09-MPLS
HomeSupportRouters5G IPRAN Access RoutersReference GuidesMIB CompanionH3C RA5300[RA5100-G] Routers MIB Reference-R7752-6W10009-MPLS
07-HH3C-VSI-MIB
07-HH3C-VSI-MIB 76.15 KB
HH3C-VSI-MIB
About this MIB
Use this MIB to configure VSI.
MIB file name
hh3c-vsi.mib
Root object
iso(1).org(3).dod(6).internet(1).private(4).enterprises(1).hh3c(25506).hh3cCommon(2).hh3cVsi(105)
Tabular objects
hh3cVsiScalarGroup
About this table
This table describes the global configuration for VSI.
Support for operations
Create
Edit/Modify
Delete
Read
Supported
Not supported
Supported
Supported
Columns
This table does not contain indexes.
Object (OID)
Access
Value range
Implementation
hh3cVsiNextAvailableVsiIndex (1.3.6.1.4.1.25506.2.105.1.1.1)
read-only
Unsigned32
Unsigned32 (0..4294967295)
Next available VSI entry index.
As per the MIB.
hh3cVsiL2vpnStatus (1.3.6.1.4.1.25506.2.105.1.1.2)
read-write
TruthValue
true(1)
false(2)
Global enabling status of L2VPN.
As per the MIB.
hh3cVsiTable
About this table
Use this table to configure VSI parameters.
Create
Edit/Modify
Delete
Read
Supported
Not supported
Supported
Supported
Columns
The table index is hh3cVsiIndex.
Object (OID)
Access
Value range
Implementation
hh3cVsiIndex (1.3.6.1.4.1.25506.2.105.1.2.1.1)
not-accessible
Unsigned32
Index of a VSI.
As per the MIB.
hh3cVsiName (1.3.6.1.4.1.25506.2.105.1.2.1.2)
read-create
OCTET STRING
OCTET STRING (1..31)
Name of a VSI.
Not editable after creation.
hh3cVsiMode (1.3.6.1.4.1.25506.2.105.1.2.1.3)
read-create
INTEGER
default(0),
martini(1),
minm(2)
martiniAndMinm(3),
kompella(4),
kompellaAndMinm(5),
minmpxp(6),
martiniAndMinmpxp(7),
kompellaAndMinmpxp(8),
vxlan(9)
Mode of the VSI.
Supports only default(0) and vxlan(9). The set operation on other variables will be ignored. The default value is default(0).
hh3cMinmIsid (1.3.6.1.4.1.25506.2.105.1.2.1.4)
read-create
Integer32
Integer32 (1..2147483647)
PBB I-SID of the VSI in MAC-in-MAC mode.
hh3cVsiId (1.3.6.1.4.1.25506.2.105.1.2.1.5)
read-create
Unsigned32
Default PW ID.
hh3cVsiTransMode (1.3.6.1.4.1.25506.2.105.1.2.1.6)
read-create
INTEGER
vlan(1),
ethernet(2)
Transmit mode of the VSI.
Supports only the read operation. The value is always vlan(1).
hh3cVsiEnableHubSpoke (1.3.6.1.4.1.25506.2.105.1.2.1.7)
read-create
INTEGER
disable(1),
enable(2)
Hub-spoke capability of the VSI.
Not supported.
hh3cVsiAdminState (1.3.6.1.4.1.25506.2.105.1.2.1.8)
read-create
INTEGER
adminUp(1),
adminDown(2)
Administrative state of the VSI.
Default value: adminUp(1).
hh3cVsiRowStatus (1.3.6.1.4.1.25506.2.105.1.2.1.9)
read-create
RowStatus
active(1),
notInService(2),
notReady(3),
createAndGo(4),
createAndWait(5),
destroy(6)
Row status.
Supports only active(1), createAndGo(4), and destroy(6).
Active(1) is only used to change the value for hh3cVsiAdminState, hh3cVsiArpSuppression, hh3cVsiFlooding, and hh3cVsiStatistics.
hh3cVsiSpbIsid (1.3.6.1.4.1.25506.2.105.1.2.1.10)
read-create
Integer32
SPB I-SID of the VSI in MAC-in-MAC mode.
hh3cVsiVxlanID (1.3.6.1.4.1.25506.2.105.1.2.1.11)
read-only
Unsigned32
VXLAN ID.
Not supported.
hh3cVsiArpSuppression (1.3.6.1.4.1.25506.2.105.1.2.1.12)
read-create
TruthValue
true(1)
false(2)
The capability of ARP suppression.
Not supported.
hh3cVsiFlooding (1.3.6.1.4.1.25506.2.105.1.2.1.13)
read-create
TruthValue
true(1)
false(2)
The capability of MAC flooding.
Not supported.
hh3cVsiLocalMacCount (1.3.6.1.4.1.25506.2.105.1.2.1.14)
read-only
Unsigned32
Number of local MAC addresses of the VSI.
This value is 0 if hh3cVsiVxlanID uses an invalid value.
This value cannot be 0 if hh3cVsiVxlanID uses a valid value.
hh3cVsiInterfaceID (1.3.6.1.4.1.25506.2.105.1.2.1.15)
read-create
Unsigned32
VSI interface number.
Not supported.
hh3cVsiXconnectTable
About this table
Use this table to configure AC-VSI bindings.
Create
Edit/Modify
Delete
Read
Supported
Not supported
Supported
Supported
Columns
The table indexes are hh3cVsiXconnectIfIndex and hh3cVsiXconnectEvcSrvInstId.
Object (OID)
Access
Value range
Implementation
(1.3.6.1.4.1.25506.2.105.1.3.1.1)
not-accessible
Unsigned32
Index of an interface.
As per the MIB.
(1.3.6.1.4.1.25506.2.105.1.3.1.2)
not-accessible
Unsigned32
Service instance ID.
As per the MIB.
hh3cVsiXconnectVsiName
(1.3.6.1.4.1.25506.2.105.1.3.1.3)
read-create
OCTET STRING
Name of the VSI.
hh3cVsiXconnectAccessMode
(1.3.6.1.4.1.25506.2.105.1.3.1.4)
read-create
INTEGER
vlan(1),
ethernet(2)
Access mode.
hh3cVsiXconnectHubSpoke
(1.3.6.1.4.1.25506.2.105.1.3.1.5)
read-create
INTEGER
none(1),
hub(2),
spoke(3)
The hub-spoke capability of the service instance.
Not supported.
hh3cVsiPwBindTable
About this table
Use this table to configure PW-VSI bindings.
Create
Edit/Modify
Delete
Read
Supported
Not supported
Supported
Supported
Columns
The table indexes are hh3cVsiIndex and hh3cVsiPwIndex.
Object (OID)
Access
Value range
Implementation
hh3cVsiPwIndex (1.3.6.1.4.1.25506.2.105.1.4.1.1)
not-accessible
Unsigned32
Index of a PW.
As per the MIB.
hh3cVsiPwBindAttributes (1.3.6.1.4.1.25506.2.105.1.4.1.2)
read-create
BITS
noSplitHorizon (0),               hub (1)
PW attribute.
As per the MIB.
hh3cVsiPwBindRowStatus (1.3.6.1.4.1.25506.2.105.1.4.1.3)
read-create
RowStatus
active(1),
notInService(2),
notReady(3),
createAndGo(4),
createAndWait(5),
destroy(6)
Row status.
