H3C G3&G5 Servers Storage Controller User Guide-6W109
HomeSupportConfigure & DeployUser ManualsH3C G3&G5 Servers Storage Controller User Guide-6W109
07-Configuring a 9361, 9440, 9460, L460, P5408, or H5408 storage controller
Configuring an LSI-9440, 9460, 5408, LSI-9361, L460, 9560, or 9540 series storage controller
The BIOS screens might vary by the BIOS version. The screenshots in this chapter are for illustration only.
About LSI-9440, 9460, 5408, LSI-9361, L460, 9560, or 9540 series storage controllers
The storage controllers provide a maximum interface rate of 12 Gbps, and some storage controllers support caching, which greatly increases performance and data security. For more information about storage controller details and the supported cache, access http://www.h3c.com/en/home/qr/default.htm?id=66.
This chapter is applicable to the following storage controllers:
·     RAID-LSI-9361-8i(1G)-A1-X
·     RAID-LSI-9361-8i(2G)-1-X
·     HBA-LSI-9440-8i
·     RAID-LSI-9460-8i(2G)
·     RAID-LSI-9460-8i(4G)
·     RAID-LSI-9460-16i(4G)
·     HBA-H5408-Mf-8i
·     RAID-P5408-Mf-8i-4GB
·     RAID-P5408-Ma-8i-4GB
·     RAID-LSI-9560-LP-16i-8GB
·     RAID-LSI-9560-LP-8i-4GB
·     RAID-P9560-3S-8i-4G
·     HBA-LSI-9540-LP-8i
Features
Operating mode
The storage controller supports the following operating modes, as shown in Table 1:
·     JBOD mode—In this mode, both JBOD drives and RAID arrays are visible to the operating system. This mode supports simple RAID levels such as RAID 0, RAID 1, and RAID 10.
·     RAID mode—This is the default mode. In this mode, both JBOD drives and RAID arrays are visible to the operating system. This mode supports all RAID levels such as RAID 0, RAID 1, RAID 5, RAID 6, RAID 10, RAID 50, and RAID 60.
IMPORTANT
IMPORTANT:
The LSI storage controller in RAID mode supports configuring JBOD drives (in JBOD or JBOD online state). For more information, see "Switching the drive state." If you use a 9361/9460/9440/9540 controller to configure JBOD drives in RAID mode, you must also enable the JBOD feature. For more information, see "Setting the JBOD state."
Table 1 Supported operating modes
Storage controller model
JBOD mode supported
RAID mode supported
Yes
Yes
Yes
Yes
Yes
Yes
Yes
Yes
Yes
Yes
Yes
Yes
Yes
Yes
HBA-H5408-Mf-8i
No
Yes
HBA-LSI-9440-8i
No
Yes
Yes
Yes
Yes
Yes
RAID-P9560-3S-8i-4GB
Yes
Yes
HBA-LSI-9540-LP-8i
No
Yes
RAID levels
The supported RAID levels vary by storage controller model. For more information about the supported RAID levels of each storage controller, contact Technical Support.
Table 2 shows the minimum number of drives required by each RAID level and the maximum number of failed drives supported by each RAID level. For more information about RAID levels, see "Appendix B  RAID arrays and fault tolerance."
Table 2 RAID levels and the numbers of drives for each RAID level
RAID level
Min. drives required
Max. failed drives
RAID 0
1
0
RAID 1
2
Number of drives divided by 2
RAID 5
3
1
RAID 6
For the LSI 9560: 4
For the other storage controllers: 3 (4 is recommended.)
2
RAID 00
2
0
RAID 10
4
n, where n is the number of RAID 1 arrays in the RAID 10 array.
RAID 50
6
n, where n is the number of RAID 5 arrays in the RAID 50 array.
RAID 60
For the LSI 9560: 8
For the other storage controllers: 6 (8 is recommended.)
2n, where n is the number of RAID 6 arrays in the RAID 60 array.
Storage controllers described in this chapter support using a maximum of eight member RAID 1/5/6 arrays to form a RAID 10/50/60 array.
Restrictions and guidelines for configuring RAID
·     As a best practice, configure RAID with drives that do not contain RAID information.
·     To build a RAID successfully and ensure RAID performance, make sure all drives in the RAID are the same type (HDDs or SSDs) and have the same connector type (SAS or SATA).
·     For efficient use of storage, use drives that have the same capacity to build a RAID. If the drives have different capacities, the lowest capacity is used across all drives in the RAID.
·     If you use one physical drive to create multiple RAIDs, RAID performance might decrease in addition to increased maintenance complexities.
Configuring RAID arrays in UEFI mode
This section describes how to configure RAID arrays through a storage controller in UEFI mode. For more information about how to enter the BIOS and set the boot mode to UEFI, see the BIOS user guide for the server.
RAID array configuration tasks at a glance
To configure a RAID array in UEFI mode, perform the following tasks:
·     Accessing the storage controller configuration screen
·     Switching the drive state
·     Configuring a RAID array
·     (Optional.) Configuring hot spare drives
·     (Optional.) Deleting a RAID array
·     (Optional.) Locating drives
·     (Optional.) Initializing a virtual drive
·     (Optional.) Initializing a physical drive
·     (Optional.) Erasing drives
·     (Optional.) Expanding a RAID array
·     (Optional.) Migrating the RAID level
·     (Optional.) Clearing RAID array information on the drive
·     (Optional.) Hiding a virtual drive
·     (Optional.) Hiding a RAID array
·     (Optional.) Upgrading the storage controller firmware online
1.     Access the BIOS. Press Delete, Esc, or F2 as prompted during server POST to open the BIOS setup screen as shown in Figure 1. For some devices, the Front Page screen opens, and you must select Device Management before proceeding to the next step.
For how to navigate screens and modify settings, see the operation instructions at the lower right corner.
Figure 1 BIOS setup screen
2.     On the screen as shown in Figure 2, select Advanced > Dynamic Device Configuration (Optional, based on BIOS version) > storage controller model, and press Enter.
In this example, the storage controller model is AVAGO MegaRAID <AVAGO MegaRAID SAS 9361-8i>.
Figure 2 Advanced screen
3.     Select Main Menu as shown in Figure 3, and press Enter.
Figure 3 Selecting Main Menu
The storage controller configuration screen as shown in Figure 4 opens. This screen contains five tasks as described in Table 3.
Figure 4 Storage controller configuration screen
Table 3 Storage controller configuration tasks
Option
Configuration Management
Select Configuration Management to perform the following tasks:
·     Create RAID arrays.
·     View RAID array properties.
·     View hot spare drives.
·     Clear configuration.
Controller Management
Select Controller Management to perform the following tasks:
·     View and manage controller properties.
·     Clear, schedule, or run controller events.
Virtual Drive Management
Select Virtual Drive Management to perform the following tasks:
·     View logical drive properties.
·     Locate logical drives.
·     Run consistency check.
Drive Management
Select Drive Management to perform the following tasks:
·     View physical drive properties.
·     Locate drives.
·     Initialize drives.
·     Rebuild drives.
Hardware Components
Select Hardware Components to perform the following tasks:
·     View supercapacitor properties.
·     Manage supercapacitor.
·     Manage peripheral components.
The storage controller supports the following drive states:
·     Unconfigured Good—The drive is normal and can be used for RAID array or hot backup configuration.
·     Unconfigured Bad—The drive is faulty or has RAID array information remaining on it. If the drive is faulty, replace the drive. If RAID array information remains on the drive, clear the RAID array information.
·     Hotspare—The drive is a hot spare drive.
·     JBOD/JBOD online—Just a Bunch Of Disks. The drive is a passthrough or passthrough-like drive and does not support RAID configuration. The passthrough drive is in JBOD online state by default for the RAID-LSI-9560-LP-16i-8GB or RAID-LSI-9560-LP-8i-4GB storage controller and in JBOD state for other storage controllers.
To switch from Unconfigured Good state to Unconfigured Bad state:
1.     On the storage controller configuration screen as shown in Figure 5, select Drive Management and press Enter.
Figure 5 Storage controller configuration screen
2.     On the screen as shown in Figure 6, select the target drive and press Enter.
Figure 6 Drive Management screen
3.     On the screen as shown in Figure 7, select Operation and press Enter. On the dialog box that appears, select Make Unconfigured Bad and press Enter.
Figure 7 Operation screen
4.     On the screen as shown in Figure 8, select Go and press Enter.
Figure 8 Selecting Go
When the operation is complete, the screen as shown in Figure 9 opens.
Figure 9 Completing drive state switchover
1.     On the storage controller configuration screen as shown in Figure 10, select Configuration Management and press Enter.
Figure 10 Storage controller configuration screen
2.     On the screen as shown in Figure 11, select Create Virtual Drive and press Enter.
Figure 11 Selecting Create Virtual Drive
3.     On the screen as shown in Figure 12, select Select RAID Level to set the RAID level, and then press Enter.
Figure 12 Setting the RAID level
4.     On the screen as shown in Figure 13, select Select Drives From to set the drive capacity source, and then press Enter.
¡     Unconfigured Capacity—The capacity source is the unconfigured drives.
¡     Free Capacity—The capacity source is the remaining drive capacity.
Figure 13 Setting the drive capacity source
5.     On the screen as shown in Figure 14, select Select Drives and press Enter.
Figure 14 Selecting Select Drives
6.     On the screen as shown in Figure 15, select the target drives. ([Enabled] following a drive means that the drive has been selected.) Then, select Apply Changes and press Enter. A drive in JBOD or Unconfigured Bad status cannot be selected.
Figure 15 Selecting the target drives
7.     On the screen as shown in Figure 16, configure the parameters, select Save Configuration, and press Enter. For more information about the parameter description, see Table 4.
Figure 16 Configuring RAID parameters
Table 4 Parameter description
Parameter
Virtual Drive Name
RAID array name, a case-insensitive string of letters, digits, and special characters.
Virtual Drive Size
Capacity for the RAID array.
Virtual Drive Size Unit
Capacity unit for the RAID array.
Stripe Size
Data block size for each drive.
Read Policy
Read cache policy:
·     Read ahead—Enables read ahead capability. When this capability is enabled, the storage controller can pre-read sequential data or anticipate data to be requested and store the data in the cache
·     No read ahead—Disables read ahead capability.
Write Policy
Write cache policy:
·     Write through—Enables the controller to send data transfer completion signal to the host when the physical drives have received all data in a transaction.
·     Write back—Enables the controller to send data transfer completion signal to the host when the controller cache receives all data in a transaction. If the supercapacitor is faulty or no supercapacitor is present, the Write through policy is used.
·     Always write back—Uses the Write back policy even if the supercapacitor of the storage controller is absent or faulty. If the server is powered off, the controller cache loses its data because of lack of power.
Access Policy
Read and write policy:
·     Read/Write
·     Read Only
·     Blocked
I/O Policy
I/O policy:
·     Direct—The definition varies by scenario:
¡     In read scenarios, data is directly read from drives. If Read Ahead is set, read operations preload data to the RAID cache in advance.
¡     In write scenarios, data is first cached in the RAID cache, and then asynchronously written to drives. If the Write Policy field is set to Write through, data is written directly to drives, bypassing the cache.
·     Cached—Enables the cache module of the RAID controller to process all read and write operations. As a best practice, use this policy only when you configure CacheCade 1.1.
The HBA-LSI-9540-LP-8i storage controller does not support configuring an I/O policy in the current software version.
Drive Cache
Drive cache policy:
·     Enable—Enables the write drive cache policy. With this policy enabled, write performance will improve, but data might get lost upon an unexpected power failure if additional protection mechanism is not in place.
·     Disable—Disables the write drive cache policy. With this policy enabled, data will not get lost upon an unexpected power failure, but the write performance might be impacted.
·     Unchanged—Maintains the current drive cache policy.
Disable Background Initialization
Enabling status of background initialization.
Default Initialization
Default initialization mode:
·     NO.
·     Fast.
·     Full.
Emulation Type
Sector size reported to the OS:
·     Default—Displays 512e (4K) as the sector size as long as one 512e member drive exists, and displays 512n as the sector size if no 512e  member drive exists.
·     Disable—Displays 512n as the sector size if no 512e member drive exists.
·     Force—Displays 512e (4K) as the sector size even if no 512e member drive exists.
Save Configuration
Select this option to save the configuration.
8.     On the screen as shown in Figure 17, select Confirm and press Enter. On the dialog box that opens, select Enabled and press Enter. Then, select Yes and press Enter.
Figure 17 Confirming the configuration
9.     On the screen as shown in Figure 18, select OK to return to the storage controller configuration screen.
Figure 18 Completing RAID array configuration
10.     Select Virtual Drive Management and press Enter as shown in Figure 19.
Figure 19 Storage controller configuration screen
11.     On the screen as shown in Figure 20, you can see the created drives. Select the drive you want to view and press Enter.
Figure 20 Virtual Drive Management screen
12.     On the screen as shown in Figure 21, select View Associated Drives and press Enter. You can view the detailed information about the RAID array, including name, level, and drive information.
Figure 21 Selecting View Associated Drives
For data security purposes, configure hot spare drives after configuring a RAID array. You can configure global hot spare drives or dedicated hot spare drives.
·     A hot spare drive can be used only for RAID levels with redundancy.
·     The capacity of a hot spare drive must be equal to or greater than the capacity of the smallest drive in the RAID array.
·     Only the drive in Unconfigured Good state can be configured as a hot spare drive.
Configuring a global hot spare drive
1.     On the storage controller configuration screen as shown in Figure 22, select Drive Management and press Enter.
Figure 22 Storage controller configuration screen
2.     On the screen as shown in Figure 23, select the target drive and press Enter.
Figure 23 Drive Management screen
3.     On the screen as shown in Figure 24, select Operation and press Enter. On the dialog box that appears, select Assign Global Hot Spare Drive and press Enter.
Figure 24 Operation screen
4.     On the screen as shown in Figure 25, select Go and press Enter.
Figure 25 Selecting Go
5.     On the screen as shown in Figure 26, select Confirm and press Enter. On the dialog box that opens, select Enabled and press Enter. Then, select Yes and press Enter.
Figure 26 Confirming the configuration
When the operation is complete, the screen as shown in Figure 27 opens.
Figure 27 Completing global hot spare drive configuration
Configuring a dedicated hot spare drive
1.     On the storage controller configuration screen as shown in Figure 28, select Drive Management and press Enter.
Figure 28 Storage controller configuration screen
2.     On the screen as shown in Figure 29, select the target drive and press Enter.
Figure 29 Drive Management screen
3.     On the screen as shown in Figure 30, select Operation and press Enter. On the dialog box that appears, select Assign Dedicated Hot Spare Drive and press Enter.
Figure 30 Operation screen
4.     On the screen as shown in Figure 31, select Go and press Enter.
Figure 31 Selecting Go
5.     On the screen as shown in Figure 32, select the drive you want to configure as the hot spare drive. ([Enabled] following the drive means that the drive has been selected.) Then, select OK and press Enter.
Figure 32 Confirming selection
When the operation is complete, the screen as shown in Figure 33 opens.
Figure 33 Completing the operation
1.     On the storage controller configuration screen as shown in Figure 34, select Virtual Drive Management and press Enter.
Figure 34 Storage controller configuration screen
2.     On the screen as shown in Figure 35, select the target virtual drive and press Enter.
Figure 35 Virtual Drive Management screen
3.     On the screen as shown in Figure 36, select Operation and press Enter. On the dialog box that appears, select Delete Virtual Drive and press Enter.
Figure 36 Operation screen
4.     On the screen as shown in Figure 37, select Go and press Enter.
Figure 37 Selecting Go
5.     On the screen as shown in Figure 38, select Confirm and press Enter. On the dialog box that opens, select Enabled and press Enter. Then, select Yes and press Enter.
Figure 38 Confirming the deletion
When the operation is complete, the screen as shown in Figure 39 opens.
Figure 39 Completing the operation
Locating drives
This task allows you to locate a physical drive or all drives for a virtual drive.
Locating a physical drive
1.     On the storage controller configuration screen as shown in Figure 40, select Drive Management and press Enter.
Figure 40 Storage controller configuration screen
2.     On the screen as shown in Figure 41, select the target drive and press Enter.
Figure 41 Selecting the target drive
3.     On the screen as shown in Figure 42, select Operation and press Enter. On the dialog box that opens, select Start Locate and press Enter.
Figure 42 Operation screen
4.     On the screen as shown in Figure 43, select Go and press Enter.
Figure 43 Selecting Go
When the operation is complete, the screen as shown in Figure 44 opens. The Fault/UID LED on the drive turns steady blue.
Figure 44 Completing locating the physical drive
Locating all drives for a virtual drive
1.     On the storage controller configuration screen as shown in Figure 45, select Virtual Drive Management and press Enter.
Figure 45 Storage controller configuration screen
2.     On the screen as shown in Figure 46, select the target drive and press Enter.
Figure 46 Selecting the target drive
3.     On the screen as shown in Figure 47, select Operation and press Enter. On the dialog box that opens, select Start Locate and press Enter.
Figure 47 Operation screen
4.     On the screen as shown in Figure 48, select Go and press Enter.
Figure 48 Selecting Go
When the operation is complete, the screen as shown in Figure 49 opens. The Fault/UID LED on the drive turns steady blue.
Figure 49 Completing locating all drives for a virtual drive
This task allows you to initialize a virtual drive to be used by operating systems.
To initialize a virtual drive:
1.     On the storage controller configuration screen as shown in Figure 50, select Virtual Drive Management and press Enter.
Figure 50 Storage controller configuration screen
2.     On the screen as shown in Figure 51, select the target drive and press Enter.
Figure 51 Virtual Drive Management screen
3.     On the screen as shown in Figure 52, select Operation and press Enter. On the dialog box that appears, select Fast Initialization or Slow Initialization and press Enter.
Figure 52 Operation screen
Fast initialization allows immediately writing data. Slow initialization allows writing data after initialization is complete.
4.     On the screen as shown in Figure 53, select Go and press Enter.
Figure 53 Selecting Go
5.     On the screen as shown in Figure 54, select Confirm and press Enter. On the dialog box that opens, select Enabled and press Enter. Then, select Yes and press Enter.
Figure 54 Confirming the initialization
When the operation is complete, the screen as shown in Figure 55 opens.
Figure 55 Completing the operation
1.     On the storage controller configuration screen as shown in Figure 56, select Drive Management and press Enter.
Figure 56 Storage controller configuration screen
2.     On the screen as shown in Figure 57, select the target drive and press Enter.
Figure 57 Drive Management screen
3.     On the screen as shown in Figure 58, select Operation and press Enter. On the dialog box that opens, select Initialize Drive and press Enter.
Figure 58 Operation screen
4.     On the screen as shown in Figure 59, select Go and press Enter.
Figure 59 Selecting Go
5.     On the screen as shown in Figure 60, select Confirm and press Enter. On the dialog box that opens, select Enabled and press Enter. Then, select Yes and press Enter.
Figure 60 Confirming the initialization
When the operation is complete, the screen as shown in Figure 61 opens.
Figure 61 Completing the operation
Erasing drives
CAUTION
CAUTION:
To avoid drive failure, do not perform other operations when erasing a physical drive.
This task allows you to erase data from physical and logical drives.
Erasing a physical drive
1.     On the storage controller configuration screen as shown in Figure 62, select Drive Management and press Enter.
Figure 62 Storage controller configuration screen
2.     On the screen as shown in Figure 63, select the target drive and press Enter.
Figure 63 Drive Management screen
3.     On the screen as shown in Figure 64, select Operation and press Enter.
4.     On the dialog box that opens, select Drive Erase and press Enter.
For some controllers, you must select Cryptographic Erase for a SAS drive and select Drive Erase for a SATA drive.
Figure 64 Operation screen
5.     On the screen as shown in Figure 65, press Enter and set the Erase Mode (the default Simple mode is recommended).
Figure 65 Setting the Erase Mode
6.     On the screen as shown in Figure 66, select Go and press Enter.
Figure 66 Selecting Go
7.     On the screen as shown in Figure 67, select Confirm and press Enter. On the dialog box that opens, select Enabled and press Enter. Then, select Yes and press Enter.
Figure 67 Confirming the operation
When the operation is complete, the screen as shown in Figure 68 opens.
Figure 68 Completing the operation
Erasing a logical drive
1.     On the storage controller configuration screen as shown in Figure 69, select Virtual Drive Management and press Enter.
Figure 69 Storage controller configuration screen
2.     On the screen as shown in Figure 70, select the target drive and press Enter.
Figure 70 Virtual Drive Management screen
3.     On the screen as shown in Figure 71, select Operation and press Enter. On the dialog box that appears, select Virtual Drive Erase and press Enter.
Figure 71 Operation screen
4.     On the screen as shown in Figure 72, press Enter and set the Erase Mode (the default Simple mode is recommended).
Figure 72 Setting the Erase Mode
5.     On the screen as shown in Figure 73, select Go and press Enter.
Figure 73 Selecting Go
6.     On the screen as shown in Figure 74, select Confirm and press Enter. On the dialog box that opens, select Enabled and press Enter. Then, select Yes and press Enter.
Figure 74 Confirming the operation
7.     When the operation is complete, the screen as shown in Figure 75 opens.
Figure 75 Completing the operation
This task allows you to expand the RAID array capacity by setting the percentage of available logical drive capacity for availability purposes.
The LSI 9440&9460&9540&9560 controller supports migration and scale-up in UEFI mode or the operating system only when the RAID level is 0, 1, 5, or 6.
To expand a RAID array:
1.     On the storage controller configuration screen as shown in Figure 76, select Virtual Drive Management and press Enter.
Figure 76 Storage controller configuration screen
2.     On the screen as shown in Figure 77, select the target drive and press Enter.
Figure 77 Virtual Drive Management screen
3.     On the screen as shown in Figure 78, select Operation and press Enter. On the dialog box that appears, select Expand Virtual Drive and press Enter.
Figure 78 Operation screen
4.     On the screen as shown in Figure 79, select Go and press Enter.
Figure 79 Selecting Go
5.     On the screen as shown in Figure 80, modify the value for Enter a Percentage of Available Capacity, select OK, and then press Enter.
Figure 80 Setting the percentage of available capacity
When the operation is complete, the screen as shown in Figure 81 opens.
Figure 81 Completing expanding a RAID array
This task allows you to change the RAID level without affecting data integrity.
To migrate the RAID level:
1.     On the storage controller configuration screen as shown in Figure 82, select Virtual Drive Management and press Enter.
Figure 82 Storage controller configuration screen
2.     On the screen as shown in Figure 83, select the target drive and press Enter.
Figure 83 Virtual Drive Management screen
3.     On the screen as shown in Figure 84, select Operation and press Enter. On the dialog box that appears, select Reconfigure Virtual Drive and press Enter.
Figure 84 Operation screen
4.     On the screen as shown in Figure 85, select Go and press Enter.
Figure 85 Selecting Go
5.     On the screen as shown in Figure 86, set the RAID level, select Choose the Operation, and then press Enter.
Figure 86 Choose the operation
6.     On the screen as shown in Figure 87, select the target drives. ([Enabled] following a drive means that the drive has been selected.) Then, select Apply Changes and press Enter.
Figure 87 Adding drives
7.     On the screen as shown in Figure 88, select Confirm and press Enter. On the dialog box that opens, select Enabled and press Enter. Then, select Yes and press Enter.
Figure 88 Confirming the operation
8.     On the screen as shown in Figure 89, select Start Operation, and then press Enter.
Figure 89 Start the operation
9.     On the screen as shown in Figure 90, select OK, and then press Enter.
Figure 90 Selecting OK
10.     On the screen as shown in Figure 91, you can view the migration progress.
Figure 91 Viewing the migration progress
This task allows you to clear remaining RAID array information on the drive for reconfiguring RAID array on the drive. The task typically applies to drives in Unconfigured Bad state.
To clear RAID array information on the drive:
1.     Switch the drive state from Unconfigured Bad to Unconfigured Good. For more information, see "Switching the drive state."
2.     On the storage controller configuration screen as shown in Figure 92, select Configuration Management and press Enter.
Figure 92 Storage controller configuration screen
3.     On the screen as shown in Figure 93, select Manage Foreign Configuration and press Enter.
Figure 93 Selecting Manage Foreign Configuration
4.     On the screen as shown in Figure 94, select Clear Foreign Configuration and press Enter.
Figure 94 Selecting Clear Foreign Configuration
5.     On the screen as shown in Figure 95, select Confirm and press Enter. On the dialog box that opens, select Enabled and press Enter. Then, select Yes and press Enter.
Figure 95 Confirming the operation
When the operation is complete, the screen as shown in Figure 96 opens.
Figure 96 Completing the operation
This task allows you to hide a virtual drive to avoid unintentional deletion.
To hide a virtual drive:
1.     On the storage controller configuration screen as shown in Figure 97, select Virtual Drive Management and press Enter.
Figure 97 Storage controller configuration screen
2.     On the screen as shown in Figure 98, select the target drive and press Enter.
Figure 98 Virtual Drive Management screen
3.     On the screen as shown in Figure 99, select Operation and press Enter. On the dialog box that appears, select Hide Virtual Drive and press Enter.
Figure 99 Operation screen
Hiding a RAID array
This task allows you to hide a RAID array to avoid unintentional deletion. If you hide a RAID array, all the virtual drives of the RAID array are hidden.
To hide a RAID array:
1.     On the storage controller configuration screen as shown in Figure 100, select Virtual Drive Management and press Enter.
Figure 100 Storage controller configuration screen
2.     On the screen as shown in Figure 101, select the target drive and press Enter.
Figure 101 Virtual Drive Management screen
3.     On the screen as shown in Figure 102, select Operation and press Enter. On the dialog box that appears, select Hide Drive Group and press Enter.
Figure 102 Operation screen
To use a USB drive for the firmware upgrade, save the firmware file in the root directory or a level-1 folder of the USB drive.
To upgrade the storage controller firmware online:
1.     On the Advanced screen as shown in Figure 103, select Update Firmware and press Enter.
Figure 103 Advanced screen
2.     On the screen as shown in Figure 104, select the directory of the target firmware and press Enter.
Figure 104 Selecting directory
3.     On the screen as shown in Figure 105, select the image file of the target firmware and press Enter.
Figure 105 Selecting image
4.     On the screen as shown in Figure 106, select Update and press Enter.
Figure 106 Selecting Update
5.     On the screen as shown in Figure 107, select Confirm and press Enter. On the dialog box that opens, select Enabled and press Enter. Then, select Yes and press Enter.
CAUTION
CAUTION:
After confirming the upgrade, the screen is stuck for a short time during which the firmware is being upgraded. Do not perform any other operations during this time.
Figure 107 Confirming the operation
6.     On the screen as shown in Figure 108, select OK and press Enter.
Figure 108 Completing the operation
7.     Restart the BIOS for the operation to take effect.
Switching the storage controller mode
1.     On the Advanced menu, select Main Menu and press Enter.
Figure 109 Selecting Main Menu
2.     Select Controller Management and press Enter.
Figure 110 Selecting Controller Management
3.     Select Advanced Controller Management and press Enter.
Figure 111 Selecting Advanced Controller Management
4.     Select Manage Personality Mode and press Enter.
Figure 112 Selecting Manage Personality Mode
As shown in Figure 113, the storage controller is now is RAID mode. To switch the controller to JBOD mode, select Switch to JBOD Mode and press Enter.
Figure 113 Switching the controller to JBOD mode
5.     Select Confirm to enable the specified mode, select Yes and then press Enter.
CAUTION
CAUTION:
When switching the storage controller to JBOD mode, you can also change logical drives managed by the controller to JBOD mode at the same time. Be careful that data might be cleared for logical drives that do not support JBOD mode once you switch the mode. As a best practice, set drive state to Unconfigured Good before you switch the mode of any LSI storage controller. For example, logical drives in RAID 5, RAID 6, RAID 50, or RAID 60 managed by RAID-LSI-9560-LP-8i-4GB storage controller do not support JBOD mode and will be cleared if you switch their mode. For more information, see the screen prompt.
Figure 114 Confirming the mode switching
6.     Select OK and press Enter to reboot the operating system for the change to take effect.
Figure 115 Completing the mode switching
Forcing a logical drive to come online
When the number of faulty drives exceeds the tolerance range of the logical drive fault-tolerant method, the management tool interface displays the state of logical drives as Offline. In this case, you can use this feature to force logical drives to come online.
CAUTION
CAUTION:
Using this function may change data in the logical drive. Before forcing a logical drive to come online, perform an evaluation task to determine whether the operation can be performed.
To force a logical drive to come online:
1.     On the storage controller screen, select Virtual Drive Management and then press Enter.
Figure 116 Storage controller screen
2.     Select the target logical drive, and then press Enter.
Figure 117 Virtual Drive Management screen
3.     Select View Associated Drives and then press Enter.
Figure 118 Selecting View Associated Drives
4.     Select the target offline member drive, enable the drive, select View Drive Properties, and then press Enter.
Figure 119 Selecting View Drive Properties
5.     Select Operation, press Enter, select Place Drive Online, and then press Enter again.
Figure 120 Selecting Place Drive Online
6.     Select Go and then press Enter.
Figure 121 Selecting Go
7.     Select Confirm, set this field to Enabled, select Yes, and then press Enter.
Figure 122 Confirming the configuration
Figure 123 Operation succeeded
Setting alarm control
Perform this task to enable or disable alarm control.
1.     On the storage controller configuration page, select Controller Management and then press Enter.
Figure 124 Storage controller configuration screen
2.     On the Controller Management screen, select Advanced Controller Properties and press Enter.
Figure 125 Controller Management screen
3.     On the Advanced Controller Properties screen, select Alarm Control and press Enter. Then, select Enabled or Disabled and press Enter.
The buzzer has been removed from the LSI9560/9540 controller. The Alarm Control option is not available for the controller.
Figure 126 Drive management screen
Silencing the buzzer
1.     Access the Advanced tab, select the target storage controller (such as AVAGO MegaRAID<AVAGO MegaRAID SAS 9361-8i>) and then press Enter.
Figure 127 Advanced screen
2.     Select Silence Alarm and press Enter.
Figure 128 Selecting Silence Alarm
Configuring RAID arrays in legacy mode
This section describes how to configure RAID arrays through a storage controller in legacy mode. For more information about how to enter the BIOS and set the boot mode to legacy, see the BIOS user guide for the server.
Only the LSI-9361 series storage controllers support RAID array configuration in legacy mode. The other storage controllers support displaying managed physical drives and logical drives on the POST screen in legacy mode, but do not support accessing the storage controller configuration screen.
To configure a RAID array in legacy, perform the following tasks:
·     (Optional.) Configuring boot options
1.     During server POST, press Ctrl+R as prompted as shown in Figure 129.
Figure 129 Pressing Ctrl+R
2.     On the screen as shown in Figure 130, follow the instructions at the bottom of the screen to navigate through screens and modify settings.
Figure 130 LSI RAID management screen
·     Unconfigured Bad—The drive is faulty or has RAID array information remaining on it. If the drive is faulty, replace the drive. If the drive has RAID array information remaining on it, clear the information.
·     JBOD—Just a Bunch Of Drives. The drive is a passthrough drive and does not support RAID configuration.
To switch from Unconfigured Bad state to Unconfigured Good state:
1.     On the PD Mgmt screen as shown in Figure 131, select the target drive and press F2.
Figure 131 Selecting the target drive
2.     On the screen as shown in Figure 132, select Make unconfigured good and press Enter.
Figure 132 Selecting Make unconfigured good
1.     On the VD Mgmt screen as shown in Figure 133, press F2 and select Create Virtual Drive.
Figure 133 Selecting Create Virtual Drive
2.     On the screen as shown in Figure 134, set the RAID level and press Enter.
Figure 134 Setting the RAID level
3.     On the screen as shown in Figure 135, select the target drive and press Enter.
Figure 135 Selecting the target drive
4.     On the screen as shown in Figure 136, specify the size and name, select Advanced, and then press Enter.
Figure 136 Specifying the RAID array name and size
5.     On the screen as shown in Figure 137, configure the parameters, select OK, and then press Enter. For more information about the parameter description, see Table 4.
Figure 137 Configuring advanced RAID array parameters
6.     On the screen as shown in Figure 138, select OK, and then press Enter.
Figure 138 Confirming the creation
7.     On the screen as shown in Figure 139, select the target RAID array and press Enter. You can view the detailed information about the RAID array, including name, level, and drive information.
Figure 139 Viewing RAID array information
For data security purposes, configure hot spare drives after configuring a RAID array. You can configure a global hot spare drive or dedicated hot spare drive.
·     The capacity of the hot spare drive must be equal to or greater than the capacity of the smallest drive in the RAID array.
1.     On the PD Mgmt screen as shown in Figure 140, select the target drive and press F2.
Figure 140 Selecting the target drive
2.     On the screen as shown in Figure 141, select Make Global HS and press Enter.
Figure 141 Selecting Make Global HS
3.     On the screen as shown in Figure 142, you can view global hot spare drive information by selecting the target drive.
Figure 142 Viewing global hot spare drive information
This section describes the procedure for configuring a dedicated hot spare drive when creating a RAID array.
1.     On the VD Mgmt screen, press F2 and then select Manage Ded.HS.
2.     On the screen as shown in Figure 143, select the target drive, select Advanced, and then press Enter.
Figure 143 Selecting the target virtual drive
3.     On the screen as shown in Figure 144, select Configure HotSpare, select OK, and then press Enter.
Figure 144 Selecting Configure HotSpare
4.     On the screen as shown in Figure 145, select the target drive, select OK, and then press Enter.
Figure 145 Selecting the target drive
1.     On the VD Mgmt screen as shown in Figure 146, select the target drive and press F2.
Figure 146 Selecting the target drive
2.     On the screen as shown in Figure 147, select Delete VD and press Enter.
Figure 147 Selecting Delete VD
3.     On the screen as shown in Figure 148, select YES and press Enter.
Figure 148 Confirming the operation
Locating drives
This task allows you to locate a physical drive.
To locate drives:
1.     On the PD Mgmt screen as shown in Figure 149, select the target drive and press F2.
Figure 149 Selecting the target drive
2.     On the screen as shown in Figure 150, select Locate > Start. The Fault/UID LED on the drive turns steady blue. To stop locating drives, select Locate > Stop.
Figure 150 Selecting Locate > Start
1.     On the VD Mgmt screen as shown in Figure 151, select the target drive and press F2.
Figure 151 Selecting the target drive
2.     On the screen as shown in Figure 152, select Initialization > Start FGI.
Figure 152 Selecting Initialization > Start FGI
·     Background Initialization (BGI) first initializes part of the RAID array space for data write operations, and initializes the rest of the RAID array space in the background.
·     Full Ground Initialization (FGI) initializes the entire RAID array space. Data write operations can be performed only when the initialization is complete.
3.     On the screen as shown in Figure 153, select YES and press Enter.
Figure 153 Confirming the operation
Erasing drives
CAUTION
CAUTION:
This task allows you to erase physical and logical drives.
1.     On the PD Mgmt screen as shown in Figure 154, select the target drive and press F2.
Figure 154 Selecting the target drive
2.     On the screen as shown in Figure 155, select the erase mode (the default Simple mode is recommended) and press Enter.
Figure 155 Selecting the erase mode
3.     On the screen as shown in Figure 156, select Yes and press Enter.
Figure 156 Confirming the operation
1.     On the VD Mgmt screen as shown in Figure 157, select the target drive and press F2.
Figure 157 Selecting the target drive
2.     On the screen as shown in Figure 158, select the erase mode (the default Simple mode is recommended) and press Enter.
Figure 158 Selecting the erase mode
3.     On the screen as shown in Figure 159, select YES and press Enter.
Figure 159 Confirming the operation
This task allows you to expand the RAID array capacity by setting the percentage of available capacity for logical drives.
1.     On the VD Mgmt screen as shown in Figure 160, select the target drive and press F2.
Figure 160 Selecting the target drive
2.     On the screen as shown in Figure 161, select Expand VD size and press Enter.
Figure 161 Selecting Expand VD size
3.     On the screen as shown in Figure 162, modify the value for Enter a percentage of available capacity as needed, select Resize, and then press Enter.
Figure 162 Setting the percentage of available capacity
2.     On the Foreign View screen as shown in Figure 163, select the target storage controller and press F2. Select Foreign Config > Clear and press Enter.
Figure 163 Selecting Foreign Config > Clear
3.     On the dialog box that appears as shown in Figure 164, select OK and press Enter.
Figure 164 Confirming the operation
1.     On the Ctrl Mgmt screen as shown in Figure 165, select the target physical drive or logical drive as the boot device and then press Enter.
Figure 165 Selecting the boot device
2.     Select APPLY and then press Enter as shown in Figure 166.
Figure 166 Confirming the operation
Downloading and installing StorCLI
This section introduces the download and installation steps of the OS command line tool. You can use the OS command line tool to manage storage controllers during normal server operation without restarting the server.
Downloading StorCLI
1.     Access https://www.h3c.com/cn/BizPortal/DownLoadAccessory/DownLoadAccessoryFilt.aspx.
2.     Download the installation package and release notes for the corresponding storage controller firmware as instructed.
3.     Decompress the installation package to obtain the StorCLI tool package for different operating systems.
Installing StorCLI
See the release notes to install StorCLI for the corresponding operating system.
Commonly-used commands in StorCLI
This section describes the usage and examples of commonly used commands in StorCLI. You can use the OS command line tool to manage storage controllers during normal server operation without restarting the server.
Commands related to the specified path in this tool do not support spaces and special characters.
Viewing storage controller information
Perform this task to view basic information about an LSI storage controller.
storcli64 /ccontroller_id show [logfile=logfilename]
storcli64 /ccontroller_id show all [logfile=logfilename]
controller_id: Specifies the ID of a storage controller. If only one storage controller exists, the ID is 0 by default. If multiple storage controllers exist, use the storcli64 /call show command to view the controller ID. To view information about all storage controllers, specify the controller ID as all.
logfilename: Specifies the name of the exported file used to save the filtered information.
# View basic information about a storage controller.
[root@localhost ~]# storcli64 /c0 show
Generating detailed summary of the adapter, it may take a while to complete.
CLI Version = 007.2408.0000.0000 Nov 15, 2022
Operating system = Linux 4.18.0-193.el8.x86_64
Controller = 0
Status = Success
Description = None
Product Name = MegaRAID 9560-8i 4GB
Serial Number = SK01065334
SAS Address =  500062b2024fe0c0
PCI Address = 00:4b:00:00
System Time = 11/09/2023 14:38:46
Mfg. Date = 03/04/20
Controller Time = 11/09/2023 06:38:47
FW Package Build = 52.24.0-4763
BIOS Version = 7.24.01.0_0x07180100
FW Version = 5.240.02-3768
Driver Name = megaraid_sas
Driver Version = 07.726.02.00
Current Personality = RAID-Mode
Vendor Id = 0x1000
Device Id = 0x10E2
SubVendor Id = 0x1000
SubDevice Id = 0x4010
Host Interface = PCI-E
Device Interface = SAS-12G
Bus Number = 75
Device Number = 0
Function Number = 0
Domain ID = 0
Security Protocol = None
Drive Groups = 1
TOPOLOGY :
DG Arr Row EID:Slot DID Type  State BT       Size PDC  PI SED DS3  FSpace TR
 0 -   -   -        -   RAID1 Optl  N  893.750 GB dflt N  N   none N      N
 0 0   -   -        -   RAID1 Optl  N  893.750 GB dflt N  N   none N      N
 0 0   0   249:0    31  DRIVE Onln  N  893.750 GB dflt N  N   none -      N
 0 0   1   249:1    30  DRIVE Onln  N  893.750 GB dflt N  N   none -      N
DG=Disk Group Index|Arr=Array Index|Row=Row Index|EID=Enclosure Device ID
DID=Device ID|Type=Drive Type|Onln=Online|Rbld=Rebuild|Optl=Optimal|Dgrd=Degraded
Pdgd=Partially degraded|Offln=Offline|BT=Background Task Active
PDC=PD Cache|PI=Protection Info|SED=Self Encrypting Drive|Frgn=Foreign
DS3=Dimmer Switch 3|dflt=Default|Msng=Missing|FSpace=Free Space Present
TR=Transport Ready
Virtual Drives = 1
VD LIST :
DG/VD TYPE  State Access Consist Cache Cac sCC       Size Name
0/235 RAID1 Optl  RW     No      RWBD  -   ON  893.750 GB
VD=Virtual Drive| DG=Drive Group|Rec=Recovery
Cac=CacheCade|OfLn=OffLine|Pdgd=Partially Degraded|Dgrd=Degraded
Optl=Optimal|dflt=Default|RO=Read Only|RW=Read Write|HD=Hidden|TRANS=TransportReady
B=Blocked|Consist=Consistent|R=Read Ahead Always|NR=No Read Ahead|WB=WriteBack
AWB=Always WriteBack|WT=WriteThrough|C=Cached IO|D=Direct IO|sCC=Scheduled
Check Consistency
JBOD Drives = 12
JBOD LIST :
ID EID:Slt DID State Intf Med     Size SeSz Model                Vendor   Port
 4 249:4    32 Onln  SATA HDD 7.277 TB 512B HGST HUS728T8TALE6L4 ATA      C0.0 & C0.1
 5 249:5     9 Onln  SATA HDD 7.277 TB 512B HGST HUS728T8TALE6L4 ATA      C0.0 & C0.1
 6 249:6     1 Onln  SAS  HDD 7.277 TB 512B HUS728T8TAL5204      HGST     C0.0 & C0.1
 7 249:7    33 Onln  SATA HDD 7.277 TB 512B HGST HUS728T8TALE6L4 ATA      C0.0 & C0.1
 8 249:8    16 Onln  SATA HDD 7.277 TB 512B HGST HUS728T8TALE6L4 ATA      C0.0 & C0.1
 9 249:9    22 Onln  SATA HDD 7.277 TB 512B HGST HUS728T8TALE6L4 ATA      C0.0 & C0.1
10 249:10   17 Onln  SATA HDD 7.277 TB 512B HGST HUS728T8TALE6L4 ATA      C0.0 & C0.1
11 249:11   11 Onln  SATA HDD 7.277 TB 512B HGST HUS728T8TALE6L4 ATA      C0.0 & C0.1
12 249:12   20 Onln  SATA HDD 7.277 TB 512B HGST HUS728T8TALE6L4 ATA      C0.0 & C0.1
13 249:13   13 Onln  SATA HDD 7.277 TB 512B HGST HUS728T8TALE6L4 ATA      C0.0 & C0.1
14 249:14   12 Onln  SATA HDD 7.277 TB 512B HGST HUS728T8TALE6L4 ATA      C0.0 & C0.1
15 249:15   21 Onln  SATA HDD 7.277 TB 512B HGST HUS728T8TALE6L4 ATA      C0.0 & C0.1
ID=JBOD Target ID|EID=Enclosure Device ID|Slt=Slot No|DID=Device ID|Onln=Online
Offln=Offline|Intf=Interface|Med=Media Type|SeSz=Sector Size
SED=Self Encryptive Drive|PI=Protection Info|Sp=Spun|U=Up|D=Down
Physical Drives = 14
PD LIST :
EID:Slt DID State DG       Size Intf Med SED PI SeSz Model                     Sp Type
249:0    31 Onln   0 893.750 GB SATA SSD N   N  512B Micron_5300_MTFDDAK960TDS U  -
249:1    30 Onln   0 893.750 GB SATA SSD N   N  512B Micron_5300_MTFDDAK960TDS U  -
249:4    32 Onln   -   7.277 TB SATA HDD N   N  512B HGST HUS728T8TALE6L4      U  JBOD
249:5     9 Onln   -   7.277 TB SATA HDD N   N  512B HGST HUS728T8TALE6L4      U  JBOD
249:6     1 Onln   -   7.277 TB SAS  HDD N   N  512B HUS728T8TAL5204           U  JBOD
249:7    33 Onln   -   7.277 TB SATA HDD N   N  512B HGST HUS728T8TALE6L4      U  JBOD
249:8    16 Onln   -   7.277 TB SATA HDD N   N  512B HGST HUS728T8TALE6L4      U  JBOD
249:9    22 Onln   -   7.277 TB SATA HDD N   N  512B HGST HUS728T8TALE6L4      U  JBOD
249:10   17 Onln   -   7.277 TB SATA HDD N   N  512B HGST HUS728T8TALE6L4      U  JBOD
249:11   11 Onln   -   7.277 TB SATA HDD N   N  512B HGST HUS728T8TALE6L4      U  JBOD
249:12   20 Onln   -   7.277 TB SATA HDD N   N  512B HGST HUS728T8TALE6L4      U  JBOD
249:13   13 Onln   -   7.277 TB SATA HDD N   N  512B HGST HUS728T8TALE6L4      U  JBOD
249:14   12 Onln   -   7.277 TB SATA HDD N   N  512B HGST HUS728T8TALE6L4      U  JBOD
249:15   21 Onln   -   7.277 TB SATA HDD N   N  512B HGST HUS728T8TALE6L4      U  JBOD
EID=Enclosure Device ID|Slt=Slot No|DID=Device ID|DG=DriveGroup
DHS=Dedicated Hot Spare|UGood=Unconfigured Good|GHS=Global Hotspare
UBad=Unconfigured Bad|Sntze=Sanitize|Onln=Online|Offln=Offline|Intf=Interface
Med=Media Type|SED=Self Encryptive Drive|PI=Protection Info
SeSz=Sector Size|Sp=Spun|U=Up|D=Down|T=Transition|F=Foreign
UGUnsp=UGood Unsupported|UGShld=UGood shielded|HSPShld=Hotspare shielded
CFShld=Configured shielded|Cpybck=CopyBack|CBShld=Copyback Shielded
UBUnsp=UBad Unsupported|Rbld=Rebuild
Enclosures = 1
Enclosure LIST :
EID State Slots PD PS Fans TSs Alms SIM Port#          ProdID VendorSpecific
249 OK       28 14  0    1   7    0   0 C0.0 & C0.1 x8 Cub    exp-2.1.1.0
EID=Enclosure Device ID | PD=Physical drive count | PS=Power Supply count
TSs=Temperature sensor count | Alms=Alarm count | SIM=SIM Count | ProdID=Product ID
Cachevault_Info :
Model  State   Temp Mode MfgDate
CVPM05 Optimal 27C  -    2019/09/18
# View all information about a storage controller and save the information to the specified file.
[root@localhost ~]# storcli64 /c0 show all logfile=logfile.txt
Perform this task to switch the storage controller mode.
storcli64 /ccontroller_id set personality =mode
A storage controller operates in RAID mode.
mode: Specifies the controller mode. Options include:
·     raid: Specifies the RAID mode.
·     jbod: Specifies the JBOD mode.
·     Before switching the controller mode to JBOD, make sure the storage controller is using the most recent version. Lower versions may not support the JBOD mode.
·     Before using this command, make sure all drives managed by the storage controller are in Unconfigured Good state.
·     For the configuration to take effect, you must restart the operating system after executing the command.
# Switch the storage controller mode to JBOD.
[root@localhost home]# ./storcli64 /c0 set personality=jbod
CLI Version = 007.1017.0000.0000 May 10, 2019
Controller = 0
Status = Success
Description = None
Controller Properties :
Ctrl_Prop       Value
Set Personality JBOD (Reboot the system for the change to take effect.)
Updating the firmware
Perform this task to upgrade, downgrade, or update the firmware of a storage controller.
To upgrade the firmware:
storcli64 /ccontroller_id download file= fw_file
To downgrade or update the firmware:
storcli64 /ccontroller_id download file= fw_file noverchk
fw_file: Specifies the firmware file name.
noverchk: Configures the system not to check the firmware image version when downgrading or updating the storage controller firmware.
If the firmware file does not exist in the current path, you must add the absolute path to the file name.
# Upgrade the storage controller firmware.
[root@localhost home]# ./storcli64 /c0 download file=MR_4MB.rom noverchk
Download Completed.
Flashing image to adapter...
Controller = 0
Status = Success
Description = F/W Flash Completed. Please reboot the system for the changes to take effect
# Downgrade or update the firmware.
Download Completed.
Controller = 0
Status = Success
Creating and deleting RAID arrays
Perform this task to create and delete RAID arrays.
To create a RAID array:
storcli64 /ccontroller_id add vd rraid_level [size=<vd1_size>,..] [name=<vdname1>,..] drives= vd_drives [pdperarray= pdperarraynum] [pdcache=pdcache_policy] [pi] [wt|wb|awb] [nora|ra] [strip=strip_size] [emulationtype=emulationtype] [spares =spares_drives]
To delete a RAID array:
storcli64 /ccontroller_id/vraid_id del
raid_level: Specifies the RAID level. Options include 0, 1, 5, 6, 00, 10, 50, and 60.
vd1_size: Specifies the capacity of the RAID array, in gb. If you specify all, it indicates that the array can use all the available capacity.
vdname1: Specify the name of the logical drive.
vd_drives: Specifies member drives. The name of each member drive must be in the enclosure_id:slot_id format, where enclosure_id represents the ID the enclosure in which the drive resides, and slot_id represents the drive slot ID.
pdperarraynum: Specifies the number of drives in the sub-group if the RAID level is 10, 50, or 60.
pdcache_policy: Specifies the cache state for member drives. Options include on, off, and default. Setting this field to default represents retaining the current cache state.
pi: Enables data protection.
wt|wb|awb: Specifies the write cache policy. Write through (wt) notifies the system of transmission completion when data are written into disks. Write back (wb) notifies the system of transmission completion when data are written into the controller cache. Always write back (awb) forces the system to use write back when no supercapacitor is present, which may cause data loss in the event of unexpected power-off.
nora|ra: Specifies the read cache policy. When reading data from RAID, the ra policy enables the system to read the surrounding data and store them in the cache at the same time. When the user accesses these data subsequently, they can can be directly read from the cache, which reduces the disk seeking time and improves read performance.
strip_size: Specifies the strip size. For an MR controller, options include 8, 16, 32, 64, 128, 256, 512, and 1024. For an iMR controller, only 64 is supported. Among all the controllers supported by this document, only the HBA-LSI-9440-8i is an iMR controller.
emulationtype: Options include 0, 1, and 2. By default, the value is 0. 0: Displays the sector size as 512e if member drives include a 512e drive, and 512n if member drives do not include 512e drives. 1: Displays the sector size 512n if member drives do not include 512e drives. 2: Displays the sector size as 512e even if member drives do not include 512e drives.
spares_drives: Specifies hot spare drives. The name of each hot spare drive is in the format of enclosure_id:slot_id.
raid_id: Specifies the ID of the RAID array to be deleted. To obtain the ID, use the ./storcli64 /c0/vall show command. If you specify this field to all, the command deletes all the RAID arrays.
When you specify member drives, use a comma (,) to separate two slots and use a hyphen (-) to indicate a slot range.
# Create RAID 1.
[root@localhost home]# ./storcli64 /c0 add vd r1 size=all drives=2:8,23
Controller = 0
Status = Success
Description = Add VD Succeeded
[root@localhost home]# ./storcli64 /c0/v0 del
Controller = 0
Status = Success
Description = Delete VD succeeded
Perform this task to turn on or turn off the UID LED of a physical drive.
storcli64 /ccontroller_id/eenclosure_id/sslot_id  action locate
enclosure_id: Specifies the enclosure ID. If you specify this field as all, the command turns on the UID LEDs for all drives in all enclosures.
slot_id: Specifies the ID of the physical drive slot. If you specify this field as all, the command turns on the UID LEDs for all drives in the enclosure.
action: Specifies the action to take. Options include:
·     start: Turn on the UID LED.
·     stop: Turn off the UID LED.
# Turn on the drive UID LED.
[root@localhost home]# ./storcli64 /c0/e2/s8 start locate
Controller = 0
Status = Success
Description = Start Drive Locate Succeeded.
# Turn off the drive UID LED.
[root@localhost home]# ./storcli64 /c0/e2/s8 stop locate
Controller = 0
Status = Success
Description = Stop Drive Locate Succeeded.
Viewing the JBOD state
Perform this task to view the enabling status of the JBOD function for a storage controller.
storcli64 /ccontroller_id jbod
# View the JBOD state.
[root@localhost home]# ./storcli64 /c0 show jbod
CLI Version = 007.1316.0000.0000 Mar 12, 2020
Operating system = Linux 3.10.0-862.el7.x86_64
Controller = 0
Status = Success
Description = None
Ctrl_Prop Value
JBOD      ON
Perform this task to enable or disable the JBOD function for a storage controller in RAID mode.
storcli64 /ccontroller_id set jbod=mode
The JBOD function is disabled in RAID mode.
mode: Specifies the action to take. Options include:
·     on: Enable JBOD.
·     off: Disable JBOD.
This feature is supported only by the 9361, 9460, 9440, and 9540 controllers.
# Enable JBOD.
[root@localhost home]# ./storcli64 /c0 set jbod=on
Controller = 0
Status = Success
Description = None
Ctrl_Prop Value
JBOD      ON
# Disable JBOD.
[root@localhost home]# ./storcli64 /c0 set jbod=off
Controller = 0
Status = Success
Description = None
Ctrl_Prop Value
JBOD      OFF
Perform this task to switch the drive state between JBOD and Unconfigured Good.
storcli64 /ccontroller_id/eenclosure_id/sslot_id set good [force]
storcli64 /ccontroller_id/eenclosure_id/sslot_id set jbod
Before switching the drive state from Unconfigured Good to JBOD, make sure the JBOD function is enabled for the storage controller.
# Switch the drive state to Unconfigured Good.
[root@localhost home]# ./storcli64 /c0/e2/s8 set good force
Controller = 0
Status = Success
Description = Set Drive Good Succeeded.
# Switch the drive state to JBOD.
[root@localhost home]# ./storcli64 /c0/e2/s8 set jbod
Controller = 0
Status = Success
Description = Set Drive JBOD Succeeded.
Viewing drive information
Perform this task to view basic drive information.
storcli64 /ccontroller_id/eenclosure_id/sslot_id show [all]
[root@localhost home]# ./storcli64 /c0/e2/s8 show
Controller = 0
Status = Success
Description = Show Drive Information Succeeded.
Drive Information :
2:8      39 JBOD  -  5.458 TB SATA HDD N   N  512B ST6000NM0115-1YZ110 U  -
EID=Enclosure Device ID|Slt=Slot No.|DID=Device ID|DG=DriveGroup
UBad=Unconfigured Bad|Onln=Online|Offln=Offline|Intf=Interface
UGUnsp=Unsupported|UGShld=UnConfigured shielded|HSPShld=Hotspare shielded
Importing and exporting RAID configuration
Perform this task to save, restore, or import RAID configuration.
storcli64 /ccontroller_id get config file=filename
storcli64 /ccontroller_id set config file=filename
filename: Specifies the configuration file name.
Before performing this task, make sure the server environments are identical for the source and target servers.
For the LSI 9361/9460 in JBOD mode and the LSI 9560 controller in any mode, you must first configure all drives to be in Unconfigured Good state before importing any RAID configuration.
# Export RAID configuration.
[root@localhost home]# ./storcli64 /c0 get config file=conf.txt
Controller = 0
Status = Success
Description = Config data is saved to the file
# Import RAID configuration.
[root@localhost home]# ./storcli64 /c0 set config file=conf.txt
Controller = 0
Status = Success
Description = Config data is restored to the adapter
Scaling up RAID
Perform this task to scale up a RAID array.
storcli64 /ccontroller_id/vraid_id expand size=target_size
raid_id: Specifies the ID of the RAID array to be scaled up.
target_size: Specifies the target capacity size.
The LSI 9440&9460&9540&9560 controllers support migration and scaling up in UEFI mode or the OS only when the RAID level is 0, 1, 5, or 6.
# Scale up the RAID capacity to 20Gb.
[root@localhost home]# ./storcli64 /c0/v0 expand size=20gb
Controller = 0
Status = Success
Description = expansion operation succeeded
EXPANSION RESULT :
VD      Size FreSpc   ReqSize   AbsUsrSz  %FreSpc NewSize   Status NoArrExp
 0 10.000 GB 1.808 TB 20.000 GB 37.049 GB       2 47.049 GB -      1.808 TB
Size - Current VD size|FreSpc - Freespace available before expansion
%FreSpc - Requested expansion size in % of available free space
AbsUsrSz - User size rounded to nearest %
Perform this task to change the RAID level without affecting data integrity.
storcli64 /ccontroller_id/vraid_id start migrate type=raidx option=operation drives= vd_drives force
raidx: Specifies the target RAID level.
operation: Specifies whether to add or remove member drives. Options include add and remove.
[root@localhost home]# ./storcli64 /c0/v0 start migrate type=raid5 option=add drives=2:11
Controller = 0
Status = Success
Description = Start Reconstruction Operation Success
[root@localhost home]# ./storcli64 /c0/v0 start migrate type=raid0 option=remove drives=2:9
Controller = 0
Status = Success
Managing external configuration
Perform this task to import or delete external configuration.
storcli64 /ccontroller_id/fall operation
operation: Specifies the action to take. Options include:
·     import: Import external configuration.
·     del: Delete external configuration.
If multiple storage controllers exist, use the storcli64 /call show command to obtain a controller ID.
# Import external configuration.
[root@localhost home]# ./storcli64 /c0/fall import
Controller = 0
Status = Success
Description = Successfully imported foreign configuration
# Delete external configuration.
[root@localhost home]# ./storcli64 /c0/fall del
Controller = 0
Status = Success
Description = Successfully deleted foreign configuration
Perform this task to add hot spare drives for a redundant RAID array.
storcli64 /ccontroller_id/eenclosure_id/sslot_id add hotsparedrive
storcli64 /ccontroller_id/eenclosure_id/sslot_id add hotsparedrive dgs=drive_group
storcli64 /ccontroller_id/eenclosure_id/sslot_id delete hotsparedrive
If you do not specify the dgs keyword for an add operation, the command adds a global hot spare.
drive_group: Specify the drive group ID.
·     If multiple storage controllers exist, use the storcli64 /call show command to obtain a controller ID.
·     Hot spare disks must use consistent interface protocols as the member drives of the RAID array, and must have higher or the same capacity as the member drives.
# Add a global hot spare.
[root@localhost home]# ./storcli64 /c0/e2/s11 add hotsparedrive
Controller = 0
Status = Success
Description = Add Hot Spare Succeeded.
# Add a dedicated hot spare.
[root@localhost home]# ./storcli64 /c0/e2/s8 add hotsparedrive dgs=0
Controller = 0
Status = Success
# Delete a hot spare.
[root@localhost home]# ./storcli64 /c0/e2/s8 delete hotsparedrive
Controller = 0
Status = Success
Description = Delete Hot Spare Succeeded.
Collecting logs
Perform this task to export storage controller logs. A SnapDump file is a log file that can be automatically generated in scenarios with abnormal RAID controllers. You can obtain the SnapDump log for the current RAID controller.
storcli /ccontroller_id show all logfile=logfilename
storcli /ccontroller_id show snapdump
storcli /ccontroller_id get snapdump
storcli /ccontroller_id get snapdump id=all
storcli /ccontroller_id get snapdump id=snapdump_id file= logfilename
storcli /ccontroller_id show alilog logfile=logfilename
storcli /ccontroller_id show events logfile=logfilename
storcli /ccontroller_id show termlog logfile=logfilename
logfilename: Specifies the log file name.
snapdump_id: Specifies the SnapDump log ID.
logfilename: Specifies the name of the .zip file into which SnapDump data will be written.
·     Generating SnapDump data is a resource-intensive operation, which might lead to I/O timeouts. Therefore, leave a minimum of a 10-minute interval between two consecutive get SnapDump requests.
·     The LSI9440-8i (any firmware version) and the LSI9540-8i (firmware version earlier than 52.26.0-5014) support only one SnapDump. Each execution of the storcli /ccontroller_id get snapdump command overwrites existing SnapDump data on the controller. If an issue occurs, first execute storcli /ccontroller_id show snapdump to check if SnapDump has been auto-generated.
¡     If SnapDump has been generated, use the storcli /ccontroller_id get snapdump id=all or storcli /ccontroller_id get snapdump id=snapdump_id file= logfilename command to download SnapDump data.
¡     If SnapDump has not been generated, use the storcli /ccontroller_id get snapdump command to trigger the controller to generate new SnapDump data.
·     Switching the storage controller mode and updating the firmware will discard all SnapDump data on the DDR and flash.
Table 5 Support for SnapDump
Storage controller
Remarks
LSI9361-8i
No
N/A
LSI9440-8i
Yes
·     SnapDump data is saved on the flash.
·     Only one SnapDump is supported.
LSI9460-8i
Yes
·     SnapDump data is saved on the DDR.
·     If a supercapacitor is in place, the SnapDump data can be retained for up to four reboots.
·     If no supercapacitor is in place, the SnapDump data will be lost after a reboot.
LSI9460-16i
Yes
·     SnapDump data is saved in the cache.
LSI9540-8i
Yes
·     In a version earlier than 52.26.0-5014, only one SnapDump is supported.
LSI9560-8i
Yes
LSI9560-16i
Yes
# Display all information of a controller, and save the .txt file that records the information in the specified location.
[root@localhost home]# storcli64 /c0 show all logfile=/log/showall.txt
# Display the current SnapDump properties of the controller and the SnapDump data on the controller.
[root@localhost home]# storcli64 /c0 show snapdump
CLI Version = 007.2612.0000.0000 June 13, 2023
Operating system = Linux 5.14.0-70.22.1.el9_0.x86_64
Controller = 0
Status = Success
Description = None
SnapDump Properties :
Ctrl_Prop                     Value
Snapdump                      ON
Snapdump Save Count           N/A
Snapdump Delay OCR            15
Snapdump properties           Read-Write
Snapdump Preboot Trace Buffer ON
Snapdump Current Count        1
SnapDump Details :
ID Snapdump Size Snapdump time       OnDemand
 0       2492649 09-15-2023 11:43:26 Yes
# Execute the command without specifying any ID to trigger the controller to generate new SnapDump data and download existing SnapDump data from the controller.
[root@localhost home]# storcli64 /c0 get snapdump
Controller = 0
Status = Success
Description = Download Support Log
Snapdump :
Ctrl Status  Ctrl_Prop    ErrCd ErrMsg
   0 Success Get Snapdump     0 -
# Download all existing SnapDump data from the controller. The system names the file in the snapdump_c#(controller_id)_id#(snapdump_id)_yy_mm_dd_hh_mm_ss.zip format.
[root@localhost home]# /opt/MegaRAID/storcli/storcli64 /c0 get snapdump id=all
Operating system = Linux 3.10.0-1160.el7.x86_64
Controller = 0
Status = Success
Description = None
Snapdump :
# Specify the SnapDump ID and export SnapDump data to the specified file. If the file already exists, it will be truncated and new information will be added.
[root@localhost home]# storcli64 /c0 get snapdump id=0 file=snapdump.zip
Controller = 0
Status = Success
Description = None
Snapdump :
# Output the alilog logs to a .txt file and save the file in the specified location.
[root@localhost home]# ./storcli64 /c0 show alilog logfile=/log/alilog.txt
# Output the events logs to a .txt file and save the file in the specified location.
[root@localhost home]# storcli64 /c0 show events logfile=/log/events.txt
# Output the termlog logs to a .txt file and save the file in the specified location.
[root@localhost home]# storcli64 /c0 show termlog logfile=/log/termlog.txt
Managing logs
Perform this task to filter or clear storage controller logs.
storcli64 /ccontroller_id show termlog
storcli64 /ccontroller_id show events
storcli64 /ccontroller_id show snapdump
storcli64 /ccontroller_id delete termlog
storcli64 /ccontroller_id delete events
storcli64 /ccontroller_id delete snapdump force
storcli64 /ccontroller_id set snapdump state=on|off
controller_id: Specifies the ID of a storage controller. If only one storage controller exists, the ID is 0 by default. If multiple storage controllers exist, use the storcli64 command to view the controller ID.
# Display TTY logs.
[root@localhost home]# ./storcli64 /c0 show termlog
Firmware Term Log Information on controller 0:
03/13/22  9:12:37: C0:TTY History buffer cleared
Controller = 0
Status = Success
Description = None
# Display event logs.
[root@localhost home]# ./storcli64 /c0 show events
seqNum: 0x00079e17
Time: Sun Mar 13 09:13:18 2022
Code: 0x0000001e
Class: 0
Locale: 0x20
Event Description: Event log cleared
Event Data:
None
Controller = 0
Status = Success
Description = None
Events = GETEVENTS
Ctrl Status  Method          Value
   0 Success handleSuboption Events
[root@localhost 0920]# storcli64 /c0 show snapdump
Controller = 0
Status = Success
Description = None
Ctrl_Prop                     Value
Snapdump                      ON
Snapdump Current Count        2
SnapDump Details :
 0       1643485 09-19-2023 07:03:58 Yes
 1       2499469 09-20-2023 06:48:47 Yes
# Clear all records in the TTY logs.
[root@localhost home]# ./storcli64 /c0 delete termlog
Controller = 0
Status = Success
Description = None
Ctrl Method Result
   0 Delete Termlog deleted
# Clear all records in the event logs.
[root@localhost home]# ./storcli64 /c0 delete events
Controller = 0
Status = Success
Description = None
   0 Success DeleteEvents Events
# Clear all SnapDump data.
[root@localhost 0920]# storcli64 /c0 delete snapdump force
Controller = 0
Status = Success
Description = Snapdump delete
# Disable the SnapDump function.
[root@localhost ~]# storcli64 /c0 set snapdump state=off
Controller = 0
Status = Success
Description = None
Ctrl_Prop    Value
Set Snapdump off
# Enable the SnapDump function.
[root@localhost ~]# storcli64 /c0 set snapdump state=on
Controller = 0
Status = Success
Description = None
Ctrl_Prop    Value
Set Snapdump on
Configuring RAID cache settings
Perform this task to configure RAID cache settings.
storcli64 /ccontroller_id/vraid_id set wrcache={wt|wb|awb}
storcli64 /ccontroller_id/vraid_id set rdcache={ra|nora}
raid_id: Specifies the target RAID ID.
{wt|wb|awb}: Specifies the write cache policy. Write through (wt) notifies the system of transmission completion when data are written into disks. Write back (wb) notifies the system of transmission completion when data are written into the controller cache. Always write back (awb) forces the system to use write back when no supercapacitor is present, which may cause data loss in the event of unexpected power-off.
{ra|nora}: Specifies the read cache policy. When reading data from RAID, the ra policy enables the system to read the surrounding data and store them in the cache at the same time. When the user accesses these data subsequently, they can can be directly read from the cache, which reduces the disk seeking time and improves read performance.
[root@localhost home]# ./storcli64 /c0/v0 set wrcache=awb
Controller = 0
Status = Success
Description = None
Detailed Status :
VD Property Value Status  ErrCd ErrMsg
 0 wrCache  AWB   Success     0 -
[root@localhost home]# ./storcli64 /c0/v0 set rdcache=nora
Controller = 0
Status = Success
Description = None
Detailed Status :
 0 rdCache  NoRA  Success     0 -
Setting the RAID access policy
Perform this task to configure the read and write permissions for RAID.
storcli64 /ccontroller_id/vraid_id set accesspolicy={rw|ro|blocked}
{rw|ro|blocked}: Specifies the access policy. rw represents read and write, ro represents read-only, and blocked represents no access.
# Set the RAID access policy to read-only.
[root@localhost home]# ./storcli64 /c0/v0 set accesspolicy=rw
Controller = 0
Status = Success
Description = None
Detailed Status :
 0 AccPolicy RW    Success     0 -
Setting the read/write cache state for member drives
Perform this task to set the read and write cache state for member drives.
storcli64 /ccontroller_id/vraid_id set pdcache= pdcache_policy
pdcache_policy: Specifies the cache policy. Options include on, off, and default. Setting this field to default represents retaining the current cache state.
# Disable the read/write cache.
[root@localhost home]# ./storcli64 /c0/v0 set pdcache=off
Controller = 0
Status = Success
Description = None
Detailed Status :
 0 PdCac    Off   Success     0 -
Viewing the cache state of member drives
Perform this task to view the cache state of member drives.
storcli64 /ccontroller_id /eenclosure_id/sslot_id show all
·     If you use this command to view the cache state of member drives for the LSI-9361 storage controller, the command output displays Write Cache = N/A.
# View the cache state of member drives.
[root@localhost ~]# storcli64 /c1 /e252/s10 show all
CLI Version = 007.1705.0000.0000 Mar 31, 2021
Controller = 1
Status = Success
Drive /c1/e252/s10 :
252:10   20 Onln   0 893.750 GB SATA SSD N   N  512B INTEL SSDSC2KB960G8 U  -
Drive /c1/e252/s10 - Detailed Information :
Drive /c1/e252/s10 State :
Shield Counter = 0
Media Error Count = 0
Other Error Count = 0
Drive Temperature =  36C (96.80 F)
Predictive Failure Count = 0
S.M.A.R.T alert flagged by drive = No
Drive /c1/e252/s10 Device attributes :
SN = PHYF832001H8960CGN
Manufacturer Id = ATA
Model Number = INTEL SSDSC2KB960G8
NAND Vendor = NA
WWN = 55CD2E414FA85A2E
Firmware Revision = XCV10120
Raw size = 894.252 GB [0x6fc81ab0 Sectors]
Coerced size = 893.750 GB [0x6fb80000 Sectors]
Non Coerced size = 893.752 GB [0x6fb81ab0 Sectors]
Device Speed = 6.0Gb/s
Link Speed = 6.0Gb/s
NCQ setting = Enabled
Write Cache = Enabled
Logical Sector Size = 512B
Physical Sector Size = 4 KB
Connector Name = C1.0 x1
Drive /c1/e252/s10 Policies/Settings :
Drive position = DriveGroup:0, Span:0, Row:0
Enclosure position = 1
Connected Port Number = 11(path0)
Sequence Number = 10
Commissioned Spare = No
Emergency Spare = No
Last Predictive Failure Event Sequence Number = 0
Successful diagnostics completion on = N/A
FDE Type = None
SED Capable = No
SED Enabled = No
Secured = No
Cryptographic Erase Capable = Yes
Sanitize Support = CryptoErase, OverWrite, BlockErase
Locked = No
Needs EKM Attention = No
PI Eligible = No
Certified = No
Wide Port Capable = No
Unmap capable = Yes
Unmap capable for LDs = No
Multipath = No
Port Information :
Port Status Linkspeed SAS address
   0 Active 6.0Gb/s   0x300062b20c75204a
Inquiry Data =
40 00 ff 3f 37 c8 10 00 00 00 00 00 3f 00 00 00
00 00 00 00 48 50 46 59 33 38 30 32 31 30 38 48
36 39 43 30 4e 47 20 20 00 00 00 00 00 00 43 58
31 56 31 30 30 32 4e 49 45 54 20 4c 53 53 53 44
32 43 42 4b 36 39 47 30 20 38 20 20 20 20 20 20
20 20 20 20 20 20 20 20 20 20 20 20 20 20 01 80
00 40 00 2f 00 40 00 00 00 00 06 00 ff 3f 10 00
3f 00 10 fc fb 00 01 fd ff ff ff 0f 00 00 07 00
Erasing data on a physical drive
Perform this task to start or stop erasing data on a physical drive or view the erasure process.
storcli64 /ccontroller_id/eenclosure_id/sslot_id start erase mode
storcli64 /ccontroller_id/eenclosure_id/sslot_id show erase
storcli64 /ccontroller_id/eenclosure_id/sslot_id stop erase
mode: Specify the action to take. Options include simple, normal, and thorough, which represents one-time, three-time, and nine-time erasure operations, respectively.
# Perform one-time erasure for data on a physical drive.
[root@localhost home]# ./storcli64 /c0/e2/s11 start erase simple
Controller = 0
Status = Success
Description = Start Drive Erase Succeeded.
# View the erasure process.
[root@localhost home]# ./storcli64 /c0/e2/s11 show erase
Controller = 0
Status = Success
Description = Show Drive Erse Status Succeeded.
Drive-ID Progress% Status Estimated Time Left
/c0/e2/s11 0 In progress 0 Seconds
# Stop erasing the physical drive.
[root@localhost home]# ./storcli64 /c0/e2/s11 stop erase
Controller = 0
Status = Success
Description = Stop Drive Erase Succeeded.
Viewing supercapacitor information
Perform this task to view supercapacitor information.
storcli64 /ccontroller_id/cv show all
[root@localhost ~]# storcli64 /c0/cv show all
Controller = 0
Status = Success
Description = None
Cachevault_Info :
Property    Value
Type        CVPM05
Temperature 25 C
State       Optimal
Firmware_Status :
Property                         Value
NVCache State                    OK
Replacement required             No
No space to cache offload        No
Module microcode update required No
GasGaugeStatus :
Property                Value
Pack Energy             319 J
Capacitance             100 %
Remaining Reserve Space 0
Design_Info :
Property                 Value
Date of Manufacture      18/09/2019
Serial Number            21428
Manufacture Name         LSI
Design Capacity          374 J
Device Name              CVPM05
tmmFru                   N/A
CacheVault Flash Size    8.187 GB
scapBatversionNo         0x00
scapSerialNo             0x53b4
scap Date of Manufacture 18/09/2019
scapPcbAssmNo            50046-01
scapPCBversionNo          B
scapBatPackAssmNo        49571-222
Module Version           07251-01
Properties :
Property                   Value
Auto Learn Period          27d (2412000 seconds)
Next Learn time            2022/07/18  21:59:20 (711496760 seconds)
Learn Delay Interval       0 hour(s)
Auto-Learn Mode            Transparent
Last Successful Learn Time Completed, MON, June 20, 2022 at 23:59:20
Manually making a physical drive come online or go offline
Perform this task to manually make a physical drive come online or go offline.
storcli64 /ccontroller_id/eenclosure_id/sslot_id set mode
mode: Specifies the action to take. Options include offline and online.
# Manually make a physical drive go offline.
[root@localhost home]# ./storcli64 /c0/e2/s23 set offline
Controller = 0
Status = Success
Description = Set Drive Offline Succeeded.
# Manually make a physical drive come online.
[root@localhost home]# ./storcli64 /c0/e2/s23 set online
Controller = 0
Status = Success
Description = Set Drive Online Succeeded.
Configuring Patrol Read parameters
Perform this task to view and configure Patrol Read parameters.
storcli64 /ccontroller_id set patrolread starttime=start_time maxconcurrentpd=number
storcli64 /ccontroller_id set patrolread delay=delay_time
storcli64 /ccontroller_id show patrolread
start_time: Specifies the start time.
number: Specifies the number of drives to be checked concurrently.
delay_time: Specifies the check cycle.
·     Patrol read takes effect only on member drives of RAID arrays.
·     The start time must be a sharp hour.
# Configure Patrol Read parameters.
[root@localhost home]# ./storcli64 /c0 set pr starttime=2022/03/19 15 maxconcurrentpd=32
Controller = 0
Status = Success
Description = None
Ctrl_Prop          Value
PR Starttime       2022/03/19 15:00:00
PR MaxConcurrentPd 32
# View Patrol Read parameters.
[root@localhost home]# ./storcli64 /c0 show pr
Controller = 0
Status = Success
Description = None
Ctrl_Prop               Value
PR Mode                 Auto
PR Execution Delay      168 hours
PR iterations completed 1
PR Next Start time      03/19/2022, 15:00:00
PR on SSD               Disabled
PR Current State        Stopped
PR Excluded VDs         None
Configuring consistency check parameters
Perform this task to view and configure consistency check parameters.
storcli64 /ccontroller_id[/vraid_id] show cc
storcli64 /ccontroller_id/vraid_id start cc force
storcli64 /ccontroller_id/vraid_id op cc
storcli64 /ccontroller_id set cc=conc delay=delay_time starttime=start_time
op: Specifies the action to take. Options include pause, resume, and stop.
delay_time: Specifies the consistency check cycle.
If you do not specify the /vraid_id option when executing the storcli64 show cc command, the command displays the consistency check parameters. If you specify the /vraid_id option, the command displays the specific check progress.
# View the consistency check parameters.
[root@localhost home]# ./storcli64 /c0 show cc
Controller = 0
Status = Success
Description = None
Ctrl_Prop                 Value
CC Operation Mode         Concurrent
CC Execution Delay        2
CC Next Starttime         03/19/2022, 15:00:00
CC Current State          Stopped
CC Number of iterations   1
CC Number of VD completed 0
CC Excluded VDs           None
# View the consistency check progress.
[root@localhost home]# ./storcli64 /c0/v0 show cc
Controller = 0
Status = Success
Description = None
VD Operation Status :
VD Operation Progress% Status          Estimated Time Left
 0 CC        -         Not in progress -
# Enable consistency check.
[root@localhost home]# ./storcli64 /c0/v0 start cc force
Controller = 0
Status = Success
Description = Start CC Operation Success
# Stop consistency check.
[root@localhost home]# ./storcli64 /c0/v0 stop cc
Controller = 0
Status = Success
Description = Stop CC Operation Success
# Configure consistency check parameters.
[root@localhost home]# ./storcli64 /c0 set cc=conc delay=2 starttime=2022/03/19 15
Controller = 0
Status = Success
Description = None
Ctrl_Prop    Value
CC Mode      CONC
CC delay     2
CC Starttime 2022/03/19 15:00:00
Performing RAID rebuild or copyback
Perform this task to start or stop a RAID rebuild or copyback task or view the task status.
storcli64 /ccontroller_id/eenclosure_id/sslot_id op func
op: Specifies the action to take. Options include show, pause, resume, and stop.
func: Specifies a function, such as copyback and rebuild.
# View the copyback progress.
[root@localhost home]# ./storcli64 /c0/e2/s23 show copyback
Controller = 0
Status = Success
Description = Show Drive Copyback Status Succeeded.
/c0/e2/s23 -         Not in progress -
# View the rebuild progress.
[root@localhost home]# ./storcli64 /c0/e2/s23 show rebuild
Controller = 0
Status = Success
Description = Show Drive Rebuild Status Succeeded.
Managing task resources
Perform this task to set the Patrol Read rate, consistency check rate, bgi backstage initialization rate, rebuild rate, and reconstruction rate.
storcli64 /ccontroller_id set func=rate_value
The rate for each task is 30%.
func: Specifies the function. Options include prrate, ccrate, bgirate, rebuildrate, and reconrate.
rate_value: Specifies the rate value, in the range of 0 to 100.
# Set the reconstruction rate.
[root@localhost home]# ./storcli64 /c0 set reconrate=40
Controller = 0
Status = Success
Description = None
Ctrl_Prop Value
ReconRate 40%
Filtering and clearing PreservedCache data
Perform this task to filter and clear PreservedCache data.
storcli64 /ccontroller_id show preservedcache
storcli64 /ccontroller_id/vraid_id delete preservedcache force
# Filter PreservedCache data.
[root@localhost home]# ./storcli64 /c0 show preservedcache
Controller = 0
Status = Success
Description = No Virtual Drive has Preserved Cache Data.
# Clear PreservedCache data.
[root@localhost home]# ./storcli64 /c0/v0 delete preservedcache force
Controller = 0
Status = Success
Upgrading the drive firmware
Perform this task to upgrade the drive firmware.
storcli64 /ccontroller_id/eenclosure_id/sslot_id download src=fw_file
fw_file: Specifies the firmware file.
# Upgrade the drive firmware.
[root@localhost home]# ./storcli64 /c0/e2/s8 download src=fw.bin
Starting microcode update  .....please wait...
Flashing PD image  ..... please wait...
Controller = 0
Status = Success
Description = Firmware Download succeeded.
Drive Firmware Download :
Drive     Status  ErrCd    ErrMsg
/c0/e2/s8 Success   0
Perform this task to set alarm control.
storcli64 /ccontroller_id show alarm
storcli64 /ccontroller_id set alarm={on|off|silence}
on: Enable alarm control. With this feature enabled, the buzzer sounds an alarm when a critical error occurs.
off: Disable alarm control. With this feature disabled, the buzzer is silenced for any activity and will not sound an alarm for any error, including critical errors.
silence: Silence the buzzer. Any ongoing alarms will be stopped. If a critical error still exists and alarm control is enabled, it will be activated again after a restart. If alarm control is disabled, this option will also be disabled.
# View alarm control status.
[root@localhost storcli]# ./storcli64 /c0 show alarm
Operating system = Linux 4.18.0-425.3.1.el8.x86_64
Controller = 0
Status = Success
Description = None
Ctrl_Prop Value
Alarm     OFF
# Disable alarm control.
[root@localhost storcli]# ./storcli64 /c0 set alarm=off
Controller = 0
Status = Success
Description = None
Ctrl_Prop Value
Alarm     OFF
# Enable alarm control.
[root@localhost storcli]# ./storcli64 /c0 set alarm=on
Controller = 0
Status = Success
Description = None
Ctrl_Prop Value
Alarm     ON
# Silence the buzzer.
[root@localhost storcli]# ./storcli64 /c0 set alarm=silence
Controller = 0
Status = Success
Description = None
Ctrl_Prop Value
Alarm     SILENCE
Set Firmware Device order
Perform this task to view Firmware Device order status or enable or disable Firmware Device order.
storcli64 /ccontroller_id show deviceorderbyfirmware
storcli64 /ccontroller_id set deviceorderbyfirmware=mode
mode: Specifies the state of Firmware Device order.Options include:
·     on: Enable Firmware Device order.
·     off: Disable Firmware Device order.
Only the 9460/9440/9540/9560 controllers support this command.
Enabling this feature is only applicable to Linux. For other operating systems such as Windows or VMware, this feature is not supported. If you enable it accidentally in an unsupported system, system hang may occur during the boot process.
With this feature enabled, the reporting order of devices on the storage card during server reboot will change. The devices will be reported in the order of the boot disk, logical disk, and pass-through disk. However, note that all storage controllers will introduce random reporting order for logical disks. In the case of JBOD mode of 9460 controller and all modes of 9560 controller, there may be random reporting order for pass-through disk devices.
This configuration takes effect after you restart the server.
This feature is supported in LSI 9440/9460 51.15.0-3630 and higher versions.
This feature is supported in LSI 9560 52.15.0-3720 and higher versions.
This feature is supported in LSI 9540 52.20.0-4341 and higher versions.
# View the Firmware Device order state of a storage controller.
[root@localhost ~]# storcli64 /c0 show deviceorderbyfirmware
CLI Version = 007.2203.0000.0000 May 11, 2022
Operating system = Linux 4.18.0-240.el8.x86_64
Controller = 0
Status = Success
Description = None
Ctrl_Prop                      Value
Firmware based device ordering OFF
# Enable Firmware Device order for a storage controller.
[root@localhost ~]# storcli64 /c0 set deviceorderbyfirmware=on
Controller = 0
Status = Success
Description = Please reboot the system for the changes to take effect
Ctrl_Prop                      Value
Firmware based device ordering ON
# Disable Firmware Device order for a storage controller.
[root@localhost ~]# storcli64 /c0 set deviceorderbyfirmware=off
Controller = 0
Status = Success
Ctrl_Prop                      Value
Setting direct pd mapping
Perform this task to view the state of direct pd mapping or enable or disable direct pd mapping for an LSI storage controller.
storcli64 /ccontroller_id show directpdmapping
storcli64 /ccontroller_id set directpdmapping=mode
mode: Specifies the state of direct pd mapping.Options include:
·     on: Enable direct pd mapping.
·     off: Disable direct pd mapping.
This feature cannot be enabled when the storage controller is connected to the Expander backplane. Enabling it accidentally may cause the storage controller to enter Failed state.
With this feature enabled, during the server reboot phase, the pass-through disk devices under the storage controller will be reported based on their slot numbers.
# View the state of direct pd mapping for a storage controller.
[root@localhost ~]# storcli64 /c0 show directpdmapping
Controller = 0
Status = Success
Description = None
Ctrl_Prop       Value
Directpdmapping OFF
# Enable direct pd mapping for a storage controller.
[root@localhost ~]# storcli64 /c0 set directpdmapping=on
Controller = 0
Status = Success
Description = None
Ctrl_Prop       Value
Directpdmapping ON (Requires reboot for effect)
# Disable direct pd mapping for a storage controller.
[root@localhost ~]# storcli64 /c0 set directpdmapping=off
Controller = 0
Status = Success
Description = None
Ctrl_Prop       Value
Directpdmapping OFF (Requires reboot for effect)
Checking the PSoC information
Perform this task to view the PSoC firmware of a storage controller.
storcli64 /ccontroller_id/ show all | grep -i psoc
For the LSI 9560 controller, you can view the PSoC information or update the PSoC firmware only when either of the following conditions is met:
·     The controller firmware version is 52.20.0-4341 or later and the StorCLI version is 7.2007.0000.0000 or later.
·     The controller firmware version is 52.22.0-4544 or later and the StorCLI version is 7.2307.0000.0000 or later.
# Display PSoC information, including the PSoC FW Version, PSoC Part Number, and PSoC support status.
[root@localhost ~]# storcli64 /c0 show all | grep -i psoc
PSOC FW Version = 0x001B
PSOC Hardware Version = 0x0003
PSOC Part Number = 15987-270-4GB
Support PSOC Update = Yes
Support PSOC Part Information = Yes
Upgradable PSOC = Present
Updating the PSoC firmware
Perform this task to update the PSoC firmware of a storage controller.
fw_file: Specifies the PSoC firmware file.
When you use this command, follow these restrictions and guidelines:
·     If the PSoC firmware file of the storage controller is not in the current path, you must add the absolute path of the file in front of the file name.
·     Commands used to specify paths in the StorCLI tool do not support spaces and special characters.
·     After updating the PSoC firmware, you must perform an AC power cycle of the server for the update to take effect.
·     For the LSI 9560 controller, you can view the PSoC information or update the PSoC firmware only when either of the following conditions is met:
¡     The controller firmware version is 52.20.0-4341 or later and the StorCLI version is 7.2007.0000.0000 or later.
¡     The controller firmware version is 52.22.0-4544 or later and the StorCLI version is 7.2307.0000.0000 or later.
# Upgrade the PSoC firmware of a storage controller.
[root@localhost ~]# storcli64 /c0 download file=pblp_catalog.signed.rom
Download Completed.
Controller = 0
Status = Success
Description = F/W Flash Completed. Please shutdown the system for the changes to take effect
# Downgrade or update the PSoC firmware of a storage controller.
[root@localhost ~]# storcli64 /c0 download file=pblp_catalog.signed.rom noverchk
Download Completed.
Controller = 0
Status = Success
Configuring emergency hot spare drives
Perform this task to configure the emergency hot spare feature. With this feature configured, if a drive in any redundant RAID array fails and no specific hot spare drive is assigned, an idle drive of the same type managed by the same storage controller replaces the drive in fail or prefail state. Then, the drive starts data rebuilding to avoid data loss.
storcli64 /ccontroller_id set eghs eug={on|off}
storcli64 /ccontroller_id set eghs smarter={on|off}
storcli64 /ccontroller_id set eghs state={on|off}
eug: Specifies drives in Unconfigured Good state as emergency hot spare drives.
smarter: Specifies drives in SMART Error state as emergency hot spare drives.
state: Specifies drives in Unconfigured Good and hot spare state as emergency hot spare drives.
If multiple storage controllers exist, use the storcli64 /call show command to obtain the controller ID.
The hot spare drive must use the same interface protocol as the member drives of the RAID array, and has a capacity equal to or larger than any member drives.
# Configure drives in Unconfigured Good state as emergency hot spare drives.
[root@localhost ~]# storcli /c0 set eghs eug=on
CLI Version = 007.2807.0000.0000 Dec 22, 2023
Controller = 0
Status = Success
Description = None
Ctrl_Prop   Value
EmergencyUG ON
# Configure drives in SMART Error state as emergency hot spare drives.
[root@localhost ~]# storcli /c0 set eghs smarter=on
Controller = 0
Status = Success
Description = None
Ctrl_Prop        Value
EmergencySmarter ON
# Configure drives in Unconfigured Good and hot spare state as emergency hot spare drives.
[root@localhost ~]# storcli /c0 set eghs state=on
Controller = 0
Status = Success
Description = None
Ctrl_Prop    Value
EmergencyGHS ON
Support for fault alarming
Fault alarming includes alarming for faults that have occurred and predictive faults. Support for fault alarming depends on the storage controller model and connection mode. For more information, see Table 6 and Table 7.
Table 6 Support for fault alarming
Storage controller series
RAID-mode directly-connected drives
RAID-mode connected drive expander modules
JBOD-mode directly-connected drives
JBOD-mode connected drive expander modules
LSI-9361
Yes
Yes
Yes
Yes
LSI-9440
Yes
Yes
N/A
N/A
LSI-9460
Yes
Yes
Yes
Yes
LSI-9540
Yes
Yes
N/A
N/A
LSI-9560
Yes
Yes
Yes
Yes
Table 7 Support for Predictive Failure Analysis (PFA)
LSI-9361
Support identifying the FPA state only for Unconfigured Good drives, members of logical drives, and hot spare drives (LED not flashing amber at 0.5 Hz)
Support identifying the FPA state only for Unconfigured Good drives, members of logical drives, and hot spare drives (LED flashing amber at 0.5 Hz)
No
No
LSI-9440
N/A
N/A
LSI-9460
Support identifying the FPA state for all drives (LED not flashing amber at 0.5)
Support identifying the FPA state for all drives (LED flashing amber at 0.5 Hz only supported on UG, logical drives, and hot spare drives)
LSI-9540
N/A
N/A
LSI-9560
Support identifying the FPA state for all drives (LED not flashing amber at 0.5 Hz)
Support identifying the FPA state for all drives (LED flashing amber at 0.5 Hz)
Troubleshooting
For detailed information about collecting storage controller fault information, diagnosing and locating faults, and troubleshooting servers, see H3C Servers Troubleshooting Guide.
Compatibility
For information about storage controller and server compatibility, access http://www.h3c.com/en/home/qr/default.htm?id=66.
Downloading and installing drivers
Access the H3C official website to download the storage controller drivers. For more information about installing drivers, see the release notes for the driver program.
