06-Layer 2 - LAN Switching
HomeSupportRoutersCR16000-F SeriesReference GuidesMIB CompanionH3C CR16000-F Routers MIB Reference-R8530Pxx-6W10006-Layer 2 - LAN Switching
19-LLDP-EXT-DOT1-EVB-EXTENSIONS-MIB
19-LLDP-EXT-DOT1-EVB-EXTENSIONS-MIB 87.06 KB
About this MIB
Use this MIB to obtain information about EVB TLV configuration.
MIB file name
lldp-ext-dot1-evb-extensions.mib
Root object
iso(1).org(3).ieee(111).standards-association-numbers-series-standards(2).lan-man-stds(802).ieee802dot1mibs(1).lldpV2MIB(13).lldpV2Objects(1).lldpV2Extensions(5).lldpV2Xdot1MIB(32962).lldpXdot1StandAloneExtensions(7).lldpXDot1EvbExtensions(1)
Tabular objects
lldpXdot1EvbConfigEvbTable
About this table
This table configures the transmission of EVB TLVs on a set of ports.
Support for operations
CreateNot supported
Edit/ModifySupported
DeleteNot supported
ReadSupported
Columns
The table indexes are lldpV2PortConfigIfIndex and lldpV2PortConfigDestAddressIndex.
Object (OID)
Access
Value range
Implementation
lldpXdot1EvbConfigEvbTxEnable(1.3.111.2.802.1.1.13.1.5.32962.7.1.1.1.1.1.1.1)
read-write
TruthValue
true(1),
false(2)
Selects whether to enable EVB TLV transmission.
As per the MIB.
lldpXdot1EvbConfigCdcpTable
About this table
This table configures the transmission of CDCP TLVs on a set of ports.
CreateNot supported
DeleteNot supported
ReadSupported
Columns
Object (OID)
Access
Value range
Implementation
lldpXdot1EvbConfigCdcpTxEnable(1.3.111.2.802.1.1.13.1.5.32962.7.1.1.1.1.2.1.1)
read-write
TruthValue
true(1),
false(2)
Selects whether to enable CDCP TLV transmission.
As per the MIB.
lldpV2Xdot1LocEvbTlvTable
About this table
This table contains information about local EVB TLVs.
CreateNot supported
Edit/ModifyNot supported
DeleteNot supported
ReadSupported
Columns
The table index is lldpV2LocPortIfIndex.
Object (OID)
Access
Value range
Implementation
lldpV2Xdot1LocEvbTlvString (1.3.111.2.802.1.1.13.1.5.32962.7.1.1.1.2.1.1.1)
read-only
OCTET STRING
OCTET STRING (0..514)
Local EVB TLV information.
As per the MIB.
lldpV2Xdot1LocCdcpTlvTable
About this table
This table contains information about local CDCP TLVs.
CreateNot supported
DeleteNot supported
ReadSupported
Columns
The table index islldpV2LocPortIfIndex.
Object (OID)
Access
Value range
Implementation
lldpV2Xdot1LocCdcpTlvString (1.3.111.2.802.1.1.13.1.5.32962.7.1.1.1.2.2.1.1)
read-only
OCTET STRING
Local CDCP TLV information.
As per the MIB.
lldpV2Xdot1RemEvbTlvTable
About this table
This table contains information about EVB TLVs received from the neighboring devices.
CreateNot supported
DeleteNot supported
ReadSupported
Columns
The table indexes are lldpV2RemTimeMark, lldpV2RemLocalIfIndex, lldpV2RemLocalDestMACAddress, and lldpV2RemIndex.
Object (OID)
Access
Value range
Implementation
lldpV2Xdot1RemEvbTlvString (1.3.111.2.802.1.1.13.1.5.32962.7.1.1.1.3.1.1.1)
read-only
OCTET STRING
Information about EVB TLVs from neighboring devices.
As per the MIB.
lldpV2Xdot1RemCdcpTlvTable
About this table
This table contains information about CDCP TLVs received from the neighboring devices.
CreateNot supported
DeleteNot supported
ReadSupported
Columns
Object (OID)
Access
Value range
Implementation
lldpV2Xdot1RemCdcpTlvString (1.3.111.2.802.1.1.13.1.5.32962.7.1.1.1.3.2.1.1)
read-only
OCTET STRING
Information about CDCP TLVs from neighboring devices.
As per the MIB.
