09-MPLS
HomeSupportRouters5G IPRAN Access RoutersReference GuidesMIB CompanionH3C RA5300[RA5100-G] Routers MIB Reference-R7752-6W10009-MPLS
02-HH3C-L2VPN-MIB
02-HH3C-L2VPN-MIB 108.58 KB
HH3C-L2VPN-MIB
About this MIB
Use this MIB to obtain L2VPN configuration information. This MIB also contains notifications about PW state changes.
MIB file name
hh3c-l2vpn.mib
Root object
iso(1).org(3).dod(6).internet(1).private(4).enterprises(1).hh3c(25506).hh3cCommon(2).hh3L2vpn(162)
Tabular objects
hh3cL2vpnPwcTable
About this table
This table contains PW class information.
Support for operations
Create
Edit/Modify
Delete
Read
Not supported
Not supported
Not supported
Supported
Columns
The table index is hh3cL2vpnPwcName.
Object (OID)
Access
Value range
Implementation
hh3cL2vpnPwcName (1.3.6.1.4.1.25506.2.162.2.1.1.1)
not-accessible
OCTET STRING
OCTET STRING (0..19)
PW class name.
As per the MIB.
hh3cL2vpnPwcCvType (1.3.6.1.4.1.25506.2.162.2.1.1.2)
read-create
INTEGER
unknown(1),
bfd(2),
rawBFD(3)
Encapsulation mode used by BFD packets for PW fault detection.
Supports only the read operation.
hh3cL2vpnPwcCcType (1.3.6.1.4.1.25506.2.162.2.1.1.3)
read-create
INTEGER
unknown(1),
controlWord(2),
routerAlert(3),
ttl(4)
VCCV control channel type.
hh3cL2vpnPwcControlWord (1.3.6.1.4.1.25506.2.162.2.1.1.4)
read-create
TruthValue
true(1)
false(2)
Whether the control word feature is enabled.
hh3cL2vpnPwcPwType (1.3.6.1.4.1.25506.2.162.2.1.1.5)
read-create
INTEGER
vlan(4),
ethernet(5)
PW data encapsulation type.
hh3cL2vpnPwcRowStatus (1.3.6.1.4.1.25506.2.162.2.1.1.6)
read-create
RowStatus
active(1),
notInService(2),
notReady(3),
createAndGo(4),
createAndWait(5),
destroy(6)
Row status.
hh3cL2vpnXcgTable
About this table
This table contains L2VPN cross-connect group information.
Create
Edit/Modify
Delete
Read
Not supported
Not supported
Not supported
Supported
Columns
The table index is hh3cL2vpnXcgName.
Object (OID)
Access
Value range
Implementation
hh3cL2vpnXcgName (1.3.6.1.4.1.25506.2.162.3.1.1.1)
not-accessible
OCTET STRING
OCTET STRING (1..31))
Name of the cross-connect group.
As per the MIB.
hh3cL2vpnXcgAdminState (1.3.6.1.4.1.25506.2.162.3.1.1.2)
read-create
INTEGER
adminUp(1),
adminDown(2)
Administrative state of the cross-connect group.
hh3cL2vpnXcgRowStatus (1.3.6.1.4.1.25506.2.162.3.1.1.3)
read-create
RowStatus
active(1),
notInService(2),
notReady(3),
createAndGo(4),
createAndWait(5),
destroy(6)
Row status.
hh3cL2vpnXcgConnTable
About this table
This table contains L2VPN cross-connect information.
Create
Edit/Modify
Delete
Read
Not supported
Not supported
Not supported
Supported
Columns
The table indexes are hh3cL2vpnXcgName and hh3cL2vpnXcgConnName.
Object (OID)
Access
Value range
Implementation
hh3cL2vpnXcgConnName (1.3.6.1.4.1.25506.2.162.3.2.1.1)
not-accessible
OCTET STRING
OCTET STRING (1..20)
Name of the cross-connect.
As per the MIB.
hh3cL2vpnXcgConnRowStatus (1.3.6.1.4.1.25506.2.162.3.2.1.2)
read-create
RowStatus
active(1),
notInService(2),
notReady(3),
createAndGo(4),
createAndWait(5),
destroy(6)
Row status.
hh3cL2vpnXcgAcTable
About this table
This table contains cross-connect group AC information.
Create
Edit/Modify
Delete
Read
Not supported
Not supported
Not supported
Supported
Columns
The table indexes are hh3cL2vpnXcgName, hh3cL2vpnXcgConnName, hh3cL2vpnXcgAcIfIndex, and hh3cL2vpnXcgAcEvcSrvInstId.
Object (OID)
Access
Value range
Implementation
hh3cL2vpnXcgAcIfIndex (1.3.6.1.4.1.25506.2.162.3.3.1.1)
not-accessible
InterfaceIndex
InterfaceIndex (1..2147483647)
Interface index of the AC.
As per the MIB.
hh3cL2vpnXcgAcEvcSrvInstId (1.3.6.1.4.1.25506.2.162.3.3.1.2)
not-accessible
Unsigned32
Unsigned32 (0..4294967295)
ID of the Ethernet service instance bound to the cross-connect group.
As per the MIB.
The value of this object is fixed at 0 for a Layer 3 interface.
hh3cL2vpnXcgAcAccessMode (1.3.6.1.4.1.25506.2.162.3.3.1.3)
read-create
INTEGER
vlan(1),
ethernet(2)
Access mode of the AC.
This object is meaningless when the AC is not a Layer 2 Ethernet interface.
hh3cL2vpnXcgAcRowStatus (1.3.6.1.4.1.25506.2.162.3.3.1.4)
read-create
RowStatus
active(1),
notInService(2),
notReady(3),
createAndGo(4),
createAndWait(5),
destroy(6)
Row status.
hh3cL2vpnXcgPwTable
About this table
This table contains cross-connect group PW information.
Create
Edit/Modify
Delete
Read
Not supported
Not supported
Not supported
Supported
Columns
The table indexes are hh3cL2vpnXcgName, hh3cL2vpnXcgConnName, and hh3cL2vpnXcgPwIndex.
Object (OID)
Access
Value range
Implementation
hh3cL2vpnXcgPwIndex (1.3.6.1.4.1.25506.2.162.3.4.1.1)
accessible-for-notify
Unsigned32
PW index.
As per the MIB.
hh3cL2vpnXcgPwCfgType (1.3.6.1.4.1.25506.2.162.3.4.1.2)
read-create
INTEGER
primary(1),
backup(2)
PW type, primary PW or backup PW.
hh3cL2vpnXcgPwClassName (1.3.6.1.4.1.25506.2.162.3.4.1.3)
read-create
OCTET STRING
Name of the used PW class.
hh3cL2vpnXcgPwTunnelPolicy (1.3.6.1.4.1.25506.2.162.3.4.1.4)
read-create
OCTET STRING
Name of the used tunnel policy.
hh3cL2vpnXcgPwPeerIp (1.3.6.1.4.1.25506.2.162.3.4.1.5)
IpAddress
OCTET STRING (SIZE (4))
Peer's IP address.
As per the MIB.
hh3cL2vpnXcgPwPwID (1.3.6.1.4.1.25506.2.162.3.4.1.6)
Unsigned32
PW ID.
As per the MIB.
hh3cL2vpnXcgPwRowStatus (1.3.6.1.4.1.25506.2.162.3.4.1.7)
read-create
RowStatus
active(1),
notInService(2),
notReady(3),
createAndGo(4),
createAndWait(5),
destroy(6)
Row status.
hh3cL2vpnPwCfgTable
About this table
This table contains L2VPN PW information.
Create
Edit/Modify
Delete
Read
Not supported
Not supported
Not supported
Supported
Columns
The table indexes are hh3cL2vpnPwPeerIp and hh3cL2vpnPwId.
Object (OID)
Access
Value range
Implementation
hh3cL2vpnPwPeerIp
(1.3.6.1.4.1.25506.2.162.5.1.1.1)
not-accessible
IpAddress
OCTET STRING (4)
Peer IP address of a PW.
As per the MIB.
 hh3cL2vpnPwId
(1.3.6.1.4.1.25506.2.162.5.1.1.2)
not-accessible
Unsigned32
PW ID.
As per the MIB.
Notifications
hh3cL2vpnPwSwitchPtoB
Basic information
OID
Event
Severity
Recovery notification
Default status
1.3.6.1.4.1.25506.2.162.0.1
Traffic is switched from the primary PW to the backup PW.
Error
Warning
1.3.6.1.4.1.25506.2.162.0.2(hh3cL2vpnPwSwitchBtoP)
OFF
Notification triggers
This notification is generated when the traffic is switched from the primary PW to the backup PW.
System impact
Millisecond-level packet loss will occur when the traffic is switched from the primary PW to the backup PW.
Status control
ON
CLI: Use the snmp-agent trap enable l2vpn pw-switch command.
OFF
CLI: Use the undo snmp-agent trap enable l2vpn pw-switch command.
Objects
OID (object name)
Index nodes
Value range
1.3.6.1.4.1.25506.2.162.3.4.1.1 (hh3cL2vpnXcgPwIndex)
PW index associated with the cross-connect.
hh3cL2vpnXcgPwIndex
hh3cL2vpnXcgName
Unsigned32
As per the MIB.
1.3.6.1.4.1.25506.2.162.3.4.1.5 (hh3cL2vpnXcgPwPeerIp)
IP address of the PW associated with the cross-connect.
hh3cL2vpnXcgPwIndex
hh3cL2vpnXcgName
IpAddress
As per the MIB.
1.3.6.1.4.1.25506.2.162.3.4.1.6 (hh3cL2vpnXcgPwPwID)
ID of the PW associated with the cross-connect.
hh3cL2vpnXcgPwIndex
hh3cL2vpnXcgName
Unsigned32
As per the MIB.
Recommended action
No action is required.
Basic information
OID
Event
Severity
Default status
Traffic is switched from the backup PW to the primary PW.
Recovery
Warning
N/A
OFF
This notification is generated when the traffic is switched from the backup PW to the primary PW.
System impact
Millisecond-level packet loss will occur when the traffic is switched from the backup PW to the primary PW.
Status control
ON
OFF
Objects
OID (object name)
Index nodes
Value range
hh3cL2vpnXcgPwIndex
hh3cL2vpnXcgName
Unsigned32
As per the MIB.
hh3cL2vpnXcgPwIndex
hh3cL2vpnXcgName
IpAddress
As per the MIB.
hh3cL2vpnXcgPwIndex
hh3cL2vpnXcgName
Unsigned32
As per the MIB.
Recommended action
