- H3C Wi-Fi7 Indoor Access Points Installation Guide-5W107
- 01-Installing the device
- 02-Logging in to the device
- 03-Appendix A AP views and technical specifications
- 04-Appendix B LEDs and buttons
- 05-Appendix C Optional transceiver modules
- 06-Appendix D Connecting the hybrid copper-fiber cable
- 07-Appendix E Cabling recommendations
- 08-Appendix F RED Declaration of Conformity
00-Preface | 110.09 KB |
Preface
This installation guide describes the installation procedure for H3C Wi-Fi 7 indoor access points.
· WA7220-HI
· WA7320i
· WA7330i
· WA7338-HI
· WA7539
· WA7638
· Audience.
· Conventions.
Audience
· Network planners.
· Network administrators working with the Wi-Fi 7 indoor access points.
Conventions
Command conventions
Convention |
Boldface |
Italic |
{ x | y | ... } |
[ x | y | ... ] |
{ x | y | ... } * |
[ x | y | ... ] * |
&<1-n> |
GUI conventions
Convention |
Boldface |
Symbols
Convention |
NOTE: |
Network topology icons
Convention |
Represents an access point. |
Documentation feedback
We appreciate your comments.
