H3C Network Adapter Datasheet-6W103
HomeSupportServersNetwork AdapterProduct LiteratureCard DatasheetsH3C Network Adapter Datasheet-6W103
06-OCP network adapter specifications
06-OCP network adapter specifications 1.35 MB
OCP network adapter list
Table 1 OCP network adapters
Model
NIC-ETH640F-3S-2P
2-port 25Gb/s PCIe3.0 x8 SFP28 fiber interface ETH640F OCP3.0 Ethernet adapter (Mellanox CX4-LX)
NIC-ETH540F-3S-2P
2-port 10Gb/s PCIe3.0 x8 SFP+ fiber interface ETH540F OCP3.0 Ethernet adapter (Mellanox CX4-LX)
NIC-ETH561F-3S-2P
2-port 10Gb/s PCIe3.0 x8 SFP+ fiber interface ETH561F OCP3.0 Ethernet adapter (Intel X710)
NIC-ETH565T-3S-2P
2-port 10Gb/s PCIe3.0 x4 copper interface ETH565T OCP3.0 Ethernet adapter (Intel X710)
NIC-ETH360T-3S-4P
4-port 1Gb/s PCIe2.0 x4 copper interface ETH360T OCP3.0 Ethernet adapter (Intel i350)
NIC-ETH660F-3S-2P
2-port 25Gb/s PCIe3.0 x8 SFP28 fiber interface ETH660F OCP3.0 Ethernet adapter (Intel E810)
NIC-ETH330T-3S-4P
4-port 1Gb/s PCIe2.0 x4 copper interface ETH330T OCP3.0 Ethernet adapter (Broadcom BCM5719)
NIC-ETH531F-3S-2P
2-port 10Gb/s PCIe3.0 x8 SFP+ fiber interface ETH531F OCP3.0 Ethernet adapter (Broadcom BCM57412)
NIC-ETH3M0T-3S-4P
4-port 1Gb/s PCIe2.0 x4 copper interface ETH3M0T OCP3.0 Ethernet adapter (MUCSE RNP N500)
NIC-ETH640F-3S-2P
Figure 1 NIC-ETH640F-3S-2P
Ports and LEDs
Figure 2 NIC-ETH640F-3S-2P front panel
(1) SFP28 fiber port LINK LED
(2) SFP28 fiber port ACT LED
(3) 25GE SFP28 fiber ports (2 in total)
For information about the fiber port LEDs, see Table 25.
Technical specifications
Table 2 NIC-ETH640F-3S-2P technical specifications
Item
Specifications
Basic properties
Chip model
Mellanox ConnectX-4 Lx (MT27712A0-FDCF-AE)
Maximum power consumption
14 W
Bus type
PCIe 3.0 ×8
Form factor
OCP3.0 (76 × 115 mm or 2.99 × 4.53 in)
Network properties
Connectors
2 × 25-GE SFP28
Data rate
10/25Gbit/s
Transmission media
Optical fiber
Duplex mode
Full duplex
Standards
802.3ae, 802.3az, 802.3ap, 802.1ax, 802.1Q, 802.1p, 802.1Qaz, 802.1Qbb, 802.1Qbg
Features
Table 3 NIC-ETH640F-3S-2P features
Feature
Supported or not
Jumbo frames
Load balancing
802.1Q VLANs
Auto-negotiation
FCoE
iSCSI
SRIOV
VMDq
Multiple Rx queues (RSS)
TCP/IP stateless offloading
TCP/IP Offload Engine (TOE)
Wake-on-LAN
RDMA over Converged Ethernet version 1 (RoCE v1)
RDMA over Converged Ethernet version 2 (RoCE v2)
Internet Wide Area RDMA Protocol (iWARP)
NPAR
NCSI
NIC bonding
DPDK
IPv6
LLDP
LLDP pass-through
25 Gigabit Ethernet Consortium
Remote boot
PXE boot
FCoE boot
iSCSI boot
·     One asterisk (*) indicates that the feature is not available for VMware ESXi.
·     Three asterisks (***) indicate that the feature is available only for Linux and BSD.
·     Only one port on the network adapter supports NCSI at a time.
NIC-ETH540F-3S-2P
Figure 3 NIC-ETH540F-3S-2P
Ports and LEDs
Figure 4 NIC-ETH540F-3S-2P front panel
(1) SFP+ fiber port LINK LED
(2) SFP+ fiber port ACT LED
(3) 10-GE SFP+ fiber ports (2 in total)
Table 4 NIC-ETH540F-3S-2P technical specifications
Item
Specifications
Basic properties
Chip model
Mellanox ConnectX-4 Lx (MT27712A0-FDCF-XE)
12 W
Bus type
PCIe 3.0 ×8
Form factor
Network properties
Connectors
2 × 10-GE SFP+
Data rate
10Gbit/s
Transmission media
Optical fiber
Duplex mode
Full duplex
Standards
802.3ae, 802.3az, 802.3ap, 802.3ad, 802.1ax, 802.1Q, 802.1p, 802.1Qaz, 802.1Qbb, 802.1Qbg
Features
Table 5 NIC-ETH540F-3S-2P features
Feature
Supported or not
Jumbo frames
Load balancing
802.1Q VLANs
Auto-negotiation
FCoE
iSCSI
SRIOV
VMDq
Wake-on-LAN
NPAR
NCSI
NIC bonding
DPDK
IPv6
LLDP
LLDP pass-through
Remote boot
PXE boot
FCoE boot
iSCSI boot
NIC-ETH561F-3S-2P
Figure 5 NIC-ETH561F-3S-2P
Ports and LEDs
Figure 6 NIC-ETH561F-3S-2P front panel
For information about the fiber port LEDs, see Table 22.
Table 6 NIC-ETH561F-3S-2P technical specifications
Item
Specifications
Basic properties
Chip model
Intel FTX710-BM2
12 W
Bus type
PCIe 3.0 ×8
Form factor
Network properties
Connectors
2 × 10-GE SFP+
Data rate
10Gbit/s
Transmission media
Optical fiber
Duplex mode
Full/half duplex
Standards
802.3, 802.3ad, 802.1Qbg, 802.1as, 802.1Q, 802.1p, 802.1az, 802.1Qbb
Features
Table 7 NIC-ETH561F-3S-2P features
Feature
Supported or not
Jumbo frames
Load balancing
802.1Q VLANs
Auto-negotiation
FCoE
iSCSI
SRIOV
VMDq
Wake-on-LAN
NPAR
NCSI
NIC bonding
DPDK
IPv6
LLDP
LLDP pass-through
Remote boot
PXE boot
FCoE boot
iSCSI boot
NIC-ETH565T-3S-2P
Figure 7 NIC-ETH565T-3S-2P
Ports and LEDs
Figure 8 NIC-ETH565T-3S-2P front panel
(1) RJ-45 copper port LINK LED
(2) RJ-45 copper port ACT LED
(3) 10-GE RJ-45 copper ports (2 in total)
For information about the copper port LEDs, see Table 24.
Table 8 NIC-ETH565T-3S-2P technical specifications
Item
Specifications
Basic properties
Chip model
Intel X710-AT2
13 W
Bus type
PCIe 3.0 ×4
Form factor
Network properties
Connectors
2 × 10-GE RJ-45
Data rate
1/10Gbit/s
Transmission media
STP cable
Duplex mode
Full/half duplex
Standards
802.3, 802.3ad, 802.1Qbg, 802.1as, 802.1Q, 802.1p, 802.1az, 802.1Qbb, 802.3bz, 802.3az, 802.1Qaz
Features
Table 9 NIC-ETH565T-3S-2P features
Feature
Supported or not
Jumbo frames
Load balancing
802.1Q VLANs
Auto-negotiation
FCoE
iSCSI
SRIOV
VMDq
Wake-on-LAN
NPAR
NCSI
NIC bonding
DPDK
IPv6
LLDP
LLDP pass-through
Remote boot
PXE boot
FCoE boot
iSCSI boot
NIC-ETH360T-3S-4P
Figure 9 NIC-ETH360T-3S-4P
Ports and LEDs
Figure 10 NIC-ETH360T-3S-4P front panel
(3) GE RJ-45 copper ports 1 through 4 (from left to right)
For information about the copper port LEDs, see Table 21.
Table 10 NIC-ETH360T-3S-4P technical specifications
Item
Specifications
Basic properties
Chip model
Intel NHI350AM4
6 W
Bus type
PCIe 2.0 ×4
Form factor
Network properties
Connectors
4 × 1GE RJ-45
Data rate
10/100/1000 Mbps
Transmission media
STP cable
Duplex mode
Full/half duplex
Standards
802.3, 802.3ab, 802.3u, 802.3x, 802.3z, 802.3as, 802.3ad, 802.1q, 802.3az, 802.3ap
Features
Table 11 NIC-ETH360T-3S-4P features
Feature
Supported or not
Jumbo frames
Load balancing
802.1Q VLANs
Auto-negotiation
FCoE
iSCSI
SRIOV
VMDq
Wake-on-LAN
NPAR
NCSI
NIC bonding
DPDK
IPv6
LLDP
LLDP pass-through
Remote boot
PXE boot
FCoE boot
iSCSI boot
NIC-ETH660F-3S-2P
Figure 11 NIC-ETH660F-3S-2P
Ports and LEDs
Figure 12 NIC-ETH660F-3S-2P front panel
(3) 25-GE SFP28 fiber ports (2 in total)
For information about the fiber port LEDs, see Table 26.
Table 12 NIC-ETH660F-3S-2P technical specifications
Item
Specifications
Basic properties
Chip model
EYE810XXVAM2
9.2 W
Bus type
PCIe 4.0 ×8
Form factor
Network properties
Connectors
2 × 25-GE SFP28
Data rate
25Gbit/s
Transmission media
Optical fiber
Duplex mode
Full duplex
Standards
802.3, 802.3bd, 802.3ae, 802.3an, 802.3ap, 802.3az, 802.3ba, 802.3z
Features
Table 13 NIC-ETH660F-3S-2P features
Feature
Supported or not
Jumbo frames
Load balancing
802.1Q VLANs
Auto-negotiation
FCoE
iSCSI
SRIOV
VMDq
Wake-on-LAN
NPAR
NCSI
NIC bonding
DPDK
IPv6
LLDP
LLDP pass-through
Remote boot
PXE boot
FCoE boot
iSCSI boot
NIC-ETH330T-3S-4P
Figure 13 NIC-ETH330T-3S-4P
Ports and LEDs
Figure 14 NIC-ETH330T-3S-4P front panel
(3) 1GE RJ-45 copper ports (4 in total)
For information about the fiber port LEDs, see Table 23.
Table 14 NIC-ETH330T-3S-4P technical specifications
Item
Specifications
Basic properties
Chip model
BCM5719A1KFBG
2.3 W
Bus type
PCIe2.1 ×4
Form factor
Network properties
Connectors
4 × 1GE RJ-45
Data rate
10/100/1000 Mbit/s
Transmission media
Twisted pair cables
Duplex mode
Full duplex/half duplex
Standards
802.3, 802.3ab, 802.3u, 802.3x, 802.3ap, 802.1q, 802.3az
Features
Table 15 NIC-ETH330T-3S-4P features
Feature
Supported or not
Jumbo frames
Load balancing
802.1Q VLANs
Auto-negotiation
FCoE
iSCSI
SRIOV
VMDq
Wake-on-LAN
NPAR
NCSI
NIC bonding
DPDK
IPv6
LLDP
LLDP pass-through
Remote boot
PXE boot
FCoE boot
iSCSI boot
NIC-ETH531F-3S-2P
Figure 15 NIC-ETH531F-3S-2P
Ports and LEDs
Figure 16 NIC-ETH531F-3S-2P front panel
Table 16 NIC-ETH531F-3S-2P technical specifications
Item
Specifications
Basic properties
Chip model
BCM57412(BCM57412B1KFSBG)
8.32 W
Bus type
PCIe3.0 ×8
Form factor
Network properties
Connectors
2 × 10-GE SFP+
Data rate
10 Gbit/s
Transmission media
Optical fiber
Duplex mode
Full duplex
Standards
802.3, 802.3x, 802.3ad, 802.3az, 802.3u, 802.1q, 802.1Qbb, 802.1Qaz, 802.1Qau
Features
Table 17 NIC-ETH531F-3S-2P features
Feature
Supported or not
Jumbo frames
Load balancing
802.1Q VLANs
Auto-negotiation
FCoE
iSCSI
SRIOV
VMDq
Wake-on-LAN
NPAR
NCSI
NIC bonding
DPDK
IPv6
LLDP
LLDP pass-through
Remote boot
PXE boot
FCoE boot
iSCSI boot
NIC-ETH3M0T-3S-4P
Figure 17 NIC-ETH3M0T-3S-4P
Ports and LEDs
Figure 18 NIC-ETH3M0T-3S-4P front panel
(3) 1-GE RJ-45 copper ports (4 in total)
Table 18 NIC-ETH3M0T-3S-4P technical specifications
Item
Specifications
Basic properties
Chip model
Mucse N500L-AM4
2.71W
Bus type
PCIe 2.0 x4
Form factor
OCP3.0 (76 mm * 115 mm) (3.00 in * 4.53 in)
Network properties
Connectors
4*1GE RJ45
Data rate
10/100/1000Mbit/s
Transmission media
Twisted pair cables
Duplex mode
Standards
802.1P, 802.1Q, Y802.2, 802.3ac, 802.3az, 802.3x, 802.3z, 802.3ad
Features
Table 19 NIC-ETH3M0T-3S-4P features
Feature
Supported or not
Jumbo Frames
Load Balancing
802.1Q VLANs
Auto-Negotiation
FCoE
iSCSI
SRIOV
1
VMDq
Multiple Rx Queues(RSS)
TCP/IP Stateless Offloading
1
TCP/IP Offload Engine(TOE)
Wake-on-LAN
RoCE v1 (RDMA over Converged Ethernet version 1)
RoCE v2 (RDMA over Converged Ethernet version 2)
iWARP (Internet Wide Area RDMA Protocol)
NPAR
NCSI
4
NIC bonding
DPDK
3
IPv6
LLDP
LLDP Pass-through
Remote boot
PXE Boot
FCoE Boot
iSCSI Boot
LEDs
Table 20 SFP+/SFP28 port status LED description
Status
LINK (amber)
ACT (green)
Steady on
Flashing
The port is sending or receiving data.
Steady on
Off
A link is present, but the port is not sending or receiving data.
Off
Off
No link is present.
Table 21 RJ-45 port status LED description
Status
LINK (green)
ACT (green)
Steady on
Flashing
Steady on
Off
Off
Off
No link is present.
Table 22 SFP+ port status LED description for NIC-ETH561F-3S-2P/NIC-ETH531F-3S-2P
Status
LINK
ACT
Steady green
Flashing green
A 10-GE link is present, and the port is sending or receiving data.
Steady green
Off
A 10-GE link is present, but not data is being sent or received.
Steady amber
Flashing green
A GE link is present, and the port is sending or receiving data.
Steady amber
Off
A GE link is present, but not data is being sent or received.
Off
Off
No link is present.
Table 23 RJ-45 port status LED description for the NIC-ETH330T-3S-4P
Status
LINK
ACT (green)
Steady green
Flashing
Steady green
Off
Steady amber
Flashing
A 10M/100M link is present, and the port is sending or receiving data.
Steady amber
Off
A 10M/100M link is present, but not data is being sent or received.
Off
Off
No link is present.
Table 24 RJ-45 port status LED description for NIC-ETH565T-3S-2P
Status
LINK
ACT
Steady green
Flashing green
Steady green
Off
Steady amber
Flashing green
A 1G/100M link is present, and the port is sending or receiving data.
Steady amber
Off
A 1G/100M link is present, but not data is being sent or received.
Off
Off
No link is present.
Table 25 SFP+/SFP28 port status LED description for NIC-ETH540F-3S-2P and NIC-ETH640F-3S-2P
Status
LINK (green)
ACT (green)
Steady
Flashing
A link is present, and the port is sending or receiving data.
Steady
Off
Off
Off
No link is present.
Table 26 SFP28 port status LED description for NIC-ETH660F-3S-2P
Status
LINK
ACT
Steady green
Flashing green
A 25-GE link is present, and the port is sending or receiving data.
Steady green
Off
A 25-GE link is present, but not data is being sent or received.
Steady amber
Flashing green
Steady amber
Off
Off
Off
No link is present.
