- 09-MPLS
- 01-HH3C-MPLSSCRLSP-MIB
- 02-HH3C-L2VPN-MIB
- 03-HH3C-MPLS-LDP-MIB
- 04-HH3C-MPLSEXT-MIB
- 05-HH3C-MPLSLSPV-MIB
- 06-HH3C-MPLSPCE-MIB
- 07-HH3C-VSI-MIB
- 08-HH3C-MPLSTE-MIB
- 09-HH3C-MPLSSLSP-MIB
- 10-MPLS-FRR-FACILITY-STD-MIB
- 11-MPLS-FRR-GENERAL-STD-MIB
- 12-MPLS-FTN-STD-MIB
- 13-MPLS-L3VPN-STD-MIB
- 14-MPLS-LDP-STD-MIB
- 15-MPLS-LSR-STD-MIB
- 16-MPLS-TE-STD-MIB
- 17-PW-ENET-STD-MIB
- 18-PW-MPLS-STD-MIB
- 19-PW-STD-MIB
- 20-TE-MIB
06-HH3C-MPLSPCE-MIB | 88.95 KB |
HH3C-MPLSPCE-MIB
About this MIB
Use this MIB to notify PCE traps.
MIB file name
hh3c-mplspce.mib
Root object
iso(1).org(3).dod(6).internet(1).private(4).enterprises(1).hh3c(25506).hh3cCommon(2).hh3cMplsPce(240)
Scalar objects
hh3cMplsPcePcepSessInfo
Object (OID) |
Access |
Syntax |
Value range |
Implementation |
hh3cMplsPcePcepSessInfo (1.3.6.1.4.1.25506.2.240.1.1.1) |
accessible-for-notify |
OCTET STRING |
OCTET STRING (1..127) |
PCEP session information. |
As per the MIB. |
Notifications
hh3cMplsPcePcepSessDown
Basic information
OID |
Event |
Type |
Severity |
Recovery notification |
Default status |
1.3.6.1.4.1.25506.2.240.0.1 |
PCEP session DOWN |
Error |
Major |
1.3.6.1.4.1.25506.2.240.0.2 (hh3cMplsPcePcepSessUp) |
ON |
Notification triggers
This notification is generated when a PCEP session goes down. Possible reasons are as follows:
· Hold timer expired
· Source address configuration change
· Protocol error message received
· Protocol close message received
· PCEP configuration delete
System impact
If PCEP is used to calculate and delegate RSVP-TE, SR-TE, SR-TE policy, or SRv6-TE policy paths, PCEP might be unable to function and the delegated paths will bypass the nodes after a period of time.
Status control
ON
CLI: Use the snmp-agent trap enable pce-private pcepsess-up-down command.
OFF
CLI: Use the undo snmp-agent trap enable pce-private pcepsess-up-down command.
Objects
OID (object name) |
Index nodes |
Type |
Value range |
PCEP session information |
N/A |
OCTET STRING |
As per the MIB. |
Recommended action
To resolve this issue:
1. Execute the display current-configuration command to identify whether the source address configured on the PCE server is the same as the candidate server address on the PCE client.
¡ If yes, go the next step.
¡ If not, edit the configuration on the PCE client to have the source address on the PCE server the same as the candidate server address on the PCE client.
2. Execute the display current-configuration command to identify whether the keychain configuration on the PCE server matches that on the PCE client.
¡ If yes, go to the next step.
¡ If not, edit the configuration on the PCE client to have the keychain configuration on the PCE server the same as that on the PCE client.
3. Execute the display ip routing-table command on the PCE client to identify whether routes from the server are received.
¡ If not, identify whether the OSPF configuration on the PCE server matches that on the PCE client. If they do not match, edit the OSPF configuration to make sure the PCE client can receive routes from the PCE server.
4. Identify whether the physical link between the PCE client and PCE server is normal.
¡ If not, remove and reconnect or replace the cable between them.
5. If the issue persists, collect alarm information and configuration data, and then contact Technical Support for help.
Basic information
OID |
Event |
Type |
Severity |
Default status |
1.3.6.1.4.1.25506.2.240.0.2 |
PCEP session UP |
Recovery |
Warning |
N/A |
ON |
This notification is generated when a PCEP session comes up.
System impact
No impact on services.
Status control
ON
OFF
Objects
OID (object name) |
Index nodes |
Type |
Value range |
N/A |
OCTET STRING |
As per the MIB. |
Recommended action
No action is required.
hh3cMplsPceRetDelegation
Basic information
OID |
Event |
Type |
Severity |
Default status |
1.3.6.1.4.1.25506.2.240.0.3 |
The PCE server undelegates the paths delegated by the PCC. |
Error |
Major |
1.3.6.1.4.1.25506.2.240.0.4 (hh3cMplsPceRetDelegationClear) |
OFF |
This notification is generated when the PCE rejects or undelegates the paths delegated by the PCC.
System impact
The rejected or undelegated paths will be delegated to another PCE server. If no PCE server accepts the delegation within a specific period of time, the paths will bypass the nodes.
Status control
ON
CLI: Use the snmp-agent trap enable pcep-private pcep-redelegation command.
OFF
CLI: Use the undo snmp-agent trap enable pcep-private pcep-redelegation command.
Objects
OID (object name) |
Index nodes |
Type |
Value range |
hh3cMplsPceDelegationInfo (1.3.6.1.4.1.25506.2.240.1.1.2) |
PCE delegation information. |
N/A |
OCTET STRING |
As per the MIB. |
Recommended action
1. Check the reason for the undelegation. If the paths are undelegated because the number of paths that can be delegated reaches the upper limit, remove the paths from delegation or start a new PCE server. If the PCE server undelegates the paths proactively, contact Technical Support of the PCE server.
2. If the issue persists, collect alarm information and configuration data, and then contact Technical Support for help.
Basic information
OID |
Event |
Type |
Severity |
Default status |
1.3.6.1.4.1.25506.2.240.0.4 |
The PCE redelegates MPLS TE tunnels. |
Recovery |
Warning |
N/A |
OFF |
This notification is generated when the PCC redelegates paths to the PCE server successfully.
System impact
Status control
ON
OFF
Objects
OID (object name) |
Index nodes |
Type |
Value range |
PCE redelegation information. |
N/A |
OCTET STRING |
As per the MIB. |
Recommended action
