06-Layer 2 - LAN Switching
HomeSupportRoutersCR16000-F SeriesReference GuidesMIB CompanionH3C CR16000-F Routers MIB Reference-R8530Pxx-6W10006-Layer 2 - LAN Switching
17-LLDP-EXT-MED-MIB
17-LLDP-EXT-MED-MIB 181.72 KB
LLDP-EXT-MED-MIB
About this MIB
Use this MIB to obtain TIA-TR41.4 Media Endpoint Discovery (MED) information.
MIB file name
lldp-ext-med.mib
Root object
iso(1).std(0).iso8802(8802).ieee802dot1(1).ieee802dot1mibs(1).lldpMIB(2).lldpObjects(1).lldpExtnesions(5).lldpXMedMIB(4795)
Scalar objects
lldpXMedLocDeviceClass (1.0.8802.1.1.2.1.5.4795.1.1.1)
Object (OID)
Access
Value range
Implementation
read-only
LldpXMedDeviceClass
Standard MIB values.
MED device class.
As per the MIB.
lldpXMedFastStartRepeatCount (1.0.8802.1.1.2.1.5.4795.1.1.3)
Object (OID)
Access
Value range
Implementation
read-write
Unsigned32
Unsigned32 (1..8)
Number of times the fast start LLDPDU are being sent.
As per the MIB.
lldpXMedLocHardwareRev (1.0.8802.1.1.2.1.5.4795.1.2.2)
Object (OID)
Access
Value range
Implementation
read-only
SnmpAdminString
OCTET STRING (0..32)
Local hardware revision.
As per the MIB.
lldpXMedLocFirmwareRev (1.0.8802.1.1.2.1.5.4795.1.2.3)
Object (OID)
Access
Value range
Implementation
read-only
SnmpAdminString
Local firmware revision.
As per the MIB.
lldpXMedLocSoftwareRev (1.0.8802.1.1.2.1.5.4795.1.2.4)
Object (OID)
Access
Value range
Implementation
read-only
SnmpAdminString
Local software revision.
As per the MIB.
lldpXMedLocSerialNum (1.0.8802.1.1.2.1.5.4795.1.2.5)
Object (OID)
Access
Value range
Implementation
read-only
SnmpAdminString
Local serial number.
As per the MIB.
lldpXMedLocMfgName (1.0.8802.1.1.2.1.5.4795.1.2.6)
Object (OID)
Access
Value range
Implementation
read-only
SnmpAdminString
Local manufacturer name.
As per the MIB.
lldpXMedLocModelName (1.0.8802.1.1.2.1.5.4795.1.2.7)
Object (OID)
Access
Value range
Implementation
read-only
SnmpAdminString
Local model name.
As per the MIB.
lldpXMedLocAssetID (1.0.8802.1.1.2.1.5.4795.1.2.8)
Object (OID)
Access
Value range
Implementation
read-only
SnmpAdminString
Local asset tracking identifier.
As per the MIB.
lldpxMedLocXPoEDeviceType (1.0.8802.1.1.2.1.5.4795.1.2.10)
Object (OID)
Access
Value range
Implementation
read-only
INTEGER
unknown(1)
pseDevice(2)
pdDevice(3)
none(4)
Local PoE type.
As per the MIB.
lldpXMedLocXPoEPSEPowerSource (1.0.8802.1.1.2.1.5.4795.1.2.12)
Object (OID)
Access
Value range
Implementation
read-only
INTEGER
unknown(1)
primary(2)
backup(3)
Local PSE power supply type.
As per the MIB.
lldpXMedLocXPoEPDPowerReq (1.0.8802.1.1.2.1.5.4795.1.2.13)
Object (OID)
Access
Value range
Implementation
read-only
Gauge32
Power required by a PD.
As per the MIB.
lldpXMedLocXPoEPDPowerSource (1.0.8802.1.1.2.1.5.4795.1.2.14)
Object (OID)
Access
Value range
Implementation
read-only
INTEGER
unknown(1)
fromPSE(2)
local(3)
localAndPSE(4)
Local PD power supply type.
As per the MIB.
lldpXMedLocXPoEPDPowerPriority (1.0.8802.1.1.2.1.5.4795.1.2.15)
Object (OID)
Access
Value range
Implementation
read-only
INTEGER
unknown(1)
critical(2)
high(3)
low(4)
Local PD power priority.
As per the MIB.
Tabular objects
lldpXMedPortConfigTable
About this table
Use this table to configure MED on ports.
Support for operations
CreateNot supported
Edit/ModifySupported
DeleteNot supported
ReadSupported
Columns
The table index is lldpPortConfigPortNum.
Object (OID)
Access
Value range
Implementation
lldpXMedPortCapSupported (1.0.8802.1.1.2.1.5.4795.1.1.2.1.1)
read-only
LldpXMedCapabilities
Supported MED TLVs.
As per the MIB.
lldpXMedPortConfigTLVsTxEnable (1.0.8802.1.1.2.1.5.4795.1.1.2.1.2)
read-write
Enabled MED TLVs.
By default, the  networkPolicy bit  is set to 0. On a port operating in bridging mode, the networkPolicy bit is set to 1.
By default, the location and extendedPD bits are set to 0, and the other bits are set to 1. If the extendedPSE bit is set to 1 but a port does not support a capability, the bridge agents on the port does not send the related TLVs, and this bit is read-only.
lldpXMedPortConfigNotifEnable (1.0.8802.1.1.2.1.5.4795.1.1.2.1.3)
read-write
TruthValue
true(1)
false(2)
LLDP-MED trapping status.
As per the MIB.
lldpXMedLocMediaPolicyTable
About this table
Use this table to obtain local media policy configuration.
CreateNot supported
Edit/ModifyNot supported
DeleteNot supported
ReadSupported
Columns
The table indexes are lldpLocPortNum and lldpXMedLocMediaPolicyAppType.
Object (OID)
Access
Value range
Implementation
lldpXMedLocMediaPolicyAppType (1.0.8802.1.1.2.1.5.4795.1.2.1.1.1)
not-accessible
PolicyAppType
Media policy type.
As per the MIB.
lldpXMedLocMediaPolicyVlanID (1.0.8802.1.1.2.1.5.4795.1.2.1.1.2)
read-only
Integer32
Integer32 (0|1..4094|4095)
Media VLAN ID.
As per the MIB.
lldpXMedLocMediaPolicyPriority(1.0.8802.1.1.2.1.5.4795.1.2.1.1.3)
read-only
Integer32
Integer32 (0..7)
Media policy priority.
As per the MIB.
lldpXMedLocMediaPolicyDscp (1.0.8802.1.1.2.1.5.4795.1.2.1.1.4)
read-only
Dscp
DSCP value.
As per the MIB.
lldpXMedLocMediaPolicyUnknown (1.0.8802.1.1.2.1.5.4795.1.2.1.1.5)
read-only
TruthValue
true(1)
false(2)
Whether the media policy type is unknown.
As per the MIB.
lldpXMedLocMediaPolicyTagged (1.0.8802.1.1.2.1.5.4795.1.2.1.1.6)
read-only
TruthValue
true(1)
false(2)
Whether packets of the media VLAN are tagged.
As per the MIB.
lldpXMedLocLocationTable
About this table
Use this table to configure the local location information.
CreateNot supported
DeleteNot supported
ReadSupported
Columns
The table indexes are lldpLocPortNum and lldpXMedLocLocationSubtype.
Object (OID)
Access
Value range
Implementation
lldpXMedLocLocationSubtype (1.0.8802.1.1.2.1.5.4795.1.2.9.1.1)
not-accessible
LocationSubtype
Local MED location type.
Supports only civicAddress(3) and elin(4).
lldpXMedLocLocationInfo (1.0.8802.1.1.2.1.5.4795.1.2.9.1.2)
read-write
OCTET STRING
OCTET STRING (0..256)
Local MED location information.
As per the MIB.
lldpXMedLocXPoEPSEPortTable
About this table
Use this table to obtain PSE information on ports.
CreateNot supported
DeleteNot supported
ReadSupported
Columns
The table index is lldpLocPortNUm.
Object (OID)
Access
Value range
Implementation
lldpXMedLocXPoEPSEPortPowerAv (1.0.8802.1.1.2.1.5.4795.1.2.11.1.1)
read-only
Gauge32
Available PoE power on PSE ports.
As per the MIB.
lldpXMedLocXPoEPSEPortPDPriority (1.0.8802.1.1.2.1.5.4795.1.2.11.1.2)
read-only
INTEGER
Unknown(1)
Critical(2)
High(3)
Low(4)
PSE port power priority.
As per the MIB.
lldpXMedRemCapabilitiesTable
About this table
Use this table to obtain the LLDP-MED capabilities of a neighbor.
CreateNot supported
DeleteNot supported
ReadSupported
Columns
The table indexes are lldpRemTimeMark, lldpRemLocalPortNum, and lldpRemIndex.
Object (OID)
Access
Value range
Implementation
lldpXMedRemCapSupported (1.0.8802.1.1.2.1.5.4795.1.3.1.1.1)
read-only
Supported MED TLVs.
As per the MIB.
lldpXMedRemCapCurrent (1.0.8802.1.1.2.1.5.4795.1.3.1.1.2)
read-only
Sent MED TLVs.
As per the MIB.
lldpXMedRemDeviceClass (1.0.8802.1.1.2.1.5.4795.1.3.1.1.3)
read-only
LldpXMedDeviceClass
MED device type.
As per the MIB.
lldpXMedRemMediaPolicyTable
About this table
Use this table to obtain the media policy configuration of a neighbor.
CreateNot supported
DeleteNot supported
ReadSupported
Columns
The table indexes are lldpRemTimeMark, lldpRemLocalPortNum, lldpRemIndex, and lldpXMedRemMediaPolicyAppType.
Object (OID)
Access
Value range
Implementation
lldpXMedRemMediaPolicyAppType (1.0.8802.1.1.2.1.5.4795.1.3.2.1.1)
not-accessible
PolicyAppType
Media policy type.
As per the MIB.
lldpXMedRemMediaPolicyVlanID (1.0.8802.1.1.2.1.5.4795.1.3.2.1.2)
read-only
Integer32
Media VLAN ID.
As per the MIB.
lldpXMedRemMediaPolicyPriority (1.0.8802.1.1.2.1.5.4795.1.3.2.1.3)
read-only
Integer32
Integer32 (0..7)
As per the MIB.
lldpXMedRemMediaPolicyDscp (1.0.8802.1.1.2.1.5.4795.1.3.2.1.4)
read-only
Dscp
DSCP value.
As per the MIB.
lldpXMedRemMediaPolicyUnknown (1.0.8802.1.1.2.1.5.4795.1.3.2.1.5)
read-only
TruthValue
true(1)
false(2)
As per the MIB.
lldpXMedRemMediaPolicyTagged (1.0.8802.1.1.2.1.5.4795.1.3.2.1.6)
read-only
TruthValue
true(1)
false(2)
As per the MIB.
lldpXMedRemInventoryTable
About this table
Use this table to obtain the inventory information about a neighbor.
CreateNot supported
DeleteNot supported
ReadSupported
Columns
Object (OID)
Access
Value range
Implementation
lldpXMedRemHardwareRev (1.0.8802.1.1.2.1.5.4795.1.3.3.1.1)
read-only
SnmpAdminString
Hardware revision.
As per the MIB.
lldpXMedRemFirmwareRev (1.0.8802.1.1.2.1.5.4795.1.3.3.1.2)
read-only
SnmpAdminString
Firmware revision.
As per the MIB.
lldpXMedRemSoftwareRev (1.0.8802.1.1.2.1.5.4795.1.3.3.1.3)
read-only
SnmpAdminString
Software revision.
As per the MIB.
lldpXMedRemSerialNum (1.0.8802.1.1.2.1.5.4795.1.3.3.1.4)
read-only
SnmpAdminString
Serial number.
As per the MIB.
lldpXMedRemMfgName (1.0.8802.1.1.2.1.5.4795.1.3.3.1.5)
read-only
SnmpAdminString
Manufacturer name.
As per the MIB.
lldpXMedRemModelName (1.0.8802.1.1.2.1.5.4795.1.3.3.1.6)
read-only
SnmpAdminString
Model name.
As per the MIB.
lldpXMedRemAssetID (1.0.8802.1.1.2.1.5.4795.1.3.3.1.7)
read-only
SnmpAdminString
Asset tracking identifier.
As per the MIB.
lldpXMedRemLocationTable
About this table
Use this table to obtain the location information about a neighbor.
CreateNot supported
DeleteNot supported
ReadSupported
Columns
The table indexes are lldpRemTimeMark, lldpRemLocalPortNum, lldpRemIndex ,and lldpXMedRemLocationSubtype.
Object (OID)
Access
Value range
Implementation
lldpXMedRemLocationSubtype(1.0.8802.1.1.2.1.5.4795.1.3.4.1.1)
not-accessible
LocationSubtype
MED location type.
As per the MIB.
lldpXMedRemLocationInfo (1.0.8802.1.1.2.1.5.4795.1.3.4.1.2)
read-only
OCTET STRING
As per the MIB.
lldpXMedRemXPoETable
About this table
Use this table to obtain the PoE type of a neighbor.
CreateNot supported
DeleteNot supported
ReadSupported
Columns
Object (OID)
Access
Value range
Implementation
lldpXMedRemXPoEDeviceType (1.0.8802.1.1.2.1.5.4795.1.3.5.1.1)
read-only
INTEGER
unknown(1)
pseDevice(2)
pdDevice(3)
none(4)
PoE type.
As per the MIB.
lldpXMedRemXPoEPSETable
About this table
Use this table to obtain the PSE information about a neighbor.
CreateNot supported
DeleteNot supported
ReadSupported
Columns
Object (OID)
Access
Value range
Implementation
lldpXMedRemXPoEPSEPowerAv (1.0.8802.1.1.2.1.5.4795.1.3.6.1.1)
read-only
Gauge32
As per the MIB.
lldpXMedRemXPoEPSEPowerSource (1.0.8802.1.1.2.1.5.4795.1.3.6.1.2)
read-only
INTEGER
unknown(1)
primary(2)
backup(3)
As per the MIB.
lldpXMedRemXPoEPSEPowerPriority (1.0.8802.1.1.2.1.5.4795.1.3.6.1.3)
read-only
INTEGER
unknown(1)
critical(2)
high(3)
low(4)
As per the MIB.
lldpXMedRemXPoEPDTable
About this table
Use this table to obtain the PD information about a neighbor.
CreateNot supported
DeleteNot supported
ReadSupported
Columns
Object (OID)
Access
Value range
Implementation
lldpXMedRemXPoEPDPowerReq (1.0.8802.1.1.2.1.5.4795.1.3.7.1.1)
read-only
Gauge32
As per the MIB.
lldpXMedRemXPoEPDPowerSource (1.0.8802.1.1.2.1.5.4795.1.3.7.1.2)
read-only
INTEGER
unknown(1)
fromPSE(2)
local(3)
localAndPSE(4)
As per the MIB.
lldpXMedRemXPoEPDPowerPriority (1.0.8802.1.1.2.1.5.4795.1.3.7.1.3)
read-only
INTEGER
unknown(1)
critical(2)
high(3)
low(4)
PD power priority.
As per the MIB.
Notifications
lldpXMedTopologyChangeDetected
Basic information
OID
Event
Severity
Recovery notification
Default status
1.0.8802.1.1.2.1.5.4795.0.1
MED neighbor topology changes.
Informational
Warning
OFF
Notification triggers
This notification is generated when the device detects MED neighbor topology changes, such as attaching a peer device to the local device, disconnecting a peer device, or moving a peer device from one port to another port.
System impact
No negative impact on services.
Status control
ON
CLI: Use the lldp notification med-topology-change enable command.
MIB: Set the lldpXMedPortConfigNotifEnable object to true (1).
OFF
CLI: Use the undo lldp notification med-topology-change enable command.
MIB: Set the lldpXMedPortConfigNotifEnable object to false (2).
Object
OID (object name)
Index
Value range
1.0.8802.1.1.2.1.4.1.1.4 (lldpRemChassisIdSubtype)
Neighbor chassis ID type.
lldpRemTimeMark
lldpRemLocalPortNum
lldpRemIndex
LldpChassisIdSubtype
1.0.8802.1.1.2.1.4.1.1.5 (lldpRemChassisId)
Neighbor chassis ID.
lldpRemTimeMark
lldpRemLocalPortNum
lldpRemIndex
LldpChassisId
1.0.8802.1.1.2.1.5.4795.1.3.1.1.3 (lldpXMedRemDeviceClass)
Neighbor MED device class.
lldpRemTimeMark
lldpRemLocalPortNum
lldpRemIndex
LldpXMedDeviceClass
Recommended action
Verify that the topology changes are as expected.
If the issue persists, collect alarm information and configuration data, and then contact H3C Support.
