-GE SFP+ fiber ports
High performance
·     Data center networking
·     Cloud computing
·     Network storage
·     High performance computing
·     NIC-10GE-2P-520F-B2
·     NIC-10GE-2P-520F-B2-1-X
·     NIC-10GE-2P-530F-STD-B
PCIe
Low latency
·     Cloud computing
·     NIC-10GE-2P-530F-B2
·     NIC-10GE-2P-530F-B2-1-X
PCIe
NPAR
Flexible network configuration
·     CNA-10GE-2P-560F-B2
·     ST-CNA-10GE-2P-560F
·     CNA-10GE-2P-560F-B2-1-X
PCIe
All functions supported
·     Virtual environment
·     Unification of network environment
·     NIC-GE-4P-360T-B2
·     NIC-GE-4P-360T-B2-1-X
·     NIC-ETH360T-LP-4*1G
PCIe
4 × GE RJ-45 copper ports
Basic functions supported
Virtual environment
NIC-ETH330T-LP-4P
PCIe
·     CNA-560T-B2-10Gb-2P
·     CNA-560T-B2-10Gb-2P-1-X
·     NIC-ETH563T-LP-2*10G
PCIe
2 × 10-GE RJ-45 copper ports
Virtual environment
·     NIC-620F-B2-25Gb-2P
·     NIC-620F-B2-25Gb-2P-1
·     NIC-620F-B2-25Gb-2P-2
·     NIC-620F-B2-25Gb-2P-1-X
·     NIC-25GE-2P-620F-STD-B
PCIe
2 × 25-GE SFP28 fiber ports
High performance
·     Cloud computing
·     Network storage
·     NIC-ETH540F-LP-2P
·     NIC-ETH540F-LP-2P-1
PCIe
NIC-ETH641F-LP-2P
PCIe
2 × 25-GE QSFP28 fiber ports
High performance
·     Cloud computing
·     Network storage
NIC-ETH1040F-LP-2P
PCIe
2 × 100-GE QSFP56 fiber ports
High performance
·     Cloud computing
·     Network storage
NIC-ETH1060F-LP-2P
PCIe
2 × 100-GE QSFP28 fiber ports
High performance
·     Cloud computing
·     Network storage
NIC-ETH531F-LP-2P
PCIe
2 × 10GE SFP+ fiber ports
·     Flexible network configuration
·     NIC-10GE-2P-530F-L2
·     ST-NIC-10GE-2P-530F
FLOM
NPAR
·     NIC-10GE-2P-560F-LOM
FLOM
Virtual environment
NIC-GE-4P-360T-L2
FLOM
Virtual environment
·     CNA-560T-L2-10Gb-2P
·     NIC-ETH560T-fL-2P
FLOM
Virtual environment
NIC-10GE-2P-560F-L2
mLOM
Virtual environment
NIC-10GE-2P-560F-L2-M
mLOM
Virtual environment
NIC-GE-4P-360T-L3
mLOM
Virtual environment
NIC-GE-4P-360T-L3-M
mLOM
Virtual environment
NIC-10GE-2P-560T-L2
mLOM
Virtual environment
NIC-10GE-2P-560T-L2-M
mLOM
Virtual environment
NIC-GE-4P-360T-s2
sLOM
Virtual environment
NIC-10GE-2P-530F-s3
sLOM
·     Network storage
NIC-ETH561F-sL-2*10G
sLOM
Virtual environment
NIC-ETH561F-sL-4*10G
sLOM
4 × 10-GE SFP+ fiber ports
Virtual environment
NIC-ETH640F-L-2*25G
sLOM
High performance
·     Cloud computing
·     Network storage
NIC-ETH563T-SL-2P
sLOM
·     Network storage
NIC-ETH640F-3S-2P
OCP
High performance
·     Cloud computing
·     Network storage
NIC-ETH540F-3S-2P
OCP
High performance
·     Cloud computing
·     Network storage
NIC-ETH561F-3S-2P
OCP
Virtual environment
NIC-ETH565T-3S-2P
OCP
·     Network storage
NIC-ETH360T-3S-4P
OCP
Virtual environment
NIC-ETH660F-3S-2P
OCP
2 × 25-GE SFP28+ fiber ports
High performance
·     Cloud computing
·     Network storage
NIC-ETH330T-3S-4P
OCP
NIC-ETH531F-3S-2P
OCP
Application scenarios
This section introduces the applicable scenarios for H3C network adapters.
The network adapters provide the following benefits for data center networking:
·     Scaling out of servers and NAS.
·     Fast implementation of data transfer and synchronization between data centers.
·     Reduced network cost through the unification of LANs, SANs and cluster networks.
Cloud computing
The network adapters provide the following benefits for cloud computing:
·     Maximized cloud scale and utilization through network adapter virtualization.
·     Support of high performance computing (HPC) via InfiniBand and FC application without Ethernet network adjustment.
·     Differentiated services through QoS traffic management.
Network storage
Deploying high-performance NAS and Ethernet-based IP SANs can help implement the shared storage system at the file level and block level.
HPC requires high-speed transmission between cluster networks, LANs, and SANs, which can be achieved by deploying high-bandwidth and ultra-low-latency Ethernet networks.
NPAR can split a physical Ethernet interface into multiple partitions or multiple virtual interfaces with each virtual interface supporting TCP/IP or iSCSI. You can also configure SR-IOV on a virtual interface to manage network resources flexibly and efficiently.
Virtual environment
The network adapters can provide the following features:
·     Intel virtualization technologyHelps reduce I/O bottlenecks and improve overall server performance.
·     VMDqEnhances processing efficiency of I/O controllers by hardware-assisted virtualization.
·     VMDcEnables VMs to provide physical host-like performance, increases VM scalability, and enables flexible VM migration between physical servers through direct interconnection.
Supporting both LANs and SANs, the network adapters integrates previously dispersed network resources, and simplifies I/O adapter deployment and cabling, which reduces management and operating costs.
Network adapter driver
To obtain the driver and driver installation guide for the network adapter, access the H3C official website at http://www.h3c.com/cn/Service/Software_Download/.
Transceiver modules
For information about transceiver modules available for H3C network adapters, use the Transceiver Module Lookup Tool at https://www.h3c.com/en/Support/Resource_Center/Technical_Documents/Severs/. For detailed specifications about transceiver modules, see H3C Transceiver Modules User Guide.
Environment requirements
Before using a network adapter, make sure the environment meets the following requirements as shown in Table 2, Table 3, and Table 4.
Table 2 Temperature requirements
Item
Specifications
Operating temperature
·     0°C to 50°C (32°F to 122°F):
¡     CNA-10GE-2P-510F-B2
·     0°C to 45°C (32°F to 113°F):
¡     NIC-10GE-2P-560F-L2
¡     NIC-GE-4P-360T-L3
¡     NIC-10GE-2P-560T-L2
¡     NIC-10GE-2P-560F-L2-M
¡     NIC-GE-4P-360T-L3-M
¡     NIC-10GE-2P-560T-L2-M
·     5°C to 45°C (41°F to 113°F):
¡     NIC-ETH640F-L-2*25G
·     0°C to 55°C (32°F to 131°F): Network adapters not listed above.
Storage temperature
40°C to +70°C (–40°F to +158°F)
Table 3 Humidity requirements
Item
Specifications
Operating humidity
8% RH to 90% RH, non-condensing
Storage humidity
5% RH to 95% RH, non-condensing
Table 4 Altitude requirements
Item
Specifications
Operating altitude
–60 m to +5000 m (–196.85 ft to +16404.20 ft)
The allowed maximum temperature decreases by 0.33 °C (32.59°F) as the altitude increases by 100 m (328.08 ft) from 900 m (2952.76 ft).
Storage altitude
