H3C Network Adapter Datasheet-6W103
HomeSupportServersNetwork AdapterProduct LiteratureCard DatasheetsH3C Network Adapter Datasheet-6W103
03-FLOM network adapter specifications
03-FLOM network adapter specifications 545.57 KB
The figures in this section are for illustration only.
FLOM network adapter list
Table 1 FLOM network adapters
Model
Specifications
NIC-10GE-2P-530F-L2
2-port 10-GE optical interface LOM network adapter (SFP+)
NIC-10GE-2P-560F-LOM
NIC-GE-4P-360T-L2
4-port GE electrical interface LOM network adapter
CNA-560T-L2-10Gb-2P
2-port GE electrical interface LOM network adapter
NIC-10GE-2P-530F-L2
Figure 1 NIC-10GE-2P-530F-L2
Ports and LEDs
Figure 2 NIC-10GE-2P-530F-L2 front panel
v6r1_003
(1) SFP+ fiber port ACT LED
(2) SFP+ fiber port LINK LED
(3) 10-GE SFP+ fiber ports (2 in total)
For information about the fiber port LEDs, see Table 10.
Technical specifications
Table 2 NIC-10GE-2P-530F-L2 technical specifications
Item
Specifications
Basic properties
Chip model
Qlogic BCM57810S
Maximum power consumption
10 W
Bus type
PCIe2.0 ×8
Form factor
FLOM
Network properties
Connectors
2 × 10-GE SFP+
Data rate
10 Gbit/s
Transmission media
Optical fiber
Duplex mode
Full duplex
Standards
802.3, 802.3ab, 802.3u, 802.3x, 802.3ad, 802.1q, 802.3az
Available transceiver modules
See "About H3C Network Adapters."
Features
Table 3 NIC-10GE-2P-530F-L2 features
Feature
Supported
Jumbo Frames
Load Balancing
802.1Q VLANs
Auto-Negotiation
FCoE
iSCSI
SRIOV
VMDq
Multiple Rx Queues (RSS)
TCP/IP Stateless Offloading
TCP/IP Offload Engine (TOE)
Wake-on-LAN
RDMA over Converged Ethernet version 1 (RoCE v1)
RDMA over Converged Ethernet version 2 (RoCE v2)
Internet Wide Area RDMA Protocol (iWARP)
NPAR
NCSI
NIC bonding
DPDK
IPv6
LLDP
LLDP Pass-through
Remote boot
PXE Boot
FCoE Boot
iSCSI Boot
·     One asterisk (*) indicates that the feature is not available for VMware ESXi.
·     Only one port on the network adapter supports NCSI at a time.
Figure 3 NIC-10GE-2P-560F-LOM
Ports and LEDs
Figure 4 NIC-10GE-2P-560F-LOM front panel
v6r1_003
Table 4 NIC-10GE-2P-560F-LOM technical specifications
Item
Specifications
Basic properties
Chip model
Intel JL82599
15 W
Bus type
PCIe2.0 ×8
Form factor
FLOM
Network properties
Connectors
2 × 10-GE SFP+
Data rate
10 Gbit/s
Transmission media
Optical fiber
Duplex mode
Full duplex
Standards
Features
Table 5 NIC-10GE-2P-560F-LOM features
Feature
Supported
Jumbo Frames
Load Balancing
802.1Q VLANs
Auto-Negotiation
FCoE
iSCSI
SRIOV
VMDq
Wake-on-LAN
NPAR
NCSI
NIC bonding
DPDK
IPv6
LLDP
LLDP Pass-through
Remote boot
PXE Boot
FCoE Boot
iSCSI Boot
·     Two asterisks (**) indicate that the feature is not available for H3C CAS or VMware ESXi.
·     Three asterisks (***) indicate that the feature is available only for Linux and BSD.
NIC-GE-4P-360T-L2
Figure 5 NIC-GE-4P-360T-L2
Ports and LEDs
Figure 6 NIC-GE-4P-360T-L2 front panel
v6r1_004
(1) RJ-45 copper port LINK LED
(2) RJ-45 copper port ACT LED
(3) 10/100/1000Base-T autosensing Ethernet ports 1 through 4 (from right to left)
For information about the copper port LEDs, see Table 11.
Table 6 NIC-GE-4P-360T-L2 technical specifications
Item
Specifications
Basic properties
Chip model
Intel NHI350AM
5 W
Bus type
PCIe2.0 ×4
Form factor
FLOM
Network properties
Connectors
4 × RJ-45
Data rate
10/100/1000 Mbit/s
Transmission media
STP cable
Duplex mode
Full duplex
Standards
Features
Table 7 NIC-GE-4P-360T-L2 features
Feature
Supported
Jumbo Frames
Load Balancing
802.1Q VLANs
Auto-Negotiation
FCoE
iSCSI
SRIOV
VMDq
Wake-on-LAN
NPAR
NCSI
NIC bonding
DPDK
IPv6
LLDP
LLDP Pass-through
Remote boot
PXE Boot
FCoE Boot
iSCSI Boot
CNA-560T-L2-10Gb-2P
Figure 7 CNA-560T-L2-10Gb-2P
Ports and LEDs
Figure 8 CNA-560T-L2-10Gb-2P front panel
(3) 1/10Gbit/s autosensing Ethernet ports 1 and 2 (from right to left)
Table 8 CNA-560T-L2-10Gb-2P technical specifications
Item
Specifications
Basic properties
Chip model
Intel ELX550AT2SLL2E
12 W
Bus type
PCIe3.0 ×4
Form factor
FLOM
Network properties
Connectors
2 × RJ-45
Data rate
1/10 Gbit/s
Transmission media
STP cable
Duplex mode
Full duplex
Standards
802.3, 802.3u, 802.3x, 802.1q, 802.3az, 802.3an, 802.3bz, 802.3ac, 802.1Qbb, 802.1Qaz, 802.1p
Features
Table 9 CNA-560T-L2-10Gb-2P features
Feature
Supported
Jumbo Frames
Load Balancing
802.1Q VLANs
Auto-Negotiation
FCoE
iSCSI
SRIOV
VMDq
Wake-on-LAN
NPAR
NCSI
NIC bonding
DPDK
IPv6
LLDP
LLDP Pass-through
Remote boot
PXE Boot
FCoE Boot
iSCSI Boot
LEDs
Table 10 SFP+/SFP28 port status LED description
Status
LINK (amber)
ACT (green)
Steady on
Flashing
The port is sending or receiving data.
Steady on
Off
A link is present, but the port is not sending or receiving data.
Off
Off
No link is present.
Table 11 RJ-45 port status LED description
Status
LINK (green)
ACT (green)
Steady on
Flashing
Steady on
Off
Off
Off
No link is present.
