- 09-MPLS
- 01-HH3C-MPLSSCRLSP-MIB
- 02-HH3C-L2VPN-MIB
- 03-HH3C-MPLS-LDP-MIB
- 04-HH3C-MPLSEXT-MIB
- 05-HH3C-MPLSLSPV-MIB
- 06-HH3C-MPLSPCE-MIB
- 07-HH3C-VSI-MIB
- 08-HH3C-MPLSTE-MIB
- 09-HH3C-MPLSSLSP-MIB
- 10-MPLS-FRR-FACILITY-STD-MIB
- 11-MPLS-FRR-GENERAL-STD-MIB
- 12-MPLS-FTN-STD-MIB
- 13-MPLS-L3VPN-STD-MIB
- 14-MPLS-LDP-STD-MIB
- 15-MPLS-LSR-STD-MIB
- 16-MPLS-TE-STD-MIB
- 17-PW-ENET-STD-MIB
- 18-PW-MPLS-STD-MIB
- 19-PW-STD-MIB
- 20-TE-MIB
04-HH3C-MPLSEXT-MIB | 172.42 KB |
HH3C-MPLSEXT-MIB
About this MIB
Use this MIB to manage MPLS and LDP capabilities and MPLS BFD sessions.
MIB file name
hh3c-mplsext.mib
Root object
iso(1).org(3).dod(6).internet(1).private(4).enterprises(1).hh3c(25506).hh3cCommon(2).hh3cMplsExt(142)
Scalar objects
hh3cMplsExtLsrID
Object (OID) |
Access |
Syntax |
Value range |
Implementation |
hh3cMplsExtLsrID (1.3.6.1.4.1.25506.2.142.1.1.1) |
read-write |
OCTET STRING |
OCTET STRING (0..255) |
Global LSR ID. |
As per the MIB. |
hh3cMplsExtLdpStatus
Object (OID) |
Access |
Syntax |
Value range |
Implementation |
hh3cMplsExtLdpStatus (1.3.6.1.4.1.25506.2.142.1.1.2) |
read-write |
TruthValue |
true(1), false(2) |
Enabling status of global LDP. |
As per the MIB. |
hh3cMplsExtLabelInfo
Object (OID) |
Access |
Syntax |
Value range |
Implementation |
hh3cMplsExtLabelInfo (1.3.6.1.4.1.25506.2.142.1.1.3) |
accessible-for-notify |
OCTET STRING |
OCTET STRING (0..127) |
MPLS label information. |
As per the MIB. |
hh3cMplsExtTnlToVpnInfo
Object (OID) |
Access |
Syntax |
Value range |
Implementation |
hh3cMplsExtTnlToVpnInfo (1.3.6.1.4.1.25506.2.142.1.1.4) |
OCTET STRING |
Tunnel policy information. |
As per the MIB. |
Tabular objects
hh3cMplsExtTable
About this table
Use this table to configure the MPLS capability for interfaces.
Support for operations
Create |
Edit/Modify |
Delete |
Read |
You cannot set an MTU for a tunnel interface. By default, the MPLS MTU depends on the interface MTU. Different types of interfaces have different MTU values. |
The MTU of a tunnel interface cannot be modified. |
Supported |
Supported |
Columns
The table index is hh3cMplsExtIndex.
Object (OID) |
Access |
Syntax |
Value range |
Implementation |
hh3cMplsExtIndex (1.3.6.1.4.1.25506.2.142.1.2.1.1) |
not-accessible |
Unsigned32 |
Unsigned32 (1..4294967295) |
Index of an interface. |
As per the MIB. |
hh3cMplsExtCapability (1.3.6.1.4.1.25506.2.142.1.2.1.2) |
read-create |
TruthValue |
true(1), false(2) |
MPLS capability of the interface. |
As per the MIB. |
hh3cMplsExtMtu (1.3.6.1.4.1.25506.2.142.1.2.1.3) |
read-create |
Unsigned32 |
Unsigned32 (46..65535) |
MPLS MTU of the interface. |
As per the MIB. |
hh3cMplsExtRowStatus (1.3.6.1.4.1.25506.2.142.1.2.1.4) |
read-create |
RowStatus |
active(1), notInService(2), notReady(3), createAndGo(4), createAndWait(5), destroy(6) |
Row status. |
Supports only active(1), createAndGo(4), and destroy(6). |
hh3cMplsExtLdpTable
About this table
Use this table to configure the LDP capability for interfaces.
Create |
Edit/Modify |
Delete |
Read |
When create, the value of hh3cMplsExtLdpCapability must be true(1). |
Supported |
Supported |
Supported |
Columns
The table index is hh3cMplsExtLdpIndex.
Object (OID) |
Access |
Syntax |
Value range |
Implementation |
hh3cMplsExtLdpIndex (1.3.6.1.4.1.25506.2.142.1.3.1.1) |
not-accessible |
Unsigned32 |
As per the MIB. |
hh3cMplsExtLdpCapability (1.3.6.1.4.1.25506.2.142.1.3.1.2) |
read-create |
TruthValue |
false(0), |
LDP capability of the interface. |
As per the MIB. |
hh3cMplsExtLdpRowStatus (1.3.6.1.4.1.25506.2.142.1.3.1.3) |
read-create |
RowStatus |
active(1),
Row status. |
hh3cMplsExtBfdTable
About this table
This table contains information about MPLS BFD sessions.
Create |
Edit/Modify |
Delete |
Read |
Not supported |
Not supported |
Not supported |
Supported |
Columns
The table index is hh3cMplsExtBfdLocalDiscr.
Object (OID) |
Access |
Syntax |
Value range |
Implementation |
hh3cMplsExtBfdLocalDiscr (1.3.6.1.4.1.25506.2.142.1.4.1.1) |
not-accessible |
Unsigned32 |
Local discriminator of a BFD session. |
As per the MIB. |
hh3cMplsExtBfdType (1.3.6.1.4.1.25506.2.142.1.4.1.2) |
read-only |
INTEGER |
1: unknown 4: BFD for VPLS PW 5: BFD for TE |
Type of the BFD session. |
As per the MIB. |
hh3cMplsExtBfdBindIfIndex (1.3.6.1.4.1.25506.2.142.1.4.1.3) |
read-only |
InterfaceIndexOrZero |
This object displays a tunnel interface index when the value of hh3cMplsExtBfdType is 5 (BFD for TE) and displays the index of an AC interface bound to a PW when the value of hh3cMplsExtBfdType is 3 (BFD for VPWS PW). This object is invalid and displays 0 when the value of hh3cMplsExtBfdType is not 5 (BFD for TE) or 3 (BFD for VPWS PW). |
Index of the bound local interface. |
As per the MIB. |
hh3cMplsExtBfdBindIfName (1.3.6.1.4.1.25506.2.142.1.4.1.4) |
read-only |
DisplayString |
DisplayString (0..255) |
Name of the bound local interface. |
As per the MIB. |
hh3cMplsExtBfdXcIndex (1.3.6.1.4.1.25506.2.142.1.4.1.5) |
read-only |
OCTET STRING |
OCTET STRING (0..24) |
MplsOutSegmentEntry index for an LSP entry. |
As per the MIB. |
hh3cMplsExtBfdPwBackupFlag (1.3.6.1.4.1.25506.2.142.1.4.1.6) |
read-only |
INTEGER |
1: Non-PW |
Primary or backup flag of a PW. |
As per the MIB. |
hh3cMplsExtBfdPwId (1.3.6.1.4.1.25506.2.142.1.4.1.7) |
read-only |
Unsigned32 |
Unsigned32 (0..4294967295) |
PW identifier. |
As per the MIB. |
hh3cMplsExtBfdVsiIndex (1.3.6.1.4.1.25506.2.142.1.4.1.8) |
read-only |
Unsigned32 |
VSI index + 1. |
As per the MIB. |
hh3cMplsExtBfdPwPeerIpType (1.3.6.1.4.1.25506.2.142.1.4.1.9) |
read-only |
InetAddressType |
IPv4 or IPv6. The value of this object is 0 if the BFD session is not for a PW. |
Type of the PW peer address. |
As per the MIB. |
hh3cMplsExtBfdPwPeerIp (1.3.6.1.4.1.25506.2.142.1.4.1.10) |
read-only |
InetAddress |
Peer address of the PW. |
As per the MIB. |
hh3cMplsExtBfdPwSPE (1.3.6.1.4.1.25506.2.142.1.4.1.11) |
read-only |
INTEGER |
1: Non-VPWS PW |
Node information of the VPWS PW. |
As per the MIB. |
hh3cMplsExtBfdPwEncapType (1.3.6.1.4.1.25506.2.142.1.4.1.12) |
read-only |
INTEGER |
1: unknown 2: fr-dlci-martini 3: atm-aal5-sdu 4: atm-trans-cell 5: vlan 6: ethernet 7: hdlc 8: ppp 9: cesom 10: atm-nto1-vcc 11: atm-nto1-vpc 12: ip-interworking 13: atm-1to1-vcc 14: atm-1to1-vpc 15: atm-aal5-pdu 16: fr-port 17: cep 18: satop-e1 19: satop-t1 20: satop-e3 21: satop-t3 22: esopsn-basic 23: tdmoip-aal1-mode 24: tdm-cesopsn-with-cas 25: tdmoip-aal2-mode 26: fr-dlci |
Encapsulation type of the PW. |
As per the MIB. |
hh3cMplsExtStaticLspTable
About this table
This table contains information about MPLS static LSPs.
Create |
Edit/Modify |
Delete |
Read |
Not supported |
Not supported |
Not supported |
Supported |
Columns
The table index is hh3cMplsExtStaticLspName.
Object (OID) |
Access |
Syntax |
Value range |
Implementation |
hh3cMplsExtStaticLspName (1.3.6.1.4.1.25506.2.142.1.7.1.1) |
not-accessible |
OCTET STRING |
OCTET STRING (1..15) |
Name of a static LSP. |
As per the MIB. |
hh3cMplsExtStaticLspType (1.3.6.1.4.1.25506.2.142.1.7.1.2) |
read-only |
Enumeration |
1—Ingress 2—Transit 3—Egress |
Type of the static LSP. |
As per the MIB. |
hh3cMplsExtStaticLspInLabel (1.3.6.1.4.1.25506.2.142.1.7.1.3) |
read-only |
Unsigned integer. |
Unsigned integer. (16..4294967295) |
Incoming label for the static LSP. |
As per the MIB. |
hh3cMplsExtStaticLspOutLabel (1.3.6.1.4.1.25506.2.142.1.7.1.4) |
read-only |
Unsigned integer |
Unsigned integer. (0,3,16..4294967295) |
Outgoing label for the static LSP. |
As per the MIB. |
hh3cMplsExtStaticLspDestAddr (1.3.6.1.4.1.25506.2.142.1.7.1.5) |
read-only |
String, dotted decimal notation. |
Destination address of the static LSP. |
As per the MIB. |
hh3cMplsExtStaticLspDestAddrMaskLen (1.3.6.1.4.1.25506.2.142.1.7.1.6) |
read-only |
Unsigned integer. |
Unsigned integer. (0..32) |
Mask length of the destination address. |
As per the MIB. |
hh3cMplsExtStaticLspNextHopAddr (1.3.6.1.4.1.25506.2.142.1.7.1.7) |
read-only |
Nexthop address of the static LSP. |
As per the MIB. |
hh3cMplsExtStaticLspOutIfIndex (1.3.6.1.4.1.25506.2.142.1.7.1.8) |
read-only |
Unsigned integer. |
Unsigned integer. (0..4294967295) |
Index of the outgoing interface for this static LSP. |
As per the MIB. |
Notifications
hh3cMplsExtLabThreExceed
Basic information
OID |
Event |
Type |
Severity |
Recovery notification |
Default status |
1.3.6.1.4.1.25506.2.142.0.1 |
The MPLS LSM label usage reached the upper threshold. |
Error |
Warning |
1.3.6.1.4.1.25506.2.142.0.2 (hh3cMplsExtLabThreExceedClear) |
OFF |
Notification triggers
This notification is generated when the usage of a type of MPLS labels reaches the upper threshold.
【System impact】
Status control
ON
CLI: Use the snmp-agent trap enable mpls-private [ label-threshold | label-total | tunnel-to-vpn | slsp-up-down ]* command.
OFF
CLI: Use the undo snmp-agent trap enable mpls-private [ label-threshold | label-total | tunnel-to-vpn | slsp-up-down ]* command.
Objects
OID (object name) |
Index nodes |
Type |
Value range |
N/A |
OCTET STRING |
As per the MIB. |
Recommended action
No action is required.
Basic information
OID |
Event |
Type |
Severity |
Default status |
1.3.6.1.4.1.25506.2.142.0.2 |
MPLS LSM label usage dropped below the lower threshold. |
Recovery |
N/A |
N/A |
OFF |
This notification is generated when the usage of a type of MPLS labels drops below the lower threshold.
【System impact】
Status control
ON
OFF
Objects
OID (object name) |
Index nodes |
Type |
Value range |
N/A |
OCTET STRING |
As per the MIB. |
Recommended action
hh3cMplsExtLabTotExceed
Basic information
OID |
Event |
Type |
Severity |
Default status |
1.3.6.1.4.1.25506.2.142.0.3 |
MPLS LSM labels are used up. |
Error |
Major |
1.3.6.1.4.1.25506.2.142.0.4 (hh3cMplsExtLabTotExceedClear) |
OFF |
This notification is generated when the usage of a type of MPLS labels reaches 100%.
【System impact】
Status control
ON
OFF
Objects
OID (object name) |
Index nodes |
Type |
Value range |
N/A |
OCTET STRING |
As per the MIB. |
Recommended action
Basic information
OID |
Event |
Type |
Severity |
Default status |
1.3.6.1.4.1.25506.2.142.0.4 |
The MPLS LSM label usage dropped to the specified value. |
Recovery |
N/A |
N/A |
OFF |
This notification is generated when the MPLS LSM label usage drops to the specified value, which is 95%.
【System impact】
Status control
ON
OFF
Objects
OID (object name) |
Index nodes |
Type |
Value range |
N/A |
OCTET STRING |
As per the MIB. |
Recommended action
hh3cMplsExtTnlToVpnEvent
Basic information
OID |
Event |
Type |
Severity |
Default status |
1.3.6.1.4.1.25506.2.142.0.5 |
The tunnel selected for the VPN changed. |
Recovery |
Major |
N/A |
OFF |
This notification is generated when the selected tunnel for the VPN changes.
【System impact】
Status control
ON
OFF
Objects
OID (object name) |
Index nodes |
Type |
Value range |
Tunnel policy information |
N/A |
OCTET STRING |
As per the MIB. |
Recommended action
