- H3C WBC580 G2 Multiservice Access Controller Installation Guide-5W104
- 01-Preparing for installation
- 02-Installing and removing the device
- 03-Powering on, powering off, and rebooting the device
- 04-Logging in to the device
- 05-Maintenance
- 06-Appendix A Chassis views and technical specifications
- 07-Appendix B LEDs
- 08-Appendix C Optional transceiver modules
| 06-Appendix A Chassis views and technical specifications | 250.23 KB |
Chassis views
Figure1-1 Front panel
(1) 4TB drives |
(2) 1000BASE-T Ethernet ports |
(3) USB 2.0 connectors |
(4) SFP+ fiber ports |
(5) VGA connector |
(6) BIOS serial port |
(7) 1000BASE-T HDM dedicated network port (default IP address 192.168.1.2/24) |
Table1-1 Port and connector description
Port or connector |
Connector type |
4TB drive |
SATA |
N/A |
1000BASE-T Ethernet port |
RJ-45 |
Used together with an Ethernet cable to provide network connection. |
USB connector |
USB 2.0 |
Used for connecting the following USB devices: · USB flash disk. · USB keyboard or mouse. · USB optical drive. |
SFP+ fiber port |
LC |
Used together with an optical fiber to provide network connection. |
VGA connector |
DB-15 |
Used for connecting a display terminal, such as a monitor. |
BIOS serial port |
RJ-45 |
· Used for connecting to the device to locate the fault when remote access to the device fails. · Used for applications such as dongle and SMS modem. |
1000BASE-T HDM dedicated network port |
RJ-45 |
Used for logging in to the HDM Web interface. |
Figure1-2 Rear panel
(1) Fan module slots |
(2) Power supply slots 1 and 2 |
Technical specifications
Table1-2 Technical specifications
Item |
Specifications |
Chassis height |
2 U 1 U equals 44.45 mm (1.75 in) |
Dimensions (H × W × D) (excluding the mounting brackets) |
87.5 × 440 × 451 mm (3.44 × 17.32 × 17.76 in) |
Weight (including two power supplies) |
14 kg (30.86 lb) |
Memory |
128 GB |
Storage |
4TB 6G SATA 7.2K 3.5in HDD General Intelligent Disk Equipment Module (FIO) |
Power supply |
550W power supply |
Power consumption |
≤ 194.1 W |
Rated input voltage |
100 to 240 VAC @ 50 or 60 Hz |
Network ports |
· 2 × embedded 1000 Mbps Ethernet ports · 2 × 10 Gbps Ethernet fiber ports · 1 × HDM dedicated network port |
I/O connectors |
· 2 × USB 2.0 connectors · 1 × VGA connector · 1 × BIOS serial port |
Table1-3 AC power supply specifications
Item |
Specifications |
Vendor model |
DPS-550AB-22 G |
Product code |
DPS-550AB-22 G |
100 VAC to 240 VAC @ 50 or 60 Hz |
Rated power consumption |
550W |
