06-Layer 2 - LAN Switching
HomeSupportRoutersCR16000-F SeriesReference GuidesMIB CompanionH3C CR16000-F Routers MIB Reference-R8530Pxx-6W10006-Layer 2 - LAN Switching
25-MAU-MIB
25-MAU-MIB 103.45 KB
MAU-MIB
About this MIB
This MIB is defined in RFC 3636 and contains interface media attachment unit (MAU) information.
The document might not be updated in time. For the latest detailed informatin, see the offical document at https://www.iana.org/assignments/ianamau-mib/ianamau-mib.
MIB file name
rfc3636-mau.mib
Root object
iso(1).org(3).dod(6).internet(1).mgmt(2).mib-2(1).snmpDot3MauMgt(26)
Tabular objects
ifMauTable
About this table
Use this table to obtain the interface MAU state.
Support for operations
CreateNot supported
Edit/ModifyNot supported
DeleteNot supported
ReadSupported
Columns
The table indexes are ifMauIfIndex and ifMauIndex.
Object (OID)
Access
Value range
Implementation
ifMauIfIndex (1.3.6.1.2.1.26.2.1.1.1)
read-only
InterfaceIndex
Standard MIB values.
Index of the interface in this entry.
As per the MIB.
ifMauIndex (1.3.6.1.2.1.26.2.1.1.2)
read-only
Integer32
Integer32 (1..2147483647)
Interface MAU index.
As per the MIB.
ifMauType (1.3.6.1.2.1.26.2.1.1.3)
read-only
AutonomousType
Interface MAU operation type. The value (1) indicates autonegotiation. The value (2) indicates autonegotiation is not enabled or applied on an interface.
As per the MIB.
ifMauStatus (1.3.6.1.2.1.26.2.1.1.4)
read-write
INTEGER
other(1),
unknown(2),
operational(3),
standby(4),
shutdown(5),
reset(6)
Current state of the interface MAU.
The object can only be read.
ifMauMediaAvailable (1.3.6.1.2.1.26.2.1.1.5)
read-only
INTEGER
other(1),
unknown(2),
available(3),
notAvailable(4),
remoteFault(5),
invalidSignal(6),
remoteJabber(7),
remoteLinkLoss(8),
remoteTest(9),
offline(10),
autoNegError(11),
pmdLinkFault(12),
wisFrameLoss(13),
wisSignalLoss(14),
pcsLinkFault(15),
excessiveBER(16),
dxsLinkFault(17),
pxsLinkFault(18)
Current availability state of the interface MAU.
As per the MIB.
ifMauDefaultType (1.3.6.1.2.1.26.2.1.1.11)
read-write
AutonomousType
Default interface MAU type.
ifMauAutoNegSupported (1.3.6.1.2.1.26.2.1.1.12)
read-only
TruthValue
true(1),
false(2)
Whether an interface MAU supports autonegotiation.
As per the MIB.
ifMauTypeListBits (1.3.6.1.2.1.26.2.1.1.13)
read-only
BITS
bOther(0),
bAUI(1),
b10base5(2),
bFoirl(3),
b10base2(4),
b10baseT(5),
b10baseFP(6),
b10baseFB(7),
b10baseFL(8),
b10broad36(9),
b10baseTHD(10),
b10baseTFD(11),
b10baseFLHD(12),
b10baseFLFD(13),
b100baseT4(14),
b100baseTXHD(15),
b100baseTXFD(16),
b100baseFXHD(17),
b100baseFXFD(18),
b100baseT2HD(19),
b100baseT2FD(20),
b1000baseXHD(21),
b1000baseXFD(22),
b1000baseLXHD(23),
b1000baseLXFD(24),
b1000baseSXHD(25),
b1000baseSXFD(26),
b1000baseCXHD(27),
b1000baseCXFD(28),
b1000baseTHD(29),
b1000baseTFD(30),
b10GbaseX(31),
b10GbaseLX4(32),
b10GbaseR(33),
b10GbaseER(34),
b10GbaseLR(35),
b10GbaseSR(36),
b10GbaseW(37),
b10GbaseEW(38),
b10GbaseLW(39),
b10GbaseSW(40),
-- new since RFC 3636
b10GbaseCX4(41),
b2BaseTL(42),
b10PassTS(43),
b100BaseBX10D(44),
b100BaseBX10U(45),
b100BaseLX10(46),
b1000BaseBX10D(47),
b1000BaseBX10U(48),
b1000BaseLX10(49),
b1000BasePX10D(50),
b1000BasePX10U(51),
b1000BasePX20D(52),
b1000BasePX20U(53),
b10GbaseT(54),
b10GbaseLRM(55),
b1000baseKX(56),
b10GbaseKX4(57),
b10GbaseKR(58),
b10G1GbasePRXD1(59),
b10G1GbasePRXD2(60),
b10G1GbasePRXD3(61),
b10G1GbasePRXU1(62),
b10G1GbasePRXU2(63),
b10G1GbasePRXU3(64),
b10GbasePRD1(65),
b10GbasePRD2(66),
b10GbasePRD3(67),
b10GbasePRU1(68),
b10GbasePRU3(69),
b40GbaseKR4(70),
b40GbaseCR4(71),
b40GbaseSR4(72),
b40GbaseFR(73),
b40GbaseLR4(74),
b100GbaseCR10(75),
b100GbaseSR10(76),
b100GbaseLR4(77),
b100GbaseER4(78),
b1000baseT1(79),
b1000basePX30D(80),
b1000basePX30U(81),
b1000basePX40D(82),
b1000basePX40U(83),
b10G1GbasePRXD4(84),
b10G1GbasePRXU4(85),
b10GbasePRD4(86),
b10GbasePRU4(87),
b25GbaseCR(88),
b25GbaseCRS(89),
b25GbaseKR(90),
b25GbaseKRS(91),
b25GbaseR(92),
b25GbaseSR(93),
b25GbaseT(94),
b40GbaseER4(95),
b40GbaseR(96),
b40GbaseT(97),
b100GbaseCR4(98),
b100GbaseKR4(99),
b100GbaseKP4(100),
b100GbaseR(101),
b100GbaseSR4(102),
b2p5GbaseT(103),
b5GbaseT(104),
b100baseT1(105),
b1000baseRHA(106),
b1000baseRHB(107),
b1000baseRHC(108),
b2p5GbaseKX(109),
b2p5GbaseX(110),
b5GbaseKR(111),
b5GbaseR(112),
b10GpassXR(113),
b25GbaseLR(114),
b25GbaseER(115),
b50GbaseR(116),
b50GbaseCR(117),
b50GbaseKR(118),
b50GbaseSR(119),
b50GbaseFR(120),
b50GbaseLR(121),
b50GbaseER(122),
b100GbaseCR2(123),
b100GbaseKR2(124),
b100GbaseSR2(125),
b100GbaseDR(126),
b200GbaseR(127),
b200GbaseDR4(128),
b200GbaseFR4(129),
b200GbaseLR4(130),
b200GbaseCR4(131),
b200GbaseKR4(132),
b200GbaseSR4(133),
b200GbaseER4(134),
b400GbaseR(135),
b400GbaseSR16(136),
b400GbaseDR4(137),
b400GbaseFR8(138),
b400GbaseLR8(139),
b400GbaseER8(140),
b10baseT1L(141),
b10baseT1SHD(142),
b10baseT1SMD(143),
b10baseT1SFD(144),
Set of possible IEEE 802.3 types that the MAU could be.
As per the MIB.
ifJackTable
About this table
Use this table to obtain the external jack information of an interface MAU.
CreateNot supported
DeleteNot supported
ReadSupported
Columns
The table indexes are ifMauIfIndex, ifMauIndex, and ifJackIndex.
Object (OID)
Access
Value range
Implementation
ifJackIndex (1.3.6.1.2.1.26.2.2.1.1)
not-accessible
Integer32
Index of the external jack of an interface MAU.
As per the MIB.
ifJackType (1.3.6.1.2.1.26.2.2.1.2)
read-only
JackType
Type of the external jack of an interface MAU.
As per the MIB.
ifMauAutoNegTable
About this table
Use this table to obtain the autonegotiation information of an interface MAU.
CreateNot supported
DeleteNot supported
ReadSupported
Columns
Object (OID)
Access
Value range
Implementation
ifMauAutoNegAdminStatus (1.3.6.1.2.1.26.5.1.1.1)
read-write
INTEGER
enabled(1),
disabled(2)
Autonegotiation enabling state of an interface MAU.
ifMauAutoNegConfig (1.3.6.1.2.1.26.5.1.1.4)
read-only
INTEGER
other(1),
configuring(2),
complete(3),
disabled(4),
parallelDetectFail(5)
Current autonegotiation state of an interface MAU.
As per the MIB.
ifMauAutoNegCapabilityBits (1.3.6.1.2.1.26.5.1.1.9)
read-only
BITS
bOther(0),
b10baseT(1),
b10baseTFD(2),
b100baseT4(3),
b100baseTX(4),
b100baseTXFD(5),
b100baseT2(6),
b100baseT2FD(7),
bfdxPause(8),
bfdxAPause(9),
bfdxSPause(10),
bfdxBPause(11),
b1000baseX(12),
b1000baseXFD(13),
b1000baseT(14),
b1000baseTFD(15),
b10GbaseT(16),
b1000baseKX(17),
b10GbaseKX4(18),
b10GbaseKR(19),
b40GbaseKR4(20),
b40GbaseCR4(21),
b100GbaseCR10(22),
b1000baseT1(23),
b25GbaseRS(24),
b25GbaseR(25),
bRSFEC25Greq(26),
bBaseFEC25Greq(27),
b25GbaseT(28),
b40GbaseT(29),
b100GbaseCR4(30),
b100GbaseKR4(31),
b100GbaseKP4(32),
bForceMS(33),
b2p5GbaseT(34),
b5GBaseT(35),
b2p5GbaseKX(36),
b5GbaseKR(37),
b50GbaseR(38),
b100GbaseR2(39),
b200GbaseR4(40),
b10baseT1L(41),
b10baseT1S(42),
Set of capabilities of the local autonegotiation entity.
As per the MIB.
ifMauAutoNegCapAdvertisedBits (1.3.6.1.2.1.26.5.1.1.10)
read-write
BITS
bOther(0),
b10baseT(1),
b10baseTFD(2),
b100baseT4(3),
b100baseTX(4),
b100baseTXFD(5),
b100baseT2(6),
b100baseT2FD(7),
bFdxPause(8),
bFdxAPause(9),
bFdxSPause(10),
bFdxBPause(11),
b1000baseX(12),
b1000baseXFD(13),
b1000baseT(14),
b1000baseTFD(15),
b10GbaseT(16),
b1000baseKX(17),
b10GbaseKX4(18),
b10GbaseKR(19),
b40GbaseKR4(20),
b40GbaseCR4(21),
b100GbaseCR10(22),
b1000baseT1(23),
b25GbaseRS(24),
b25GbaseR(25),
bRSFEC25Greq(26),
bBaseFEC25Greq(27),
b25GbaseT(28),
b40GbaseT(29),
b100GbaseCR4(30),
b100GbaseKR4(31),
b100GbaseKP4(32),
bForceMS(33),
b2p5GbaseT(34),
b5GBaseT(35),
b2p5GbaseKX(36),
b5GbaseKR(37),
b50GbaseR(38),
b100GbaseR2(39),
b200GbaseR4(40),
b10baseT1L(41),
b10baseT1S(42),
Set of capabilities advertised by the local autonegotiation entity.
