- H3C WBC580 G2 Multiservice Access Controller Installation Guide-5W104
- 01-Preparing for installation
- 02-Installing and removing the device
- 03-Powering on, powering off, and rebooting the device
- 04-Logging in to the device
- 05-Maintenance
- 06-Appendix A Chassis views and technical specifications
- 07-Appendix B LEDs
- 08-Appendix C Optional transceiver modules
| 00-Preface | 111.14 KB |
Preface
This installation guide describes the procedure for installing an H3C WBC580 G2 multiservice access controller.
The WBC580 G2 includes the following models:
· WBC580 G2 Multiservice Access Controller-Enhanced Edition
· WBC580 G2 Multiservice Access Controller-Standard Edition
· WBC580 G2 Multiservice Access Controller-Healthcare Edition
The installation and removal methods are the same for all the models. This document uses the enhanced edition as an example.
· Audience.
· Conventions.
Audience
· Network planners.
· Network administrators .
Conventions
Command conventions
Convention |
Boldface |
Italic |
{ x | y | ... } |
[ x | y | ... ] |
{ x | y | ... } * |
[ x | y | ... ] * |
&<1-n> |
GUI conventions
Convention |
Boldface |
Symbols
Convention |
NOTE: |
Network topology icons
Convention |
Represents an access point. |
Documentation feedback
We appreciate your comments.
