00-Preface | 110.04 KB |
Preface
The H3C Wi-Fi 7 Access Points Cloud Mode documentation set describes the software features for the APs(cloud mode) and guide you through the software configuration procedures. These guides also provide configuration examples to help you apply software features to different network scenarios.
· Audience.
· Conventions.
Audience
· Network planners.
· Network administrators working with the H3C access points (Cloud mode).
Conventions
Command conventions
Convention |
Boldface |
Italic |
{ x | y | ... } |
[ x | y | ... ] |
{ x | y | ... } * |
[ x | y | ... ] * |
&<1-n> |
GUI conventions
Convention |
Boldface |
Symbols
Convention |
NOTE: |
Network topology icons
Convention |
Represents an access point. |
Documentation feedback
We appreciate your comments.
