09-MPLS
HomeSupportRouters5G IPRAN Access RoutersReference GuidesMIB CompanionH3C RA5300[RA5100-G] Routers MIB Reference-R7752-6W10009-MPLS
17-PW-ENET-STD-MIB
17-PW-ENET-STD-MIB 65.01 KB
PW-ENET-STD-MIB
About this MIB
Use this MIB to configure Ethernet PW related settings.
MIB file name
rfc5603-pw-enet-std.mib
Root object
iso(1).org(3).dod(6).internet(1).mgmt(2).mib-2(1).pwEnetStdMIB(180)
Tabular objects
pwEnetTable
About this table
This table contains the AC configuration for Ethernet PW.
Support for operations
Create
Edit/Modify
Delete
Read
Supported
Not supported
Supported
Supported
Columns
The table indexes are pwIndex and pwEnetPwInstance.
Object (OID)
Access
Value range
Implementation
pwEnetPwInstance (1.3.6.1.2.1.180.1.1.1.1)
not-accessible
Unsigned32
Unsigned32 (0..4294967295)
Index of an AC configuration entry for an Ethernet PW.
As per the MIB.
pwEnetPwVlan (1.3.6.1.2.1.180.1.1.1.2)
read-create
VlanIdOrAnyOrNone
Integer32 (0 | 1..4094 | 4095)
Negotiated VLAN ID.
As per the MIB.
pwEnetVlanMode (1.3.6.1.2.1.180.1.1.1.3)
read-create
INTEGER
other(0),
portBased(1),
noChange(2),
changeVlan(3),
addVlan(4),
removeVlan(5)
VLAN handling mode.
As per the MIB.
pwEnetPortVlan (1.3.6.1.2.1.180.1.1.1.4)
read-create
VlanIdOrAnyOrNone
Port VLAN ID.
As per the MIB.
pwEnetPortIfIndex (1.3.6.1.2.1.180.1.1.1.5)
read-create
InterfaceIndexOrZero
Integer32 (0..2147483647)
Index of the Ethernet port.
As per the MIB.
pwEnetRowStatus (1.3.6.1.2.1.180.1.1.1.7)
read-create
RowStatus
active(1),
notInService(2),
notReady(3),
createAndGo(4),
createAndWait(5),
destroy(6)
Row status.
Supports only active(1), createAndGo(4), and destroy(6).
pwEnetStorageType (1.3.6.1.2.1.180.1.1.1.8)
read-create
StorageType
other(1),
volatile(2),
nonVolatile(3),
permanent(4),
readOnly(5)
Storage type for the AC configuration entry.
Supports only the read operation.
The value is always nonVolatile(3).
If the AC is an Ethernet service instance, the values for pwType (see PW-STD-MIB), pwEnetPortVlan, pwEnetVlanMode, and pwEnetPwVlan are as follows:
encapsulation
AC access mode
pwType
pwEnetPortVlan
pwEnetVlanMode
pwEnetPwVlan
Implementation
default | tagged
ethernet
ethernet
4095
portBased
4095
For a set operation, the encapsulation supports only default.
default | tagged
ethernet
ethernetTagged
4095
addVlan
0 or requested VLAN
default | tagged
vlan
ethernet
4095
removeVlan
0
default | tagged
vlan
ethernetTagged
4095
noChange or changeVlan
4095 or requested VLAN
untagged
ethernet
ethernet
0
nochange
0
untagged
ethernet
ethernetTagged
0
addVlan
0 or requested VLAN
untagged
vlan
ethernet
0
nochange
0
untagged
vlan
ethernetTagged
0
addVlan
0 or requested VLAN
s-vid [only-tagged]
ethernet
ethernet
s-vid
noChange
s-vid
For a set operation, the encapsulation supports only s-vid.
s-vid [only-tagged]
ethernet
ethernetTagged
s-vid
addVlan
0 or requested VLAN
s-vid [only-tagged]
vlan
ethernet
s-vid
removeVlan
0
s-vid [only-tagged]
vlan
ethernetTagged
s-vid
s-vid or requested VLAN
If the AC is a Layer 3 interface, the values for pwType (see PW-STD-MIB), pwEnetPortVlan, pwEnetVlanMode, and pwEnetPwVlan are as follows:
interface type
AC access mode
pwType
pwEnetPortVlan
pwEnetVlanMode
pwEnetPwVlan
main
ethernet
ethernet
4095
portBased
4095
main
ethernet
ethernetTagged
4095
addVlan
0 or requested VLAN
sub
vlan
ethernet
vlan dot1q
removeVlan
4095
sub
vlan
ethernetTagged
vlan dot1q
changeVlan
requested VLAN
sub
vlan
ethernetTagged
vlan dot1q
noChange
vlan dot1q
vlan
vlan
ethernet
vlan ID
removeVlan
4095
vlan
vlan
ethernetTagged
vlan ID
changeVlan
requested VLAN
vlan
vlan
ethernetTagged
vlan ID
noChange
vlan ID
